[mapguide-commits] r7939 - in sandbox/jng/fusion_robust_error_handling_templates: aqua limegold maroon slate turquoiseyellow
svn_mapguide at osgeo.org
Thu Nov 28 04:58:22 PST 2013
Author: jng
Date: 2013-11-28 04:58:22 -0800 (Thu, 28 Nov 2013)
New Revision: 7939
sandbox/jng/fusion_robust_error_handling_templates/aqua/index.html
sandbox/jng/fusion_robust_error_handling_templates/limegold/index.html
sandbox/jng/fusion_robust_error_handling_templates/maroon/index.html
sandbox/jng/fusion_robust_error_handling_templates/slate/index.html
sandbox/jng/fusion_robust_error_handling_templates/turquoiseyellow/index.html
Fusion ticket 576: Update the 5 templates as follows:
- Add a showErrorDialog() function to display error messages in a Jx.Dialog instead of using an alert()
- Update the default error handler to check for Fusion.DetailedError instances
- For Fusion.DetailedError instances, construct a formatted summary of the error for display in a Jx.Dialog
Modified: sandbox/jng/fusion_robust_error_handling_templates/aqua/index.html
--- sandbox/jng/fusion_robust_error_handling_templates/aqua/index.html 2013-11-28 10:42:03 UTC (rev 7938)
+++ sandbox/jng/fusion_robust_error_handling_templates/aqua/index.html 2013-11-28 12:58:22 UTC (rev 7939)
@@ -82,20 +82,20 @@
main.addEvent('sizeChange', function(){
- if (dOverviewMap.domObj.getStyle('display') != 'none'){
- dOverviewMap.show();
- if (dLegend.domObj.getStyle('display') != 'none'){
- dLegend.show();
+ if (dOverviewMap.domObj.getStyle('display') != 'none'){
+ dOverviewMap.show();
+ if (dLegend.domObj.getStyle('display') != 'none'){
+ dLegend.show();
if (dTasks.domObj.getStyle('display') != 'none'){
- dTasks.show();
+ dTasks.show();
if (dSelection.domObj.getStyle('display') != 'none'){
- dSelection.show();
+ dSelection.show();
main.resize();
Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, fusionInitialized);
@@ -103,69 +103,73 @@
Fusion.initialize();
+var showErrorDialog = function(msg) {
+ var errorDialog = new Jx.Dialog({
+ label: "Fusion Error",
+ image: "images/icons/error.png",
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ errorDialog.show();
var fusionError = function(eventId, error) {
- var errorMessage = error.toString();
- var readableMessage = '';
+ if (error instanceof Fusion.DetailedError) {
+ var fmtStack = "";
+ for (var i = 0; i < error.stack.length; i++) {
+ var stackFrame = error.stack[i];
+ fmtStack += " - " + (stackFrame.func != "" ? stackFrame.func : "?") + " at " + stackFrame.url + " (line: " + stackFrame.line + ")";
+ fmtStack += "\n";
+ var message = OpenLayers.i18n("detailedErrorTemplateHtml", {
+ name: error.name,
+ source: error.url,
+ message: error.message,
+ stacktrace: fmtStack
+ showErrorDialog(message);
+ console.log('Fusion Error: \n' + message);
+ } else {
+ var errorMessage = error.toString();
+ var readableMessage = '';
- //Case 1: For dealing with Function: convertXML (fusion.js)
- // xml2json: function(callback, r, json) {
- // if (json) {
- // var o;
- // eval("o="+r.responseText);
- // callback(o);
- // } else {
- // if (r.status >= 400) {
- // Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
- // 'xml2json: invalid XML document: ' + r.transport.responseText + " : " + r.request.url));
- // return;
- var tagStart = '<h2>';
- var tagEnd = '</h2>';
- var indexStart = errorMessage.indexOf(tagStart);
- var indexEnd = errorMessage.indexOf(tagEnd, tagStart);
- if (indexStart != -1 && indexEnd != -1) {
