[mapguide-commits] r7693 - in trunk/Tools/Maestro/Maestro.Editors: . Common
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jul 19 00:52:32 PDT 2013
Author: jng
Date: 2013-07-19 00:52:31 -0700 (Fri, 19 Jul 2013)
New Revision: 7693
   trunk/Tools/Maestro/Maestro.Editors/Common/CoordinateSystemPicker.cs
   trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Strings.resx
#2211: Allow arbitrary WKT strings in the coordinate system picker
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/CoordinateSystemPicker.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/CoordinateSystemPicker.cs	2013-07-19 06:46:26 UTC (rev 7692)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/CoordinateSystemPicker.cs	2013-07-19 07:52:31 UTC (rev 7693)
@@ -172,9 +172,26 @@
                         m_wktCoordSys.WKT = WKTText.Text;
+                else
+                    if (MessageBox.Show(Strings.ConfirmNonMapGuideSupportedCsWkt, Strings.NonMapGuideSupportedCsWkt, MessageBoxButtons.YesNo) == System.Windows.Forms.DialogResult.Yes)
+                        m_wktCoordSys = _cat.CreateEmptyCoordinateSystem();
+                        m_wktCoordSys.Code = null;
+                        m_wktCoordSys.Description = null;
+                        m_wktCoordSys.WKT = WKTText.Text;
             catch
             UpdateOKButton();
@@ -189,6 +206,7 @@
             catch
             UpdateOKButton();
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs	2013-07-19 06:46:26 UTC (rev 7692)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs	2013-07-19 07:52:31 UTC (rev 7693)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:4.0.30319.18047
+//     Runtime Version:4.0.30319.18213
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -367,6 +367,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to The WKT you entered is not recognised by MapGuide's Coordinate System Library. Use it anyway?.
+        /// </summary>
+        internal static string ConfirmNonMapGuideSupportedCsWkt {
+            get {
+                return ResourceManager.GetString("ConfirmNonMapGuideSupportedCsWkt", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to In some cases, the actual WMS layer name would be generated in the FDO class description. Swap FDO logical class names with their descriptions?.
         /// </summary>
         internal static string ConfirmWmsLogicalClassSwap {
@@ -1607,6 +1616,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Non-supported WKT.
+        /// </summary>
+        internal static string NonMapGuideSupportedCsWkt {
+            get {
+                return ResourceManager.GetString("NonMapGuideSupportedCsWkt", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to This feature source has no class definitions with raster properties.
         /// </summary>
         internal static string NoRasterClasses {
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx	2013-07-19 06:46:26 UTC (rev 7692)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx	2013-07-19 07:52:31 UTC (rev 7693)
@@ -1527,4 +1527,10 @@
   <data name="ExtendedFeatureClassAlreadyExists" xml:space="preserve">
     <value>An extended feature class named ({0}) already exist. Please choose a different name</value>
   </data>
+  <data name="ConfirmNonMapGuideSupportedCsWkt" xml:space="preserve">
+    <value>The WKT you entered is not recognised by MapGuide's Coordinate System Library. Use it anyway?</value>
+  </data>
+  <data name="NonMapGuideSupportedCsWkt" xml:space="preserve">
+    <value>Non-supported WKT</value>
+  </data>
 </root>
\ No newline at end of file
More information about the mapguide-commits mailing list
