[mapguide-commits] r7839 - in trunk/Tools/Maestro: Maestro.Base Maestro.Base/Editor Maestro.Editors/Generic
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Sep 5 02:51:06 PDT 2013
Author: jng
Date: 2013-09-05 02:51:05 -0700 (Thu, 05 Sep 2013)
New Revision: 7839
   trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Strings.resx
   trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.resx
#2354: Implement ability to re-read XML content from the source resource in the Generic XML editor.
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.Designer.cs	2013-09-04 14:09:13 UTC (rev 7838)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.Designer.cs	2013-09-05 09:51:05 UTC (rev 7839)
@@ -43,10 +43,12 @@
             this.editor.BackgroundColor = System.Drawing.SystemColors.Window;
             resources.ApplyResources(this.editor, "editor");
             this.editor.Name = "editor";
+            this.editor.SupportsReReadFromSource = true;
             this.editor.TextColor = System.Drawing.SystemColors.WindowText;
             this.editor.TextFont = new System.Drawing.Font("Courier New", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
             this.editor.Validator = null;
             this.editor.XmlContent = "";
+            this.editor.RequestReloadFromSource += new System.EventHandler(this.editor_RequestReloadFromSource);
             // XmlEditor
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs	2013-09-04 14:09:13 UTC (rev 7838)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs	2013-09-05 09:51:05 UTC (rev 7839)
@@ -196,5 +196,22 @@
                 return Properties.Resources.icon_xmleditor;
+        private void editor_RequestReloadFromSource(object sender, EventArgs e)
+            if (MessageService.AskQuestion(Strings.ConfirmReloadXmlFromSource))
+                var resId = this.EditorService.ResourceID;
+                using (var stream = this.EditorService.ResourceService.GetResourceXmlData(resId))
+                    using (var sr = new StreamReader(stream))
+                        var xml = sr.ReadToEnd();
+                        editor.XmlContent = xml;
+                        MessageService.ShowMessage(Strings.XmlReloadedFromSource);
Modified: trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs	2013-09-04 14:09:13 UTC (rev 7838)
+++ trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs	2013-09-05 09:51:05 UTC (rev 7839)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:4.0.30319.18047
+//     Runtime Version:4.0.30319.18052
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -370,6 +370,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Are you sure you want to reload the XML from source? This will discard any un-saved changes you have made..
+        /// </summary>
+        internal static string ConfirmReloadXmlFromSource {
+            get {
+                return ResourceManager.GetString("ConfirmReloadXmlFromSource", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to You are about to reset all preferences to default values. Are you sure you want to do this?.
         /// </summary>
         internal static string ConfirmResetPrefs {
@@ -2537,6 +2546,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to XML content reloaded from source.
+        /// </summary>
+        internal static string XmlReloadedFromSource {
+            get {
+                return ResourceManager.GetString("XmlReloadedFromSource", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Load this resource into the Site Repository.
         /// </summary>
         internal static string XmlResHandlerAction {
Modified: trunk/Tools/Maestro/Maestro.Base/Strings.resx
--- trunk/Tools/Maestro/Maestro.Base/Strings.resx	2013-09-04 14:09:13 UTC (rev 7838)
+++ trunk/Tools/Maestro/Maestro.Base/Strings.resx	2013-09-05 09:51:05 UTC (rev 7839)
@@ -965,4 +965,10 @@
   <data name="Label_ResourceID" xml:space="preserve">
     <value>Resource ID:</value>
   </data>
+  <data name="ConfirmReloadXmlFromSource" xml:space="preserve">
+    <value>Are you sure you want to reload the XML from source? This will discard any un-saved changes you have made.</value>
+  </data>
+  <data name="XmlReloadedFromSource" xml:space="preserve">
+    <value>XML content reloaded from source</value>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.Designer.cs	2013-09-04 14:09:13 UTC (rev 7838)
+++ trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.Designer.cs	2013-09-05 09:51:05 UTC (rev 7839)
@@ -43,6 +43,7 @@
