[mapguide-commits] r7536 - in trunk/Tools/JenkinsCI: . home/slave_win home/slave_win/jobs/FDO x64 home/slave_win/jobs/FDO x86 home/slave_win/jobs/Maestro 4.0.x home/slave_win/jobs/Maestro trunk home/slave_win/jobs/MapGuide Open Source x64 home/slave_win/jobs/MapGuide Open Source x86 home/slave_win/jobs/MgInstantSetup home/slave_win/jobs/mg-desktop-net40-vc10-x64 home/slave_win/jobs/mg-desktop-net40-vc10-x86 tools
svn_mapguide at osgeo.org
Wed May 29 12:34:53 PDT 2013
Author: jng
Date: 2013-05-29 12:34:53 -0700 (Wed, 29 May 2013)
New Revision: 7536
Added:
trunk/Tools/JenkinsCI/tools/
trunk/Tools/JenkinsCI/tools/SetAssemblyVersion.exe
trunk/Tools/JenkinsCI/tools/UpdateVersion.exe
trunk/Tools/JenkinsCI/tools/fdo_enable_vcexpress64.bat
trunk/Tools/JenkinsCI/tools/revnum.pl
Removed:
trunk/Tools/JenkinsCI/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jenkins.xml
trunk/Tools/JenkinsCI/jobs/
trunk/Tools/JenkinsCI/home/slave_win/config.xml
trunk/Tools/JenkinsCI/home/slave_win/hudson.scm.CVSSCM.xml
trunk/Tools/JenkinsCI/home/slave_win/hudson.scm.SubversionSCM.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/
trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86/
trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 4.0.x/
trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 4.0.x/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/
trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/
trunk/Tools/JenkinsCI/home/slave_win/jobs/MgInstantSetup/
trunk/Tools/JenkinsCI/home/slave_win/jobs/mg-desktop-net40-vc10-x64/
trunk/Tools/JenkinsCI/home/slave_win/jobs/mg-desktop-net40-vc10-x86/
trunk/Tools/JenkinsCI/readme.txt
#2210: Re-org the jenkins configuration. We now version track the files and directories such that we can re-point JENKINS_HOME into it. This will dramatically simplify Jenkins setup for a fresh build environment.
Also check in commonly used tools and scripts that will be used by most Jenkins jobs
Deleted: trunk/Tools/JenkinsCI/config.xml
--- trunk/Tools/JenkinsCI/config.xml 2013-05-29 17:46:13 UTC (rev 7535)
+++ trunk/Tools/JenkinsCI/config.xml 2013-05-29 19:34:53 UTC (rev 7536)
@@ -1,45 +0,0 @@
-<?xml version='1.0' encoding='UTF-8'?>
-<hudson>
- <disabledAdministrativeMonitors/>
- <version>1.465</version>
- <numExecutors>2</numExecutors>
- <mode>NORMAL</mode>
- <useSecurity>true</useSecurity>
- <authorizationStrategy class="hudson.security.AuthorizationStrategy$Unsecured"/>
- <securityRealm class="hudson.security.SecurityRealm$None"/>
- <projectNamingStrategy class="jenkins.model.ProjectNamingStrategy$DefaultProjectNamingStrategy"/>
- <workspaceDir>${ITEM_ROOTDIR}/workspace</workspaceDir>
- <buildsDir>${ITEM_ROOTDIR}/builds</buildsDir>
- <jdks>
- <jdk>
- <name>JDK 6u33 x86</name>
- <home>C:\Program Files (x86)\Java\jdk1.6.0_33</home>
- <properties/>
- </jdk>
- <jdk>
- <name>JDK 6u33 x64</name>
- <home>C:\Program Files\Java\jdk1.6.0_33</home>
- <properties/>
- </jdk>
- </jdks>
- <viewsTabBar class="hudson.views.DefaultViewsTabBar"/>
- <myViewsTabBar class="hudson.views.DefaultMyViewsTabBar"/>
- <clouds/>
- <slaves/>
- <quietPeriod>5</quietPeriod>
- <scmCheckoutRetryCount>0</scmCheckoutRetryCount>
- <views>
- <hudson.model.AllView>
- <owner class="hudson" reference="../../.."/>
- <name>All</name>
- <filterExecutors>false</filterExecutors>
- <filterQueue>false</filterQueue>
- <properties class="hudson.model.View$PropertyList"/>
- </hudson.model.AllView>
- </views>
- <primaryView>All</primaryView>
- <slaveAgentPort>0</slaveAgentPort>
