[mapguide-commits] r7922 - in trunk/Tools/Maestro/Maestro.Base: Commands/SiteExplorer UI
svn_mapguide at osgeo.org
Sun Nov 24 07:29:14 PST 2013
Author: jng
Date: 2013-11-24 07:29:14 -0800 (Sun, 24 Nov 2013)
New Revision: 7922
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ResourcePropertiesCommand.cs
trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.cs
trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.resx
#2328: Add option in the References tab of the Resource Properties dialog to open selected referenced resources in an editor
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ResourcePropertiesCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ResourcePropertiesCommand.cs 2013-11-24 15:09:09 UTC (rev 7921)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ResourcePropertiesCommand.cs 2013-11-24 15:29:14 UTC (rev 7922)
@@ -44,8 +44,10 @@
//Can only show properties of one selected item
if (items.Length == 1)
+ var openMgr = ServiceRegistry.GetService<OpenResourceManager>();
var icons = ResourceIconCache.CreateDefault();
- var dlg = new ResourcePropertiesDialog(icons, conn, items[0].ResourceId);
+ var dlg = new ResourcePropertiesDialog(icons, conn, items[0].ResourceId, openMgr, wb.ActiveSiteExplorer);
dlg.ShowDialog(wb);
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.Designer.cs 2013-11-24 15:09:09 UTC (rev 7921)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.Designer.cs 2013-11-24 15:29:14 UTC (rev 7922)
@@ -40,6 +40,11 @@
this.columnHeader1 = ((System.Windows.Forms.ColumnHeader)(new System.Windows.Forms.ColumnHeader()));
this.columnHeader2 = ((System.Windows.Forms.ColumnHeader)(new System.Windows.Forms.ColumnHeader()));
this.columnHeader3 = ((System.Windows.Forms.ColumnHeader)(new System.Windows.Forms.ColumnHeader()));
+ this.securityContextMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
+ this.readWriteAccessToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.readOnlyAccessToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.denyAccessToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.inheritedAccessRightsToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.WMSTab = new System.Windows.Forms.TabPage();
this.WMSClearHeaderButton = new System.Windows.Forms.Button();
this.groupBox2 = new System.Windows.Forms.GroupBox();
@@ -106,14 +111,14 @@
this.OKBtn = new System.Windows.Forms.Button();
this.ReferenceWorker = new System.ComponentModel.BackgroundWorker();
this.UserAndGroupImages = new System.Windows.Forms.ImageList(this.components);
- this.securityContextMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
- this.readWriteAccessToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.readOnlyAccessToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.denyAccessToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.inheritedAccessRightsToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.toolTip = new System.Windows.Forms.ToolTip(this.components);
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.toolStrip2 = new System.Windows.Forms.ToolStrip();
+ this.btnReferencesOpenSelected = new System.Windows.Forms.ToolStripButton();
+ this.btnReferencedByOpenSelected = new System.Windows.Forms.ToolStripButton();
this.tabControl1.SuspendLayout();
this.SecurityTab.SuspendLayout();
+ this.securityContextMenu.SuspendLayout();
this.WMSTab.SuspendLayout();
this.groupBox2.SuspendLayout();
this.groupBox1.SuspendLayout();
@@ -123,6 +128,7 @@
this.CustomTab.SuspendLayout();
((System.ComponentModel.ISupportInitialize)(this.dataGridView1)).BeginInit();
this.ReferenceTab.SuspendLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).BeginInit();
this.splitContainer1.Panel1.SuspendLayout();
this.splitContainer1.Panel2.SuspendLayout();
this.splitContainer1.SuspendLayout();
@@ -132,7 +138,8 @@
this.ctxReferenced.SuspendLayout();
this.panel2.SuspendLayout();
this.panel1.SuspendLayout();
- this.securityContextMenu.SuspendLayout();
+ this.toolStrip1.SuspendLayout();
+ this.toolStrip2.SuspendLayout();
this.SuspendLayout();
// tabControl1
@@ -187,6 +194,41 @@
resources.ApplyResources(this.columnHeader3, "columnHeader3");
+ // securityContextMenu
+ this.securityContextMenu.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.readWriteAccessToolStripMenuItem,
+ this.readOnlyAccessToolStripMenuItem,
+ this.denyAccessToolStripMenuItem,
+ this.inheritedAccessRightsToolStripMenuItem});
+ this.securityContextMenu.Name = "securityContextMenu";
+ resources.ApplyResources(this.securityContextMenu, "securityContextMenu");
+ this.securityContextMenu.Opening += new System.ComponentModel.CancelEventHandler(this.securityContextMenu_Opening);
+ // readWriteAccessToolStripMenuItem
+ this.readWriteAccessToolStripMenuItem.Name = "readWriteAccessToolStripMenuItem";
+ resources.ApplyResources(this.readWriteAccessToolStripMenuItem, "readWriteAccessToolStripMenuItem");
+ this.readWriteAccessToolStripMenuItem.Click += new System.EventHandler(this.readWriteAccessToolStripMenuItem_Click);
+ // readOnlyAccessToolStripMenuItem
+ this.readOnlyAccessToolStripMenuItem.Name = "readOnlyAccessToolStripMenuItem";
+ resources.ApplyResources(this.readOnlyAccessToolStripMenuItem, "readOnlyAccessToolStripMenuItem");
+ this.readOnlyAccessToolStripMenuItem.Click += new System.EventHandler(this.readOnlyAccessToolStripMenuItem_Click);
+ // denyAccessToolStripMenuItem
+ this.denyAccessToolStripMenuItem.Name = "denyAccessToolStripMenuItem";
+ resources.ApplyResources(this.denyAccessToolStripMenuItem, "denyAccessToolStripMenuItem");
+ this.denyAccessToolStripMenuItem.Click += new System.EventHandler(this.denyAccessToolStripMenuItem_Click);
+ // inheritedAccessRightsToolStripMenuItem
+ this.inheritedAccessRightsToolStripMenuItem.Name = "inheritedAccessRightsToolStripMenuItem";
+ resources.ApplyResources(this.inheritedAccessRightsToolStripMenuItem, "inheritedAccessRightsToolStripMenuItem");
+ this.inheritedAccessRightsToolStripMenuItem.Click += new System.EventHandler(this.inheritedAccessRightsToolStripMenuItem_Click);
// WMSTab
this.WMSTab.Controls.Add(this.WMSClearHeaderButton);
@@ -570,6 +612,7 @@
// OutReferences
this.OutReferences.Controls.Add(this.OutReferenceList);
+ this.OutReferences.Controls.Add(this.toolStrip1);
resources.ApplyResources(this.OutReferences, "OutReferences");
this.OutReferences.Name = "OutReferences";
this.OutReferences.TabStop = false;
@@ -580,10 +623,10 @@
resources.ApplyResources(this.OutReferenceList, "OutReferenceList");
this.OutReferenceList.FullRowSelect = true;
this.OutReferenceList.GridLines = true;
- this.OutReferenceList.MultiSelect = false;
this.OutReferenceList.Name = "OutReferenceList";
this.OutReferenceList.UseCompatibleStateImageBehavior = false;
this.OutReferenceList.View = System.Windows.Forms.View.List;
+ this.OutReferenceList.SelectedIndexChanged += new System.EventHandler(this.OutReferenceList_SelectedIndexChanged);
this.OutReferenceList.KeyUp += new System.Windows.Forms.KeyEventHandler(this.OutReferenceList_KeyUp);
// ctxReferences
@@ -603,6 +646,7 @@
// InReferences
this.InReferences.Controls.Add(this.InReferenceList);
+ this.InReferences.Controls.Add(this.toolStrip2);
resources.ApplyResources(this.InReferences, "InReferences");
this.InReferences.Name = "InReferences";
this.InReferences.TabStop = false;
@@ -613,10 +657,10 @@
