[mapguide-commits] r7297 - in trunk/MgDev: . BuildTools BuildTools/WebTools/IMake BuildTools/WebTools/IMake/Win32 Common/Foundation/Data Common/MapGuideCommon/Services Common/PlatformBase/Services Oem/SQLite/src/SQLitePhpApi Oem/SWIGEx/Source/Modules Oem/SWIGEx/Win32 UnitTest/Common UnitTest/Common/JavaApiExTest UnitTest/Common/JavaApiExTest/.idea UnitTest/Common/JavaApiExTest/.idea/copyright UnitTest/Common/JavaApiExTest/.idea/inspectionProfiles UnitTest/Common/JavaApiExTest/.idea/scopes UnitTest/Common/JavaApiExTest/src Web/src Web/src/DotNetApi/Foundation Web/src/DotNetApi/Geometry Web/src/DotNetApi/MapGuideCommon Web/src/DotNetApi/PlatformBase Web/src/DotNetApi/Web Web/src/DotNetUnmanagedApi/Foundation Web/src/DotNetUnmanagedApi/Geometry Web/src/DotNetUnmanagedApi/MapGuideCommon Web/src/DotNetUnmanagedApi/PlatformBase Web/src/DotNetUnmanagedApi/Web Web/src/JavaApiEx Web/src/JavaApiEx/org Web/src/JavaApiEx/org/osgeo Web/src/JavaApiEx/org/osgeo/mapguide Web/src/MapGuideApi
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jan 11 19:36:04 PST 2013
Author: jng
Date: 2013-01-11 19:36:03 -0800 (Fri, 11 Jan 2013)
New Revision: 7297
Added:
   trunk/MgDev/UnitTest/Common/JavaApiExTest/
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/.name
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/ant.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/compiler.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/copyright/
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/copyright/profiles_settings.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/encodings.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/inspectionProfiles/
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/misc.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/modules.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/scopes/
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/scopes/scope_settings.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/uiDesigner.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/vcs.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/workspace.xml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/MapGuideApiExTest.iml
   trunk/MgDev/UnitTest/Common/JavaApiExTest/src/
   trunk/MgDev/UnitTest/Common/JavaApiExTest/src/AssertException.java
   trunk/MgDev/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java
   trunk/MgDev/Web/src/JavaApiEx/
   trunk/MgDev/Web/src/JavaApiEx/COPYRIGHT
   trunk/MgDev/Web/src/JavaApiEx/DIFFERENCES.txt
   trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.rc
   trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj
   trunk/MgDev/Web/src/JavaApiEx/Makefile.am
   trunk/MgDev/Web/src/JavaApiEx/catchall.code
   trunk/MgDev/Web/src/JavaApiEx/getclassid.code
   trunk/MgDev/Web/src/JavaApiEx/java.i
   trunk/MgDev/Web/src/JavaApiEx/javaextensions.i
   trunk/MgDev/Web/src/JavaApiEx/org/
   trunk/MgDev/Web/src/JavaApiEx/org/osgeo/
   trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/
   trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/AppThrowable.java
   trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgBase64.java
   trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgLocalizer.java
Removed:
   trunk/MgDev/BuildTools/DoxyTransform/
   trunk/MgDev/BuildTools/WebTools/IMake/IMake.cpp
   trunk/MgDev/BuildTools/WebTools/IMake/Win32/IMake.exe
   trunk/MgDev/BuildTools/WebTools/IMake/stdafx.h
   trunk/MgDev/Common/Foundation/Data/PropertyDefinition.h
   trunk/MgDev/Common/MapGuideCommon/Services/MappingService.h
   trunk/MgDev/Common/PlatformBase/Services/ClassDefinition.h
   trunk/MgDev/Common/PlatformBase/Services/FeatureSchema.h
   trunk/MgDev/Oem/SQLite/src/SQLitePhpApi/SQliteApiGen.xml
   trunk/MgDev/Oem/SWIGEx/Source/Modules/java.cxx
   trunk/MgDev/Oem/SWIGEx/Source/Modules/main.cxx
   trunk/MgDev/Oem/SWIGEx/Win32/Swig.exe
   trunk/MgDev/Web/src/DotNetApi/Foundation/FoundationMakefile
   trunk/MgDev/Web/src/DotNetApi/Geometry/GeometryMakefile
   trunk/MgDev/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonMakefile
   trunk/MgDev/Web/src/DotNetApi/PlatformBase/PlatformBaseMakefile
   trunk/MgDev/Web/src/DotNetApi/Web/WebMakefile
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml
   trunk/MgDev/Web/src/Makefile.am
   trunk/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml
   trunk/MgDev/Web/src/WebTier_VS2010.sln
   trunk/MgDev/build.bat
   trunk/MgDev/build64.bat
   trunk/MgDev/configure.in
Merge RFC 129 to trunk from our sandbox
Modified: trunk/MgDev/BuildTools/WebTools/IMake/IMake.cpp
--- trunk/MgDev/BuildTools/WebTools/IMake/IMake.cpp	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/BuildTools/WebTools/IMake/IMake.cpp	2013-01-12 03:36:03 UTC (rev 7297)
@@ -12,21 +12,24 @@
     java
-static char version[] = "1.1";
+static char version[] = "1.2";
 static string module;
 static string customPath;
 static string target;
+static string docTarget;
 static string cppInline;
 static string swigInline;
 static string typedefs;
 static string nameSpace;
 static string package;
+static set<string> classesWithDocs;
 static map<string, string> typeReplacements;
 static map<string, bool> classes;
 static vector<string> headers;
 static map<string, int> rootObjectMethods;
 static FILE* outfile;
+static FILE* docOutFile;
 static char charbuf[2];
 static bool translateMode;
 static Language language;
@@ -75,6 +78,15 @@
     return attr->value;
+string parseDocTarget(XNode* elt)
+    LPXAttr attr = elt->GetAttr("path");
+    if(attr == NULL)
+        error("DocTarget element does not have a 'path' attribute");
+    return attr->value;
 string parseCppInline(XNode* elt)
     string text = Trim(elt->GetText());
@@ -204,6 +216,12 @@
                 error("Target is not a valid section in translation mode");
             target = parseTarget(node);
+        else if(node->name == "DocTarget")
+            if(translateMode)
+                error("DocTarget is not a valid section in translation mode");
+            docTarget = parseDocTarget(node);
         else if(node->name == "CppInline")
             if(translateMode)
@@ -336,6 +354,7 @@
                         break;
                     case '/':
                         if(!translateMode)
                             if(i < (int)input.length() - 1 && input[i + 1] == '/')
@@ -343,7 +362,7 @@
                             else
                                 tokens.push_back("/");
-                        else
+                        else*/
                             if(input[i + 1] == '/')
@@ -512,6 +531,596 @@
     return itMethod != rootObjectMethods.end();
+bool isAllSlashes(const string& str)
+    for (int i = 0; i < str.length(); i++) {
+        if (str[i] != '/')
+            return false;
+    return str.length() > 3; //A "///" does not count
+string linkifyCSharpDocFragment(const string& str)
+    // Explode the fragment into a space delimited list.
+    // Go through the delimited tokens and surround any
+    // token containing "Mg" with {@link <token>}
+    // Re-combine each delimited token to form the linkified result
+    std::vector<std::string> elems;
+    std::stringstream ss(str);
+    std::string item;
+    while(std::getline(ss, item, ' ')) {
+        //We can't process these yet, so skip them as they may
+        //interfere with doxygen directive translation
+        if (item == "\\link" || item == "\\endlink")
+            continue;
+        elems.push_back(item);
+    std::string nspace = nameSpace;
+    if (nspace.empty()) //Faulty logic if this is the case
+        nspace = "OSGeo.MapGuide";
+    std::string output;
+    for (int i = 0; i < elems.size(); i++) {
+        if (i != 0) {
+            output.append(" ");
+        //If it contains "Mg", assume it's a MapGuide class name and link-ify it
+        //TODO: Resolve :: to member links. Right now it just linkifies the Mg class name
+        int idx = elems[i].find("Mg");
+        if (idx != std::string::npos) {
+            std::string prefix;
+            std::string mgClassName;
+            std::string suffix;
+            //Collect characters before Mg
+            if (idx > 0) {
+                prefix = elems[i].substr(0, idx);
+            int cont = -1;
+            //Collect the characters in the MapGuide class name
+            for (int j = idx; j < elems[i].length(); j++) {
+                if (!isalnum(elems[i][j])) {
+                    cont = j;
+                    break;
+                } else {
+                    mgClassName += elems[i][j];
+            //Collect any characters afterwards
+            for (int j = cont; j < elems[i].length(); j++) {
+                suffix += elems[i][j];
+            output.append(prefix);
+            output.append("<see cref=\"");
+            output.append(nspace);
+            output.append(".");
+            output.append(mgClassName);
+            output.append("\" />");
+            output.append(suffix);
+        } else {
+            output.append(elems[i]);
+    return output;
+string linkifyJavaDocFragment(const string& str)
+    std::string item;
+            continue;
+        if (i != 0) {
+            if (idx > 0) {
+            int cont = -1;
+                    cont = j;
+                    break;
+                } else {
+            output.append("{@link ");
+            output.append("}");
+        } else {
+    return output;
+string doxygenToJavaDoc(const string& commentStr)
+    // Doxygen documentation translation overview:
+    // What sorcery allows us to transplant doxygen documentation to our target language of choice?
+    // The answer lies in the swig directives %javamethodmodifiers and %typemap(javaclassmodifiers)
+    // (and its csharp equvialents %csmethodmodifiers and %typemap(csclassmodifiers))
+    // The official SWIG documentation says that these directives are used to modify the visibility modifier for
+    // <class declaration|class method name>. Although this directive is mainly used to modify
+    // class/method visibility, the content itself does not have to be public/protected/abstract/static/const/etc
+    // SWIG itself does not do any validation of the content in this directive.
+    // Given this directive
+    // %javamethodmodifiers MgMyClass::MyMethod() <content>
+    // SWIG generates this (Java):
+    // public class MgMyClass {
+    //    <content> MyMethod() {
+    // <content> should generally be public/protected/abstract/static/const/etc, but SWIG does not validate or enforce this
+    // Therefore we (ab)use these SWIG directives to prepend arbitrary content to the generated proxy class declaration/methods. In our
+    // case, the content being our doxygen commentary (collected by IMake) translated to the target-specific documentation format
+    // In fact, this technique is documented as a way of transplanting documentation:
+    //   http://www.swig.org/Doc1.3/Java.html#javadoc_comments
+    // Supported doxygen tags:
+    // \brief - Converted to main javadoc body
+    // \param - @param
+    // \return - @return
+    // \deprecated - Adds the @Deprecated annotation to the class/method declaration (after the converted javadoc)
+    // \since - @since
+    // \exception - @exception
+    //Re-tokenize the doxygen comments
+    std::stringstream ss(commentStr);
+    std::string item;
+    while(std::getline(ss, item, '\n')) {
+    int i = 0;
+    bool isDeprecated = false;
+    std::vector<std::string> descriptionParts;
+    std::vector<std::string> paramParts;
+    std::vector<std::string> returnParts;
+    std::string sinceVer;
+    std::vector<std::string> exceptionParts;
+    while(i < elems.size()) {
+        if (elems[i].find("<!-- Syntax in .Net, Java, and PHP -->") != std::string::npos ||
+            elems[i].find("<!-- Example (PHP) -->") != std::string::npos ||
+            elems[i].find("<!-- Example (Java) -->") != std::string::npos ||
+            elems[i].find("<!-- Example (C#) -->") != std::string::npos) {
+            i++;
+            continue;
+        if (elems[i].find("\\brief") != std::string::npos) {
+            i++;
+            //Keep going until we find the next doxygen directive or end of comments
+            while (i < elems.size() && elems[i].find("\\") == std::string::npos) {
+                    i++;
+                    continue;
+                std::string token = elems[i].substr(3);
+                if (!token.empty())
+                    descriptionParts.push_back(token);
+                i++;
+            continue;
+        else if (elems[i].find("\\param") != std::string::npos) {
+            std::string paramPart = elems[i].substr(elems[i].find("\\param") + 6);
+            paramPart.append(" ");
+            i++;
+                if (!token.empty()) {
+                    paramPart.append(token);
+                i++;
+            paramParts.push_back(paramPart);
+            continue;
+        else if (elems[i].find("\\return") != std::string::npos) {
+            i++;
+                    i++;
+                    continue;
+                    returnParts.push_back(token);
+                i++;
+            continue;
+        else if (elems[i].find("\\deprecated") != std::string::npos) {
+            i++;
+            isDeprecated = true;
+            continue;
+        else if (elems[i].find("\\since") != std::string::npos) {
+            sinceVer = elems[i].substr(elems[i].find("\\since") + 6);
+            i++;
+            continue;
+        else if (elems[i].find("\\exception") != std::string::npos) {
+            std::string except = elems[i].substr(elems[i].find("\\exception") + 10);
+            exceptionParts.push_back(except);
+            i++;
+            continue;
+        i++;
+    // ---------------------- JAVADOC START ------------------------ //
+    std::string javaDoc = "\n/**\n";
+    if (descriptionParts.size() > 0) {
+        for (int i = 0; i < descriptionParts.size(); i++) {
+            javaDoc.append(" *");
+            javaDoc.append(linkifyJavaDocFragment(descriptionParts[i]));
+            javaDoc.append("\n");
+        javaDoc.append(" *\n");
+    } else {
+        javaDoc.append(" * TODO: API Documentation is missing or failed to translate doxygen brief directive (message inserted by IMake.exe)\n");
+    if (paramParts.size() > 0) {
+        for (int i = 0; i < paramParts.size(); i++) {
+            javaDoc.append(" * @param ");
+            javaDoc.append(linkifyJavaDocFragment(paramParts[i]));
+    if (returnParts.size() > 0) {
+        javaDoc.append(" * @return ");
+        for (int i = 0; i < returnParts.size(); i++) {
+            javaDoc.append(linkifyJavaDocFragment(returnParts[i]));
+            if (i < returnParts.size() - 1)
+                javaDoc.append("\n * ");
+    if (exceptionParts.size() > 0) {
+        for (int i = 0; i < exceptionParts.size(); i++) {
+            javaDoc.append(" * @exception ");
+            javaDoc.append(exceptionParts[i]);
+    if (!sinceVer.empty()) {
+        javaDoc.append(" * @since ");
+        javaDoc.append(sinceVer);
+    // ---------------------- JAVADOC END ------------------------ //
+    javaDoc.append(" */\n");
+    if (isDeprecated)
+        javaDoc.append("@Deprecated\n");
+    return javaDoc;
+string doxygenToCsharpDoc(const string& commentStr)
+    //See doxygenToJavaDoc for how we do this sorcery
+    std::string item;
+    int i = 0;
+            i++;
+            continue;
+            i++;
+                    i++;
+                    continue;
+                i++;
+            continue;
+            i++;
+                i++;
+            continue;
+            i++;
+                    i++;
+                    continue;
+                i++;
+            continue;
+            i++;
+            continue;
+            i++;
+            continue;
+        i++;
+    // ---------------------- csharpDoc START ------------------------ //
+    std::string csharpDoc = "\n///<summary>\n";
+            csharpDoc.append("///");
+            csharpDoc.append(linkifyCSharpDocFragment(descriptionParts[i]));
+            csharpDoc.append("\n");
+        csharpDoc.append("///</summary>\n");
+    } else {
+        csharpDoc.append("///TODO: API Documentation is missing or failed to translate doxygen brief directive (message inserted by IMake.exe)\n///</summary>\n");
+            std::vector<std::string> pelems;
+            std::stringstream pss(linkifyCSharpDocFragment(paramParts[i]));
+            std::string pitem;
+            while(std::getline(pss, pitem, ' ')) {
+                if (!pitem.empty())
+                    pelems.push_back(pitem);
+            if (pelems.size() > 1) { //Should be
+                csharpDoc.append("///<param name=\"");
+                csharpDoc.append(pelems[0]);
+                csharpDoc.append("\">");
+                csharpDoc.append("\n///");
+                for (int i = 1; i < pelems.size(); i++) {
+                    csharpDoc.append(" ");
+                    csharpDoc.append(pelems[i]);
+                csharpDoc.append("\n///</param>\n");
+        csharpDoc.append("///<returns>");
+            csharpDoc.append(linkifyCSharpDocFragment(returnParts[i]));
+                csharpDoc.append("\n/// ");
+        csharpDoc.append("\n///</returns>\n");
+            std::vector<std::string> eelems;
+            std::stringstream ess(exceptionParts[i]);
+            std::string eitem;
+            while(std::getline(ess, eitem, ' ')) {
+                if (!eitem.empty())
+                    eelems.push_back(eitem);
+            csharpDoc.append("///<exception cref=\"");
+            csharpDoc.append(nspace);
+            csharpDoc.append(".");
+            if (eelems.size() > 1) {
+                csharpDoc.append(eelems[0]);
+                for (int j = 1; j < eelems.size(); j++) {
+                    csharpDoc.append(eelems[j]);
+                csharpDoc.append("</exception>\n");
+            } else {
+                csharpDoc.append("\"></exception>\n");
+    // ---------------------- csharpDoc END ------------------------ //
+    csharpDoc.append("///\n");
+    if (isDeprecated)
+        csharpDoc.append("[Obsolete(\"This method is deprecated\")]\n");
+    return csharpDoc;
+void outputClassDoc(const string& className, const string& commentStr)
+    //Nothing for PHP
+    if (language == php)
+        return;
+    string convertedDoc;
+    if (language == java) {
+        convertedDoc = doxygenToJavaDoc(commentStr);
+        fprintf(docOutFile, "\n%%typemap(javaclassmodifiers) %s %%{%s public%%}\n", className.c_str(), convertedDoc.c_str());
+    } else if(language == csharp) {
+        convertedDoc = doxygenToCsharpDoc(commentStr);
+        fprintf(docOutFile, "\n%%typemap(csclassmodifiers) %s %%{%s public%%}\n", className.c_str(), convertedDoc.c_str());
+void outputMethodDoc(const string& className, const string& methodDecl, const string& commentStr)
+    //Nothing for PHP
+        return;
+    //Skip destructors
+    if (methodDecl.find("~") != string::npos)
+        return;
+    string swigMethodDecl;
+    swigMethodDecl = className;
+    swigMethodDecl += "::";
+    //Re-tokenize the method declaration
+    //We want the bits between '(' and ')' (parentheses included) and the first token before the '('
+    std::stringstream ss(methodDecl);
+    std::string item;
+    std::string methodName;
+        if (elems[i] == "" || elems[i] == "virtual")
+            continue;
+        if (elems[i] == "(") {
+            if (i > 0) //Should be
+                methodName += elems[i-1];
+            methodName += elems[i];
+            int j = i;
+            //Process parameters between the ( and )
+            while(j < elems.size()) {
+                j++;
+                if (elems[j] != ")") {
+                    methodName += " ";
+                    methodName += elems[j];
+                } else {
+                    break;
+            break;
+    if (methodName.empty())
+        return;
+    swigMethodDecl += methodName;
+        fprintf(docOutFile, "\n%%javamethodmodifiers %s %%{%s public%%}\n", swigMethodDecl.c_str(), convertedDoc.c_str());
+        fprintf(docOutFile, "\n%%csmethodmodifiers %s %%{%s public%%}\n", swigMethodDecl.c_str(), convertedDoc.c_str());
 void processExternalApiSection(string& className, vector<string>& tokens, int begin, int end)
     //until we find a problem with that, we output whatever we find in this section. In the
@@ -524,6 +1133,41 @@
     FILE* propertyFile = NULL;
+    string commentStr;
+    string methodDecl;
+    //NOTE: This can get called multiple times for a given class with various offsets, so use a std::set to guard
+    //against duplicate class documentation entries
+    if (!translateMode && classesWithDocs.find(className) == classesWithDocs.end() && begin > 0) {
+        int slashesCount = 0;
+        for (int i = 0; i < begin; i++) {
+            string token = tokens[i];
+            if(token == "")
+                continue;
+            //pickup the doc comments for the class, if any.
+            //all contiguous doc comment will be considered part of the class comment
+            if(strncmp(token.c_str(), "///", 3) == 0)
+                if (isAllSlashes(token))
+                    slashesCount++;
+                if (slashesCount > 1) //Stop here, as this is generally the start of the documentation for the first method in the class
+                    break;
+                commentStr.append(token);
+                commentStr.append("\n");
+                continue;
+        if (!commentStr.empty()) {
+            outputClassDoc(className, commentStr);
+            commentStr.clear();
+            classesWithDocs.insert(className);
     for(int i = begin; i <= end; i++)
         assignmentAdded = false;
@@ -532,6 +1176,15 @@
         if(token == "")
             continue;
+            continue;
         if(token[0] == '_' || isalpha(token[0]))
             if(typeReplacements.find(token) != typeReplacements.end())
@@ -545,6 +1198,22 @@
                 firstToken = true;
                 continue;
+            if (firstToken)
+                if (translateMode && !commentStr.empty())
+                        fprintf(outfile, "%s\n   ", convertedDoc.c_str());
+                    } else if (language == csharp) {
             if(firstToken && (language == java || language == csharp))
                 fprintf(outfile, "public ");
@@ -692,8 +1361,15 @@
             destructor = true;
+        methodDecl.append(" ");
+        methodDecl.append(token);
         if(token[0] == ';' || assignmentAdded)
+            if (!translateMode) {
+                outputMethodDoc(className, methodDecl, commentStr);
+            methodDecl.clear();
             if(nesting == 0)
                 fprintf(outfile, "\n   ");
@@ -764,7 +1440,7 @@
         //in translation mode, filters out clases which don't belong to the class list
         bool ignore = translateMode && classes.find(className) == classes.end();
+        //printf("Processing header: %s\n", className.c_str());
         if(!ignore)
             if(translateMode)
@@ -784,8 +1460,9 @@
                         fprintf(outfile, "package %s;\n\n", package.c_str());
-                //in translate mode, pickup the doc comments for the class, if any.
                 int commentStart = i - 2;
                 for(; commentStart >= 0; )
@@ -799,10 +1476,22 @@
                     for(commentStart = commentStart < 0? commentStart+1: commentStart; commentStart <= i - 2; commentStart++)
                         const char* thisTok = tokens[commentStart].c_str();
-                        fprintf(outfile, "%s\n", tokens[commentStart].c_str());
+                        commentStr.append(thisTok);
+                        fprintf(outfile, "%s", convertedDoc.c_str());
             //output the class header
@@ -865,11 +1554,12 @@
         if(!ignore)
             fprintf(outfile, "\n}");
-            if(!translateMode)
+            if(!translateMode) {
                 fprintf(outfile, ";\n\n");
-            else
+            else {
                 fprintf(outfile, "\n\n");
@@ -895,7 +1585,10 @@
         outfile = fopen(target.c_str(), "w");
         if(outfile == NULL)
-            error(string("Cannot create file ") + target);
+            error(string("Cannot create target file ") + target);
+        docOutFile = fopen(docTarget.c_str(), "w");
+        if(docOutFile == NULL)
+            error(string("Cannot create doctarget file ") + docTarget);
     time_t now = time(NULL);
@@ -909,6 +1602,15 @@
     //write the module
     fprintf(outfile, "%%module %s\n", module.c_str());
+        //write the banner
+        fprintf(docOutFile, "//======================================================\n");
+        fprintf(docOutFile, "// Generated with IMake version %s\n", version);
+        fprintf(docOutFile, "// %s\n", asctime(localtime(&now)));
+        fprintf(docOutFile, "//\n");
     if(!translateMode || language != java)
         //write the C++ inline code
@@ -926,7 +1628,12 @@
         processHeaderFile(*it);
         fclose(outfile);
+        if (docOutFile != NULL) {
+            fclose(docOutFile);
 void createNativeFile()
@@ -934,6 +1641,9 @@
     if(target.length() == 0)
         error("Target section is missing");
+    if (!translateMode && docTarget.length() == 0)
+        error("DocTarget section is missing");
     if(language == unknown)
         error("Unknown language");
@@ -942,6 +1652,11 @@
         if(outfile == NULL)
+            if (docOutFile == NULL)
+                error(string("Cannot create file ") + docTarget);
     if(language == php)
@@ -978,6 +1693,8 @@
     if(language != java)
         fclose(outfile);
 void createInterfaceFile(char* paramFile)
Modified: trunk/MgDev/BuildTools/WebTools/IMake/Win32/IMake.exe
(Binary files differ)
Modified: trunk/MgDev/BuildTools/WebTools/IMake/stdafx.h
--- trunk/MgDev/BuildTools/WebTools/IMake/stdafx.h	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/BuildTools/WebTools/IMake/stdafx.h	2013-01-12 03:36:03 UTC (rev 7297)
@@ -7,10 +7,12 @@
 #define _IMAKE_STD_H_
 #include <string>
+#include <iostream>
 #include <vector>
 #include <algorithm>
 #include <deque>
 #include <map>
+#include <set>
 #include <iostream>
 #include <sstream>
 #include <time.h>
Modified: trunk/MgDev/Common/Foundation/Data/PropertyDefinition.h
--- trunk/MgDev/Common/Foundation/Data/PropertyDefinition.h	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Common/Foundation/Data/PropertyDefinition.h	2013-01-12 03:36:03 UTC (rev 7297)
@@ -201,6 +201,7 @@
     /// Returns nothing.
     /// \since 2.2
     void Delete();
 EXTERNAL_API:
Modified: trunk/MgDev/Common/MapGuideCommon/Services/MappingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/MappingService.h	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Common/MapGuideCommon/Services/MappingService.h	2013-01-12 03:36:03 UTC (rev 7297)
@@ -337,7 +337,7 @@
     /// The requested image height in pixels.
     /// \param format (String/string)
     /// Input
-    /// Image format, from MgImageFormats. Example: PNG, JPG, PNG8, etc …
+    /// Image format, from MgImageFormats. Example: PNG, JPG, PNG8, etc
     /// \param geomType (int)
     /// Input
     /// The type of symbolization required: 1=Point, 2=Line, 3=Area, 4=Composite
@@ -400,7 +400,7 @@
     /// \return
     /// A byte reader containing an XML document with the feature
     /// information described in GML (Geography Markup Language). GML
-    /// is defined by the OpenGIS® consortium. A specification for
+    /// is defined by the OpenGIS consortium. A specification for
     /// this language can be found at: /// https://portal.opengeospatial.org/files/?artifact_id=7174
@@ -439,7 +439,7 @@
     /// \return
     /// Returns a byte reader containing an XML document with the feature
Modified: trunk/MgDev/Common/PlatformBase/Services/ClassDefinition.h
--- trunk/MgDev/Common/PlatformBase/Services/ClassDefinition.h	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Common/PlatformBase/Services/ClassDefinition.h	2013-01-12 03:36:03 UTC (rev 7297)
@@ -318,6 +318,7 @@
     /// \since 2.2
     void Delete();
 EXTERNAL_API:
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureSchema.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureSchema.h	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureSchema.h	2013-01-12 03:36:03 UTC (rev 7297)
@@ -200,6 +200,7 @@
     /// \since 2.2
     void Delete();
 INTERNAL_API:
Modified: trunk/MgDev/Oem/SQLite/src/SQLitePhpApi/SQliteApiGen.xml
--- trunk/MgDev/Oem/SQLite/src/SQLitePhpApi/SQliteApiGen.xml	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Oem/SQLite/src/SQLitePhpApi/SQliteApiGen.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -9,6 +9,7 @@
    Target section.
 <Target path="./SQLitePhpApi.i"/>
+<DocTarget path="./SQLitePhpApi_Doc.i"/>
    C++ inline section.
Modified: trunk/MgDev/Oem/SWIGEx/Source/Modules/java.cxx
--- trunk/MgDev/Oem/SWIGEx/Source/Modules/java.cxx	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Oem/SWIGEx/Source/Modules/java.cxx	2013-01-12 03:36:03 UTC (rev 7297)
@@ -62,6 +62,8 @@
   bool   wrapping_member_flag; // Flag for when wrapping a member variable/enum/const
   bool   global_variable_flag; // Flag for when wrapping a global variable
   bool   member_func_flag;      // flag set when wrapping a member function
+  bool   lower_camel_case_method_names; //Flag to determine if java method should be forced into lowerCamelCase
+  bool   skip_throws_clause; //Flag to determine if throws clauses are to be omitted (assumes root exception proxy extends RuntimeException)
   bool	 firstFuncWrapper;
@@ -136,6 +138,8 @@
     global_variable_flag(false),
     member_func_flag(false),
 	firstFuncWrapper(true),
+    lower_camel_case_method_names(false),
+    skip_throws_clause(false),
     imclass_name(NULL),
     module_class_name(NULL),
@@ -332,6 +336,12 @@
         } else if ((strcmp(argv[i],"-noproxy") == 0)) {
           Swig_mark_arg(i);
           proxy_flag = false;
+        } else if ((strcmp(argv[i],"-mgjavacasing") == 0)) {
+          Swig_mark_arg(i);
+          lower_camel_case_method_names = true;
+        } else if ((strcmp(argv[i],"-mgjavanothrow") == 0)) {
+          Swig_mark_arg(i);
+          skip_throws_clause = true;
         } else if ((strcmp(argv[i],"-dllname") == 0)) {
 			if (argv[i+1])
@@ -1885,6 +1895,7 @@
     String    *imcall = NewString("");
     String    *return_type = NewString("");
     String    *function_code = NewString("");
+    String    *camelCasedName = NULL;
     if(!proxy_flag) return;
@@ -1915,12 +1926,31 @@
     /* Start generating the proxy function */
+    //NOTE: Not for general consumption. All MapGuide API methods are in UpperCamelCase so this simply lowercases the first letter
+    if (lower_camel_case_method_names)
+        camelCasedName = NewString("");
+        char * chOriginalName = Char(proxy_function_name);
+        if (chOriginalName && strlen(chOriginalName) > 0)
+            int i = 0;
+            Printf(camelCasedName, "%c", tolower(chOriginalName[i]));
+            i++;
+            while(chOriginalName[i] != '\0')
+                Printf(camelCasedName, "%c", chOriginalName[i]);
+                i++;
     const String *methodmods = Getattr(n,"feature:java:methodmodifiers");
     methodmods = methodmods ? methodmods : (is_protected(n) ? protected_string : public_string);
     Printf(function_code, "  %s ", methodmods);
     if (static_flag)
       Printf(function_code, "static ");
-    Printf(function_code, "%s %s(", return_type, proxy_function_name);
+    Printf(function_code, "%s %s(", return_type, (camelCasedName != NULL ? camelCasedName : proxy_function_name));
     Printv(imcall, imclass_name, ".", intermediary_function_name, "(", NIL);
     if (!static_flag)
@@ -1992,7 +2022,7 @@
     Printf(imcall, ")");
     Printf(function_code, ")");
-    if(baseException)
+    if(baseException && !skip_throws_clause)
         Printf(function_code, " throws %s ", baseException);
     // Transform return type used in JNI function (in intermediary class) to type used in Java wrapper function (in proxy class)
@@ -2022,6 +2052,11 @@
     Printv(proxy_class_code, function_code, NIL);
+    if (camelCasedName != NULL) {
+        Delete(camelCasedName);
+        camelCasedName = NULL;
     Delete(function_code);
     Delete(return_type);
     Delete(imcall);
@@ -2121,7 +2156,7 @@
       Printf(proxy_class_code, ")");
-      if(baseException)
           Printf(proxy_class_code, " throws %s", baseException);
       generateThrowsClause(n, proxy_class_code);
@@ -3604,6 +3639,8 @@
      -package <name> - set name of the Java package to <name>\n\
      -noproxy        - Generate the low-level functional interface instead\n\
                        of proxy classes\n\
+     -mgjavanothrow  - Omit the throws clause in Java wrapper methods (root proxy exception class must extend RuntimeException)\n\
+     -mgjavacasing   - Force java methods to be written in lowerCamelCase\n\
      -root <name>    - set the name of the root class\n\
      -dllname <name>    - set the name of JNI dll\n\
 \n";
Modified: trunk/MgDev/Oem/SWIGEx/Source/Modules/main.cxx
--- trunk/MgDev/Oem/SWIGEx/Source/Modules/main.cxx	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Oem/SWIGEx/Source/Modules/main.cxx	2013-01-12 03:36:03 UTC (rev 7297)
@@ -71,11 +71,11 @@
 static char *usage = (char*)"\
 \nGeneral Options\n\
-	 -baseexception <name>  - Name of the exception base class\n\
+     -baseexception <name>  - Name of the exception base class\n\
      -c++            - Enable C++ processing\n\
-	 -clsiddata <member> - Data member used as class identifier\n\
-	 -clsidcode <file> - Name of the file implementing getClassId()\n\
-	 -catchallcode <file> - Name of the file implementing onCatchAll()\n\
+     -clsiddata <member> - Data member used as class identifier\n\
+     -clsidcode <file> - Name of the file implementing getClassId()\n\
+     -catchallcode <file> - Name of the file implementing onCatchAll()\n\
      -co             - Check a file out of the SWIG library\n\
      -dispose <code> - Code to call to replace 'delete arg1'\n\
      -dirprot        - Turn on wrapping of protected members for director classes\n\
Modified: trunk/MgDev/Oem/SWIGEx/Win32/Swig.exe
Property changes on: trunk/MgDev/UnitTest/Common/JavaApiExTest
___________________________________________________________________
Added: svn:ignore
   + out
Added: bugtraq:number
   + true
Property changes on: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea
   + true
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/.name
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/.name	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/.name	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1 +0,0 @@
-MapGuideApiExTest
\ No newline at end of file
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/.name (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/.name)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/.name	                        (rev 0)
@@ -0,0 +1 @@
+MapGuideApiExTest
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/ant.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/ant.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/ant.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,7 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<project version="4">
-  <component name="AntConfiguration">
-    <defaultAnt bundledAnt="true" />
-  </component>
-</project>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/ant.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/ant.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/ant.xml	                        (rev 0)
@@ -0,0 +1,7 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<project version="4">
+  <component name="AntConfiguration">
+    <defaultAnt bundledAnt="true" />
+  </component>
+</project>
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/compiler.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/compiler.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/compiler.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,21 +0,0 @@
-  <component name="CompilerConfiguration">
-    <option name="DEFAULT_COMPILER" value="Javac" />
-    <resourceExtensions />
-    <wildcardResourcePatterns>
-      <entry name="?*.properties" />
-      <entry name="?*.xml" />
-      <entry name="?*.gif" />
-      <entry name="?*.png" />
-      <entry name="?*.jpeg" />
-      <entry name="?*.jpg" />
-      <entry name="?*.html" />
-      <entry name="?*.dtd" />
-      <entry name="?*.tld" />
-      <entry name="?*.ftl" />
-    </wildcardResourcePatterns>
-    <annotationProcessing enabled="false" useClasspath="true" />
-  </component>
-</project>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/compiler.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/compiler.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/compiler.xml	                        (rev 0)
@@ -0,0 +1,21 @@
+  <component name="CompilerConfiguration">
+    <option name="DEFAULT_COMPILER" value="Javac" />
+    <resourceExtensions />
+    <wildcardResourcePatterns>
+      <entry name="?*.properties" />
+      <entry name="?*.xml" />
+      <entry name="?*.gif" />
+      <entry name="?*.png" />
+      <entry name="?*.jpeg" />
+      <entry name="?*.jpg" />
+      <entry name="?*.html" />
+      <entry name="?*.dtd" />
+      <entry name="?*.tld" />
+      <entry name="?*.ftl" />
+    </wildcardResourcePatterns>
+    <annotationProcessing enabled="false" useClasspath="true" />
+  </component>
+</project>
Property changes on: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/copyright
   + true
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/copyright/profiles_settings.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/copyright/profiles_settings.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/copyright/profiles_settings.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,5 +0,0 @@
-<component name="CopyrightManager">
-  <settings default="">
-    <module2copyright />
-  </settings>
-</component>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/copyright/profiles_settings.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/copyright/profiles_settings.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/copyright/profiles_settings.xml	                        (rev 0)
@@ -0,0 +1,5 @@
+<component name="CopyrightManager">
+  <settings default="">
+    <module2copyright />
+  </settings>
+</component>
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/encodings.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/encodings.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/encodings.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,5 +0,0 @@
-  <component name="Encoding" useUTFGuessing="true" native2AsciiForPropertiesFiles="false" />
-</project>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/encodings.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/encodings.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/encodings.xml	                        (rev 0)
@@ -0,0 +1,5 @@
+  <component name="Encoding" useUTFGuessing="true" native2AsciiForPropertiesFiles="false" />
+</project>
Property changes on: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/inspectionProfiles
   + true
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/misc.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/misc.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/misc.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,31 +0,0 @@
-  <component name="EntryPointsManager">
-    <entry_points version="2.0" />
-  </component>
-  <component name="ProjectResources">
-    <default-html-doctype>http://www.w3.org/1999/xhtml</default-html-doctype>
-  </component>
-  <component name="ProjectRootManager" version="2" languageLevel="JDK_1_6" assert-keyword="true" jdk-15="true" project-jdk-name="1.6" project-jdk-type="JavaSDK">
-    <output url="file://$PROJECT_DIR$/out" />
-  </component>
-  <component name="SvnConfiguration" maxAnnotateRevisions="500" myUseAcceleration="nothing" myAutoUpdateAfterCommit="false" cleanupOnStartRun="false">
-    <option name="USER" value="" />
-    <option name="PASSWORD" value="" />
-    <option name="mySSHConnectionTimeout" value="30000" />
-    <option name="mySSHReadTimeout" value="30000" />
-    <option name="LAST_MERGED_REVISION" />
-    <option name="MERGE_DRY_RUN" value="false" />
-    <option name="MERGE_DIFF_USE_ANCESTRY" value="true" />
-    <option name="UPDATE_LOCK_ON_DEMAND" value="false" />
-    <option name="IGNORE_SPACES_IN_MERGE" value="false" />
-    <option name="DETECT_NESTED_COPIES" value="true" />
-    <option name="CHECK_NESTED_FOR_QUICK_MERGE" value="false" />
-    <option name="IGNORE_SPACES_IN_ANNOTATE" value="true" />
-    <option name="SHOW_MERGE_SOURCES_IN_ANNOTATE" value="true" />
-    <option name="FORCE_UPDATE" value="false" />
-    <option name="IGNORE_EXTERNALS" value="false" />
-    <myIsUseDefaultProxy>false</myIsUseDefaultProxy>
-  </component>
-</project>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/misc.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/misc.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/misc.xml	                        (rev 0)
@@ -0,0 +1,31 @@
+  <component name="EntryPointsManager">
+    <entry_points version="2.0" />
+  </component>
+  <component name="ProjectResources">
+    <default-html-doctype>http://www.w3.org/1999/xhtml</default-html-doctype>
+  </component>
+  <component name="ProjectRootManager" version="2" languageLevel="JDK_1_6" assert-keyword="true" jdk-15="true" project-jdk-name="1.6" project-jdk-type="JavaSDK">
+    <output url="file://$PROJECT_DIR$/out" />
+  </component>
+  <component name="SvnConfiguration" maxAnnotateRevisions="500" myUseAcceleration="nothing" myAutoUpdateAfterCommit="false" cleanupOnStartRun="false">
+    <option name="USER" value="" />
+    <option name="PASSWORD" value="" />
+    <option name="mySSHConnectionTimeout" value="30000" />
+    <option name="mySSHReadTimeout" value="30000" />
+    <option name="LAST_MERGED_REVISION" />
+    <option name="MERGE_DRY_RUN" value="false" />
+    <option name="MERGE_DIFF_USE_ANCESTRY" value="true" />
+    <option name="UPDATE_LOCK_ON_DEMAND" value="false" />
+    <option name="IGNORE_SPACES_IN_MERGE" value="false" />
+    <option name="DETECT_NESTED_COPIES" value="true" />
+    <option name="CHECK_NESTED_FOR_QUICK_MERGE" value="false" />
+    <option name="IGNORE_SPACES_IN_ANNOTATE" value="true" />
+    <option name="SHOW_MERGE_SOURCES_IN_ANNOTATE" value="true" />
+    <option name="FORCE_UPDATE" value="false" />
+    <option name="IGNORE_EXTERNALS" value="false" />
+    <myIsUseDefaultProxy>false</myIsUseDefaultProxy>
+  </component>
+</project>
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/modules.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/modules.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/modules.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,9 +0,0 @@
-  <component name="ProjectModuleManager">
-    <modules>
-      <module fileurl="file://$PROJECT_DIR$/MapGuideApiExTest.iml" filepath="$PROJECT_DIR$/MapGuideApiExTest.iml" />
-    </modules>
-  </component>
-</project>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/modules.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/modules.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/modules.xml	                        (rev 0)
@@ -0,0 +1,9 @@
+  <component name="ProjectModuleManager">
+    <modules>
+      <module fileurl="file://$PROJECT_DIR$/MapGuideApiExTest.iml" filepath="$PROJECT_DIR$/MapGuideApiExTest.iml" />
+    </modules>
+  </component>
+</project>
Property changes on: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/scopes
   + true
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/scopes/scope_settings.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/scopes/scope_settings.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/scopes/scope_settings.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,5 +0,0 @@
-<component name="DependencyValidationManager">
-  <state>
-    <option name="SKIP_IMPORT_STATEMENTS" value="false" />
-  </state>
-</component>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/scopes/scope_settings.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/scopes/scope_settings.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/scopes/scope_settings.xml	                        (rev 0)
@@ -0,0 +1,5 @@
+<component name="DependencyValidationManager">
+  <state>
+    <option name="SKIP_IMPORT_STATEMENTS" value="false" />
+  </state>
+</component>
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/uiDesigner.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/uiDesigner.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/uiDesigner.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,125 +0,0 @@
-  <component name="Palette2">
-    <group name="Swing">
-      <item class="com.intellij.uiDesigner.HSpacer" tooltip-text="Horizontal Spacer" icon="/com/intellij/uiDesigner/icons/hspacer.png" removable="false" auto-create-binding="false" can-attach-label="false">
-        <default-constraints vsize-policy="1" hsize-policy="6" anchor="0" fill="1" />
-      </item>
-      <item class="com.intellij.uiDesigner.VSpacer" tooltip-text="Vertical Spacer" icon="/com/intellij/uiDesigner/icons/vspacer.png" removable="false" auto-create-binding="false" can-attach-label="false">
-        <default-constraints vsize-policy="6" hsize-policy="1" anchor="0" fill="2" />
-      </item>
-      <item class="javax.swing.JPanel" icon="/com/intellij/uiDesigner/icons/panel.png" removable="false" auto-create-binding="false" can-attach-label="false">
-        <default-constraints vsize-policy="3" hsize-policy="3" anchor="0" fill="3" />
-      </item>
-      <item class="javax.swing.JScrollPane" icon="/com/intellij/uiDesigner/icons/scrollPane.png" removable="false" auto-create-binding="false" can-attach-label="true">
-        <default-constraints vsize-policy="7" hsize-policy="7" anchor="0" fill="3" />
-      </item>
-      <item class="javax.swing.JButton" icon="/com/intellij/uiDesigner/icons/button.png" removable="false" auto-create-binding="true" can-attach-label="false">
-        <default-constraints vsize-policy="0" hsize-policy="3" anchor="0" fill="1" />
-        <initial-values>
-          <property name="text" value="Button" />
-        </initial-values>
-      </item>
-      <item class="javax.swing.JRadioButton" icon="/com/intellij/uiDesigner/icons/radioButton.png" removable="false" auto-create-binding="true" can-attach-label="false">
-        <default-constraints vsize-policy="0" hsize-policy="3" anchor="8" fill="0" />
-        <initial-values>
-          <property name="text" value="RadioButton" />
-        </initial-values>
-      </item>
-      <item class="javax.swing.JCheckBox" icon="/com/intellij/uiDesigner/icons/checkBox.png" removable="false" auto-create-binding="true" can-attach-label="false">
-        <initial-values>
-          <property name="text" value="CheckBox" />
-        </initial-values>
-      </item>
-      <item class="javax.swing.JLabel" icon="/com/intellij/uiDesigner/icons/label.png" removable="false" auto-create-binding="false" can-attach-label="false">
-        <default-constraints vsize-policy="0" hsize-policy="0" anchor="8" fill="0" />
-        <initial-values>
-          <property name="text" value="Label" />
-        </initial-values>
-      </item>
-      <item class="javax.swing.JTextField" icon="/com/intellij/uiDesigner/icons/textField.png" removable="false" auto-create-binding="true" can-attach-label="true">
-        <default-constraints vsize-policy="0" hsize-policy="6" anchor="8" fill="1">
-          <preferred-size width="150" height="-1" />
-        </default-constraints>
-      </item>
-      <item class="javax.swing.JPasswordField" icon="/com/intellij/uiDesigner/icons/passwordField.png" removable="false" auto-create-binding="true" can-attach-label="true">
-      </item>
-      <item class="javax.swing.JFormattedTextField" icon="/com/intellij/uiDesigner/icons/formattedTextField.png" removable="false" auto-create-binding="true" can-attach-label="true">
