[mapguide-commits] r7310 - in trunk/MgDev/nuget: . MapGuideNuget MapGuideNuget/.nuget MapGuideNuget/CoordSysEnumTest MapGuideNuget/CoordSysEnumTest/Properties MapGuideNuget/CoordSysEnumTest64 MapGuideNuget/CoordSysEnumTest64/Properties MapGuideNuget/DesktopConsoleTest MapGuideNuget/DesktopConsoleTest/Properties MapGuideNuget/DesktopConsoleTest64 MapGuideNuget/DesktopConsoleTest64/Properties MapGuideNuget/DesktopViewerTest MapGuideNuget/DesktopViewerTest/Properties MapGuideNuget/DesktopViewerTest64 MapGuideNuget/DesktopViewerTest64/Properties MapGuideNuget/MapGuideNuget MapGuideNuget/MapGuideNuget/Properties MapGuideNuget/MapGuideNuget64 MapGuideNuget/MapGuideNuget64/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Jan 13 04:26:07 PST 2013
Author: jng
Date: 2013-01-13 04:26:06 -0800 (Sun, 13 Jan 2013)
New Revision: 7310
Added:
   trunk/MgDev/nuget/MapGuideNuget/
   trunk/MgDev/nuget/MapGuideNuget/.nuget/
   trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config
   trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.exe
   trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/AssemblyInfo.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Resources.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Resources.resx
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Settings.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Settings.settings
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings
   trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/DesktopConsoleTest.csproj
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Program.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Properties/
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Properties/AssemblyInfo.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/packages.config
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/DesktopViewerTest.csproj
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.resx
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Program.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/AssemblyInfo.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Resources.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Resources.resx
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Settings.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Settings.settings
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/packages.config
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings
   trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx.cs
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx.designer.cs
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Global.asax
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Global.asax.cs
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj.user
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Properties/
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Properties/AssemblyInfo.cs
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.Debug.config
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.Release.config
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.config
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/packages.config
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/webconfig.ini
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config
   trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini
   trunk/MgDev/nuget/MapGuideNuget/Web.sln
   trunk/MgDev/nuget/MapGuideNuget/Web64.sln
Add a set of test applications (VS2012, .net 4.0) for testing our nuget packages
Property changes on: trunk/MgDev/nuget/MapGuideNuget
___________________________________________________________________
Added: bugtraq:number
   + true
Property changes on: trunk/MgDev/nuget/MapGuideNuget/.nuget
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config
--- trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,6 @@
+<?xml version="1.0" encoding="utf-8"?>
+<configuration>
+  <solution>
+    <add key="disableSourceControlIntegration" value="true" />
+  </solution>
+</configuration>
\ No newline at end of file
Added: trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.exe
(Binary files differ)
Property changes on: trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.exe
Added: svn:mime-type
   + application/octet-stream
Added: trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets
--- trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,150 @@
+<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+    <PropertyGroup>
+        <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">$(MSBuildProjectDirectory)\..\</SolutionDir>
+        <!-- Enable the restore command to run before builds -->
+        <RestorePackages Condition="  '$(RestorePackages)' == '' ">false</RestorePackages>
+        <!-- Property that enables building a package from a project -->
+        <BuildPackage Condition=" '$(BuildPackage)' == '' ">false</BuildPackage>
+        <!-- Determines if package restore consent is required to restore packages -->
+        <RequireRestoreConsent Condition=" '$(RequireRestoreConsent)' != 'false' ">true</RequireRestoreConsent>
+        <!-- Download NuGet.exe if it does not already exist -->
+        <DownloadNuGetExe Condition=" '$(DownloadNuGetExe)' == '' ">false</DownloadNuGetExe>
+    </PropertyGroup>
+    <ItemGroup Condition=" '$(PackageSources)' == '' ">
+        <!-- Package sources used to restore packages. By default will used the registered sources under %APPDATA%\NuGet\NuGet.Config -->
+            <PackageSource Include="https://nuget.org/api/v2/" />
+            <PackageSource Include="https://my-nuget-source/nuget/" />
+    </ItemGroup>
+    <PropertyGroup Condition=" '$(OS)' == 'Windows_NT'">
+        <!-- Windows specific commands -->
+        <NuGetToolsPath>$([System.IO.Path]::Combine($(SolutionDir), ".nuget"))</NuGetToolsPath>
+        <PackagesConfig>$([System.IO.Path]::Combine($(ProjectDir), "packages.config"))</PackagesConfig>
+    </PropertyGroup>
+    <PropertyGroup Condition=" '$(OS)' != 'Windows_NT'">
+        <!-- We need to launch nuget.exe with the mono command if we're not on windows -->
+        <NuGetToolsPath>$(SolutionDir).nuget</NuGetToolsPath>
+        <PackagesConfig>packages.config</PackagesConfig>
+    </PropertyGroup>
+    <PropertyGroup>
+        <!-- NuGet command -->
+        <NuGetExePath Condition=" '$(NuGetExePath)' == '' ">$(NuGetToolsPath)\nuget.exe</NuGetExePath>
+        <PackageSources Condition=" $(PackageSources) == '' ">@(PackageSource)</PackageSources>
+        <NuGetCommand Condition=" '$(OS)' == 'Windows_NT'">"$(NuGetExePath)"</NuGetCommand>
+        <NuGetCommand Condition=" '$(OS)' != 'Windows_NT' ">mono --runtime=v4.0.30319 $(NuGetExePath)</NuGetCommand>
+        <PackageOutputDir Condition="$(PackageOutputDir) == ''">$(TargetDir.Trim('\\'))</PackageOutputDir>
+        <RequireConsentSwitch Condition=" $(RequireRestoreConsent) == 'true' ">-RequireConsent</RequireConsentSwitch>
+        <!-- Commands -->
+        <RestoreCommand>$(NuGetCommand) install "$(PackagesConfig)" -source "$(PackageSources)"  $(RequireConsentSwitch) -solutionDir "$(SolutionDir) "</RestoreCommand>
+        <BuildCommand>$(NuGetCommand) pack "$(ProjectPath)" -p Configuration=$(Configuration) -o "$(PackageOutputDir)" -symbols</BuildCommand>
+        <!-- We need to ensure packages are restored prior to assembly resolve -->
+        <ResolveReferencesDependsOn Condition="$(RestorePackages) == 'true'">
+            RestorePackages;
+            $(ResolveReferencesDependsOn);
+        </ResolveReferencesDependsOn>
+        <!-- Make the build depend on restore packages -->
+        <BuildDependsOn Condition="$(BuildPackage) == 'true'">
+            $(BuildDependsOn);
+            BuildPackage;
+        </BuildDependsOn>
+    </PropertyGroup>
+    <Target Name="CheckPrerequisites">
+        <!-- Raise an error if we're unable to locate nuget.exe  -->
+        <Error Condition="'$(DownloadNuGetExe)' != 'true' AND !Exists('$(NuGetExePath)')" Text="Unable to locate '$(NuGetExePath)'" />
+        <SetEnvironmentVariable EnvKey="VisualStudioVersion" EnvValue="$(VisualStudioVersion)" Condition=" '$(VisualStudioVersion)' != '' AND '$(OS)' == 'Windows_NT' " />
+        Take advantage of MsBuild's build dependency tracking to make sure that we only ever download nuget.exe once.
+        This effectively acts as a lock that makes sure that the download operation will only happen once and all
+        parallel builds will have to wait for it to complete.