resources.ApplyResources(this.InReferenceList, "InReferenceList");
this.InReferenceList.FullRowSelect = true;
this.InReferenceList.GridLines = true;
- this.InReferenceList.MultiSelect = false;
this.InReferenceList.Name = "InReferenceList";
this.InReferenceList.UseCompatibleStateImageBehavior = false;
this.InReferenceList.View = System.Windows.Forms.View.List;
+ this.InReferenceList.SelectedIndexChanged += new System.EventHandler(this.InReferenceList_SelectedIndexChanged);
this.InReferenceList.KeyUp += new System.Windows.Forms.KeyEventHandler(this.InReferenceList_KeyUp);
// ctxReferenced
@@ -693,41 +737,34 @@
this.UserAndGroupImages.Images.SetKeyName(6, "InheritedUser.ico");
this.UserAndGroupImages.Images.SetKeyName(7, "InheritedGroup.ico");
- // securityContextMenu
+ // toolStrip1
- this.securityContextMenu.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.readWriteAccessToolStripMenuItem,
- this.readOnlyAccessToolStripMenuItem,
- this.denyAccessToolStripMenuItem,
- this.inheritedAccessRightsToolStripMenuItem});
- this.securityContextMenu.Name = "securityContextMenu";
- resources.ApplyResources(this.securityContextMenu, "securityContextMenu");
- this.securityContextMenu.Opening += new System.ComponentModel.CancelEventHandler(this.securityContextMenu_Opening);
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnReferencesOpenSelected});
+ resources.ApplyResources(this.toolStrip1, "toolStrip1");
+ this.toolStrip1.Name = "toolStrip1";
- // readWriteAccessToolStripMenuItem
+ // toolStrip2
- this.readWriteAccessToolStripMenuItem.Name = "readWriteAccessToolStripMenuItem";
- resources.ApplyResources(this.readWriteAccessToolStripMenuItem, "readWriteAccessToolStripMenuItem");
- this.readWriteAccessToolStripMenuItem.Click += new System.EventHandler(this.readWriteAccessToolStripMenuItem_Click);
+ this.toolStrip2.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnReferencedByOpenSelected});
+ resources.ApplyResources(this.toolStrip2, "toolStrip2");
+ this.toolStrip2.Name = "toolStrip2";
- // readOnlyAccessToolStripMenuItem
+ // btnReferencesOpenSelected
- this.readOnlyAccessToolStripMenuItem.Name = "readOnlyAccessToolStripMenuItem";
- resources.ApplyResources(this.readOnlyAccessToolStripMenuItem, "readOnlyAccessToolStripMenuItem");
- this.readOnlyAccessToolStripMenuItem.Click += new System.EventHandler(this.readOnlyAccessToolStripMenuItem_Click);
+ resources.ApplyResources(this.btnReferencesOpenSelected, "btnReferencesOpenSelected");
+ this.btnReferencesOpenSelected.Image = global::Maestro.Base.Properties.Resources.folder_open_document;
+ this.btnReferencesOpenSelected.Name = "btnReferencesOpenSelected";
+ this.btnReferencesOpenSelected.Click += new System.EventHandler(this.btnReferencesOpenSelected_Click);
- // denyAccessToolStripMenuItem
+ // btnReferencedByOpenSelected
- this.denyAccessToolStripMenuItem.Name = "denyAccessToolStripMenuItem";
- resources.ApplyResources(this.denyAccessToolStripMenuItem, "denyAccessToolStripMenuItem");
- this.denyAccessToolStripMenuItem.Click += new System.EventHandler(this.denyAccessToolStripMenuItem_Click);
+ resources.ApplyResources(this.btnReferencedByOpenSelected, "btnReferencedByOpenSelected");
+ this.btnReferencedByOpenSelected.Image = global::Maestro.Base.Properties.Resources.folder_open_document;
+ this.btnReferencedByOpenSelected.Name = "btnReferencedByOpenSelected";
+ this.btnReferencedByOpenSelected.Click += new System.EventHandler(this.btnReferencedByOpenSelected_Click);
- // inheritedAccessRightsToolStripMenuItem
- this.inheritedAccessRightsToolStripMenuItem.Name = "inheritedAccessRightsToolStripMenuItem";
- resources.ApplyResources(this.inheritedAccessRightsToolStripMenuItem, "inheritedAccessRightsToolStripMenuItem");
- this.inheritedAccessRightsToolStripMenuItem.Click += new System.EventHandler(this.inheritedAccessRightsToolStripMenuItem_Click);
// ResourcePropertiesDialog
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
@@ -740,6 +777,7 @@
this.tabControl1.ResumeLayout(false);
this.SecurityTab.ResumeLayout(false);
this.SecurityTab.PerformLayout();
+ this.securityContextMenu.ResumeLayout(false);
this.WMSTab.ResumeLayout(false);
this.groupBox2.ResumeLayout(false);
this.groupBox2.PerformLayout();
@@ -755,15 +793,21 @@
this.ReferenceTab.ResumeLayout(false);
this.splitContainer1.Panel1.ResumeLayout(false);
this.splitContainer1.Panel2.ResumeLayout(false);
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).EndInit();
this.splitContainer1.ResumeLayout(false);
this.OutReferences.ResumeLayout(false);
+ this.OutReferences.PerformLayout();
this.ctxReferences.ResumeLayout(false);
this.InReferences.ResumeLayout(false);
+ this.InReferences.PerformLayout();
this.ctxReferenced.ResumeLayout(false);
this.panel2.ResumeLayout(false);
this.panel2.PerformLayout();
this.panel1.ResumeLayout(false);
- this.securityContextMenu.ResumeLayout(false);
+ this.toolStrip1.ResumeLayout(false);
+ this.toolStrip1.PerformLayout();
+ this.toolStrip2.ResumeLayout(false);
+ this.toolStrip2.PerformLayout();
this.ResumeLayout(false);
@@ -849,5 +893,9 @@
private System.Windows.Forms.ToolStripMenuItem copyResourceIDToolStripMenuItem;
private System.Windows.Forms.ContextMenuStrip ctxReferenced;
private System.Windows.Forms.ToolStripMenuItem copyResourceIDToolStripMenuItem1;
+ private System.Windows.Forms.ToolStrip toolStrip1;
+ private System.Windows.Forms.ToolStripButton btnReferencesOpenSelected;
+ private System.Windows.Forms.ToolStrip toolStrip2;
+ private System.Windows.Forms.ToolStripButton btnReferencedByOpenSelected;
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.cs 2013-11-24 15:09:09 UTC (rev 7921)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.cs 2013-11-24 15:29:14 UTC (rev 7922)
@@ -36,6 +36,7 @@
using OSGeo.MapGuide.ObjectModels.LayerDefinition;
using OSGeo.MapGuide.MaestroAPI.Schema;
using Maestro.Editors.Common;
+using Maestro.Base.Services;
namespace Maestro.Base.UI
@@ -88,13 +89,18 @@
/// </summary>
public string OpenResource { get { return m_openResource; } }
- public ResourcePropertiesDialog(IResourceIconCache icons, IServerConnection connection, string resourceId)
+ private OpenResourceManager _openMgr;
+ private ISiteExplorer _siteExp;
+ public ResourcePropertiesDialog(IResourceIconCache icons, IServerConnection connection, string resourceId, OpenResourceManager openMgr, ISiteExplorer siteExp)
: this()
m_connection = connection;
m_resourceId = resourceId;
ResourceID.Text = resourceId;
m_icons = icons;
+ _openMgr = openMgr;
+ _siteExp = siteExp;
InReferenceList.SmallImageList = OutReferenceList.SmallImageList = icons.SmallImageList;
@@ -1086,5 +1092,33 @@
if (InReferenceList.SelectedItems.Count != 1)
e.Cancel = true;
+ private void OutReferenceList_SelectedIndexChanged(object sender, EventArgs e)
+ btnReferencesOpenSelected.Enabled = (OutReferenceList.SelectedItems.Count > 0);
+ btnReferencedByOpenSelected.Enabled = (InReferenceList.SelectedItems.Count > 0);
+ private void InReferenceList_SelectedIndexChanged(object sender, EventArgs e)
+ private void btnReferencesOpenSelected_Click(object sender, EventArgs e)
+ foreach (ListViewItem item in OutReferenceList.SelectedItems)
+ _openMgr.Open(item.Text, m_connection, false, _siteExp);
+ private void btnReferencedByOpenSelected_Click(object sender, EventArgs e)
+ foreach (ListViewItem item in InReferenceList.SelectedItems)