-      </item>
-      <item class="javax.swing.JTextArea" icon="/com/intellij/uiDesigner/icons/textArea.png" removable="false" auto-create-binding="true" can-attach-label="true">
-        <default-constraints vsize-policy="6" hsize-policy="6" anchor="0" fill="3">
-          <preferred-size width="150" height="50" />
-      </item>
-      <item class="javax.swing.JTextPane" icon="/com/intellij/uiDesigner/icons/textPane.png" removable="false" auto-create-binding="true" can-attach-label="true">
-      </item>
-      <item class="javax.swing.JEditorPane" icon="/com/intellij/uiDesigner/icons/editorPane.png" removable="false" auto-create-binding="true" can-attach-label="true">
-      </item>
-      <item class="javax.swing.JComboBox" icon="/com/intellij/uiDesigner/icons/comboBox.png" removable="false" auto-create-binding="true" can-attach-label="true">
-        <default-constraints vsize-policy="0" hsize-policy="2" anchor="8" fill="1" />
-      </item>
-      <item class="javax.swing.JTable" icon="/com/intellij/uiDesigner/icons/table.png" removable="false" auto-create-binding="true" can-attach-label="false">
-      </item>
-      <item class="javax.swing.JList" icon="/com/intellij/uiDesigner/icons/list.png" removable="false" auto-create-binding="true" can-attach-label="false">
-        <default-constraints vsize-policy="6" hsize-policy="2" anchor="0" fill="3">
-      </item>
-      <item class="javax.swing.JTree" icon="/com/intellij/uiDesigner/icons/tree.png" removable="false" auto-create-binding="true" can-attach-label="false">
-      </item>
-      <item class="javax.swing.JTabbedPane" icon="/com/intellij/uiDesigner/icons/tabbedPane.png" removable="false" auto-create-binding="true" can-attach-label="false">
-        <default-constraints vsize-policy="3" hsize-policy="3" anchor="0" fill="3">
-          <preferred-size width="200" height="200" />
-      </item>
-      <item class="javax.swing.JSplitPane" icon="/com/intellij/uiDesigner/icons/splitPane.png" removable="false" auto-create-binding="false" can-attach-label="false">
-      </item>
-      <item class="javax.swing.JSpinner" icon="/com/intellij/uiDesigner/icons/spinner.png" removable="false" auto-create-binding="true" can-attach-label="true">
-        <default-constraints vsize-policy="0" hsize-policy="6" anchor="8" fill="1" />
-      </item>
-      <item class="javax.swing.JSlider" icon="/com/intellij/uiDesigner/icons/slider.png" removable="false" auto-create-binding="true" can-attach-label="false">
-      </item>
-      <item class="javax.swing.JSeparator" icon="/com/intellij/uiDesigner/icons/separator.png" removable="false" auto-create-binding="false" can-attach-label="false">
-        <default-constraints vsize-policy="6" hsize-policy="6" anchor="0" fill="3" />
-      </item>
-      <item class="javax.swing.JProgressBar" icon="/com/intellij/uiDesigner/icons/progressbar.png" removable="false" auto-create-binding="true" can-attach-label="false">
-        <default-constraints vsize-policy="0" hsize-policy="6" anchor="0" fill="1" />
-      </item>
-      <item class="javax.swing.JToolBar" icon="/com/intellij/uiDesigner/icons/toolbar.png" removable="false" auto-create-binding="false" can-attach-label="false">
-        <default-constraints vsize-policy="0" hsize-policy="6" anchor="0" fill="1">
-          <preferred-size width="-1" height="20" />
-      </item>
-      <item class="javax.swing.JToolBar$Separator" icon="/com/intellij/uiDesigner/icons/toolbarSeparator.png" removable="false" auto-create-binding="false" can-attach-label="false">
-        <default-constraints vsize-policy="0" hsize-policy="0" anchor="0" fill="1" />
-      </item>
-      <item class="javax.swing.JScrollBar" icon="/com/intellij/uiDesigner/icons/scrollbar.png" removable="false" auto-create-binding="true" can-attach-label="false">
-        <default-constraints vsize-policy="6" hsize-policy="0" anchor="0" fill="2" />
-      </item>
-    </group>
-  </component>
-</project>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/uiDesigner.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/uiDesigner.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/uiDesigner.xml	                        (rev 0)
@@ -0,0 +1,125 @@
+  <component name="Palette2">
+    <group name="Swing">
+      <item class="com.intellij.uiDesigner.HSpacer" tooltip-text="Horizontal Spacer" icon="/com/intellij/uiDesigner/icons/hspacer.png" removable="false" auto-create-binding="false" can-attach-label="false">
+        <default-constraints vsize-policy="1" hsize-policy="6" anchor="0" fill="1" />
+      </item>
+      <item class="com.intellij.uiDesigner.VSpacer" tooltip-text="Vertical Spacer" icon="/com/intellij/uiDesigner/icons/vspacer.png" removable="false" auto-create-binding="false" can-attach-label="false">
+        <default-constraints vsize-policy="6" hsize-policy="1" anchor="0" fill="2" />
+      </item>
+      <item class="javax.swing.JPanel" icon="/com/intellij/uiDesigner/icons/panel.png" removable="false" auto-create-binding="false" can-attach-label="false">
+        <default-constraints vsize-policy="3" hsize-policy="3" anchor="0" fill="3" />
+      </item>
+      <item class="javax.swing.JScrollPane" icon="/com/intellij/uiDesigner/icons/scrollPane.png" removable="false" auto-create-binding="false" can-attach-label="true">
+        <default-constraints vsize-policy="7" hsize-policy="7" anchor="0" fill="3" />
+      </item>
+      <item class="javax.swing.JButton" icon="/com/intellij/uiDesigner/icons/button.png" removable="false" auto-create-binding="true" can-attach-label="false">
+        <default-constraints vsize-policy="0" hsize-policy="3" anchor="0" fill="1" />
+        <initial-values>
+          <property name="text" value="Button" />
+        </initial-values>
+      </item>
+      <item class="javax.swing.JRadioButton" icon="/com/intellij/uiDesigner/icons/radioButton.png" removable="false" auto-create-binding="true" can-attach-label="false">
+        <default-constraints vsize-policy="0" hsize-policy="3" anchor="8" fill="0" />
+        <initial-values>
+          <property name="text" value="RadioButton" />
+        </initial-values>
+      </item>
+      <item class="javax.swing.JCheckBox" icon="/com/intellij/uiDesigner/icons/checkBox.png" removable="false" auto-create-binding="true" can-attach-label="false">
+        <initial-values>
+          <property name="text" value="CheckBox" />
+        </initial-values>
+      </item>
+      <item class="javax.swing.JLabel" icon="/com/intellij/uiDesigner/icons/label.png" removable="false" auto-create-binding="false" can-attach-label="false">
+        <default-constraints vsize-policy="0" hsize-policy="0" anchor="8" fill="0" />
+        <initial-values>
+          <property name="text" value="Label" />
+        </initial-values>
+      </item>
+      <item class="javax.swing.JTextField" icon="/com/intellij/uiDesigner/icons/textField.png" removable="false" auto-create-binding="true" can-attach-label="true">
+        <default-constraints vsize-policy="0" hsize-policy="6" anchor="8" fill="1">
+          <preferred-size width="150" height="-1" />
+        </default-constraints>
+      </item>
+      <item class="javax.swing.JPasswordField" icon="/com/intellij/uiDesigner/icons/passwordField.png" removable="false" auto-create-binding="true" can-attach-label="true">
+      </item>
+      <item class="javax.swing.JFormattedTextField" icon="/com/intellij/uiDesigner/icons/formattedTextField.png" removable="false" auto-create-binding="true" can-attach-label="true">
+      </item>
+      <item class="javax.swing.JTextArea" icon="/com/intellij/uiDesigner/icons/textArea.png" removable="false" auto-create-binding="true" can-attach-label="true">
+        <default-constraints vsize-policy="6" hsize-policy="6" anchor="0" fill="3">
+          <preferred-size width="150" height="50" />
+      </item>
+      <item class="javax.swing.JTextPane" icon="/com/intellij/uiDesigner/icons/textPane.png" removable="false" auto-create-binding="true" can-attach-label="true">
+      </item>
+      <item class="javax.swing.JEditorPane" icon="/com/intellij/uiDesigner/icons/editorPane.png" removable="false" auto-create-binding="true" can-attach-label="true">
+      </item>
+      <item class="javax.swing.JComboBox" icon="/com/intellij/uiDesigner/icons/comboBox.png" removable="false" auto-create-binding="true" can-attach-label="true">
+        <default-constraints vsize-policy="0" hsize-policy="2" anchor="8" fill="1" />
+      </item>
+      <item class="javax.swing.JTable" icon="/com/intellij/uiDesigner/icons/table.png" removable="false" auto-create-binding="true" can-attach-label="false">
+      </item>
+      <item class="javax.swing.JList" icon="/com/intellij/uiDesigner/icons/list.png" removable="false" auto-create-binding="true" can-attach-label="false">
+        <default-constraints vsize-policy="6" hsize-policy="2" anchor="0" fill="3">
+      </item>
+      <item class="javax.swing.JTree" icon="/com/intellij/uiDesigner/icons/tree.png" removable="false" auto-create-binding="true" can-attach-label="false">
+      </item>
+      <item class="javax.swing.JTabbedPane" icon="/com/intellij/uiDesigner/icons/tabbedPane.png" removable="false" auto-create-binding="true" can-attach-label="false">
+        <default-constraints vsize-policy="3" hsize-policy="3" anchor="0" fill="3">
+          <preferred-size width="200" height="200" />
+      </item>
+      <item class="javax.swing.JSplitPane" icon="/com/intellij/uiDesigner/icons/splitPane.png" removable="false" auto-create-binding="false" can-attach-label="false">
+      </item>
+      <item class="javax.swing.JSpinner" icon="/com/intellij/uiDesigner/icons/spinner.png" removable="false" auto-create-binding="true" can-attach-label="true">
+        <default-constraints vsize-policy="0" hsize-policy="6" anchor="8" fill="1" />
+      </item>
+      <item class="javax.swing.JSlider" icon="/com/intellij/uiDesigner/icons/slider.png" removable="false" auto-create-binding="true" can-attach-label="false">
+      </item>
+      <item class="javax.swing.JSeparator" icon="/com/intellij/uiDesigner/icons/separator.png" removable="false" auto-create-binding="false" can-attach-label="false">
+        <default-constraints vsize-policy="6" hsize-policy="6" anchor="0" fill="3" />
+      </item>
+      <item class="javax.swing.JProgressBar" icon="/com/intellij/uiDesigner/icons/progressbar.png" removable="false" auto-create-binding="true" can-attach-label="false">
+        <default-constraints vsize-policy="0" hsize-policy="6" anchor="0" fill="1" />
+      </item>
+      <item class="javax.swing.JToolBar" icon="/com/intellij/uiDesigner/icons/toolbar.png" removable="false" auto-create-binding="false" can-attach-label="false">
+        <default-constraints vsize-policy="0" hsize-policy="6" anchor="0" fill="1">
+          <preferred-size width="-1" height="20" />
+      </item>
+      <item class="javax.swing.JToolBar$Separator" icon="/com/intellij/uiDesigner/icons/toolbarSeparator.png" removable="false" auto-create-binding="false" can-attach-label="false">
+        <default-constraints vsize-policy="0" hsize-policy="0" anchor="0" fill="1" />
+      </item>
+      <item class="javax.swing.JScrollBar" icon="/com/intellij/uiDesigner/icons/scrollbar.png" removable="false" auto-create-binding="true" can-attach-label="false">
+        <default-constraints vsize-policy="6" hsize-policy="0" anchor="0" fill="2" />
+      </item>
+    </group>
+  </component>
+</project>
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/vcs.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/vcs.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/vcs.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,7 +0,0 @@
-  <component name="VcsDirectoryMappings">
-    <mapping directory="" vcs="" />
-  </component>
-</project>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/vcs.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/vcs.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/vcs.xml	                        (rev 0)
@@ -0,0 +1,7 @@
+  <component name="VcsDirectoryMappings">
+    <mapping directory="" vcs="" />
+  </component>
+</project>
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/workspace.xml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/workspace.xml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/workspace.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,645 +0,0 @@
-  <component name="ChangeListManager">
-    <list default="true" id="f24f429b-81bb-475f-9057-46f372ac8279" name="Default" comment="" />
-    <ignored path="MapGuideApiExTest.iws" />
-    <ignored path=".idea/workspace.xml" />
-    <option name="TRACKING_ENABLED" value="true" />
-    <option name="SHOW_DIALOG" value="false" />
-    <option name="HIGHLIGHT_CONFLICTS" value="true" />
-    <option name="HIGHLIGHT_NON_ACTIVE_CHANGELIST" value="false" />
-    <option name="LAST_RESOLUTION" value="IGNORE" />
-  </component>
-  <component name="ChangesViewManager" flattened_view="true" show_ignored="false" />
-  <component name="CreatePatchCommitExecutor">
-    <option name="PATCH_PATH" value="" />
-  </component>
-  <component name="DaemonCodeAnalyzer">
-    <disable_hints />
-  </component>
-  <component name="DebuggerManager">
-    <line_breakpoints>
-      <breakpoint url="file://$PROJECT_DIR$/src/MapGuideApiTest.java" line="1026" class="MapGuideApiTest" package="">
-        <option name="ENABLED" value="true" />
-        <option name="LOG_ENABLED" value="false" />
-        <option name="LOG_EXPRESSION_ENABLED" value="false" />
-        <option name="SUSPEND_POLICY" value="SuspendAll" />
-        <option name="COUNT_FILTER_ENABLED" value="false" />
-        <option name="COUNT_FILTER" value="0" />
-        <option name="CONDITION_ENABLED" value="false" />
-        <option name="CLASS_FILTERS_ENABLED" value="false" />
-        <option name="INSTANCE_FILTERS_ENABLED" value="false" />
-        <option name="CONDITION" value="" />
-        <option name="LOG_MESSAGE" value="" />
-      </breakpoint>
-    </line_breakpoints>
-    <breakpoint_any>
-      <breakpoint>
-        <option name="NOTIFY_CAUGHT" value="true" />
-        <option name="NOTIFY_UNCAUGHT" value="true" />
-        <option name="ENABLED" value="false" />
-      </breakpoint>
-      <breakpoint>
-      </breakpoint>
-    </breakpoint_any>
-    <breakpoint_rules />
-    <ui_properties />
-  </component>
-  <component name="FavoritesManager">
-    <favorites_list name="MapGuideApiExTest" />
-  </component>
-  <component name="FileEditorManager">
-    <leaf>
-      <file leaf-file-name="MapGuideApiTest.java" pinned="false" current="true" current-in-tab="true">
-        <entry file="file://$PROJECT_DIR$/src/MapGuideApiTest.java">
-          <provider selected="true" editor-type-id="text-editor">
-            <state line="1227" column="57" selection-start="58790" selection-end="58790" vertical-scroll-proportion="0.9583333">
-              <folding>
-                <element signature="method#testReadOnlyLayerCollection#0;class#MapGuideApiTest#0" expanded="false" />
-                <element signature="method#testStringCollection#0;class#MapGuideApiTest#0" expanded="false" />
-                <element signature="method#testPropertyCollection#0;class#MapGuideApiTest#0" expanded="false" />
-                <element signature="method#testClassDefinitionCollection#0;class#MapGuideApiTest#0" expanded="false" />
-                <element signature="e#54940#54954#0" expanded="true" />
-              </folding>
-            </state>
-          </provider>
-        </entry>
-      </file>
-    </leaf>
-  </component>
-  <component name="FindManager">
-    <FindUsagesManager>
-      <setting name="OPEN_NEW_TAB" value="false" />
-    </FindUsagesManager>
-  </component>
-  <component name="IdeDocumentHistory">
-    <option name="changedFiles">
-      <list>
-        <option value="$PROJECT_DIR$/src/AssertException.java" />
-        <option value="$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgFeatureSchemaCollection.java" />
-        <option value="$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgPropertyDefinitionCollection.java" />
-        <option value="$PROJECT_DIR$/src/MapGuideApiTest.java" />
-      </list>
-    </option>
-  </component>
-  <component name="ProjectFrameBounds">
-    <option name="x" value="1721" />
-    <option name="y" value="53" />
-    <option name="width" value="1218" />
-    <option name="height" value="928" />
-  </component>
-  <component name="ProjectLevelVcsManager" settingsEditedManually="false">
-    <OptionsSetting value="true" id="Add" />
-    <OptionsSetting value="true" id="Remove" />
-    <OptionsSetting value="true" id="Checkout" />
-    <OptionsSetting value="true" id="Update" />
-    <OptionsSetting value="true" id="Status" />
-    <OptionsSetting value="true" id="Edit" />
-    <ConfirmationsSetting value="0" id="Add" />
-    <ConfirmationsSetting value="0" id="Remove" />
-  </component>
-  <component name="ProjectReloadState">
-    <option name="STATE" value="0" />
-  </component>
-  <component name="ProjectView">
-    <navigator currentView="ProjectPane" proportions="" version="1" splitterProportion="0.5">
-      <flattenPackages />
-      <showMembers />
-      <showModules />
-      <showLibraryContents />
-      <hideEmptyPackages />
-      <abbreviatePackageNames />
-      <autoscrollToSource />
-      <autoscrollFromSource />
-      <sortByType />
-    </navigator>
-    <panes>
-      <pane id="Scope">
-        <subPane subId="Project Files">
-          <PATH>
-            <PATH_ELEMENT USER_OBJECT="Root">
-              <option name="myItemId" value="" />
-              <option name="myItemType" value="" />
-            </PATH_ELEMENT>
-          </PATH>
-        </subPane>
-      </pane>
-      <pane id="PackagesPane">
-        <subPane>
-          <PATH>
-            <PATH_ELEMENT>
-              <option name="myItemId" value="MapGuideApiExTest" />
-              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.PackageViewProjectNode" />
-            </PATH_ELEMENT>
-            <PATH_ELEMENT>
-              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.PackageViewModuleNode" />
-            </PATH_ELEMENT>
-          </PATH>
-        </subPane>
-      </pane>
-      <pane id="ProjectPane">
-        <subPane>
-          <PATH>
-            <PATH_ELEMENT>
-              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.ProjectViewProjectNode" />
-            </PATH_ELEMENT>
-            <PATH_ELEMENT>
-              <option name="myItemId" value="External Libraries" />
-              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.ExternalLibrariesNode" />
-            </PATH_ELEMENT>
-          </PATH>
-          <PATH>
-            <PATH_ELEMENT>
-            </PATH_ELEMENT>
-            <PATH_ELEMENT>
-            </PATH_ELEMENT>
-            <PATH_ELEMENT>
-              <option name="myItemId" value="MapGuideApiEx.jar" />
-              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.PsiDirectoryNode" />
-            </PATH_ELEMENT>
-            <PATH_ELEMENT>
-              <option name="myItemId" value="mapguide" />
-            </PATH_ELEMENT>
-          </PATH>
-          <PATH>
-            <PATH_ELEMENT>
-            </PATH_ELEMENT>
-            <PATH_ELEMENT>
-            </PATH_ELEMENT>
-            <PATH_ELEMENT>
-            </PATH_ELEMENT>
-          </PATH>
-          <PATH>
-            <PATH_ELEMENT>
-            </PATH_ELEMENT>
-          </PATH>
-        </subPane>
-      </pane>
-    </panes>
-  </component>
-  <component name="PropertiesComponent">
-    <property name="GoToFile.includeJavaFiles" value="false" />
-    <property name="project.structure.last.edited" value="Modules" />
-    <property name="project.structure.proportion" value="0.15" />
-    <property name="options.splitter.main.proportions" value="0.3" />
-    <property name="MemberChooser.sorted" value="false" />
-    <property name="recentsLimit" value="5" />
-    <property name="options.lastSelected" value="reference.projectsettings.compiler.javacompiler" />
-    <property name="project.structure.side.proportion" value="0.2" />
-    <property name="MemberChooser.copyJavadoc" value="false" />
-    <property name="GoToClass.toSaveIncludeLibraries" value="false" />
-    <property name="MemberChooser.showClasses" value="true" />
-    <property name="GoToClass.includeLibraries" value="false" />
-    <property name="dynamic.classpath" value="false" />
-    <property name="options.searchVisible" value="true" />
-    <property name="options.splitter.details.proportions" value="0.2" />
-  </component>
-  <component name="RunManager" selected="Application.Console">
-    <configuration default="true" type="#org.jetbrains.idea.devkit.run.PluginConfigurationType" factoryName="Plugin">
-      <module name="" />
-      <option name="VM_PARAMETERS" value="-Xmx512m -Xms256m -XX:MaxPermSize=250m" />
-      <option name="PROGRAM_PARAMETERS" />
-      <method>
-        <option name="AntTarget" enabled="false" />
-        <option name="BuildArtifacts" enabled="false" />
-        <option name="Make" enabled="true" />
-        <option name="Maven.BeforeRunTask" enabled="false" />
-      </method>
-    </configuration>
-    <configuration default="true" type="Remote" factoryName="Remote">
-      <option name="USE_SOCKET_TRANSPORT" value="true" />
-      <option name="SERVER_MODE" value="false" />
-      <option name="SHMEM_ADDRESS" value="javadebug" />
-      <option name="HOST" value="localhost" />
-      <option name="PORT" value="5005" />
-      <method>
-      </method>
-    </configuration>
-    <configuration default="true" type="Applet" factoryName="Applet">
-      <option name="MAIN_CLASS_NAME" />
-      <option name="HTML_FILE_NAME" />
-      <option name="HTML_USED" value="false" />
-      <option name="WIDTH" value="400" />
-      <option name="HEIGHT" value="300" />
-      <option name="POLICY_FILE" value="$APPLICATION_HOME_DIR$/bin/appletviewer.policy" />
-      <option name="VM_PARAMETERS" />
-      <option name="ALTERNATIVE_JRE_PATH_ENABLED" value="false" />
-      <option name="ALTERNATIVE_JRE_PATH" />
-      <method>
-      </method>
-    </configuration>
-    <configuration default="true" type="TestNG" factoryName="TestNG">
-      <option name="SUITE_NAME" />
-      <option name="PACKAGE_NAME" />
-      <option name="METHOD_NAME" />
-      <option name="GROUP_NAME" />
-      <option name="TEST_OBJECT" value="CLASS" />
-      <option name="VM_PARAMETERS" value="-ea" />
-      <option name="PARAMETERS" />
-      <option name="WORKING_DIRECTORY" value="$PROJECT_DIR$" />
-      <option name="OUTPUT_DIRECTORY" />
-      <option name="ANNOTATION_TYPE" />
-      <option name="ENV_VARIABLES" />
-      <option name="PASS_PARENT_ENVS" value="true" />
-      <option name="TEST_SEARCH_SCOPE">
-        <value defaultName="moduleWithDependencies" />
-      </option>
-      <option name="USE_DEFAULT_REPORTERS" value="false" />
-      <option name="PROPERTIES_FILE" />
-      <envs />
-      <properties />
-      <listeners />
-      <method>
-      </method>
-    </configuration>
-    <configuration default="true" type="Application" factoryName="Application">
-      <option name="MAIN_CLASS_NAME" value="MapGuideApiTest" />
-      <option name="VM_PARAMETERS" value="" />
-      <option name="PROGRAM_PARAMETERS" value="" />
-      <option name="WORKING_DIRECTORY" value="file://$PROJECT_DIR$/../../../Web/bin/release" />
-      <option name="ALTERNATIVE_JRE_PATH" value="" />
-      <option name="ENABLE_SWING_INSPECTOR" value="false" />
-      <envs />
-      <method>
-      </method>
-    </configuration>
-    <configuration default="true" type="JUnit" factoryName="JUnit">
-      <option name="TEST_OBJECT" value="class" />
-      </option>
-      <envs />
-      <patterns />
-      <method>
-      </method>
-    </configuration>
-    <configuration default="false" name="Console" type="Application" factoryName="Application">
-      <module name="MapGuideApiExTest" />
-      <envs />
-      <RunnerSettings RunnerId="Debug">
-        <option name="DEBUG_PORT" value="" />
-        <option name="TRANSPORT" value="0" />
-        <option name="LOCAL" value="true" />
-      </RunnerSettings>
-      <RunnerSettings RunnerId="Run" />
-      <ConfigurationWrapper RunnerId="Debug" />
-      <ConfigurationWrapper RunnerId="Run" />
-      <method />
-    </configuration>
-    <list size="1">
-      <item index="0" class="java.lang.String" itemvalue="Application.Console" />
-    </list>
-    <configuration name="<template>" type="WebApp" default="true" selected="false">
-      <Host>localhost</Host>
-      <Port>5050</Port>
-    </configuration>
-  </component>
-  <component name="ShelveChangesManager" show_recycled="false" />
-  <component name="TaskManager">
-    <task active="true" id="Default" summary="Default task">
-      <changelist id="f24f429b-81bb-475f-9057-46f372ac8279" name="Default" comment="" />
-      <created>1353932158797</created>
-      <updated>1353932158797</updated>
-    </task>
-    <servers />
-  </component>
-  <component name="ToolWindowManager">
-    <frame x="1721" y="53" width="1218" height="928" extended-state="0" />
-    <editor active="false" />
-    <layout>
-      <window_info id="Changes" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="7" side_tool="false" content_ui="tabs" />
-      <window_info id="JetGradle" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" />
-      <window_info id="Palette" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" />
-      <window_info id="Ant Build" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.25" sideWeight="0.5" order="1" side_tool="false" content_ui="tabs" />
-      <window_info id="Debug" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.3484163" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" />
-      <window_info id="Event Log" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="7" side_tool="true" content_ui="tabs" />
-      <window_info id="Favorites" active="false" anchor="left" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="2" side_tool="true" content_ui="tabs" />
-      <window_info id="Version Control" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="7" side_tool="false" content_ui="tabs" />
-      <window_info id="Messages" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="7" side_tool="false" content_ui="tabs" />
-      <window_info id="TODO" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="6" side_tool="false" content_ui="tabs" />
-      <window_info id="Structure" active="false" anchor="left" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="true" weight="0.23243712" sideWeight="0.6049223" order="1" side_tool="true" content_ui="tabs" />
-      <window_info id="Maven Projects" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" />
-      <window_info id="Commander" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.4" sideWeight="0.5" order="0" side_tool="false" content_ui="tabs" />
-      <window_info id="Project" active="false" anchor="left" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="true" weight="0.23243712" sideWeight="0.059585493" order="0" side_tool="false" content_ui="combo" />
-      <window_info id="Run" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.32642487" sideWeight="0.5" order="2" side_tool="false" content_ui="tabs" />
-      <window_info id="Documentation" active="false" anchor="right" auto_hide="true" internal_type="DOCKED" type="FLOATING" visible="false" weight="0.32928944" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" x="839" y="583" width="636" height="307" />
-      <window_info id="Cvs" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.25" sideWeight="0.5" order="4" side_tool="false" content_ui="tabs" />
-      <window_info id="Message" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="0" side_tool="false" content_ui="tabs" />
-      <window_info id="Find" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="1" side_tool="false" content_ui="tabs" />
-      <window_info id="Hierarchy" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.25" sideWeight="0.5" order="2" side_tool="false" content_ui="combo" />
-      <window_info id="Inspection" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.4" sideWeight="0.5" order="5" side_tool="false" content_ui="tabs" />
-    </layout>
-  </component>
-  <component name="VcsContentAnnotationSettings">
-    <option name="myLimit" value="2678400000" />
-  </component>
-  <component name="VcsManagerConfiguration">
-    <option name="OFFER_MOVE_TO_ANOTHER_CHANGELIST_ON_PARTIAL_COMMIT" value="true" />
-    <option name="CHECK_CODE_SMELLS_BEFORE_PROJECT_COMMIT" value="true" />
-    <option name="CHECK_NEW_TODO" value="true" />
-    <option name="myTodoPanelSettings">
-      <value>
-        <are-packages-shown value="false" />
-        <are-modules-shown value="false" />
-        <flatten-packages value="false" />
-        <is-autoscroll-to-source value="false" />
-      </value>
-    </option>
-    <option name="PERFORM_UPDATE_IN_BACKGROUND" value="true" />
-    <option name="PERFORM_COMMIT_IN_BACKGROUND" value="true" />
-    <option name="PERFORM_EDIT_IN_BACKGROUND" value="true" />
-    <option name="PERFORM_CHECKOUT_IN_BACKGROUND" value="true" />
-    <option name="PERFORM_ADD_REMOVE_IN_BACKGROUND" value="true" />
-    <option name="PERFORM_ROLLBACK_IN_BACKGROUND" value="false" />
-    <option name="CHECK_LOCALLY_CHANGED_CONFLICTS_IN_BACKGROUND" value="false" />
-    <option name="ENABLE_BACKGROUND_PROCESSES" value="false" />
-    <option name="CHANGED_ON_SERVER_INTERVAL" value="60" />
-    <option name="SHOW_ONLY_CHANGED_IN_SELECTION_DIFF" value="true" />
-    <option name="CHECK_COMMIT_MESSAGE_SPELLING" value="true" />
-    <option name="DEFAULT_PATCH_EXTENSION" value="patch" />
-    <option name="SHORT_DIFF_HORISONTALLY" value="true" />
-    <option name="SHORT_DIFF_EXTRA_LINES" value="2" />
-    <option name="SOFT_WRAPS_IN_SHORT_DIFF" value="true" />
-    <option name="INCLUDE_TEXT_INTO_PATCH" value="false" />
-    <option name="INCLUDE_TEXT_INTO_SHELF" value="false" />
-    <option name="CREATE_PATCH_EXPAND_DETAILS_DEFAULT" value="true" />
-    <option name="SHOW_FILE_HISTORY_DETAILS" value="true" />
-    <option name="SHOW_VCS_ERROR_NOTIFICATIONS" value="true" />
-    <option name="FORCE_NON_EMPTY_COMMENT" value="false" />
-    <option name="CLEAR_INITIAL_COMMIT_MESSAGE" value="false" />
-    <option name="LAST_COMMIT_MESSAGE" />
-    <option name="MAKE_NEW_CHANGELIST_ACTIVE" value="false" />
-    <option name="OPTIMIZE_IMPORTS_BEFORE_PROJECT_COMMIT" value="false" />
-    <option name="CHECK_FILES_UP_TO_DATE_BEFORE_COMMIT" value="false" />
-    <option name="REFORMAT_BEFORE_PROJECT_COMMIT" value="false" />
-    <option name="REFORMAT_BEFORE_FILE_COMMIT" value="false" />
-    <option name="FILE_HISTORY_DIALOG_COMMENTS_SPLITTER_PROPORTION" value="0.8" />
-    <option name="FILE_HISTORY_DIALOG_SPLITTER_PROPORTION" value="0.5" />
-    <option name="ACTIVE_VCS_NAME" />
-    <option name="UPDATE_GROUP_BY_PACKAGES" value="false" />
-    <option name="UPDATE_GROUP_BY_CHANGELIST" value="false" />
-    <option name="SHOW_FILE_HISTORY_AS_TREE" value="false" />
-    <option name="FILE_HISTORY_SPLITTER_PROPORTION" value="0.6" />
-  </component>
-  <component name="XDebuggerManager">
-    <breakpoint-manager />
-  </component>
-  <component name="antWorkspaceConfiguration">
-    <option name="IS_AUTOSCROLL_TO_SOURCE" value="false" />
-    <option name="FILTER_TARGETS" value="false" />
-  </component>
-  <component name="editorHistoryManager">
-    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MapGuideJavaApiExJNI.java">
-        <state line="2904" column="0" selection-start="270715" selection-end="270715" vertical-scroll-proportion="0.0" />
-      </provider>
-    </entry>
-    <entry file="file://$PROJECT_DIR$/src/AssertException.java">
-        <state line="12" column="54" selection-start="284" selection-end="284" vertical-scroll-proportion="0.0" />
-      </provider>
-    </entry>
-    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgSerializable.java">
-        <state line="22" column="67" selection-start="712" selection-end="712" vertical-scroll-proportion="0.32258064" />
-      </provider>
-    </entry>
-    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgNamedSerializable.java">
-        <state line="16" column="50" selection-start="516" selection-end="516" vertical-scroll-proportion="0.32258064" />
-      </provider>
-    </entry>
-    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/lang/String.java">
-        <state line="1004" column="0" selection-start="38011" selection-end="38011" vertical-scroll-proportion="0.03307393" />
-      </provider>
-    </entry>
-    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/lang/StringBuilder.java">
-        <state line="429" column="0" selection-start="12939" selection-end="12939" vertical-scroll-proportion="0.032258064" />
-      </provider>
-    </entry>
-    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/lang/ClassLoader.java">
-        <state line="322" column="0" selection-start="11967" selection-end="11967" vertical-scroll-proportion="0.24408014" />
-      </provider>
-    </entry>
-    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/lang/Object.java">
-        <state line="133" column="0" selection-start="6113" selection-end="6113" vertical-scroll-proportion="0.0" />
-      </provider>
-    </entry>
-    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/util/ArrayList.java">
-        <state line="215" column="0" selection-start="8342" selection-end="8342" vertical-scroll-proportion="0.0" />
-      </provider>
-    </entry>
-    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgFeatureSchemaCollection.java">
-        <state line="210" column="26" selection-start="6412" selection-end="6412" vertical-scroll-proportion="0.0" />
-      </provider>
-    </entry>
-    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgFeatureSchema.java">
-        <state line="79" column="51" selection-start="2059" selection-end="2059" vertical-scroll-proportion="0.60830325" />
-      </provider>
-    </entry>
-    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgByteProperty.java">
-        <state line="16" column="14" selection-start="491" selection-end="491" vertical-scroll-proportion="-0.6895943" />
-      </provider>
-    </entry>
-    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgBatchPropertyCollection.java">
-        <state line="116" column="0" selection-start="3461" selection-end="3461" vertical-scroll-proportion="0.33212996" />
-      </provider>
-    </entry>
-    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgPropertyDefinitionCollection.java">
-        <state line="248" column="13" selection-start="7649" selection-end="7649" vertical-scroll-proportion="0.33212996" />
-      </provider>
-    </entry>
-    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgLayerCollection.java">
-        <state line="172" column="71" selection-start="4032" selection-end="4922" vertical-scroll-proportion="0.6502732" />
-      </provider>
-    </entry>
-        <state line="1227" column="57" selection-start="58790" selection-end="58790" vertical-scroll-proportion="0.9583333" />
-      </provider>
-    </entry>
-  </component>
-  <component name="masterDetails">
-    <states>
-      <state key="ArtifactsStructureConfigurable.UI">
-        <settings>
-          <artifact-editor />
-          <splitter-proportions>
-            <option name="proportions">
-              <list>
-                <option value="0.2" />
-              </list>
-            </option>
-          </splitter-proportions>
-        </settings>
-      </state>
-      <state key="FacetStructureConfigurable.UI">
-        <settings>
-          <last-edited>No facets are configured</last-edited>
-              <list>
-              </list>
-            </option>
-        </settings>
-      </state>
-      <state key="GlobalLibrariesConfigurable.UI">
-        <settings>
-              <list>
-              </list>
-            </option>
-        </settings>
-      </state>
-      <state key="JdkListConfigurable.UI">
-        <settings>
-          <last-edited>1.6</last-edited>
-              <list>
-              </list>
-            </option>
-        </settings>
-      </state>
-      <state key="ModuleStructureConfigurable.UI">
-        <settings>
-          <last-edited>MapGuideApiExTest</last-edited>
-              <list>
-              </list>
-            </option>
-        </settings>
-      </state>
-      <state key="ProjectJDKs.UI">
-        <settings>
-              <list>
-              </list>
-            </option>
-        </settings>
-      </state>
-      <state key="ProjectLibrariesConfigurable.UI">
-        <settings>
-              <list>
-              </list>
-            </option>
-        </settings>
-      </state>
-    </states>
-  </component>
-</project>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/workspace.xml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/.idea/workspace.xml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/.idea/workspace.xml	                        (rev 0)
@@ -0,0 +1,645 @@
+  <component name="ChangeListManager">
+    <list default="true" id="f24f429b-81bb-475f-9057-46f372ac8279" name="Default" comment="" />
+    <ignored path="MapGuideApiExTest.iws" />
+    <ignored path=".idea/workspace.xml" />
+    <option name="TRACKING_ENABLED" value="true" />
+    <option name="SHOW_DIALOG" value="false" />
+    <option name="HIGHLIGHT_CONFLICTS" value="true" />
+    <option name="HIGHLIGHT_NON_ACTIVE_CHANGELIST" value="false" />
+    <option name="LAST_RESOLUTION" value="IGNORE" />
+  </component>
+  <component name="ChangesViewManager" flattened_view="true" show_ignored="false" />
+  <component name="CreatePatchCommitExecutor">
+    <option name="PATCH_PATH" value="" />
+  </component>
+  <component name="DaemonCodeAnalyzer">
+    <disable_hints />
+  </component>
+  <component name="DebuggerManager">
+    <line_breakpoints>
+      <breakpoint url="file://$PROJECT_DIR$/src/MapGuideApiTest.java" line="1026" class="MapGuideApiTest" package="">
+        <option name="ENABLED" value="true" />
+        <option name="LOG_ENABLED" value="false" />
+        <option name="LOG_EXPRESSION_ENABLED" value="false" />
+        <option name="SUSPEND_POLICY" value="SuspendAll" />
+        <option name="COUNT_FILTER_ENABLED" value="false" />
+        <option name="COUNT_FILTER" value="0" />
+        <option name="CONDITION_ENABLED" value="false" />
+        <option name="CLASS_FILTERS_ENABLED" value="false" />
+        <option name="INSTANCE_FILTERS_ENABLED" value="false" />
+        <option name="CONDITION" value="" />
+        <option name="LOG_MESSAGE" value="" />
+      </breakpoint>
+    </line_breakpoints>
+    <breakpoint_any>
+      <breakpoint>
+        <option name="NOTIFY_CAUGHT" value="true" />
+        <option name="NOTIFY_UNCAUGHT" value="true" />
+        <option name="ENABLED" value="false" />
+      </breakpoint>
+      <breakpoint>
+      </breakpoint>
+    </breakpoint_any>
+    <breakpoint_rules />
+    <ui_properties />
+  </component>
+  <component name="FavoritesManager">
+    <favorites_list name="MapGuideApiExTest" />
+  </component>
+  <component name="FileEditorManager">
+    <leaf>
+      <file leaf-file-name="MapGuideApiTest.java" pinned="false" current="true" current-in-tab="true">
+        <entry file="file://$PROJECT_DIR$/src/MapGuideApiTest.java">
+          <provider selected="true" editor-type-id="text-editor">
+            <state line="1227" column="57" selection-start="58790" selection-end="58790" vertical-scroll-proportion="0.9583333">
+              <folding>
+                <element signature="method#testReadOnlyLayerCollection#0;class#MapGuideApiTest#0" expanded="false" />
+                <element signature="method#testStringCollection#0;class#MapGuideApiTest#0" expanded="false" />
+                <element signature="method#testPropertyCollection#0;class#MapGuideApiTest#0" expanded="false" />
+                <element signature="method#testClassDefinitionCollection#0;class#MapGuideApiTest#0" expanded="false" />
+                <element signature="e#54940#54954#0" expanded="true" />
+              </folding>
+            </state>
+          </provider>
+        </entry>
+      </file>
+    </leaf>
+  </component>
+  <component name="FindManager">
+    <FindUsagesManager>
+      <setting name="OPEN_NEW_TAB" value="false" />
+    </FindUsagesManager>
+  </component>
+  <component name="IdeDocumentHistory">
+    <option name="changedFiles">
+      <list>
+        <option value="$PROJECT_DIR$/src/AssertException.java" />
+        <option value="$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgFeatureSchemaCollection.java" />
+        <option value="$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgPropertyDefinitionCollection.java" />
+        <option value="$PROJECT_DIR$/src/MapGuideApiTest.java" />
+      </list>
+    </option>
+  </component>
+  <component name="ProjectFrameBounds">
+    <option name="x" value="1721" />
+    <option name="y" value="53" />
+    <option name="width" value="1218" />
+    <option name="height" value="928" />
+  </component>
+  <component name="ProjectLevelVcsManager" settingsEditedManually="false">
+    <OptionsSetting value="true" id="Add" />
+    <OptionsSetting value="true" id="Remove" />
+    <OptionsSetting value="true" id="Checkout" />
+    <OptionsSetting value="true" id="Update" />
+    <OptionsSetting value="true" id="Status" />
+    <OptionsSetting value="true" id="Edit" />
+    <ConfirmationsSetting value="0" id="Add" />
+    <ConfirmationsSetting value="0" id="Remove" />
+  </component>
+  <component name="ProjectReloadState">
+    <option name="STATE" value="0" />
+  </component>
+  <component name="ProjectView">
+    <navigator currentView="ProjectPane" proportions="" version="1" splitterProportion="0.5">
+      <flattenPackages />
+      <showMembers />
+      <showModules />
+      <showLibraryContents />
+      <hideEmptyPackages />
+      <abbreviatePackageNames />
+      <autoscrollToSource />
+      <autoscrollFromSource />
+      <sortByType />
+    </navigator>
+    <panes>
+      <pane id="Scope">
+        <subPane subId="Project Files">
+          <PATH>
+            <PATH_ELEMENT USER_OBJECT="Root">
+              <option name="myItemId" value="" />
+              <option name="myItemType" value="" />
+            </PATH_ELEMENT>
+          </PATH>
+        </subPane>
+      </pane>
+      <pane id="PackagesPane">
+        <subPane>
+          <PATH>
+            <PATH_ELEMENT>
+              <option name="myItemId" value="MapGuideApiExTest" />
+              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.PackageViewProjectNode" />
+            </PATH_ELEMENT>
+            <PATH_ELEMENT>
+              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.PackageViewModuleNode" />
+            </PATH_ELEMENT>
+          </PATH>
+        </subPane>
+      </pane>
+      <pane id="ProjectPane">
+        <subPane>
+          <PATH>
+            <PATH_ELEMENT>
+              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.ProjectViewProjectNode" />
+            </PATH_ELEMENT>
+            <PATH_ELEMENT>
+              <option name="myItemId" value="External Libraries" />
+              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.ExternalLibrariesNode" />
+            </PATH_ELEMENT>
+          </PATH>
+          <PATH>
+            <PATH_ELEMENT>
+            </PATH_ELEMENT>
+            <PATH_ELEMENT>
+            </PATH_ELEMENT>
+            <PATH_ELEMENT>
+              <option name="myItemId" value="MapGuideApiEx.jar" />
+              <option name="myItemType" value="com.intellij.ide.projectView.impl.nodes.PsiDirectoryNode" />
+            </PATH_ELEMENT>
+            <PATH_ELEMENT>
+              <option name="myItemId" value="mapguide" />
+            </PATH_ELEMENT>
+          </PATH>
+          <PATH>
+            <PATH_ELEMENT>
+            </PATH_ELEMENT>
+            <PATH_ELEMENT>
+            </PATH_ELEMENT>
+            <PATH_ELEMENT>
+            </PATH_ELEMENT>
+          </PATH>
+          <PATH>
+            <PATH_ELEMENT>
+            </PATH_ELEMENT>
+          </PATH>
+        </subPane>
+      </pane>
+    </panes>
+  </component>
+  <component name="PropertiesComponent">
+    <property name="GoToFile.includeJavaFiles" value="false" />
+    <property name="project.structure.last.edited" value="Modules" />
+    <property name="project.structure.proportion" value="0.15" />
+    <property name="options.splitter.main.proportions" value="0.3" />
+    <property name="MemberChooser.sorted" value="false" />
+    <property name="recentsLimit" value="5" />
+    <property name="options.lastSelected" value="reference.projectsettings.compiler.javacompiler" />
+    <property name="project.structure.side.proportion" value="0.2" />
+    <property name="MemberChooser.copyJavadoc" value="false" />
+    <property name="GoToClass.toSaveIncludeLibraries" value="false" />
+    <property name="MemberChooser.showClasses" value="true" />
+    <property name="GoToClass.includeLibraries" value="false" />
+    <property name="dynamic.classpath" value="false" />
+    <property name="options.searchVisible" value="true" />
+    <property name="options.splitter.details.proportions" value="0.2" />
+  </component>
+  <component name="RunManager" selected="Application.Console">
+    <configuration default="true" type="#org.jetbrains.idea.devkit.run.PluginConfigurationType" factoryName="Plugin">
+      <module name="" />
+      <option name="VM_PARAMETERS" value="-Xmx512m -Xms256m -XX:MaxPermSize=250m" />
+      <option name="PROGRAM_PARAMETERS" />
+      <method>
+        <option name="AntTarget" enabled="false" />
+        <option name="BuildArtifacts" enabled="false" />
+        <option name="Make" enabled="true" />
+        <option name="Maven.BeforeRunTask" enabled="false" />
+      </method>
+    </configuration>
+    <configuration default="true" type="Remote" factoryName="Remote">
+      <option name="USE_SOCKET_TRANSPORT" value="true" />
+      <option name="SERVER_MODE" value="false" />
+      <option name="SHMEM_ADDRESS" value="javadebug" />
+      <option name="HOST" value="localhost" />
+      <option name="PORT" value="5005" />
+      <method>
+      </method>
+    </configuration>
+    <configuration default="true" type="Applet" factoryName="Applet">
+      <option name="MAIN_CLASS_NAME" />
+      <option name="HTML_FILE_NAME" />
+      <option name="HTML_USED" value="false" />
+      <option name="WIDTH" value="400" />
+      <option name="HEIGHT" value="300" />
+      <option name="POLICY_FILE" value="$APPLICATION_HOME_DIR$/bin/appletviewer.policy" />
+      <option name="VM_PARAMETERS" />
+      <option name="ALTERNATIVE_JRE_PATH_ENABLED" value="false" />
+      <option name="ALTERNATIVE_JRE_PATH" />
+      <method>
+      </method>
+    </configuration>
+    <configuration default="true" type="TestNG" factoryName="TestNG">
+      <option name="SUITE_NAME" />
+      <option name="PACKAGE_NAME" />
+      <option name="METHOD_NAME" />
+      <option name="GROUP_NAME" />
+      <option name="TEST_OBJECT" value="CLASS" />
+      <option name="VM_PARAMETERS" value="-ea" />
+      <option name="PARAMETERS" />
+      <option name="WORKING_DIRECTORY" value="$PROJECT_DIR$" />
+      <option name="OUTPUT_DIRECTORY" />
+      <option name="ANNOTATION_TYPE" />
+      <option name="ENV_VARIABLES" />
+      <option name="PASS_PARENT_ENVS" value="true" />
+      <option name="TEST_SEARCH_SCOPE">
+        <value defaultName="moduleWithDependencies" />
+      </option>
+      <option name="USE_DEFAULT_REPORTERS" value="false" />
+      <option name="PROPERTIES_FILE" />
+      <envs />
+      <properties />
+      <listeners />
+      <method>
+      </method>
+    </configuration>
+    <configuration default="true" type="Application" factoryName="Application">
