[mapguide-commits] r7857 - in trunk/Tools/Maestro/Maestro.Editors: . Generic/XmlEditor/AutoCompletion Properties Resources
svn_mapguide at osgeo.org
Sat Sep 14 09:01:22 PDT 2013
Author: jng
Date: 2013-09-14 09:01:22 -0700 (Sat, 14 Sep 2013)
New Revision: 7857
Added:
trunk/Tools/Maestro/Maestro.Editors/Resources/document-code.png
trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditor/AutoCompletion/XmlCompletionDataProvider.cs
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
#2360: Add icons for XML auto-completion
Modified: trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditor/AutoCompletion/XmlCompletionDataProvider.cs
--- trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditor/AutoCompletion/XmlCompletionDataProvider.cs 2013-09-11 06:51:26 UTC (rev 7856)
+++ trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditor/AutoCompletion/XmlCompletionDataProvider.cs 2013-09-14 16:01:22 UTC (rev 7857)
@@ -55,26 +55,19 @@
this.defaultNamespacePrefix = defaultNamespacePrefix;
DefaultIndex = 0;
+ static ImageList smImageList;
- public class XmlCompletionDataImageList
- XmlCompletionDataImageList()
- public static ImageList GetImageList()
- ImageList imageList = new ImageList();
- return imageList;
public ImageList ImageList
get
- return XmlCompletionDataImageList.GetImageList();
+ if (smImageList == null)
+ smImageList = new ImageList();
+ smImageList.Images.Add(Properties.Resources.document_code);
+ return smImageList;
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2013-09-11 06:51:26 UTC (rev 7856)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2013-09-14 16:01:22 UTC (rev 7857)
@@ -2288,6 +2288,7 @@
<Content Include="OdbcDriverMap.xml">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <None Include="Resources\document-code.png" />
<None Include="Resources\document-search-result.png" />
<None Include="Resources\arrow-split.png" />
<None Include="Resources\folder-horizontal-open.png" />
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2013-09-11 06:51:26 UTC (rev 7856)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2013-09-14 16:01:22 UTC (rev 7857)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:4.0.30319.18047
+// Runtime Version:4.0.30319.18052
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -417,6 +417,16 @@
/// <summary>
/// Looks up a localized resource of type System.Drawing.Bitmap.
/// </summary>
+ internal static System.Drawing.Bitmap document_code {
+ get {
+ object obj = ResourceManager.GetObject("document_code", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
+ /// <summary>
+ /// Looks up a localized resource of type System.Drawing.Bitmap.
+ /// </summary>
internal static System.Drawing.Bitmap document_copy {
get {
object obj = ResourceManager.GetObject("document-copy", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2013-09-11 06:51:26 UTC (rev 7856)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2013-09-14 16:01:22 UTC (rev 7857)
@@ -144,17 +144,17 @@
<data name="blueprints" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACLklEQVQ4T4WSTUhUURTHz8q2
- BW2azURMJFkQBIEQjqsoaJHmQIuWWREMlZl9qOnCTS6UgoohZ1pUZpPDUFEUVkrqaM2FMiVnkomk6cOQ
- t3Dec56r0/lfmsfzMdWFH9zLfed/fufyKBhboNpbvzTY/zlH5KzKURUKBbY2NFBlfT1tqaujUoETUtP3
- gwTVNlnkxNwKnxle5lMvinxyqMiHB/IsxceEwF8DYLA7klfJ3AqPfrV54KPF/TMW3/lg8YG+DGNJ8XFh
- s9tglXIw+tPaf2+RQ/FFPprI6pATTw2u6U45+MLPlEDQ/adyy+0n3JjIcPfEkg6BCcbZdTWnBILuf5XD
- 0UfcOJjh8HNDj4M32dmTVQJR9fV5oC6mTI7P4tIoq1zVPurc4WF3XJ5RAhE0oNM6UeB4xnJCvMp7o/N8
- +qXB96VJy2uLt3W9UwIRNKDTNlngsbzNTa8Mvjll6m5u5dobOafB+TGTKzvTSiCCBnTa3xR4MGvxAwEh
- 6FYaB8r7InPyTxg65MK4yYHWlBKIoAGdS28LPP7N5uYRQ3/Yk15apbzn2qxuAMtkzuaNZ0eUQAQN6HSk
- xeCTpQNi06bTDQ8L5ereaYblw882d6plXn8kqSp824mgAZ0O6ZiQgFIIurmV/c3D1pqDMVWiIniun4g2
- 0YZDVwg6j7/YnPpu6xCMggC3sr9paEoKfB7WyZnWQqfrvckIgQnGwZt4leVbXeBdftG569Yrt3eUPdW/
- Ab7ReT9BDLTyAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACIElEQVQ4T4WQTUhUYRSGz8q2
+ BW2azURMJFkQBIEQjqsoaJHmgAuXWREMlZn9qOnCTS6MgoohZ1pUZpPDUFEUVkrqaM0HZUrOJBOJ0y9y
+ F869znX1ds6Hc7kzTHjg4d6Pc897nu+SP/KHau/+1cj72jnEqHJUBQK+nQ0NVFlfTzvq6qgoQKjp/yWo
+ jqk8YvOrODeygjOv8zg9nEfTYBY8fILx/TdAzvtDWRXPrGJs0cbgFwsDsxbuf7ZwpD8FKR4+yWx3BxQp
+ +8O/rcMPlxCILuF4LK1DTr0wUNObcPAEXyqG1lVuu/cczbEUeieXdYiYSG/fjYxiSHTXVQ6Gn6J5KIXg
+ K0P3ZMHevrRiiKpvLQjqcsJEdE6aRlnlqs4xpyeWe67OKoZINESnfTKHaMpyQkqVD4YXcPaNgUfcb3tn
+ YVfPR8UQiYbodEzlMJ610fLWwJ1pU4e4lWtvZ5wFF8dNVHYnFUMkGqLT+T6HobSFx4yEyDa38qHQPD8N
+ HXJpwoSvPaEYItEQnSsfcpj4YaN11NAf9iWXi5QP3JzTC8QynrGx9fyoYohEQ3S6kmzw1dIBkRnT2VZQ
+ rr42A7F88s1Gt1rB5mNxVeHZTSQaotPFG2McUAiRbW5lb+uIteFoRBWo8F8YIKJttKXxOonOs+82Ej9t
+ HSJXkQC3srdleJoHPCVsYmij6PR8MiEhYiLXkX9SqlwYKC0v6zxw65XDUS4qon++0Xk/qAJ7LQAAAABJ
+ RU5ErkJggg==
</value>
</data>
<data name="icon_clearselect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -175,16 +175,16 @@
<value>
YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACLUlEQVQ4T52ST0iTYRzHn0vB
- qK4h3YQu4aEOFmMYmQ461ASTdRDyojRzltFbzFZrik2DIKJDdik6dAg6BHXokIo61prOVzfX2GROUZes
- xXRs7/64d/v2/F7aG4MdxAe+vL/fC58vH573ZUa73cBz44AxsA6bzYQDHmJZu9XaW+YFei/QOl9Gy1wJ
- Fz0yLrj3cN6VR5MzC92sBO10GuemUjg7uYvGiR0QQyxrs1j65HJZKXiahFLgSMh48ruoFNhjWdg2M0qB
- dT2FweiOUkAMseyyIJgLpZJq0CNKcPgTGFmKY1jcxpA3hsfzW3jk2YDVvY4H39cw6IqCGGLZpYGBWzlZ
- Vg1G/X+wx3eKKxhU52mfT50nFhZADLFMbzbfzhSLqgEVeFZW4A6FsBSNwhkIYHZ5GV7+bmpxEZOiCCpQ
- GM6yZpPpTqpQqDKQ+E4hg8pMBpWZCoghljV1d99N5vM1DcTVVdVgLhyuMiCGWKbt6hISuVyVQYrvFDKo
- zGRA8+hMEs+/BUEMsayxs/N+PJutaeCNRFSDH/xO6A6uvoso+Rjgn5Oz7IzRaPklSVUGSb5TyODh5zUY
- 34Rx5ZVfeVLGY0AHf57uf/GBnTIYrFuZTE0DKmh95sbLTaDvJ3Dd9z9CCDh572uM1el0w3F+oxvpdM30
- v/eh2TFTFa2L/7FjTtS1C5+Ypr7+5pGGhrH95ti119uUoy09X4hl/Gh4jvOc2E8Ot42/PaQf6f3HaP4C
- dRjFo//0njYAAAAASUVORK5CYII=
+ qK4h3YQu4aEOFmMYmQ461ASLdRDyojRzltFbzN5aS2waBBEdskvRoUPQIahDh1TUsdZ0vrq5xiZzirpk
+ LWZje/fH/fn2/F7YGy/sIL7w5fn9Xvh8+fC+DzM7HCae6/uMiV2x2y3Y50Ms6xTFvipfjD6gfb6KtrkK
+ znvLOOfZxVl3AS2uHAyzMvTTGZyZSuP05F80T+yAGGJZh83WX65WlYKnKSgFzmQZT36XlAJHPAf7ZlYp
+ ENfTGIrtKAXEEMsuCoK1WKmoBr2SDGcgiZGlBIalbTz2xfFofgsPvRsQPeu4/30NQ+4YiCGWXRgcvJkv
+ l1WD0cAf7PKd4g6F1Hna71fniYUFEEMsM1qtt7KlkmpABd6VFXjCYSzFYnAFg5hdXoaPv5taXMSkJCkF
+ CsNZ1mqx3E4XixoDme8UMqjNZFCbqYAYYllLT8+dVKFQ10BaXVUN5iIRjQExxDJ9d7eQzOc1Bmm+U8ig
+ NpMBnaMzKTz/FgIxxLLmrq57iVyuroEvGlUNfvCdDC6/iyr5GOS/k7PslNls+yXLGoMU3ylk8ODzGsxv
+ Irj0KqCclPE4v4X8PDnw4gM7YTKJW9lsXQMqaH/mwctNoP8ncM3/P0IYOH73a5w1GAzDCf5FNzKZuhl4
+ 70erc0YTvZvf2DEXGjqFT0zX2HjjUFPT2F5z5Orrbcrhtt4vxDL+6HiO8hzbSw52jL89YBzp4zNnmO4f
+ dRjFo0T6AokAAAAASUVORK5CYII=
</value>
</data>
<data name="icon_panright" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -240,30 +240,30 @@
<data name="sum" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAtElEQVQ4T2P4//8/AyWYIs0g
- iweZAYyMjAxA3AjEa3BgkByKq1E4UAM4gXQPEK8HYh2oGMhgEBskRtAAkGKQIROAeAsQ6yEZokusASBD
- uIB4ChDvBGJ9JENwu4ABCqCKDYD0fiCeATUMZCgYI6cbVA7CACOgwqNAPBemGSQFZIPECRpgAlR0BogX
- gzTDXAWkYeJ4DeAEKlwPxA9x4A1AcS58XgAZIAzEUjiwKF4DyMlUA58XALSICQGuLQH3AAAAAElFTkSu
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAtElEQVQ4T6XMKw4CMRSF4Y6c
+ WoJhDbxC2CAegUBgUFiSQWBQKBybYCXlvzMl6UnahEKTLzPntPe6EMJfsmWNbFkjW9aQ0DSN2eBcYHcy
+ I8Eu0WKLDtPYGfu3TmYkJI9tyQ5XzGNnZvZNZyQkD43HHjcsYtdLZzTEEx8ucccBtqxqwQoPHNEPJ73O
+ SBjOmkdPnOBjZ+fT64wE51p0eBVc4GVGwrBghEnBGOUFv8iWNbLl94J7A7SICQEtnzdJAAAAAElFTkSu
QmCC
</value>
</data>
<data name="map--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC5ElEQVQ4T53STUzTZwDH8ecy
- E52e57yZnRaiWRZdCPHgYdHDhtMwdkA0MQ0UeauA0A55UQSRYJEgL4KCQIq2EMGmCgEE5K0DLGwoXUFR
- wLYgEtm0BSQi3z1PYrKYeDA+yef2+/6T////iNDMzGAp8jME/5qRIURIerqWzziqk4Q4lJoatS4fUNeX
- RtNQDn1jxTgn63BMtmF6OEb2oAdDj5eEVi9xNi/RjV7UXnWSEAf0+ui19XWudabQPmlk0FPOkKucxZVO
- /vZNYJ7zk2H3ctYJaQ6ItnpRe9VJQvyUlBSz+u4d5a0J3Hado/NpIa0jRp77brGwbGfgnxny70+R9whO
- P4BYmxu1V50kxH6dLm5lbY1iWwwVbYnU3kvFOpxL12ghD8ZrGZxoxuxykWWfJqVrBl3LDGqvOkmIH2Ni
- 4v1v33LxZhRmxymsY2cxdZ/iD/dlphYtvFzuoMPZgWXuNcYn6yS2T6P2qpOE2KvVnni1uorxeiQmu576
- kXSutidz98lFhmcrmX3VxLCrQb7KNJXuVQxdU6i96iQh9mg0iYtv3lBQpaWmO5m6QQOld3TcGT/Pvaki
- nC9qcYxV4vY7aF2Y53TPY9RedZIQgUePJi2srFBYGk1+dQQXzBGUNMdR1nyCqrsG6nuzsDtLcTysoW20
- hWONT2ka96E6SYhdYWHJ88vLFBfGYbIaqOk4yQVLBJbhNKzObPlrC2jsz8Hz701eLPXwS/UEh80efkip
- uPF9QpkQ34WG6meXlijJ12GpT6f2dgrnTRpMA3oa/sxAc93GvqJuDl4ZIOSqg59Lhyjzws4z/Z4dOX+F
- i2+Dg1M9fj8lefFcyo/HeCmKvEoNeXUajA1agrJtFLnlBZIX6cjo/5LG4Zvfex1ia1DQmXn5VZ/5fB8V
- axplb073BwL7YWvEjdmvY1vCxcbt249/GRCQ+6m2/HZ5TtkUGFa8efdhoc4m6Stp26fYcKCs6ot9uZHv
- O/EfeeONT9E6bWgAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC30lEQVQ4T53SW0hTcQDH8f9L
+ QbfnLm/RU0QRUSHSQw9RD2UXyh7sAjF05m2p6Zap3TQTW4l5yUpLmbUpaWOlqKlpudRmZbmmZalt00yy
+ y6Ymmd/+/6cIeogOfOBw+H0fzjl/EXziRJAU9h+C9qSmCrE7JUXLf1yqk4TYlZQUPiMflD1KpqojnUfd
+ uTj7ynD01WF62U1auwdDi5fYWi/RNi8RlV7UXnWSENv1+ojpmRmuNyZS32ek3VNIh6uQsclGXvl6MQ/7
+ SbV7OeOEZAdEWL2oveokIbbGx0dO/fxJYW0sd11naXyXTe1TIx98dxidsNP2eZCsJ/1kvoaTLyDK5kbt
+ VScJsUWni56cnibXFsmVujhKHyRh7cygqSubFz2ltPdWY3a5OG0fILFpEF3NIGqvOkmITZGRMf4fP7h4
+ Oxyz4zjW7jOYmo/z2H2Z/jELnyYaaHA2YBn+hvHtDHH1A6i96iQhNmq1R75OTWG8GYbJrqf8aQrX6hO4
+ //YinUNFDH2totNVIV9lgCL3FIamftRedZIQGzSauLHv37lQrKWkOYGydgP593Tc6znHg/4cnB9LcXQX
+ 4fY7qB0d4WTLG9RedZIQAQcPxo9OTpKdH0HWjVDOm0PJq46moPoIxfcNlD88jd2Zj+NlCXVdNRyqfEdV
+ jw/VSUKsDQlJGJmYIDc7GpPVQEnDUc5bQrF0JmN1pslfe4HK1nQ8X27zcbyFHTd62Wf2sD7xyq01sQVC
+ rA4O1g+Nj5OXpcNSnkLp3UTOmTSY2vRUPEtFc9PG5pxmdl5tY/c1B9vyOyjwwqpTrZ6V6c/3i+VBQUke
+ v5+8zBguZcVgvBROZpGGzDINxgotgWk2ctzyAMmDdKDrt/geWHbsoUMsCgw8NSK/6nuf76+iTF1sTG/+
+ Q0ArLAq9NbQ4qma/mLN06eF5K1Zk/KsFey8PK3MDQnLnr9sn1DVXWigt+ReztxcUz9qcESbvZSfEL3nj
+ jU/YIEHvAAAAAElFTkSuQmCC
</value>
</data>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
@@ -273,15 +273,15 @@
<data name="application-import" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABx0lEQVQ4T6XUPWgaYRgH8Afc
- LIJjySiCOOrkopOCDoKKDiV0jW0phVJoh1BwcXdyUgRxEAQHEYyIuly0EZJKk+LgpPj9gYKC4te/7yMI
- BQ0Y8sKPO47//+55D+4IAL0Gud3uPY/HoxLeCVdn4qyKXC7XwWWpVHqq1+uo1Wp4fPyDh4d73N39wu1t
- CZJUFscKyuXfqFT+4uZGehLdS3I4HAcfc7kcstksMpkM0uk0UqkUkskkEokE4vE4YrEYotEoIpEIQqEQ
- ZDLZFY9+4BXv4kVLdL1ktVrJ6XSyD9vtVoxXQT6fR7vdxmazeRZnuUMmk4ksFgvZ7fZPq9VqPzYvSZLQ
- 6/WwXC5P4ix3yGg0esRNvjLeJ+v3++AnVKtVjEYjzOfzI4vFAjab7TPpdLofpza+Xq/BodlshslkcoSv
- m83mL6RWq9+rVKqfLBAIgLVaLfCIxWIRjUYDw+HwyHQ6BU9Nosg3IYPB8G08HsPv92O32yEcDu+30Ol0
- TuIsd0ir1ZJer2ffB4MBgsEgfD4fCoUCms3mszjLHdJoNAfXPGq32z0LZ0X3muRy+Z5CofAqlUr/S3CH
- /ltycf5WuDgTZ9+86lPm38A/lieNoGpgVUMAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwklEQVQ4T6XTPWgacRgG8Bfc
+ LIJjyHgI4qiTi04KOggqOoSSNWlLKZRCO5SCi7uTkyKIgyA4iGBE1OWijZBUmhQHJ8XvDxQUFL+e3nsg
+ lGjA0Bd+HBzPc//3PxwB+C/k8XhkXq9XkFxIrk7EWYHcbvfe21Kp9FSv11Gr1fD4+BsPD/e4u/uJ29sS
+ RLEsPSsol3+hUvmDmxvxiTvkdDr33udyOWSzWWQyGaTTaaRSKSSTSSQSCcTjccRiMUSjUUQiEYRCISgU
+ iitefe9autOrhjtks9nI5XKxd9vtVlqvgnw+j3a7jc1m8yLOcofMZjNZrVZyOBwfVquVvDaPKIro9XpY
+ LpdHcZY7ZDKZvNJHPjO+J+v3+/IJ1WoVo9EI8/n8wGKxgN1u/0h6vf6bfOSzWa/Xcmg2m2EymRzg9xaL
+ 5RNpNJpLQRB+sEAgANZqteQVi8UiGo0GhsPhgel0Ct6apCJ/hIxG45fxeAy/34/dbodwOCxfodPpHMVZ
+ 7pBOpyODwcC+DgYDBINB+Hw+FAoFNJvNF3GWO6TVave+82rdbvcknOUOKZVKmUqlular1f7X4A79M0rJ
+ meT8RJx9c/QXPR3oL5YnjaBUK8UhAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_plotdwf_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -320,34 +320,34 @@
<data name="database--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACQUlEQVQ4T5WST2iSYRzHn5qK
- Hhq1oMLLoINsbC4wki6CXUZ/NsHES0SnGhTrFJIDDy47OnaoLd6pzbk5nU77N6evUzcyK927IQt0NMrt
- jd7I/hBdOn573rEO5qL5wIeHh9/v+4Xny5eYzWayQy+9+/aIuLut+yMmBoOhr1qtolKpoFQqYW3tDdLp
- V5ibyyGVWkU+v4Fy+TME4Rfo7g2j0UhEagwEQUCxWKTCNFg2icnJCFzuMKYDCSTYApa5d9jifzZgMBXB
- GDXwB+cRT75GgdvAJv+jEYNZMJ4ZTAVjmE++RJ5bR4X/9k+Dk/39/c9cLhcYhsHw8DBsNhusVivsdjuc
- TifEmcViidMMtLtm8HeIqUwOT+YXEU/nkC0Usbb+HpvC171/wecP48G4H95QFE8XMsitFLHBf2zAYDqE
- 0fFJjIfCeJxawIuVFbzl+QYMAiGMeCfwMDyDR6kEeuOX0RHTQTnUllUPaEn7bU1ND/4bYqvvBK5+t0Di
- PVomE4cJ8bQQYjKZtunp6alrYmopi0g8gQvRS1AFTqF95jTMX/ogHz22RcUccbcwRKvVku7ubqLX66/V
- NpGFLxjEPZ8HrWNdOPPpYh1k5CBHxKNSqYharb6+u4EbOuYsjo92QTWmQSevg/TuIZ44mzky1MyIegXl
- iFKpvFXXg6XnmE3MIboYA7ucQdt9DZSVDjRZD3wQNTtaQpMgnQqF4qZcLh+USqWDEolE5A7FQd8OmUzm
- oDNH03nZ6r4rMmH/OSkraigtvwEKQSNnrT8HPgAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACN0lEQVQ4T5WQTWiScRzH/zUV
+ PTTKoMLLoINsbC4wki4Du4xeNsHES0SnEop1CsnBDi47OjzUjMeXdDo3X6a9+T51kVnpHocYzJGU2xM9
+ kb0QXTp+e55RwdqC+YfP4c//9/3w/32JXq//wyiHYZfws5u5vwKNRmNot9totVpYXV1Fvf4a+fxLxOMl
+ 5HIrKJebaDQ+gWV/gpu9ptVqCc8WAcuyqNVqXDCPTCYLvz8KpyuCufk00pkKlum32GB+dCCYjcLBCQLB
+ JFLZV6jQTawz3zsRLIByhzAbTCCZfYEyvYYW8/W/guNjY2NPnE4nKIqCzWbDxMQETCYTzGYzrFYr+Dej
+ 0ZjiZlU7/uDfEnOFEh4ll5DKl1Cs1FBfe4d19svuV/AFIrjnCcAbjuHxYgGlag1N5kMHgrkw7B4/POEI
+ HuYW8bxaxRuG6UAwH8a0dwb3IyE8yKUxmrqI/sQQZFO9RcW4ivTdVHZWYo/vGC5/M0LgPdwgMwcJcUsJ
+ 0el0m4yMjGwv8WkR0VQa52IXIJ8/gb7QSeg/GyC2H9ngwjRxSSmiUqnI8PAwUavVV7aukIEvGMQdnxs9
+ jkGc+nh+G2R6P034I5fLiUKhuLqzwIUh6jSO2gchdygxwAxBePsAQ6zdNJnqpvi8hOOQTCa7sX2FZ1hI
+ xxFbSiCzXEDvXSVkrX50mfa95zO/s4RrggxIJJLrYrF4UigUTgoEAp5bHBbubhGJRBbuzdJ1VrSy55KI
+ 3XtGmOEzhBDpLwpBI2fkOXsyAAAAAElFTkSuQmCC
</value>
</data>
<data name="printer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACYklEQVQ4T42SX0hTYRjGX1To
- omIggdDVLvJi5o0IJjrI5ZgtNuG4KVsodtPZGSNScirHzY2mTIQSDPVK8MKBN6JSyVTUGAkTuqyLBInU
- iQRZ+OdChz5978nBxJTew+/84/c853zwkbO7mzLUh0J2gXwJdxzBIEldXecgfpmF51c6jdTBATb29/F9
- b09jJpGAcDyCwgsFkqpSFsrvoyNs7O7i684Ovmxv43MqhdjsLHiEp1hbW/UmRSGmzuMhcjgcVCfLVNvR
- wXj3j4/xQ3w1u+TN+DgyFFqtAQE9qK/XstrJ6XSSo6mJbG1tvgNR8PPw8EIJ/wkvhx12tcxZQY54sAs8
- eXl5r/x+P66CHXY5IwpySJKkW6qqhnbEmhVFQSQSQTAYvEAgEEA4HNacra0tdHZ2hjhLNpvNMDg4OLa2
- tgaXy4X29nbIsozm5mZIUh2qq82orDSirOwerNZHmjM3t4yent4xzlJNTU3V5OTk8urqKsxmswh7YLFY
- YTRWieD9c5jNDzVnZmYBAwPDy5wlk8nkSiaT60tLSygpKUFDQ6OQ7P/EYqnVHFkcExPv1zlLFRUVz+Lx
- OGKxGPR6PZzOJ7DbH18KO6Ojo5iamgJnqbS01J9IfMT0dBw+33P09w+jr28I0ehwFiPi/i9ebysWFj5p
- cJYMBoO6uLiC+fkVuN3u/yJTwFnS6XQt+fn5vUxubm5fSmyY6mgKr9+mMPTuAypfuHG3UYXRO4Jvm5tg
- J+NzlsTcFNxmCsrLX2qbPmtOTk/BpE9OkBZXdjL+WZY7iK4VFNCN4uKn14uKolfBDruZ+QOvqgI74xfB
- qAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXklEQVQ4T42ST0iacRjHf6xg
+ h20EMRB28rAOti4htDBhOcXm0OBVCx2Fu+xVkbFiafKmGaswgi1wVKegQ0KXKNkWVlRDFiTsuB0WxFhp
+ xGBt9OdQUt/9nrcUoxV7Xj7K6/v5PO8rvMze3V2gKRKxcMRLuGsLh5nQ1XUORj8W4f6dyyG7v4+NvT38
+ 2N2VSaRSoGucigsLBEkqxvPn8BAbOzv4tr2Nr1tb+JLNIj47Cxq6bmpvV+o8HkZY3W7+BDYbs4oia+zs
+ JLx7R0f4ye9avOTtxESBCpMpxGEPm5rkVv6w2+3M1trKzB0dvn2+4NfBwYUl9CT0d8ghV27OFlzjJxaO
+ u7S09LXf78dVkEMuNdQyQRBuS5IU2eZ38ng86O3tRTgcvkAoFEJPT4/sZDIZBIPBCLXMbDarYrHY+Nra
+ GhwOBwKBAERRhMvlgiBYodcbUFenRU3NfZhMj2Vnbm4ZfX3949SyhoaG+qmpqeV0Og2DwcBjN4xGE7Ta
+ eh4+OIfB8Eh2EokFDA2NLFPLdDqdY3V1dX1paQnV1dVobm7hkuWfGI2NsiPyY3Lywzq1TKPRPE8mk4jH
+ 41AqlbDbn8JieXIp5IyNjWF6ehrUMrVa7U+lPmFmJgmf7wUGB0cwMDCMaHSkiNECXm87FhY+y1DLVCqV
+ tLi4gvn5FTidzv8iv4BaVlZW1lZeXt5PlJSUDGT5C6OPZvHmXRbD7z+i7qUT91okaL2j+L65CXLyPrWM
+ zy3OHUJRW/tKfumL5vjkRCZ3fIwc/yYn75+1p3NdoWA3q6qe3aisjF4FOeSeDmN/Aa+qAjvcCoH6AAAA
+ AElFTkSuQmCC
</value>
</data>
<data name="icon_measure" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -389,19 +389,19 @@
<data name="database_share" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACqklEQVQ4T5WSa0iTURjHz6oP
- Db8EpfghDLpRKH5RhBXJGIE52VzNVaybEGibFZZ9UNIuGDgIxRRzF3NL1FDx0tzm5iWdl3nZ61Rkajd1
- inOogRJlkPDvvAMTh4Ed+MF5Xt73d97n/xwik8lIACJap+wC9j0S+DERi8UpS0tLmJ6ehtvtBsOMwmzu
- hdU6hL6+SfrMi4WFnxCJREqJRLKzwOv1wuVyob29HSaTBbqyWhgqjGg29WJg8CNmPav/K6iBvqIJRnM3
- +ocmMOP5tiXg8xO2tUFbiFIoFM1arRZqtRoqlQqZmZnIzs7270tLS5GRkdFCW4jxtxASEhMoCMhgBKYW
- O0y2HnQ5hjHi/ozZheWtPyAkfJuEDTEwA62+GrrKGtRbrOh2Mvjkmd8uYCWbo9xJoNFXQVv1DnUtZnQ5
- BzE1N/NvQXLiuV1lIBQKYxISEghd4cMsUqk0lcUgP2gbe6OEU6uEqyEfTocdzbYONLbaYOu3Y2DChSnv
- V/D5/FSBQEBIenoRJJKH2NjYgNFoBL7U+Pk9WYn51jy0qpJQnnsbakMxqqz1aGM6MT43gcjIyLQs4WFC
- 4uPTwONdh8/nQ3V1NdZdOqz1Ff3lB6PBVH0WGp/Go+r1Ixhr82EpkKNQxHV0JO9Tkujoy4iISPRfXY1G
- g+8DJRgtT4O94BraVDKMGe5h+cNL/KLit/fPgCm7g1V6AFs3yffqSFycAlFRMiwuLiI0NPT5K2nw+GDJ
- jRXP+ydgNCmw5Eqgv8uDNjUanflyzBtz1nvyLrgbFMe69Bf3XKEhnlhjCQoKyuNyuQ/OhpGbj2NJXeGl
- Q+OOwqsrPksuNmHr4qTgkRcCTsn5oxye+BSHnQIJo5ymRFCOU05SoqjoFit6xifMJjmxpDb2CKH3lxyg
- 7Kdw/gAsOxzv+3rD2AAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACnElEQVQ4T5XRa0hTYRzH8WfV
+ i4ZvglJ8EQbdKBLfTIQVyRiBubG5mqtYVwi0zQrLXihpFwwchGKKuYu5JW6h4qW5zc1LOi/zsuNUZGo3
+ dYpzqIESZZDw65yBicvCXnzhPIfDh/P8/0Qmk4UmokvZRsx35A9ALBanLCwsYHJyEl6vFxQ1DKu1G3b7
+ AHp6xul3fszNfYdIJFJKJJKtAb/fD4/Hg9bWVlgsNujKqmGoMKPR0o2+/veY9i3/L1AFfUUDzNZO9A6M
+ Ycr3ZQPg8YShAEehUDRqtVqo1WqoVCpkZmYiOzs7+FxaWoqMjIwmGogLAhERcaFAyAyGYGlywuLoQodr
+ EEPej5ieW9z4A0JObEK2uoJWb4Kusgq1Njs63RQ++GY3A0z/AjR6I7TGN6hpsqLD3Y+Jmam/AzeSTm9r
+ BgKBIE4oFAaBQSapVJrKZJDvdYy8UsKtVcJTlw+3y4lGRxvqmx1w9DrRN+bBhP8zeDxeKp/PJyQ9vQgS
+ yX2sra3BbDYDn6qC/RyvxGxzHppVySjPvQm1oRhGey1aqHaMzowhJiYmLUuwn5DExDRwuVcQCARgMpmw
+ 6tFhpafod98oDSZqs1D/OBHGlw9grs6HrUCOQhHb1XZjl5LExl5AdHRScG0ajQZf+0owXJ4GZ8FltKhk
+ GDHcweK75/hBw6/vngRVdgvLNMycG+Q7dSQhQQEOR4b5+XlERkY+fSENH+0vubrke/sIlCYFtlwJ9Le5
+ 0KbGoj1fjllzzmpX3llvneJQh/7cjov0EI+sMIWFheWx2ex7p6LItYfxpKbw/L5RV+GlpYAtF+sx5+Lk
+ 8KFnfFbJmYMsrvgYi9kCiaI7ThdNd5juKB2Hhq4z0BMeodbLiSfV8QcIs/w9dLsJIaxfLDsc751acxMA
+ AAAASUVORK5CYII=
</value>
</data>
<data name="icon_selectpolygon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -415,16 +415,16 @@
<data name="images_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T6WRXUiTURjHz03o
- lK0EE1SwL9JCvJj4dZF14S5sMEVJB13YRYiitpjKbt7cuhGxZJDlLoKapkwqxUVRM9YkEwTPhR8QTENE
- /ID0ItLEhrp/5znqcFim+MKf83J4nv/v/fEyAOw4YSVWK7vR0LD3NIi7ikPGEFZQYrOxIkWpFF+E4H9C
- MzS7j1ysKK5+zvH86bV/5pUzA5vBIAwWS5UsOCr5hVOH31tbuG4211CBdN4l6x9wFLRwFNs5DA85bj7m
- uOXguNfN0ebxS7KrS49fGxvQVVebjuTc+WlEkjvaC/EjEMDV8nIzIw9qHe2N/UtOh+5o5uXAsCQ3N2Vh
- eX0dOWVldYw8qHWs7yz875Mw+WE7Ux/PYHrgPL55z2HSkyTJLq9Pku+atFhcW0O60Whh5EGtt3VX4LRl
- YO7zJcwPXsbyRDYCK0b8nNFhYShVkq2vvZLscLuxJIpS9HqFkQe15iYmoiAtFfY76ehpyYR/uFT86Uas
- fDdhdjBbkmvb+yX5Yn6+75RW26hOTq5g5EGtbnuUSDTePlLjXasGX1wxWPiagHFPHHzPToaRL+TlNTPG
- EkRUjDyo9UltZChtdSo476sw9EaN3tYoOOoj95FPaDRiXzzkQT7zq6sHhmbCyNvrjJEH+RwmNBsi7xaI
- M0IkfseJvA6Kas+efP0DD+tcAk1PV7wAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB7UlEQVQ4T6WPTUiTcRzH/5fI
+ GVsFKaRgb2SGeJhYdsg8uIMNpiTpwIMdRJTUxTR2eXLzIuILAy13CHJasuhFXCg6Y058gYH/QyUIs4iI
+ NDAPoiY2zH37//6iOWa+9YMPz3N4ns+HLwPwX7B8q5XdrqnZ/jQISveJIUyQb7OxW4pSJswI7QEdfRtR
+ zlMU1yDnaH+c+U9eOtPwOxSCwWK5e6jyU6cOv9bXcdNsrogo6xs5cpo58uwchiaOwoccdxwcD55ztHkC
+ suzq0uPn2hp05eWmA5WfDU3IcmdHLhaCQdwoKTEz2kHWd92ndiBm652+eTHsl+WG+quYX13FtaKiakY7
+ yPq+5ywC/QmYHtjg49sz+Dx8Hp+85zDtSZBll9cny/dMWnxfWUGq0WhhtIOsxbrrcNrS8G0kCTOjlzE/
+ mY7gkhGLX3SYHU+WZesrryw73G78EKJLer3CaAdZM+LjkZOSDHtlKl43X0HAXyBW12FpzoSvo+myXNUx
+ KMsXs7N9J7TaOnViYimjHWR126MFx9DbokZfqwZjrpOYnYrDB08sfE+Oh5UvZGU1MMbiBCpGO8j6qCpq
+ i7ZqFZy1Koy/UaO7NRqO+1ER5SMajfhfHO0g68zy8q5ElDePbGTdD2HlbXdUcFpA5r34W5bH2B8P61wC
+ XKQHIAAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_selectradius" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -448,76 +448,75 @@
<data name="edit-indent" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABjElEQVQ4T5XTS0sCURQH8OOm
- rVmL1E0UGhRWJqGGBUapQZE9NpWQSBBtg4i2EkF9iXa10srHFJHUWNGDgmhTqyjaRASt293+Z3AmXyM0
- 8PPO3Hse98oMCSHIYDCwOCQgWbCHcR8OIAVpyIIEW5zDucpPocC/x/IC3LlWV+oNrClcQ6vkHFzR3wEH
- qMHquLj5TaqFjS+Kxj/+CjQ7Y8Ts7iVlIbb+KSNI6OH1kgL983li3rlTCi8/MXH+8KOL1zlO+w/cMzkC
- 4RhP+z2zOeqLnMn8rIfXuaFWwB5KELyB4PvO8BG1j6YrdIxlyTl1yM2UHWsFbMEUgWgdTvjtoQyKZWR+
- Lsfz9pBEXRPH1DN9UrwDCUkStY1I1D15w6qen+cL60qctoNGW4RYvdlLjuAutvcqD0TfRTmedwR2yNjk
- Ib5030ST1UctrpUKJotPSVSv8gIy3sQ8XMAlXME13MId3MMjkp/hpeYO9L6NkvbFR8C9EUnbNbomEWMt
- sGBsgDrtCFwAzEVBanC1saTAL88kUjz8yRfZAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABdklEQVQ4T5XS3ytDYRgH8Gc3
+ bmdc2HYj2hQNs7RNoya2KTI/brCylpJbJbldUvwT7rjasF8k4viRH1Fyw5XIjaRcu3t9n7ft2I4dy1uf
+ Oud9nvf7vKcOCSHIYDCwOCQgmbcF27ADKUhDFnKwBvJsccC/aQMqTaXOwJLk6lskZ++C/g24odBcMLv6
+ qZpZ+aBo/O0noN4Zk+zuOVmILb8raBJ6uF4S0D19Inmnjig8/8DE6d2XLq5znxrgnjhkwjGc9nsmD6kr
+ cqzwux6u80A1wB5KsBcQ/Nwa3qPmwfQvLUNZco7tyoElAbZgionG/oTfHsogLKPwuxbv20M5ahvZp47x
+ g+Ib5KSmgRy1j16xst/O+/m6pAbU2iJStdlLjuAmrves9ERfhRbvOwIbZKzzEC81QPsfmKw+anAt/GKy
+ +OTBwtIGKHACZ3AOF3AJ13ADt3CPc4/wVC6gIu1SA7CMaFgHvalJsOZZoAaqSgLADIWmvxQFCPoGzyRS
+ PHSKlsAAAAAASUVORK5CYII=
</value>
</data>
<data name="gear--exclamation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACv0lEQVQ4T6WQbUhTYRTHn9sm
- IhbolwWlEqaYTEO2SGcfFiu1ph/UbZ8MxC+9EEUQjQwTkkyioMIFpWIpawVGoUyDTTfTeVfe5e5eTJfT
- llxfNoiSWIUUp+dsLhT61oUf53DO///n3IcAAPkfYma1Wk2qqqpITU0Nqa2tjVWtVqugnNpAsXmHWvQg
- WwKqq6tLqfAMrbuxrq+vQzQahc0z1PwzoLKy8pBer78biUSgoaHhChWdXV5eAgR7nOEONajdckFFRQWh
- nAuFQsBxk7C0JIDZbJ4TBAEQ7IPBYGyHGtRueOK/oFAoiFKpzNBoNM0eDw8874aFhXlYXPwUA3uc4Q41
- qEVPcXFxPKCkpERJBxeRnp7HQb/fBybTk5mCgoL7CPY4w11Ch56/ATKZTO9ycWC328DpZMHr9UJh4f42
- kUhEEOw9zuvAWVQwYb0MqEUPJX6BVCptdDgcYLVaAavP9x6KimQtDMMQRC6TtrpHNfA10gsTQ8fAMW4D
- 9FDiAbm5uWU5OTlNSHu74aPb7YeBgWG3XH7wKvLCpPcHPefhV7QP3ljKhZMnJEb0UOIBWVlZJDMzc49M