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.resx 2013-11-24 15:09:09 UTC (rev 7921)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.resx 2013-11-24 15:29:14 UTC (rev 7922)
@@ -171,6 +171,42 @@
<data name="columnHeader3.Width" type="System.Int32, mscorlib">
<value>93</value>
</data>
+ <metadata name="securityContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>314, 17</value>
+ </metadata>
+ <data name="readWriteAccessToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+ <value>191, 22</value>
+ </data>
+ <data name="readWriteAccessToolStripMenuItem.Text" xml:space="preserve">
+ <value>Read write access</value>
+ </data>
+ <data name="readOnlyAccessToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="readOnlyAccessToolStripMenuItem.Text" xml:space="preserve">
+ <value>Read only access</value>
+ </data>
+ <data name="denyAccessToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="denyAccessToolStripMenuItem.Text" xml:space="preserve">
+ <value>Deny access</value>
+ </data>
+ <data name="inheritedAccessRightsToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="inheritedAccessRightsToolStripMenuItem.Text" xml:space="preserve">
+ <value>Inherited access rights</value>
+ </data>
+ <data name="securityContextMenu.Size" type="System.Drawing.Size, System.Drawing">
+ <value>192, 92</value>
+ </data>
+ <data name=">>securityContextMenu.Name" xml:space="preserve">
+ <value>securityContextMenu</value>
+ </data>
+ <data name=">>securityContextMenu.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ContextMenuStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
<data name="UsersAndGroups.Enabled" type="System.Boolean, mscorlib">
<value>False</value>
</data>
@@ -178,7 +214,7 @@
<value>16, 40</value>
</data>
<data name="UsersAndGroups.Size" type="System.Drawing.Size, System.Drawing">
- <value>316, 310</value>
+ <value>466, 310</value>
</data>
<data name="UsersAndGroups.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -202,7 +238,7 @@
<value>3, 3, 3, 3</value>
</data>
<data name="SecurityTab.Size" type="System.Drawing.Size, System.Drawing">
- <value>346, 361</value>
+ <value>496, 361</value>
</data>
<data name="SecurityTab.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -258,14 +294,14 @@
<data name="AutoGenerateWMSBounds.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAXNJREFUOE+tkrFL
- AnEcxYWmoD+gsc3FpaFNqsnBKBpqCII22xy6IQNxqcEWwUmIDiKMME2oJSEi4VoqCCoIo646Q07zyAw8
- 0OJevZ8YRkIcdfAdjt+9z/e9dz+H47+f22APXi9WQa6p7aCcmYaRGUf1RBLTcV8kEkE4HMbV8RaeUv2o
- Hg2hcjiIh5gTpZQHDWMG5rUXpaQLzwfe76B4fAO6rqO4O4fHFSca92Ow7gZgXnqghrpQSvThrTiBen4S
- utwtYOXtXpj59aabaDQK06yhdrOHwtqo2PxeGBGCYmIYdUMRkIoy25zP8x9RCDEMA7ncObSYS1jfX3JD
- S06JLS+noc7Z2wtp9XC27EZ2cxGBhQCCwfnfhe0QWZYhSRLoiN2wWJ/PZw9CoN/vF2JC6OzPEDoilEBb
- 944idkFhezxbEAI4BGiaBlVVRSxbEPbBGJZlieEvtw1hDEVRviC8fITacsKP0+m0gDCO7VJb22ifnfD9
- A5gpQ9n5eKQcAAAAAElFTkSuQmCC
+ YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAXlJREFUOE+tkr9L
+ AmEYxw+agv6AxjYXl4Y2qSYHo2ioIQjabHPohgzEpYZrEW4SooMII0w7qCUhIuFaKggqCKOuOkNO8yUz
+ 8ECL+9bzqmE/II/6wgPvy/M+n/f5Pu8r/LuuQ114PlsGrS1jC8XUJFhqFOUjkQc/9FWRSASSJOHicAMP
+ yV6UDwZQ2u/HXdSFQtKLGpuCdelDIeHG457vMygWW4Npmshvz+B+yYXa7Qjsmz5Y517o4Q4U4j14yY+h
+ mh2HqXRyWHGzG1Z2tQ6RZRmWVUHlage5lWF+82tuiBfk44OoMo1DStp0Pd7z36wQhDGGTOYURtTNW99d
+ 8MBITPCDT8fhn723qjmHk0UP0uvzCM4FEQrN/l7YKkVRIIoiqCOaDQH9fr8zCCkQCPBiglBnf4ZQR7Sn
+ dSPdnqiIZkGFrfYa6fZEAAoCGIYBXde5rUa6PZEVutm2bR705I4hZEPTtA8IfT7HdkiqqnIA2XE81Kao
+ fZqJIAjCG5gpQ9lWxR6HAAAAAElFTkSuQmCC
</value>
</data>
<data name="AutoGenerateWMSBounds.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
@@ -904,14 +940,14 @@
<data name="AutoGenerateWFSBounds.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="AutoGenerateWFSBounds.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
@@ -1551,10 +1587,10 @@
<value>Fill</value>
</data>
<data name="OutReferenceList.Location" type="System.Drawing.Point, System.Drawing">
- <value>3, 16</value>
+ <value>3, 41</value>
</data>
<data name="OutReferenceList.Size" type="System.Drawing.Size, System.Drawing">
- <value>334, 156</value>
+ <value>484, 131</value>
</data>
<data name="OutReferenceList.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -1571,6 +1607,45 @@
<data name=">>OutReferenceList.ZOrder" xml:space="preserve">
<value>0</value>
</data>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>843, 17</value>
+ </metadata>
+ <data name="btnReferencesOpenSelected.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnReferencesOpenSelected.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <value>Magenta</value>
+ </data>
+ <data name="btnReferencesOpenSelected.Size" type="System.Drawing.Size, System.Drawing">
+ <value>103, 22</value>
+ </data>
+ <data name="btnReferencesOpenSelected.Text" xml:space="preserve">
+ <value>Open Selected</value>
+ </data>
+ <data name="toolStrip1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 16</value>
+ </data>
+ <data name="toolStrip1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>484, 25</value>
+ </data>
+ <data name="toolStrip1.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="toolStrip1.Text" xml:space="preserve">
+ <value>toolStrip1</value>
+ </data>
+ <data name=">>toolStrip1.Name" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>toolStrip1.Parent" xml:space="preserve">
+ <value>OutReferences</value>
+ </data>
+ <data name=">>toolStrip1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
<data name="OutReferences.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
@@ -1581,7 +1656,7 @@
<value>0, 0</value>
</data>
<data name="OutReferences.Size" type="System.Drawing.Size, System.Drawing">
- <value>340, 175</value>
+ <value>490, 175</value>
</data>
<data name="OutReferences.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -1623,7 +1698,7 @@
<value>Copy Resource ID</value>
</data>
<data name="ctxReferenced.Size" type="System.Drawing.Size, System.Drawing">
- <value>168, 48</value>
+ <value>168, 26</value>
</data>
<data name=">>ctxReferenced.Name" xml:space="preserve">
<value>ctxReferenced</value>
@@ -1635,10 +1710,10 @@
<value>Fill</value>
</data>
<data name="InReferenceList.Location" type="System.Drawing.Point, System.Drawing">
</data>
<data name="InReferenceList.Size" type="System.Drawing.Size, System.Drawing">
- <value>334, 157</value>
+ <value>484, 132</value>
</data>
<data name="InReferenceList.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -1655,6 +1730,45 @@
<data name=">>InReferenceList.ZOrder" xml:space="preserve">
<value>0</value>
</data>
+ <metadata name="toolStrip2.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 56</value>
+ </metadata>
+ <data name="btnReferencedByOpenSelected.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="btnReferencedByOpenSelected.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnReferencedByOpenSelected.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnReferencedByOpenSelected.Text" xml:space="preserve">
+ </data>
+ <data name="toolStrip2.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="toolStrip2.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="toolStrip2.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="toolStrip2.Text" xml:space="preserve">
+ <value>toolStrip2</value>
+ </data>