- <label></label>
- <nodeProperties/>
- <globalNodeProperties/>
-</hudson>
\ No newline at end of file
Property changes on: trunk/Tools/JenkinsCI/home/slave_win
___________________________________________________________________
Added: svn:ignore
+ identity.key
plugins
secret.key
secret.key.not-so-secret
secrets
updates
war
Modified: trunk/Tools/JenkinsCI/home/slave_win/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/config.xml 2013-05-29 17:46:13 UTC (rev 7535)
+++ trunk/Tools/JenkinsCI/home/slave_win/config.xml 2013-05-29 19:34:53 UTC (rev 7536)
@@ -51,5 +51,27 @@
<label></label>
<nodeProperties/>
+ <globalNodeProperties>
+ <hudson.slaves.EnvironmentVariablesNodeProperty>
+ <envVars serialization="custom">
+ <unserializable-parents/>
+ <tree-map>
+ <default>
+ <comparator class="hudson.util.CaseInsensitiveComparator"/>
+ </default>
+ <int>5</int>
+ <string>MG_BUILD_AREA</string>
+ <string>C:\working\build_area</string>
+ <string>MG_BUILD_ARTIFACT_PATH</string>
+ <string>C:\builds</string>
+ <string>MG_LIB_ROOT</string>
+ <string>C:\working\libs</string>
+ <string>MG_TOOL_PATH</string>
+ <string>C:\working\JenkinsCI</string>
+ <string>WINDOWS_SDK_71_ROOT</string>
+ <string>C:\Program Files\Microsoft SDKs\Windows\v7.1</string>
+ </tree-map>
+ </envVars>
+ </hudson.slaves.EnvironmentVariablesNodeProperty>
+ </globalNodeProperties>
</hudson>
Modified: trunk/Tools/JenkinsCI/home/slave_win/hudson.scm.CVSSCM.xml
--- trunk/Tools/JenkinsCI/home/slave_win/hudson.scm.CVSSCM.xml 2013-05-29 17:46:13 UTC (rev 7535)
+++ trunk/Tools/JenkinsCI/home/slave_win/hudson.scm.CVSSCM.xml 2013-05-29 19:34:53 UTC (rev 7536)
@@ -3,7 +3,7 @@
<generation>1</generation>
<compressionLevel>3</compressionLevel>
<privateKeyLocation>C:\/.ssh/id_rsa</privateKeyLocation>
- <privateKeyPassword>i5p9Nb3bU7LPIbGPeOhoEA==</privateKeyPassword>
+ <privateKeyPassword>UPk/of7GPKBpanq4xlQT3icsfYni+7d7z9HC4ddveYL2KZaLqMWcM6SfTU4jMrpt</privateKeyPassword>
<knownHostsLocation>C:\/.ssh/known_hosts</knownHostsLocation>
<authTokens/>
<changelogEncoding>UTF-8</changelogEncoding>
Modified: trunk/Tools/JenkinsCI/home/slave_win/hudson.scm.SubversionSCM.xml
--- trunk/Tools/JenkinsCI/home/slave_win/hudson.scm.SubversionSCM.xml 2013-05-29 17:46:13 UTC (rev 7535)
+++ trunk/Tools/JenkinsCI/home/slave_win/hudson.scm.SubversionSCM.xml 2013-05-29 19:34:53 UTC (rev 7536)
@@ -1,6 +1,6 @@
<hudson.scm.SubversionSCM_-DescriptorImpl plugin="subversion at 1.48">
- <generation>1</generation>
+ <generation>5</generation>
<credentials class="hashtable"/>
<workspaceFormat>10</workspaceFormat>
<validateRemoteUpToVar>false</validateRemoteUpToVar>
Deleted: trunk/Tools/JenkinsCI/home/slave_win/jenkins.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jenkins.xml 2013-05-29 17:46:13 UTC (rev 7535)
+++ trunk/Tools/JenkinsCI/home/slave_win/jenkins.xml 2013-05-29 19:34:53 UTC (rev 7536)
@@ -1,50 +0,0 @@
-The MIT License
-Copyright (c) 2004-2009, Sun Microsystems, Inc., Kohsuke Kawaguchi
-Permission is hereby granted, free of charge, to any person obtaining a copy
-of this software and associated documentation files (the "Software"), to deal
-in the Software without restriction, including without limitation the rights
-to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
-copies of the Software, and to permit persons to whom the Software is
-furnished to do so, subject to the following conditions:
-The above copyright notice and this permission notice shall be included in
-all copies or substantial portions of the Software.
-THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
-IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
-FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
-AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
-LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
-OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
-THE SOFTWARE.
- Windows service definition for Jenkins
- To uninstall, run "jenkins.exe stop" to stop the service, then "jenkins.exe uninstall" to uninstall the service.
- Both commands don't produce any output if the execution is successful.
-<service>
- <id>jenkins</id>
- <name>Jenkins</name>
- <description>This service runs Jenkins continuous integration system.</description>
- <env name="JENKINS_HOME" value="%BASE%"/>
- if you'd like to run Jenkins with a specific version of Java, specify a full path to java.exe.
- The following value assumes that you have java in your PATH.
- <executable>%BASE%\jre\bin\java</executable>
- <arguments>-Xrs -Xmx256m -Dhudson.lifecycle=hudson.lifecycle.WindowsServiceLifecycle -jar "%BASE%\jenkins.war" --httpPort=8080</arguments>
- interactive flag causes the empty black Java window to be displayed.
- I'm still debugging this.
- <interactive />
- <logmode>rotate</logmode>
- <onfailure action="restart" />
-</service>
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64
Added: svn:ignore
+ builds
nextBuildNumber
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml 2013-05-29 17:46:13 UTC (rev 7535)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml 2013-05-29 19:34:53 UTC (rev 7536)
@@ -2,7 +2,7 @@
<project>
<actions/>
<description></description>
- <logRotator>
+ <logRotator class="hudson.tasks.LogRotator">
<daysToKeep>-1</daysToKeep>
<numToKeep>1</numToKeep>
<artifactDaysToKeep>-1</artifactDaysToKeep>
@@ -15,43 +15,18 @@
<hudson.model.StringParameterDefinition>
<name>BUILD_SRC64</name>
<description>FDO Source directory</description>
- <defaultValue>C:\fdo-3.8-x64</defaultValue>
+ <defaultValue>C:\working\sources\fdo-3.8</defaultValue>
</hudson.model.StringParameterDefinition>
- <name>BUILD_OUTPUT64</name>
- <description>FDO build output directory</description>
- <defaultValue>C:\builds\fdo\3.8\x64_vc10</defaultValue>
- </hudson.model.StringParameterDefinition>
- <hudson.model.StringParameterDefinition>
- <name>MYSQL_SDK64</name>
- <description>MySQL Connector C SDK path</description>
- <defaultValue>C:\fdo_rdbms_thirdparty\mysql_x64</defaultValue>
- <name>ORACLE_SDK64</name>
- <description>Oracle Instant Client SDK path</description>
- <defaultValue>C:\fdo_rdbms_thirdparty\oracle_x64\instantclient\11.2\sdk</defaultValue>
<name>FDO_VERSION_64</name>
<description>FDO Version Number (major.minor.rev)</description>
<defaultValue>3.8.0</defaultValue>
- <name>FDO_STAMP_FILE64</name>
- <description>Path to store the last FDO svn revision</description>
- <defaultValue>C:\builds\last_fdo_x64_revision.txt</defaultValue>
<name>REVNUM_FILE64</name>
<description>Path to revnum.pl script</description>
<defaultValue>C:\builds\revnum.pl</defaultValue>
- <name>FDO_BIN_EXTRAS64</name>
- <description>Path to FDO binaries to overlay on top of the build output</description>
- <defaultValue>C:\builds\fdo_extras_x64</defaultValue>
</parameterDefinitions>
</hudson.model.ParametersDefinitionProperty>
</properties>
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86
Added: svn:ignore
+ builds
nextBuildNumber
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 4.0.x
Added: svn:ignore
+ builds
lastStable
lastSuccessful