- readableMessage = errorMessage.substring(indexStart + tagStart.length, indexEnd);
- readableMessage = readableMessage.replace(/\\n/g, '\n');
- readableMessage = readableMessage.replace(/\\t/g, '\t');
- readableMessage = readableMessage.replace(/\\'/g, '\'');
+ //Case 1: For dealing with Function: convertXML (fusion.js)
+ // xml2json: function(callback, r, json) {
+ // if (json) {
+ // var o;
+ // eval("o="+r.responseText);
+ // callback(o);
+ // } else {
+ // if (r.status >= 400) {
+ // Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
+ // 'xml2json: invalid XML document: ' + r.transport.responseText + " : " + r.request.url));
+ // return;
+ var tagStart = '<h2>';
+ var tagEnd = '</h2>';
+ var indexStart = errorMessage.indexOf(tagStart);
+ var indexEnd = errorMessage.indexOf(tagEnd, tagStart);
+ if (indexStart != -1 && indexEnd != -1) {
+ readableMessage = errorMessage.substring(indexStart + tagStart.length, indexEnd);
+ readableMessage = readableMessage.replace(/\\n/g, '\n');
+ readableMessage = readableMessage.replace(/\\t/g, '\t');
+ readableMessage = readableMessage.replace(/\\'/g, '\'');
- //Case 2: For dealing with Function: ajaxException. (fusion.js)
- // ajaxException: function(r, e) {
- // this.reportError(new Fusion.Error(Fusion.Error.WARNING,
- // OpenLayers.i18n('ajaxError', {'exception':e.message,
- // 'filename':e.fileName,
- // 'line':e.lineNumber,
- // 'response': r.transport.responseText
- if (readableMessage == '') {
- var ajaxCallback = 'WARNING: Exception occurred in AJAX callback.';
- var responseError = 'Response: ERROR: ';
- var indexAjaxCallback = errorMessage.indexOf(ajaxCallback);
- var indexResponseError = errorMessage.indexOf(responseError);
- if (indexAjaxCallback != -1 && indexResponseError != -1) {
- var indexReturn = errorMessage.indexOf('\n', indexResponseError);
- if (indexReturn != -1) {
- readableMessage = errorMessage.substring(indexResponseError + responseError.length, indexReturn);
+ if (readableMessage != '') {
+ showErrorDialog(readableMessage);
+ else {
+ showErrorDialog('Fusion Error: \n' + errorMessage);
+ console.log('Fusion Error: \n' + errorMessage);
- if (readableMessage != '') {
- alert(readableMessage);
- else {
- alert('Fusion Error: \n' + errorMessage);
- console.log('Fusion Error: \n' + errorMessage);
var fusionInitialized = function() {
Modified: sandbox/jng/fusion_robust_error_handling_templates/limegold/index.html
--- sandbox/jng/fusion_robust_error_handling_templates/limegold/index.html 2013-11-28 10:42:03 UTC (rev 7938)
+++ sandbox/jng/fusion_robust_error_handling_templates/limegold/index.html 2013-11-28 12:58:22 UTC (rev 7939)
@@ -76,87 +76,91 @@
contentId: 'SelectionPanel'
- tabbox1.add(tab1, tab2, tab3);
+ tabbox1.add(tab1, tab2, tab3);
- var tabbox2 = new Jx.TabBox({parent: splitter2.elements[1]});
+ var tabbox2 = new Jx.TabBox({parent: splitter2.elements[1]});
- var tab4 = new Jx.Tab({
- label: OpenLayers.i18n('ovmapTitle'),
- contentId: 'OverviewMap'});
+ var tab4 = new Jx.Tab({
+ label: OpenLayers.i18n('ovmapTitle'),
+ contentId: 'OverviewMap'});
- tabbox2.add(tab4);
+ tabbox2.add(tab4);
- main.resize();
+ main.resize();
- Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, fusionInitialized);
- Fusion.registerForEvent(Fusion.Event.FUSION_ERROR, fusionError);
- Fusion.initialize();
+ Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, fusionInitialized);
+ Fusion.registerForEvent(Fusion.Event.FUSION_ERROR, fusionError);
+ Fusion.initialize();