+      <option name="MAIN_CLASS_NAME" value="MapGuideApiTest" />
+      <option name="VM_PARAMETERS" value="" />
+      <option name="PROGRAM_PARAMETERS" value="" />
+      <option name="WORKING_DIRECTORY" value="file://$PROJECT_DIR$/../../../Web/bin/release" />
+      <option name="ALTERNATIVE_JRE_PATH" value="" />
+      <option name="ENABLE_SWING_INSPECTOR" value="false" />
+      <envs />
+      <method>
+      </method>
+    </configuration>
+    <configuration default="true" type="JUnit" factoryName="JUnit">
+      <option name="TEST_OBJECT" value="class" />
+      </option>
+      <envs />
+      <patterns />
+      <method>
+      </method>
+    </configuration>
+    <configuration default="false" name="Console" type="Application" factoryName="Application">
+      <module name="MapGuideApiExTest" />
+      <envs />
+      <RunnerSettings RunnerId="Debug">
+        <option name="DEBUG_PORT" value="" />
+        <option name="TRANSPORT" value="0" />
+        <option name="LOCAL" value="true" />
+      </RunnerSettings>
+      <RunnerSettings RunnerId="Run" />
+      <ConfigurationWrapper RunnerId="Debug" />
+      <ConfigurationWrapper RunnerId="Run" />
+      <method />
+    </configuration>
+    <list size="1">
+      <item index="0" class="java.lang.String" itemvalue="Application.Console" />
+    </list>
+    <configuration name="<template>" type="WebApp" default="true" selected="false">
+      <Host>localhost</Host>
+      <Port>5050</Port>
+    </configuration>
+  </component>
+  <component name="ShelveChangesManager" show_recycled="false" />
+  <component name="TaskManager">
+    <task active="true" id="Default" summary="Default task">
+      <changelist id="f24f429b-81bb-475f-9057-46f372ac8279" name="Default" comment="" />
+      <created>1353932158797</created>
+      <updated>1353932158797</updated>
+    </task>
+    <servers />
+  </component>
+  <component name="ToolWindowManager">
+    <frame x="1721" y="53" width="1218" height="928" extended-state="0" />
+    <editor active="false" />
+    <layout>
+      <window_info id="Changes" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="7" side_tool="false" content_ui="tabs" />
+      <window_info id="JetGradle" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" />
+      <window_info id="Palette" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" />
+      <window_info id="Ant Build" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.25" sideWeight="0.5" order="1" side_tool="false" content_ui="tabs" />
+      <window_info id="Debug" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.3484163" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" />
+      <window_info id="Event Log" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="7" side_tool="true" content_ui="tabs" />
+      <window_info id="Favorites" active="false" anchor="left" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="2" side_tool="true" content_ui="tabs" />
+      <window_info id="Version Control" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="7" side_tool="false" content_ui="tabs" />
+      <window_info id="Messages" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="7" side_tool="false" content_ui="tabs" />
+      <window_info id="TODO" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="6" side_tool="false" content_ui="tabs" />
+      <window_info id="Structure" active="false" anchor="left" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="true" weight="0.23243712" sideWeight="0.6049223" order="1" side_tool="true" content_ui="tabs" />
+      <window_info id="Maven Projects" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" />
+      <window_info id="Commander" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.4" sideWeight="0.5" order="0" side_tool="false" content_ui="tabs" />
+      <window_info id="Project" active="false" anchor="left" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="true" weight="0.23243712" sideWeight="0.059585493" order="0" side_tool="false" content_ui="combo" />
+      <window_info id="Run" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.32642487" sideWeight="0.5" order="2" side_tool="false" content_ui="tabs" />
+      <window_info id="Documentation" active="false" anchor="right" auto_hide="true" internal_type="DOCKED" type="FLOATING" visible="false" weight="0.32928944" sideWeight="0.5" order="3" side_tool="false" content_ui="tabs" x="839" y="583" width="636" height="307" />
+      <window_info id="Cvs" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.25" sideWeight="0.5" order="4" side_tool="false" content_ui="tabs" />
+      <window_info id="Message" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="0" side_tool="false" content_ui="tabs" />
+      <window_info id="Find" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.33" sideWeight="0.5" order="1" side_tool="false" content_ui="tabs" />
+      <window_info id="Hierarchy" active="false" anchor="right" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.25" sideWeight="0.5" order="2" side_tool="false" content_ui="combo" />
+      <window_info id="Inspection" active="false" anchor="bottom" auto_hide="false" internal_type="DOCKED" type="DOCKED" visible="false" weight="0.4" sideWeight="0.5" order="5" side_tool="false" content_ui="tabs" />
+    </layout>
+  </component>
+  <component name="VcsContentAnnotationSettings">
+    <option name="myLimit" value="2678400000" />
+  </component>
+  <component name="VcsManagerConfiguration">
+    <option name="OFFER_MOVE_TO_ANOTHER_CHANGELIST_ON_PARTIAL_COMMIT" value="true" />
+    <option name="CHECK_CODE_SMELLS_BEFORE_PROJECT_COMMIT" value="true" />
+    <option name="CHECK_NEW_TODO" value="true" />
+    <option name="myTodoPanelSettings">
+      <value>
+        <are-packages-shown value="false" />
+        <are-modules-shown value="false" />
+        <flatten-packages value="false" />
+        <is-autoscroll-to-source value="false" />
+      </value>
+    </option>
+    <option name="PERFORM_UPDATE_IN_BACKGROUND" value="true" />
+    <option name="PERFORM_COMMIT_IN_BACKGROUND" value="true" />
+    <option name="PERFORM_EDIT_IN_BACKGROUND" value="true" />
+    <option name="PERFORM_CHECKOUT_IN_BACKGROUND" value="true" />
+    <option name="PERFORM_ADD_REMOVE_IN_BACKGROUND" value="true" />
+    <option name="PERFORM_ROLLBACK_IN_BACKGROUND" value="false" />
+    <option name="CHECK_LOCALLY_CHANGED_CONFLICTS_IN_BACKGROUND" value="false" />
+    <option name="ENABLE_BACKGROUND_PROCESSES" value="false" />
+    <option name="CHANGED_ON_SERVER_INTERVAL" value="60" />
+    <option name="SHOW_ONLY_CHANGED_IN_SELECTION_DIFF" value="true" />
+    <option name="CHECK_COMMIT_MESSAGE_SPELLING" value="true" />
+    <option name="DEFAULT_PATCH_EXTENSION" value="patch" />
+    <option name="SHORT_DIFF_HORISONTALLY" value="true" />
+    <option name="SHORT_DIFF_EXTRA_LINES" value="2" />
+    <option name="SOFT_WRAPS_IN_SHORT_DIFF" value="true" />
+    <option name="INCLUDE_TEXT_INTO_PATCH" value="false" />
+    <option name="INCLUDE_TEXT_INTO_SHELF" value="false" />
+    <option name="CREATE_PATCH_EXPAND_DETAILS_DEFAULT" value="true" />
+    <option name="SHOW_FILE_HISTORY_DETAILS" value="true" />
+    <option name="SHOW_VCS_ERROR_NOTIFICATIONS" value="true" />
+    <option name="FORCE_NON_EMPTY_COMMENT" value="false" />
+    <option name="CLEAR_INITIAL_COMMIT_MESSAGE" value="false" />
+    <option name="LAST_COMMIT_MESSAGE" />
+    <option name="MAKE_NEW_CHANGELIST_ACTIVE" value="false" />
+    <option name="OPTIMIZE_IMPORTS_BEFORE_PROJECT_COMMIT" value="false" />
+    <option name="CHECK_FILES_UP_TO_DATE_BEFORE_COMMIT" value="false" />
+    <option name="REFORMAT_BEFORE_PROJECT_COMMIT" value="false" />
+    <option name="REFORMAT_BEFORE_FILE_COMMIT" value="false" />
+    <option name="FILE_HISTORY_DIALOG_COMMENTS_SPLITTER_PROPORTION" value="0.8" />
+    <option name="FILE_HISTORY_DIALOG_SPLITTER_PROPORTION" value="0.5" />
+    <option name="ACTIVE_VCS_NAME" />
+    <option name="UPDATE_GROUP_BY_PACKAGES" value="false" />
+    <option name="UPDATE_GROUP_BY_CHANGELIST" value="false" />
+    <option name="SHOW_FILE_HISTORY_AS_TREE" value="false" />
+    <option name="FILE_HISTORY_SPLITTER_PROPORTION" value="0.6" />
+  </component>
+  <component name="XDebuggerManager">
+    <breakpoint-manager />
+  </component>
+  <component name="antWorkspaceConfiguration">
+    <option name="IS_AUTOSCROLL_TO_SOURCE" value="false" />
+    <option name="FILTER_TARGETS" value="false" />
+  </component>
+  <component name="editorHistoryManager">
+    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MapGuideJavaApiExJNI.java">
+        <state line="2904" column="0" selection-start="270715" selection-end="270715" vertical-scroll-proportion="0.0" />
+      </provider>
+    </entry>
+    <entry file="file://$PROJECT_DIR$/src/AssertException.java">
+        <state line="12" column="54" selection-start="284" selection-end="284" vertical-scroll-proportion="0.0" />
+      </provider>
+    </entry>
+    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgSerializable.java">
+        <state line="22" column="67" selection-start="712" selection-end="712" vertical-scroll-proportion="0.32258064" />
+      </provider>
+    </entry>
+    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgNamedSerializable.java">
+        <state line="16" column="50" selection-start="516" selection-end="516" vertical-scroll-proportion="0.32258064" />
+      </provider>
+    </entry>
+    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/lang/String.java">
+        <state line="1004" column="0" selection-start="38011" selection-end="38011" vertical-scroll-proportion="0.03307393" />
+      </provider>
+    </entry>
+    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/lang/StringBuilder.java">
+        <state line="429" column="0" selection-start="12939" selection-end="12939" vertical-scroll-proportion="0.032258064" />
+      </provider>
+    </entry>
+    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/lang/ClassLoader.java">
+        <state line="322" column="0" selection-start="11967" selection-end="11967" vertical-scroll-proportion="0.24408014" />
+      </provider>
+    </entry>
+    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/lang/Object.java">
+        <state line="133" column="0" selection-start="6113" selection-end="6113" vertical-scroll-proportion="0.0" />
+      </provider>
+    </entry>
+    <entry file="jar://C:/Program Files (x86)/Java/jdk1.6.0_33/src.zip!/java/util/ArrayList.java">
+        <state line="215" column="0" selection-start="8342" selection-end="8342" vertical-scroll-proportion="0.0" />
+      </provider>
+    </entry>
+    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgFeatureSchemaCollection.java">
+        <state line="210" column="26" selection-start="6412" selection-end="6412" vertical-scroll-proportion="0.0" />
+      </provider>
+    </entry>
+    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgFeatureSchema.java">
+        <state line="79" column="51" selection-start="2059" selection-end="2059" vertical-scroll-proportion="0.60830325" />
+      </provider>
+    </entry>
+    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgByteProperty.java">
+        <state line="16" column="14" selection-start="491" selection-end="491" vertical-scroll-proportion="-0.6895943" />
+      </provider>
+    </entry>
+    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgBatchPropertyCollection.java">
+        <state line="116" column="0" selection-start="3461" selection-end="3461" vertical-scroll-proportion="0.33212996" />
+      </provider>
+    </entry>
+    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgPropertyDefinitionCollection.java">
+        <state line="248" column="13" selection-start="7649" selection-end="7649" vertical-scroll-proportion="0.33212996" />
+      </provider>
+    </entry>
+    <entry file="jar://$PROJECT_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/org/osgeo/mapguide/MgLayerCollection.java">
+        <state line="172" column="71" selection-start="4032" selection-end="4922" vertical-scroll-proportion="0.6502732" />
+      </provider>
+    </entry>
+        <state line="1227" column="57" selection-start="58790" selection-end="58790" vertical-scroll-proportion="0.9583333" />
+      </provider>
+    </entry>
+  </component>
+  <component name="masterDetails">
+    <states>
+      <state key="ArtifactsStructureConfigurable.UI">
+        <settings>
+          <artifact-editor />
+          <splitter-proportions>
+            <option name="proportions">
+              <list>
+                <option value="0.2" />
+              </list>
+            </option>
+          </splitter-proportions>
+        </settings>
+      </state>
+      <state key="FacetStructureConfigurable.UI">
+        <settings>
+          <last-edited>No facets are configured</last-edited>
+              <list>
+              </list>
+            </option>
+        </settings>
+      </state>
+      <state key="GlobalLibrariesConfigurable.UI">
+        <settings>
+              <list>
+              </list>
+            </option>
+        </settings>
+      </state>
+      <state key="JdkListConfigurable.UI">
+        <settings>
+          <last-edited>1.6</last-edited>
+              <list>
+              </list>
+            </option>
+        </settings>
+      </state>
+      <state key="ModuleStructureConfigurable.UI">
+        <settings>
+          <last-edited>MapGuideApiExTest</last-edited>
+              <list>
+              </list>
+            </option>
+        </settings>
+      </state>
+      <state key="ProjectJDKs.UI">
+        <settings>
+              <list>
+              </list>
+            </option>
+        </settings>
+      </state>
+      <state key="ProjectLibrariesConfigurable.UI">
+        <settings>
+              <list>
+              </list>
+            </option>
+        </settings>
+      </state>
+    </states>
+  </component>
+</project>
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/MapGuideApiExTest.iml
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/MapGuideApiExTest.iml	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/MapGuideApiExTest.iml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,23 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<module type="JAVA_MODULE" version="4">
-  <component name="NewModuleRootManager" inherit-compiler-output="true">
-    <exclude-output />
-    <content url="file://$MODULE_DIR$">
-      <sourceFolder url="file://$MODULE_DIR$/src" isTestSource="false" />
-    </content>
-    <orderEntry type="jdk" jdkName="1.6" jdkType="JavaSDK" />
-    <orderEntry type="sourceFolder" forTests="false" />
-    <orderEntry type="module-library" exported="">
-      <library>
-        <CLASSES>
-          <root url="jar://$MODULE_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx.jar!/" />
-        </CLASSES>
-        <JAVADOC />
-        <SOURCES>
-          <root url="jar://$MODULE_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/" />
-        </SOURCES>
-      </library>
-    </orderEntry>
-  </component>
-</module>
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/MapGuideApiExTest.iml (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/MapGuideApiExTest.iml)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/MapGuideApiExTest.iml	                        (rev 0)
@@ -0,0 +1,23 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<module type="JAVA_MODULE" version="4">
+  <component name="NewModuleRootManager" inherit-compiler-output="true">
+    <exclude-output />
+    <content url="file://$MODULE_DIR$">
+      <sourceFolder url="file://$MODULE_DIR$/src" isTestSource="false" />
+    </content>
+    <orderEntry type="jdk" jdkName="1.6" jdkType="JavaSDK" />
+    <orderEntry type="sourceFolder" forTests="false" />
+    <orderEntry type="module-library" exported="">
+      <library>
+        <CLASSES>
+          <root url="jar://$MODULE_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx.jar!/" />
+        </CLASSES>
+        <JAVADOC />
+        <SOURCES>
+          <root url="jar://$MODULE_DIR$/../../../Web/src/WEB-INF/lib/MapGuideApiEx-sources.jar!/" />
+        </SOURCES>
+      </library>
+    </orderEntry>
+  </component>
+</module>
Property changes on: trunk/MgDev/UnitTest/Common/JavaApiExTest/src
___________________________________________________________________
Added: bugtraq:number
   + true
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/src/AssertException.java
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/src/AssertException.java	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/src/AssertException.java	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,12 +0,0 @@
- * Created with IntelliJ IDEA.
- * User: Jackie Ng
- * Date: 26/11/12
- * Time: 11:46 PM
- * To change this template use File | Settings | File Templates.
-public class AssertException extends RuntimeException {
-    public AssertException(String msg) {
-        super(msg);
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/src/AssertException.java (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/src/AssertException.java)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/src/AssertException.java	                        (rev 0)
@@ -0,0 +1,12 @@
+ * Created with IntelliJ IDEA.
+ * User: Jackie Ng
+ * Date: 26/11/12
+ * Time: 11:46 PM
+ * To change this template use File | Settings | File Templates.
+public class AssertException extends RuntimeException {
+    public AssertException(String msg) {
+        super(msg);
Deleted: trunk/MgDev/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,1245 +0,0 @@
- * User: Jackie Ng
- * Date: 26/11/12
- * Time: 11:37 PM
-import org.osgeo.mapguide.*;
-import java.util.ArrayList;
-import java.util.Collection;
-import java.util.List;
- * This test harness is to exercise the java.util.Collection implementation of the MapGuide proxy classes that implement it
- * and the common usage scenarios involving them
-public class MapGuideApiTest {
-    static List<AssertException> assertFailures;
-    static String sessionId;
-    static String mapName;
-    public static void main(String [] args) {
-        assertFailures = new ArrayList<AssertException>();
-        if (args.length == 1) {
-            MapGuideJavaApiEx.MgInitializeWebTier(args[0]);
-        } else {
-            if (System.getProperty("os.name").startsWith("Windows")) {
-                MapGuideJavaApiEx.MgInitializeWebTier("C:\\Program Files\\OSGeo\\MapGuide\\Web\\www\\webconfig.ini");
-            } else {
-                MapGuideJavaApiEx.MgInitializeWebTier("/usr/local/mapguideopensource/webserverextensions/www/webconfig.ini");
-        MgUserInformation userInfo = new MgUserInformation("Administrator", "admin");
-        MgSiteConnection siteConn = new MgSiteConnection();
-        siteConn.open(userInfo);
-        MgSite site = siteConn.getSite();
-        sessionId = site.createSession();
-        userInfo.setMgSessionId(sessionId);
-        MgMap map = new MgMap(siteConn);
-        MgResourceService resSvc = (MgResourceService)siteConn.createService(MgServiceType.ResourceService);
-        MgResourceIdentifier mdfId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
-        mapName = mdfId.getName();
-        map.create(mdfId, mapName);
-        MgSelection sel = new MgSelection(map);
-        sel.save(resSvc, mapName);
-        MgResourceIdentifier mapStateId = new MgResourceIdentifier("Session:" + sessionId + "//" + mapName + "." + MgResourceType.Map);
-        map.save(resSvc, mapStateId);
-        System.out.println("Running tests");
-        runTests(siteConn, map);
-        System.exit(assertFailures.size());
-    private static void assertCondition(boolean condition, String failureMsg) {
-        if (!condition)
-            throw new AssertException(failureMsg);
-    private static void runTests(MgSiteConnection siteConn, MgMap map) {
-        System.out.print(testFeatureSchemaCollection() ? "." : "F");
-        System.out.print(testClassDefinitionCollection() ? "." : "F");
-        System.out.print(testPropertyDefinitionCollection() ? "." : "F");
-        System.out.print(testPropertyCollection() ? "." : "F");
-        System.out.print(testStringCollection() ? "." : "F");
-        System.out.print(testReadOnlyLayerCollection(siteConn, map) ? "." : "F");
-        System.out.print(testLayerCollection(siteConn, map) ? "." : "F");
-        System.out.print(testLayerGroupCollection(siteConn, map) ? "." : "F");
-        System.out.println();
-        if (assertFailures.size() > 0) {
-            int i = 1;
-            for (AssertException ex : assertFailures) {
-                System.out.println("Assertion Failure: " + i);
-                ex.printStackTrace(System.out);
-                i++;
-    private static boolean testReadOnlyLayerCollection(MgSiteConnection siteConn, MgMap map) {
-        try {
-            MgFeatureQueryOptions query1 = new MgFeatureQueryOptions();
-            query1.setFilter("Autogenerated_SDF_ID < 4");
-            MgFeatureQueryOptions query2 = new MgFeatureQueryOptions();
-            query2.setFilter("Autogenerated_SDF_ID < 4");
-            MgLayerCollection layers = map.getLayers();
-            MgLayerBase item1 = layers.getItem("Parcels");
-            MgLayerBase item2 = layers.getItem("Buildings");
-            MgFeatureReader fr1 = item1.selectFeatures(query1);
-            MgFeatureReader fr2 = item2.selectFeatures(query2);
-            sel.open(resSvc, map.getName());
-            sel.fromXml(""); //Clear
-            try {
-                sel.addFeatures(item1, fr1, 0);
-                sel.addFeatures(item2, fr2, 0);
-            } finally{
-                fr1.close();
-                fr2.close();
-            sel.save(resSvc);
-            //Now we can test the collection
-            MgReadOnlyLayerCollection items = sel.getLayers();
-            assertCondition(items.getCount() == 2, "Expected 2 items");
-            //NOTE: Possible bug in ordering of MgReadOnlyLayerCollection here (I had to reverse the order of layers
-            //being tested) Nevertheless, were testing that the ordering (whether correct or not) is the same when iterated
-            //in both the classical and iterative methods
-            int i = 0;
-            //Looping the classic way
-            for (i = 0; i < items.getCount(); i++) {
-                switch (i){
-                    case 0:
-                        assertCondition(items.getItem(i).getName().equals("Buildings"), "Expected item #" + (i+1) + " to be Buildings");
-                        break;
-                    case 1:
-                        assertCondition(items.getItem(i).getName().equals("Parcels"), "Expected item #" + (i+1) + " to be Parcels");
-                        break;
-            //Looping the iterative way
-            i = 0;
-            for (MgLayerBase item : items) {
-                String itemName = item.getName();
-                switch (i){
-                    case 0:
-                        assertCondition(itemName.equals("Buildings"), "Expected item #" + (i+1) + " to be Buildings");
-                        break;
-                    case 1:
-                        assertCondition(itemName.equals("Parcels"), "Expected item #" + (i+1) + " to be Parcels");
-                        break;
-                i++;
-            return true;
-        catch (MgException ex) {
-            assertCondition(false, ex.getMessage());
-        catch (AssertException ex) {
-            assertFailures.add(ex);
-        return false;
-    private static boolean testStringCollection() {
-        try {
-            MgStringCollection items = new MgStringCollection();
-            String item1 = "Item1";
-            String item2 = "Item2";
-            String item3 = "Item3";
-            String item4 = "Item4";
-            //Items inserted the MapGuide API way
-            items.addItem(item1);
-            items.addItem(item2);
-            items.addItem(item3);
-            assertCondition(items.getCount() == 3, "Expected 3 items");
-            assertCondition(!items.isEmpty(), "Expected non-empty item collection");
-            int i = 0;
-                switch (i){
-                    case 0:
-                        assertCondition(items.getItem(i).equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
-                        break;
-                    case 1:
-                        assertCondition(items.getItem(i).equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
-                        break;
-                    case 2:
-                        assertCondition(items.getItem(i).equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
-                        break;
-            i = 0;
-            for (String item : items) {
-                String itemName = item;
-                switch (i){
-                    case 0:
-                        assertCondition(itemName.equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
-                        break;
-                    case 1:
-                        assertCondition(itemName.equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
-                        break;
-                    case 2:
-                        assertCondition(itemName.equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
-                        break;
-                i++;
-            items.clear();
-            assertCondition(items.getCount() == 0, "Expected empty item collection");
-            assertCondition(items.isEmpty(), "Expected empty item collection");
-            //Now test through java.util.Collection facade
-            Collection<String> facade = items;
-            //add()
-            assertCondition(facade.add(item1), "Could not add item1 the java.util.Collection way");
-            assertCondition(facade.add(item2), "Could not add item2 the java.util.Collection way");
-            assertCondition(facade.add(item3), "Could not add item3 the java.util.Collection way");
-            assertCondition(facade.size() == 3, "Expected 3 items");
-            assertCondition(!facade.isEmpty(), "Expected non-empty item collection");
-            //contains()
-            assertCondition(facade.contains(item1), "item1 should exist");
-            assertCondition(facade.contains(item2), "item2 should exist");
-            assertCondition(facade.contains(item3), "item3 should exist");
-            ArrayList<String> testCollection = new ArrayList<String>();
-            testCollection.add(item1);
-            testCollection.add(item2);
-            testCollection.add(item3);
-            //containsAll()
-            assertCondition(facade.containsAll(testCollection), "All items in test collection should match");
-            testCollection.clear();
-            testCollection.add(item4);
-            assertCondition(!facade.containsAll(testCollection), "Should not have matched test collection");
-            facade.clear();
-            assertCondition(facade.size() == 0, "Expected 0 items");
-            assertCondition(facade.isEmpty(), "Expected empty item collection");
-            //addAll()
-            assertCondition(facade.addAll(testCollection), "Expected addAll() success");
-            //remove()
-            assertCondition(!facade.remove(item4), "Expected remove() of non-existent item to return false");
-            assertCondition(!facade.remove(new MgClassDefinition()), "Expected remove() of different type to return false");
-            assertCondition(facade.remove(item2), "Expected remove() of item2 to return true");
-            //removeAll()
-            testCollection.remove(item2);
-            assertCondition(facade.removeAll(testCollection), "Expected removeAll() to succeed");
-            //retainAll()
-            assertCondition(facade.size() == 3, "Expected 3 schemas");
-            assertCondition(!facade.isEmpty(), "Expected non-empty schema collection");
-            assertCondition(facade.retainAll(testCollection), "Expected retainAll() to succeed");
-            assertCondition(facade.contains(item1), "Expected item1 to exist");
-            assertCondition(!facade.contains(item2), "Expected item2 to not exist");
-            assertCondition(facade.contains(item3), "Expected item3 to exist");
-            //toArray()
-            Object[] itemArray = facade.toArray();
-            assertCondition(itemArray != null, "Expected non-null item array");
-            assertCondition(itemArray.length == 2, "Expected 2 item array");
-            for (Object o : itemArray) {
-                assertCondition(o instanceof String, "Expected item to be String");
-            String[] fitems = facade.toArray(new String[0]);
-            assertCondition(fitems != null, "Expected non-null item array");
-            assertCondition(fitems.length == 2, "Expected 2 item array");
-            fitems = facade.toArray(new String[1]);
-            fitems = facade.toArray(new String[3]);
-            assertCondition(fitems.length == 3, "Expected 3 item array");
-            assertCondition(fitems[0] != null, "Expected non-null item #1");
-            assertCondition(fitems[1] != null, "Expected non-null item #2");
-            assertCondition(fitems[2] == null, "Expected null item #3");
-            return true;
-        return false;
-    private static boolean testPropertyCollection() {
-        try {
-            MgPropertyCollection items = new MgPropertyCollection();
-            MgProperty item1 = new MgStringProperty("Item1", "Hello World");
-            MgProperty item2 = new MgInt32Property("Item2", 42);
-            MgProperty item3 = new MgBooleanProperty("Item3", false);
-            MgProperty item4 = new MgByteProperty("Item4", (short)4);
-            int i = 0;
-                switch (i){
-                    case 0:
-                        assertCondition(items.getItem(i).getName().equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
-                        break;
-                    case 1:
-                        assertCondition(items.getItem(i).getName().equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
-                        break;
-                    case 2:
-                        assertCondition(items.getItem(i).getName().equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
-                        break;
-            i = 0;
-            for (MgProperty item : items) {
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-                i++;
-            items.clear();
-            Collection<MgProperty> facade = items;
-            //add()
-            //contains()
-            ArrayList<MgProperty> testCollection = new ArrayList<MgProperty>();
-            //containsAll()
-            facade.clear();
-            //addAll()
-            //remove()
-            //removeAll()
-            //retainAll()
-            //toArray()
-            i = 0;
-                assertCondition(o instanceof MgProperty, "Expected item to be MgProperty");
-                switch(i) {
-                    case 0:
-                        assertCondition(o instanceof MgStringProperty, "Expected item to be MgStringProperty");
-                        break;
-                    case 1:
-                        assertCondition(o instanceof MgBooleanProperty, "Expected item to be MgBooleanProperty");
-                        break;
-                i++;
-            MgProperty[] fitems = facade.toArray(new MgProperty[0]);
-            fitems = facade.toArray(new MgProperty[1]);
-            fitems = facade.toArray(new MgProperty[3]);
-            return true;
-        return false;
-    private static boolean testClassDefinitionCollection() {
-        try {
-            MgFeatureSchema parent = new MgFeatureSchema("Parent", "");
-            MgClassDefinitionCollection items = parent.getClasses();
-            MgClassDefinition item1 = new MgClassDefinition(); item1.setName("Item1");
-            MgClassDefinition item2 = new MgClassDefinition(); item2.setName("Item2");
-            MgClassDefinition item3 = new MgClassDefinition(); item3.setName("Item3");
-            MgClassDefinition item4 = new MgClassDefinition(); item4.setName("Item4");
-            int i = 0;
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-            i = 0;
-            for (MgClassDefinition item : items) {
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-                i++;
-            items.clear();
-            Collection<MgClassDefinition> facade = items;
-            //add()
-            //contains()
-            ArrayList<MgClassDefinition> testCollection = new ArrayList<MgClassDefinition>();
-            //containsAll()
-            facade.clear();
-            //addAll()
-            //remove()
-            assertCondition(!facade.remove(new MgFeatureSchema()), "Expected remove() of different type to return false");
-            //removeAll()
-            //retainAll()
-            //toArray()
-                assertCondition(o instanceof MgClassDefinition, "Expected item to be MgClassDefinition");
-            MgClassDefinition[] fitems = facade.toArray(new MgClassDefinition[0]);
-            fitems = facade.toArray(new MgClassDefinition[1]);
-            fitems = facade.toArray(new MgClassDefinition[3]);
-            return true;
-        return false;
-    private static boolean testFeatureSchemaCollection() {
-        try {
-            MgFeatureSchemaCollection items = new MgFeatureSchemaCollection();
-            MgFeatureSchema item1 = new MgFeatureSchema("Item1", "");
-            MgFeatureSchema item2 = new MgFeatureSchema("Item2", "");
-            MgFeatureSchema item3 = new MgFeatureSchema("Item3", "");
-            MgFeatureSchema item4 = new MgFeatureSchema("Item4", "");
-            int i = 0;
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-            i = 0;
-            for (MgFeatureSchema item : items) {
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-                i++;
-            items.clear();
-            Collection<MgFeatureSchema> facade = items;
-            //add()
-            //contains()
-            ArrayList<MgFeatureSchema> testCollection = new ArrayList<MgFeatureSchema>();
-            //containsAll()
-            facade.clear();
-            //addAll()
-            //remove()
-            //removeAll()
-            //retainAll()
-            //toArray()
-                assertCondition(o instanceof MgFeatureSchema, "Expected item to be MgFeatureSchema");
-            MgFeatureSchema[] fitems = facade.toArray(new MgFeatureSchema[0]);
-            fitems = facade.toArray(new MgFeatureSchema[1]);
-            fitems = facade.toArray(new MgFeatureSchema[3]);
-            return true;
-        return false;
-    private static boolean testPropertyDefinitionCollection() {
-        try {
-            MgClassDefinition parent = new MgClassDefinition();
-            parent.setName("Parent");
-            MgPropertyDefinitionCollection items = parent.getProperties();
-            MgPropertyDefinition item1 = new MgDataPropertyDefinition("Item1");
-            MgPropertyDefinition item2 = new MgDataPropertyDefinition("Item2");
-            MgPropertyDefinition item3 = new MgDataPropertyDefinition("Item3");
-            MgPropertyDefinition item4 = new MgDataPropertyDefinition("Item4");
-            int i = 0;
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-            i = 0;
-            for (MgPropertyDefinition item : items) {
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-                i++;
-            items.clear();
-            Collection<MgPropertyDefinition> facade = items;
-            //add()
-            //contains()
-            ArrayList<MgPropertyDefinition> testCollection = new ArrayList<MgPropertyDefinition>();
-            //containsAll()
-            facade.clear();
-            //addAll()
-            //remove()
-            //removeAll()
-            //retainAll()
-            //toArray()
-                assertCondition(o instanceof MgPropertyDefinition, "Expected item to be MgPropertyDefinition");
-            MgPropertyDefinition[] fitems = facade.toArray(new MgPropertyDefinition[0]);
-            fitems = facade.toArray(new MgPropertyDefinition[1]);
-            fitems = facade.toArray(new MgPropertyDefinition[3]);
-            return true;
-        return false;
-    private static boolean testLayerCollection(MgSiteConnection siteConn, MgMap map) {
-        try {
-            map.open(mapName);
-            MgLayerCollection items = map.getLayers();
-            items.clear();
-            MgResourceIdentifier ldfId = new MgResourceIdentifier("Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition");
-            MgLayerBase item1 = new MgLayer(ldfId, resSvc);
-            item1.setName("Item1");
-            MgLayerBase item2 = new MgLayer(ldfId, resSvc);
-            item2.setName("Item2");
-            MgLayerBase item3 = new MgLayer(ldfId, resSvc);
-            item3.setName("Item3");
-            MgLayerBase item4 = new MgLayer(ldfId, resSvc);
-            item4.setName("Item4");
-            int i = 0;
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-            i = 0;
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-                i++;
-            items.clear();
-            Collection<MgLayerBase> facade = items;
-            //add()
-            //contains()
-            ArrayList<MgLayerBase> testCollection = new ArrayList<MgLayerBase>();
-            //containsAll()
-            facade.clear();
-            //addAll()
-            //remove()
-            //removeAll()
-            //retainAll()
-            //toArray()
-                assertCondition(o instanceof MgLayerBase, "Expected item to be MgLayerBase");
-            MgLayerBase[] fitems = facade.toArray(new MgLayerBase[0]);
-            fitems = facade.toArray(new MgLayerBase[1]);
-            fitems = facade.toArray(new MgLayerBase[3]);
-            return true;
-        return false;
-    private static boolean testLayerGroupCollection(MgSiteConnection siteConn, MgMap map) {
-        try {
-            MgLayerGroupCollection items = map.getLayerGroups();
-            items.clear();
-            MgLayerGroup item1 = new MgLayerGroup("Item1");
-            MgLayerGroup item2 = new MgLayerGroup("Item2");
-            MgLayerGroup item3 = new MgLayerGroup("Item3");
-            MgLayerGroup item4 = new MgLayerGroup("Item4");
-            int i = 0;
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-            i = 0;
-            for (MgLayerGroup item : items) {
-                switch (i){
-                    case 0:
-                        break;
-                    case 1:
-                        break;
-                    case 2:
-                        break;
-                i++;
-            items.clear();
-            Collection<MgLayerGroup> facade = items;
-            //add()
-            //contains()
-            ArrayList<MgLayerGroup> testCollection = new ArrayList<MgLayerGroup>();
-            //containsAll()
-            facade.clear();
-            //addAll()
-            //remove()
-            //removeAll()
-            //retainAll()
-            //toArray()
-                assertCondition(o instanceof MgLayerGroup, "Expected item to be MgLayerBase");
-            MgLayerGroup[] fitems = facade.toArray(new MgLayerGroup[0]);
-            fitems = facade.toArray(new MgLayerGroup[1]);
-            fitems = facade.toArray(new MgLayerGroup[3]);
-            return true;
-        return false;
Copied: trunk/MgDev/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java (from rev 7251, sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java)
--- trunk/MgDev/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java	                        (rev 0)
@@ -0,0 +1,1245 @@
+ * User: Jackie Ng
+ * Date: 26/11/12
+ * Time: 11:37 PM
+import org.osgeo.mapguide.*;
+import java.util.ArrayList;
+import java.util.Collection;
+import java.util.List;
+ * This test harness is to exercise the java.util.Collection implementation of the MapGuide proxy classes that implement it
+ * and the common usage scenarios involving them
+public class MapGuideApiTest {
+    static List<AssertException> assertFailures;
+    static String sessionId;
+    static String mapName;
+    public static void main(String [] args) {
+        assertFailures = new ArrayList<AssertException>();
+        if (args.length == 1) {
+            MapGuideJavaApiEx.MgInitializeWebTier(args[0]);
+        } else {
+            if (System.getProperty("os.name").startsWith("Windows")) {
+                MapGuideJavaApiEx.MgInitializeWebTier("C:\\Program Files\\OSGeo\\MapGuide\\Web\\www\\webconfig.ini");
+            } else {
+                MapGuideJavaApiEx.MgInitializeWebTier("/usr/local/mapguideopensource/webserverextensions/www/webconfig.ini");
+        MgUserInformation userInfo = new MgUserInformation("Administrator", "admin");
+        MgSiteConnection siteConn = new MgSiteConnection();
+        siteConn.open(userInfo);
+        MgSite site = siteConn.getSite();
+        sessionId = site.createSession();
+        userInfo.setMgSessionId(sessionId);
+        MgMap map = new MgMap(siteConn);
+        MgResourceService resSvc = (MgResourceService)siteConn.createService(MgServiceType.ResourceService);
+        MgResourceIdentifier mdfId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
+        mapName = mdfId.getName();
+        map.create(mdfId, mapName);
+        MgSelection sel = new MgSelection(map);
+        sel.save(resSvc, mapName);
+        MgResourceIdentifier mapStateId = new MgResourceIdentifier("Session:" + sessionId + "//" + mapName + "." + MgResourceType.Map);
+        map.save(resSvc, mapStateId);
+        System.out.println("Running tests");
+        runTests(siteConn, map);
+        System.exit(assertFailures.size());
+    private static void assertCondition(boolean condition, String failureMsg) {
+        if (!condition)
+            throw new AssertException(failureMsg);
+    private static void runTests(MgSiteConnection siteConn, MgMap map) {
+        System.out.print(testFeatureSchemaCollection() ? "." : "F");
+        System.out.print(testClassDefinitionCollection() ? "." : "F");
+        System.out.print(testPropertyDefinitionCollection() ? "." : "F");
+        System.out.print(testPropertyCollection() ? "." : "F");
+        System.out.print(testStringCollection() ? "." : "F");
+        System.out.print(testReadOnlyLayerCollection(siteConn, map) ? "." : "F");
+        System.out.print(testLayerCollection(siteConn, map) ? "." : "F");
+        System.out.print(testLayerGroupCollection(siteConn, map) ? "." : "F");
+        System.out.println();
+        if (assertFailures.size() > 0) {
+            int i = 1;
+            for (AssertException ex : assertFailures) {
+                System.out.println("Assertion Failure: " + i);
+                ex.printStackTrace(System.out);
+                i++;
+    private static boolean testReadOnlyLayerCollection(MgSiteConnection siteConn, MgMap map) {
+        try {
+            MgFeatureQueryOptions query1 = new MgFeatureQueryOptions();
+            query1.setFilter("Autogenerated_SDF_ID < 4");
+            MgFeatureQueryOptions query2 = new MgFeatureQueryOptions();
+            query2.setFilter("Autogenerated_SDF_ID < 4");
+            MgLayerCollection layers = map.getLayers();
+            MgLayerBase item1 = layers.getItem("Parcels");
+            MgLayerBase item2 = layers.getItem("Buildings");
+            MgFeatureReader fr1 = item1.selectFeatures(query1);
+            MgFeatureReader fr2 = item2.selectFeatures(query2);
+            sel.open(resSvc, map.getName());
+            sel.fromXml(""); //Clear
+            try {
+                sel.addFeatures(item1, fr1, 0);
+                sel.addFeatures(item2, fr2, 0);
+            } finally{
+                fr1.close();
+                fr2.close();
+            sel.save(resSvc);
+            //Now we can test the collection
+            MgReadOnlyLayerCollection items = sel.getLayers();
+            assertCondition(items.getCount() == 2, "Expected 2 items");
+            //NOTE: Possible bug in ordering of MgReadOnlyLayerCollection here (I had to reverse the order of layers
+            //being tested) Nevertheless, were testing that the ordering (whether correct or not) is the same when iterated
+            //in both the classical and iterative methods
+            int i = 0;
+            //Looping the classic way
+            for (i = 0; i < items.getCount(); i++) {
+                switch (i){
+                    case 0:
+                        assertCondition(items.getItem(i).getName().equals("Buildings"), "Expected item #" + (i+1) + " to be Buildings");
+                        break;
+                    case 1:
+                        assertCondition(items.getItem(i).getName().equals("Parcels"), "Expected item #" + (i+1) + " to be Parcels");
+                        break;
+            //Looping the iterative way
+            i = 0;
+            for (MgLayerBase item : items) {
+                String itemName = item.getName();
+                switch (i){
+                    case 0:
+                        assertCondition(itemName.equals("Buildings"), "Expected item #" + (i+1) + " to be Buildings");
+                        break;
+                    case 1:
+                        assertCondition(itemName.equals("Parcels"), "Expected item #" + (i+1) + " to be Parcels");
+                        break;
+                i++;
+            return true;
+        catch (MgException ex) {
+            assertCondition(false, ex.getMessage());
+        catch (AssertException ex) {
+            assertFailures.add(ex);
+        return false;
+    private static boolean testStringCollection() {
+        try {
+            MgStringCollection items = new MgStringCollection();
+            String item1 = "Item1";
+            String item2 = "Item2";
+            String item3 = "Item3";
+            String item4 = "Item4";
+            //Items inserted the MapGuide API way
+            items.addItem(item1);
+            items.addItem(item2);
+            items.addItem(item3);
+            assertCondition(items.getCount() == 3, "Expected 3 items");
+            assertCondition(!items.isEmpty(), "Expected non-empty item collection");
+            int i = 0;
+                switch (i){
+                    case 0:
+                        assertCondition(items.getItem(i).equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
+                        break;
+                    case 1:
+                        assertCondition(items.getItem(i).equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
+                        break;
+                    case 2:
+                        assertCondition(items.getItem(i).equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
+                        break;
+            i = 0;
+            for (String item : items) {
+                String itemName = item;
+                switch (i){
+                    case 0:
+                        assertCondition(itemName.equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
+                        break;
+                    case 1:
+                        assertCondition(itemName.equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
+                        break;
+                    case 2:
+                        assertCondition(itemName.equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
+                        break;
+                i++;
+            items.clear();
+            assertCondition(items.getCount() == 0, "Expected empty item collection");
+            assertCondition(items.isEmpty(), "Expected empty item collection");
+            //Now test through java.util.Collection facade
+            Collection<String> facade = items;
+            //add()
+            assertCondition(facade.add(item1), "Could not add item1 the java.util.Collection way");
+            assertCondition(facade.add(item2), "Could not add item2 the java.util.Collection way");