+ <data name=">>toolStrip2.Name" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip2.Type" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip2.Parent" xml:space="preserve">
+ <value>InReferences</value>
+ </data>
+ <data name=">>toolStrip2.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
<data name="InReferences.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
@@ -1665,7 +1779,7 @@
<value>0, 0</value>
</data>
<data name="InReferences.Size" type="System.Drawing.Size, System.Drawing">
- <value>340, 176</value>
+ <value>490, 176</value>
</data>
<data name="InReferences.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -1698,7 +1812,7 @@
<value>1</value>
</data>
<data name="splitContainer1.Size" type="System.Drawing.Size, System.Drawing">
- <value>340, 355</value>
+ <value>490, 355</value>
</data>
<data name="splitContainer1.SplitterDistance" type="System.Int32, mscorlib">
<value>175</value>
@@ -1725,7 +1839,7 @@
</data>
<data name="ReferenceTab.Size" type="System.Drawing.Size, System.Drawing">
</data>
<data name="ReferenceTab.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
@@ -1752,7 +1866,7 @@
<value>0, 32</value>
</data>
<data name="tabControl1.Size" type="System.Drawing.Size, System.Drawing">
- <value>354, 387</value>
+ <value>504, 387</value>
</data>
<data name="tabControl1.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
@@ -1776,7 +1890,7 @@
<value>88, 6</value>
</data>
<data name="ResourceID.Size" type="System.Drawing.Size, System.Drawing">
- <value>260, 20</value>
+ <value>410, 20</value>
</data>
<data name="ResourceID.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -1830,7 +1944,7 @@
<value>0, 0</value>
</data>
<data name="panel2.Size" type="System.Drawing.Size, System.Drawing">
- <value>354, 32</value>
+ <value>504, 32</value>
</data>
<data name="panel2.TabIndex" type="System.Int32, mscorlib">
<value>5</value>
@@ -1854,7 +1968,7 @@
<value>NoControl</value>
</data>
<data name="CancelBtn.Location" type="System.Drawing.Point, System.Drawing">
- <value>261, 8</value>
+ <value>411, 8</value>
</data>
<data name="CancelBtn.Size" type="System.Drawing.Size, System.Drawing">
<value>75, 23</value>
@@ -1884,7 +1998,7 @@
</data>
<data name="OKBtn.Location" type="System.Drawing.Point, System.Drawing">
- <value>180, 8</value>
+ <value>330, 8</value>
</data>
<data name="OKBtn.Size" type="System.Drawing.Size, System.Drawing">
@@ -1914,7 +2028,7 @@
<value>0, 419</value>
</data>
<data name="panel1.Size" type="System.Drawing.Size, System.Drawing">
- <value>354, 40</value>
+ <value>504, 40</value>
</data>
<data name="panel1.TabIndex" type="System.Int32, mscorlib">
<value>3</value>
@@ -1941,223 +2055,186 @@
<value>
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj00LjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAACG
- KQAAAk1TRnQBSQFMAgEBCAEAAUwBAAFMAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
- AwABMAMAAQEBAAEgBgABMP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8AQgADVAGrAUoBTQFi
- AflgAAEeAWwBEAH+AV0BpQFcAf8BagGvAWkB/wFmAawBZgH/AWEBqAFhAf8BXQGlAV0B/wFbAaMBWgH/
- AV4BpgFeAf8BYAGnAV8B/wFiAakBYgH/ATwBgQE8Af8BBQE6AQUB/wM1AVcUAANEAXkBLwGFAS8B/wFJ
- AZcBSAH/AUYBlQFFAf8BQQGRAUEB/wE7AY0BOwH/AToBjAE6Af8BPwGPAT4B/wE9AYsBPQH/AQUBMwEF
- Af8BGAGBARgB/wMtAUYUAAMFAQcDBgEIAwQBBQFeAlYB1QFNAZQBsgH+AUoBTQFjAfkDBAEFAwABASAA
- AwUBBwMGAQgDBAEFAwIBAwMCAQMDHQEpASsBIQFPAfsBKwEhAWkB+wErASEBWwH7Az0BaQgAAz0BaQGB
- AdUBgQH/ATYBvQE0Af8BNgG9ATQB/wE2Ab0BNAH/ATYBvQE0Af8BPAG+AToB/wFZAcgBWAH/ATYBvQE0
- Af8BNgG9ATQB/wE2Ab0BNAH/AVEBeAEnAf8BkwEFARYB/wEVAYEBFQH/FAABTQGaAU0B/wE2Ab0BNAH/
- ATYBvQE0Af8BNgG9ATQB/wE2Ab0BNAH/AUwBxAFKAf8BRwHCAUUB/wE2Ab0BNAH/ATQBtwEyAf8BlAEF
- ARcB/wE2Ab0BNAH/AS8BhgEvAf8MAAMLAQ8BegF/AWYB/gF/AZQBdgH+AX8BlAF2Af4BfwGUAXcB/gF/
- AZIBdwH+AUYBfwGbAf4BkgHMAeoB/wGrAaUBpgH/AakBqgGjAf8BsQGwAasB/wGfAooB/gMEAQYMAAML
- AQ8BegF/AWYB/gF/AZQBdgH+AX8BlAF2Af4BfwGUAXcB/gF/AZIBdwH+AX8BiAF0Af4CCgHnAf8BDAEO
- AbQB/wFDAUwBQQH+AS0BIAFqAf4BJgETAaMB/gNAAXAEAANQAZ4BYQHKAWAB/wE2Ab0BNAH/ATYBvQE0
- Af8BNgG9ATQB/wE2Ab0BNAH/AUsBmAFKAf8BKwGBASkB/wF1AdEBcwH/ATYBvQE0Af8BNgG9ATQB/wE1
- AbwBMwH/ASoBkAEoAf8BSQGXAUgB/xQAAW4BswFtAf8BNgG9ATQB/wE2Ab0BNAH/ATYBvQE0Af8BPQG/
- ATsB/wEZAYEBFwH/ARgBgQEXAf8BOgG+ATgB/wE2Ab0BNAH/ASEBcwEgAf8BNgG9ATQB/wFcAaUBWwH/
- DAADQgF2AVMBiQFBAf4BSwGEAUEB/gFLAYQBQQH+AUsBhAFBAf4BeAF/AWQB/gF/AZABeAH+AaUBogGg
- Af8BxQHcAasB/wHKAdsBmQH/AdwB2wGdAf8BWAJWAcEBpwKWAf4MAANCAXYBUwGJAUEB/gFLAYQBQQH+
- AUsBhAFBAf4BSwGEAUEB/gF4AX8BZAH+ATUBKAFiAf4BCgEMAeAB/wEMAREBgAH/AT8BWAEvAf4BfwGS
- AXcB/gFcAkcB6gErARwBbAH8BAADUQGiAV8ByQFeAf8BNQG8ATQB/wE1AbwBNAH/ATUBvAE0Af8BbgHO
- AW0B/wFlAaABYQL/AvcB/wFTAZ4BUgH/ATUBvAE0Af8BNQG8ATQB/wEpAY0BKAH/AY0BBQEWAf8BJQFJ
- AR8B/wgAAxQBHAM/AW0BQAI/AW8BcwG2AXIB/wE1AbsBNAH/ATUBuwE0Af8BNQG7ATQB/wGGAdABhQH/
- AecB6gHgAf8B1AHhAc4B/wGEAdMBgwH/ATUBuwE0Af8BlAEFARcB/wEqATYBFAH/AWMBqQFiAf8MAAFI
- AkcBgwFQAYcBQQH+AUsBhAFBAf4BSwGEAUEB/gFxAZABXQH+AYoBkAF/Af4BUAF/AUEB/gGnAqIB/wHJ
- AdsBmQH/AckB1wGLAf8B2wHWAYYB/wFdAlcBygFoAUEBOwH2DAABSAJHAYMBUAGHAUEB/gFLAYQBQQH+
- AUsBhAFBAf4BcQGQAV0B/gGKAZABfwH+AQoBDAGTAf8BCwEOAZQB/wFLAYQBQQH+AQsBDgGjAf8BcgF/
- AV4B/gNMAZMBJgETAaMB/gQAA0wBkwFmAckBZQH/ATQBuAEzAf8BNAG4ATMB/wE0AbgBMwH/AYEBuQGA
- Af8B/AH1AfQB/wH+AvYB/wE8AYsBOAH/AU0BwQFMAf8BNAG4ATMB/wE0AbgBMwH/AT8BowEvAf8BlAEF
- ARcB/wMsAUQDEgEYAegBuAGCAf8B5AGfAUwB/wHMAY4BRAH/AW0BrwFrAf8BMwG2ATIB/wEzAbYBMgH/
- ATMBtgEyAf8BRQGTAUIB/wH8AfUB9AH/AfwB9QH0Af8BUQGbAU8B/wEzAbYBMgH/ATUBsgEyAf8BkQEJ
- ARcB/wEeATIBEQH/AwwBEAGiAX8BaAH+Aa4BfwFzAf4CfwFBAf4BUgGEAUEB/gFKAX8BQAH+AUoBfwFA
- Af4BegF/AWUB/gHFAa4BrQH+AbUBqAGiAf4BsQKsAf8ByQHWAYsB/wHJAdABgQH/AeEB1wGEAf8BZQJO
- AeUBgwJHAfkDDAEQAaIBfwFoAf4BrgF/AXMB/gJ/AUEB/gFSAYQBQQH+AUoBfwFAAf4BSgF/AUAB/gF6
- AX8BZQH+AcUBrgGtAf4BSgE+AWkB/gIKAecB/wFKAX8BQAH+AUoBfwFAAf4BDAEOAccB/wFZATkBPAHy
- ASsBHAFiAfwEAAMyAVABiAHTAYcB/wEyAbMBMQH/ATIBswExAf8BNgG0ATUB/wEuAYEBKgH/Ad8C2AH/
- AdkC0gH/AcABzQG5Af8BjgHQAY0B/wFtAQUBEQH/AUEBmAEtAf8BMwGzATMB/wGUAQUBFwH/ATUCNAFV
- AzsBZAHlAaABTgH/AeMBmAE+Af8B1QGPAToB/wE4AYoBMwH/ATUBsQE1Af8BMQGwATAB/wFHAbYBRgH/
- AV4BigFZAf8BgQGaAcAB/wGBAZsBwAH/ATYBBgELAf8BZwFYASMB/wExAbABMAH/AYIBIgEbAf8BVgEz
- ASwB9QNBAXIBrgF/AUEB/gGuAX8BQQH+AX8BewE/Af4BfwGOAXAB/gFJAX8BPgH+AUoBfwE/Af4BUgF/
- AUEB/gGAAX8BhgH+AZEBfwGHAf4BpQGoAaEB/wG+Ac0BngH/AdEB0AGBAf8B7QHgAacB/wFgAlYB1gFq
- AjsB9QNBAXIBrgF/AUEB/gGuAX8BQQH+AX8BewE/Af4BfwGOAXAB/gFJAX8BPgH+AUoBfwE/Af4BUgF/
- AUEB/gGAAX8BhgH+AY0BfwGDAf4CCgHZAf8BCgEMAdwB/wEtASgBVwH+AQ4BEAGnAf8BJgETAaMB/gMr
- AUIIAAFKAZUBRQH/AUkBtgFIAf8BMAGsATAB/wFqAbQBagH/AR8BcgGYAf8BCgFwAdUB/wEkAYEB2QH/
- AQwBbwHSAf8BQgGBAVMB/wEgASQBDwH/AYMBBQEUAf8BlAEFARcB/wFYAjwB7wQAAT0CPAFnAeMBngFM
- Af8B4QGWAT0B/wHgAZUBPQH/Aa4BjQFlAf8BUgGaAU0B/wGBAckBgQH/AUMBigGfAf8BgAGuAeoB/wGp
- AdYB/gH/AaoB1wH+Af8BVQFXAV4B/wF4AQUBEwH/AZQBBQEXAf8BXQEFAQ8B/wMFAQcDRAF5Aa4BfwFB
- Af4BrgF/AUEB/gGlAX8BQQH+AVUBdQE8Af4BfwGJAXoB/gFdAX8BcgH+AXEBfwGhAf4BhQGXAbIB/gGJ
- AZgBsgH+AUQBfAGYAf4BkAJ/Af4B0QHOAc0B/wGbAYUBhAH+AWQCRgHsBAADRAF5Aa4BfwFBAf4BrgF/
- AUEB/gGlAX8BQQH+AVUBdQE8Af4BfwGJAXoB/gFdAX8BcgH+AXEBfwGhAf4BhQGXAbIB/gGJAZgBsgH+
- AUUBegGWAf4BNgEpAVsB/gELAQwBpgH/AVEBJQE8AfgDHQEqDAADBwEKAUkBQQEzAfYBbAGnAWkB/wEH
- AW4B0gH/AbgB3QH9Af8BjQHKAv8BjAHJAv8BlgHOAf4B/wFpAaUB5wH/AVsBlQGMAf8BRgGSAUAB/wNI
- AYQIAAMvAUkB4AGdAVYB/wHcAY0BOwH/AdwBjQE7Af8BrwFmAUYB/wHXAtEB/wGNAZgBngH/AZsByAHz
- Af8BigHIAv8BiQHIAv8BiQHIAv8BiAHHAv8BigG8Ae8B/wMkATYIAAM1AVYBqgF/AUEB/gGpAX8BQQH+
- Aa4BfwFhAf4BrwGXAZUB/gGRAn8B/gF9AX8BpAH+AX8BjQGzAf4BfwGNAbMB/gF/AY0BswH+AX8BjQGz