+        <MsBuild Targets="_DownloadNuGet" Projects="$(MSBuildThisFileFullPath)" Properties="Configuration=NOT_IMPORTANT" />
+    </Target>
+    <Target Name="_DownloadNuGet">
+        <DownloadNuGet OutputFilename="$(NuGetExePath)" Condition=" '$(DownloadNuGetExe)' == 'true' AND !Exists('$(NuGetExePath)')" />
+    </Target>
+    <Target Name="RestorePackages" DependsOnTargets="CheckPrerequisites">
+        <Exec Command="$(RestoreCommand)"
+              Condition="'$(OS)' != 'Windows_NT' And Exists('$(PackagesConfig)')" />
+              LogStandardErrorAsError="true"
+              Condition="'$(OS)' == 'Windows_NT' And Exists('$(PackagesConfig)')" />
+    </Target>
+    <Target Name="BuildPackage" DependsOnTargets="CheckPrerequisites">
+        <Exec Command="$(BuildCommand)"
+              Condition=" '$(OS)' != 'Windows_NT' " />
+              Condition=" '$(OS)' == 'Windows_NT' " />
+    </Target>
+    <UsingTask TaskName="DownloadNuGet" TaskFactory="CodeTaskFactory" AssemblyFile="$(MSBuildToolsPath)\Microsoft.Build.Tasks.v4.0.dll">
+        <ParameterGroup>
+            <OutputFilename ParameterType="System.String" Required="true" />
+        </ParameterGroup>
+        <Task>
+            <Reference Include="System.Core" />
+            <Using Namespace="System" />
+            <Using Namespace="System.IO" />
+            <Using Namespace="System.Net" />
+            <Using Namespace="Microsoft.Build.Framework" />
+            <Using Namespace="Microsoft.Build.Utilities" />
+            <Code Type="Fragment" Language="cs">
+                <![CDATA[
+                try {
+                    OutputFilename = Path.GetFullPath(OutputFilename);
+                    Log.LogMessage("Downloading latest version of NuGet.exe...");
+                    WebClient webClient = new WebClient();
+                    webClient.DownloadFile("https://nuget.org/nuget.exe", OutputFilename);
+                    return true;
+                catch (Exception ex) {
+                    Log.LogErrorFromException(ex);
+                    return false;
+            </Code>
+        </Task>
+    </UsingTask>
+     <UsingTask TaskName="SetEnvironmentVariable" TaskFactory="CodeTaskFactory" AssemblyFile="$(MSBuildToolsPath)\Microsoft.Build.Tasks.v4.0.dll">
+        <ParameterGroup>
+            <EnvKey ParameterType="System.String" Required="true" />
+            <EnvValue ParameterType="System.String" Required="true" />
+        </ParameterGroup>
+        <Task>
+                <![CDATA[
+                try {
+                    Environment.SetEnvironmentVariable(EnvKey, EnvValue, System.EnvironmentVariableTarget.Process);
+                catch  {
+            </Code>
+        </Task>
+    </UsingTask>
+</Project>
Property changes on: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,104 @@
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+  <PropertyGroup>
+    <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+    <Platform Condition=" '$(Platform)' == '' ">x86</Platform>
+    <ProductVersion>8.0.30703</ProductVersion>
+    <SchemaVersion>2.0</SchemaVersion>
+    <ProjectGuid>{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}</ProjectGuid>
+    <OutputType>WinExe</OutputType>
+    <AppDesignerFolder>Properties</AppDesignerFolder>
+    <RootNamespace>CoordSysEnumTest</RootNamespace>
+    <AssemblyName>CoordSysEnumTest</AssemblyName>
+    <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
+    <TargetFrameworkProfile>Client</TargetFrameworkProfile>
+    <FileAlignment>512</FileAlignment>
+  </PropertyGroup>
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x86' ">
+    <PlatformTarget>x86</PlatformTarget>
+    <DebugSymbols>true</DebugSymbols>
+    <DebugType>full</DebugType>
+    <Optimize>false</Optimize>
+    <OutputPath>bin\Debug\</OutputPath>
+    <DefineConstants>DEBUG;TRACE</DefineConstants>
+    <ErrorReport>prompt</ErrorReport>
+    <WarningLevel>4</WarningLevel>
+    <UseVSHostingProcess>false</UseVSHostingProcess>
+  </PropertyGroup>
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x86' ">
+    <DebugType>pdbonly</DebugType>
+    <Optimize>true</Optimize>
+    <OutputPath>bin\Release\</OutputPath>
+    <DefineConstants>TRACE</DefineConstants>
+  </PropertyGroup>
+  <ItemGroup>
+    <Reference Include="OSGeo.MapGuide.Foundation">
+      <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.Geometry">
+      <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.PlatformBase">
+      <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
+    </Reference>
+    <Reference Include="System" />
+    <Reference Include="System.Xml.Linq" />
+    <Reference Include="System.Data.DataSetExtensions" />
+    <Reference Include="Microsoft.CSharp" />
+    <Reference Include="System.Data" />
+    <Reference Include="System.Deployment" />
+    <Reference Include="System.Drawing" />
+    <Reference Include="System.Windows.Forms" />
+    <Reference Include="System.Xml" />
+  </ItemGroup>
+  <ItemGroup>
+    <Compile Include="MainForm.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="MainForm.Designer.cs">
+      <DependentUpon>MainForm.cs</DependentUpon>
+    </Compile>
+    <Compile Include="Program.cs" />
+    <Compile Include="Properties\AssemblyInfo.cs" />
+    <EmbeddedResource Include="MainForm.resx">
+    </EmbeddedResource>
+    <EmbeddedResource Include="Properties\Resources.resx">
+      <Generator>ResXFileCodeGenerator</Generator>
+      <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+      <SubType>Designer</SubType>
+    <Compile Include="Properties\Resources.Designer.cs">
+      <AutoGen>True</AutoGen>
+      <DependentUpon>Resources.resx</DependentUpon>
+    </Compile>
+    <None Include="packages.config" />
+    <None Include="Properties\Settings.settings">
+      <Generator>SettingsSingleFileGenerator</Generator>
+      <LastGenOutput>Settings.Designer.cs</LastGenOutput>
+    </None>
+    <Compile Include="Properties\Settings.Designer.cs">
+      <DependentUpon>Settings.settings</DependentUpon>
+      <DesignTimeSharedInput>True</DesignTimeSharedInput>
+    </Compile>
+  </ItemGroup>
+  <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+  <PropertyGroup>
+    <PostBuildEvent>
+if not exist "$(TargetDir)Dictionaries" md "$(TargetDir)Dictionaries"
+xcopy /s /y "$(SolutionDir)packages\cs-map-dictionaries.2.4.0.7093\dictionaries\*.*" "$(TargetDir)Dictionaries"
+xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x86.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"</PostBuildEvent>
+  </PropertyGroup>
+  <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+       Other similar extension points exist, see Microsoft.Common.targets.
+  <Target Name="BeforeBuild">
+  </Target>
+  <Target Name="AfterBuild">
+  </Target>
+</Project>
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,73 @@
+namespace CoordSysEnumTest
+    partial class MainForm
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            this.label1 = new System.Windows.Forms.Label();
+            this.lstCoordSysCategories = new System.Windows.Forms.ListBox();
+            this.SuspendLayout();
+            // label1
+            this.label1.AutoSize = true;
+            this.label1.Location = new System.Drawing.Point(13, 13);
+            this.label1.Name = "label1";
+            this.label1.Size = new System.Drawing.Size(400, 13);
+            this.label1.TabIndex = 0;
+            this.label1.Text = "If you see these coordinate system categories, the MapGuide API base is working :" +
+            // lstCoordSysCategories
+            this.lstCoordSysCategories.FormattingEnabled = true;
+            this.lstCoordSysCategories.Location = new System.Drawing.Point(16, 47);
+            this.lstCoordSysCategories.Name = "lstCoordSysCategories";
+            this.lstCoordSysCategories.Size = new System.Drawing.Size(406, 186);
+            this.lstCoordSysCategories.TabIndex = 1;
+            // MainForm
+            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.ClientSize = new System.Drawing.Size(434, 257);
+            this.Controls.Add(this.lstCoordSysCategories);
+            this.Controls.Add(this.label1);
+            this.Name = "MainForm";
+            this.Text = "Form1";
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.ListBox lstCoordSysCategories;
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,38 @@
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide;
+    public partial class MainForm : Form
+        private MainForm()
+            InitializeComponent();
+        private MgCoordinateSystemFactory _fact;
+        public MainForm(MgCoordinateSystemFactory fact) : this()
+            _fact = fact;
+        protected override void OnLoad(EventArgs e)
+            base.OnLoad(e);
+            MgStringCollection categories = _fact.EnumerateCategories();
+            var items = new List<string>();
+            for (int i = 0; i < categories.GetCount(); i++)
+                items.Add(categories.GetItem(i));
+            lstCoordSysCategories.DataSource = items;
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,120 @@
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+</root>
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,28 @@
+using System;
+using System.Linq;
+using System.IO;
+    static class Program
+        /// <summary>
+        /// The main entry point for the application.
+        /// </summary>
+        [STAThread]
+        static void Main()
+            Application.EnableVisualStyles();
+            Application.SetCompatibleTextRenderingDefault(false);
+            MgCoordinateSystemFactory fact = new MgCoordinateSystemFactory();
+            MgCoordinateSystemCatalog cat = fact.GetCatalog();
+            cat.SetDictionaryDir(Path.Combine(Application.StartupPath, "Dictionaries"));
+            Application.Run(new MainForm(fact));
Property changes on: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/AssemblyInfo.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("CoordSysEnumTest")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("CoordSysEnumTest")]
+[assembly: AssemblyCopyright("Copyright ©  2012")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components.  If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("c7322422-5546-4cd1-a5c8-67b65c671874")]
+// Version information for an assembly consists of the following four values:
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Resources.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Resources.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Resources.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,71 @@
+// <auto-generated>
+//     This code was generated by a tool.