- Jr/Nsi4YGRmHQECA1dUfsLLyDdz2OviyfAd0Oh2EF5p/2kwik6OPEVPiARKJBGlhWR76+y0wNuYCg6Ez
- NDnphwl7B0zZtb/XhCYgVL4yexoGjXuF0WfMEfvTjYD09HRCOa5SlRk5bhby8vLvpaWltbKsD2wvdTA7
- Vfd9xlcOg+ZL4OUPwzu2dG3YyDyw9NIHwgvwE4vFJCUlRZ2amtqWnJycjZXnzOB8dRRCARXMT8tjF2Cd
- nz4Ar5/vcA51M6WJADFd7qTQZyVyJCkpqf7aBZGHH82OhufyIfxhH0Q/N8YqEnBmhPsfMl2JgG3UtJ0i
- oexK0NlKOiiuzXTdIFx3G3n76CZhe28Rwx+y4Aflu5kbswAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACvElEQVQ4T6WSXUhTcRjG/6dN
+ RCzQmwWlEqaYTEO2SGcXi5Va0wt125WBeNMHUQTRyDAhySQKKlxQKpayVmAUyjTYdDOdZ+VZ7uzDdDlt
+ yfFjgyiJVUjx9n83FwrddeB3npf3fZ6HcRgBgP8i9lKr1aSqqorU1NSQ2tramGq1WgXl1AaKzTf0YgbZ
+ UlBdXV1KDWeo7kZdX1+HaDQKm3fo+WdBZWXlIb1efzcSiUBDQ8MVajq7vLwECM64wxt60LuloKKiAjkX
+ CoWA4yZhaUkAs9k8JwgCIDgHg8HYDT3o3cjECxQKBVEqlRkajabZ4+GB592wsDAPi4ufYuCMO7yhB72Y
+ KS4ujheUlJQo6eIi0tPzOOj3+8BkejJTUFBwH8EZd3hL+DDzt0Amk+ldLg7sdhs4nSx4vV4oLNzfJhKJ
+ CIKzx3kdOIsKJqyXAb2YocQLpFJpo8PhAKvVCqg+33soKpK1MAxDELlM2uoe1cDXSC9MDB0Dx7gNMEOJ
+ F+Tm5pbl5OQ0Ie3tho9utx8GBobdcvnBq8gLk94f9JyHX9E+eGMpF06ekBgxQ4kXZGVlkczMzD0ymfw2
+ y7pgZGQcAgEBVld/wMrKN3Db6+DL8h3Q6XQQXmj+aTOJTI4+RkyJF0gkEqSFZXno77fA2JgLDIbO0OSk
+ HybsHTBl1/5eE5ro/5bAyuxpGDTuFUafMUfsTzcK0tPTkeMqVZmR42YhLy//XlpaWivL+sD2UgezU3Xf
+ Z3zlMGi+BF7+MLxjS9eGjcwDSy/9QFiAj1gsJikpKerU1NS25OTkbFSeM4Pz1VEIBVQwPy2P/QLU+ekD
+ 8Pr5DudQN1OaKBBTdlLoZyVyJCkpqf7aBZGHH82OhufyIfxhH0Q/N8YUCTgzwv0Pma5EwTbKdoqEsitB
+ ZyvpoLg203WDcN1t5O2jm4TtvUUMfwCy4AflZi15lQAAAABJRU5ErkJggg==
</value>
</data>
<data name="application--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABbklEQVQ4T6XUsUsCYRzG8ZdT
- BwdBl4ZGFycRnJycXBwEFYTiwFErIgihpamhqX9BRBBMEOTgSEShKfVCowSlBCchDxRRUDgR5en9jRUG
- b77wgZf33i+878EdA8D2wWKxmJM75hKCqHGyaDQqNxqN7mAwQL//gV6vh07nDe12G5qmgT9DvU6e+fwF
- zWYHrdY7KpWnLrUsHA6f1mo1VKtVvlhBuVyGqqpQFAWlUgnFYhGFQgH5fB65XA7ZbBaZTAbpdBomkylB
- V0jyd/CvQS2LRCIn2+0Wm81GCDXUslAodLZer7FarYRQQy0LBoPnhmFguVwKoYZaFggELhaLBWazmRBq
- qGV+v/9yPp9jMpkIoYZa5vP5UtPpFKPRSAg11DKv13s1Ho8xHA53epRlqG73Nw8eD24cDo25XK5rOr6u
- 6zvd881GPP7LncXyyWw2W9Jut9/+RTabX1OSpP90JEkK48PKHXCHgqix7vUp02/gC8LYywg0EW0TAAAA
- AElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABbUlEQVQ4T6XTv0uCQRzH8eNR
+ BwdBl4ZGFycRnJycXBwEFYTiAUf7QQQhtDQ1NPUviAiCCYI88JCIQlPqExolKCU4CfmAIgoKj4jy6b5j
+ P4yuDl5w3N0b7oZjAP6FxWIxJ7fPJQRR42TRaFSu1+udfr+PXu8V3W4X7fYzWq0WNE0D30OtRh74/BGN
+ RhvN5gvK5fsOtSwcDh9Vq1VUKhW+WEapVIKqqlAUBcViEYVCAfl8HrlcDtlsFplMBul0GqlUCiaTKUFP
+ OOBv+dOglkUikcPNZoP1ei2EGmpZKBQ6Xq1WWC6XQqihlgWDwRPDMLBYLIRQQy0LBAKn8/kc0+lUCDXU
+ Mr/ffzabzTAej4VQQy3z+XzJyWSC4XAohBpqmdfrPR+NRhgMBlvdyTJUt/uDW48Hlw6Hxlwu1wVdSdf1
+ rW74YSMe/+LaYnljNpvtwG63X/1ENpufkpKkf7YnSQrjw8rtcLuCqLF++0V/D+wdwtjLCFHUMDoAAAAA
+ SUVORK5CYII=
</value>
</data>
<data name="drive-upload" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACS0lEQVQ4T42OX2iScRSGD3QR
- C4QwiBH9WV3U0qLIiyyoNuyiG1FBRwwsRqtR4BZFuQXNbiRydNMgmEFrxC5WBJbZZvbH0pVuXwyJFBW1
- DWpaQYsIzVGn3yv7bGOw+n08cL5znvdwiObeirpdtKGlj3b2xEnbm6V9Nz5SQ/+n/QA1epjBgVt9qw60
- 0roj12nzxQjVXxr/u8D94ZAIShVELS+AAxcZZCs/MvKC3dcyCEi9ud98NfmLUaOHC+QFcmbRgh2udxCl
- nsQsd4Z/cEfgOzvGi4weZksu2OIYgyBdfvuTnbES2/yf2TKQ4uP3p7jlXpYxgzP/atpkf1ll4/kXfXXn
- gpJMx5NpNt6M8/wenPmZBQuESOvPPKW1pwNUe8o3ah0pFBtvZ4uo0cMMzoIFe45dIbC31UXbbYO0xjZC
- K4/eAbcO+r9F6u9+iYi6Hz3M4MCVc2QwGCqYTCayWCykazpJNU0DoH1rYNalfFB2oUYPMzhw5dyiBRAa
- zW20zOBuqH3MxuU+NqJGD7OlFijMZnOzoO0fNIsLFNUL9Ho9zWENhUKpWCzG0WiEg8FnPDz8iL1er+Ch
- wC94zkNDvpTwrXKONBoN6XQ60F4ul7lUKvHMzFfO56d5cvI9ZzIZQVYwxZKU4GQyz3CRQbby1Go1abXa
- s4VCgT0eDzudTnY4urmrq5PtdtAtcPIJ8UUiCYaLjPxqRLFapVJdEOfm0uk0JxJxnph4I+TXHA6HBaOC
- KAcCr9jtHszBRUaALCkF2xQKxWGlUun8H+Aig+wfdPytZLAK/bMAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACRUlEQVQ4T42OXWiScRTGD3QR
+ C4QwiBF9rC5qaVG0iyyoNuyiG1FBRwxWjFajwC2Kcgua3bxEjm4aBDNojdjFisAy28w+LF3p9saQSFFR
+ 26CmFbSI0Bx1+j/Sa47o4y8/OO85v+dBUt6Sum20pm2AtvbFSNefoV1X3lLj4LvdADN2uMGBW3nL9rTT
+ qgOXaf3ZMNWfm/xV4HqzTwTlMmJWCuDARQbZ8oeCUrD9UhoBuT/7nS8mvjFm7KoLFBZ84LjF+Qqi3Bef
+ 5+7QF+7yf2bHZIGxw+2vBRscExDk8y+/shQtss33nq1DST58e4bbbmUYNzjVGVpnf1ph7eknA3WnArJC
+ 14NZNl2NcfUOTnVmQYEQaPWJh7TyuJ9qj3nHW8fyhabrmQJm7HCDU52hHYculNnZ7qTNtmFaYRujpQdv
+ gGt7fZ/C9Tc/hMU8iB1ucOAqOTIajWXMZjNZrVbSNx+lmuYh0LnRP+9U3yk5MWOHGxy4Su63AtBk6aBF
+ Rldj7X02LfayCTN2yv1PBSqLxdIi6PgHLXArBQaDQaE1GAwmo9EoRyJhDgQe8ejoPfZ4PIK7Ap/gMY+M
+ eJNwlRw1NDSQXq8HnaVSiYvFIs/NfeRcbpanp19zOp0WZAQzLMtxTiRyDBcZZMtPq9WSTqc7mc/n2e12
+ syRJ7HD0ck9PN9vtoFcg8RHxC4fjDBcZ5dUIlms0mjPi72ZTqRTH4zGemnoh5OccCoUE44II+/3P2OUa
+ zsJF5meW1IJNKpVqv1qtlv4HuMgQkfoHdPytZP3hoKAAAAAASUVORK5CYII=
</value>
</data>
<data name="arrow-270" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T6WPT0hUYRTFPyYH
- QkkJMpgBNSYEiRY2SiAyFvhnUy0Cy4GeQpS6UDeaiQ4oucqVQiKOWIumRdMgWlHSX7UYXXhdCLpSU2FM
- Z1NYDI4gc7p3cOS9N86qD35c7jnnO+97CoD6H+KXrzzdMXD1WdjLkA6vOZP4aLzANbJlhgY3gP6VGJ6s
- A+yTOWMoKBnaVCaob/kAnrkoHi8dgD0yZwwFF3oXVPHAih56tBBFy4c/6JnfA3uk9yVvKMhr+6ryPUFV
- 2LeUgDxzETS8+YWu2QhYp4QnOcknFZxrn1LnO78raWeofWYXNb51NL4NQXbRxZdcygIxHR0zKr8rSHfH
- 1lAxQKj1r0J20cU/tiC39YuXW0mPO/ADZYOLuOVfg9mTvOEX7M2Tmq3pPTUHd3F9YhvXxn/C9WIThSOr
- KPVtoDIQQsWrEKrfhSE5yRsKWFTZ9RPamfvjdPvbX+T6wkmUT/6G+JKTfFIBmyqrzq9l1r6ksul9ZAYi
- R1z6GIXo4ksuqeDU5Tsq3elWGVXdKsPt09JrnlPBVAyW1zE4Pscgu+jiW20XlRzDC+LK4bGcLVBproea
- 9eYo2T8BMmUXXX+OK7ByIIdxMkUW570HlhvDJFP2Qxw8T6Z6wQk2shgbY0/BadbT9AX/ADWhA8f0EOn9
- AAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3ElEQVQ4T6WMT0iTcRzGf6wN
+ YkMlyGCDliwEiQ46IxDZErIu6UHwz6B3QaR50C6ViRsYdXKnBko0KQ/Og2uIVqj0d1lMD/48BHra/AfL
+ 3MWwGE6QPf2+Y4v3z3byB5/35fk+Dx8G4FhkP1de7SpoGEsGBFxGQL1RCByjP9XwkS3gWSyD4U2AsqpX
+ Cuqeb6vhvrUjeJfSGFo9AmVVrxRceLrCLvljcviTlTTuvf+Dx8sHoCzvaa8QnHvwhVV6o6zat5qHe5dS
+ uPt2D57FFCjnO9rRXiOo6Iuw8wPfs3YB71vYR0dwE93vEqBMd+ppV1RA2PoXWKUnym9PraPRz+EOxUGZ
+ 7vmNRmC9/zkgjlyOK7wB58gPtIXWoe5orxBYeuclc88c743uo2nmF25M78AxsY3q0Tjqg1u4Fk6g8XUC
+ rbNJ0I72CoE4svKuGel05zRv//YX1mBSw9X536CedrTXCETJym6FpFL3JHd+PURpOPWfmg9p0J162mkE
+ JZdvMqPdxUzXB5nJFZSMHeO8KpKB7k0Gtk8ZUKY79QbzRUZPIZA/3Zkqpnc8kgwtL7nlI0B/ynSXv0IC
+ g+CswC6o1dnvPNQ1v+D0p5zDJjgpKCg4ISgTmAWWIpwS6AU5Adg/NaEDx/iBYXYAAAAASUVORK5CYII=
</value>
</data>
<data name="icon_panleft_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -559,17 +558,16 @@
<data name="tick" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACHElEQVQ4T2P4//8/AyWYIs0g
- i8EGMEwXZGCYLcTAMAeIQTSIv0iYgWGpCAQvA+IVogwMK0XlGVaJngFiD4blIhC9OA2YCTRkPtAwEIYY
- JgDUtCHtXfl/IH0GiD1IMYCNYbHIPMNjzk+jHmX/j39Z8BvIP0OsAYwMC4RbFXYY3wu4kfjf+2rML54V
- cpcYFgr7oBvgAfT/GSD2AIfBZH5Y2GQKr1K54XY+/J/L2dC/AssVrwHDKhloKFIYTBMEaTqT9Kr4L4hm
- APFBBkwT9OGYK3FZZ5vtb7X15v/4FsjfAspXM8yABDrCBZP4z8Q8zf3lcSHyf8TDzD8MQD4Q57JMFT6t
- vMXkh+Imo//88+XvA8V6GKYIMDFMFWAAYYQBfXweDL18Z/xvxv9U2mP83+FCwA8QX2qT1mfpHTr/+RfJ
- PQHy5zH083MADQBrZvDmQDKgl4+BoYPXg6Gd94zxKedvEoc1/2ucsfwvfkjjP/8quVdA8XUMXbwCQAMY
- GLw4GGAA4QJ3dgaGVC4GhmZuD4Ym7jPSB7S+CJ9V+c+3TfY9YzPPboZWHmkGV6AaNIAwACahwMzAEM7m
- wVDEfoZrmdgLxjKOI0C+JoMcE4ZmkACyASAVQPcxyAOxLoMxUxpDPNMZBm3GUCBfE4iVgFgKiIFJkoEH
- iNmAmBHZAEagAMhzwNBhEIcqloSygZmAARhvDLxADPQnWDPQqUgGUJKdAYAsiHz3wn5/AAAAAElFTkSu
- QmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACE0lEQVQ4T2P4//8/RRirICkY
+ QkwXZGCYLcTAMAeIQTSIv0iYgWGpCAQvA+IVogwMK0XlGVaJngFiD4blIgQMmAnE84FsEIYYJgDUtCHt
+ Xfl/IH0GiD1IMYCNYbHIPMNjzk+jHmX/j39Z8BvIP0OsAYwMC4RbFXYY3wu4kfjf+2rML54VcpcYFgr7
+ oBvgAcRnwDSIP5kfJp4pvErlhtv58H8uZ0P/CixXvAa0KBloKFIYTBMEaTqT9Kr4L4gG80EGTBP04Zgr
+ cVlnm+1vtfXm//gWyN8CylczzAAbjGTAJP4zMU9zf3lciPwf8TDzD4gPxLksU4VPK28x+aG4yeg//3z5
+ +0CxHoYpAkwMUwUYQBhhQB+fB0Mv3xn/m/E/lfYY/3e4EPADxJfapPVZeofOf/5Fck+A/HkM/fwcQAPA
+ mhm8OZAM6OVjYOjg9WBo5z1jfMr5m8Rhzf8aZyz/ix/S+M+/Su4VUHwdQxevANAABgYvDgYYQBjgzs7A
+ kMrFwNDM7cHQxH1G+oDWF+GzKv/5tsm+Z2zm2c3QyiPN4ApUgwYQBsCAAjMDQzibB0MR+xmuZWIvGMs4
+ jgD5mgxyTFAFqADZAJAKoPsY5IFYl8GYKY0hnukMgzZjKJCvCcRKQCwFxMAkycADxGxAzIhsACMQgzwH
+ DB0GcSAGKZaEsoGZgAEYbwy8QAz0J1gz0KlIBpCP/zMAAIAsiHxWMptuAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_zoomrect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -639,15 +637,15 @@
<data name="arrow-090" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB1klEQVQ4T6WQTyjkYRzG32ax
- WlK7xvhzsNnNxko7RYkiBzkoBwfZWtMmm4ucJIuTPeHCblgkB8q/SRPbYvewbStcvnsQ7QEzWOYgcVAT
- iXn2faZ+mjEzqH3r09v3eZ73eX/vTwFQ/4Pv8MsPv5W1c0Pl9myp/P49VTjkVsUjh9Ua4c6ZOn3mmDcu
- DVfAQzLoBrhrqu9f0LfLsHzeB9pWz9H/F+Ccr/W7v6B7kyHp2/Oi4dvpNR+dV6Ceq/2wT3jVsU5TPrmu
- UDd3EkTXnwvQZy7oH2S2C0Xp3rpE64oHLcse1C8co2psB28mXKh17OKt3YnmpSMwx3zAT3zRtjKY3ros
- /tTMOFHSI7BNbeOmx3xAgQ6o5++XfDxr/qWeNv6Q13YXinrXUDnlBGfqRob5kAVpTT9Vcv08kbIZN6xD
- 2yidPgBn6vRZErJA36LM7xwGkjd7gtSxQ+Q4jqF1MTzmggriC2tVtLVSxdkmDST96xni7B6kfdG7bVIM
- LyIpS3EFPMGn6PXAkqkeVY0SsSx6YZr14smCF5yp0zdWyAKapoQMFVkxLJbvQOw88HgR4Ezdf4UqeKgD
- TOWYChrHTeUDco2eqWuyNTHhnhChDbMm5RYStRflX/AP4Mv/7H+tMgIAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAByUlEQVQ4T6WNT0jTYRzGX9as
+ MBHMNc2DYmJkEQ0WRMLCg3QQPHiQBTUiFl2k04jVPNWpvGxFmzqig4NqDhkaudkhojG7vB2i6JDbmtoO
+ EvMQDEPcHt9n+Btbmyn0hc9enj+/ZwLAf1H8Of3gkzA9+irOe5bERd+ysPgzou/52jWF5EtNnzl77O81
+ wI/kZAbgS73/AW+aZTm+Cox+/APfCkBNf+8B93eWpHe5gNsLv0s8TuZBn/muA+cefmEon6TyuDW3XsXY
+ t00wZ69qoOe+pCndS1twLeZwL57DSCQLa+AHrr5MwR5O43ooCWfsF9hjv2Lg5OjiZLcrLsu5MZNEv0fC
+ Fkzg74z9igFliq67sSInnB9Eh+OdvBJK4dLTzxgOJkFNX+uwX3Og8857cXxknsiBmQxM/gQuT/8ENX3m
+ uw6ofxGGm2ENeWF2He2BNZjDWVBrGXtVA80WuzhsGhaNtlcasvvNBhpDOXS+Vq/SWqZvPSN4FQPaHTD2
+ iHrrFJHGaAG62QKORgqgps9cu5oDPN2xU6Ju6Jk0vgUa5oGmKEBNv/xqDRxSsGXW9Tpe6AYnZAml6SvO
+ Ko4oag7oFQZF2z9oURxU7AxAbAPgy//sQfE9hAAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_null" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -660,95 +658,94 @@
<data name="globe--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADSklEQVQ4T4WRbUxTVxzGD+1M
- JGYuMSFmiyMOQQuaiDUqGwsRGG+aoCRkKpHOlymKi2SZQkKmbAxtKC8FtUoDErRQFalhzhpe3PaBqZRC
- G7RNKavWKbRAJZQi2lXWZ/9zxU9+8Ca/PPee//M859x7mejYfSYqMjLxL38zsfyfhWLF6FfiCpeCaCO6
- 51UhrPM5+bif57JKvmXCjVBQal9OQ/Wmhqdm+V/PPVqrz3/T7gsOTM/5WxwvPSlal5nPue9tAc++KSg0
- LP+oxNxe8NtT13XbFPp9c2ixTqPeNIV7E37YAoDtX6DaOOniPu4XckJBnj5UlN/VWND+yF3e40aX208F
- QbRYpqCz+9Az7kefdw59s8C9F8DpHpeb+4Vcnp6xkN3atJjiDus314Zx6KYTl+wvUPrHCE78PoIrQzP4
- cxI4qXdAQ+s3xoC2Z68Rdfy2ledCcjRUkHXhjOyiaSq90YaUpiFs0wxhR6sDubrHONzuxO6mB8g8a4By
- MIBiatune4Ic8vMcwRhLK+/4Xj8WSFRZsFY5gLg6C+LrLUhosOJLlRkynQtFd//Dd92zSFCaEFthxJY6
- U4DnCCpI/NkQV3InmNw4iqhTBkgqBxBdaUJMlQnRCiOkChMSamzI1s3i02OdkFZReWVvkOcIKtj8U2e8
- whj4rLQXkfJ+RFFg1TwS0qiyXmyscSC1ZRbhBZ3YqgOyNOMBniOoIPnUudVFHd6V5Q8gqXiINdUWxCot
- kNZaBWKrBrGp1oG1ZYOIV48hrQ1IVj3y8hxBBelVGUtyNcPrySQlvlA9RpLaibQGJ9IvPkFqvROJFxzY
- cNqMr29DYNnhG8OrN+ZnZEemUkHm+VC2Xd0sOdnnSVK7kdk0jl3aCexp9WD/dY+g8qRcqMLXoEGynjT6
- dc2isEltiMikZUzN2I7LjO1sjvggt7VLKrd4ZFe9ONLuww+3ZlConxFUGbkOr2Syd6hjrJ+OQNfSGHqV
- sgi299fmZYV37dvqR735uunA8Vsvg1yPxO98dTRshf/o4o8nfxQveEifrp9TJpyAMTERRkSzD5fGsc8P
- HmCy1kZ2sKOb5XUZBOXPfJ3PGaPdWFg45fg/4JeIWDRf8gnp++CbcT/Psf8BxLcXab+EC34AAAAASUVO
- RK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADQ0lEQVQ4T42Re0iTaxzHH7eC
+ RCo4IFGUVEdP04JsUtnxIKmlVmAJ0UVy3bMskqgUorLMGk5tdlk5NPGc6SpzYZeFly5/2MU53bA25jyr
+ dSo3bUecM2st27ffs4r+6J8e+PB93+f3/X7f531fJjjwhAny9Ex44l8mlP43TijrXSIsdsiIeqLlm8oC
+ +3xOPu7nufT8bexHQYF1Og2VCytfGaUP/3epzR7vTavH3zk06q21vXctVTuMfM593ws4Xy9yddMn5hsb
+ cm69clyzDKLDM4pa8xAqDIN4/NYLiw+wfARO6wcc3Mf9PwqytMGC7OaqnIbnzqJWJ5qdXirwo9Y0CI3V
+ g9Z+L9rdo2gfAR6/A061OpzcH8hlaRkL2qBOiTrUaN54tQc7b9rxt/UdCu6/wZF7b3C5exgPBoCjWhtU
+ tH+9D6h//QkRB++YeS4oQ0UF6RfPSi4ZBlOrLFha3Y2Vqm6srbMhU/MCuxrs2FD9FGnndJB3+XCI2rZo
+ XiKD/DxHMMZSihr3aft8CQoT5so7EVtuQlyFCfGVZvylMEKicSDv0WfsaRlBvNyA6GI9lpcbfDxHUEHC
+ cV1s/l1/UlUvIk7qICrpRGSJAVGlBkTK9BDLDIgvs2C1ZgTTDjRBXErlJW1+niOoYPGxpjiZ3jejoA3h
+ 0g5EUGDWN0RERGEbFpTZkFw7grCcJqzQAOmqfh/PEVSQdPL87LxG9x9FTyEqfoY5p02IlpsgPmMOEF3a
+ hYVnbJhb2IU4ZR9S6oEkxXM3zxFUkFq67LdMVU8MmcTEn4oXSFTakVJpR+qll0iusCPhog3zTxmx5g4C
+ TN11vWf2guxlq8OTqSDtQjBbpawRHW13JSqdSKvux3r1W2yqc2HrNVdApYmZUITNQaUohjTyU1lI6IA6
+ SGBQM6ZkbO0/jK2rmTkms65ZLDW5JFfc2N3gwf7bw8jVDgdUHj4PHySSnyhnrIOOQGtSFL1K4Uy2+UbN
+ 1NxH1pUVve5szZDv4O33fq6749Z92Bv6u3fvhMkDh4Vjn9Gn6+AUBk7AmJAIJSLZ+EmxbNGO7UxSV8V2
+ NLawrGZdQPk93+dzxuhpLDSMcvwf8CUgQgheMuUX4D7upxxjXwDEtxdpCOfy3wAAAABJRU5ErkJggg==
</value>
</data>
<data name="ui_menu" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABG0lEQVQ4T53OvYqDQBDA8anS
- iO0VV+YVxCCxt7OyEbnC6hK4T0E4swiGIFgIQQiE+Bq+kVXQRCFIuujcTp7AdeBfbPGbHdhutybvfWIm
- hGG4wolDFjabzWoYBjydTtj3/ejIkAXf99cEH4+HUGTIgqZp6zzPnxccj0c8HA6YZRnu93tM0xSTJME4
- jnG322EURcjPRsYYBkGAy+WSwWKxeC6gEV3AP2egKMrkC1RVZeC67sf9fseu64QiQxYcx/m83W7oeR5e
- r9fRkSELlmV90aNtW6HIkAXTNL+LosApkQXDMH6apsG6roUiQxZ0Xf+tqgpt28ayLEdHhizM53P/crng
- +XwWigxZkCTpTZblvymRBT4z3gvvVTAys38hdsO4G3bw/gAAAABJRU5ErkJggg==
+ iO0VV/oKYhDt7axsJFxhdQncpyCcESEhCBZCEAIhvoZvZCWJHyBip845eQLXgX+xC7/dgePxqE+9L0wH
+ 3/e3uHDIwn6/347jiLfbDYdhmB0ZsuA4zo4u+r5nigxZkGV5lyTJc4Pr9YqXywXjOMbz+YxRFGEYhhgE
+ AZ5OJzwcDrQ2ep6HruuioigerNfr5wM0rA9Mn3sgiuLiDSRJ8sCyrI+u67BtW6bIkIXNZvPZNA3ato1l
+ Wc6ODFkwDOOLDnVdM0WGLOi6/p2mKS6JLGia9lNVFT4eD6bIkAVVVX/v9zuapolZls2ODFkQBMEpigLz
+ PGeKDFngOO6N5/m/JZGFaVZTL1OvjE0GVv8hdsO4fy0mJQAAAABJRU5ErkJggg==
</value>
</data>
<data name="sql-join-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADAUlEQVQ4T6WT+0uTURyHXwz6
- IUgzu1lQUJIilqhBWQRqZlZkaqvUnMIMiw00NS94WUt0DtFlqVPUzOmc2hyjubmL13mZl3LL6dTNrXev
- c+/mZumWBklg5639Bx54+By+53ye89OBdnd3ob2wpzL2MBT1Qg3FFyAQocTq85S63gyAATtYplBtzMii
- rzFBuX33AfHOvBKYI3UNyJZA/lmi/4K4fDj2SRFiLmqwmhv5mzru8NZKGcumTCw2zCWQDRtM0dqYzfFb
- gdh+ibvkRkZkiQwPBKf/CSKJSp976SpzJduq7xhwLLH7HQttUruaUKHntYg25+kd1pXoTJVjVPV90mDd
- lq6sbw+qjfbum8VDyUDgBl1NHG4m0ZbM7X2OBZbUPg8Ei3mNxsESFjqOzTBItEULkaqAgaBfZ9kSwdbt
- vrYRmHEhQ3gd8oviw5VsVNsi3lRhAIEmoXSxp0mwoXzLXR8rY1v7ChuQzwE4waZAgVazRpFS7tRqhVyz
- 3uqbxo+DvCI4O0zxxnKTcEOJ0SqxL9zNn+VVfrTJCt6jfAwae03mdYvzRzCD1jOkOjJDonvVqzQ3eJN4
- qdDZcC5cxlxdquf/mAGlsfJOm+wBZU5IZVtkeU2mHozsmm/T3nd4ds6EsaZKqKVU9Wop3Elj7blnnCTI
- +7a4ObFAhZZ3WkdzGkyCog9myfM3y/0ZDHiooBkVYeCylStR6aPaeqm+vPyT5nWtWEejdCrpZ1I6IqCL
- 0XKfQNyUJY2OKPMaTaKsemNPcSs6EkOeFYEcT6cb5i49mvxZwdF2FXerKZU9mjLmkL7al9iVcSq57TDk
- 6ZsK+d5ojb2G11jwZAR5yTBNU9stEyQ6/CWMqNYG4xccmdWLA92TxpYPg/q63Japd+dT27Pdw3O9D/rH
- QNjaBzhy3AsXcRkn54QQTEhoinknlIAaguMVnBMhZJLHw7oMj8eNhR642ky3sJyk/Z5+QVjH2YVcwOaA
- c3ASpCfgKOAQwNWJO8hjzjPsDlbGOi57/0x7+cpY9y8yIme1LfwcuAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADAklEQVQ4T6XTa0hTYRgH8INB
+ H4I0s5sFBSVNxBI1KItAzcyKTG2VmheYYeFAU/OCl7VEpwy3LuoUZ7rNObU5pDndxeu8a+lyOnVz6+w4
+ dzY3S7c0SAJ7T/nRD0kv/Hjg/77P/9sLbW1t/Zcdw92AQp+poKhcBCIUWtwfU1ZqARjYxGYCxcoOyf8c
+ 7pvVeReI2p6XfDJljt4ZUsgrXfy3IDIHjniUj5jyqy0mpnBNK+hbXyzmWhUxBfrpaJJ+lS1eHrTaf04i
+ 1h+S5mEDI6RQHgsKTv4pCElSuN9JUZpoPIuusds+z+uyz9bLbCpCqa6VJV6boTdaFsPSlPYB5ddRvWVD
+ triy0aMy2FquF/TGgwIn6HJMXy2xZN7U0Gmf5cpsM6BgLptp6CnkokNYhiGWzJmTKJMwKOjSmtfFsGWj
+ s74fZpxLbb8KeYYKYRoP1bAka0oMKFBHF8211YhWFW8EK4PFPEtnXjXy0RsvWhNNomXcAaRIMLZUOqxe
+ 4XgkCyMht2D+JluyulDTvqrAcKS22ds5U62091Z57jtUiCnhLcvdbvB/iSbQKoZMS2JItS86FKZqHLE1
+ ETodJICL2UvzVcJvE2BpkNpkld8jT7dTeGZ5do2xDZNR/mUcd6vVxh8xlL9u15Bfd2jIglFDxZkn/DgI
+ d1NSG5OrRKlNloHMaqMov84kffpqoSuVAffm1qJiDD5DsRiaMqCpkumo1A/qlxUSbQm5SUE/ldAYDJ0P
+ G3b3wY+Zk+mIIptpFKdXGdoKOGh/OGlKDOZQCl0/feHB6PdSvqa5oEVFprWpi9m9ujKPpObUE/H1ByFX
+ j0TI4xon4kqs2hxLQpDnDOM4pcE8QqTDnwKTVBq/2Fl7Wtlcd8uogVXXo6vMYo29PZvYkOEclIXb7xUO
+ YWcPcOioGz74In6Y708wIgEJps0AAqr3i5rkH/MnEV3uV6a6PGTmueAr0pwCM+P2unr6Yjvbu5ADsG87
+ OA64AoeBA4DjNmfgCIDdYW+wt9iOw44fZDd2DP/dFvQbMiJntfgsfKwAAAAASUVORK5CYII=
</value>
</data>
<data name="application--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABpElEQVQ4T6XQTUgCQRjG8QEh
- iBK8VNAxAukWHsKTJy8Wkit56ItOfRJRBF2iLtE5kCAiEUMSwRJBENGOaYb2sdCSgZeMlBRRUFBEeZo3
- ggoK3HrhB7uz/IfZYQDYfzCLxdLHjXNzMlHTx8xm82Q0Gr1PpVJ4fExCkiSI4h0SiQRisRj4N0Qi5Io/
- X+PyUkQ8/oBg8OKeWmYymRbD4TBCoRBfDCIQCMDv98Pn88Hr9cLj8cDtdsPlcsHpdMLhcMBut8Nms0Gh
- UMzRL8zzO/jTUMsEQVhoNptoNBqyUEMtMxqNS/V6HbVaTRZqqGUGg2G5Wq2iUqnIQg21TK/Xr5TLZRSL
- RVmooZbpdLq1UqmEfD7fkp3zV5zd5kANtUyr1a4XCgVkMpmWTJ48gZzevIJaptFoNnK5HNLp9I82PEmY
- D6VvDl6AsaMHDE5su5lard6k42ez2R8N78VhfQaWJGBa/LSeBPpX/S9MqVTOq1Sq3d90jWzd9swcZ7/S
- RgB6Vw2N7zM+7Vw319sK5YRTJJ2CdfajpT1aG8XAKGsTbIfcVIfJ+h69AbnIrwah7HLvAAAAAElFTkSu
- QmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABqklEQVQ4T6XPMWhaURTG8QNC
+ oKSCS1vIKAHpVhyKk5OLCVKfxEFN6FRtQwkNgSylXUrnghSCRMQgEcFWBEFEO1Zj0dY88BEDLrFEiSIK
+ CoooX+/pkgQS8CUHftz37uUP9xKAeyGn06kXXIJXJW705HA4PIVCoVqv13F6WoOiKJDlY5TLZRSLRYgz
+ 5PPsl/j+jaMjGaXSCTKZn1VuyW63v8nlcshms2Izg3Q6jVQqhWQyiUQigXg8jlgshmg0ikgkgnA4jFAo
+ hGAwCI1G4+Un+MRb7jTckiRJr2ezGabTqSrccEs2m21zMplgPB6rwg23ZLVa345GIwyHQ1W44ZYsFsvW
+ YDBAr9dThRtuyWw2b/f7fXQ6nbl8+nGB75U2uOGWTCbTTrfbRbPZnIvn8Oy/b38uwC0ZjcbddruNRqNx
+ o914DY6Acs3eObC2f4Jn7o8xMhgM7/lqrVbrRitfSvD/BTYVYEO+tFMDlt+lzkmr1fp0Ot3n2zxa/VB5
+ 8vKgdZUpD/Cqe+76SmIeCI+FpXlo3RGZPZT8r8Q/t/OP5ukLWpCCAWF90e4XO0T/ALnIrwbTp6lgAAAA
+ AElFTkSuQmCC
</value>
</data>
<data name="document_task" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACBklEQVQ4T42SPWhTYRSGz1rc
- FH+WgpWkYBFFOhgcLAiCARXFCB26dKhtaENJCA2ttgUXBQcRRxEcWhAdxCWLReMF6RIIgg4OIkZTSwnR
- 5v//9H0vOYL0Sr3wcHMv3/PmnHOPhJaWhNxYXr4Mbu6B7/riolxbWJCr8/Muwhc9Jivttv5qNHSrWtVc
- uazZUkm/FYsurxxHcW4S+P8K4EOPqVKzqXmIP7e39Ws+r583N/XTxoZ+zOV0NZlUXjg7Bfx/KriSSEiP
- cBkBhUrFM+TRyooa/mDwNhAil+JxY7raaulvlP+vEFbCduBMmycXo1FjpoYZOD8cN+RtNqXDz4/taocB
- cGbMkwuRiBGpI+D0s6P6MHPfvbMS/uvLVErfZDL6Ym3NHSyciHlyPhw2ZpudjlYxh5Or/Vqs1Tzb4deB
- M2uenJuYMKItBNQxB4aU63XPkC0Ew4maJ2fHx41Yu9vV95gBQ5zv7/T40yO7QrgncGLmyZmxMSPeQcDg
- k4P6IH3PvbOSL4WCvk6n9UM2q8n1dS3iHZy4eTI8OmrMdbEobbThe3xAGxioVztcNjhz5olvZEROhUIk
- wU3rogqGcB5eIRW0x7N06LpXfyAgg8HgLXdX9wjhsvEsHbv68OPQ4UDgjgW4IYAz4WBZDT8x96SBZ56l
- A+jKfnCib2Agtm9o6O7/wLN06O4ALt15PeGOvdAAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB/ElEQVQ4T42ST0hUURTGz1ba
+ KWYbQWNGcIgiXDi0SAgEB0yMJnDhxoXpYEOMDA1aKrRJcBHRUoQWClGLaDObpKYH4WZgEHThIqLRMZFh
+ 0vn//3i+yxxBfFoXfjzu5fu+d+65h7zz84ZHCwv3hcf/wPFwbo4ezM7S8MyMgXDQYCJXrfLfUokP83lO
+ ZLMcz2T4dzpt+GxZDI3gPBOATYPJTLnMSTH+OT7mX8kk7xwc8Pb+Pm8lErwWDjMWdILzNGAoFFJ8WQlI
+ 5XK2IW9XV09xejwvBAI0GAwqU/lKhY+k/ItCUAmuA636aCAQUJ4UpAfWnmVCvsUj3PPh+rkQBECrPur3
+ +xV/UQJuv+/gN7El80Ul+OunSIS/xmL8cX3dNBZa9dE9n095Wq7VOC99uLnWzulCwfY6eB1o1Ud3x8eV
+ QEUCitIHhGSLRduQQzmDVn10Z2xMma7W6/xDeoAQa/c7d7+7di4EcwKt+qh3dFQJ1iSga6WVX0cXzReV
+ /Eyl+Es0ypvxOIc3NjgtZ9Cqj3pGRpRndRmUqlzDsdzCJWmo3XUwbNCqjxx9fXTL6wUhTFpdqkAI+mEX
+ kpM9tPDAa1a7201dHs9zBGBdFoJhgxYeXU3C1Ta3+2XDbxaug56gsQjCE2NOSrKHFp6Gl5qFG02dndNX
+ XK5X/wO08BBR8wku3Xk930xtLAAAAABJRU5ErkJggg==
</value>
</data>
<data name="sort-number" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABuElEQVQ4T42TTUsCYRSFJwMJ
- QWoXCFKEtAhqE/4EN4E7V+nGELUsAyUcUdC9W8Ef4cKtG3+BuJGgtQiCX/iFIn7d7rk5Mg4JCg/nfe89
- 58yIqKiqqiSTyT3S6bSSyWQcTBCKu9GDHBEpyoEChEJsICjjOFiQSCRuuOSZCenZbDa0Xq8JatzBj5y8
- QTwe97Zare/VakV6lsslaRh38CMnBdFo9HWxWNB8Pj8a+JGTgnA4/IbwdDqlUqlEhUJBznoqlYrMoZjD
- j5wU+P3+yGw2o/F4LORyud3ZONN28CMnBV6v930ymdBgMBBSqZRovV7fnYvFopy1HfzISYHH4/kYjUbU
- 6/WESCSyO2szaLVapVgsJjv4kZMCt9sdxRPb7TZls1ny+XyiuGvk83kKBAJULpdlBj9yUuByuT77/T7x
- T3M08CMnBU6n86VWq/10u13qdDo7ms0maejn8MGPnBTY7fZbm80WZL70DIdDajQaBDXu4EdOCviiWCyW
- Pcxm8x2j4rtCcTd6rFbr359p+zGxnjNXzD3zaDKZnhgVijvzwFwzF8wpcvqCE76fbZeXrLZ/wBxh+PBA
- KfgFcqFa2BgtJlQAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABsUlEQVQ4T42TS0sCARSFJwMJ
+ QWoXCFJEtAhqE/4EN4E7V+rGELWmDJRwREH3bgV/hAu3bvwF4kaC1iIIvvCFIr5u99xyGIcChY/7OucM
+ w6CiaZqSSqX2yGQySjabvWbCqJjNGviISPkvAKYICwgVs1mjBySTySsefEzEyHa7pc1mQ6jmG+ODTwIS
+ iYS/3W5/rtdrMrJarXTMN+jhk4BYLPa8XC5psVgcDPTwSUA0Gn3BcjabUblcpmKxKL2RarUqe1TM0MMn
+ AcFgUJ3P5zSZTIR8Pq/35t2uQg+fBPj9/tfpdErD4VBIp9NSG42G3pdKJel3M/TwSYDX630bj8fU7/cF
+ VVX13kitVqN4PC499PBJgMfjiSG10+lQLpejQCAgFfOOQqFAoVCIKpWKzNDDJwFut/t9MBjg0xwM9PBJ
+ gMvleqrX61+9Xo+63a5Oq9XSMe6hgx4+CXA6nTcOhyPMfBgZjUbUbDYJ1XxjwvBJAA+KzWbbw2q13jIa
+ 3hUVs1ljt9t//gu/Pwtzylwwd8yDxWJ5ZDRUzMw9c8mcMcfMXsARc8LgeM44/gB73KHDAzmAlG9yoVrY
+ r1VqEQAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_pan" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -766,33 +763,32 @@
<data name="tick-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC5UlEQVQ4T12Q60uTYRiHHzIZ
- HlssW6Em62BQikPE0cyJg6W20h0cgc2gxMAYfVACFbEDJkIRnb4IrukyM1kuJhqK6NJEreHUPDWXEydK
- +g/47dd7Pw1jPXC93Nz377rf531ZSUkJ0+l0zGAwMKPRyEpLSxNMJpNKgE5FCKpVNKMMZckhlz9CC0TC
- MLempqZ2ampqfmdnB1tbWxyqJycn56urq2spIywQ/b9ApNfrr9pstg4S2mbtuDNxDznDWg7V1NvcDMJq
- tXZQVlgg4jcoLi4m8oSBPRAIQDdyA+pvRph+3cb1oIVT6q9E/rSBz/z+VbS2ttrJIZdptVqpxWJpWF8P
- oHioDJfnymDwVUD7wxyG/uctXJq5xjMrKyuoqqpqIJcVFhaqR0dHFp6Pv4bq61UUCQvyJnVhZA1rQOfd
- 715ccBfh2ZeX6OtzLZDLNBqNma5l7q9EgfCG9H4VskcKIB/Mx5nebCR1pmNjYwPBYBDb29s451LyrMfz
- HeQytVpt8Xq9yPiYA43HhL29PSS+T4O4QwbxGxnW1tb4Avq5YqsMiT1pPDs+Pg5ymUqluuvxeJD2QQFH
- wIXFxUXs7u4i/m1KmBxvT0FsdzKOOE7zrNvtBrlMqVTe9HpnYXKU4+RQJl/g8/nC5LiuE4j+lMg53Cvj
- Wbd7DOQyhUJR0NPjWH78+SlSHOchdoRfO7YnGaLBY/tIu0+haeAJbDb7MrksKyvruF5vbJ6ZWcDFTg0k
- Lhlincn8m6OdiTg4lrDPIWcSz0xPz0Kn0zeTy+RyOcvIyChsbHzkmJtbhaJNhbj2o4gclCBi4i9Ux7Yn
