[mapguide-commits] r7491 - in trunk/Tools/Maestro: Maestro.Base Maestro.Base/Commands/SiteExplorer Maestro.Editors Maestro.Editors/FeatureSource OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Commands
svn_mapguide at osgeo.org
Sun May 12 10:47:04 PDT 2013
Author: jng
Date: 2013-05-12 10:47:03 -0700 (Sun, 12 May 2013)
New Revision: 7491
Added:
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/CreateLayersFromFeatureSourceCommand.cs
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestFeatureSourceCommand.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.resx
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Strings.resx
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
This submission contains the following changes:
- #2262: Implement shortcut to create default layers from a feature source.
- Implement a context menu shortcut to test a feature source connection (without needing to open it in an editor)
Added: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/CreateLayersFromFeatureSourceCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/CreateLayersFromFeatureSourceCommand.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/CreateLayersFromFeatureSourceCommand.cs 2013-05-12 17:47:03 UTC (rev 7491)
@@ -0,0 +1,99 @@
+#region Disclaimer / License
+// Copyright (C) 2013, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using Maestro.Editors.FeatureSource;
+using Maestro.Shared.UI;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Schema;
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Linq;
+using System.Text;
+namespace Maestro.Base.Commands.SiteExplorer
+ internal class CreateLayersFromFeatureSourceCommand : AbstractMenuCommand
+ public override void Run()
+ var wb = Workbench.Instance;
+ var exp = wb.ActiveSiteExplorer;
+ if (exp != null && exp.SelectedItems != null && exp.SelectedItems.Length == 1)
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
+ var item = exp.SelectedItems[0];
+ var diag = new CreateLayersFromFeatureSourceDialog(conn, item.ResourceId);
+ if (diag.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ CreateLayers(conn, diag.FeatureSource, diag.TargetFolder, diag.FeatureClasses);
+ static object DoBackgroundWorker(BackgroundWorker wrk, DoWorkEventArgs e, params object[] args)
+ var items = (List<ClassDefinition>)args[0];
+ var conn = (IServerConnection)args[1];
+ string featureSource = (string)args[2];
+ string targetFolder = (string)args[3];
+ LengthyOperationProgressCallBack cb = (o, pe) =>
+ wrk.ReportProgress(pe.Progress, o);
+ var result = new HashSet<string>();
+ int processed = 0;
+ foreach (var cls in items)
+ var lyrId = Utility.CreateDefaultLayer(conn, featureSource, cls, targetFolder);
+ if (lyrId != null)
+ result.Add(lyrId);
+ processed++;
+ cb(null, new LengthyOperationProgressArgs(string.Empty, (int)((processed / items.Count) * 100)));
+ return result;
+ static void CreateLayers(IServerConnection conn, string featureSource, string targetFolder, string[] featureClasses)
+ List<ClassDefinition> classes = new List<ClassDefinition>();
+ foreach (var clsName in featureClasses)
+ classes.Add(conn.FeatureService.GetClassDefinition(featureSource, clsName));
+ var prg = new ProgressDialog();
+ var results = (ICollection<string>)prg.RunOperationAsync(wb, DoBackgroundWorker, classes, conn, featureSource, targetFolder);
+ if (exp != null)
+ exp.RefreshModel(exp.ConnectionName, targetFolder);
+ exp.ExpandNode(exp.ConnectionName, targetFolder);
Added: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestFeatureSourceCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestFeatureSourceCommand.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestFeatureSourceCommand.cs 2013-05-12 17:47:03 UTC (rev 7491)
@@ -0,0 +1,56 @@
+#endregion
+using System;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+ internal class TestFeatureSourceCommand : AbstractMenuCommand
+ try
+ if (Utility.IsSuccessfulConnectionTestResult(conn.FeatureService.TestConnection(item.ResourceId)))