+//     Runtime Version:4.0.30319.269
+//     Changes to this file may cause incorrect behavior and will be lost if
+//     the code is regenerated.
+// </auto-generated>
+namespace CoordSysEnumTest.Properties
+    /// <summary>
+    ///   A strongly-typed resource class, for looking up localized strings, etc.
+    /// </summary>
+    // This class was auto-generated by the StronglyTypedResourceBuilder
+    // class via a tool like ResGen or Visual Studio.
+    // To add or remove a member, edit your .ResX file then rerun ResGen
+    // with the /str option, or rebuild your VS project.
+    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")]
+    [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+    [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+    internal class Resources
+        private static global::System.Resources.ResourceManager resourceMan;
+        private static global::System.Globalization.CultureInfo resourceCulture;
+        [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+        internal Resources()
+        /// <summary>
+        ///   Returns the cached ResourceManager instance used by this class.
+        /// </summary>
+        [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+        internal static global::System.Resources.ResourceManager ResourceManager
+            get
+                if ((resourceMan == null))
+                    global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("CoordSysEnumTest.Properties.Resources", typeof(Resources).Assembly);
+                    resourceMan = temp;
+                return resourceMan;
+        /// <summary>
+        ///   Overrides the current thread's CurrentUICulture property for all
+        ///   resource lookups using this strongly typed resource class.
+        /// </summary>
+        internal static global::System.Globalization.CultureInfo Culture
+            get
+                return resourceCulture;
+            set
+                resourceCulture = value;
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Resources.resx
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Resources.resx	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Resources.resx	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,117 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+            : System.Serialization.Formatters.Binary.BinaryFormatter
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" msdata:Ordinal="1" />
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+</root>
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Settings.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Settings.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Settings.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,30 @@
+    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "10.0.0.0")]
+    internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase
+        private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
+        public static Settings Default
+            get
+                return defaultInstance;
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Settings.settings
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Settings.settings	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/Settings.settings	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,7 @@
+<?xml version='1.0' encoding='utf-8'?>
+<SettingsFile xmlns="http://schemas.microsoft.com/VisualStudio/2004/01/settings" CurrentProfile="(Default)">
+  <Profiles>
+    <Profile Name="(Default)" />
+  </Profiles>
+  <Settings />
+</SettingsFile>
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,5 @@
+<packages>
+  <package id="cs-map-dictionaries" version="2.4.0.7093" targetFramework="net40-Client" />
+  <package id="mapguide-api-base-x86" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Property changes on: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,106 @@
+  <PropertyGroup>
+    <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\</SolutionDir>
+    <RestorePackages>true</RestorePackages>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x64'">
+    <OutputPath>bin\x64\Debug\</OutputPath>
+    <PlatformTarget>x64</PlatformTarget>
+    <CodeAnalysisRuleSet>ManagedMinimumRules.ruleset</CodeAnalysisRuleSet>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|x64'">
+    <OutputPath>bin\x64\Release\</OutputPath>
+  </PropertyGroup>
+  <ItemGroup>
+      <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
+    </Reference>
+      <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
+    </Reference>
+      <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
+    </Reference>
+  </ItemGroup>
+  <ItemGroup>
+    </Compile>
+    </Compile>
+    </Compile>
+    </None>
+    </Compile>
+  </ItemGroup>
+  <PropertyGroup>
+    <PostBuildEvent>
+xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x64.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"</PostBuildEvent>
+  </PropertyGroup>
+  <Import Project="$(SolutionDir)\.nuget\nuget.targets" />
+  </Target>
+  </Target>
+</Project>
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,73 @@
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+            // label1
+            // MainForm
+        #endregion
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,38 @@
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+            _fact = fact;
+            base.OnLoad(e);
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,120 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+</root>
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,28 @@
+using System;
+using System.Linq;
+using System.IO;
+        /// <summary>
+        /// </summary>
+        [STAThread]
Property changes on: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,36 @@
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,71 @@
+    /// <summary>
+    /// </summary>
+        /// <summary>
+        /// </summary>
+            get
+        /// <summary>
+        /// </summary>
+            get
+            set
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,117 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+</root>
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,30 @@
+            get
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,7 @@
+  <Profiles>
+  </Profiles>
+  <Settings />
+</SettingsFile>
Added: trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,5 @@
+<packages>
+  <package id="mapguide-api-base-x64" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Property changes on: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/DesktopConsoleTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/DesktopConsoleTest.csproj	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/DesktopConsoleTest.csproj	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,85 @@
+  <PropertyGroup>
+    <ProjectGuid>{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}</ProjectGuid>
+    <OutputType>Exe</OutputType>
+    <RootNamespace>DesktopConsoleTest</RootNamespace>
+    <AssemblyName>DesktopConsoleTest</AssemblyName>
+  </PropertyGroup>
+  </PropertyGroup>
+  </PropertyGroup>
+  <ItemGroup>
+    <Reference Include="OSGeo.MapGuide.Desktop, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=AMD64">
+      <SpecificVersion>False</SpecificVersion>
+      <HintPath>..\packages\mg-desktop-net40-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Desktop.dll</HintPath>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.Foundation, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.Geometry, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.PlatformBase, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
+    </Reference>
+  </ItemGroup>
+  <ItemGroup>
+  </ItemGroup>
+  <ItemGroup>
+  </ItemGroup>
+  <PropertyGroup>
+    <PostBuildEvent>
+xcopy /s /y "$(SolutionDir)packages\mg-desktop-net40-x86.2.4.0.7093\mg-desktop\*.*" "$(TargetDir)"</PostBuildEvent>
+  </PropertyGroup>
+  </Target>
+  </Target>
+</Project>
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Program.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Program.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,42 @@
+using System;
+using System.Linq;
+using System.Text;
+using System.IO;
+namespace DesktopConsoleTest
+    class Program
+        static void Main(string[] args)
+            MgdPlatform.Initialize("Platform.ini");
+            string currentDir = Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().Location);
+            //Test mapguide-api-base
+            MgCoordinateSystemFactory csFact = new MgCoordinateSystemFactory();
+            Console.WriteLine("Testing coordinate system categories");
+            MgStringCollection csCategories = csFact.EnumerateCategories();
+            for (int i = 0; i < csCategories.GetCount(); i++)
+                Console.WriteLine(csCategories.GetItem(i));
+            //Test mg-desktop
+            MgdServiceFactory serviceFact = new MgdServiceFactory();
+            Console.Write("Can we create a MgdFeatureService? ");
+            MgdFeatureService featSvc = (MgdFeatureService)serviceFact.CreateService(MgServiceType.FeatureService);
+            Console.WriteLine("yes");
+            Console.Write("Can we create a MgdResourceService? ");
+            MgdResourceService resSvc = (MgdResourceService)serviceFact.CreateService(MgServiceType.ResourceService);
+            MgdPlatform.Terminate();
+            Console.WriteLine("Things look all good :) Press any key to continue");
+            Console.Read();
Property changes on: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Properties
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/Properties/AssemblyInfo.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,36 @@
+[assembly: AssemblyTitle("DesktopConsoleTest")]
+[assembly: AssemblyProduct("DesktopConsoleTest")]
+[assembly: Guid("cafc7a89-4da9-48b9-87e3-f564367718bd")]
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/packages.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/packages.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,6 @@
+<packages>
+  <package id="mg-desktop-net40-x86" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Property changes on: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,83 @@