- 8JnX60NDw0MHOeQyqVTKZDJZVGpqqrmu7oFzaWkTLQMvcMVqgLhJwqGaektLQdTV3XdSlhxy6RwQiBaJ
- REkSiaRcqcx91dXl8vt8u8LP/Af1aEYZIZtMTshlEUIhEUgVyIyMjFRHRUVVxsTE1Au0hKinHs0oI3A2
- 5ET8AeUdBAROQKmSAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC3klEQVQ4T12Q60vTYRTHHzIZ
+ XlssW6Em67KgFEXE0cyJg6W20l0cgc2gxMAYvVACFbELJkIR3d4IrukyM1kuJhqK6NJkWsOpeWuaEydK
+ +g/47tvvPIq1DnzgcM73c34PP1ZUVMR0Oh0zGAzMaDSy4uLiOJPJpBKgKtuDSkU7ylCWHHL/PSASltlV
+ VVXV4+PjM1tbW9jY2OBQ7/F4ZiorK6spQ9n/D4j0ev1Vm83WRkLLlB13xu4ha1DLoZ5m6+tBWK3WNsqS
+ ww8UFhYSOcLCHggEoBu6AfU3I0y/buN60MIpXi5H7oSB75aXl9Dc3Gwnh1ym1WqlFoulbnU1gMKBElye
+ LoHBXwbtD3MI+p+3cGnyGs8sLi6ioqKijlyWn5+vHh4emn0++hqqr1dRIBzI8ehCyBjUgOrd725ccBfg
+ 2ZeX6OlxzZLLNBqNmZ5l7i1HnvCFlF4VMofykNafizPdmUhoT8Ha2hqCwSA2NzdxzqXkWa/3O8hlarXa
+ 4vP5kPoxCxqvCTs7O4h/nwxxmwziNzKsrKzwA/RzxVYZ4ruSeXZ0dBTkMpVKddfr9SL5gwKOgAtzc3PY
+ 3t5G7NukEDnWnoTozkQccZzmWbfbDXKZUqm86fNNweQoxcmBdH7A7/eHyDEdJxD5KZ5zuFvGs273CMhl
+ CoUir6vLsfD481MkOc5D7Ah9dnRXIkT9x/aRdp5CQ98T2Gz2BXJZRkbGcb3e2Dg5OYuL7RpIXDJEOxO5
+ HOmMx8GRuH0OORN4ZmJiCjqdvpFclpaWxlJTU/Pr6x85pqeXoGhRIab1KML7JQgb24X66NY4vvP5/Kir
+ e+ggh1wmlUqZTCaLkMvl5pqaB875+XU09b3AFasB4gYJh3qazc8HUVNz30lZcsilOiAQKRKJEiQSSalS
+ mf2qo8O17PdvCz/zLzSjHWWEbCI5ey4LE5AIyAXSw8PD1REREeVRUVG1Ak171NKMdpQROLvrsLA/5R0E
+ BM6iflMAAAAASUVORK5CYII=
</value>
</data>
<data name="control-stop-square" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABcUlEQVQ4T8XTO0hCYRjG8Q8M
- 6YKE2RC1VRANQVNDQi65RVC0hDQEBS2F4FBQSy2BQxdrUOg6mDWEBJZJUdBSw1cEZYNh2AUywgiHEBSf
- 3ldQ+ChJcGj4cc6B/3nOtxwBQBSjqJf5w5mBjtWoMK29uYgsgIv77KkzN0bXC5PLEWD+Pq2YC6WR5XgA
- uONeGWhzhAWR9rsUJs8Tec3eJMEd98pAqz0oiJy5SmA0EM8Z8cUwuPuKgZ0nWDwRWI/fwR33ykDztBRE
- Tl18YXgvhn73I7qctzAvXqJzQeZYPCFwx70yUD9+Joi0nn7A7AzCtHT9q153CNxxrwzUjQUEkT2+KFpW
- wnmZtp/BHffKQPWQVxDZ7o+jxhPLq8n7Ce64VwZ0li1BZONRClpvMq8qXxLcca8MlPatCyIbTgBDANAf
- ApV+QEcqDoByUrZPz3TlTmuaUAeEEBqN0bah6XbJPxltm9SXKCfgAaIntQUw/Bj417/xG49phw+gF0Mn
- AAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABZElEQVQ4T6XMTyiDcRzH8dWj
+ 5U9LMwdxQ8lBOTlYeS52kyIXLQdFudBqB4oLF7WDP+Owp/w9zDhoqTGLKBcOX1LMYZrmT5k0aQettnz8
+ vg7TL3sy7Vev39Pz693HAKAgOR//4/tqW44b1JUXTaA8aNxLA1btidFiDJi9/ZTMRH647wDuuJcGWtxR
+ Rq6bDMZPU7qmr9LgjntpoNkVZjR1kcJwKJk1FEigf/sZfVsPsPticBy+gjvupYHGSWI0cfaBwZ0Eer33
+ 6PBcwzZ/jvY5yrL7IuCOe2mgdvSEkeP4DTZPGOrCZU7d3gi4414aqBkJMeoKxNG0FNWlbj6CO+6lgcoB
+ P6PWYBJVvoSuBv87uONeGjDZNxjVH2Rg9Kd1VQTS4I57aaC4Z5VR3RFgCQHmfaA8CJiEsj2gVCjZFf/i
+ y51RHZMHxFEUq3NN6dToT1bnuuiLfg0IZqE6DxZBHihEzsf8wfAFj2mHD3XhXHEAAAAASUVORK5CYII=
</value>
</data>
<data name="icon_zoomnext" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -813,28 +809,27 @@
<data name="application--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABq0lEQVQ4T6XQz0vacRzH8Tda
- gwjD7dAhdvLiYS3Bk7H1pcCLB0EFD8ODEKFzW8EY26EgunToTwhEBJkIMnEI4vSq5tBoQrIFwkCYX1BM
- QUER5dXn3Y9TlH3bGx68P9/vlyd8v18CQP+DnE6nTngjeBTiRkcOh8OVz+dPq9Uqzs7+oFKpoFz+hVKp
- hEKhAPEMuRz7Kc7HODoqo1j8jVQqe8ot2Ww2XyaTQTqdFjdTSCaTSCQSiMfjiMViiEajiEQiCIfDCIVC
- CAaDCAQC8Pv9UKvVHv4Er/gHjxpuyW63vx2PxxiNRopwwy1ZrdZ3w+EQg8FAEW64JYvF8qHf76PX6ynC
- DbdkNpu3ut0u2u22ItxwS5Ikfex0Omg2mxO5s+9hSK6CNzfckslk+tRqtVCv1yda+i5h4/wzeHPDLRmN
- xi+NRgO1Wu1Orh8evIy+vuRsXp0N3yQ83X5eIL1ev8OvL8vynQxfX2FNdtwyffDsH2k0Gq9Wq92/z9T6
- 3Ilqd05mi7UV3JxV7tk4iZkR5oWFifZmywt/X4DEvm64feAsTxFtPjkk33TpcvO1mAsmbJya11eQ2wAA
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABq0lEQVQ4T6XPz0vacRzH8Tdq
+ gyGK7dAhOnnx0Jbgydj6ssCLB0EFD6NDMMJmv2CM7bBg7LLD/oRARJBEkMQQxPRaamSUkKxACIT8gl+c
+ goIiymuft2OnUfbdPvDg/fl8vzzh8yEA/4V8Pp9ZeCP4VeLGTF6vdyWfz19Vq1Xc3FyjUqmgXL5EqVRC
+ sViE+IeTE3Yq9ucoFMo4O/uBTOb4iltyu92BXC6HbDYrPmaQTqeRSqWQTCaRSCQQj8cRi8UQjUYRiUQQ
+ DocRCoUQDAah1Wr9/IR18ZZ/WtySx+N5NxqNMBwOVeGGW3K5XBuDwQD9fl8Vbrglp9O51ev10O12VeGG
+ W3I4HDudTgetVksVbrglSZLet9ttKIoy0erxJqzp1+PJDbdkt9s/NJtN1Ov1iRYOJaz9/Die3HBLNpvt
+ U6PRQK1Wu9fKkR8v4q/GfMrvvfVAwvTnuSJZLJZdvp4sy/ey7r/Esuz9y9T3Z3dkMBjWTSbTt4fo3hov
+ NF+MMnteW8KfvWZVnySxngozwuxEX/Xl2dt58BRnbrh95FrUEW0/2aPAVGk8+UxEvwAmbJyauUwqoQAA
AABJRU5ErkJggg==
</value>
</data>
<data name="applications_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABc0lEQVQ4T5WSMWvCQBiGv8Ut
- pZMIxcVMri4ZI4hjBhUdikvpYKmLS5cu/Qv5Bw4OdXCRokYQHKoGETooLhldgw5ZxMm399kkikZJAw+5
- cHdv7uU5IvdJp9NULBZ9SqWSLHgUVK7AczJFo1E63VwoFMilbJrm0rIsLBZzzGYzTCYmxuMpptM5DON7
- KdaVz/96+M7lcszrYDBAv99Hp9NBu91Gq9VCs9lEo9FAvV5HJBKpXASIYxEjgl72+z1uwWuu9s7n85+G
- YaDb7foMh0OsVitst1vsdjtomlY9BITtPRr9oNfrYb1ew3EcZDKZmnfc0L11XYdt29hsNlAU5e0Q8J/e
- qqp+JRKJDyYejz/zZt93mN7ZbPZdXJ0Hl3vuf9N3UO9UKuXdPwrl+7y36E7JZPIvJIzv896xWIwYSZKI
- 2CU7ZbdB8NxF72MBInbJTtltEJ5vWZZPtx3H7JKdstsgfN9Ed4EJwuWT5/XaW6yputouMn4B8esdOkQY
- S3EAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABXklEQVQ4T52SPWvCUBSG7+Jm
+ 6RSE4pJMri6OCsExgwlxKF1KB0tdXLp06V/wH2RwqIOLFPMBgkPVIEIHxcXRVczgIk55e48xoU1jqb7w
+ cAn3nHPzcC8LUyqVmK7rEdVqVeLccmonoD2JCYLwo1nTtJA713UXy+US8/kM0+kU47GL0WiCyWQG2/5Y
+ UE381MNaqVSIp36/D8dx0Ov10O120el00G630Wq1YBgGUqlU7deAEP796Ps+/oJq4gMib1VV32zbhmma
+ EYPBAKvVCrvdDvv9Hoqi1A+N//UeDj9hWRY2mw222y1kWW6c7d1sNrFer+F5HgqFwvPZ3sVi8V0UxVci
+ m80+nO1dLpdf+LO5OXJ9kXc+n6e3F+QSbw7L5XLBgEu8M5kMI9LpNGN0l+RGjkkken8POZEbOSYRekuS
+ dOyIhZzIjRyTiO6bsaugIxbudB/6nYLX1Hkp/X4sjH0B8esdOufNXnwAAAAASUVORK5CYII=
</value>
</data>
<data name="icon_zoomout_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -942,63 +937,63 @@
<data name="layer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwElEQVQ4T6XS6ytDcRzH8e8z
- yTMkUUpJLsntP/AP8ERJuSV3kdwe+QvkkrtaybXUMcPmNilmdjEP7IHNZbScmWNnmLtH8/sclvFAR1av
- zvme832fXRr5/X76D8pu10Ick8sUyoRdNERZbeuQZzrxrlz73iyC79X8G+xgFw1aymxdgyLh7nXP6XnS
- yoFdNGgpo2UVit23L4Zz4XFNDuyiQUvpzStQ6vI+60/dD8tyYBcNWkpr0kAZ++g6G3+vDnbgvFPq7eKE
- 1no1pN6/7J03851gPPHOoEFLqY1LUH4mPG1Znb4F2D+75Vg0OmfiuznjRZfE8EVn80yhQUspDYtQcex+
- 2GShcvvQMzlvdvVxBr6XM0p6pCPmj2s9Ops4gwYtJdWroOqQv9/YsArj7F0H5ozf9LM5QLrHHjCLBi0l
- 1iqhxuK40ShN/Agz/AnnwTOuS7PO7uHQoKWEag7q9EeiSmV2KQLY11AA5p/nO3ZRhQYtxVfMQgP7ZTUL
- FteYZO/zGJiDj+wedtGgpZDoZIotmayc3nKssr/o8u6RqP4NdrCLBi1e4WFpuTkR+YNNkQWKDjmwiwYt
- HhDKRDExf4Qm9B0h5nPvHST9+wAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABuklEQVQ4T6XS6SsEcRzH8e8z
+ yTMkUUpJjuT6D/wDPFFSruQWyfXIXyBHrqWUnKXGHuy6Voq19rAe2Ad23W1mrbGzWLdH6/cZZJU0svVq
+ Zn77fc/VUCAQ+BfKbtdDHJPLFMqEWTREWW2rkGc58i1d+V9tgv/F+hvMYBYNWspsXYEi4fZlx+V91MuB
+ WTRoKaNlGYo9N8+mM+FhRQ7MokFL6c1LUOr2PRmPPfeLcmAWDVpKa9JBGbs1g4O/0wbbc90qjU5xQm+/
+ HNLuXvSqrHwnmI98M2jQUmrjApSfCo8bdpdfA7unNxyLRuYsfDdnPu+SmL4YHN4pNGgppWEeKg499+ss
+ VG7ueydVVncfZ+J7ObOkR9ri+H2tx+AQZ9CgpaR6NVTt83dra3ZhnF11YM78TX8QaY2dYBYNWkqsVUKN
+ 7eRap7Tww4ziA/aDjz/XFAanl0ODlhKqOagzHohqtdU9+ok9huSn/S2nqEaDluIrZqGBvVmdxuYek+x8
+ bH/C/sMsGrQUEp1MsSWTldMbJ8vsE13cPhC1v8EMZtGgxS88LC03JyJ/sCmyYLRDDsyiQYsThDJRTMwf
+ sYZC3wAh5nPvZl53vQAAAABJRU5ErkJggg==
</value>
</data>
<data name="sql-join" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXklEQVQ4T6WTW0jTYRjGPwy6
- CHLZKsjALhYVkkhJtJvqoiN0EUGSXaQX0oIEc4oNR+ga2kRUxJ106lquaOps03by72GosZzhVonWdJuu
- nZxa2WhBV+t7ZEL3G/z4Xp73+b27+pNkMknSIS0Zf0zyq6zkdPUIOfOYYRUIRrmUm5S7qfccfcH/GRdd
- OHB3DuRcr5+81+cIKgIbf2wb8b+u0U8xzQ3J9COAGRl26KBLD+TsHGBdEdtLFoK/9N82ExOr6wnGE42P
- FLW+E84HtqwAMzLs0EEXDj3AInl883nt1IpiZT0x6l37baWlsWf6z9KesWU1MoAZGXboIIMDl+SWDxd9
- CcVNiyn8sYT9Wp1N5Pb/NI7Px7reOEMtFlek86LQXGtyRaQvpwMNg85Qs8Oz2QuXnCgz8OjVyY+rWwbw
- NRxnjvF0NVZXVKlkvHXA4o4qOPd1Naa5SIeC8dYqRrYzFVzCeTBQPOf/YXR6v+ut7rVu42xYya0yiPsd
- AWWbeUkEMCMbeB+UbWeWJdHgTFAOlxwtfX213bSoGvoQ7m4e9og7GF8TTzbVJuydlclsy40AMzLsmoY8
- T+U2b6NI526FS46UaNmnyvorX9h90pa3HolYvyDSTPg6z1YMSNTj3h6AGRl26KCb+7CPD5fszb9Fsi4L
- Th7nvaoWaJzt6gmfUj8T1DT0u1WcUm09wIzsOd2hgy4cuPjtohzYnZ1XwLokKGbflley73Q9YRcqKzIv
- lBcCOvOR7ac7dNCFk3JJBh32pIJs+h6mHKTso2SmyKLvodQOHchwMtL/mNL5lOH+A5i6WIwCDkE+AAAA
- AElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXElEQVQ4T6WTW0iTYRzGXwy6
+ CNJsFWRQF4sKSaRE8qa66AhdRJBkF+mFtCDBnGLDEbqGNhEVcSedupYr0jnbtJ3cdEMNc4ZbJVrTb9O1
+ g8fKRgu6Wu8jn9CFF0mDH3t4/s/vvftIIpH4L7YstwPJLLOSU+UD5PRDe0qWwJFDuU65zf6fYfm7y8EW
+ DtzNBw5frR6+0z0WUgRXf9lWY789jg/LmmuS0QcAGR1u2GALZ/OBlEtiV8F06If+y1rcubASt/sWYwN5
+ jW+EU8F1K0BGhxs22MKBSzL45rPakXnF/ErcwSz9tNLR4BP9R2nH4JwaHUBGhxs26ODAJenF/XmfwjHT
+ DEtgOe66UmUTeQPfjUNTy22v3OEGiyfael5orjR5otLno8GaXne4fsy31gmXHC8y8Oirw+8X1g3gcyRm
+ P8rrqrB6FpVKO1MFLN5FBfduV4VpMtqisDOVioGNTgWXcO/15E8GvhndzFe91bvUbpyIKHPKDGLdWFDZ
+ ZJ4VAWR0PW9Dso3OMivqHQ/J4ZIjhS8vN5tmVH3vIu31/T5xi91fx5ONNAk7J2Qy21wtQEaHW12f77Hc
+ xtSKuryNcMmhAi3nZJGu9JnLL2147ZOI9dMijdPfml3SI1EPMR0AGR1u2GCbfr+bD5fszrxBUi8KThzj
+ vSgXaNzNaqdfqR8PaWp0XhW3UFsNkNE9pTdssIUDF78dlH070zKyUi4I8jk35aWcW22POLnKkuRzxbmA
+ Zj66vfSGDbZwWJckUXaxRRrlIGU/ZQ8lmSWVcoCCGzbYwkna8gPZDluW/06C/AGYuliMcYMAOwAAAABJ
+ RU5ErkJggg==
</value>
</data>
<data name="property" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXUlEQVQ4T5WQUUiTURTHj7bH
- BF8C6XGEwnoIpg/rIcEY2QhlW86USMjKUoa1LIO0h8AoRRSVolFWkFmuaUaBzW1awkZue+hh1pgJMWiL
- rbGFC4fM/t1zSfEhaF34cb5zv//vfPe7ZDKZiHGfVEjmmhXV882K/n/BuTdNCpIyc76hinhDMJILPcHK
- i24ERtuAzxPgPubuQ/zdAFLeEWQCVnBu5oTiyNYAHmI+VkXWhpLaqcYdo/77rch9GoPzlknWxHw/lsYs
- WJm8iq8zPfgues7xAKWgUdDCXKqrGJy6WBHKfhiVctozLCv3sdmbCE904sv0NSw9OB1/fLTwGRmNxuNe
- rze4vLwM78t7cPfV4+f723ho3o+Eqxe2K1pZeQjX0HjHr1fd2uRAdcHckK6gifR6favT6YTD4cDdU/vw
- Y2EQY5YDuHO5Dr31SnwTx+UhXKe6DmP4jAaH9hTaeg7SbjFEXuJZ/FlhzzQemTXgyuvjwiSsLeWIvr4u
- h7iejiAQCIAdvjNL7V4ig8FwbmNjA7lc7q8E3z6XQ2bHh+Dz+eD3+8GOgF2impqatvX1dZTblMhms+Df
- 4a8Eg0GEw2G5tx3OsiNgl0in05nX1taQyWTygrPsCNgl0mq17aurq1iwtCOVSsHlcsHj8Wyx2W9WzrIj
- YJeosrLSkk6nkUgk8oKz7AjYJdJoNB3JZBItViAajcLtdsNut8u6/XlxcVG+5yw7AlKpVERqtbozHo8j
- EonkBWfZKS0tJbnKysq6+PixWCwvOMuOUHcJdlJRUVFbcXHxjf9BOBeELM5PJb8B18GBdzrX/msAAAAA
- SUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACWklEQVQ4T5WQUUhTYRiGP22X
+ DXYTSJcSDuwimF6siwRjZCMmas6USMjKUoa1LIO0i8AoRRQdRaNWQWZpakaB6TatwUa6XXQxS2ZCCG2x
+ NbbYYmNsvf3fT4oXQeuHh/f857zPd/5zyGg0SpwnFZKFFkXVYoti4F9w702zgrYGnG+sJL4hsGRXn2D9
+ RQ98tnbg8zh4H3L2I/xuEDGPBUmfFdybPaE4sjWAMR2rJGtjUfV00w6b934bsp9GYb9llBlZHMDKqBnr
+ U1fxdbYX38WeeywWC5oErcyl+vKh6Yvlq+kPNinH3SMyeR+av4nAeBe+zFzDyoPT4cdHC59RXV3dcY/H
+ 419bW4Pn5T04+xvw8/1tPDTtR8TRh4krOpk8hHN1rPPXqx5ddLCqYGFYX9BMNTU1bXa7HXNzc7h7ah9+
+ uIYwaj6AO5fr0ddQjG/iuDyEc7r7MEbOaHFoT+FE70HaLYbIn3gWf1bAPYNHJq1MXh9dU7C2liH4+roc
+ 4nhqgc/nAzsCMlfvJaqtrT2Xy+WQzWb/iv/tczlkfmwYy8vL8Hq9YEfALpHBYGjPZDIomyhGOp0Gfw6/
+ xe/3IxAIyHvb4S47AnaJ9Hq9KZVKIZlM5gV32RGwS6TT6ToSiQRc5g7EYjE4HA643e4tNvebyV12BOwS
+ VVRUmOPxOCKRSF5wlx0Bu0RarbYzGo2i1QoEg0E4nU5MTk7K3H69tLQkn3OXHQGVlpYSaTSarnA4jI2N
+ jbzgLjslJSUkl1qt7uajhUKhvOAuO0LdJdhJSqWyXaVS3fgfhHNByOL8VPQb18GBdynqi84AAAAASUVO
+ RK5CYII=
</value>
</data>
<data name="application-export" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzklEQVQ4T6WTO2hiURCGB+0M
- go0YtrwKaqlphKCVhQ/EB1qE9Ek2CYElsFvErRZ7KytBEAtBsFDBqK2P5MpmIckiaCGIKCqi+MAHyuyZ
- W66Fhgx85zTzDWd+OICI8BnA5/NxjDPGxYFQL+f1eoEAj8dzXi6X3xuNBtZqNXx7e8WXl9/4/PyEpVIZ
- i8UKu3msVP4gz//Fx8fiOzkMcgFcLtfXQqGAuVwOs9ksZjIZTKVSmEwmMZFIYDwex1gshtFoFCORCIbD
- YRSLxRcikQgIWuGSZfChIodBLoDb7b7abre42Wz2wvM85vN5ZE+/cjqdYLFYABwOx/V6vcblcrkXWo3K
- brff2Gw2nclkArBarbeLxQJns9kO/X4f6/U6C7Ek5EJ59Ho9YQiTvxmNxhMwm8130+kUR6PRDpPJBOfz
- Oa5WK6Q1/y+dTvcDaNJ4PMbBYLBDs9nEarWK6XRaSD8YDGK73RbmcBz3U6VSGcBgMNwPh0PsdDp7CQQC
- giyXy38pFIpTNgRAr9d/p11brdZeQqEQ+v1+1Gg0D0qlErRaLYBarX6g53e73YOgXnIY5AJIpdJLmUwW
- +AjkSCQSIKjoPGZ8ORDqPRJMqs98ZXL/Ad8QklT8D+CBAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABy0lEQVQ4T6XQO4haURAG4EE7
+ g2AjhpQqqKWmEYJWFj4QH2gR0u9uHgRCICnWVMHeykoQxEIQLFRw1dZH9ko2kN0gaCGIKCqi+MAHyp9z
+ brpY6LID373N/MOZIQBPQsFgUM28Zi7OxHvVgUCAOPL7/W9qtdpDu91Gs9nE/f1v3N39xO3tD1SrNVQq
+ dfYXUK//giD8wc1N5YFnGJ4l8nq9b8vlMorFIgqFAvL5PLLZLDKZDNLpNFKpFJLJJBKJBOLxOGKxGKRS
+ 6YVEIiGOr3DJdnlU8QzDs0Q+n+/qcDhgv9+fJAgCSqUS2NOvPB4P2e12Irfb/W6322Gz2ZzEV+Plcrne
+ O51Oo9VqJXI4HB/W6zWWy+WR0WiEVqvFjlgVw/wew+FQHMLCnywWy0uy2WwfF4sFptPpkfl8jtVqhe12
+ C77m/2U0Gr8SnzSbzTAej490Oh00Gg3kcjnx+pFIBL1eTwyr1epvWq3WTGaz+fNkMkG/3z8pHA6LYaVS
+ +V2lUr1iQ4hMJtMXvmu32z0pGo0iFApBr9dfazQaMhgMRDqd7po/dzAYnIX38gzDs0RyufxSoVCEH4Nn
+ ZDIZcbz49znz4ky89xnzr9hNngD0F98QklS9cXDvAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_buffer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1014,50 +1009,49 @@
<data name="arrow-return-180" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAClUlEQVQ4T6XSe0hTcRQH8IPm
- Y1ZWPnK2yqt/NMpHPqMkUaNCqn8iMYSbZGFhSMtCS6RBD4VmDxqVjCywP9QwLa5GPkK9PVDHtVrlkx6z
- 1WbhH5kSE7d7OnduK8T6p8GHc36/e8733j8GiAj/A1JvjTmk3f6qI8I/6OkZR9Q0z6TcNENy5ScAqXES
- rhkRL4+I87pE9+VvbdYCfsqytXqMp510R8CmG6MugvaDiJoBm9uFfhu6lL+eQbV+Gku7rVjS+3Myreoz
- T7sMbNC+d9ElXX0n/E2q7qMhp+mbqfjplF3VPom5zeNmmlW7A+gAiVdGIFbT7yD1f4q/OKiIqxjQZN+z
- mApavmNhx4SVzhwo1b2w9owAUedfOvqocy9Yoos82we05A6Jo9DosleKpIo3hpyGUcxrtiDt6EF+5CGs
- VLVBxEke1pzuYSlEcAKmqAtWFT52iDj1RHquiCnrM+yoM+Kuu0akud8B4cVdLIUIWqMdpRp2osO9LAUw
- RZ0KutdsrBw0RdeYcXPdFyududkvONrK0lcIpUM2zOqeRqmfK7yEN0RdHzIp70/Y5fU/MLJy2EwzagjJ
- b84gQq5BRK8HM7iuw4479SJu6xEx5bmIibzdcRfWZkP/Jhv6cTO4unZ8Uq5q5enlDAQcaMggwnY9/ac5
- xCWPEBXtiKFE3oa4nAS1Iga2iBjcOGWVa4ctgflNfODBxvTgwxzAsv314L+vjl3M1gpJz2YXpX4eerrj
- iJrmGXopLEzMBpDFZoFPTCb47b3DyrKqBWUnolR9t5SCd/Seefmsz4S5P0+6kC1IPnbIa3eVIKHzCqdQ
- qiEkiCwli4gv8SIeriBvagJImEdCnsoj+XgN9QlO8VRjiJIwRO4MklH1/AWgVvXWOcn9vQAAAABJRU5E
- rkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACjElEQVQ4T6XSWUhUYRQH8IPm
+ MlZWLjk2laMPDeWSa5QkalRI9RKJIdwkCwtDmiy0RBpoUWhsoaGSIQvswQXT4mrkEuptQR2u1VSutIxN
+ zVj4kCkx4sw9nXsdxxDrpQ9+fOf77jn/7+UCIv4XSL4zKkm5+01P+H8wEJZoqF+ZdNsCieWfAcTCib9h
+ Qrw6LCzoCil9Z7flcZPW7ZWjHPWnSgFbbo3M4nUfBdT2210u9c0pfTONGsMUFnfZsKjn10RKxReOZpSw
+ Sfdhlj7h+nv+b5L1n4xZjd/Nhc8mHeq2CcxuGrPQvcYVQAeIvzYM0do+iVj/KfbygCKmrF+bed9qzmv+
+ gfnt4zY6s6DS9MD6czxEXHwl1REXXjJEH36+VxxyBcRQaGTJa0VC2VtjVv0I5jRZkWYMID/2CFarWyHs
+ NAfrznYzFMI7gbKgE9bkP5GEnXkqfldElfQad9WYcE+tCalnLiC0sJOhEF5ncqC4h5xqdw2LlAUdCrrX
+ bi4fMEdWWXBrzVcbndmZgOMtDIXwxYN2zOiaQrGeL7SIM0bcHDSrHow75HU/Mbx8yEL3GgjKbUojfLZR
+ QI+H07ih3YG7DQLu6BYw6YWA8ZxDugtptaNvox192GlcWz02IVe3cPS4EvwO1acRfqeB/ksWcdljREUb
+ YjCRtyKuJAEtiP7NAgY2TNrkuiGrf24j53+4ITXwKAuw4mAd+B6oYZYy1XzC85lBsV6AgbBEQ/1KehQW
+ x2cCyKIzwCsqHXz232NkGZW8qgNR3L23FYNn5L4FeW1Mh/nLncgWJZ444rG3ghfReZVTMAkiAWQ5WUK8
+ iQdxI9LyJH4kxC0uR+2WeLKK6jinWBJFVERJ5EQMkgGA+2+gVvXWL25IBwAAAABJRU5ErkJggg==
</value>
</data>
<data name="exclamation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACDklEQVQ4T6XTz2vTYBgH8OcN
- is6LqAM7cXpxwlAsHnSIiF6ml/0FIlgRhUEOO2g30JPgPCi402C4grP+3rSz/qqpWKtlunXQt7GzrO1W
- Bk2wdLWDukJdx+P7hKVka0HQwIc8ffL9Jj0kgIjwP4COi6cZTL6ssVnshlfQvCpDHQIDvXXLFL6gxR1c
- i5/lNNd5gHFDmHjBaoS9rDni2+qpLI6UK4tPyxHfFg/t6mXhq4fVGB9lV7IzXcml/C1cyt/EbEpO0q5e
- FsaesVW+PGd27t+t/F4YXHY6nUjKhf5lrjQrdG1tHj4PMyspNML6cukerZjpRlmWDcXMZcwmZY2uibxk
- 7UDwMav69IS1R9/vD/36cQMX0p3ocDgMNBe1q8iVlhBlrB348ICZGgKPJHcu3V0ozHaKJ55Du92ONpsN
- Y+FTqE6cxNhkR4EyotNg9uDdEDP43eyMGmjj+bkuTE11oMpPoHhFDFF+3BBT23HszS5OWbMHvruMNPrv
- b/DqyfOlROwYxr8dMcxnrxnM33SeihwqKe51XupQF165GLx2sUuRwIHE3PRRnP1+sMr8B9YdzWF/U4I6
- 1IXRAbbHd29jUE8crujT+9DKvMHafSbeWnk7tD5IXXh4G1zqx536/Ewr5lJ7hZaq0s8eJNadOUcD23Xq
- wmAv9N+5DuP/grr0MUrCJmGb0CTs+AvKNK50pD9EZQJEPplB2AAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACB0lEQVQ4T6XSy2sTURQG8HOD
+ 4mMjasG0WN1YoSgGF1pEpG6qm/4FIhgRhcIsutC0oCvBulCwq0KxAdv4bjU1vuJEjNFQbVPIZEwNTdKG
+ QmYwpDGF2EBsyuk9FydMkoKgAz+4c873zcxiABH/i7gunWEw/bLONm70DzpX7alDYLCvemFyUYvZFS12
+ TqFzza4Cpl6wOiEPaw57d7jLy2Ol8vLTUti73U2z9bLw1c3qTI6zq5m57sRK7jau5G5hJiklaLZeFiae
+ sSpfnjOb4tsr/14aWnU4HEhK+YFVRW6WaVebh8+jzMwSHGP92VSvVkj3oCRJQiF9BTMJSaMdZcwdCDxm
+ FZ+esI7I+4PBXz9u4lKqC+12u0DngnYNFbklSBlzBz48YIYt/kcWVzbVk8/Pd/E3nkebzYZWqxWjodOo
+ Tp3C6HRnnjKUNXrwbpgJPhc7q/rblNxCNyZnOlFVTtJfIkSUdiGqduDEmz0KZY0eeO8x0uC7v8mjJy4U
+ 49ETGPt2TFjMXBeMezITPlKUXRs81KEuvHIyeO1kl8P+Q/GF2eM4//1whfEF5hkJ+Rrj1KEujA+yfd6R
+ zQE9frSszx5AM+MBtfN0rLX8dnhjgLrw8A441Y+79cW5Vswm93MtFcWfvYJ5Zoj4d+nUhaE+GLh7Ayb/
+ BXX5F4KF28rt5Bq5pr+gTAPHO2BZA0RlAkRncDeTAAAAAElFTkSuQmCC
</value>
</data>
<data name="document--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACMklEQVQ4T4WSTWgTURDHZ4/V
- Ww4KhRwCjWgIegjFrVLbSq1djaKYQg/10ENMQxs0JRhSbRu8iBc9eBLUXuJFlFCsi7YiGL/wXrURTGgw
- aZRQbb423+PMtg+CtPHBD5bH/H/Mmx1wzMwAMzQ7e4a49B86LkxPw/mpKTgXCMD+7m4AvtjCVajV8He5
- jL+KRUzm85jI5XA1m9WZj0SQ6lyEWQhYotu2GMtVKpih4NrGBsYzGYym0/g5lcLlZBIfqSryodoxwsxh
- XXDW7xe48yRYLxS2ldwNhVBgVpTrBDBg9/kE48VqFf9Q+ztJuBN+DmXGRQ4GvV7BhEYzyGpaSwkLKDPB
- uVtdXQAnPB6Bp0SCfKnUUsKDpYxn0WiET5IEcNztFlyu1OtYpDm0kvDfuWK334lJUviDJPXCMadT4K2S
- oERzaCVZjsXQ2d+vYjCI85L0Bo6Mjgoma40GlukZO0ni8Zf4OBxGjeY00N5+ew5gAA6PjAh8dRJwF9tJ
- EqtLGHk2iFoqgAc6O18YDIaD94GObXhYcLVBi1Ijwb+SZOIVvl1Q9PCTh314+uLReyabDVxWK0BHTw8c
- cjgYP29ag7polqR/vMZ3C6c2ww968Vt0EbmWM5zVj1GWYZ+iXNN3tUmy/vMrvn++GX5K4ZUvKvKycS1n
- xGmjjz17ZfmGEOgS4qMaRMxHMTzXh9+jS8h7UqYOuZYzBGfBQFjbTKbJ3RbLzWboHodO7lqxyMZQ8z3X
- coazfwEpq4JeDHDvFwAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACKUlEQVQ4T4WSPWhTYRSGzx2r
+ 2x0UChkCjWgIOoTirVLbSlt7NYpiCh3q0CHWoEFTgiGtbYOLuOjgJKhd4iJKKNagrQjGP9yrNoIJDSZG
+ CdUmN/8/x3Nu85UgbTzwLB/v+/D9gX1mRmd4dvYkcf4/dJydnoYzk5Nw2ueDvd3dALzQYDxXreLvUgl/
+ 5fOY0DSMZ7O4msnozIfDyBnCJASMbmtwIVsuY5qKP9bXMZZOYySVwk/JJC4nEvgwFEIezhGmTcEpr1fg
+ 1EiwlsttKbkTCGxiUtVrBDBg83gEF/OVCv6h7W8n4Z3wcTgrejDkdgsuFegOMoVCSwkLOMudm11dAAMu
+ l8BVJIFWLLaU8MVydtFggI+SBHDU6RRcLtdqmKd7aCXh17lis92OSlLwvST1whGHQ+CukKBI99BKshyN
+ oqO/P4R+P85L0ms4NDYmmKjW61iiY2wnicVe4KNgEAu0NtjefmsOYBAOjo4KPDUS8C62ksRXlzD8dAgL
+ SR/u6+x8Lsvy/ntAYx0ZEVyt00epkuBfSSL+Et8sqHr58YM+PHHu8F2j1QrjFgtAR08PHLDbGS//tDrt
+ olmS+v4K3y4c3yjf78WvkUXkLHe4q49BUWCPqk6xgEdI1n5+wXfPNspPqLzyOYT82TjLHTFtxK7dinK9
+ 0deHj/Mh5EfUIhic68NvkSXkf1IiOWe50+iCTFjajMaJnWbzjWZoHYeP7VgxK4ZA8zpnuQMA8l8pq4Je
+ +8ojoAAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_zoomrect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1078,16 +1072,16 @@
<data name="folder--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACDUlEQVQ4T43OXUjTYRTH8XNh
- gRJDd7Gk2yICZSu8C8K8qJsuIiG66E0rFkJXUZG4lK2xaavVYuKWbikT7U1p9EIks6JXdWbQC5GhlKYb
- 0/VvLnOp+3Ue6dlFqz8d+HAGO9+HPw3UEwnheqpk5v9UKTvqt5NkwfcgkOhWxzfcWGRHfTaSrPh2A+mp
- TlXihhur7OiZlSTbYvwqFqLtqsQNNzbZ0ZPTJDUsxDowP9GmStxw0yA7emQmyTEfCSA15lMlbrhxyI56
- 60hypr74MTvqUfUz0gZunL21RCFGPacyXD8+NSM57P6n1LgfIw9N4MbFSu6b+IF7NRnu2ZEmJN5f+Cvx
- 38dQNTuJxXQa3LlFS7sduWR05lKpV/N2wy09Knq2QHnjyJL8cBFDXVUQe2ZuDneqqYnx+LS0/LKWCv0F
- sUPx4zB0FWH6lT1L4p0T4WtGiD2hKAieoEuMp0Xr5UfChZ78qZ0xIwyd65bsu1mK2KAlQ3l9Bi86DkDs
- 4WgU3cfIx3ga88Nlk+X4k6F1LaL9dRlf+aueBvZD7LK+NK4fpVbGc07jpbOa8Er7injx503Qe9Ys2du+
- EZHnpoz4SytCzbsgtv5uEoEjdKWmXDxAlMd0uto8ZdVoEda7VmN6wJxFGbIheH4bxG48SLcrNtOO3y1p
- +Udxwfacx7rDy2ZKjDmTjj30QE3VVmoRDdP+AgqRc9vLR4PDAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACBElEQVQ4T43OXUhTYRwG8P+F
+ BUoMPRdLui0iULbCuyDMi7rpIhKii760YiF0FRWJS5mNzVqtDMUt3VIm2pfS6INIZkWf6imDPogMpS/d
+ mK7TXOZS9/S+L533otWhP/x4Ls7zvBwaaiBBbaBKxvGfKvUdDbqlenwPA8leY6zDu/qOBlySE9+uIjPZ
+ bYh3eFff0WOn5FpIXMJ8rNMQ7/CuvqOHx6UT8/EuzI13GOId3tV3dN8heeaiIaQ/BQzxDu/qO+qvk7zp
+ L0HMjPkM/Yx2gHf7a4kiDPUdkxp/fGhFaqTpn9Kfgxi9ZwfvMiV37OyB2zVS08xoC5Jvz/4V//Y+Us0c
+ xUImA97nO9ruySWbN5dK/abXa65bUNG3AdorT5bUu3MY7qkSOT07i5vV1MKwCyi0+IJChcGC+L7EYVh7
+ ijD1wp0l+cYL9bJN5LimIXyEzjPs2hQ/e0Qt9OVPbo3bYO1eJey6Vor4s3pJe3kST7v2iByJxdB7iAIM
+ u+Z8tWyiHH+ytq9EbLBO+sr+4lFot8iygQyuHKR2ht1pk59OmdSl7iWJ4o/rYPGtEHZ2rkX0iV1KPHci
+ 0rpNpOVWCqEDdLGmnD9AlMeYzbV52rKxIqxuXI6pIUcWbdiF8JlNIpv30o2K9bTl95YUprhgc84D8/5F
+ 0yW2nAnPDrprpGojtfENESm/AAqRc9toKh4FAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_refreshmap" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1143,17 +1137,17 @@
<data name="magnifier" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACPklEQVQ4T2Pw8/NjwIYDAwMZ
- QkJCBENDQx2AOAqIU6G0A0gcJA/Sh1UzSAKoQDEuITlpyuKN3UevPlt//9WX4zcfv926aM22PpA4SB5s
- gI+PDwb29fUVjIqNT1l38OrCIzdeH3r05tvZJ2+/nQNhEHvHiZtLomMTUkDqGDw9PbFh54nz1/btvvTi
- wNXHH0/ANMPoa08+nZi+ZMNEoF5nBmdnrDhh2+kHa0AG4MIHLz/ZBNSbwGBnZ4cN5++78nIfTDO6C0D8
- E7ffHgXqzWewsLDAhlP3nH+4EWQANs0gsVM3nu8A6k1lMDQ0xIY9J89dMX3/1VeH77/8ehrdEGBAnpu3
- bO1coF5PBicnJwYHBwewN2xtbRlsbGwYzM3NVVzc3KuPXLy37+azzygGPHv//eLlm/d3WNvYlqipqYlg
- GGBtbS0PNKR47dr1/zU0tdsnTp+79PGLd0fefv557emr90fnLVi8UkNDs1ZQUFBLTk6OAcUAoEYtNzf3
- mh079vwXFRVrZmFh0QLiMCCuBOJ2KA3ii/Hx8TGgGAB0vkVgYHDbkSNn/isqKvUAFakCMQMuzMXFxcDB
- wcEA8793QkLKhIsX7/7X0zOYBtRkzMzMzMDIyMjAxMSEgRmQAcgZwEAruXXr1X97e+d5QM0uII2kAA5R
- UVEXERGRFqDmbKBGfSDWAWINIFYBYnkglgZiMSAWBGIeIAa6nYEViJlAFrFAJaWAtCQQS0D5IkBaCIgF
- gJgPiLmBmBOI2aB6mIE0IwDSnmBluZcHuwAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACN0lEQVQ4T2Pw8/PDigMDAxlC
+ QkIEQ0NDHYA4CohTobQDSBwkD1KHoRGGgQoU4xKSk6Ys3th99Oqz9fdffTl+8/HbrYvWbOsDiYPkQeoY
+ fHx8MLCvr69gVGx8yrqDVxceufH60KM3384+efvtHAiD2DtO3FwSHZuQAlLH4OnpiQ07T5y/tm/3pRcH
+ rj7+eAKmGYavPfl0YvqSDRNB6hicnbHihG2nH6wBGYALH7z8ZBNIHYOdnR02nL/vyst9MMXoLgDhE7ff
+ HgWpY7CwsMCGU/ecf7gRl2YQPnXj+Q6QOgZDQ0Ns2HPy3BXT9199dfj+y6+n0TUDA/LcvGVr54LUMTg5
