[mapguide-commits] r7477 - in trunk/MgDev: Common/MapGuideCommon/Resources Common/Stylization Desktop/MgDesktop/Services Desktop/MgDesktop/Services/Rendering Desktop/UnitTest Server/src/Core Server/src/PostBuild Server/src/Services/Kml Server/src/Services/Mapping Server/src/Services/Rendering Server/src/UnitTesting UnitTest/TestData/TileService
svn_mapguide at osgeo.org
Mon May 6 05:46:21 PDT 2013
Author: jng
Date: 2013-05-06 05:46:20 -0700 (Mon, 06 May 2013)
New Revision: 7477
Added:
trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureSource.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureSource.h
trunk/MgDev/Common/Stylization/ExpressionFunctionHtmlColor.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionHtmlColor.h
trunk/MgDev/Common/Stylization/ExpressionFunctionLayerDefinition.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionLayerDefinition.h
trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterX.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterX.h
trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterY.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterY.h
trunk/MgDev/Common/Stylization/ExpressionFunctionMapScale.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionMapScale.h
trunk/MgDev/UnitTest/TestData/TileService/UT_StylizationFuncs.mdf
trunk/MgDev/UnitTest/TestData/TileService/UT_VotingDistrictsFunctions.ldf
trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
trunk/MgDev/Common/Stylization/ExpressionHelper.cpp
trunk/MgDev/Common/Stylization/Makefile.am
trunk/MgDev/Common/Stylization/RendererStyles.h
trunk/MgDev/Common/Stylization/Stylization.vcxproj
trunk/MgDev/Common/Stylization/Stylization.vcxproj.filters
trunk/MgDev/Desktop/MgDesktop/Services/MappingService.cpp
trunk/MgDev/Desktop/MgDesktop/Services/Rendering/MappingUtil.cpp
trunk/MgDev/Desktop/MgDesktop/Services/RenderingService.cpp
trunk/MgDev/Desktop/UnitTest/TestRenderingService.cpp
trunk/MgDev/Desktop/UnitTest/TestRenderingService.h
trunk/MgDev/Server/src/Core/Makefile.am
trunk/MgDev/Server/src/PostBuild/PostBuild.mak
trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp
trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h
Merge in sandbox implementation of RFC 133 (Additional Stylization Expression Functions) to trunk. This completes the implementation work.
Modified: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2013-05-06 12:46:20 UTC (rev 7477)
@@ -439,17 +439,26 @@
MgFunctionDECAP_StringValueDescription = String to format
MgFunctionFEATURECLASS_Description = Returns the active feature class name
MgFunctionFEATUREID_Description = Returns the active feature Id
+MgFunctionFEATURESOURCE_Description = Returns the Feature Source resource id where the current feature originates from
+MgFunctionHTMLCOLOR_Description = HTML Color generation function
+MgFunctionHTMLCOLOR_RValueDescription = Red value
+MgFunctionHTMLCOLOR_GValueDescription = Green value
+MgFunctionHTMLCOLOR_BValueDescription = Blue value
MgFunctionIF_Description = If evaluator for style theming
MgFunctionIF_ConditionDescription = Boolean expression (filter) encapsulated in a string
MgFunctionIF_TrueValueDescription = Returned if condition is true
MgFunctionIF_FalseValueDescription = Returned if condition is false
MgFunctionLAYERID_Description = Returns the active layer Id
+MgFunctionLAYERDEFINITION_Description = Returns the Layer Definition resource id used for stylizing the current feature
MgFunctionLOOKUP_Description = Lookup table for style theming
MgFunctionLOOKUP_ExpressionDescription = Key expression
MgFunctionLOOKUP_DefaultValueDescription = Default value returned if expression does not evaluate to any of the keys
MgFunctionLOOKUP_IndexDescription = Lookup index that can be matched by the key expression
MgFunctionLOOKUP_ValueDescription = Value that is returned when the key expression matches the associated index
+MgFunctionMAPCENTERX_Description = Returns the X coordinate of the view center of the currently rendered map
+MgFunctionMAPCENTERY_Description = Returns the Y coordinate of the view center of the currently rendered map
MgFunctionMAPNAME_Description = Returns the active map name
+MgFunctionMAPSCALE_Description = Returns the scale of the currently rendered map
MgFunctionRANGE_Description = Range table for style theming
MgFunctionRANGE_ExpressionDescription = Key expression
MgFunctionRANGE_DefaultValueDescription = Default value returned if expression does not fall into any of the ranges
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureSource.cpp (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionFeatureSource.cpp)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureSource.cpp (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureSource.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,91 @@
+// Copyright (C) 2007-2013 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "stdafx.h"
+#include "ExpressionFunctionFeatureSource.h"
+#include "Foundation.h"
+ExpressionFunctionFeatureSource::ExpressionFunctionFeatureSource(const wchar_t* featureSourceId)
+ m_featureSourceIdValue = FdoStringValue::Create(featureSourceId);
+ m_functionDefinition = NULL;
+ExpressionFunctionFeatureSource::~ExpressionFunctionFeatureSource()
+ FDO_SAFE_RELEASE(m_featureSourceIdValue);
+ FDO_SAFE_RELEASE(m_functionDefinition);
+ExpressionFunctionFeatureSource* ExpressionFunctionFeatureSource::Create(const wchar_t* featureSourceId)
+ return new ExpressionFunctionFeatureSource(featureSourceId);
+FdoFunctionDefinition* ExpressionFunctionFeatureSource::GetFunctionDefinition()
+ if (!m_functionDefinition)
+ STRING funcDesc = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgFunctionFEATURESOURCE_Description");
+ FdoPtr<FdoArgumentDefinitionCollection> args = FdoArgumentDefinitionCollection::Create();
+ m_functionDefinition = FdoFunctionDefinition::Create(L"FEATURESOURCE", // NOXLATE
+ funcDesc.c_str(),
+ FdoDataType_String,
+ args,
+ FdoFunctionCategoryType_String,
+ false);
+ return FDO_SAFE_ADDREF(m_functionDefinition);
+FdoLiteralValue* ExpressionFunctionFeatureSource::Evaluate(FdoLiteralValueCollection* literalValues)
+ // make sure we have zero arguments
+ if (literalValues->GetCount() != 0)
+ MgResources* resources = MgResources::GetInstance();
+ assert(NULL != resources);
+ STRING message = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgIncorrectNumberOfArguments");
+ MgStringCollection arguments;
+ arguments.Add(L"FEATURESOURCE"); // NOXLATE
+ message = resources->FormatMessage(message, &arguments);
+ throw FdoExpressionException::Create(message.c_str());
+ return FDO_SAFE_ADDREF(m_featureSourceIdValue);
+FdoExpressionEngineIFunction* ExpressionFunctionFeatureSource::CreateObject()
+ return ExpressionFunctionFeatureSource::Create(m_featureSourceIdValue->GetString());
+void ExpressionFunctionFeatureSource::Dispose()
+ delete this;
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureSource.h (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionFeatureSource.h)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureSource.h (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureSource.h 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,51 @@