+            assertCondition(facade.add(item3), "Could not add item3 the java.util.Collection way");
+            assertCondition(facade.size() == 3, "Expected 3 items");
+            assertCondition(!facade.isEmpty(), "Expected non-empty item collection");
+            //contains()
+            assertCondition(facade.contains(item1), "item1 should exist");
+            assertCondition(facade.contains(item2), "item2 should exist");
+            assertCondition(facade.contains(item3), "item3 should exist");
+            ArrayList<String> testCollection = new ArrayList<String>();
+            testCollection.add(item1);
+            testCollection.add(item2);
+            testCollection.add(item3);
+            //containsAll()
+            assertCondition(facade.containsAll(testCollection), "All items in test collection should match");
+            testCollection.clear();
+            testCollection.add(item4);
+            assertCondition(!facade.containsAll(testCollection), "Should not have matched test collection");
+            facade.clear();
+            assertCondition(facade.size() == 0, "Expected 0 items");
+            assertCondition(facade.isEmpty(), "Expected empty item collection");
+            //addAll()
+            assertCondition(facade.addAll(testCollection), "Expected addAll() success");
+            //remove()
+            assertCondition(!facade.remove(item4), "Expected remove() of non-existent item to return false");
+            assertCondition(!facade.remove(new MgClassDefinition()), "Expected remove() of different type to return false");
+            assertCondition(facade.remove(item2), "Expected remove() of item2 to return true");
+            //removeAll()
+            testCollection.remove(item2);
+            assertCondition(facade.removeAll(testCollection), "Expected removeAll() to succeed");
+            //retainAll()
+            assertCondition(facade.size() == 3, "Expected 3 schemas");
+            assertCondition(!facade.isEmpty(), "Expected non-empty schema collection");
+            assertCondition(facade.retainAll(testCollection), "Expected retainAll() to succeed");
+            assertCondition(facade.contains(item1), "Expected item1 to exist");
+            assertCondition(!facade.contains(item2), "Expected item2 to not exist");
+            assertCondition(facade.contains(item3), "Expected item3 to exist");
+            //toArray()
+            Object[] itemArray = facade.toArray();
+            assertCondition(itemArray != null, "Expected non-null item array");
+            assertCondition(itemArray.length == 2, "Expected 2 item array");
+            for (Object o : itemArray) {
+                assertCondition(o instanceof String, "Expected item to be String");
+            String[] fitems = facade.toArray(new String[0]);
+            assertCondition(fitems != null, "Expected non-null item array");
+            assertCondition(fitems.length == 2, "Expected 2 item array");
+            fitems = facade.toArray(new String[1]);
+            fitems = facade.toArray(new String[3]);
+            assertCondition(fitems.length == 3, "Expected 3 item array");
+            assertCondition(fitems[0] != null, "Expected non-null item #1");
+            assertCondition(fitems[1] != null, "Expected non-null item #2");
+            assertCondition(fitems[2] == null, "Expected null item #3");
+            return true;
+        return false;
+    private static boolean testPropertyCollection() {
+        try {
+            MgPropertyCollection items = new MgPropertyCollection();
+            MgProperty item1 = new MgStringProperty("Item1", "Hello World");
+            MgProperty item2 = new MgInt32Property("Item2", 42);
+            MgProperty item3 = new MgBooleanProperty("Item3", false);
+            MgProperty item4 = new MgByteProperty("Item4", (short)4);
+            int i = 0;
+                switch (i){
+                    case 0:
+                        assertCondition(items.getItem(i).getName().equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
+                        break;
+                    case 1:
+                        assertCondition(items.getItem(i).getName().equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
+                        break;
+                    case 2:
+                        assertCondition(items.getItem(i).getName().equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
+                        break;
+            i = 0;
+            for (MgProperty item : items) {
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+                i++;
+            items.clear();
+            Collection<MgProperty> facade = items;
+            //add()
+            //contains()
+            ArrayList<MgProperty> testCollection = new ArrayList<MgProperty>();
+            //containsAll()
+            facade.clear();
+            //addAll()
+            //remove()
+            //removeAll()
+            //retainAll()
+            //toArray()
+            i = 0;
+                assertCondition(o instanceof MgProperty, "Expected item to be MgProperty");
+                switch(i) {
+                    case 0:
+                        assertCondition(o instanceof MgStringProperty, "Expected item to be MgStringProperty");
+                        break;
+                    case 1:
+                        assertCondition(o instanceof MgBooleanProperty, "Expected item to be MgBooleanProperty");
+                        break;
+                i++;
+            MgProperty[] fitems = facade.toArray(new MgProperty[0]);
+            fitems = facade.toArray(new MgProperty[1]);
+            fitems = facade.toArray(new MgProperty[3]);
+            return true;
+        return false;
+    private static boolean testClassDefinitionCollection() {
+        try {
+            MgFeatureSchema parent = new MgFeatureSchema("Parent", "");
+            MgClassDefinitionCollection items = parent.getClasses();
+            MgClassDefinition item1 = new MgClassDefinition(); item1.setName("Item1");
+            MgClassDefinition item2 = new MgClassDefinition(); item2.setName("Item2");
+            MgClassDefinition item3 = new MgClassDefinition(); item3.setName("Item3");
+            MgClassDefinition item4 = new MgClassDefinition(); item4.setName("Item4");
+            int i = 0;
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+            i = 0;
+            for (MgClassDefinition item : items) {
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+                i++;
+            items.clear();
+            Collection<MgClassDefinition> facade = items;
+            //add()
+            //contains()
+            ArrayList<MgClassDefinition> testCollection = new ArrayList<MgClassDefinition>();
+            //containsAll()
+            facade.clear();
+            //addAll()
+            //remove()
+            assertCondition(!facade.remove(new MgFeatureSchema()), "Expected remove() of different type to return false");
+            //removeAll()
+            //retainAll()
+            //toArray()
+                assertCondition(o instanceof MgClassDefinition, "Expected item to be MgClassDefinition");
+            MgClassDefinition[] fitems = facade.toArray(new MgClassDefinition[0]);
+            fitems = facade.toArray(new MgClassDefinition[1]);
+            fitems = facade.toArray(new MgClassDefinition[3]);
+            return true;
+        return false;
+    private static boolean testFeatureSchemaCollection() {
+        try {
+            MgFeatureSchemaCollection items = new MgFeatureSchemaCollection();
+            MgFeatureSchema item1 = new MgFeatureSchema("Item1", "");
+            MgFeatureSchema item2 = new MgFeatureSchema("Item2", "");
+            MgFeatureSchema item3 = new MgFeatureSchema("Item3", "");
+            MgFeatureSchema item4 = new MgFeatureSchema("Item4", "");
+            int i = 0;
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+            i = 0;
+            for (MgFeatureSchema item : items) {
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+                i++;
+            items.clear();
+            Collection<MgFeatureSchema> facade = items;
+            //add()
+            //contains()
+            ArrayList<MgFeatureSchema> testCollection = new ArrayList<MgFeatureSchema>();
+            //containsAll()
+            facade.clear();
+            //addAll()
+            //remove()
+            //removeAll()
+            //retainAll()
+            //toArray()
+                assertCondition(o instanceof MgFeatureSchema, "Expected item to be MgFeatureSchema");
+            MgFeatureSchema[] fitems = facade.toArray(new MgFeatureSchema[0]);
+            fitems = facade.toArray(new MgFeatureSchema[1]);
+            fitems = facade.toArray(new MgFeatureSchema[3]);
+            return true;
+        return false;
+    private static boolean testPropertyDefinitionCollection() {
+        try {
+            MgClassDefinition parent = new MgClassDefinition();
+            parent.setName("Parent");
+            MgPropertyDefinitionCollection items = parent.getProperties();
+            MgPropertyDefinition item1 = new MgDataPropertyDefinition("Item1");
+            MgPropertyDefinition item2 = new MgDataPropertyDefinition("Item2");
+            MgPropertyDefinition item3 = new MgDataPropertyDefinition("Item3");
+            MgPropertyDefinition item4 = new MgDataPropertyDefinition("Item4");
+            int i = 0;
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+            i = 0;
+            for (MgPropertyDefinition item : items) {
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+                i++;
+            items.clear();
+            Collection<MgPropertyDefinition> facade = items;
+            //add()
+            //contains()
+            ArrayList<MgPropertyDefinition> testCollection = new ArrayList<MgPropertyDefinition>();
+            //containsAll()
+            facade.clear();
+            //addAll()
+            //remove()
+            //removeAll()
+            //retainAll()
+            //toArray()
+                assertCondition(o instanceof MgPropertyDefinition, "Expected item to be MgPropertyDefinition");
+            MgPropertyDefinition[] fitems = facade.toArray(new MgPropertyDefinition[0]);
+            fitems = facade.toArray(new MgPropertyDefinition[1]);
+            fitems = facade.toArray(new MgPropertyDefinition[3]);
+            return true;
+        return false;
+    private static boolean testLayerCollection(MgSiteConnection siteConn, MgMap map) {
+        try {
+            map.open(mapName);
+            MgLayerCollection items = map.getLayers();
+            items.clear();
+            MgResourceIdentifier ldfId = new MgResourceIdentifier("Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition");
+            MgLayerBase item1 = new MgLayer(ldfId, resSvc);
+            item1.setName("Item1");
+            MgLayerBase item2 = new MgLayer(ldfId, resSvc);
+            item2.setName("Item2");
+            MgLayerBase item3 = new MgLayer(ldfId, resSvc);
+            item3.setName("Item3");
+            MgLayerBase item4 = new MgLayer(ldfId, resSvc);
+            item4.setName("Item4");
+            int i = 0;
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+            i = 0;
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+                i++;
+            items.clear();
+            Collection<MgLayerBase> facade = items;
+            //add()
+            //contains()
+            ArrayList<MgLayerBase> testCollection = new ArrayList<MgLayerBase>();
+            //containsAll()
+            facade.clear();
+            //addAll()
+            //remove()
+            //removeAll()
+            //retainAll()
+            //toArray()
+                assertCondition(o instanceof MgLayerBase, "Expected item to be MgLayerBase");
+            MgLayerBase[] fitems = facade.toArray(new MgLayerBase[0]);
+            fitems = facade.toArray(new MgLayerBase[1]);
+            fitems = facade.toArray(new MgLayerBase[3]);
+            return true;
+        return false;
+    private static boolean testLayerGroupCollection(MgSiteConnection siteConn, MgMap map) {
+        try {
+            MgLayerGroupCollection items = map.getLayerGroups();
+            items.clear();
+            MgLayerGroup item1 = new MgLayerGroup("Item1");
+            MgLayerGroup item2 = new MgLayerGroup("Item2");
+            MgLayerGroup item3 = new MgLayerGroup("Item3");
+            MgLayerGroup item4 = new MgLayerGroup("Item4");
+            int i = 0;
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+            i = 0;
+            for (MgLayerGroup item : items) {
+                switch (i){
+                    case 0:
+                        break;
+                    case 1:
+                        break;
+                    case 2:
+                        break;
+                i++;
+            items.clear();
+            Collection<MgLayerGroup> facade = items;
+            //add()
+            //contains()
+            ArrayList<MgLayerGroup> testCollection = new ArrayList<MgLayerGroup>();
+            //containsAll()
+            facade.clear();
+            //addAll()
+            //remove()
+            //removeAll()
+            //retainAll()
+            //toArray()
+                assertCondition(o instanceof MgLayerGroup, "Expected item to be MgLayerBase");
+            MgLayerGroup[] fitems = facade.toArray(new MgLayerGroup[0]);
+            fitems = facade.toArray(new MgLayerGroup[1]);
+            fitems = facade.toArray(new MgLayerGroup[3]);
+            return true;
+        return false;
Modified: trunk/MgDev/Web/src/DotNetApi/Foundation/FoundationMakefile
--- trunk/MgDev/Web/src/DotNetApi/Foundation/FoundationMakefile	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetApi/Foundation/FoundationMakefile	2013-01-12 03:36:03 UTC (rev 7297)
@@ -12,8 +12,8 @@
 release: $(OUTDIR)\OSGeo.MapGuide.Foundation.dll
 $(OUTDIR)\OSGeo.MapGuide.Foundation.Temp.dll:
-  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /platform:$(PLATFORM) /target:library .\*.cs
+  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Foundation.xml /platform:$(PLATFORM) /target:library .\*.cs
   copy /y $(OUTDIR)\OSGeo.MapGuide.Foundation.dll $(OUTDIR)\OSGeo.MapGuide.Foundation.Temp.dll
 $(OUTDIR)\OSGeo.MapGuide.Foundation.dll:
-  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /platform:$(PLATFORM) /target:library .\*.cs
+  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Foundation.xml /platform:$(PLATFORM) /target:library .\*.cs
Modified: trunk/MgDev/Web/src/DotNetApi/Geometry/GeometryMakefile
--- trunk/MgDev/Web/src/DotNetApi/Geometry/GeometryMakefile	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetApi/Geometry/GeometryMakefile	2013-01-12 03:36:03 UTC (rev 7297)
@@ -12,8 +12,8 @@
 release: $(OUTDIR)\OSGeo.MapGuide.Geometry.dll
 $(OUTDIR)\OSGeo.MapGuide.Geometry.Temp.dll:
-  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Geometry.dll /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /target:library .\*.cs
+  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Geometry.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Geometry.xml /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /target:library .\*.cs
   copy /y $(OUTDIR)\OSGeo.MapGuide.Geometry.dll $(OUTDIR)\OSGeo.MapGuide.Geometry.Temp.dll
 $(OUTDIR)\OSGeo.MapGuide.Geometry.dll:
-  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Geometry.dll /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /target:library .\*.cs
+  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Geometry.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Geometry.xml /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /target:library .\*.cs
Modified: trunk/MgDev/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonMakefile
--- trunk/MgDev/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonMakefile	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonMakefile	2013-01-12 03:36:03 UTC (rev 7297)
@@ -12,8 +12,8 @@
 release: $(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll
 $(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.Temp.dll:
-  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll .\*.cs
+  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll /doc:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll .\*.cs
   copy /y $(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll $(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.Temp.dll
 $(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll:
-  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll /target:library /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll .\*.cs
+  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll /doc:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.xml /target:library /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll .\*.cs
Modified: trunk/MgDev/Web/src/DotNetApi/PlatformBase/PlatformBaseMakefile
--- trunk/MgDev/Web/src/DotNetApi/PlatformBase/PlatformBaseMakefile	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetApi/PlatformBase/PlatformBaseMakefile	2013-01-12 03:36:03 UTC (rev 7297)
@@ -12,8 +12,8 @@
 release: $(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll
 $(OUTDIR)\OSGeo.MapGuide.PlatformBase.Temp.dll:
-  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll .\*.cs
+  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll /doc:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll .\*.cs
   copy /y $(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll $(OUTDIR)\OSGeo.MapGuide.PlatformBase.Temp.dll
 $(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll:
-  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll .\*.cs
+  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll /doc:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll .\*.cs
Modified: trunk/MgDev/Web/src/DotNetApi/Web/WebMakefile
--- trunk/MgDev/Web/src/DotNetApi/Web/WebMakefile	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetApi/Web/WebMakefile	2013-01-12 03:36:03 UTC (rev 7297)
@@ -12,8 +12,8 @@
 release: $(OUTDIR)\OSGeo.MapGuide.Web.dll
 $(OUTDIR)\OSGeo.MapGuide.Web.Temp.dll:
-  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Web.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll;$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll .\*.cs
+  csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Web.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Web.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll;$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll .\*.cs
   copy /y $(OUTDIR)\OSGeo.MapGuide.Web.dll $(OUTDIR)\OSGeo.MapGuide.Web.Temp.dll
 $(OUTDIR)\OSGeo.MapGuide.Web.dll:
-  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Web.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll;$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll .\*.cs
+  csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Web.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Web.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll;$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll .\*.cs
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -14,6 +14,7 @@
    Target section.
 <Target path="./FoundationApi.i" />
+<DocTarget path="./FoundationApi_Doc.i" />
    C++ inline section.
@@ -47,6 +48,7 @@
    Swig inline section.
 <SwigInline>
+  %include "FoundationApi_Doc.i" //doc fragments
   %include "language.i"   //typemaps specific for each language
   %include "../../../../Common/Foundation/System/FoundationClassId.h"
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -14,6 +14,7 @@
    Target section.
 <Target path="./GeometryApi.i" />
+<DocTarget path="./GeometryApi_Doc.i" />
    C++ inline section.
@@ -49,6 +50,7 @@
 <SwigInline>
   %import "../Foundation/FoundationApi.i"
+  %include "GeometryApi_Doc.i" //doc fragments
   %include "../../../../Common/Geometry/GeometryClassId.h"
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -14,6 +14,7 @@
    Target section.
 <Target path="./MapGuideCommonApi.i" />
+<DocTarget path="./MapGuideCommonApi_Doc.i" />
    C++ inline section.
@@ -52,6 +53,7 @@
   %import "../Geometry/GeometryApi.i"
   %import "../PlatformBase/PlatformBaseApi.i"
+  %include "MapGuideCommonApi_Doc.i" //doc fragments
   %include "../../../../Common/MapGuideCommon/System/MapGuideCommonClassId.h"
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -14,6 +14,7 @@
    Target section.
 <Target path="./PlatformBaseApi.i" />
+<DocTarget path="./PlatformBaseApi_Doc.i" />
    C++ inline section.
@@ -51,6 +52,7 @@
 <SwigInline>
+  %include "PlatformBaseApi_Doc.i" //doc fragments
   %include "../../../../Common/PlatformBase/Services/PlatformBaseClassId.h"
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -14,6 +14,7 @@
    Target section.
 <Target path="./MapGuideApi.i" />
+<DocTarget path="./WebApi_Doc.i" />
    C++ inline section.
@@ -61,6 +62,7 @@
   %import "../MapGuideCommon/MapGuideCommonApi.i"
+  %include "WebApi_Doc.i" //doc fragments
   %include "InitializeWebTier.i"
   %include "../../WebApp/WebAppClassId.h"
Property changes on: trunk/MgDev/Web/src/JavaApiEx
   + true
Deleted: trunk/MgDev/Web/src/JavaApiEx/COPYRIGHT
--- sandbox/jng/swig-java/Web/src/JavaApiEx/COPYRIGHT	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/COPYRIGHT	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,19 +0,0 @@
-Where copyrights have not been included in the source file, this
-copyright shall be used for all source files in this directory
-and subdirectories.
-Copyright (C) 2004-2011 by Autodesk, Inc.
-This library is free software; you can redistribute it and/or
-modify it under the terms of version 2.1 of the GNU Lesser
-General Public License as published by the Free Software Foundation.
-This library is distributed in the hope that it will be useful,
-but WITHOUT ANY WARRANTY; without even the implied warranty of
-MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-Lesser General Public License for more details.
-You should have received a copy of the GNU Lesser General Public
-License along with this library; if not, write to the Free Software
-Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
Copied: trunk/MgDev/Web/src/JavaApiEx/COPYRIGHT (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/COPYRIGHT)
--- trunk/MgDev/Web/src/JavaApiEx/COPYRIGHT	                        (rev 0)
@@ -0,0 +1,19 @@
+Where copyrights have not been included in the source file, this
+copyright shall be used for all source files in this directory
+and subdirectories.
+Copyright (C) 2004-2011 by Autodesk, Inc.
+This library is free software; you can redistribute it and/or
+modify it under the terms of version 2.1 of the GNU Lesser
+General Public License as published by the Free Software Foundation.
+This library is distributed in the hope that it will be useful,
+but WITHOUT ANY WARRANTY; without even the implied warranty of
+MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+Lesser General Public License for more details.
+You should have received a copy of the GNU Lesser General Public
+License along with this library; if not, write to the Free Software
+Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
Deleted: trunk/MgDev/Web/src/JavaApiEx/DIFFERENCES.txt
--- sandbox/jng/swig-java/Web/src/JavaApiEx/DIFFERENCES.txt	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/DIFFERENCES.txt	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,51 +0,0 @@
-JavaApiEx differences from JavaApi
-1. MgException/AppThrowable is no longer a checked exception
-AppThrowable now extends RuntimeException making it (and MgException and its subclasses) unchecked exceptions, all methods in the MapGuide API no longer have the (throws MgException) clause.
-2. Method names follow Java conventions
-All method names in the Java proxy classes are now in lowerCamelCase instead of the MapGuide-default UpperCamelCase
- eg. Instead of this:
-	MgUserInformation userInfo = new MgUserInfomration(sessionId);
-	siteConn.Open(userInfo);
-	MgFeatureService featureSvc = (MgFeatureService)siteConn.CreateService(MgServiceType.FeatureService);
-	MgFeatureSchemaCollection schema = featureSvc.DescribeSchema(new MgResourceIdentifier("Library://Samples/Sheboygan/Data/Parcels.FeatureSource"), "SHP_Schema");
- It is now this:
-	siteConn.open(userInfo); //Note the lowercase
-	MgFeatureSchemaCollection schema = featureSvc.describeSchema(new MgResourceIdentifier("Library://Samples/Sheboygan/Data/Parcels.FeatureSource"), "SHP_Schema"); //Note the lowercase
-3. The following MapGuide collection classes now implement java.util.Collection<T>:
- - MgBatchPropertyCollection (T is MgPropertyCollection)
- - MgClassDefinitionCollection (T is MgClassDefinition)
- - MgFeatureSchemaCollection (T is MgFeatureSchema)
- - MgPropertyCollection (T is MgProperty)
- - MgStringCollection (T is String)
-4. The following classes now implement java.util.Iterable<T> allowing them to be used in an enhanced for-loop
- - MgReadOnlyLayerCollection (T is MgLayerBase)
-5. To avoid naming conflicts with SWIG generated code and methods from inherited java classes or interfaces as a result of the above changes, the following class methods have been renamed in the Java MapGuide API:
- - MgPropertyDefinition.Delete      is now MgPropertyDefinition.markAsDeleted
- - MgClassDefinition.Delete         is now MgClassDefinition.markAsDeleted
- - MgFeatureSchema.Delete           is now MgFeatureSchema.markAsDeleted
- - MgException.GetStackTrace        is now MgException.getExceptionStackTrace
- - MgBatchPropertyCollection.Add    is now MgBatchPropertyCollection.addItem
- - MgClassDefinitionCollection.Add  is now MgClassDefinitionCollection.addItem
- - MgFeatureSchemaCollection.Add    is now MgFeatureSchemaCollection.addItem
- - MgIntCollection.Add              is now MgIntCollection.addItem
- - MgPropertyCollection.Add         is now MgPropertyCollection.addItem
- - MgStringCollection.Add           is now MgStringCollection.addItem
Copied: trunk/MgDev/Web/src/JavaApiEx/DIFFERENCES.txt (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/DIFFERENCES.txt)
--- trunk/MgDev/Web/src/JavaApiEx/DIFFERENCES.txt	                        (rev 0)
@@ -0,0 +1,51 @@
+JavaApiEx differences from JavaApi
+1. MgException/AppThrowable is no longer a checked exception
+AppThrowable now extends RuntimeException making it (and MgException and its subclasses) unchecked exceptions, all methods in the MapGuide API no longer have the (throws MgException) clause.
+2. Method names follow Java conventions
+All method names in the Java proxy classes are now in lowerCamelCase instead of the MapGuide-default UpperCamelCase
+ eg. Instead of this:
+	MgUserInformation userInfo = new MgUserInfomration(sessionId);
+	siteConn.Open(userInfo);
+	MgFeatureService featureSvc = (MgFeatureService)siteConn.CreateService(MgServiceType.FeatureService);
+	MgFeatureSchemaCollection schema = featureSvc.DescribeSchema(new MgResourceIdentifier("Library://Samples/Sheboygan/Data/Parcels.FeatureSource"), "SHP_Schema");
+ It is now this:
+	siteConn.open(userInfo); //Note the lowercase
+	MgFeatureSchemaCollection schema = featureSvc.describeSchema(new MgResourceIdentifier("Library://Samples/Sheboygan/Data/Parcels.FeatureSource"), "SHP_Schema"); //Note the lowercase
+3. The following MapGuide collection classes now implement java.util.Collection<T>:
+ - MgBatchPropertyCollection (T is MgPropertyCollection)
+ - MgClassDefinitionCollection (T is MgClassDefinition)
+ - MgFeatureSchemaCollection (T is MgFeatureSchema)
+ - MgPropertyCollection (T is MgProperty)
+ - MgStringCollection (T is String)
+4. The following classes now implement java.util.Iterable<T> allowing them to be used in an enhanced for-loop
+ - MgReadOnlyLayerCollection (T is MgLayerBase)
+5. To avoid naming conflicts with SWIG generated code and methods from inherited java classes or interfaces as a result of the above changes, the following class methods have been renamed in the Java MapGuide API:
+ - MgPropertyDefinition.Delete      is now MgPropertyDefinition.markAsDeleted
+ - MgClassDefinition.Delete         is now MgClassDefinition.markAsDeleted
+ - MgFeatureSchema.Delete           is now MgFeatureSchema.markAsDeleted
+ - MgException.GetStackTrace        is now MgException.getExceptionStackTrace
+ - MgBatchPropertyCollection.Add    is now MgBatchPropertyCollection.addItem
+ - MgClassDefinitionCollection.Add  is now MgClassDefinitionCollection.addItem
+ - MgFeatureSchemaCollection.Add    is now MgFeatureSchemaCollection.addItem
+ - MgIntCollection.Add              is now MgIntCollection.addItem
+ - MgPropertyCollection.Add         is now MgPropertyCollection.addItem
+ - MgStringCollection.Add           is now MgStringCollection.addItem
Deleted: trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.rc
--- sandbox/jng/swig-java/Web/src/JavaApiEx/JavaApiEx.rc	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.rc	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,96 +0,0 @@
-// Microsoft Visual C++ generated resource script.
-#define APSTUDIO_READONLY_SYMBOLS
-// Generated from the TEXTINCLUDE 2 resource.
-#include "winresrc.h"
-#undef APSTUDIO_READONLY_SYMBOLS
-// English (U.S.) resources
-#if !defined(AFX_RESOURCE_DLL) || defined(AFX_TARG_ENU)
-#ifdef _WIN32
-LANGUAGE LANG_ENGLISH, SUBLANG_ENGLISH_US
-#pragma code_page(1252)
-#endif //_WIN32
-#ifdef APSTUDIO_INVOKED
-// TEXTINCLUDE
-1 TEXTINCLUDE
-BEGIN
-    "#include ""winresrc.h""\r\n"
-    "\0"
-END
-2 TEXTINCLUDE
-BEGIN
-    "\r\n"
-    "\0"
-END
-#endif    // APSTUDIO_INVOKED
-// Version
-VS_VERSION_INFO VERSIONINFO
- FILEVERSION 2,5,0,0
- PRODUCTVERSION 2,5,0,0
- FILEFLAGSMASK 0x17L
-#ifdef _DEBUG
- FILEFLAGS 0x1L
-#else
- FILEFLAGS 0x0L
-#endif
- FILEOS 0x4L
- FILETYPE 0x2L
- FILESUBTYPE 0x0L
-BEGIN
-    BLOCK "StringFileInfo"
-    BEGIN
-        BLOCK "040904b0"
-        BEGIN
-            VALUE "CompanyName", "Open Source Geospatial Foundation"
-            VALUE "FileDescription", "MapGuideJavaApiEx Dynamic Link Library"
-            VALUE "FileVersion", "2, 5, 0, 0"
-            VALUE "InternalName", "MapGuideJavaApiEx"
-            VALUE "LegalCopyright", "Copyright (C) 2006-2011 by Autodesk, Inc."
-            VALUE "OriginalFilename", "MapGuideJavaApiEx.dll"
-            VALUE "ProductName", "MapGuide Open Source"
-            VALUE "ProductVersion", "2, 5, 0, 0"
-        END
-    END
-    BLOCK "VarFileInfo"
-    BEGIN
-        VALUE "Translation", 0x409, 1200
-    END
-END
-#endif    // English (U.S.) resources
-#ifndef APSTUDIO_INVOKED
-// Generated from the TEXTINCLUDE 3 resource.
-#endif    // not APSTUDIO_INVOKED
Copied: trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.rc (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/JavaApiEx.rc)
--- trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.rc	                        (rev 0)
@@ -0,0 +1,96 @@
+// Microsoft Visual C++ generated resource script.
+#define APSTUDIO_READONLY_SYMBOLS
+// Generated from the TEXTINCLUDE 2 resource.
+#include "winresrc.h"
+#undef APSTUDIO_READONLY_SYMBOLS
+// English (U.S.) resources
+#if !defined(AFX_RESOURCE_DLL) || defined(AFX_TARG_ENU)
+#ifdef _WIN32
+LANGUAGE LANG_ENGLISH, SUBLANG_ENGLISH_US
+#pragma code_page(1252)
+#endif //_WIN32
+#ifdef APSTUDIO_INVOKED
+// TEXTINCLUDE
+1 TEXTINCLUDE
+BEGIN
+    "#include ""winresrc.h""\r\n"
+    "\0"
+END
+2 TEXTINCLUDE
+BEGIN
+    "\r\n"
+    "\0"
+END
+#endif    // APSTUDIO_INVOKED
+// Version
+VS_VERSION_INFO VERSIONINFO
+ FILEVERSION 2,5,0,0
+ PRODUCTVERSION 2,5,0,0
+ FILEFLAGSMASK 0x17L
+#ifdef _DEBUG
+ FILEFLAGS 0x1L
+#else
+ FILEFLAGS 0x0L
+#endif
+ FILEOS 0x4L
+ FILETYPE 0x2L
+ FILESUBTYPE 0x0L
+BEGIN
+    BLOCK "StringFileInfo"
+    BEGIN
+        BLOCK "040904b0"
+        BEGIN
+            VALUE "CompanyName", "Open Source Geospatial Foundation"
+            VALUE "FileDescription", "MapGuideJavaApiEx Dynamic Link Library"
+            VALUE "FileVersion", "2, 5, 0, 0"
+            VALUE "InternalName", "MapGuideJavaApiEx"
+            VALUE "LegalCopyright", "Copyright (C) 2006-2011 by Autodesk, Inc."
+            VALUE "OriginalFilename", "MapGuideJavaApiEx.dll"
+            VALUE "ProductName", "MapGuide Open Source"
+            VALUE "ProductVersion", "2, 5, 0, 0"
+        END
+    END
+    BLOCK "VarFileInfo"
+    BEGIN
+        VALUE "Translation", 0x409, 1200
+    END
+END
+#endif    // English (U.S.) resources
+#ifndef APSTUDIO_INVOKED
+// Generated from the TEXTINCLUDE 3 resource.
+#endif    // not APSTUDIO_INVOKED
Deleted: trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj
--- sandbox/jng/swig-java/Web/src/JavaApiEx/JavaApiEx.vcxproj	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,290 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<Project DefaultTargets="Build" ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
-  <ItemGroup Label="ProjectConfigurations">
-    <ProjectConfiguration Include="Debug|Win32">
-      <Configuration>Debug</Configuration>
-      <Platform>Win32</Platform>
-    </ProjectConfiguration>
-    <ProjectConfiguration Include="Debug|x64">
-      <Platform>x64</Platform>
-    <ProjectConfiguration Include="Release|Win32">
-      <Configuration>Release</Configuration>
-    <ProjectConfiguration Include="Release|x64">
-  </ItemGroup>
-  <PropertyGroup Label="Globals">
-    <ProjectGuid>{C02F44CB-D916-428D-A1A5-04E225A2A4EC}</ProjectGuid>
-    <RootNamespace>JavaApi</RootNamespace>
-    <Keyword>Win32Proj</Keyword>
-  </PropertyGroup>
-  <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
-  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
-    <ConfigurationType>DynamicLibrary</ConfigurationType>
-    <CharacterSet>Unicode</CharacterSet>
-  </PropertyGroup>
-  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
-  </PropertyGroup>
-  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="Configuration">
-  </PropertyGroup>
-  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="Configuration">
-  </PropertyGroup>
-  <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
-  <ImportGroup Label="ExtensionSettings">
-  </ImportGroup>
-  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
-    <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
-  </ImportGroup>
-  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
-  </ImportGroup>
-  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="PropertySheets">
-  </ImportGroup>
-  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="PropertySheets">
-  </ImportGroup>
-  <PropertyGroup Label="UserMacros" />
-  <PropertyGroup>
-    <_ProjectFileVersion>10.0.40219.1</_ProjectFileVersion>
-    <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\..\bin\debug\</OutDir>
-    <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\..\obj\debug\JavaApiEx\</IntDir>
-    <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</LinkIncremental>
-    <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\bin\debug64\</OutDir>
-    <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\obj\debug64\JavaApiEx\</IntDir>
-    <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</LinkIncremental>
-    <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\..\bin\release\</OutDir>
-    <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\..\obj\release\JavaApiEx\</IntDir>
-    <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">false</LinkIncremental>
-    <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\bin\release64\</OutDir>
-    <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\obj\release64\JavaApiEx\</IntDir>
-    <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|x64'">false</LinkIncremental>
-    <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
-    <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
-    <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
-    <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
-    <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
-    <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
-    <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
-    <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
-    <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
-    <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
-    <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
-    <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
-    <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">MapGuideJavaApiExd</TargetName>
-    <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">MapGuideJavaApiExd</TargetName>
-    <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">MapGuideJavaApiEx</TargetName>
-    <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">MapGuideJavaApiEx</TargetName>
-  </PropertyGroup>
-  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
-    <PreBuildEvent>
-      <Command>..\..\..\BuildTools\WebTools\IMake\Win32\IMake.exe ..\MapGuideApi\Constants.xml Java .
-copy .\java.i .\language.i
-..\..\..\BuildTools\WebTools\IMake\Win32\IMake.exe ..\MapGuideApi\MapGuideApiGen.xml Java
-..\..\..\Oem\SwigEx\Win32\swig -c++ -java -mgjavanothrow -mgjavacasing -DJAVA -DWIN32 -dllname MapGuideJavaApiExd -package org.osgeo.mapguide -root Object -baseexception MgException -clsidcode getclassid.code -clsiddata m_cls_id -catchallcode catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise()%3b" -nodefault -noconstants -module MapGuideJavaApiEx -o MgApi_wrap.cpp -lib ..\..\..\Oem\SWIGEx\Lib MapGuideApi.i
-move /Y *.java org\osgeo\mapguide
-del org\osgeo\mapguide\*.class
-echo Building java classes...
-"$(JAVA_HOME)\bin\javac" -classpath . org\osgeo\mapguide\*.java
-echo Building JAR file
-"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApid.jar org\osgeo\mapguide\*.class
-</Command>
-    </PreBuildEvent>
-    <ClCompile>
-      <Optimization>Disabled</Optimization>
-      <AdditionalIncludeDirectories>..\HttpHandler;..\WebApp;..\WebSupport;..\..\..\Common\MdfModel;..\..\..\Common\Foundation;..\..\..\Common\PlatformBase;..\..\..\Common\Geometry;..\..\..\Common\MapGuideCommon;..\..\..\Oem\ACE\ACE_wrappers;..\..\..\Oem\dbxml\xerces-c-src\src;$(JAVA_HOME)\include;$(JAVA_HOME)\include\win32;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
-      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;JAVA;%(PreprocessorDefinitions)</PreprocessorDefinitions>
-      <MinimalRebuild>true</MinimalRebuild>
-      <ExceptionHandling>Async</ExceptionHandling>
-      <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
-      <RuntimeLibrary>MultiThreadedDebugDLL</RuntimeLibrary>
-      <WarningLevel>Level3</WarningLevel>
-      <DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
-    </ClCompile>
-    <Link>
-      <AdditionalDependencies>ACEd.lib;%(AdditionalDependencies)</AdditionalDependencies>
-      <OutputFile>$(OutDir)MapGuideJavaApid.dll</OutputFile>
-      <AdditionalLibraryDirectories>..\..\..\Oem\ACE\ACE_wrappers\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
-      <GenerateDebugInformation>true</GenerateDebugInformation>
-      <ProgramDatabaseFile>$(OutDir)MapGuideJavaApid.pdb</ProgramDatabaseFile>
-      <SubSystem>Windows</SubSystem>
-      <RandomizedBaseAddress>false</RandomizedBaseAddress>
-      <DataExecutionPrevention>
-      </DataExecutionPrevention>
-      <ImportLibrary>..\..\lib\debug\MapGuideJavaApid.lib</ImportLibrary>
-      <TargetMachine>MachineX86</TargetMachine>
-    </Link>
-  </ItemDefinitionGroup>
-  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
-    <PreBuildEvent>
-</Command>
-    </PreBuildEvent>
-    <ClCompile>
-    </ClCompile>
-    <Link>
-      <AdditionalLibraryDirectories>..\..\..\Oem\ACE\ACE_wrappers\lib64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
-      <ImportLibrary>..\..\lib\debug64\MapGuideJavaApid.lib</ImportLibrary>
-      <TargetMachine>MachineX64</TargetMachine>
-    </Link>
-  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
-    <PreBuildEvent>
-..\..\..\Oem\SwigEx\Win32\swig -c++ -java -mgjavanothrow -mgjavacasing -DJAVA -DWIN32 -dllname MapGuideJavaApiEx -package org.osgeo.mapguide -root Object -baseexception MgException -clsidcode getclassid.code -clsiddata m_cls_id -catchallcode catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise()%3b" -nodefault -noconstants -module MapGuideJavaApiEx -o MgApi_wrap.cpp -lib ..\..\..\Oem\SWIGEx\Lib MapGuideApi.i
-"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApiEx.jar org\osgeo\mapguide\*.class
-</Command>
-    </PreBuildEvent>
-    <ClCompile>
-      <Optimization>MaxSpeed</Optimization>
-      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;JAVA;%(PreprocessorDefinitions)</PreprocessorDefinitions>
-      <RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
-    </ClCompile>
-    <Link>
-      <AdditionalDependencies>ACE.lib;%(AdditionalDependencies)</AdditionalDependencies>
-      <OutputFile>$(OutDir)MapGuideJavaApiEx.dll</OutputFile>
-      <ProgramDatabaseFile>$(OutDir)MapGuideJavaApiEx.pdb</ProgramDatabaseFile>
-      <OptimizeReferences>true</OptimizeReferences>
-      <EnableCOMDATFolding>true</EnableCOMDATFolding>
-      <ImportLibrary>..\..\lib\release\MapGuideJavaApiEx.lib</ImportLibrary>
-    </Link>
-  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
-    <PreBuildEvent>
-</Command>
-    </PreBuildEvent>
-    <ClCompile>
-    </ClCompile>
-    <Link>
-      <ImportLibrary>..\..\lib\release64\MapGuideJavaApiEx.lib</ImportLibrary>
-    </Link>
-  <ItemGroup>
-    <None Include="catchall.code" />
-    <None Include="getclassid.code" />
-    <None Include="java.i" />
-  </ItemGroup>
-  <ItemGroup>
-    <ResourceCompile Include="JavaApiEx.rc" />
-  </ItemGroup>
-  <ItemGroup>
-    <ClCompile Include="MgApi_wrap.cpp" />
-  </ItemGroup>
-  <ItemGroup>
-    <ProjectReference Include="..\..\..\Common\Foundation\Foundation.vcxproj">
-      <Project>{a82adc7d-4da4-42f2-9bf6-df5dcfb44425}</Project>
-      <ReferenceOutputAssembly>false</ReferenceOutputAssembly>
-    </ProjectReference>
-    <ProjectReference Include="..\..\..\Common\Geometry\Geometry.vcxproj">
-      <Project>{d954daac-e305-40ce-b3f3-c229a0bef4f0}</Project>
-    <ProjectReference Include="..\..\..\Common\MapGuideCommon\MapGuideCommon.vcxproj">
-      <Project>{5287a594-4d4f-43fe-a281-e279ab708cf1}</Project>
-    <ProjectReference Include="..\..\..\Common\PlatformBase\PlatformBase.vcxproj">
-      <Project>{f7334b1b-0efa-47e3-8e66-df158e61b7e4}</Project>
-    <ProjectReference Include="..\HttpHandler\HttpHandler.vcxproj">
-      <Project>{78619d0e-d3f9-4ddf-b90e-f99cb03dfc44}</Project>
-    <ProjectReference Include="..\WebApp\WebApp.vcxproj">
-      <Project>{b797917b-6842-467c-8b14-e00b76a91247}</Project>
-    <ProjectReference Include="..\WebSupport\WebSupport.vcxproj">
-      <Project>{795b1b0e-4ec8-469d-b641-e26324266fbf}</Project>
-  </ItemGroup>
-  <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
-  <ImportGroup Label="ExtensionTargets">
-  </ImportGroup>
-</Project>
\ No newline at end of file
Copied: trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/JavaApiEx.vcxproj)
--- trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj	                        (rev 0)
@@ -0,0 +1,290 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project DefaultTargets="Build" ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+  <ItemGroup Label="ProjectConfigurations">
+    <ProjectConfiguration Include="Debug|Win32">
+      <Configuration>Debug</Configuration>
+      <Platform>Win32</Platform>
+    </ProjectConfiguration>
+    <ProjectConfiguration Include="Debug|x64">
+      <Platform>x64</Platform>
+    <ProjectConfiguration Include="Release|Win32">
+      <Configuration>Release</Configuration>
+    <ProjectConfiguration Include="Release|x64">
+  </ItemGroup>
+  <PropertyGroup Label="Globals">
+    <ProjectGuid>{C02F44CB-D916-428D-A1A5-04E225A2A4EC}</ProjectGuid>
+    <RootNamespace>JavaApi</RootNamespace>
+    <Keyword>Win32Proj</Keyword>
+  </PropertyGroup>
+  <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
+    <ConfigurationType>DynamicLibrary</ConfigurationType>
+    <CharacterSet>Unicode</CharacterSet>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="Configuration">
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="Configuration">
+  </PropertyGroup>
+  <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
+  <ImportGroup Label="ExtensionSettings">
+  </ImportGroup>
+  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
+    <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
+  </ImportGroup>
+  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
+  </ImportGroup>
+  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'" Label="PropertySheets">
+  </ImportGroup>
+  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" Label="PropertySheets">
+  </ImportGroup>
+  <PropertyGroup Label="UserMacros" />
+  <PropertyGroup>
+    <_ProjectFileVersion>10.0.40219.1</_ProjectFileVersion>
+    <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\..\bin\debug\</OutDir>
+    <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">..\..\obj\debug\JavaApiEx\</IntDir>
+    <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</LinkIncremental>
+    <OutDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\bin\debug64\</OutDir>
+    <IntDir Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">..\..\obj\debug64\JavaApiEx\</IntDir>
+    <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</LinkIncremental>
+    <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\..\bin\release\</OutDir>
+    <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">..\..\obj\release\JavaApiEx\</IntDir>
+    <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">false</LinkIncremental>
+    <OutDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\bin\release64\</OutDir>
+    <IntDir Condition="'$(Configuration)|$(Platform)'=='Release|x64'">..\..\obj\release64\JavaApiEx\</IntDir>
+    <LinkIncremental Condition="'$(Configuration)|$(Platform)'=='Release|x64'">false</LinkIncremental>
+    <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
+    <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
+    <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" />
+    <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
+    <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
+    <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Debug|x64'" />
+    <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">AllRules.ruleset</CodeAnalysisRuleSet>
+    <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
+    <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" />
+    <CodeAnalysisRuleSet Condition="'$(Configuration)|$(Platform)'=='Release|x64'">AllRules.ruleset</CodeAnalysisRuleSet>
+    <CodeAnalysisRules Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
+    <CodeAnalysisRuleAssemblies Condition="'$(Configuration)|$(Platform)'=='Release|x64'" />
+    <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">MapGuideJavaApiExd</TargetName>
+    <TargetName Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">MapGuideJavaApiExd</TargetName>
+    <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|x64'">MapGuideJavaApiEx</TargetName>
+    <TargetName Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">MapGuideJavaApiEx</TargetName>
+  </PropertyGroup>
+  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+    <PreBuildEvent>
+      <Command>..\..\..\BuildTools\WebTools\IMake\Win32\IMake.exe ..\MapGuideApi\Constants.xml Java .
+copy .\java.i .\language.i
+..\..\..\BuildTools\WebTools\IMake\Win32\IMake.exe ..\MapGuideApi\MapGuideApiGen.xml Java
+..\..\..\Oem\SwigEx\Win32\swig -c++ -java -mgjavanothrow -mgjavacasing -DJAVA -DWIN32 -dllname MapGuideJavaApiExd -package org.osgeo.mapguide -root Object -baseexception MgException -clsidcode getclassid.code -clsiddata m_cls_id -catchallcode catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise()%3b" -nodefault -noconstants -module MapGuideJavaApiEx -o MgApi_wrap.cpp -lib ..\..\..\Oem\SWIGEx\Lib MapGuideApi.i
+move /Y *.java org\osgeo\mapguide
+del org\osgeo\mapguide\*.class
+echo Building java classes...
