[mapguide-commits] r7622 - in sandbox/jng/node: BuildTools/WebTools/IMake BuildTools/WebTools/IMake/Win32 Web/src/MapGuideApi
svn_mapguide at osgeo.org
Fri Jun 14 05:48:24 PDT 2013
Author: jng
Date: 2013-06-14 05:48:24 -0700 (Fri, 14 Jun 2013)
New Revision: 7622
sandbox/jng/node/BuildTools/WebTools/IMake/IMake.cpp
sandbox/jng/node/BuildTools/WebTools/IMake/Win32/IMake.exe
sandbox/jng/node/Web/src/MapGuideApi/Constants.xml
Update IMake to support generating constants for javascript
Modified: sandbox/jng/node/BuildTools/WebTools/IMake/IMake.cpp
--- sandbox/jng/node/BuildTools/WebTools/IMake/IMake.cpp 2013-06-14 12:19:56 UTC (rev 7621)
+++ sandbox/jng/node/BuildTools/WebTools/IMake/IMake.cpp 2013-06-14 12:48:24 UTC (rev 7622)
@@ -9,10 +9,11 @@
unknown,
php,
csharp,
- java
+ java,
+ javascript
-static char version[] = "1.2";
+static char version[] = "1.3";
static string module;
static string customPath;
@@ -251,6 +252,13 @@
if(language == php)
parseTypeReplacements(node, typeReplacements);
+ else if(node->name == "JavaScriptTypeReplacements")
+ if(!translateMode)
+ error("JavaScriptTypeReplacements is not a valid section in SWIG mode");
+ if(language == javascript)
+ parseTypeReplacements(node, typeReplacements);
else if(node->name == "JavaTypeReplacements")
if(!translateMode)
@@ -1257,15 +1265,25 @@
string expr = comment.substr(posBeginValue + 6, strLen);
comment = comment.substr(0, posBeginValue) + comment.substr(posEndValue + 1);
+ string endstr = ";";
+ string assignOp = "=";
+ if (language == javascript)
+ //We use object literal notation for JS
+ endstr = ",";
+ comment = "";
+ assignOp = ":";
if(Trim(comment) == "")
//comment contained only the string value. remove comment at all
- token = " = " + expr + ";";
+ token = " " + assignOp + " " + expr + endstr;
else
// insert
- token = " = " + expr + "; /// " + comment;
+ token = " " + assignOp + " " + expr + endstr +" /// " + comment;
assignmentAdded = true;
@@ -1353,8 +1371,24 @@
- if(token.length() > 0)
+ if (token.length() > 0)
+ if (translateMode && language == javascript)
+ //This is an assignment expression
+ if (token.find('=') != string::npos)
+ std::replace(token.begin(), token.end(), '=', ':');
+ if (token.find(';') != string::npos)
+ std::replace(token.begin(), token.end(), ';', ',');
+ token += "\n";
fprintf(outfile, "%s ", token.c_str());
if (token.find('~') != string::npos)
@@ -1498,7 +1532,11 @@
if(translateMode && (language == java || language == csharp))
fprintf(outfile, "public ");
- fprintf(outfile, "class %s", className.c_str());
+ fprintf(outfile, "OSGeo.MapGuide.%s = ", className.c_str());
+ else
+ fprintf(outfile, "class %s", className.c_str());
if(colonPos != -1)
fprintf(outfile, " : ");
@@ -1553,8 +1591,12 @@
//end of class
if(!ignore)
+ fprintf(outfile, "CLASS_NAME:\"%s\"\n\n", className.c_str());
fprintf(outfile, "\n}");
- if(!translateMode) {
+ if(!translateMode || language == javascript) {
fprintf(outfile, ";\n\n");
else {
@@ -1659,6 +1701,11 @@
+ fprintf(outfile, "if (typeof(OSGeo) == 'undefined') OSGeo = {};\nif (typeof(OSGeo.MapGuide) == 'undefined') OSGeo.MapGuide = {};\n");
if(language == php)
fprintf(outfile, "<?php\n\n");
else
@@ -1730,7 +1777,7 @@
printf("\n parameterFile: XML description of generation parameters\n");
printf("\n lang: Target language (PHP, C# or Java).\n");
printf("\n generation_path_or_folder: Do not generate SWIG. Generate constant definitions.");
- printf("\n For PHP and C#, pathname of the constant file.");
+ printf("\n For PHP, JavaScript and C#, pathname of the constant file.");
printf("\n For Java, folder where the constant files are created");
exit(1);
@@ -1762,6 +1809,8 @@
else if(!strcmp(argv[2], "Java"))
language = java;
+ else if(!strcmp(argv[2], "JavaScript"))
+ language = javascript;
else
usage();
Modified: sandbox/jng/node/BuildTools/WebTools/IMake/Win32/IMake.exe
(Binary files differ)
Modified: sandbox/jng/node/Web/src/MapGuideApi/Constants.xml
--- sandbox/jng/node/Web/src/MapGuideApi/Constants.xml 2013-06-14 12:19:56 UTC (rev 7621)
+++ sandbox/jng/node/Web/src/MapGuideApi/Constants.xml 2013-06-14 12:48:24 UTC (rev 7622)
@@ -5,6 +5,18 @@
Type replacements.
+<JavaScriptTypeReplacements>
+ <TypeReplacement oldtype="STRING" newtype="" />
+ <TypeReplacement oldtype="INT8" newtype="" />
+ <TypeReplacement oldtype="INT16" newtype="" />
+ <TypeReplacement oldtype="INT32" newtype="" />
+ <TypeReplacement oldtype="int" newtype="" />
+ <TypeReplacement oldtype="float" newtype="" />
+ <TypeReplacement oldtype="double" newtype="" />
+ <TypeReplacement oldtype="static" newtype="" />
+ <TypeReplacement oldtype="bool" newtype="" />
+ <TypeReplacement oldtype="const" newtype="" />
+</JavaScriptTypeReplacements>
<PHPTypeReplacements>
More information about the mapguide-commits