nextBuildNumber
scm-polling.log
svnexternals.txt
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 4.0.x/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 4.0.x/config.xml 2013-05-29 17:46:13 UTC (rev 7535)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 4.0.x/config.xml 2013-05-29 19:34:53 UTC (rev 7536)
@@ -2,7 +2,7 @@
<project>
<actions/>
- <logRotator>
<numToKeep>5</numToKeep>
@@ -15,16 +15,18 @@
<name>VersionLabel</name>
<description>The release version label</description>
- <defaultValue>4.0.4</defaultValue>
+ <defaultValue>4.0.6</defaultValue>
</properties>
- <scm class="hudson.scm.SubversionSCM">
+ <scm class="hudson.scm.SubversionSCM" plugin="subversion at 1.48">
<locations>
<hudson.scm.SubversionSCM_-ModuleLocation>
<remote>http://svn.osgeo.org/mapguide/branches/maestro-4.0.x</remote>
<local>.</local>
+ <depthOption>infinity</depthOption>
+ <ignoreExternalsOption>false</ignoreExternalsOption>
</hudson.scm.SubversionSCM_-ModuleLocation>
</locations>
<excludedRegions></excludedRegions>
@@ -33,6 +35,8 @@
<excludedRevprop></excludedRevprop>
<excludedCommitMessages></excludedCommitMessages>
<workspaceUpdater class="hudson.scm.subversion.UpdateUpdater"/>
+ <ignoreDirPropChanges>false</ignoreDirPropChanges>
+ <filterChangelog>false</filterChangelog>
</scm>
<canRoam>true</canRoam>
<disabled>false</disabled>
@@ -42,6 +46,7 @@
<triggers class="vector">
<hudson.triggers.SCMTrigger>
<spec>15 * * * *</spec>
+ <ignorePostCommitHooks>false</ignorePostCommitHooks>
</hudson.triggers.SCMTrigger>
</triggers>
<concurrentBuild>false</concurrentBuild>
@@ -51,17 +56,18 @@
rd /S /Q out
popd
pushd %WORKSPACE%\Properties
-C:\builds\SetAssemblyVersion.exe -set:%VersionLabel%.%SVN_REVISION% GlobalAssemblyInfo.cs
+%MG_TOOL_PATH%\SetAssemblyVersion.exe -set:%VersionLabel%.%SVN_REVISION% GlobalAssemblyInfo.cs
popd
pushd %WORKSPACE%\SDK
rd /S /Q bin
popd</command>
</hudson.tasks.BatchFile>
- <hudson.plugins.msbuild.MsBuildBuilder>
+ <hudson.plugins.msbuild.MsBuildBuilder plugin="msbuild at 1.17">
<msBuildName>MSBUILD 3.5 x86</msBuildName>
<msBuildFile>Maestro\Maestro_All.sln</msBuildFile>
<cmdLineArgs>/p:Configuration=Release</cmdLineArgs>
<buildVariablesAsProperties>true</buildVariablesAsProperties>
+ <continueOnBuildFailure>false</continueOnBuildFailure>
</hudson.plugins.msbuild.MsBuildBuilder>
<hudson.tasks.BatchFile>
<command>pushd %WORKSPACE%\UserDoc
@@ -89,11 +95,12 @@
7z a -tzip -mx9 C:\builds\MapGuideMaestro-%VersionLabel%-Release.zip .
popd</command>
<msBuildName>MSBUILD 4.0 x86</msBuildName>
<msBuildFile>Doc\MaestroAPI.shfbproj</msBuildFile>
<cmdLineArgs></cmdLineArgs>
<command>pushd %WORKSPACE%\Doc\Help
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk
Added: svn:ignore
+ builds
lastStable
lastSuccessful
nextBuildNumber
scm-polling.log
svnexternals.txt
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml 2013-05-29 17:46:13 UTC (rev 7535)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml 2013-05-29 19:34:53 UTC (rev 7536)
@@ -2,7 +2,7 @@
<project>
<actions/>
- <logRotator>
@@ -15,16 +15,18 @@
- <defaultValue>5.0b5</defaultValue>
+ <defaultValue>5.0RC2</defaultValue>
</properties>
<locations>
<remote>http://svn.osgeo.org/mapguide/trunk/Tools/Maestro</remote>
<local>.</local>
</locations>
@@ -33,6 +35,8 @@
</scm>
@@ -42,6 +46,7 @@
</triggers>
@@ -51,17 +56,18 @@
rd /S /Q out
popd
-C:\builds\SetAssemblyVersion.exe -set:5.0.0.%SVN_REVISION% GlobalAssemblyInfo.cs
+%MG_TOOL_PATH%\SetAssemblyVersion.exe -set:5.0.0.%SVN_REVISION% GlobalAssemblyInfo.cs
