[mapguide-commits] r7679 - in branches/maestro-4.0.x/Maestro.Editors: . FeatureSource FeatureSource/Extensions MapDefinition
svn_mapguide at osgeo.org
Tue Jul 9 06:14:53 PDT 2013
Author: jng
Date: 2013-07-09 06:14:52 -0700 (Tue, 09 Jul 2013)
New Revision: 7679
branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.Designer.cs
branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.cs
branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.resx
branches/maestro-4.0.x/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs
branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs
branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs
branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.resx
branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
branches/maestro-4.0.x/Maestro.Editors/Strings.Designer.cs
branches/maestro-4.0.x/Maestro.Editors/Strings.resx
#2290, #2299: Merge to 4.0.x
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.Designer.cs 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.Designer.cs 2013-07-09 13:14:52 UTC (rev 7679)
@@ -28,11 +28,14 @@
/// </summary>
private void InitializeComponent()
+ this.components = new System.ComponentModel.Container();
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ExtendedClassSettings));
this.label1 = new System.Windows.Forms.Label();
this.txtExtendedName = new System.Windows.Forms.TextBox();
this.label2 = new System.Windows.Forms.Label();
this.cmbBaseClass = new System.Windows.Forms.ComboBox();
+ this.errorProvider = new System.Windows.Forms.ErrorProvider(this.components);
+ ((System.ComponentModel.ISupportInitialize)(this.errorProvider)).BeginInit();
this.SuspendLayout();
// label1
@@ -44,6 +47,7 @@
resources.ApplyResources(this.txtExtendedName, "txtExtendedName");
this.txtExtendedName.Name = "txtExtendedName";
+ this.txtExtendedName.TextChanged += new System.EventHandler(this.txtExtendedName_TextChanged);
// label2
@@ -57,6 +61,10 @@
this.cmbBaseClass.FormattingEnabled = true;
this.cmbBaseClass.Name = "cmbBaseClass";
+ // errorProvider
+ this.errorProvider.ContainerControl = this;
// ExtendedClassSettings
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
@@ -66,6 +74,7 @@
this.Controls.Add(this.label1);
this.Name = "ExtendedClassSettings";
resources.ApplyResources(this, "$this");
+ ((System.ComponentModel.ISupportInitialize)(this.errorProvider)).EndInit();
this.ResumeLayout(false);
this.PerformLayout();
@@ -77,5 +86,6 @@
private System.Windows.Forms.TextBox txtExtendedName;
private System.Windows.Forms.Label label2;
private System.Windows.Forms.ComboBox cmbBaseClass;
+ private System.Windows.Forms.ErrorProvider errorProvider;
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.cs
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.cs 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.cs 2013-07-09 13:14:52 UTC (rev 7679)
@@ -39,28 +39,27 @@
InitializeComponent();
- public ExtendedClassSettings(IEnumerable<ClassDefinition> classes, IFeatureSourceExtension ext)
+ private IFeatureSourceExtension _ext;
+ private IFeatureSource _fs;
+ public ExtendedClassSettings(IEnumerable<ClassDefinition> classes, IFeatureSource fs, IFeatureSourceExtension ext)
: this()
+ _ext = ext;
+ _fs = fs;
var klasses = new List<ClassDefinition>(classes);
cmbBaseClass.DisplayMember = "QualifiedName";
cmbBaseClass.ValueMember = "QualifiedName";
cmbBaseClass.DataSource = klasses;
- ext.PropertyChanged += (sender, e) => { OnResourceChanged(); };
+ _ext.PropertyChanged += (sender, e) => { OnResourceChanged(); };
//HACK
- if (string.IsNullOrEmpty(ext.FeatureClass))
- ext.FeatureClass = klasses[0].QualifiedName;
- TextBoxBinder.BindText(txtExtendedName, ext, "Name");
+ if (string.IsNullOrEmpty(_ext.FeatureClass))
+ _ext.FeatureClass = klasses[0].QualifiedName;
ComboBoxBinder.BindSelectedIndexChanged(cmbBaseClass, "SelectedValue", ext, "FeatureClass");
- //private void txtExtendedName_TextChanged(object sender, EventArgs e)
- // txtExtendedName.DataBindings[0].WriteValue();
public void Bind(IEditorService service)
service.RegisterCustomNotifier(this);
@@ -74,5 +73,31 @@
public event EventHandler ResourceChanged;
+ private int GetExtensionCount(string name)
+ int count = 0;
+ foreach (var ext in _fs.Extension)
+ if (ext.Name == name)
+ count++;
+ return count;
+ private void txtExtendedName_TextChanged(object sender, EventArgs e)
+ //Before we apply, check if the new name matches any existing feature classes
+ string newName = txtExtendedName.Text;
+ if (GetExtensionCount(newName) > 0)
+ errorProvider.SetError(txtExtendedName, string.Format("Extended Feature Class ({0}) already exists. Choose a different name", newName));
+ else
+ errorProvider.Clear();
+ _ext.Name = txtExtendedName.Text;
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.resx
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.resx 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.resx 2013-07-09 13:14:52 UTC (rev 7679)
@@ -154,7 +154,7 @@
<value>17, 32</value>
</data>