+#ifndef EXPRESSION_FUNCTION_FEATURESOURCE_H_
+#define EXPRESSION_FUNCTION_FEATURESOURCE_H_
+#include "Stylization.h"
+class ExpressionFunctionFeatureSource : public FdoExpressionEngineINonAggregateFunction
+public:
+ ExpressionFunctionFeatureSource(const wchar_t* featureSourceId);
+ ~ExpressionFunctionFeatureSource();
+ static ExpressionFunctionFeatureSource* Create(const wchar_t* featureSourceId);
+ // FdoExpressionEngineINonAggregateFunction implementation
+ virtual FdoLiteralValue* Evaluate(FdoLiteralValueCollection* literalValues);
+ // FdoExpressionEngineIFunction implementation
+ virtual FdoFunctionDefinition* GetFunctionDefinition();
+ virtual FdoExpressionEngineIFunction* CreateObject();
+ // FdoIDisposable implementation
+ virtual void Dispose();
+private:
+ FdoStringValue* m_featureSourceIdValue;
+ FdoFunctionDefinition* m_functionDefinition;
+#endif
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionHtmlColor.cpp (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionHtmlColor.cpp)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionHtmlColor.cpp (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionHtmlColor.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,127 @@
+#include "ExpressionFunctionHtmlColor.h"
+#include "ExpressionHelper.h"
+ExpressionFunctionHtmlColor::ExpressionFunctionHtmlColor()
+ m_htmlColorValue = FdoStringValue::Create();
+ExpressionFunctionHtmlColor::~ExpressionFunctionHtmlColor()
+ FDO_SAFE_RELEASE(m_htmlColorValue);
+ExpressionFunctionHtmlColor* ExpressionFunctionHtmlColor::Create()
+ return new ExpressionFunctionHtmlColor();
+FdoFunctionDefinition* ExpressionFunctionHtmlColor::GetFunctionDefinition()
+ STRING funcDesc = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgFunctionHTMLCOLOR_Description");
+ STRING rValDesc = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgFunctionHTMLCOLOR_RValueDescription");
+ STRING gValDesc = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgFunctionHTMLCOLOR_GValueDescription");
+ STRING bValDesc = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgFunctionHTMLCOLOR_BValueDescription");
+ FdoPtr<FdoArgumentDefinition> arg1 = FdoArgumentDefinition::Create(L"rValue", rValDesc.c_str(), FdoDataType_Int32); // NOXLATE
+ FdoPtr<FdoArgumentDefinition> arg2 = FdoArgumentDefinition::Create(L"gValue", gValDesc.c_str(), FdoDataType_Int32); // NOXLATE
+ FdoPtr<FdoArgumentDefinition> arg3 = FdoArgumentDefinition::Create(L"bValue", bValDesc.c_str(), FdoDataType_Int32); // NOXLATE
+ args->Add(arg1);
+ args->Add(arg2);
+ args->Add(arg3);
+ m_functionDefinition = FdoFunctionDefinition::Create(L"HTMLCOLOR", // NOXLATE
+ funcDesc.c_str(),
+ FdoDataType_Int32,
+ args,
+ false);
+FdoLiteralValue* ExpressionFunctionHtmlColor::Evaluate(FdoLiteralValueCollection* literalValues)
+ // make sure we have three arguments
+ if (literalValues->GetCount() != 3)
+ arguments.Add(L"HTMLCOLOR"); // NOXLATE
+ FdoPtr<FdoLiteralValue> arg1 = literalValues->GetItem(0);
+ FdoPtr<FdoLiteralValue> arg2 = literalValues->GetItem(1);
+ FdoPtr<FdoLiteralValue> arg3 = literalValues->GetItem(2);
+ FdoInt32 red = ExpressionHelper::GetAsInt32(arg1);
+ FdoInt32 green = ExpressionHelper::GetAsInt32(arg2);
+ FdoInt32 blue = ExpressionHelper::GetAsInt32(arg3);
+ // clean up
+ red &= 0xFF;
+ green &= 0xFF;
+ blue &= 0xFF;
+ wchar_t tmp[32] = { 0 };
+ std::wstring str;
+ swprintf(tmp, 32, L"%0.2x", red);
+ str.append(&tmp[0]);
+ swprintf(tmp, 32, L"%0.2x", green);
+ swprintf(tmp, 32, L"%0.2x", blue);
+ m_htmlColorValue->SetString(str.c_str());
+ return FDO_SAFE_ADDREF(m_htmlColorValue);
+FdoExpressionEngineIFunction* ExpressionFunctionHtmlColor::CreateObject()
+ return ExpressionFunctionHtmlColor::Create();
+void ExpressionFunctionHtmlColor::Dispose()
+ delete this;
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionHtmlColor.h (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionHtmlColor.h)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionHtmlColor.h (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionHtmlColor.h 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,52 @@
+#ifndef EXPRESSION_FUNCTION_HTMLCOLOR_H_
+#define EXPRESSION_FUNCTION_HTMLCOLOR_H_
+class ExpressionFunctionHtmlColor : public FdoExpressionEngineINonAggregateFunction
+public:
+ ExpressionFunctionHtmlColor();
+ ~ExpressionFunctionHtmlColor();
+ static ExpressionFunctionHtmlColor* Create();
+private:
+ FdoStringValue* m_htmlColorValue;
+#endif
\ No newline at end of file
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionLayerDefinition.cpp (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionLayerDefinition.cpp)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionLayerDefinition.cpp (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionLayerDefinition.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,91 @@
+#include "ExpressionFunctionLayerDefinition.h"
+ExpressionFunctionLayerDefinition::ExpressionFunctionLayerDefinition(const wchar_t* layerDefinitionId)
+ m_layerDefinitionIdValue = FdoStringValue::Create(layerDefinitionId);
+ExpressionFunctionLayerDefinition::~ExpressionFunctionLayerDefinition()
+ FDO_SAFE_RELEASE(m_layerDefinitionIdValue);
+ExpressionFunctionLayerDefinition* ExpressionFunctionLayerDefinition::Create(const wchar_t* layerDefinitionId)
+ return new ExpressionFunctionLayerDefinition(layerDefinitionId);
+FdoFunctionDefinition* ExpressionFunctionLayerDefinition::GetFunctionDefinition()
+ STRING funcDesc = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgFunctionLAYERDEFINITION_Description");
+ m_functionDefinition = FdoFunctionDefinition::Create(L"LAYERDEFINITION", // NOXLATE
+ funcDesc.c_str(),
+ args,
+ false);
+FdoLiteralValue* ExpressionFunctionLayerDefinition::Evaluate(FdoLiteralValueCollection* literalValues)
+ arguments.Add(L"LAYERDEFINITION"); // NOXLATE
+ return FDO_SAFE_ADDREF(m_layerDefinitionIdValue);
+FdoExpressionEngineIFunction* ExpressionFunctionLayerDefinition::CreateObject()
+ return ExpressionFunctionLayerDefinition::Create(m_layerDefinitionIdValue->GetString());
+void ExpressionFunctionLayerDefinition::Dispose()
+ delete this;
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionLayerDefinition.h (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionLayerDefinition.h)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionLayerDefinition.h (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionLayerDefinition.h 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,51 @@
+#ifndef EXPRESSION_FUNCTION_LAYERDEFINITION_H_
+#define EXPRESSION_FUNCTION_LAYERDEFINITION_H_
+class ExpressionFunctionLayerDefinition : public FdoExpressionEngineINonAggregateFunction
+public:
+ ExpressionFunctionLayerDefinition(const wchar_t* layerDefinitionId);
+ ~ExpressionFunctionLayerDefinition();
+ static ExpressionFunctionLayerDefinition* Create(const wchar_t* layerDefinitionId);
+private:
+ FdoStringValue* m_layerDefinitionIdValue;
+#endif
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterX.cpp (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionMapCenterX.cpp)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterX.cpp (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterX.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,91 @@