+"$(JAVA_HOME)\bin\javac" -classpath . org\osgeo\mapguide\*.java
+echo Building JAR file
+"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApid.jar org\osgeo\mapguide\*.class
+</Command>
+    </PreBuildEvent>
+    <ClCompile>
+      <Optimization>Disabled</Optimization>
+      <AdditionalIncludeDirectories>..\HttpHandler;..\WebApp;..\WebSupport;..\..\..\Common\MdfModel;..\..\..\Common\Foundation;..\..\..\Common\PlatformBase;..\..\..\Common\Geometry;..\..\..\Common\MapGuideCommon;..\..\..\Oem\ACE\ACE_wrappers;..\..\..\Oem\dbxml\xerces-c-src\src;$(JAVA_HOME)\include;$(JAVA_HOME)\include\win32;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;JAVA;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <MinimalRebuild>true</MinimalRebuild>
+      <ExceptionHandling>Async</ExceptionHandling>
+      <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
+      <RuntimeLibrary>MultiThreadedDebugDLL</RuntimeLibrary>
+      <WarningLevel>Level3</WarningLevel>
+      <DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
+    </ClCompile>
+    <Link>
+      <AdditionalDependencies>ACEd.lib;%(AdditionalDependencies)</AdditionalDependencies>
+      <OutputFile>$(OutDir)MapGuideJavaApid.dll</OutputFile>
+      <AdditionalLibraryDirectories>..\..\..\Oem\ACE\ACE_wrappers\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+      <GenerateDebugInformation>true</GenerateDebugInformation>
+      <ProgramDatabaseFile>$(OutDir)MapGuideJavaApid.pdb</ProgramDatabaseFile>
+      <SubSystem>Windows</SubSystem>
+      <RandomizedBaseAddress>false</RandomizedBaseAddress>
+      <DataExecutionPrevention>
+      </DataExecutionPrevention>
+      <ImportLibrary>..\..\lib\debug\MapGuideJavaApid.lib</ImportLibrary>
+      <TargetMachine>MachineX86</TargetMachine>
+    </Link>
+  </ItemDefinitionGroup>
+  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
+    <PreBuildEvent>
+</Command>
+    </PreBuildEvent>
+    <ClCompile>
+    </ClCompile>
+    <Link>
+      <AdditionalLibraryDirectories>..\..\..\Oem\ACE\ACE_wrappers\lib64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+      <ImportLibrary>..\..\lib\debug64\MapGuideJavaApid.lib</ImportLibrary>
+      <TargetMachine>MachineX64</TargetMachine>
+    </Link>
+  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+    <PreBuildEvent>
+..\..\..\Oem\SwigEx\Win32\swig -c++ -java -mgjavanothrow -mgjavacasing -DJAVA -DWIN32 -dllname MapGuideJavaApiEx -package org.osgeo.mapguide -root Object -baseexception MgException -clsidcode getclassid.code -clsiddata m_cls_id -catchallcode catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise()%3b" -nodefault -noconstants -module MapGuideJavaApiEx -o MgApi_wrap.cpp -lib ..\..\..\Oem\SWIGEx\Lib MapGuideApi.i
+"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApiEx.jar org\osgeo\mapguide\*.class
+</Command>
+    </PreBuildEvent>
+    <ClCompile>
+      <Optimization>MaxSpeed</Optimization>
+      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;JAVA;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
+    </ClCompile>
+    <Link>
+      <AdditionalDependencies>ACE.lib;%(AdditionalDependencies)</AdditionalDependencies>
+      <OutputFile>$(OutDir)MapGuideJavaApiEx.dll</OutputFile>
+      <ProgramDatabaseFile>$(OutDir)MapGuideJavaApiEx.pdb</ProgramDatabaseFile>
+      <OptimizeReferences>true</OptimizeReferences>
+      <EnableCOMDATFolding>true</EnableCOMDATFolding>
+      <ImportLibrary>..\..\lib\release\MapGuideJavaApiEx.lib</ImportLibrary>
+    </Link>
+  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
+    <PreBuildEvent>
+</Command>
+    </PreBuildEvent>
+    <ClCompile>
+    </ClCompile>
+    <Link>
+      <ImportLibrary>..\..\lib\release64\MapGuideJavaApiEx.lib</ImportLibrary>
+    </Link>
+  <ItemGroup>
+    <None Include="catchall.code" />
+    <None Include="getclassid.code" />
+    <None Include="java.i" />
+  </ItemGroup>
+  <ItemGroup>
+    <ResourceCompile Include="JavaApiEx.rc" />
+  </ItemGroup>
+  <ItemGroup>
+    <ClCompile Include="MgApi_wrap.cpp" />
+  </ItemGroup>
+  <ItemGroup>
+    <ProjectReference Include="..\..\..\Common\Foundation\Foundation.vcxproj">
+      <Project>{a82adc7d-4da4-42f2-9bf6-df5dcfb44425}</Project>
+      <ReferenceOutputAssembly>false</ReferenceOutputAssembly>
+    </ProjectReference>
+    <ProjectReference Include="..\..\..\Common\Geometry\Geometry.vcxproj">
+      <Project>{d954daac-e305-40ce-b3f3-c229a0bef4f0}</Project>
+    <ProjectReference Include="..\..\..\Common\MapGuideCommon\MapGuideCommon.vcxproj">
+      <Project>{5287a594-4d4f-43fe-a281-e279ab708cf1}</Project>
+    <ProjectReference Include="..\..\..\Common\PlatformBase\PlatformBase.vcxproj">
+      <Project>{f7334b1b-0efa-47e3-8e66-df158e61b7e4}</Project>
+    <ProjectReference Include="..\HttpHandler\HttpHandler.vcxproj">
+      <Project>{78619d0e-d3f9-4ddf-b90e-f99cb03dfc44}</Project>
+    <ProjectReference Include="..\WebApp\WebApp.vcxproj">
+      <Project>{b797917b-6842-467c-8b14-e00b76a91247}</Project>
+    <ProjectReference Include="..\WebSupport\WebSupport.vcxproj">
+      <Project>{795b1b0e-4ec8-469d-b641-e26324266fbf}</Project>
+  </ItemGroup>
+  <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
+  <ImportGroup Label="ExtensionTargets">
+  </ImportGroup>
+</Project>
Deleted: trunk/MgDev/Web/src/JavaApiEx/Makefile.am
--- sandbox/jng/swig-java/Web/src/JavaApiEx/Makefile.am	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/Makefile.am	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,468 +0,0 @@
-AUTOMAKE_OPTIONS = foreign
-EXTRA_DIST = getclassid.code \
-             catchall.code \
-             java.i \
-             JavaApiEx.rc \
-             JavaApiEx.vcproj \
-             org/osgeo/mapguide/AppThrowable.java \
-             org/osgeo/mapguide/MgBase64.java \
-             org/osgeo/mapguide/MgLocalizer.java
-prefix=@prefix@/webserverextensions
-INCLUDES = -I../../../Common/MdfModel \
-           -I../../../Common/Foundation \
-           -I../../../Common/Geometry \
-           -I../../../Common/PlatformBase \
-           -I../../../Common/MapGuideCommon \
-           -I$(JAVA_HOME)/include \
-           -I$(JAVA_HOME)/include/linux \
-           -I../../../Oem/ACE/ACE_wrappers \
-           -I../HttpHandler \
-           -I../WebSupport \
-           -I../WebApp \
-           -I../../../Oem/dbxml/xerces-c-src/src
-BUILT_SOURCES = MgApi_wrap.cpp
-lib_LTLIBRARIES = libMapGuideJavaApiEx.la
-nodist_libMapGuideJavaApiEx_la_SOURCES = MgApi_wrap.cpp
-AM_CXXFLAGS = @CXXFLAGS@ -fno-strict-aliasing -DJAVA
-libMapGuideJavaApiEx_la_LIBADD = \
-    -lACE \
-    -lMgFoundation \
-    -lMgGeometry \
-    -lMgPlatformBase \
-    -lMgMapGuideCommon \
-    -lMgHttpHandler \
-    -lMgMdfModel \
-    -lMgMdfParser \
-    -lxerces-c \
-    -lMgWebApp
-libMapGuideJavaApiEx_la_LDFLAGS = -release $(PACKAGE_VERSION) \
-    -L../../../Oem/ACE/ACE_wrappers/ace \
-    -L../../../Common/MdfModel \
-    -L../../../Common/MdfParser \
-    -L../../../Common/Foundation \
-    -L../../../Common/Geometry \
-    -L../../../Common/PlatformBase \
-    -L../../../Common/MapGuideCommon \
-    -L../HttpHandler \
-    -L../WebApp \
-    -L../../../Oem/dbxml/install/lib
-MgApi_wrap.cpp : \
-    ../WebApp/WebApp.h \
-    ../WebSupport/InitializeWebTier.cpp \
-    ../../../Common/MdfModel/UnicodeString.h \
-    ../HttpHandler/HttpHandlerApiDllExport.h \
-    ../HttpHandler/HttpHandler.h \
-    ../../../Common/Foundation/System/Object.h \
-    ../../../Common/Foundation/System/Disposable.h \
-    ../../../Common/Foundation/System/GuardDisposable.h \
-    ../../../Common/Foundation/System/Serializable.h \
-    ../../../Common/Foundation/System/NamedSerializable.h \
-    ../../../Common/Foundation/Data/Collection.h \
-    ../../../Common/Foundation/Data/Property.h \
-    ../../../Common/Foundation/System/DisposableCollection.h \
-    ../../../Common/Foundation/Data/BatchPropertyCollection.h \
-    ../../../Common/Foundation/Data/ByteReader.h \
-    ../../../Common/Foundation/Data/ByteSource.h \
-    ../../../Common/Foundation/Data/ByteSink.h \
-    ../../../Common/Foundation/Data/DateTime.h \
-    ../../../Common/Foundation/Data/NullableProperty.h \
-    ../../../Common/Foundation/Data/PropertyCollection.h \
-    ../../../Common/Foundation/Data/PropertyDefinition.h \
-    ../../../Common/Foundation/Data/StringCollection.h \
-    ../../../Common/Foundation/Data/StringProperty.h \
-    ../../../Common/Foundation/Data/FeaturePropertyType.h \
-    ../../../Common/Foundation/Data/MimeType.h \
-    ../../../Common/Foundation/Data/PropertyType.h \
-    ../../../Common/Foundation/Exception/Exception.h \
-    ../../../Common/Foundation/Exception/SystemException.h \
-    ../../../Common/Foundation/Exception/IoException.h \
-    ../../../Common/Foundation/Exception/FileIoException.h \
-    ../../../Common/Foundation/Exception/ApplicationException.h \
-    ../../../Common/Foundation/Exception/ThirdPartyException.h \
-    ../../../Common/Foundation/Exception/StreamIoException.h \
-    ../../../Common/Foundation/Exception/OutOfRangeException.h \
-    ../../../Common/Foundation/Exception/ArgumentOutOfRangeException.h \
-    ../../../Common/Foundation/Exception/ClassNotFoundException.h \
-    ../../../Common/Foundation/Exception/ConfigurationException.h \
-    ../../../Common/Foundation/Exception/ConfigurationLoadFailedException.h \
-    ../../../Common/Foundation/Exception/ConfigurationSaveFailedException.h \
-    ../../../Common/Foundation/Exception/DateTimeException.h \
-    ../../../Common/Foundation/Exception/DecryptionException.h \
-    ../../../Common/Foundation/Exception/DirectoryNotFoundException.h \
-    ../../../Common/Foundation/Exception/DivideByZeroException.h \
-    ../../../Common/Foundation/Exception/DomainException.h \
-    ../../../Common/Foundation/Exception/DuplicateDirectoryException.h \
-    ../../../Common/Foundation/Exception/DuplicateFileException.h \
-    ../../../Common/Foundation/Exception/DuplicateObjectException.h \
-    ../../../Common/Foundation/Exception/EncryptionException.h \
-    ../../../Common/Foundation/Exception/FileNotFoundException.h \
-    ../../../Common/Foundation/Exception/IndexOutOfRangeException.h \
-    ../../../Common/Foundation/Exception/InvalidArgumentException.h \
-    ../../../Common/Foundation/Exception/InvalidCastException.h \
-    ../../../Common/Foundation/Exception/InvalidOperationException.h \
-    ../../../Common/Foundation/Exception/InvalidPropertyTypeException.h \
-    ../../../Common/Foundation/Exception/InvalidStreamHeaderException.h \
-    ../../../Common/Foundation/Exception/LengthException.h \
-    ../../../Common/Foundation/Exception/LogicException.h \
-    ../../../Common/Foundation/Exception/NotFiniteNumberException.h \
-    ../../../Common/Foundation/Exception/NotImplementedException.h \
-    ../../../Common/Foundation/Exception/NullArgumentException.h \
-    ../../../Common/Foundation/Exception/NullPropertyValueException.h \
-    ../../../Common/Foundation/Exception/NullReferenceException.h \
-    ../../../Common/Foundation/Exception/ObjectNotFoundException.h \
-    ../../../Common/Foundation/Exception/OutOfMemoryException.h \
-    ../../../Common/Foundation/Exception/OverflowException.h \
-    ../../../Common/Foundation/Exception/PlatformNotSupportedException.h \
-    ../../../Common/Foundation/Exception/ResourcesException.h \
-    ../../../Common/Foundation/Exception/ResourcesLoadFailedException.h \
-    ../../../Common/Foundation/Exception/RuntimeException.h \
-    ../../../Common/Foundation/Exception/TemporaryFileNotAvailableException.h \
-    ../../../Common/Foundation/Exception/UnclassifiedException.h \
-    ../../../Common/Foundation/Exception/UnderflowException.h \
-    ../../../Common/Foundation/Exception/XmlException.h \
-    ../../../Common/Foundation/Exception/XmlParserException.h \
-    ../../../Common/Geometry/GeometricEntity.h \
-    ../../../Common/Geometry/Geometry.h \
-    ../../../Common/Geometry/GeometryComponent.h \
-    ../../../Common/Geometry/Curve.h \
-    ../../../Common/Geometry/CurveSegment.h \
-    ../../../Common/Geometry/Ring.h \
-    ../../../Common/Geometry/Region.h \
-    ../../../Common/Geometry/AgfReaderWriter.h \
-    ../../../Common/Geometry/AggregateGeometry.h \
-    ../../../Common/Geometry/ArcSegment.h \
-    ../../../Common/Geometry/Coordinate.h \
-    ../../../Common/Geometry/CoordinateCollection.h \
-    ../../../Common/Geometry/CoordinateIterator.h \
-    ../../../Common/Geometry/CoordinateXY.h \
-    ../../../Common/Geometry/CoordinateXYM.h \
-    ../../../Common/Geometry/CoordinateXYZ.h \
-    ../../../Common/Geometry/CoordinateXYZM.h \
-    ../../../Common/Geometry/CurvePolygon.h \
-    ../../../Common/Geometry/CurvePolygonCollection.h \
-    ../../../Common/Geometry/CurveRing.h \
-    ../../../Common/Geometry/CurveRingCollection.h \
-    ../../../Common/Geometry/CurveSegmentCollection.h \
-    ../../../Common/Geometry/CurveString.h \
-    ../../../Common/Geometry/CurveStringCollection.h \
-    ../../../Common/Geometry/Envelope.h \
-    ../../../Common/Geometry/GeometryCollection.h \
-    ../../../Common/Geometry/GeometryFactory.h \
-    ../../../Common/Geometry/LinearRing.h \
-    ../../../Common/Geometry/LinearRingCollection.h \
-    ../../../Common/Geometry/LinearSegment.h \
-    ../../../Common/Geometry/LineString.h \
-    ../../../Common/Geometry/LineStringCollection.h \
-    ../../../Common/Geometry/Measure.h \
-    ../../../Common/Geometry/MultiCurvePolygon.h \
-    ../../../Common/Geometry/MultiCurveString.h \
-    ../../../Common/Geometry/MultiGeometry.h \
-    ../../../Common/Geometry/MultiLineString.h \
-    ../../../Common/Geometry/MultiPoint.h \
-    ../../../Common/Geometry/MultiPolygon.h \
-    ../../../Common/Geometry/Point.h \
-    ../../../Common/Geometry/PointCollection.h \
-    ../../../Common/Geometry/Polygon.h \
-    ../../../Common/Geometry/PolygonCollection.h \
-    ../../../Common/Geometry/Transform.h \
-    ../../../Common/Geometry/WktReaderWriter.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystem.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryBase.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCatalog.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCategory.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCategoryDictionary.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDatumDictionary.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformDefParams.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionary.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryUtility.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoidDictionary.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFactory.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformation.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMathComparator.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionInformation.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h \
-    ../../../Common/Geometry/Exception/CoordinateSystemComputationFailedException.h \
-    ../../../Common/Geometry/Exception/CoordinateSystemConversionFailedException.h \
-    ../../../Common/Geometry/Exception/CoordinateSystemInitializationFailedException.h \
-    ../../../Common/Geometry/Exception/CoordinateSystemLoadFailedException.h \
-    ../../../Common/Geometry/Exception/CoordinateSystemMeasureFailedException.h \
-    ../../../Common/Geometry/Exception/CoordinateSystemTransformFailedException.h \
-    ../../../Common/Geometry/Exception/GeometryException.h \
-    ../../../Common/Geometry/Exception/InvalidCoordinateSystemException.h \
-    ../../../Common/Geometry/Exception/InvalidCoordinateSystemTypeException.h \
-    ../../../Common/Geometry/Exception/InvalidCoordinateSystemUnitsException.h \
-    ../../../Common/Geometry/CoordinateDimension.h \
-    ../../../Common/Geometry/GeometricEntityType.h \
-    ../../../Common/Geometry/GeometricPathInstructionType.h \
-    ../../../Common/Geometry/GeometryComponentType.h \
-    ../../../Common/Geometry/GeometryType.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCodeFormat.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionLogicalType.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionParameterType.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemType.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitCode.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitType.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemWktFlavor.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h \
-	../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformationMethod.h \
-    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h \
-    ../../../Common/PlatformBase/Data/BlobProperty.h \
-    ../../../Common/PlatformBase/Data/BooleanProperty.h \
-    ../../../Common/PlatformBase/Data/ByteProperty.h \
-    ../../../Common/PlatformBase/Data/ClobProperty.h \
-    ../../../Common/PlatformBase/Data/Color.h \
-    ../../../Common/PlatformBase/Data/DateTimeProperty.h \
-    ../../../Common/PlatformBase/Data/DoubleProperty.h \
-    ../../../Common/PlatformBase/Data/Int16Property.h \
-    ../../../Common/PlatformBase/Data/Int32Property.h \
-    ../../../Common/PlatformBase/Data/Int64Property.h \
-    ../../../Common/PlatformBase/Data/IntCollection.h \
-    ../../../Common/PlatformBase/Data/PropertyDefinitionCollection.h \
-    ../../../Common/PlatformBase/Data/SingleProperty.h \
-    ../../../Common/PlatformBase/Data/StringPropertyCollection.h \
-    ../../../Common/PlatformBase/Exception/ArrayTypeMismatchException.h \
-    ../../../Common/PlatformBase/Exception/DuplicateResourceDataException.h \
-    ../../../Common/PlatformBase/Exception/DuplicateResourceException.h \
-    ../../../Common/PlatformBase/Exception/EmptyFeatureSetException.h \
-    ../../../Common/PlatformBase/Exception/FdoException.h \
-    ../../../Common/PlatformBase/Exception/FeatureServiceException.h \
-    ../../../Common/PlatformBase/Exception/InvalidMapDefinitionException.h \
-    ../../../Common/PlatformBase/Exception/InvalidRepositoryNameException.h \
-    ../../../Common/PlatformBase/Exception/InvalidRepositoryTypeException.h \
-    ../../../Common/PlatformBase/Exception/InvalidResourceDataNameException.h \
-    ../../../Common/PlatformBase/Exception/InvalidResourceDataTypeException.h \
-    ../../../Common/PlatformBase/Exception/InvalidResourceNameException.h \
-    ../../../Common/PlatformBase/Exception/InvalidResourcePathException.h \
-    ../../../Common/PlatformBase/Exception/InvalidResourcePreProcessingTypeException.h \
-    ../../../Common/PlatformBase/Exception/InvalidResourceTypeException.h \
-    ../../../Common/PlatformBase/Exception/LayerNotFoundException.h \
-    ../../../Common/PlatformBase/Exception/ResourceBusyException.h \
-    ../../../Common/PlatformBase/Exception/ResourceDataNotFoundException.h \
-    ../../../Common/PlatformBase/Exception/ResourceNotFoundException.h \
-    ../../../Common/PlatformBase/Exception/ServiceNotAvailableException.h \
-    ../../../Common/PlatformBase/Exception/ServiceNotSupportedException.h \
-    ../../../Common/PlatformBase/Exception/UserNotFoundException.h \
-    ../../../Common/PlatformBase/Services/FeatureCommand.h \
-    ../../../Common/PlatformBase/Services/FeatureQueryOptions.h \
-    ../../../Common/PlatformBase/Services/FeatureSourceParams.h \
-    ../../../Common/PlatformBase/Services/Reader.h \
-    ../../../Common/PlatformBase/Services/Service.h \
-    ../../../Common/PlatformBase/Services/BaseService.h \
-    ../../../Common/PlatformBase/Services/ClassDefinition.h \
-    ../../../Common/PlatformBase/Services/ClassDefinitionCollection.h \
-    ../../../Common/PlatformBase/Services/FileFeatureSourceParams.h \
-    ../../../Common/PlatformBase/Services/CreateSdfParams.h \
-    ../../../Common/PlatformBase/Services/DataPropertyDefinition.h \
-    ../../../Common/PlatformBase/Services/DataReader.h \
-    ../../../Common/PlatformBase/Services/DeleteFeatures.h \
-    ../../../Common/PlatformBase/Services/FeatureAggregateOptions.h \
-    ../../../Common/PlatformBase/Services/FeatureCommandCollection.h \
-    ../../../Common/PlatformBase/Services/FeatureProperty.h \
-    ../../../Common/PlatformBase/Services/FeatureReader.h \
-    ../../../Common/PlatformBase/Services/FeatureSchema.h \
-    ../../../Common/PlatformBase/Services/FeatureSchemaCollection.h \
-    ../../../Common/PlatformBase/Services/FeatureService.h \
-    ../../../Common/PlatformBase/Services/GeometricPropertyDefinition.h \
-    ../../../Common/PlatformBase/Services/GeometryProperty.h \
-    ../../../Common/PlatformBase/Services/GeometryTypeInfo.h \
-    ../../../Common/PlatformBase/Services/GwsFeatureReader.h \
-    ../../../Common/PlatformBase/Services/InsertFeatures.h \
-    ../../../Common/PlatformBase/Services/LongTransactionReader.h \
-    ../../../Common/PlatformBase/Services/ObjectPropertyDefinition.h \
-    ../../../Common/PlatformBase/Services/Parameter.h \
-    ../../../Common/PlatformBase/Services/ParameterCollection.h \
-    ../../../Common/PlatformBase/Services/Raster.h \
-    ../../../Common/PlatformBase/Services/RasterProperty.h \
-    ../../../Common/PlatformBase/Services/RasterPropertyDefinition.h \
-    ../../../Common/PlatformBase/Services/Resource.h \
-    ../../../Common/PlatformBase/Services/ResourceIdentifier.h \
-    ../../../Common/PlatformBase/Services/ResourceService.h \
-    ../../../Common/PlatformBase/Services/SpatialContextReader.h \
-    ../../../Common/PlatformBase/Services/SqlDataReader.h \
-    ../../../Common/PlatformBase/Services/Transaction.h \
-    ../../../Common/PlatformBase/Services/UpdateFeatures.h \
-    ../../../Common/PlatformBase/Services/Warnings.h \
-    ../../../Common/PlatformBase/Services/BaseServiceDefs.h \
-    ../../../Common/PlatformBase/Services/FeatureCommandType.h \
-    ../../../Common/PlatformBase/Services/FeatureGeometricType.h \
-    ../../../Common/PlatformBase/Services/FeatureSpatialOperations.h \
-    ../../../Common/PlatformBase/Services/ObjectPropertyType.h \
-    ../../../Common/PlatformBase/Services/OrderingOption.h \
-    ../../../Common/PlatformBase/Services/ParameterDirection.h \
-    ../../../Common/PlatformBase/Services/RasterTypes.h \
-    ../../../Common/PlatformBase/Services/ReaderType.h \
-    ../../../Common/PlatformBase/Services/ResourceDefs.h \
-    ../../../Common/PlatformBase/Services/SpatialContextExtentType.h \
-    ../../../Common/PlatformBase/MapLayer/LayerBase.h \
-    ../../../Common/PlatformBase/MapLayer/LayerCollection.h \
-    ../../../Common/PlatformBase/MapLayer/LayerGroup.h \
-    ../../../Common/PlatformBase/MapLayer/LayerGroupCollection.h \
-    ../../../Common/PlatformBase/MapLayer/MapBase.h \
-    ../../../Common/PlatformBase/MapLayer/MapCollection.h \
-    ../../../Common/PlatformBase/MapLayer/ReadOnlyLayerCollection.h \
-    ../../../Common/PlatformBase/MapLayer/SelectionBase.h \
-    ../../../Common/PlatformBase/MapLayer/LayerGroupType.h \
-    ../../../Common/PlatformBase/MapLayer/LayerType.h \
-    ../../../Common/MapGuideCommon/Exception/AuthenticationFailedException.h \
-    ../../../Common/MapGuideCommon/Exception/ConnectionFailedException.h \
-    ../../../Common/MapGuideCommon/Exception/ConnectionNotOpenException.h \
-    ../../../Common/MapGuideCommon/Exception/DbException.h \
-    ../../../Common/MapGuideCommon/Exception/DbXmlException.h \
-    ../../../Common/MapGuideCommon/Exception/DuplicateGroupException.h \
-    ../../../Common/MapGuideCommon/Exception/DuplicateNameException.h \
-    ../../../Common/MapGuideCommon/Exception/DuplicateParameterException.h \
-    ../../../Common/MapGuideCommon/Exception/DuplicateRepositoryException.h \
-    ../../../Common/MapGuideCommon/Exception/DuplicateRoleException.h \
-    ../../../Common/MapGuideCommon/Exception/DuplicateServerException.h \
-    ../../../Common/MapGuideCommon/Exception/DuplicateSessionException.h \
-    ../../../Common/MapGuideCommon/Exception/DuplicateUserException.h \
-    ../../../Common/MapGuideCommon/Exception/DwfException.h \
-    ../../../Common/MapGuideCommon/Exception/DwfSectionNotFoundException.h \
-    ../../../Common/MapGuideCommon/Exception/DwfSectionResourceNotFoundException.h \
-    ../../../Common/MapGuideCommon/Exception/EndOfStreamException.h \
-    ../../../Common/MapGuideCommon/Exception/GroupNotFoundException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidDwfPackageException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidDwfSectionException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidFeatureSourceException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidIpAddressException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidLicenseException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidLogEntryException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidPasswordException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutFontSizeUnitsException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutPositionUnitsException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutSizeUnitsException.h \
-    ../../../Common/MapGuideCommon/Exception/InvalidServerNameException.h \
-    ../../../Common/MapGuideCommon/Exception/LicenseException.h \
-    ../../../Common/MapGuideCommon/Exception/LicenseExpiredException.h \
-    ../../../Common/MapGuideCommon/Exception/OperationProcessingException.h \
-    ../../../Common/MapGuideCommon/Exception/ParameterNotFoundException.h \
-    ../../../Common/MapGuideCommon/Exception/PathTooLongException.h \
-    ../../../Common/MapGuideCommon/Exception/PortNotAvailableException.h \
-    ../../../Common/MapGuideCommon/Exception/PrintToScaleModeNotSelectedException.h \
-    ../../../Common/MapGuideCommon/Exception/RepositoryCreationFailedException.h \
-    ../../../Common/MapGuideCommon/Exception/RepositoryNotFoundException.h \
-    ../../../Common/MapGuideCommon/Exception/RepositoryNotOpenException.h \
-    ../../../Common/MapGuideCommon/Exception/RepositoryOpenFailedException.h \
-    ../../../Common/MapGuideCommon/Exception/RoleNotFoundException.h \
-    ../../../Common/MapGuideCommon/Exception/ServerNotFoundException.h \
-    ../../../Common/MapGuideCommon/Exception/ServerNotOnlineException.h \
-    ../../../Common/MapGuideCommon/Exception/SessionExpiredException.h \
-    ../../../Common/MapGuideCommon/Exception/SessionNotFoundException.h \
-    ../../../Common/MapGuideCommon/Exception/UnauthorizedAccessException.h \
-    ../../../Common/MapGuideCommon/Exception/UriFormatException.h \
-    ../../../Common/MapGuideCommon/Services/DrawingService.h \
-    ../../../Common/MapGuideCommon/Services/DwfVersion.h \
-    ../../../Common/MapGuideCommon/Services/FeatureInformation.h \
-    ../../../Common/MapGuideCommon/Services/KmlService.h \
-    ../../../Common/MapGuideCommon/Services/Layout.h \
-    ../../../Common/MapGuideCommon/Services/MappingService.h \
-    ../../../Common/MapGuideCommon/Services/MapPlot.h \
-    ../../../Common/MapGuideCommon/Services/MapPlotCollection.h \
-    ../../../Common/MapGuideCommon/Services/PackageStatusInformation.h \
-    ../../../Common/MapGuideCommon/Services/PlotSpecification.h \
-    ../../../Common/MapGuideCommon/Services/ProfilingService.h \
-    ../../../Common/MapGuideCommon/Services/RenderingOptions.h \
-    ../../../Common/MapGuideCommon/Services/RenderingService.h \
-    ../../../Common/MapGuideCommon/Services/ServerAdmin.h \
-    ../../../Common/MapGuideCommon/Services/Site.h \
-    ../../../Common/MapGuideCommon/Services/SiteConnection.h \
-    ../../../Common/MapGuideCommon/Services/SiteInfo.h \
-    ../../../Common/MapGuideCommon/Services/TileService.h \
-    ../../../Common/MapGuideCommon/System/UserInformation.h \
-    ../../../Common/MapGuideCommon/MapLayer/Layer.h \
-    ../../../Common/MapGuideCommon/MapLayer/Map.h \
-    ../../../Common/MapGuideCommon/MapLayer/Selection.h \
-    ../../../Common/MapGuideCommon/Services/MappingDefs.h \
-    ../../../Common/MapGuideCommon/Services/MapPlotInstruction.h \
-    ../../../Common/MapGuideCommon/Services/ServerAdminDefs.h \
-    ../../../Common/MapGuideCommon/Services/UnitType.h \
-    ../../../Common/MapGuideCommon/System/ConfigProperties.h \
-    ../WebApp/WebCommand.h \
-    ../WebApp/WebUiTargetCommand.h \
-    ../WebApp/WebWidget.h \
-    ../WebApp/WebWidgetCollection.h \
-    ../WebApp/WebUiPane.h \
-    ../WebApp/WebUiSizablePane.h \
-    ../WebApp/WebBufferCommand.h \
-    ../WebApp/WebCommandCollection.h \
-    ../WebApp/WebCommandWidget.h \
-    ../WebApp/WebContextMenu.h \
-    ../WebApp/WebFlyoutWidget.h \
-    ../WebApp/WebGetPrintablePageCommand.h \
-    ../WebApp/WebHelpCommand.h \
-    ../WebApp/WebInformationPane.h \
-    ../WebApp/WebInvokeScriptCommand.h \
-    ../WebApp/WebInvokeUrlCommand.h \
-    ../WebApp/WebLayout.h \
-    ../WebApp/WebMeasureCommand.h \
-    ../WebApp/WebPrintCommand.h \
-    ../WebApp/WebSearchCommand.h \
-    ../WebApp/WebSelectWithinCommand.h \
-    ../WebApp/WebSeparatorWidget.h \
-    ../WebApp/WebTaskBar.h \
-    ../WebApp/WebTaskBarWidget.h \
-    ../WebApp/WebTaskPane.h \
-    ../WebApp/WebToolbar.h \
-    ../WebApp/WebViewOptionsCommand.h \
-    ../WebApp/WebActions.h \
-    ../WebApp/WebTargetType.h \
-    ../WebApp/WebTargetViewerType.h \
-    ../WebApp/WebTaskButtonType.h \
-    ../WebApp/WebWidgetType.h \
-    ../HttpHandler/HttpHeader.h \
-    ../HttpHandler/HttpPrimitiveValue.h \
-    ../HttpHandler/HttpRequest.h \
-    ../HttpHandler/HttpRequestMetadata.h \
-    ../HttpHandler/HttpRequestParam.h \
-    ../HttpHandler/HttpResponse.h \
-    ../HttpHandler/HttpResult.h
-	../../../BuildTools/WebTools/IMake/Linux/IMake ../MapGuideApi/MapGuideApiGen.xml Java
-	cp -f java.i language.i
-	../../../BuildTools/WebTools/IMake/Linux/IMake ../MapGuideApi/Constants.xml Java .
