[mapguide-commits] r7317 - branches/2.5/MgDev/Oem/gd/jpeg
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Jan 17 23:50:24 PST 2013
Author: jng
Date: 2013-01-17 23:50:24 -0800 (Thu, 17 Jan 2013)
New Revision: 7317
   branches/2.5/MgDev/Oem/gd/jpeg/config.guess
   branches/2.5/MgDev/Oem/gd/jpeg/config.sub
#1657: Update config.guess and config.sub with the copies from MgDev root. The configure script had no clue about this system with the existing files
Modified: branches/2.5/MgDev/Oem/gd/jpeg/config.guess
--- branches/2.5/MgDev/Oem/gd/jpeg/config.guess	2013-01-18 01:37:22 UTC (rev 7316)
+++ branches/2.5/MgDev/Oem/gd/jpeg/config.guess	2013-01-18 07:50:24 UTC (rev 7317)
@@ -1,7 +1,10 @@
 #! /bin/sh
 # Attempt to guess a canonical system name.
-#   Copyright (C) 1992, 93, 94, 95, 96, 1997 Free Software Foundation, Inc.
+#   Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
+#   2000, 2001, 2002, 2003, 2004, 2005 Free Software Foundation, Inc.
+timestamp='2005-09-19'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
 # the Free Software Foundation; either version 2 of the License, or
@@ -14,154 +17,323 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# Foundation, Inc., 51 Franklin Street - Fifth Floor, Boston, MA
+# 02110-1301, USA.
 # As a special exception to the GNU General Public License, if you
 # distribute this file as part of a program that contains a
 # configuration script generated by Autoconf, you may include it under
 # the same distribution terms that you use for the rest of that program.
-# Written by Per Bothner <bothner at cygnus.com>.
-# The master version of this file is at the FSF in /home/gd/gnu/lib.
+# Originally written by Per Bothner <per at bothner.com>.
+# Please send patches to <config-patches at gnu.org>.  Submit a context
+# diff and a properly formatted ChangeLog entry.
 # This script attempts to guess a canonical system name similar to
 # config.sub.  If it succeeds, it prints the system name on stdout, and
 # exits with 0.  Otherwise, it exits with 1.
 # The plan is that this can be called by configure scripts if you
-# don't specify an explicit system type (host/target name).
-# Only a few systems have been added to this list; please add others
-# (but try to keep the structure clean).
+# don't specify an explicit build system type.
+me=`echo "$0" | sed -e 's,.*/,,'`
+usage="\
+Usage: $0 [OPTION]
+Output the configuration name of the system \`$me' is run on.
+Operation modes:
+  -h, --help         print this help, then exit
+  -t, --time-stamp   print date of last modification, then exit
+  -v, --version      print version number, then exit
+Report bugs and patches to <config-patches at gnu.org>."
+version="\
+GNU config.guess ($timestamp)
+Originally written by Per Bothner.
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005
+Free Software Foundation, Inc.
+This is free software; see the source for copying conditions.  There is NO
+warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
+help="
+Try \`$me --help' for more information."
+# Parse command line
+while test $# -gt 0 ; do
+  case $1 in
+    --time-stamp | --time* | -t )
+       echo "$timestamp" ; exit ;;
+    --version | -v )
+       echo "$version" ; exit ;;
+    --help | --h* | -h )
+       echo "$usage"; exit ;;
+    -- )     # Stop option processing
+       shift; break ;;
+    - )	# Use stdin as input.
+       break ;;
+       echo "$me: invalid option $1$help" >&2
+       exit 1 ;;
+       break ;;
+  esac
+done
+if test $# != 0; then
+  echo "$me: too many arguments$help" >&2
+  exit 1
+fi
+trap 'exit 1' 1 2 15
+# CC_FOR_BUILD -- compiler used by this script. Note that the use of a
+# compiler to aid in system detection is discouraged as it requires
+# temporary files to be created and, as you can see below, it is a
+# headache to deal with in a portable fashion.
+# Historically, `CC_FOR_BUILD' used to be named `HOST_CC'. We still
+# use `HOST_CC' if defined, but it is deprecated.
+# Portable tmp directory creation inspired by the Autoconf team.
+set_cc_for_build='
+trap "exitcode=\$?; (rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null) && exit \$exitcode" 0 ;
+trap "rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null; exit 1" 1 2 13 15 ;
+: ${TMPDIR=/tmp} ;
+ { tmp=`(umask 077 && mktemp -d -q "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
+ { test -n "$RANDOM" && tmp=$TMPDIR/cg$$-$RANDOM && (umask 077 && mkdir $tmp) ; } ||
+ { tmp=$TMPDIR/cg-$$ && (umask 077 && mkdir $tmp) && echo "Warning: creating insecure temp directory" >&2 ; } ||
+ { echo "$me: cannot create a temporary directory in $TMPDIR" >&2 ; exit 1 ; } ;
+dummy=$tmp/dummy ;
+tmpfiles="$dummy.c $dummy.o $dummy.rel $dummy" ;
+case $CC_FOR_BUILD,$HOST_CC,$CC in
+ ,,)    echo "int x;" > $dummy.c ;
+	for c in cc gcc c89 c99 ; do
+	  if ($c -c -o $dummy.o $dummy.c) >/dev/null 2>&1 ; then
+	     CC_FOR_BUILD="$c"; break ;
+	  fi ;
+	done ;
+	if test x"$CC_FOR_BUILD" = x ; then
+	  CC_FOR_BUILD=no_compiler_found ;
+	fi
+ ,,*)   CC_FOR_BUILD=$CC ;;
+ ,*,*)  CC_FOR_BUILD=$HOST_CC ;;
+esac ; set_cc_for_build= ;'
 # This is needed to find uname on a Pyramid OSx when run in the BSD universe.
-# (ghazi at noc.rutgers.edu 8/24/94.)
+# (ghazi at noc.rutgers.edu 1994-08-24)
 if (test -f /.attbin/uname) >/dev/null 2>&1 ; then
 	PATH=$PATH:/.attbin ; export PATH
 fi
 UNAME_MACHINE=`(uname -m) 2>/dev/null` || UNAME_MACHINE=unknown
 UNAME_RELEASE=`(uname -r) 2>/dev/null` || UNAME_RELEASE=unknown
-UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
+UNAME_SYSTEM=`(uname -s) 2>/dev/null`  || UNAME_SYSTEM=unknown
 UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
-trap 'rm -f dummy.c dummy.o dummy; exit 1' 1 2 15
 # Note: order is significant - the case branches are not exclusive.
 case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
+    *:NetBSD:*:*)
+	# NetBSD (nbsd) targets should (where applicable) match one or
+	# more of the tupples: *-*-netbsdelf*, *-*-netbsdaout*,
+	# *-*-netbsdecoff* and *-*-netbsd*.  For targets that recently
+	# switched to ELF, *-*-netbsd* would select the old
+	# object file format.  This provides both forward
+	# compatibility and a consistent mechanism for selecting the
+	# Note: NetBSD doesn't particularly care about the vendor
+	# portion of the name.  We always set it to "unknown".
+	sysctl="sysctl -n hw.machine_arch"
+	UNAME_MACHINE_ARCH=`(/sbin/$sysctl 2>/dev/null || \
+	    /usr/sbin/$sysctl 2>/dev/null || echo unknown)`
+	case "${UNAME_MACHINE_ARCH}" in
+	    armeb) machine=armeb-unknown ;;
+	    arm*) machine=arm-unknown ;;
+	    sh3el) machine=shl-unknown ;;
+	    sh3eb) machine=sh-unknown ;;
+	    *) machine=${UNAME_MACHINE_ARCH}-unknown ;;
+	esac
+	# The Operating System including object format, if it has switched
+	# to ELF recently, or will in the future.
+	    arm*|i386|m68k|ns32k|sh3*|sparc|vax)
+		eval $set_cc_for_build
+		if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
+			| grep __ELF__ >/dev/null
+		then
+		    # Once all utilities can be ECOFF (netbsdecoff) or a.out (netbsdaout).
+		    # Return netbsd for either.  FIX?
+		    os=netbsd
+		else
+		    os=netbsdelf
+		fi
+	        os=netbsd
+	esac
+	# The OS release
+	# Debian GNU/NetBSD machines have a different userland, and
+	# thus, need a distinct triplet. However, they do not need
+	# kernel version information, so it can be replaced with a
+	# suitable tag, in the style of linux-gnu.
+	case "${UNAME_VERSION}" in
+	    Debian*)
+		release='-gnu'
+		release=`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
+	esac
+	# Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
+	# contains redundant information, the shorter form:
+	# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
+	echo "${machine}-${os}${release}"
+	exit ;;
+    *:OpenBSD:*:*)
+	UNAME_MACHINE_ARCH=`arch | sed 's/OpenBSD.//'`
+	echo ${UNAME_MACHINE_ARCH}-unknown-openbsd${UNAME_RELEASE}
+	exit ;;
+    *:ekkoBSD:*:*)
+	echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
+	exit ;;
+    macppc:MirBSD:*:*)
+	echo powerppc-unknown-mirbsd${UNAME_RELEASE}
+	exit ;;
+    *:MirBSD:*:*)
+	echo ${UNAME_MACHINE}-unknown-mirbsd${UNAME_RELEASE}
+	exit ;;
     alpha:OSF1:*:*)
-	if test $UNAME_RELEASE = "V4.0"; then
+	case $UNAME_RELEASE in
+	*4.0)
 		UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $3}'`
-	fi
+	*5.*)
+	        UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $4}'`
+	esac
+	# According to Compaq, /usr/sbin/psrinfo has been available on
+	# OSF/1 and Tru64 systems produced since 1995.  I hope that
+	# covers most systems running today.  This code pipes the CPU
+	# types through head -n 1, so we only detect the type of CPU 0.
+	ALPHA_CPU_TYPE=`/usr/sbin/psrinfo -v | sed -n -e 's/^  The alpha \(.*\) processor.*$/\1/p' | head -n 1`
+	case "$ALPHA_CPU_TYPE" in
+	    "EV4 (21064)")
+		UNAME_MACHINE="alpha" ;;
+	    "EV4.5 (21064)")
+	    "LCA4 (21066/21068)")
+	    "EV5 (21164)")
+		UNAME_MACHINE="alphaev5" ;;
+	    "EV5.6 (21164A)")
+		UNAME_MACHINE="alphaev56" ;;
+	    "EV5.6 (21164PC)")
+		UNAME_MACHINE="alphapca56" ;;
+	    "EV5.7 (21164PC)")
+		UNAME_MACHINE="alphapca57" ;;
+	    "EV6 (21264)")
+		UNAME_MACHINE="alphaev6" ;;
+	    "EV6.7 (21264A)")
+		UNAME_MACHINE="alphaev67" ;;
+	    "EV6.8CB (21264C)")
+		UNAME_MACHINE="alphaev68" ;;
+	    "EV6.8AL (21264B)")
+	    "EV6.8CX (21264D)")
+	    "EV6.9A (21264/EV69A)")
+		UNAME_MACHINE="alphaev69" ;;
+	    "EV7 (21364)")
+		UNAME_MACHINE="alphaev7" ;;
+	    "EV7.9 (21364A)")
+		UNAME_MACHINE="alphaev79" ;;
+	esac
+	# A Pn.n version is a patched version.
 	# A Vn.n version is a released version.
 	# A Tn.n version is a released field test version.
 	# A Xn.n version is an unreleased experimental baselevel.
 	# 1.2 uses "1.2" for uname -r.
-	cat <<EOF >dummy.s
-	.globl main
-	.ent main
-main:
-	.frame \$30,0,\$26,0
-	.prologue 0
-	.long 0x47e03d80 # implver $0
-	lda \$2,259
-	.long 0x47e20c21 # amask $2,$1
-	srl \$1,8,\$2
-	sll \$2,2,\$2
-	sll \$0,3,\$0
-	addl \$1,\$0,\$0
-	addl \$2,\$0,\$0
-	ret \$31,(\$26),1
-	.end main
-EOF
-	${CC-cc} dummy.s -o dummy 2>/dev/null
-	if test "$?" = 0 ; then
-		./dummy
-		case "$?" in
-			7)
-				UNAME_MACHINE="alpha"
-			15)
-				UNAME_MACHINE="alphaev5"
-			14)
-				UNAME_MACHINE="alphaev56"
-			10)
-				UNAME_MACHINE="alphapca56"
-			16)
-				UNAME_MACHINE="alphaev6"
-		esac
-	fi
-	rm -f dummy.s dummy
-	echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[VTX]//' | tr [[A-Z]] [[a-z]]`
-	exit 0 ;;
+	echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[PVTX]//' | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
+	exit ;;
+    Alpha\ *:Windows_NT*:*)
+	# How do we know it's Interix rather than the generic POSIX subsystem?
