[mapguide-commits] r7859 - branches/maestro-5.0.x/Maestro
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Sep 14 09:31:42 PDT 2013
Author: jng
Date: 2013-09-14 09:31:42 -0700 (Sat, 14 Sep 2013)
New Revision: 7859
   branches/maestro-5.0.x/Maestro/changelog.txt
changelog.txt update
Modified: branches/maestro-5.0.x/Maestro/changelog.txt
--- branches/maestro-5.0.x/Maestro/changelog.txt	2013-09-14 16:22:05 UTC (rev 7858)
+++ branches/maestro-5.0.x/Maestro/changelog.txt	2013-09-14 16:31:42 UTC (rev 7859)
@@ -1,4 +1,19 @@
-5.0
+5.0.1
+ - Initial support for XML element auto-completion
+ - Initial API support for CREATERUNTIMEMAP and DESCRIBERUNTIMEMAP operations in MapGuide 2.6
+ - Resource ID "address bar" now has two buttons: One to open the resource using the designated editor and one to open using the Generic XML editor
+ - Fix: Missing context menu for granting/denying user/group access to a given resource in the Site Explorer
+ - Fix: Strange cursor behaviour in Generic XML editor
+ - Fix: New Map Definitions always being created as v2.4.0
+ - Fix: Missing Selection from ResourceType enum
+ - Fix: NullReferenceException on Layer Definition Editor when pointing to a multi-schema Feature Source
+ - Fix: Inline SymbolDefinition element in a Layer Definition saved with version and xsi:noNamespaceSchemaLocation attributes
+ - Fix: Infinte loop when compiling a dependency list that includes one or more self-referencing resources
+ - Fix: BaseMapDefinition XML element not cleanly detached when deleting last finite display scale or base layer group in Map Definition editor
+ - Fix: Modified composite rule filters not saved when Layer Definition is saved
+5.0
  - New WebLayout now auto-prompts for Map Definition like its Fusion counterpart
  - User documentation content updates
More information about the mapguide-commits mailing list