+ OTE4ODiAnW5ra8tgY2PDYG5uruLi5l595OK9fTeffUYx4Nn77xcv37y/w9rGtkRNTU0EwwBra2t5oCHF
+ a9eu/6+hqd0+cfrcpY9fvDvy9vPPa09fvT86b8HilRoamrWCgoJacnJyDCgGADVqubm51+zYsee/qKhY
+ MwsLixYQhwFxJRC3Q2kQX4yPj48BxQCg7RaBgcFtR46c+a+oqNQDVKQKxAy4MBcXFwMHBwcDzHbvhISU
+ CRcv3v2vp2cwDajAmJmZmYGRkZGBiYkJA6MAkDOAgVZy69ar//b2zvOAml1AGkkBHKKioi4iIiItQM3Z
+ QL4+EOsAsQYQqwCxPBBLA7EYEAsCMQ8QA93OwArEYOewADFIUgqIJYFYAsoXAWIhIBYAYj4g5gZiTiBm
+ A2KQHmYGBgZGANKeYGU4uD9WAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_forward" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1170,42 +1164,42 @@
<data name="arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T2P4//8/AyUYrFmv
- /RKDfsdlOLaf+4IBhh3mvZwJxDE2s54yWEx9wGDcdxOsXqP+FFgvVgOMe28wgDRA8RkgDcIxRBsAco1R
- z3WwjUB8ZsaT//9BtMWU+zFEuQDmHcOuqyAnn+m8+uf/lAf//oPYQNfFYHhBt+3iTKDgGVy48eyP/0X7
- vvzvvfnnP0gNUH0MShgAOUBbfv2vPfntf82Jb/+rj38F46pjX/9XHv36v2DPp/8ZW96DcfP5H/9B6tXr
- TsbAA1Gp/NAZkIa0Te/gOGHdq//BSx7+95x947/LtMv/HSdfAGMQO2PHi/8gPXADZPJ2nmk8+/1/2aEv
- /wsPfP4fvePdf88NL/67rnv+33nts/+mSx//15z3EIx9t77+D1Ivm78L4QLx9E0zxdI2nsGFVbd+/8+3
- +ut/o13f/4PUANXHAA1BpAOgIINIynoMLJy8jkEgftUZoZ3//8vt+f8fxBZMWB0DUo9iALdxJAOXUQQG
- 5o5YzADEZyR2/f8Ponkil8TwuNczsErqMIAAPAzAPCyASVSDgS1o7hkQZrUri2EW00RRhWwAE1CGD4hl
- gFgLiI1hmMmqeBmTUXIJlK8NpGWBmB+ImZENYAQKsEMNEQXSUjiwGFQzB5BmghtASXYGADrJ+mn64PZ5
- AAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB4ElEQVQ4T2P4//8/RRhM6LVf
+ YtDvuAzH9nNfwLHDvJczgTjGZtZTBoupDxiM+26C1WvUn8JtgHHvDQaQBig+A8UxRBsAwkY918E2AvGZ
+ GU/+/wfRFlPuxxBtAAgbdl0F2Xim8+qf/1Me/PsPYgNdF4NhgG7bxZlAwTO4cOPZH/+L9n3533vzz38Q
+ H6g+BsUAIAdoy6//tSe//a858e1/9fGvYFx17Ov/yqNf/xfs+fQ/Y8t7MG4+/+M/SL163ckYuAFK5YfO
+ gDSkbXoHxwnrXv0PXvLwv+fsG/9dpl3+7zj5AhiD2Bk7XvwH6YEbIJO3E+jM7//LDn35X3jg8//oHe/+
+ e2548d913fP/zmuf/Tdd+vi/5ryHYOy79fV/kHrZ/F0IF4inb5oplrbxDC6suvX7f77VX/8b7fr+H8QH
+ qo8BGoIIA6Agg0jKegwsnLyOQSB+1Rmhnf//y+35/x/EFkxYHQNSj2IAt3EkA5dRBAbmjlgMwmckdv3/
+ D6J5IpfE8LjXM7BK6jCAANwAXIBJVIOBLWjuGRBmtSuLYRbThMpAALIBTEDMB8QyQKwFxMYwzGRVvIzJ
+ KLkEytcGYlkg5gdiZmQDGIGYHYhBhogCsRQOLAbEIM0cQMwEN4B8/J8BADrJ+mnlo424AAAAAElFTkSu
+ QmCC
</value>
</data>
<data name="cross" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABfUlEQVQ4T6WTu0vDUBTGz1+g
- VBtB1KBgdSsUNFvHQoZChw4upWoRupYO7a6giw66KCj4wgciuAiKg5M4XcFBUHAVBxdXcfD4fTGJqaZT
- hx+353yPezNUVFU6oaMwL/YKDkXkCJyIuMDw5LzvE6cx87eAIaPNpvIEbqTA0z5qtVBrKfCN5qvR0Id8
- Xj/rdcXOAJYQ81apeNpLqRRovy/YxXOAuwPje7Wq146jr+WyciaPhYK3u8vlvB29zISfwAGCbEHYhOG5
- WNSLdFpvs1m9ymR027L02LaVGj30xhbAIBswrMN4nkrpXiLhcZBMKnfU6PlXsIjlElgBqzCtwXyGW08R
- DuCOGj30MhN+QlCw/GMwlwjGQY2edgUUzA3CAZzb7NyWF8zjOcDcIxzAeQG3kTiNmfATbAxTMNYRekIJ
- T87D2JM4jZmwAL8HwdiEyNw0wpMis5hHwRAYACOOyAw1ejCPMxMt6MKiF/T79OHsAd2AWgJYET3JfVjQ
- yd/5G8s+qAWdGU8YAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABcUlEQVQ4T6WNvUtCYRTGz19g
+ 3PIGkUlB1iYI5eYoOAgODi1iJYGr3EH3glpqqKWgoC/6IIKWoGhoiqY3aAgKWqOhpTUaOj3P7d6b5nWo
+ hJ8v5zy/81xR1X8RuvwN7t++iByAI5EcMHw573qEZbz5WcDAaKOhfDk3FbjZW60WZC0Fnmg+6nW9y+f1
+ 3XGUM2AJMS+Vips9lUp+9l2wjQHkthC8Vqt6mU7rc7msnMl9oeDubrJZd0eXNy0FCGQDwTqEx2JRz5JJ
+ vc5k9CKV0k3b1sN4XJnRoRtaAEHWIKxCPE0kdMeyXPaiUeWOGZ22gnkMC2AJLENagXyCrx7j2Ic7ZnTo
+ 8qatYPFLMOc4CIMZnU4FDMwVRB/OHXa5loJZDMDcQvDhPAeRhGW8CQriGCYgOggeIPDlPIg9Cct4ExTg
+ FwMjYyIzkxDGRaYxD4MB0A+G0iJTzOhgHgWx5oII6AF9Hr2gG3QBZhawgZ9HQSQo+Dsqn8s+qAWjmxJ/
+ AAAAAElFTkSuQmCC
</value>
</data>
<data name="layer-shape-curve" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABlklEQVQ4T6WS2y/CYRjHH4uN
- ZbRSU8sqM1FSsdEF5sKFzYXIoTJuwozKMcw9rurSDS64YWbOZ/+C/ynf5+33tn5lDvPbPr/v8x6e7/u8
- B+rceu8CcUUJmscZTZPW6qHiTx9Mk2HykLLZLFHH5lsCwQcr4Hae9rUnalt5IPfyvcAxtk/G7gipDPyp
- 1wBIKkpQgUwuNGATV/KOmhYuyTx9kquAJ/s2XsJABzhWJX9l0Jq4JUYYeNefmUHg4lU9q4+iXE6UyC3I
- ClQGnARsYALJWjn51wa8IoOEPjAKAyvQIO4BKdZvKygY1CD2gTCIgW2+HValzf0+HKJGtYVCd7lHPmlM
- 6gU7rGiXQxvAOOhvid8QIw7RFIiK+5VGnKwYiEm8WkG72rl0PQUczYtXOQP58YtjM34oDCdKA3toT8Sc
- BLwgWGJQ8l6LOqosbvGAgAHMNc5fqCv4yYDHa/0hssXOBuyz57uscgtlGNOAClAJtKAG6IAe1AETqAdm
- y8xphm9HUbHunwwMI5nhuvDRgTFyPCQq4N9/+ATdd0wu3kGkzgAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABeklEQVQ4T53SSy8DURQH8CMl
+ IRWavqJNpa2IoqotCV0gFhYSC6UebYVNEaGtZxF7rNqlDRZsiIj321fodxr/c800U4rWTX49986c87+L
+ DnVuvXdBXK58znFF06S1eejr0gfTZJg8JEmSiDo23xLYZLkCn3Pa156obeWB3Mv3gnNsn0zdkfwAf+o1
+ AEm58llQhtUBrDV5R40Ll2SZPskFkG/jJQw64H3ecKGAlsStIAK8689sEFp50LP6KBqLDuAhsMMEhrVK
+ Y9EBfCNDYx+MoskGGux7IMX11wDVSw34IAwx2EZDlqt85uc+BGh+ChD4BvmWXtjhinM5aj2MQ39z/IaY
+ CDAHouL/LRAgmriqztWupespcDYtXn0GKIu/OA7jD4WpAxyhPbHnIfBC8FvAX6vK6hYfEBhgrmH+orQA
+ XrX+ENljZwOO2fNdrkpAGWigAipBCzWgAz0YwQx1YLHOnGYwmJUrHpUYYBjJDBvDRwemyPGQCOCf/5Po
+ A913TC5y9DpLAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_printablepage_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1241,16 +1235,16 @@
<data name="block" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB80lEQVQ4T4WSUUhTURjH//fV
- hwgiRBnSi8xxG0qlBZZtajK0xir30MCQYI/51AQzFEXSUQ8JiiAqiGLMh0HhQ4U1aNBDHoiIZbYpRKWE
- DaHe/Tzf8d7rdu/ACz8+/ud83++ce7nQWrqhjb0/Ip4OavH0VgmCRX1yjogAbSRlZ7Xh5c7/zrV9MuEs
- +1btvUrQ7euCNvC6kJz/1S6dX9604Cx7cra+wxukADyr8kLrfWGSvbKyQ3XPv1twlvvZgh7o45EjgZK4
- dGg9CWbjUvIHnV34asGZ1419+GZ0hJdRLFCSSg+06Pz6uUSO3HOfLTjzugS+aY8atgTvgIBEmETqQts8
- 4F1ct1CCyFTGN+W2hi3BGyC53XE9vx/rJWbhXh+FQ/2Kmmt39iq6DtEfXP3dmYAoIKA+4oo8/V99G/3B
- GQfDtyDGRCsl8tEi4l/8+dAikkqQlIK/3ib6CZeDR0GIxx+baXLjJnE14dw+A6EES1Lwq7qBsqhwEGuH
- GP7QROOZG8TVhHPrhCGYk4Itl5cyOO3gfhvEYLqRnn4KEFcTzpefGIJJKchV1dK3U9UOon6I/tRFdXWu
- JpwvDBmCu8DsQykpxe1GiL639TS61lL0Cpz1mCGQ/0+ZpFxSacN9ohlLJ8MQpZB7s+ojHvPYpWbmA8tY
- cADrXMqIVYe9mAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T33PX0hTYRjH8d+5
+ 9SKCEFGGdCNLTiPJNEGzTU2G5ZjlLhoYIuzSrppgRqFEKXWRkAihQijKvBgYXlRUg4Qu8oWImH+XEJkS
+ NQK79+l93p33uJ0zOvDh5XnP+37PBqO1F8bo+yNjKyFpp4hQwTl5j4gA437K6U39i/2/3auHpPHM+45z
+ uUCvvwfG3Vf5MoGXv6h28auNZ953nMsFUgCeVPpgDCxp2xeW96lmYcvGM+/nnYE5Hj0KqIjHhHEzwTYb
+ kt/o9OyajWfet97DP2UisojCgIpUVMOIPV8/m8iQd+azjWfel+B/Vq0u24F3QFASWrQmvMcXfHPrNhWI
+ Tqb9k177sh14DST3Ll/JHsYHiM32DVIkPKScunT9T3lPjnnr4o/uBESeoAosy68e1LXTT5x0GbkKMSra
+ KJGNFRj7EsiG55BUgaQM/PY103d4XO6EIB58bKGJzS7iVeO5YwpCBeZlYLeqnrZR7hLvgBj50Ezj6U7i
+ VeO57akVmJGBHY+P0ih16W+HuLfSSI8/BYlXjeemR1ZgQgYylWdo40SVSywAMZQ6r342rxrP54atwA1g
+ +raMFHOtEWLwbR09XG0t+As8m3ErIJ8SqUyqcPAea8H88QhEMfLdtA7873FGNf5gCRHhH+tcyohrphD2
+ AAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_forward_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1265,18 +1259,18 @@
<data name="gear--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeklEQVQ4T6WQUUhTURzGz9zm
- GNMxJSasHFEbKzZDNmhbESNLRnMPc9pzDCKR6ikaFC1EKBEsCvWhslBovtSL4lNmgskV3IVtbrikpWts
- Tgx6k9CXf+e7d4VGPXXhx/nz/b/v29lhRMT+BykcCARYMBhknZ2dLBwOS2d3d7eX01PFu38HLzLgQEEo
- FDrDjb38PIxzb2+PdnZ2aL8Gz18LOjo6zkaj0Sfb29sUiUTuctP1zc0yAczQsIMH3gM38Pv9jHOzUChQ
- IrFM5XKJZmZmPpdKJQKY8/m8tIMH3mpG/gter5f5fL4jXV1d99PpFKVSSVpf/0LF4lcJzNCwgwdeZNxu
- t1zg8Xh8XLgFJibG89lshiYn4zmHwzEKMEPD7pcPmd8FTqczKooJmp//QEtLAq2srFBLy6kBpVLJAGZo
- 2MEDLzIc+QZ2u/3O4uIizc7OEs5MZpVaW539CoWCAczQ9nuQ4cgFVqu13WKx3APDwyMbyWSWpqffJ12u
- 0zGAGdqFt6Fd1fOmcn3MlECGIxeYzWbW3Nx81Ol0DQmCSHNzH2ltrURbWz8kMEM78cZLV7/fJsX4oYy2
- z8jYy0a5wGg0gn5BSNHU1DtaWBBpZORFYXk5S+BiPLxri7vJMuGiy9+ukfJx4yYPi2ys8ZlU0NDQAC61
- tbW/TiQ+kc128qnBYHggCBkCNQ8NlfOVMP0JGzWIUgE+lUrFtFptQKfTDWg0mmM4c7kKf9AiqSL1ScWg
- PqOI6SuO4jliQ3pR4pFevgHynCYOf1bmAmq1+govGgSYJT2mWzVt2In11aXZcf6LQ3r5DfhXw6nj8Jdh
- pn/SW/uK9ajT7EbtWDXDfgLZQt8vMfwSKAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeUlEQVQ4T6WQUUhTYRzFv7nN
+ MaZjSkywlKiJxWbIBs0VMbJE2vYwpz3HIBKpnqJB0UKEEsGiUB8qCwfpS70oPrVMMLmC98I2NzRp6Rqb
+ kwW9jXAv/75zr8WMeurC737/e/7nnI2PEdF/Ib88Hg/z+Xysp6eHBQIB+ezr63Nx+vdxVe7gRQYcKPD7
+ /We4YYCfh3GWy2UqlUpUqcHz1wKv13s2FAo9KRaLFAwG73LT9Z2dPAHM0LCDB94DBd3d3eBmJpMhUVyl
+ fD5H8/Pzn3O5HAHM6XRa3sED735GKXC5XMztdh/p7e29n0jEKR6P0dbWF8pmv8pghoYdPPAi43Q6lYKO
+ jg43F26BSGQqnUolaWZmesNms00AzNCw++VD5neB3W4PSZJIi4sfaGVFoLW1NWprOzWsVqsZwAwNO3jg
+ RYajFFit1jvLy8sUjUYJZzK5Tu3t9iGVSsUAZmiVHmQ4SkFLS0uXxWK5B8bGxrdjsRTNzb2PORynwwAz
+ tAtv/Xua5w352nCjiAxHKWhubmZNTU1H7XbHqCBItLDwkTY3c7S7+0MGM7QTb1x09fttUk0dSuoHzYy9
+ rFcKzGYzGBKEOM3OvqOlJYnGx19kVldTBC5OB/Zap51kiTjo8rdrpH5cv8PDEpusfyYX1NXVgUudnV2v
+ RfETtbaefGoymR4IQpJA1UNT4XwhQH/CJkySXIBHo9EwvV7vMRgMwzqd7hjOjY0Cv9AsaYK1MdWIMakK
+ Gwu27Dlio0ZJ5pFR+QfIcxo4/FqZA2i12iu8aARglvWwYb1x20pssCbBjvNfHDUqd8CfKk4Nh98Ma/wn
+ A9WvWL82wW5UT/JvnmHsJ9lC3y9ayCOwAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_selectpolygon_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1290,17 +1284,17 @@
<data name="layer--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACHUlEQVQ4T6XSXUhTcRjH8Qel
- QrwJDZWlUhBR2ZzpbV7UZQRGIERhrRdXahhS1lVedRFEKdVyg1XUaiCczVmbL80CG2svzgtHuMxUTp7T
- 2nbmNs2yq9P/d1xkXtigwYf/nvF8z84ZI1mW6X9QzTUXlDN1zPEsYRcNUfXVV3DEP5UYiKV/BqPp5cB6
- sINdNGhpX/sQNERTy6N8fMmVDeyiQUtVVwbhZCT5wzsb/TaUDeyiQUuaywOgFRPfPZ8ii/3ZwC4atKRu
- c8JpduvusLDgWG2cT9k8H6SnrtDXB46xL129AeEW+KYSFjRoqeLSSzg7E10aCfHpPhibSXIsMlr9wh3O
- N3db4f3DHY4/Q4OW9rS+gMaPkcU3LLS9nYibewPiXc4rdHE+RadyYl75rNMdlixo0NKui3Y4PyEsDA+H
- ok/Yt963+v5yj82K/Y6G90VWTezQ6zM8GrS0s9kGTcHpeafNLxiY7gy8Xz13F/doYufm2+UyriaJpvCG
- lmjHBQ5aPJOS3R4QTb+xxzAB5lruRLjYXBmH+rhOLrNUJ3MN23gyFRhpe2MPtLJf1tkXFB8rRjNnZi55
- qJYORI7Ka5F+c5A2leymrafMuucj04PsL9r/blJyrHWY04rlhqoU7P1cK6v0lencm6U8Necbib0K8tV1
- Bwvr9W1bjpmuryeno1RUzVbIOR2qOTRocYE8pohR/VPTxkek2zBOOFeavF/hwGWQJJEHwAAAAABJRU5E
- rkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACG0lEQVQ4T6XSb0gTcRzH8S9K
+ hfgkNFSWSkFEZXOmT/NBPYzACIQorPXHlRqGlPUoH/UgiFKq5QarqNVAuM1Zm3+aBTbW/jgfOMJlpnJ5
+ 17r9cZtm2aPr97kmmQ9s0MGL393xfd8/jmRZ/i9Uc80F5UwdczxLmEVDVH31FRzxTyUGoumfQSm9HFgP
+ ZjCLBi3tax+CBim1PMrHllzZwCwatFR1ZRBORpI/vLPSt6FsYBYNWtJcHgCtmPju+RRZ7M8GZtGgJXWb
+ E06zR3OHhQXHauN8yub5EH/qCn194Bj70tUbEG6BbyphQYOWKi69hLMz0tJIiE/3wdhMkmOR0eoX7nC+
+ udsK7x/ucOwZGrS0p/UFNH6MLL5hoe3tRMzcGxDvcl6hi/MpOpUVx7/PdbrDcQsatLTroh3OTwgLw8Mh
+ 6Qm7632r7y/3Vux3NLwvsmqih16f4dGgpZ3NNmgKTs87bX7BwHRnYH/1cXdxjyZ6br5dLuNqkmgKb2iJ
+ dlzgoMUzGbfbA6JpBXsNBfZruRPhYnNlDOpjOrnMUp3MNWzjyVRgpO2NPdDKvqyzLyg+Voxm1oySh+r4
+ gchReS3Sbw7SppLdtPWUWfd8ZHqQ/aL97ybjjrUOc1qx3FCVgr2fa2WVvjKde7OUp+Z8I7GtIF9dd7Cw
+ Xt+25Zjp+npyOkpF1WyFnNOhmkODFhfIY4oY1T81bXxEug3jyqo0lPcL4cBlkH5AnMoAAAAASUVORK5C
+ YII=
</value>
</data>
<data name="icon_zoom_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1321,64 +1315,64 @@
<data name="image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T6XTT0iTYRzA8efk
- Jbp0EOpQFy9drIMXVyhaEbWsjBUxTCmQOf8wojcYMWcmZKM/tsoKCXSXVtiqJdlaRmVeKjH7Y5pKUNvK
- zD+DuS3X5rfnWaeObi98eZ8Xns/z4zm8AhDZlBVWg8X+pqYymSnDysQ+m61GnpTRo6zYY7WaU0tL6M7B
- 5vNQchG2XYbiNii6ALuugbETKl1w8iF0D4F7EJRRVug1rS6RSmG+BZY7YJebLj2HEw+g5dG/tVPW3Aue
- YZj8Be9DoIyyYrvF0hBPJmnpGeD2YAj/KDz+JJPv4SD45PqehD0f4MUEjPyAr3OgjLJiS22tJZJIUNx8
- mB2OOpz+Pt7JCWrjhJw2Pk36OzAPX2YgGIa5KCijrCiqrj46v7jI6kObWF+vR2er4JTHRWf/M3wfJxn6
- NsvoVJSAhGkck9P/gDLKisKqqmMz8Tirdh8gt9zIWuMRNtZrFGqNbLWfYa/jChXtXZhdHqx3n9D+coTe
- sTDKKCsKjMbjU7EYBaYOdA1dlGhu9HYvB88+xdTxGmv3GI6+ENffhLn5+TfeYAqfvFraSCs2GAzW7wsL
- /x2ws/E+hlY/lc4BzDfeornHsXuDtPpnaeuPcvVVEmWUFetKS+0/5X0CkciyUkZZsSIvr2Zlfv7pTFJW
- yCdHlitbs8yUycn6b/wLvnCph/venGUAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACBElEQVQ4T6XTT0jTUQDA8Xfy
+ El06CHWoi5cu1sGLKxStiFr2jxUxTCmQOf8wol8wYs5MyEZ/bJUVEugurbBVS7K1jMq8VGL2xzSVoLaV
+ lX8Gc1uuzW/vrVPgoa0HX37v9+N93uMdfgL4rxb9mEliT2NjmcyUZWVit81WLXfKaigrdlit5tTCArrT
+ sP4MlJyDTReguBWKzsK2y2DsgAoXHLsHXYPgHgBllBV6TatNpFKYr4PlJtjlovNP4OhdaL7/Z+6UNfWA
+ ZwgmfsCbECijrNhssdTHk0mau/u5MRDCPwIP3svkcygIPjm/LWH3W3g6DsNf4dMMKKOs2FBTY4kkEhQ3
+ HWCLoxanv5fX8gS1cFyeNvad9HtgFj5OQTAMM1FQRllRVFV1aHZ+nuX717G6To/OVs5xj4uOvsf43k0w
+ +HmakckoAQnTOCZP/wXKKCsKKysPT8XjLNu+l9xdRlYaD7K2TqNQa2Cj/SQ7HRcpb+vE7PJgvfWQtmfD
+ 9IyGUUZZUWA0HpmMxSgwtaOr76REc6O3e9l36hGm9hdYu0Zx9Ia48jLMtQ8/8QZT+OTV0kZascZgsH6Z
+ m/trg60NdzC0+Klw9mO++grNPYbdG6TFP01rX5RLz5Moo6xYVVpq/ybvE4hEMkoZZcWSvLzqpfn5J7JJ
+ WSFHjixXtiLDlMlZ9A/79xC/Ab5wqYdFIGATAAAAAElFTkSuQmCC
</value>
</data>
<data name="document--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEklEQVQ4T4WSS0hUYRSAD5NF
- gyA5mFJRMOBEmJSPRYM43SyChh70mAEXEkw+B73KyNjglBpCtKlNUSAlQdimTQQh2HI2bmbRohatJGtm
- xAYf834fz7nM2ahzu/BtLv/33f8/9wfH9DQwzpmZm8TAf2i8NzUFd/x+uD05CWdsNgB+UWYwWSjgZjaL
- 66kUhhIJXI3H8XcspvElEEBaN0hYJMARrVZmKJ7LYZTEyPY2rkSj+GttDX+Gw/gjFMKPi4vID60dIiws
- a4FbPp/gTlBgI5ncN/JqYQEFi93+mAAGbni9wnAqn8ct2n6lCO+Ej0POsHhwzeMRRtI0g1g6rRvhADkj
- 4sFVVRXUDAUSmYxuhAdLjioeXHa7hbFcsYgpmoNehP8OOWPiwcX+fsGTp0CG5qAXWacjkuMRDzpcLmG8
- UCphlo5RKXJ/eRRblq5g3ctzy+ZZBU496QC40NMjeIsU4F1UirR87cK+jQk8NH/ij+H9UYB5E0B7d7fw
- sEQXpUCB3ZEHAfry50uEgs5/A3jwzbG/JAfhnWkOGhUFzjscjI9vWol2sTvS+knBrsjdPcDrI0Hg56TV
- Cqft9kfaXd0n0rukYusHm0bzqg2rntaF4HlNEF7UzLFvJOobrNZZCWgRgmfCg+Uj8S9ue9uJx1fO4gF/
- bZidsgs0CWg2ms3j1U1Nz/SoctZ+N7iMEcP1w9/YIUw7Q/B728HeTjIAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACDUlEQVQ4T4WSS2hTURCGf2IV
+ g1BsqIqKQqARqUVbuzAU47WKYPCBjwS6KELUVoNNJSUaGm0rBXGjG0WhaBGkbtyIIIW6zKabLFzowlWx
+ mqTUUG3e7+nMJaeLaK4D3+Yy/3fnzDlwjY/ruCcmzjGD/6Ht8tgYLoZCuDA6iv0OByAfatzIlMv0u1Cg
+ 5WyWouk0LaZS9D2Z1PkQDpP0MDYlEHRbjZupYpESHIyvrtJCIkHflpboayxGX6JRejs7S1LSx9jWBeeD
+ QYU3zYKVTOafkmczM+vYnM77DAScDQQUt7KlEv3h8RtJZBI5jvSqHE77/YqhHO8gmcsZSkQgvSqHUz6f
+ wpdnQTqfN5TIYqVX5XDC61XcLlYqlOU9GEnkdqRX5XBsYEDhL7Egz3swkizzN+lVOfR4PIqRcrVKBT5G
+ I8mV+WHqnDtJrU8PzlsnNex90AMc6e9XBCoskCkaSTo/9tL1lTu0aXr3D9PrbcC0Beju61PcrfJDKbOg
+ XnI1zH9+f5zRyP1rkDa+2PmTwxG8skyhTdNwyOUSgvLSqjxFvaTrnUa98Ut/gedbI5DaY7djn9N5TwRS
+ 9ZJrcz7qeuPQ6Vh0UNPD1igeN0fwpHlK8mZm+w67fbKW10uOIzuRxYpIrvjwy6O0a+EAbQi1xCRTy4I3
+ gQ6z1Tqypb39kRFN7pbPJo85bjqz+ZNkAFjWAEPwe9vSE1Y8AAAAAElFTkSuQmCC
</value>
</data>
<data name="function" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABIElEQVQ4T6WTsU4CQRRFdwnE
- EIkxKBL5BkKjDRQWFljQEwq0pCI2FFT8ABV+gB0dxMrEBAsTowmVxs5f8CvWc/GtWcdZDWGSk3nvvnl3
- Zmd3gyiKgk0IwjD00UafG4q967Sxr3BMww2cQtXitQx6NM1gL23nWE87wYQFV/81q+4ajBHvHGqJvGum
- ZdO6vhPUKd6DZj33hc0d03UvU2j6TqCGS1hAyXmEBvmD8X2hvhNcs0i4t95CewK9oVQD7foIA8dA38HS
- OPvL4ITiC2gONJiHpilW7dwMFH+9hcQYEb9B2bQ+83uiHufSWtKTBnXyZ7j9Yfk7KSCJ1YgNPojFKxzB
- PhRhF3ZgG/KwBTnIQgbC2KBCcgg6+sHaBpv8yur9BCINtCQt9llRAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABC0lEQVQ4T6XSPUpDQRiF4bkh
+ IsEgwb+gawg2pomFhUUs0gcLtbQSGwsrN5BKF2Bnp1gJAS0EUUil2LmFrOLmPZPvhmGYW5gMPJlvDsPJ
+ zY/L83whLsuylD6ejObUndKCNp5xiJbNqXulBed4xHqQJZUV3OIuypLiggGGkd1gPoHuNYtz6gk6eLNd
+ 5zPbj6Fc38sDukh+hEu8YjPIZB/vZpanCu5NnPfwCf1Cszwu0Lt+4CrIRP+DkTmyzIsLDvBtu9Niv7ZM
+ s/bTYJ4WBOsGv2j6k3MX+JuOfhVn6SkICzr4wos/la+68asoGJsf7GEDa2hgFSuoYRlLqKKCrCjYwTb0
+ 6Fv4X4Fe5pe7CSINtCR/xwMpAAAAAElFTkSuQmCC
</value>
</data>
<data name="folder--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3klEQVQ4T43SS0hUYRjG8Wfd
- SlwEZbTOiBZJy6A2bdyUmzZhWRAIrSIiccpmmkZtYMqYUvNCMjJOacZAihhjF7qpUwZFRIYilcygTqdp
- vIyXeXpf8TuLmA4e+PEe+N7/x1kcjNYBKl6HCuHepArTYaQWhofzUTLd60x2pPGYDsM+GF7+7mFutsuR
- 7kjjNR1ee2H41lL3uZrsdKQ70vhMh5dXYdSvzoS5Mt3hSHekqTcdnrth+FcSIWa/tznSHWn8psNQDYxA
- 9mc7FyabHC0nOihNYOgyEBN4csnWsDjVwsx48L+yP9o58cxFaRpEyaBLLhiotgUXJhqZ/nIzLz37FqsS
- F7mWy1G6oLZ4dADoq1rXmPl6i9Ynf156Nvawkjr/LC1R97VDl+jZCUQv4G76c4BzH2rz0rP4gzPUOW1Z
- 1H0BhIFmuSQeKcBs/+4d7Cvevu5F2X7OvPPYrI/X+TZ8ijrHk0n2nkebAJokXiwv578iu7YxOVJj+yVf
- 9ip0gjoPDefYfQ73BCA/YvMVueRaAVJ3iosYlFB1H9nHxBuXLfXey1jLMerc259h6Cwi1WVygTxbxNbb
- p/HYGvNxbtSdl55Fb5RSp+6ePIijGy0K5WVP5WG0+o/j6Wborjai8C+upHqE/vhN6AAAAABJRU5ErkJg
- gg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB00lEQVQ4T43STUhUYRQG4Hfd
+ SlwIWrhOCReFS8E2bdqUGzfhT0IguAqRxCkdnUZrwDKm1ExJJsZJTRlIiWI0xTR11KCIyFCikhnU8TqO
+ P5M6x3M+ut8ixosXHs7ivO/hW1zMNkEJNqGU2U+o1OxhplGrp20/UXTAGmcka/Yw7dQctNlPibUeS5KR
+ rNnDpENzHkZe0kH4hSXJSNbsYaJBu3ew6qX9lW5LkpGs2cOYXXPthzwU/9VpSTKSNXsYqdWa43+6aGe5
+ zdLfUDdJduQOEGB4d1tr2f3ZQbFF97Hiv7to6b2NJMsuvLXxgTc1mntnqZWi3x4mJbsfgWp2iw4TCZK8
+ 9DCYBwxVK62x74/I+OJKSnYLr8rV3NrbI8lLDz2sPxPwV+Fp9GszrX9qTEp2wd4baq4YBkmeAV6gnY8E
+ fSlYG84+Q0NZGcp4QS6tztVrxuf79NF7Xc3FcJgGKtHJgDYu7xYV0f98Z9MpPFOrbfArPniK1bw4naC+
+ m3jOAP6Z2uv4yN0URJ5knSY3F0XflfMUmrJpkXkHBToK1cwZjpGnAr6aAj7A3ymW9rgMr40FJ63P2pOS
+ nf/BZTUlW5KPq/+6SGXnyi/hmesaRk9CstIBkHoErqR6hFnddsMAAAAASUVORK5CYII=
</value>
</data>
<data name="ui-separator" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAKklEQVQ4T2P4//8/AyWYIs0g
- i0cNoEYYMDExVVCCR2OBGrFASUYaHHkBAGwz1S9OnHZ7AAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAPUlEQVQ4T6XMoQ0AQAzDwCpT
+ //bpAgZvFRwx8LQ9wWhgNDAaGA2MBkZjkrwLvBoYDYwGRgOjgdHAaGD811lsM9UvSFbKxAAAAABJRU5E
+ rkJggg==
</value>
</data>
<data name="icon_zoomselect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1399,18 +1393,17 @@
<data name="plus-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACY0lEQVQ4T6WPX0hTcRTHT3eW
- C93W3dTVlbLdoQbTejCMKDP/lJBs+CewJBnUY3vsvSACDXrpoYfCyig1IxekQWRei4WTscK2NbQ9bLt7
- GMzXe9nL5XR+V9u1KHroBx/4/s453+/v/AAR4X/QzfDEAfCsCmCaeF4twEx1gJgkQlswHdB7bIbNkkf3
- /hbgNb+slY6EO2Vfyq8My1e1i4Tvu185vNwhl1OPArx/C/Bag66ob92vDqxfQd83P7Yv9+kw3b92GXvX
- RlTL7MEoBXh/3WDCIZRPCVJv8pLa8+UCnv08hMc/nKPlNg/TrMZ6Z74Oqbsm90lAHuMLD+2BJqlN7oqc
- x7ZPPp2Wd92lAKZ/1jtWBrD+basM5DEC7vNTpyP9SutiDzbPn9JpmD2GhUIBs9ksVo3Xo/2BW6fmUSO6
- Xx1VgDxGwL09oc7IoOZ5fRKLxSJmMhlMJBKYTCYxlUphOp3GXC6H+Xwe+cci1s40aUAeI+CuLdQe7tPE
- YAvG43GMxWJ/NG9sbCA/KaJz9pAG5DEC7linPO9PKPY5N/LT4iZPxdLLTJfqc6SDLgXIYwSMWQKOaVGu
- XmpAfpEGGPOisTbpUp16uyecMpDHCLhVKZhu2yTnUqNqD9MWYTIsiPqf9bVJ6zXCtlCncmMWCchjBNys
- ALhe4S0btUb5kEu1r1LIKhnebME0Yft4QDWNWqJsFshjBACdOhPA4E4vd80smccdsjW0X+HjLo3BNKux
- HpvRZ+lsDyiju5PwgLCjC7q5GzDMvYARLqTDNKuxHkAzsZco2x7AUaGSqCGEf8AeYrMcC/gB3xr3gK0n
- sEUAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACVUlEQVQ4T6WOX0hTcRTHf10t
+ F7qtuzlXk7LdoQZqPRhGlJl/Skg2/BNYkgzqsT32XhCBBr300ENhZZQuoy1Ig8i8FjecjBW2raHtwXn3
+ IGyv97KXy+mc69o1MHrowOfy5Zzv93t/DAD+i63PMztjL6oZCyIvHS424wggU4hUhHRAv5GHvJjZqcBr
+ el0rHot0yb60XxmRr2uXEd9Pv3J0qVOuwBt5/lbgtYTdMd+aXx1cuwa+H37oWOrXIT2wehX6VkdVc+hw
+ jLx/FkzaXRXTLrEvdUXt/XYJzn8dhpOfLuBpa0jTjm7nvg+re6YOiJTBU7HgsS3QLLbL3dGL0P7Fp9P6
+ oUcP05D+ve9cHoT6920yZfBULHjIT5+NDihtC73QMndGpyF0AnK5HGxsbED1RD3YHnl0ap40gufNcYUy
+ RsGDfVJXdEhrensaCoUCZDIZSCaTkEqlIJ1Ow/r6OmSzWdjc3AT+qQC1M80aZYyC+1apI9KvCeFWSCQS
+ EI/Hdwzn83ngpwRwho5olDEK7lmmmz6eUmyzHuCDwhbPhVKYdGk/i4TdCmWMgnFzwB4UZMdiA/ALaCDm
+ BOPZqEt7ZO+kU6aMUXCnylV21yo6FxtVWwRfEUHjvGA8G7W+Q6zzdSo3bhYpYxTcrmTsZqW3fMwS4yW3
+ alvBkhUMvCtCGrF+PqSWjZlj5KWMUUBTV8bY0G4vd8MkmibsskU6qPAJt0aQph3dyKN7cbYXlCNOpIm5
+ dnWzHu4WG+FesVFO0iFNO7ox1oLsp8z2Ag6pQmoQ1z+gH5GXAwD2C98a94C4gBufAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_search" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1453,17 +1446,17 @@
<data name="scissors-blue" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACRUlEQVQ4T6VSS2gTURS9mSyD
- QRGtRlOxkM+gdcAQiIImMQYbE2tIqqVmJUHcWPCDkj4k/q2gYBcuahYuhIpWorgQsSqEqhUpmE1WQQrR
- QsBo1m7M8543HQ0ibhw43LnnN2+GISkl/Q8ok8lQNpvdxzBSqRRFo1EKBoPk9/vJ7XariR08dPjgRw4P
- VmQ+nxdAMpk0/lUA3fIipwpweTweUa1WZS6XE5FIxPjbCcBDhw9+5H4V8L3h9XpFrVaTfDQRCASM7lfA
- Dh46fPD/WYDd8Pl8ol6vy0QiIdho4BtgYgcP3Qr/LvDtJ9KzRKs3qRJ+smg0GjIcDguXyzWEiR28CsMH
- P+fMVxi8Q5S5R3RgmihyHkWGruui2WzKeDw+U6lUJHbwSocPfs51Fzho6EGacYkxSeFiuW/30flWqyWd
- gzfnKTVZVrypp7nA0V3goPTdse3F17NnyovfxmfanWsv2vJ46Y2077nexj0AHjp88HOBwzzB3tLBUOHl
- O5g8R6Y+2AduvLr87Iu0x8YrjAlMtTPfM1Kau/r8q4QfObMgNnGrO3z28Sep7bwwq4UvDmu7rpCavIO3
- SsSjz9+RMwtC556y2IFYfLIotdDYW22bGNG2HCbbxhhhqp35wsMFVXL6/scfyJkFm0dv7zg21cQpbFtP
- vbd5hw/ZnL3mL7p0YVc864XphQ78yJkFy9xR6h8tMeaod+AkM/34uxkbGOsY6xl9DJ31E8oHP+esX9nF
- ooW1fN/DWMlYznAuYQXPVYw1XV4XCn4Cnzlvq0a0CiQAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACP0lEQVQ4T6WRT2iScRjHH1+P
+ IymiVpaLBq9/qPXCRLCg1EyaaUt0NZankNGlQX8o3I+w/y0oaIcOy0OHYFELiw4RrQJZtRiDvHiSGFgD
+ Ictzl/z1fH9vrvcQXfrBl8fn+/08XwVJSvlfonQ6TZlM5iDLSCaTFIlEKBAIkNfrJZfLpSZ2+MjBgced
+ KoCZy+UElEgkjH8VIO+wuFMFeLqui0qlIrPZrAiHw8bfCuAjBwcedysF/Ay32y2q1arknyb8fr9hLcAO
+ Hzk48DiyFuAZHo9H1Go1GY/HBYMGCjCxw0cOzsQ7BZ5DRL4M0fpt8PDNol6vy1AoJJxO5xAmdvjIFQee
+ 78yCwXv8VzwgOjxDFL6IIsPn84lGoyFjsdhsuVyW2OGrHBx4vrMWdNHQoxTrCmuKQoVS777ji81mUzoG
+ by9ScqqkfDNPKd5S0EWp++O7Cm/nzpWWv0/Mtto3XrXkyeI7ad9/s4XPEHzk4MDjziw4UDwSzL/+AEgf
+ nf5oH7j15uqLr9IenSizJjHVzn73SHH++stvEjzuzILo5B3r8fmnn6W259KcFro8rO29RmryDr9TIp58
+ +YE7syB44TmHbYSFZ8tSC46/13aKEW3HMbJtjRKm2tnPP15SJWcffvqJO7Ng+9jd3SemG/gVtv4zCzb3
+ 8FGbo4eDPw+78jnPzyy1wePOLFjlilDfWJE1Tz0Dp9npY+msLaxNrM2sXpaP81OKA893ZgGR06KNrG7W
+ WtZqluO31rDWsTawVngpJf0CnzlvqzPbQEYAAAAASUVORK5CYII=
</value>
</data>
<data name="icon_zoomselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1487,78 +1480,77 @@
<data name="sql-join-right" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC50lEQVQ4T2P4//8/AyWYIs0g
- ixn0i7czGJbuZDAq28VnXL7bAoj9gTgSRHvUXghMbnu9MKXtzX0g/gWl5yW1vNKIrH7I4FdwFW6AnEfL
- wdiVxx5Pe/j6247Xn36eW7j95ZGougfvY5oeXG5f8vr82gNfHs3e9OFO7axXz6NrHz6PqLofBDOA37Vp
- f/zVxx/XPHrzdd+DV193Hb709kRA0aVPfctfPVqw/cOVpJ676xfv+nh12Z5P15bv/XSjd9mru775l557
- ZJ3XYNAt3Gq7+ND9afdffd1958WX7UAD9mS1nbuf3XH9xdLdn66BcMuSZ0crZj/eBzTg+pJdH6+AxLI7