+	# Should we change UNAME_MACHINE based on the output of uname instead
+	# of the specific Alpha model?
+	echo alpha-pc-interix
+	exit ;;
     21064:Windows_NT:50:3)
 	echo alpha-dec-winnt3.5
-	exit 0 ;;
+	exit ;;
     Amiga*:UNIX_System_V:4.0:*)
-	echo m68k-cbm-sysv4
-	exit 0;;
-    amiga:NetBSD:*:*)
-      echo m68k-cbm-netbsd${UNAME_RELEASE}
-      exit 0 ;;
-    amiga:OpenBSD:*:*)
-	echo m68k-unknown-openbsd${UNAME_RELEASE}
-	exit 0 ;;
-    arc64:OpenBSD:*:*)
-	echo mips64el-unknown-openbsd${UNAME_RELEASE}
-	exit 0 ;;
-    arc:OpenBSD:*:*)
-	echo mipsel-unknown-openbsd${UNAME_RELEASE}
-	exit 0 ;;
-    hkmips:OpenBSD:*:*)
-	echo mips-unknown-openbsd${UNAME_RELEASE}
-	exit 0 ;;
-    pmax:OpenBSD:*:*)
-	exit 0 ;;
-    sgi:OpenBSD:*:*)
-	exit 0 ;;
-    wgrisc:OpenBSD:*:*)
-	exit 0 ;;
+	echo m68k-unknown-sysv4
+	exit ;;
+    *:[Aa]miga[Oo][Ss]:*:*)
+	echo ${UNAME_MACHINE}-unknown-amigaos
+	exit ;;
+    *:[Mm]orph[Oo][Ss]:*:*)
+	echo ${UNAME_MACHINE}-unknown-morphos
+	exit ;;
+    *:OS/390:*:*)
+	echo i370-ibm-openedition
+	exit ;;
+    *:z/VM:*:*)
+	echo s390-ibm-zvmoe
+	exit ;;
+    *:OS400:*:*)
+        echo powerpc-ibm-os400
+	exit ;;
     arm:RISC*:1.[012]*:*|arm:riscix:1.[012]*:*)
 	echo arm-acorn-riscix${UNAME_RELEASE}
-	exit 0;;
-    arm32:NetBSD:*:*)
-	echo arm-unknown-netbsd`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
-	exit 0 ;;
-    SR2?01:HI-UX/MPP:*:*)
+	exit ;;
+    arm:riscos:*:*|arm:RISCOS:*:*)
+	echo arm-unknown-riscos
+	exit ;;
+    SR2?01:HI-UX/MPP:*:* | SR8000:HI-UX/MPP:*:*)
 	echo hppa1.1-hitachi-hiuxmpp
-	exit 0;;
-    Pyramid*:OSx*:*:*|MIS*:OSx*:*:*)
+	exit ;;
+    Pyramid*:OSx*:*:* | MIS*:OSx*:*:* | MIS*:SMP_DC-OSx*:*:*)
 	# akee at wpdis03.wpafb.af.mil (Earle F. Ake) contributed MIS and NILE.
 	if test "`(/bin/universe) 2>/dev/null`" = att ; then
 		echo pyramid-pyramid-sysv3
 	else
 		echo pyramid-pyramid-bsd
 	fi
-	exit 0 ;;
-    NILE:*:*:dcosx)
+	exit ;;
+    NILE*:*:*:dcosx)
 	echo pyramid-pyramid-svr4
-	exit 0 ;;
+	exit ;;
+    DRS?6000:unix:4.0:6*)
+	echo sparc-icl-nx6
+	exit ;;
+    DRS?6000:UNIX_SV:4.2*:7* | DRS?6000:isis:4.2*:7*)
+	case `/usr/bin/uname -p` in
+	    sparc) echo sparc-icl-nx7; exit ;;
+	esac ;;
+    sun4H:SunOS:5.*:*)
+	echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+	exit ;;
     sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
 	echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
-	exit 0 ;;
+	exit ;;
     i86pc:SunOS:5.*:*)
 	echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
-	exit 0 ;;
+	exit ;;
     sun4*:SunOS:6*:*)
 	# According to config.sub, this is the proper way to canonicalize
 	# SunOS6.  Hard to guess exactly what SunOS6 will be like, but
 	# it's likely to be more like Solaris than SunOS4.
 	echo sparc-sun-solaris3`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
-	exit 0 ;;
+	exit ;;
     sun4*:SunOS:*:*)
 	case "`/usr/bin/arch -k`" in
 	    Series*|S4*)
@@ -170,12 +342,12 @@
 	esac
 	# Japanese Language versions have a version number like `4.1.3-JL'.
 	echo sparc-sun-sunos`echo ${UNAME_RELEASE}|sed -e 's/-/_/'`
-	exit 0 ;;
+	exit ;;
     sun3*:SunOS:*:*)
 	echo m68k-sun-sunos${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
     sun*:*:4.2BSD:*)
-	UNAME_RELEASE=`(head -1 /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
+	UNAME_RELEASE=`(sed 1q /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
 	test "x${UNAME_RELEASE}" = "x" && UNAME_RELEASE=3
 	case "`/bin/arch`" in
 	    sun3)
@@ -185,52 +357,63 @@
 		echo sparc-sun-sunos${UNAME_RELEASE}
 	esac
-	exit 0 ;;
+	exit ;;
     aushp:SunOS:*:*)
 	echo sparc-auspex-sunos${UNAME_RELEASE}
-	exit 0 ;;
-    atari*:NetBSD:*:*)
-	echo m68k-atari-netbsd${UNAME_RELEASE}
-	exit 0 ;;
-    atari*:OpenBSD:*:*)
-	exit 0 ;;
-    sun3*:NetBSD:*:*)
-	echo m68k-sun-netbsd${UNAME_RELEASE}
-	exit 0 ;;
-    sun3*:OpenBSD:*:*)
-	exit 0 ;;
-    mac68k:NetBSD:*:*)
-	echo m68k-apple-netbsd${UNAME_RELEASE}
-	exit 0 ;;
-    mac68k:OpenBSD:*:*)
-	exit 0 ;;
-    mvme68k:OpenBSD:*:*)
-	exit 0 ;;
-    mvme88k:OpenBSD:*:*)
-	echo m88k-unknown-openbsd${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
+    # The situation for MiNT is a little confusing.  The machine name
+    # can be virtually everything (everything which is not
+    # "atarist" or "atariste" at least should have a processor
+    # > m68000).  The system name ranges from "MiNT" over "FreeMiNT"
+    # to the lowercase version "mint" (or "freemint").  Finally
+    # the system name "TOS" denotes a system which is actually not
+    # MiNT.  But MiNT is downward compatible to TOS, so this should
+    # be no problem.
+    atarist[e]:*MiNT:*:* | atarist[e]:*mint:*:* | atarist[e]:*TOS:*:*)
+        echo m68k-atari-mint${UNAME_RELEASE}
+	exit ;;
+    atari*:*MiNT:*:* | atari*:*mint:*:* | atarist[e]:*TOS:*:*)
+        exit ;;
+    *falcon*:*MiNT:*:* | *falcon*:*mint:*:* | *falcon*:*TOS:*:*)
+	exit ;;
+    milan*:*MiNT:*:* | milan*:*mint:*:* | *milan*:*TOS:*:*)
+        echo m68k-milan-mint${UNAME_RELEASE}
+        exit ;;
+    hades*:*MiNT:*:* | hades*:*mint:*:* | *hades*:*TOS:*:*)
+        echo m68k-hades-mint${UNAME_RELEASE}
+        exit ;;
+    *:*MiNT:*:* | *:*mint:*:* | *:*TOS:*:*)
+        echo m68k-unknown-mint${UNAME_RELEASE}
+        exit ;;
+    m68k:machten:*:*)
+	echo m68k-apple-machten${UNAME_RELEASE}
+	exit ;;
     powerpc:machten:*:*)
 	echo powerpc-apple-machten${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
     RISC*:Mach:*:*)
 	echo mips-dec-mach_bsd4.3
-	exit 0 ;;
+	exit ;;
     RISC*:ULTRIX:*:*)
 	echo mips-dec-ultrix${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
     VAX*:ULTRIX*:*:*)
 	echo vax-dec-ultrix${UNAME_RELEASE}
-	exit 0 ;;
-    2020:CLIX:*:*)
+	exit ;;
+    2020:CLIX:*:* | 2430:CLIX:*:*)
 	echo clipper-intergraph-clix${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
     mips:*:*:UMIPS | mips:*:*:RISCos)
-	sed 's/^	//' << EOF >dummy.c
-	int main (argc, argv) int argc; char **argv; {
+	sed 's/^	//' << EOF >$dummy.c
+#ifdef __cplusplus
+#include <stdio.h>  /* for printf() prototype */
+	int main (int argc, char *argv[]) {
+#else
+	int main (argc, argv) int argc; char *argv[]; {
+#endif
 	#if defined (host_mips) && defined (MIPSEB)
 	#if defined (SYSTYPE_SYSV)
 	  printf ("mips-mips-riscos%ssysv\n", argv[1]); exit (0);
@@ -245,62 +428,83 @@
 	  exit (-1);
 EOF
-	${CC-cc} dummy.c -o dummy \
-	  && ./dummy `echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` \
-	  && rm dummy.c dummy && exit 0
-	rm -f dummy.c dummy
+	$CC_FOR_BUILD -o $dummy $dummy.c &&
+	  dummyarg=`echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` &&
+	  SYSTEM_NAME=`$dummy $dummyarg` &&
+	    { echo "$SYSTEM_NAME"; exit; }
 	echo mips-mips-riscos${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
+    Motorola:PowerMAX_OS:*:*)
+	echo powerpc-motorola-powermax
+	exit ;;
+    Motorola:*:4.3:PL8-*)
+	echo powerpc-harris-powermax
+	exit ;;
+    Night_Hawk:*:*:PowerMAX_OS | Synergy:PowerMAX_OS:*:*)
+	exit ;;
     Night_Hawk:Power_UNIX:*:*)
 	echo powerpc-harris-powerunix
-	exit 0 ;;
+	exit ;;
     m88k:CX/UX:7*:*)
 	echo m88k-harris-cxux7
-	exit 0 ;;
+	exit ;;
     m88k:*:4*:R4*)
 	echo m88k-motorola-sysv4
-	exit 0 ;;
+	exit ;;
     m88k:*:3*:R3*)
 	echo m88k-motorola-sysv3
-	exit 0 ;;
+	exit ;;
     AViiON:dgux:*:*)
         # DG/UX returns AViiON for all architectures
         UNAME_PROCESSOR=`/usr/bin/uname -p`
-        if [ $UNAME_PROCESSOR = mc88100 -o $UNAME_PROCESSOR = mc88110 ] ; then
-	if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx \
-	     -o ${TARGET_BINARY_INTERFACE}x = x ] ; then
+	if [ $UNAME_PROCESSOR = mc88100 ] || [ $UNAME_PROCESSOR = mc88110 ]
+	then
+	    if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx ] || \
+	       [ ${TARGET_BINARY_INTERFACE}x = x ]
+	    then
 		echo m88k-dg-dgux${UNAME_RELEASE}
+	    else
+		echo m88k-dg-dguxbcs${UNAME_RELEASE}
+	    fi
 	else
-		echo m88k-dg-dguxbcs${UNAME_RELEASE}
+	    echo i586-dg-dgux${UNAME_RELEASE}
 	fi
-        else echo i586-dg-dgux${UNAME_RELEASE}
-        fi
- 	exit 0 ;;
+ 	exit ;;
     M88*:DolphinOS:*:*)	# DolphinOS (SVR3)
 	echo m88k-dolphin-sysv3
-	exit 0 ;;
+	exit ;;
     M88*:*:R3*:*)
 	# Delta 88k system running SVR3
-	exit 0 ;;
+	exit ;;
     XD88*:*:*:*) # Tektronix XD88 system running UTekV (SVR3)
 	echo m88k-tektronix-sysv3
-	exit 0 ;;
+	exit ;;
     Tek43[0-9][0-9]:UTek:*:*) # Tektronix 4300 system running UTek (BSD)
 	echo m68k-tektronix-bsd
-	exit 0 ;;
+	exit ;;
     *:IRIX*:*:*)
 	echo mips-sgi-irix`echo ${UNAME_RELEASE}|sed -e 's/-/_/g'`
-	exit 0 ;;
+	exit ;;
     ????????:AIX?:[12].1:2)   # AIX 2.2.1 or AIX 2.1.1 is RT/PC AIX.