+#include "ExpressionFunctionMapCenterX.h"
+ExpressionFunctionMapCenterX::ExpressionFunctionMapCenterX(const double xValue)
+ m_xValue = FdoDoubleValue::Create(xValue);
+ExpressionFunctionMapCenterX::~ExpressionFunctionMapCenterX()
+ FDO_SAFE_RELEASE(m_xValue);
+ExpressionFunctionMapCenterX* ExpressionFunctionMapCenterX::Create(const double xValue)
+ return new ExpressionFunctionMapCenterX(xValue);
+FdoFunctionDefinition* ExpressionFunctionMapCenterX::GetFunctionDefinition()
+ STRING funcDesc = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgFunctionMAPCENTERX_Description");
+ m_functionDefinition = FdoFunctionDefinition::Create(L"MAPCENTERX", // NOXLATE
+ funcDesc.c_str(),
+ FdoDataType_Double,
+ args,
+ FdoFunctionCategoryType_Numeric,
+ false);
+FdoLiteralValue* ExpressionFunctionMapCenterX::Evaluate(FdoLiteralValueCollection* literalValues)
+ arguments.Add(L"MAPCENTERX"); // NOXLATE
+ return FDO_SAFE_ADDREF(m_xValue);
+FdoExpressionEngineIFunction* ExpressionFunctionMapCenterX::CreateObject()
+ return ExpressionFunctionMapCenterX::Create(m_xValue->GetDouble());
+void ExpressionFunctionMapCenterX::Dispose()
+ delete this;
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterX.h (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionMapCenterX.h)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterX.h (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterX.h 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,52 @@
+#ifndef EXPRESSION_FUNCTION_MAPCENTERX_H_
+#define EXPRESSION_FUNCTION_MAPCENTERX_H_
+class ExpressionFunctionMapCenterX : public FdoExpressionEngineINonAggregateFunction
+public:
+ ExpressionFunctionMapCenterX(const double xValue);
+ ~ExpressionFunctionMapCenterX();
+ static ExpressionFunctionMapCenterX* Create(const double xValue);
+private:
+ FdoDoubleValue* m_xValue;
+#endif
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterY.cpp (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionMapCenterY.cpp)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterY.cpp (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterY.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,91 @@
+#include "ExpressionFunctionMapCenterY.h"
+ExpressionFunctionMapCenterY::ExpressionFunctionMapCenterY(const double yValue)
+ m_yValue = FdoDoubleValue::Create(yValue);
+ExpressionFunctionMapCenterY::~ExpressionFunctionMapCenterY()
+ FDO_SAFE_RELEASE(m_yValue);
+ExpressionFunctionMapCenterY* ExpressionFunctionMapCenterY::Create(const double yValue)
+ return new ExpressionFunctionMapCenterY(yValue);
+FdoFunctionDefinition* ExpressionFunctionMapCenterY::GetFunctionDefinition()
+ STRING funcDesc = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgFunctionMAPCENTERY_Description");
+ m_functionDefinition = FdoFunctionDefinition::Create(L"MAPCENTERY", // NOXLATE
+ funcDesc.c_str(),
+ args,
+ false);
+FdoLiteralValue* ExpressionFunctionMapCenterY::Evaluate(FdoLiteralValueCollection* literalValues)
+ arguments.Add(L"MAPCENTERY"); // NOXLATE
+ return FDO_SAFE_ADDREF(m_yValue);
+FdoExpressionEngineIFunction* ExpressionFunctionMapCenterY::CreateObject()
+ return ExpressionFunctionMapCenterY::Create(m_yValue->GetDouble());
+void ExpressionFunctionMapCenterY::Dispose()
+ delete this;
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterY.h (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionMapCenterY.h)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterY.h (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionMapCenterY.h 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,52 @@
+#ifndef EXPRESSION_FUNCTION_MAPCENTERY_H_
+#define EXPRESSION_FUNCTION_MAPCENTERY_H_
+class ExpressionFunctionMapCenterY : public FdoExpressionEngineINonAggregateFunction
+public:
+ ExpressionFunctionMapCenterY(const double yValue);
+ ~ExpressionFunctionMapCenterY();
+ static ExpressionFunctionMapCenterY* Create(const double yValue);
+private:
+ FdoDoubleValue* m_yValue;
+#endif
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionMapScale.cpp (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionMapScale.cpp)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionMapScale.cpp (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionMapScale.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,91 @@
+#include "ExpressionFunctionMapScale.h"
+ExpressionFunctionMapScale::ExpressionFunctionMapScale(const double scaleValue)
+ m_scaleValue = FdoDoubleValue::Create(scaleValue);
+ExpressionFunctionMapScale::~ExpressionFunctionMapScale()
+ FDO_SAFE_RELEASE(m_scaleValue);
+ExpressionFunctionMapScale* ExpressionFunctionMapScale::Create(const double scaleValue)
+ return new ExpressionFunctionMapScale(scaleValue);
+FdoFunctionDefinition* ExpressionFunctionMapScale::GetFunctionDefinition()
+ STRING funcDesc = MgUtil::GetResourceMessage(MgResources::Stylization, L"MgFunctionMAPSCALE_Description");
+ m_functionDefinition = FdoFunctionDefinition::Create(L"MAPSCALE", // NOXLATE
+ funcDesc.c_str(),
+ args,
+ false);
+FdoLiteralValue* ExpressionFunctionMapScale::Evaluate(FdoLiteralValueCollection* literalValues)
+ arguments.Add(L"MAPSCALE"); // NOXLATE
+ return FDO_SAFE_ADDREF(m_scaleValue);
+FdoExpressionEngineIFunction* ExpressionFunctionMapScale::CreateObject()
+ return ExpressionFunctionMapScale::Create(m_scaleValue->GetDouble());
+void ExpressionFunctionMapScale::Dispose()
+ delete this;
Copied: trunk/MgDev/Common/Stylization/ExpressionFunctionMapScale.h (from rev 7462, sandbox/jng/extra_stylization_funcs/Common/Stylization/ExpressionFunctionMapScale.h)
--- trunk/MgDev/Common/Stylization/ExpressionFunctionMapScale.h (rev 0)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionMapScale.h 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,52 @@
+#ifndef EXPRESSION_FUNCTION_MAPCENTERSCALE_H_
+#define EXPRESSION_FUNCTION_MAPCENTERSCALE_H_
+class ExpressionFunctionMapScale : public FdoExpressionEngineINonAggregateFunction
+public:
+ ExpressionFunctionMapScale(const double scaleValue);
+ ~ExpressionFunctionMapScale();
+ static ExpressionFunctionMapScale* Create(const double scaleValue);
+private:
+ FdoDoubleValue* m_scaleValue;
+#endif
Modified: trunk/MgDev/Common/Stylization/ExpressionHelper.cpp
--- trunk/MgDev/Common/Stylization/ExpressionHelper.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Common/Stylization/ExpressionHelper.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -21,14 +21,22 @@
#include "ExpressionFunctionDecap.h"
#include "ExpressionFunctionFeatureClass.h"
#include "ExpressionFunctionFeatureId.h"
#include "ExpressionFunctionLayerId.h"
#include "ExpressionFunctionMapName.h"
#include "ExpressionFunctionSession.h"
#include "ExpressionFunctionUrlEncode.h"
#include "ExpressionFunctionIf.h"
#include "ExpressionFunctionLookup.h"
#include "ExpressionFunctionRange.h"
#include "RS_FeatureReader.h"
@@ -45,7 +53,15 @@
// common functions
RS_FeatureClassInfo* featInfo = renderer? renderer->GetFeatureClassInfo() : NULL;
const RS_String& featCls = (featInfo != NULL)? featInfo->name() : s_Empty;
+ const RS_String& featSource = (featInfo != NULL) ? featInfo->source() : s_Empty;
+ RS_MapUIInfo* mapInfo = renderer? renderer->GetMapInfo() : NULL;