+  <PropertyGroup>
+  </PropertyGroup>
+  </PropertyGroup>
+  </PropertyGroup>
+  <ItemGroup>
+    <Reference Include="OSGeo.MapGuide.Desktop">
+      <HintPath>..\packages\mg-desktop-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Desktop.dll</HintPath>
+    </Reference>
+    </Reference>
+    </Reference>
+    </Reference>
+  </ItemGroup>
+  <ItemGroup>
+  </ItemGroup>
+  <ItemGroup>
+  </ItemGroup>
+  <PropertyGroup>
+    <PostBuildEvent>
+xcopy /s /y "$(SolutionDir)packages\mg-desktop-net40-x64.2.4.0.7093\mg-desktop\*.*" "$(TargetDir)"</PostBuildEvent>
+  </PropertyGroup>
+  </Target>
+  </Target>
+</Project>
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,42 @@
+using System;
+using System.Linq;
+using System.Text;
+using System.IO;
+    class Program
+            //Test mg-desktop
+            Console.Read();
Property changes on: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,36 @@
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,6 @@
+<packages>
+  <package id="mg-desktop-net40-x64" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Property changes on: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/DesktopViewerTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/DesktopViewerTest.csproj	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/DesktopViewerTest.csproj	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,119 @@
+  <PropertyGroup>
+    <ProjectGuid>{A0DCC768-B341-426B-889A-0701A2399CE8}</ProjectGuid>
+    <RootNamespace>DesktopViewerTest</RootNamespace>
+    <AssemblyName>DesktopViewerTest</AssemblyName>
+  </PropertyGroup>
+  </PropertyGroup>
+  </PropertyGroup>
+  <ItemGroup>
+    </Reference>
+    </Reference>
+    </Reference>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.Viewer, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=MSIL">
+      <HintPath>..\packages\mg-desktop-viewer-net40-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.dll</HintPath>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.Viewer.Desktop, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=MSIL">
+      <HintPath>..\packages\mg-desktop-viewer-net40-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.Desktop.dll</HintPath>
+    </Reference>
+  </ItemGroup>
+  <ItemGroup>
+    </Compile>
+    </Compile>
+    </Compile>
+    </None>
+    </Compile>
+  </ItemGroup>
+  <PropertyGroup>
+    <PostBuildEvent>
+  </PropertyGroup>
+  </Target>
+  </Target>
+</Project>
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,212 @@
+namespace DesktopViewerTest
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+            this.mgDefaultToolbar1 = new OSGeo.MapGuide.Viewer.MgDefaultToolbar();
+            this.statusStrip1 = new System.Windows.Forms.StatusStrip();
+            this.lblCoords = new System.Windows.Forms.ToolStripStatusLabel();
+            this.lblSelected = new System.Windows.Forms.ToolStripStatusLabel();
+            this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
+            this.lblSize = new System.Windows.Forms.ToolStripStatusLabel();
+            this.splitContainer1 = new System.Windows.Forms.SplitContainer();
+            this.splitContainer2 = new System.Windows.Forms.SplitContainer();
+            this.mgLegend1 = new OSGeo.MapGuide.Viewer.MgLegend();
+            this.mgPropertyPane1 = new OSGeo.MapGuide.Viewer.MgPropertyPane();
+            this.mgMapViewer1 = new OSGeo.MapGuide.Viewer.MgMapViewer();
+            this.statusStrip1.SuspendLayout();
+            ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).BeginInit();
+            this.splitContainer1.Panel1.SuspendLayout();
+            this.splitContainer1.Panel2.SuspendLayout();
+            this.splitContainer1.SuspendLayout();
+            ((System.ComponentModel.ISupportInitialize)(this.splitContainer2)).BeginInit();
+            this.splitContainer2.Panel1.SuspendLayout();
+            this.splitContainer2.Panel2.SuspendLayout();
+            this.splitContainer2.SuspendLayout();
+            // mgDefaultToolbar1
+            this.mgDefaultToolbar1.Location = new System.Drawing.Point(0, 0);
+            this.mgDefaultToolbar1.Name = "mgDefaultToolbar1";
+            this.mgDefaultToolbar1.Size = new System.Drawing.Size(613, 25);
+            this.mgDefaultToolbar1.TabIndex = 0;
+            this.mgDefaultToolbar1.Text = "mgDefaultToolbar1";
+            this.mgDefaultToolbar1.Viewer = null;
+            // statusStrip1
+            this.statusStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+            this.lblCoords,
+            this.lblSelected,
+            this.lblScale,
+            this.lblSize});
+            this.statusStrip1.Location = new System.Drawing.Point(0, 484);
+            this.statusStrip1.Name = "statusStrip1";
+            this.statusStrip1.Size = new System.Drawing.Size(613, 22);
+            this.statusStrip1.TabIndex = 1;
+            this.statusStrip1.Text = "statusStrip1";
+            // lblCoords
+            this.lblCoords.Name = "lblCoords";
+            this.lblCoords.Size = new System.Drawing.Size(0, 17);
+            // lblSelected
+            this.lblSelected.Name = "lblSelected";
+            this.lblSelected.Size = new System.Drawing.Size(598, 17);
+            this.lblSelected.Spring = true;
+            this.lblSelected.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
+            // lblScale
+            this.lblScale.Name = "lblScale";
+            this.lblScale.Size = new System.Drawing.Size(0, 17);
+            this.lblScale.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
+            // lblSize
+            this.lblSize.Name = "lblSize";
+            this.lblSize.Size = new System.Drawing.Size(0, 17);
+            // splitContainer1
+            this.splitContainer1.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.splitContainer1.Location = new System.Drawing.Point(0, 25);
+            this.splitContainer1.Name = "splitContainer1";
+            // splitContainer1.Panel1
+            this.splitContainer1.Panel1.Controls.Add(this.splitContainer2);
+            // splitContainer1.Panel2
+            this.splitContainer1.Panel2.Controls.Add(this.mgMapViewer1);
+            this.splitContainer1.Size = new System.Drawing.Size(613, 459);
+            this.splitContainer1.SplitterDistance = 204;
+            this.splitContainer1.TabIndex = 2;
+            // splitContainer2
+            this.splitContainer2.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.splitContainer2.Location = new System.Drawing.Point(0, 0);
+            this.splitContainer2.Name = "splitContainer2";
+            this.splitContainer2.Orientation = System.Windows.Forms.Orientation.Horizontal;
+            // splitContainer2.Panel1
+            this.splitContainer2.Panel1.Controls.Add(this.mgLegend1);
+            // splitContainer2.Panel2
+            this.splitContainer2.Panel2.Controls.Add(this.mgPropertyPane1);
+            this.splitContainer2.Size = new System.Drawing.Size(204, 459);
+            this.splitContainer2.SplitterDistance = 219;
+            this.splitContainer2.TabIndex = 0;
+            // mgLegend1
+            this.mgLegend1.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.mgLegend1.GroupContextMenu = null;
+            this.mgLegend1.LayerContextMenu = null;
+            this.mgLegend1.Location = new System.Drawing.Point(0, 0);
+            this.mgLegend1.Name = "mgLegend1";
+            this.mgLegend1.ShowTooltips = true;
+            this.mgLegend1.Size = new System.Drawing.Size(204, 219);
+            this.mgLegend1.TabIndex = 0;
+            this.mgLegend1.ThemeCompressionLimit = 0;
+            // mgPropertyPane1
+            this.mgPropertyPane1.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.mgPropertyPane1.Location = new System.Drawing.Point(0, 0);
+            this.mgPropertyPane1.Name = "mgPropertyPane1";
+            this.mgPropertyPane1.Size = new System.Drawing.Size(204, 236);
+            this.mgPropertyPane1.TabIndex = 0;
+            // mgMapViewer1
+            this.mgMapViewer1.Cursor = System.Windows.Forms.Cursors.Default;
+            this.mgMapViewer1.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.mgMapViewer1.Location = new System.Drawing.Point(0, 0);
+            this.mgMapViewer1.MaxScale = 1000000000;
+            this.mgMapViewer1.MinScale = 10;
+            this.mgMapViewer1.MouseWheelDelayRenderInterval = 800;
+            this.mgMapViewer1.Name = "mgMapViewer1";
+            this.mgMapViewer1.PointPixelBuffer = 2;
+            this.mgMapViewer1.SelectionColor = System.Drawing.Color.Blue;
+            this.mgMapViewer1.Size = new System.Drawing.Size(405, 459);
+            this.mgMapViewer1.TabIndex = 0;
+            this.mgMapViewer1.Text = "mgMapViewer1";
+            this.mgMapViewer1.TooltipDelayInterval = 1000;
+            this.mgMapViewer1.ZoomInFactor = 0.5D;
+            this.mgMapViewer1.ZoomOutFactor = 2D;
+            this.mgMapViewer1.SelectionChanged += new System.EventHandler(this.mgMapViewer1_SelectionChanged);
+            // MainForm
+            this.ClientSize = new System.Drawing.Size(613, 506);
+            this.Controls.Add(this.splitContainer1);
+            this.Controls.Add(this.statusStrip1);
+            this.Controls.Add(this.mgDefaultToolbar1);
+            this.Text = "mg-desktop Sample";
+            this.statusStrip1.ResumeLayout(false);
+            this.statusStrip1.PerformLayout();
+            this.splitContainer1.Panel1.ResumeLayout(false);
+            this.splitContainer1.Panel2.ResumeLayout(false);
+            ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).EndInit();
+            this.splitContainer1.ResumeLayout(false);
+            this.splitContainer2.Panel1.ResumeLayout(false);
+            this.splitContainer2.Panel2.ResumeLayout(false);
+            ((System.ComponentModel.ISupportInitialize)(this.splitContainer2)).EndInit();
+            this.splitContainer2.ResumeLayout(false);
+        #endregion
+        private OSGeo.MapGuide.Viewer.MgDefaultToolbar mgDefaultToolbar1;
+        private System.Windows.Forms.StatusStrip statusStrip1;
+        private System.Windows.Forms.ToolStripStatusLabel lblCoords;
+        private System.Windows.Forms.ToolStripStatusLabel lblSelected;