<data name="txtExtendedName.Size" type="System.Drawing.Size, System.Drawing">
- <value>289, 20</value>
+ <value>282, 20</value>
</data>
<data name="txtExtendedName.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -205,7 +205,7 @@
<value>17, 89</value>
</data>
<data name="cmbBaseClass.Size" type="System.Drawing.Size, System.Drawing">
- <value>289, 21</value>
+ <value>282, 21</value>
</data>
<data name="cmbBaseClass.TabIndex" type="System.Int32, mscorlib">
<value>3</value>
@@ -222,12 +222,21 @@
<data name=">>cmbBaseClass.ZOrder" xml:space="preserve">
<value>0</value>
</data>
+ <metadata name="errorProvider.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
<value>327, 212</value>
</data>
+ <data name=">>errorProvider.Name" xml:space="preserve">
+ <value>errorProvider</value>
+ </data>
+ <data name=">>errorProvider.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ErrorProvider, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
<data name=">>$this.Name" xml:space="preserve">
<value>ExtendedClassSettings</value>
</data>
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs 2013-07-09 13:14:52 UTC (rev 7679)
@@ -327,7 +327,7 @@
var calc = e.Node.Tag as ICalculatedProperty;
if (ext != null)
- var ctl = new ExtendedClassSettings(CachedSchema().AllClasses, ext);
+ var ctl = new ExtendedClassSettings(CachedSchema().AllClasses, _fs, ext);
ctl.Dock = DockStyle.Fill;
//If editing to something valid, update the toolbar
ctl.ResourceChanged += (s, evt) =>
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs 2013-07-09 13:14:52 UTC (rev 7679)
@@ -28,6 +28,7 @@
/// </summary>
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(GroupPropertiesCtrl));
this.groupBox1 = new System.Windows.Forms.GroupBox();
this.chkExpanded = new System.Windows.Forms.CheckBox();
@@ -37,7 +38,9 @@
this.txtName = new System.Windows.Forms.TextBox();
this.groupBox1.SuspendLayout();
// groupBox1
@@ -80,6 +83,7 @@
resources.ApplyResources(this.txtName, "txtName");
this.txtName.Name = "txtName";
+ this.txtName.TextChanged += new System.EventHandler(this.txtName_TextChanged);
// label2
@@ -91,6 +95,10 @@
resources.ApplyResources(this.label1, "label1");
this.label1.Name = "label1";
+ // errorProvider
// GroupPropertiesCtrl
@@ -99,6 +107,7 @@
this.groupBox1.ResumeLayout(false);
this.groupBox1.PerformLayout();
@@ -113,5 +122,6 @@
private System.Windows.Forms.TextBox txtName;
private System.Windows.Forms.Label label1;
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs 2013-07-09 13:14:52 UTC (rev 7679)
@@ -38,43 +38,69 @@
public event EventHandler GroupChanged;
+ private IMapDefinition _mdf;
+ private IMapLegendElementBase _el;
- public GroupPropertiesCtrl(IMapLayerGroup group)
+ private bool _init = false;
+ public GroupPropertiesCtrl(IMapDefinition map, IMapLayerGroup group)
: this()
- group.PropertyChanged += new PropertyChangedEventHandler(OnGroupChanged);
- //TextBoxBinder.BindText(txtName, group, "Name");
- IMapDefinition mdf = group.Parent;
- string currentName = group.Name;
- txtName.Text = currentName;
- txtName.TextChanged += (s, e) =>
+ _init = true;
+ try
- string newName = txtName.Text;
- group.Name = newName;
- mdf.UpdateDynamicGroupName(currentName, newName);
- System.Diagnostics.Debug.WriteLine(string.Format("Updated group name {0} -> {1}", currentName, newName));
- currentName = newName;
+ _mdf = map;
+ _el = group;
+ group.PropertyChanged += new PropertyChangedEventHandler(OnGroupChanged);
+ string currentName = group.Name;
+ txtName.Text = currentName;
+ //TextBoxBinder.BindText(txtName, group, "Name");
+ IMapDefinition mdf = group.Parent;
+ txtName.TextChanged += (s, e) =>
+ string newName = txtName.Text;
+ group.Name = newName;
+ mdf.UpdateDynamicGroupName(currentName, newName);
+ System.Diagnostics.Debug.WriteLine(string.Format("Updated group name {0} -> {1}", currentName, newName));
+ currentName = newName;
- TextBoxBinder.BindText(txtLegendLabel, group, "LegendLabel");
+ TextBoxBinder.BindText(txtLegendLabel, group, "LegendLabel");
- CheckBoxBinder.BindChecked(chkExpanded, group, "ExpandInLegend");
- CheckBoxBinder.BindChecked(chkLegendVisible, group, "ShowInLegend");
- CheckBoxBinder.BindChecked(chkVisible, group, "Visible");
+ CheckBoxBinder.BindChecked(chkExpanded, group, "ExpandInLegend");
+ CheckBoxBinder.BindChecked(chkLegendVisible, group, "ShowInLegend");
+ CheckBoxBinder.BindChecked(chkVisible, group, "Visible");
+ finally
+ _init = false;
- public GroupPropertiesCtrl(IBaseMapGroup group)
+ public GroupPropertiesCtrl(IMapDefinition map, IBaseMapGroup group)
: this()
+ _init = true;
+ try
+ _mdf = map;
+ _el = group;
- TextBoxBinder.BindText(txtName, group, "Name");
+ finally
+ _init = false;
void OnGroupChanged(object sender, PropertyChangedEventArgs e)
@@ -83,5 +109,46 @@
if (handler != null)
handler(this, EventArgs.Empty);
+ static int GetGroupCount(IMapDefinition map, string name)
+ int count = 0;
+ foreach (var grp in map.MapLayerGroup)
+ if (grp.Name == name)
+ count++;
+ if (map.BaseMap != null)