+ RS_LayerUIInfo* layerInfo = renderer? renderer->GetLayerInfo() : NULL;
+ const double mapScale = (mapInfo != NULL) ? mapInfo->scale() : 0.0;
+ const double mapX = (mapInfo != NULL) ? mapInfo->viewx() : 0.0;
+ const double mapY = (mapInfo != NULL) ? mapInfo->viewy() : 0.0;
+ const RS_String& layerDef = (layerInfo != NULL) ? layerInfo->layerdef() : s_Empty;
FdoPtr<ExpressionFunctionArgb> funcArgb = ExpressionFunctionArgb::Create();
FdoPtr<ExpressionFunctionDecap> funcDecap = ExpressionFunctionDecap::Create();
FdoPtr<ExpressionFunctionFeatureClass> funcFeatureClass = ExpressionFunctionFeatureClass::Create(featCls.c_str());
@@ -53,6 +69,11 @@
FdoPtr<ExpressionFunctionIf> funcIf = ExpressionFunctionIf::Create();
FdoPtr<ExpressionFunctionLookup> funcLookup = ExpressionFunctionLookup::Create();
FdoPtr<ExpressionFunctionRange> funcRange = ExpressionFunctionRange::Create();
+ FdoPtr<ExpressionFunctionFeatureSource> funcFeatureSource = ExpressionFunctionFeatureSource::Create(featSource.c_str());
+ FdoPtr<ExpressionFunctionLayerDefinition> funcLayerDefinition = ExpressionFunctionLayerDefinition::Create(layerDef.c_str());
+ FdoPtr<ExpressionFunctionMapCenterX> funcMapCenterX = ExpressionFunctionMapCenterX::Create(mapX);
+ FdoPtr<ExpressionFunctionMapCenterY> funcMapCenterY = ExpressionFunctionMapCenterY::Create(mapY);
+ FdoPtr<ExpressionFunctionMapScale> funcMapScale = ExpressionFunctionMapScale::Create(mapScale);
userDefinedFunctions->Add(funcIf); // make IF the first one to optimize search in GetExpressionEngine
userDefinedFunctions->Add(funcArgb);
@@ -61,20 +82,25 @@
userDefinedFunctions->Add(funcUrlEncode);
userDefinedFunctions->Add(funcLookup);
userDefinedFunctions->Add(funcRange);
+ userDefinedFunctions->Add(funcFeatureSource);
+ userDefinedFunctions->Add(funcLayerDefinition);
+ userDefinedFunctions->Add(funcMapCenterX);
+ userDefinedFunctions->Add(funcMapCenterY);
+ userDefinedFunctions->Add(funcMapScale);
// MapGuide-specific functions
#ifndef MG_EXCLUDE_EXPRESSION_FUNCTIONS
- RS_MapUIInfo* mapInfo = renderer? renderer->GetMapInfo() : NULL;
- RS_LayerUIInfo* layerInfo = renderer? renderer->GetLayerInfo() : NULL;
const RS_String& session = ( mapInfo != NULL)? mapInfo->session() : s_Empty;
const RS_String& mapName = ( mapInfo != NULL)? mapInfo->name() : s_Empty;
const RS_String& layerId = (layerInfo != NULL)? layerInfo->guid() : s_Empty;
+ FdoPtr<ExpressionFunctionHtmlColor> funcHtmlColor = ExpressionFunctionHtmlColor::Create();
FdoPtr<ExpressionFunctionFeatureId> funcFeatureId = ExpressionFunctionFeatureId::Create(reader);
FdoPtr<ExpressionFunctionLayerId> funcLayerId = ExpressionFunctionLayerId::Create(layerId.c_str());
FdoPtr<ExpressionFunctionMapName> funcMapName = ExpressionFunctionMapName::Create(mapName.c_str());
FdoPtr<ExpressionFunctionSession> funcSession = ExpressionFunctionSession::Create(session.c_str());
+ userDefinedFunctions->Add(funcHtmlColor);
userDefinedFunctions->Add(funcFeatureId);
userDefinedFunctions->Add(funcLayerId);
userDefinedFunctions->Add(funcMapName);
Modified: trunk/MgDev/Common/Stylization/Makefile.am
--- trunk/MgDev/Common/Stylization/Makefile.am 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Common/Stylization/Makefile.am 2013-05-06 12:46:20 UTC (rev 7477)
@@ -30,10 +30,16 @@
ExpressionFunctionDecap.cpp \
ExpressionFunctionFeatureClass.cpp \
ExpressionFunctionFeatureId.cpp \
+ ExpressionFunctionFeatureSource.cpp \
+ ExpressionFunctionHtmlColor.cpp \
ExpressionFunctionIf.cpp \
+ ExpressionFunctionLayerDefinition.cpp \
ExpressionFunctionLayerId.cpp \
ExpressionFunctionLookup.cpp \
+ ExpressionFunctionMapCenterX.cpp \
+ ExpressionFunctionMapCenterY.cpp \
ExpressionFunctionMapName.cpp \
+ ExpressionFunctionMapScale.cpp \
ExpressionFunctionRange.cpp \
ExpressionFunctionSession.cpp \
ExpressionFunctionUrlEncode.cpp \
@@ -117,10 +123,16 @@
ExpressionFunctionDecap.h \
ExpressionFunctionFeatureClass.h \
ExpressionFunctionFeatureId.h \
+ ExpressionFunctionFeatureSource.h \
+ ExpressionFunctionHtmlColor.h \
ExpressionFunctionIf.h \
+ ExpressionFunctionLayerDefinition.h \
ExpressionFunctionLayerId.h \
ExpressionFunctionLookup.h \
+ ExpressionFunctionMapCenterX.h \
+ ExpressionFunctionMapCenterY.h \
ExpressionFunctionMapName.h \
+ ExpressionFunctionMapScale.h \
ExpressionFunctionRange.h \
ExpressionFunctionSession.h \
ExpressionFunctionUrlEncode.h \
Modified: trunk/MgDev/Common/Stylization/RendererStyles.h
--- trunk/MgDev/Common/Stylization/RendererStyles.h 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Common/Stylization/RendererStyles.h 2013-05-06 12:46:20 UTC (rev 7477)
@@ -582,6 +582,7 @@
public:
RS_LayerUIInfo() :
m_name(L""),
+ m_layerdef(L""),
m_guid(L""),
m_selectable(true),
m_visible(true),
@@ -598,6 +599,7 @@
RS_LayerUIInfo(const RS_String& name,
+ const RS_String& layerdef,
const RS_String& guid,
bool selectable,
bool visible,
@@ -611,6 +613,7 @@
bool hastooltips = false,
bool hashyperlinks = false) :
m_name(name),
+ m_layerdef(layerdef),
m_guid(guid),
m_selectable(selectable),
m_visible(visible),
@@ -627,6 +630,7 @@
inline RS_String& name() { return m_name; }
+ inline RS_String& layerdef() { return m_layerdef; }
inline RS_String& guid() { return m_guid; }
inline bool& selectable() { return m_selectable; }
inline bool& visible() { return m_visible; }
@@ -642,6 +646,7 @@
private:
RS_String m_name;
+ RS_String m_layerdef;
RS_String m_guid;
bool m_selectable;
bool m_visible;
@@ -667,7 +672,10 @@
m_guid(L""),
m_coordsys(L""),
m_units(L""),
- m_bgcolor(255, 255, 255, 255)
+ m_bgcolor(255, 255, 255, 255),
+ m_viewx(0.0),
+ m_viewy(0.0),
+ m_scale(0.0)
@@ -676,13 +684,19 @@
const RS_String& coordsys,
const RS_String& units,
- const RS_Color& bgcolor) :
+ const RS_Color& bgcolor,
+ const double viewx = 0.0,
+ const double viewy = 0.0,
+ const double scale = 0.0) :
m_session(session),
m_name(name),
m_guid(guid),
m_coordsys(coordsys),
m_units(units),
- m_bgcolor(bgcolor)
+ m_bgcolor(bgcolor),
+ m_viewx(viewx),
+ m_viewy(viewy),
+ m_scale(scale)
@@ -692,6 +706,9 @@
inline RS_String& coordsys() { return m_coordsys; }
inline RS_String& units() { return m_units; }
inline RS_Color& bgcolor() { return m_bgcolor; }
+ inline double& scale() { return m_scale; }
+ inline double& viewx() { return m_viewx; }
+ inline double& viewy() { return m_viewy; }
private:
RS_String m_session;
@@ -700,6 +717,9 @@
RS_String m_coordsys;
RS_String m_units;
RS_Color m_bgcolor;
+ double m_scale;
+ double m_viewx;
+ double m_viewy;
@@ -708,12 +728,12 @@
public:
RS_FeatureClassInfo() :
- m_name(L"")
+ m_name(L""), m_source(L"")
- RS_FeatureClassInfo(const RS_String& name) :
- m_name(name)
+ RS_FeatureClassInfo(const RS_String& name, const RS_String& source) :
+ m_name(name), m_source(source)
@@ -730,8 +750,10 @@
inline std::vector<RS_String>& mappings() { return m_propMappings; }
+ inline RS_String& source() { return m_source; }
private:
+ RS_String m_source;
RS_String m_name;
std::vector<RS_String> m_propMappings;
Modified: trunk/MgDev/Common/Stylization/Stylization.vcxproj
--- trunk/MgDev/Common/Stylization/Stylization.vcxproj 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Common/Stylization/Stylization.vcxproj 2013-05-06 12:46:20 UTC (rev 7477)
