[mapguide-commits] r7501 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Mon May 20 02:56:40 PDT 2013
Author: jng
Date: 2013-05-20 02:56:40 -0700 (Mon, 20 May 2013)
New Revision: 7501
trunk/Tools/Maestro/Maestro/changelog.txt
changelog.txt update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2013-05-20 06:39:46 UTC (rev 7500)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2013-05-20 09:56:40 UTC (rev 7501)
@@ -1,4 +1,30 @@
-5.0 Beta 5
+5.0 RC1
+ - New context menu command to create default layers from a Feature Source
+ - New context menu command to test a Feature Source connection
+ - All specialized Fusion widget editors removed. All widget editing is through XML
+ - Fusion editor enhancements:
+ - Using ICSharpCode.TextEditor for all XML editing functionality
+ - Fix errant whitespace in widget XML
+ - Basic XML editor support for the Map Widget
+ - Indicate which widgets are dockable
+ - Filter out un-dockable widgets when prompting the user for the widget to attach to a toolbar/container
+ - Support for new Resampling Method paramter in GDAL Feature Source editor
+ - Fix: Dependency list compilation failure on Flexible Layout documents
+ - Fix: OutOfMemoryException on HTTP SETRESOURCEDATA calls involving really large files
+ - Fix: Exceptions during resource preview generation not being shown
+ - Fix: Support WebLayout previews for versions not recognized/supported by Maestro
+ - Fix: Infinite loop in MapViewer legend due to nested group structure
+ - Fix: Layer/Group presentation order in MapViewer legend
+ - Fix: XML editor crash on Ctrl+C due to un-assigned font
+ - Fix: 64-bit ODBC driver flag not set if ODBC connection string references a known 64-bit driver
+ - Fix: Group parentage not being assigned when creating a RuntimeMap
+ - Fix: No legend label for layers not visible in the legend in RtMapInspector
+ - Fix: Display of nested groups in RtMapInspector
+ - Fix: Cannot parse geometry WKT with Z or M coordinates
+ - Fix: "EPSG:" not prepended to epsg codes in WFS metadata tab
+5.0 Beta 5
- First 5.0 release with a matching SDK. Consult the SDK changelog for overview of changes
More information about the mapguide-commits