+ foreach (var grp in map.BaseMap.BaseMapLayerGroup)
+ count++;
+ System.Diagnostics.Debug.WriteLine(string.Format("{0} groups with the name: {1}", count, name));
+ return count;
+ private void txtName_TextChanged(object sender, EventArgs e)
+ if (_init)
+ return;
+ //Before we apply to model, check if another one of the same name exists
+ if (GetGroupCount(_mdf, newName) == 0)
+ string currentName = _el.Name;
+ _el.Name = newName;
+ _mdf.UpdateDynamicGroupName(currentName, newName);
+ else
+ errorProvider.SetError(txtName, string.Format(Strings.GroupAlreadyExists, newName));
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.resx 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.resx 2013-07-09 13:14:52 UTC (rev 7679)
@@ -208,7 +208,7 @@
<value>107, 45</value>
</data>
<data name="txtLegendLabel.Size" type="System.Drawing.Size, System.Drawing">
- <value>277, 20</value>
+ <value>266, 20</value>
</data>
<data name="txtLegendLabel.TabIndex" type="System.Int32, mscorlib">
<value>11</value>
@@ -232,7 +232,7 @@
<value>107, 19</value>
</data>
<data name="txtName.Size" type="System.Drawing.Size, System.Drawing">
</data>
<data name="txtName.TabIndex" type="System.Int32, mscorlib">
<value>10</value>
@@ -330,12 +330,21 @@
<data name=">>groupBox1.ZOrder" xml:space="preserve">
<value>0</value>
</data>
+ </metadata>
<value>True</value>
</metadata>
<value>400, 187</value>
</data>
+ </data>
+ </data>
<value>GroupPropertiesCtrl</value>
</data>
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2013-07-09 13:14:52 UTC (rev 7679)
@@ -222,7 +222,7 @@
btnConvertLayerGroupToBaseGroup.Enabled = true;
propertiesPanel.Controls.Clear();
- var item = new GroupPropertiesCtrl(group.Tag);
+ var item = new GroupPropertiesCtrl(_map, group.Tag);
item.GroupChanged += (s, evt) => { OnResourceChanged(); };
item.Dock = DockStyle.Fill;
_activeLayer = null;
@@ -919,7 +919,7 @@
btnBaseLayerGroupToRegular.Enabled = true;
Modified: branches/maestro-4.0.x/Maestro.Editors/Strings.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/Strings.Designer.cs 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/Strings.Designer.cs 2013-07-09 13:14:52 UTC (rev 7679)
@@ -70,6 +70,1356 @@
/// <summary>
+ /// Looks up a localized string similar to The content file does not exist.
+ /// </summary>
+ internal static string ContentFileMissing {
+ get {
+ return ResourceManager.GetString("ContentFileMissing", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to transform coordinates: {0}.
+ /// </summary>
+ internal static string CoordinateTransformationFailed {
+ get {
+ return ResourceManager.GetString("CoordinateTransformationFailed", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Custom commands exported to {0}.
+ /// </summary>
+ internal static string CustomCommandsExported {
+ get {
+ return ResourceManager.GetString("CustomCommandsExported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0} custom commands imported from {1}. The following commands had to be renamed to prevent clashes: {2}.
+ /// </summary>
+ internal static string CustomCommandsImported {
+ get {
+ return ResourceManager.GetString("CustomCommandsImported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Unable to read data from the selected column: {0}.
+ /// </summary>
+ internal static string DataReadError {
+ get {
+ return ResourceManager.GetString("DataReadError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Delete Command.
+ /// </summary>
+ internal static string DeleteCommand {
+ get {
+ return ResourceManager.GetString("DeleteCommand", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Do you want to remove the selected item?.
+ /// </summary>
+ internal static string DeleteConfirmation {
+ get {
+ return ResourceManager.GetString("DeleteConfirmation", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Displays the current map extents.
+ /// </summary>
+ internal static string Desc_GetExtents {
+ get {
+ return ResourceManager.GetString("Desc_GetExtents", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Gets the current map as a KML document.
+ /// </summary>
+ internal static string Desc_GetMapKml {
+ get {
+ return ResourceManager.GetString("Desc_GetMapKml", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Zoom to a specified scale.
+ /// </summary>
+ internal static string Desc_ZoomToScale {
+ get {
+ return ResourceManager.GetString("Desc_ZoomToScale", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Diverging.
+ /// </summary>
+ internal static string DivergingName {
+ get {
+ return ResourceManager.GetString("DivergingName", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Edit Watermark Instance.
+ /// </summary>
+ internal static string EditWatermarkInstance {
+ get {
+ return ResourceManager.GetString("EditWatermarkInstance", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to None.
+ /// </summary>
+ internal static string EmptyText {
+ get {
+ return ResourceManager.GetString("EmptyText", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Not a folder.