+ MessageBox.Show(Strings.ConnectionTestOk);
+ else
+ MessageBox.Show(string.Format(Strings.ConnectionTestFailed, false));
+ catch (Exception ex)
+ MessageBox.Show(string.Format(Strings.ConnectionTestFailed, ex.Message));
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2013-05-12 15:40:44 UTC (rev 7490)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2013-05-12 17:47:03 UTC (rev 7491)
@@ -549,6 +549,13 @@
class="Maestro.Base.Commands.SiteExplorer.PurgeFeatureSourceCacheCommand" />
</Condition>
<Condition action="Disable" name="ResourceType" types="FeatureSource">
+ <MenuItem id="TestFeatureSource"
+ label="${res:SiteExplorer_TestFeatureSource}"
+ icon="tick"
+ class="Maestro.Base.Commands.SiteExplorer.TestFeatureSourceCommand" />
+ <MenuItem id="CreateLayersFromFeatureSource"
+ label="${res:SiteExplorer_CreateLayersFromFeatureSource}"
+ class="Maestro.Base.Commands.SiteExplorer.CreateLayersFromFeatureSourceCommand" />
<MenuItem id="ShowSpatialContexts"
label="${res:SiteExplorer_ShowSpatialContexts}"
class="Maestro.Base.Commands.SiteExplorer.ShowSpatialContextsCommand" />
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2013-05-12 15:40:44 UTC (rev 7490)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2013-05-12 17:47:03 UTC (rev 7491)
@@ -98,6 +98,7 @@
<Compile Include="Commands\LiveMapEditorCommand.cs" />
<Compile Include="Commands\OpenResourceIdCommand.cs" />
<Compile Include="Commands\RtMapInspectorCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\CreateLayersFromFeatureSourceCommand.cs" />
<Compile Include="Commands\SiteExplorer\EditResourceHeaderCommand.cs" />
<Compile Include="Commands\LoadPackageCommand.cs" />
<Compile Include="Commands\LocalFeatureSourcePreviewCommand.cs" />
@@ -133,6 +134,7 @@
<Compile Include="Commands\SiteExplorer\ResourcePropertiesCommand.cs" />
<Compile Include="Commands\SiteExplorer\SetupFolderStructureCommand.cs" />
<Compile Include="Commands\SiteExplorer\ShowSpatialContextsCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\TestFeatureSourceCommand.cs" />
<Compile Include="Commands\SiteExplorer\ValidateCommand.cs" />
<Compile Include="Commands\StartupCommand.cs" />
<Compile Include="Commands\SiteExplorer\TestResourceCompatibilityCommand.cs" />
Modified: trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs 2013-05-12 15:40:44 UTC (rev 7490)
+++ trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs 2013-05-12 17:47:03 UTC (rev 7491)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:4.0.30319.17929
+// Runtime Version:4.0.30319.18034
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -397,6 +397,24 @@
/// <summary>
+ /// Looks up a localized string similar to Connection Test Failed: {0}.
+ /// </summary>
+ internal static string ConnectionTestFailed {
+ get {
+ return ResourceManager.GetString("ConnectionTestFailed", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Connection Test OK.
+ /// </summary>
+ internal static string ConnectionTestOk {
+ get {
+ return ResourceManager.GetString("ConnectionTestOk", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Messages.
/// </summary>
internal static string Content_Messages {
@@ -1898,6 +1916,15 @@
/// <summary>
+ /// Looks up a localized string similar to Create Layers from Feature Source.
+ /// </summary>
+ internal static string SiteExplorer_CreateLayersFromFeatureSource {
+ get {
+ return ResourceManager.GetString("SiteExplorer_CreateLayersFromFeatureSource", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Disconnect.
/// </summary>
internal static string SiteExplorer_Disconnect {
@@ -2087,6 +2114,15 @@
/// <summary>
+ /// Looks up a localized string similar to Test Feature Source Connection.
+ /// </summary>
+ internal static string SiteExplorer_TestFeatureSource {
+ get {
+ return ResourceManager.GetString("SiteExplorer_TestFeatureSource", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Test Resource Compatibility.
