[mapguide-commits] r7480 - sandbox/jng/queryfeatures_v2/Web/src/mapviewerjava
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed May 8 05:10:10 PDT 2013
Author: jng
Date: 2013-05-08 05:10:10 -0700 (Wed, 08 May 2013)
New Revision: 7480
Removed:
   sandbox/jng/queryfeatures_v2/Web/src/mapviewerjava/getselectedfeatures.jsp
   sandbox/jng/queryfeatures_v2/Web/src/mapviewerjava/mapframe.jsp
So long getselectedfeatures.jsp. This RFC has eliminated the need for you
Deleted: sandbox/jng/queryfeatures_v2/Web/src/mapviewerjava/getselectedfeatures.jsp
--- sandbox/jng/queryfeatures_v2/Web/src/mapviewerjava/getselectedfeatures.jsp	2013-05-08 11:40:41 UTC (rev 7479)
+++ sandbox/jng/queryfeatures_v2/Web/src/mapviewerjava/getselectedfeatures.jsp	2013-05-08 12:10:10 UTC (rev 7480)
@@ -1,449 +0,0 @@
-<%@ page contentType="text/html; charset=UTF-8" pageEncoding="UTF-8" %>
-<%@ page import="org.osgeo.mapguide.*" %>
-<%@ page import="java.util.*" %>
-<%@ page import="java.lang.*" %>
-<%@ page import="java.io.*" %>
-<%@ page import="java.text.*" %>
-<%@ page import="javax.xml.parsers.DocumentBuilder" %>
-<%@ page import="javax.xml.parsers.DocumentBuilderFactory" %>
-<%@ page import="org.w3c.dom.Document" %>
-<%@ page import="org.w3c.dom.Element" %>
-<%@ page import="org.w3c.dom.Node" %>
-<%@ page import="org.w3c.dom.NodeList" %>
-<%@ page import="javax.servlet.jsp.*" %>
-<%@ page import="javax.servlet.http.*" %>
-<%@ include file="common.jsp" %>
-<%@ page isThreadSafe="false" %>
-    String mapName;
-    String sessionId;
-    String localeCode;
-    Locale locale;
-    class SelectionSet
-        private HashMap<String, Vector<Feature>> _layers;
-        public SelectionSet()
-            _layers = new HashMap<String, Vector<Feature>>();
-        public void addFeature(Feature feat)
-            if (!_layers.containsKey(feat.LayerName))
-                _layers.put(feat.LayerName, new Vector<Feature>());
-            _layers.get(feat.LayerName).add(feat);
-        public String[] getLayers()
-            String[] layers = new String[_layers.keySet().size()];
-            _layers.keySet().toArray(layers);
-            return layers;
-        public Feature[] getFeatures(String layerName)
-            if (_layers.containsKey(layerName))
-                Vector<Feature> layerFeatures = _layers.get(layerName);
-                Feature[] feats = new Feature[layerFeatures.size()];
-                layerFeatures.toArray(feats);
-                return feats;
-            return null;
-    class ZoomBox
-        public double MinX;
-        public double MinY;
-        public double MaxX;
-        public double MaxY;
-    class FeatureProperty
-        public String Name;
-        public String Value;
-    class Feature
-        public String LayerName;
-        public ZoomBox Zoom;
-        private HashMap<String, FeatureProperty> _properties;
-        public Feature(String layerName)
-            this.LayerName = layerName;
-            _properties = new HashMap<String, FeatureProperty>();
-        public void addProperty(FeatureProperty prop)
-            _properties.put(prop.Name, prop);
-        public FeatureProperty[] getProperties()
-            Collection<FeatureProperty> values = _properties.values();
-            FeatureProperty[] props = new FeatureProperty[values.size()];
-            values.toArray(props);
-            return props;
-    static String getTextValue(Element el, String tagName)
-        String textVal = null;
-        NodeList nl = el.getElementsByTagName(tagName);
-        if (nl != null && nl.getLength() > 0)
-            Element e = (Element)nl.item(0);
-            textVal = e.getFirstChild().getNodeValue();
-        return textVal;
-    static HashMap<String, String> GetLayerPropertyMappings(MgResourceService resSvc, MgLayerBase layer) throws Exception
-        HashMap<String, String> mappings = new HashMap<String, String>();
-        MgByteReader content = resSvc.GetResourceContent(layer.GetLayerDefinition());
-        ByteArrayInputStream contentReader = new ByteArrayInputStream(content.ToString().getBytes("UTF-8"));
-        DocumentBuilderFactory dbf = DocumentBuilderFactory.newInstance();
-        DocumentBuilder db = dbf.newDocumentBuilder();
-        Document doc = db.parse(contentReader);
-        doc.getDocumentElement().normalize();
-        NodeList propNodes = doc.getElementsByTagName("PropertyMapping");
-        for (int i = 0; i < propNodes.getLength(); i++)
-            Element propEl = (Element)propNodes.item(i);
-            String name = getTextValue(propEl, "Name");
-            String value = getTextValue(propEl, "Value");
-            if (name != null && value != null)
-                mappings.put(name, value);
-        return mappings;
-    String GetPropertyValueFromFeatureReader(MgFeatureReader reader, MgAgfReaderWriter agfRw, int propType, String propName) throws Exception
-        String value = "";
-        switch(propType)
-            case MgPropertyType.Boolean:
-                value = String.format(locale, "%s", reader.GetBoolean(propName));