+ /// </summary>
+ internal static string ErrNotAFolder {
+ get {
+ return ResourceManager.GetString("ErrNotAFolder", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Exploding Composite Styles is not currently supported.
+ /// </summary>
+ internal static string ErrorExplodingCompositeStyleNotSupported {
+ get {
+ return ResourceManager.GetString("ErrorExplodingCompositeStyleNotSupported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Not a valid symbol library resource identifier: {0}.
+ /// </summary>
+ internal static string ErrorInvalidSymbolLibraryResourceId {
+ get {
+ return ResourceManager.GetString("ErrorInvalidSymbolLibraryResourceId", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to This Layer Definition version does not support composite symbolization.
+ /// </summary>
+ internal static string ErrorLayerDefnitionDoesNotSupportCompositeSymbolization {
+ get {
+ return ResourceManager.GetString("ErrorLayerDefnitionDoesNotSupportCompositeSymbolization", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Error loading WMS configuration document: {0}. A default document will be created.
+ /// </summary>
+ internal static string ErrorLoadingWmsConfig {
+ get {
+ return ResourceManager.GetString("ErrorLoadingWmsConfig", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Could not transform extents of any layer in this Map Definition. You will have to specify the extents manually..
+ /// </summary>
+ internal static string ErrorMapExtentCalculationFailed {
+ get {
+ return ResourceManager.GetString("ErrorMapExtentCalculationFailed", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No commands selected. Nothing to export.
+ /// </summary>
+ internal static string ExportNoCommandsSelected {
+ get {
+ return ResourceManager.GetString("ExportNoCommandsSelected", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No custom commands selected. Nothing to export.
+ /// </summary>
+ internal static string ExportNoCustomCommandsSelected {
+ get {
+ return ResourceManager.GetString("ExportNoCustomCommandsSelected", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0}{3}{1}{3}Returns: {2}.
+ /// </summary>
+ internal static string ExprEditorFunctionDesc {
+ get {
+ return ResourceManager.GetString("ExprEditorFunctionDesc", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Expression....
+ /// </summary>
+ internal static string ExpressionItem {
+ get {
+ return ResourceManager.GetString("ExpressionItem", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Extended class based on: {0}.
+ /// </summary>
+ internal static string ExtendedClassTooltip {
+ get {
+ return ResourceManager.GetString("ExtendedClassTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Map extents calculation completed. Click Accept to use the calculated extents..
+ /// </summary>
+ internal static string ExtentsCalculationCompleted {
+ get {
+ return ResourceManager.GetString("ExtentsCalculationCompleted", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Could not transform extent of layer {0} to the map definition's coordinate system. Extents ignored.
+ /// </summary>
+ internal static string ExtentsTransformationFailed {
+ get {
+ return ResourceManager.GetString("ExtentsTransformationFailed", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Could not calculate the extents of the Feature Source. Preview is not possible.
+ /// </summary>
+ internal static string FailedToCalculateFeatureSourceExtents {
+ get {
+ return ResourceManager.GetString("FailedToCalculateFeatureSourceExtents", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to enumerate data stores. Reason: {0}.
+ /// </summary>
+ internal static string FailEnumDataStores {
+ get {
+ return ResourceManager.GetString("FailEnumDataStores", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to FDO Connection Status: {0}.
+ /// </summary>
+ internal static string FdoConnectionStatus {
+ get {
+ return ResourceManager.GetString("FdoConnectionStatus", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The component "{0}" could not be found in the specified FDO connection string.
+ /// </summary>
+ internal static string FdoConnectionStringComponentNotFound {
+ get {
+ return ResourceManager.GetString("FdoConnectionStringComponentNotFound", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Feature Class not found: {0}.
+ /// </summary>
+ internal static string FeatureClassNotFound {
+ get {
+ return ResourceManager.GetString("FeatureClassNotFound", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to This feature is not implemented yet.
+ /// </summary>
+ internal static string FeatureNotImplemented {
+ get {
+ return ResourceManager.GetString("FeatureNotImplemented", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to This field is required: {0}.
+ /// </summary>
+ internal static string FieldRequired {
+ get {
+ return ResourceManager.GetString("FieldRequired", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to An error occured while copying file: {0}.
+ /// </summary>
+ internal static string FileCopyError {
+ get {
+ return ResourceManager.GetString("FileCopyError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to File Downloaded to {0}.
+ /// </summary>
+ internal static string FileDownloaded {
+ get {
+ return ResourceManager.GetString("FileDownloaded", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to validate the filenames: {0}.
+ /// </summary>
+ internal static string FilenameValidationError {
+ get {
+ return ResourceManager.GetString("FilenameValidationError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to All files ({0}).
+ /// </summary>
+ internal static string FiletypeAll {
+ get {
+ return ResourceManager.GetString("FiletypeAll", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to MapGuide Packages ({0}).
+ /// </summary>
+ internal static string FiletypeMGP {
+ get {
+ return ResourceManager.GetString("FiletypeMGP", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Zip files ({0}).
+ /// </summary>
+ internal static string FiletypeZip {
+ get {
+ return ResourceManager.GetString("FiletypeZip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Cannot Find an Empty String.
+ /// </summary>
+ internal static string FindEmptyString {
+ get {
+ return ResourceManager.GetString("FindEmptyString", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Could not find specified string or end of document reached.