-	echo romp-ibm-aix      # uname -m gives an 8 hex-code CPU id
-	exit 0 ;;              # Note that: echo "'`uname -s`'" gives 'AIX '
-    i?86:AIX:*:*)
+	echo romp-ibm-aix     # uname -m gives an 8 hex-code CPU id
+	exit ;;               # Note that: echo "'`uname -s`'" gives 'AIX '
+    i*86:AIX:*:*)
 	echo i386-ibm-aix
-	exit 0 ;;
+	exit ;;
+    ia64:AIX:*:*)
+	if [ -x /usr/bin/oslevel ] ; then
+		IBM_REV=`/usr/bin/oslevel`
+	else
+		IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
+	fi
+	echo ${UNAME_MACHINE}-ibm-aix${IBM_REV}
+	exit ;;
     *:AIX:2:3)
 	if grep bos325 /usr/include/stdio.h >/dev/null 2>&1; then
 		#include <sys/systemcfg.h>
 		main()
@@ -311,17 +515,21 @@
 			exit(0);
 EOF
-		${CC-cc} dummy.c -o dummy && ./dummy && rm dummy.c dummy && exit 0
-		echo rs6000-ibm-aix3.2.5
+		if $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy`
+		then
+			echo "$SYSTEM_NAME"
+		else
+			echo rs6000-ibm-aix3.2.5
+		fi
 	elif grep bos324 /usr/include/stdio.h >/dev/null 2>&1; then
 		echo rs6000-ibm-aix3.2.4
 	else
 	fi
-	exit 0 ;;
-    *:AIX:*:4)
-	if /usr/sbin/lsattr -EHl proc0 | grep POWER >/dev/null 2>&1; then
+	exit ;;
+    *:AIX:*:[45])
+	IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
+	if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
 		IBM_ARCH=rs6000
 	else
 		IBM_ARCH=powerpc
@@ -329,43 +537,120 @@
 	else
-		IBM_REV=4.${UNAME_RELEASE}
 	fi
 	echo ${IBM_ARCH}-ibm-aix${IBM_REV}
-	exit 0 ;;
+	exit ;;
     *:AIX:*:*)
 	echo rs6000-ibm-aix
-	exit 0 ;;
+	exit ;;
     ibmrt:4.4BSD:*|romp-ibm:BSD:*)
 	echo romp-ibm-bsd4.4
-	exit 0 ;;
-    ibmrt:*BSD:*|romp-ibm:BSD:*)            # covers RT/PC NetBSD and
+	exit ;;
+    ibmrt:*BSD:*|romp-ibm:BSD:*)            # covers RT/PC BSD and
 	echo romp-ibm-bsd${UNAME_RELEASE}   # 4.3 with uname added to
-	exit 0 ;;                           # report: romp-ibm BSD 4.3
+	exit ;;                             # report: romp-ibm BSD 4.3
     *:BOSX:*:*)
 	echo rs6000-bull-bosx
-	exit 0 ;;
+	exit ;;
     DPX/2?00:B.O.S.:*:*)
 	echo m68k-bull-sysv3
-	exit 0 ;;
+	exit ;;
     9000/[34]??:4.3bsd:1.*:*)
 	echo m68k-hp-bsd
-	exit 0 ;;
+	exit ;;
     hp300:4.4BSD:*:* | 9000/[34]??:4.3bsd:2.*:*)
 	echo m68k-hp-bsd4.4
-	exit 0 ;;
-    9000/[3478]??:HP-UX:*:*)
+	exit ;;
+    9000/[34678]??:HP-UX:*:*)
+	HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
 	case "${UNAME_MACHINE}" in
 	    9000/31? )            HP_ARCH=m68000 ;;
 	    9000/[34]?? )         HP_ARCH=m68k ;;
-	    9000/7?? | 9000/8?[1679] ) HP_ARCH=hppa1.1 ;;
-	    9000/8?? )            HP_ARCH=hppa1.0 ;;
+	    9000/[678][0-9][0-9])
+		if [ -x /usr/bin/getconf ]; then
+		    sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
+                    sc_kernel_bits=`/usr/bin/getconf SC_KERNEL_BITS 2>/dev/null`
+                    case "${sc_cpu_version}" in
+                      523) HP_ARCH="hppa1.0" ;; # CPU_PA_RISC1_0
+                      528) HP_ARCH="hppa1.1" ;; # CPU_PA_RISC1_1
+                      532)                      # CPU_PA_RISC2_0
+                        case "${sc_kernel_bits}" in
+                          32) HP_ARCH="hppa2.0n" ;;
+                          64) HP_ARCH="hppa2.0w" ;;
+			  '') HP_ARCH="hppa2.0" ;;   # HP-UX 10.20
+                        esac ;;
+                    esac
+		fi
+		if [ "${HP_ARCH}" = "" ]; then
+              #define _HPUX_SOURCE
+              #include <stdlib.h>
+              #include <unistd.h>
+              int main ()
+              #if defined(_SC_KERNEL_BITS)
+                  long bits = sysconf(_SC_KERNEL_BITS);
+              #endif
+                  long cpu  = sysconf (_SC_CPU_VERSION);
+                  switch (cpu)
+              	case CPU_PA_RISC1_0: puts ("hppa1.0"); break;
+              	case CPU_PA_RISC1_1: puts ("hppa1.1"); break;
+              	case CPU_PA_RISC2_0:
+              	    switch (bits)
+              		case 64: puts ("hppa2.0w"); break;
+              		case 32: puts ("hppa2.0n"); break;
+              		default: puts ("hppa2.0"); break;
+              		} break;
+              #else  /* !defined(_SC_KERNEL_BITS) */
+              	    puts ("hppa2.0"); break;
+              #endif
+              	default: puts ("hppa1.0"); break;
+                  exit (0);
+EOF
+		    (CCOPTS= $CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null) && HP_ARCH=`$dummy`
+		    test -z "$HP_ARCH" && HP_ARCH=hppa
+		fi ;;
 	esac
+	if [ ${HP_ARCH} = "hppa2.0w" ]
+	then
+	    # hppa2.0w-hp-hpux* has a 64-bit kernel and a compiler generating
+	    # 32-bit code.  hppa64-hp-hpux* has the same kernel and a compiler
+	    # generating 64-bit code.  GNU and HP use different nomenclature:
+	    # $ CC_FOR_BUILD=cc ./config.guess
+	    # => hppa2.0w-hp-hpux11.23
+	    # $ CC_FOR_BUILD="cc +DA2.0w" ./config.guess
+	    # => hppa64-hp-hpux11.23
+	    if echo __LP64__ | (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) |
+		grep __LP64__ >/dev/null
+	    then
+		HP_ARCH="hppa2.0w"
+	    else
+		HP_ARCH="hppa64"
+	    fi
+	fi
+	echo ${HP_ARCH}-hp-hpux${HPUX_REV}
+	exit ;;
+    ia64:HP-UX:*:*)
-	echo ${HP_ARCH}-hp-hpux${HPUX_REV}
-	exit 0 ;;
+	echo ia64-hp-hpux${HPUX_REV}
+	exit ;;
     3050*:HI-UX:*:*)
 	#include <unistd.h>
 	int
 	main ()
@@ -390,324 +675,447 @@
 	  exit (0);
 EOF
+	$CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy` &&
 	echo unknown-hitachi-hiuxwe2
-	exit 0 ;;
+	exit ;;
     9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:* )
 	echo hppa1.1-hp-bsd
-	exit 0 ;;
+	exit ;;
     9000/8??:4.3bsd:*:*)
 	echo hppa1.0-hp-bsd
-	exit 0 ;;
+	exit ;;
+    *9??*:MPE/iX:*:* | *3000*:MPE/iX:*:*)
+	echo hppa1.0-hp-mpeix
+	exit ;;
     hp7??:OSF1:*:* | hp8?[79]:OSF1:*:* )
 	echo hppa1.1-hp-osf
-	exit 0 ;;
+	exit ;;
     hp8??:OSF1:*:*)
 	echo hppa1.0-hp-osf
-	exit 0 ;;
-    i?86:OSF1:*:*)
+	exit ;;
+    i*86:OSF1:*:*)
 	if [ -x /usr/sbin/sysversion ] ; then
 	    echo ${UNAME_MACHINE}-unknown-osf1mk
 	else
 	fi
-	exit 0 ;;
+	exit ;;
     parisc*:Lites*:*:*)
 	echo hppa1.1-hp-lites
-	exit 0 ;;
+	exit ;;
     C1*:ConvexOS:*:* | convex:ConvexOS:C1*:*)
 	echo c1-convex-bsd
-        exit 0 ;;
+        exit ;;
     C2*:ConvexOS:*:* | convex:ConvexOS:C2*:*)
 	if getsysinfo -f scalar_acc
 	then echo c32-convex-bsd
 	else echo c2-convex-bsd
 	fi
-        exit 0 ;;
+        exit ;;
     C34*:ConvexOS:*:* | convex:ConvexOS:C34*:*)
 	echo c34-convex-bsd
-        exit 0 ;;
+        exit ;;
     C38*:ConvexOS:*:* | convex:ConvexOS:C38*:*)
 	echo c38-convex-bsd
-        exit 0 ;;
+        exit ;;
     C4*:ConvexOS:*:* | convex:ConvexOS:C4*:*)
 	echo c4-convex-bsd
-        exit 0 ;;
-    CRAY*X-MP:*:*:*)
-	echo xmp-cray-unicos
-        exit 0 ;;
+        exit ;;
     CRAY*Y-MP:*:*:*)
-	echo ymp-cray-unicos${UNAME_RELEASE}
-	exit 0 ;;
+	echo ymp-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	exit ;;
     CRAY*[A-Z]90:*:*:*)
 	echo ${UNAME_MACHINE}-cray-unicos${UNAME_RELEASE} \
 	| sed -e 's/CRAY.*\([A-Z]90\)/\1/' \
-	      -e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/
-	exit 0 ;;
+	      -e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/ \
+	      -e 's/\.[^.]*$/.X/'
+	exit ;;
     CRAY*TS:*:*:*)
-	echo t90-cray-unicos${UNAME_RELEASE}
-	exit 0 ;;
-    CRAY-2:*:*:*)
-	echo cray2-cray-unicos
-        exit 0 ;;
-    F300:UNIX_System_V:*:*)
-        FUJITSU_SYS=`uname -p | tr [A-Z] [a-z] | sed -e 's/\///'`
+	echo t90-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	exit ;;
+    CRAY*T3E:*:*:*)
+	echo alphaev5-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	exit ;;
+    CRAY*SV1:*:*:*)
+	echo sv1-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	exit ;;
+    *:UNICOS/mp:*:*)
+	echo craynv-cray-unicosmp${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+	exit ;;
+    F30[01]:UNIX_System_V:*:* | F700:UNIX_System_V:*:*)
+	FUJITSU_PROC=`uname -m | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
+        FUJITSU_SYS=`uname -p | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/\///'`
         FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
-        echo "f300-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
-        exit 0 ;;
-    F301:UNIX_System_V:*:*)
-       echo f301-fujitsu-uxpv`echo $UNAME_RELEASE | sed 's/ .*//'`
-       exit 0 ;;
-    hp3[0-9][05]:NetBSD:*:*)
-	echo m68k-hp-netbsd${UNAME_RELEASE}
-	exit 0 ;;
-    hp300:OpenBSD:*:*)
-	exit 0 ;;
-    i?86:BSD/386:*:* | *:BSD/OS:*:*)
+        echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
+        exit ;;
+    5000:UNIX_System_V:4.*:*)
+        FUJITSU_REL=`echo ${UNAME_RELEASE} | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/ /_/'`
+        echo "sparc-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
+	exit ;;
+    i*86:BSD/386:*:* | i*86:BSD/OS:*:* | *:Ascend\ Embedded/OS:*:*)
 	echo ${UNAME_MACHINE}-pc-bsdi${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
+    sparc*:BSD/OS:*:*)
+	echo sparc-unknown-bsdi${UNAME_RELEASE}
+	exit ;;
+    *:BSD/OS:*:*)
+	echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
+	exit ;;
     *:FreeBSD:*:*)
 	echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
-	exit 0 ;;
-    *:NetBSD:*:*)
-	echo ${UNAME_MACHINE}-unknown-netbsd`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
-	exit 0 ;;
-    *:OpenBSD:*:*)
-	echo ${UNAME_MACHINE}-unknown-openbsd`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
-	exit 0 ;;
+	exit ;;
     i*:CYGWIN*:*)
-	echo i386-pc-cygwin32
-	exit 0 ;;
+	echo ${UNAME_MACHINE}-pc-cygwin
+	exit ;;
     i*:MINGW*:*)
-	echo i386-pc-mingw32
-	exit 0 ;;
+	echo ${UNAME_MACHINE}-pc-mingw32
+	exit ;;
+    i*:windows32*:*)
+    	# uname -m includes "-pc" on this system.