-                break;
-            case MgPropertyType.Byte:
-                value = String.format(locale, "%d", reader.GetByte(propName));
-                break;
-            case MgPropertyType.DateTime:
-                value = GetDateTimeString(reader.GetDateTime(propName)); // yyyy-mm-dd is enforced regardless of locale
-                break;
-            case MgPropertyType.Single:
-                value = String.format(locale, "%f", reader.GetSingle(propName));
-                break;
-            case MgPropertyType.Double:
-                value = String.format(locale, "%f", reader.GetDouble(propName));
-                break;
-            case MgPropertyType.Int16:
-                value = String.format(locale, "%d", reader.GetInt16(propName));
-                break;
-            case MgPropertyType.Int32:
-                value = String.format(locale, "%d", reader.GetInt32(propName));
-                break;
-            case MgPropertyType.Int64:
-                value = String.format(locale, "%d", reader.GetInt64(propName));
-                break;
-            case MgPropertyType.String:
-                value = JsonEscape(reader.GetString(propName)); // string content is arbitrary
-                value = value.replaceAll("\\s+", " ").trim();
-                break;
-            default: //NOT PRESENTABLE IN PROPERTY GRID
-                value = "";
-                break;
-        return value;
-    static String GetDateTimeString(MgDateTime value) throws MgException
-        return value.GetYear() + "-" + value.GetMonth() + "-" + value.GetDay();
-    void GetParameters(HttpServletRequest request)
-        mapName = GetParameter(request, "MAPNAME");
-        sessionId = GetParameter(request, "SESSION");
-        localeCode = GetParameter(request, "LOCALE");
-    String JsonEscape(String str)
-        return EscapeForHtml(str).replace("\\", "\\\\");
-    String JsonifyError(Exception ex)
-        if (ex == null)
-            return "";
-            "Error" : {
-                "Message" : <exception-message>,
-                "StackTrace" : <exception-stack-trace>
-        StringBuffer sb = new StringBuffer();
-        //Use exception message or type name if no message found
-        String msg = ex.getMessage();
-        if (msg == null || msg.length() == 0)
-            msg = MgLocalizer.GetString("SERVERERROR", localeCode);
-        //Begin response
-        sb.append("{\"Error\":{");
-        //Exception message
-        sb.append("\"Message\":\"" + JsonEscape(msg) + "\",");
-        StringBuffer strace = new StringBuffer();
-        StackTraceElement[] st = ex.getStackTrace();
-        for (int i = 0; i < st.length; i++)
-            strace.append(st[i].getClassName() + "." + st[i].getMethodName() + "(" + st[i].getLineNumber() + ")\\n");
-        sb.append("\"StackTrace\":\"" + JsonEscape(strace.toString()) + "\"");
-        //End response
-        sb.append("}}");
-        return sb.toString();
-    static String GetJson(SelectionSet set)
-        A sample of the JSON output this method will produce:
-            "Layer1" : [
-                    'values' { "name" : "name1" , "value" : "value1" },
-                    'zoom' : { x: num1, y: num2 }
-            "Layer2" : [
-                    'values' { "name" : "name2" , "value" : "value2" },
-        if (set == null)
-            return "";
-        //Begin selection set
-        sb.append("{");
-        String[] layers = set.getLayers();
-        for (int i = 0; i < layers.length; i++)
-            //Begin layer
-            sb.append("\"" + layers[i] + "\" : [");
-            Feature[] features = set.getFeatures(layers[i]);
-            for (int j = 0; j < features.length; j++)
-                Feature feat = features[j];
-                //begin feature
-                //begin feature properties
-                sb.append("{\"values\" : [");
-                FeatureProperty[] properties = feat.getProperties();
-                for(int k = 0; k < properties.length; k++)
-                    FeatureProperty fp = properties[k];
-                    sb.append("{\"name\" : \"" + fp.Name + "\", \"value\" : \"" + fp.Value + "\" }");
-                    if (k != properties.length - 1)
-                        sb.append(",");
-                //end feature properties
-                //begin zoom
-                sb.append("], \"zoom\" : ");
-                if (feat.Zoom == null)
-                    sb.append("null");
-                else
-                    sb.append(String.format(Locale.ROOT, "{\"minx\" : %f, \"miny\" : %f, \"maxx\" : %f, \"maxy\" : %f }", feat.Zoom.MinX, feat.Zoom.MinY, feat.Zoom.MaxX, feat.Zoom.MaxY));
-                //end zoom
-                //end feature
-                sb.append("}");
-                if (j != features.length - 1)
-                    sb.append(",");
-            //End Layer
-            sb.append("]");
-            if (i != layers.length - 1)
-                sb.append(",");
-        //End selection set
-        sb.append("}");
-    mapName = "";
-    sessionId = "";