+        private System.Windows.Forms.ToolStripStatusLabel lblScale;
+        private System.Windows.Forms.ToolStripStatusLabel lblSize;
+        private System.Windows.Forms.SplitContainer splitContainer1;
+        private OSGeo.MapGuide.Viewer.MgMapViewer mgMapViewer1;
+        private System.Windows.Forms.SplitContainer splitContainer2;
+        private OSGeo.MapGuide.Viewer.MgLegend mgLegend1;
+        private OSGeo.MapGuide.Viewer.MgPropertyPane mgPropertyPane1;
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,127 @@
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+using OSGeo.MapGuide.Viewer;
+using OSGeo.MapGuide.Viewer.Desktop;
+    public partial class MainForm : Form, IMapStatusBar
+        public MainForm()
+            mgMapViewer1.UseRenderMapIfTiledLayersExist = true;
+            mgMapViewer1.RespectFiniteDisplayScales = true;
+            new MapViewerController(mgMapViewer1,          //The MgMapViewer
+                                    mgLegend1,             //The MgLegend
+                                    this,                  //The IMapStatusBar
+                                    mgPropertyPane1,       //The MgPropertyPane
+                                    mgDefaultToolbar1);    //The MgDefaultToolbar
+            MgdServiceFactory factory = new MgdServiceFactory();
+            MgdResourceService resSvc = (MgdResourceService)factory.CreateService(MgServiceType.ResourceService);
+            MgResourceIdentifier mapDefId = new MgResourceIdentifier("Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition");
+            //If this map definition doesn't exist, we ask the user to
+            //load the Sheboygan package
+            if (!resSvc.ResourceExists(mapDefId))
+                using (OpenFileDialog diag = new OpenFileDialog())
+                    diag.Filter = "MapGuide Packages (*.mgp)|*.mgp";
+                    if (diag.ShowDialog() == DialogResult.OK)
+                        MgByteSource source = new MgByteSource(diag.FileName);
+                        MgByteReader reader = source.GetReader();
+                        resSvc.ApplyResourcePackage(reader);
+                    else
+                        //No map, nothing to do here
+                        Application.Exit();
+            //Create our runtime map
+            MgdMap map = new MgdMap(mapDefId);
+            //Create our viewer provider
+            MgMapViewerProvider provider = new MgDesktopMapViewerProvider(map);
+            //Initialize our viewer with this provider
+            mgMapViewer1.Init(provider);
+        public void SetCursorPositionMessage(string message)
+            lblCoords.Text = message;
+        public void SetFeatureSelectedMessage(string message)
+            lblSelected.Text = message;
+        public void SetMapScaleMessage(string message)
+            lblScale.Text = message;
+        public void SetMapSizeMessage(string message)
+            lblSize.Text = message;
+        private void mgMapViewer1_SelectionChanged(object sender, EventArgs e)
+            MgSelectionBase selection = mgMapViewer1.GetSelection();
+            MgReadOnlyLayerCollection layers = selection.GetLayers();
+            if (layers != null)
+                for (int i = 0; i < layers.GetCount(); i++)
+                    MgLayerBase layer = layers.GetItem(i);
+                    if (layer.Name == "Parcels") //The selected layer is parcels
+                        //Check that we only have one selected object
+                        int count = selection.GetSelectedFeaturesCount(layer, layer.FeatureClassName);
+                        if (count == 1)
+                            MgFeatureReader reader = null;
+                            try
+                                reader = selection.GetSelectedFeatures(layer, layer.FeatureClassName, false);
+                                if (reader.ReadNext())
+                                    //Address is in the RPROPAD property
+                                    if (reader.IsNull("RPROPAD"))
+                                        MessageBox.Show("Selected parcel has no address");
+                                    else
+                                        MessageBox.Show("Address: " + reader.GetString("RPROPAD"));
+                            finally //Must close all readers, otherwise connections will leak
+                                reader.Close();
+                        else
+                            MessageBox.Show("Please select only one parcel");
+                        break;
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.resx
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.resx	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/MainForm.resx	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,126 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+  <metadata name="mgDefaultToolbar1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 17</value>
+  </metadata>
+  <metadata name="statusStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>174, 17</value>
+  </metadata>
+</root>
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Program.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Program.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,24 @@
+using System;
+using System.Linq;
+        /// <summary>
+        /// </summary>
+        [STAThread]
+            Application.Run(new MainForm());
Property changes on: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/AssemblyInfo.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,36 @@
+[assembly: AssemblyTitle("DesktopViewerTest")]
+[assembly: AssemblyProduct("DesktopViewerTest")]
+[assembly: Guid("65637a5a-6232-4741-910e-d57f120d5806")]
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Resources.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Resources.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Resources.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,71 @@
+namespace DesktopViewerTest.Properties
+    /// <summary>
+    /// </summary>
+        /// <summary>
+        /// </summary>
+            get
+                    global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("DesktopViewerTest.Properties.Resources", typeof(Resources).Assembly);
+        /// <summary>
+        /// </summary>
+            get
+            set
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Resources.resx
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Resources.resx	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Resources.resx	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,117 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+</root>
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Settings.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Settings.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Settings.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,30 @@
+            get
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Settings.settings
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Settings.settings	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/Properties/Settings.settings	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,7 @@
+  <Profiles>
+  </Profiles>
+  <Settings />
+</SettingsFile>
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/packages.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest/packages.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,7 @@
+<packages>
+  <package id="mg-desktop-viewer-net40-x86" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Property changes on: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,112 @@
+  <PropertyGroup>
+  </PropertyGroup>
+  </PropertyGroup>
+  </PropertyGroup>
+  <ItemGroup>
+    </Reference>
+    </Reference>
+    </Reference>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.Viewer">
+      <HintPath>..\packages\mg-desktop-viewer-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.dll</HintPath>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.Viewer.Desktop">
+      <HintPath>..\packages\mg-desktop-viewer-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.Desktop.dll</HintPath>
+    </Reference>
+  </ItemGroup>
+  <ItemGroup>
+    </Compile>
+    </Compile>
+    </Compile>
+    </None>
+    </Compile>
+  </ItemGroup>
+  <PropertyGroup>
+    <PostBuildEvent>
+  </PropertyGroup>
+  </Target>
+  </Target>
+</Project>
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,208 @@
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+            // statusStrip1
+            this.lblCoords,
+            this.lblSelected,
+            this.lblScale,
+            this.lblSize});
+            // lblCoords
+            // lblSelected
+            // lblScale
+            // lblSize
+            // mgLegend1
+            // mgMapViewer1
+            this.mgMapViewer1.ZoomInFactor = 0.5;
+            this.mgMapViewer1.ZoomOutFactor = 2;
+            // MainForm
+        #endregion
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,125 @@
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+        public MainForm()
+            MgResourceIdentifier mapDefId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
+                    else
+                        if (count == 1)
+                            try
+                                    else
+                                reader.Close();
+                        else
+                        break;
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,24 @@
+using System;
+using System.Linq;
+        /// <summary>
+        /// </summary>
+        [STAThread]
Property changes on: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,36 @@
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,71 @@
+    /// <summary>
+    /// </summary>
+        /// <summary>
+        /// </summary>
+            get
+        /// <summary>
+        /// </summary>
+            get
+            set
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,117 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+</root>
\ No newline at end of file
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,30 @@
+            get
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,7 @@
+  <Profiles>
+  </Profiles>
+  <Settings />