- Af4BRwFBAU4B+RAAAzUBVgGqAX8BQQH+AakBfwFBAf4BrgF/AWEB/gGvAZcBlQH+AZECfwH+AX0BfwGk
- Af4BfwGNAbMB/gF/AY0BswH+AX8BjQGzAf4BfwGNAbMB/gFHAUEBTgH5IAABUwJSAagBtgHcAf0B/wGI
- AccC/wGIAccC/wGIAccC/wGHAccC/wGJAccB/gH/ATABgwHeAf8DBAEFEAAB1AGgAYEB/wHUAYIBOQH/
- AdEBhwFHAf8BZwFwAYcB/wEYAXEBywH/AQ0BcgHXAf8BhwHGAf4B/wGDAcQC/wGDAcMC/wGCAcMC/wGB
- AcMC/wGHAcUB/gH/AVsCVQHZDAABogF/AXMB/gGlAX8BQQH+AX8BfAF+Af4BUAF/AZwB/gFGAXMBiwH+
- AX8BjgGzAf4BfwGKAbMB/gF/AYoBswH+AX8BiQGzAf4BfwGJAbMB/gF/AZIBsAH+AwMBBBAAAaIBfwFz
- Af4BpQF/AUEB/gF/AXwBfgH+AVABfwGcAf4BRgFzAYsB/gF/AY4BswH+AX8BigGzAf4BfwGKAbMB/gF/
- AYkBswH+AX8BiQGzAf4BfwGSAbAB/gMDAQQcAAEhAYEB4QH/AYMBxAL/AYMBwwL/AYIBwwL/AYEBwwL/
- AYEBwgL/AYEBwgL/AbMB2gH9Af8DOgFiEAADGwEmAbEBawFKAf8BIwF1AcgB/wGlAdUB/gH/AYMBvQHw
- Af8BNgGMAeoB/wGBAcAC/wGBAb8C/wGBAb8C/wGBAb8C/wGBAb4C/wGBAb4C/wEhAYEB6AH/DAADAQEC
- AVkCVwG/AX8BkwGwAf4BfwGNAbIB/gFHAX8BmQH+AX8BhwGzAf4BfwGFAbMB/gF/AYUBswH+AX8BhAGz
- Af4BfwGEAbMB/gF/AZEBsgH+AxoBJBAAAwEBAgFZAlcBvwF/AZMBsAH+AX8BjQGyAf4BRwF/AZkB/gF/
- AYcBswH+AX8BhQGzAf4BfwGFAbMB/gF/AYQBswH+AX8BhAGzAf4BfwGRAbIB/gMaASQcAAFuAawB8QH/
- AYEBwAL/AYEBvwL/AYEBvwL/AYEBvwL/AYEBvgL/AYEBvgL/AY4ByQH+Af8BVgJVAbQUAAMYASIBqwHW
- AfwB/wGGAcYC/wGBAbkB8AH/ASkBiAHxAf8BgAG7Av8BeAG7Av8BdwG6Av8BdwG6Av8BdgG6Av8BdQG5
- Av8BGAGBAfAB/xAAAWQCSgHnAX8BigGzAf4BfwGKAbMB/gFWAX8BmAH+AX8BigGzAf4BfwGAAbMB/gF/
- AYABswH+An8BswH+An8BswH+AX8BjwGxAf4DAAEBFAABZAJKAecBfwGKAbMB/gF/AYoBswH+AVYBfwGY
- Af4BfwGKAbMB/gF/AYABswH+AX8BgAGzAf4CfwGzAf4CfwGzAf4BfwGPAbEB/gMAAQEcAAFkAakB9AH/
- AYEBvAL/AYABuwL/AXgBuwL/AXgBuwL/AXcBugL/AXYBugL/AY0BxwH+Af8BUgJQAaMUAANOAZkBgQHC
- Af4B/wGBAcAC/wGBAbwB+QH/AS0BhgHmAf8BgQHBAf4B/wFwAbcC/wFwAbYC/wFvAbYC/wFuAbYC/wGG
- AcQB/gH/A04BmBAAAVoBfwGpAf4BfwGFAbMB/gF/AYUBswH+AXoBfwGeAf4BcQF/AbIB/gF6AX8BswH+
- AXkBfwGzAf4BeQF/AbMB/gF9AX8BswH+AWQBQAFDAfEYAAFaAX8BqQH+AX8BhQGzAf4BfwGFAbMB/gF6
- AX8BngH+AXEBfwGyAf4BegF/AbMB/gF5AX8BswH+AXkBfwGzAf4BfQF/AbMB/gFkAUABQwHxIAABGAGD
- AfYB/wF3AboB/gH/AXIBtwL/AXEBtwL/AXEBtwL/AXABtgL/AXABtgL/AaQB0QH8Af8DIAEvFAABTgJN
- AZUBgQG9Af4B/wGAAbsC/wF4AboB/gH/AWYBngHZAf8BQQGbAf4B/wFyAbcB/gH/AWkBswL/AWkBswL/
- AXQBuAH+Af8BNQGVAf4B/xQAAVwCWAHJAn8BswH+An8BswH+AX0BfwGyAf4BYQF/AZUB/gFdAX8BsgH+
- AX8BjwGyAf4BfwGOAbIB/gFJATUBSAH2HAABXAJYAckCfwGzAf4CfwGzAf4BfQF/AbIB/gFhAX8BlQH+
- AV0BfwGyAf4BfwGPAbIB/gF/AY4BsgH+AUkBNQFIAfYkAAMvAUkBmgHMAf0B/wFsAbQC/wFrAbQC/wFr
- AbQC/wFqAbMC/wGBAb0B/gH/ATIBfwHBAf4YAAMQARUBnAHOAf0B/wFwAbYC/wFvAbYC/wFtAbQB/AH/
- AVoBlgHUAf8BGgGGAfwB/wFzAbUB/gH/AXEBtAH+Af8BXAFEAUgB7hgAAwIBAwF/AYIBsgH+AXcBfwGz
- Af4BdgF/AbMB/gF/AYwBsgH+AzQBVAMEAQYDAAEBIAADAgEDAX8BggGyAf4BdwF/AbMB/gF2AX8BswH+
- AX8BjAGyAf4DNAFUAwQBBgMAAQEsAAFSAlEBpwGBAb0B/QH/AYIBwQH+Af8BgQG7Af4B/wGlAdIB/QH/
- ASIBjAH+Af8DAgEDHAABXAJYAckBjwHHAf4B/wFoAbIC/wFsAbQB/gH/AYABuAH9Af8DDQERKAADAQEC
- AVMCUgGoAVsCWAHEAxkBIzAAAwEBAgFTAlIBqAFbAlgBxAMZASM8AAMKAQ4BUQJPAaUBWQJWAccDOgFi
- KAADKwFCAVsCWAHIAVECUAGfAwABAUAAAyEBMDwAA1QBqwFKAU0BYgH5eAADIQEwJAADFgEfAT4CPQFq
- AUACPwFvAzwBZgE6AjkBYAM3AVoDPQFpAXwBmQGiAf4BXAJXAdEDMwFSAwEBAhQAAxYBHwE+Aj0BagFA
- Aj8BbwM8AWYBOgI5AWADNwFaAVgBPgFQAfgBTQGUAbIB/gFNAVQBagH6AzMBUgMBAQIUAAMWAR8BPgI9
- AWoBQAI/AW8DPAFmAToCOQFgAzcBWgE6AjkBYAM7AWMBPQI8AWcBKwEhAU8B+wErASEBaQH7ASsBIQFb
- AfsDPQFpGAADBQEHAwYBCAMEAQUDCAELAXwBmQGiAf4BXAJXAdEDBAEFAwABARAAAToCOQFgAX8BkwF/
- Af4BbwGPAVoB/gFtAY4BWAH+AXEBkAFcAf4BdAGQAWAB/gF3AZEBYwH+AXQBkAFgAf4BKQGwAfMB/wEi
- AaEB5wH/ATcBoQHkAf8BbgF/AVoB/gMEAQUMAAE6AjkBYAF/AZMBfwH+AW8BjwFaAf4BbQGOAVgB/gFx
- AZABXAH+AXQBkAFgAf4BdwGRAWMB/gF0AZABYAH+AUQBfwGZAf4BkgHMAeoB/wGrAaUBpgH/AawBqgGm
- Af8BawI8AfMBnwKKAf4DBAEGBAABOgI5AWABfwGTAX8B/gFvAY8BWgH+AW0BjgFYAf4BcQGQAVwB/gF0
- AZABYAH+AXcBkQFjAf4BdAGQAWAB/gFwAYUBWwH+AgoB5wH/AQsBDgGzAf8BTAFNAUEB/gFYATwBPwHv
- ASYBEwGjAf4DQAFwDAADCwEPAXoBfwFmAf4BfwGUAXYB/gF/AZQBdgH+AX8BlAF3Af4BfwGSAXcB/gEq
- AbAB8wH/ASIBoQHnAf8BSgF/AaEB/gF/AZEBdwH+AUQBfwE0Af4MAAFdAlYB0gFPAYYBQQH+AUsBhAFB
- Af4BSwGEAUEB/gFLAYQBQQH+AXcBkQFiAf4BUwF/AUEB/gFTAYkBQQH+AUsBhAFBAf4BLQHAAe8B/wEi
- AaEB5wH/AUgBfwGfAf4DOwFkDAABXQJWAdIBTwGGAUEB/gFLAYQBQQH+AUsBhAFBAf4BSwGEAUEB/gF3
- AZEBYgH+AVMBfwFBAf4BUwGJAUEB/gFLAYQBQQH+AaUBogGgAf8BxQHcAasB/wHVAd4BpQH/AV4CVQHY
- AVoCVwHAAacClgH+BAABXQJWAdIBTwGGAUEB/gFLAYQBQQH+AUsBhAFBAf4BSwGEAUEB/gF3AZEBYgH+
- AVMBfwFBAf4BUwGJAUEB/gEsASYBWAH+AQoBDAHgAf8BKAEaAW8B/gFSAWQBQQH+AzsBZAFfAkkB6AEr
- ARwBbAH8DAADQgF2AVMBiQFBAf4BSwGEAUEB/gFLAYQBQQH+AUsBhAFBAf4BeAF/AWQB/gF/AZABeAH+
- AS0BwAHvAf8BIgGhAecB/wE/AX8BkwH+AX8BkgF3Af4DAQECCAABXQJQAeIBTQGFAUEB/gFLAYQBQQH+
- AUsBhAFBAf4BSwGEAUEB/gFLAX8BQQH+AcQBrgGsAf4BfgF/AWkB/gFLAYQBQQH+AUsBhAFBAf4BLQHA
- AfAB/wEiAaEB5wH/AWECVQHcDAABXQJQAeIBTQGFAUEB/gFLAYQBQQH+AUsBhAFBAf4BSwGEAUEB/gFL
- AX8BQQH+AcQBrgGsAf4BfgF/AWkB/gFLAYQBQQH+AacCogH/AckB2wGZAf8B0wHaAZQB/wFhAlUB3AFc
- AlgByQFoAUEBOwH2BAABXQJQAeIBTQGFAUEB/gFLAYQBQQH+AUsBhAFBAf4BSwGEAUEB/gFLAX8BQQH+
- AcQBrgGsAf4BfgF/AWkB/gEKAQ0BkwH/AQsBDgGUAf8BSwGEAUEB/gELAQ4BowH/A0gBhgNKAYsBJgET
- AaMB/gwAAUgCRwGDAVABhwFBAf4BSwGEAUEB/gFLAYQBQQH+AXEBkAFdAf4BigGQAX8B/gFQAX8BQQH+
- AU0BhQFBAf4BLQHAAfAB/wEiAaEB5wH/An8BigH+AwYBCAgAAVsCVQHZAU0BggFBAf4BSwGBAUEB/gFL
- AYEBQQH+AWcBjAFUAf4CfwF5Af4BxQKuAf4BSgF/AT0B/gFOAYMBQQH+AUsBgQFBAf4BSwGBAUEB/gGW
- AcgB2AH/AY0CfwH+AWEBVQFXAdoIAAFbAlUB2QFNAYIBQQH+AUsBgQFBAf4BSwGBAUEB/gFnAYwBVAH+
- An8BeQH+AcUCrgH+AUoBfwE9Af4BTgGDAUEB/gGxAqwB/wHJAdYBiwH/AtQBgQH/AWECUAHiAWUCTgHl
- AYMCRwH5BAABWwJVAdkBTQGCAUEB/gFLAYEBQQH+AUsBgQFBAf4BZwGMAVQB/gJ/AXkB/gHFAq4B/gFK
- AX8BPQH+ATUBNgFMAf4CCgHnAf8BSgF/AUAB/gFpAYkBVQH+ATwBHQGcAf0BWQE5ATwB8gErARwBYgH8
- AwwBEAGiAX8BaAH+Aa4BfwFzAf4CfwFBAf4BUgGEAUEB/gFKAX8BQAH+AUoBfwFAAf4BegF/AWUB/gHF
- Aa4BrQH+AbUBqAGiAf4BfwGRAXcB/gFKAX8BQAH+AZYByAHXAf8BsgKwAf8BYQFVAVcB2ggAA1EBoAFW
- AYMBQgH+AUoBfwE/Af4BSgF/AT8B/gF/AYoBfQH+AbIBoAGfAf4BrQKZAf4BlwGQAX8B/gF/AZIBewH+
- AUoBfwE/Af4BSgF/AT8B/gF/AZIBeQH+An8BjAH+AVEBQQGMAf4BUQJQAZ8EAANRAaABVgGDAUIB/gFK
- AX8BPwH+AUoBfwE/Af4BfwGKAX0B/gGyAaABnwH+Aa0CmQH+AZcBkAF/Af4BfwGSAXsB/gGBAn8B/gG+
- Ac4BnwH/AeEB1gGDAf8BYQFOAU0B5gFgAlYB1gFqAjsB9QQAA1EBoAFWAYMBQgH+AUoBfwE/Af4BSgF/
- AT8B/gF/AYoBfQH+AbIBoAGfAf4BrQKZAf4BlwGQAX8B/gF/AZABewH+AQoBCwHZAf8BCgEMAdwB/wE2
- ASwBYAH+AVIBKgE+AfcBJgETAaMB/gMrAUIDQQFyAa4BfwFBAf4BrgF/AUEB/gF/AXsBPwH+AX8BjgFw
- Af4BSQF/AT4B/gFKAX8BPwH+AVIBfwFBAf4BgAF/AYYB/gGRAX8BhwH+AWgBfwFSAf4BSQF/AT4B/gFJ
- AX8BPgH+AZEBjgHHAf8BUQFBAYwB/gFRAlABnwQAAwcBCQJ/AXIB/gFLAX8BQQH+AUgBfwE9Af4BRQFu
- AVkB/gEtAWwBlgH+AU4BfwGcAf4BLAFqAZQB/gFjAX8BYQH+AUkBfwE9Af4BUgF/AUEB/gFdAX8BRQH+
- BAABXwJUAdsDAAEBBAADBwEJAn8BcgH+AUsBfwFBAf4BSAF/AT0B/gFFAW4BWQH+AS0BbAGWAf4BTgF/
- AZwB/gEsAWoBlAH+AWMBfwFhAf4BSQF/AT0B/gGKAYEBfwH+AdEBzgHNAf8BmwGFAYQB/gFkAkYB7AgA
- AwcBCQJ/AXIB/gFLAX8BQQH+AUgBfwE9Af4BRQFuAVkB/gEtAWwBlgH+AU4BfwGcAf4BLAFqAZQB/gFj
- AX8BYQH+AUgBfwE9Af4BMAEqAVQB/gEKAQwBpQH/AVIBKgE4AfcDHQEqBAADRAF5Aa4BfwFBAf4BrgF/
- AUQBfAGYAf4BawF/AVkB/gJ/AXEB/gM7AWQBXwJUAdsDAAEBCAADEgEYAV0BPgE9AfABTAJ/Af4BhAGU
- Aa4B/gF/AY4BswH+AX8BjgGzAf4BfwGPAbMB/gJ/AaYB/gFZAX8BZwH+AVoCVgHTAwABARQAAxIBGAFd
- AT4BPQHwAUwCfwH+AYQBlAGuAf4BfwGOAbMB/gF/AY4BswH+AX8BjwGzAf4CfwGmAf4BWQF/AWcB/gFa
- AlYB0wMAAQEUAAMSARgBXQE+AT0B8AFMAn8B/gGEAZQBrgH+AX8BjgGzAf4BfwGOAbMB/gF/AY8BswH+
- An8BpgH+AVkBfwFnAf4BWgJWAdMDAAEBDAADNQFWAaoBfwFBAf4BqQF/AUEB/gGuAX8BYQH+Aa8BlwGV
- Af4BkQJ/Af4BfQF/AaQB/gF/AY0BswH+AX8BjQGzAf4BfwGNAbMB/gF/AY0BswH+AUcBQQFOAfkcAAMD
- AQQBcwGpAeoB/wF/AYwBswH+AYcBxgL/AX8BjAGzAf4BfwGMAbMB/gF/AYwBswH+AUIBfAGcAf4gAAMD
- AQQBcwGpAeoB/wF/AYwBswH+AYcBxgL/AX8BjAGzAf4BfwGMAbMB/gF/AYwBswH+AUIBfAGcAf4YAAGi
