[mapguide-commits] r7702 - sandbox/jng/http304/Web/src/HttpHandler
svn_mapguide at osgeo.org
Tue Jul 30 05:44:23 PDT 2013
Author: jng
Date: 2013-07-30 05:44:23 -0700 (Tue, 30 Jul 2013)
New Revision: 7702
sandbox/jng/http304/Web/src/HttpHandler/HttpGetTileImage.cpp
Check in v2.6.0 GETTILEIMAGE support. This is currently blowing up (MgInvalidStreamHeaderException) due to some strange quirk in MgTile deserialization that is boggling my mind at the moment.
Modified: sandbox/jng/http304/Web/src/HttpHandler/HttpGetTileImage.cpp
--- sandbox/jng/http304/Web/src/HttpHandler/HttpGetTileImage.cpp 2013-07-30 08:23:23 UTC (rev 7701)
+++ sandbox/jng/http304/Web/src/HttpHandler/HttpGetTileImage.cpp 2013-07-30 12:44:23 UTC (rev 7702)
@@ -51,7 +51,7 @@
// Get the tile row index and convert to integer
m_tileRow = MgUtil::StringToInt32(params->GetParameterValue(MgHttpResourceStrings::reqRenderingTileRow));
- else if (version == MG_API_VERSION(1,2,0))
+ else if (version == MG_API_VERSION(1,2,0) || version == MG_API_VERSION(2,6,0))
// Get the map name
m_mapName = params->GetParameterValue(MgHttpResourceStrings::reqTileMapDefinition);
@@ -128,7 +128,20 @@
// Set the result
hResult->SetResultObject(tileImage, tileImage->GetMimeType());
+ else if (version == MG_API_VERSION(2,6,0))
+ Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(m_mapName);
+ // Get Proxy Tile Service instance
+ Ptr<MgTileService> service = (MgTileService*)(CreateService(MgServiceType::TileService));
+ // Call the C++ API
+ Ptr<MgTile> tile = service->GetTileWithCreationDate(resId, m_baseMapLayerGroupName, m_tileCol, m_tileRow, m_scaleIndex);
+ Ptr<MgByteReader> tileImage = tile->GetImage();
+ // Set the result
+ hResult->SetResultObject(tileImage, tileImage->GetMimeType());
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetTileImage.Execute")
@@ -144,7 +157,8 @@
// There are multiple supported versions
INT32 version = m_userInfo->GetApiVersion();
if (version != MG_API_VERSION(1,0,0) &&
- version != MG_API_VERSION(1,2,0))
+ version != MG_API_VERSION(1,2,0) &&
+ version != MG_API_VERSION(2,6,0))
throw new MgInvalidOperationVersionException(
L"MgHttpGetTileImage.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
More information about the mapguide-commits