- bjy3ijkwj0Erb1PE9SeftlyD4nsvv+43Ct3ysWvJ0+sT17450r7s1e6eVa8OhTVf29S98vW+pkUvtwHF
- djXPf3xBx2/TfQb17PVpQJsPXnjwYT0I33j6aZeK++o/ncteHqqe+2wTCPesen3Au+ri+p6Vrw/CxDqX
- vzyi4rb6F4Ny+uq4s/febTh55+2a7edfzNlw6ul0de/1H0un3DtVMefpZhBuW/biYHDD5a1Am/fDxEqn
- 3j+p5LL2PoN88nK3SVuuzdp4+umcnk03m2bsutvll3/4Vkjp+UfV855tB+HCaff3Z/Tf3lM7//nOsllP
- N4PEQksvPFD33DGPQTp+sZBO9qqihfvvTu7dfLO9ac3Vhp7Vt1aahJ34nN/34HLTomdHA+subgfSh4pn
- PAa5aHte38PzRiEnn+sFHNNg4NUPZBB0KVdXS1taWr7g5KR5++5OX3Pi8YKiydf3WsZe++SUdfVWdt/9
- M21LXxwvnfb0VGzdw4fWsTdfaDkvCpLUSmMAAWYgFmGT1DHmdyqLEw6ZWiQcPrtGOHR6oYRDXZZlxLnV
- DknPHjgmP//lkPT0oXnIsdXiKiFuID1QvQxMQAYXVEAKSEsCsSgQCwAxHxQLAmkxqBxIDUgzSA8T5ZmJ
- kqwM0gsAucRqK8NQIioAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC6UlEQVQ4T2P4//8/RRirICmY
+ Qb94O4Nh6U4Go7JdfMbluy2A2B+II0G0R+2FwOS21wtT2t7cB+JfUHpeUssrjcjqhwx+BVfhBsh5tByM
+ XXns8bSHr7/teP3p57mF218eiap78D6m6cHl9iWvz6898OXR7E0f7tTOevU8uvbh84iq+0EwA/hdm/bH
+ X338cc2jN1/3PXj1ddfhS29PBBRd+tS3/NWjBds/XEnqubt+8a6PV5ft+XRt+d5PN3qXvbrrm3/puUfW
+ eQ0G3cKttosP3Z92/9XX3XdefNkONGBPVtu5+9kd118s3f3pGgi3LHl2tGL2431AA64v2fXxCkgsu+PG
+ c6uYA/MYtPI2RVx/8mnLNSi+9/LrfqPQLR+7ljy9PnHtmyPty17t7ln16lBY87VN3Stf72ta9HIbUGxX
+ 8/zHF3T8Nt1nUM9enwa0+eCFBx/Wg/CNp592qbiv/tO57OWh6rnPNoFwz6rXB7yrLq7vWfn6IEysc/nL
+ Iypuq38xKKevjjt7792Gk3fertl+/sWcDaeeTlf3Xv+xdMq9UxVznm4G4bZlLw4GN1zeCrR5P0ysdOr9
+ k0oua+8zyCcvd5u05dqsjaefzunZdLNpxq67XX75h2+FlJ5/VD3v2XYQLpx2f39G/+09tfOf7yyb9XQz
+ SCy09MIDdc8d8xik4xcL6WSvKlq4/+7k3s0325vWXG3oWX1rpUnYic/5fQ8uNy16djSw7uJ2IH2oeMZj
+ kO3b8/oenjcKOflcL+CYBgOvfiCDoEu5ulra0tLyBScnzdt3d/qaE48XFE2+vtcy9tonp6yrt7L77p9p
+ W/rieOm0p6di6x4+tI69+ULLeVGQpFYaAwgwA7EIm6SOMb9TWZxwyNQi4fDZNcKh0wslHOqyLCPOrXZI
+ evbAMfn5L4ekpw/NQ46tFlcJcQPpgeplYAJiLqiAFBBLArEoEAsAMR8UCwKxGBCD5EBqQGpBepiwZhBS
+ MFZB4vF/BgC5xGorvamwnQAAAABJRU5ErkJggg==
</value>
</data>
<data name="drive-download" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACTklEQVQ4T42OXWhSYRjHH4KK
- iBNkX9AHWx9QeaQuDpTsZgu7CsRJGjIcqyAFiY0xhm7RFqxTdLPoqtjCm+jCPsCwUhtL86O0nRo2zZy5
- tXWR3qztYuUkfHqfsSOOsdWRHzz+n9//4YV6ZwFWQXB+xwYxUW5ge2E1D47d/FTh+K0xqLs7LWO79/XP
- 9Y7AvMgym5yTU92B2s5AhQOOEBy9NgJCf4Z4fCe1kLJ6ZlJsfkQZ7cip7qw4cKg7CoevxoDv+yj1vZ/D
- M4NfkGbKaLfmgf32N7eZ4FtCsoVmUHV/Atl/Sc7JWfaCvW2vQGZPq9988Eoo1Z4o4SVpAQXfPG5zzWH9
- 8C80RH9jjSOYJKe6UylTuPuyFxQXn5p3tfuT2pEybveWcd2zMqqCZdzR5kvSjpxlB060iECcPH8Djlic
- sPXCE9hsemDeYnUn66KItcOInMWdpIx25JAr90Cn0y2i1+vBaDTCaZMN9p3rh/WNg+aNLa6xDQyaKaMd
- OeTKvRUHSCBOnbUA39hZQ9As52sd4AwGQxPD+g+a2Au4ygu0Wi0s0RwOh8cTiQTG4zEMBl+j1/sSPR4P
- 4znDzwigy/VinPnNcg8EQQCNRkO0lkolLBaLODv7E/P5Hzg19Q1zuRxjgjGNkpTGTCaP5FKHuosfz/Og
- Vqs7CoUCut1uFEURe3t7sKvLgXY70cMQ0cJ+sVgayaWO/G1iw06lUtnNnjuZzWYxnf6Mo6MfmPwOI5EI
- I8qI49DQWxwYeDhJLnUY1AUFQ8VxnEmhUIj/A7nUoe5fouy03kA6Jw4AAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACR0lEQVQ4T42OX2hScRTHD0FF
+ hEG3f9Aftv5ApVIPF0r2soU9BeIkDRnGKkhBYmOMoVu0BesWvSx6KrbwJXqwP2BYqY2l+ae0WcN2zZy5
+ tfWQvqztYeUkPP2O7MpdsepePnDu+X6+hwuNruJK8K4v2CSkKk00/5bVgEPX3tc4fH0cGm7NSNhvf/p5
+ pTO4INAs7cmRd6C+K1hjjzMMBy+PAj+QJR7cTC+mbd7ZNJvv044ycuSdZR8U7uuJwf5LcVD1v0v2v5nH
+ E0MfkWbaUfbXA7sdL28wwb9E0h6eRfWdSaRZ2pMj78DO9uc1drQFLHsvhtMdqTKeTy4i71/ATe55bBz5
+ jsbYD6xzhkRy5J1lB7Zf8AF37pFlW0dA1I1WcLOvgqseV1AdquCWdr9IGTnyDhxpFaocPXMVDlhdsPHs
+ Q1hvvmvZYPOIDTHE+hFEhdUj0o4ycsiVeqDX66sYDAYwmUxw3GyHXacGYHXzkGVtq3t8DYNm2lFGDrlS
+ 748DEsdOWkHV3FVH0CzPVjqgMBqNLQzbP2ght3ZAp9NJnI5EIhOpVAoTiTiGQi/Q53uGXq+X8YQRYATR
+ 7X46Qa7UA57nQavVEm3lchlLpRLOzX3DQuErTk9/xnw+z5hkzGAymcFstoDkUoe61UelUoFGo+ksFovo
+ 8XhQEATs6+vF7m4nOhxEL0NAK3vj8QySSx3pWcfYqlQqe9jvTuVyOcxkPuDY2Fsmv8ZoNMqIMRI4PPwK
+ BwfvTZFLnaUucAy1QqEwcxwn/A/kUgcAuF+i7LTexweyfwAAAABJRU5ErkJggg==
</value>
</data>
<data name="cross-script" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACFElEQVQ4T6WTT0iTcRjHn3D6
- 5nJbr+2dZo3Ci0KE6EC9rpNEl52yS4HFhKyItJIKCwnBlVYUFh0a2b95yYJRHdYunYJJZBZEeogxhJAu
- ecnSt88zt5cF0WWDz37P832e5/v7A6/Yti3lUNawbpw3SIjIlEgXZArcfII2CXfhHjwE+nZRH4JnEHUM
- tAiZ3wMD9nJf39pMe3tO8/slBg9ERhNVVe/QXz8S2QsbHIM4jRBlp8zbjo7ct54eO9vdvTIdCHziBKEp
- rzeebm5eoJ6kb4duiEH+9Pk/NdBj3qF5QiQGmZlw+PvnSGT1ZVNTNt3SkkV7jlm99v7PQK7TMIbROCap
- 1tYfqVBo5XZ19Ry5XANdlb9OcAmhyLCINcIjJRoaFpONjT/HDWM27vd/HausnKUmF2CwgHOFonCewpDI
- jceWlUsHg6sxw5i7KHIY7ektt3ue9cW5fxmcRFROi/ROeDzzmbo6e9Lny51FYkh06AzGMZfrI+tIP/mp
- 0kc8RnKc1z3Bvd9b1q83prlMnMTUVGM9oQ6gDcMresM641whSgJX4253bqG21h6sqPjQy0NG0Iu/ToKj
- 632XYfSIiMsxqKdwiN2/mObadE3NEvGVrSXDpWHbem9/l0ibY4C2ncLBA5jsF0kFRPag7QRC8YEHNoMF
- 24IinbtF9pUaeCn4QTdWdFAHNsFGMAqr5tprwhbHoJzP+Q95lHpGrVHH8wAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACCUlEQVQ4T6WQT0iTYRyAf+H0
+ y+W2Pts3zRqFF4UIsYF2XSeJLjtllwKLCVkSaSUVFhKCK60oLDo0sn/zkgWjOqxdOgWfRGZBpIcYH0FE
+ l7xk6dfzi+1LQYLqhWfv+/v3vPtecV33v1gx+Tf8+smIyLhIG9hFrtwnNwY34CbcAfq2UOuHh5D0BFoE
+ +0dvrzvX1bU42dLiaHxrieC2yFCmouIl+Wd3RXbCKk+QpgGSNNovWludTx0dbqG9fX4iEnmLIDYeDKbz
+ jY2z1LP0bdILEfz+BBXoLddpHhVJgT0Zj395l0gsPGloKOSbmgrkHiGr1d4/CeQSDCMaQZJrbv6ai8Xm
+ r1VWThPLRdBdWSY4S1BiQMQa5JEydXUfs/X130YMYyodDn8YLi+foianoa+IJyglTkG/yOV7luXko9GF
+ lGFMnxHZT+7BVb9/hv3xyWLvMsERAuWYSOdoIDBj19S4Y6GQc4IUQ6JDxxGnfL437IM9xEfBExwiOMzr
+ dvPdryzr+3PTnOOcRWqqWG/TAXID8JTeuM54giQBXEj7/c5sdbXbV1b2upOHTJAvre1wEOg7B0MHRHye
+ oJbCPm5/b5qLE1VVnzmfX69TK6xtQL2njaMnYG2ksHcPkt0iuYjIDnKbgaOEIABrwYINUf7QVpFdSwVB
+ CINerOigDqyB1WAUd42114R1nuDfceUneZR6RqCIHXQAAAAASUVORK5CYII=
</value>
</data>
<data name="sql" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABE0lEQVQ4T82Tv2rCUBjFb+ji
- IF1KKfgATtJBtFOW6gOIi2hBEAJm8QncpHXxBRwEB0cVRHBx0Uknh76CD+AzpOeEc+EmSJd06IUf5/tz
- vi83hJgoikwWMg3zwf9gged5PliDqdRAX8Cn8jm0CXhGqtHfAobmDWiDkmLWxmACnkBd9VcOOH7G8YId
- CNTsSFnrKn6Q58Pp2The8A72oCYDa8ztgnSe6MXX0DWPUuaMe85CN0/0aLbXHyA+aYjad16BufW5cZkL
- LsaYCjRkrKEZdIE6v0ZD9ap69ISa4ay5grM0gBbAG9iq9g0dqr5UjTNkxQU58AieZeICy5eWF1M9ejnD
- 2V9PHt0DuAH/rjPLn/gnP9MPy8pUmKBE2kMAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABEUlEQVQ4T6XSPUoDQRjG8Vls
+ UoQ0IgEPkCqkELVKox5A0kgUBCFgGk9gJ2rjBVIELCxVkICNjVZaWXgFD+AZ1v+zPAOTOIiLA7+d933m
+ g12SUJblv2TDOrJhHdmwjlAURR/3mHhW1sa5+2sMoHEGZbKH6oIHDNF1rewSV1jGDpT3kO5XXV3wiJGD
+ fc/KDl0vuT9wn9bVBVt4wnYM3ccLFvu5tbhBr/niWb3qI9eL/dyaHvH1T/DqWvOxa32C+rgvrdf0eA8h
+ rDOPVXthihty/Rq7zjdQ7cfYZ3Q2fOLN8wir2MTM2QdOofzWWXSH0EALK9Cm1AV0eSfJRHt1Rmd/HU08
+ 4wt9BT9G7u9ZRzb8uzJ8A8vKVJj1/8sZAAAAAElFTkSuQmCC
</value>
</data>
<data name="gear" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACHElEQVQ4T6WQT4gScRTHf66K
- iB30YlEpEcoSaiwjhFMHYWGR1IP/7uEpIjoFQlEdFmIJOhRrpy4t1N538ZRtC5vMgiPoOpIt2WYybot3
- Cby83nfIYRaCDg18eI/v+36/MyqISPwPRjidTotsNivy+bwoFArGLJVKMnP7D7L1Bi8yyJ4qyOVy19l4
- h+cFzNlsRtPplKwaPH8tyGQyNyqVyovJZELlcvkhm+4eH48JYIeGGzzwnvqCVColmHvD4ZBUtUnjsU61
- Wu2rrusEsA8GA+MGD7zImD9BlmWRTCYvFovFJwcHHep02nR09I1Gox8G2KHhBg+8yJgFiUQiycJ9sLHx
- ZtDrabS5+a4fjUZfAezQcJv7kDELJEmqtFoq7e5+pP19hbrdLsViV9fsdrsA2KHhBg+8yJgFkUjkQaPR
- oHq9Tpia9pmWlqRVm80mAHZoVg8yZkE4HF4JhUKPwPp69Xu73aPt7Q/tePzaY4AdGm5zHzJmQTAYFIFA
- 4JIkxZ8rSot2dj7R4aFOJye/DLBDww0eeJExC/x+v2BWFaVDW1vvaW+vRdXq62Gz2SOAHRpu8MCLjFng
- 8/kEc3N5eeWtqn6hxcUrL71e71NF0TigEXZouMEDLzJmgeDH4XAIt9ud9ng8ay6X6zJmv/+T/9ARWTV4
- 4MVjLYBylokwceB0Om9x0TOAfa7zjDHn8E5rwQILZxg/c/4f4EXwLqDgN4SU6ia8nlT3AAAAAElFTkSu
- QmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACFklEQVQ4T6WQT2iScRjHf05F
+ xA56sVEpI5QRaoxXGL51EAZDph78dw9PEdEpEIrqMIgRdFjMnXZpULtveMrWYMk78BV0vpKNbJm8ruFd
+ Ai9Pv+9L/nijoMOEj7+H7/N5voKMiC6E8ZVMJlk6nWbZbJblcjnjLRQKMufub2TzDi5u/irIZDK3uHCP
+ v1fxTiYTGo/HZM7g/LMglUrdLpVK66PRiIrF4mMu3T87GxLAjAw7OHD/KEgkEuBBv98nVa3TcKhTpVL5
+ ous6Acy9Xs/YwYGLG1EgyzKLx+PX8vn8s+PjFrVaTTo9/UqDwXcDzMiwgwMXN6IgFovFefAQbG+/7nU6
+ Gu3svO2Gw+FNgBkZdlMPN6JAkqRSo6HSwcEHOjpSqN1uUyRyc81qtTKAGRl2cODiRhSEQqFHtVqNqtUq
+ 4dW0T7SwIK1aLBYGMCMzO7gRBcFgcDkQCDwBGxvlb81mh/b23jej0cWnADMy7KYebkSB3+9nPp9vTpKi
+ LxWlQfv7H+nkRKfz858GmJFhBwcubkSB1+sFq4rSot3dd3R42KByeatfr3cIYEaGHRy4uBEFHo8HrCwt
+ Lb9R1c80P3/jldvtfq4oGj/QCDMy7ODAxY0owMdmszGn05l0uVxrDofjOt5u9wf/QwdkzuDAxcdcgOQy
+ J8SJArvdfocfvQCYpzknwpnl2MwFM5xLHC/nyn/AD8GdISL2C4SU6iawP8yWAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_print_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1583,37 +1575,37 @@
<data name="minus-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACC0lEQVQ4T6WSP2gTYRjGP5JA
- EyhNc0M8SotbAxU7pNDsNRA6hLQIpXiVzi0d3RVEaAUXBwexYgT7T9EKcfHfWQlSJJfmUFAhZOgJRocM
- yh1ZjtfnCXq0pY2DgR+8933v87v3u3xKRNT/0AnfV0o9ABtgU6mBLaWWwBoo/4H1EvfYw15mmD0qyD+O
- xcxaJuP8mJtzfy0u+j8XFvzvhuHujY873IMgf5Ig/7S/32oahvdtfl4cwzgE177Oznrb8bgFQf7QBEWO
- Fo2a+zMz3pfpaflUKBzL56kpqRcK3npPj8lMcIS7ON+7dNqxJyfl/cREV/ZyOXk1MuIwEwhuK7X+IZdz
- zUxG/vI8nZbtVErWBgflXjIpdzStA+tSKuUyEwhu4Wvj7f6LsTFpt9vSaDSkWq2KbdtSr9el2WxKq9Xq
- UEwk5NHQkM9MILiJByub9Z8ND0utVpNKpXJsmIItCJ7ous9MILiBcd6MjroljLiBhm6UKNA0l5lAsMKL
- k0zu7+B8r9HwL4qxmMNMILiGv+R6OGzu6Lq3iyl2ITmJl/G4txIKmcwEgqu4lpdxOZYjEausaZ4NiQ3J
- Ud4ivBwOW+xlJhCgVqfBeWxcgn01GnXKfX3ux0TCJ6y5xj32sJe/g4IInk+BMwNKncsqdeWCUg8v4ksT
- 1lzjHnrOAh1EDgpCWOgFSYC+rvBF7A1R8BuYvt7nXvKiFAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACBklEQVQ4T6WSTWgTURSFL0mg
+ CZSmmcU4lBZ3DVTsIoVmXwOhi5IWoRSn0nVLl+4VRGiFbrpwIVaM0B9raSvEjX9jJUiRTJpBQYWQRUcw
+ ushCmSGb4XpP0EcraVw48A133j3nvJ95xMz/Rev1kIjWhS3hEVHfNtGisCEUf4N6ET1ooIWnXcDEbixm
+ VdJp9/vsrPdzYSH4MT8ffDNN72h01EUPmrMCJp709tp10/S/zs2xa5qnwNiXmRl/Px63oT0VkMfSolHr
+ eHra/zw1xR9zubZ8mpzkai7nb3Z1WfCogPuyv7eplOuMj/O7sbGOHGWz/HJoyIVHBdwl2nyfzXpWOs1/
+ eJZK8X4yyRv9/fxA1/meprVAXUgmPXhUwB05aZk9eD4yws1mk2u1GpfLZXYch6vVKtfrdW40Gi3yiQTv
+ DAwE8KiAVfmwM5ng6eAgVyoVLpVKbc1gWwL2DCOARwWsyHJeDw97BVnilgg6URD2NM2DRwUs4+Lo+vGB
+ 7O+VCP5FPhZz4VEBt+SX3A6HrQPD8A9lFYciOosX8bi/HApZ8KiAm3IprsvlWIpE7KKm+Y6EOCL+mzdi
+ XgqHbWjhUQF4zguXpXFN0teiUbfY0+N9SCQCgBpj6EEDLZ6TARHhnHChj+hShujGFaLHV+WkAWqMoSea
+ i4IBz8mAkNAt6ILoOoKJoA0xM/0CmL7e56qYTa4AAAAASUVORK5CYII=
</value>
</data>
<data name="globe--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADV0lEQVQ4T3WPf1DTdRzG327K
- 5WnY4RWnZ51pU0AvuXUlanJNVDDvILs8y5MpWaDmxWkCd96pSQgxmGBGOgc7ajBtuo7MdfxQ+wM1xmAT
- 227MpjOSTVwEDLG1cI/vz+KuP7y+d697Pt/353me7/tLkn0/k6TIStLPfiVp2W9PSVX9q6UVPhVzjmmb
- UFV0Lu7ZJ/zRHPPvQRQUu+fypWZpbZ+97MofAYMzGDrvDka6R8ZDjZ6HgTUGn13cC9+TBYWWuTMO2Zvy
- f+jznXUNoSs4jkbnCLS2IVy7H4IrDLj+Bo5aB33CJ2H/fxvkmadKdrXq8ptu+cvb/Wj1h7gggkbHEEzu
- INoHQugcHkfnGHDtAVDa7vMLv0Tk8sxEk7YY0pP2Nzu3fnsTO8578bX7AYov38WBS3dxuncUPw0CB80e
- 6Hn+3T3g3O//QFbwo1PkJm3Wc8GGE18o62xDGToX1tT3Ikvfi01GD7JNt7GzyYst9TeQedyCqp4w9nPb
- +6Y72Mx+kWOIKL28eY/5XlhR48CSqm6knHRghdaB1FonXq+xQ2nyoejqI+xuG0NqlQ3JFVa8edIWFjmG
- CxSHLSmHLkbSdP2QHbEgobIbiZU2JKltSFRZIVfZkFrtwjumMTy/rwVyNZdXdkREjuGCNz5tWaGyhl8s
- 7sBLZV2QcWDhBAmsspIOvFbtwdrGMbyQ34L1JmCDfiAscgwXpB35clFR8/CC8htIqPgFi486kFzlgPyY
- M0qyugdLj3mwpKQHM7U5iDWuxizdtpDIMVyQoV4Xl62/+Qqb5MzymttYpfEivdaLjLo7WKv1QnHCg1dL
- 7Yg7k4YP/ixAzKnkECk/Xkd7s7gg86up9JamIeFgZ2CVxo/M+gG8Z7iPbcYAtp8NRHV+/Q7M0C5HvEGB
- jYFc0HHZINXNtFFtnIZo0zdE7zbMm5xtbJWXOQLKM8P4qCmITy6MotA8GtXntCuh8L/9BFTzTBevwE98
- Ev9KyTzK+b5hTuFVd5a2f3iXaSRccOFhROic6py/pnz+cohKZYOL+1aCKmO7oqhjeQMiKfMsk0hPx6fQ
- stwPSWnUUW5zG+W1WqIq3sX8wHTXbO8i0OHp12n+ZCmXRL8vYaZNlMxm/X92xugob8p12h2jncjRY8Vf
- HJIr03vAAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADUklEQVQ4T32PbUyTZxSGj1TJ
+ jA4XjBKNW5yuDtAoqVGZTrKKCmoCumxxGqmyTfArkm0CiYk6GYIUKjiH2BUaXKFz1S7M2YUPt/1gOkqh
+ FW1Tqp11TFqxY0AR13Ws987TmPjDxDe5cvKc576vPC9FHfqVogotJPnsDklKf39BouxfKyn3KplLTNuT
+ qYzsxT3nRD7SY54Kilxz+VK9orbPVvrLn369IxC87AqEu0fGg43ux/51eq9N3Ivcs4IC89xpx2xNed/3
+ eS86h9AVGEejYwQa6xCuPwzCGQKc/wCnLINekRP5p4Jc0+Sofa3avKbffGXtPrT6giwIo9E+BKMrgPaB
+ IDqHx9E5Blx/BJS0e30iH+nlmogm7NCnJR5uduz85jb2XPbgvOsRin66jyM/3sfXvaP4eRA4anJDx/tv
+ HwCX/vgX0vwfHKI3YbuOBVtqPlfUWYfStU6sq+9Fpq4XWw1uZBnvYm+TBzvqbyLjjBmVPSEcZtv7xnvY
+ znnRY4goraz5I9ODkLzajiWV3Ug+Z8cqjR0ptQ68WW2DwuhF4bX/cKBtDCmVViSVW7DxnDUkegwL5MfN
+ yceuhlO1/ZCeMCO+ohsJFVYkqqxIUFogU1qRUuXEO8YxvHyoBTIVyys6wqLHsOCtT1tWKS2hV4s68Fpp
+ F6RceP0J8Yy0uAPLq9xY3ziGV/JasMkIbNENhESPYUHqiS8WFjYPLyi7ifjyW1h0yo6kSjtkpx0RklQ9
+ WHHajSXFPZiuyUaMYS1maXcFRY9hQbpqQ2yW7vZSDsmYldV3sUbtQVqtB+l197Be44G8xo1lJTbEXkjF
+ h3/lI/rLpCApDm6gjzNZkHF2Mm1WN8Qf7fSvUfuQUT+AbfqH2GXw44OL/sicX78H0zQrEaeX411/DuiM
+ dJDqplupNlZNtPUrovca5k3MMrTKSu1+xYVh7G8K4JMroygwjUbmTM1qyH1vPwNVv9TFT+AvLpF/pXge
+ ZX/XMKfgmitT0z+8zzgSyr/yOCzmnKrsvyedXBykEungor7VoIqYrgiqGH4BkYSZwSTQi3HJ9EbOblIY
+ tJTT3Ea5rebIFGexPzLVOduzEHR86g2aP1HCEtGnKGYKIySzn8veaC3lTrpBB6I1fOYe0f/FXxySylY+
+ MQAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_pandown_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1649,14 +1641,13 @@
<data name="server" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABaUlEQVQ4T42SMWvCUBRGr+LU
- jqVQujh1dtDFxSVDBhFB9DdokCAigpNDBscundw7+A8cRDAEFKQiySAYXESy+Ceu95Z3H0IerYGTId+5
- ZwogIjSbzV9arVaNaP9DTXy+BX41Gg2hc71eMUkSI7yR2xFfB+r1Oiicy+WCcRwb4Y08R3wdqFaroOj6
- vo/r9doIb+R1xdcB27ZB4Z7PZzydTkZ4I88VXwcsywJF73g84n6/N8IbeT3xdaBSqYCiP5/PcbFYGOGN
- vL74OlAul0ExOBwOGIahEd7IG4ivA6VSCRTD3W6HQRCkmE6nyBt5Q/F1oFAogGK03W5xtVqliKIIeSNv
- JL4O5PN5UIw3mw0ul0sjvJE3Fl8HstksKGb0G+NfkDcTXwcymQzkcjnmy3VddBwnRfGniLyxwy7f6ADQ
- Q9UPGj4nkwl6nmeEN3bY5Zv7wAsV2zR8PwK5Hbp/vQ880Yc34v1B2H3mwA1XqPmpzb5U7wAAAABJRU5E
- rkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABVUlEQVQ4T42SsWrCUBSGE3Fq
+ x1IoXZw6O+ji4pLBIUggxGfQUEIppdCpQwbHLp2yd+gbZAiBSEBBGsQMQoJLkCy+xOn9hXMRcmkNfFn+
+ 73zT1YhIcxznxGQyGQum/zBmH7enn23bzOx4PFJd10qwwWFfBizLYtzD4UBlWSrBBod9GTBNk3lcLBa0
+ XC6VYIPDvgyMRiPGq6qK9vu9Emxw2JcBwzCYp6IoaLPZKMEGh30ZGA6HzHMYhhRFkRJscNiXgcFgwLzs
+ djvabrdKsMFhXwb6/T7zmmUZpWnaIAgCwgaHfRnodrvM23q9piRJGuR5TtjgsC8DnU6HeV+tVhTHsRJs
+ cNiXgVarxXyLp0p/AYd9GdB1XWu32+DT8zxyXbdB76dH2ODAxY0M4BPFBzF8zOdz8n1fCTY4cHFzHrgR
+ xakYvi5BuDNxc3seuBLcCe4vBO41EWm/V6j5qYaWq90AAAAASUVORK5CYII=
</value>
</data>
<data name="icon_buffer_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1671,24 +1662,24 @@
<data name="grid" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAApklEQVQ4T6WTMQrCQBBFZ0+Q
- NljkrjYpU3oKEUFQhBQpAjZewAt4jXX+kpG/3V8S+PAW/r6dKWI5Z9sTSykhR8+5IeiXh0Nw2UQ4y8yC
- KwlkZsHNBZFRYHSrFe40gcw8wZMEMrNgdkFkEhjdaoWFJpCZJ1hJIDMLXi6InARGt1rhTRPIXCbYvs+f
- zGQOweCXH55vQ9AfQtD5ofccGoJ+VwR7fmXc/QGbydmsomqW4QAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAkElEQVQ4T6WMMQrCQBREd0+Q
+ VixyVxtLS08hEggkCBYWgo0X8AJeY/0TJjDb7cSFt/OKz0ullL9IOWdwCC4GuK8CV67lGhi4lmtgFI4N
+ DqrAxLVcAzeu5Rq4C6cGB1XgwbVcA0+u5Rp4CecGB1XgzbV8CfB9uHjNvgb6YA6+Brjv10AX7IK9Ae67
+ JYBvOyX9AJvJ2axM6V30AAAAAElFTkSuQmCC
</value>
</data>
<data name="ruler" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3UlEQVQ4T2PYn8jCsD+JheFA
- EksGEHdDcQZIbG0EM0gcJw3SywAiQIqAdM/fm8v+/7qy8D+IjU8jzGCwAfsSWTJBGpaFMF98sLnh/9dT
- 0//vTWQ5AxJbE8E8Bx8N0suwPZZlyu9ri/9fnej+/8fFef8/n5gKZ9/fWAcWw0aD9ID0MgBtmf92f8//
- baUm/+9tqP3/8eik/6dbrP4/29aMF4P0gPQyzAtgap7lx7QRyLn/9fSM/+8P9YMk7oPECGGQXgagIjCe
- 5MY0787aqv8gkzdHM88AiU30ZMSLQWoYloYwM2yIAuPZIOe/2tP5H8QGic30xW8I2IBOeyYYXnhzZdn/
- FzvbwH4DYlD4MMzAYwjYgJVhzDC8COR8UOABxRYhiTNM98HuErABjZaMMLz0+tKi/0+AaWFZKNNSIGaA
- YS0xRgZ0oCrMyOCrDhRfHMwEwytfAZ3/CBiVQLGVMHFNUUzNKIaJsTEwVBgxgvDqK4vy/z9YV/1/rj/T
- eiBm0CCkGWYSyDkTPBn3vAa64NmWxv8gNkiMWCAPVGiUasywsM2Z4TgIA9nzgGLKQCwHxBJALAzEfEDM
- CcSsQAwMPQQQADIloRikWAyIRYBYCIj5gZgHiLmAmB2qmRlIw50HAIdyTYaOb/frAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABxUlEQVQ4T42SWShEYRTHz10Q
+ CVkmXniQLI944cWDImUrSyIPoxRPSpGIiJQoS2Rso6GZmuwRKYyUCC/KkpKZpEkkSUqk45zbXLvLqd/9
+ zv3f7//v3O9esOllsJXIsF4ilxHtLspYmyqQWP91Za9ycd10vJxY8OnAhNxrGT8FrOnlcjZYcqV9x3wj
+ Puz046pe3mNtskAa1lrZC0vFcu/z0Tgedqfi474R77f73nr7XMOvK3vYC5Q2emPrwMWqeDybrce7zR7c
+ bUlE52KzJuxhLxizxebBTHGObuwPuwa83ejkB3bW/oK9QI1CT4poPJ2qVZLniyQDa91pgia8B8y5EswW
+ Kgzx+Fcrbcg9awMZ2iFKQFuSqGI6sVbj5XKr8m4Enw8YNEKUAGu+pDLG4/MBcf9Bh/70n0OUgKYEQcV8
+ bK7EC/oXLHmimQCVGJ0AXysiQICMSNLHc0QV6xWNf06fkntVjw76bv5UOneAmliBmTgYq0DHdB2OZIkz
+ BET9ZVaLx+lKE1auaQLnQhNyz9p/K4yILY0DU2sybDHUG0kLJ0KJYCKA8CE8CTeCTu+9/IgQF7xZRwQS
+ /oQv4U14ER4EmyXCNR7AK4dyTYa1Y09BAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_print" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1736,18 +1727,18 @@
<data name="question" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeUlEQVQ4T6WPbUhTYRTHH+9U
- IvVbllsQC99yTdSYJtbULHJOsKFpzT7obNNFRaKJhVDfNAuCAgvKFRQRFFb41iau1iLMWiyDam4ZE0nI
- 2GDu9m1yOufWvCpEH3rgxz33nPP/3ecyAGD/gxCWKIeYJHuESXKsiC1FkjtmRG4go3+g2ijMaId2MUPZ
- tQJNUqF9aI952ttyKRBqv8ZH2vr4SHNvIFTS7PHSDAWavwk0ycUOZ8vFQNjU8wN0bZ5VmHoWoKl7IbxB
- /dyJAs2aGwxKk/Ktw8bu72F9lx+0Jz7g7Vaf05e9QLP6c3PhRNXTYYlyUCr+guKxabdhyld35gtUtX6C
- iuNTcOXOR4FR57xg6h/wC7OaDi/sODTpk2BmWcBlPrTUnZ1ZLD/mhihlxjewU++AjgtOcLlc0Nk7Dmn7
- ByBT+wQK9C8WKSMK0u/b9F0zkX3NLihtmoS8g3bIrByB+nY7uN1TcO/RBGRUDEKGdlgA5xEOM6Ig9e5Y
- bef00q6G16CsdoBC9wy2VdnA5/MJZFWNCb0oObXOJQ4zokB++1aZ6X04V/8Wcg6LZB0YB2Jlj2qF7lWY
- w4wo2HLTnF5unyk8Og35jR6BXP07CAaDAlRH+/SUqa1fOcyIgs3Xpeu29lsLDV6+yDwPRS3fQNXweVlA
- NfWIvCMePl7eb+UwIwpkfYxLuapNSLNMFDTN8iWnQlCM5NW7BagmVI1+fn2qZYJ2OcwsCxiemPg0FpNg
- qIxP7h2Xq62zBYY5vrT15xJBNfVoRju0S2elIBbfNyHbGSffy2JrzrO4kw9YXNvL32BNPZoxlo2kILEr
- BRw2EpGNiOwf0IdolyPBL48SEnGn6e/kAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACaklEQVQ4T6WQX0hTcRTHr9uU
+ SH3Lmgti4b9cii7mGtbULFInrJFpbT3obJuLimQmFkK9aRYEBRaUKygiKKzQaXdjK1uEWYu1oJpbxkQS
+ MjaY9/a2cfqdm3pnFD30g884fM/5fi6MAoD/gvsRloxSwtIxSlhGE5xiYbnLRLhOGF8CZxO3wxu8JZ0/
+ CeqzVZ7RXdbpUMfFaLzrKpuwDbIJy0A0Xm0JhnCHN38T1OdUTXg7LkQZc/930NmCqzD3L0B73wKzTv3M
+ i7e/CUZysytoh6nvG6PvjYDm+HsSr36nLoUAd4azc0yW4okDOyReEsgemXcaA+GW059B2/kRGo4F4PLt
+ Dxzj3nlOMDQc4XZN3SHYdnAqjJ0VgaDogb3lzMxi3VE/LFNreg3b9RPQfd4LPp8PegbckL93GIo0j0Gp
+ f76IHV5QcM+p751J7LH4oKZ9CuQHPFDUOAaGLg/4/QG4+3ASChtGoFDj4CD7BHZ4Qd4dV3PPdHJH6yso
+ 2T8BMt1T2KJ1Qjgc5ijWurhsmbJmbxI7vEB662at+R1Trn8DZYd4ive5OVIzRKZ7yWCHF2y6YS2o88yo
+ jkxDRVuQo1z/FmKxGAfOyzkiUdNfsMMLNl7LXbN5iFYZQ2yldR4qO76CovXTigBnzBD54SCbIR2iscML
+ JIOUQHxFk5lvn1S2z7LVJ+NQRZAb/Bw4I4q2CLs2zz6Jt9hZEeBLy8in0jKNjRk5A26pmp5VGufYms4f
+ SQRnzHCHN3iLL1UgImwgbCX/6G5K1HSOSj9xn0q3vfgFmTHDHUWVEsQEUapAQMgirCdI/gF+CG8FAED9
+ BI8SEnFZTeEGAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_tasks_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1763,20 +1754,20 @@
<data name="map--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC6klEQVQ4T53Rf0zUdRzH8fdq
- 1srNWv2R6eZy8x9Hg9babKRTNmd/FG5l9Idbru2Cw8PjBII7EfAHKjI8ZcJR14DidjQOhniB2ImAml2C
- h07lPH+gB3IHIpMyTpCJPP186s/Wan63xz7/vJ7f7fv9SMqOHclK2jNI/qyoSGRDYaGRZ3h0p4h8kp+f
- PqdeUH+2gJbevZztryQ4UE9g4ATuK/3s6YlgOxMlyxfF3BrFdCSK3utOEVlvtZpm5+b4viuPjgE7PREn
- vSEnE9NdXJ28TsNojCJ/lOIgFATA5I2i97pTRD7KycmYefIEpy+LttA+um6X47tg5+7kUcan/Jz7fYiy
- 82FKb8DOy7CldRi9150i8qHFYp6enaWyNYPvTmTjOpWPt6+E7kvlXL7moud6Ow2hELv9g+R1D2E5PoTe
- 604RWZuRkRl7/JhDzek0BLbj7S/GfXo7vw1/S3jCw/2pTjqDnXhG/8R+a47sjkH0XneKyBqjceuDmRns
- P6bh9ltpvFBIdUcuJ28dom+khpEHLfSFmtSnDFIzPIOtO4ze604RWWkwZE88esTBWiN1p3Op77FRdczC
- sWv7ORU+TPCei0B/DcOxAL7xMXaeuYne604ReX/Tppzx6WnKq0yU/ZDKgYZUHO1mvmnfSu1JG42/7MYf
- rCJwpY6PfZ+z5GgiX/ZmoTtF5L2NG3PHpqaoLDfj9tqo6/yaA55UPH0FeIN71NUe5Mive4n80UxC2wq+
- mshVZxK6W1ywQuSdlBTryMOHOMoseBoLcbXlsd9twH3OStPFInW1JSQ1riSuOZ6ElndJGU8jvmU18xxv
- RqT6NacsT07Oj8RiOEozqSjLxF6RTmmNgdJ6A/YmIxU/mXmrehlJo5/+gzheDcjCxMRdY+qv3pmc/Fdf
- /LyF+LoP/vL2nVUkuFbxfPHrI2Jf4JSXli7dPD8uruT/eG7bK6OLwnHoU3ey7kXRz8vKG8qi/7T5hVpJ
- m3dJTOr8u5Onl817ThS42NsAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC6UlEQVQ4T53RYUzUdRzH8e9s
+ 5rKtXD4odWu59cThwLk2G+qSrdUDpa2UHrjl3E44PDxOILgLAU1UZHjKgsOuAcrtcBwM8QLJEwE1u4QO
+ m8p1WtiB3EHEpJQTZCLvfj+ftmbzv7322/77vB/8/z9J2bs3WUl7DslbiopENhcWGnmOR3eKyMf5+elz
+ 6kX9lQJaeg9ypb+S4EA9gYHzuG/2c6Angu1ylCxfFHNrFNPpKHqvO0XkI6vVNDs3x4muPDoG7PREnPSG
+ nExMd/HL5G0aRmMU+aMUB6EgACZvFL3XnSKyMScnY+bJE5y+LNpCh+j6vRzfNTt/TJ5hfMrP1b+GKPsp
+ TOmvsO8G7GodRu91p4h8aLGYp2dnqWzN4Jvz2bgu5uPtK6H7ejk3brnoud1OQyjEfv8ged1DWL4bQu91
+ p4i8n5GRGXv8mGPN6TQE9uDtL8Z9aQ8/Dn9NeMLDvalOOoOdeEYfYL8zR3bHIHqvO0Vkg9G4+/7MDPZT
+ abj9VhqvFVLdkcuFO8foG6lh5H4LfaEm9SmD1AzPYOsOo/e6U0TWGQzZE48ecbTWSN2lXOp7bFSdtXD2
+ 1mEuhr8i+KeLQH8Nw7EAvvEx9l3+Db3XnSLy7rZtOePT05RXmSg7mcqRhlQc7WaOt++m9oKNxu/34w9W
+ EbhZxybfp7x5JpHtvVnoThF5Z+vW3LGpKSrLzbi9Nuo6P+eIJxVPXwHe4AF1tUc5/cNBIn83k9C2hh0T
+ uepMQnfLCtaIrEpJsY48fIijzIKnsRBXWx6H3QbcV600/VykrraEpMZ1xDXHk9CympTxNOJb3mO+Y0lE
+ ql9zyork5PxILIajNJOKskzsFemU1hgorTdgbzJS8a2Zt6rfJmn0k38Rx6KAvJGY+OWY+qt3Jyf/02fn
+ dhFft/aplXfXk+BazwvFi0fE/opTXlq+fOfLcXEl/8e8L14dXRqOQ5+6kw8WiH4WKq8rS59p54u1kjb/
+ upjU+bQT+QeXzXtObOCHlAAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_popupscrollup" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1844,18 +1835,18 @@
<data name="gear--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACkElEQVQ4T6WPUUjTURTG799N
- zNnD9GGJpcRQJOZMNtCtGTPNxG0POn3oLUYPUREEwcCsMCmEiMpcTxW6UiNWgTYLNNNs/MVttOlGJi1b
- son4nA58Od3vvyUTeuvCj3P4zne+ey8jIvY/SMsWi4XZbDbW3t7O7Ha7VDs7O42ccxmM2TN4sQP2BLS1
- tR3jxvO8HkTd2dmhra0tytbg+WeA1Wo1OZ3OB5ubm+RwOK5y08X19SQB9NAwgwfePS9oaWlhnEvxeJwC
- AT8lkwnyer3fE4kEAfSxWEyawQNvZif9BaPRyMxm86GOjo4bi4thCodDtLr6g9bWfkmgh4YZPPBiZ0EQ
- 0gEGg8HMhSvA7R6KRaMRGh0dWa6qqnoE0EPD7K8PO7sBOp3OGQwGaGbmI83Pi7S0tERabXWfTCZjAD00