- AX8BcwH+AaUBfwFBAf4BfwF8AX4B/gFQAX8BnAH+AUYBcwGLAf4BfwGOAbMB/gF/AYoBswH+AX8BigGz
- Af4BfwGJAbMB/gF/AYkBswH+AX8BkgGwAf4DAwEEGAADNgFZAX8BlAGzAf4BfwGKAbMB/gF/AYkBswH+
- AX8BiQGzAf4BfwGIAbMB/gF/AYgBswH+AX8BkAGvAf4DBAEFHAADNgFZAX8BlAGzAf4BfwGKAbMB/gF/
- AYkBswH+AX8BiQGzAf4BfwGIAbMB/gF/AYgBswH+AX8BkAGvAf4DBAEFHAADNgFZAX8BlAGzAf4BfwGK
- AbMB/gF/AYkBswH+AX8BiQGzAf4BfwGIAbMB/gF/AYgBswH+AX8BkAGvAf4DBAEFFAADAQECAVkCVwG/
- AX8BkwGwAf4BfwGNAbIB/gFHAX8BmQH+AX8BhwGzAf4BfwGFAbMB/gF/AYUBswH+AX8BhAGzAf4BfwGE
- AbMB/gF/AZEBsgH+AxoBJBgAAUcCRgGBAY4ByAH+Af8BfwGFAbMB/gGBAb0C/wF/AYUBswH+AX8BhAGz
- Af4BfwGEAbMB/gGGAZYBsgH+AxQBHBwAAUcCRgGBAY4ByAH+Af8BfwGFAbMB/gGBAb0C/wF/AYUBswH+
- AX8BhAGzAf4BfwGEAbMB/gGGAZYBsgH+AxQBHBwAAUcCRgGBAY4ByAH+Af8BfwGFAbMB/gGBAb0C/wF/
- AYUBswH+AX8BhAGzAf4BfwGEAbMB/gGGAZYBsgH+AxQBHBgAAWQCSgHnAX8BigGzAf4BfwGKAbMB/gFW
- AX8BmAH+AX8BigGzAf4BfwGAAbMB/gF/AYABswH+An8BswH+An8BswH+AX8BjwGxAf4DAAEBGAADJgE5
- AX8BlAGyAf4BfwGBAbMB/gF/AYABswH+AX8BgAGzAf4BfwGAAbMB/gJ/AbMB/gF/AYkBsAH+IAADJgE5
- AX8BlAGyAf4BfwGBAbMB/gF/AYABswH+AX8BgAGzAf4BfwGAAbMB/gJ/AbMB/gF/AYkBsAH+HAABWgF/
- AakB/gF/AYUBswH+AX8BhQGzAf4BegF/AZ4B/gFxAX8BsgH+AXoBfwGzAf4BeQF/AbMB/gF5AX8BswH+
- AX0BfwGzAf4BZAFAAUMB8SAAAUUBmgH7Af8BfAF/AbMB/gFyAbUC/wF6AX8BswH+AXoBfwGzAf4BfwGB
- AbMB/gFJATQBSAH2JAABRQGaAfsB/wF8AX8BswH+AXIBtQL/AXoBfwGzAf4BegF/AbMB/gF/AYEBswH+
- AUkBNAFIAfYkAAFFAZoB+wH/AXwBfwGzAf4BcgG1Av8BegF/AbMB/gF6AX8BswH+AX8BgQGzAf4BSQE0
- AUgB9hwAAVwCWAHJAn8BswH+An8BswH+AX0BfwGyAf4BYQF/AZUB/gFdAX8BsgH+AX8BjwGyAf4BfwGO
- AbIB/gFJATUBSAH2JAADGQEjAWwBfwGzAf4BfwGFAbMB/gF6AX8BswH+AX8BiwGzAf4BSwF/AbMB/gMA
- AQEkAAMZASMBbAF/AbMB/gF/AYUBswH+AXoBfwGzAf4BfwGLAbMB/gFLAX8BswH+AwABASQAAxkBIwFs
- AX8BswH+AX8BhQGzAf4BegF/AbMB/gF/AYsBswH+AUsBfwGzAf4DAAEBHAADAgEDAX8BggGyAf4BdwF/
- AbMB/gF2AX8BswH+AX8BjAGyAf4DNAFUAwQBBgMAAQEwAANMAZMBXAJYAc8DQgF2NAADTAGTAVwCWAHP
- A0IBdjQAA0wBkwFcAlgBzwNCAXYoAAMBAQIBUwJSAagBWwJYAcQDGQEjJAABQgFNAT4HAAE+AwABKAMA
- AUADAAEwAwABAQEAAQEFAAGAAQEWAAP/gQAB/wE/Av8BwAEBAfABAAH4AQcB+AEBAYABAQHwAQAB4AEA
- AeABAAGAAQEB8AEAAeABAAHgAQABgAEBAYABAAHgAQAB4AEAAYAHAAGABwABwAEBAwABAQEAAQEBwAED
- AQABAwEAAQ8BAAEPAfABBwGAAQMBgAEHAYABBwHwAQcBgAEDAYABBwGAAQcB8AEHAcABAwHAAQcBwAEH
- AfABBwHAAQMBwAEPAcABDwHwAQcBwAEHAcABHwHAAR8B8AEPAcABDwHAAT8BwAE/AfgBDwHgAX8B4QH/
- AeEB/wH8AT8B8AL/AX8B/wE/A/8BfwHAAQcBwAEHAcABAQH4AQcBgAEDAYABAAGAAQAB4AEDAYABAwGA
- AQABgAEAAeABAQGAAQMBgAEAAYABAAHgAQEBgAEBAYABAAGAAgABAQGAAQABgAEAAYADAAGAAQQBgAEB
- AYABAQIAAcABBwHAAQcBwAEHAQABDwHgAR8B4AEfAeABHwGAAQcB4AEPAeABDwHgAQ8BgAEHAeABDwHg
- AQ8B4AEPAcABBwHgAR8B4AEfAeABHwHAAQ8B8AEfAfABHwHwAR8BwAEfAfABHwHwAR8B8AEfAcABPwH8
- AX8B/AF/AfwBfwHhAf8L
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAABQ
+ KQAAAk1TRnQBSQFMAgEBCAEAAVQBAAFUAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ AwABMAMAAQEBAAEgBgABMP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8AQgADVAGrAUkBTAFi
+ AflgAAEeAWwBEAH+AVwBpQFbAf8BaQGvAWgB/wFlAawBZQH/AWABqAFgAf8BXAGlAVwB/wFaAaMBWQH/
+ AV0BpgFdAf8BXwGnAV4B/wFhAakBYQH/ATsBgQE7Af8BBAE5AQQB/wM1AVcUAANEAXkBLgGFAS4B/wFI
+ AZcBRwH/AUUBlQFEAf8BQAGRAUAB/wE6AY0BOgH/ATkBjAE5Af8BPgGPAT0B/wE8AYsBPAH/AQQBMgEE
+ Af8BFwGBARcB/wMtAUYUAAMFAQcDBgEIAwQBBQFeAlkB1QFNAZIBsAH+AUkBTAFjAfkDBAEFAwABASAA
+ AwUBBwMGAQgDBAEFAwIBAwMCAQMDHQEpASsBIQFPAfsBKwEhAWYB+wErASEBWwH7Az0BaQgAAz0BaQGB
+ AdUBgQH/ATUBvQEzAf8BNQG9ATMB/wE1Ab0BMwH/ATUBvQEzAf8BOwG+ATkB/wFYAcgBVwH/ATUBvQEz
+ Af8BNQG9ATMB/wE1Ab0BMwH/AVABdwEmAf8BkwEEARUB/wEUAYEBFAH/FAABTAGaAUwB/wE1Ab0BMwH/
+ ATUBvQEzAf8BNQG9ATMB/wE1Ab0BMwH/AUsBxAFJAf8BRgHCAUQB/wE1Ab0BMwH/ATMBtwExAf8BlAEE
+ ARYB/wE1Ab0BMwH/AS4BhgEuAf8MAAMLAQ8BegF/AWYB/gF/AZIBdgH+AX8BkgF2Af4BfwGSAXcB/gF/
+ AZABdwH+AUYBfwGZAf4BkgHMAeoB/wGrAaUBpgH/AakBqgGjAf8BsQGwAasB/wGdAogB/gMEAQYMAAML
+ AQ8BegF/AWYB/gF/AZIBdgH+AX8BkgF2Af4BfwGSAXcB/gF/AZABdwH+AX8BhgF0Af4CCQHnAf8BCwEN
+ AbQB/wFDAUwBQQH+AS0BIAFqAf4BJgETAaEB/gNAAXAEAANQAZ4BYAHKAV8B/wE1Ab0BMwH/ATUBvQEz
+ Af8BNQG9ATMB/wE1Ab0BMwH/AUoBmAFJAf8BKgGBASgB/wF0AdEBcgH/ATUBvQEzAf8BNQG9ATMB/wE0
+ AbwBMgH/ASkBkAEnAf8BSAGXAUcB/xQAAW0BswFsAf8BNQG9ATMB/wE1Ab0BMwH/ATUBvQEzAf8BPAG/
+ AToB/wEYAYEBFgH/ARcBgQEWAf8BOQG+ATcB/wE1Ab0BMwH/ASABcgEfAf8BNQG9ATMB/wFbAaUBWgH/
+ DAADQgF2AVMBhwFBAf4BSwGCAUEB/gFLAYIBQQH+AUsBggFBAf4BeAF/AWQB/gF/AY4BeAH+AaUBogGg
+ Af8BxQHcAasB/wHKAdsBmQH/AdwB2wGdAf8BWAJWAcEBpQKUAf4MAANCAXYBUwGHAUEB/gFLAYIBQQH+
+ AUsBggFBAf4BSwGCAUEB/gF4AX8BZAH+ATUBKAFiAf4BCQELAeAB/wELARABgAH/AT8BWAEvAf4BfwGQ
+ AXcB/gFcAkoB6gErAR0BawH8BAADUQGiAV4ByQFdAf8BNAG8ATMB/wE0AbwBMwH/ATQBvAEzAf8BbQHO
+ AWwB/wFkAaABYAL/AvcB/wFSAZ4BUQH/ATQBvAEzAf8BNAG8ATMB/wEoAY0BJwH/AY0BBAEVAf8BJAFI
+ AR4B/wgAAxQBHAM/AW0BQAI/AW8BcgG2AXEB/wE0AbsBMwH/ATQBuwEzAf8BNAG7ATMB/wGGAdABhQH/
+ AecB6gHgAf8B1AHhAc4B/wGEAdMBgwH/ATQBuwEzAf8BlAEEARYB/wEpATUBEwH/AWIBqQFhAf8MAAFI
+ AkcBgwFQAYUBQQH+AUsBggFBAf4BSwGCAUEB/gFxAY4BXQH+AYgBjgF/Af4BUAF/AUEB/gGnAqIB/wHJ
+ AdsBmQH/AckB1wGLAf8B2wHWAYYB/wFdAlkBygFlAUMBPQH2DAABSAJHAYMBUAGFAUEB/gFLAYIBQQH+
+ AUsBggFBAf4BcQGOAV0B/gGIAY4BfwH+AQkBCwGTAf8BCgENAZQB/wFLAYIBQQH+AQoBDQGjAf8BcgF/
+ AV4B/gNMAZMBJgETAaEB/gQAA0wBkwFlAckBZAH/ATMBuAEyAf8BMwG4ATIB/wEzAbgBMgH/AYEBuQGA
+ Af8B/AH1AfQB/wH+AvYB/wE7AYsBNwH/AUwBwQFLAf8BMwG4ATIB/wEzAbgBMgH/AT4BowEuAf8BlAEE
+ ARYB/wMsAUQDEgEYAegBuAGCAf8B5AGfAUsB/wHMAY4BQwH/AWwBrwFqAf8BMgG2ATEB/wEyAbYBMQH/
+ ATIBtgExAf8BRAGTAUEB/wH8AfUB9AH/AfwB9QH0Af8BUAGbAU4B/wEyAbYBMQH/ATQBsgExAf8BkQEI
+ ARYB/wEdATEBEAH/AwwBEAGgAX8BaAH+AawBfwFzAf4CfwFBAf4BUgGCAUEB/gFKAX8BQAH+AUoBfwFA
+ Af4BegF/AWUB/gHDAawBqwH+AbMBpgGgAf4BsQKsAf8ByQHWAYsB/wHJAdABgQH/AeEB1wGEAf8BZQJR
+ AeUBggJHAfkDDAEQAaABfwFoAf4BrAF/AXMB/gJ/AUEB/gFSAYIBQQH+AUoBfwFAAf4BSgF/AUAB/gF6
+ AX8BZQH+AcMBrAGrAf4BSgE+AWkB/gIJAecB/wFKAX8BQAH+AUoBfwFAAf4BCwENAccB/wFZATwBQAHy
+ ASsBHQFhAfwEAAMyAVABiAHTAYcB/wExAbMBMAH/ATEBswEwAf8BNQG0ATQB/wEtAYEBKQH/Ad8C2AH/
+ AdkC0gH/AcABzQG5Af8BjgHQAY0B/wFsAQQBEAH/AUABmAEsAf8BMgGzATIB/wGUAQQBFgH/ATUCNAFV
+ AzsBZAHlAaABTQH/AeMBmAE9Af8B1QGPATkB/wE3AYoBMgH/ATQBsQE0Af8BMAGwAS8B/wFGAbYBRQH/
+ AV0BigFYAf8BgQGaAcAB/wGBAZsBwAH/ATUBBQEKAf8BZgFXASIB/wEwAbABLwH/AYIBIQEaAf8BVwE1
+ AS4B9QNBAXIBrAF/AUEB/gGsAX8BQQH+AX8BewE/Af4BfwGMAXAB/gFJAX8BPgH+AUoBfwE/Af4BUgF/
+ AUEB/gJ/AYQB/gGPAX8BhQH+AaUBqAGhAf8BvgHNAZ4B/wHRAdABgQH/Ae0B4AGnAf8BYAJXAdYBaQI+
+ AfUDQQFyAawBfwFBAf4BrAF/AUEB/gF/AXsBPwH+AX8BjAFwAf4BSQF/AT4B/gFKAX8BPwH+AVIBfwFB
+ Af4CfwGEAf4BiwF/AYEB/gIJAdkB/wEJAQsB3AH/AS0BKAFXAf4BDQEPAacB/wEmARMBoQH+AysBQggA
+ AUkBlQFEAf8BSAG2AUcB/wEvAawBLwH/AWkBtAFpAf8BHgFxAZgB/wEJAW8B1QH/ASMBgQHZAf8BCwFu
+ AdIB/wFBAYEBUgH/AR8BIwEOAf8BgwEEARMB/wGUAQQBFgH/AVgCPwHvBAABPQI8AWcB4wGeAUsB/wHh
+ AZYBPAH/AeABlQE8Af8BrgGNAWQB/wFRAZoBTAH/AYEByQGBAf8BQgGKAZ8B/wGAAa4B6gH/AakB1gH+
+ Af8BqgHXAf4B/wFUAVYBXQH/AXcBBAESAf8BlAEEARYB/wFcAQQBDgH/AwUBBwNEAXkBrAF/AUEB/gGs
+ AX8BQQH+AaMBfwFBAf4BVQF1ATwB/gF/AYcBegH+AV0BfwFyAf4BcQF/AZ8B/gGDAZUBsAH+AYcBlgGw
+ Af4BRAF8AZYB/gGOAn8B/gHRAc4BzQH/AZkBgwGCAf4BZAJKAewEAANEAXkBrAF/AUEB/gGsAX8BQQH+
+ AaMBfwFBAf4BVQF1ATwB/gF/AYcBegH+AV0BfwFyAf4BcQF/AZ8B/gGDAZUBsAH+AYcBlgGwAf4BRQF6
+ AZQB/gE2ASkBWwH+AQoBCwGmAf8BUgEoAT0B+AMdASoMAAMHAQoBSQFDATQB9gFrAacBaAH/AQYBbQHS
+ Af8BuAHdAf0B/wGNAcoC/wGMAckC/wGWAc4B/gH/AWgBpQHnAf8BWgGVAYwB/wFFAZIBPwH/A0gBhAgA
+ Ay8BSQHgAZ0BVQH/AdwBjQE6Af8B3AGNAToB/wGvAWUBRQH/AdcC0QH/AY0BmAGeAf8BmwHIAfMB/wGK
+ AcgC/wGJAcgC/wGJAcgC/wGIAccC/wGKAbwB7wH/AyQBNggAAzUBVgGoAX8BQQH+AacBfwFBAf4BrAF/
+ AWEB/gGtAZUBkwH+AY8CfwH+AX0BfwGiAf4BfwGLAbEB/gF/AYsBsQH+AX8BiwGxAf4BfwGLAbEB/gFH
+ AUEBTQH5EAADNQFWAagBfwFBAf4BpwF/AUEB/gGsAX8BYQH+Aa0BlQGTAf4BjwJ/Af4BfQF/AaIB/gF/
