[mapguide-commits] r7937 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Wed Nov 27 06:02:14 PST 2013
Author: jng
Date: 2013-11-27 06:02:13 -0800 (Wed, 27 Nov 2013)
New Revision: 7937
trunk/Tools/Maestro/Maestro/App.config
Add proxy server support for Maestro. Patch by Johan Van de Wauw
Modified: trunk/Tools/Maestro/Maestro/App.config
--- trunk/Tools/Maestro/Maestro/App.config 2013-11-27 13:01:44 UTC (rev 7936)
+++ trunk/Tools/Maestro/Maestro/App.config 2013-11-27 14:02:13 UTC (rev 7937)
@@ -1,6 +1,6 @@
<?xml version="1.0"?>
<configuration>
If you use the Local Native Connection, setup assembly binding redirection by
editing this file here. For more information, visit the following links:
@@ -14,7 +14,7 @@
Note that Local Native Connection is not available for Mono.
<runtime>
<assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
<dependentAssembly>
@@ -28,4 +28,10 @@
</assemblyBinding>
</runtime>
-<startup><supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/></startup></configuration>
+ <startup>
+ <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/>
+ </startup>
+ <system.net>
+ <defaultProxy useDefaultCredentials="true" />
+ </system.net>
+</configuration>
More information about the mapguide-commits
