[mapguide-commits] r7373 - in trunk/MgDev/Server/src: Services/Feature UnitTesting
svn_mapguide at osgeo.org
Wed Feb 20 02:25:04 PST 2013
Author: jng
Date: 2013-02-20 02:25:03 -0800 (Wed, 20 Feb 2013)
New Revision: 7373
trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp
trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp
trunk/MgDev/Server/src/UnitTesting/TestFeatureService.h
#2218: Merge in r7370, r7371 and r7372
Modified: trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp
--- trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp 2013-02-20 02:13:05 UTC (rev 7372)
+++ trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp 2013-02-20 10:25:03 UTC (rev 7373)
@@ -91,9 +91,6 @@
// Execute the operation
Ptr<MgPropertyCollection> rowsAffected = m_service->UpdateFeatures(resource, commands, useTransaction);
- // Write the response
- EndExecution(rowsAffected);
// #649: Exceptions are only thrown in transactional cases (which will never reach here). For non-transactional cases,
// we check for any MgStringProperty instances. These are "serialized" FDO exception messages indicating failure for that
// particular command. We can't throw for non-transactional cases, instead we put the onus on the consuming caller to do
@@ -109,6 +106,13 @@
break;
+ if (mgException == NULL && partialFailureMsg.empty())
+ // Only Write the response if there no Fdo Exception
+ // if there is an exception, Response will be written by MgFeatureServiceHandler::ProcessOperation catching it
+ EndExecution(rowsAffected);
else
@@ -148,4 +152,5 @@
MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY();
MG_FEATURE_SERVICE_THROW()
Modified: trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp 2013-02-20 02:13:05 UTC (rev 7372)
+++ trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp 2013-02-20 10:25:03 UTC (rev 7373)
@@ -270,6 +270,9 @@
Ptr<MgResourceIdentifier> fsres9 = new MgResourceIdentifier(L"Library://UnitTests/Data/GetIdentityPropertiesTest.FeatureSource");
if (pService->ResourceExists(fsres9)) pService->DeleteResource(fsres9);
+ Ptr<MgResourceIdentifier> fsres10 = new MgResourceIdentifier(L"Library://UnitTests/Data/TestInsert.FeatureSource");
+ if (pService->ResourceExists(fsres10)) pService->DeleteResource(fsres10);
#ifdef _DEBUG
ACE_DEBUG((LM_INFO, ACE_TEXT("TestFeatureService::TestEnd()\n")));
MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
@@ -2366,7 +2369,7 @@
void TestFeatureService::TestCase_SavePoint()
- try
+ try
MgServiceManager* serviceManager = MgServiceManager::GetInstance();
if(serviceManager == 0)
@@ -2465,6 +2468,145 @@
/// Test Case Description:
+/// This test case exercises the UpdateFeatures API for insertion
+void TestFeatureService::TestCase_UpdateFeaturesInsert()
+ try
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ if(serviceManager == 0)
+ throw new MgNullReferenceException(L"TestFeatureService.TestCase_SavePoint", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgFeatureService> pService = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
+ if (pService == 0)
+ throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_SavePoint", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgResourceIdentifier> featureSource = new MgResourceIdentifier(L"Library://UnitTests/Data/TestInsert.FeatureSource");
+ //Create our test data store (SQLite)
+ STRING scName = L"Default";
+ STRING srsWkt = L"LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
+ //Setup schema
+ Ptr<MgFeatureSchema> schema = new MgFeatureSchema(L"Default", L"Test schema for TestCase_2218");
+ Ptr<MgClassDefinition> klass = new MgClassDefinition();
+ klass->SetName(L"TestClass");
+ Ptr<MgPropertyDefinitionCollection> clsProps = klass->GetProperties();
+ Ptr<MgPropertyDefinitionCollection> idProps = klass->GetIdentityProperties();
+ //ID
+ Ptr<MgDataPropertyDefinition> idProperty = new MgDataPropertyDefinition(L"ID");
+ idProperty->SetDataType(MgPropertyType::Int32);
+ idProperty->SetAutoGeneration(false);
+ idProperty->SetNullable(false);
+ clsProps->Add(idProperty);
+ idProps->Add(idProperty);
+ //Name
+ Ptr<MgDataPropertyDefinition> nameProperty = new MgDataPropertyDefinition(L"Name");
+ nameProperty->SetDataType(MgPropertyType::String);
+ nameProperty->SetLength(255);
+ nameProperty->SetNullable(true);
+ clsProps->Add(nameProperty);
+ //Geom