             this.lblCursorPos = new System.Windows.Forms.ToolStripLabel();
             this.btnFind = new System.Windows.Forms.ToolStripButton();
             this.btnFindAndReplace = new System.Windows.Forms.ToolStripButton();
+            this.btnReRead = new System.Windows.Forms.ToolStripButton();
             this.resDataCtrl = new Maestro.Editors.Generic.ResourceDataPanel();
             this.nodeNumericUpDown1 = new Aga.Controls.Tree.NodeControls.NodeNumericUpDown();
             this.txtXmlContent = new Maestro.Editors.Generic.XmlTextEditorControl();
@@ -71,7 +72,8 @@
             this.toolStripSeparator3,
             this.lblCursorPos,
             this.btnFind,
-            this.btnFindAndReplace});
+            this.btnFindAndReplace,
+            this.btnReRead});
             resources.ApplyResources(this.toolStrip1, "toolStrip1");
             this.toolStrip1.Name = "toolStrip1";
@@ -158,6 +160,13 @@
             this.btnFindAndReplace.Name = "btnFindAndReplace";
             this.btnFindAndReplace.Click += new System.EventHandler(this.btnFindAndReplace_Click);
+            // btnReRead
+            this.btnReRead.Image = global::Maestro.Editors.Properties.Resources.arrow_circle_135;
+            resources.ApplyResources(this.btnReRead, "btnReRead");
+            this.btnReRead.Name = "btnReRead";
+            this.btnReRead.Click += new System.EventHandler(this.btnReRead_Click);
             // resDataCtrl
             this.resDataCtrl.ContentBackgroundColor = System.Drawing.SystemColors.Control;
@@ -284,5 +293,6 @@
         private System.Windows.Forms.ToolStripSeparator toolStripSeparator4;
         private System.Windows.Forms.ToolStripMenuItem findToolStripMenuItem;
         private System.Windows.Forms.ToolStripMenuItem findReplaceToolStripMenuItem;
+        private System.Windows.Forms.ToolStripButton btnReRead;
Modified: trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs	2013-09-04 14:09:13 UTC (rev 7838)
+++ trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs	2013-09-05 09:51:05 UTC (rev 7839)
@@ -404,6 +404,32 @@
             DoFindReplace();
+        /// <summary>
+        /// Gets or sets whether this editor can support reloading XML content
+        /// from a source resource. If true, subscribe to the
+        /// <see cref="E:Maestro.Editors.Generic.XmlEditorCtrl.RequestReloadFromSource"/>
+        /// event to handle this particular action
+        /// </summary>
+        public bool SupportsReReadFromSource
+            get { return btnReRead.Enabled; }
+            set { btnReRead.Enabled = value; }
+        /// <summary>
+        /// Raised if the user wishes to reload the XML content from source. To handle this
+        /// action, read the XML content from the requested source resource and load it into
+        /// this editor
+        /// </summary>
+        public event EventHandler RequestReloadFromSource;
+        private void btnReRead_Click(object sender, EventArgs e)
+            var h = this.RequestReloadFromSource;
+            if (h != null)
+                h(this, EventArgs.Empty);
     /// <summary>
Modified: trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.resx	2013-09-04 14:09:13 UTC (rev 7838)
+++ trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.resx	2013-09-05 09:51:05 UTC (rev 7839)
@@ -205,6 +205,18 @@
   <data name="btnFindAndReplace.Text" xml:space="preserve">
     <value>Find/Replace</value>
   </data>
+  <data name="btnReRead.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+    <value>Magenta</value>
+  </data>
+  <data name="btnReRead.Size" type="System.Drawing.Size, System.Drawing">
+    <value>133, 22</value>
+  </data>
+  <data name="btnReRead.Text" xml:space="preserve">
+    <value>Reload From Source</value>
+  </data>
+  <data name="btnReRead.ToolTipText" xml:space="preserve">
+    <value>Re-loads the XML content from the source resource ID</value>
+  </data>
   <data name="toolStrip1.Location" type="System.Drawing.Point, System.Drawing">
     <value>0, 0</value>
   </data>
@@ -405,6 +417,12 @@
   <data name=">>btnFindAndReplace.Type" xml:space="preserve">
     <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
+  <data name=">>btnReRead.Name" xml:space="preserve">
+    <value>btnReRead</value>
+  </data>
+  <data name=">>btnReRead.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
   <data name=">>nodeNumericUpDown1.Name" xml:space="preserve">
     <value>nodeNumericUpDown1</value>
   </data>
More information about the mapguide-commits mailing list