popd
rd /S /Q bin
popd</command>
<command>pushd %WORKSPACE%\out\Release\AddIns
@@ -95,11 +101,12 @@
popd</command>
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64
Added: svn:ignore
+ builds
nextBuildNumber
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86
Added: svn:ignore
+ builds
nextBuildNumber
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/MgInstantSetup
Added: svn:ignore
+ builds
nextBuildNumber
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/mg-desktop-net40-vc10-x64
Added: svn:ignore
+ builds
nextBuildNumber
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/mg-desktop-net40-vc10-x86
Added: svn:ignore
+ builds
nextBuildNumber
Modified: trunk/Tools/JenkinsCI/readme.txt
--- trunk/Tools/JenkinsCI/readme.txt 2013-05-29 17:46:13 UTC (rev 7535)
+++ trunk/Tools/JenkinsCI/readme.txt 2013-05-29 19:34:53 UTC (rev 7536)
@@ -66,24 +66,40 @@
* Currently configured for MGOS 2.5 and FDO 3.8, adjust these version numbers as necessary
-C:\apache-ant-1.8.3 [extracted location of apache ant v1.8.3]
-C:\builds [all build artifacts produced by Jenkins will be here]
- - revnum.pl [copy from http://svn.osgeo.org/fdo/branches/2.5/Installer/scripts/revnum.pl]
-C:\fdo_rdbms_thirdparty
- mysql [extract/copy MySQL Connector C 32-bit headers/libs here]
- mysql_x64 [extract/copy MySQL Connector C 64-bit headers/libs here]
- oracle [extract 32-bit oracle 11.2 instant client sdk here]
- oracle_x64 [extract 64-bit oracle 11.2 instant client sdk here]
-C:\fdo-3.8-x86 [svn wc of http://svn.osgeo.org/fdo/branches/3.8]
-C:\fdo-3.8-x64 [svn wc of http://svn.osgeo.org/fdo/branches/3.8]
-C:\mg-2.5-x86
- - Installer [svn wc of http://svn.osgeo.org/mapguide/branches/2.5/Installer]
- - MgDev [svn wc of http://svn.osgeo.org/mapguide/branches/2.5/MgDev]
-C:\mg-2.5-x64
-C:\nasm [extract nasm binaries here]
+C:\apache-ant-1.8.3 [extracted location of apache ant v1.8.3]
+C:\builds [all build artifacts produced by Jenkins will be here]
+C:\nasm [extract nasm binaries here]
+C:\working
+ libs
+ fdo_rdbms_thirdparty
+ mysql [extract/copy MySQL Connector C 32-bit headers/libs here]
+ mysql_x64 [extract/copy MySQL Connector C 64-bit headers/libs here]
+ oracle [extract 32-bit oracle 11.2 instant client sdk here]
+ oracle_x64 [extract 64-bit oracle 11.2 instant client sdk here]
+ sources
+ fdo-3.8 [svn checkout of http://svn.osgeo.org/fdo/branches/3.8]
+ mg-2.5
+ Installer [svn checkout of http://svn.osgeo.org/mapguide/branches/2.5/Installer]
+ MgDev [svn checkout of http://svn.osgeo.org/mapguide/branches/2.5/MgDev]
+ JenkinsCI [svn checkout of http://svn.osgeo.org/mapguide/trunk/Tools/JenkinsCI]
+ home
+ slave_win [the path of JENKINS_HOME]
+Required Jenkins Plugins
+ * MSBuild
+Jenkins Post-install config
+ * Environment variables (already defined in JenkinsCI checkout. Double check paths)
+ * MG_BUILD_ARTIFACT_PATH = C:\builds
+ * MG_TOOL_PATH = C:\working\JenkinsCI\tools
+ * MG_LIB_ROOT = C:\working\libs
+ * MG_BUILD_AREA = C:\working\build_area
+ * WINDOWS_SDK_71_ROOT = C:\Program Files\Microsoft SDKs\Windows\v7.1
PATH environment variable
Property changes on: trunk/Tools/JenkinsCI/tools
Added: bugtraq:number
+ true
Added: trunk/Tools/JenkinsCI/tools/SetAssemblyVersion.exe
(Binary files differ)
Property changes on: trunk/Tools/JenkinsCI/tools/SetAssemblyVersion.exe
Added: svn:mime-type
+ application/octet-stream
Added: trunk/Tools/JenkinsCI/tools/UpdateVersion.exe
Property changes on: trunk/Tools/JenkinsCI/tools/UpdateVersion.exe
Added: trunk/Tools/JenkinsCI/tools/fdo_enable_vcexpress64.bat