- zOD5MjRIMwpFVBSEBukFGo2my+fz0dTUFKFGIl+ppkbXK/AnAvTQMPN4POTu7ibq6aExQfgkBVRUVDSX
- l5dfAwMDrp+hUJTGxz+E9Pra6wC9pHlubptMJm8qlaKmkpJXg4ydkgLKyspYaWnpYZ1Of1cUgzQ9/ZlW
- VhK0sZGSQD/93kXvRo5Tar2L1Gr1vaKiouonjB8EqFQq0CuKYRobm6S5uSC5XI/jfn+UwMSbO9sTw/XS
- sru/lmprlM94ADutUKQDCgsLQWtjY/NwIPCNKiuP9CuVytuiGKHZyafk6pHHsPz8oYFO1he/hjezkw7A
- kcvlLD8/31JQUNCXl5enRg0t+GjyZZN08/0uYb7u6L4X8MC7ezIBUA5wNBw9yM3NPeNolfno9wrdupyz
- fKKOXcjMtLwW404pJBOQw9v9HBWnJAs6axXe2hsEW5aGi+DFDvsDd0bcBZIplukAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACi0lEQVQ4T6WNUUhTcRjF/9dN
+ zNnD9GGJpcRQJOZMNtCtGTPNxG0POn3oLUYPUREEwcCsMCmEiMpcTxW6UiNWgTYLNNNsXHEbbbqRScuW
+ bCI+pwNfvv7nbsmE3rrwu9/H+c45f0ZE/4X0s1gszGazsfb2dma326XZ2dlp5JzLYMy+wYsM2FPQ1tZ2
+ jBvO83kQc2dnh7a2tihbg+efBVar1eR0Oh9sbm6Sw+G4yk0X19eTBLBDww0eePcUtLS0gEvxeJwCAT8l
+ kwnyer3fE4kEAeyxWEy6wQNvJpMuMBqNzGw2H+ro6LixuBimcDhEq6s/aG3tlwR2aLjBAy8yC4KQLjAY
+ DGYuXAFu91AsGo3Q6OjIclVV1SOAHRpuf33I7BbodDpnMBigmZmPND8v0tLSEmm11X0ymYwB7NBwg+fL
+ 0CDNKBRRURAapAKNRtPl8/loamqKMCORr1RTo+sV+AsAOzTcPB4Pubu7iXp6aEwQPkkFFRUVzeXl5dfA
+ wIDrZygUpfHxDyG9vvY6wC5pnpvbJpPJm0qlqKmk5NUgY6ekgrKyMlZaWnpYp9PfFcUgTU9/ppWVBG1s
+ pCSwT7930buR45Ra7yK1Wn2vqKio+gnjHwpUKhXoFcUwjY1N0txckFyux3G/P0pg4s2d7Ynheins7q+l
+ 2hrlM17ATisU6YLCwkLQ2tjYPBwIfKPKyiP9SqXytihGaHbyKbl65DGEnz800Mn64tfwZjLpAnxyuZzl
+ 5+dbCgoK+vLy8tSYoQUfTb5skl6+3yXM1x3d9wIeeHe/TAGUAxwNRw9yc3PPOFplPvq9Qrcu5yyfqGMX
+ Mjctp5iTbskU5HD2c1SckizorFV4a28QbFkaHoKXZxj7A3dG3AXxRFgrAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_select" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1886,16 +1877,15 @@
<data name="document-copy" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB70lEQVQ4T42SPUubYRSGz+Kg
- IphFqCAFY4YiWboIUkyLhZjQWhULWVwcNJUgRqpECWazP6DkF9S2UkTqoAjBqnF3dOtQBC1YNOb7+/Tc
- Dz3yECvkgQteeN735lz3eWlybY3exmKvhZkH6JuIRmlsZQXvGUYnh8nf30aurhYiXArBXLXK18Ui/87n
- +TyT4V/pNO8kk4w7wWUHaOCg10MmWXiXLZf5TzbLF6kU/7y64rPLS/68t8c4uBdcOoEGvIlEiF4tLYG5
- XKXCN7mcCUmcnvLXoyNejcfveBEMfv+neKdkAkbCYRAqiMJtoWBCtk9OuBklE/AyFALzJQnISgcI2Rb3
- ZpRMwPPZWbBQrtU4Lz0gZOv4mG0l7eXjxgYrLp8vKhA9m54Gi9V6nYvSA0K2Dg/ZVmosFxuCNvRpYGoK
- vK9JQEU0EPLt4IBtJS1XJzmXoqENfXoaCIDluqyrKhoI2Uwk2FbScnUS/CvQhj65x8dBBPuuyxQI+bK/
- z7aSlquT3JRKDG3oU6vDQT0eT8z8MQgRPu3usq2k5eokaekJ2tDHedzudIY73O4PSp/X+8NW0nJ1EqwY
- 2tDH6RQeCd3KE79/3VbScnWSvBQN7d6hIRPQeDoblaCDTlAstlOSZ7wjHzr+F3BPydbTZ2jLx71/Ad5i
- gsnRJ2HiAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB1klEQVQ4T42RyyuEURiH340F
+ UmajKCnMQpqNjZIMUcPkHjWb2VgwNMkIDU0zO/4A+Qtc0zSxIDW5DPtZ2llIochlzP32en8fo89BOfXU
+ mb7zPp3nDI14vTTq8/UJ439QP+zx0ODiIs5p9I90krWxhIwVRUT4KDhi2Sw/JZN8H4/zzdsbX0civH9+
+ zvgmGPWCgrDFYiZtI0xG02l+jEb59uWFrx4e+PLujjcPDxkL3wWjKhhwu4l65+fBVCyT4edYTJMEw2He
+ PjvjpbW1Lzocjj0Z/pakCbpdLuBMSMJrIqFJAhcX/J8kTdDldILplAxEZQCSgBz8T5ImaJ+YADPpXI7j
+ MgSJPxRifVJBsrqx8YWxp8cjELWOjYHZbD7PSRmCxH96yvok9SbIQTbyqdluB3M5EWRkCJLd42PWJ6mS
+ G9kjG/nUZLOBhby0ZSUDkp1gkPVJqgQPi2zkk2loCLjxOHm5BSRbR0esT1Ilz6kUIxv5VGwwULXZ7IMA
+ CzdZPzhgfZIqichvZAuEVVNaV+cqM5lWCtRbLCf6JFWCvxjZyMcqFyqFqgINVuuydpvPJFUSlz2ya9va
+ 5PjPVa4mIQdvgofFv5OSPc7IWcPHyPf1I+k3cIaIat8B3mKCyYSeIBwAAAAASUVORK5CYII=
</value>
</data>
<data name="icon_invokescript_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1913,19 +1903,19 @@
<data name="map--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACt0lEQVQ4T52ROU8TUACA32bQ
- H6BxI+qgJqjEwRgHBhMHxcQoCwNLxSJYiiC0QcALRQIFIodURYW0hoKglSuAnGIVbL2g1gMFpAWRiCKF
- QkA+34txMg76ki9v+b53iohTp8IlR/6D8EMZGUIcTE/X8h9DdRIhDqSmxizLBaw9adzpO0/PQBHuQSvO
- wRYs/QNk9noxdvs43uxDV+cjttaH8lUnEWK/wRC7tLzMjfYUWgdN9HrN9HnMTAXaeTXzhspxPxkOH+fc
- kOaEWLsP5atOIsTepKS4hR8/MDcfp95zgfYPBTQ/NfFp5i6Tcw4efx0h58kQ2W/h9Es4VjeK8lUnEWKP
- Xq8LLC1RVBfHlZZEKjpTsbuy6HhRwMvXFfS+aaTS4+GsY5iUjhH0TSMoX3USIXbHxcX7FxfJr4mh0nkS
- +8A5LF0neTRaytCUjS9zbbS527CNf8f0fpnE1mGUrzqJEGFabcL0wgKmW0ewOAxUPU3nWmsy99/n4xor
- Y2z6Di5PtbzKMGWjCxg7hlC+6iRC7NJoEqfm58m7rqW8Kxlrr5GSBj0Nry/SOXQJ9+cKnANljPqdNE9O
- cLr7HcpXnUSIHVFRSZOBAAUlseTcjCa3MpriRh2XGxO4ft9I1YOzONwlOPvLaXnRROGj5yhfdRIhtkdG
- Jk/MzVFUoMNiN1LedoJcWzQ2Vxp2d6b82jxqH57H+62Gz7Pd1LraUb7q4kNChNgaEWEYm52lOEePrSqd
- ivoULlo0WB4bqH6WIb82C+u+UO5uCaZ+23pqNq2T8zauBgV5bwlhFhvDw1O9fj/F2fEU5sRjKowhu0xD
- tlWDqVpL4T0d5g1rCERF/UGpEE6xZufOMxPyVT/OzPyV24cPUyR3/U1xaCgnVqwYy1QnCAoOPrpq8+as
- f0V1YeLXWClZLVn7DyhfdeInSrd8PdhgSYgAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACuUlEQVQ4T52RyU4TQABA52bQ
+ D9B4I+pBTVCJB2M8cDDxoJgY5cKBS8UiWIogtEHADUUCBSKLVEWFtIaCoJUtgKxiFWzdoNYFBaQFkYgi
+ hUJAnjMxnowHneRlksl7mU1EnDoVLjnyH4QfysgQ4mB6upb/GKqTCHEgNTVmWS5Ye9K403eenoEi3INW
+ nIMtWPoHyOz1Yuz2cbzZh67OR2ytD+WrTiLEfoMhdml5mRvtKbQOmuj1munzmJkKtPNq5g2V434yHD7O
+ uSHNCbF2H8pXnUSIvUlJcQs/fmBuPk695wLtHwpofmri08xdJuccPP46Qs6TIbLfwumXcKxuFOWrTiLE
+ Hr1eF1haoqgujistiVR0pmJ3ZdHxooCXryvofdNIpcfDWccwKR0j6JtGUL7qJELsjouL9y8ukl8TQ6Xz
+ JPaBc1i6TvJotJShKRtf5tpoc7dhG/+O6f0yia3DKF91EiHCtNqE6YUFTLeOYHEYqHqazrXWZO6/z8c1
+ VsbY9B1cnmp5lWHKRhcwdgyhfNVJhNil0SROzc+Td11LeVcy1l4jJQ16Gl5fpHPoEu7PFTgHyhj1O2me
+ nOB09zuUrzqJEDuiopImAwEKSmLJuRlNbmU0xY06LjcmcP2+kaoHZ3G4S3D2l9PyoonCR89RvuokQmyP
+ jEyemJujqECHxW6kvO0EubZobK407O5M+bV51D48j/dbDZ9nu6l1taN81cWHhAixNSLCMDY7S3GOHltV
+ OhX1KVy0aLA8NlD9LEN+bRbWfaHc3RJM/bb11GxaJ+dtXA0K8t4Swiw2hoenev1+irPjKcyJx1QYQ3aZ
+ hmyrBlO1lsJ7Oswb1hCIivqDUiGcYs3OnWcm5Kt+nJn5K7cPH6ZI7vqb4tBQTqxYMZapThAUHHx01ebN
+ Wf+K6sLEr7FSslqy9h9QvuyE+AlKt3w9YDzhwwAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_popupscrolldown_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1950,13 +1940,13 @@
<data name="folder_horizontal" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABLUlEQVQ4T6XUvUoDQRSG4a/K
- JVh4EXsPVl6FVQrBykJEQZEkrIn/GBSMEIQIoogiFinEFIKgxoiCiGBABTG66MrihpC47B7nExt1txhT
- PMWZM285AxFBO1BOI1IlA0NJRDDYMo4rqSh+EIjbbErNcaRqWdJ1EohRrMv3/TiOTJjibkvgbP7AM+ts
- 4svvHWfu2eIwhYxvr4v3VPjDVxdrZVNu94dCscVBAlOetSqth3yoD7UL472uCVuUxjDbelyRxt2SFjZs
- sTeCbOM+J+5NVgsbtigOY7FeXRDnakYLG7bYHUTu/XpO7Iu0FjZssTWAvHM5KS+VpBY2bLHRj8Lb+bg8
- H49qYcMWy73YcdRgnya1sGGLvm7MT/eg9B9s1WtATOlQOjWxibX1lPkNfAJSiLGOr2CqXQAAAABJRU5E
- rkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABK0lEQVQ4T6XTzysEcRjH8c9p
+ /wQHf8T8D07+Cqc9KCcHiSLtbmPX72yUVZtaJRLJYQ+yB6WwdqMkZQsly8RoMtu2a9r5+D7igJny5fA6
+ fL/P8z4+IPkvKCbDlVIwlFgIQ3ZkMaokwrR8n26jwarjsGJZ7DjyaeRr/JhHcWDCpLtJ31n/Qv6s8ti7
+ 77PPubTYTyDVslfp3ed+aKnFatHk1e5AIGmxF8OEZy2zeZsN9KpmQbynFUqLwgimm3dLrF8vaJFGWuwM
+ IV2/ydC9TGuRRlrkBzFfq8zROZ/SIo202O5H5uVihvZpUos00mKjD1nnbJyPpbgWaaTFWi9yzyejfDgc
+ 1iKNtFjsxpajHvZxXIs00qKnE7OTXSj8hbTqGhBR2pR2TdJEAk/094g3UoixjopQ+mgAAAAASUVORK5C
+ YII=
</value>
</data>
<data name="icon_select_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -1991,15 +1981,15 @@
<data name="table" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzUlEQVQ4T52RzUtiUQDF71ba
- R7RrGW5aVIQUNVPQYjCIwU2LNg3ZjMwUSViPzGKmmf6oiigcs+zZF5FSFn3iGJbo8yOfnrnnwXskuMkL
- B8598Dv8uE+4AgGnzGSDcYrPfr8bDR6yYlRRpqpyYCgCDO5X8XGvgg9hHf2hV/QFi+jdycOxraFnK4vu
- zQy6Nl7Quf4MMmTFiM/3Ta9WjYG1NIyB1ZSOX//KxkDgPg//bc4YUK4zmE88GwNkyIpPXq+nVKlYBl9U
- DavHKfw8TGJFfcRy5B5L+3dYDN9ACV1j4e8V5oMJkCErhqenvxd03TL4ffyEV3lngmdnVt86OrL6+sEB
- yJAVQx7Pj1y5bBlwIByPI3R+jsNEAjunp9g+OUFEftuMRrGhquCAwUhWDLjdM5lSqcZAk3eGBmangdk5
- QIas6J2YmE0Xi3UN1MtLy2AvFqsxIENW9IyPe1OFQo1BRt4ZGpidBmanARmyonNsbC6Zz9c1iFxcWAa7
- 8k3evgEZsqLD5fI9aFqNQVreGRqYnQZmpwEZsqLd6VTucrm6Bhww/wIH3hqQIStaHI6VpHzRm2z2XSFD
- Vtja2r422e1/GglZIY9Nplmm9Z0hY/sP0fXQjui6fQYAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzElEQVQ4T52QS0sbYRiF323o
+ vkh3LoubLmyRYGm1QhcSQSQbF26UphrU0iCxQ2MUb/1RKqLENBrHK6KiUby0xJTYkEwuZpLjdwZmMJCN
+ +eDAeQeew8OINxz2qHxpMB7pC4V8aPCRlV5N+1pVR1cc+LRVRedmBR0xEx+iD3gfKaJ9PQ/3moG21Sze
+ rWTwdvk/WpfuQYas9ASDI2a1ag38SsMamE+ZmLsrWwPh2zxC1zlrQLvMYDJxbw2QISvdgYC/VKk4BkO6
+ gfn9FGZ3k5jR/2I6fouprRv8jF1Bi17ix8YFJiMJkCErn8fHRwum6Rgs7P/Dg7qZyNGR01f39py+tL0N
+ MmSly+8fy5XLjgEHYqeniB4fYzeRwPrhIdYODhBX31Z2drCs69aAxShWPvp83zKlUo2BoW6GBnangd05
+ QIastA8Ofk8Xi3UN9PNzx2Dz5KTGgAxZaRsYCKQKhRqDjLoZGtidBnbnABmy0trfP5HM5+saxM/OHIPf
+ 6n5qQIasvPF6g38Mo8YgrW6GBnangd05QIasvPZ4tJtcrq4BB2wDDjw1IENWmtzumaT6o1fZ7LNChqy4
+ mpuHX7S0LDYSsqKeS+WlyqtnRjHiegTR9dCO4+5C7wAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_fitwindow_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2032,36 +2022,36 @@
<data name="globe--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADYklEQVQ4T32QfUxTZxTGX1td
- ZgyaLDHoMg1+sAFzkxSVKqYR/IBtBjRZ5nS0cy6KVhNiQIgmfiGFUKgojEFTIGABJ9qNKXUFnPsDUUpp
- a6VNqVTrFy1YCVDEdBX77NxK4h8mu8kv573nPM/znnsZL/sO4+UaGP/MAOMXPv6QLx/cxC92y4krRMd0
- lYf63Jx0nD7kI94euIA8RwQNlfHVT8yFt154m2w+/1WHL2gcn/I3Ol95Nze5zdyc070fkKOPmHfS3JJ5
- 7Yn7sn0Uvb4pNNrGoTKN4vZzP+wBwP4vcNYw4uZ0PNK/2yBDO5snba/NbHngKer0oN3jp4AgGq2j0Dh8
- 6Bz2o2dsCj2TwO2XQEGn28PpeZwvQ8vYjPSm5JhjOtuPl+5j/1UX6h0vkXfzGY7//QwX+yfwzwhwQuuE
- mvq/DwFXnr5G5JHrNs43Y5eaArZXlklqTKMptXZsrutHmrofO5qdEGse4kCLC+l195BarkepJYBjlLZH
- 8wi7SM/5CMZYcpHusHYokFhhxcpSI4RVViSorBBV27C+wgyJxo3crjc41DEJUakJscUGfF1lCnA+ggIS
- T+uFJ28EN9YOIlKmR1SJEdElJsQoTIiWGyCQmyA6Z8e3mkksym6DQEHhJd1BzkdQwIZTbQlyQ2BJXjeW
- F/YikgyfTRNFNTK/G2vOObGlcRKLM9vwjQbYrh4OcD6CAjbKfvk8Vzf2adE9RBX3YcVZK2JLrRCct4WI
- VVgQf96JlfkWJCiHkKQeh6h8YILzERSQovjqI7H6fhyJBMS6iodIUrqQXO1CSs0jbFG5kFjpxOoCM767
- DohUbsQp7P6IrBtnwjP+oIDUX2ezbcqGqBM93iSlB6l1w9jZ9By7m734+bIXieUDiFfYsaqIfi6d44r7
- XlcOAl8WWExfyO6mM7bjAmPfNyydKW5uFxRavZLfxnCwxYes1gnkaCcQJzOi7CkgtQFiyzuy+oFlRzt7
- aQV6wmPoU/KXsp/+bPgkp8uRphock2rGA0daXwWFMuObZdk3pxYc1PnnH2gdCZdq+4RdwAKptnfhob9o
- A8b4xHwimoWFC9nafXuZpLmW7dN1sIx2fahy71yf5mE7661hPzTcnSu+KKGQ0P08Ys50yMdU/5cP0qpq
- Zm0t2z3tY/8BOAMvdn6kKfgAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADXklEQVQ4T4WQbUyTVxiGj3Rb
+ NIYtWWJQo4bp2ACdkrJJJ0szcAr7CGhidCqtX5nMakIWEDKT6YYUQqGiMAZNgeAKqGg3VKoF/PiBKKW0
+ tdKmVDrrFy3YEaCI6Sr23nMaE37sx97kyjnvee77ynlfFpF3h0UUGJng+BATlDyaK1AMfyEo8yiIC0TX
+ 61URPudzyvF8uEfMCgqd0TRUJdU9tpTc+tvXYvcHLjn9IdPkTKDZ9cK3ocVj4XOe+68g3xD9zjFLW87l
+ x57zjnH0+2fQbJ+E2jyO288CcAQBxz/ACeOYh+d4flaQrZsXIetsyGn7y1va7UWnN0CCEJpt49A6/ege
+ DaBvYgZ908Dt50Bxt8fL8+Feto6xOVktafFH9PZd5+7j+0tunHY+R+GNp/jp+lOcGZzCzTHgqM4FDZ3/
+ MQJcePISMYev2Hlvzg4NCTbXVErrzePpDQ5saBxEpmYQ21pdkGgf4ECbG1mN95BRZUCFNYgjZNurfYgd
+ lOc9gjGWVqr/QTcSTKm2YU2FCaJaG5LVNojr7Pis2gKp1oOCnlc41DUNcYUZCWVGfFVrDvIeQYKUXwyi
+ Y9dC6xuGESM3ILbchLhyM+KVZsQpjBAqzBCfdGCLdhpL8zogVJK8vDfEewQJPv+5I1lhDL5X2Iv3S/oR
+ Q4UPXxNLxBT1Yu1JFzY2T2NZTge+1gKbNaNB3iNIsF7+68oC/cQHpfcQWzaAVSdsSKiwQXjKHiZBaUXS
+ KRfWFFmRrBpBqmYS4qqhKd4jSJCu/PJdieZ+IoWExLrqB0hVuZFW50Z6/UNsVLuRUuPCJ8UWbL0CiNUe
+ JCodgejca8ejsv8kQcZv89gmVVPs0T5fqsqLjMZRbG95ht2tPuw770NK1RCSlA58XEo/l/aJZQMva4aB
+ 1cVW80fyu1mMbfudsW+blr8hae0Ulth80rMTONjmR277FPJ1U0iUm1D5BJDZAYl1ltxBYMWP3f10BXqi
+ 4ulTipazPRebluT3ODPVwxMy7WTwcPuLkEhuerUi78bMwoP6wIID7WNRMt2AqAdYKNP1Lzp0lW7AmIBY
+ QMSxyCgR+3T/d0za2sD267tYdqchvPJ3fk7zyO2nbZE7m+6+LTkjJQnvswhiPsEli/+PtzJr69/8pnI3
+ 7anH2L84Ay92Z9FcXAAAAABJRU5ErkJggg==
</value>
</data>
<data name="MgCooker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAJcEhZcwAADsEAAA7BAbiRa+0AAAHrSURBVDhPhZLtS1NhGMb9T/rQx6ACyUVDyQjDaKAGQYOB
- Ew2K9ilifrA+LDAMablFb1IM03DbMXMwj4O15VZ5iPly2Go0yzCzF0iwr4OdX3seOxK1owcunofzPPfv
- vq77nLo6i2d44j0Xb8elgk90rO7VfN80dB13coLmyUFalCMcHjvJ+fBnHkdLu4Psty5wKhZgz9022tUw
- 9oiHpuQy+1IG7umNnQGdfkV2bA4fq3ZtpCP+EI9u4NAM6mMJDkaDuPoj1pCGgUt/LDfiSYV4sFzGm6/g
- zBkcGOtj/4gTm/+cNeBqvIBttIeexDDqlwqhjxX6ixVcc1/lHITawn5rwBVlVRa0x4ZoVc7i1V5JBx3p
- nIwk4wU6rQG+e3m8ehlnMrodxaGOc+K1gS21waHRMzh6B3cepHDRrf2UHe3jp2mZXaf+hcHeRBnxeXf9
- H4L3Z3HfnOJoyMVxtUSD+ovW55t03SnguzZNOp2xhiws6GjaPJPPXnLDn8Hnn6NvIMvl3qcEApHq2Rsp
- SxcCUHj7QUrsTaAo0vUSi0vv5JklxCwUl0Wxuf4NE3vLGCuf1rdtii7Z7JZlASoWV1G6uslEpsjlFmvH
- WFv7wcxM6j8JZ9++bzL/aISV/Ja7mnNYqmY07YouQubg/l1NwG/XLb2y/7oFegAAAABJRU5ErkJggg==
+ YQUAAAAJcEhZcwAADsAAAA7AAWrWiQkAAAHrSURBVDhPjZHvS1phFMf9T3qxl4MaxDKSoiKKIqEaBAlC
+ Rg2KfBWhL9peOCiK2F0abSs2xFWk3n4JdhVMS2tdhv246CazreiHa4OCeit4v/N5vA5He2oHvpyH+5zz
+ Od/zXBUrZha/on/SS2Wbl6B8/r+omhiBIbCImuVx1PMVKJ9rQq/zFB/cyftBmld9aPZYUfS6Ba2CExqX
+ EVWBQzwMyjCsXd0N6OR4OrHGWZudWok27zsYJRlaUUapx49Hbhv0wy42pGx0QLFcCWPQjunDNEyxDHRR
+ GSVzQyh26KDmnrIBz71xqGd70OOfgXCegf17BsOJDPQ7P+g7ELU4OTbgGX9CG1o9E2jkO2ASt6mDtlCU
+ uqLrWTvZAMubGExSGrqA+88qWmEBDR9lqINXeDzbDq15/O6HJC66xUvarFl4gvrNFEo3ZDzwp0F+r1LG
+ DtvbTRherqLarkedkESZcIPG9Wt0TcVhebGGUCjMhuztSRDFXSyvbGGMC8PC7WBoNIJB8xKsVlf27hOV
+ Un47CCD++RsVOeeBpEmSktg/+ELvmJB8IykuzIUwkplrHB2nKD2vSCSXCSiROAHf1Y2waxXR6P6/AWdn
+ v+DzBW+JOLv4eY3d9w4cxXKulJa/4yC7Y94umUJU6KhQuQ6V6jfXLb2yZTPz9wAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_pandown" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2088,30 +2078,29 @@
<data name="document" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABp0lEQVQ4T42SzUoCYRSGz1ba
- tahVC0FbSNCiRdIiIQgSKooMWrhxUSk6yIgoVhq06QK6BbuANl5A11CLVlGgRUjl//h7es/gCYIa++CB
- meE8L+c7cyhUKJCwf36+BY4m4NnL52n35IR2cjkbkg9jjluDAX90u/zWbnO52eTnRoOf6nWbm9tbRt0x
- 8P4IkJcx0Uavx1WIL7UaP1ar/PD6yveVCt+Vy3xdKrEc1EaB97uD7WyWxsSaCHhvtX4NuSoWWfEGg2eA
- BNpMp5V4u9/nT7T/V4h0IteBE1ePNkxTSXQwg3qn4xgiAXAS6tG6YSiGhYCmZTmGyGDhGOrRWiymJHvD
- IbcxB6cQ+TtwkurR6uGhYvYRYGEOTiFvuCIcUz1aiUSU1GA04i6u4RQiewInpR4th8NKeogA6cIppI4r
- wkmrR0sHB0pmhEUZIMApRJYNTkY98gQCtBgKCVnZtBG6cAppYUZSK4649pnz+2k+GDy1d3VCiCyb1Iqj
- x4WHmVm//0ID7BAgM5HBypXkF8uedPEuteIAcWkaLLjc7tSUz3f5H6RWHHG/API/kG3WfDzsAAAAAElF
- TkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABnElEQVQ4T42SP0tCURjG31Xa
+ HGpqELRBgoaGpCEhCLpQUWTg4OJgJSWhSKKlQksfoK9gH6DFD+BnqKEpCjQRqbz+vf47vc/lvkFQpw78
+ hnt4nh/nvPdQqFCwOSgWt5nDP/Du5/O0l8vRbjZrQ9hwOOqOx+rdslSj11PVTke9tNvq2TRt7ioVhQzj
+ +ybAh8NxezhUTS6+tlrqqdlUj/W6eqjV1H21qm7LZYWFHOP7EuxkMkK8w4K3bvdHyU2p9IXPMC4ZArSV
+ TgsnvdFIffDxf5PgJLgOstKjzWRSOO3zDMx+XyuBAFnp0UYiISQGLOgMBloJBous9Gg9HhfOhpOJ6vEc
+ dBL8HWSlR2uxmJAcsWDAc9BJGryHrPRoNRoVUuPpVFl8DZ0E7wRZ6dFKJCKkJyzAKXQSk/eQlR4th8PC
+ +ZQfypgFOgkeG7LSI28wSEuhEMjgpU35FDpJl7+RRQdde80HArRgGBcQYOkkeGzIoiPLxczOBQJXTt9e
+ uA5mgsFChF+Md2LxN7LoOF1yM4sujyc14/df/wdk0SEi9yfyP5Btd7QayAAAAABJRU5ErkJggg==
</value>
</data>
<data name="databases-relation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACD0lEQVQ4T42SvW8ScRzGb+B9
- 0oSBl8EAIWGAOLIhgyMkLCxOJgaNbwlDBzGVsz3BPwAxosH42qiHl1LbhuRsKJQ3y3bm0pqI9dQj7VWM
- k+vj3UktR7DyS57ll3ue3+f73JeIx+PEFDorf3NzkqYxE5FI5LwkSej1euB5HrXaJlZWWlhf5zB1QL/f
- R7fbBcuyePFyEQ+KJZSYNTVgIpp8r2CrDygE4wH3izRohgUxjsRxXyGKvxCNRi/FYjFCOW63O5RIJN4U
- CgXk83mQJIlUKgWKokCMIzWaPD4LP9UAn8+n+E9mb2dpTQcb71BerYKtdQ4DDpA2Whx2hIEaoJipbIb+
- /mMAzQivGNx79BwLi0sgxpFyuRySyWTF6/WemcvconcH+0iTZFUTQDO4+/gJnpWZYQcjSF1uGzuiBDJD
- 0d/29zBLpqsej+fc0R2MIK21O/ggfIEg7eJ6+kZVp9OdCoVCCU0HjTaYSgXL9bfDDkaQ2HYTW8InXEvP
- qman00n4/f6LmhFKr3HnaREPlxb+3UEwGDxttVoJk8lE2O32GS1BC6XKMsr1yrCDEaTG+01six8RDocv
- uFwu5TeeMJvNV4xG45xMdCBKr9dTBoOB+rMHI0irHRacwCMQCFy22WxKwDFZdlmOiVI3sXGIVOea4MUt
- OByOGdlwXF3Fo84Q6y+SPPO8xWKZl7GvKlv8P/9vysUMoJZl8vEAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACCElEQVQ4T42RvW8ScRjHb+B9
+ 0oSBl6EBQsIAcWRDBkdIWFicTAwa3xKGDmIqZ3uCfwBipAbja6MeXkptG5KzoVDeLNuZS2si1lOPVCrG
+ yfXrHaXx7oTGX/KZ7nm++TzfI+Lx+P9wTuLWJCYN/0MkErkwGAzQ6/XA8zxqtW2srbWwuclh4oIWOaDf
+ 76Pb7YJlWbx4uYwHxRJKzMYoYKKahKw9NWCxSINmWBBaJY77ClH8jWg0ejkWixHyc7vdoUQi8aZQKCCf
+ z4MkSaRSKVAUBUKr1Gjy+Cz8GgX4fD55/1T2TpZWdbD1DuX1Ktha52/AkdJWi8OeMBwFyMtUNkP/+DmE
+ 6oRXDO4/eo6l5RUQWqVcLodkMlnxer1n5zO36f3hAdIkWVUF0AzuPX6CZ2Vm3IFCqcvtYk8cgMxQ9LeD
+ 75gj01WPx3P++A4UShvtDj4IXyAM9nEjfbOq0+lOh0KhhKqDRhtMpYLV+ttxgEKJbTexI3zC9fTcaNnp
+ dBJ+v/+S6oTSa9x9WsTDlaXpHQSDwTNWq5UwmUyE3W6fVRu0UKqsolyvjDtQKDXeb2NX/IhwOHzR5XLJ
+ v3HGbDZfNRqN85LREZRer6cMBgN1eIJCab3DghN4BAKBKzabTQ44IWGXcExEq1TnmuDFHTgcjllp4KTE
+ 8U+rJN28YLFYFiTta9Jn9+HUtEcQfwDKxQygANp/PwAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_fitwindow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2132,30 +2121,30 @@
<data name="ruler1" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="arrow-curve" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACE0lEQVQ4T2P4//8/AyWYIs0g
- ixlUKo+AsVrNcQbt5nMMBl1XGQx7rsOx3dwXDCBsP+/lTCD2sJ75hMFs0l2wOs3GM4QNMJlwmwGkCYjP
- gPGMxx4kGQByjXHfTZCtZ6Y+/PcfRJtNvOOB0wX6nVdMgZK9QLwNiE8D8RkYrj/943/39d//QXygOg90
- L3ABBSptJ129nL3nzZu6099+Np//+b/x7I//dae+/68+/u1/4d5P/zO2vP9ff/r7f6DaMxoNpz0Y5Iv2
- MiiU7GdQKj9U6Tnr+t2aE9/+lB789j9j+/v/Yaue/Pecd+u/84yr/x2mXARj5+lX/nvMufk/fcfr/0A9
- Zxgks7cxSOXuMDVoOnq57PDnPxl7vvz32fbhv+2G12Bsvf71f4t1r/6brnn1X2v5y/8Ki57/t9709r90
- 3s4zMvm7PBhEUtaDcG/k8ruvw9c//WjYd+6BUs3B65L5Oy6Kpm88C5Q7A8fb/v6X2fn3P4gvmrrBA2gI
- AwNv9DIQ3qaYt/kskO7lj13hDsQaQCwIxCxCSWsZBBNWg9ScEdrx/z+I5otZ7sHv3czALq3HwMAspsHA
- ETL/DJt9RRWbbhADNgBTA1XnwSyuiaJMmNm6eDFQxBgLNgCK6QCxOlDNImaD2HAgWxiIeYGYHYiZQSZx
- AbE4EEthwRJAMTEgFgFiAahGkHqQZhYgZqI8M1GSlUF6AcIC84BckOgRAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACE0lEQVQ4T6XTW0hUURQG4IVH
+ VAQz73mBTKLGriM2Egxm4ENb6ikkiRQiCgckpbLL5KDZPKWNlBRplIFBE1mNlRzHUMIuGJ09hugwWA4U
+ GaVjaBdGJW219vHyECdqcMPHWuz9r3WeDiDikmheBgJWm5+r1lh6YL21F/Q1bsg471m07fpnVU7TSCNh
+ xsZhyKr3qrn0av7vBVsuvAUxRLiq4QMLaIGQWTcovsovv/+FomZdHGJ/XbD53ICBHm1EJgrhC6qUKaz1
+ /ETRU479uSCcLszZ9e7+ks6xsUrFP219PY3VrimsfDWJFT1+PNL1DU1t41ilTCJlue6MwmDl0S5ILX8C
+ aSefmvOueryWl/6Z491+NLWP4547w5jX9AZzG9y4/VKfKvfKALJrg1js9CHNcEgskSHpsNOgP/ui/8Sz
+ 7zOmzh+4S57A7Fafyujw4db7o2i4O4rr7COY2vwJjQ+/YHJpB08pe8wg9qBDsO21e30Fjo9fM+p636VZ
+ uj2JZc6+uOIHLnrji+RZTOmYRdHHHWpltAQgYt8tQV5V+shF1RZZdHsH0ZEoEhx94B5E7W8RGR7tRBR1
+ WaGdRe60QmjyJgApXgdh+Td4SM6p0yEbd4PWWcjM55iUkD7/MndiJOOxm1QzNejJBrKWMs2SvqiA+hgS
+ QUKJRCCcJJAkDStIPIkly4kYFHkxHEyCNH+QQGhe/j+E38IC84Ag6BEDAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_invokeurl_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2173,14 +2162,14 @@
<data name="control" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABeklEQVQ4T2P4//8/AyUYRbP9
- 3BcMDvNezgTiGJtZTxkspj5gMO67yaDXfolBo/4UVotQBEGagPgMFMeQbABIAxCfmfn0/38QbTHlfgxJ
- LgApBuIzHVd+/5/++P9/ENu490YM0V4AKQTiM/Wnv//P2vbx/4Q7f/+D+LptF2OICgOQIiA+U3Xs6//E
- tS//hy++/7/hzMf/IDH1upMx2GILJRCVyg8xAPGZtC1P/7tMOvffeeJZMM7f8/w/SJygATJ5OxmA+EzA
- uif/TWbeBOOE3a/+g8Rk83cRdoFY2kYGID5jufn9f9klr/577f30H8QXT98UAzKcoAsE4lcxAPEZxR2/
- /5vs//0fxBZMWB0DMlg0qJuwAdwRixmA+Izq/v//QTRP5JIYHvd6BlZJHQYQIOgCFi1/BraguWdAmNWu
- LIZZTBOsEQYIGgBUyMFkVbyIySi5BMg2AGINIFYAYgkgZifGABagQjEgloJqEgHSAkDMA8QsBA0gJ1sD
- AE2BbRvnALnyAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABhUlEQVQ4T6XOTSiEURQG4NuY
+ QZnFKMZPplAyhGQskFCUsqHZoG4ZKcqCBVEWxgolQqRRY2FmRZSf5LcpC4VLkQWlKCbMRpQsJh3nTK6+
+ W8rIrafvvrf3nD4GAP+ihHL3I6uYe3IhXjrrZ0XTt8w2dsXyhs6Z1XmkdCUl0BASX/ifF9AAEi4/AH2L
+ pm74nxZQGYnhiyDM3AHQ3TZ6ycNeQEUknMfv0L7xAuPXH0A5d/CMh7WASkj0HbxB89IT1HtuYEC8AL1l
+ 9h9ybVdSQnrvPhGt636omjyFyomTkM7dB6B3bVdSQkrHFhF1y/dQ6LoKcewEgN4sndu//4G5dYWI4rVn
+ sHgDULP3CpQT2lY5Ldd2JSWYmhaISNsMQqEvCHSPdSxyWhxvH1G6khJiGjxEZPgA6Gts9HJjtZMZknIY
+ HW1XUoI+u5ZF2t2CGMp6eIQ5KzQoj7YrqYGxaF1J17yuoKUb7/nIilJRIorSdr9nlMCYHplRMqKhOGRC
+ RqTXdr9nfnoMH7BPTYFtG3kcKMcAAAAASUVORK5CYII=
</value>
</data>
<data name="icon_selectwithin" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2212,46 +2201,47 @@
<data name="script--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACA0lEQVQ4T43TT0iTYRzA8d/o
- DylIsEOUOyS85qGZhxXULsGG0kCrQ60uG3aIZ7iNZIZ/VuhFbSQIug5dUrpK4KGIIII0iQi3WtFCR6XD
- 3jne+Ta3uSG67dfvCZ7q9ODhA+/h9+X9Pc/LCx39/cBdCgbh6tCQlbC9ujI4WP8n5i4ODFhfLi4+q1Sr
- WK5UpPKl0satyck79NLjcCEQEFihXMZMoSCV29nB8OzsY0dPTyN/MZzv6hKYurWFy+m0FJ+hhtn8fmjt
- 7gY409kpsGQ+j19UVYrPUMNEByedToGt0fpfUykpPkMNEx00tLcL7Cett0RHkOEz1DDRwRG7XWDrxSJ+
- 0zQpPkMNEx3UWa0Cy5RKmNR1KT5DDRMdHLRYBPZrextTm5tSw3M6Kp7x6Yab98HkHgYwNDcLnjx94w26
- JBn3jIqnxz4mzz744WoJfQaApibBV9zdxRyt+L+7T1fQObX817XpBD5UESmOnBqNuQBMJgBF4QJaLofp
- bBY1OkaGnnXapiMcxfAaojeO6P70z+0lRCW4EAEwGnlsvuzzPXkVjeJ8LIbv4nH8kEhgfHUVPY/eo21k
- Du2j89h67w22hRbw3FvEo97nkWP+Fy4wGI1ms8Mxoel6tko/khQinvDOFOquT32vtfd56AIOgaGmpmWf
- ooT26oCt9/V+y40+iunscPg3qfGIS2EPRjUAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T43TT0iTYRwH8N/o
+ DxlIsENUOyS85aGZhxXULsKG0UCrQ60uG3aId7iNZEbqDL2YjYIg16FLSlcJPBQRRJAmEeFWK1ro6I/D
+ 3jXe+Ta3uSG67dvzBI91evDwgffw/b6/3/O8vNTZ3//X2XCYLgwP2xl1q84PDR3YfMGZgQH7i7m5p7V6
+ HdVaTapYqSxfHRsbZEMP0ulQSFBL1SpypZJUYX0d0ampR67e3kN8MLV1dwuqtrqKhWxWimd41hEMUntP
+ D9Hxri5BTReL+KxpUjzDs6JHR9xuQV1iK37JZKR4hmdFj5o6OgT1J1tvnq0pwzM8K3q01+kU1F/lMr7q
+ uhTP8KzoUaPdLqi5SgVpw5DiGZ4VPdppswnq77U1ZFZWpEamDSi+uxNNV26TxTtCZGppEXxF9o2X2SXJ
+ eCc1HLvzIX3i/ndPa+QTETU3C4HyxgYKbMX/3XjyA+7xhU0XJ1J4oAGsHDs6mvAQWSxEisKF9EIB2Xwe
+ Ols1x54NNrEzGkd0CfAnAe/Hf67NA0p4NkZkNvOy9Vwg8PhlPI6ZRAJvk0m8T6WQXFyE7+E7OG5Owzk6
+ g/Zbr3EqMouTb4B9/mex/cHnHjKZzVary3VPN4x8nf1IUgAO+ydLjZfGv+129vnYBewiU0ND6zZFiWzV
+ Dsf1V9ttl/tYmZ2d9vwBqfGISyDsxfQAAAAASUVORK5CYII=
</value>
</data>
<data name="marker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABlklEQVQ4T4WSP0iCURTF75Og
- oWwp+gNurQ0tzq6igyBokkOUhAkqiOZQkyCCW0stQkUukkMUjbUEQpRRS1s0BI6SGoqVdrvH/KQanh/8
- ON85977jg09iZjKoKEXCpBATDoVCX+GRD3aNM38CWZgT9usOx20nm23wzg5D4ZFj/vsH8f6/INFwue45