+    	echo ${UNAME_MACHINE}-mingw32
+	exit ;;
+    i*:PW*:*)
+	echo ${UNAME_MACHINE}-pc-pw32
+	exit ;;
+    x86:Interix*:[34]*)
+	echo i586-pc-interix${UNAME_RELEASE}|sed -e 's/\..*//'
+	exit ;;
+    [345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
+	echo i${UNAME_MACHINE}-pc-mks
+	exit ;;
+    i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
+	# It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
+	# UNAME_MACHINE based on the output of uname instead of i386?
+	exit ;;
+    i*:UWIN*:*)
+	echo ${UNAME_MACHINE}-pc-uwin
+	exit ;;
+    amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
+	echo x86_64-unknown-cygwin
+	exit ;;
     p*:CYGWIN*:*)
-	echo powerpcle-unknown-cygwin32
-	exit 0 ;;
+	echo powerpcle-unknown-cygwin
+	exit ;;
     prep*:SunOS:5.*:*)
 	echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
-	exit 0 ;;
+	exit ;;
     *:GNU:*:*)
+	# the GNU system
 	echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
-	exit 0 ;;
-    *:Linux:*:*)
+	exit ;;
+    *:GNU/*:*:*)
+	# other systems with GNU libc and userland
+	echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-gnu
+	exit ;;
+    i*86:Minix:*:*)
+	echo ${UNAME_MACHINE}-pc-minix
+	exit ;;
+    arm*:Linux:*:*)
+	echo ${UNAME_MACHINE}-unknown-linux-gnu
+	exit ;;
+    cris:Linux:*:*)
+	echo cris-axis-linux-gnu
+	exit ;;
+    crisv32:Linux:*:*)
+	echo crisv32-axis-linux-gnu
+	exit ;;
+    frv:Linux:*:*)
+    	echo frv-unknown-linux-gnu
+	exit ;;
+    ia64:Linux:*:*)
+	exit ;;
+    m32r*:Linux:*:*)
+	exit ;;
+    m68*:Linux:*:*)
+	exit ;;
+    mips:Linux:*:*)
+	#undef CPU
+	#undef mips
+	#undef mipsel
+	#if defined(__MIPSEL__) || defined(__MIPSEL) || defined(_MIPSEL) || defined(MIPSEL)
+	CPU=mipsel
+	#else
+	#if defined(__MIPSEB__) || defined(__MIPSEB) || defined(_MIPSEB) || defined(MIPSEB)
+	CPU=mips
+	#else
+	CPU=
+	#endif
+	#endif
+EOF
+	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^CPU=`
+	test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
+    mips64:Linux:*:*)
+	#undef CPU
+	#undef mips64
+	#undef mips64el
+	CPU=mips64el
+	#else
+	CPU=mips64
+	#else
+	CPU=
+	#endif
+	#endif
+EOF
+    or32:Linux:*:*)
+	echo or32-unknown-linux-gnu
+	exit ;;
+    ppc:Linux:*:*)
+	echo powerpc-unknown-linux-gnu
+	exit ;;
+    ppc64:Linux:*:*)
+	echo powerpc64-unknown-linux-gnu
+	exit ;;
+    alpha:Linux:*:*)
+	case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
+	  EV5)   UNAME_MACHINE=alphaev5 ;;
+	  EV56)  UNAME_MACHINE=alphaev56 ;;
+	  PCA56) UNAME_MACHINE=alphapca56 ;;
+	  PCA57) UNAME_MACHINE=alphapca56 ;;
+	  EV6)   UNAME_MACHINE=alphaev6 ;;
+	  EV67)  UNAME_MACHINE=alphaev67 ;;
+	  EV68*) UNAME_MACHINE=alphaev68 ;;
+        esac
+	objdump --private-headers /bin/sh | grep ld.so.1 >/dev/null
+	if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
+	echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
+	exit ;;
+    parisc:Linux:*:* | hppa:Linux:*:*)
+	# Look for CPU level
+	case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
+	  PA7*) echo hppa1.1-unknown-linux-gnu ;;
+	  PA8*) echo hppa2.0-unknown-linux-gnu ;;
+	  *)    echo hppa-unknown-linux-gnu ;;
+	esac
+	exit ;;
+    parisc64:Linux:*:* | hppa64:Linux:*:*)
+	echo hppa64-unknown-linux-gnu
+	exit ;;
+    s390:Linux:*:* | s390x:Linux:*:*)
+	echo ${UNAME_MACHINE}-ibm-linux
+	exit ;;
+    sh64*:Linux:*:*)
+	exit ;;
+    sh*:Linux:*:*)
+	exit ;;
+    sparc:Linux:*:* | sparc64:Linux:*:*)
+	exit ;;
+    x86_64:Linux:*:*)
+	echo x86_64-unknown-linux-gnu
+	exit ;;
+    i*86:Linux:*:*)
 	# The BFD linker knows what the default object file format is, so
-	# first see if it will tell us.
-	ld_help_string=`ld --help 2>&1`
-	ld_supported_emulations=`echo $ld_help_string \
-			 | sed -ne '/supported emulations:/!d
+	# first see if it will tell us. cd to the root directory to prevent
+	# problems with other programs or directories called `ld' in the path.
+	# Set LC_ALL=C to ensure ld outputs messages in English.
+	ld_supported_targets=`cd /; LC_ALL=C ld --help 2>&1 \
+			 | sed -ne '/supported targets:/!d
 				    s/[ 	][ 	]*/ /g
-				    s/.*supported emulations: *//
+				    s/.*supported targets: *//
 				    s/ .*//
 				    p'`
-        case "$ld_supported_emulations" in
-	  i?86linux)  echo "${UNAME_MACHINE}-pc-linux-gnuaout"      ; exit 0 ;;
-	  i?86coff)   echo "${UNAME_MACHINE}-pc-linux-gnucoff"      ; exit 0 ;;
-	  sparclinux) echo "${UNAME_MACHINE}-unknown-linux-gnuaout" ; exit 0 ;;
-	  m68klinux)  echo "${UNAME_MACHINE}-unknown-linux-gnuaout" ; exit 0 ;;
-	  elf32ppc)   echo "powerpc-unknown-linux-gnu"              ; exit 0 ;;
+        case "$ld_supported_targets" in
+	  elf32-i386)
+		TENTATIVE="${UNAME_MACHINE}-pc-linux-gnu"
+	  a.out-i386-linux)
+		echo "${UNAME_MACHINE}-pc-linux-gnuaout"
+		exit ;;
+	  coff-i386)
+		echo "${UNAME_MACHINE}-pc-linux-gnucoff"
+		exit ;;
+		# Either a pre-BFD a.out linker (linux-gnuoldld) or
+		# one that does not give us useful --help.
+		echo "${UNAME_MACHINE}-pc-linux-gnuoldld"
+		exit ;;
 	esac
-	if test "${UNAME_MACHINE}" = "alpha" ; then
-		sed 's/^	//'  <<EOF >dummy.s
-		.globl main
-		.ent main
-	main:
-		.prologue 0
-		lda \$2,259
-		srl \$1,8,\$2
-		sll \$2,2,\$2
-		sll \$0,3,\$0
-		addl \$1,\$0,\$0
-		addl \$2,\$0,\$0
-		ret \$31,(\$26),1
-		.end main
+	# Determine whether the default compiler is a.out or elf
+	#include <features.h>
+	#ifdef __ELF__
+	# ifdef __GLIBC__
+	#  if __GLIBC__ >= 2
+	LIBC=gnu
+	#  else
+	LIBC=gnulibc1
+	#  endif
+	# else
+	LIBC=gnulibc1
+	# endif
+	#else
+	#ifdef __INTEL_COMPILER
+	LIBC=gnu
+	#else
+	LIBC=gnuaout
+	#endif
+	#endif
+	#ifdef __dietlibc__
+	LIBC=dietlibc
+	#endif
 EOF
-		LIBC=""
-			./dummy
-			case "$?" in
-			7)
-			15)
-			14)
-			10)
-			16)
-			esac
-			objdump --private-headers dummy | \
-			  grep ld.so.1 > /dev/null
-				LIBC="libc1"
-			fi
-		fi
-		echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC} ; exit 0
-	elif test "${UNAME_MACHINE}" = "mips" ; then
-	  cat >dummy.c <<EOF
-main(argc, argv)
-     int argc;
-     char *argv[];
-#ifdef __MIPSEB__
-  printf ("%s-unknown-linux-gnu\n", argv[1]);
-#endif
-#ifdef __MIPSEL__
-  printf ("%sel-unknown-linux-gnu\n", argv[1]);
-#endif
-  return 0;
-EOF
-	  ${CC-cc} dummy.c -o dummy 2>/dev/null && ./dummy "${UNAME_MACHINE}" && rm dummy.c dummy && exit 0
-	else
-	  # Either a pre-BFD a.out linker (linux-gnuoldld)
-	  # or one that does not give us useful --help.
-	  # GCC wants to distinguish between linux-gnuoldld and linux-gnuaout.
-	  # If ld does not provide *any* "supported emulations:"
-	  # that means it is gnuoldld.
-	  echo "$ld_help_string" | grep >/dev/null 2>&1 "supported emulations:"
-	  test $? != 0 && echo "${UNAME_MACHINE}-pc-linux-gnuoldld" && exit 0
-	  case "${UNAME_MACHINE}" in
-	  i?86)
-	    VENDOR=pc;
-	    VENDOR=unknown;
-	  esac
-	  # Determine whether the default compiler is a.out or elf
-#include <features.h>
-main(argc, argv)
-     int argc;
-     char *argv[];
-#ifdef __ELF__
-# ifdef __GLIBC__
-#  if __GLIBC__ >= 2
-    printf ("%s-${VENDOR}-linux-gnu\n", argv[1]);
-#  else
-    printf ("%s-${VENDOR}-linux-gnulibc1\n", argv[1]);
-#  endif
-# else
-# endif
-#else
-  printf ("%s-${VENDOR}-linux-gnuaout\n", argv[1]);
-#endif
-  return 0;
-EOF
-	fi ;;
-# ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.  earlier versions
-# are messed up and put the nodename in both sysname and nodename.
-    i?86:DYNIX/ptx:4*:*)
+	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^LIBC=`
+	test x"${LIBC}" != x && {
+		echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
+		exit
+	test x"${TENTATIVE}" != x && { echo "${TENTATIVE}"; exit; }
+    i*86:DYNIX/ptx:4*:*)
+	# ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
+	# earlier versions are messed up and put the nodename in both
+	# sysname and nodename.
 	echo i386-sequent-sysv4
-	exit 0 ;;
-    i?86:UNIX_SV:4.2MP:2.*)
+	exit ;;
+    i*86:UNIX_SV:4.2MP:2.*)
         # Unixware is an offshoot of SVR4, but it has its own version
         # number series starting with 2...
         # I am not positive that other SVR4 systems won't match this,
 	# I just have to hope.  -- rms.
         # Use sysv4.2uw... so that sysv4* matches it.
 	echo ${UNAME_MACHINE}-pc-sysv4.2uw${UNAME_VERSION}
-	exit 0 ;;
-    i?86:*:4.*:* | i?86:SYSTEM_V:4.*:*)
+	exit ;;
+    i*86:OS/2:*:*)
+	# If we were able to find `uname', then EMX Unix compatibility
+	# is probably installed.
+	echo ${UNAME_MACHINE}-pc-os2-emx
+	exit ;;
+    i*86:XTS-300:*:STOP)
+	echo ${UNAME_MACHINE}-unknown-stop
+	exit ;;
+    i*86:atheos:*:*)
+	echo ${UNAME_MACHINE}-unknown-atheos
+	exit ;;
+    i*86:syllable:*:*)
+	echo ${UNAME_MACHINE}-pc-syllable
+	exit ;;
+    i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.0*:*)
+	echo i386-unknown-lynxos${UNAME_RELEASE}
+	exit ;;
+    i*86:*DOS:*:*)
+	echo ${UNAME_MACHINE}-pc-msdosdjgpp
+	exit ;;
+    i*86:*:4.*:* | i*86:SYSTEM_V:4.*:*)
+	UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
 	if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
-		echo ${UNAME_MACHINE}-univel-sysv${UNAME_RELEASE}
+		echo ${UNAME_MACHINE}-univel-sysv${UNAME_REL}
 	else
-		echo ${UNAME_MACHINE}-pc-sysv${UNAME_RELEASE}
+		echo ${UNAME_MACHINE}-pc-sysv${UNAME_REL}
 	fi
-	exit 0 ;;
-    i?86:*:3.2:*)
+	exit ;;
+    i*86:*:5:[678]*)
+    	# UnixWare 7.x, OpenUNIX and OpenServer 6.