+</SettingsFile>
Added: trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,7 @@
+<packages>
+  <package id="mg-desktop-viewer-net40-x64" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Property changes on: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget
___________________________________________________________________
Added: bugtraq:number
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1 @@
+<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="Default.aspx.cs" Inherits="MapGuideNuget.Default" %>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,23 @@
+using System;
+using System.Linq;
+using System.Web;
+using System.Web.UI;
+using System.Web.UI.WebControls;
+namespace MapGuideNuget
+    public partial class Default : System.Web.UI.Page
+        protected void Page_Load(object sender, EventArgs e)
+            MgUserInformation user = new MgUserInformation("Anonymous", "");
+            MgSite site = new MgSite();
+            site.Open(user);
+            string sessionId = site.CreateSession();
+            string wl = "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
+            Response.Redirect("http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=" + wl + "&SESSION=" + sessionId);
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx.designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx.designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Default.aspx.designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,15 @@
+namespace MapGuideNuget {
+    public partial class Default {
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Global.asax
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Global.asax	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Global.asax	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1 @@
+<%@ Application Codebehind="Global.asax.cs" Inherits="MapGuideNuget.Global" Language="C#" %>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Global.asax.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Global.asax.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Global.asax.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,49 @@
+using System;
+using System.Linq;
+using System.Web;
+using System.Web.Security;
+using System.Web.SessionState;
+    public class Global : System.Web.HttpApplication
+        protected void Application_Start(object sender, EventArgs e)
+            MapGuideApi.MgInitializeWebTier(Server.MapPath("~/webconfig.ini"));
+        protected void Session_Start(object sender, EventArgs e)
+        protected void Application_BeginRequest(object sender, EventArgs e)
+        protected void Application_AuthenticateRequest(object sender, EventArgs e)
+        protected void Application_Error(object sender, EventArgs e)
+        protected void Session_End(object sender, EventArgs e)
+        protected void Application_End(object sender, EventArgs e)
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,140 @@
+  <Import Project="$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props" Condition="Exists('$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props')" />
+  <PropertyGroup>
+    <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+    <ProductVersion>
+    </ProductVersion>
+    <ProjectGuid>{A4665445-2B49-4808-BD7A-8A6B6AAF5237}</ProjectGuid>
+    <ProjectTypeGuids>{349c5851-65df-11da-9384-00065b846f21};{fae04ec0-301f-11d3-bf4b-00c04f79efbc}</ProjectTypeGuids>
+    <OutputType>Library</OutputType>
+    <RootNamespace>MapGuideNuget</RootNamespace>
+    <AssemblyName>MapGuideNuget</AssemblyName>
+    <UseIISExpress>false</UseIISExpress>
+    <IISExpressSSLPort />
+    <IISExpressAnonymousAuthentication />
+    <IISExpressWindowsAuthentication />
+    <IISExpressUseClassicPipelineMode />
+  </PropertyGroup>
+  <ItemGroup>
+    </Reference>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.MapGuideCommon">
+      <HintPath>..\packages\mapguide-api-web-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.MapGuideCommon.dll</HintPath>
+    </Reference>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.Web">
+      <HintPath>..\packages\mapguide-api-web-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Web.dll</HintPath>
+    </Reference>
+    <Reference Include="System.Web.DynamicData" />
+    <Reference Include="System.Web.Entity" />
+    <Reference Include="System.Web.ApplicationServices" />
+    <Reference Include="System.ComponentModel.DataAnnotations" />
+    <Reference Include="System.Core" />
+    <Reference Include="System.Web.Extensions" />
+    <Reference Include="System.Web" />
+    <Reference Include="System.Configuration" />
+    <Reference Include="System.Web.Services" />
+    <Reference Include="System.EnterpriseServices" />
+  </ItemGroup>
+  <ItemGroup>
+    <Content Include="Default.aspx" />
+    <Content Include="Global.asax" />
+    <Content Include="Web.config" />
+  </ItemGroup>
+  <ItemGroup>
+    <Compile Include="Default.aspx.cs">
+      <DependentUpon>Default.aspx</DependentUpon>
+      <SubType>ASPXCodeBehind</SubType>
+    </Compile>
+    <Compile Include="Default.aspx.designer.cs">
+    </Compile>
+    <Compile Include="Global.asax.cs">
+      <DependentUpon>Global.asax</DependentUpon>
+    </Compile>
+  </ItemGroup>
+  <ItemGroup>
+    <Content Include="packages.config" />
+    <None Include="Web.Debug.config">
+      <DependentUpon>Web.config</DependentUpon>
+    </None>
+    <None Include="Web.Release.config">
+    </None>
+    <Content Include="webconfig.ini" />
+  </ItemGroup>
+  <PropertyGroup>
+    <VisualStudioVersion Condition="'$(VisualStudioVersion)' == ''">10.0</VisualStudioVersion>
+    <VSToolsPath Condition="'$(VSToolsPath)' == ''">$(MSBuildExtensionsPath32)\Microsoft\VisualStudio\v$(VisualStudioVersion)</VSToolsPath>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x86'">
+    <DebugSymbols>true</DebugSymbols>
+    <OutputPath>bin\</OutputPath>
+    <DefineConstants>DEBUG;TRACE</DefineConstants>
+    <DebugType>full</DebugType>
+    <PlatformTarget>x86</PlatformTarget>
+    <ErrorReport>prompt</ErrorReport>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|x86'">
+    <DebugType>pdbonly</DebugType>
+  </PropertyGroup>
+  <Import Project="$(MSBuildBinPath)\Microsoft.CSharp.targets" />
+  <Import Project="$(VSToolsPath)\WebApplications\Microsoft.WebApplication.targets" Condition="'$(VSToolsPath)' != ''" />
+  <Import Project="$(MSBuildExtensionsPath32)\Microsoft\VisualStudio\v10.0\WebApplications\Microsoft.WebApplication.targets" Condition="false" />
+  <ProjectExtensions>
+    <VisualStudio>
+      <FlavorProperties GUID="{349c5851-65df-11da-9384-00065b846f21}">
+        <WebProjectProperties>
+          <UseIIS>True</UseIIS>
+          <AutoAssignPort>True</AutoAssignPort>
+          <DevelopmentServerPort>58686</DevelopmentServerPort>
+          <DevelopmentServerVPath>/</DevelopmentServerVPath>
+          <IISUrl>http://localhost/MapGuideNuget</IISUrl>
+          <NTLMAuthentication>False</NTLMAuthentication>
+          <UseCustomServer>False</UseCustomServer>
+          <CustomServerUrl>
+          </CustomServerUrl>
+          <SaveServerSettingsInUserFile>False</SaveServerSettingsInUserFile>
+        </WebProjectProperties>
+      </FlavorProperties>
+    </VisualStudio>
+  </ProjectExtensions>
+  <PropertyGroup>
+    <PostBuildEvent>
+xcopy /s /y "$(SolutionDir)packages\mapguide-api-web-x86.2.4.0.7093\mapguide-api-web\*.*" "$(TargetDir)"</PostBuildEvent>
+  </PropertyGroup>
+  </Target>
+  </Target>
+</Project>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj.user
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj.user	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj.user	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,28 @@
+<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+    <VisualStudio>
+          <StartPageUrl>
+          </StartPageUrl>
+          <StartAction>CurrentPage</StartAction>
+          <AspNetDebugging>True</AspNetDebugging>
+          <SilverlightDebugging>False</SilverlightDebugging>
+          <NativeDebugging>False</NativeDebugging>
+          <SQLDebugging>False</SQLDebugging>
+          <ExternalProgram>
+          </ExternalProgram>
+          <StartExternalURL>
+          </StartExternalURL>
+          <StartCmdLineArguments>
+          </StartCmdLineArguments>
+          <StartWorkingDirectory>
+          </StartWorkingDirectory>
+          <EnableENC>False</EnableENC>
+          <AlwaysStartWebServerOnDebug>True</AlwaysStartWebServerOnDebug>
+    </VisualStudio>
+</Project>
Property changes on: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Properties
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Properties/AssemblyInfo.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,35 @@
+[assembly: AssemblyTitle("MapGuideNuget")]
+[assembly: AssemblyProduct("MapGuideNuget")]
+[assembly: Guid("43a5bb36-748c-4637-8a4e-386ed3a7aa82")]
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
+// You can specify all the values or you can default the Revision and Build Numbers
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.Debug.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.Debug.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.Debug.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,30 @@
+<!-- For more information on using web.config transformation visit http://go.microsoft.com/fwlink/?LinkId=125889 -->
+<configuration xmlns:xdt="http://schemas.microsoft.com/XML-Document-Transform">
+    In the example below, the "SetAttributes" transform will change the value of
+    "connectionString" to use "ReleaseSQLServer" only when the "Match" locator
+    finds an attribute "name" that has a value of "MyDB".
+    <connectionStrings>
+      <add name="MyDB"
+        connectionString="Data Source=ReleaseSQLServer;Initial Catalog=MyReleaseDB;Integrated Security=True"
+        xdt:Transform="SetAttributes" xdt:Locator="Match(name)"/>
+    </connectionStrings>
+  <system.web>
+      In the example below, the "Replace" transform will replace the entire
+      <customErrors> section of your web.config file.
+      Note that because there is only one customErrors section under the
+      <system.web> node, there is no need to use the "xdt:Locator" attribute.