-	../../../Oem/SWIGEx/Linux/swig -dllname MapGuideJavaApiEx -c++ -java -mgjavanothrow -mgjavacasing -DJAVA -package org.osgeo.mapguide -root MgObject -baseexception MgException -clsidcode getclassid.code -clsiddata m_cls_id -catchallcode catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise();" -nodefault -noconstants -module MapGuideJavaApiEx -o MgApi_wrap.cpp -lib ../../../Oem/SWIGEx/Lib MapGuideApi.i
-	rm -f org/osgeo/mapguide/*.class
-	mv -f *.java org/osgeo/mapguide
-	$(JAVA_HOME)/bin/javac -classpath . org/osgeo/mapguide/*.java
-	$(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApiEx.jar org/osgeo/mapguide/*.class
Copied: trunk/MgDev/Web/src/JavaApiEx/Makefile.am (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/Makefile.am)
--- trunk/MgDev/Web/src/JavaApiEx/Makefile.am	                        (rev 0)
@@ -0,0 +1,468 @@
+AUTOMAKE_OPTIONS = foreign
+EXTRA_DIST = getclassid.code \
+             catchall.code \
+             java.i \
+             JavaApiEx.rc \
+             JavaApiEx.vcproj \
+             org/osgeo/mapguide/AppThrowable.java \
+             org/osgeo/mapguide/MgBase64.java \
+             org/osgeo/mapguide/MgLocalizer.java
+prefix=@prefix@/webserverextensions
+INCLUDES = -I../../../Common/MdfModel \
+           -I../../../Common/Foundation \
+           -I../../../Common/Geometry \
+           -I../../../Common/PlatformBase \
+           -I../../../Common/MapGuideCommon \
+           -I$(JAVA_HOME)/include \
+           -I$(JAVA_HOME)/include/linux \
+           -I../../../Oem/ACE/ACE_wrappers \
+           -I../HttpHandler \
+           -I../WebSupport \
+           -I../WebApp \
+           -I../../../Oem/dbxml/xerces-c-src/src
+BUILT_SOURCES = MgApi_wrap.cpp
+lib_LTLIBRARIES = libMapGuideJavaApiEx.la
+nodist_libMapGuideJavaApiEx_la_SOURCES = MgApi_wrap.cpp
+AM_CXXFLAGS = @CXXFLAGS@ -fno-strict-aliasing -DJAVA
+libMapGuideJavaApiEx_la_LIBADD = \
+    -lACE \
+    -lMgFoundation \
+    -lMgGeometry \
+    -lMgPlatformBase \
+    -lMgMapGuideCommon \
+    -lMgHttpHandler \
+    -lMgMdfModel \
+    -lMgMdfParser \
+    -lxerces-c \
+    -lMgWebApp
+libMapGuideJavaApiEx_la_LDFLAGS = -release $(PACKAGE_VERSION) \
+    -L../../../Oem/ACE/ACE_wrappers/ace \
+    -L../../../Common/MdfModel \
+    -L../../../Common/MdfParser \
+    -L../../../Common/Foundation \
+    -L../../../Common/Geometry \
+    -L../../../Common/PlatformBase \
+    -L../../../Common/MapGuideCommon \
+    -L../HttpHandler \
+    -L../WebApp \
+    -L../../../Oem/dbxml/install/lib
+MgApi_wrap.cpp : \
+    ../WebApp/WebApp.h \
+    ../WebSupport/InitializeWebTier.cpp \
+    ../../../Common/MdfModel/UnicodeString.h \
+    ../HttpHandler/HttpHandlerApiDllExport.h \
+    ../HttpHandler/HttpHandler.h \
+    ../../../Common/Foundation/System/Object.h \
+    ../../../Common/Foundation/System/Disposable.h \
+    ../../../Common/Foundation/System/GuardDisposable.h \
+    ../../../Common/Foundation/System/Serializable.h \
+    ../../../Common/Foundation/System/NamedSerializable.h \
+    ../../../Common/Foundation/Data/Collection.h \
+    ../../../Common/Foundation/Data/Property.h \
+    ../../../Common/Foundation/System/DisposableCollection.h \
+    ../../../Common/Foundation/Data/BatchPropertyCollection.h \
+    ../../../Common/Foundation/Data/ByteReader.h \
+    ../../../Common/Foundation/Data/ByteSource.h \
+    ../../../Common/Foundation/Data/ByteSink.h \
+    ../../../Common/Foundation/Data/DateTime.h \
+    ../../../Common/Foundation/Data/NullableProperty.h \
+    ../../../Common/Foundation/Data/PropertyCollection.h \
+    ../../../Common/Foundation/Data/PropertyDefinition.h \
+    ../../../Common/Foundation/Data/StringCollection.h \
+    ../../../Common/Foundation/Data/StringProperty.h \
+    ../../../Common/Foundation/Data/FeaturePropertyType.h \
+    ../../../Common/Foundation/Data/MimeType.h \
+    ../../../Common/Foundation/Data/PropertyType.h \
+    ../../../Common/Foundation/Exception/Exception.h \
+    ../../../Common/Foundation/Exception/SystemException.h \
+    ../../../Common/Foundation/Exception/IoException.h \
+    ../../../Common/Foundation/Exception/FileIoException.h \
+    ../../../Common/Foundation/Exception/ApplicationException.h \
+    ../../../Common/Foundation/Exception/ThirdPartyException.h \
+    ../../../Common/Foundation/Exception/StreamIoException.h \
+    ../../../Common/Foundation/Exception/OutOfRangeException.h \
+    ../../../Common/Foundation/Exception/ArgumentOutOfRangeException.h \
+    ../../../Common/Foundation/Exception/ClassNotFoundException.h \
+    ../../../Common/Foundation/Exception/ConfigurationException.h \
+    ../../../Common/Foundation/Exception/ConfigurationLoadFailedException.h \
+    ../../../Common/Foundation/Exception/ConfigurationSaveFailedException.h \
+    ../../../Common/Foundation/Exception/DateTimeException.h \
+    ../../../Common/Foundation/Exception/DecryptionException.h \
+    ../../../Common/Foundation/Exception/DirectoryNotFoundException.h \
+    ../../../Common/Foundation/Exception/DivideByZeroException.h \
+    ../../../Common/Foundation/Exception/DomainException.h \
+    ../../../Common/Foundation/Exception/DuplicateDirectoryException.h \
+    ../../../Common/Foundation/Exception/DuplicateFileException.h \
+    ../../../Common/Foundation/Exception/DuplicateObjectException.h \
+    ../../../Common/Foundation/Exception/EncryptionException.h \
+    ../../../Common/Foundation/Exception/FileNotFoundException.h \
+    ../../../Common/Foundation/Exception/IndexOutOfRangeException.h \
+    ../../../Common/Foundation/Exception/InvalidArgumentException.h \
+    ../../../Common/Foundation/Exception/InvalidCastException.h \
+    ../../../Common/Foundation/Exception/InvalidOperationException.h \
+    ../../../Common/Foundation/Exception/InvalidPropertyTypeException.h \
+    ../../../Common/Foundation/Exception/InvalidStreamHeaderException.h \
+    ../../../Common/Foundation/Exception/LengthException.h \
+    ../../../Common/Foundation/Exception/LogicException.h \
+    ../../../Common/Foundation/Exception/NotFiniteNumberException.h \
+    ../../../Common/Foundation/Exception/NotImplementedException.h \
+    ../../../Common/Foundation/Exception/NullArgumentException.h \
+    ../../../Common/Foundation/Exception/NullPropertyValueException.h \
+    ../../../Common/Foundation/Exception/NullReferenceException.h \
+    ../../../Common/Foundation/Exception/ObjectNotFoundException.h \
+    ../../../Common/Foundation/Exception/OutOfMemoryException.h \
+    ../../../Common/Foundation/Exception/OverflowException.h \
+    ../../../Common/Foundation/Exception/PlatformNotSupportedException.h \
+    ../../../Common/Foundation/Exception/ResourcesException.h \
+    ../../../Common/Foundation/Exception/ResourcesLoadFailedException.h \
+    ../../../Common/Foundation/Exception/RuntimeException.h \
+    ../../../Common/Foundation/Exception/TemporaryFileNotAvailableException.h \
+    ../../../Common/Foundation/Exception/UnclassifiedException.h \
+    ../../../Common/Foundation/Exception/UnderflowException.h \
+    ../../../Common/Foundation/Exception/XmlException.h \
+    ../../../Common/Foundation/Exception/XmlParserException.h \
+    ../../../Common/Geometry/GeometricEntity.h \
+    ../../../Common/Geometry/Geometry.h \
+    ../../../Common/Geometry/GeometryComponent.h \
+    ../../../Common/Geometry/Curve.h \
+    ../../../Common/Geometry/CurveSegment.h \
+    ../../../Common/Geometry/Ring.h \
+    ../../../Common/Geometry/Region.h \
+    ../../../Common/Geometry/AgfReaderWriter.h \
+    ../../../Common/Geometry/AggregateGeometry.h \
+    ../../../Common/Geometry/ArcSegment.h \
+    ../../../Common/Geometry/Coordinate.h \
+    ../../../Common/Geometry/CoordinateCollection.h \
+    ../../../Common/Geometry/CoordinateIterator.h \
+    ../../../Common/Geometry/CoordinateXY.h \
+    ../../../Common/Geometry/CoordinateXYM.h \
+    ../../../Common/Geometry/CoordinateXYZ.h \
+    ../../../Common/Geometry/CoordinateXYZM.h \
+    ../../../Common/Geometry/CurvePolygon.h \
+    ../../../Common/Geometry/CurvePolygonCollection.h \
+    ../../../Common/Geometry/CurveRing.h \
+    ../../../Common/Geometry/CurveRingCollection.h \
+    ../../../Common/Geometry/CurveSegmentCollection.h \
+    ../../../Common/Geometry/CurveString.h \
+    ../../../Common/Geometry/CurveStringCollection.h \
+    ../../../Common/Geometry/Envelope.h \
+    ../../../Common/Geometry/GeometryCollection.h \
+    ../../../Common/Geometry/GeometryFactory.h \
+    ../../../Common/Geometry/LinearRing.h \
+    ../../../Common/Geometry/LinearRingCollection.h \
+    ../../../Common/Geometry/LinearSegment.h \
+    ../../../Common/Geometry/LineString.h \
+    ../../../Common/Geometry/LineStringCollection.h \
+    ../../../Common/Geometry/Measure.h \
+    ../../../Common/Geometry/MultiCurvePolygon.h \
+    ../../../Common/Geometry/MultiCurveString.h \
+    ../../../Common/Geometry/MultiGeometry.h \
+    ../../../Common/Geometry/MultiLineString.h \
+    ../../../Common/Geometry/MultiPoint.h \
+    ../../../Common/Geometry/MultiPolygon.h \
+    ../../../Common/Geometry/Point.h \
+    ../../../Common/Geometry/PointCollection.h \
+    ../../../Common/Geometry/Polygon.h \
+    ../../../Common/Geometry/PolygonCollection.h \
+    ../../../Common/Geometry/Transform.h \
+    ../../../Common/Geometry/WktReaderWriter.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystem.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryBase.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCatalog.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCategory.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCategoryDictionary.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDatumDictionary.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformDefParams.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionary.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryUtility.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoidDictionary.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFactory.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformation.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMathComparator.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionInformation.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h \
+    ../../../Common/Geometry/Exception/CoordinateSystemComputationFailedException.h \
+    ../../../Common/Geometry/Exception/CoordinateSystemConversionFailedException.h \
+    ../../../Common/Geometry/Exception/CoordinateSystemInitializationFailedException.h \
+    ../../../Common/Geometry/Exception/CoordinateSystemLoadFailedException.h \
+    ../../../Common/Geometry/Exception/CoordinateSystemMeasureFailedException.h \
+    ../../../Common/Geometry/Exception/CoordinateSystemTransformFailedException.h \
+    ../../../Common/Geometry/Exception/GeometryException.h \
+    ../../../Common/Geometry/Exception/InvalidCoordinateSystemException.h \
+    ../../../Common/Geometry/Exception/InvalidCoordinateSystemTypeException.h \
+    ../../../Common/Geometry/Exception/InvalidCoordinateSystemUnitsException.h \
+    ../../../Common/Geometry/CoordinateDimension.h \
+    ../../../Common/Geometry/GeometricEntityType.h \
+    ../../../Common/Geometry/GeometricPathInstructionType.h \
+    ../../../Common/Geometry/GeometryComponentType.h \
+    ../../../Common/Geometry/GeometryType.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemCodeFormat.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionLogicalType.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemProjectionParameterType.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemType.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitCode.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemUnitType.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemWktFlavor.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h \
+	../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformationMethod.h \
+    ../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h \
+    ../../../Common/PlatformBase/Data/BlobProperty.h \
+    ../../../Common/PlatformBase/Data/BooleanProperty.h \
+    ../../../Common/PlatformBase/Data/ByteProperty.h \
+    ../../../Common/PlatformBase/Data/ClobProperty.h \
+    ../../../Common/PlatformBase/Data/Color.h \
+    ../../../Common/PlatformBase/Data/DateTimeProperty.h \
+    ../../../Common/PlatformBase/Data/DoubleProperty.h \
+    ../../../Common/PlatformBase/Data/Int16Property.h \
+    ../../../Common/PlatformBase/Data/Int32Property.h \
+    ../../../Common/PlatformBase/Data/Int64Property.h \
+    ../../../Common/PlatformBase/Data/IntCollection.h \
+    ../../../Common/PlatformBase/Data/PropertyDefinitionCollection.h \
+    ../../../Common/PlatformBase/Data/SingleProperty.h \
+    ../../../Common/PlatformBase/Data/StringPropertyCollection.h \
+    ../../../Common/PlatformBase/Exception/ArrayTypeMismatchException.h \
+    ../../../Common/PlatformBase/Exception/DuplicateResourceDataException.h \
+    ../../../Common/PlatformBase/Exception/DuplicateResourceException.h \
+    ../../../Common/PlatformBase/Exception/EmptyFeatureSetException.h \
+    ../../../Common/PlatformBase/Exception/FdoException.h \
+    ../../../Common/PlatformBase/Exception/FeatureServiceException.h \
+    ../../../Common/PlatformBase/Exception/InvalidMapDefinitionException.h \
+    ../../../Common/PlatformBase/Exception/InvalidRepositoryNameException.h \
+    ../../../Common/PlatformBase/Exception/InvalidRepositoryTypeException.h \
+    ../../../Common/PlatformBase/Exception/InvalidResourceDataNameException.h \
+    ../../../Common/PlatformBase/Exception/InvalidResourceDataTypeException.h \
+    ../../../Common/PlatformBase/Exception/InvalidResourceNameException.h \
+    ../../../Common/PlatformBase/Exception/InvalidResourcePathException.h \
+    ../../../Common/PlatformBase/Exception/InvalidResourcePreProcessingTypeException.h \
+    ../../../Common/PlatformBase/Exception/InvalidResourceTypeException.h \
+    ../../../Common/PlatformBase/Exception/LayerNotFoundException.h \
+    ../../../Common/PlatformBase/Exception/ResourceBusyException.h \
+    ../../../Common/PlatformBase/Exception/ResourceDataNotFoundException.h \
+    ../../../Common/PlatformBase/Exception/ResourceNotFoundException.h \
+    ../../../Common/PlatformBase/Exception/ServiceNotAvailableException.h \
+    ../../../Common/PlatformBase/Exception/ServiceNotSupportedException.h \
+    ../../../Common/PlatformBase/Exception/UserNotFoundException.h \
+    ../../../Common/PlatformBase/Services/FeatureCommand.h \
+    ../../../Common/PlatformBase/Services/FeatureQueryOptions.h \
+    ../../../Common/PlatformBase/Services/FeatureSourceParams.h \
+    ../../../Common/PlatformBase/Services/Reader.h \
+    ../../../Common/PlatformBase/Services/Service.h \
+    ../../../Common/PlatformBase/Services/BaseService.h \
+    ../../../Common/PlatformBase/Services/ClassDefinition.h \
+    ../../../Common/PlatformBase/Services/ClassDefinitionCollection.h \
+    ../../../Common/PlatformBase/Services/FileFeatureSourceParams.h \
+    ../../../Common/PlatformBase/Services/CreateSdfParams.h \
+    ../../../Common/PlatformBase/Services/DataPropertyDefinition.h \
+    ../../../Common/PlatformBase/Services/DataReader.h \
+    ../../../Common/PlatformBase/Services/DeleteFeatures.h \
+    ../../../Common/PlatformBase/Services/FeatureAggregateOptions.h \
+    ../../../Common/PlatformBase/Services/FeatureCommandCollection.h \
+    ../../../Common/PlatformBase/Services/FeatureProperty.h \
+    ../../../Common/PlatformBase/Services/FeatureReader.h \
+    ../../../Common/PlatformBase/Services/FeatureSchema.h \
+    ../../../Common/PlatformBase/Services/FeatureSchemaCollection.h \
+    ../../../Common/PlatformBase/Services/FeatureService.h \
+    ../../../Common/PlatformBase/Services/GeometricPropertyDefinition.h \
+    ../../../Common/PlatformBase/Services/GeometryProperty.h \
+    ../../../Common/PlatformBase/Services/GeometryTypeInfo.h \
+    ../../../Common/PlatformBase/Services/GwsFeatureReader.h \
+    ../../../Common/PlatformBase/Services/InsertFeatures.h \
+    ../../../Common/PlatformBase/Services/LongTransactionReader.h \
+    ../../../Common/PlatformBase/Services/ObjectPropertyDefinition.h \
+    ../../../Common/PlatformBase/Services/Parameter.h \
+    ../../../Common/PlatformBase/Services/ParameterCollection.h \
+    ../../../Common/PlatformBase/Services/Raster.h \
+    ../../../Common/PlatformBase/Services/RasterProperty.h \
+    ../../../Common/PlatformBase/Services/RasterPropertyDefinition.h \
+    ../../../Common/PlatformBase/Services/Resource.h \
+    ../../../Common/PlatformBase/Services/ResourceIdentifier.h \
+    ../../../Common/PlatformBase/Services/ResourceService.h \
+    ../../../Common/PlatformBase/Services/SpatialContextReader.h \
+    ../../../Common/PlatformBase/Services/SqlDataReader.h \
+    ../../../Common/PlatformBase/Services/Transaction.h \
+    ../../../Common/PlatformBase/Services/UpdateFeatures.h \
+    ../../../Common/PlatformBase/Services/Warnings.h \
+    ../../../Common/PlatformBase/Services/BaseServiceDefs.h \
+    ../../../Common/PlatformBase/Services/FeatureCommandType.h \
+    ../../../Common/PlatformBase/Services/FeatureGeometricType.h \
+    ../../../Common/PlatformBase/Services/FeatureSpatialOperations.h \
+    ../../../Common/PlatformBase/Services/ObjectPropertyType.h \
+    ../../../Common/PlatformBase/Services/OrderingOption.h \
+    ../../../Common/PlatformBase/Services/ParameterDirection.h \
+    ../../../Common/PlatformBase/Services/RasterTypes.h \
+    ../../../Common/PlatformBase/Services/ReaderType.h \
+    ../../../Common/PlatformBase/Services/ResourceDefs.h \
+    ../../../Common/PlatformBase/Services/SpatialContextExtentType.h \
+    ../../../Common/PlatformBase/MapLayer/LayerBase.h \
+    ../../../Common/PlatformBase/MapLayer/LayerCollection.h \
+    ../../../Common/PlatformBase/MapLayer/LayerGroup.h \
+    ../../../Common/PlatformBase/MapLayer/LayerGroupCollection.h \
+    ../../../Common/PlatformBase/MapLayer/MapBase.h \
+    ../../../Common/PlatformBase/MapLayer/MapCollection.h \
+    ../../../Common/PlatformBase/MapLayer/ReadOnlyLayerCollection.h \
+    ../../../Common/PlatformBase/MapLayer/SelectionBase.h \
+    ../../../Common/PlatformBase/MapLayer/LayerGroupType.h \
+    ../../../Common/PlatformBase/MapLayer/LayerType.h \
+    ../../../Common/MapGuideCommon/Exception/AuthenticationFailedException.h \
+    ../../../Common/MapGuideCommon/Exception/ConnectionFailedException.h \
+    ../../../Common/MapGuideCommon/Exception/ConnectionNotOpenException.h \
+    ../../../Common/MapGuideCommon/Exception/DbException.h \
+    ../../../Common/MapGuideCommon/Exception/DbXmlException.h \
+    ../../../Common/MapGuideCommon/Exception/DuplicateGroupException.h \
+    ../../../Common/MapGuideCommon/Exception/DuplicateNameException.h \
+    ../../../Common/MapGuideCommon/Exception/DuplicateParameterException.h \
+    ../../../Common/MapGuideCommon/Exception/DuplicateRepositoryException.h \
+    ../../../Common/MapGuideCommon/Exception/DuplicateRoleException.h \
+    ../../../Common/MapGuideCommon/Exception/DuplicateServerException.h \
+    ../../../Common/MapGuideCommon/Exception/DuplicateSessionException.h \
+    ../../../Common/MapGuideCommon/Exception/DuplicateUserException.h \
+    ../../../Common/MapGuideCommon/Exception/DwfException.h \
+    ../../../Common/MapGuideCommon/Exception/DwfSectionNotFoundException.h \
+    ../../../Common/MapGuideCommon/Exception/DwfSectionResourceNotFoundException.h \
+    ../../../Common/MapGuideCommon/Exception/EndOfStreamException.h \
+    ../../../Common/MapGuideCommon/Exception/GroupNotFoundException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidDwfPackageException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidDwfSectionException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidFeatureSourceException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidIpAddressException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidLicenseException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidLogEntryException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidPasswordException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutFontSizeUnitsException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutPositionUnitsException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutSizeUnitsException.h \
+    ../../../Common/MapGuideCommon/Exception/InvalidServerNameException.h \
+    ../../../Common/MapGuideCommon/Exception/LicenseException.h \
+    ../../../Common/MapGuideCommon/Exception/LicenseExpiredException.h \
+    ../../../Common/MapGuideCommon/Exception/OperationProcessingException.h \
+    ../../../Common/MapGuideCommon/Exception/ParameterNotFoundException.h \
+    ../../../Common/MapGuideCommon/Exception/PathTooLongException.h \
+    ../../../Common/MapGuideCommon/Exception/PortNotAvailableException.h \
+    ../../../Common/MapGuideCommon/Exception/PrintToScaleModeNotSelectedException.h \
+    ../../../Common/MapGuideCommon/Exception/RepositoryCreationFailedException.h \
+    ../../../Common/MapGuideCommon/Exception/RepositoryNotFoundException.h \
+    ../../../Common/MapGuideCommon/Exception/RepositoryNotOpenException.h \
+    ../../../Common/MapGuideCommon/Exception/RepositoryOpenFailedException.h \
+    ../../../Common/MapGuideCommon/Exception/RoleNotFoundException.h \
+    ../../../Common/MapGuideCommon/Exception/ServerNotFoundException.h \
+    ../../../Common/MapGuideCommon/Exception/ServerNotOnlineException.h \
+    ../../../Common/MapGuideCommon/Exception/SessionExpiredException.h \
+    ../../../Common/MapGuideCommon/Exception/SessionNotFoundException.h \
+    ../../../Common/MapGuideCommon/Exception/UnauthorizedAccessException.h \
+    ../../../Common/MapGuideCommon/Exception/UriFormatException.h \
+    ../../../Common/MapGuideCommon/Services/DrawingService.h \
+    ../../../Common/MapGuideCommon/Services/DwfVersion.h \
+    ../../../Common/MapGuideCommon/Services/FeatureInformation.h \
+    ../../../Common/MapGuideCommon/Services/KmlService.h \
+    ../../../Common/MapGuideCommon/Services/Layout.h \
+    ../../../Common/MapGuideCommon/Services/MappingService.h \
+    ../../../Common/MapGuideCommon/Services/MapPlot.h \
+    ../../../Common/MapGuideCommon/Services/MapPlotCollection.h \
+    ../../../Common/MapGuideCommon/Services/PackageStatusInformation.h \
+    ../../../Common/MapGuideCommon/Services/PlotSpecification.h \
+    ../../../Common/MapGuideCommon/Services/ProfilingService.h \
+    ../../../Common/MapGuideCommon/Services/RenderingOptions.h \
+    ../../../Common/MapGuideCommon/Services/RenderingService.h \
+    ../../../Common/MapGuideCommon/Services/ServerAdmin.h \
+    ../../../Common/MapGuideCommon/Services/Site.h \
+    ../../../Common/MapGuideCommon/Services/SiteConnection.h \
+    ../../../Common/MapGuideCommon/Services/SiteInfo.h \
+    ../../../Common/MapGuideCommon/Services/TileService.h \
+    ../../../Common/MapGuideCommon/System/UserInformation.h \
+    ../../../Common/MapGuideCommon/MapLayer/Layer.h \
+    ../../../Common/MapGuideCommon/MapLayer/Map.h \
+    ../../../Common/MapGuideCommon/MapLayer/Selection.h \
+    ../../../Common/MapGuideCommon/Services/MappingDefs.h \
+    ../../../Common/MapGuideCommon/Services/MapPlotInstruction.h \
+    ../../../Common/MapGuideCommon/Services/ServerAdminDefs.h \
+    ../../../Common/MapGuideCommon/Services/UnitType.h \
+    ../../../Common/MapGuideCommon/System/ConfigProperties.h \
+    ../WebApp/WebCommand.h \
+    ../WebApp/WebUiTargetCommand.h \
+    ../WebApp/WebWidget.h \
+    ../WebApp/WebWidgetCollection.h \
+    ../WebApp/WebUiPane.h \
+    ../WebApp/WebUiSizablePane.h \
+    ../WebApp/WebBufferCommand.h \
+    ../WebApp/WebCommandCollection.h \
+    ../WebApp/WebCommandWidget.h \
+    ../WebApp/WebContextMenu.h \
+    ../WebApp/WebFlyoutWidget.h \
+    ../WebApp/WebGetPrintablePageCommand.h \
+    ../WebApp/WebHelpCommand.h \
+    ../WebApp/WebInformationPane.h \
+    ../WebApp/WebInvokeScriptCommand.h \
+    ../WebApp/WebInvokeUrlCommand.h \
+    ../WebApp/WebLayout.h \
+    ../WebApp/WebMeasureCommand.h \
+    ../WebApp/WebPrintCommand.h \
+    ../WebApp/WebSearchCommand.h \
+    ../WebApp/WebSelectWithinCommand.h \
+    ../WebApp/WebSeparatorWidget.h \
+    ../WebApp/WebTaskBar.h \
+    ../WebApp/WebTaskBarWidget.h \
+    ../WebApp/WebTaskPane.h \
+    ../WebApp/WebToolbar.h \
+    ../WebApp/WebViewOptionsCommand.h \
+    ../WebApp/WebActions.h \
+    ../WebApp/WebTargetType.h \
+    ../WebApp/WebTargetViewerType.h \
+    ../WebApp/WebTaskButtonType.h \
+    ../WebApp/WebWidgetType.h \
+    ../HttpHandler/HttpHeader.h \
+    ../HttpHandler/HttpPrimitiveValue.h \
+    ../HttpHandler/HttpRequest.h \
+    ../HttpHandler/HttpRequestMetadata.h \
+    ../HttpHandler/HttpRequestParam.h \
+    ../HttpHandler/HttpResponse.h \
+    ../HttpHandler/HttpResult.h
+	../../../BuildTools/WebTools/IMake/Linux/IMake ../MapGuideApi/MapGuideApiGen.xml Java
+	cp -f java.i language.i
+	../../../BuildTools/WebTools/IMake/Linux/IMake ../MapGuideApi/Constants.xml Java .
+	../../../Oem/SWIGEx/Linux/swig -dllname MapGuideJavaApiEx -c++ -java -mgjavanothrow -mgjavacasing -DJAVA -package org.osgeo.mapguide -root MgObject -baseexception MgException -clsidcode getclassid.code -clsiddata m_cls_id -catchallcode catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise();" -nodefault -noconstants -module MapGuideJavaApiEx -o MgApi_wrap.cpp -lib ../../../Oem/SWIGEx/Lib MapGuideApi.i
+	rm -f org/osgeo/mapguide/*.class
+	mv -f *.java org/osgeo/mapguide
+	$(JAVA_HOME)/bin/javac -classpath . org/osgeo/mapguide/*.java
+	$(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApiEx.jar org/osgeo/mapguide/*.class
Deleted: trunk/MgDev/Web/src/JavaApiEx/catchall.code
--- sandbox/jng/swig-java/Web/src/JavaApiEx/catchall.code	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/catchall.code	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,8 +0,0 @@
-void onCatchAll(JNIEnv* jenv, const char* proxyfname)
-    string s = proxyfname;
-    wstring fname = MgUtil::MultiByteToWideChar(s);
-    MgUnclassifiedException* e = new MgUnclassifiedException(fname, __LINE__, __WFILE__, NULL, L"", NULL);
-    ThrowJavaExceptionWrapper(jenv, e);
Copied: trunk/MgDev/Web/src/JavaApiEx/catchall.code (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/catchall.code)
--- trunk/MgDev/Web/src/JavaApiEx/catchall.code	                        (rev 0)
@@ -0,0 +1,8 @@
+void onCatchAll(JNIEnv* jenv, const char* proxyfname)
+    string s = proxyfname;
+    wstring fname = MgUtil::MultiByteToWideChar(s);
+    MgUnclassifiedException* e = new MgUnclassifiedException(fname, __LINE__, __WFILE__, NULL, L"", NULL);
+    ThrowJavaExceptionWrapper(jenv, e);
Deleted: trunk/MgDev/Web/src/JavaApiEx/getclassid.code
--- sandbox/jng/swig-java/Web/src/JavaApiEx/getclassid.code	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/getclassid.code	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,6 +0,0 @@
-/* Get a class identifier from an Object instance */
-JNIEXPORT jint JNICALL Java_org_osgeo_mapguide_MapGuideJavaApiExJNI_getClassId(JNIEnv* jenv, jclass jcls, jlong jarg1)
-  return ((MgObject*)(void*)jarg1)->GetClassId();
Copied: trunk/MgDev/Web/src/JavaApiEx/getclassid.code (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/getclassid.code)
--- trunk/MgDev/Web/src/JavaApiEx/getclassid.code	                        (rev 0)
@@ -0,0 +1,6 @@
+/* Get a class identifier from an Object instance */
+JNIEXPORT jint JNICALL Java_org_osgeo_mapguide_MapGuideJavaApiExJNI_getClassId(JNIEnv* jenv, jclass jcls, jlong jarg1)
+  return ((MgObject*)(void*)jarg1)->GetClassId();
Deleted: trunk/MgDev/Web/src/JavaApiEx/java.i
--- sandbox/jng/swig-java/Web/src/JavaApiEx/java.i	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/java.i	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,103 +0,0 @@
-//  Copyright (C) 2004-2011 by Autodesk, Inc.
-//  This library is free software; you can redistribute it and/or
-//  modify it under the terms of version 2.1 of the GNU Lesser
-//  General Public License as published by the Free Software Foundation.
-//  This library is distributed in the hope that it will be useful,
-//  but WITHOUT ANY WARRANTY; without even the implied warranty of
-//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-//  Lesser General Public License for more details.
-//  You should have received a copy of the GNU Lesser General Public
-//  License along with this library; if not, write to the Free Software
-//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-%typemap(jni) STRINGPARAM "jstring"
-%typemap(jtype) STRINGPARAM "String"
-%typemap(jstype) STRINGPARAM "String"
-%typemap(javain) STRINGPARAM "$javainput"
-%typemap(in) STRINGPARAM
-    if($input == NULL)
-       $1 = std::wstring(L"");
-    else
-        int len = jenv->GetStringLength($input);
-        const jchar *pstr = jenv->GetStringChars($input, 0);
-        if (!pstr)
-            $1 = std::wstring(L"ERROR: SWIG string conversion");
-        else
-#ifdef WIN32
-            $1 =  std::wstring((const wchar_t*)pstr, len);
-#else
-            xstring u16String = xstring((XMLCh*)pstr, len);
-            lstring u32String;
-            UnicodeString::UTF16toUTF32(u16String.c_str(),u32String);
-            $1 =  std::wstring((const wchar_t*) u32String.c_str());
-#endif
-            jenv->ReleaseStringChars($input, pstr);
-%typemap(jni) STRING "jstring"
-%typemap(jtype) STRING "String"
-%typemap(jstype) STRING "String"
-%typemap(javaout) STRING
-  { return $jnicall; }
-%typemap(out) STRING
-#ifdef WIN32
-    jresult = jenv->NewString((const jchar *)result.c_str(), (jsize)result.length());
-#else
-    xstring u16String;
-    UnicodeString::UTF32toUTF16((const LCh*) result.c_str(), u16String);
-    jresult = jenv->NewString((const jchar *)u16String.c_str(), (jsize)u16String.length());
-#endif
-%typemap(jni) BYTE_ARRAY_IN "jbyteArray"
-%typemap(jtype) BYTE_ARRAY_IN "byte[]"
-%typemap(jstype) BYTE_ARRAY_IN "byte[]"
-%typemap(in) BYTE_ARRAY_IN (jbyte* bytes)
-    bytes = jenv->GetByteArrayElements($input, 0);
-    if (!bytes)
-        return $null;
-    $1 = (BYTE_ARRAY_IN)bytes;
-%typemap(freearg) BYTE_ARRAY_IN
-    jenv->ReleaseByteArrayElements($input, bytes$argnum, 0);
-%typemap(javain) BYTE_ARRAY_IN "$javainput"
-%typemap(jni) BYTE_ARRAY_OUT "jbyteArray"
-%typemap(jtype) BYTE_ARRAY_OUT "byte[]"
-%typemap(jstype) BYTE_ARRAY_OUT "byte[]"
-%typemap(in) BYTE_ARRAY_OUT (jbyte* bytes)
-    if (!bytes)
-        return $null;
-    $1 = (BYTE_ARRAY_OUT)bytes;
-%typemap(freearg) BYTE_ARRAY_OUT
-    jenv->ReleaseByteArrayElements($input, bytes$argnum, JNI_COMMIT);
-%typemap(javain) BYTE_ARRAY_OUT "$javainput"
-%include "javaextensions.i"
-// Global functions
-void MgInitializeWebTier(STRINGPARAM configFile);
Copied: trunk/MgDev/Web/src/JavaApiEx/java.i (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/java.i)
--- trunk/MgDev/Web/src/JavaApiEx/java.i	                        (rev 0)
@@ -0,0 +1,103 @@
+//  Copyright (C) 2004-2011 by Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+%typemap(jni) STRINGPARAM "jstring"
+%typemap(jtype) STRINGPARAM "String"
+%typemap(jstype) STRINGPARAM "String"
+%typemap(javain) STRINGPARAM "$javainput"
+%typemap(in) STRINGPARAM
+    if($input == NULL)
+       $1 = std::wstring(L"");
+    else
+        int len = jenv->GetStringLength($input);
+        const jchar *pstr = jenv->GetStringChars($input, 0);
+        if (!pstr)
+            $1 = std::wstring(L"ERROR: SWIG string conversion");
+        else
+#ifdef WIN32
+            $1 =  std::wstring((const wchar_t*)pstr, len);
+#else
+            xstring u16String = xstring((XMLCh*)pstr, len);
+            lstring u32String;
+            UnicodeString::UTF16toUTF32(u16String.c_str(),u32String);
+            $1 =  std::wstring((const wchar_t*) u32String.c_str());
+#endif
+            jenv->ReleaseStringChars($input, pstr);
+%typemap(jni) STRING "jstring"
+%typemap(jtype) STRING "String"
+%typemap(jstype) STRING "String"
+%typemap(javaout) STRING
+  { return $jnicall; }
+%typemap(out) STRING
+#ifdef WIN32
+    jresult = jenv->NewString((const jchar *)result.c_str(), (jsize)result.length());
+#else
+    xstring u16String;
+    UnicodeString::UTF32toUTF16((const LCh*) result.c_str(), u16String);
+    jresult = jenv->NewString((const jchar *)u16String.c_str(), (jsize)u16String.length());
+#endif
+%typemap(jni) BYTE_ARRAY_IN "jbyteArray"
+%typemap(jtype) BYTE_ARRAY_IN "byte[]"
+%typemap(jstype) BYTE_ARRAY_IN "byte[]"
+%typemap(in) BYTE_ARRAY_IN (jbyte* bytes)
+    bytes = jenv->GetByteArrayElements($input, 0);
+    if (!bytes)
+        return $null;
+    $1 = (BYTE_ARRAY_IN)bytes;
+%typemap(freearg) BYTE_ARRAY_IN
+    jenv->ReleaseByteArrayElements($input, bytes$argnum, 0);
+%typemap(javain) BYTE_ARRAY_IN "$javainput"
+%typemap(jni) BYTE_ARRAY_OUT "jbyteArray"
+%typemap(jtype) BYTE_ARRAY_OUT "byte[]"
+%typemap(jstype) BYTE_ARRAY_OUT "byte[]"
+%typemap(in) BYTE_ARRAY_OUT (jbyte* bytes)
+    if (!bytes)
+        return $null;
+    $1 = (BYTE_ARRAY_OUT)bytes;
+%typemap(freearg) BYTE_ARRAY_OUT
+    jenv->ReleaseByteArrayElements($input, bytes$argnum, JNI_COMMIT);
+%typemap(javain) BYTE_ARRAY_OUT "$javainput"
+%include "javaextensions.i"
+// Global functions
+void MgInitializeWebTier(STRINGPARAM configFile);
Deleted: trunk/MgDev/Web/src/JavaApiEx/javaextensions.i
--- sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/javaextensions.i	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,345 +0,0 @@
-//---------------------- Java interface decorations ------------------------------//
-//NOTE: If we're eventually targeting JDK7, change to AutoCloseable for automatic try-with-resources syntax support
-//%typemap(javainterfaces) MgReader "java.io.Closeable"
-//%typemap(javainterfaces) MgFeatureReader "java.io.Closeable"
-//%typemap(javainterfaces) MgDataReader "java.io.Closeable"
-//%typemap(javainterfaces) MgSqlDataReader "java.io.Closeable"
-//%typemap(javainterfaces) MgLongTransactionReader "java.io.Closeable"
-//%typemap(javainterfaces) MgSpatialContextReader "java.io.Closeable"
-//---------------------- Renames to avoid Java/C++ API clashes ---------------------------//
-//Already defined in Java Exception so rename our proxy method
-%rename(getExceptionStackTrace) MgException::GetStackTrace;
-//delete() is the name of the standard SWIG release method called on finalize(). Unfortunately this conflicts with
-//MgPropertyDefinition::Delete, MgClassDefinition::Delete and MgFeatureSchema::Delete when java proxy clases for these
-//classes are generated
-//So rename the java proxies to these methods. This is the most minimally destructive change of all the available options
-//available to us
-%rename(markAsDeleted) MgPropertyDefinition::Delete;
-%rename(markAsDeleted) MgClassDefinition::Delete;
-%rename(markAsDeleted) MgFeatureSchema::Delete;
-//If we want to implement java.util.Collection, we need to rename this incompatible API (as add() is expected to
-//return boolean in the java.util.Collection API)
-%rename(addItem) MgBatchPropertyCollection::Add;
-%rename(addItem) MgClassDefinitionCollection::Add;
-%rename(addItem) MgFeatureSchemaCollection::Add;
-%rename(addItem) MgPropertyDefinitionCollection::Add;
-%rename(addItem) MgIntCollection::Add;
-%rename(addItem) MgPropertyCollection::Add;
-%rename(addItem) MgStringCollection::Add;
-%rename(addItem) MgLayerCollection::Add;
-%rename(addItem) MgLayerGroupCollection::Add;
-//This is a helper macro to implement the required APIs for collection items
-//This could possibly apply to all proxy classes, but for now we're only interested in classes
-//that are part of any collection class that implements java.util.Collection. This is needed for
-//contains() and other container tests for equality to work
-//Implementation borrowed from OGR swig java bindings
-%define IMPLEMENT_MG_ITEM_API(item_type)
-%typemap(javacode) item_type %{
-    public boolean equals(Object obj) {
-        boolean equal=false;
-        if(obj instanceof $javaclassname)
-            equal=((($javaclassname)obj).swigCPtr==this.swigCPtr);
-        return equal;
-    public int hashCode() {
-        return (int)swigCPtr;
-%enddef
-//This is a helper macro to implement the bulk of the java.util.Collection interface for any proxy class
-//that needs one
-//Kinda like C++ templates for Java without the suck. And we all know how much Java generics suck :D
-//TODO: Not sure if a SWIG macro can call into another SWIG macro, but if it can it should call into
-//the IMPLEMENT_MG_JAVA_ITERABLE_API
-%define IMPLEMENT_MG_JAVA_COLLECTION_API(collection_type, item_type)
-//Necessary imports
-%typemap(javaimports) collection_type %{
-import java.util.Collection;
-import java.util.Iterator;
-import java.util.ArrayList;
-import java.util.NoSuchElementException;
-//Java Interfaces implemented by the java proxy class
-%typemap(javainterfaces) collection_type "Collection<item_type>"
-//This is the java.util.Collection implementation that is injected into each java proxy class
-%typemap(javacode) collection_type %{
-     * An iterator to iterate over this collection
-    class ItemIterator implements Iterator<item_type> {
-        private collection_type _collection;
-        private int _pos;
-        private int _count;
-        public ItemIterator(collection_type c) {
-            _collection = c;
-            _count = _collection.getCount();
-            _pos = -1;
-         * Returns true if the iteration has more elements
-        public boolean hasNext() {
-            return _pos + 1 < _count;
-         * Returns the next item_type in the collection
-        public item_type next() {
-            _pos++;
-            if (_pos >= _count)
-                throw new NoSuchElementException();
-            return _collection.getItem(_pos);
-         * Removes from the underlying collection the last element returned by the iterator (not supported).
-        public void remove() {
-            throw new UnsupportedOperationException();
-     * Returns an iterator over the elements in this collection.
-    public Iterator<item_type> iterator() { return new ItemIterator(this); }
-     * Ensures that this collection contains the specified element (optional operation).
-    public boolean add(item_type item) {
-        this.addItem(item);
-        return true;
-     * Adds all of the elements in the specified collection to this collection (optional operation).
-    public boolean addAll(Collection<? extends item_type> c) {
-        int added = 0;
-        for (item_type item : c) {
-            added++;
-        return added > 0;
-     *  Returns true if this collection contains the specified element.
-    public boolean contains(Object o) {
-        if (o instanceof item_type) {
-            return this.contains((item_type)o);
-        return false;
-     * Returns true if this collection contains all of the elements in the specified collection.
-    public boolean containsAll(Collection<?> c) {
-        for (Object o : c) {
-            if (!this.contains(o))
-                return false;
-        return true;
-     * Returns true if this collection contains no elements.
-    public boolean isEmpty() { return this.getCount() == 0; }
-     * Removes a single instance of the specified element from this collection, if it is present (optional operation).
-    public boolean remove(Object o) {
-            return this.remove((item_type)o);
-        return false;
-     * Removes all of this collection's elements that are also contained in the specified collection (optional operation).
-    public boolean removeAll(Collection<?> c) {
-        int removed = 0;
-            if (this.remove(o))
-                removed++;
-        return removed > 0;
-     * Retains only the elements in this collection that are contained in the specified collection (optional operation).
-    public boolean retainAll(Collection<?> c) {
-        int removed = 0;
-        ArrayList<item_type> remove = new ArrayList<item_type>();
-        for (int i = 0; i < this.getCount(); i++) {
-            item_type item = this.getItem(i);
-            if (!c.contains(item))
-                remove.add(item);
-        if (remove.size() > 0) {
-            return this.removeAll(remove);
-        } else {
-            return false;
-     * Returns the number of elements in this collection.
-    public int size() { return this.getCount(); }
-     * Returns an array containing all of the elements in this collection.
-    public Object[] toArray() {
-        int count = this.getCount();
-        Object[] items = new Object[count];
-        for (int i = 0; i < count; i++) {
-            items[i] = this.getItem(i);
-        return items;
-     * Returns an array containing all of the elements in this collection; the runtime type of the returned array is that of the specified array.
-    public <item_type> item_type[] toArray(item_type[] a) {
-        Object[] items = this.toArray();
-        if (a.length >= items.length) {
-            for (int i = 0; i < items.length; i++) {
-                a[i] = (item_type)items[i];
-            for (int i = items.length; i < a.length; i++) {
-                a[i] = null;
-            return a;
-        } else {
-            item_type[] retVal = (item_type[])java.lang.reflect.Array.newInstance(a.getClass().getComponentType(), items.length);
-            for (int i = 0; i < retVal.length; i++) {
-                retVal[i] = (item_type)items[i];
-            return retVal;
-%enddef
-//This helper macro implements the java.lang.Iterable API allowing the instance of the
-//java proxy to be used in an enhanced for loop (akin to IEnumerable/foreach in C#)
-%define IMPLEMENT_MG_JAVA_ITERABLE_API(collection_type, item_type)
-%typemap(javainterfaces) collection_type "java.lang.Iterable<item_type>"
-//This is the java.lang.Iterable<T> implementation that is injected into each java proxy class
-        private int _pos;
-            _collection = c;
-            _pos = -1;
-            _pos++;
-%enddef
-//Plug the stock implementation for our MapGuide collection and item classes
-IMPLEMENT_MG_ITEM_API(MgClassDefinition)
-IMPLEMENT_MG_ITEM_API(MgFeatureSchema)
-IMPLEMENT_MG_ITEM_API(MgPropertyDefinition)
-IMPLEMENT_MG_ITEM_API(MgProperty)
-IMPLEMENT_MG_ITEM_API(MgLayerBase)
-IMPLEMENT_MG_ITEM_API(MgLayerGroup)
-//IMPLEMENT_MG_JAVA_COLLECTION_API(MgBatchPropertyCollection, MgPropertyCollection)
-IMPLEMENT_MG_JAVA_COLLECTION_API(MgClassDefinitionCollection, MgClassDefinition)
-IMPLEMENT_MG_JAVA_COLLECTION_API(MgFeatureSchemaCollection, MgFeatureSchema)
-IMPLEMENT_MG_JAVA_COLLECTION_API(MgPropertyDefinitionCollection, MgPropertyDefinition)
-IMPLEMENT_MG_JAVA_COLLECTION_API(MgPropertyCollection, MgProperty)
-IMPLEMENT_MG_JAVA_COLLECTION_API(MgStringCollection, String)
-IMPLEMENT_MG_JAVA_COLLECTION_API(MgLayerCollection, MgLayerBase)
-IMPLEMENT_MG_JAVA_COLLECTION_API(MgLayerGroupCollection, MgLayerGroup)
-IMPLEMENT_MG_JAVA_ITERABLE_API(MgReadOnlyLayerCollection, MgLayerBase)
\ No newline at end of file
Copied: trunk/MgDev/Web/src/JavaApiEx/javaextensions.i (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i)
--- trunk/MgDev/Web/src/JavaApiEx/javaextensions.i	                        (rev 0)
@@ -0,0 +1,345 @@
+//---------------------- Java interface decorations ------------------------------//
+//NOTE: If we're eventually targeting JDK7, change to AutoCloseable for automatic try-with-resources syntax support
+//%typemap(javainterfaces) MgReader "java.io.Closeable"
+//%typemap(javainterfaces) MgFeatureReader "java.io.Closeable"
+//%typemap(javainterfaces) MgDataReader "java.io.Closeable"
+//%typemap(javainterfaces) MgSqlDataReader "java.io.Closeable"
+//%typemap(javainterfaces) MgLongTransactionReader "java.io.Closeable"
+//%typemap(javainterfaces) MgSpatialContextReader "java.io.Closeable"
+//---------------------- Renames to avoid Java/C++ API clashes ---------------------------//
+//Already defined in Java Exception so rename our proxy method
+%rename(getExceptionStackTrace) MgException::GetStackTrace;
+//delete() is the name of the standard SWIG release method called on finalize(). Unfortunately this conflicts with
+//MgPropertyDefinition::Delete, MgClassDefinition::Delete and MgFeatureSchema::Delete when java proxy clases for these
+//classes are generated
+//So rename the java proxies to these methods. This is the most minimally destructive change of all the available options
+//available to us
+%rename(markAsDeleted) MgPropertyDefinition::Delete;
+%rename(markAsDeleted) MgClassDefinition::Delete;
+%rename(markAsDeleted) MgFeatureSchema::Delete;
+//If we want to implement java.util.Collection, we need to rename this incompatible API (as add() is expected to
+//return boolean in the java.util.Collection API)
+%rename(addItem) MgBatchPropertyCollection::Add;
+%rename(addItem) MgClassDefinitionCollection::Add;
+%rename(addItem) MgFeatureSchemaCollection::Add;
+%rename(addItem) MgPropertyDefinitionCollection::Add;
+%rename(addItem) MgIntCollection::Add;
+%rename(addItem) MgPropertyCollection::Add;
+%rename(addItem) MgStringCollection::Add;
+%rename(addItem) MgLayerCollection::Add;
+%rename(addItem) MgLayerGroupCollection::Add;
+//This is a helper macro to implement the required APIs for collection items
+//This could possibly apply to all proxy classes, but for now we're only interested in classes
+//that are part of any collection class that implements java.util.Collection. This is needed for
+//contains() and other container tests for equality to work
+//Implementation borrowed from OGR swig java bindings
+%define IMPLEMENT_MG_ITEM_API(item_type)
+%typemap(javacode) item_type %{
+    public boolean equals(Object obj) {
+        boolean equal=false;
+        if(obj instanceof $javaclassname)
+            equal=((($javaclassname)obj).swigCPtr==this.swigCPtr);
+        return equal;
+    public int hashCode() {
+        return (int)swigCPtr;
+%enddef
+//This is a helper macro to implement the bulk of the java.util.Collection interface for any proxy class
+//that needs one
+//Kinda like C++ templates for Java without the suck. And we all know how much Java generics suck :D
+//TODO: Not sure if a SWIG macro can call into another SWIG macro, but if it can it should call into
+//the IMPLEMENT_MG_JAVA_ITERABLE_API
+%define IMPLEMENT_MG_JAVA_COLLECTION_API(collection_type, item_type)
+//Necessary imports
+%typemap(javaimports) collection_type %{
+import java.util.Collection;
+import java.util.Iterator;
+import java.util.ArrayList;
+import java.util.NoSuchElementException;
+//Java Interfaces implemented by the java proxy class
+%typemap(javainterfaces) collection_type "Collection<item_type>"
+//This is the java.util.Collection implementation that is injected into each java proxy class
+%typemap(javacode) collection_type %{
+     * An iterator to iterate over this collection
+    class ItemIterator implements Iterator<item_type> {
+        private collection_type _collection;
+        private int _pos;
+        private int _count;
+        public ItemIterator(collection_type c) {
+            _collection = c;
+            _count = _collection.getCount();
+            _pos = -1;
+         * Returns true if the iteration has more elements
+        public boolean hasNext() {
+            return _pos + 1 < _count;
+         * Returns the next item_type in the collection
+        public item_type next() {
+            _pos++;
+            if (_pos >= _count)
+                throw new NoSuchElementException();
+            return _collection.getItem(_pos);
+         * Removes from the underlying collection the last element returned by the iterator (not supported).
+        public void remove() {
+            throw new UnsupportedOperationException();
+     * Returns an iterator over the elements in this collection.
+    public Iterator<item_type> iterator() { return new ItemIterator(this); }
+     * Ensures that this collection contains the specified element (optional operation).
+    public boolean add(item_type item) {
+        this.addItem(item);
+        return true;
+     * Adds all of the elements in the specified collection to this collection (optional operation).
+    public boolean addAll(Collection<? extends item_type> c) {
+        int added = 0;
+        for (item_type item : c) {
+            added++;
+        return added > 0;
+     *  Returns true if this collection contains the specified element.
+    public boolean contains(Object o) {
+        if (o instanceof item_type) {
+            return this.contains((item_type)o);
+        return false;
+     * Returns true if this collection contains all of the elements in the specified collection.
+    public boolean containsAll(Collection<?> c) {
+        for (Object o : c) {
+            if (!this.contains(o))
+                return false;
+        return true;
+     * Returns true if this collection contains no elements.
+    public boolean isEmpty() { return this.getCount() == 0; }
+     * Removes a single instance of the specified element from this collection, if it is present (optional operation).
+    public boolean remove(Object o) {
+            return this.remove((item_type)o);
+        return false;
+     * Removes all of this collection's elements that are also contained in the specified collection (optional operation).
+    public boolean removeAll(Collection<?> c) {
+        int removed = 0;
+            if (this.remove(o))
+                removed++;
+        return removed > 0;
+     * Retains only the elements in this collection that are contained in the specified collection (optional operation).
+    public boolean retainAll(Collection<?> c) {
+        int removed = 0;
+        ArrayList<item_type> remove = new ArrayList<item_type>();
+        for (int i = 0; i < this.getCount(); i++) {
+            item_type item = this.getItem(i);
+            if (!c.contains(item))
+                remove.add(item);
+        if (remove.size() > 0) {
+            return this.removeAll(remove);
+        } else {
+            return false;
+     * Returns the number of elements in this collection.
+    public int size() { return this.getCount(); }
+     * Returns an array containing all of the elements in this collection.
+    public Object[] toArray() {
+        int count = this.getCount();
+        Object[] items = new Object[count];
+        for (int i = 0; i < count; i++) {
+            items[i] = this.getItem(i);
+        return items;
+     * Returns an array containing all of the elements in this collection; the runtime type of the returned array is that of the specified array.
+    public <item_type> item_type[] toArray(item_type[] a) {
+        Object[] items = this.toArray();
+        if (a.length >= items.length) {
+            for (int i = 0; i < items.length; i++) {
+                a[i] = (item_type)items[i];
+            for (int i = items.length; i < a.length; i++) {
+                a[i] = null;
+            return a;
+        } else {
+            item_type[] retVal = (item_type[])java.lang.reflect.Array.newInstance(a.getClass().getComponentType(), items.length);
+            for (int i = 0; i < retVal.length; i++) {
+                retVal[i] = (item_type)items[i];
+            return retVal;
+%enddef
+//This helper macro implements the java.lang.Iterable API allowing the instance of the
+//java proxy to be used in an enhanced for loop (akin to IEnumerable/foreach in C#)
+%define IMPLEMENT_MG_JAVA_ITERABLE_API(collection_type, item_type)
+%typemap(javainterfaces) collection_type "java.lang.Iterable<item_type>"
+//This is the java.lang.Iterable<T> implementation that is injected into each java proxy class
+        private int _pos;
+            _collection = c;
+            _pos = -1;
+            _pos++;
+%enddef
+//Plug the stock implementation for our MapGuide collection and item classes
+IMPLEMENT_MG_ITEM_API(MgClassDefinition)
+IMPLEMENT_MG_ITEM_API(MgFeatureSchema)
+IMPLEMENT_MG_ITEM_API(MgPropertyDefinition)
+IMPLEMENT_MG_ITEM_API(MgProperty)
+IMPLEMENT_MG_ITEM_API(MgLayerBase)
+IMPLEMENT_MG_ITEM_API(MgLayerGroup)
+//IMPLEMENT_MG_JAVA_COLLECTION_API(MgBatchPropertyCollection, MgPropertyCollection)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgClassDefinitionCollection, MgClassDefinition)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgFeatureSchemaCollection, MgFeatureSchema)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgPropertyDefinitionCollection, MgPropertyDefinition)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgPropertyCollection, MgProperty)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgStringCollection, String)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgLayerCollection, MgLayerBase)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgLayerGroupCollection, MgLayerGroup)
+IMPLEMENT_MG_JAVA_ITERABLE_API(MgReadOnlyLayerCollection, MgLayerBase)
Property changes on: trunk/MgDev/Web/src/JavaApiEx/org
___________________________________________________________________
Added: bugtraq:number
   + true
Property changes on: trunk/MgDev/Web/src/JavaApiEx/org/osgeo
   + true
Property changes on: trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide
   + true
Deleted: trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/AppThrowable.java
--- sandbox/jng/swig-java/Web/src/JavaApiEx/org/osgeo/mapguide/AppThrowable.java	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/AppThrowable.java	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,57 +0,0 @@
-package org.osgeo.mapguide;
-class AppThrowable extends RuntimeException
-    public AppThrowable()
-    public AppThrowable(long cPtr, boolean cMemoryOwn)
-    public String getMessage()
-        try
-            return ((MgException)this).getExceptionMessage();
-        catch (MgException e)
-            return "";
-    public void printStackTrace()
-        try
-            System.out.println(((MgException)this).getExceptionStackTrace());
-    public void delete()
-        //implemented by derived classes
Copied: trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/AppThrowable.java (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/org/osgeo/mapguide/AppThrowable.java)
--- trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/AppThrowable.java	                        (rev 0)
@@ -0,0 +1,57 @@
+package org.osgeo.mapguide;
+class AppThrowable extends RuntimeException
+    public AppThrowable()
+    public AppThrowable(long cPtr, boolean cMemoryOwn)
+    public String getMessage()
+        try
+            return ((MgException)this).getExceptionMessage();
+        catch (MgException e)
+            return "";
+    public void printStackTrace()
+        try
+            System.out.println(((MgException)this).getExceptionStackTrace());
+    public void delete()
+        //implemented by derived classes
Deleted: trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgBase64.java
--- sandbox/jng/swig-java/Web/src/JavaApiEx/org/osgeo/mapguide/MgBase64.java	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgBase64.java	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,1469 +0,0 @@
- * Encodes and decodes to and from Base64 notation.