+	case `/bin/uname -X | grep "^Machine"` in
+	    *486*)	     UNAME_MACHINE=i486 ;;
+	    *Pentium)	     UNAME_MACHINE=i586 ;;
+	    *Pent*|*Celeron) UNAME_MACHINE=i686 ;;
+	esac
+	echo ${UNAME_MACHINE}-unknown-sysv${UNAME_RELEASE}${UNAME_SYSTEM}${UNAME_VERSION}
+	exit ;;
+    i*86:*:3.2:*)
 	if test -f /usr/options/cb.name; then
 		UNAME_REL=`sed -n 's/.*Version //p' </usr/options/cb.name`
 		echo ${UNAME_MACHINE}-pc-isc$UNAME_REL
 	elif /bin/uname -X 2>/dev/null >/dev/null ; then
-		UNAME_REL=`(/bin/uname -X|egrep Release|sed -e 's/.*= //')`
-		(/bin/uname -X|egrep i80486 >/dev/null) && UNAME_MACHINE=i486
-		(/bin/uname -X|egrep '^Machine.*Pentium' >/dev/null) \
+		UNAME_REL=`(/bin/uname -X|grep Release|sed -e 's/.*= //')`
+		(/bin/uname -X|grep i80486 >/dev/null) && UNAME_MACHINE=i486
+		(/bin/uname -X|grep '^Machine.*Pentium' >/dev/null) \
 			&& UNAME_MACHINE=i586
+		(/bin/uname -X|grep '^Machine.*Pent *II' >/dev/null) \
+			&& UNAME_MACHINE=i686
+		(/bin/uname -X|grep '^Machine.*Pentium Pro' >/dev/null) \
 		echo ${UNAME_MACHINE}-pc-sco$UNAME_REL
 	else
 		echo ${UNAME_MACHINE}-pc-sysv32
 	fi
-	exit 0 ;;
+	exit ;;
     pc:*:*:*)
+	# Left here for compatibility:
         # uname -m prints for DJGPP always 'pc', but it prints nothing about
         # the processor, so we play safe by assuming i386.
 	echo i386-pc-msdosdjgpp
-        exit 0 ;;
+        exit ;;
     Intel:Mach:3*:*)
 	echo i386-pc-mach3
-	exit 0 ;;
+	exit ;;
     paragon:*:*:*)
 	echo i860-intel-osf1
-	exit 0 ;;
+	exit ;;
     i860:*:4.*:*) # i860-SVR4
 	if grep Stardent /usr/include/sys/uadmin.h >/dev/null 2>&1 ; then
 	  echo i860-stardent-sysv${UNAME_RELEASE} # Stardent Vistra i860-SVR4
 	else # Add other i860-SVR4 vendors below as they are discovered.
 	  echo i860-unknown-sysv${UNAME_RELEASE}  # Unknown i860-SVR4
 	fi
-	exit 0 ;;
+	exit ;;
     mini*:CTIX:SYS*5:*)
 	# "miniframe"
 	echo m68010-convergent-sysv
-	exit 0 ;;
-    M68*:*:R3V[567]*:*)
-	test -r /sysV68 && echo 'm68k-motorola-sysv' && exit 0 ;;
-    3[34]??:*:4.0:3.0 | 3[34]??,*:*:4.0:3.0 | 4850:*:4.0:3.0)
+	exit ;;
+    mc68k:UNIX:SYSTEM5:3.51m)
+	echo m68k-convergent-sysv
+	exit ;;
+    M680?0:D-NIX:5.3:*)
+	echo m68k-diab-dnix
+	exit ;;
+    M68*:*:R3V[5678]*:*)
+	test -r /sysV68 && { echo 'm68k-motorola-sysv'; exit; } ;;
+    3[345]??:*:4.0:3.0 | 3[34]??A:*:4.0:3.0 | 3[34]??,*:*:4.0:3.0 | 3[34]??/*:*:4.0:3.0 | 4400:*:4.0:3.0 | 4850:*:4.0:3.0 | SKA40:*:4.0:3.0 | SDS2:*:4.0:3.0 | SHG2:*:4.0:3.0 | S7501*:*:4.0:3.0)
 	OS_REL=''
 	test -r /etc/.relid \
 	&& OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
 	/bin/uname -p 2>/dev/null | grep 86 >/dev/null \
-	  && echo i486-ncr-sysv4.3${OS_REL} && exit 0
+	  && { echo i486-ncr-sysv4.3${OS_REL}; exit; }
 	/bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
-	  && echo i586-ncr-sysv4.3${OS_REL} && exit 0 ;;
+	  && { echo i586-ncr-sysv4.3${OS_REL}; exit; } ;;
     3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
-          && echo i486-ncr-sysv4 && exit 0 ;;
-    m68*:LynxOS:2.*:*)
+          && { echo i486-ncr-sysv4; exit; } ;;
+    m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
 	echo m68k-unknown-lynxos${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
     mc68030:UNIX_System_V:4.*:*)
 	echo m68k-atari-sysv4
-	exit 0 ;;
-    i?86:LynxOS:2.*:*)
-	echo i386-unknown-lynxos${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
     TSUNAMI:LynxOS:2.*:*)
 	echo sparc-unknown-lynxos${UNAME_RELEASE}
-	exit 0 ;;
-    rs6000:LynxOS:2.*:* | PowerPC:LynxOS:2.*:*)
+	exit ;;
+    rs6000:LynxOS:2.*:*)
 	echo rs6000-unknown-lynxos${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
+    PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.0*:*)
+	echo powerpc-unknown-lynxos${UNAME_RELEASE}
+	exit ;;
     SM[BE]S:UNIX_SV:*:*)
 	echo mips-dde-sysv${UNAME_RELEASE}
-	exit 0 ;;
+	exit ;;
+    RM*:ReliantUNIX-*:*:*)
+	echo mips-sni-sysv4
+	exit ;;
     RM*:SINIX-*:*:*)
 	echo mips-sni-sysv4
-	exit 0 ;;
+	exit ;;
     *:SINIX-*:*:*)
 	if uname -p 2>/dev/null >/dev/null ; then
 		UNAME_MACHINE=`(uname -p) 2>/dev/null`
@@ -715,39 +1123,153 @@
 	else
 		echo ns32k-sni-sysv
 	fi
-	exit 0 ;;
-    PENTIUM:CPunix:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
-                           # says <Richard.M.Bartel at ccMail.Census.GOV>
+	exit ;;
+    PENTIUM:*:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
+                      # says <Richard.M.Bartel at ccMail.Census.GOV>
         echo i586-unisys-sysv4
-        exit 0 ;;
+        exit ;;
     *:UNIX_System_V:4*:FTX*)
 	# From Gerald Hewes <hewes at openmarket.com>.
 	# How about differentiating between stratus architectures? -djm
 	echo hppa1.1-stratus-sysv4
-	exit 0 ;;
+	exit ;;
     *:*:*:FTX*)
 	# From seanf at swdc.stratus.com.
 	echo i860-stratus-sysv4
-	exit 0 ;;
+	exit ;;
+    i*86:VOS:*:*)
+	# From Paul.Green at stratus.com.
+	echo ${UNAME_MACHINE}-stratus-vos
+	exit ;;
+    *:VOS:*:*)
+	echo hppa1.1-stratus-vos
+	exit ;;
     mc68*:A/UX:*:*)
 	echo m68k-apple-aux${UNAME_RELEASE}
-	exit 0 ;;
-    news*:NEWS-OS:*:6*)
+	exit ;;
+    news*:NEWS-OS:6*:*)
 	echo mips-sony-newsos6
-	exit 0 ;;
-    R3000:*System_V*:*:* | R4000:UNIX_SYSV:*:*)
+	exit ;;
+    R[34]000:*System_V*:*:* | R4000:UNIX_SYSV:*:* | R*000:UNIX_SV:*:*)
 	if [ -d /usr/nec ]; then
 	        echo mips-nec-sysv${UNAME_RELEASE}
 	else
 	        echo mips-unknown-sysv${UNAME_RELEASE}
 	fi
-        exit 0 ;;
+        exit ;;
+    BeBox:BeOS:*:*)	# BeOS running on hardware made by Be, PPC only.
+	echo powerpc-be-beos
+	exit ;;
+    BeMac:BeOS:*:*)	# BeOS running on Mac or Mac clone, PPC only.
+	echo powerpc-apple-beos
+	exit ;;
+    BePC:BeOS:*:*)	# BeOS running on Intel PC compatible.
+	echo i586-pc-beos
+	exit ;;
+    SX-4:SUPER-UX:*:*)
+	echo sx4-nec-superux${UNAME_RELEASE}
+	exit ;;
+    SX-5:SUPER-UX:*:*)
+	echo sx5-nec-superux${UNAME_RELEASE}
+	exit ;;
+    SX-6:SUPER-UX:*:*)
+	echo sx6-nec-superux${UNAME_RELEASE}
+	exit ;;
+    Power*:Rhapsody:*:*)
+	echo powerpc-apple-rhapsody${UNAME_RELEASE}
+	exit ;;
+    *:Rhapsody:*:*)
+	echo ${UNAME_MACHINE}-apple-rhapsody${UNAME_RELEASE}
+	exit ;;
+    *:Darwin:*:*)
+	UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
+	case $UNAME_PROCESSOR in
+	    unknown) UNAME_PROCESSOR=powerpc ;;
+	esac
+	echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
+	exit ;;
+    *:procnto*:*:* | *:QNX:[0123456789]*:*)
+	if test "$UNAME_PROCESSOR" = "x86"; then
+		UNAME_PROCESSOR=i386
+		UNAME_MACHINE=pc
+	fi
+	echo ${UNAME_PROCESSOR}-${UNAME_MACHINE}-nto-qnx${UNAME_RELEASE}
+	exit ;;
+    *:QNX:*:4*)
+	echo i386-pc-qnx
+	exit ;;
+    NSE-?:NONSTOP_KERNEL:*:*)
+	echo nse-tandem-nsk${UNAME_RELEASE}
+	exit ;;
+    NSR-?:NONSTOP_KERNEL:*:*)
+	echo nsr-tandem-nsk${UNAME_RELEASE}
+	exit ;;
+    *:NonStop-UX:*:*)
+	echo mips-compaq-nonstopux
+	exit ;;
+    BS2000:POSIX*:*:*)
+	echo bs2000-siemens-sysv
+	exit ;;
+    DS/*:UNIX_System_V:*:*)
+	echo ${UNAME_MACHINE}-${UNAME_SYSTEM}-${UNAME_RELEASE}
+	exit ;;
+    *:Plan9:*:*)
+	# "uname -m" is not consistent, so use $cputype instead. 386
+	# is converted to i386 for consistency with other x86
+	# operating systems.
+	if test "$cputype" = "386"; then
+	    UNAME_MACHINE=i386
+	else
+	    UNAME_MACHINE="$cputype"
+	fi
+	echo ${UNAME_MACHINE}-unknown-plan9
+	exit ;;
+    *:TOPS-10:*:*)
+	echo pdp10-unknown-tops10
+	exit ;;
+    *:TENEX:*:*)
+	echo pdp10-unknown-tenex
+	exit ;;
+    KS10:TOPS-20:*:* | KL10:TOPS-20:*:* | TYPE4:TOPS-20:*:*)
+	echo pdp10-dec-tops20
+	exit ;;
+    XKL-1:TOPS-20:*:* | TYPE5:TOPS-20:*:*)
+	echo pdp10-xkl-tops20
+	exit ;;
+    *:TOPS-20:*:*)
+	echo pdp10-unknown-tops20
+	exit ;;
+    *:ITS:*:*)
+	echo pdp10-unknown-its
+	exit ;;
+    SEI:*:*:SEIUX)
+        echo mips-sei-seiux${UNAME_RELEASE}
+	exit ;;
+    *:DragonFly:*:*)
+	echo ${UNAME_MACHINE}-unknown-dragonfly`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
+	exit ;;
+    *:*VMS:*:*)
+    	UNAME_MACHINE=`(uname -p) 2>/dev/null`
+	case "${UNAME_MACHINE}" in
+	    A*) echo alpha-dec-vms ; exit ;;
+	    I*) echo ia64-dec-vms ; exit ;;
+	    V*) echo vax-dec-vms ; exit ;;
+	esac ;;
+    *:XENIX:*:SysV)
+	echo i386-pc-xenix
+	exit ;;
+    i*86:skyos:*:*)
+	echo ${UNAME_MACHINE}-pc-skyos`echo ${UNAME_RELEASE}` | sed -e 's/ .*$//'
+	exit ;;
 esac
 #echo '(No uname command or uname output not recognized.)' 1>&2
 #echo "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" 1>&2
-cat >dummy.c <<EOF
+eval $set_cc_for_build
+cat >$dummy.c <<EOF
 #ifdef _SEQUENT_
 # include <sys/types.h>
 # include <sys/utsname.h>
@@ -772,7 +1294,7 @@
 #endif
 #if defined (__arm) && defined (__acorn) && defined (__unix)
-  printf ("arm-acorn-riscix"); exit (0);
+  printf ("arm-acorn-riscix\n"); exit (0);
 #endif
 #if defined (hp300) && !defined (hpux)
@@ -785,7 +1307,10 @@
 #endif
   int version;
   version=`(hostinfo | sed -n 's/.*NeXT Mach \([0-9]*\).*/\1/p') 2>/dev/null`;
-  printf ("%s-next-nextstep%d\n", __ARCHITECTURE__, version);
+  if (version < 4)
+    printf ("%s-next-nextstep%d\n", __ARCHITECTURE__, version);
+  else
+    printf ("%s-next-openstep%d\n", __ARCHITECTURE__, version);
   exit (0);
 #endif
@@ -830,12 +1355,25 @@
 #endif
 #if defined (vax)
-#if !defined (ultrix)
-  printf ("vax-dec-bsd\n"); exit (0);
-#else
-  printf ("vax-dec-ultrix\n"); exit (0);
+# if !defined (ultrix)
+#  include <sys/param.h>
+#  if defined (BSD)
+#   if BSD == 43
+      printf ("vax-dec-bsd4.3\n"); exit (0);
+#   else
+#    if BSD == 199006
+      printf ("vax-dec-bsd4.3reno\n"); exit (0);
+#    else
+      printf ("vax-dec-bsd\n"); exit (0);
+#    endif
+#   endif
+#  else
+#  endif
+# else
+    printf ("vax-dec-ultrix\n"); exit (0);
+# endif
 #endif
-#endif
 #if defined (alliant) && defined (i860)
   printf ("i860-alliant-bsd\n"); exit (0);
@@ -845,12 +1383,12 @@
 EOF
-${CC-cc} dummy.c -o dummy 2>/dev/null && ./dummy && rm dummy.c dummy && exit 0
-rm -f dummy.c dummy
+$CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null && SYSTEM_NAME=`$dummy` &&
