[mapguide-commits] r7574 - branches/2.5/MgDev/Desktop/MgDesktop/Services/Feature/Commands
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jun 7 01:59:35 PDT 2013
Author: jng
Date: 2013-06-07 01:59:34 -0700 (Fri, 07 Jun 2013)
New Revision: 7574
   branches/2.5/MgDev/Desktop/MgDesktop/Services/Feature/Commands/DescribeSchema.cpp
mg-desktop: When interrogating identity properties and we get MgDuplicateObjectException thrown back, catch and re-throw with added context as we'd like to know which Feature Class is causing this to happen. Also change a bunch of CHECKNULL calls to CHECKARGUMENTNULL
Modified: branches/2.5/MgDev/Desktop/MgDesktop/Services/Feature/Commands/DescribeSchema.cpp
--- branches/2.5/MgDev/Desktop/MgDesktop/Services/Feature/Commands/DescribeSchema.cpp	2013-06-06 18:23:16 UTC (rev 7573)
+++ branches/2.5/MgDev/Desktop/MgDesktop/Services/Feature/Commands/DescribeSchema.cpp	2013-06-07 08:59:34 UTC (rev 7574)
@@ -1264,7 +1264,7 @@
 bool MgdDescribeSchema::IsClassNameHintUsed(FdoIDescribeSchema* fdoCommand)
-    CHECKNULL(fdoCommand, L"MgdDescribeSchema.IsClassNameHintUsed");
+    CHECKARGUMENTNULL(fdoCommand, L"MgdDescribeSchema.IsClassNameHintUsed");
     FdoPtr<FdoStringCollection> classNames = fdoCommand->GetClassNames();
     bool classNameHintUsed = (NULL != classNames.p);
@@ -1275,7 +1275,7 @@
 MgStringCollection* MgdDescribeSchema::GetSchemaNames(MgFeatureSchemaCollection* schemas)
-    CHECKNULL(schemas, L"MgdDescribeSchema.GetSchemaNames");
+    CHECKARGUMENTNULL(schemas, L"MgdDescribeSchema.GetSchemaNames");
     Ptr<MgStringCollection> schemaNames = new MgStringCollection();
     INT32 schemaCount = schemas->GetCount();
@@ -1336,7 +1336,7 @@
 MgClassDefinition* MgdDescribeSchema::GetClassDefinition(MgFeatureSchemaCollection* schemas, CREFSTRING schemaName, CREFSTRING className)
-    CHECKNULL(schemas, L"MgdDescribeSchema.GetClassDefinition");
+    CHECKARGUMENTNULL(schemas, L"MgdDescribeSchema.GetClassDefinition");
     Ptr<MgClassDefinition> classDef;
@@ -1390,9 +1390,12 @@
     FdoFeatureSchemaCollection* schemas, MgResourceIdentifier* resource,
-    CHECKNULL(schemas, L"MgdDescribeSchema.GetIdentityProperties");
+    CHECKARGUMENTNULL(schemas, L"MgdDescribeSchema.GetIdentityProperties");
+    CHECKARGUMENTNULL(resource, L"MgdDescribeSchema.GetIdentityProperties");
+    Ptr<MgPropertyDefinitionCollection> idProps;
-    Ptr<MgPropertyDefinitionCollection> idProps = new MgPropertyDefinitionCollection();
+    MG_FEATURE_SERVICE_TRY()
+    idProps = new MgPropertyDefinitionCollection();
     // There should be at least one schema for the primary feature source.
@@ -1453,6 +1456,31 @@
+    MG_FEATURE_SERVICE_CATCH_WITH_FEATURE_SOURCE(L"MgdDescribeSchema.GetIdentityProperties", resource)
+    if (mgException != NULL)
+        //Sorry, if you're complaining about duplicate identity properties, then we need that thing called context
+        if (mgException->IsOfClass(Foundation_Exception_MgDuplicateObjectException))
+            STRING detail = mgException->GetDetails();
+            MgStringCollection args;
+            args.Add(resource->ToString());
+            STRING qualifiedClassName;
+            qualifiedClassName += schemaName;
+            qualifiedClassName += L":";
+            qualifiedClassName += className;
+            args.Add(qualifiedClassName);
+            args.Add(L"MgDuplicateObjectException"); //NOXLATE
+            args.Add(detail);
+            mgException = NULL;
+            mgException = new MgFeatureServiceException(L"MgdDescribeSchema.GetIdentityProperties", __LINE__, __WFILE__, NULL, L"MgFeatureSourceFormatInnerExceptionMessage", &args);
+    MG_FEATURE_SERVICE_THROW()
     return idProps.Detach();
More information about the mapguide-commits mailing list