@@ -215,10 +215,16 @@
<ClCompile Include="ExpressionFunctionDecap.cpp" />
<ClCompile Include="ExpressionFunctionFeatureClass.cpp" />
<ClCompile Include="ExpressionFunctionFeatureId.cpp" />
+ <ClCompile Include="ExpressionFunctionFeatureSource.cpp" />
+ <ClCompile Include="ExpressionFunctionHtmlColor.cpp" />
<ClCompile Include="ExpressionFunctionIf.cpp" />
+ <ClCompile Include="ExpressionFunctionLayerDefinition.cpp" />
<ClCompile Include="ExpressionFunctionLayerId.cpp" />
<ClCompile Include="ExpressionFunctionLookup.cpp" />
+ <ClCompile Include="ExpressionFunctionMapCenterX.cpp" />
+ <ClCompile Include="ExpressionFunctionMapCenterY.cpp" />
<ClCompile Include="ExpressionFunctionMapName.cpp" />
+ <ClCompile Include="ExpressionFunctionMapScale.cpp" />
<ClCompile Include="ExpressionFunctionRange.cpp" />
<ClCompile Include="ExpressionFunctionSession.cpp" />
<ClCompile Include="ExpressionFunctionUrlEncode.cpp" />
@@ -297,10 +303,16 @@
<ClInclude Include="ExpressionFunctionDecap.h" />
<ClInclude Include="ExpressionFunctionFeatureClass.h" />
<ClInclude Include="ExpressionFunctionFeatureId.h" />
+ <ClInclude Include="ExpressionFunctionFeatureSource.h" />
+ <ClInclude Include="ExpressionFunctionHtmlColor.h" />
<ClInclude Include="ExpressionFunctionIf.h" />
+ <ClInclude Include="ExpressionFunctionLayerDefinition.h" />
<ClInclude Include="ExpressionFunctionLayerId.h" />
<ClInclude Include="ExpressionFunctionLookup.h" />
+ <ClInclude Include="ExpressionFunctionMapCenterX.h" />
+ <ClInclude Include="ExpressionFunctionMapCenterY.h" />
<ClInclude Include="ExpressionFunctionMapName.h" />
+ <ClInclude Include="ExpressionFunctionMapScale.h" />
<ClInclude Include="ExpressionFunctionRange.h" />
<ClInclude Include="ExpressionFunctionSession.h" />
<ClInclude Include="ExpressionFunctionUrlEncode.h" />
Modified: trunk/MgDev/Common/Stylization/Stylization.vcxproj.filters
--- trunk/MgDev/Common/Stylization/Stylization.vcxproj.filters 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Common/Stylization/Stylization.vcxproj.filters 2013-05-06 12:46:20 UTC (rev 7477)
@@ -265,6 +265,24 @@
<Filter>Shared</Filter>
</ClCompile>
<ClCompile Include="ThemeParameters.cpp" />
+ <ClCompile Include="ExpressionFunctionHtmlColor.cpp">
+ <Filter>ExpressionEngine</Filter>
+ </ClCompile>
+ <ClCompile Include="ExpressionFunctionFeatureSource.cpp">
+ </ClCompile>
+ <ClCompile Include="ExpressionFunctionLayerDefinition.cpp">
+ </ClCompile>
+ <ClCompile Include="ExpressionFunctionMapCenterX.cpp">
+ </ClCompile>
+ <ClCompile Include="ExpressionFunctionMapCenterY.cpp">
+ </ClCompile>
+ <ClCompile Include="ExpressionFunctionMapScale.cpp">
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="ExpressionFunctionArgb.h">
@@ -572,6 +590,24 @@
<ClInclude Include="StylizationAPI.h" />
<ClInclude Include="StylizationDefs.h" />
<ClInclude Include="ThemeParameters.h" />
+ <ClInclude Include="ExpressionFunctionHtmlColor.h">
+ </ClInclude>
+ <ClInclude Include="ExpressionFunctionFeatureSource.h">
+ </ClInclude>
+ <ClInclude Include="ExpressionFunctionLayerDefinition.h">
+ </ClInclude>
+ <ClInclude Include="ExpressionFunctionMapCenterX.h">
+ </ClInclude>
+ <ClInclude Include="ExpressionFunctionMapCenterY.h">
+ </ClInclude>
+ <ClInclude Include="ExpressionFunctionMapScale.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="Stylization.rc" />
Modified: trunk/MgDev/Desktop/MgDesktop/Services/MappingService.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/MappingService.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Desktop/MgDesktop/Services/MappingService.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -834,7 +834,7 @@
if (userInfo != NULL)
sessionId = userInfo->GetMgSessionId();*/
- RS_MapUIInfo mapInfo(sessionId, map->GetName(), L"", srs, units, layoutColor);
+ RS_MapUIInfo mapInfo(sessionId, map->GetName(), L"", srs, units, layoutColor, center->GetX(), center->GetY(), dMapScale);
// Dynamically adjust the width and height of the map
printLayout->ComputeMapOffsetAndSize(dMapScale, extents, metersPerUnit, dr.mapOffsetX(), dr.mapOffsetY(), dr.mapWidth(), dr.mapHeight(), mapPlot->GetExpandToFit());
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Rendering/MappingUtil.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/Rendering/MappingUtil.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Rendering/MappingUtil.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -434,6 +434,7 @@
//layer legend and ui specific information
RS_UIGraphic uig(NULL, 0, mapLayer->GetLegendLabel());
RS_LayerUIInfo layerInfo( mapLayer->GetName(),
+ layerid->ToString(),
mapLayer->GetObjectId(),
mapLayer->GetSelectable(),
mapLayer->GetVisible(),
@@ -529,7 +530,7 @@
//string the viewer should be displaying as the name of each
//feature property
// TODO: check to see if name is FeatureClass or Extension name
- RS_FeatureClassInfo fcinfo(vl->GetFeatureName());
+ RS_FeatureClassInfo fcinfo(vl->GetFeatureName(), vl->GetResourceID());
MdfModel::NameStringPairCollection* pmappings = vl->GetPropertyMappings();
for (int j=0; j<pmappings->GetCount(); j++)
@@ -641,7 +642,7 @@
//feature property
- RS_FeatureClassInfo fcinfo(gl->GetFeatureName());
+ RS_FeatureClassInfo fcinfo(gl->GetFeatureName(), gl->GetResourceID());
//check for overridden feature query filter and remember it.
//we will use this when making feature queries
Modified: trunk/MgDev/Desktop/MgDesktop/Services/RenderingService.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/RenderingService.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Desktop/MgDesktop/Services/RenderingService.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -1293,9 +1293,6 @@
// get the session ID
STRING sessionId = map->GetSessionId();
- //Ptr<MgUserInformation> userInfo = MgUserInformation::GetCurrentUserInfo();
- //if (userInfo != NULL)
- // sessionId = userInfo->GetMgSessionId();
// initialize the stylizer
RSMgdSymbolManager mgr(m_svcResource);
@@ -1308,7 +1305,9 @@
STRING format = options->GetImageFormat();
- RS_MapUIInfo mapInfo(sessionId, map->GetName(), map->GetObjectId(), srs, units, bgcolor);
+ Ptr<MgPoint> ptCenter = map->GetViewCenter();
+ Ptr<MgCoordinate> coord = ptCenter->GetCoordinate();
+ RS_MapUIInfo mapInfo(sessionId, map->GetName(), map->GetObjectId(), srs, units, bgcolor, coord->GetX(), coord->GetY(), scale);
// begin map stylization
dr->StartMap(&mapInfo, b, scale, map->GetDisplayDpi(), map->GetMetersPerUnit(), NULL);
@@ -2084,7 +2083,7 @@
RS_Color bgcolor(0, 0, 0, 255); // not used
STRING srs = map->GetMapSRS();
- RS_MapUIInfo mapInfo(sessionId, map->GetName(), map->GetObjectId(), srs, L"", bgcolor);
+ RS_MapUIInfo mapInfo(sessionId, map->GetName(), map->GetObjectId(), srs, L"", bgcolor, center->GetX(), center->GetY(), scale);
SEMgdSymbolManager semgr(m_svcResource);
@@ -2241,7 +2240,9 @@
//for the first feature hit
RS_UIGraphic uig(NULL, 0, L"");
+ Ptr<MgResourceIdentifier> layerDefId = layer->GetLayerDefinition();
RS_LayerUIInfo layerinfo(layer->GetName(),
+ layerDefId->ToString(),
layer->GetObjectId(), // object ID
true, // selectable
true, // visible
@@ -2263,7 +2264,7 @@
//feature property
// TODO: can FeatureName be an extension name rather than a FeatureClass?