 # Apollos put the system type in the environment.
-test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit 0; }
+test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit; }
 # Convex versions that predate uname can use getsysinfo(1)
@@ -859,25 +1397,70 @@
     case `getsysinfo -f cpu_type` in
     c1*)
 	echo c1-convex-bsd
-	exit 0 ;;
+	exit ;;
     c2*)
 	fi
-	exit 0 ;;
+	exit ;;
     c34*)
 	echo c34-convex-bsd
-	exit 0 ;;
+	exit ;;
     c38*)
 	echo c38-convex-bsd
-	exit 0 ;;
+	exit ;;
     c4*)
 	echo c4-convex-bsd
-	exit 0 ;;
+	exit ;;
     esac
 fi
-#echo '(Unable to guess system type)' 1>&2
+cat >&2 <<EOF
+$0: unable to guess system type
+This script, last modified $timestamp, has failed to recognize
+the operating system you are using. It is advised that you
+download the most up to date version of the config scripts from
+  http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.guess
+and
+  http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.sub
+If the version you run ($0) is already up to date, please
+send the following data and any information you think might be
+pertinent to <config-patches at gnu.org> in order to provide the needed
+information to handle your system.
+config.guess timestamp = $timestamp
+uname -m = `(uname -m) 2>/dev/null || echo unknown`
+uname -r = `(uname -r) 2>/dev/null || echo unknown`
+uname -s = `(uname -s) 2>/dev/null || echo unknown`
+uname -v = `(uname -v) 2>/dev/null || echo unknown`
+/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null`
+/bin/uname -X     = `(/bin/uname -X) 2>/dev/null`
+hostinfo               = `(hostinfo) 2>/dev/null`
+/bin/universe          = `(/bin/universe) 2>/dev/null`
+/usr/bin/arch -k       = `(/usr/bin/arch -k) 2>/dev/null`
+/bin/arch              = `(/bin/arch) 2>/dev/null`
+/usr/bin/oslevel       = `(/usr/bin/oslevel) 2>/dev/null`
+/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null`
+UNAME_MACHINE = ${UNAME_MACHINE}
+UNAME_RELEASE = ${UNAME_RELEASE}
+UNAME_SYSTEM  = ${UNAME_SYSTEM}
+UNAME_VERSION = ${UNAME_VERSION}
+EOF
 exit 1
+# Local variables:
+# eval: (add-hook 'write-file-hooks 'time-stamp)
+# time-stamp-start: "timestamp='"
+# time-stamp-format: "%:y-%02m-%02d"
+# time-stamp-end: "'"
+# End:
Modified: branches/2.5/MgDev/Oem/gd/jpeg/config.sub
--- branches/2.5/MgDev/Oem/gd/jpeg/config.sub	2013-01-18 01:37:22 UTC (rev 7316)
+++ branches/2.5/MgDev/Oem/gd/jpeg/config.sub	2013-01-18 07:50:24 UTC (rev 7317)
@@ -1,6 +1,10 @@
 #! /bin/sh
-# Configuration validation subroutine script, version 1.1.
-#   Copyright (C) 1991, 92, 93, 94, 95, 96, 1997 Free Software Foundation, Inc.
+# Configuration validation subroutine script.
+timestamp='2005-07-08'
 # This file is (in principle) common to ALL GNU software.
 # The presence of a machine in this file suggests that SOME GNU software
 # can handle that machine.  It does not imply ALL GNU software can.
@@ -17,14 +21,18 @@
-# Boston, MA 02111-1307, USA.
+# 02110-1301, USA.
 # Configuration subroutine to validate and canonicalize a configuration type.
 # Supply the specified configuration type as an argument.
 # If it is invalid, we print an error message on stderr and exit with code 1.
@@ -45,30 +53,74 @@
 #	CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM
 # It is wrong to echo any other type of specification.
-if [ x$1 = x ]
-then
-	echo Configuration name missing. 1>&2
-	echo "Usage: $0 CPU-MFR-OPSYS" 1>&2
-	echo "or     $0 ALIAS" 1>&2
-	echo where ALIAS is a recognized configuration type. 1>&2
-	exit 1
-fi
-# First pass through any local machine types.
-case $1 in
-	*local*)
-		echo $1
-		exit 0
+usage="\
+Usage: $0 [OPTION] CPU-MFR-OPSYS
+       $0 [OPTION] ALIAS
+Canonicalize a configuration name.
+Operation modes:
+version="\
+GNU config.sub ($timestamp)
+help="
+  case $1 in
+    --version | -v )
+       shift; break ;;
+       break ;;
+       exit 1 ;;
+    *local*)
+       # First pass through any local machine types.
+       echo $1
+       exit ;;
+       break ;;
+  esac
+done
+case $# in
+ 0) echo "$me: missing argument$help" >&2
+    exit 1;;
+ 1) ;;
+ *) echo "$me: too many arguments$help" >&2
+    exit 1;;
 esac
 # Separate what the user gave into CPU-COMPANY and OS or KERNEL-OS (if any).
 # Here we must recognize all the valid KERNEL-OS combinations.
 maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
 case $maybe_os in
-  linux-gnu*)
+  nto-qnx* | linux-gnu* | linux-dietlibc | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | \
+  kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | storm-chaos* | os2-emx* | rtmk-nova*)
     os=-$maybe_os
     basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
@@ -94,15 +146,33 @@
 	-convergent* | -ncr* | -news | -32* | -3600* | -3100* | -hitachi* |\
 	-c[123]* | -convex* | -sun | -crds | -omron* | -dg | -ultra | -tti* | \
 	-harris | -dolphin | -highlevel | -gould | -cbm | -ns | -masscomp | \
-	-apple)
+	-apple | -axis | -knuth | -cray)
 		os=
 		basic_machine=$1
+	-sim | -cisco | -oki | -wec | -winbond)
+		os=
+		basic_machine=$1
+	-scout)
+	-wrs)
+		os=-vxworks
+		basic_machine=$1
+	-chorusos*)
+		os=-chorusos
+		basic_machine=$1
+ 	-chorusrdb)
+ 		os=-chorusrdb
+		basic_machine=$1
 	-hiux*)
 		os=-hiuxwe2
 	-sco5)
-		os=sco3.2v5
+		os=-sco3.2v5
 		basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
 	-sco4)
@@ -121,6 +191,9 @@
 		os=-sco3.2v2
+	-udk*)
+		basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
 	-isc)
 		os=-isc2.2
@@ -143,26 +216,81 @@
 	-psos*)
 		os=-psos
+	-mint | -mint[0-9]*)
+		basic_machine=m68k-atari
+		os=-mint
 esac
 # Decode aliases for certain CPU-COMPANY combinations.
 case $basic_machine in
 	# Recognize the basic CPU types without company name.
 	# Some are omitted here because they have special meanings below.
-	tahoe | i860 | m32r | m68k | m68000 | m88k | ns32k | arc | arm \
-		| arme[lb] | pyramid | mn10200 | mn10300 \
-		| tron | a29k | 580 | i960 | h8300 | hppa | hppa1.0 | hppa1.1 \
-		| alpha | alphaev5 | alphaev56 | we32k | ns16k | clipper \
-		| i370 | sh | powerpc | powerpcle | 1750a | dsp16xx | pdp11 \
-		| mips64 | mipsel | mips64el | mips64orion | mips64orionel \
-		| mipstx39 | mipstx39el \
-		| sparc | sparclet | sparclite | sparc64 | v850)
+	1750a | 580 \
+	| a29k \
+	| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
+	| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
+	| am33_2.0 \
+	| arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr \
+	| bfin \
+	| c4x | clipper \
+	| d10v | d30v | dlx | dsp16xx \
+	| fr30 | frv \
+	| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
+	| i370 | i860 | i960 | ia64 \
+	| ip2k | iq2000 \
+	| m32r | m32rle | m68000 | m68k | m88k | maxq | mcore \
+	| mips | mipsbe | mipseb | mipsel | mipsle \
+	| mips16 \
+	| mips64 | mips64el \
+	| mips64vr | mips64vrel \
+	| mips64orion | mips64orionel \
+	| mips64vr4100 | mips64vr4100el \
+	| mips64vr4300 | mips64vr4300el \
+	| mips64vr5000 | mips64vr5000el \
+	| mips64vr5900 | mips64vr5900el \
+	| mipsisa32 | mipsisa32el \
+	| mipsisa32r2 | mipsisa32r2el \
+	| mipsisa64 | mipsisa64el \
+	| mipsisa64r2 | mipsisa64r2el \
+	| mipsisa64sb1 | mipsisa64sb1el \
+	| mipsisa64sr71k | mipsisa64sr71kel \
+	| mipstx39 | mipstx39el \
+	| mn10200 | mn10300 \
+	| ms1 \
+	| msp430 \
+	| ns16k | ns32k \
+	| or32 \
+	| pdp10 | pdp11 | pj | pjl \
+	| powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
+	| pyramid \
+	| sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | shbe | shle | sh[1234]le | sh3ele \
+	| sh64 | sh64le \
+	| sparc | sparc64 | sparc64b | sparc86x | sparclet | sparclite \
+	| sparcv8 | sparcv9 | sparcv9b \
+	| strongarm \
+	| tahoe | thumb | tic4x | tic80 | tron \
+	| v850 | v850e \
+	| we32k \
+	| x86 | xscale | xscalee[bl] | xstormy16 | xtensa \
+	| z8k)
 		basic_machine=$basic_machine-unknown
+	m32c)
+		basic_machine=$basic_machine-unknown
+	m6811 | m68hc11 | m6812 | m68hc12)
+		# Motorola 68HC11/12.