/// </summary>
internal static string SiteExplorer_TestResourceCompatibility {
Modified: trunk/Tools/Maestro/Maestro.Base/Strings.resx
--- trunk/Tools/Maestro/Maestro.Base/Strings.resx 2013-05-12 15:40:44 UTC (rev 7490)
+++ trunk/Tools/Maestro/Maestro.Base/Strings.resx 2013-05-12 17:47:03 UTC (rev 7491)
@@ -992,4 +992,16 @@
<data name="FailedToCalculateFeatureSourceExtents" xml:space="preserve">
<value>Could not calculate the extents of the Feature Source. Preview is not possible</value>
</data>
+ <data name="SiteExplorer_CreateLayersFromFeatureSource" xml:space="preserve">
+ <value>Create Layers from Feature Source</value>
+ </data>
+ <data name="SiteExplorer_TestFeatureSource" xml:space="preserve">
+ <value>Test Feature Source Connection</value>
+ </data>
+ <data name="ConnectionTestFailed" xml:space="preserve">
+ <value>Connection Test Failed: {0}</value>
+ </data>
+ <data name="ConnectionTestOk" xml:space="preserve">
+ <value>Connection Test OK</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.Designer.cs 2013-05-12 17:47:03 UTC (rev 7491)
@@ -0,0 +1,176 @@
+namespace Maestro.Editors.FeatureSource
+ partial class CreateLayersFromFeatureSourceDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(CreateLayersFromFeatureSourceDialog));
+ this.label1 = new System.Windows.Forms.Label();
+ this.txtFeatureSource = new System.Windows.Forms.TextBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtCreateTargetFolder = new System.Windows.Forms.TextBox();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.lstFeatureClasses = new System.Windows.Forms.ListBox();
+ this.label3 = new System.Windows.Forms.Label();
+ this.btnFeatureSource = new System.Windows.Forms.Button();
+ this.btnCreateTarget = new System.Windows.Forms.Button();
+ this.btnCreate = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ this.lnkSelectAll = new System.Windows.Forms.LinkLabel();
+ this.lnkClear = new System.Windows.Forms.LinkLabel();
+ this.groupBox1.SuspendLayout();
+ this.SuspendLayout();
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // txtFeatureSource
+ resources.ApplyResources(this.txtFeatureSource, "txtFeatureSource");
+ this.txtFeatureSource.Name = "txtFeatureSource";
+ this.txtFeatureSource.ReadOnly = true;
+ // label2
+ resources.ApplyResources(this.label2, "label2");
+ this.label2.Name = "label2";
+ // txtCreateTargetFolder
+ resources.ApplyResources(this.txtCreateTargetFolder, "txtCreateTargetFolder");
+ this.txtCreateTargetFolder.Name = "txtCreateTargetFolder";
+ this.txtCreateTargetFolder.ReadOnly = true;
+ // groupBox1
+ resources.ApplyResources(this.groupBox1, "groupBox1");
+ this.groupBox1.Controls.Add(this.lnkClear);
+ this.groupBox1.Controls.Add(this.lnkSelectAll);
+ this.groupBox1.Controls.Add(this.lstFeatureClasses);
+ this.groupBox1.Controls.Add(this.label3);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.TabStop = false;
+ // lstFeatureClasses
+ resources.ApplyResources(this.lstFeatureClasses, "lstFeatureClasses");
+ this.lstFeatureClasses.FormattingEnabled = true;
+ this.lstFeatureClasses.Name = "lstFeatureClasses";
+ this.lstFeatureClasses.SelectionMode = System.Windows.Forms.SelectionMode.MultiSimple;
+ this.lstFeatureClasses.SelectedIndexChanged += new System.EventHandler(this.lstFeatureClasses_SelectedIndexChanged);
+ // label3
+ resources.ApplyResources(this.label3, "label3");
+ this.label3.Name = "label3";
+ // btnFeatureSource
+ resources.ApplyResources(this.btnFeatureSource, "btnFeatureSource");
+ this.btnFeatureSource.Name = "btnFeatureSource";
+ this.btnFeatureSource.UseVisualStyleBackColor = true;
+ this.btnFeatureSource.Click += new System.EventHandler(this.btnFeatureSource_Click);
+ // btnCreateTarget
+ resources.ApplyResources(this.btnCreateTarget, "btnCreateTarget");
+ this.btnCreateTarget.Name = "btnCreateTarget";
+ this.btnCreateTarget.UseVisualStyleBackColor = true;
+ this.btnCreateTarget.Click += new System.EventHandler(this.btnCreateTarget_Click);
+ // btnCreate
+ resources.ApplyResources(this.btnCreate, "btnCreate");
+ this.btnCreate.Name = "btnCreate";
+ this.btnCreate.UseVisualStyleBackColor = true;
+ this.btnCreate.Click += new System.EventHandler(this.btnCreate_Click);
+ // btnCancel
+ this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ resources.ApplyResources(this.btnCancel, "btnCancel");
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // lnkSelectAll
+ resources.ApplyResources(this.lnkSelectAll, "lnkSelectAll");
+ this.lnkSelectAll.Name = "lnkSelectAll";
+ this.lnkSelectAll.TabStop = true;
+ this.lnkSelectAll.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkSelectAll_LinkClicked);