+ /// </summary>
+ internal static string FindNothing {
+ get {
+ return ResourceManager.GetString("FindNothing", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Nothing to replace.
+ /// </summary>
+ internal static string FindReplaceNothing {
+ get {
+ return ResourceManager.GetString("FindReplaceNothing", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Finite Display Scales.
+ /// </summary>
+ internal static string FiniteDisplayScales {
+ get {
+ return ResourceManager.GetString("FiniteDisplayScales", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The folder must start with \"Library://\", do you want the starting folder to become:\n {0} ?.
+ /// </summary>
+ internal static string FolderMissingPrefix {
+ get {
+ return ResourceManager.GetString("FolderMissingPrefix", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Cannot Preview Font "{0}".
+ /// </summary>
+ internal static string FontPreviewError {
+ get {
+ return ResourceManager.GetString("FontPreviewError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to MySQL Feature Source.
+ /// </summary>
+ internal static string FsMySql {
+ get {
+ return ResourceManager.GetString("FsMySql", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to PostgreSQL/PostGIS Feature Source.
+ /// </summary>
+ internal static string FsPostgreSql {
+ get {
+ return ResourceManager.GetString("FsPostgreSql", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Name: {0}{3}Description: {1}{3}Geometry Property: {2}.
+ /// </summary>
+ internal static string FsPreview_ClassNodeTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_ClassNodeTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Name: {0}{8}Description: {1}{8}Data Type: {2}{8}Nullable: {3}{8}Read Only: {4}{8}Length: {5}{8}Precision: {6}{8}Scale: {7}.
+ /// </summary>
+ internal static string FsPreview_DataPropertyNodeTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_DataPropertyNodeTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Property: {0}{2}Type: {1}.
+ /// </summary>
+ internal static string FsPreview_GenericPropertyTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_GenericPropertyTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Name: {0}{7}Description: {1}{7}Geometry Types: {2}{7}Read Only: {3}{7}Has Elevation: {4}{7}Has Measure: {5}{7}Spatial Context: {6}.
+ /// </summary>
+ internal static string FsPreview_GeometryPropertyNodeTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_GeometryPropertyNodeTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Name: {0}{6}Description: {1}{6}Nullable: {2}{6}Image X Size: {3}{6}Image Y Size: {4}{6}Spatial Context: {5}.
+ /// </summary>
+ internal static string FsPreview_RasterPropertyNodeTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_RasterPropertyNodeTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to SQL Server Spatial Feature Source.
+ /// </summary>
+ internal static string FsSqlServerSpatial {
+ get {
+ return ResourceManager.GetString("FsSqlServerSpatial", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Alpha value.
+ /// </summary>
+ internal static string Func_ARGB_AValueDescription {
+ get {
+ return ResourceManager.GetString("Func_ARGB_AValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Blue value.
+ /// </summary>
+ internal static string Func_ARGB_BValueDescription {
+ get {
+ return ResourceManager.GetString("Func_ARGB_BValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Color generation function.
+ /// </summary>
+ internal static string Func_ARGB_Description {
+ get {
+ return ResourceManager.GetString("Func_ARGB_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Green value.
+ /// </summary>
+ internal static string Func_ARGB_GValueDescription {
+ get {
+ return ResourceManager.GetString("Func_ARGB_GValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Red value.
+ /// </summary>
+ internal static string Func_ARGB_RValueDescription {
+ get {
+ return ResourceManager.GetString("Func_ARGB_RValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to String formatting function.
+ /// </summary>
+ internal static string Func_DECAP_Description {
+ get {
+ return ResourceManager.GetString("Func_DECAP_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to String to format.
+ /// </summary>
+ internal static string Func_DECAP_StringValueDescription {
+ get {
+ return ResourceManager.GetString("Func_DECAP_StringValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active feature class name.
+ /// </summary>
+ internal static string Func_FEATURECLASS_Description {
+ get {
+ return ResourceManager.GetString("Func_FEATURECLASS_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active feature Id.
+ /// </summary>
+ internal static string Func_FEATUREID_Description {
+ get {
+ return ResourceManager.GetString("Func_FEATUREID_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Boolean expression (filter) encapsulated in a string.
+ /// </summary>
+ internal static string Func_IF_ConditionDescription {
+ get {
+ return ResourceManager.GetString("Func_IF_ConditionDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to If evaluator for style theming.
+ /// </summary>
+ internal static string Func_IF_Description {
+ get {
+ return ResourceManager.GetString("Func_IF_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returned if condition is false.
+ /// </summary>
+ internal static string Func_IF_FalseValueDescription {
+ get {
+ return ResourceManager.GetString("Func_IF_FalseValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returned if condition is true.
+ /// </summary>
+ internal static string Func_IF_TrueValueDescription {
+ get {
+ return ResourceManager.GetString("Func_IF_TrueValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active layer Id.
+ /// </summary>
+ internal static string Func_LAYERID_Description {
+ get {
+ return ResourceManager.GetString("Func_LAYERID_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Default value returned if expression does not evaluate to any of the keys.
+ /// </summary>
+ internal static string Func_LOOKUP_DefaultValueDescription {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_DefaultValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Lookup table for style theming.
+ /// </summary>
+ internal static string Func_LOOKUP_Description {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Key expression.