- leKvZHIAPHIpSGgLXpTKd9Lpt24iwYVAgFe93p7CI8dcW/CkVLGbyXQ7sRgvOZ1st9t7Co8cc23Bo1IH
- rXi8+hmNcs7jYYfN1lN45JhrC+6UCj5brXcfcuX3cHgAPHLMtQUlpaZKJtNpbWOj3g6F2AAeOebagiv5
- zhdKrZbn58vtSIRb6+sMhUeOubbgnIiEsTOik4rbXW2urTEUHjnm2oKiLIBjouVLi+WhKZ8QCm/MtAV5
- OdzHfERUaqysMFQyM/LtYTeQOW0KuR+u634/Q+GR49HeoL9DMXnZI7qp+XwMhTeeYQUmWRwXpnfl4Kv8
- laHiZ4UJYWRYwYgszQgLQaItHIaKXxQswuj/gm+HNTFEuMVJpAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABpUlEQVQ4T4WSPUhCURiGz5Gg
+ oZ+l6AfcXBtanF1FB0HQJIdIkRRUuGgONQkiuLnUIlTUIjlE0VhLIEQltbRFQ+AoqaFYaV/fe1M5Z+rA
+ w8vzfe+5XLhXENGYupRgjjGYI6Y8TDjmWh9owoVl5qDlct33C4U2FYuEhGOOvdoHmnAh3fZ4HimbpZ9M
+ Zgwcc+zVPtDkTcqTfi73MUinqRwO06bfbyYcc+zVPtDkRcrKIJ8f9A2D1txucjqdZsIxx17tA02epTzs
+ plKN72SSSj4fuRwOM+GYY6/2gSY1Kbde7fbaF7/yZzw+Bo459mofaFKVcr5qsZw3o9FWLxajEXDMsVf7
+ QJMb/s5XUm4+2GwPvUSCupEIIeGYY6/2gSaXQoCpCyHO6l5voxMKERKOOfZqH2hS4QI4FWL92mp96vAn
+ RMJHO7UPNDnhwpCZYyGq7Y0NQsIx3/3vATjbTOmP21YwSEg45jhq37yjyfAYzL4Qd81AgJDw0VH75h1N
+ hLAw08zCHl98518Zyb7EzDITat+8owkXmEVmZUuIHVxGsq8yVmZS7ROR+AWHNTFET84WNQAAAABJRU5E
+ rkJggg==
</value>
</data>
<data name="gear--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACW0lEQVQ4T6WQUUhTYRTHv+s2
- ZKwHfdmi2pDYWqYLuYPmihhIMpp72OaeejB8ipBeCkaFRUihQQ+FRkUvCbWIKFD2lJlg4wpusOlGJi5b
- Y5vi+5D2cjr/e13MCHrogx/ncM7//7/f/QQRif9BNQcCAREMBkU4HBaRSESt0WjUy1zaw9u8gxYesC8g
- FAqdZuFlrodR6/U61Wo1ap5B89eAgYGBM7FY7OHOzg4NDw/fZNFItVohgB4z7KCBdt8N/H6/YK4Ui0VK
- pZapUilTIpHYKJfLBNAXCgV1Bw20ex7tF7xer/D5fEcGBwdvr6xkKZvN0ObmNyqVfqigxww7aKCFx+Px
- aAG9vb0+HlwD09MvCvl8juLxV2vd3d2PAXrMsGvo4PkdIMtyLJ1O0cLCJ1paUmh1dZVcrpPjOp1OAPSY
- YQcNtPAw2g26urpuJJNJmpubI9Rc7gv19MhjkiQJgB6zZg08jBbgcDj67Xb7KJicnPqeyeRpdvZjxu0+
- dQugxwy7hg4eRguw2WzCarV2yLL7gaKkaX7+M62vl2l7e1cFPWbYQXPWYumYMBrFa8EHAWazGYwpSpZm
- Zj7Q4mKapqaeF5eX8wTenvP/fOfspDf2Y/T++Al6otNV2ZyOC/FMDWhvbwfn+/r6X6ZSX8np7HzU1tZ2
- T1Fy/NUcTbS0bO0ODdGfPOUQNQBHr9cLo9EYMJlM462trUdR19a2+EFLdEGvz4xKUu6qJG1dl6SNO2wE
- dxs3gJ+xMPyswg0MBsNFDroP0DfmXF3MQRt7OER7Az4tzAHGzBz6B/gQtPCIX1/g1Ah/cmufAAAAAElF
- TkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACWUlEQVQ4T6WQT0iTcRzGf+82
+ kbEO8zKjckhsLXMLeQfNFTGQZDQ9bOqpg+EpQroUjAqLkEKDDoWLii4JtYgoUHZqmWDyCm6wuY1MXLbG
+ /sjuQ9rl2/d5XxcaQYd+8Nnvy/N9nucdP0FE/4X6EwgExODgoAiFQmJoaEi9R0ZGvMylXbx7d/AiA/YV
+ BIPB02y4zPdh3I1Gg+r1Ou3V4PlrwcDAwJlwOPywVqvR2NjYTTaNVyplApihYQcPvPsK/H4/uFIoFCiR
+ WKVyuUSxWGyzVCoRwJzP59UdPPDuZrQCr9crfD7fkeHh4dtra2lKp1O0tfWNisUfKpihYQcPvMh4PB6t
+ oLe318fCNTA7+yKfy2UpGn217nQ6HwPM0LBr+pD5XSDLcjiZTNDi4idaWVEok8mQy3VySq/XC4AZGnbw
+ wIsMoxV0d3ffWF5epng8Triz2S/U0yNPSpIkAGZoez3IMFqB3W7vt9lsE2BmJvI9lcrR/PzHlNt96hbA
+ DA27pg8ZRiuwWq2io6OjU5bdDxQlSQsLn2ljo0Tb2zsqmKFhB8/Z9vbOaaNRvBZ8UGCxWMCkoqRpbu4D
+ LS0lKRJ5XlhdzRF4e87/852ji97YjtH74yfoiV5f4XAyKsQztaCtrQ2c7+vrf5lIfCWHo+uR2Wy+pyhZ
+ /mqWpnW66s7oKP3JUy5RC3AMBoMwGo0Bk8k01draehT3+nqVH7RIFwyG1IQkZa9KUvW6JG3e4SC42/wH
+ yDPtDD+rcIOWlpaLXHQfYG7qjIs5aOUMl2hvwEfHHGAszKF/gA/ByxkhfgFf4NQI/4LwJQAAAABJRU5E
+ rkJggg==
</value>
</data>
<data name="icon_clearselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2271,18 +2261,18 @@
<data name="gear--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACfklEQVQ4T6WQXUhTcRjG/7Yt
- GWbozexrI0qRUMPOwG11MbDEmov8uojQZFBIq66kgVERgogglG1hEJRSGdRNihG0TFA7ws6JnX2YmsuW
- bTq8l8ibt/9zjpZCdNOBH+/L8z7PwzmHERH7H9Swy+Vibreb1dXVsfr6enU2NjY6OK3rODbf4EUGbCmo
- ra09yo2X+NyLuba2Rqurq7RZg+evBTU1Ncd8Pt/dlZUV8ng817np8tJSmgB2aLjBA++WN6iurmacq8lk
- kiQpROl0ikZGRuZTqRQB7IlEQr3BA+96RvsEh8PBnE7nvoaGhluRiEKKEqaFhS+0uPhNBTs03OCBFxmb
- zaYV2O12JxfawMBAfyIej9Hg4LOZ0tLS+wA7NNw2fMj8LhAEwSfLEo2NvaepKZGi0SiVlR3u0ul0DGCH
- hhs88CLD0d6gpKSkfXJykoLBIGHGYp+ovFzoyMrKYgA7tM0eZDhaQVFRUVVhYeEN4PcHvobDcRoefhe2
- WituAuzQcKu49lw60nz7JTIcrcBisTCz2bxfEKw9oijT6OgEzc2lKJP5oYIdGm72bilj6/0cs/kXmviH
- aQUmkwl0iKJCQ0NvaXxcpkDgYTIUipP3sULHe6Sfbn+ETt75SKcDUepLE/GwXNapNKkF+fn54FRlZdVT
- SZql4uJDvXl5eZ2iGKMT3VN07zuRd5qoOfKHtlmig+0TslqAR6/XM6PR6MrJyenKzs4+gDkzs0wX+0Jk
- ahlYLmh9FVPnhRfz9g9Eu7yv5d1X3mhvgDyngMN/K7MCg8HQwou6AfYNPfds/3TuuSeRnU2D53mJ9g/4
- s42zg2Pi7PkX2888eGRw93rWM+wXiN3yhzE1UjYAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeklEQVQ4T6WQX0hTcRzFr+kS
+ MUNfZv+UKEVCDdvAbfUwsMSai/z3EKHJoJCsnqSBURGCiCCUbWEQlFIZ1EuKEWQmqF1h98b+mprLlm0q
+ vkvky+l37tVSiF668Nn38P2ec7i7EoD/QvtxOByS0+mUqqurpZqaGm3W1dXZBE3r2Dbf6GWGbCmoqqo6
+ KgyXxNzLuba2htXVVWze0fPXgsrKymNut/vuysoKXC7XdWG6vLiYAKHmjjd66N1SUFFRQa7GYjEoig+J
+ RBxDQ0Nz8XgchDoajWo3euhdz+gFNptNstvt+2pra28FgwEEAn7Mz3/BwsI3DWrueKOHXmYsFoteYLVa
+ 7WLRQvr6eqORSBj9/c+mi4qK7hNq7njb8DHzu8BkMrlVVcHo6HtMTsoIhUIoLj7ckZycLBFq7nijh15m
+ BHpBYWFh68TEBIaHh8EZDn9CSYmpLSkpSSLU3G32MCPQC/Lz88vz8vJuEI/H+9Xvj2Bw8J3fbC69Sai5
+ 46302nPlSMPtl8wI9ILc3FwpJydnv8lk7pJlFSMj45idjWN5+YcGNXe8WTuVZUv357DFM18v/pheYDQa
+ SZssBzAw8BZjYyq83ocxny+C5scBHO9Sfjo9QZy88xGnvSH0JAARVovbA/VaQVZWFjlVVlb+VFFmUFBw
+ qDszM7NdlsM40TmJe9+B5imgIfiHlhngYOu4qhXwSUlJkdLS0hzp6ekdqampBzinp5dwsccHY2PfUnbT
+ q7A2L7yYs34AdjW/VndfeaO/AfOCbIH4rJKZGAyGRlHUSag39hlne6cyzj0J7qzvPy9K9G8gnm2CHQKj
+ YM+/2H7mwSODs9sltMhI0i+I3fKHiOg60AAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_pan_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2297,32 +2287,32 @@
<data name="disk" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwklEQVQ4T6XOT0iTcRzH8e+e
- 7e7BgxDixbuXELyKlxQPgiwx/JOa4UE8CR4UFcTUubUJk4nhX6ytRHCCqJvicuEk6KBWZKgVRaIM/IPK
- YLBPv8+jgwR5VBy8tvH7fd7PJgDkPqTa7FRcdUqvta3t+W1we9E4RarUm+LYenOi/giQuAE33LJhK0/N
- DnJujkYRTyQQi8cNccMtG7ZSabZT3/rwAc5UfHR+bogbbtmwlQqzjdyfBv/iMBbD3vGxIW64ZcNWyrQu
- 8nz0/Ma++vUf0aghbrhlw1aeaJ00GHH/xO7OEf6cnhrihls2bKVU66ChsGsbga7NW+GWDVsp0dppNOTY
- Qs/jcXRbx67Fu6S1/l9gw1asWitNLPZ8gb30NSKRNayshK/gGe/eNYXhLPPhQ98O2LCVYq2ZfAsvNuAq
- f4tgMISW/H7dzMycjme84wM8z6bx/uV3sGErRVoTTQW7P8NdNQW/P6B/ks/n1yXP+ICR+nks27+BDVtJ
- NaVLjqk4t8DUEGh/9OpwcnIBA7V+ndc7q0ue8QHexhCWbF/BPVu+MpSsTMmuyZPaVYvFYrsO7/73UAqH
- L1tJUV/SlAd3xCblH+s4aw2T/BzJAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwElEQVQ4T6XNTUjTcRzH8e/+
+ 291DB0HCi3cvIXgVLyodBJlimOYjHsJT4EFRQXyam5swmRg+JOqmIjQhyk1xuXASdPCRDLXCKJKBD6gM
+ Bvv4+/x1UCD/lAavDX6/z/s3AfBfpMrsVFz1Sq+1tbXuLri9bpwilepLcexOnakHgcQ/8MMtG7byzOwg
+ 5+ZYFPFEArF43BA33LJhKxVmO/WvjxzhQg1OLi8NccMtG7ZSbraR+9PQTxzHYvh1emqIG27ZsJUyrYs8
+ Hz2H+K3+4Ws0aogbbtmwlSdaBw1F3N9wsH+CH+fnhrjhlg1bKdXaaTjs2kOga/NOuGXDVkq0NhoLOXbR
+ UzyObuurW/EuaW3gO9iwFavWQhOLPduwl04iElnDykr4Lzzj3UxjGM4yHz7074MNWynSmsi30LkB19Np
+ BIMhNOcP6Obn3+p4xjs+4Kl5jfd9X8CGrRRqjTQX7N6Cu3IOfn9A/yWfz69LnvGB0efvsGz/DDZs5YHp
+ oWSbinIKTA2BtryXx7OzCxis9eu83je65Bkf8L4IYcm2A+7Z8pOuZGZIVnWu1K5aLBbbbXj3p0fyeOSm
+ lRQlVUm7J9VIyhXrOGsNnL9vHwAAAABJRU5ErkJggg==
</value>
</data>
<data name="application_browser" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACiklEQVQ4T6WUXUiTURiAT3rl
- heBNXQTdCGF2E+1qUIwkiwwsleyHfonUrAhCMTAKE7xINCORgnSslqYNZSmJusrQnH9zttraVkNJdLOt
- uaWbzrH19H1eBF2aLzycc97D8/KeA+cIQGwEkZ+fnypxSqJwnchOqsjLyzttNBqtLpcLp9OBzWbDYvmI
- yWRiZGQEaY+hIZlRaT7B8LCF8XE7PT0frLIrcnJyig0GA319fVKyh+7ubrq6utDr9XR0dKDT6WhtbaWl
- pQWtVotGo0GtVtPY2EhiYmKhfIQi6Q7+K2RX5ObmXo7H48RisX8Ir8YwTC1T1h8kX7/Awbafa6O8lvPL
- 0TiyK7Kzs69Eo1EikchfvnnDFHS6uaB3Uz/qp/XLIp3ORSYXY7z6vsLVXh+FXR5kV2RlZV1bWVkhFAqt
- YZ8LcPL5VyoMs+jsAUyS1Gz7xRNzAKM3gj0K9lVQfw6yufxdm8jMzLy+tLREIBBg3rfAuSYzd3qmuTfo
- oc8TkQr8ptkaoF3qYPBHhLFgjLEwGEOQeNfxXqhUqhvBYBCfz4fug5Ps+wOcb/vK5c5pnjpDVL6b5fbb
- WV44luj3w53XLrRSvmMeEkqNA0KpVJb4/X7cbjeXHvZSrLVwSG3ngMbBUa2DEy9dnG2folg/zRnNJ47U
- j1JniVIuVUso6BwSCoWizOv1MjMzw76SZ5R2z5PRYGVX3QTKx1b2PLGiarSxt2GSc+1ubg7FuWYIo6oz
- s+m4ekSkpaXdktv3eDwoCh6hrHjDfvUc26tG2VEzQXqNmZ21ZtKrx1FUm1E9sHOsPcy20l7E4dpxkZyc
- XJSSklIlIzIqTeti98UmIUWSxBaJretEdpI29JTlb+APrpaoVzbDpskAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACiklEQVQ4T6WTX0jTURSAb+7J
+ B8GXegh6EcLsJdrToBhJFhmsVLI/9JdIy5IgEgMjsaCHQjOKKHCN1cpmQ1lKoq40LJfmnK22ttlQEtts
+ a23ppnNsff1+PgRBD1kHPu655/Idznm4AvgvRGlpaY7EPonyJSI7OaKkpGS/1Wp1+nw+vF4PLpcLh+Mt
+ NpuNwcFBpDcGBmSGpHyE168dDA+76ep65ZRdUVRUVGGxWOjp6ZGKXXR2dtLR0YHZbKatrQ2TyYTRaKS5
+ uRmDwYBer0en06HValEoFOXyCselXf4pZFcUFxefSKfTpFKp34gvpLCMz1HdF6XU/I2tLV8XT/ku1+eS
+ aWRXaDSak8lkkkQi8YuPwThl7X6OmP3cHApj/DBDu3eG0ZkUTz7Nc6o7RHlHANkVhYWFlfPz88RisUXc
+ nyPsfTBGnWUKkzuCTZIeur7TZI9gDSZwJ8G9ALr3UZbX9LaIgoKC07Ozs0QiEaZD3zh0105t1wRXXgbo
+ CSSkBj946IzQKk3w8kuCN9EUb+JgjYHioueFUKvVZ6LRKKFQCNMrL5pr/RxuGeNE+wT3vDEu9U5x4fkU
+ jzyz9IWh9qkPg1Rvm4aMKmu/UKlUZ8PhMH6/n2M3uqkwONimc7NF72GnwcOexz4Oto5TYZ7ggP4dO24O
+ 0ehIUiN1yyhrHxBKpbI6GAwyOTnJprP3qeqcJv+Wk3WNI6juONnQ5EStdbHx1iiHWv2cG0hTaYmjbrSz
+ bLduUOTm5p6Xxw8EAijLbqOqe8Zm3WdWXx5iTf0IefV21jbYybs6jPKqHfV1N7ta46yq6kZsbxgWWVlZ
+ x7Ozsy/LiPxLtiWx/uhdIUWmxAqJlUtEdjL/+EX/HsRPrpaoV4RdUxcAAAAASUVORK5CYII=
</value>
</data>
<data name="icon_viewoptions_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2340,118 +2330,118 @@
<data name="globe--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADRElEQVQ4T4WPe0iTURjGz7ag
- IqIIKrALFV1MC8UoZ3bRNLcuaEV0I82otIwaUSldNdOG84bV1Llp5dTKS3nJ0HWjLMvMSbWhW7ZVeMm+
- wjkr15A9nfMl0X8d+PF+57zP72EjwmPPiTCumYjOvyMi+cdRIkVXsCi1W0Epp9wbngr+ne4XHMoj+Z6e
- fhaB4HajQBBA/hYkmmbQEpWv5lOr/OlXrsRod1Sb7K6W/iFHccdPbnVJdyvbL4xRBsjE4tNISECVQPD4
- T0Fs04xx8a2VsppP3WVtfXhlH0KxsR9qfR8avzjQ5gTafgE5j6o4r72KN4ODgwhxc8u4QkgIEUbXjhbG
- 6Apkle97Uhp6oOtx0AIXig19qDDZ0dDrwEvbEBo/PsHdmvUY7D6BSSt26sdPc1+iIfQIdpZIPE7WGXfd
- NGN/tRXXTN+R+LATZx504nr7AB59A7JqbqK8TMrL6txA+MmSLMwT7NDSgo05FyPy9X3SgjasvtqOMG07
- tpZ2ILzCggOVVsRpC3EpexkvZ2QuR3ReIXbQPPMo9CdIUuqO1H52BioN8MpsgTjXAH+1ASs0Rqy/WI3c
- /GBeVmSsRGiyEt6pzVibq3cyj0ILAs81iePvu4IKujAnuQnuaS2Yn6aHR7oe4aeigO8mxJ/3RaSmBtOO
- 1cMnnZanvXAxj0ILAhLq/RXNzpmJLzBb/gpzFHrMG4ZusSkyGBL5LYQU/8B0WT3WVQAbtb1O5lFoJCj5
- smdcnW1uyhu4p77FggwDvDMN8Mky8ninv4ZvVge8kl7DX/UZknIgSPnexjwKLZCmr5kQrjUvoiEfylKl
- BatUVkg0VkjzPyBEbUVgTgcWX2jFlrvgmXrglpl5RJJKC0KzR5MNqiL3sy+5VaoehF7txfaSL4gs5bCn
- jOMnu0uzzDjcCATnmTmW573QbFqwtZCQbUWzRoSX6nzkBi7ihg0HK+04emcAsbUD/GT37ZpObL5u4UZG
- lulYnvcY/JnsQf9K0iyyu6poauwzU5i6yxZT0e88fueni012n3K0wcT2fI7l/zki+j2RMp+MnSwmflH7
- SERpAYmqu0eidU38ZHf2zvaEMJvlmccfIWXM8KMbnf+DySzPPPIbH8MN9etvR7oAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADQ0lEQVQ4T42Pe0iTURjGz7ag
+ IqIISrALFV1MC8UoZ3bRNLcu2IXIijSj0jJqRKV01UwbzhtWU+emlVMrL+UlQ9eNsiwzJ9WGbtlW4SX7
+ CuesXEP2dM5XUH924MfLOe/ze/g+Ijz6jAjjW4jo3Fsikn8YJVJ0h4jSehSUCsrdP1PBv9P9/IP5pMDL
+ y98iENxqEggC/xYkmabTEpWf5mOb/MkXrtRod9SY7K7WgWFHSecPblVpTxvbL4hVBsrE4lNITES1QPDo
+ d0Fc8/RxCW1VstqPPeXt/XhpH0aJcQBqfT+aPjvQ7gTafwK5D6s57z2K10NDQwh1d8+8TEgoEcbUjRbG
+ 6gplVe96Uxt7oet10AIXSgz9qDTZ0djnwAvbMJo+PMad2nUY6jmOSct36MdP9VisIfQIdpRKPE/UG3fe
+ MGNfjRVXTd+Q9KALp+934VrHIB5+BbJrb6CiXMrL6rwg+MuSLcwTbNfSgo25FyIL9P3SwnasutKB9doO
+ hJd1IqLSgv1VVsRri3AxZykvZ2YtQ0x+EbbTPPMo9BMkqfWH6z45g5QGeGe1QpxnQIDagOUaI9ZdqEFe
+ QQgvKzJXICxFCZ+0FqzJ0zuZR6EFQWebxQn3XMGF3Zid0gyP9FbMS9fDM0OPiJPRwDcTEs75IUpTi6lH
+ G+CbQcvTn7uYR6EFgYkNAYoW54yk55glf4nZCj3m/oFusSkqBBL5TYSWfMc0WQPWVgIbtX1O5lFoJDjl
+ kld8vW1O6mt4pL3B/EwDfLIM8M028vhkvIJfdie8k18hQPUJkgogWPnOxjwKLZBmrJ4QoTUvpCFfyhKl
+ BStVVkg0VkgL3iNUbUVQbicWnW/DljvgmbL/ppl5RJJGC8JyRpMNqmKPMy+4lapehF3pw7bSz4gq47C7
+ nOMnu0uzzTjUBITkmzmW572wHFoQXkTI1uKZIyLKdL5yAxd53YYDVXYcuT2IuLpBfrL7Nk0XNl+zcCOj
+ ynUsz3sM/rh50l9Jnkl2VRdPiXtqWq/utsVWDjiP3f7hYpPdJx9pNLE9n2P5f46IMpEyj4x1ExP/6L0k
+ sqyQRNffJTG6Zn6yO3tne0KYzfLM44+QMobCHt3/A5ZjeeoR8gsfww31jk5/egAAAABJRU5ErkJggg==
</value>
</data>
<data name="arrow-curve-180-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACGElEQVQ4T2P4//8/AyWYIs0g
- ixk0G88wGHRdZTCbdJfBeuYTBvt5Lz2AeKbd3BcMIGzYcx2OQeq0m88xqNUcZ1CpPALGqAbMeOwBNOQM
- FDOYTLhNggET73gAXXFm5tP//0G0cd9NFM0gl+B0gX7nFQ+gJFhz9/U//0FsJHwayN4GxL1AdaYYXtBo
- OO0BDIcz0x///1+078v/qmPf/jed+/G/8eyP/w1nfvyvP/39f/mRzz+TN798Y9V/5TJQbSUwDLjgYaBU
- fujM5Pt//2dseY+CEze8/h+y/PF/z3m3/jvPuPrfcdql/17zb/wx7T57F6inUqFkP4N80V4GBpn8XR7S
- eTvPdF379T9t07v/6Ts+/g/b+eG/w6Y3/63Xv/5vvvbVf8PVr/5rr3j5X2XJi/+aS5//ka86fFkqd4ep
- ZPY2BgagZgbR1A0eIinrz+Sc+fVfZ++f/yA2DIumbTwrlrf9okTlweuSbeceCC948VF4+oPXQPleIGZg
- 4DOPZeD3bmbgi1nuwRu97IzR4f//QbRgwmoGoaS1DPyxK1iAWBCINYDYHSjXy5uz/SyQ3gbEDHDALK7J
- wGZf4cERMv8MCDOLaSAkkVhsukEgdVXIahiB8qxAzAXEAsyG8SHM1sULgWwVINYEYj0gNgJiY2QMVAOy
- XgFkNsgAZqghHECaG4j5gVgIiEWBWByIJYFYCgsWoDwzUZKVQXoB+7/02cSOHsEAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEElEQVQ4T6XTXUiTYRQH8BMr
+ EUPnR9NmgRIjNuxr2hIaZNFFb3UXo5sS+7QgM7DANoI0IUhbn5DuIi2oFEQ0i6mBRSl1sWeDUltfkrCi
+ zUklRS1ZnP7PsLHRiEYP/HgOzznn/169xMz/JeFjMshQL2hV4xituTROZsc7KmsNKOBYd9VPkvGsN0rO
+ FTV4aOmJJ6SzDkfEB7T4FISIWbT6wuskAi6+URAiHO+Z5V1y7mXc8l8DVp4ZVdCMLDd5wyzrGC5wgh1z
+ pj8C9HUuBSGi2cdcc/8r2x5/41OeENe7Q1wnQnzS9Z1rh7/82HsnMLX2/OgIZq0ISIsGLKl9JC6//ckH
+ 736Ks7snyJZ2H29ufcUbW8Z4w5VnvKXtRdjU5B7HjrXw2AMqqBkkWnzknrKoekA0Pp/hyt6PfKB/mrcP
+ fOb1vVNs7g5yadckGzsnuagjwLobfjbc/BAusA2N5B/uN2kPOYmwTJr9PcqCfd2iSszwssEwy/o3TeVt
+ d25139OF1ode7WnPRM41/3RO80QQPTsQZZSWk3prA2XsbFfSd9wSxUPM8s7a1UnZe7pIXd4xF7JAD5vQ
+ s6dX9blxO4GiR5VnoJSy40qqpU1Iqlz9bCf+pCzfJudssTNzYB6kQabKWGFRmY9eR60DA6yAYiiJhRn5
+ +UKIBKhAhqTCfFBDNmggD7SQn0Bmwh8kGQkf/x3TL/u/9NmKeOePAAAAAElFTkSuQmCC
</value>
</data>
<data name="color" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC3klEQVQ4T6XSa0hTYRgH8Cdd
- yyCCBDWLWRARdsE+VhRllCH0LWEYFSZ2wTJ0kIhm0dzy0rIbCGGOXKkLNU1y3nNU1vCSudlxK0bBlpk5
- 5Ciabu78e/TDTAj60Ic/L+dw/r/zPu85BID+JwvlisdEA8+IPuYTWRIpbOAQKe07g7X2cHmZXb6mzC7b
- rh2kWGU/HQ8TSEM2qiUztS50lwI3KdZxLdQwWnamf+al0SO9Nfukjle+GUOTZzSppN8RmmMQqCD270AD
- HXZUK1pmP1eJsD4BjFeBPBWg4jX3MVDajdl7VtGxvqrFRvWHl+zgSQ1FWntWm2Y8jybhLgYsXGxUA3od
- oHsAaBqAy128fsGM+vukdZXF1ErmyMAIejOlCe4E15xUCkxmAK4iwKYHOqqBmhag/ANQ/BXIFDGX54ew
- 3+0ykiUtABRaqP7TVOEvN7IwjuuYm+PyeDPg7AZ6HUDbGPwGLyZuAN94cx+Sp37pyFIfAM69JrvVXyJ1
- 4RJsKIQLTzEJC/yzbkgj05juA4brAOE28C4d6Dzvl1LptT0AHOokZ7O/QKpEGhoZeMPAIAPD+IkfIjD0
- nosMNDFgZEB/wi8doU5nAIhqpXbtRIq3iHdwh0cohwHNDHRjDL0MtDFQYQTu8wjaVODCwQnvRmptDwDL
- Kih711CMmMFABnJRhEro0YNqBmom+AwH+Axr+Aw1QNIpIHrDkBhEddkBgNSkkJvkwlHxpDeFR1DxCGr0
- QgcPdAxorPwVeYSkQmDfMdErW24SiB4qFoF0Iqok5coXEe4D41d8iahFCvpwkYGLDJxlIPE5sDd33Bei
- eOEmqlYS3V38lblOFM1JD1bK9NGCoksl7h5t9sb7RqR4j0/a0zHqjcrqEmUxeoHkKi5vXags7oBIxtcR
- nG20aUUcnd5yizQJZsrPdFJOvpMSNWbalnyLQjbH8TM7OGs5sj+BIL6xihPOWfePzL9o/tmgeeA3KbNy
- RaQn6HMAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC2UlEQVQ4T6XRa0hTYRgH8Cdb
+ qyCCBLULsyAi7EJ9rCjKKCPoW8JYVFjYhcrQQRKWRWvLZstuIIQ5aqUtttJE55yao1oNL5nTjlsxCly3
+ 1ZDjqHSX8++ZwSoQ+tCB/3m/vP/feZ/3EID/yvir5jZR3wOiV2VEbhWl9W0ipXflZJ03XV7tlc+q9sqW
+ 6QYoW9lLO9IE0lI/3ScnOSYALlC273SqKVi9r3f0kTkkPXNGpfbH0VFTcyiYV9nrSz1hEuh89sRAA232
+ WRQtY2/uivDcAcyngLNqQM1r6W2gqhNjVz2ib97dln6q3/wXcMdKczxdM22joZthBCoANxebNIDRABiu
+ A9oG4JiL17cY1XwMe2a4bQ5yzkkCRicVCIHcoZhUBYSLgKFyoN8ItFsAawtw6yVQ8Q4oFhE7G4ewPjBk
+ JndBEtC7qf71N/2PAI5jGGcQi3F52A74O4FuH9D6FXFTBCPngPd8uJd7v/0wkLs+CRx4Ql5PvFJy4Sj6
+ occQ7iEMN+JjAUifvuN7D/ChDhAuAc8LgY6DcekQPfEmgU0d5LfHz0u1KEATA08ZGGDgA77gswgMvuAi
+ A80MmBkw7oxLW6jDnwQyHdSmG8mPlPMJLvMIt2CCnYFOfEU3A60M1JiBazyC7hBweONIZAE52pLApBoq
+ WTW4QixioAilKEctjOiChQHrCN9hH9+hle9QC+TtBrLmD4opVFeSBEhDCrlNLmwTd0XyeQQ1j6BBNwwI
+ wcCA1sN/kUfI0wPrtosR2RSbQHRD8RsoJKJaUk5vzAhsGD4ZVeE+8tGDIwwcYWA/A6qHwNrS4eg0RWOA
+ yKIkuvKrO/5KPFmcwslKmTFLULjU4uqgPbI1+knaGopKa9qDkczjLlG2wiiQXM3lJeOVPwEZJ4OzlBZO
+ zaE9iy+SNtdJZcV+OlHmJ5XWSUv3XqRpi3J4z3LO7ETnTyCFM4OTzpn7jyQ+lNibAoB+AimzckVMBrui
+ AAAAAElFTkSuQmCC
</value>
</data>
<data name="cross-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACw0lEQVQ4T22SXUhTYRjHXxI5
- LG+UmWNSiAoLvFBJRZhswZHZUNyHU7tRU7ILZXThbpwM+7gQL6OMWiLTE4gfS01DJDJnq6a1dtxaR3Nz
- ExVZBl504+XT+7wcQaMHfjsPz/P/vTsvHGI2m4nFYiENDQ3EZrORxsbGS01NTXoK1m0Z7PW4wwxm0UGX
- /cgHcHSpczgcvWtra5GjoyM4PDxkYB8IBCI9PT29mKEHcP8ewFmt1nqPxzOGwveJCfjscMAyzzOwj9DZ
- wcE+jIyMjGGWHsCxNzCZTMh1uhCSySSsdnSAaDTCL/r8093NSLW3Q6imhu3i8Ri43W4BHXRJXV2dym63
- u3Z3k/CurRV+2myAlWhuPgfOfphMLLO1tQVdXV0udInRaORXVt5HPw6/gC/V1Uw+rW8GAyBny6/Tgd/9
- HBYW5qPoEoPB0IKvtdjZCZLZDNOFhSx/cnICqVQKEokExGIx2NnZgeGsLFgsLmbZYPAroEt4nreLogiv
- KiogUlsLSzQwqlRCKBSCcDgMkiTRe8fBQ2WBMpOXx7J+vx/QJXq9/m4wGITJsjJYr6qCmexs8NLgWXlv
- b4/NkNdqNcv6fD5Al2i12g5R3ICZtluwWlQES/+RT78F3L1RqVjW5/sA6JLKysobU1PezbePn8JcQcG5
- f56jAoIf0vHxMWM6NxeWHg2BxyNsokvKy8vVVqttIBSKwqTJAkJODrvzIhU3ZLBHWaDXw8z6+gZYLNYB
- dElpaSkpKSkx9vc/9IbDMXhZWw9DmZnwiUpRGexxhjtR3AaX64EXHXSJSqUi+fn5Co1G0+J03p+VpANY
- fjYKws1WGFTnMrDHmSTtg9N5bxaz6KCLdYFykeO4y0qlslWr1T0ZH5+Pb2//hrPgDHeYodkr6MguSaON
- kqKhXEtPT+cVCsWdjIyMPsqgTB/OcIcZylXZSfsLjyUbBUyIGBQAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACvElEQVQ4T22SXUiTYRTHHxIZ
+ azfKzDEpRIUFXqikIky24JXZUNyHU7tRU7ILZXThbpwM+7gQL6OMWiLTNxA/lpqGSGTOVk5r7XVrvZqb
+ m6iMZeBFN16envM0YUYHfryHc/6/h+eBlxiNRmIymUhjYyOxWCykqanpUnNzs5aCdTsFlhZ3mMEsOuim
+ HyChS43NZuvb2NgIHR8fQyKRYGDv8/lCvb29fZjB7L8HSMxmc4PL5RpH4dvkJKzbbLDCcQzsQ3R2dHQI
+ o6Oj45hFhx1gMBiQ63TBx+NxWOvsBEGvh5/0+7unh5Hs6IBAbS3bRaMRcDqdPDrokvr6eoXVanXs78fh
+ XXsb/LBYACvW0nIOrO8GA8vs7OxAd3e3A12i1+u51dX34Y8jL+BzTQ0LntVXnY6RXl6NBrzO57C4uBBG
+ l+h0ula81lJXF4hGI8wUFbHg6ekpJJNJiMViEIlEYG9vD0ays2GppIRl/f4vgC7hOM4qCAK8qqyEUF0d
+ LNPAmFwOgUAAgsEgiKJI3x0FF5V5ymx+Pst6vV5Al2i12rt+vx+mysths7oaZnNywE2D6fLBwQGbIa+V
+ Spb1eDyALlGr1Z2CsAWz7bdgrbgYlv8jn/0LuHujULCsx/MB0CVVVVU3pqfd228fP4X5wsJz8jwVEJRP
+ Tk4YM3l5sPxoGFwufhtdUlFRoTSbLYOBQBimDCbgc3OZvETFrRTYo8zT52Fmc3MLTCbzILqkrKyMlJaW
+ 6gcGHrqDwQi8rGuA4aws+ESlcArscYY7QdgFh+OBGx10iUKhIAUFBVKVStVqt9+fE8UjWHk2BvzNNhhS
+ 5jGwx5koHoLdfm8Os+igi3WBclEikVyWy+VtarXmycTEQnR39xekgzPcYYZmr6CTckkGRU5RUa5lZmZy
+ Uqn0jkwm66cMpejHGe4wQ7n61yEZfwCPJRsF7cBiYgAAAABJRU5ErkJggg==
</value>
</data>
<data name="funnel" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB9klEQVQ4T6WT30uaYRTHj7/w
- FzLyQnFC4Mgh4hgs9B8QvJH0vxDqJhiDRYMuNsaoi6Cr3bSgaIHMNghrUhmZliwpMXCMGAoyJNzNbnf1
- 3TkvzxtKNoJe+MDzvDznc85zzvsSALoPWnA6nZ6IRCIZm82WISJhinllNBrnnU7nvNfrfRsMBuei0ejL
- eDw+zefTelJdkOn1euh2u2i1Wmg2mzg9Pcf2dgWFwjdUKt9xcfEL7fYfXF39BcdP3hBIBaVSCfl8Htls
- FsvLH7CwsITFxfe8/ojNzR3s7x9DVTAoSCaTJIJOp4N6vY5iscjZv3LgJ6yt5Xld5Yp+4vLytyZIpVLX
- fdMWsVhMBGPSg0ajgXK5jN3dPays5LCxUeDM5zg7a0P1IJRIJIYKiAVj0sRarYbDwxJWVz8jlztAtfoD
- qolhroD+J+B4EsnUyUkV6+tfsLVVgZrCE66A7iIQyWMZo0xBjfEpV0C3Cvx+P3k8HjKbzRKsP9cCt9tN
- Pp+PAoEAhUIhCofDgz3ojxomcLlcpONwOMhqtd5JMKuu8K4/WE8w8CH1V2AwGEjxQgR2u31OsvKEBgq9
- VSCn+B8QnovAYrHMMDduOUxg4lMPGB/zkJk5OmrAZDLNqr28G2G0Tg8TSJpR5hkzzrxm3vB1Umov7x4x
- 2l10wT8uhpNvS0oRDQAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB7ElEQVQ4T6WT30uaURjHH3/h
+ L2TMC8UJAyOHiDHY0H9A8Eam/4VQN4MxKAq62BijLoJd7aYFRQWSNQjbpGVkumRJiYFjxFCQIeFudrur
+ 757n9Wi16Qj6wuflHN73+ZxznsNLAG6F9kgmk09CoVDKYrGkiEiYYGb0ev2c3W6fc7vdr/x+/2w4HJ6M
+ RqNP+fvk34JUp9NBu91Go9FAvV7H8fEpdnZKyOW+oFT6irOzH2g2f+Hi4jf4+/F/BLKDQqGAbDaLdDqN
+ xcV3mJ9/g4WFtzxew+bmB+ztfYbawXVBPB4nEbRaLVSrVeTzeV79IxduYGUly+My7+g7zs9/aoJEIqHV
+ 9QWRSEQEo9KDWq2GYrGI3d1PWFrKYH09xyuf4uSkCdWDQCwWGyggFoxKEyuVCg4OClhe3kIms49y+RtU
+ E4MsoP8JuJ5EMnF0VMbq6ntsb5egbmGMBXQTgeQBMyO3oK7xIQtoqMDr9ZLL5SKj0dgt76YvcDqd5PF4
+ yOfzUSAQoGAweF0wJH2Bw+GgHjabjcxm840E00rw+mpxL0MFOp2ux3MRWK3WWSm80h8tQwUS/geEZyIw
+ mUxTjHpzmUECA3OH8TD3mKnDwxoMBsO0mgt3Ga3TgwSyzH3mEfOYecG85KMk1FwYYbSzdAWgPy6Gk2+q
+ GukdAAAAAElFTkSuQmCC
</value>
</data>
<data name="ui_splitter_horizontal" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABD0lEQVQ4T62TsWqEQBCGxwTS
- JFZpEq0sAj6ARUrtbFLlBWzkIHCkFwtfJV1eTUVEBBER5+bfc8WzusNb+JiZ3f3/HWWXmJn2sEuMg/cb
- pGlKWZYt+L5P8zAlHgREwvx6H3Sqg61BFEXa4CiJhjB/lYHehBM1a6HOlw6SJPmS4nAr0KlPiOP4RxKe
- ponHceRhGLjve+66jtu25aZpuK5rrqqKi6LgPM+5LEuedURhGH4HQfB7K9CpDkRInudd4Lou2ba9gHq7
- B7rFwLIs/edVNAwD/K24WDdNkxzHORusxoPkz8K78CHiT+EfEbXwJrwIj1qzNTBk4Wm+OK+zAK1BiBpi
- rOMgNe5zlfe8xLt0cALSyt8vnqRT9gAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABDklEQVQ4T6WSsWqEQBRFxwTS
+ JFZpEq0sAn6ARUrtbFLlB2xkIRDSi4W/sl1+TUVEBBERX96ddYfJMoEMe+E48968e0dEQURXYWzaYGza
+ IMqyFFVVKeI4Frtc5rCvsq/PwWcMyLIM89Cnhuzrc38GnMGNZ0znKqAoijcuDrbAJwPyPP/gDW3bRuu6
+ 0rIsNM8zTdNE4zjSMAzU9z11XUdN01Bd19S2Le0+IdI0fU+S5MsW+GQAFyKKol+EYSh831egvpyBTwV4
+ nocPreQ4Djhq7Ccnua4rgiA4BWi6Ye6ZZ+aFTa/MN1bUzBPzwNwyUpcBuOaOwY/zyMCAV8OKGmac4yIp
+ GYDHNRibNhib/4fED9LK3y95o+n+AAAAAElFTkSuQmCC
</value>
</data>
<data name="arrow-circle-135" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC1UlEQVQ4T6WSfSxVcRjHf93K
- HxSNCKNkSGSpKyOMpfVi3aympVvRIhZXhWV3RSuypZmYl1WrvC1RrveX0UVKpXZ0N1Ot3MQurisvYbc7
- pp6e56j+sP5o62yfne/zfJ/f93d+5xwGAOx/YNuylDyeeQPM5/YQ8707ssrvnkaEpCPtCIeUIBL0LGmG
- ZmkNbbw4wNY/Xy2NkE+VpHTPKbKUP6YQQK2NbJlW+ReoFRgg+ntAbr/FzvzB0Oy+75mpirm6ZG72HTKF
- AIE9QA92FQ51e+b2i/48gTDjA3O78VHPK/eTf1bvfExix0zm2ebJmn2Fqma3zN52hEOtjJVP6pI6ZgBn
- wDuvT4FrLPkjuKb1EBZHyof2S1snYiKr1FlYX9ty/W0AhROoxdjjous0OpyB0Gq1CmsJH+CU3EXYS5o0
- QadlgxLvjB6pc8qbrZuuKtjGKxwfQJtgT7wj571SUjUE8W1jWlzzgA9wSHzJHC6+sEl4Mu4bcv+zn/2F
- 50Jb6VNmc76NrYtvZdaxcuaEQRuSOhl6XESFCnAWSPMBNLA2ruUWDnOLoT75VuceM2uE/BMYEN2kAdJ8
- gEV0A8GFNIzCoUo1T4R8HKhnKWk8Zh5Vz1aHVzKLqHqxe9prZWDZIASVDWjRXzgCmQi3t3oM3IqH4WDj
- BFCN5BiflDGj0IfMJKxCTL3AymGdV+kICNO7VFgvvETD46UE5103DXuaZ8CudAJIu6R0KKlPkN5dM6pz
- Lv8KHrVTYBwuUxiFlC18Rv3DRQQX8GwW6O7aqAO7Wh041OvAXT7LQ9q84husr9GBYZis2yC4WLTyaMnC
- rywwdWTLD9zhfpGqF1zc5pL+SrVZ9kVr3jgP+jXzsKJAozW41KlCT7HMJ0EkMHNkdPEBeFkJtscXCYSn