--- trunk/Tools/JenkinsCI/tools/fdo_enable_vcexpress64.bat (rev 0)
+++ trunk/Tools/JenkinsCI/tools/fdo_enable_vcexpress64.bat 2013-05-29 19:34:53 UTC (rev 7536)
@@ -0,0 +1,73 @@
+ at echo off
+REM Description: Helper script to enable building 64-bit FDO with the 64-bit C++ compiler from the Windows 7.1 SDK
+REM Author: Jackie Ng (jumpinjackie at gmail.com)
+REM Usage: fdo_enable_vcexpress64.bat
+SET FDOROOT=%1
+if not exist "%FDOROOT%" goto usage
+if exist %FDOROOT%\Fdo\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Fdo\build.bat
+ echo Updated %FDOROOT%\Fdo\build.bat
+if exist %FDOROOT%\Providers\ArcSDE\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\ArcSDE\build.bat
+ echo Updated %FDOROOT%\Providers\ArcSDE\build.bat
+if exist %FDOROOT%\Providers\GDAL\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\GDAL\build.bat
+ echo Updated %FDOROOT%\Providers\GDAL\build.bat
+if exist %FDOROOT%\Providers\GenericRdbms\Src\MySQL\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\GenericRdbms\Src\MySQL\build.bat
+ echo Updated %FDOROOT%\Providers\GenericRdbms\Src\MySQL\build.bat
+if exist %FDOROOT%\Providers\GenericRdbms\Src\ODBC\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\GenericRdbms\Src\ODBC\build.bat
+ echo Updated %FDOROOT%\Providers\GenericRdbms\Src\ODBC\build.bat
+if exist %FDOROOT%\Providers\GenericRdbms\Src\PostGis\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\GenericRdbms\Src\PostGis\build.bat
+ echo Updated %FDOROOT%\Providers\GenericRdbms\Src\PostGis\build.bat
+if exist %FDOROOT%\Providers\GenericRdbms\Src\SQLServerSpatial\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\GenericRdbms\Src\SQLServerSpatial\build.bat
+ echo Updated %FDOROOT%\Providers\GenericRdbms\Src\SQLServerSpatial\build.bat
+if exist %FDOROOT%\Providers\KingOracle\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\KingOracle\build.bat
+ echo Updated %FDOROOT%\Providers\KingOracle\build.bat
+if exist %FDOROOT%\Providers\OGR\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\OGR\build.bat
+ echo Updated %FDOROOT%\Providers\OGR\build.bat
+if exist %FDOROOT%\Providers\SDF\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\SDF\build.bat
+ echo Updated %FDOROOT%\Providers\SDF\build.bat
+if exist %FDOROOT%\Providers\SHP\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\SHP\build.bat
+ echo Updated %FDOROOT%\Providers\SHP\build.bat
+if exist %FDOROOT%\Providers\SQLite\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\SQLite\build.bat
+ echo Updated %FDOROOT%\Providers\SQLite\build.bat
+if exist %FDOROOT%\Providers\WFS\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\WFS\build.bat
+ echo Updated %FDOROOT%\Providers\WFS\build.bat
+if exist %FDOROOT%\Providers\WMS\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Providers\WMS\build.bat
+ echo Updated %FDOROOT%\Providers\WMS\build.bat
+if exist %FDOROOT%\Thirdparty\build.bat (
+ sed -i "s/REM SET EXTRA_MSBUILD_PROPERTIES/SET EXTRA_MSBUILD_PROPERTIES/g" %FDOROOT%\Thirdparty\build.bat
+ echo Updated %FDOROOT%\Thirdparty\build.bat
+goto exit
+:usage
+echo Usage - fdo_enable_vcexpress64.bat FDO_SRC_ROOT
+:error
+exit /B 1
+:exit
+exit /B 0
Added: trunk/Tools/JenkinsCI/tools/revnum.pl
--- trunk/Tools/JenkinsCI/tools/revnum.pl (rev 0)
+++ trunk/Tools/JenkinsCI/tools/revnum.pl 2013-05-29 19:34:53 UTC (rev 7536)
@@ -0,0 +1,8 @@
+while (defined($line = <STDIN>))
+ ($key,$value) = split(/: /,$line);
+ if ($key eq "Last Changed Rev")
+ print $value;
More information about the mapguide-commits