+      <customErrors defaultRedirect="GenericError.htm"
+        mode="RemoteOnly" xdt:Transform="Replace">
+        <error statusCode="500" redirect="InternalError.htm"/>
+      </customErrors>
+  </system.web>
+</configuration>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.Release.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.Release.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.Release.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,31 @@
+      <add name="MyDB"
+  <system.web>
+    <compilation xdt:Transform="RemoveAttributes(debug)" />
+      </customErrors>
+  </system.web>
+</configuration>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/Web.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,13 @@
+<?xml version="1.0"?>
+  For more information on how to configure your ASP.NET application, please visit
+  http://go.microsoft.com/fwlink/?LinkId=169433
+<configuration>
+    <system.web>
+      <compilation debug="true" targetFramework="4.0" />
+    </system.web>
+</configuration>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/packages.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/packages.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,5 @@
+<packages>
+  <package id="mapguide-api-base-x86" version="2.4.0.7093" targetFramework="net40" />
+  <package id="mapguide-api-web-x86" version="2.4.0.7093" targetFramework="net40" />
+</packages>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/webconfig.ini
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/webconfig.ini	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget/webconfig.ini	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,198 @@
+# MapGuide Web Configuration File
+# WARNING: BE VERY CAREFUL WHEN MODIFYING THIS FILE AS IT COULD
+#          ADVERSLY IMPACT SERVER PERFORMANCE
+# COMMON VALIDATION INFORMATION
+# (Unless otherwise noted under the property description)
+# String Property                  Range of String Length   Reserved Characters
+# File Name                        0 <  Length <= 128       \/:*?"<>|
+# Folder Name                      0 <  Length <= 128       \/:*?"<>|
+# Log Parameters                   0 <= Length <= 1024
+# Password                         0 <= Length <= 64        \t\r\n\v\f
+# Path                             0 <  Length <= 255       *?"<>|
+# Numeric Property                 Range of Numeric Value
+# Port Number                      0 <= Value <= 65535
+[GeneralProperties]
+# G E N E R A L
+# Property Name                    Description
+# DefaultMessageLocale             ISO 639-1 name for the message locale
+#                                       Length = 2
+#                                       Example: en
+#                                  or
+#                                       Length = 5
+#                                       Example: en-US
+#                                  WARNING: if a 5 character locale is specified
+#                                           the first 2 characters must be lower
+#                                           case and the last 2 characters must
+#                                           be upper case.
+# LogsPath                         Path where log files are stored
+# MentorDictionaryPath             The path where the CS-Map Coordinate System Dictionaries are installed
+# ResourcesPath                    Path where the localization resource files are stored
+# TcpIpMtu                         The TCP/IP maximum transmission unit
+#                                       0 < Value <= 65535
+# TempPath                         Path where the temporary files are stored
+# FailoverRetryTime                Time in seconds for when to retry connecting
+#                                  to a MapGuide server that has gone offline.
+#                                  Note: For a single Web Tier and MapGuide server
+#                                        pair use 1. For a load balanced
+#                                        configuration with multiple MapGuide
+#                                        servers use 60. Values other than 1 will
+#                                        cause a delay when re-establishing a
+#                                        connection with the Web Tier after
+#                                        restarting a MapGuide server.
+DefaultMessageLocale               = en
+LogsPath                           = Logs/
+MentorDictionaryPath               =C:\Program Files\OSGeo\MapGuide\CS-Map\Dictionaries\
+ResourcesPath                      =C:\Program Files\OSGeo\MapGuide\Web\www\mapagent\Resources
+TcpIpMtu                           = 1460
+TempPath                           =C:\Program Files\OSGeo\MapGuide\Web\Temp\
+FailoverRetryTime                  = 1
+[AdministrativeConnectionProperties]
+# A D M I N I S T R A T I V E  C O N N E C T I O N
+# MaxConnections                   The maximum allowed concurrent connections for this port.
+#                                  Default value of 2 is for a typical load when the web
+#                                  is connected to a quad core server machine.
+# Port                             The port to use for administration operations
+#                                  WARNING: If you change the port # here you
+#                                           must also change the corresponding
+#                                           port # for the server configuration
+#                                           file.
+MaxConnections                     = 2
+Port                               =2810
+[ClientConnectionProperties]
+# C L I E N T  C O N N E C T I O N
+#                                  Default value of 12 is for a typical load when the web
+# Port                             The port to use for client operations
+#                                           file.
+MaxConnections                     = 12
+Port                               =2811
+[SiteConnectionProperties]
+# S I T E  C O N N E C T I O N
+# IpAddress                        The IP address of the site server
+#                                       0 < Length <= 255
+#                                  Default value of 6 is for a typical load when the web
+# Port                             The port to use for site operations
+#                                           file.
+IpAddress                          =127.0.0.1
+MaxConnections                     = 6
+Port                               =2812
+[AgentProperties]
+# M A P  A G E N T
+# DebugPause                       Number of seconds the agent pauses before
+#                                  each request, for debugging purpose
+#                                       0 <= Value <= 86400
+# DisableAuthoring                 Disables Authoring HTTP requests
+#                                       0 = false and 1 = true
+# DisableWfs                       Disables OGC Wfs HTTP requests
+# DisableWms                       Disables OGC Wms HTTP requests
+# ErrorLogEnabled                  0 = log disabled, 1 = log enabled
+# ErrorLogFilename                 Name of the log file
+# RequestLogEnabled                0 = log disabled, 1 = log enabled
+# RequestLogFilename               Name of the log file
+DebugPause                         = 0
+DisableAuthoring                   = 0
+DisableWfs                         = 0
+DisableWms                         = 0
+ErrorLogEnabled                    = 0
+ErrorLogFilename                   = Error.log
+RequestLogEnabled                  = 0
+RequestLogFilename                 = Request.log
+[OgcProperties]
+# O G C  S E T T I N G S
+# WfsPassword                      Password to be used for credentials in WFS
+#                                  requests
+# WmsPassword                      Password to be used for credentials in WMS
+#                                  requests
+# CITEWfsEnabled                   Enable OGC CITE Test for WFS
+#                                  Consider unknown requests as OGC Wfs HTTP requests
+# CITEWmsEnabled                   Enable OGC CITE Test for WMS
+#                                  Consider unknown requests as OGC Wms HTTP requests
+WfsPassword                        = wfs
+WmsPassword                        = wms
+CITEWfsEnabled                     = 0
+CITEWmsEnabled                     = 0
+[WebApplicationProperties]
+# W E B   A P P L I C A T I O N   S E T T I N G S
+# TemplateRootFolder               The root folder containing the viewer
+#                                  templates
+# WidgetInfoFolder                 The folder containing widget info files
+# ContainerInfoFolder              The folder containing container info files
+TemplateRootFolder                 =C:\Program Files\OSGeo\MapGuide\Web\www\fusion\templates\mapguide
+WidgetInfoFolder                   =C:\Program Files\OSGeo\MapGuide\Web\www\fusion\widgets\widgetinfo
+ContainerInfoFolder                =C:\Program Files\OSGeo\MapGuide\Web\www\fusion\containerinfo
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,32 @@
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio Express 2012 for Windows Desktop
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "CoordSysEnumTest", "CoordSysEnumTest\CoordSysEnumTest.csproj", "{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopConsoleTest", "DesktopConsoleTest\DesktopConsoleTest.csproj", "{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopViewerTest", "DesktopViewerTest\DesktopViewerTest.csproj", "{A0DCC768-B341-426B-889A-0701A2399CE8}"
+EndProject
+Global
+	GlobalSection(SolutionConfigurationPlatforms) = preSolution
+		Debug|x86 = Debug|x86
+		Release|x86 = Release|x86
+	EndGlobalSection
+	GlobalSection(ProjectConfigurationPlatforms) = postSolution
+		{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x86.ActiveCfg = Debug|x86
+		{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x86.Build.0 = Debug|x86
+		{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x86.ActiveCfg = Release|x86
+		{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x86.Build.0 = Release|x86
+		{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x86.ActiveCfg = Debug|x86
+		{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x86.Build.0 = Debug|x86
+		{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x86.ActiveCfg = Release|x86
+		{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x86.Build.0 = Release|x86
+		{A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x86.ActiveCfg = Debug|x86
+		{A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x86.Build.0 = Debug|x86
+		{A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x86.ActiveCfg = Release|x86
+		{A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x86.Build.0 = Release|x86
+	EndGlobalSection
+	GlobalSection(SolutionProperties) = preSolution
+		HideSolutionNode = FALSE
+	EndGlobalSection
+EndGlobal
Property changes on: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1 @@
+<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="Default.aspx.cs" Inherits="MapGuideNuget.Default" Trace="true" %>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,50 @@
+using OSGeo.MapGuide;
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Web;
+            site.Open(user);
+            user.SetMgSessionId(sessionId);
+            MgSiteConnection siteConn = new MgSiteConnection();
+            siteConn.Open(user);
+            MgResourceIdentifier mdfId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
+            System.Diagnostics.Stopwatch sw = new System.Diagnostics.Stopwatch();
+            sw.Start();
+            MgMap map1 = new MgMap(siteConn);
+            map1.Create(mdfId, "ColdStart");
+            sw.Stop();
+            Trace.Write("ColdStart - " + sw.ElapsedMilliseconds + "ms");
+            sw.Reset();
+            sw.Start();
+            MgMap map2 = new MgMap(siteConn);
+            map2.Create(mdfId, "WarmStart");
+            sw.Stop();
+            Trace.Write("WarmStart - " + sw.ElapsedMilliseconds + "ms");
+            sw.Start();
+            MgMap map3 = new MgMap(siteConn);
+            map3.Create(mdfId, "WarmStart2");
+            sw.Stop();
+            Trace.Write("WarmStart2 - " + sw.ElapsedMilliseconds + "ms");
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,15 @@
+// <auto-generated>
+//     This code was generated by a tool.