+ // lnkClear
+ resources.ApplyResources(this.lnkClear, "lnkClear");
+ this.lnkClear.Name = "lnkClear";
+ this.lnkClear.TabStop = true;
+ this.lnkClear.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkClear_LinkClicked);
+ // CreateLayersFromFeatureSourceDialog
+ this.AcceptButton = this.btnCreate;
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ this.CancelButton = this.btnCancel;
+ resources.ApplyResources(this, "$this");
+ this.ControlBox = false;
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnCreate);
+ this.Controls.Add(this.btnCreateTarget);
+ this.Controls.Add(this.btnFeatureSource);
+ this.Controls.Add(this.groupBox1);
+ this.Controls.Add(this.txtCreateTargetFolder);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.txtFeatureSource);
+ this.Controls.Add(this.label1);
+ this.Name = "CreateLayersFromFeatureSourceDialog";
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.TextBox txtFeatureSource;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.TextBox txtCreateTargetFolder;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.ListBox lstFeatureClasses;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.Button btnFeatureSource;
+ private System.Windows.Forms.Button btnCreateTarget;
+ private System.Windows.Forms.Button btnCreate;
+ private System.Windows.Forms.Button btnCancel;
+ private System.Windows.Forms.LinkLabel lnkClear;
+ private System.Windows.Forms.LinkLabel lnkSelectAll;
Added: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.cs 2013-05-12 17:47:03 UTC (rev 7491)
@@ -0,0 +1,165 @@
+#endregion
+using Maestro.Editors.Generic;
+using System;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+ public partial class CreateLayersFromFeatureSourceDialog : Form
+ private CreateLayersFromFeatureSourceDialog()
+ InitializeComponent();
+ private IServerConnection _conn;
+ public CreateLayersFromFeatureSourceDialog(IServerConnection conn, string featureSource)
+ : this()
+ _conn = conn;
+ txtFeatureSource.Text = featureSource;
+ protected override void OnLoad(EventArgs e)
+ LoadFeatureClassesAsync();
+ private void LoadFeatureClassesAsync()
+ btnCreate.Enabled = false;
+ string fsId = txtFeatureSource.Text;
+ BusyWaitDialog.Run(null, () =>
+ return _conn.FeatureService.GetClassNames(fsId, null);
+ }, (result, ex) =>
+ if (ex != null)
+ ErrorDialog.Show(ex);
+ else
+ lstFeatureClasses.DataSource = result;
+ EvalButtonState();
+ private void EvalButtonState()
+ btnCreate.Enabled = !string.IsNullOrEmpty(txtFeatureSource.Text) &&
+ !string.IsNullOrEmpty(txtCreateTargetFolder.Text) &&
+ lstFeatureClasses.SelectedItems.Count > 0;
+ public string FeatureSource
+ get { return txtFeatureSource.Text; }
+ public string TargetFolder
+ get { return txtCreateTargetFolder.Text; }
+ public string[] FeatureClasses
+ get
+ var items = new List<string>();
+ var selected = lstFeatureClasses.SelectedItems;
+ for (int i = 0; i < selected.Count; i++)
+ items.Add(selected[i].ToString());
+ return items.ToArray();
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ private void btnCreate_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
+ private void btnFeatureSource_Click(object sender, EventArgs e)
+ using (var picker = new ResourcePicker(_conn.ResourceService, ResourceTypes.FeatureSource, ResourcePickerMode.OpenResource))
+ if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ txtFeatureSource.Text = picker.ResourceID;
+ private void btnCreateTarget_Click(object sender, EventArgs e)
+ using (var picker = new ResourcePicker(_conn.ResourceService, ResourcePickerMode.OpenFolder))
+ txtCreateTargetFolder.Text = picker.ResourceID;
+ private void lstFeatureClasses_SelectedIndexChanged(object sender, EventArgs e)
+ private void lnkSelectAll_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+ for (int i = 0; i < lstFeatureClasses.Items.Count; i++)
+ lstFeatureClasses.SetSelected(i, true);
+ private void lnkClear_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+ lstFeatureClasses.SetSelected(i, false);
Added: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/CreateLayersFromFeatureSourceDialog.resx 2013-05-12 17:47:03 UTC (rev 7491)
@@ -0,0 +1,480 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 13</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>80, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Feature Source</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>8</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="txtFeatureSource.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="txtFeatureSource.Location" type="System.Drawing.Point, System.Drawing">
+ <value>114, 10</value>
+ </data>