+		os=-none
+	m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
 	# We use `pc' rather than `unknown'
 	# because (1) that's what they normally are, and
 	# (2) the word "unknown" tends to confuse beginning users.
-	i[3456]86)
+	i*86 | x86_64)
 	  basic_machine=$basic_machine-pc
 	# Object if more than one company name word.
@@ -171,27 +299,91 @@
 		exit 1
 	# Recognize the basic CPU types with company name.
-	vax-* | tahoe-* | i[3456]86-* | i860-* | m32r-* | m68k-* | m68000-* \
-	      | m88k-* | sparc-* | ns32k-* | fx80-* | arc-* | arm-* | c[123]* \
-	      | mips-* | pyramid-* | tron-* | a29k-* | romp-* | rs6000-* \
-	      | power-* | none-* | 580-* | cray2-* | h8300-* | i960-* \
-	      | xmp-* | ymp-* | hppa-* | hppa1.0-* | hppa1.1-* \
-	      | alpha-* | alphaev5-* | alphaev56-* | we32k-* | cydra-* \
-	      | ns16k-* | pn-* | np1-* | xps100-* | clipper-* | orion-* \
-	      | sparclite-* | pdp11-* | sh-* | powerpc-* | powerpcle-* \
-	      | sparc64-* | mips64-* | mipsel-* \
-	      | mips64el-* | mips64orion-* | mips64orionel-*  \
-	      | mipstx39-* | mipstx39el-* \
-	      | f301-*)
+	580-* \
+	| a29k-* \
+	| alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
+	| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
+	| alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
+	| arm-*  | armbe-* | armle-* | armeb-* | armv*-* \
+	| avr-* \
+	| bfin-* | bs2000-* \
+	| c[123]* | c30-* | [cjt]90-* | c4x-* | c54x-* | c55x-* | c6x-* \
+	| clipper-* | craynv-* | cydra-* \
+	| d10v-* | d30v-* | dlx-* \
+	| elxsi-* \
+	| f30[01]-* | f700-* | fr30-* | frv-* | fx80-* \
+	| h8300-* | h8500-* \
+	| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
+	| i*86-* | i860-* | i960-* | ia64-* \
+	| ip2k-* | iq2000-* \
+	| m32r-* | m32rle-* \
+	| m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
+	| m88110-* | m88k-* | maxq-* | mcore-* \
+	| mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
+	| mips16-* \
+	| mips64-* | mips64el-* \
+	| mips64vr-* | mips64vrel-* \
+	| mips64orion-* | mips64orionel-* \
+	| mips64vr4100-* | mips64vr4100el-* \
+	| mips64vr4300-* | mips64vr4300el-* \
+	| mips64vr5000-* | mips64vr5000el-* \
+	| mips64vr5900-* | mips64vr5900el-* \
+	| mipsisa32-* | mipsisa32el-* \
+	| mipsisa32r2-* | mipsisa32r2el-* \
+	| mipsisa64-* | mipsisa64el-* \
+	| mipsisa64r2-* | mipsisa64r2el-* \
+	| mipsisa64sb1-* | mipsisa64sb1el-* \
+	| mipsisa64sr71k-* | mipsisa64sr71kel-* \
+	| mipstx39-* | mipstx39el-* \
+	| mmix-* \
+	| ms1-* \
+	| msp430-* \
+	| none-* | np1-* | ns16k-* | ns32k-* \
+	| orion-* \
+	| pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
+	| powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
+	| pyramid-* \
+	| romp-* | rs6000-* \
+	| sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | shbe-* \
+	| shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
+	| sparc-* | sparc64-* | sparc64b-* | sparc86x-* | sparclet-* \
+	| sparclite-* \
+	| sparcv8-* | sparcv9-* | sparcv9b-* | strongarm-* | sv1-* | sx?-* \
+	| tahoe-* | thumb-* \
+	| tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* \
+	| tron-* \
+	| v850-* | v850e-* | vax-* \
+	| we32k-* \
+	| x86-* | x86_64-* | xps100-* | xscale-* | xscalee[bl]-* \
+	| xstormy16-* | xtensa-* \
+	| ymp-* \
+	| z8k-*)
+	m32c-*)
 	# Recognize the various machine names and aliases which stand
 	# for a CPU type and a company and sometimes even an OS.
+	386bsd)
+		basic_machine=i386-unknown
+		os=-bsd
 	3b1 | 7300 | 7300-att | att-7300 | pc7300 | safari | unixpc)
 		basic_machine=m68000-att
 	3b*)
 		basic_machine=we32k-att
+	a29khif)
+		basic_machine=a29k-amd
+		os=-udi
+    	abacus)
+		basic_machine=abacus-unknown
+	adobe68k)
+		basic_machine=m68010-adobe
+		os=-scout
 	alliant | fx80)
 		basic_machine=fx80-alliant
@@ -202,25 +394,35 @@
 		basic_machine=a29k-none
 		os=-bsd
+	amd64)
+		basic_machine=x86_64-pc
+	amd64-*)
+		basic_machine=x86_64-`echo $basic_machine | sed 's/^[^-]*-//'`
 	amdahl)
 		basic_machine=580-amdahl
 		os=-sysv
 	amiga | amiga-*)
-		basic_machine=m68k-cbm
+		basic_machine=m68k-unknown
 	amigaos | amigados)
 		os=-amigaos
 	amigaunix | amix)
 		os=-sysv4
 	apollo68)
 		basic_machine=m68k-apollo
 		os=-sysv
+	apollo68bsd)
+		basic_machine=m68k-apollo
+		os=-bsd
 	aux)
 		basic_machine=m68k-apple
 		os=-aux
@@ -229,6 +431,10 @@
 		basic_machine=ns32k-sequent
 		os=-dynix
+	c90)
+		basic_machine=c90-cray
+		os=-unicos
 	convex-c1)
 		basic_machine=c1-convex
 		os=-bsd
@@ -249,27 +455,45 @@
 		basic_machine=c38-convex
 		os=-bsd
-	cray | ymp)
-		basic_machine=ymp-cray
+	cray | j90)
+		basic_machine=j90-cray
 		os=-unicos
-	cray2)
-		basic_machine=cray2-cray
-		os=-unicos
+	craynv)
+		basic_machine=craynv-cray
+		os=-unicosmp
-	[ctj]90-cray)
-		basic_machine=c90-cray
-		os=-unicos
+	cr16c)
+		basic_machine=cr16c-unknown
+		os=-elf
 	crds | unos)
 		basic_machine=m68k-crds
+	crisv32 | crisv32-* | etraxfs*)
+		basic_machine=crisv32-axis
+	cris | cris-* | etrax*)
+		basic_machine=cris-axis
+	crx)
+		basic_machine=crx-unknown
+		os=-elf
 	da30 | da30-*)
 		basic_machine=m68k-da30
 	decstation | decstation-3100 | pmax | pmax-* | pmin | dec3100 | decstatn)
 		basic_machine=mips-dec
+	decsystem10* | dec10*)
+		basic_machine=pdp10-dec
+		os=-tops10
+	decsystem20* | dec20*)
+		os=-tops20
 	delta | 3300 | motorola-3300 | motorola-delta \
 	      | 3300-motorola | delta-motorola)
 		basic_machine=m68k-motorola
@@ -278,6 +502,10 @@
 		basic_machine=m88k-motorola
 		os=-sysv3
+	djgpp)
+		basic_machine=i586-pc
+		os=-msdosdjgpp
 	dpx20 | dpx20-*)
 		basic_machine=rs6000-bull
 		os=-bosx
@@ -297,6 +525,10 @@
 	encore | umax | mmax)
 		basic_machine=ns32k-encore
+	es1800 | OSE68k | ose68k | ose | OSE)
+		basic_machine=m68k-ericsson
+		os=-ose
 	fx2800)
 		basic_machine=i860-alliant
@@ -307,6 +539,10 @@
 		basic_machine=tron-gmicro
 		os=-sysv
+	go32)
+		basic_machine=i386-pc
+		os=-go32
 	h3050r* | hiux*)
 		basic_machine=hppa1.1-hitachi
 		os=-hiuxwe2
@@ -315,6 +551,14 @@
 		basic_machine=h8300-hitachi
 		os=-hms
+	h8300xray)
+		basic_machine=h8300-hitachi
+		os=-xray
+	h8500hms)
+		basic_machine=h8500-hitachi
+		os=-hms
 	harris)
 		basic_machine=m88k-harris
 		os=-sysv3
@@ -330,42 +574,74 @@
 		basic_machine=m68k-hp
 		os=-hpux
+	hp3k9[0-9][0-9] | hp9[0-9][0-9])
+		basic_machine=hppa1.0-hp
 	hp9k2[0-9][0-9] | hp9k31[0-9])
 		basic_machine=m68000-hp
 	hp9k3[2-9][0-9])
-	hp9k7[0-9][0-9] | hp7[0-9][0-9] | hp9k8[0-9]7 | hp8[0-9]7)
+	hp9k6[0-9][0-9] | hp6[0-9][0-9])
+	hp9k7[0-79][0-9] | hp7[0-79][0-9])
 		basic_machine=hppa1.1-hp
+	hp9k78[0-9] | hp78[0-9])
+		# FIXME: really hppa2.0-hp
+		basic_machine=hppa1.1-hp
+	hp9k8[67]1 | hp8[67]1 | hp9k80[24] | hp80[24] | hp9k8[78]9 | hp8[78]9 | hp9k893 | hp893)
+	hp9k8[0-9][13679] | hp8[0-9][13679])
 	hp9k8[0-9][0-9] | hp8[0-9][0-9])
 	hppa-next)
 		os=-nextstep3
+	hppaosf)
+		os=-osf
+	hppro)
+		os=-proelf
 	i370-ibm* | ibm*)
 		basic_machine=i370-ibm
-		os=-mvs
 # I'm not sure what "Sysv32" means.  Should this be sysv3.2?
-	i[3456]86v32)
+	i*86v32)
 		basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
 		os=-sysv32
-	i[3456]86v4*)
+	i*86v4*)
 		os=-sysv4
-	i[3456]86v)
+	i*86v)
 		os=-sysv
-	i[3456]86sol2)
+	i*86sol2)
 		os=-solaris2
+	i386mach)
+		basic_machine=i386-mach
+		os=-mach
+	i386-vsta | vsta)
+		os=-vsta
 	iris | iris4d)
 		basic_machine=mips-sgi
 		case $os in
@@ -391,27 +667,51 @@
 		basic_machine=ns32k-utek
 		os=-sysv
+	mingw32)
+		os=-mingw32
 	miniframe)
 		basic_machine=m68000-convergent
-	mipsel*-linux*)
-		basic_machine=mipsel-unknown
-		os=-linux-gnu
+	*mint | -mint[0-9]* | *MiNT | *MiNT[0-9]*)
+		os=-mint
-	mips*-linux*)
-		basic_machine=mips-unknown
-		os=-linux-gnu
 	mips3*-*)
 		basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`
 	mips3*)
 		basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`-unknown
+	monitor)
+		basic_machine=m68k-rom68k
+		os=-coff
+	morphos)
+		basic_machine=powerpc-unknown
+		os=-morphos
+	msdos)
+		os=-msdos
+	mvs)
+		basic_machine=i370-ibm
+		os=-mvs
 	ncr3000)
 		basic_machine=i486-ncr
 		os=-sysv4
+	netbsd386)
+		os=-netbsd
+	netwinder)
+		basic_machine=armv4l-rebel
+		os=-linux
 	news | news700 | news800 | news900)
 		basic_machine=m68k-sony
 		os=-newsos
@@ -424,6 +724,10 @@
 		basic_machine=mips-sony
 		os=-newsos
+	necv70)
+		basic_machine=v70-nec
+		os=-sysv
 	next | m*-next )
 		basic_machine=m68k-next
 		case $os in
@@ -449,9 +753,39 @@
 		basic_machine=i960-intel
 		os=-nindy
+	mon960)
+		basic_machine=i960-intel
+		os=-mon960
+	nonstopux)
+		basic_machine=mips-compaq
+		os=-nonstopux
 	np1)
 		basic_machine=np1-gould
+	nsr-tandem)
+		basic_machine=nsr-tandem
+	op50n-* | op60c-*)
+		basic_machine=hppa1.1-oki
+		os=-proelf
+	openrisc | openrisc-*)
+		basic_machine=or32-unknown
+	os400)
+		basic_machine=powerpc-ibm
+		os=-os400
+	OSE68000 | ose68000)
+		basic_machine=m68000-ericsson
+		os=-ose
+	os68k)
+		basic_machine=m68k-none
+		os=-os68k
 	pa-hitachi)
 		os=-hiuxwe2
@@ -466,53 +800,95 @@
 	pbb)
 		basic_machine=m68k-tti
-        pc532 | pc532-*)
+	pc532 | pc532-*)
 		basic_machine=ns32k-pc532
-	pentium | p5)
-		basic_machine=i586-intel
+	pentium | p5 | k5 | k6 | nexgen | viac3)
-	pentiumpro | p6)
-		basic_machine=i686-intel
+	pentiumpro | p6 | 6x86 | athlon | athlon_*)
+		basic_machine=i686-pc
-	pentium-* | p5-*)
+	pentiumii | pentium2 | pentiumiii | pentium3)
+	pentium4)
+		basic_machine=i786-pc
+	pentium-* | p5-* | k5-* | k6-* | nexgen-* | viac3-*)