+ AYsBsQH+AX8BiwGxAf4BfwGLAbEB/gF/AYsBsQH+AUcBQQFNAfkgAAFTAlIBqAG2AdwB/QH/AYgBxwL/
+ AYgBxwL/AYgBxwL/AYcBxwL/AYkBxwH+Af8BLwGDAd4B/wMEAQUQAAHUAaABgQH/AdQBggE4Af8B0QGH
+ AUYB/wFmAW8BhwH/ARcBcAHLAf8BDAFxAdcB/wGHAcYB/gH/AYMBxAL/AYMBwwL/AYIBwwL/AYEBwwL/
+ AYcBxQH+Af8BWwJWAdkMAAGgAX8BcwH+AaMBfwFBAf4BfwF8AX4B/gFQAX8BmgH+AUYBcwGJAf4BfwGM
+ AbEB/gF/AYgBsQH+AX8BiAGxAf4BfwGHAbEB/gF/AYcBsQH+AX8BkAGuAf4DAwEEEAABoAF/AXMB/gGj
+ AX8BQQH+AX8BfAF+Af4BUAF/AZoB/gFGAXMBiQH+AX8BjAGxAf4BfwGIAbEB/gF/AYgBsQH+AX8BhwGx
+ Af4BfwGHAbEB/gF/AZABrgH+AwMBBBwAASABgQHhAf8BgwHEAv8BgwHDAv8BggHDAv8BgQHDAv8BgQHC
+ Av8BgQHCAv8BswHaAf0B/wM6AWIQAAMbASYBsQFqAUkB/wEiAXQByAH/AaUB1QH+Af8BgwG9AfAB/wE1
+ AYwB6gH/AYEBwAL/AYEBvwL/AYEBvwL/AYEBvwL/AYEBvgL/AYEBvgL/ASABgQHoAf8MAAMBAQIBWQJX
+ Ab8BfwGRAa4B/gF/AYsBsAH+AUcBfwGXAf4BfwGFAbEB/gF/AYMBsQH+AX8BgwGxAf4BfwGCAbEB/gF/
+ AYIBsQH+AX8BjwGwAf4DGgEkEAADAQECAVkCVwG/AX8BkQGuAf4BfwGLAbAB/gFHAX8BlwH+AX8BhQGx
+ Af4BfwGDAbEB/gF/AYMBsQH+AX8BggGxAf4BfwGCAbEB/gF/AY8BsAH+AxoBJBwAAW0BrAHxAf8BgQHA
+ Av8BgQG/Av8BgQG/Av8BgQG/Av8BgQG+Av8BgQG+Av8BjgHJAf4B/wFWAlUBtBQAAxgBIgGrAdYB/AH/
+ AYYBxgL/AYEBuQHwAf8BKAGIAfEB/wGAAbsC/wF3AbsC/wF2AboC/wF2AboC/wF1AboC/wF0AbkC/wEX
+ AYEB8AH/EAABZAJNAecBfwGIAbEB/gF/AYgBsQH+AVYBfwGWAf4BfwGIAbEB/gJ/AbEB/gJ/AbEB/gJ/
+ AbEB/gJ/AbEB/gF/AY0BrwH+AwABARQAAWQCTQHnAX8BiAGxAf4BfwGIAbEB/gFWAX8BlgH+AX8BiAGx
+ Af4CfwGxAf4CfwGxAf4CfwGxAf4CfwGxAf4BfwGNAa8B/gMAAQEcAAFjAakB9AH/AYEBvAL/AYABuwL/
+ AXcBuwL/AXcBuwL/AXYBugL/AXUBugL/AY0BxwH+Af8BUgJQAaMUAANOAZkBgQHCAf4B/wGBAcAC/wGB
+ AbwB+QH/ASwBhgHmAf8BgQHBAf4B/wFvAbcC/wFvAbYC/wFuAbYC/wFtAbYC/wGGAcQB/gH/A04BmBAA
+ AVoBfwGnAf4BfwGDAbEB/gF/AYMBsQH+AXoBfwGcAf4BcQF/AbAB/gF6AX8BsQH+AXkBfwGxAf4BeQF/
+ AbEB/gF9AX8BsQH+AWQBQwFFAfEYAAFaAX8BpwH+AX8BgwGxAf4BfwGDAbEB/gF6AX8BnAH+AXEBfwGw
+ Af4BegF/AbEB/gF5AX8BsQH+AXkBfwGxAf4BfQF/AbEB/gFkAUMBRQHxIAABFwGDAfYB/wF2AboB/gH/
+ AXEBtwL/AXABtwL/AXABtwL/AW8BtgL/AW8BtgL/AaQB0QH8Af8DIAEvFAABTgJNAZUBgQG9Af4B/wGA
+ AbsC/wF3AboB/gH/AWUBngHZAf8BQAGbAf4B/wFxAbcB/gH/AWgBswL/AWgBswL/AXMBuAH+Af8BNAGV
+ Af4B/xQAAVwCWQHJAn8BsQH+An8BsQH+AX0BfwGwAf4BYQF/AZMB/gFdAX8BsAH+AX8BjQGwAf4BfwGM
+ AbAB/gFJATYBSAH2HAABXAJZAckCfwGxAf4CfwGxAf4BfQF/AbAB/gFhAX8BkwH+AV0BfwGwAf4BfwGN
+ AbAB/gF/AYwBsAH+AUkBNgFIAfYkAAMvAUkBmgHMAf0B/wFrAbQC/wFqAbQC/wFqAbQC/wFpAbMC/wGB
+ Ab0B/gH/ATIBfwG/Af4YAAMQARUBnAHOAf0B/wFvAbYC/wFuAbYC/wFsAbQB/AH/AVkBlgHUAf8BGQGG
+ AfwB/wFyAbUB/gH/AXABtAH+Af8BXAFHAUoB7hgAAwIBAwF/AYABsAH+AXcBfwGxAf4BdgF/AbEB/gF/
+ AYoBsAH+AzQBVAMEAQYDAAEBIAADAgEDAX8BgAGwAf4BdwF/AbEB/gF2AX8BsQH+AX8BigGwAf4DNAFU
+ AwQBBgMAAQEsAAFSAlEBpwGBAb0B/QH/AYIBwQH+Af8BgQG7Af4B/wGlAdIB/QH/ASEBjAH+Af8DAgED
+ HAABXAJZAckBjwHHAf4B/wFnAbIC/wFrAbQB/gH/AYABuAH9Af8DDQERKAADAQECAVMCUgGoAVsCWQHE
+ AxkBIzAAAwEBAgFTAlIBqAFbAlkBxAMZASM8AAMKAQ4BUQJPAaUBWQJXAccDOgFiKAADKwFCAVsCWQHI
+ AVECUAGfAwABAUAAAyEBMDwAA1QBqwFJAUwBYgH5eAADIQEwJAADFgEfAT4CPQFqAUACPwFvAzwBZgE6
+ AjkBYAM3AVoDPQFpAXwBlwGgAf4BXAJYAdEDMwFSAwEBAhQAAxYBHwE+Aj0BagFAAj8BbwM8AWYBOgI5
+ AWADNwFaAVkBPgFRAfgBTQGSAbAB/gFNAVMBaQH6AzMBUgMBAQIUAAMWAR8BPgI9AWoBQAI/AW8DPAFm
+ AToCOQFgAzcBWgE6AjkBYAM7AWMBPQI8AWcBKwEhAU8B+wErASEBZgH7ASsBIQFbAfsDPQFpGAADBQEH
+ AwYBCAMEAQUDCAELAXwBlwGgAf4BXAJYAdEDBAEFAwABARAAAToCOQFgAX8BkQF/Af4BbwGNAVoB/gFt
+ AYwBWAH+AXEBjgFcAf4BdAGOAWAB/gF3AY8BYwH+AXQBjgFgAf4BKAGwAfMB/wEhAaEB5wH/ATYBoQHk
+ Af8BbgF/AVoB/gMEAQUMAAE6AjkBYAF/AZEBfwH+AW8BjQFaAf4BbQGMAVgB/gFxAY4BXAH+AXQBjgFg
+ Af4BdwGPAWMB/gF0AY4BYAH+AUQBfwGXAf4BkgHMAeoB/wGrAaUBpgH/AawBqgGmAf8BagI+AfMBnQKI
+ Af4DBAEGBAABOgI5AWABfwGRAX8B/gFvAY0BWgH+AW0BjAFYAf4BcQGOAVwB/gF0AY4BYAH+AXcBjwFj
+ Af4BdAGOAWAB/gFwAYMBWwH+AgkB5wH/AQoBDQGzAf8BTAFNAUEB/gFYAT8BQgHvASYBEwGhAf4DQAFw
+ DAADCwEPAXoBfwFmAf4BfwGSAXYB/gF/AZIBdgH+AX8BkgF3Af4BfwGQAXcB/gEpAbAB8wH/ASEBoQHn
+ Af8BSgF/AZ8B/gF/AY8BdwH+AUQBfwE0Af4MAAFdAlgB0gFPAYQBQQH+AUsBggFBAf4BSwGCAUEB/gFL
+ AYIBQQH+AXcBjwFiAf4BUwF/AUEB/gFTAYcBQQH+AUsBggFBAf4BLAHAAe8B/wEhAaEB5wH/AUgBfwGd
+ Af4DOwFkDAABXQJYAdIBTwGEAUEB/gFLAYIBQQH+AUsBggFBAf4BSwGCAUEB/gF3AY8BYgH+AVMBfwFB
+ Af4BUwGHAUEB/gFLAYIBQQH+AaUBogGgAf8BxQHcAasB/wHVAd4BpQH/AV4CVgHYAVoCWAHAAaUClAH+
+ BAABXQJYAdIBTwGEAUEB/gFLAYIBQQH+AUsBggFBAf4BSwGCAUEB/gF3AY8BYgH+AVMBfwFBAf4BUwGH
+ AUEB/gEsASYBWAH+AQkBCwHgAf8BKAEaAW8B/gFSAWQBQQH+AzsBZAFfAk0B6AErAR0BawH8DAADQgF2
+ AVMBhwFBAf4BSwGCAUEB/gFLAYIBQQH+AUsBggFBAf4BeAF/AWQB/gF/AY4BeAH+ASwBwAHvAf8BIQGh
+ AecB/wE/AX8BkQH+AX8BkAF3Af4DAQECCAABXQJTAeIBTQGDAUEB/gFLAYIBQQH+AUsBggFBAf4BSwGC
+ AUEB/gFLAX8BQQH+AcIBrAGqAf4BfgF/AWkB/gFLAYIBQQH+AUsBggFBAf4BLAHAAfAB/wEhAaEB5wH/
+ AWECVgHcDAABXQJTAeIBTQGDAUEB/gFLAYIBQQH+AUsBggFBAf4BSwGCAUEB/gFLAX8BQQH+AcIBrAGq
+ Af4BfgF/AWkB/gFLAYIBQQH+AacCogH/AckB2wGZAf8B0wHaAZQB/wFhAlYB3AFcAlkByQFlAUMBPQH2
+ BAABXQJTAeIBTQGDAUEB/gFLAYIBQQH+AUsBggFBAf4BSwGCAUEB/gFLAX8BQQH+AcIBrAGqAf4BfgF/
+ AWkB/gEJAQwBkwH/AQoBDQGUAf8BSwGCAUEB/gEKAQ0BowH/A0gBhgNKAYsBJgETAaEB/gwAAUgCRwGD
+ AVABhQFBAf4BSwGCAUEB/gFLAYIBQQH+AXEBjgFdAf4BiAGOAX8B/gFQAX8BQQH+AU0BgwFBAf4BLAHA
+ AfAB/wEhAaEB5wH/An8BiAH+AwYBCAgAAVsCVgHZAU0BgAFBAf4BSwF/AUEB/gFLAX8BQQH+AWcBigFU
+ Af4CfwF5Af4BwwKsAf4BSgF/AT0B/gFOAYEBQQH+AUsBfwFBAf4BSwF/AUEB/gGWAcgB2AH/AYsCfwH+
+ AWEBWAFZAdoIAAFbAlYB2QFNAYABQQH+AUsBfwFBAf4BSwF/AUEB/gFnAYoBVAH+An8BeQH+AcMCrAH+
+ AUoBfwE9Af4BTgGBAUEB/gGxAqwB/wHJAdYBiwH/AtQBgQH/AWECUwHiAWUCUQHlAYICRwH5BAABWwJW
+ AdkBTQGAAUEB/gFLAX8BQQH+AUsBfwFBAf4BZwGKAVQB/gJ/AXkB/gHDAqwB/gFKAX8BPQH+ATUBNgFM
+ Af4CCQHnAf8BSgF/AUAB/gFpAYcBVQH+AT0BHgGcAf0BWQE8AUAB8gErAR0BYQH8AwwBEAGgAX8BaAH+
+ AawBfwFzAf4CfwFBAf4BUgGCAUEB/gFKAX8BQAH+AUoBfwFAAf4BegF/AWUB/gHDAawBqwH+AbMBpgGg
+ Af4BfwGPAXcB/gFKAX8BQAH+AZYByAHXAf8BsgKwAf8BYQFYAVkB2ggAA1EBoAFWAYEBQgH+AUoBfwE/
+ Af4BSgF/AT8B/gF/AYgBfQH+AbABngGdAf4BqwKXAf4BlQGOAX8B/gF/AZABewH+AUoBfwE/Af4BSgF/
+ AT8B/gF/AZABeQH+An8BigH+AVEBQQGKAf4BUQJQAZ8EAANRAaABVgGBAUIB/gFKAX8BPwH+AUoBfwE/
+ Af4BfwGIAX0B/gGwAZ4BnQH+AasClwH+AZUBjgF/Af4BfwGQAXsB/gN/Af4BvgHOAZ8B/wHhAdYBgwH/
+ AWECUAHmAWACVwHWAWkCPgH1BAADUQGgAVYBgQFCAf4BSgF/AT8B/gFKAX8BPwH+AX8BiAF9Af4BsAGe
+ AZ0B/gGrApcB/gGVAY4BfwH+AX8BjgF7Af4BCQEKAdkB/wEJAQsB3AH/ATYBLAFgAf4BUgEuAT8B9wEm
+ ARMBoQH+AysBQgNBAXIBrAF/AUEB/gGsAX8BQQH+AX8BewE/Af4BfwGMAXAB/gFJAX8BPgH+AUoBfwE/
+ Af4BUgF/AUEB/gJ/AYQB/gGPAX8BhQH+AWgBfwFSAf4BSQF/AT4B/gFJAX8BPgH+AZEBjgHHAf8BUQFB
+ AYoB/gFRAlABnwQAAwcBCQJ/AXIB/gFLAX8BQQH+AUgBfwE9Af4BRQFuAVkB/gEtAWwBlAH+AU4BfwGa
+ Af4BLAFqAZIB/gFjAX8BYQH+AUkBfwE9Af4BUgF/AUEB/gFdAX8BRQH+BAABXwJWAdsDAAEBBAADBwEJ
+ An8BcgH+AUsBfwFBAf4BSAF/AT0B/gFFAW4BWQH+AS0BbAGUAf4BTgF/AZoB/gEsAWoBkgH+AWMBfwFh
+ Af4BSQF/AT0B/gGIAn8B/gHRAc4BzQH/AZkBgwGCAf4BZAJKAewIAAMHAQkCfwFyAf4BSwF/AUEB/gFI
+ AX8BPQH+AUUBbgFZAf4BLQFsAZQB/gFOAX8BmgH+ASwBagGSAf4BYwF/AWEB/gFIAX8BPQH+ATABKgFU
+ Af4BCQELAaUB/wFSAS4BOQH3Ax0BKgQAA0QBeQGsAX8BQQH+AawBfwFBAf4BowF/AUEB/gFVAXUBPAH+
+ AX8BhwF6Af4BXQF/AXIB/gFxAX8BnwH+AYMBlQGwAf4BhwGWAbAB/gFEAXwBlgH+AWsBfwFZAf4CfwFx
+ Af4DOwFkAV8CVgHbAwABAQgAAxIBGAFdAUABPwHwAUwCfwH+AYIBkgGsAf4BfwGMAbEB/gF/AYwBsQH+
+ AX8BjQGxAf4CfwGkAf4BWQF/AWcB/gFaAlcB0wMAAQEUAAMSARgBXQFAAT8B8AFMAn8B/gGCAZIBrAH+
+ AX8BjAGxAf4BfwGMAbEB/gF/AY0BsQH+An8BpAH+AVkBfwFnAf4BWgJXAdMDAAEBFAADEgEYAV0BQAE/
+ AfABTAJ/Af4BggGSAawB/gF/AYwBsQH+AX8BjAGxAf4BfwGNAbEB/gJ/AaQB/gFZAX8BZwH+AVoCVwHT
+ AwABAQwAAzUBVgGoAX8BQQH+AacBfwFBAf4BrAF/AWEB/gGtAZUBkwH+AY8CfwH+AX0BfwGiAf4BfwGL
+ AbEB/gF/AYsBsQH+AX8BiwGxAf4BfwGLAbEB/gFHAUEBTQH5HAADAwEEAXIBqQHqAf8BfwGKAbEB/gGH
+ AcYC/wF/AYoBsQH+AX8BigGxAf4BfwGKAbEB/gFCAXwBmgH+IAADAwEEAXIBqQHqAf8BfwGKAbEB/gGH
+ AcYC/wF/AYoBsQH+AX8BigGxAf4BfwGKAbEB/gFCAXwBmgH+GAABoAF/AXMB/gGjAX8BQQH+AX8BfAF+
