[mapguide-commits] r7847 - trunk/Tools/Maestro/Maestro.Base/UI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Sep 6 09:00:56 PDT 2013
Author: jng
Date: 2013-09-06 09:00:56 -0700 (Fri, 06 Sep 2013)
New Revision: 7847
   trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.Designer.cs
Add missing context menu for granting/denying user/group access to a given resource in the Site Explorer. Patch by Crispin Hoult.
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.Designer.cs	2013-09-06 15:23:24 UTC (rev 7846)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ResourcePropertiesDialog.Designer.cs	2013-09-06 16:00:56 UTC (rev 7847)
@@ -169,6 +169,7 @@
             this.columnHeader1,
             this.columnHeader2,
             this.columnHeader3});
+            this.UsersAndGroups.ContextMenuStrip = this.securityContextMenu;
             this.UsersAndGroups.FullRowSelect = true;
             this.UsersAndGroups.Name = "UsersAndGroups";
             this.UsersAndGroups.UseCompatibleStateImageBehavior = false;
@@ -701,26 +702,31 @@
             this.inheritedAccessRightsToolStripMenuItem});
             this.securityContextMenu.Name = "securityContextMenu";
             resources.ApplyResources(this.securityContextMenu, "securityContextMenu");
+            this.securityContextMenu.Opening += new System.ComponentModel.CancelEventHandler(this.securityContextMenu_Opening);
             // readWriteAccessToolStripMenuItem
             this.readWriteAccessToolStripMenuItem.Name = "readWriteAccessToolStripMenuItem";
             resources.ApplyResources(this.readWriteAccessToolStripMenuItem, "readWriteAccessToolStripMenuItem");
+            this.readWriteAccessToolStripMenuItem.Click += new System.EventHandler(this.readWriteAccessToolStripMenuItem_Click);
             // readOnlyAccessToolStripMenuItem
             this.readOnlyAccessToolStripMenuItem.Name = "readOnlyAccessToolStripMenuItem";
             resources.ApplyResources(this.readOnlyAccessToolStripMenuItem, "readOnlyAccessToolStripMenuItem");
+            this.readOnlyAccessToolStripMenuItem.Click += new System.EventHandler(this.readOnlyAccessToolStripMenuItem_Click);
             // denyAccessToolStripMenuItem
             this.denyAccessToolStripMenuItem.Name = "denyAccessToolStripMenuItem";
             resources.ApplyResources(this.denyAccessToolStripMenuItem, "denyAccessToolStripMenuItem");
+            this.denyAccessToolStripMenuItem.Click += new System.EventHandler(this.denyAccessToolStripMenuItem_Click);
             // inheritedAccessRightsToolStripMenuItem
             this.inheritedAccessRightsToolStripMenuItem.Name = "inheritedAccessRightsToolStripMenuItem";
             resources.ApplyResources(this.inheritedAccessRightsToolStripMenuItem, "inheritedAccessRightsToolStripMenuItem");
+            this.inheritedAccessRightsToolStripMenuItem.Click += new System.EventHandler(this.inheritedAccessRightsToolStripMenuItem_Click);
             // ResourcePropertiesDialog
More information about the mapguide-commits mailing list