+ <data name="txtFeatureSource.Size" type="System.Drawing.Size, System.Drawing">
+ <value>294, 20</value>
+ </data>
+ <data name="txtFeatureSource.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>txtFeatureSource.Name" xml:space="preserve">
+ <value>txtFeatureSource</value>
+ </data>
+ <data name=">>txtFeatureSource.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtFeatureSource.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtFeatureSource.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 42</value>
+ </data>
+ <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>83, 13</value>
+ </data>
+ <data name="label2.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="label2.Text" xml:space="preserve">
+ <value>Create Layers in</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name="txtCreateTargetFolder.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtCreateTargetFolder.Location" type="System.Drawing.Point, System.Drawing">
+ <value>114, 39</value>
+ </data>
+ <data name="txtCreateTargetFolder.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="txtCreateTargetFolder.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name=">>txtCreateTargetFolder.Name" xml:space="preserve">
+ <value>txtCreateTargetFolder</value>
+ </data>
+ <data name=">>txtCreateTargetFolder.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtCreateTargetFolder.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtCreateTargetFolder.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name="lnkClear.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lnkClear.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
+ <data name="lnkClear.Location" type="System.Drawing.Point, System.Drawing">
+ <value>330, 26</value>
+ </data>
+ <data name="lnkClear.Size" type="System.Drawing.Size, System.Drawing">
+ <value>37, 13</value>
+ </data>
+ <data name="lnkClear.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="lnkClear.Text" xml:space="preserve">
+ <value>(Clear)</value>
+ </data>
+ <data name=">>lnkClear.Name" xml:space="preserve">
+ <value>lnkClear</value>
+ </data>
+ <data name=">>lnkClear.Type" xml:space="preserve">
+ <value>System.Windows.Forms.LinkLabel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lnkClear.Parent" xml:space="preserve">
+ <value>groupBox1</value>
+ </data>
+ <data name=">>lnkClear.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="lnkSelectAll.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lnkSelectAll.Location" type="System.Drawing.Point, System.Drawing">
+ <value>267, 26</value>
+ </data>
+ <data name="lnkSelectAll.Size" type="System.Drawing.Size, System.Drawing">
+ <value>57, 13</value>
+ </data>
+ <data name="lnkSelectAll.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="lnkSelectAll.Text" xml:space="preserve">
+ <value>(Select All)</value>
+ </data>
+ <data name=">>lnkSelectAll.Name" xml:space="preserve">
+ <value>lnkSelectAll</value>
+ </data>
+ <data name=">>lnkSelectAll.Type" xml:space="preserve">
+ </data>
+ <data name=">>lnkSelectAll.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lnkSelectAll.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="lstFeatureClasses.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="lstFeatureClasses.Location" type="System.Drawing.Point, System.Drawing">
+ <value>22, 52</value>
+ </data>
+ <data name="lstFeatureClasses.Size" type="System.Drawing.Size, System.Drawing">
+ <value>385, 173</value>
+ </data>
+ <data name="lstFeatureClasses.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>lstFeatureClasses.Name" xml:space="preserve">
+ <value>lstFeatureClasses</value>
+ </data>
+ <data name=">>lstFeatureClasses.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lstFeatureClasses.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lstFeatureClasses.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="label3.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>19, 26</value>
+ </data>
+ <data name="label3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>231, 13</value>
+ </data>
+ <data name="label3.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label3.Text" xml:space="preserve">
+ <value>Select the Feature Classes to create layers from</value>
+ </data>
+ <data name=">>label3.Name" xml:space="preserve">
+ <value>label3</value>
+ </data>
+ <data name=">>label3.Type" xml:space="preserve">
+ </data>
+ <data name=">>label3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label3.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 70</value>
+ </data>
+ <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>426, 243</value>
+ </data>