for (int i=0; i<pmappings->GetCount(); i++)
Modified: trunk/MgDev/Desktop/UnitTest/TestRenderingService.cpp
--- trunk/MgDev/Desktop/UnitTest/TestRenderingService.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Desktop/UnitTest/TestRenderingService.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -315,12 +315,23 @@
// publish the resource data
Ptr<MgByteSource> dataSource6 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.sdf", false);
Ptr<MgByteReader> dataReader6 = dataSource6->GetReader();
- m_svcResource->SetResourceData(fsres5, L"UT_RoadCenterLines.sdf", L"File", dataReader6);
+ m_svcResource->SetResourceData(fsres6, L"UT_RoadCenterLines.sdf", L"File", dataReader6);
Ptr<MgByteSource> dataSource7 = new MgByteSource(L"../UnitTestFiles/UT_VotingDistricts.sdf", false);
Ptr<MgByteReader> dataReader7 = dataSource7->GetReader();
- m_svcResource->SetResourceData(fsres6, L"UT_VotingDistricts.sdf", L"File", dataReader7);
+ m_svcResource->SetResourceData(fsres7, L"UT_VotingDistricts.sdf", L"File", dataReader7);
+ // Data related to stylization function tests
+ Ptr<MgResourceIdentifier> ldfres14 = new MgResourceIdentifier(L"Library://UnitTests/Layers/StylizationFuncs.LayerDefinition");
+ Ptr<MgByteSource> ldfsrc14 = new MgByteSource(L"../UnitTestFiles/UT_VotingDistrictsFunctions.ldf", false);
+ Ptr<MgByteReader> ldfrdr14 = ldfsrc14->GetReader();
+ m_svcResource->SetResource(ldfres14, ldfrdr14, NULL);
+ Ptr<MgResourceIdentifier> mapres15 = new MgResourceIdentifier(L"Library://UnitTests/Maps/StylizationFuncs.MapDefinition");
+ Ptr<MgByteSource> mdfsrc15 = new MgByteSource(L"../UnitTestFiles/UT_StylizationFuncs.mdf", false);
+ Ptr<MgByteReader> mdfrdr15 = mdfsrc15->GetReader();
+ m_svcResource->SetResource(mapres15, mdfrdr15, NULL);
catch (MgException* e)
@@ -440,6 +451,13 @@
m_svcResource->DeleteResource(fsres6);
Ptr<MgResourceIdentifier> fsres7 = new MgResourceIdentifier(L"Library://UnitTests/Data/VotingDistricts.FeatureSource");
m_svcResource->DeleteResource(fsres7);
+ m_svcResource->GetResourceHeader(ldfres14);
+ m_svcResource->GetResourceHeader(mapres15);
catch(MgFileIoException* e)
@@ -669,6 +687,42 @@
+void TestRenderingService::TestCase_StylizationFunctions(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgdMap> map = CreateTestStylizationFunctionMap();
+ // call the API using a scale of 75000
+ map->SetViewScale(75000.0);
+ Ptr<MgByteReader> rdr1 = m_svcRendering->RenderDynamicOverlay(map, NULL, imageFormat);
+ rdr1->ToFile(GetPath(L"../UnitTestFiles/StylizationFunc_75k", imageFormat, extension));
+ // call the API using a scale of 12000
+ map->SetViewScale(12000);
+ Ptr<MgByteReader> rdr2 = m_svcRendering->RenderDynamicOverlay(map, NULL, imageFormat);
+ rdr2->ToFile(GetPath(L"../UnitTestFiles/StylizationFunc_12k", imageFormat, extension));
+ // Move around
+ Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.733753, 43.746899);
+ Ptr<MgPoint> ptNewCenter = new MgPoint(coordNewCenter);
+ map->SetViewCenter(ptNewCenter);
+ Ptr<MgByteReader> rdr3 = m_svcRendering->RenderDynamicOverlay(map, NULL, imageFormat);
+ rdr3->ToFile(GetPath(L"../UnitTestFiles/StylizationFunc_12k_Moved", imageFormat, extension));
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
void TestRenderingService::TestCase_QueryFeatures()
try
@@ -740,6 +794,23 @@
return map;
+MgdMap* TestRenderingService::CreateTestStylizationFunctionMap()
+ Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/StylizationFuncs.MapDefinition");
+ MgdMap* map = new MgdMap(mdfres);
+ //map->Create(mdfres, L"StylizationFuncs");
+ Ptr<MgCoordinate> coordNewCenter = new MgCoordinateXY(-87.733253, 43.746199);
+ map->SetViewScale(60000.0);
+ map->SetDisplayDpi(96);
+ map->SetDisplayWidth(1024);
+ map->SetDisplayHeight(1024);
+ return map;
MgdMap* TestRenderingService::CreateTestTiledMap()
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/BaseMap.MapDefinition");
Modified: trunk/MgDev/Desktop/UnitTest/TestRenderingService.h
--- trunk/MgDev/Desktop/UnitTest/TestRenderingService.h 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Desktop/UnitTest/TestRenderingService.h 2013-05-06 12:46:20 UTC (rev 7477)
@@ -25,6 +25,8 @@
CPPUNIT_TEST_SUITE(TestRenderingService);
CPPUNIT_TEST(TestStart); // This must be the very first unit test
+ CPPUNIT_TEST(TestCase_StylizationFunctionsPNG);
CPPUNIT_TEST(TestCase_SymbologyPointsPNG);
CPPUNIT_TEST(TestCase_SymbologyPointsParamPNG);
CPPUNIT_TEST(TestCase_SymbologyLinesPNG);
@@ -41,6 +43,8 @@
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkPNG);
CPPUNIT_TEST(TestCase_RenderLegendPNG);
+ CPPUNIT_TEST(TestCase_StylizationFunctionsPNG8);
CPPUNIT_TEST(TestCase_SymbologyPointsPNG8);
CPPUNIT_TEST(TestCase_SymbologyPointsParamPNG8);
CPPUNIT_TEST(TestCase_SymbologyLinesPNG8);
@@ -57,6 +61,8 @@
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkPNG8);
CPPUNIT_TEST(TestCase_RenderLegendPNG8);
+ CPPUNIT_TEST(TestCase_StylizationFunctionsGIF);
CPPUNIT_TEST(TestCase_SymbologyPointsGIF);
CPPUNIT_TEST(TestCase_SymbologyPointsParamGIF);
CPPUNIT_TEST(TestCase_SymbologyLinesGIF);
@@ -73,6 +79,8 @@
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkGIF);
CPPUNIT_TEST(TestCase_RenderLegendGIF);
+ CPPUNIT_TEST(TestCase_StylizationFunctionsJPG);
CPPUNIT_TEST(TestCase_SymbologyPointsJPG);
CPPUNIT_TEST(TestCase_SymbologyPointsParamJPG);
CPPUNIT_TEST(TestCase_SymbologyLinesJPG);
@@ -122,6 +130,8 @@
void TestCase_Annotation2(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_Annotation3(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_StylizationFunctions(CREFSTRING imageFormat, CREFSTRING extension);
//PNG output tests
void TestCase_RenderDynamicOverlayPNG() { TestCase_RenderDynamicOverlay(L"PNG", L"png"); }
void TestCase_RenderDynamicOverlayTiledMapPNG() { TestCase_RenderDynamicOverlayTiledMap(L"PNG", L"png"); }
@@ -136,6 +146,7 @@
void TestCase_Annotation1PNG() { TestCase_Annotation1(L"PNG", L"png"); }
void TestCase_Annotation2PNG() { TestCase_Annotation2(L"PNG", L"png"); }
void TestCase_Annotation3PNG() { TestCase_Annotation3(L"PNG", L"png"); }
+ void TestCase_StylizationFunctionsPNG() { TestCase_StylizationFunctions(L"PNG", L"png"); }
//PNG8 output tests
void TestCase_RenderDynamicOverlayPNG8() { TestCase_RenderDynamicOverlay(L"PNG8", L"png"); }
@@ -151,6 +162,7 @@
void TestCase_Annotation1PNG8() { TestCase_Annotation1(L"PNG8", L"png"); }
void TestCase_Annotation2PNG8() { TestCase_Annotation2(L"PNG8", L"png"); }
void TestCase_Annotation3PNG8() { TestCase_Annotation3(L"PNG8", L"png"); }
+ void TestCase_StylizationFunctionsPNG8() { TestCase_StylizationFunctions(L"PNG8", L"png"); }
//GIF output tests
void TestCase_RenderDynamicOverlayGIF() { TestCase_RenderDynamicOverlay(L"GIF", L"gif"); }
@@ -166,6 +178,7 @@
void TestCase_Annotation1GIF() { TestCase_Annotation1(L"GIF", L"gif"); }
void TestCase_Annotation2GIF() { TestCase_Annotation2(L"GIF", L"gif"); }
void TestCase_Annotation3GIF() { TestCase_Annotation3(L"GIF", L"gif"); }
+ void TestCase_StylizationFunctionsGIF() { TestCase_StylizationFunctions(L"GIF", L"gif"); }
//JPG output tests
void TestCase_RenderDynamicOverlayJPG() { TestCase_RenderDynamicOverlay(L"JPG", L"jpg"); }
@@ -181,6 +194,7 @@
void TestCase_Annotation1JPG() { TestCase_Annotation1(L"JPG", L"jpg"); }
void TestCase_Annotation2JPG() { TestCase_Annotation2(L"JPG", L"jpg"); }
void TestCase_Annotation3JPG() { TestCase_Annotation3(L"JPG", L"jpg"); }
+ void TestCase_StylizationFunctionsJPG() { TestCase_StylizationFunctions(L"JPG", L"jpg"); }
void TestCase_QueryFeatures();
@@ -189,6 +203,7 @@
private:
MgdMap* CreateTestMap();
MgdMap* CreateTestTiledMap();
+ MgdMap* CreateTestStylizationFunctionMap();
MgdMap* CreateTestMapWithWatermark();
MgPolygon* CreateSelectionPolygon(MgdMap* map, double width, double height);
