[mapguide-commits] r7836 - in trunk/Tools/Maestro: Maestro.Editors/MapDefinition OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Sep 3 00:40:04 PDT 2013
Author: jng
Date: 2013-09-03 00:40:04 -0700 (Tue, 03 Sep 2013)
New Revision: 7836
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs
#2350: Detach the BaseMapDefinition element if removing the last tiled layer group or finite display scale and there's nothing left.
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.cs	2013-09-03 05:18:02 UTC (rev 7835)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.cs	2013-09-03 07:40:04 UTC (rev 7836)
@@ -88,22 +88,21 @@
         private void ClearScales()
             _map.InitBaseMap();
-            _map.BaseMap.RemoveAllScales();
+            _map.RemoveAllFiniteDisplayScales(true);
             _edSvc.MarkDirty();
         private void RemoveScaleFromMap(double scale)
             _scales.Remove(scale);
-            _map.InitBaseMap();
-            _map.BaseMap.RemoveFiniteDisplayScale(scale);
+            _map.RemoveFiniteDisplayScale(scale, true);
             _edSvc.MarkDirty();
         private void AddScaleToMap(double scale)
             _map.InitBaseMap();
-            _map.BaseMap.AddFiniteDisplayScale(scale);
+            _map.AddFiniteDisplayScale(scale);
             _edSvc.MarkDirty();
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2013-09-03 05:18:02 UTC (rev 7835)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2013-09-03 07:40:04 UTC (rev 7836)
@@ -413,7 +413,7 @@
                     layerCount++;
                 //Detach the base layer group
-                _map.BaseMap.RemoveBaseLayerGroup(group.Tag);
+                _map.RemoveBaseLayerGroup(group.Tag, true);
                 MessageBox.Show(string.Format(Strings.BaseLayerGroupConvertedToLayerGroup, group.Tag.Name, groupName));
                 this.RefreshModels();
                 tabControl1.SelectedIndex = 0; //Switch to Layer Groups
@@ -705,7 +705,7 @@
         private void RemoveSelectedTiledLayerItem(BaseLayerGroupItem group)
             propertiesPanel.Controls.Clear();
             _tiledLayerModel.Invalidate();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs	2013-09-03 05:18:02 UTC (rev 7835)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinitionInterfaces.cs	2013-09-03 07:40:04 UTC (rev 7836)
@@ -463,6 +463,92 @@
     public static class MapDefinitionExtensions
         /// <summary>
+        /// Adds the specified finite display scale to the Map Definition
+        /// </summary>
+        /// <param name="map"></param>
+        /// <param name="scale"></param>
+        public static void AddFiniteDisplayScale(this IMapDefinition map, double scale)
+            Check.NotNull(map, "map"); //NOXLATE
+            if (map.BaseMap != null)
+                map.InitBaseMap();
+            map.BaseMap.AddFiniteDisplayScale(scale);
+        /// <summary>
+        /// Removes the specified finite display scale from the Map Definition
+        /// </summary>
+        /// <param name="bDetachIfEmpty"></param>
+        public static void RemoveFiniteDisplayScale(this IMapDefinition map, double scale, bool bDetachIfEmpty)
+            if (map.BaseMap == null)
+                return;
+            map.BaseMap.RemoveFiniteDisplayScale(scale);
+            if (map.BaseMap.GroupCount == 0 && map.BaseMap.ScaleCount == 0 && bDetachIfEmpty)
+                map.RemoveBaseMap();
+        /// <summary>
+        /// Removes all finite display scales from the Map Definition
+        /// </summary>
+        public static void RemoveAllFiniteDisplayScales(this IMapDefinition map, bool bDetachIfEmpty)
+                return;
+            map.BaseMap.RemoveAllScales();
+        /// <summary>
+        /// Adds the specified base layer group to the map definition
+        /// </summary>
+        /// <param name="name"></param>
+        /// <returns></returns>
+        public static IBaseMapGroup AddBaseLayerGroup(this IMapDefinition map, string name)
+            Check.NotEmpty(name, "name"); //NOXLATE
+            return map.BaseMap.AddBaseLayerGroup(name);
+        /// <summary>
+        /// Removes the given base layer group from the Map Definition
+        /// </summary>
+        /// <param name="group"></param>
+        public static void RemoveBaseLayerGroup(this IMapDefinition map, IBaseMapGroup group, bool bDetachIfEmpty)
+            if (null == group)
+                return;
+                return;
+            map.BaseMap.RemoveBaseLayerGroup(group);
+            if (map.BaseMap.GroupCount == 0 && map.BaseMap.GroupCount == 0 && bDetachIfEmpty)
+        /// <summary>
         /// Updates the group name references of all layers belonging to a particular group
         /// </summary>
         /// <param name="map">The map.</param>
More information about the mapguide-commits mailing list