+ <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="groupBox1.Text" xml:space="preserve">
+ <value>Feature Classes</value>
+ </data>
+ <data name=">>groupBox1.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>groupBox1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="btnFeatureSource.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Right</value>
+ </data>
+ <data name="btnFeatureSource.Location" type="System.Drawing.Point, System.Drawing">
+ <value>414, 8</value>
+ </data>
+ <data name="btnFeatureSource.Size" type="System.Drawing.Size, System.Drawing">
+ <value>28, 23</value>
+ </data>
+ <data name="btnFeatureSource.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name="btnFeatureSource.Text" xml:space="preserve">
+ <value>...</value>
+ </data>
+ <data name=">>btnFeatureSource.Name" xml:space="preserve">
+ <value>btnFeatureSource</value>
+ </data>
+ <data name=">>btnFeatureSource.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnFeatureSource.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnFeatureSource.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="btnCreateTarget.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="btnCreateTarget.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="btnCreateTarget.Location" type="System.Drawing.Point, System.Drawing">
+ <value>414, 37</value>
+ </data>
+ <data name="btnCreateTarget.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnCreateTarget.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="btnCreateTarget.Text" xml:space="preserve">
+ </data>
+ <data name=">>btnCreateTarget.Name" xml:space="preserve">
+ <value>btnCreateTarget</value>
+ </data>
+ <data name=">>btnCreateTarget.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnCreateTarget.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnCreateTarget.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="btnCreate.Location" type="System.Drawing.Point, System.Drawing">
+ <value>286, 328</value>
+ </data>
+ <data name="btnCreate.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnCreate.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name="btnCreate.Text" xml:space="preserve">
+ <value>Create</value>
+ </data>
+ <data name=">>btnCreate.Name" xml:space="preserve">
+ <value>btnCreate</value>
+ </data>
+ <data name=">>btnCreate.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnCreate.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnCreate.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>367, 328</value>
+ </data>
+ <data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnCancel.TabIndex" type="System.Int32, mscorlib">
+ <value>8</value>
+ </data>
+ <data name="btnCancel.Text" xml:space="preserve">
+ <value>Cancel</value>
+ </data>
+ <data name=">>btnCancel.Name" xml:space="preserve">
+ <value>btnCancel</value>
+ </data>
+ <data name=">>btnCancel.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>454, 363</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Create Layers From Feature Source</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>CreateLayersFromFeatureSourceDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2013-05-12 15:40:44 UTC (rev 7490)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2013-05-12 17:47:03 UTC (rev 7491)
@@ -224,6 +224,12 @@
<Compile Include="FeatureSource\CoordSys\CoordSysOverrideDialog.Designer.cs">
<DependentUpon>CoordSysOverrideDialog.cs</DependentUpon>
</Compile>
+ <Compile Include="FeatureSource\CreateLayersFromFeatureSourceDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="FeatureSource\CreateLayersFromFeatureSourceDialog.Designer.cs">
+ <DependentUpon>CreateLayersFromFeatureSourceDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="FeatureSource\ExtensionsCtrl.cs">
<SubType>UserControl</SubType>
</Compile>
@@ -1259,6 +1265,9 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="FeatureSource\CreateLayersFromFeatureSourceDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="FeatureSource\ExtensionsCtrl.resx">
<DependentUpon>ExtensionsCtrl.cs</DependentUpon>
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2013-05-12 15:40:44 UTC (rev 7490)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2013-05-12 17:47:03 UTC (rev 7491)
@@ -1,7 +1,7 @@
// <auto-generated>
@@ -1346,6 +1346,15 @@
/// <summary>
+ /// Looks up a localized string similar to Loading Feature Classes.
+ /// </summary>
+ internal static string LoadingFeatureClasses {
+ get {
+ return ResourceManager.GetString("LoadingFeatureClasses", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to This connection does not support executing this type of Load Procedure.