static STRING GetPath(CREFSTRING basePath, CREFSTRING imageFormat, CREFSTRING extension);
Modified: trunk/MgDev/Server/src/Core/Makefile.am
--- trunk/MgDev/Server/src/Core/Makefile.am 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Server/src/Core/Makefile.am 2013-05-06 12:46:20 UTC (rev 7477)
@@ -260,6 +260,7 @@
@cp -f ../../../UnitTest/TestData/Symbology/UT_Annotation3.ldf ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/Symbology/UT_Annotation3.mdf ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/TileService/UT_BaseMap.mdf ../UnitTestFiles
+ @cp -f ../../../UnitTest/TestData/TileService/UT_StylizationFuncs.mdf ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/TileService/UT_Parcels.fs ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/TileService/UT_Parcels.ldf ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/TileService/UT_Parcels.sdf ../UnitTestFiles
@@ -268,6 +269,7 @@
@cp -f ../../../UnitTest/TestData/TileService/UT_RoadCenterLines.sdf ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/TileService/UT_VotingDistricts.fs ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/TileService/UT_VotingDistricts.ldf ../UnitTestFiles
+ @cp -f ../../../UnitTest/TestData/TileService/UT_VotingDistrictsFunctions.ldf ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/TileService/UT_VotingDistricts.sdf ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/ServerAdmin/1.1.1.mgd ../UnitTestFiles
@cp -f ../../../UnitTest/TestData/CoordinateSystems/epsgcodes.txt ../UnitTestFiles
Modified: trunk/MgDev/Server/src/PostBuild/PostBuild.mak
--- trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Server/src/PostBuild/PostBuild.mak 2013-05-06 12:46:20 UTC (rev 7477)
@@ -164,6 +164,7 @@
..\..\bin\UnitTestFiles\TEST.FeatureSource \
..\..\bin\UnitTestFiles\TEST.sdf \
..\..\bin\UnitTestFiles\UT_BaseMap.mdf \
+ ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf \
..\..\bin\UnitTestFiles\UT_Parcels.fs \
..\..\bin\UnitTestFiles\UT_Parcels.ldf \
..\..\bin\UnitTestFiles\UT_Parcels.sdf \
@@ -172,6 +173,7 @@
..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf \
..\..\bin\UnitTestFiles\UT_VotingDistricts.fs \
..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf \
+ ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf \
..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf \
..\..\bin\UnitTestFiles\UT_AllElements.pl \
..\..\bin\UnitTestFiles\UT_NoLegend.pl \
@@ -421,6 +423,7 @@
@@ -429,6 +432,7 @@
@@ -678,6 +682,7 @@
@@ -686,6 +691,7 @@
@@ -935,6 +941,7 @@
@@ -943,6 +950,7 @@
@@ -1065,6 +1073,7 @@
if EXIST ..\..\bin\UnitTestFiles\TEST.FeatureSource del /F ..\..\bin\UnitTestFiles\TEST.FeatureSource
if EXIST ..\..\bin\UnitTestFiles\TEST.sdf del /F ..\..\bin\UnitTestFiles\TEST.sdf
if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.mdf del /F ..\..\bin\UnitTestFiles\UT_BaseMap.mdf
+ if EXIST ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf del /F ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.fs del /F ..\..\bin\UnitTestFiles\UT_Parcels.fs
if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.ldf del /F ..\..\bin\UnitTestFiles\UT_Parcels.ldf
if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.sdf del /F ..\..\bin\UnitTestFiles\UT_Parcels.sdf
@@ -1073,6 +1082,7 @@
if EXIST ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf del /F ..\..\bin\UnitTestFiles\UT_RoadCenterLines.sdf
if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.fs
if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.ldf
+ if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf del /F ..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf
if EXIST ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf del /F ..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf
if EXIST ..\..\bin\UnitTestFiles\UT_AllElements.pl del /F ..\..\bin\UnitTestFiles\UT_AllElements.pl
if EXIST ..\..\bin\UnitTestFiles\UT_NoLegend.pl del /F ..\..\bin\UnitTestFiles\UT_NoLegend.pl
@@ -1190,6 +1200,7 @@
@@ -1198,6 +1209,7 @@
@@ -1315,6 +1327,7 @@
@@ -1323,6 +1336,7 @@
@@ -1394,8 +1408,8 @@
if EXIST ..\..\bin\UnitTestFiles\UT_Annotation3.mdf del /F ..\..\bin\UnitTestFiles\UT_Annotation3.mdf
if EXIST ..\..\bin\UnitTestFiles\SavePointTest.sqlite del /F ..\..\bin\UnitTestFiles\SavePointTest.sqlite
if EXIST ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource del /F ..\..\bin\UnitTestFiles\SavePointTest.FeatureSource
- if EXIST ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource del /F ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource
- if EXIST ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource del /F ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource
+ if EXIST ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource del /F ..\..\bin\UnitTestFiles\UT_Parcels_SQLite_Join.FeatureSource
+ if EXIST ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource del /F ..\..\bin\UnitTestFiles\UT_FdoJoin.FeatureSource
if EXIST ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite del /F ..\..\bin\UnitTestFiles\ParcelsJoinTest.sqlite
if EXIST ..\..\bin\UnitTestFiles\JoinTest.sqlite del /F ..\..\bin\UnitTestFiles\JoinTest.FeatureSource
@@ -1438,6 +1452,7 @@
@@ -1446,6 +1461,7 @@
@@ -1558,6 +1574,7 @@
"..\..\..\UnitTest\TestData\MappingService\UT_Rail.fs" :
"..\..\..\UnitTest\TestData\MappingService\UT_Rail.ldf" :
"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" :
+"..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" :
"..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" :
"..\..\..\UnitTest\TestData\TileService\UT_Parcels.ldf" :
"..\..\..\UnitTest\TestData\TileService\UT_Parcels.sdf" :
@@ -1566,6 +1583,7 @@
"..\..\..\UnitTest\TestData\TileService\UT_RoadCenterLines.sdf" :
"..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.fs" :
"..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" :
+"..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" :
"..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" :
"..\..\..\UnitTest\TestData\ServerAdmin\1.1.1.mgd" :
"..\..\..\UnitTest\TestData\CoordinateSystems\epsgcodes.txt" :
@@ -1755,6 +1773,10 @@
if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf : "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf"
+ if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
+ if EXIST "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" ..\..\bin\UnitTestFiles\
..\..\bin\UnitTestFiles\UT_Parcels.fs : "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs"
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" ..\..\bin\UnitTestFiles\
@@ -1787,6 +1809,10 @@
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.ldf" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\UT_VotingDistrictsFunctions.ldf : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf"
+ if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistrictsFunctions.ldf" ..\..\bin\UnitTestFiles\
..\..\bin\UnitTestFiles\UT_VotingDistricts.sdf : "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf"
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_VotingDistricts.sdf" ..\..\bin\UnitTestFiles\
Modified: trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp
--- trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -451,8 +451,10 @@
wcstombs(legendImage, strLegendImage.c_str(), 4096 );
RS_UIGraphic uig((unsigned char*)legendImage, 0, layer->GetLegendLabel());
RS_LayerUIInfo layerInfo(layer->GetName(),
layer->GetSelectable(),
layer->GetVisible(),
@@ -487,7 +489,7 @@
if (NULL != fdoReader.p)
- RS_FeatureClassInfo fcInfo(vl->GetFeatureName());
+ RS_FeatureClassInfo fcInfo(vl->GetFeatureName(), vl->GetResourceID());
Modified: trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -451,6 +451,7 @@
@@ -546,7 +547,7 @@
//feature property
@@ -658,7 +659,7 @@
//feature property
Modified: trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
--- trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -223,10 +223,12 @@
StylizationUtil::ParseColor( mdf->GetBackgroundColor(), bgcolor);
//These should not matter for GenerateMap
double dMapScale = map->GetViewScale();
double dpi = map->GetDisplayDpi();
- RS_MapUIInfo mapInfo(sessionId, mapResId->GetName(), map->GetObjectId(), srs, units, bgcolor);
+ RS_MapUIInfo mapInfo(sessionId, mapResId->GetName(), map->GetObjectId(), srs, units, bgcolor, coord->GetX(), coord->GetY(), dMapScale);
dr.StartMap(&mapInfo, b, dMapScale, dpi, metersPerUnit);
@@ -244,6 +246,7 @@
RS_UIGraphic uig(NULL, 0, mggroup->GetLegendLabel());
RS_LayerUIInfo layerInfo( mggroup->GetName(),
+ L"",
mggroup->GetObjectId(),
false, // selectable - does not apply to groups
mggroup->GetVisible(),
@@ -277,8 +280,10 @@
bEditable = false;
+ Ptr<MgResourceIdentifier> layerDefId = mglayer->GetLayerDefinition();
RS_UIGraphic uig(NULL, 0, mglayer->GetLegendLabel());
RS_LayerUIInfo layerInfo( mglayer->GetName(),
mglayer->GetObjectId(),
mglayer->GetSelectable(),
mglayer->GetVisible(),
@@ -475,6 +480,8 @@
RS_Color bgcolor;
StylizationUtil::ParseColor( map->GetBackgroundColor(), bgcolor);
@@ -499,7 +506,7 @@
SEMgSymbolManager semgr(m_svcResource);
DefaultStylizer ds(&semgr);
+ RS_MapUIInfo mapInfo(sessionId, map->GetName(), map->GetObjectId(), srs, units, bgcolor, coord->GetX(), coord->GetY(), dMapScale);
//begin map stylization
dr.StartMap(&mapInfo, b, dMapScale, dpi, metersPerUnit, xformToLL);
@@ -517,6 +524,7 @@
+ L"",
@@ -547,9 +555,11 @@
if (mglayer->GetLayerType() == MgLayerType::BaseMap)
bEditable = false;
@@ -1222,7 +1232,7 @@
@@ -1419,8 +1429,12 @@
double metersPerUnit = (dstCs.p) ? dstCs->ConvertCoordinateSystemUnitsToMeters(1.0) : 1.0;
RS_String units = (dstCs.p) ? dstCs->GetUnits() : L"";
+ double dMapScale = map->GetViewScale();
RS_Color mapBgColor(255, 255, 255, 0);
- RS_MapUIInfo mapInfo(L"", map->GetName(), L"", srs, units, mapBgColor);
+ RS_MapUIInfo mapInfo(L"", map->GetName(), L"", srs, units, mapBgColor, coord->GetX(), coord->GetY(), dMapScale);
dr.StartMap(&mapInfo, b, scale, dpi, metersPerUnit);
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -985,7 +985,9 @@
@@ -1228,7 +1230,7 @@
@@ -1384,7 +1386,9 @@
true, // selectable
true, // visible
@@ -1406,7 +1410,7 @@
//feature property
Modified: trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2013-05-06 12:46:20 UTC (rev 7477)
@@ -359,12 +359,22 @@
@@ -490,6 +500,13 @@
#ifdef _DEBUG
MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
if(pFdoConnectionManager)
@@ -727,7 +744,42 @@
+ try
+ Ptr<MgMap> map = CreateTestStylizationFunctionMap();
+ // Move around
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
try
@@ -735,8 +787,8 @@
// make a runtime map
Ptr<MgMap> map = CreateTestMap();
- // call the API using a scale of 75000
- map->SetViewScale(75000.0);
+ // call the API using a scale of 60000
Ptr<MgStringCollection> layerNames1 = new MgStringCollection();
layerNames1->Add(L"Rail");
@@ -799,6 +851,23 @@
return map;
+MgMap* TestRenderingService::CreateTestStylizationFunctionMap()
+ MgMap* map = new MgMap(m_siteConnection);
+ map->Create(mdfres, L"StylizationFuncs");
+ return map;
MgMap* TestRenderingService::CreateTestTiledMap()
Modified: trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h
--- trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h 2013-05-06 10:37:11 UTC (rev 7476)
+++ trunk/MgDev/Server/src/UnitTesting/TestRenderingService.h 2013-05-06 12:46:20 UTC (rev 7477)
@@ -25,6 +25,8 @@
@@ -41,6 +43,8 @@
@@ -57,6 +61,8 @@
@@ -73,6 +79,8 @@
@@ -124,6 +132,8 @@
//PNG output tests
@@ -138,6 +148,7 @@
//PNG8 output tests
@@ -153,6 +164,7 @@
//GIF output tests
@@ -168,6 +180,7 @@
//JPG output tests
@@ -183,12 +196,14 @@
//void TestCase_RendererPerformance();
private:
MgMap* CreateTestMap();
MgMap* CreateTestTiledMap();
+ MgMap* CreateTestStylizationFunctionMap();
MgMap* CreateTestMapWithWatermark();
MgPolygon* CreateSelectionPolygon(MgMap* map, double width, double height);
Copied: trunk/MgDev/UnitTest/TestData/TileService/UT_StylizationFuncs.mdf (from rev 7462, sandbox/jng/extra_stylization_funcs/UnitTest/TestData/TileService/UT_StylizationFuncs.mdf)
--- trunk/MgDev/UnitTest/TestData/TileService/UT_StylizationFuncs.mdf (rev 0)
+++ trunk/MgDev/UnitTest/TestData/TileService/UT_StylizationFuncs.mdf 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,23 @@
+<?xml version="1.0" encoding="utf-8"?>
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="MapDefinition-2.4.0.xsd">
+ <Name />
+ <CoordinateSystem>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</CoordinateSystem>
+ <Extents>
+ <MinX>-87.764986236796631</MinX>
+ <MaxX>-87.695517537538109</MaxX>
+ <MinY>43.691398447253356</MinY>
+ <MaxY>43.7975198255836</MaxY>
+ </Extents>
+ <BackgroundColor>ffffffff</BackgroundColor>
+ <MapLayer>
+ <Name>StylizationTest</Name>
+ <ResourceId>Library://UnitTests/Layers/StylizationFuncs.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <ShowInLegend>true</ShowInLegend>
+ <LegendLabel>StylizationTest</LegendLabel>
+ <ExpandInLegend>true</ExpandInLegend>
+ <Visible>true</Visible>
+ <Group />
+ </MapLayer>
+ <Watermarks />
+</MapDefinition>
Copied: trunk/MgDev/UnitTest/TestData/TileService/UT_VotingDistrictsFunctions.ldf (from rev 7462, sandbox/jng/extra_stylization_funcs/UnitTest/TestData/TileService/UT_VotingDistrictsFunctions.ldf)
--- trunk/MgDev/UnitTest/TestData/TileService/UT_VotingDistrictsFunctions.ldf (rev 0)
+++ trunk/MgDev/UnitTest/TestData/TileService/UT_VotingDistrictsFunctions.ldf 2013-05-06 12:46:20 UTC (rev 7477)
@@ -0,0 +1,49 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="LayerDefinition-1.2.0.xsd" version="1.2.0">
+ <VectorLayerDefinition>
+ <ResourceId>Library://UnitTests/Data/VotingDistricts.FeatureSource</ResourceId>
+ <FeatureName>Default:VotingDistricts</FeatureName>
+ <FeatureNameType>FeatureClass</FeatureNameType>
+ <PropertyMapping>
+ <Name>NAME</Name>
+ <Value>NAME</Value>
+ </PropertyMapping>
+ <Geometry>Geometry</Geometry>
+ <VectorScaleRange>
+ <AreaTypeStyle>
+ <AreaRule>
+ <LegendLabel></LegendLabel>
+ <Label>
+ <Unit>Centimeters</Unit>
+ <SizeContext>DeviceUnits</SizeContext>
+ <SizeX>0.3</SizeX>
+ <SizeY>0.3</SizeY>
+ <Text>concat('HTML Color: ', HTMLCOLOR(255, 0, 14), '\nFeature Source: ', FEATURESOURCE(), '\nLayer Definition: ', LAYERDEFINITION(), '\nMap Scale: ', MAPSCALE(), '\nMap Center (X): ', MAPCENTERX(), '\nMap Center (Y): ', MAPCENTERY(), '\nColor: ', ARGB(0, 255, 0, 255), '\nDecap: ', DECAP('HELLO WORLD'), '\nFeature Class: ', FEATURECLASS(), '\nFeature ID: ', FEATUREID(), '\nIf result (Built after 1980?): ', IF('YRBUILT > 1980', 'Yes', 'No'), '\nLayer ID: ', LAYERID(), '\nLookup Example (based on FeatId): ', Lookup( FeatId , 'FeatId unknown or empty', 1, 'one', 2, 'two', 3, 'three', 4, 'four', 5, 'five', 6, 'six', 7, 'seven', 8, 'eight', 9, 'nine', 10, 'ten'), '\nMap Name: ', MAPNAME(), '\nSession ID: ', SESSION(), '\nRange Example (FeatId): ', RANGE( FeatId , 'Unknown', 1, 3, '1-3', 3, 6,'3-6', 6, 10, '6 - 10'), '\nURL Encode example: ', URLENCODE('http://www.google.com/?foo=bar'))</Text>
+ <FontName>Arial</FontName>
+ <ForegroundColor>ff000000</ForegroundColor>
+ <BackgroundStyle>Ghosted</BackgroundStyle>
+ <VerticalAlignment>'Halfline'</VerticalAlignment>
+ <AdvancedPlacement>
+ <ScaleLimit>0.5</ScaleLimit>
+ </AdvancedPlacement>
+ </Label>
+ <AreaSymbolization2D>
+ <Fill>
+ <FillPattern>Solid</FillPattern>
+ <ForegroundColor>ffffffff</ForegroundColor>
+ </Fill>
+ <Stroke>
+ <LineStyle>Solid</LineStyle>
+ <Thickness>1</Thickness>
+ <Color>ff000000</Color>
+ <Unit>Points</Unit>
+ </Stroke>
+ </AreaSymbolization2D>
+ </AreaRule>
+ </AreaTypeStyle>
+ </VectorScaleRange>
+ </VectorLayerDefinition>
+</LayerDefinition>
More information about the mapguide-commits