 		basic_machine=i586-`echo $basic_machine | sed 's/^[^-]*-//'`
-	pentiumpro-* | p6-*)
+	pentiumpro-* | p6-* | 6x86-* | athlon-*)
 		basic_machine=i686-`echo $basic_machine | sed 's/^[^-]*-//'`
-	k5)
-		# We don't have specific support for AMD's K5 yet, so just call it a Pentium
-		basic_machine=i586-amd
+	pentiumii-* | pentium2-* | pentiumiii-* | pentium3-*)
+		basic_machine=i686-`echo $basic_machine | sed 's/^[^-]*-//'`
-	nexen)
-		# We don't have specific support for Nexgen yet, so just call it a Pentium
-		basic_machine=i586-nexgen
+	pentium4-*)
+		basic_machine=i786-`echo $basic_machine | sed 's/^[^-]*-//'`
 	pn)
 		basic_machine=pn-gould
-	power)	basic_machine=rs6000-ibm
+	power)	basic_machine=power-ibm
 	ppc)	basic_machine=powerpc-unknown
 	ppc-*)	basic_machine=powerpc-`echo $basic_machine | sed 's/^[^-]*-//'`
 	ppcle | powerpclittle | ppc-le | powerpc-little)
 		basic_machine=powerpcle-unknown
 	ppcle-* | powerpclittle-*)
 		basic_machine=powerpcle-`echo $basic_machine | sed 's/^[^-]*-//'`
+	ppc64)	basic_machine=powerpc64-unknown
+	ppc64-*) basic_machine=powerpc64-`echo $basic_machine | sed 's/^[^-]*-//'`
+	ppc64le | powerpc64little | ppc64-le | powerpc64-little)
+		basic_machine=powerpc64le-unknown
+	ppc64le-* | powerpc64little-*)
+		basic_machine=powerpc64le-`echo $basic_machine | sed 's/^[^-]*-//'`
 	ps2)
 		basic_machine=i386-ibm
+	pw32)
+		basic_machine=i586-unknown
+		os=-pw32
+	rom68k)
+		os=-coff
 	rm[46]00)
 		basic_machine=mips-siemens
 	rtpc | rtpc-*)
 		basic_machine=romp-ibm
+	s390 | s390-*)
+		basic_machine=s390-ibm
+	s390x | s390x-*)
+		basic_machine=s390x-ibm
+	sa29200)
+		os=-udi
+	sb1)
+		basic_machine=mipsisa64sb1-unknown
+	sb1el)
+		basic_machine=mipsisa64sb1el-unknown
+	sei)
+		basic_machine=mips-sei
+		os=-seiux
 	sequent)
 		basic_machine=i386-sequent
@@ -520,6 +896,13 @@
 		basic_machine=sh-hitachi
 		os=-hms
+	sh64)
+		basic_machine=sh64-unknown
+	sparclite-wrs | simso-wrs)
+		basic_machine=sparclite-wrs
+		os=-vxworks
 	sps7)
 		basic_machine=m68k-bull
 		os=-sysv2
@@ -527,6 +910,13 @@
 	spur)
 		basic_machine=spur-unknown
+	st2000)
+		basic_machine=m68k-tandem
+	stratus)
+		basic_machine=i860-stratus
+		os=-sysv4
 	sun2)
 		basic_machine=m68000-sun
@@ -567,19 +957,51 @@
 	sun386 | sun386i | roadrunner)
 		basic_machine=i386-sun
+	sv1)
+		basic_machine=sv1-cray
+		os=-unicos
 	symmetry)
 		os=-dynix
+	t3e)
+		basic_machine=alphaev5-cray
+		os=-unicos
+	t90)
+		basic_machine=t90-cray
+		os=-unicos
+	tic54x | c54x*)
+		basic_machine=tic54x-unknown
+		os=-coff
+	tic55x | c55x*)
+		basic_machine=tic55x-unknown
+		os=-coff
+	tic6x | c6x*)
+		basic_machine=tic6x-unknown
+		os=-coff
 	tx39)
 		basic_machine=mipstx39-unknown
 	tx39el)
 		basic_machine=mipstx39el-unknown
+	toad1)
+		basic_machine=pdp10-xkl
+		os=-tops20
 	tower | tower-32)
 		basic_machine=m68k-ncr
+	tpf)
+		os=-tpf
 	udi29k)
 		os=-udi
@@ -588,6 +1010,10 @@
 		basic_machine=a29k-nyu
 		os=-sym1
+	v810 | necv810)
+		basic_machine=v810-nec
+		os=-none
 	vaxv)
 		basic_machine=vax-dec
 		os=-sysv
@@ -597,8 +1023,8 @@
 		os=-vms
 	vpp*|vx|vx-*)
-               basic_machine=f301-fujitsu
+		basic_machine=f301-fujitsu
 	vxworks960)
 		basic_machine=i960-wrs
 		os=-vxworks
@@ -611,13 +1037,29 @@
 		basic_machine=a29k-wrs
 		os=-vxworks
-	xmp)
-		basic_machine=xmp-cray
-		os=-unicos
+	w65*)
+		basic_machine=w65-wdc
+		os=-none
-        xps | xps100)
+	w89k-*)
+		basic_machine=hppa1.1-winbond
+		os=-proelf
+	xbox)
+		os=-mingw32
+	xps | xps100)
 		basic_machine=xps100-honeywell
+	ymp)
+		basic_machine=ymp-cray
+		os=-unicos
+	z8k-*-coff)
+		basic_machine=z8k-unknown
+		os=-sim
 	none)
 		basic_machine=none-none
 		os=-none
@@ -625,32 +1067,44 @@
 # Here we handle the default manufacturer of certain CPU types.  It is in
 # some cases the only manufacturer, in others, it is the most popular.
-	mips)
-		if [ x$os = x-linux-gnu ]; then
-		else
-			basic_machine=mips-mips
-		fi
+	w89k)
+	op50n)
+	op60c)
 	romp)
+	mmix)
+		basic_machine=mmix-knuth
 	rs6000)
 	vax)
+	pdp10)
+		# there are many clones, so DEC is not a safe bet
+		basic_machine=pdp10-unknown
 	pdp11)
 		basic_machine=pdp11-dec
 	we32k)
-	sparc)
+	sh[1234] | sh[24]a | sh[34]eb | sh[1234]le | sh[23]ele)
+		basic_machine=sh-unknown
+	sparc | sparcv8 | sparcv9 | sparcv9b)
 		basic_machine=sparc-sun
-        cydra)
+	cydra)
 		basic_machine=cydra-cydrome
 	orion)
@@ -659,6 +1113,15 @@
 	orion105)
 		basic_machine=clipper-highlevel
+	mac | mpw | mac-mpw)
+		basic_machine=m68k-apple
+	pmac | pmac-mpw)
+		basic_machine=powerpc-apple
+	*-unknown)
+		# Make sure to match an already-canonicalized machine name.
 		echo Invalid configuration \`$1\': machine \`$basic_machine\' not recognized 1>&2
 		exit 1
@@ -711,14 +1174,47 @@
 	      | -aos* \
 	      | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
 	      | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
-	      | -hiux* | -386bsd* | -netbsd* | -openbsd* | -freebsd* | -riscix* \
-	      | -lynxos* | -bosx* | -nextstep* | -cxux* | -aout* | -elf* \
+	      | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* | -openbsd* \
+	      | -ekkobsd* | -kfreebsd* | -freebsd* | -riscix* | -lynxos* \
+	      | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
 	      | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
 	      | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
-	      | -cygwin32* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
-	      | -mingw32* | -linux-gnu* | -uxpv*)
+	      | -chorusos* | -chorusrdb* \
+	      | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
+	      | -mingw32* | -linux-gnu* | -linux-uclibc* | -uxpv* | -beos* | -mpeix* | -udk* \
+	      | -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
+	      | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
+	      | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
+	      | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
+	      | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
+	      | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
+	      | -skyos* | -haiku*)
 	# Remember, each alternative MUST END IN *, to match a version number.
+	-qnx*)
+		case $basic_machine in
+		    x86-* | i*86-*)
+			os=-nto$os
+		esac
+	-nto-qnx*)
+	-nto*)
+		os=`echo $os | sed -e 's|nto|nto-qnx|'`
+	-sim | -es1800* | -hms* | -xray | -os68k* | -none* | -v88r* \
+	      | -windows* | -osx | -abug | -netware* | -os9* | -beos* | -haiku* \
+	      | -macos* | -mpw* | -magic* | -mmixware* | -mon960* | -lnews*)
+	-mac*)
+		os=`echo $os | sed -e 's|mac|macos|'`
+	-linux-dietlibc)
+		os=-linux-dietlibc
 	-linux*)
 		os=`echo $os | sed -e 's|linux|linux-gnu|'`
@@ -728,6 +1224,15 @@
 	-sunos6*)
 		os=`echo $os | sed -e 's|sunos6|solaris3|'`
+	-opened*)
+		os=-openedition
+        -os400*)
+		os=-os400
+	-wince*)
+		os=-wince
 	-osfrose*)
 		os=-osfrose
@@ -743,12 +1248,27 @@
 	-acis*)
 		os=-aos
+	-atheos*)
+		os=-atheos
+	-syllable*)
+		os=-syllable
+	-386bsd)
+		os=-bsd
 	-ctix* | -uts*)
 		os=-sysv
+	-nova*)
+		os=-rtmk-nova
 	-ns2 )
-	        os=-nextstep2
+		os=-nextstep2
+	-nsk*)
+		os=-nsk
 	# Preserve the version number of sinix5.
 	-sinix5.*)
 		os=`echo $os | sed -e 's|sinix|sysv|'`
@@ -756,6 +1276,9 @@
 	-sinix*)
 		os=-sysv4
+        -tpf*)
+		os=-tpf
 	-triton*)
 		os=-sysv3
@@ -774,9 +1297,27 @@
 	# This must come after -sysvr4.
 	-sysv*)
+	-ose*)
+		os=-ose
+	-es1800*)
+		os=-ose
 	-xenix)
 		os=-xenix
+	-*mint | -mint[0-9]* | -*MiNT | -MiNT[0-9]*)
+		os=-mint
+	-aros*)
+		os=-aros
+	-kaos*)
+		os=-kaos
+	-zvmoe)
+		os=-zvmoe
 	-none)
@@ -802,10 +1343,20 @@
 	*-acorn)
 		os=-riscix1.2
+	arm*-rebel)
+		os=-linux
 	arm*-semi)
 		os=-aout
-        pdp11-*)
+    c4x-* | tic4x-*)
+        os=-coff
+	# This must come before the *-dec entry.
+	pdp10-*)
+		os=-tops20
+	pdp11-*)
 		os=-none
 	*-dec | vax-*)
@@ -823,15 +1374,45 @@
 		# default.
 		# os=-sunos4
+	m68*-cisco)
+		os=-aout
+	mips*-cisco)
+		os=-elf
+	mips*-*)
+		os=-elf
+	or32-*)
+		os=-coff
 	*-tti)	# must be before sparc entry or we get the wrong os.
 		os=-sysv3
 	sparc-* | *-sun)
 		os=-sunos4.1.1
+	*-be)
+		os=-beos
+	*-haiku)
+		os=-haiku
 	*-ibm)
 		os=-aix
+    	*-knuth)
+		os=-mmixware
+	*-wec)
+		os=-proelf
+	*-winbond)
+		os=-proelf
+	*-oki)
+		os=-proelf
 	*-hp)
 		os=-hpux
@@ -874,27 +1455,39 @@
 	*-next)
 		os=-nextstep3
-        *-gould)
+	*-gould)
 		os=-sysv
-        *-highlevel)
+	*-highlevel)
 		os=-bsd
 	*-encore)
 		os=-bsd
-        *-sgi)
+	*-sgi)
 		os=-irix
-        *-siemens)
+	*-siemens)
 		os=-sysv4
 	*-masscomp)
 		os=-rtu
-	f301-fujitsu)
+	f30[01]-fujitsu | f700-fujitsu)
 		os=-uxpv
+	*-rom68k)
+		os=-coff
+	*-*bug)
+		os=-coff
+	*-apple)
+		os=-macos
+	*-atari*)
+		os=-mint
 		os=-none
@@ -916,9 +1509,15 @@
 			-aix*)
 				vendor=ibm
+			-beos*)
+				vendor=be
 			-hpux*)
 				vendor=hp
+			-mpeix*)
+				vendor=hp
 			-hiux*)
 				vendor=hitachi
@@ -934,21 +1533,48 @@
 			-genix*)
 				vendor=ns
-			-mvs*)
+			-mvs* | -opened*)
 				vendor=ibm
+			-os400*)
+				vendor=ibm
 			-ptx*)
 				vendor=sequent
-			-vxsim* | -vxworks*)
+			-tpf*)
+				vendor=ibm
+			-vxsim* | -vxworks* | -windiss*)
 				vendor=wrs
 			-aux*)
 				vendor=apple
+			-hms*)
+				vendor=hitachi
+			-mpw* | -macos*)
+				vendor=apple
+				vendor=atari
+			-vos*)
+				vendor=stratus
 		esac
 		basic_machine=`echo $basic_machine | sed "s/unknown/$vendor/"`
 esac
 echo $basic_machine$os
+exit
+# Local variables:
+# End:
More information about the mapguide-commits mailing list