/// </summary>
internal static string LoadProcedureVersionExecutionNotSupported {
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2013-05-12 15:40:44 UTC (rev 7490)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2013-05-12 17:47:03 UTC (rev 7491)
@@ -1461,4 +1461,7 @@
<data name="Func_URLENCODE_StringValueDescription" xml:space="preserve">
<value>String to URL encode</value>
</data>
+ <data name="LoadingFeatureClasses" xml:space="preserve">
+ <value>Loading Feature Classes</value>
+ </data>
</root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs 2013-05-12 15:40:44 UTC (rev 7490)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs 2013-05-12 17:47:03 UTC (rev 7491)
@@ -328,8 +328,7 @@
//Step 3: Test to make sure we're all good so far
string result = this.Parent.FeatureService.TestConnection(fsId);
- //LocalNativeConnection returns this string, so I'm assuming this is the "success" result
- if (result == "No errors" || result.ToLower() == "true") //NOXLATE
+ if (Utility.IsSuccessfulConnectionTestResult(result))
//Step 4: Test to see if default cs needs to be specified
FdoSpatialContextList spatialContexts = this.Parent.FeatureService.GetSpatialContextInfo(fsId, false);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2013-05-12 15:40:44 UTC (rev 7490)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2013-05-12 17:47:03 UTC (rev 7491)
@@ -112,6 +112,17 @@
/// <summary>
+ /// Checks if the given result is a successful test connection result
+ /// </summary>
+ /// <param name="sResult"></param>
+ /// <returns></returns>
+ public static bool IsSuccessfulConnectionTestResult(string sResult)
+ //LocalNativeConnection returns this string, so I'm assuming this is the "success" result
+ return (sResult == "No errors" || sResult.ToLower() == "true"); //NOXLATE
+ /// <summary>
/// Parses a color in HTML notation (ea. #ffaabbff)
/// </summary>
/// <param name="color">The HTML representation of the color</param>
@@ -1075,6 +1086,83 @@
const string RESERVED_CHARS = "\\:*?\"<>|&'%=/";
/// <summary>
+ /// Creates a default Layer Definition from the given Class Definition
+ /// </summary>
+ /// <param name="conn"></param>
+ /// <param name="fsId"></param>
+ /// <param name="clsDef"></param>
+ /// <param name="targetFolder"></param>
+ public static string CreateDefaultLayer(IServerConnection conn, string fsId, ClassDefinition clsDef, string targetFolder)
+ GeometricPropertyDefinition geom = null;
+ //Try designated
+ if (!string.IsNullOrEmpty(clsDef.DefaultGeometryPropertyName))
+ geom = clsDef.FindProperty(clsDef.DefaultGeometryPropertyName) as GeometricPropertyDefinition;
+ //Try first geom property
+ if (geom == null)
+ foreach (PropertyDefinition pd in clsDef.Properties)
+ if (pd.Type == PropertyDefinitionType.Geometry)
+ geom = (GeometricPropertyDefinition)pd;
+ break;
+ //Can't proceed without a geometry
+ if (geom == null)
+ return null;
+ //Compute target resource id
+ var prefix = targetFolder;
+ if (!prefix.EndsWith("/")) //NOXLATE
+ prefix += "/";
+ var lyrId = prefix + clsDef.Name + ".LayerDefinition"; //NOXLATE
+ int counter = 0;
+ while (conn.ResourceService.ResourceExists(lyrId))
+ counter++;
+ lyrId = prefix + clsDef.Name + "(" + counter + ").LayerDefinition"; //NOXLATE
+ var ld = ObjectFactory.CreateDefaultLayer(conn, LayerType.Vector, new Version(1, 0, 0));
+ //Assign default properties
+ ld.ResourceID = lyrId;
+ var vld = ld.SubLayer as IVectorLayerDefinition;
+ vld.ResourceId = fsId;
+ vld.FeatureName = clsDef.QualifiedName;
+ vld.Geometry = geom.Name;
+ //Infer geometry storage support and remove unsupported styles
+ var scale = vld.GetScaleRangeAt(0);
+ var geomTypes = geom.GetIndividualGeometricTypes();
+ var remove = new List<string>();
+ if (Array.IndexOf(geomTypes, FeatureGeometricType.Point) < 0)
+ remove.Add(FeatureGeometricType.Point.ToString().ToLower());
+ if (Array.IndexOf(geomTypes, FeatureGeometricType.Curve) < 0)
+ remove.Add(FeatureGeometricType.Curve.ToString().ToLower());
+ if (Array.IndexOf(geomTypes, FeatureGeometricType.Surface) < 0)
+ remove.Add(FeatureGeometricType.Surface.ToString().ToLower());
+ scale.RemoveStyles(remove);
+ conn.ResourceService.SaveResource(ld);
+ return lyrId;
+ /// <summary>
/// Generates a unique layer name for a given vector rule
/// </summary>
/// <param name="layerFormat"></param>
More information about the mapguide-commits
