[mapguide-commits] r7324 - branches/2.5/Installer/scripts
svn_mapguide at osgeo.org
Sun Jan 20 04:57:47 PST 2013
Author: jng
Date: 2013-01-20 04:57:46 -0800 (Sun, 20 Jan 2013)
New Revision: 7324
branches/2.5/Installer/scripts/build_oem_ubuntu.sh
#1657: Update build_oem_ubuntu.sh to handle 64-bit compilation of the Oem tree
Modified: branches/2.5/Installer/scripts/build_oem_ubuntu.sh
--- branches/2.5/Installer/scripts/build_oem_ubuntu.sh 2013-01-20 12:48:56 UTC (rev 7323)
+++ branches/2.5/Installer/scripts/build_oem_ubuntu.sh 2013-01-20 12:57:46 UTC (rev 7324)
@@ -11,7 +11,7 @@
echo "MapGuide Open Source build script for OEM components"
-INSTALLDIR=/usr/local/mapguideopensource-2.4.0
+INSTALLDIR=/usr/local/mapguideopensource-2.5.0
MY_MAKE_OPTS="-j 4"
CLEAN_FLAG=0
while [ $# -gt 0 ]; do # Until you run out of parameters...
@@ -203,7 +203,11 @@
libtoolize --copy --force
autoconf
automake --add-missing --copy --force-missing
- sh ./configure --prefix="${INSTALLDIR}"
+ if [ $(uname -m) = "x86_64" ]; then
+ sh ./configure --with-pic --prefix="${INSTALLDIR}"
+ else
+ sh ./configure --prefix="${INSTALLDIR}"
+ fi
make $MY_MAKE_OPTS
# The check build is disabled as the build will fail with automake version < 2.59
# check_build
@@ -410,7 +414,13 @@
pushd gd/lpng
cp scripts/makefile.std makefile
- make $MY_MAKE_OPTS
+ #Inject -fPIC to CFLAGS for 64-bit
+ sed 's/^CFLAGS=/CFLAGS= -fPIC /g' makefile > makefile64
+ make -fmakefile64 $MY_MAKE_OPTS
+ else
+ make $MY_MAKE_OPTS
+ fi
check_build
popd
@@ -436,8 +446,16 @@
build_jpeg()
pushd gd/jpeg
- sh ./configure --enable-static --disable-shared
+ sh ./configure --enable-static --disable-shared
+ #--with-pic does nothing (probably ancient configure script), so do some sed trickery
+ #to inject this flag. Know a better way? Enlighten us :)
+ sed 's/^CFLAGS=/CFLAGS= -fPIC/g' Makefile > Makefile64
+ make -fMakefile64 $MY_MAKE_OPTS
+ else
+ fi
check_build
popd
@@ -463,7 +481,11 @@
build_freetype()
pushd gd/freetype
+ sh ./configure --enable-static --disable-shared --with-pic
+ else
+ fi
make $MY_MAKE_OPTS
check_build
popd
@@ -490,7 +512,11 @@
build_gd()
pushd gd/gd
- sh ./configure --enable-static --disable-shared --without-fontconfig
+ sh ./configure --enable-static --disable-shared --without-fontconfig --with-pic
+ else
+ fi
make $MY_MAKE_OPTS
check_build
popd
@@ -517,7 +543,11 @@
build_agg()
pushd agg-2.4
+ make $MY_MAKE_OPTS EXTRACXXFLAGS=-fPIC
+ else
+ fi
check_build
popd
@@ -570,11 +600,23 @@
pushd CsMap
mkdir -p .libs
pushd Source
- make -fLibrary.mak $MY_MAKE_OPTS
+ #Need to build CS-Map with -fPIC because linking libraries will be built with -fPIC
+ sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Library64.mak
+ make -fLibrary64.mak $MY_MAKE_OPTS
+ else
+ make -fLibrary.mak $MY_MAKE_OPTS
+ fi
cp CsMap.a ../.libs/libCsmap.a
popd
pushd Dictionaries
- make -fCompiler.mak $MY_MAKE_OPTS
+ if [ $(uname -m) = "x86_x64" ]; then
+ sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Compiler64.mak
+ make -fCompiler64.mak $MY_MAKE_OPTS
+ else
+ make -fCompiler.mak $MY_MAKE_OPTS
+ fi
./CS_Comp -b . .
popd
check_build
More information about the mapguide-commits