+ Af4BUAF/AZoB/gFGAXMBiQH+AX8BjAGxAf4BfwGIAbEB/gF/AYgBsQH+AX8BhwGxAf4BfwGHAbEB/gF/
+ AZABrgH+AwMBBBgAAzYBWQF/AZIBsQH+AX8BiAGxAf4BfwGHAbEB/gF/AYcBsQH+AX8BhgGxAf4BfwGG
+ AbEB/gF/AY4BrQH+AwQBBRwAAzYBWQF/AZIBsQH+AX8BiAGxAf4BfwGHAbEB/gF/AYcBsQH+AX8BhgGx
+ Af4BfwGGAbEB/gF/AY4BrQH+AwQBBRwAAzYBWQF/AZIBsQH+AX8BiAGxAf4BfwGHAbEB/gF/AYcBsQH+
+ AX8BhgGxAf4BfwGGAbEB/gF/AY4BrQH+AwQBBRQAAwEBAgFZAlcBvwF/AZEBrgH+AX8BiwGwAf4BRwF/
+ AZcB/gF/AYUBsQH+AX8BgwGxAf4BfwGDAbEB/gF/AYIBsQH+AX8BggGxAf4BfwGPAbAB/gMaASQYAAFH
+ AkYBgQGOAcgB/gH/AX8BgwGxAf4BgQG9Av8BfwGDAbEB/gF/AYIBsQH+AX8BggGxAf4BhAGUAbAB/gMU
+ ARwcAAFHAkYBgQGOAcgB/gH/AX8BgwGxAf4BgQG9Av8BfwGDAbEB/gF/AYIBsQH+AX8BggGxAf4BhAGU
+ AbAB/gMUARwcAAFHAkYBgQGOAcgB/gH/AX8BgwGxAf4BgQG9Av8BfwGDAbEB/gF/AYIBsQH+AX8BggGx
+ Af4BhAGUAbAB/gMUARwYAAFkAk0B5wF/AYgBsQH+AX8BiAGxAf4BVgF/AZYB/gF/AYgBsQH+An8BsQH+
+ An8BsQH+An8BsQH+An8BsQH+AX8BjQGvAf4DAAEBGAADJgE5AX8BkgGwAf4CfwGxAf4CfwGxAf4CfwGx
+ Af4CfwGxAf4CfwGxAf4BfwGHAa4B/iAAAyYBOQF/AZIBsAH+An8BsQH+An8BsQH+An8BsQH+An8BsQH+
+ An8BsQH+AX8BhwGuAf4gAAMmATkBfwGSAbAB/gJ/AbEB/gJ/AbEB/gJ/AbEB/gJ/AbEB/gJ/AbEB/gF/
+ AYcBrgH+HAABWgF/AacB/gF/AYMBsQH+AX8BgwGxAf4BegF/AZwB/gFxAX8BsAH+AXoBfwGxAf4BeQF/
+ AbEB/gF5AX8BsQH+AX0BfwGxAf4BZAFDAUUB8SAAAUQBmgH7Af8BfAF/AbEB/gFxAbUC/wF6AX8BsQH+
+ AXoBfwGxAf4CfwGxAf4BSQE1AUgB9iQAAUQBmgH7Af8BfAF/AbEB/gFxAbUC/wF6AX8BsQH+AXoBfwGx
+ Af4CfwGxAf4BSQE1AUgB9iQAAUQBmgH7Af8BfAF/AbEB/gFxAbUC/wF6AX8BsQH+AXoBfwGxAf4CfwGx
+ Af4BSQE1AUgB9hwAAVwCWQHJAn8BsQH+An8BsQH+AX0BfwGwAf4BYQF/AZMB/gFdAX8BsAH+AX8BjQGw
+ Af4BfwGMAbAB/gFJATYBSAH2JAADGQEjAWwBfwGxAf4BfwGDAbEB/gF6AX8BsQH+AX8BiQGxAf4BSwF/
+ AbEB/gMAAQEkAAMZASMBbAF/AbEB/gF/AYMBsQH+AXoBfwGxAf4BfwGJAbEB/gFLAX8BsQH+AwABASQA
+ AxkBIwFsAX8BsQH+AX8BgwGxAf4BegF/AbEB/gF/AYkBsQH+AUsBfwGxAf4DAAEBHAADAgEDAX8BgAGw
+ Af4BdwF/AbEB/gF2AX8BsQH+AX8BigGwAf4DNAFUAwQBBgMAAQEwAANMAZMBXAJZAc8DQgF2NAADTAGT
+ AVwCWQHPA0IBdjQAA0wBkwFcAlkBzwNCAXYoAAMBAQIBUwJSAagBWwJZAcQDGQEjJAABQgFNAT4HAAE+
+ AwABKAMAAUADAAEwAwABAQEAAQEFAAGAAQEWAAP/gQAB/wE/Av8BwAEBAfABAAH4AQcB+AEBAYABAQHw
+ AQAB4AEAAeABAAGAAQEB8AEAAeABAAHgAQABgAEBAYABAAHgAQAB4AEAAYAHAAGABwABwAEBAwABAQEA
+ AQEBwAEDAQABAwEAAQ8BAAEPAfABBwGAAQMBgAEHAYABBwHwAQcBgAEDAYABBwGAAQcB8AEHAcABAwHA
+ AQcBwAEHAfABBwHAAQMBwAEPAcABDwHwAQcBwAEHAcABHwHAAR8B8AEPAcABDwHAAT8BwAE/AfgBDwHg
+ AX8B4QH/AeEB/wH8AT8B8AL/AX8B/wE/A/8BfwHAAQcBwAEHAcABAQH4AQcBgAEDAYABAAGAAQAB4AED
+ AYABAwGAAQABgAEAAeABAQGAAQMBgAEAAYABAAHgAQEBgAEBAYABAAGAAgABAQGAAQABgAEAAYADAAGA
+ AQQBgAEBAYABAQIAAcABBwHAAQcBwAEHAQABDwHgAR8B4AEfAeABHwGAAQcB4AEPAeABDwHgAQ8BgAEH
+ AeABDwHgAQ8B4AEPAcABBwHgAR8B4AEfAeABHwHAAQ8B8AEfAfABHwHwAR8BwAEfAfABHwHwAR8B8AEf
+ AcABPwH8AX8B/AF/AfwBfwHhAf8L
</value>
</data>
- <metadata name="securityContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>314, 17</value>
- </metadata>
- <data name="readWriteAccessToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
- <value>191, 22</value>
- </data>
- <data name="readWriteAccessToolStripMenuItem.Text" xml:space="preserve">
- <value>Read write access</value>
- </data>
- <data name="readOnlyAccessToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="readOnlyAccessToolStripMenuItem.Text" xml:space="preserve">
- <value>Read only access</value>
- </data>
- <data name="denyAccessToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="denyAccessToolStripMenuItem.Text" xml:space="preserve">
- <value>Deny access</value>
- </data>
- <data name="inheritedAccessRightsToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="inheritedAccessRightsToolStripMenuItem.Text" xml:space="preserve">
- <value>Inherited access rights</value>
- </data>
- <data name="securityContextMenu.Size" type="System.Drawing.Size, System.Drawing">
- <value>192, 92</value>
- </data>
- <data name=">>securityContextMenu.Name" xml:space="preserve">
- <value>securityContextMenu</value>
- </data>
- <data name=">>securityContextMenu.Type" xml:space="preserve">
- <value>System.Windows.Forms.ContextMenuStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
<metadata name="toolTip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>470, 17</value>
</metadata>
@@ -2165,7 +2242,7 @@
<value>True</value>
</metadata>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
- <value>354, 459</value>
+ <value>504, 459</value>
</data>
<data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
<value>CenterParent</value>
@@ -2191,6 +2268,30 @@
<data name=">>columnHeader3.Type" xml:space="preserve">
<value>System.Windows.Forms.ColumnHeader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
+ <data name=">>readWriteAccessToolStripMenuItem.Name" xml:space="preserve">
+ <value>readWriteAccessToolStripMenuItem</value>
+ </data>
+ <data name=">>readWriteAccessToolStripMenuItem.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>readOnlyAccessToolStripMenuItem.Name" xml:space="preserve">
+ <value>readOnlyAccessToolStripMenuItem</value>
+ </data>
+ <data name=">>readOnlyAccessToolStripMenuItem.Type" xml:space="preserve">
+ </data>
+ <data name=">>denyAccessToolStripMenuItem.Name" xml:space="preserve">
+ <value>denyAccessToolStripMenuItem</value>
+ </data>
+ <data name=">>denyAccessToolStripMenuItem.Type" xml:space="preserve">
+ </data>
+ <data name=">>inheritedAccessRightsToolStripMenuItem.Name" xml:space="preserve">
+ <value>inheritedAccessRightsToolStripMenuItem</value>
+ </data>
+ <data name=">>inheritedAccessRightsToolStripMenuItem.Type" xml:space="preserve">
+ </data>
<data name=">>ItemKey.Name" xml:space="preserve">
<value>ItemKey</value>
</data>
@@ -2227,36 +2328,24 @@
<data name=">>UserAndGroupImages.Type" xml:space="preserve">
<value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>readWriteAccessToolStripMenuItem.Name" xml:space="preserve">
- <value>readWriteAccessToolStripMenuItem</value>
+ <data name=">>toolTip.Name" xml:space="preserve">
+ <value>toolTip</value>
</data>
- <data name=">>readWriteAccessToolStripMenuItem.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <data name=">>toolTip.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>readOnlyAccessToolStripMenuItem.Name" xml:space="preserve">
- <value>readOnlyAccessToolStripMenuItem</value>
+ <data name=">>btnReferencesOpenSelected.Name" xml:space="preserve">
+ <value>btnReferencesOpenSelected</value>
</data>
- <data name=">>readOnlyAccessToolStripMenuItem.Type" xml:space="preserve">
+ <data name=">>btnReferencesOpenSelected.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>denyAccessToolStripMenuItem.Name" xml:space="preserve">
- <value>denyAccessToolStripMenuItem</value>
+ <data name=">>btnReferencedByOpenSelected.Name" xml:space="preserve">
+ <value>btnReferencedByOpenSelected</value>
</data>
- <data name=">>denyAccessToolStripMenuItem.Type" xml:space="preserve">
+ <data name=">>btnReferencedByOpenSelected.Type" xml:space="preserve">
</data>
- <data name=">>inheritedAccessRightsToolStripMenuItem.Name" xml:space="preserve">
- <value>inheritedAccessRightsToolStripMenuItem</value>
- </data>
- <data name=">>inheritedAccessRightsToolStripMenuItem.Type" xml:space="preserve">
- </data>
- <data name=">>toolTip.Name" xml:space="preserve">
- <value>toolTip</value>
- </data>
- <data name=">>toolTip.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
<data name=">>$this.Name" xml:space="preserve">
<value>ResourcePropertiesDialog</value>
</data>
More information about the mapguide-commits