- 4lALl5g5+Qs8zlwWBGQ/EohudvGQxh55OOOEmCJLfwcYYmGCrEEs/wFabIAIKOAngC8O+qdBFeoAAAAA
- SUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC0klEQVQ4T6WSe0iTURjGT6v8
+ Q0tD05xomajZTLJmYqkoLbpISwojW6WRpqSzUklGaZQmZIg5vFBReSPTcl7mZWhTs6wsPhuIFeWyZM45
+ 89KUNRTr7T3fqj/CP4IO/Pie87zPeT6+CwGA/4JskapZthYPkeBbWhJyZ3RF6F29EMlFuhAGqUTEOHOi
+ GZqlZxYqcBOU6CRxSkNlVt+cSqr+YUAAtTG+fVojKNWpMCNcuKDoM3dHyXB0weD3/GzVXFMmM/sWMSBA
+ QQ9wBjvLtH2YFf4p4Oe9J37XP1gEFn0USAfmk9K7Z/LPtE3J95Zp2vzyB7oQBrU6WTllyuieAcxAUPGg
+ Cs84sQW+Of0U7uEa7T5Jx2RSfL1Oivurm669CaPlFNQi9JjEJr0JMxDdoNPgXswW8DJ7KR7iVn3EKdmw
+ OCivX+Kd9Xrzhisqsv4ywxbQm6An2l74Ti2u10Jq57gRz9xnCzzTXxDPC89d0x5PhETd+xTqcf4Z303y
+ hLie6yRrUjuIS7KS8LBoXUYPwRkTV6sBzALVbAENrE5pv4lh5m+oT+fOZx8RF4R6x7EgsVUPVLMF3MQW
+ ChPVMgYH63QsccoJoJ6TWHHUMaGZrIytI9yEZpF/zit1ePUwRFQPGXFufgQ6RJg9DePgVzECBxSTQPdI
+ oe0JGbGJfkDsYmpF1AuvGzEFVo0CP7dXg3vzS7Q+VkVhgpqmYXfbDLhXTQLVPlndaupTqN4lHzN513yF
+ gEYD2MbKVDZR1ebPaHmonMKEPZ0FevVVmMC90QSezSbwV86yUO1Y+w3Wyk1gHSPrs4qsEC4/Umn+kTj2
+ XmTp/tvML7ItIis6fXJfajbKvhgdFfNgKZ+HZaV6o9XFHg3OVEuC04QcBy9CF1uAy5mzLbWcwz+Zgpq/
+ yIEn4AScvsQJK3jIEd7oZaEaPTrDDA+xRxb/LrBG7JBViNM/QA9bIRwAID8BgC8O+snWpdIAAAAASUVO
+ RK5CYII=
</value>
</data>
<data name="icon_ctxarrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2487,14 +2477,13 @@
<data name="edit" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABaElEQVQ4T6WSv07CUBSHWzWO
- xtE/g08Am5rwDtCGm9w2oBAUW3SC0NAmDaEk3XgRB0PC0IEQFhYWJkYmJwbDwBscz6m2uYqViCf52vR3
- zv1621wJAKT/EC6WZbmLvPyRLq2NBH3f98HzvJhOpwPtdhtc1wXHcaDVakGz2YR6vQ62bQO+rC8KBrRA
- 1/UVNgYRlmVBo9Gg4TjLZDKrSqUSZqIgIAGGAUKfRASGYUC1Wt3ITdMMM1HQw2CIMEEwLJfLUCqVaJh6
- kZhm6LknCqKmeB9zzoExRoKxIIhntgkmiqJCNquQYLKLYKooecjl8iSY7iKYqSoHVdVIMNsqkDZrztgN
- /oNbPC3S/Id+eIY+Lpt1jdGC8zvg/J4GFghlXypJ8IxTr6nU5ZrzBxQYkE5frSlDqBdXkmBZLD5BofAI
- mlZDzE9qtJPlb4IDbJ4jI+QtAepdIIck+r6DPcyOkBPkLIFTzI+R/UjwDveQHRw0Mf7uAAAAAElFTkSu
- QmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABYklEQVQ4T6WQvWrCYBSGtS0d
+ S8f+DL0C3dpC7kETDHyKtglpbWI7GRJUkBAFN2+kQyl06CDFxcXFydGpk0Nx8A5Oz/nyQxINofTAk+R7
+ z/s9Q3IA8C/4I5/PD5G3PzKMCt5HoxEMBoMQ13XBcRzo9/vQ6/Wg0+mAZVnQbreh2+0C3YkKPuhCrVbb
+ 0HeAbdtgmiaVw0wQhI2maTyLCj5JQG+EzjzTdR2azeZObhgGz6KCMTJBZCQoTlRVBUVRqEy7IKcOncdR
+ wT6mjDGQZZkE08SOkyWYiaIEpZJIgllix8kSzEWxAuVyhQTzxI6TJVhIEgNJqpJgkdhxYoI9s5TlO/wH
+ 99jKLb0oPqFgz9wiK8YegLFHKqz8LDZpglfku1C43jL2hAIdisWbLWX+Lpw0wbrReIF6/Rmq1RZi+LSo
+ uPYq3iQFR8gl8oX8pEC7K+QY2REcICfIGXKRwjlyihwieBdyv/eQHRy2xoTtAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_panup_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2515,55 +2504,55 @@
<data name="clipboard-paste" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACc0lEQVQ4T43SW0hUURQG4PWS
- 0JsIFUQ9lWMTFo63RqXRLKoRDMbMcbyMWtqY5qBOjsEEFmlRJAaTlJRdTLtn+ZBBL4EE9rBDu0AlIURZ
- D4VQjo3j7W+v0+xT+tSBj7M5Z6+ftdc5dC6diLVn/HXIaozIzc3NkVxhOfzs3z2qTisOB3TIDYKdMNFw
- 12H3l5GRD2C85mfqvbx36AF+GRAm3rfvRV9NKgYHX2Fo6B1GRz9reM3P+N1bfynkfqHq6OxmUsTrtiJc
- L4nFRftaXCtej5v74nC7Ih7dpRtwuSAGPWUb8bK1ALJGqDpqTSVFDJ9x4NnRbDz2ZGguNNjQ1ujQnW8q
- Q2eLC83bl72pLbSQ25FGdNqsEy9O5eGpb6fO7yvGr7k5/JyexvepKYwFAugbGECtPeWjzeeLzvZ6iU4m
- 6cTzZhueeLfqWr35mJyZwfjkJL5NTODT+Dh6+vvBlyyukgx0PIEUwe0/qrNoeGDHqrIRnJ3Fj2BQD/F3
- d0OJtlqPUFMcKYLbv38gWRvkpfxoNJRkIiSPEAiFFoRwJ2Oyq23V1W7yxZIi+uvTcaVwHTodBo3HmYkZ
- GRCUM1gcwjOxVFTUUaORFPGg2oyrRUZdXfEWzM3PIySPsTiEB2t2Oj1UbyBF9MqALtm+4i7MwLwc2Kzs
- YnFIQAbE2+1e2r2SyL1GI3qrNmk/i1KZl6ZNnEO4Ez4Oz4QHOyXvMVlZPuJr1woi1+o/AbfKTboaWzzy
- raYFHFkmJBlXfY00mVqiEhPLuX6ptHxPJImHB1O0r3CvMgl3XYm6O/sTwPi3ZryXa8K1FCUXsclL6MaO
- CBL/g/dyjRT1G7y5F+bDPK+HAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACbUlEQVQ4T43SS0iUURQH8LNJ
+ aCdCBVGrcmzCwvGVD9LJohrBYMwcx7eljY05OJpjMIFFWhSJwSQVZQ/T3lkumqBNIIEtbmgPqCSEKGtR
+ COXYzPj6d8+X301d9cHvm8v9zjmce+bSuUzSdJj/OWQxRuTl5eVKjjm5vDc/Rs+bX+CiJNgJEw11HXZ9
+ HR7+CMZr3tO/c6wq4JOvOeJDx1701aZhYOA1BgffY2Tki4bXvMff3vnKwbF6Hp3drIg37cW4URaLS7a1
+ uF6yHrf2xeFOVTy6yzfgSmEMeio24lVbIThWz6O2NEUMnbHj+dEcPGkway40WtHeZFfON1egs9WBlu3L
+ 3tYVZZDLnk50OkURL0/l45l3p+LzluD3zAx+TU7iRyiE0UAAff39qLOlfrJ6vdE5Hg/RySRFvGix4qln
+ q9LmKcDE1BTGJibwfXwcn8fG0OP3gx+Z7JQMdDyBdILbf+zO0PDAjjlzEJyexs9gUBXxdXcr0RbLEWqO
+ I53gth8cSNYGebkgGo1lWQjLIwTC4QVFuJNRud5WU+MibyzphL8+E1eL1qHTbtA0lGZhShYIyhksLsIz
+ yaiqclOTkXTiYU0KrhUbFXfJFszMziIsj7G4CA82pbS0geoNpBO9skCXbF/nKjJjVg5sWnaxuEhAruNt
+ Ng/tXknkWqMRvc5N2mXRVeenaxPnItwJH4dnwoMNyd+Y7GyvvEpEu1YQOVb/LXC70qTUWuNRYDEtYM82
+ Icm46lukydQalZhYyflLpeV7Ikk8Opiq/Qv3q5Nwz5Go3N2foOFrzTiWc+ZyKUqKTV5CN3dEkPgfHMs5
+ RBT1B7y5F+bFJBNnAAAAAElFTkSuQmCC
</value>
</data>
<data name="map" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACnklEQVQ4T52RSU9TUQBGu1V/
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACnUlEQVQ4T52RSU9TUQBGu1V/
gMYdS8PGhQtDXLgwcWEwMYYNCzYNFMFSBqENswwCgUIjg6KCgMVQELAyyVQGsVBskakWFASEgoWIYssU
- huO7L/4A8SVf8hbnnLx3ryIoLS1QWth/LBBQKG6npKiklxM/fz2F4lZiYvixpNcOJdM8ms3QdAnOuVrs
- c10Yp6bJsq2gG3QT0+lG3eImosmN4IUnf8FNrTbi8PiY55YEuuf02FbKGXWVs7lr4ZN3lro1H6lWN5lO
- SLZDhNmN4IUnB27ExUXuHx1R3hlDq+sBlq8GOsf0fPe+ZmPHysjPJfI/LJD3GdIn4W7LMoIXnhy4rtGo
- dw8PKWmJ5ElXLDX9iZgdOfRNGJicqcE2206dy0WGdZGEviU0HUsIXnhy4FpkZJTv4ICixnDq7EmYpzMx
- DiQxvPyYhU0TP3Z66XX2Ylr7jX7+mNjuRQQvPDlwVaWK3trfR/8yDKNVS/1YCs+64+mZL8KxWsHqVjMO
- V4P0K4tULO+j61tA8MKTA1eUytjNvT0KK1VUD8RTa9NR1qahbSaX/oWHONdrsE9XsOyz07nhIX3wC4IX
- nhy4HBISt7G7i6EsgvyqUArqQiltV/OoPZrKHh317zKwOsuwT1XTNdFB8fA4gheeHLgUHBzv2dmhxKDG
- aNZR3XuPAlMoJkcyZmeWdLWFNL3PZuVXI+vbgzQ5LAheeHLgYlCQdnV7m9J8Dab6FGpaE8g1KjGOaGn4
- mCpdbQ4vLMlMearweFsYHH+F4IUnBy4EBiau+HyU5kVRnB+FvjicvAolebVK9A0qit+oefpWOpu+NLps
- ekbGKxG88OTAuYCA+x7pVL95vf88wQtPDpzy87tzxt8/56QTnhyQntPSzko7f4IJ/rQI/AE63awC7yrB
- bwAAAABJRU5ErkJggg==
+ huO7L/4A8SVfchfnnOTdqwhKSwuUFvYfCwQUitspKSrpcOLvr6dQ3EpMDD+WTrVDyTSPZjM0XYJzrhb7
+ XBfGqWmybCvoBt3EdLpRt7iJaHIjeOHJgZtabcTh8THPLQl0z+mxrZQz6ipnc9fCJ+8sdWs+Uq1uMp2Q
+ bIcIsxvBC08O3IiLi9w/OqK8M4ZW1wMsXw10jun57n3Nxo6VkZ9L5H9YIO8zpE/C3ZZlBC88OXBdo1Hv
+ Hh5S0hLJk65YavoTMTty6JswMDlTg222nTqXiwzrIgl9S2g6lhC88OTAtcjIKN/BAUWN4dTZkzBPZ2Ic
+ SGJ4+TELmyZ+7PTS6+zFtPYb/fwxsd2LCF54cuCqShW9tb+P/mUYRquW+rEUnnXH0zNfhGO1gtWtZhyu
+ BulXFqlY3kfXt4DghScHriiVsZt7exRWqqgeiKfWpqOsTUPbTC79Cw9xrtdgn65g2Wenc8ND+uAXBC88
+ OXA5JCRuY3cXQ1kE+VWhFNSFUtqu5lF7NJU9OurfZWB1lmGfqqZrooPi4XEELzw5cCk4ON6zs0OJQY3R
+ rKO69x4FplBMjmTMzizpaQtpep/Nyq9G1rcHaXJYELzw5MDFoCDt6vY2pfkaTPUp1LQmkGtUYhzR0vAx
+ VXraHF5YkpnyVOHxtjA4/grBC08OXAgMTFzx+SjNi6I4Pwp9cTh5FUryapXoG1QUv1Hz9K10N31pdNn0
+ jIxXInjhyYFzAQH3PdKtfvN6/3mCF54cOOXnd+eMv3/OSSc8OSB9p6WdlXb+BBP8aUDxBzrdrAKtK4Yr
+ AAAAAElFTkSuQmCC
</value>
</data>
<data name="layers-stack-arrange-back" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC20lEQVQ4T4WQa0hTYRjHz5c+
- RV+iog9dIOmKFGYEfakgiyAkQfqQIeYNK8TEvGDYBbpgUFEjB1oLTGXOtebmdG5q25w7c21ubi53OdvZ
- dnY7u29uK4Tg7X1XyhCpF36cc3if/+/Pc7DDZa+x4o6pHDVPw1jts0h53fMoCQH/gUSz62EkONuJYxVd
- FClQJhPuSFbqCmcmNwPdoRk0my/YByVXS1q0oEfiMHWPWuc24+24XS420HwylJGU3jWDdcHJdmmZzBwe
- Hcdp4Apnw45g2r8RJ50JqKxR6qXQKrMH0qJz1XM5Qa4ZCpioubVvETAlzjhjggjl0zftpKXGEGWH4kcc
- s/K7NzVWVD4BsLVmrSNmRs0aSxTA5p+wIbsGEUz/UFkjmZ5JRxAGqc4ho8LoTgoOXeYBrKhNUon2ES0E
- 1CZPyif+FgB6MpHVOeMr+dj8K9kXfEsQBqnWfoNC50zwD5RwAXbinrgK7cPX+HAYpIS4H2iIeEZtj6Xy
- WaJSmSdccwBK3U0snRze8QouCgB2vGWiGu3DUXlwDRGjeEofmF2OpKdMoYTYEIyLFoKxsYVATGmJph6w
- TQHcFnPd6tXIZy0R3tErMwArbBbVon0+yck5xXLExRJ7gEDrT36e90Xz+WoOJzsGFv1whqx5p1bA55ei
- ch3AjjUJ69E+jAmbAgbtzDH36oDM+4ur9iZHEPgfppdC6Y4BQxg2+5pZWgODQ0fP3CBI7EjjaAO0DT/m
- mGZ48z7iw5THxRB4Vt/wKZAPW0aDim4D6BWGwal6PThf43cXXmBVYgdv8+5MLtKDD4eN0o8zTpKDewm2
- irJvBP4TCjWzpgnRnpuDdRiG7YZsxQoauI1SI815JbT03x/Uy9r7dXhbHugb0Se1Le2tHhLtuMZs3na6
- qnjL9v0wDw+yvZfahBIjPTKuD7I3A92hmb/NBbnmtYNsyLrzOqvrX6CZrYWll2Bu13oYvvwGlvytQyev
- aMIAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC2klEQVQ4T4WQe0hTURzHzz/9
+ Jf0TFf3RA5KeSGFG0D8VZBGEJEh/ZEj5wgoxMR8Y9oAeGFSU5EBrganMudbcnM5NbZtzd65N5+Zybne7
+ 2+5ed083txVCcDpnlgyR+sGHw73n++B3wKHi16CgZTxDxdMQqHwWLql6HqEQ8D9QWLtuxpxpJUBpG00J
+ VfFlVzgtc4ZSY5uB77AGa7MD9iKuFDboYKfUbmofWprejLcjNoXEwAioYEpadNcM1wNONMuK5ebQ0AjB
+ QGcoHbIHkr6NOJiUX70UoV+KluQ2f1J8tnw6E5BpRgEs3NzYPQ9ZUkesY5QMZtM94WBkxiBtQ0GPuGbV
+ d09iOL9kFK436+xRM27WWiIQtf1EDem/kIHkD/VSONU5Zg8gI93ab1QaXXHhwUt8CPKbpGV4H/GsX2Ny
+ J7ySb344Ry2n9Y7YSjZW30r6hcASQEa6sceg1DuWBfsLeRAcvye5gfcRaL0EMtIiwge1ZCylsUUT2SzQ
+ idQTntmPwlx1bL0C/ePnXhBCcKxhtBzvw1W7CS0ZpfkqL5xaDCfHTcFliSEQE88GosOz/qjKEkk84Jj8
+ hDXqvNWlVUxZwvwjlychyKsXV+J9PimoaeVi2MmWuKFQ54t/nvFGsvlqDsVbeud9SENVvNMo0fklv0QP
+ wdE6UTXep2PUqkRGG2vYtdor9/ziaTzxQQyxxsRCMNnSawihZm89W2fo4DKR09dJChyuHapBaQOPuaZJ
+ /oyX/DDudnYI3atvBDTMhiNnYGm7AXaJQvBk9Rw8V+Fz5Z1nl4EDt/l3xuaZvocDRtnHSQfFJTwkR03b
+ NoLehMbN7AlSvPtmXxUAYBciB+TW8GplRob7SmTpud83J2/u0RNNWeBvTLfMurCnvF+8/SqrfuupGwVb
+ tu1DfjQ47b3MKpIamcGRuQBnM/Ad1vxpzkXkZMx4cBpO3XGN3fYvsCYnr+gisuxcc+IB4DeW/K1D9pQD
+ QwAAAABJRU5ErkJggg==
</value>
</data>
<data name="icon_copy_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2590,33 +2579,33 @@
<data name="layer--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB+ElEQVQ4T6XSzU/TcBzH8e/N
- TA8QNcSIAZGHiISgGP8BLx7Bg8GYOEQCKBAIAeHk1QtRiI8QlviALiwpY8jGgyMkuIw9MA7sQEEE09g6
- azu3ggie5u9TR5w7kBqWvNJ+u++765ZRIpGg/aDzXW7IYSqYawZhFw1Reec7qAysRie+ab9CsrYT3At2
- sIsGLZ27MwXX5fjOvKBsuY3ALhq0dLZjEsyR2Lbvk/xjygjsokFLZe0TcEOK/vR+jGyOG4FdNGiptM0F
- NezRPby44Uy1KMTt3mX1lTv89alz4UvvSFDsBv9q1IoGLZW0jkHturw1Gxa0UVhYj3Es6h8OiA84/+f7
- Ot9fHl55jQYtnWl5C3UfIpszLLS/X1IGR4LSQ84n9nJ+XY9+xPznWo+HV61o0NLpZgc0LIkb09Nh+SX7
- 1MfD/n88YvMu/T12AxsatFTUaIfbobXvLntA7GOeJeE8dcZ1ffYsKxyahgtVRAW3OGjyrqgOR1Cy7GJf
- wwKYbZcq+aHsXMXG4MidzI8NHMwUrET9lFdngxb2y7pGQ9Jz3XzymJwHTuSq22ZzIl0fUYgOHCum7OrB
- +jeza5PsLzo+t6I60724XCV15xXEdacKtXs5+VqXKUO4iSdgr8OHSisuHrnypO3oVctdI7CLBi1uYGKy
- mOP/CY3pN4OVZi86RL5AAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB9UlEQVQ4T6XSzUsUcRzH8e9N
+ Ng9FiUSKD/lAJaIp/QNeOqqHUIRWLcyyMKTSk1cvUkpWKgqV1tLCuK6160MrgS3bPrge2oOr+cTgjOs0
+ s+6OZtpp+33GlTYPMtHCi9/Mj+97nliKxWL/hUrbHJDBlDM1OmEWDVFJ60eo8C6FJ76rv/ySuu87DmYw
+ iwYtXX40Bdel6P4sL+869MAsGrRU/HASjKHInntN+jGlB2bRoKWiBxNQJ4Z/upZDO+N6YBYNWipssUM9
+ ezRnUNi2JfrKRy2uBWXIEdh8YZvb6B71CZ3gWQqb0KClgvsf4OaqtDsT4NUxmFuNcCzqH/EKTzjP+mON
+ +w9nUH6DBi1dan4PDd9CO59YaPk8Lw+P+sSnnFvo5jyaLm3F+cFelzOomNCgpQv3rNA4L2xPTwek1+yu
+ z0Y8f+lJoO2xC5jRoKX8Jgvc8a9s2S1eoY/pjcNx4vnhXq9zQebQNF6pIsq9zcFd16JitfrEwUPsNTQ4
+ Nl+tCL5Ly5TNDFYuKycycOIUbyLqp+wGMzSzL2sf84svNbPxNW4gPVPZMxpjR/UR+Snp7EVKqx2+9XZm
+ ZZL9Rce/LCq2o15VVomd2blRzfk8tSMjR20znORv4AnY73RyYXnZmWvPW1KqB9v1wCwatLiAgUllzv0j
+ 1pDhN4OVZi+iACrtAAAAAElFTkSuQmCC
</value>
</data>
<data name="sql-join-inner" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACZ0lEQVQ4T6WTW0jTYRjGPwy6
- CGrJKrDALooSSaQjdRERnQk6QAeN0gvFIiGZMRdouqRYjC1M3SZmZqnVTjh1Ot3MtTLdFLWRzrb+Oufc
- Wtsa22xBEKzvkQndb/Dje3ne5/fu6k/i8ThJhqRk/DHJvqsju7n9ZE+ZnrWXZzhIOU/JxXum0noO/J+h
- gy4cuCsH0k8/NN2QD7ulrsDvvkD0z0T7QGioUOCPAMzIsEMHXXogfeUA60S1MX/aHVEtBGOD8/6Y/tNU
- 2HytgolK1CEXwIwMO3TQhUMPsEgWp+dw6wen1OmPGRjfLx0tDZSIppwl4m++dkPUBjAjww4ddOHAJZl3
- unJmFqNaW4K5HzHjgVxdRNjmnXmqDg4JXvsN9xtdY/tzdGHthLeu7aPrkdqyKBq2B1/BJTuLO4roVdPn
- +XAH+OqJ6refUv4VKwKm8ufeLiBSBN4j0457G6R6plLaz1T1Tn5vhEu23VTmjc+FNBbmp0o36WvSjHpk
- GWc1EW69c/Rek6cbYEamHHHX1/Q4+DW9Dr7a7JbAJVsL3pys1doaO8c8TaIue3WDflZ4gTPiuML7slDe
- 7NUBzMiwE3baH0j6mMf8t5NP4JIt+a3sXcWK0pfG2Tpxt11QrZrmi1WM/NB16xJXsmgFmJEt72gH3czb
- cg5csjb7Ikk9zsvYUdTO5bVYapsHZ2Uqs7uFK2HeHSlYWAKYkb2gO3TQhQMXv1WUDavTsvaxjpXlsS9J
- StlXn1WwL8s4aUerbgHMyxndoYMunIRLUuiwJhFspm8aZSNlPWVdglT6bkrs0IEMJyX5jymZTxnuP42L
- XZ3g33aHAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACZ0lEQVQ4T6WTW0iTYRzGXwy6
+ CMpkFVhQF0WJJNIRu4iIzgQdoING6YVikZDMmAs0XaNYjC1M/aaYmaVW6oZTp59uplmmm6JL0tnsm3PH
+ bFvDzRYEwXofmdDFLpIGP/bw/J/fe/eRcDj8X0QtlwNJvs2SXYJusjtfG7tHqEuhnKWk4f9U0fgZ8HdH
+ ScEWDtylBzafvN9/rXHQobB5f3Z5g7/GGnr8A1kSTwAgo8MNG2zhLD0Qe0zclzHpCCjtvlDvrCek/TAx
+ r79SyAUZld8GkNHhhg22cOCSJH7Hwbp3VoXVE9Jxcz9YOurJlU1Yc+Vf5hp0QRNARocbNtjCgUsSb7Wl
+ TjmDGlOEmW+hvv1pbEBa7556rPINSF56dHerbCP7Utl5zZi7rP697YHK4JQNmn0v4JIdOS3Z9NX+j7Pz
+ LeCzK6jddqL5t7zJ21/w1N0GZE3et+g0o+5KhZYrUnRzxZ3Gr1VwydbrzemjM361gfuuZI1z1ephV0XC
+ aXVAUG4dvlPtagfI6JqHHOUlHdOiks5pkUrvYOCSLZmvjpdqTFWtI65qWZtZXKm1SM/xh6YvCT/ZC2rc
+ LEBGh5u01XyP6eIeil4bH8ElmzLqeDtzmvKe91nK5O1miVg5KZIrucYDV8cXBIxzHCCjW7zRDbaJNxv5
+ cMnq5PMk7qgwYXt2g0BYayit6bVUKPWOWgHDvTmUaV8AyOie0Rs22MKBi98KyrqV8Ul7Y4/kp/MuMHm8
+ y08KeRcr+PGHi28A5MWO3rDBFk7EJTGUVZFiIyWesp6ylrImQhxlAwU3bLCFExP1A1kOUct/J0z+AI2L
+ XZ2e82tVAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_zoomin" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2637,36 +2626,36 @@
<data name="application-search-result" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACjUlEQVQ4T5XST0iacRgH8J/W
- IBFGtEteOtRBL7u4SycbImRYw8IGrR3Nav9gDrbDTpHBW5c22A6NatHB0TKSFbWSTpqtJmOyUMM2h2j+
- yVI0fE2MZ8/zshdcu2wvfPDnw+/5vs9Pf8xkMjFRb29vM+pDln9A+5pZT09PtX6v17sfDochEAiA3+8H
- n+8z7OzsgMfjhe3tT+D1foHd3X1YX/fsY28/MxqN1YZdLhdsbGzA2toarK6ugtPphKWlJVhYWAC73Q7z
- 8/MwNzcHMzMzUFNTY2E4RrVB+I8HewdZd3d3taFCoQDpdBpOTk7g7OwMyuUyVCqVv1xcXAD2DjGDwSDo
- 7OxkXV1d9w4PDyGbzQLP84JisSgolUp/oGDaz9rb2wV6vb7FarWOpVKpc5vNtqVSqV4RWmcymfN8Pi9M
- JKLwjo6OB0yn04lMPp/vG8dxm7fuWLi9YGxxLxRbNN4dHKcaHQmDhOkIHRV7HzGNRiO6j28vtrW1Tbx1
- Be3vPNEV4nCHHVSj3yUajcLx8bEgl8sB9j5mra2toofJZLKI5xp1eL6/D8Tym2Tra2yFavF4HEKhEBwd
- HQloIux9wtRqtagPL0xgampqeYR7OfIjkf34M5lzTbx4baPawcGBcLFoCkITYe9TplAoWGNjI9FMT097
- IpEIPzs767BYLM8IrYPBIO92u4H+oUQiIaBjKJXK56y2tpbhjVKbzebl09NTmJyc3MXbGMaReUJrrVb7
- pr6+fuyyhoYGMwXcxGYnNQ8MDDjxuw4No9HfaH29rq5OIpfLWTUMZBTAUTOGfMBJbkilUnaZRCJh4oN7
- mEwmE4KEACz0Y8g4ft7GTSrUgpqQAl1DV5EMXUFSMYhCKOAXo8sWCvVAT3EAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACiklEQVQ4T5XST0jacRQA8K/W
+ IBGGtItedqhDXnZxl042QrDIhoUNWjuarf2DOdgOO0UG1qUNtkOjnHRwtJRkha2kk2azyVhM/INuDTG1
+ 8h8mapK8vfdjbq5dti988Ovzvef7/n5fptFofhkaGmpDw0j3DyivjQ0ODjYa8Xg8/kgkAoFAAPb29sDn
+ +wg7Ozvgdntge/sDeDyfwOv1w/q620/5TK1WNxp3Op2wsbEBDocD1tbWwG63g81mg6WlJbBYLLC4uAhm
+ sxkWFhagqalJR2M3GoP/WJTPBgYGGt0+OTmBo6MjyGQyUCwWoVqtwtnZ2V9qtRpQPuvr6+OoVCrW399/
+ JxqNQi6Xg3K5zCmVSpxKpfIHakz5TKlUcnp6etr1ev3U4eHhqcFg2JJKpS8I7dPp9GmhUOAmqqPmvb29
+ 95hCoajT+Hy+L0ajcfP6TZ1xNxhf3g3Fl9W3xqYpRkfCRtx0hI6KNQ+YXC6vu4v/Xurq6pp57Qxa3rhj
+ q8TqilgpRs8lFovB8fExJ5/PA9Y8ZJ2dnXX3U6lUCc81aXV/fRuIFzbJ1uf4KsUODg4gFApBIpHg0ERY
+ 84jJZLK6Ybwwgbm5uZUJ4/OJb8nc+++pvHPm2UsDxcLhMHexaApCE2HNYyaRSJhYLCby+fl59/7+ftlk
+ Mll1Ot0TQvtgMFh2uVxAbyiZTHLoGB0dHU9Zc3Mzwxsl02q1K9lsFmZnZ714GyM4cpnQvru7+5VIJJo6
+ r7W1VUsNrmGxnYpHR0ft+F2BxtHkT7S/0tLSwhMKhawRNmHUwEjF2OQdTnKVz+ez83g8HqsvzGECgeB3
+ AwyMYJNp/LyBv0tRO7qMJOgSuogE6ALiI25RE5FIxH4Ao8sWCkhO/FoAAAAASUVORK5CYII=
</value>
</data>
<data name="layers-stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACm0lEQVQ4T4WQ3UtTYRzHn5uu
- pC7CoouyCwmioiih/oLugroRKgi1F6QQGb0oQqHQTYFdJG1gpaBZOnVN3dqrbTu24xrOHffiXs7Zdjw7
- 287Ldvbizui25xEmxzHqgQ/n7ff9ffkc0DFoBw20weebkLv/Ac20NYbBlQHbLWdYXNrJ12y0KFuagb6h
- GTSrXLDXDF9q1JZE8M1SzN2M9ybKZSZ4fUqQrZdfWO/tL6g3bySkEC3WRIqXs40kBTmHxwrpUUPMSeaq
- xkvPzF1owYHm4fkwpbEmi2MmSlAybk/ytoDAkFw1O6IN/9pmK4aLT009+8715nC6UqI4+Q9sqNWhuGoN
- Nstqa4LbZnfTQ18DWGCnvHxBZXwAkAfyMW5mPUGmknHH8qI/Var5ksVdJbFstfZWH83BIPN8inD5kiX9
- uf6VRwB5IB+9N4P76RLrDAuil5JkD1moKAmly/LrxW0OLt3pn/C5PKSkO9u31AuQB/LR4gzupYqMleCE
- tUi+ag/wRTPBST/8nGTczEnuaL78ajaYW49LdO+4F1uL5nVnHuueAOSBfKZdNI5FRHrWnc4tb2TLut9s
- QYkjLJQHp4ksFsmn7n/wYPD6vb13oQ8gD+QzZopjMEh9/pliv7mZyoKHrcx72HKd1ZAgD34hRNicUU1u
- EBOrlPFk98xDgDzgtrkRbXBV582Qk45UVGMhM2pznFOyuM4Ubo9i9LQzETnV89XQ2qlRHb7a1QGQh2WL
- nxme27JPOpIp7TpLzeFpshF7UEgfaAbgBACgBSAPW4DXvjNEp4Zm/I6BKR/ejI+2eEjZfOjoaZiHB3l8
- ssVXrAF+Hv7x2Wagb2hmzxmA9r3m+jlyrbsD+Ry7M/HyX7R2qlUt529ch7nj+2F48xccaJZr1sn7YAAA
- AABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAClUlEQVQ4T4WQS2sTURiGZ+Oq
+ 6EKquNC6KIKoKFrQX+BO0E1BBWnrhaKUEry0FJQW3CjUhcUEqraQ2NqmbUzbxFxrkqmZxtA001yay0yS
+ 6cwkmUsyuTQT3HpOtTA2QQ88DJzzvd/LM0jHoHM/bYDrgNv/Ac60NSy4NOC44Y6Ki9uFuoMSZVsz4Buc
+ gbPK8G4zuNSobanwq8WEtxlvLaTHivPGjCDbLz6z32loXk9JEUqsiyQv5/aTFuQ8ligyo6aEm8jXzBee
+ WLsamofnoqTGni6NWUhBybgzzTtCAk1wtdyIPvp9i62azj+29DQ0R5lqmeTkn6ChvgfJ1eqgWVbbU9wW
+ u8MMTYfQ0HZl6ZzKfA+BHtDHvJHzhelq1psoiMFMuR5Il3aUJHK1+mtjPA+C9FMt7gmky8Yz/csPEOgB
+ fYz+LBakyqw7Koh+UpJ9RLGqJMJU5JcLWxxYtt0/EfD4CMlwum+xF4Ee0EeP0ZifLNF2nBNWY4WaM8SX
+ rDgnfQ1yknkjL3njhcqLmXB+LSlRveN+dDVeMJx6aHiEQA/oo/NQGBoTqRkvk19az1UMP9iiEldUqAzq
+ 8BwaK2TuvvOh4PulvXe+D4Ee0GfMkkRBkPz4LcN+9tLVeR9bnfOxlT1WIoI8+AkXQXNWNbmOT6yQ5uPd
+ U/cR6AG2zY7owysGf5aYdGXiGhuRVVuTnJKFNbp4cxSldO5U7ETPtKm1U6M6eLmrA4Eetk1+anh20znp
+ Smf0ayw5izHEfpxhgfmrGUGOAVoQ6OEI8fo3prh2aCroGtAGsGa8dyQjyuYDh0+CPDhw2wdHctke4ufA
+ H59pBnyDM3+a2wEtu2F4Dl3p7oBbj9yaeP4vWjvVqpaz166CyNHfSXgQ5BccaJZrYeZTrwAAAABJRU5E
+ rkJggg==
</value>
</data>
<data name="ColorBrewer" xml:space="preserve">
@@ -4403,36 +4392,39 @@
<data name="document--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB20lEQVQ4T42SO0hbYRTHz2jo
- 5qBZOgiJgwgl6dAgqCAIBlQqRnBQQTDGoEFuCAbfIkK3Lg5GXLUdOrVD3IVujjo4lYpRkeAj7/fxfy45
- i4+rH/zg3sv3/3HOuYd8a2skjKyvD4DpN3AMr67S0NISfV1cpMHxTiL5UCeQrVT4rljkm1yOE5kMn6fT
- /D+VMvl9dMS4FwBOFYjEtNWZSZdKnETw6uGB/yWTfHZ9zaeXl3ySSPBBPM5ycHcGOCVsCgajUSWYgeA2
- m31Rsr2/z4rT610BJFB/JKLM5splvkf5r0mkEmkHmVnNUZ9hKHN5zCCVz1tKRIDMnOaoNxRSQgUIMoWC
- pUQGi0xIc9QTDCrzpWqVc5iDlUT+DjLzmqMuv18xyhAUMAcryQ1aRMbQHHVMTirhSq3GRbRhJZE9QSYs
- OcPlIvoyNqZEqhBIFVaSFFpEJvLdbqefhPN5dFRZqGFRKhA8lfydmuK4y2Vy6Hbzns12gfDxD6JdcnR3
- 0yefT4jKptVQxVPJL4TyExPPiEEiRdBHj4davd5lc1dfkPzx+3kHEiEGFhoaEhsIb0kFODbQ1OzxbKrA
- lACZiQxWWpJfLHtSxLvclUw9S414aLe1tIQ/tLV9ew9yVzKg8REGvINQesvmrAAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzElEQVQ4T42STSjDcRjHn6Pl
+ tgMuDsocpLQ5WAqllBUiUw4oZVgsTWvL6yTl5uKAXIeDE4e5KzdHDk4iG2l52fv74/n+289h+PPU5/D/
+ 9Xw/Pb/n/yP72prGsN/fJ0z9Qf3Q6ioNLi3RwOIi9Y+1E+GgxHQin+e3TIZfkkkOxeP8EIvxfTSqcXpx
+ wegRTEoANFuJmVg2yxEJPn188F0kwrfPz3wTDvN1KMSHwSCj0CeYvgT9Pp/CGRfBayLxo2QnEPjCZLOt
+ CASo1+NRzCZzOX6X8X+TYBJcB70qRz1ut2IuJTuIplK6EgjQq3LU7XIpXGkRxNNpXQkWi16Voy6nUzGf
+ LRQ4KXvQk+DvoFflqMPhULhzIkjLHvQkL3KGXpWjtokJxUK+WOSMXENPgneCXmTcZjNR6+iowlMQAabQ
+ k0TlDL3bNTV0TFItIyMKb1EeSl4E5ZLLyUkOms0a5xYLHxgMjxK+OiLap/rOTmq224EPL60oU5RLTiSU
+ Gh//xp5IMATVWq3UYLMtQ4Aql5w5HLwrErAneCsqQusS3sQEUgahqtpq3SjltcJ1sBMsFiL8YryTjHyj
+ F5lSloxCk6GubqGysXHrP6AXGSIyfgIGvINQcFyFeQAAAABJRU5ErkJggg==
</value>
</data>
<data name="layers-stack-arrange" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACuElEQVQ4T4WQb0gTYRzHnze9
- it5ERC/KIOkvUpggRC8qKggiiqQXWWH+CSvMtNIoonrRP6LAwoSiCYqmc61tOp2bzm06N4fTuXm67c7d
- ttttt+223ea2eiFxPY8xuUTs4MPdc8/n+/vec6D4YhMoejgkJA+uz0NK/wNy8kDVq9g/Aw43ai7osKjc
- x2Y13mhmcC3QHnKQKxyw3AxftnxSLzjeyF3GtfjQj+tVtrCMjGTUhQ3qa8sDLr/wg1zz5EIc80az0QUm
- HVyNJ5wJjbti1Ltelw4PpZWH7qvKQOVLtgQOISH8etQ3xZZ6dIkIDgc/E2Njc4FU38F7A+Wg9AlFKsaS
- XK4Zo1IcbP4FG7I5CCb9Uz7K/a5+TS/BIPWo026w+5KKgjplJTh3F+PReZRTIbPDn6KNLpadJrms1ZNY
- FOIOLmaRC4PUgzabwerhZAdqe2+AY+VGHp1HZqFNMEjpsEjEQiQyZjyeEjJLpTLIhUN9tSKrHu5J99XI
- q0FhyQCPziMe95ssRJxSzzCR0Xk2PeSIcCobk1BOMfG+qVB8zBlLIdfkjntvfrboR52sdPct6W2w54wU
- fZaiXU8aDfOst8voDykmg8nvE3RMyAgWTSIXOmRFs9kA7z/yqyU1YNcpCfwsTvZxwG2AQfyr1hP4ZvQv
- SsyBZA/C9Jfh2UgaubCZrhNN2kTDhHL79Y4qkH9agaZ2Pxc7tNIJmmgdIZ0tgwTdrMIZIRIzFUNuu84z
- t6O8U7nlUkvdpuKyIrD/rJYfnAl3PO22a1q1HlJsChBd4xS+GvhPKOSuNAOwDQCwEf5EK6+xh8Xve51t
- jzumdY1tVlODALRGfNG4Z5Gba96weSfMw+vIFYJs6mZYtT3c0z/NdK0F2kMOcmEkf7k5dxWcFF09XhH0
- nagM8+uBnL1H396Bua0rYfjwB5D4p3X4gwOzAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACuElEQVQ4T4WQX0hTURzHz0tP
+ 0ktE9FAGSX+RwgQheqioIIgokh6ywvwTVphppVFE9dA/osDChKIJiqZzrW06nZvObTo3h9O5eXXbve5u
+ u7vb3Xa33c1t9SBxO0dRbiJ24MPl3vP5/r73HFB0qREUPhoUkgu5ACn5D8jJBZWvY/8MONKguajDonIf
+ m9V4o5mB9UB7yEGucMBSM/zY/Fk973grdxnX42MfrlfZwjIyklEX1KuvLw248tK/2jwxH8e80Wx0nkkH
+ 1+IJZ0Jjrhj1vselw0Np5eEHqlJQ8YothkNICL8RdY2xxW5dIoLDQc/F2OhsINV76H5/GSh5SpGK0SS3
+ 0oxRKQ62/YYN2RUIJv1LPsL9qXpDL8Ig9bjDbrD7kor8WmUFOH8P49F5lJMhs8Ofoo0ulp0iuazVk1gQ
+ 4g4uZJELg9TDVpvB6uFkB2t6boLjZUYenUdmoU0wSOmwSMRCJDJmPJ4SMkOlMsiFw3w1IqsefpPur5ZX
+ gYLifh6dRzzmN1mIOKWeZiIjc2x60BHhVDYmoZxk4r2TofioM5ZCrskd9976YtGPOFnpntvSO2DvWSn6
+ LUWbnjQa5lhvp9EfUkwEkz/G6ZiQYSyaRC50yPImswE+f+ZVSarB7tMS+Fuc7FO/2wCD+DetJ/Dd6F+Q
+ mAPJboRpmaGZSBq5sJmuFU3YREOEcseN9kqQd0aBpna9EDu00nGaaBkmnc0DBN2kwhkhEjMVQ26bzjO7
+ s6xDufVyc+3motJCcOCclh+YDrc/67JrWrQeUmwKEJ1jFL4WeCcUclebAdgOyYGXaOU19rD4Q4+z9Un7
+ lK6h1WqqF4DeEV817hnkrjRv2rIL5uE6epUgG7sYVm0Pd/dNMZ3rgfaQg1wYyYPkLIXRyj8lunaiPOg7
+ WRHmNwI5+469uwsj25aTaAHwF5D4p3XcStYrAAAAAElFTkSuQmCC
</value>
</data>
<data name="document-search-result" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\document-search-result.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="document_code" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\document-code.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/document-code.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/document-code.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
More information about the mapguide-commits