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ fmtStack += "\n";
+ name: error.name,
+ } else {
- // if (json) {
- // var o;
- // callback(o);
- // } else {
- // return;
+ // if (json) {
+ // var o;
+ // callback(o);
+ // } else {
+ // return;
+ else {
- else {
Modified: sandbox/jng/fusion_robust_error_handling_templates/maroon/index.html
--- sandbox/jng/fusion_robust_error_handling_templates/maroon/index.html 2013-11-28 10:42:03 UTC (rev 7938)
+++ sandbox/jng/fusion_robust_error_handling_templates/maroon/index.html 2013-11-28 12:58:22 UTC (rev 7939)
@@ -80,104 +80,108 @@
- /* create dynamic content */
- panel1 = new Jx.Panel({
- label: OpenLayers.i18n('legendTitle'),
- collapse: true,
- maximize: true,
- contentId: 'Legend'});
- panel1.content.id = 'Legend';
+ /* create dynamic content */
+ panel1 = new Jx.Panel({
+ label: OpenLayers.i18n('legendTitle'),
+ collapse: true,
+ maximize: true,
+ contentId: 'Legend'});
+ panel1.content.id = 'Legend';
- panel2 = new Jx.Panel({
- label: OpenLayers.i18n('selectionPanelTitle'),
- collapse: true,
- maximize: true,
- contentId: 'SelectionPanel'});
+ panel2 = new Jx.Panel({
+ label: OpenLayers.i18n('selectionPanelTitle'),
+ collapse: true,
+ maximize: true,
+ contentId: 'SelectionPanel'});
- panel3 = new Jx.Panel({
- label: OpenLayers.i18n('taskPaneTitle'),
- collapse: true,
- maximize: true,
- contentId: 'TaskPane'});
+ panel3 = new Jx.Panel({
+ label: OpenLayers.i18n('taskPaneTitle'),
+ collapse: true,
+ maximize: true,
+ contentId: 'TaskPane'});
- panel4 = new Jx.Panel({
- collapse: true,
- maximize: true,
+ panel4 = new Jx.Panel({
+ collapse: true,
+ maximize: true,
- panelman = new Jx.PanelSet({parent: splitter.elements[1], panels: [panel1, panel2, panel3, panel4]});
+ panelman = new Jx.PanelSet({parent: splitter.elements[1], panels: [panel1, panel2, panel3, panel4]});
- main.resize();
+ main.resize();
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ fmtStack += "\n";
+ name: error.name,
+ } else {
- // if (json) {
- // var o;
- // callback(o);
- // } else {
- // return;
+ // if (json) {
+ // var o;
+ // callback(o);
+ // } else {
+ // return;
+ else {
- else {
Modified: sandbox/jng/fusion_robust_error_handling_templates/slate/index.html
--- sandbox/jng/fusion_robust_error_handling_templates/slate/index.html 2013-11-28 10:42:03 UTC (rev 7938)
+++ sandbox/jng/fusion_robust_error_handling_templates/slate/index.html 2013-11-28 12:58:22 UTC (rev 7939)
@@ -98,69 +98,73 @@
dOverviewMap.open();
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ fmtStack += "\n";
+ name: error.name,
+ } else {
- // if (json) {
- // var o;
- // callback(o);
- // } else {
- // return;
+ // if (json) {
+ // var o;
+ // callback(o);
+ // } else {
+ // return;
+ else {
- else {
Modified: sandbox/jng/fusion_robust_error_handling_templates/turquoiseyellow/index.html
--- sandbox/jng/fusion_robust_error_handling_templates/turquoiseyellow/index.html 2013-11-28 10:42:03 UTC (rev 7938)
+++ sandbox/jng/fusion_robust_error_handling_templates/turquoiseyellow/index.html 2013-11-28 12:58:22 UTC (rev 7939)
@@ -77,73 +77,75 @@
+ width: 800,
+ height: 400,
+ modal: true,
+ resize: true,
+ move: true,
+ content: msg
+ fmtStack += "\n";
+ name: error.name,
+ } else {
- // if (json) {
- // var o;
- // callback(o);
- // } else {
- // return;
+ // if (json) {
+ // var o;
+ // callback(o);
+ // } else {
+ // return;
+ else {
- else {
More information about the mapguide-commits