+ /// </summary>
+ internal static string Func_LOOKUP_ExpressionDescription {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_ExpressionDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Lookup index that can be matched by the key expression.
+ /// </summary>
+ internal static string Func_LOOKUP_IndexDescription {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_IndexDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Value that is returned when the key expression matches the associated index.
+ /// </summary>
+ internal static string Func_LOOKUP_ValueDescription {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_ValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active map name.
+ /// </summary>
+ internal static string Func_MAPNAME_Description {
+ get {
+ return ResourceManager.GetString("Func_MAPNAME_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Default value returned if expression does not fall into any of the ranges.
+ /// </summary>
+ internal static string Func_RANGE_DefaultValueDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_DefaultValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Range table for style theming.
+ /// </summary>
+ internal static string Func_RANGE_Description {
+ get {
+ return ResourceManager.GetString("Func_RANGE_Description", resourceCulture);
+ /// <summary>
+ /// </summary>
+ internal static string Func_RANGE_ExpressionDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_ExpressionDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Exclusive maximum of range that can be matched by the key expression.
+ /// </summary>
+ internal static string Func_RANGE_MaxDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_MaxDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Inclusive minimum of range that can be matched by the key expression.
+ /// </summary>
+ internal static string Func_RANGE_MinDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_MinDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Value that is returned when the key expression matches the associated range.
+ /// </summary>
+ internal static string Func_RANGE_ValueDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_ValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active session.
+ /// </summary>
+ internal static string Func_SESSION_Description {
+ get {
+ return ResourceManager.GetString("Func_SESSION_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to String encoding function.
+ /// </summary>
+ internal static string Func_URLENCODE_Description {
+ get {
+ return ResourceManager.GetString("Func_URLENCODE_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to String to URL encode.
+ /// </summary>
+ internal static string Func_URLENCODE_StringValueDescription {
+ get {
+ return ResourceManager.GetString("Func_URLENCODE_StringValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Function: {1}({2})
+ ///Description: {3}
+ ///Returns: {0}.
+ /// </summary>
+ internal static string FunctionTooltip {
+ get {
+ return ResourceManager.GetString("FunctionTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to An error occured: {0}.
+ /// </summary>
+ internal static string GenericError {
+ get {
+ return ResourceManager.GetString("GenericError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to <?xml version="1.0" standalone="yes"?>
+ ///<ComboBoxDataSet>
+ /// <SymbolMark>
+ /// <Display>Square</Display>
+ /// <Value>Square</Value>
+ /// </SymbolMark>
+ /// <SymbolMark>
+ /// <Display>Circle</Display>
+ /// <Value>Circle</Value>
+ /// </SymbolMark>
+ /// <SymbolMark>
+ /// <Display>Triangle</Display>
+ /// <Value>Triangle</Value>
+ /// </SymbolMark>
+ /// <SymbolMark>
+ /// <Display>Star</Display>
+ /// <Value>Star</Value>
+ /// </SymbolMark>
+ /// <SymbolMark>
+ /// <Display>Cross</Display>
+ /// <Value>Cross</Value>
+ /// </SymbolMark>
+ /// <SymbolMark>
+ /// <Display>X - [rest of string was truncated]";.
+ /// </summary>
+ internal static string GeometryStyleComboDataset {
+ get {
+ return ResourceManager.GetString("GeometryStyleComboDataset", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to <geometry property> {0} GeomFromText('<FGF geometry text>').
+ /// </summary>
+ internal static string GeomFilterTemplate {
+ get {
+ return ResourceManager.GetString("GeomFilterTemplate", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to A group named "{0}" already exists. Choose a different name.
+ /// </summary>
+ internal static string GroupAlreadyExists {
+ get {
+ return ResourceManager.GetString("GroupAlreadyExists", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The header file does not exist.
+ /// </summary>
+ internal static string HeaderFileMissing {
+ get {
+ return ResourceManager.GetString("HeaderFileMissing", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to This connection is not compatible.
+ /// </summary>
+ internal static string IncompatibleConnection {
+ get {
+ return ResourceManager.GetString("IncompatibleConnection", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to infinite.
+ /// </summary>
+ internal static string InfiniteValue {
+ get {
+ return ResourceManager.GetString("InfiniteValue", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Infinity.
+ /// </summary>
+ internal static string Infinity {
+ get {
+ return ResourceManager.GetString("Infinity", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Inline Symbol Definition.
+ /// </summary>
+ internal static string InlineSymbolDefinition {
+ get {
+ return ResourceManager.GetString("InlineSymbolDefinition", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to You have entered a non-numeric value in the Reference Y field. Due to a bug in MapGuide, this will likely give an error when saving..
+ /// </summary>
+ internal static string InsertionPointYError {
+ get {
+ return ResourceManager.GetString("InsertionPointYError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Invalid {0} color component {1} in line {2}.
+ /// </summary>
+ internal static string InvalidColorComponent {
+ get {
+ return ResourceManager.GetString("InvalidColorComponent", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Invalid column name.
+ /// </summary>
+ internal static string InvalidColumnNameError {
+ get {
+ return ResourceManager.GetString("InvalidColumnNameError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to This is not a valid connection: {0}.
+ /// </summary>
+ internal static string InvalidConnection {
+ get {
+ return ResourceManager.GetString("InvalidConnection", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Feature Source ({0}) has no usable feature classes. Choose a different feature source.