- * <p>
- * Change Log:
- * </p>
- * <ul>
- *  <li>v2.1 - Cleaned up javadoc comments and unused variables and methods. Added
- *   some convenience methods for reading and writing to and from files.</li>
- *  <li>v2.0.2 - Now specifies UTF-8 encoding in places where the code fails on systems
- *   with other encodings (like EBCDIC).</li>
- *  <li>v2.0.1 - Fixed an error when decoding a single byte, that is, when the
- *   encoded data was a single byte.</li>
- *  <li>v2.0 - I got rid of methods that used booleans to set options.
- *   Now everything is more consolidated and cleaner. The code now detects
- *   when data that's being decoded is gzip-compressed and will decompress it
- *   automatically. Generally things are cleaner. You'll probably have to
- *   change some method calls that you were making to support the new
- *   options format (<tt>int</tt>s that you "OR" together).</li>
- *  <li>v1.5.1 - Fixed bug when decompressing and decoding to a
- *   byte[] using <tt>decode( String s, boolean gzipCompressed )</tt>.
- *   Added the ability to "suspend" encoding in the Output Stream so
- *   you can turn on and off the encoding if you need to embed base64
- *   data in an otherwise "normal" stream (like an XML file).</li>
- *  <li>v1.5 - Output stream pases on flush() command but doesn't do anything itself.
- *      This helps when using GZIP streams.
- *      Added the ability to GZip-compress objects before encoding them.</li>
- *  <li>v1.4 - Added helper methods to read/write files.</li>
- *  <li>v1.3.6 - Fixed OutputStream.flush() so that 'position' is reset.</li>
- *  <li>v1.3.5 - Added flag to turn on and off line breaks. Fixed bug in input stream
- *      where last buffer being read, if not completely full, was not returned.</li>
- *  <li>v1.3.4 - Fixed when "improperly padded stream" error was thrown at the wrong time.</li>
- *  <li>v1.3.3 - Fixed I/O streams which were totally messed up.</li>
- * </ul>
- * <p>
- * I am placing this code in the Public Domain. Do with it as you will.
- * This software comes with no guarantees or warranties but with
- * plenty of well-wishing instead!
- * Please visit <a href="http://iharder.net/base64">http://iharder.net/base64</a>
- * periodically to check for updates or to contribute improvements.
- * </p>
- * @author Robert Harder
- * @author rob at iharder.net
- * @version 2.1
-public class MgBase64
-/* ********  P U B L I C   F I E L D S  ******** */
-    /** No options specified. Value is zero. */
-    public final static int NO_OPTIONS = 0;
-    /** Specify encoding. */
-    public final static int ENCODE = 1;
-    /** Specify decoding. */
-    public final static int DECODE = 0;
-    /** Specify that data should be gzip-compressed. */
-    public final static int GZIP = 2;
-    /** Don't break lines when encoding (violates strict Base64 specification) */
-    public final static int DONT_BREAK_LINES = 8;
-/* ********  P R I V A T E   F I E L D S  ******** */
-    /** Maximum line length (76) of Base64 output. */
-    private final static int MAX_LINE_LENGTH = 76;
-    /** The equals sign (=) as a byte. */
-    private final static byte EQUALS_SIGN = (byte)'=';
-    /** The new line character (\n) as a byte. */
-    private final static byte NEW_LINE = (byte)'\n';
-    /** Preferred encoding. */
-    private final static String PREFERRED_ENCODING = "UTF-8";
-    /** The 64 valid Base64 values. */
-    private final static byte[] ALPHABET;
-    private final static byte[] _NATIVE_ALPHABET = /* May be something funny like EBCDIC */
-        (byte)'A', (byte)'B', (byte)'C', (byte)'D', (byte)'E', (byte)'F', (byte)'G',
-        (byte)'H', (byte)'I', (byte)'J', (byte)'K', (byte)'L', (byte)'M', (byte)'N',
-        (byte)'O', (byte)'P', (byte)'Q', (byte)'R', (byte)'S', (byte)'T', (byte)'U',
-        (byte)'V', (byte)'W', (byte)'X', (byte)'Y', (byte)'Z',
-        (byte)'a', (byte)'b', (byte)'c', (byte)'d', (byte)'e', (byte)'f', (byte)'g',
-        (byte)'h', (byte)'i', (byte)'j', (byte)'k', (byte)'l', (byte)'m', (byte)'n',
-        (byte)'o', (byte)'p', (byte)'q', (byte)'r', (byte)'s', (byte)'t', (byte)'u',
-        (byte)'v', (byte)'w', (byte)'x', (byte)'y', (byte)'z',
-        (byte)'0', (byte)'1', (byte)'2', (byte)'3', (byte)'4', (byte)'5',
-        (byte)'6', (byte)'7', (byte)'8', (byte)'9', (byte)'+', (byte)'/'
-    /** Determine which ALPHABET to use. */
-    static
-        byte[] __bytes;
-        try
-            __bytes = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/".getBytes( PREFERRED_ENCODING );
-        }   // end try
-        catch (java.io.UnsupportedEncodingException use)
-            __bytes = _NATIVE_ALPHABET; // Fall back to native encoding
-        }   // end catch
-        ALPHABET = __bytes;
-    }   // end static
-     * Translates a Base64 value to either its 6-bit reconstruction value
-     * or a negative number indicating some other meaning.
-    private final static byte[] DECODABET =
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,                 // Decimal  0 -  8
-        -5,-5,                                      // Whitespace: Tab and Linefeed
-        -9,-9,                                      // Decimal 11 - 12
-        -5,                                         // Whitespace: Carriage Return
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 14 - 26
-        -9,-9,-9,-9,-9,                             // Decimal 27 - 31
-        -5,                                         // Whitespace: Space
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,              // Decimal 33 - 42
-        62,                                         // Plus sign at decimal 43
-        -9,-9,-9,                                   // Decimal 44 - 46
-        63,                                         // Slash at decimal 47
-        52,53,54,55,56,57,58,59,60,61,              // Numbers zero through nine
-        -9,-9,-9,                                   // Decimal 58 - 60
-        -1,                                         // Equals sign at decimal 61
-        -9,-9,-9,                                      // Decimal 62 - 64
-        0,1,2,3,4,5,6,7,8,9,10,11,12,13,            // Letters 'A' through 'N'
-        14,15,16,17,18,19,20,21,22,23,24,25,        // Letters 'O' through 'Z'
-        -9,-9,-9,-9,-9,-9,                          // Decimal 91 - 96
-        26,27,28,29,30,31,32,33,34,35,36,37,38,     // Letters 'a' through 'm'
-        39,40,41,42,43,44,45,46,47,48,49,50,51,     // Letters 'n' through 'z'
-        -9,-9,-9,-9                                 // Decimal 123 - 126
-        /*,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 127 - 139
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 140 - 152
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 153 - 165
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 166 - 178
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 179 - 191
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 192 - 204
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 205 - 217
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 218 - 230
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 231 - 243
-        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9         // Decimal 244 - 255 */
-    // I think I end up not using the BAD_ENCODING indicator.
-    //private final static byte BAD_ENCODING    = -9; // Indicates error in encoding
-    private final static byte WHITE_SPACE_ENC = -5; // Indicates white space in encoding
-    private final static byte EQUALS_SIGN_ENC = -1; // Indicates equals sign in encoding
-    /** Defeats instantiation. */
-    private MgBase64(){}
-/* ********  E N C O D I N G   M E T H O D S  ******** */
-     * Encodes up to the first three bytes of array <var>threeBytes</var>
-     * and returns a four-byte array in Base64 notation.
-     * The actual number of significant bytes in your array is
-     * given by <var>numSigBytes</var>.
-     * The array <var>threeBytes</var> needs only be as big as
-     * <var>numSigBytes</var>.
-     * Code can reuse a byte array by passing a four-byte array as <var>b4</var>.
-     * @param b4 A reusable byte array to reduce array instantiation
-     * @param threeBytes the array to convert
-     * @param numSigBytes the number of significant bytes in your array
-     * @return four byte array in Base64 notation.
-     * @since 1.5.1
-    private static byte[] encode3to4( byte[] b4, byte[] threeBytes, int numSigBytes )
-        encode3to4( threeBytes, 0, numSigBytes, b4, 0 );
-        return b4;
-    }   // end encode3to4
-     * Encodes up to three bytes of the array <var>source</var>
-     * and writes the resulting four Base64 bytes to <var>destination</var>.
-     * The source and destination arrays can be manipulated
-     * anywhere along their length by specifying
-     * <var>srcOffset</var> and <var>destOffset</var>.
-     * This method does not check to make sure your arrays
-     * are large enough to accomodate <var>srcOffset</var> + 3 for
-     * the <var>source</var> array or <var>destOffset</var> + 4 for
-     * the <var>destination</var> array.
-     * @param source the array to convert
-     * @param srcOffset the index where conversion begins
-     * @param destination the array to hold the conversion
-     * @param destOffset the index where output will be put
-     * @return the <var>destination</var> array
-     * @since 1.3
-     byte[] source, int srcOffset, int numSigBytes,
-     byte[] destination, int destOffset )
-        //           1         2         3
-        // 01234567890123456789012345678901 Bit position
-        // --------000000001111111122222222 Array position from threeBytes
-        // --------|    ||    ||    ||    | Six bit groups to index ALPHABET
-        //          >>18  >>12  >> 6  >> 0  Right shift necessary
-        //                0x3f  0x3f  0x3f  Additional AND
-        // Create buffer with zero-padding if there are only one or two
-        // significant bytes passed in the array.
-        // We have to shift left 24 in order to flush out the 1's that appear
-        // when Java treats a value as negative that is cast from a byte to an int.
-        int inBuff =   ( numSigBytes > 0 ? ((source[ srcOffset     ] << 24) >>>  8) : 0 )
-                     | ( numSigBytes > 1 ? ((source[ srcOffset + 1 ] << 24) >>> 16) : 0 )
-                     | ( numSigBytes > 2 ? ((source[ srcOffset + 2 ] << 24) >>> 24) : 0 );
-        switch( numSigBytes )
-            case 3:
-                destination[ destOffset     ] = ALPHABET[ (inBuff >>> 18)        ];
-                destination[ destOffset + 1 ] = ALPHABET[ (inBuff >>> 12) & 0x3f ];
-                destination[ destOffset + 2 ] = ALPHABET[ (inBuff >>>  6) & 0x3f ];
-                destination[ destOffset + 3 ] = ALPHABET[ (inBuff       ) & 0x3f ];
-                return destination;
-            case 2:
-                destination[ destOffset + 3 ] = EQUALS_SIGN;
-            case 1:
-                destination[ destOffset + 2 ] = EQUALS_SIGN;
-            default:
-        }   // end switch
-     * Serializes an object and returns the Base64-encoded
-     * version of that serialized object. If the object
-     * cannot be serialized or there is another error,
-     * the method will return <tt>null</tt>.
-     * The object is not GZip-compressed before being encoded.
-     * @param serializableObject The object to encode
-     * @return The Base64-encoded object
-     * @since 1.4
-    public static String encodeObject( java.io.Serializable serializableObject )
-        return encodeObject( serializableObject, NO_OPTIONS );
-    }   // end encodeObject
-     * <p>
-     * Valid options:<pre>
-     *   GZIP: gzip-compresses object before encoding it.
-     *   DONT_BREAK_LINES: don't break lines at 76 characters
-     *     <i>Note: Technically, this makes your encoding non-compliant.</i>
-     * </pre>
-     * <p>
-     * Example: <code>encodeObject( myObj, Base64.GZIP )</code> or
-     * <p>
-     * Example: <code>encodeObject( myObj, Base64.GZIP | Base64.DONT_BREAK_LINES )</code>
-     * @param options Specified options
-     * @see Base64#GZIP
-     * @see Base64#DONT_BREAK_LINES
-     * @since 2.0
-    public static String encodeObject( java.io.Serializable serializableObject, int options )
-        // Streams
-        java.io.ByteArrayOutputStream  baos  = null;
-        java.io.OutputStream           b64os = null;
-        java.io.ObjectOutputStream     oos   = null;
-        java.util.zip.GZIPOutputStream gzos  = null;
-        // Isolate options
-        int gzip           = (options & GZIP);
-        int dontBreakLines = (options & DONT_BREAK_LINES);
-        try
-            // ObjectOutputStream -> (GZIP) -> Base64 -> ByteArrayOutputStream
-            baos  = new java.io.ByteArrayOutputStream();
-            b64os = new MgBase64.OutputStream( baos, ENCODE | dontBreakLines );
-            // GZip?
-            if( gzip == GZIP )
-                gzos = new java.util.zip.GZIPOutputStream( b64os );
-                oos  = new java.io.ObjectOutputStream( gzos );
-            }   // end if: gzip
-            else
-                oos   = new java.io.ObjectOutputStream( b64os );
-            oos.writeObject( serializableObject );
-        }   // end try
-        catch( java.io.IOException e )
-            e.printStackTrace();
-            return null;
-        }   // end catch
-        finally
-            try{ oos.close();   } catch( Exception e ){}
-            try{ gzos.close();  } catch( Exception e ){}
-            try{ b64os.close(); } catch( Exception e ){}
-            try{ baos.close();  } catch( Exception e ){}
-        }   // end finally
-        // Return value according to relevant encoding.
-        try
-            return new String( baos.toByteArray(), PREFERRED_ENCODING );
-        }   // end try
-        catch (java.io.UnsupportedEncodingException uue)
-            return new String( baos.toByteArray() );
-        }   // end catch
-    }   // end encode
-     * Encodes a byte array into Base64 notation.
-     * Does not GZip-compress data.
-     * @param source The data to convert
-     * @since 1.4
-    public static String encodeBytes( byte[] source )
-        return encodeBytes( source, 0, source.length, NO_OPTIONS );
-    }   // end encodeBytes
-     * <p>
-     * </pre>
-     * <p>
-     * Example: <code>encodeBytes( myData, Base64.GZIP )</code> or
-     * <p>
-     * Example: <code>encodeBytes( myData, Base64.GZIP | Base64.DONT_BREAK_LINES )</code>
-     * @since 2.0
-    public static String encodeBytes( byte[] source, int options )
-        return encodeBytes( source, 0, source.length, options );
-     * @param off Offset in array where conversion should begin
-     * @param len Length of data to convert
-     * @since 1.4
-    public static String encodeBytes( byte[] source, int off, int len )
-        return encodeBytes( source, off, len, NO_OPTIONS );
-     * <p>
-     * </pre>
-     * <p>
-     * <p>
-     * @since 2.0
-    public static String encodeBytes( byte[] source, int off, int len, int options )
-        int dontBreakLines = ( options & DONT_BREAK_LINES );
-        int gzip           = ( options & GZIP   );
-        // Compress?
-            MgBase64.OutputStream          b64os = null;
-            try
-                // GZip -> Base64 -> ByteArray
-                gzos.write( source, off, len );
-                gzos.close();
-            }   // end try
-                return null;
-            }   // end catch
-            finally
-            }   // end finally
-            try
-            }   // end try
-            }   // end catch
-        }   // end if: compress
-        // Else, don't compress. Better not to use streams at all then.
-        else
-            // Convert option to boolean in way that code likes it.
-            boolean breakLines = dontBreakLines == 0;
-            int    len43   = len * 4 / 3;
-            byte[] outBuff = new byte[   ( len43 )                      // Main 4:3
-                                       + ( (len % 3) > 0 ? 4 : 0 )      // Account for padding
-                                       + (breakLines ? ( len43 / MAX_LINE_LENGTH ) : 0) ]; // New lines
-            int d = 0;
-            int e = 0;
-            int len2 = len - 2;
-            int lineLength = 0;
-            for( ; d < len2; d+=3, e+=4 )
-                encode3to4( source, d+off, 3, outBuff, e );
-                lineLength += 4;
-                if( breakLines && lineLength == MAX_LINE_LENGTH )
-                    outBuff[e+4] = NEW_LINE;
-                    e++;
-                    lineLength = 0;
-                }   // end if: end of line
-            }   // en dfor: each piece of array
-            if( d < len )
-                encode3to4( source, d+off, len - d, outBuff, e );
-                e += 4;
-            }   // end if: some padding needed
-            try
-                return new String( outBuff, 0, e, PREFERRED_ENCODING );
-            }   // end try
-                return new String( outBuff, 0, e );
-            }   // end catch
-        }   // end else: don't compress
-/* ********  D E C O D I N G   M E T H O D S  ******** */
-     * Decodes four bytes from array <var>source</var>
-     * and writes the resulting bytes (up to three of them)
-     * to <var>destination</var>.
-     * are large enough to accomodate <var>srcOffset</var> + 4 for
-     * the <var>source</var> array or <var>destOffset</var> + 3 for
-     * This method returns the actual number of bytes that
-     * were converted from the Base64 encoding.
-     * @return the number of decoded bytes converted
-     * @since 1.3
-    private static int decode4to3( byte[] source, int srcOffset, byte[] destination, int destOffset )
-        // Example: Dk==
-        if( source[ srcOffset + 2] == EQUALS_SIGN )
-            // Two ways to do the same thing. Don't know which way I like best.
-            //int outBuff =   ( ( DECODABET[ source[ srcOffset    ] ] << 24 ) >>>  6 )
-            //              | ( ( DECODABET[ source[ srcOffset + 1] ] << 24 ) >>> 12 );
-            int outBuff =   ( ( DECODABET[ source[ srcOffset    ] ] & 0xFF ) << 18 )
-                          | ( ( DECODABET[ source[ srcOffset + 1] ] & 0xFF ) << 12 );
-            destination[ destOffset ] = (byte)( outBuff >>> 16 );
-            return 1;
-        // Example: DkL=
-        else if( source[ srcOffset + 3 ] == EQUALS_SIGN )
-            //              | ( ( DECODABET[ source[ srcOffset + 1 ] ] << 24 ) >>> 12 )
-            //              | ( ( DECODABET[ source[ srcOffset + 2 ] ] << 24 ) >>> 18 );
-                          | ( ( DECODABET[ source[ srcOffset + 1 ] ] & 0xFF ) << 12 )
-                          | ( ( DECODABET[ source[ srcOffset + 2 ] ] & 0xFF ) <<  6 );
-            destination[ destOffset + 1 ] = (byte)( outBuff >>>  8 );
-            return 2;
-        // Example: DkLE
-        else
-            try{
-            //              | ( ( DECODABET[ source[ srcOffset + 3 ] ] << 24 ) >>> 24 );
-                          | ( ( DECODABET[ source[ srcOffset + 2 ] ] & 0xFF ) <<  6)
-                          | ( ( DECODABET[ source[ srcOffset + 3 ] ] & 0xFF )      );
-            destination[ destOffset     ] = (byte)( outBuff >> 16 );
-            destination[ destOffset + 1 ] = (byte)( outBuff >>  8 );
-            destination[ destOffset + 2 ] = (byte)( outBuff       );
-            return 3;
-            }catch( Exception e){
-                System.out.println(""+source[srcOffset]+ ": " + ( DECODABET[ source[ srcOffset     ] ]  ) );
-                System.out.println(""+source[srcOffset+1]+  ": " + ( DECODABET[ source[ srcOffset + 1 ] ]  ) );
-                System.out.println(""+source[srcOffset+2]+  ": " + ( DECODABET[ source[ srcOffset + 2 ] ]  ) );
-                System.out.println(""+source[srcOffset+3]+  ": " + ( DECODABET[ source[ srcOffset + 3 ] ]  ) );
-                return -1;
-            }   //e nd catch
-    }   // end decodeToBytes
-     * Very low-level access to decoding ASCII characters in
-     * the form of a byte array. Does not support automatically
-     * gunzipping or any other "fancy" features.
-     * @param source The Base64 encoded data
-     * @param off    The offset of where to begin decoding
-     * @param len    The length of characters to decode
-     * @return decoded data
-     * @since 1.3
-    public static byte[] decode( byte[] source, int off, int len )
-        int    len34   = len * 3 / 4;
-        byte[] outBuff = new byte[ len34 ]; // Upper limit on size of output
-        int    outBuffPosn = 0;
-        byte[] b4        = new byte[4];
-        int    b4Posn    = 0;
-        int    i         = 0;
-        byte   sbiCrop   = 0;
-        byte   sbiDecode = 0;
-        for( i = off; i < off+len; i++ )
-            sbiCrop = (byte)(source[i] & 0x7f); // Only the low seven bits
-            sbiDecode = DECODABET[ sbiCrop ];
-            if( sbiDecode >= WHITE_SPACE_ENC ) // White space, Equals sign or better
-                if( sbiDecode >= EQUALS_SIGN_ENC )
-                    b4[ b4Posn++ ] = sbiCrop;
-                    if( b4Posn > 3 )
-                        outBuffPosn += decode4to3( b4, 0, outBuff, outBuffPosn );
-                        b4Posn = 0;
-                        // If that was the equals sign, break out of 'for' loop
-                        if( sbiCrop == EQUALS_SIGN )
-                            break;
-                    }   // end if: quartet built
-                }   // end if: equals sign or better
-            }   // end if: white space, equals sign or better
-            else
-                System.err.println( "Bad Base64 input character at " + i + ": " + source[i] + "(decimal)" );
-                return null;
-            }   // end else:
-        }   // each input character
-        byte[] out = new byte[ outBuffPosn ];
-        System.arraycopy( outBuff, 0, out, 0, outBuffPosn );
-        return out;
-    }   // end decode
-     * Decodes data from Base64 notation, automatically
-     * detecting gzip-compressed data and decompressing it.
-     * @param s the string to decode
-     * @return the decoded data
-     * @since 1.4
-    public static byte[] decode( String s )
-        byte[] bytes;
-        try
-            bytes = s.getBytes( PREFERRED_ENCODING );
-        }   // end try
-        catch( java.io.UnsupportedEncodingException uee )
-            bytes = s.getBytes();
-        }   // end catch
-        //</change>
-        // Decode
-        bytes = decode( bytes, 0, bytes.length );
-        // Check to see if it's gzip-compressed
-        // GZIP Magic Two-Byte Number: 0x8b1f (35615)
-        if( bytes != null && bytes.length >= 4 )
-            int head = ((int)bytes[0] & 0xff) | ((bytes[1] << 8) & 0xff00);
-            if( java.util.zip.GZIPInputStream.GZIP_MAGIC == head )
-                java.io.ByteArrayInputStream  bais = null;
-                java.util.zip.GZIPInputStream gzis = null;
-                byte[] buffer = new byte[2048];
-                int    length = 0;
-                try
-                    bais = new java.io.ByteArrayInputStream( bytes );
-                    gzis = new java.util.zip.GZIPInputStream( bais );
-                    while( ( length = gzis.read( buffer ) ) >= 0 )
-                        baos.write(buffer,0,length);
-                    }   // end while: reading input
-                    // No error? Get new bytes.
-                    bytes = baos.toByteArray();
-                }   // end try
-                    // Just return originally-decoded bytes
-                }   // end catch
-                finally
-                    try{ gzis.close(); } catch( Exception e ){}
-                    try{ bais.close(); } catch( Exception e ){}
-                }   // end finally
-            }   // end if: gzipped
-        }   // end if: bytes.length >= 2
-        return bytes;
-    }   // end decode
-     * Attempts to decode Base64 data and deserialize a Java
-     * Object within. Returns <tt>null</tt> if there was an error.
-     * @param encodedObject The Base64 data to decode
-     * @return The decoded and deserialized object
-     * @since 1.5
-    public static Object decodeToObject( String encodedObject )
-        // Decode and gunzip if necessary
-        byte[] objBytes = decode( encodedObject );
-        java.io.ObjectInputStream     ois  = null;
-        Object obj = null;
-        try
-            bais = new java.io.ByteArrayInputStream( objBytes );
-            ois  = new java.io.ObjectInputStream( bais );
-            obj = ois.readObject();
-        }   // end try
-            obj = null;
-        }   // end catch
-        catch( java.lang.ClassNotFoundException e )
-            obj = null;
-        }   // end catch
-        finally
-            try{ ois.close();  } catch( Exception e ){}
-        }   // end finally
-        return obj;
-    }   // end decodeObject
-     * Convenience method for encoding data to a file.
-     * @param dataToEncode byte array of data to encode in base64 form
-     * @param filename Filename for saving encoded data
-     * @return <tt>true</tt> if successful, <tt>false</tt> otherwise
-     * @since 2.1
-    public static boolean encodeToFile( byte[] dataToEncode, String filename )
-        boolean success = false;
-        MgBase64.OutputStream bos = null;
-        try
-            bos = new MgBase64.OutputStream(
-                      new java.io.FileOutputStream( filename ), MgBase64.ENCODE );
-            bos.write( dataToEncode );
-            success = true;
-        }   // end try
-            success = false;
-        }   // end catch: IOException
-        finally
-            try{ bos.close(); } catch( Exception e ){}
-        }   // end finally
-        return success;
-    }   // end encodeToFile
-     * Convenience method for decoding data to a file.
-     * @param dataToDecode Base64-encoded data as a string
-     * @param filename Filename for saving decoded data
-     * @since 2.1
-    public static boolean decodeToFile( String dataToDecode, String filename )
-        try
-                          new java.io.FileOutputStream( filename ), MgBase64.DECODE );
-                bos.write( dataToDecode.getBytes( PREFERRED_ENCODING ) );
-                success = true;
-        }   // end try
-            success = false;
-        finally
-        }   // end finally
-        return success;
-    }   // end decodeToFile
-     * Convenience method for reading a base64-encoded
-     * file and decoding it.
-     * @param filename Filename for reading encoded data
-     * @return decoded byte array or null if unsuccessful
-     * @since 2.1
-    public static byte[] decodeFromFile( String filename )
-        byte[] decodedData = null;
-        MgBase64.InputStream bis = null;
-        try
-            // Set up some useful variables
-            java.io.File file = new java.io.File( filename );
-            byte[] buffer = null;
-            int length   = 0;
-            int numBytes = 0;
-            // Check for size of file
-            if( file.length() > Integer.MAX_VALUE )
-                System.err.println( "File is too big for this convenience method (" + file.length() + " bytes)." );
-                return null;
-            }   // end if: file too big for int index
-            buffer = new byte[ (int)file.length() ];
-            // Open a stream
-            bis = new MgBase64.InputStream(
-                      new java.io.BufferedInputStream(
-                      new java.io.FileInputStream( file ) ), MgBase64.DECODE );
-            // Read until done
-            while( ( numBytes = bis.read( buffer, length, 4096 ) ) >= 0 )
-                length += numBytes;
-            // Save in a variable to return
-            decodedData = new byte[ length ];
-            System.arraycopy( buffer, 0, decodedData, 0, length );
-        }   // end try
-            System.err.println( "Error decoding from file " + filename );
-        finally
-            try{ bis.close(); } catch( Exception e) {}
-        }   // end finally
-        return decodedData;
-    }   // end decodeFromFile
-     * Convenience method for reading a binary file
-     * and base64-encoding it.
-     * @param filename Filename for reading binary data
-     * @return base64-encoded string or null if unsuccessful
-     * @since 2.1
-    public static String encodeFromFile( String filename )
-        String encodedData = null;
-        try
-            byte[] buffer = new byte[ (int)(file.length() * 1.4) ];
-            int length   = 0;
-            int numBytes = 0;
-            // Open a stream
-                      new java.io.FileInputStream( file ) ), MgBase64.ENCODE );
-            encodedData = new String( buffer, 0, length, MgBase64.PREFERRED_ENCODING );
-        }   // end try
-            System.err.println( "Error encoding from file " + filename );
-        finally
-        }   // end finally
-        return encodedData;
-        }   // end encodeFromFile
-    /* ********  I N N E R   C L A S S   I N P U T S T R E A M  ******** */
-     * A {@link MgBase64.InputStream} will read data from another
-     * <tt>java.io.InputStream</tt>, given in the constructor,
-     * and encode/decode to/from MgBase64 notation on the fly.
-     * @see MgBase64
-     * @since 1.3
-    public static class InputStream extends java.io.FilterInputStream
-        private boolean encode;         // Encoding or decoding
-        private int     position;       // Current position in the buffer
-        private byte[]  buffer;         // Small buffer holding converted data
-        private int     bufferLength;   // Length of buffer (3 or 4)
-        private int     numSigBytes;    // Number of meaningful bytes in the buffer
-        private int     lineLength;
-        private boolean breakLines;     // Break lines at less than 80 characters
-         * Constructs a {@link MgBase64.InputStream} in DECODE mode.
-         * @param in the <tt>java.io.InputStream</tt> from which to read data.
-         * @since 1.3
-        public InputStream( java.io.InputStream in )
-            this( in, DECODE );
-        }   // end constructor
-         * either ENCODE or DECODE mode.
-         * <p>
-         *   ENCODE or DECODE: Encode or Decode as data is read.
-         *     (only meaningful when encoding)
-         * </pre>
-         * <p>
-         * Example: <code>new MgBase64.InputStream( in, MgBase64.DECODE )</code>
-         * @see MgBase64#ENCODE
-         * @see MgBase64#DECODE
-         * @see MgBase64#DONT_BREAK_LINES
-         * @since 2.0
-        public InputStream( java.io.InputStream in, int options )
-            super( in );
-            this.breakLines   = (options & DONT_BREAK_LINES) != DONT_BREAK_LINES;
-            this.encode       = (options & ENCODE) == ENCODE;
-            this.bufferLength = encode ? 4 : 3;
-            this.buffer   = new byte[ bufferLength ];
-            this.position = -1;
-            this.lineLength = 0;
-         * Reads enough of the input stream to convert
-         * to/from Base64 and returns the next byte.
-         * @return next byte
-         * @since 1.3
-        public int read() throws java.io.IOException
-            // Do we need to get data?
-            if( position < 0 )
-                if( encode )
-                    byte[] b3 = new byte[3];
-                    int numBinaryBytes = 0;
-                    for( int i = 0; i < 3; i++ )
-                        try
-                            int b = in.read();
-                            // If end of stream, b is -1.
-                            if( b >= 0 )
-                                b3[i] = (byte)b;
-                                numBinaryBytes++;
-                            }   // end if: not end of stream
-                        }   // end try: read
-                            // Only a problem if we got no data at all.
-                            if( i == 0 )
-                                throw e;
-                        }   // end catch
-                    }   // end for: each needed input byte
-                    if( numBinaryBytes > 0 )
-                        encode3to4( b3, 0, numBinaryBytes, buffer, 0 );
-                        position = 0;
-                        numSigBytes = 4;
-                    }   // end if: got data
-                    else
-                        return -1;
-                    }   // end else
-                }   // end if: encoding
-                // Else decoding
-                else
-                    int i = 0;
-                    for( i = 0; i < 4; i++ )
-                        // Read four "meaningful" bytes:
-                        int b = 0;
-                        do{ b = in.read(); }
-                        while( b >= 0 && DECODABET[ b & 0x7f ] <= WHITE_SPACE_ENC );
-                        if( b < 0 )
-                            break; // Reads a -1 if end of stream
-                        b4[i] = (byte)b;
-                    if( i == 4 )
-                        numSigBytes = decode4to3( b4, 0, buffer, 0 );
-                        position = 0;
-                    }   // end if: got four characters
-                    else if( i == 0 ){
-                        return -1;
-                    }   // end else if: also padded correctly
-                    else
-                        // Must have broken out from above.
-                        throw new java.io.IOException( "Improperly padded Base64 input." );
-                    }   // end
-                }   // end else: decode
-            }   // end else: get data
-            // Got data?
-            if( position >= 0 )
-                // End of relevant data?
-                if( /*!encode &&*/ position >= numSigBytes )
-                    return -1;
-                if( encode && breakLines && lineLength >= MAX_LINE_LENGTH )
-                    lineLength = 0;
-                    return '\n';
-                }   // end if
-                else
-                    lineLength++;   // This isn't important when decoding
-                                    // but throwing an extra "if" seems
-                                    // just as wasteful.
-                    int b = buffer[ position++ ];
-                    if( position >= bufferLength )
-                        position = -1;
-                    return b & 0xFF; // This is how you "cast" a byte that's
-                                     // intended to be unsigned.
-                }   // end else
-            }   // end if: position >= 0
-            // Else error
-            else
-                // When JDK1.4 is more accepted, use an assertion here.
-                throw new java.io.IOException( "Error in Base64 code reading stream." );
-            }   // end else
-        }   // end read
-         * Calls {@link #read()} repeatedly until the end of stream
-         * is reached or <var>len</var> bytes are read.
-         * Returns number of bytes read into array or -1 if
-         * end of stream is encountered.
-         * @param dest array to hold values
-         * @param off offset for array
-         * @param len max number of bytes to read into array
-         * @return bytes read into array or -1 if end of stream is encountered.
-         * @since 1.3
-        public int read( byte[] dest, int off, int len ) throws java.io.IOException
-            int i;
-            int b;
-            for( i = 0; i < len; i++ )
-                b = read();
-                //if( b < 0 && i == 0 )
-                //    return -1;
-                if( b >= 0 )
-                    dest[off + i] = (byte)b;
-                else if( i == 0 )
-                    return -1;
-                else
-                    break; // Out of 'for' loop
-            }   // end for: each byte read
-            return i;
-        }   // end read
-    }   // end inner class InputStream
-    /* ********  I N N E R   C L A S S   O U T P U T S T R E A M  ******** */
-     * A {@link MgBase64.OutputStream} will write data to another
-     * <tt>java.io.OutputStream</tt>, given in the constructor,
-     * and encode/decode to/from Base64 notation on the fly.
-     * @see Base64
-     * @since 1.3
-    public static class OutputStream extends java.io.FilterOutputStream
-        private byte[]  b4; // Scratch used in a few places
-        private boolean suspendEncoding;
-         * Constructs a {@link Base64.OutputStream} in ENCODE mode.
-         * @param out the <tt>java.io.OutputStream</tt> to which data will be written.
-         * @since 1.3
-        public OutputStream( java.io.OutputStream out )
-            this( out, ENCODE );
-         * <p>
-         * </pre>
-         * <p>
-         * Example: <code>new Base64.OutputStream( out, Base64.ENCODE )</code>
-         * @param options Specified options.
-         * @see Base64#ENCODE
-         * @see Base64#DECODE
-         * @since 1.3
-        public OutputStream( java.io.OutputStream out, int options )
-            super( out );
-            this.bufferLength = encode ? 3 : 4;
-            this.position     = 0;
-            this.suspendEncoding = false;
-            this.b4           = new byte[4];
-         * Writes the byte to the output stream after
-         * converting to/from Base64 notation.
-         * When encoding, bytes are buffered three
-         * at a time before the output stream actually
-         * gets a write() call.
-         * When decoding, bytes are buffered four
-         * at a time.
-         * @param theByte the byte to write
-         * @since 1.3
-        public void write(int theByte) throws java.io.IOException
-            // Encoding suspended?
-            if( suspendEncoding )
-                super.out.write( theByte );
-                return;
-            }   // end if: supsended
-            // Encode?
-            if( encode )
-                buffer[ position++ ] = (byte)theByte;
-                if( position >= bufferLength )  // Enough to encode.
-                    out.write( encode3to4( b4, buffer, bufferLength ) );
-                    lineLength += 4;
-                    if( breakLines && lineLength >= MAX_LINE_LENGTH )
-                        out.write( NEW_LINE );
-                        lineLength = 0;
-                    position = 0;
-                }   // end if: enough to output
-            // Else, Decoding
-            else
-                // Meaningful Base64 character?
-                if( DECODABET[ theByte & 0x7f ] > WHITE_SPACE_ENC )
-                    if( position >= bufferLength )  // Enough to output.
-                        int len = MgBase64.decode4to3( buffer, 0, b4, 0 );
-                        out.write( b4, 0, len );
-                        //out.write( MgBase64.decode4to3( buffer ) );
-                        position = 0;
-                }   // end if: meaningful base64 character
-                else if( DECODABET[ theByte & 0x7f ] != WHITE_SPACE_ENC )
-                    throw new java.io.IOException( "Invalid character in Base64 data." );
-                }   // end else: not white space either
-            }   // end else: decoding
-        }   // end write
-         * Calls {@link #write(int)} repeatedly until <var>len</var>
-         * bytes are written.
-         * @param theBytes array from which to read bytes
-         * @since 1.3
-        public void write( byte[] theBytes, int off, int len ) throws java.io.IOException
-                super.out.write( theBytes, off, len );
-                return;
-            for( int i = 0; i < len; i++ )
-                write( theBytes[ off + i ] );
-            }   // end for: each byte written
-        }   // end write
-         * Method added by PHIL. [Thanks, PHIL. -Rob]
-         * This pads the buffer without closing the stream.
-        public void flushBase64() throws java.io.IOException
-            if( position > 0 )
-                if( encode )
-                    out.write( encode3to4( b4, buffer, position ) );
-                    position = 0;
-                else
-                    throw new java.io.IOException( "Base64 input not properly padded." );
-            }   // end if: buffer partially full
-        }   // end flush
-         * Flushes and closes (I think, in the superclass) the stream.
-         * @since 1.3
-        public void close() throws java.io.IOException
-            // 1. Ensure that pending characters are written
-            flushBase64();
-            // 2. Actually close the stream
-            // Base class both flushes and closes.
-            super.close();
-            buffer = null;
-            out    = null;
-        }   // end close
-         * Suspends encoding of the stream.
-         * May be helpful if you need to embed a piece of
-         * base640-encoded data in a stream.
-         * @since 1.5.1
-        public void suspendEncoding() throws java.io.IOException
-            flushBase64();
-            this.suspendEncoding = true;
-        }   // end suspendEncoding
-         * Resumes encoding of the stream.
-         * @since 1.5.1
-        public void resumeEncoding()
-        }   // end resumeEncoding
-    }   // end inner class OutputStream
-}   // end class MgBase64
Copied: trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgBase64.java (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/org/osgeo/mapguide/MgBase64.java)
--- trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgBase64.java	                        (rev 0)
@@ -0,0 +1,1469 @@
+ * Encodes and decodes to and from Base64 notation.
+ * <p>
+ * Change Log:
+ * </p>
+ * <ul>
+ *  <li>v2.1 - Cleaned up javadoc comments and unused variables and methods. Added
+ *   some convenience methods for reading and writing to and from files.</li>
+ *  <li>v2.0.2 - Now specifies UTF-8 encoding in places where the code fails on systems
+ *   with other encodings (like EBCDIC).</li>
+ *  <li>v2.0.1 - Fixed an error when decoding a single byte, that is, when the
+ *   encoded data was a single byte.</li>
+ *  <li>v2.0 - I got rid of methods that used booleans to set options.
+ *   Now everything is more consolidated and cleaner. The code now detects
+ *   when data that's being decoded is gzip-compressed and will decompress it
+ *   automatically. Generally things are cleaner. You'll probably have to
+ *   change some method calls that you were making to support the new
+ *   options format (<tt>int</tt>s that you "OR" together).</li>
+ *  <li>v1.5.1 - Fixed bug when decompressing and decoding to a
+ *   byte[] using <tt>decode( String s, boolean gzipCompressed )</tt>.
+ *   Added the ability to "suspend" encoding in the Output Stream so
+ *   you can turn on and off the encoding if you need to embed base64
+ *   data in an otherwise "normal" stream (like an XML file).</li>
+ *  <li>v1.5 - Output stream pases on flush() command but doesn't do anything itself.
+ *      This helps when using GZIP streams.
+ *      Added the ability to GZip-compress objects before encoding them.</li>
+ *  <li>v1.4 - Added helper methods to read/write files.</li>
+ *  <li>v1.3.6 - Fixed OutputStream.flush() so that 'position' is reset.</li>
+ *  <li>v1.3.5 - Added flag to turn on and off line breaks. Fixed bug in input stream
+ *      where last buffer being read, if not completely full, was not returned.</li>
+ *  <li>v1.3.4 - Fixed when "improperly padded stream" error was thrown at the wrong time.</li>
+ *  <li>v1.3.3 - Fixed I/O streams which were totally messed up.</li>
+ * </ul>
+ * <p>
+ * I am placing this code in the Public Domain. Do with it as you will.
+ * This software comes with no guarantees or warranties but with
+ * plenty of well-wishing instead!
+ * Please visit <a href="http://iharder.net/base64">http://iharder.net/base64</a>
+ * periodically to check for updates or to contribute improvements.
+ * </p>
+ * @author Robert Harder
+ * @author rob at iharder.net
+ * @version 2.1
+public class MgBase64
+/* ********  P U B L I C   F I E L D S  ******** */
+    /** No options specified. Value is zero. */
+    public final static int NO_OPTIONS = 0;
+    /** Specify encoding. */
+    public final static int ENCODE = 1;
+    /** Specify decoding. */
+    public final static int DECODE = 0;
+    /** Specify that data should be gzip-compressed. */
+    public final static int GZIP = 2;
+    /** Don't break lines when encoding (violates strict Base64 specification) */
+    public final static int DONT_BREAK_LINES = 8;
+/* ********  P R I V A T E   F I E L D S  ******** */
+    /** Maximum line length (76) of Base64 output. */
+    private final static int MAX_LINE_LENGTH = 76;
+    /** The equals sign (=) as a byte. */
+    private final static byte EQUALS_SIGN = (byte)'=';
+    /** The new line character (\n) as a byte. */
+    private final static byte NEW_LINE = (byte)'\n';
+    /** Preferred encoding. */
+    private final static String PREFERRED_ENCODING = "UTF-8";
+    /** The 64 valid Base64 values. */
+    private final static byte[] ALPHABET;
+    private final static byte[] _NATIVE_ALPHABET = /* May be something funny like EBCDIC */
+        (byte)'A', (byte)'B', (byte)'C', (byte)'D', (byte)'E', (byte)'F', (byte)'G',
+        (byte)'H', (byte)'I', (byte)'J', (byte)'K', (byte)'L', (byte)'M', (byte)'N',
+        (byte)'O', (byte)'P', (byte)'Q', (byte)'R', (byte)'S', (byte)'T', (byte)'U',
+        (byte)'V', (byte)'W', (byte)'X', (byte)'Y', (byte)'Z',
+        (byte)'a', (byte)'b', (byte)'c', (byte)'d', (byte)'e', (byte)'f', (byte)'g',
+        (byte)'h', (byte)'i', (byte)'j', (byte)'k', (byte)'l', (byte)'m', (byte)'n',
+        (byte)'o', (byte)'p', (byte)'q', (byte)'r', (byte)'s', (byte)'t', (byte)'u',
+        (byte)'v', (byte)'w', (byte)'x', (byte)'y', (byte)'z',
+        (byte)'0', (byte)'1', (byte)'2', (byte)'3', (byte)'4', (byte)'5',
+        (byte)'6', (byte)'7', (byte)'8', (byte)'9', (byte)'+', (byte)'/'
+    /** Determine which ALPHABET to use. */
+    static
+        byte[] __bytes;
+        try
+            __bytes = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/".getBytes( PREFERRED_ENCODING );
+        }   // end try
+        catch (java.io.UnsupportedEncodingException use)
+            __bytes = _NATIVE_ALPHABET; // Fall back to native encoding
+        }   // end catch
+        ALPHABET = __bytes;
+    }   // end static
+     * Translates a Base64 value to either its 6-bit reconstruction value
+     * or a negative number indicating some other meaning.