-    localeCode = "";
-    GetParameters(request);
-    if (null == localeCode || localeCode.length() == 0)
-        localeCode = GetDefaultLocale();
-    locale = new Locale(localeCode);
-    try
-        MgUserInformation cred = new MgUserInformation(sessionId);
-        cred.SetClientIp(GetClientIp(request));
-        cred.SetClientAgent(GetClientAgent());
-        MgSiteConnection site = new MgSiteConnection();
-        site.Open(cred);
-        MgResourceService resSvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
-        MgMap map = new MgMap(site);
-        map.Open(mapName);
-        MgSelection selection = new MgSelection(map);
-        selection.Open(resSvc, mapName);
-        MgReadOnlyLayerCollection layers = selection.GetLayers();
-        if (layers != null && layers.GetCount() > 0)
-            int layerCount = layers.GetCount();
-            MgAgfReaderWriter agfRW = new MgAgfReaderWriter();
-            SelectionSet selectionSet = new SelectionSet();
-            for (int i = 0; i < layerCount; i++)
-                MgLayerBase layer = layers.GetItem(i);
-                String layerName = layer.GetName();
-                MgResourceIdentifier fsId = new MgResourceIdentifier(layer.GetFeatureSourceId());
-                String className = layer.GetFeatureClassName();
-                String geomName = layer.GetFeatureGeometryName();
-                MgFeatureQueryOptions query = new MgFeatureQueryOptions();
-                HashMap<String, String> mappings = GetLayerPropertyMappings(resSvc, layer);
-                Set<String> propNames = mappings.keySet();
-                for (String name : propNames)
-                    query.AddFeatureProperty(name);
-                query.AddFeatureProperty(geomName);
-                String filter = selection.GenerateFilter(layer, className);
-                query.SetFilter(filter);
-                MgFeatureReader reader = layer.SelectFeatures(query);
-                MgClassDefinition clsDef = reader.GetClassDefinition();
-                MgPropertyDefinitionCollection props = clsDef.GetProperties();
-                while (reader.ReadNext())
-                    Feature feat = new Feature(layerName);
-                    ZoomBox zoom = null;
-                    for (int k = 0; k < props.GetCount(); k++)
-                        MgPropertyDefinition propDef = props.GetItem(k);
-                        String propName = propDef.GetName();
-                        int propType = reader.GetPropertyType(propName);
-                        if (mappings.get(propName) != null || propType == MgPropertyType.Geometry)
-                            if (!reader.IsNull(propName))
-                                if (propName.equals(geomName))
-                                    MgByteReader agf = reader.GetGeometry(propName);
-                                    MgGeometry geom = agfRW.Read(agf);
-                                    MgEnvelope env = geom.Envelope();
-                                    MgCoordinate ll = env.GetLowerLeftCoordinate();
-                                    MgCoordinate ur = env.GetUpperRightCoordinate();
-                                    zoom = new ZoomBox();
-                                    zoom.MinX = ll.GetX();
-                                    zoom.MinY = ll.GetY();
-                                    zoom.MaxX = ur.GetX();
-                                    zoom.MaxY = ur.GetY();
-                                    feat.Zoom = zoom;
-                                else
-                                    value = GetPropertyValueFromFeatureReader(reader, agfRW, propType, propName);
-                                if (mappings.get(propName) != null)
-                                    FeatureProperty fp = new FeatureProperty();
-                                    fp.Name = mappings.get(propName);
-                                    fp.Value = value;
-                                    feat.addProperty(fp);
-                    selectionSet.addFeature(feat);
-                reader.Close();
-            //Now output the selection set
-            response.addHeader("Content-Type", "application/json");
-            response.addHeader("X-JSON", "true");
-            response.getWriter().write(GetJson(selectionSet));
-    catch (MgException ex)
-        response.getWriter().write(JsonifyError(ex));
-    catch (Exception ex)
Modified: sandbox/jng/queryfeatures_v2/Web/src/mapviewerjava/mapframe.jsp
--- sandbox/jng/queryfeatures_v2/Web/src/mapviewerjava/mapframe.jsp	2013-05-08 11:40:41 UTC (rev 7479)
+++ sandbox/jng/queryfeatures_v2/Web/src/mapviewerjava/mapframe.jsp	2013-05-08 12:10:10 UTC (rev 7480)
@@ -180,7 +180,6 @@
                     vpath + "setselection.jsp",
                     showSlider != 0? "true": "false",
                     locale,
-                    vpath + "getselectedfeatures.jsp",
                     scaleCreationCode,
                     selectionColor,
                     mapImgFormat,
More information about the mapguide-commits mailing list