+ /// </summary>
+ internal static string InvalidFeatureSourceNoClasses {
+ get {
+ return ResourceManager.GetString("InvalidFeatureSourceNoClasses", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Invalid field count in line {0}.
+ /// </summary>
+ internal static string InvalidFieldCountError {
+ get {
+ return ResourceManager.GetString("InvalidFieldCountError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Invalid Layer Name Format. Name must have both {0} and {1} format markers.
+ /// </summary>
+ internal static string InvalidLayerNameFormat {
+ get {
+ return ResourceManager.GetString("InvalidLayerNameFormat", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Invalid record count in line {0}.
+ /// </summary>
+ internal static string InvalidRecordCountError {
+ get {
+ return ResourceManager.GetString("InvalidRecordCountError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Not a valid resource identifier.
+ /// </summary>
+ internal static string InvalidResourceId {
+ get {
+ return ResourceManager.GetString("InvalidResourceId", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Must be valid resource id. Cannot be a folder.
+ /// </summary>
+ internal static string InvalidResourceIdFolder {
+ get {
+ return ResourceManager.GetString("InvalidResourceIdFolder", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Invalid Resource Identifier. Not the specified type.
+ /// </summary>
+ internal static string InvalidResourceIdNotSpecifiedType {
+ get {
+ return ResourceManager.GetString("InvalidResourceIdNotSpecifiedType", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to An error occured while validating the restore path: {0}\nIt should have the format: \"Libray://folder/folder/\"..
+ /// </summary>
+ internal static string InvalidRestorePathError {
+ get {
+ return ResourceManager.GetString("InvalidRestorePathError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Invalid value.
+ /// </summary>
+ internal static string InvalidValueError {
+ get {
+ return ResourceManager.GetString("InvalidValueError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Invoke Script Command.
+ /// </summary>
+ internal static string InvokeScriptCmdDescription {
+ get {
+ return ResourceManager.GetString("InvokeScriptCmdDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Invoke URL command.
+ /// </summary>
+ internal static string InvokeUrlCmdDescription {
+ get {
+ return ResourceManager.GetString("InvokeUrlCmdDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Cannot get layers. No map definition specified.
+ /// </summary>
+ internal static string InvokeUrlNoMapDefined {
+ get {
+ return ResourceManager.GetString("InvokeUrlNoMapDefined", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Extra Tools.
+ /// </summary>
+ internal static string Label_ExtraTools {
+ get {
+ return ResourceManager.GetString("Label_ExtraTools", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Get Extents.
+ /// </summary>
+ internal static string Label_GetExtents {
+ get {
+ return ResourceManager.GetString("Label_GetExtents", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Get KML.
+ /// </summary>
+ internal static string Label_GetMapKml {
+ get {
+ return ResourceManager.GetString("Label_GetMapKml", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Tools.
+ /// </summary>
+ internal static string Label_Tools {
+ get {
+ return ResourceManager.GetString("Label_Tools", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Zoom to Scale.
+ /// </summary>
+ internal static string Label_ZoomToScale {
+ get {
+ return ResourceManager.GetString("Label_ZoomToScale", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Last Updated: .
+ /// </summary>
+ internal static string LastUpdated {
+ get {
+ return ResourceManager.GetString("LastUpdated", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The selected layer is already at the bottom of its group.
+ /// </summary>
+ internal static string LayerAlreadyAtBottomOfGroup {
+ get {
+ return ResourceManager.GetString("LayerAlreadyAtBottomOfGroup", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The selected layer is already at the top of its group.
+ /// </summary>
+ internal static string LayerAlreadyAtTopOfGroup {
+ get {
+ return ResourceManager.GetString("LayerAlreadyAtTopOfGroup", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layer Group ({0}) successfully converted to Base Layer Group ({1}).
+ /// </summary>
+ internal static string LayerGroupConvertedToBaseLayerGroup {
+ get {
+ return ResourceManager.GetString("LayerGroupConvertedToBaseLayerGroup", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Less than {0}.
+ /// </summary>
+ internal static string LessThanLabel {
+ get {
+ return ResourceManager.GetString("LessThanLabel", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Loading Feature Classes.
+ /// </summary>
+ internal static string LoadingFeatureClasses {
+ get {
+ return ResourceManager.GetString("LoadingFeatureClasses", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to This connection does not support executing this type of Load Procedure.
+ /// </summary>
+ internal static string LoadProcedureVersionExecutionNotSupported {
+ get {
+ return ResourceManager.GetString("LoadProcedureVersionExecutionNotSupported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Map widget has been updated to use the map group: {0}.
+ /// </summary>
+ internal static string MapUpdatedToUseGroup {
+ get {
+ return ResourceManager.GetString("MapUpdatedToUseGroup", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Missing column "{0}".
+ /// </summary>
+ internal static string MissingColumnError {
+ get {
+ return ResourceManager.GetString("MissingColumnError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Mode not allowed: {0}.
+ /// </summary>
+ internal static string ModeNotAllowed {
+ get {
+ return ResourceManager.GetString("ModeNotAllowed", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to More colors....
+ /// </summary>
+ internal static string MoreColorsName {
+ get {
+ return ResourceManager.GetString("MoreColorsName", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to More than {0}.
