[mapguide-commits] r7885 - in trunk/Tools/JenkinsCI/home/slave_win/jobs: Maestro 5.0.x Maestro trunk
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Sep 30 09:48:21 PDT 2013
Author: jng
Date: 2013-09-30 09:48:20 -0700 (Mon, 30 Sep 2013)
New Revision: 7885
   trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 5.0.x/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml
Maestro CI job cleanup
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 5.0.x/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 5.0.x/config.xml	2013-09-30 16:31:04 UTC (rev 7884)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 5.0.x/config.xml	2013-09-30 16:48:20 UTC (rev 7885)
@@ -52,13 +52,13 @@
   <concurrentBuild>false</concurrentBuild>
   <builders>
     <hudson.tasks.BatchFile>
-      <command>pushd %WORKSPACE%
+      <command>pushd "%WORKSPACE%"
 rd /S /Q out
 popd
-pushd %WORKSPACE%\Properties
-%MG_TOOL_PATH%\SetAssemblyVersion.exe -set:5.0.0.%SVN_REVISION% GlobalAssemblyInfo.cs
+pushd "%WORKSPACE%\Properties"
+%MG_TOOL_PATH%\SetAssemblyVersion.exe -set:5.0.1.%SVN_REVISION% GlobalAssemblyInfo.cs
 popd
-pushd %WORKSPACE%\SDK
+pushd "%WORKSPACE%\SDK"
 rd /S /Q bin
 popd</command>
     </hudson.tasks.BatchFile>
@@ -70,37 +70,37 @@
       <continueOnBuildFailure>false</continueOnBuildFailure>
     </hudson.plugins.msbuild.MsBuildBuilder>
-      <command>pushd %WORKSPACE%\out\Release\AddIns
+      <command>pushd "%WORKSPACE%\out\Release\AddIns"
 rd /S /Q GeoRest
 popd</command>
-      <command>pushd %WORKSPACE%\UserDoc
+      <command>pushd "%WORKSPACE%\UserDoc"
 call make.bat html
 popd
-pushd %WORKSPACE%\UserDoc\build\html
+pushd "%WORKSPACE%\UserDoc\build\html"
 xcopy /S /Y *.* "%WORKSPACE%\out\Release\UserDoc\"
 popd
 </command>
-      <command>pushd %WORKSPACE%\Thirdparty\NSIS
+      <command>pushd "%WORKSPACE%\Thirdparty\NSIS"
 makensis.exe /DSLN_CONFIG=Release /DCPU=x86 /DRELEASE_VERSION=%VersionLabel% "%WORKSPACE%\Install\Maestro.nsi"
-pushd
-pushd %WORKSPACE%\out
-if not exist %MG_BUILD_ARTIFACT_PATH%\maestro mkdir %MG_BUILD_ARTIFACT_PATH%\maestro
-move /Y *.exe %MG_BUILD_ARTIFACT_PATH%\maestro
+popd
+pushd "%WORKSPACE%\out"
+if not exist "%MG_BUILD_ARTIFACT_PATH%\maestro" mkdir "%MG_BUILD_ARTIFACT_PATH%\maestro"
+move /Y *.exe "%MG_BUILD_ARTIFACT_PATH%\maestro"
 popd</command>
 rd /S /Q Local
 rd /S /Q Scripting
 popd
-pushd %WORKSPACE%\out\Release
+pushd "%WORKSPACE%\out\Release"
 del /Q LocalConfigure.*
-7z a -tzip -mx9 %MG_BUILD_ARTIFACT_PATH%\maestro\MapGuideMaestro-%VersionLabel%-Release.zip .
+7z a -tzip -mx9 "%MG_BUILD_ARTIFACT_PATH%\maestro\MapGuideMaestro-%VersionLabel%-Release.zip" .
 popd</command>
     <hudson.plugins.msbuild.MsBuildBuilder plugin="msbuild at 1.17">
@@ -111,12 +111,12 @@
-      <command>pushd %WORKSPACE%\Doc\Help
+      <command>pushd "%WORKSPACE%\Doc\Help"
 move /Y MaestroAPI.chm "%WORKSPACE%\SDK"
 popd
-7z a -tzip -mx9 %MG_BUILD_ARTIFACT_PATH%\maestro\MaestroSDK_%VersionLabel%.zip .
+7z a -tzip -mx9 "%MG_BUILD_ARTIFACT_PATH%\maestro\MaestroSDK_%VersionLabel%.zip" .
 popd</command>
   </builders>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml	2013-09-30 16:31:04 UTC (rev 7884)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml	2013-09-30 16:48:20 UTC (rev 7885)
@@ -52,13 +52,13 @@
   <builders>
 rd /S /Q out
 popd
+%MG_TOOL_PATH%\SetAssemblyVersion.exe -set:5.1.0.%SVN_REVISION% GlobalAssemblyInfo.cs
 popd
 rd /S /Q bin
 popd</command>
@@ -70,37 +70,37 @@
 rd /S /Q GeoRest
 popd</command>
 call make.bat html
 popd
 popd
 </command>
-pushd
+popd
 popd</command>
 rd /S /Q Local
 rd /S /Q Scripting
 popd
 popd</command>
 popd
 popd</command>
   </builders>
More information about the mapguide-commits mailing list