+ Ptr<MgGeometricPropertyDefinition> geomProperty = new MgGeometricPropertyDefinition(L"Geom");
+ geomProperty->SetSpatialContextAssociation(scName);
+ clsProps->Add(geomProperty);
+ klass->SetDefaultGeometryPropertyName(L"Geom");
+ Ptr<MgClassDefinitionCollection> classes = schema->GetClasses();
+ classes->Add(klass);
+ //Create the feature source
+ Ptr<MgFileFeatureSourceParams> fileParams = new MgFileFeatureSourceParams(L"OSGeo.SQLite", scName, srsWkt, schema);
+ pService->CreateFeatureSource(featureSource, fileParams);
+ //Set up insert command
+ Ptr<MgFeatureCommandCollection> commands = new MgFeatureCommandCollection();
+ Ptr<MgPropertyCollection> propVals = new MgPropertyCollection();
+ Ptr<MgInt32Property> idVal = new MgInt32Property(L"ID", 1);
+ Ptr<MgStringProperty> nameVal = new MgStringProperty(L"Name", L"Foo");
+ Ptr<MgWktReaderWriter> wktRw = new MgWktReaderWriter();
+ Ptr<MgAgfReaderWriter> agfRw = new MgAgfReaderWriter();
+ Ptr<MgGeometry> geom = wktRw->Read(L"POINT (1 2)");
+ Ptr<MgByteReader> agf = agfRw->Write(geom);
+ Ptr<MgGeometryProperty> geomVal = new MgGeometryProperty(L"Geom", agf);
+ propVals->Add(idVal);
+ propVals->Add(nameVal);
+ propVals->Add(geomVal);
+ Ptr<MgInsertFeatures> insert = new MgInsertFeatures(L"Default:TestClass", propVals);
+ commands->Add(insert);
+ //Execute insert. Should be fine
+ Ptr<MgPropertyCollection> result = pService->UpdateFeatures(featureSource, commands, true);
+ CPPUNIT_ASSERT(result->GetCount() == 1);
+ INT32 i = 0;
+ Ptr<MgProperty> resItem1 = result->GetItem(i);
+ CPPUNIT_ASSERT(resItem1->GetPropertyType() == MgPropertyType::Feature);
+ Ptr<MgFeatureReader> rdr = ((MgFeatureProperty*)resItem1.p)->GetValue();
+ rdr->Close();
+ //Change name, retain same id
+ nameVal->SetValue(L"Bar");
+ //Execute again, expect MgFdoException due to constraint violation
+ CPPUNIT_ASSERT_THROW_MG(result = pService->UpdateFeatures(featureSource, commands, true), MgFdoException*);
+ //Expect one inserted result
+ Ptr<MgFeatureQueryOptions> query = new MgFeatureQueryOptions();
+ Ptr<MgFeatureReader> qryReader = pService->SelectFeatures(featureSource, L"Default:TestClass", query);
+ INT32 count = 0;
+ while (qryReader->ReadNext()) { count++; }
+ qryReader->Close();
+ CPPUNIT_ASSERT(1 == count);
+ //Execute again, useTransaction = false. Should not throw exception, but log
+ //the error as a MgStringProperty
+ result = pService->UpdateFeatures(featureSource, commands, false);
+ resItem1 = result->GetItem(i);
+ CPPUNIT_ASSERT(resItem1->GetPropertyType() == MgPropertyType::String); //Errors are of type String
+ //Use new id
+ idVal->SetValue(2);
+ //Should be fine now
+ result = pService->UpdateFeatures(featureSource, commands, true);
+ rdr = ((MgFeatureProperty*)resItem1.p)->GetValue();
+ rdr->Close();
+ catch(MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch(FdoException* e)
+ FDO_SAFE_RELEASE(e);
+ CPPUNIT_FAIL("FdoException occurred");
+ catch(...)
+ throw;
+/// Test Case Description:
/// This test case exercises the FDO join optimization
void TestFeatureService::TestCase_JoinFdoFeatures()
Modified: trunk/MgDev/Server/src/UnitTesting/TestFeatureService.h
--- trunk/MgDev/Server/src/UnitTesting/TestFeatureService.h 2013-02-20 02:13:05 UTC (rev 7372)
+++ trunk/MgDev/Server/src/UnitTesting/TestFeatureService.h 2013-02-20 10:25:03 UTC (rev 7373)
@@ -39,9 +39,8 @@
CPPUNIT_TEST(TestCase_ApplySchema);
CPPUNIT_TEST(TestCase_SelectFeatures);
CPPUNIT_TEST(TestCase_SelectAggregate);
-// CPPUNIT_TEST(TestCase_UpdateFeatures);
+ CPPUNIT_TEST(TestCase_UpdateFeaturesInsert);
CPPUNIT_TEST(TestCase_UpdateFeaturesPartialFailure);
-// TODO write test case when know how to make command collection
CPPUNIT_TEST(TestCase_ExecuteSqlQuery);
CPPUNIT_TEST(TestCase_ExecuteSqlNonQuery);
CPPUNIT_TEST(TestCase_GetSpatialContexts);
@@ -62,7 +61,6 @@
CPPUNIT_TEST(TestCase_SavePoint);
CPPUNIT_TEST(TestCase_JoinFdoFeatures);
CPPUNIT_TEST(TestCase_BenchmarkSqliteJoin);
CPPUNIT_TEST(TestCase_BenchmarkSqliteAggregateJoin);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
@@ -89,7 +87,7 @@
void TestCase_ApplySchema();
void TestCase_SelectFeatures();
void TestCase_SelectAggregate();
-// void TestCase_UpdateFeatures();
+ void TestCase_UpdateFeaturesInsert();
void TestCase_UpdateFeaturesPartialFailure();
void TestCase_ExecuteSqlQuery();
void TestCase_ExecuteSqlNonQuery();
More information about the mapguide-commits