+    private final static byte[] DECODABET =
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,                 // Decimal  0 -  8
+        -5,-5,                                      // Whitespace: Tab and Linefeed
+        -9,-9,                                      // Decimal 11 - 12
+        -5,                                         // Whitespace: Carriage Return
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 14 - 26
+        -9,-9,-9,-9,-9,                             // Decimal 27 - 31
+        -5,                                         // Whitespace: Space
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,              // Decimal 33 - 42
+        62,                                         // Plus sign at decimal 43
+        -9,-9,-9,                                   // Decimal 44 - 46
+        63,                                         // Slash at decimal 47
+        52,53,54,55,56,57,58,59,60,61,              // Numbers zero through nine
+        -9,-9,-9,                                   // Decimal 58 - 60
+        -1,                                         // Equals sign at decimal 61
+        -9,-9,-9,                                      // Decimal 62 - 64
+        0,1,2,3,4,5,6,7,8,9,10,11,12,13,            // Letters 'A' through 'N'
+        14,15,16,17,18,19,20,21,22,23,24,25,        // Letters 'O' through 'Z'
+        -9,-9,-9,-9,-9,-9,                          // Decimal 91 - 96
+        26,27,28,29,30,31,32,33,34,35,36,37,38,     // Letters 'a' through 'm'
+        39,40,41,42,43,44,45,46,47,48,49,50,51,     // Letters 'n' through 'z'
+        -9,-9,-9,-9                                 // Decimal 123 - 126
+        /*,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 127 - 139
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 140 - 152
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 153 - 165
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 166 - 178
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 179 - 191
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 192 - 204
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 205 - 217
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 218 - 230
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,     // Decimal 231 - 243
+        -9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9,-9         // Decimal 244 - 255 */
+    // I think I end up not using the BAD_ENCODING indicator.
+    //private final static byte BAD_ENCODING    = -9; // Indicates error in encoding
+    private final static byte WHITE_SPACE_ENC = -5; // Indicates white space in encoding
+    private final static byte EQUALS_SIGN_ENC = -1; // Indicates equals sign in encoding
+    /** Defeats instantiation. */
+    private MgBase64(){}
+/* ********  E N C O D I N G   M E T H O D S  ******** */
+     * Encodes up to the first three bytes of array <var>threeBytes</var>
+     * and returns a four-byte array in Base64 notation.
+     * The actual number of significant bytes in your array is
+     * given by <var>numSigBytes</var>.
+     * The array <var>threeBytes</var> needs only be as big as
+     * <var>numSigBytes</var>.
+     * Code can reuse a byte array by passing a four-byte array as <var>b4</var>.
+     * @param b4 A reusable byte array to reduce array instantiation
+     * @param threeBytes the array to convert
+     * @param numSigBytes the number of significant bytes in your array
+     * @return four byte array in Base64 notation.
+     * @since 1.5.1
+    private static byte[] encode3to4( byte[] b4, byte[] threeBytes, int numSigBytes )
+        encode3to4( threeBytes, 0, numSigBytes, b4, 0 );
+        return b4;
+    }   // end encode3to4
+     * Encodes up to three bytes of the array <var>source</var>
+     * and writes the resulting four Base64 bytes to <var>destination</var>.
+     * The source and destination arrays can be manipulated
+     * anywhere along their length by specifying
+     * <var>srcOffset</var> and <var>destOffset</var>.
+     * This method does not check to make sure your arrays
+     * are large enough to accomodate <var>srcOffset</var> + 3 for
+     * the <var>source</var> array or <var>destOffset</var> + 4 for
+     * the <var>destination</var> array.
+     * @param source the array to convert
+     * @param srcOffset the index where conversion begins
+     * @param destination the array to hold the conversion
+     * @param destOffset the index where output will be put
+     * @return the <var>destination</var> array
+     * @since 1.3
+     byte[] source, int srcOffset, int numSigBytes,
+     byte[] destination, int destOffset )
+        //           1         2         3
+        // 01234567890123456789012345678901 Bit position
+        // --------000000001111111122222222 Array position from threeBytes
+        // --------|    ||    ||    ||    | Six bit groups to index ALPHABET
+        //          >>18  >>12  >> 6  >> 0  Right shift necessary
+        //                0x3f  0x3f  0x3f  Additional AND
+        // Create buffer with zero-padding if there are only one or two
+        // significant bytes passed in the array.
+        // We have to shift left 24 in order to flush out the 1's that appear
+        // when Java treats a value as negative that is cast from a byte to an int.
+        int inBuff =   ( numSigBytes > 0 ? ((source[ srcOffset     ] << 24) >>>  8) : 0 )
+                     | ( numSigBytes > 1 ? ((source[ srcOffset + 1 ] << 24) >>> 16) : 0 )
+                     | ( numSigBytes > 2 ? ((source[ srcOffset + 2 ] << 24) >>> 24) : 0 );
+        switch( numSigBytes )
+            case 3:
+                destination[ destOffset     ] = ALPHABET[ (inBuff >>> 18)        ];
+                destination[ destOffset + 1 ] = ALPHABET[ (inBuff >>> 12) & 0x3f ];
+                destination[ destOffset + 2 ] = ALPHABET[ (inBuff >>>  6) & 0x3f ];
+                destination[ destOffset + 3 ] = ALPHABET[ (inBuff       ) & 0x3f ];
+                return destination;
+            case 2:
+                destination[ destOffset + 3 ] = EQUALS_SIGN;
+            case 1:
+                destination[ destOffset + 2 ] = EQUALS_SIGN;
+            default:
+        }   // end switch
+     * Serializes an object and returns the Base64-encoded
+     * version of that serialized object. If the object
+     * cannot be serialized or there is another error,
+     * the method will return <tt>null</tt>.
+     * The object is not GZip-compressed before being encoded.
+     * @param serializableObject The object to encode
+     * @return The Base64-encoded object
+     * @since 1.4
+    public static String encodeObject( java.io.Serializable serializableObject )
+        return encodeObject( serializableObject, NO_OPTIONS );
+    }   // end encodeObject
+     * <p>
+     * Valid options:<pre>
+     *   GZIP: gzip-compresses object before encoding it.
+     *   DONT_BREAK_LINES: don't break lines at 76 characters
+     *     <i>Note: Technically, this makes your encoding non-compliant.</i>
+     * </pre>
+     * <p>
+     * Example: <code>encodeObject( myObj, Base64.GZIP )</code> or
+     * <p>
+     * Example: <code>encodeObject( myObj, Base64.GZIP | Base64.DONT_BREAK_LINES )</code>
+     * @param options Specified options
+     * @see Base64#GZIP
+     * @see Base64#DONT_BREAK_LINES
+     * @since 2.0
+    public static String encodeObject( java.io.Serializable serializableObject, int options )
+        // Streams
+        java.io.ByteArrayOutputStream  baos  = null;
+        java.io.OutputStream           b64os = null;
+        java.io.ObjectOutputStream     oos   = null;
+        java.util.zip.GZIPOutputStream gzos  = null;
+        // Isolate options
+        int gzip           = (options & GZIP);
+        int dontBreakLines = (options & DONT_BREAK_LINES);
+        try
+            // ObjectOutputStream -> (GZIP) -> Base64 -> ByteArrayOutputStream
+            baos  = new java.io.ByteArrayOutputStream();
+            b64os = new MgBase64.OutputStream( baos, ENCODE | dontBreakLines );
+            // GZip?
+            if( gzip == GZIP )
+                gzos = new java.util.zip.GZIPOutputStream( b64os );
+                oos  = new java.io.ObjectOutputStream( gzos );
+            }   // end if: gzip
+            else
+                oos   = new java.io.ObjectOutputStream( b64os );
+            oos.writeObject( serializableObject );
+        }   // end try
+        catch( java.io.IOException e )
+            e.printStackTrace();
+            return null;
+        }   // end catch
+        finally
+            try{ oos.close();   } catch( Exception e ){}
+            try{ gzos.close();  } catch( Exception e ){}
+            try{ b64os.close(); } catch( Exception e ){}
+            try{ baos.close();  } catch( Exception e ){}
+        }   // end finally
+        // Return value according to relevant encoding.
+        try
+            return new String( baos.toByteArray(), PREFERRED_ENCODING );
+        }   // end try
+        catch (java.io.UnsupportedEncodingException uue)
+            return new String( baos.toByteArray() );
+        }   // end catch
+    }   // end encode
+     * Encodes a byte array into Base64 notation.
+     * Does not GZip-compress data.
+     * @param source The data to convert
+     * @since 1.4
+    public static String encodeBytes( byte[] source )
+        return encodeBytes( source, 0, source.length, NO_OPTIONS );
+    }   // end encodeBytes
+     * <p>
+     * </pre>
+     * <p>
+     * Example: <code>encodeBytes( myData, Base64.GZIP )</code> or
+     * <p>
+     * Example: <code>encodeBytes( myData, Base64.GZIP | Base64.DONT_BREAK_LINES )</code>
+     * @since 2.0
+    public static String encodeBytes( byte[] source, int options )
+        return encodeBytes( source, 0, source.length, options );
+     * @param off Offset in array where conversion should begin
+     * @param len Length of data to convert
+     * @since 1.4
+    public static String encodeBytes( byte[] source, int off, int len )
+        return encodeBytes( source, off, len, NO_OPTIONS );
+     * <p>
+     * </pre>
+     * <p>
+     * <p>
+     * @since 2.0
+    public static String encodeBytes( byte[] source, int off, int len, int options )
+        int dontBreakLines = ( options & DONT_BREAK_LINES );
+        int gzip           = ( options & GZIP   );
+        // Compress?
+            MgBase64.OutputStream          b64os = null;
+            try
+                // GZip -> Base64 -> ByteArray
+                gzos.write( source, off, len );
+                gzos.close();
+            }   // end try
+                return null;
+            }   // end catch
+            finally
+            }   // end finally
+            try
+            }   // end try
+            }   // end catch
+        }   // end if: compress
+        // Else, don't compress. Better not to use streams at all then.
+        else
+            // Convert option to boolean in way that code likes it.
+            boolean breakLines = dontBreakLines == 0;
+            int    len43   = len * 4 / 3;
+            byte[] outBuff = new byte[   ( len43 )                      // Main 4:3
+                                       + ( (len % 3) > 0 ? 4 : 0 )      // Account for padding
+                                       + (breakLines ? ( len43 / MAX_LINE_LENGTH ) : 0) ]; // New lines
+            int d = 0;
+            int e = 0;
+            int len2 = len - 2;
+            int lineLength = 0;
+            for( ; d < len2; d+=3, e+=4 )
+                encode3to4( source, d+off, 3, outBuff, e );
+                lineLength += 4;
+                if( breakLines && lineLength == MAX_LINE_LENGTH )
+                    outBuff[e+4] = NEW_LINE;
+                    e++;
+                    lineLength = 0;
+                }   // end if: end of line
+            }   // en dfor: each piece of array
+            if( d < len )
+                encode3to4( source, d+off, len - d, outBuff, e );
+                e += 4;
+            }   // end if: some padding needed
+            try
+                return new String( outBuff, 0, e, PREFERRED_ENCODING );
+            }   // end try
+                return new String( outBuff, 0, e );
+            }   // end catch
+        }   // end else: don't compress
+/* ********  D E C O D I N G   M E T H O D S  ******** */
+     * Decodes four bytes from array <var>source</var>
+     * and writes the resulting bytes (up to three of them)
+     * to <var>destination</var>.
+     * are large enough to accomodate <var>srcOffset</var> + 4 for
+     * the <var>source</var> array or <var>destOffset</var> + 3 for
+     * This method returns the actual number of bytes that
+     * were converted from the Base64 encoding.
+     * @return the number of decoded bytes converted
+     * @since 1.3
+    private static int decode4to3( byte[] source, int srcOffset, byte[] destination, int destOffset )
+        // Example: Dk==
+        if( source[ srcOffset + 2] == EQUALS_SIGN )
+            // Two ways to do the same thing. Don't know which way I like best.
+            //int outBuff =   ( ( DECODABET[ source[ srcOffset    ] ] << 24 ) >>>  6 )
+            //              | ( ( DECODABET[ source[ srcOffset + 1] ] << 24 ) >>> 12 );
+            int outBuff =   ( ( DECODABET[ source[ srcOffset    ] ] & 0xFF ) << 18 )
+                          | ( ( DECODABET[ source[ srcOffset + 1] ] & 0xFF ) << 12 );
+            destination[ destOffset ] = (byte)( outBuff >>> 16 );
+            return 1;
+        // Example: DkL=
+        else if( source[ srcOffset + 3 ] == EQUALS_SIGN )
+            //              | ( ( DECODABET[ source[ srcOffset + 1 ] ] << 24 ) >>> 12 )
+            //              | ( ( DECODABET[ source[ srcOffset + 2 ] ] << 24 ) >>> 18 );
+                          | ( ( DECODABET[ source[ srcOffset + 1 ] ] & 0xFF ) << 12 )
+                          | ( ( DECODABET[ source[ srcOffset + 2 ] ] & 0xFF ) <<  6 );
+            destination[ destOffset + 1 ] = (byte)( outBuff >>>  8 );
+            return 2;
+        // Example: DkLE
+        else
+            try{
+            //              | ( ( DECODABET[ source[ srcOffset + 3 ] ] << 24 ) >>> 24 );
+                          | ( ( DECODABET[ source[ srcOffset + 2 ] ] & 0xFF ) <<  6)
+                          | ( ( DECODABET[ source[ srcOffset + 3 ] ] & 0xFF )      );
+            destination[ destOffset     ] = (byte)( outBuff >> 16 );
+            destination[ destOffset + 1 ] = (byte)( outBuff >>  8 );
+            destination[ destOffset + 2 ] = (byte)( outBuff       );
+            return 3;
+            }catch( Exception e){
+                System.out.println(""+source[srcOffset]+ ": " + ( DECODABET[ source[ srcOffset     ] ]  ) );
+                System.out.println(""+source[srcOffset+1]+  ": " + ( DECODABET[ source[ srcOffset + 1 ] ]  ) );
+                System.out.println(""+source[srcOffset+2]+  ": " + ( DECODABET[ source[ srcOffset + 2 ] ]  ) );
+                System.out.println(""+source[srcOffset+3]+  ": " + ( DECODABET[ source[ srcOffset + 3 ] ]  ) );
+                return -1;
+            }   //e nd catch
+    }   // end decodeToBytes
+     * Very low-level access to decoding ASCII characters in
+     * the form of a byte array. Does not support automatically
+     * gunzipping or any other "fancy" features.
+     * @param source The Base64 encoded data
+     * @param off    The offset of where to begin decoding
+     * @param len    The length of characters to decode
+     * @return decoded data
+     * @since 1.3
+    public static byte[] decode( byte[] source, int off, int len )
+        int    len34   = len * 3 / 4;
+        byte[] outBuff = new byte[ len34 ]; // Upper limit on size of output
+        int    outBuffPosn = 0;
+        byte[] b4        = new byte[4];
+        int    b4Posn    = 0;
+        int    i         = 0;
+        byte   sbiCrop   = 0;
+        byte   sbiDecode = 0;
+        for( i = off; i < off+len; i++ )
+            sbiCrop = (byte)(source[i] & 0x7f); // Only the low seven bits
+            sbiDecode = DECODABET[ sbiCrop ];
+            if( sbiDecode >= WHITE_SPACE_ENC ) // White space, Equals sign or better
+                if( sbiDecode >= EQUALS_SIGN_ENC )
+                    b4[ b4Posn++ ] = sbiCrop;
+                    if( b4Posn > 3 )
+                        outBuffPosn += decode4to3( b4, 0, outBuff, outBuffPosn );
+                        b4Posn = 0;
+                        // If that was the equals sign, break out of 'for' loop
+                        if( sbiCrop == EQUALS_SIGN )
+                            break;
+                    }   // end if: quartet built
+                }   // end if: equals sign or better
+            }   // end if: white space, equals sign or better
+            else
+                System.err.println( "Bad Base64 input character at " + i + ": " + source[i] + "(decimal)" );
+                return null;
+            }   // end else:
+        }   // each input character
+        byte[] out = new byte[ outBuffPosn ];
+        System.arraycopy( outBuff, 0, out, 0, outBuffPosn );
+        return out;
+    }   // end decode
+     * Decodes data from Base64 notation, automatically
+     * detecting gzip-compressed data and decompressing it.
+     * @param s the string to decode
+     * @return the decoded data
+     * @since 1.4
+    public static byte[] decode( String s )
+        byte[] bytes;
+        try
+            bytes = s.getBytes( PREFERRED_ENCODING );
+        }   // end try
+        catch( java.io.UnsupportedEncodingException uee )
+            bytes = s.getBytes();
+        }   // end catch
+        //</change>
+        // Decode
+        bytes = decode( bytes, 0, bytes.length );
+        // Check to see if it's gzip-compressed
+        // GZIP Magic Two-Byte Number: 0x8b1f (35615)
+        if( bytes != null && bytes.length >= 4 )
+            int head = ((int)bytes[0] & 0xff) | ((bytes[1] << 8) & 0xff00);
+            if( java.util.zip.GZIPInputStream.GZIP_MAGIC == head )
+                java.io.ByteArrayInputStream  bais = null;
+                java.util.zip.GZIPInputStream gzis = null;
+                byte[] buffer = new byte[2048];
+                int    length = 0;
+                try
+                    bais = new java.io.ByteArrayInputStream( bytes );
+                    gzis = new java.util.zip.GZIPInputStream( bais );
+                    while( ( length = gzis.read( buffer ) ) >= 0 )
+                        baos.write(buffer,0,length);
+                    }   // end while: reading input
+                    // No error? Get new bytes.
+                    bytes = baos.toByteArray();
+                }   // end try
+                    // Just return originally-decoded bytes
+                }   // end catch
+                finally
+                    try{ gzis.close(); } catch( Exception e ){}
+                    try{ bais.close(); } catch( Exception e ){}
+                }   // end finally
+            }   // end if: gzipped
+        }   // end if: bytes.length >= 2
+        return bytes;
+    }   // end decode
+     * Attempts to decode Base64 data and deserialize a Java
+     * Object within. Returns <tt>null</tt> if there was an error.
+     * @param encodedObject The Base64 data to decode
+     * @return The decoded and deserialized object
+     * @since 1.5
+    public static Object decodeToObject( String encodedObject )
+        // Decode and gunzip if necessary
+        byte[] objBytes = decode( encodedObject );
+        java.io.ObjectInputStream     ois  = null;
+        Object obj = null;
+        try
+            bais = new java.io.ByteArrayInputStream( objBytes );
+            ois  = new java.io.ObjectInputStream( bais );
+            obj = ois.readObject();
+        }   // end try
+            obj = null;
+        }   // end catch
+        catch( java.lang.ClassNotFoundException e )
+            obj = null;
+        }   // end catch
+        finally
+            try{ ois.close();  } catch( Exception e ){}
+        }   // end finally
+        return obj;
+    }   // end decodeObject
+     * Convenience method for encoding data to a file.
+     * @param dataToEncode byte array of data to encode in base64 form
+     * @param filename Filename for saving encoded data
+     * @return <tt>true</tt> if successful, <tt>false</tt> otherwise
+     * @since 2.1
+    public static boolean encodeToFile( byte[] dataToEncode, String filename )
+        boolean success = false;
+        MgBase64.OutputStream bos = null;
+        try
+            bos = new MgBase64.OutputStream(
+                      new java.io.FileOutputStream( filename ), MgBase64.ENCODE );
+            bos.write( dataToEncode );
+            success = true;
+        }   // end try
+            success = false;
+        }   // end catch: IOException
+        finally
+            try{ bos.close(); } catch( Exception e ){}
+        }   // end finally
+        return success;
+    }   // end encodeToFile
+     * Convenience method for decoding data to a file.
+     * @param dataToDecode Base64-encoded data as a string
+     * @param filename Filename for saving decoded data
+     * @since 2.1
+    public static boolean decodeToFile( String dataToDecode, String filename )
+        try
+                          new java.io.FileOutputStream( filename ), MgBase64.DECODE );
+                bos.write( dataToDecode.getBytes( PREFERRED_ENCODING ) );
+                success = true;
+        }   // end try
+            success = false;
+        finally
+        }   // end finally
+        return success;
+    }   // end decodeToFile
+     * Convenience method for reading a base64-encoded
+     * file and decoding it.
+     * @param filename Filename for reading encoded data
+     * @return decoded byte array or null if unsuccessful
+     * @since 2.1
+    public static byte[] decodeFromFile( String filename )
+        byte[] decodedData = null;
+        MgBase64.InputStream bis = null;
+        try
+            // Set up some useful variables
+            java.io.File file = new java.io.File( filename );
+            byte[] buffer = null;
+            int length   = 0;
+            int numBytes = 0;
+            // Check for size of file
+            if( file.length() > Integer.MAX_VALUE )
+                System.err.println( "File is too big for this convenience method (" + file.length() + " bytes)." );
+                return null;
+            }   // end if: file too big for int index
+            buffer = new byte[ (int)file.length() ];
+            // Open a stream
+            bis = new MgBase64.InputStream(
+                      new java.io.BufferedInputStream(
+                      new java.io.FileInputStream( file ) ), MgBase64.DECODE );
+            // Read until done
+            while( ( numBytes = bis.read( buffer, length, 4096 ) ) >= 0 )
+                length += numBytes;
+            // Save in a variable to return
+            decodedData = new byte[ length ];
+            System.arraycopy( buffer, 0, decodedData, 0, length );
+        }   // end try
+            System.err.println( "Error decoding from file " + filename );
+        finally
+            try{ bis.close(); } catch( Exception e) {}
+        }   // end finally
+        return decodedData;
+    }   // end decodeFromFile
+     * Convenience method for reading a binary file
+     * and base64-encoding it.
+     * @param filename Filename for reading binary data
+     * @return base64-encoded string or null if unsuccessful
+     * @since 2.1
+    public static String encodeFromFile( String filename )
+        String encodedData = null;
+        try
+            byte[] buffer = new byte[ (int)(file.length() * 1.4) ];
+            int length   = 0;
+            int numBytes = 0;
+            // Open a stream
+                      new java.io.FileInputStream( file ) ), MgBase64.ENCODE );
+            encodedData = new String( buffer, 0, length, MgBase64.PREFERRED_ENCODING );
+        }   // end try
+            System.err.println( "Error encoding from file " + filename );
+        finally
+        }   // end finally
+        return encodedData;
+        }   // end encodeFromFile
+    /* ********  I N N E R   C L A S S   I N P U T S T R E A M  ******** */
+     * A {@link MgBase64.InputStream} will read data from another
+     * <tt>java.io.InputStream</tt>, given in the constructor,
+     * and encode/decode to/from MgBase64 notation on the fly.
+     * @see MgBase64
+     * @since 1.3
+    public static class InputStream extends java.io.FilterInputStream
+        private boolean encode;         // Encoding or decoding
+        private int     position;       // Current position in the buffer
+        private byte[]  buffer;         // Small buffer holding converted data
+        private int     bufferLength;   // Length of buffer (3 or 4)
+        private int     numSigBytes;    // Number of meaningful bytes in the buffer
+        private int     lineLength;
+        private boolean breakLines;     // Break lines at less than 80 characters
+         * Constructs a {@link MgBase64.InputStream} in DECODE mode.
+         * @param in the <tt>java.io.InputStream</tt> from which to read data.
+         * @since 1.3
+        public InputStream( java.io.InputStream in )
+            this( in, DECODE );
+        }   // end constructor
+         * either ENCODE or DECODE mode.
+         * <p>
+         *   ENCODE or DECODE: Encode or Decode as data is read.
+         *     (only meaningful when encoding)
+         * </pre>
+         * <p>
+         * Example: <code>new MgBase64.InputStream( in, MgBase64.DECODE )</code>
+         * @see MgBase64#ENCODE
+         * @see MgBase64#DECODE
+         * @see MgBase64#DONT_BREAK_LINES
+         * @since 2.0
+        public InputStream( java.io.InputStream in, int options )
+            super( in );
+            this.breakLines   = (options & DONT_BREAK_LINES) != DONT_BREAK_LINES;
+            this.encode       = (options & ENCODE) == ENCODE;
+            this.bufferLength = encode ? 4 : 3;
+            this.buffer   = new byte[ bufferLength ];
+            this.position = -1;
+            this.lineLength = 0;
+         * Reads enough of the input stream to convert
+         * to/from Base64 and returns the next byte.
+         * @return next byte
+         * @since 1.3
+        public int read() throws java.io.IOException
+            // Do we need to get data?
+            if( position < 0 )
+                if( encode )
+                    byte[] b3 = new byte[3];
+                    int numBinaryBytes = 0;
+                    for( int i = 0; i < 3; i++ )
+                        try
+                            int b = in.read();
+                            // If end of stream, b is -1.
+                            if( b >= 0 )
+                                b3[i] = (byte)b;
+                                numBinaryBytes++;
+                            }   // end if: not end of stream
+                        }   // end try: read
+                            // Only a problem if we got no data at all.
+                            if( i == 0 )
+                                throw e;
+                        }   // end catch
+                    }   // end for: each needed input byte
+                    if( numBinaryBytes > 0 )
+                        encode3to4( b3, 0, numBinaryBytes, buffer, 0 );
+                        position = 0;
+                        numSigBytes = 4;
+                    }   // end if: got data
+                    else
+                        return -1;
+                    }   // end else
+                }   // end if: encoding
+                // Else decoding
+                else
+                    int i = 0;
+                    for( i = 0; i < 4; i++ )
+                        // Read four "meaningful" bytes:
+                        int b = 0;
+                        do{ b = in.read(); }
+                        while( b >= 0 && DECODABET[ b & 0x7f ] <= WHITE_SPACE_ENC );
+                        if( b < 0 )
+                            break; // Reads a -1 if end of stream
+                        b4[i] = (byte)b;
+                    if( i == 4 )
+                        numSigBytes = decode4to3( b4, 0, buffer, 0 );
+                        position = 0;
+                    }   // end if: got four characters
+                    else if( i == 0 ){
+                        return -1;
+                    }   // end else if: also padded correctly
+                    else
+                        // Must have broken out from above.
+                        throw new java.io.IOException( "Improperly padded Base64 input." );
+                    }   // end
+                }   // end else: decode
+            }   // end else: get data
+            // Got data?
+            if( position >= 0 )
+                // End of relevant data?
+                if( /*!encode &&*/ position >= numSigBytes )
+                    return -1;
+                if( encode && breakLines && lineLength >= MAX_LINE_LENGTH )
+                    lineLength = 0;
+                    return '\n';
+                }   // end if
+                else
+                    lineLength++;   // This isn't important when decoding
+                                    // but throwing an extra "if" seems
+                                    // just as wasteful.
+                    int b = buffer[ position++ ];
+                    if( position >= bufferLength )
+                        position = -1;
+                    return b & 0xFF; // This is how you "cast" a byte that's
+                                     // intended to be unsigned.
+                }   // end else
+            }   // end if: position >= 0
+            // Else error
+            else
+                // When JDK1.4 is more accepted, use an assertion here.
+                throw new java.io.IOException( "Error in Base64 code reading stream." );
+            }   // end else
+        }   // end read
+         * Calls {@link #read()} repeatedly until the end of stream
+         * is reached or <var>len</var> bytes are read.
+         * Returns number of bytes read into array or -1 if
+         * end of stream is encountered.
+         * @param dest array to hold values
+         * @param off offset for array
+         * @param len max number of bytes to read into array
+         * @return bytes read into array or -1 if end of stream is encountered.
+         * @since 1.3
+        public int read( byte[] dest, int off, int len ) throws java.io.IOException
+            int i;
+            int b;
+            for( i = 0; i < len; i++ )
+                b = read();
+                //if( b < 0 && i == 0 )
+                //    return -1;
+                if( b >= 0 )
+                    dest[off + i] = (byte)b;
+                else if( i == 0 )
+                    return -1;
+                else
+                    break; // Out of 'for' loop
+            }   // end for: each byte read
+            return i;
+        }   // end read
+    }   // end inner class InputStream
+    /* ********  I N N E R   C L A S S   O U T P U T S T R E A M  ******** */
+     * A {@link MgBase64.OutputStream} will write data to another
+     * <tt>java.io.OutputStream</tt>, given in the constructor,
+     * and encode/decode to/from Base64 notation on the fly.
+     * @see Base64
+     * @since 1.3
+    public static class OutputStream extends java.io.FilterOutputStream
+        private byte[]  b4; // Scratch used in a few places
+        private boolean suspendEncoding;
+         * Constructs a {@link Base64.OutputStream} in ENCODE mode.
+         * @param out the <tt>java.io.OutputStream</tt> to which data will be written.
+         * @since 1.3
+        public OutputStream( java.io.OutputStream out )
+            this( out, ENCODE );
+         * <p>
+         * </pre>
+         * <p>
+         * Example: <code>new Base64.OutputStream( out, Base64.ENCODE )</code>
+         * @param options Specified options.
+         * @see Base64#ENCODE
+         * @see Base64#DECODE
+         * @since 1.3
+        public OutputStream( java.io.OutputStream out, int options )
+            super( out );
+            this.bufferLength = encode ? 3 : 4;
+            this.position     = 0;
+            this.suspendEncoding = false;
+            this.b4           = new byte[4];
+         * Writes the byte to the output stream after
+         * converting to/from Base64 notation.
+         * When encoding, bytes are buffered three
+         * at a time before the output stream actually
+         * gets a write() call.
+         * When decoding, bytes are buffered four
+         * at a time.
+         * @param theByte the byte to write
+         * @since 1.3
+        public void write(int theByte) throws java.io.IOException
+            // Encoding suspended?
+            if( suspendEncoding )
+                super.out.write( theByte );
+                return;
+            }   // end if: supsended
+            // Encode?
+            if( encode )
+                buffer[ position++ ] = (byte)theByte;
+                if( position >= bufferLength )  // Enough to encode.
+                    out.write( encode3to4( b4, buffer, bufferLength ) );
+                    lineLength += 4;
+                    if( breakLines && lineLength >= MAX_LINE_LENGTH )
+                        out.write( NEW_LINE );
+                        lineLength = 0;
+                    position = 0;
+                }   // end if: enough to output
+            // Else, Decoding
+            else
+                // Meaningful Base64 character?
+                if( DECODABET[ theByte & 0x7f ] > WHITE_SPACE_ENC )
+                    if( position >= bufferLength )  // Enough to output.
+                        int len = MgBase64.decode4to3( buffer, 0, b4, 0 );
+                        out.write( b4, 0, len );
+                        //out.write( MgBase64.decode4to3( buffer ) );
+                        position = 0;
+                }   // end if: meaningful base64 character
+                else if( DECODABET[ theByte & 0x7f ] != WHITE_SPACE_ENC )
+                    throw new java.io.IOException( "Invalid character in Base64 data." );
+                }   // end else: not white space either
+            }   // end else: decoding
+        }   // end write
+         * Calls {@link #write(int)} repeatedly until <var>len</var>
+         * bytes are written.
+         * @param theBytes array from which to read bytes
+         * @since 1.3
+        public void write( byte[] theBytes, int off, int len ) throws java.io.IOException
+                super.out.write( theBytes, off, len );
+                return;
+            for( int i = 0; i < len; i++ )
+                write( theBytes[ off + i ] );
+            }   // end for: each byte written
+        }   // end write
+         * Method added by PHIL. [Thanks, PHIL. -Rob]
+         * This pads the buffer without closing the stream.
+        public void flushBase64() throws java.io.IOException
+            if( position > 0 )
+                if( encode )
+                    out.write( encode3to4( b4, buffer, position ) );
+                    position = 0;
+                else
+                    throw new java.io.IOException( "Base64 input not properly padded." );
+            }   // end if: buffer partially full
+        }   // end flush
+         * Flushes and closes (I think, in the superclass) the stream.
+         * @since 1.3
+        public void close() throws java.io.IOException
+            // 1. Ensure that pending characters are written
+            flushBase64();
+            // 2. Actually close the stream
+            // Base class both flushes and closes.
+            super.close();
+            buffer = null;
+            out    = null;
+        }   // end close
+         * Suspends encoding of the stream.
+         * May be helpful if you need to embed a piece of
+         * base640-encoded data in a stream.
+         * @since 1.5.1
+        public void suspendEncoding() throws java.io.IOException
+            flushBase64();
+            this.suspendEncoding = true;
+        }   // end suspendEncoding
+         * Resumes encoding of the stream.
+         * @since 1.5.1
+        public void resumeEncoding()
+        }   // end resumeEncoding
+    }   // end inner class OutputStream
+}   // end class MgBase64
Deleted: trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgLocalizer.java
--- sandbox/jng/swig-java/Web/src/JavaApiEx/org/osgeo/mapguide/MgLocalizer.java	2012-12-08 14:59:43 UTC (rev 7251)
+++ trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgLocalizer.java	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,154 +0,0 @@
-  Copyright (C) 2004-2011 by Autodesk, Inc.
-  This library is free software; you can redistribute it and/or
-  modify it under the terms of version 2.1 of the GNU Lesser
-  General Public License as published by the Free Software Foundation.
-  This library is distributed in the hope that it will be useful,
-  but WITHOUT ANY WARRANTY; without even the implied warranty of
-  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-  Lesser General Public License for more details.
-  You should have received a copy of the GNU Lesser General Public
-  License along with this library; if not, write to the Free Software
-  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-package org.osgeo.mapguide;
-import java.util.*;
-import java.io.*;
-public class MgLocalizer
-    protected static String english = "en";
-    protected static String localizationPath = "";
-    protected static Hashtable languages = new Hashtable();
-    public static void SetLocalizedFilesPath(String path)
-        localizationPath = path;
-    public static String Localize(String text, String locale, int os)
-        String fontSuffix = (os==0? "Windows": (os==1? "Macintosh": "Linux"));
-        Hashtable sb = null;
-        try
-            sb = GetStringBundle(locale);
-        catch (Exception e)
-            return "";
-        int len = text.length();
-        for (int i = 0; i < len; )
-            int pos1 = text.indexOf("__#", i);
-            if (pos1 != -1)
-                int pos2 = text.indexOf("#__", pos1 + 3);
-                if (pos2 != -1)
-                    String id = text.substring(pos1 + 3, pos2);
-                    String locStr;
-                    locStr = (String)sb.get(id.equals("@font") || id.equals("@fontsize") ? id + fontSuffix : id);
-                    if (locStr == null)
-                        locStr = "";
-                    int locLen = locStr.length();
-                    String begin, end;
-                    if (pos1 > 0)
-                        begin = text.substring(0, pos1);
-                    else
-                        begin = "";
-                    end = text.substring(pos2 + 3);
-                    text = begin + locStr + end;
-                    len = len - 6 - id.length() + locLen;
-                    i = pos1 + locLen;
-                else
-                    i = len;
-            else
-                i = len;
-        return text;
-    public static String GetString(String id, String locale)
-        try
-            return "";
-        String s = (String)sb.get(id);
-        if (s == null)
-            return "";
-        return s;
-    protected static Hashtable GetStringBundle(String locale)
-        if (locale.equals(""))
-            locale = english;
-        else
-            locale = locale.toLowerCase();
-        if (!languages.containsKey(locale))
-            BufferedReader in = null;
-            try
-                File f = new File(localizationPath + locale);
-                if (!f.exists())
-                    // requested locale is not supported, default to English
-                    if (languages.containsKey(english))
-                        return (Hashtable)languages.get(english);
-                    f = new File(localizationPath + english);
-                in = new BufferedReader(new InputStreamReader(new FileInputStream(f), "UTF-8"));
-                String line;
-                Hashtable sb = new Hashtable();
-                while ((line = in.readLine()) != null)
-                    line = line.trim();
-                    if (line.equals("") || line.charAt(0) == '#')
-                        continue;
-                    int sep = line.indexOf('=');
-                    if (sep == -1)
-                        continue;
-                    String key = line.substring(0, sep).trim();
-                    if (key.equals(""))
-                        continue;
-                    sb.put(key, line.substring(sep + 1).trim());
-                languages.put(locale, sb);
-                return null;
-            finally
-                if (in != null)
-                    try { in.close(); }
-                    catch (Exception e) { }
-        return (Hashtable)languages.get(locale);
Copied: trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgLocalizer.java (from rev 7251, sandbox/jng/swig-java/Web/src/JavaApiEx/org/osgeo/mapguide/MgLocalizer.java)
--- trunk/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/MgLocalizer.java	                        (rev 0)
@@ -0,0 +1,154 @@
+  Copyright (C) 2004-2011 by Autodesk, Inc.
+  This library is free software; you can redistribute it and/or
+  modify it under the terms of version 2.1 of the GNU Lesser
+  General Public License as published by the Free Software Foundation.
+  This library is distributed in the hope that it will be useful,
+  but WITHOUT ANY WARRANTY; without even the implied warranty of
+  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+  Lesser General Public License for more details.
+  You should have received a copy of the GNU Lesser General Public
+  License along with this library; if not, write to the Free Software
+  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+package org.osgeo.mapguide;
+import java.util.*;
+import java.io.*;
+public class MgLocalizer
+    protected static String english = "en";
+    protected static String localizationPath = "";
+    protected static Hashtable languages = new Hashtable();
+    public static void SetLocalizedFilesPath(String path)
+        localizationPath = path;
+    public static String Localize(String text, String locale, int os)
+        String fontSuffix = (os==0? "Windows": (os==1? "Macintosh": "Linux"));
+        Hashtable sb = null;
+        try
+            sb = GetStringBundle(locale);
+        catch (Exception e)
+            return "";
+        int len = text.length();
+        for (int i = 0; i < len; )
+            int pos1 = text.indexOf("__#", i);
+            if (pos1 != -1)
+                int pos2 = text.indexOf("#__", pos1 + 3);
+                if (pos2 != -1)
+                    String id = text.substring(pos1 + 3, pos2);
+                    String locStr;
+                    locStr = (String)sb.get(id.equals("@font") || id.equals("@fontsize") ? id + fontSuffix : id);
+                    if (locStr == null)
+                        locStr = "";
+                    int locLen = locStr.length();
+                    String begin, end;
+                    if (pos1 > 0)
+                        begin = text.substring(0, pos1);
+                    else
+                        begin = "";
+                    end = text.substring(pos2 + 3);
+                    text = begin + locStr + end;
+                    len = len - 6 - id.length() + locLen;
+                    i = pos1 + locLen;
+                else
+                    i = len;
+            else
+                i = len;
+        return text;
+    public static String GetString(String id, String locale)
+        try
+            return "";
+        String s = (String)sb.get(id);
+        if (s == null)
+            return "";
+        return s;
+    protected static Hashtable GetStringBundle(String locale)
+        if (locale.equals(""))
+            locale = english;
+        else
+            locale = locale.toLowerCase();
+        if (!languages.containsKey(locale))
+            BufferedReader in = null;
+            try
+                File f = new File(localizationPath + locale);
+                if (!f.exists())
+                    // requested locale is not supported, default to English
+                    if (languages.containsKey(english))
+                        return (Hashtable)languages.get(english);
+                    f = new File(localizationPath + english);
+                in = new BufferedReader(new InputStreamReader(new FileInputStream(f), "UTF-8"));
+                String line;
+                Hashtable sb = new Hashtable();
+                while ((line = in.readLine()) != null)
+                    line = line.trim();
+                    if (line.equals("") || line.charAt(0) == '#')
+                        continue;
+                    int sep = line.indexOf('=');
+                    if (sep == -1)
+                        continue;
+                    String key = line.substring(0, sep).trim();
+                    if (key.equals(""))
+                        continue;
+                    sb.put(key, line.substring(sep + 1).trim());
+                languages.put(locale, sb);
+                return null;
+            finally
+                if (in != null)
+                    try { in.close(); }
+                    catch (Exception e) { }
+        return (Hashtable)languages.get(locale);
Modified: trunk/MgDev/Web/src/Makefile.am
--- trunk/MgDev/Web/src/Makefile.am	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/Makefile.am	2013-01-12 03:36:03 UTC (rev 7297)
@@ -1,6 +1,6 @@
 AUTOMAKE_OPTIONS = foreign
-SUBDIRS = WebApp WebSupport HttpHandler CgiAgent PhpApi JavaApi ApacheAgent
-DIST_SUBDIRS = WebApp WebSupport HttpHandler CgiAgent PhpApi JavaApi ApacheAgent
+SUBDIRS = WebApp WebSupport HttpHandler CgiAgent PhpApi JavaApi JavaApiEx ApacheAgent
+DIST_SUBDIRS = WebApp WebSupport HttpHandler CgiAgent PhpApi JavaApi JavaApiEx ApacheAgent
 EXTRA_DIST = MapGuideApi DotNetApi DotNetUnmanagedApi mapviewernet mapviewerjava mapviewerphp mapadmin mapagent stdicons viewerfiles WebTier.sln webconfig.ini WEB-INF localized schemareport webstudio PostBuild
 prefix=@prefix@/webserverextensions/www
Modified: trunk/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml
--- trunk/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml	2013-01-12 03:36:03 UTC (rev 7297)
@@ -9,6 +9,7 @@
    Target section.
 <Target path="./MapGuideApi.i" />
+<DocTarget path="./MapGuideApi_Doc.i" />
    C++ inline section.
@@ -51,6 +52,7 @@
    Swig inline section.
 <SwigInline>
+  %include "MapGuideApi_Doc.i" //translated doxygen fragments
   %include "language.i"   //typemaps specific for each language
   %include "../../../Common/Foundation/System/FoundationClassId.h"
   %include "../../../Common/Geometry/GeometryClassId.h"
Modified: trunk/MgDev/Web/src/WebTier_VS2010.sln
--- trunk/MgDev/Web/src/WebTier_VS2010.sln	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/Web/src/WebTier_VS2010.sln	2013-01-12 03:36:03 UTC (rev 7297)
@@ -60,6 +60,8 @@
 EndProject
 Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "WebDotNetApi", "DotNetApi\Web\WebDotNetApi.vcxproj", "{41F3263B-C16C-49E8-ADF6-416DFB55C9E2}"
 EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "JavaApiEx", "JavaApiEx\JavaApiEx.vcxproj", "{C02F44CB-D916-428D-A1A5-04E225A2A4EC}"
+EndProject
 Global
 	GlobalSection(SolutionConfigurationPlatforms) = preSolution
 		Debug|Win32 = Debug|Win32
@@ -308,6 +310,14 @@
 		{41F3263B-C16C-49E8-ADF6-416DFB55C9E2}.Release|Win32.Build.0 = Release|Win32
 		{41F3263B-C16C-49E8-ADF6-416DFB55C9E2}.Release|x64.ActiveCfg = Release|x64
 		{41F3263B-C16C-49E8-ADF6-416DFB55C9E2}.Release|x64.Build.0 = Release|x64
+		{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|Win32.ActiveCfg = Debug|Win32
+		{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|Win32.Build.0 = Debug|Win32
+		{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|x64.ActiveCfg = Debug|x64
+		{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Debug|x64.Build.0 = Debug|x64
+		{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|Win32.ActiveCfg = Release|Win32
+		{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|Win32.Build.0 = Release|Win32
+		{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x64.ActiveCfg = Release|x64
+		{C02F44CB-D916-428D-A1A5-04E225A2A4EC}.Release|x64.Build.0 = Release|x64
 	EndGlobalSection
 	GlobalSection(SolutionProperties) = preSolution
 		HideSolutionNode = FALSE
Modified: trunk/MgDev/build.bat
--- trunk/MgDev/build.bat	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/build.bat	2013-01-12 03:36:03 UTC (rev 7297)
@@ -388,8 +388,6 @@
 echo [install]: Copy dlls into .net samples
 %XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetsamples\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
 %XCOPY% "%MG_OUTPUT_WEB%\www\mapviewernet\bin\*.dll" "%MG_OUTPUT_WEB%\www\dotnetviewersample\bin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
-echo [build]: .net intellisense files
-DoxyTransform.exe dotnet "%MG_DOC_XML%" "%MG_OUTPUT_WEB%\www\mapviewernet\bin"
 goto quit
 :error
Modified: trunk/MgDev/build64.bat
--- trunk/MgDev/build64.bat	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/build64.bat	2013-01-12 03:36:03 UTC (rev 7297)
@@ -420,8 +420,6 @@
 goto quit
 :error
Modified: trunk/MgDev/configure.in
--- trunk/MgDev/configure.in	2013-01-09 19:09:42 UTC (rev 7296)
+++ trunk/MgDev/configure.in	2013-01-12 03:36:03 UTC (rev 7297)
@@ -240,6 +240,7 @@
         Web/src/WebApp/Makefile \
         Web/src/WebSupport/Makefile \
         Web/src/JavaApi/Makefile \
+        Web/src/JavaApiEx/Makefile \
         Web/src/PhpApi/Makefile \
         Web/src/HttpHandler/Makefile \
         Web/src/CgiAgent/Makefile \
More information about the mapguide-commits mailing list