+//     Changes to this file may cause incorrect behavior and will be lost if
+//     the code is regenerated.
+// </auto-generated>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1 @@
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,49 @@
+using System;
+using System.Linq;
+using System.Web;
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,143 @@
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+  <PropertyGroup>
+    <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+    <ProductVersion>
+    </ProductVersion>
+    <SchemaVersion>2.0</SchemaVersion>
+    <AppDesignerFolder>Properties</AppDesignerFolder>
+    <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
+  </PropertyGroup>
+  <ItemGroup>
+    <Reference Include="Microsoft.CSharp" />
+    <Reference Include="OSGeo.MapGuide.Foundation">
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.Geometry">
+    </Reference>
+      <HintPath>..\packages\mapguide-api-web-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.MapGuideCommon.dll</HintPath>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.PlatformBase">
+    </Reference>
+      <HintPath>..\packages\mapguide-api-web-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Web.dll</HintPath>
+    </Reference>
+    <Reference Include="System" />
+    <Reference Include="System.Data" />
+    <Reference Include="System.Data.DataSetExtensions" />
+    <Reference Include="System.Xml.Linq" />
+    <Reference Include="System.Drawing" />
+    <Reference Include="System.Xml" />
+  </ItemGroup>
+  <ItemGroup>
+  </ItemGroup>
+  <ItemGroup>
+    </Compile>
+    </Compile>
+    </Compile>
+    <Compile Include="Properties\AssemblyInfo.cs" />
+  </ItemGroup>
+  <ItemGroup>
+    </None>
+    </None>
+  </ItemGroup>
+  <PropertyGroup>
+  </PropertyGroup>
+  </PropertyGroup>
+    <DefineConstants>TRACE</DefineConstants>
+    <Optimize>true</Optimize>
+  </PropertyGroup>
+    <VisualStudio>
+          <IISUrl>http://localhost/MapGuideNuget64</IISUrl>
+          <CustomServerUrl>
+    </VisualStudio>
+  <PropertyGroup>
+    <PostBuildEvent>
+xcopy /s /y "$(SolutionDir)packages\mapguide-api-web-x64.2.4.0.7093\mapguide-api-web\*.*" "$(TargetDir)"</PostBuildEvent>
+  </PropertyGroup>
+  <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+       Other similar extension points exist, see Microsoft.Common.targets.
+  <Target Name="BeforeBuild">
+  </Target>
+  <Target Name="AfterBuild">
+  </Target>
+</Project>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,28 @@
+    <VisualStudio>
+          <StartPageUrl>
+          </StartPageUrl>
+          <ExternalProgram>
+    </VisualStudio>
+</Project>
Property changes on: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties
   + true
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,35 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyCopyright("Copyright ©  2012")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components.  If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+// Version information for an assembly consists of the following four values:
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
+// by using the '*' as shown below:
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,30 @@
+      <add name="MyDB"
+  <system.web>
+      </customErrors>
+  </system.web>
+</configuration>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,31 @@
+      <add name="MyDB"
+  <system.web>
+      </customErrors>
+  </system.web>
+</configuration>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,13 @@
+<configuration>
+    <system.web>
+    </system.web>
+</configuration>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,5 @@
+<packages>
+  <package id="mapguide-api-base-x64" version="2.4.0.7093" targetFramework="net40" />
+  <package id="mapguide-api-web-x64" version="2.4.0.7093" targetFramework="net40" />
+</packages>
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,198 @@
+# G E N E R A L
+#                                       Length = 2
+#                                       Example: en
+#                                  or
+#                                       Length = 5
+#                                       Example: en-US
+#                                           be upper case.
+LogsPath                           = Logs/
+TcpIpMtu                           = 1460
+#                                           file.
+MaxConnections                     = 2
+Port                               =2810
+#                                           file.
+Port                               =2811
+#                                           file.
+MaxConnections                     = 6
+Port                               =2812
+[AgentProperties]
+# M A P  A G E N T
+DebugPause                         = 0
+DisableWfs                         = 0
+DisableWms                         = 0
+[OgcProperties]
+#                                  requests
+#                                  requests
+WfsPassword                        = wfs
+WmsPassword                        = wms
+CITEWfsEnabled                     = 0
+CITEWmsEnabled                     = 0
+#                                  templates
Added: trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,39 @@
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "CoordSysEnumTest", "CoordSysEnumTest64\CoordSysEnumTest.csproj", "{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopConsoleTest", "DesktopConsoleTest64\DesktopConsoleTest.csproj", "{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopViewerTest", "DesktopViewerTest64\DesktopViewerTest.csproj", "{A0DCC768-B341-426B-889A-0701A2399CE8}"
+EndProject
+Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = ".nuget", ".nuget", "{A4AD55B7-4C81-4238-846D-F78A67B138B8}"
+	ProjectSection(SolutionItems) = preProject
+		.nuget\NuGet.Config = .nuget\NuGet.Config
+		.nuget\NuGet.exe = .nuget\NuGet.exe
+		.nuget\NuGet.targets = .nuget\NuGet.targets
+	EndProjectSection
+EndProject
+Global
+		Debug|x64 = Debug|x64
+		Release|x64 = Release|x64
+	EndGlobalSection
+		{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x64.ActiveCfg = Debug|x64
+		{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x64.Build.0 = Debug|x64
+		{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x64.ActiveCfg = Release|x64
+		{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x64.Build.0 = Release|x64
+		{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x64.ActiveCfg = Debug|x64
+		{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x64.Build.0 = Debug|x64
+		{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x64.ActiveCfg = Release|x64
+		{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x64.Build.0 = Release|x64
+		{A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x64.ActiveCfg = Debug|x64
+		{A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x64.Build.0 = Debug|x64
+		{A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x64.ActiveCfg = Release|x64
+		{A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x64.Build.0 = Release|x64
+	EndGlobalSection
+	EndGlobalSection
+EndGlobal
Added: trunk/MgDev/nuget/MapGuideNuget/Web.sln
--- trunk/MgDev/nuget/MapGuideNuget/Web.sln	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/Web.sln	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,20 @@
+# Visual Studio Express 2012 for Web
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MapGuideNuget", "MapGuideNuget\MapGuideNuget.csproj", "{A4665445-2B49-4808-BD7A-8A6B6AAF5237}"
+EndProject
+Global
+	EndGlobalSection
+		{A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x86.ActiveCfg = Debug|x86
+		{A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x86.Build.0 = Debug|x86
+		{A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x86.ActiveCfg = Release|x86
+		{A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x86.Build.0 = Release|x86
+	EndGlobalSection
+	EndGlobalSection
+EndGlobal
Added: trunk/MgDev/nuget/MapGuideNuget/Web64.sln
--- trunk/MgDev/nuget/MapGuideNuget/Web64.sln	                        (rev 0)
+++ trunk/MgDev/nuget/MapGuideNuget/Web64.sln	2013-01-13 12:26:06 UTC (rev 7310)
@@ -0,0 +1,20 @@
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MapGuideNuget", "MapGuideNuget64\MapGuideNuget.csproj", "{A4665445-2B49-4808-BD7A-8A6B6AAF5237}"
+EndProject
+Global
+	EndGlobalSection
+		{A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x64.ActiveCfg = Debug|x64
+		{A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x64.Build.0 = Debug|x64
+		{A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x64.ActiveCfg = Release|x64
+		{A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x64.Build.0 = Release|x64
+	EndGlobalSection
+	EndGlobalSection
+EndGlobal
More information about the mapguide-commits mailing list