+ /// </summary>
+ internal static string MoreThanLabel {
+ get {
+ return ResourceManager.GetString("MoreThanLabel", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to New Flyout.
+ /// </summary>
+ internal static string NewFlyout {
+ get {
+ return ResourceManager.GetString("NewFlyout", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to New folder.
+ /// </summary>
+ internal static string NewFolder {
+ get {
+ return ResourceManager.GetString("NewFolder", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to New Layer.
+ /// </summary>
+ internal static string NewLayer {
+ get {
+ return ResourceManager.GetString("NewLayer", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to New Layer Group.
+ /// </summary>
+ internal static string NewLayerGroup {
+ get {
+ return ResourceManager.GetString("NewLayerGroup", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No active resource data file selected.
+ /// </summary>
+ internal static string NoActiveDataFile {
+ get {
+ return ResourceManager.GetString("NoActiveDataFile", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No values found in selected column.
+ /// </summary>
+ internal static string NoColumnValuesError {
+ get {
+ return ResourceManager.GetString("NoColumnValuesError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No Feature Class assigned.
+ /// </summary>
+ internal static string NoFeatureClassAssigned {
+ get {
+ return ResourceManager.GetString("NoFeatureClassAssigned", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to You have not selected a starting folder, do you want to back up the entire site?.
+ /// </summary>
+ internal static string NoFolderSelected {
+ get {
+ return ResourceManager.GetString("NoFolderSelected", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to This feature source has no class definitions with raster properties.
+ /// </summary>
+ internal static string NoRasterClasses {
+ get {
+ return ResourceManager.GetString("NoRasterClasses", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No registered previewer for connection: {0}.
+ /// </summary>
+ internal static string NoRegisteredPreviewerForProvider {
+ get {
+ return ResourceManager.GetString("NoRegisteredPreviewerForProvider", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to You have selected to restore the package at another location, but not entered one.
+ ///This will cause the package to be restored a the root of the resource tree.
+ ///Are you sure this is what you want?.
+ /// </summary>
+ internal static string NoRestorePathWarning {
+ get {
+ return ResourceManager.GetString("NoRestorePathWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Number of Scales to generate cannot be less than or equal to 0.
+ /// </summary>
+ internal static string NoScalesToGenerate {
+ get {
+ return ResourceManager.GetString("NoScalesToGenerate", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Feature Source has no schemas.
+ /// </summary>
+ internal static string NoSchemasInFeatureSource {
+ get {
+ return ResourceManager.GetString("NoSchemasInFeatureSource", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No site service available.
+ /// </summary>
+ internal static string NoSiteService {
+ get {
+ return ResourceManager.GetString("NoSiteService", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Not a folder: {0}.
+ /// </summary>
+ internal static string NotAFolder {
+ get {
+ return ResourceManager.GetString("NotAFolder", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to This is not a Map Definition with tiled layers.
+ /// </summary>
+ internal static string NotATiledMap {
+ get {
+ return ResourceManager.GetString("NotATiledMap", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No transformation required.
+ /// </summary>
+ internal static string NoTransformationRequired {
+ get {
+ return ResourceManager.GetString("NoTransformationRequired", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Resource ID must not be session based.
+ /// </summary>
+ internal static string NotSessionBasedId {
+ get {
+ return ResourceManager.GetString("NotSessionBasedId", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to You must select at least one type.
+ /// </summary>
+ internal static string NoTypesSelected {
+ get {
+ return ResourceManager.GetString("NoTypesSelected", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The specified editor does not implement the required IWidgetEditor interface.
+ /// </summary>
+ internal static string NoWidgetEditorIface {
+ get {
+ return ResourceManager.GetString("NoWidgetEditorIface", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Could not infer ODBC driver from file name: {0}.
+ /// </summary>
+ internal static string OdbcCannotInferDriver {
+ get {
+ return ResourceManager.GetString("OdbcCannotInferDriver", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The component "{0}" could not be found in the specified ODBC connection string.
+ /// </summary>
+ internal static string OdbcConnectionStringComponentNotFound {
+ get {
+ return ResourceManager.GetString("OdbcConnectionStringComponentNotFound", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to The ODBC connection string requires a %MG_USERNAME% and %MG_PASSWORD% placeholder tokens present.
/// </summary>
internal static string OdbcConnStrMissingMgPlaceholders {
Modified: branches/maestro-4.0.x/Maestro.Editors/Strings.resx
--- branches/maestro-4.0.x/Maestro.Editors/Strings.resx 2013-07-09 12:53:47 UTC (rev 7678)
+++ branches/maestro-4.0.x/Maestro.Editors/Strings.resx 2013-07-09 13:14:52 UTC (rev 7679)
@@ -123,4 +123,10 @@
<data name="OdbcConnStrMissingMgPlaceholders" xml:space="preserve">
<value>The ODBC connection string requires a %MG_USERNAME% and %MG_PASSWORD% placeholder tokens present</value>
</data>
+ <data name="GroupAlreadyExists" xml:space="preserve">
+ <value>A group named "{0}" already exists. Choose a different name</value>
+ </data>
+ <data name="ExtendedFeatureClassAlreadyExists" xml:space="preserve">
+ <value>An extended feature class named ({0}) already exist. Please choose a different name</value>
+ </data>
</root>
\ No newline at end of file
More information about the mapguide-commits
