[mapguide-commits] r8009 - in trunk/MgDev/Web/src/schemareport: . templatefiles
svn_mapguide at osgeo.org
Wed Apr 2 07:08:41 PDT 2014
Author: jng
Date: 2014-04-02 07:08:41 -0700 (Wed, 02 Apr 2014)
New Revision: 8009
Added:
trunk/MgDev/Web/src/schemareport/templatefiles/textwatermark.templ
trunk/MgDev/Web/src/schemareport/displayschemafunctions.php
trunk/MgDev/Web/src/schemareport/mapdefinitionfactory.php
trunk/MgDev/Web/src/schemareport/showgeom.php
trunk/MgDev/Web/src/schemareport/stringconstants.php
trunk/MgDev/Web/src/schemareport/templatefiles/mapdefinition.templ
#2421: Add debug watermarks for schema report map previews.
Modified: trunk/MgDev/Web/src/schemareport/displayschemafunctions.php
--- trunk/MgDev/Web/src/schemareport/displayschemafunctions.php 2014-04-01 13:17:43 UTC (rev 8008)
+++ trunk/MgDev/Web/src/schemareport/displayschemafunctions.php 2014-04-02 14:08:41 UTC (rev 8009)
@@ -307,6 +307,58 @@
return $layerDefinition;
+function CreateDebugMapDef($factory, $resourceSrvc, $className, $sessionId, $resId, $coordinate, $minX, $maxX, $minY, $maxY, $featureCount)
+ // The full WKT probably won't fit on the map, so tidy it up for display on a map
+ $csClean = str_replace("[", "[\n ", $coordinate);
+ $csClean = str_replace("],", "],\n", $csClean);
+ // Make a debug text watermark containing relevant debugging information
+ $message = sprintf(Debug::WatermarkDebugTemplate,
+ $className,
+ $featureCount,
+ $minX,
+ $minY,
+ $maxX,
+ $maxY,
+ $csClean);
+ $wmark = $factory->CreateTextWatermark($message);
+ $wmidstr = "Session:$sessionId//".$className."_DEBUG.WatermarkDefinition";
+ $wmid = new MgResourceIdentifier($wmidstr);
+ $wmSource = new MgByteSource($wmark, strlen($wmark));
+ $wmRdr = $wmSource->GetReader();
+ $resourceSrvc->SetResource($wmid, $wmRdr, null);
+ // Inputs for Extents
+ $extents = $factory->CreateExtents($minX, $maxX, $minY, $maxY);
+ // Inputs for MapLayer
+ $layerName = $className;
+ $selectable = MapDef::Selectable;
+ $showLegend = MapDef::ShowLegend;
+ $legendLabel = $className;
+ $expandLegend = MapDef::ExpandLegend;
+ $visible = MapDef::Visible;
+ $groupName = MapDef::GroupName;
+ $mapLayer = $factory->CreateMapLayer($layerName, $resId, $selectable, $showLegend, $legendLabel, $expandLegend, $visible, $groupName);
+ // Inputs for MapLayerGroup
+ $legendLabel = MapDef::LegendLabel;
+ $mapLayerGroup = $factory->CreateMapLayerGroup($groupName, $visible, $showLegend, $expandLegend, $legendLabel);
+ $dbgWatermarks = "<Watermarks><Watermark><Name>DEBUG</Name><ResourceId>$wmidstr</ResourceId></Watermark></Watermarks>";
+ // Inputs for MapDefinition
+ $mapName = MapDef::MapName;
+ $backgroundColor = MapDef::BgColor;
+ $mapDefinition = $factory->CreateMapDefinition($mapName, $coordinate, $extents, $backgroundColor, $mapLayer, $mapLayerGroup, $dbgWatermarks);
+ return $mapDefinition;
function CreateMapDef($factory, $className, $resId, $coordinate, $minX, $maxX, $minY, $maxY)
@@ -329,7 +381,7 @@
Modified: trunk/MgDev/Web/src/schemareport/mapdefinitionfactory.php
--- trunk/MgDev/Web/src/schemareport/mapdefinitionfactory.php 2014-04-01 13:17:43 UTC (rev 8008)
+++ trunk/MgDev/Web/src/schemareport/mapdefinitionfactory.php 2014-04-02 14:08:41 UTC (rev 8009)
@@ -44,12 +44,19 @@
return $extents;
- static function CreateMapDefinition($name, $coordinate, $extents, $backgroundColor, $mapLayer, $mapLayerGroup)
+ static function CreateMapDefinition($name, $coordinate, $extents, $backgroundColor, $mapLayer, $mapLayerGroup, $watermarks = "")
$mapDef = file_get_contents("templatefiles/mapdefinition.templ");
- $mapDef = sprintf($mapDef, $name, $coordinate, $extents, $backgroundColor, $mapLayer, $mapLayerGroup);
+ $mapDef = sprintf($mapDef, $name, $coordinate, $extents, $backgroundColor, $mapLayer, $mapLayerGroup, $watermarks);
return $mapDef;
+ static function CreateTextWatermark($text)
+ $wm = file_get_contents("templatefiles/textwatermark.templ");
+ $mw = sprintf($wm, $text);
+ return $mw;
Modified: trunk/MgDev/Web/src/schemareport/showgeom.php
--- trunk/MgDev/Web/src/schemareport/showgeom.php 2014-04-01 13:17:43 UTC (rev 8008)
+++ trunk/MgDev/Web/src/schemareport/showgeom.php 2014-04-02 14:08:41 UTC (rev 8009)
@@ -38,6 +38,7 @@
<?php
+ $includeDebugWatermark = true;
$sessionId = $_GET['sessionId'];
$resName = $_GET['resId'];
$schemaName = $_GET['schemaName'];
@@ -126,8 +127,11 @@
// Create a map definition
$mapfactory = new MapDefinitionFactory();
- $mapDefinition = CreateMapDef($mapfactory, $className, $resName, $mbr->coordinateSystem, $minX, $maxX, $minY, $maxY);
+ if ($includeDebugWatermark) {
+ $mapDefinition = CreateDebugMapDef($mapfactory, $resourceSrvc, $className, $sessionId, $resName, $mbr->coordinateSystem, $minX, $maxX, $minY, $maxY, $totalEntries);
+ } else {
+ $mapDefinition = CreateMapDef($mapfactory, $className, $resName, $mbr->coordinateSystem, $minX, $maxX, $minY, $maxY);
// Save the map definition to a resource stored in the session repository
$byteSource = new MgByteSource($mapDefinition, strlen($mapDefinition));
$byteSource->SetMimeType(MgMimeType::Xml);
Modified: trunk/MgDev/Web/src/schemareport/stringconstants.php
--- trunk/MgDev/Web/src/schemareport/stringconstants.php 2014-04-01 13:17:43 UTC (rev 8008)
+++ trunk/MgDev/Web/src/schemareport/stringconstants.php 2014-04-02 14:08:41 UTC (rev 8009)
@@ -101,6 +101,11 @@
const LayoutName = 'Geometry Layout';
+class Debug
+ const WatermarkDebugTemplate = 'MapGuide Debugging Information\n==============================\n\nPreviewed Class: %s\nFeature Count: %s\nComputed Extents Min: (%s, %s)\nComputed Extents Max: (%s, %s)\nCoordinate System: \n%s';
class XslStrings
const Schema = 'Schema:';
Modified: trunk/MgDev/Web/src/schemareport/templatefiles/mapdefinition.templ
--- trunk/MgDev/Web/src/schemareport/templatefiles/mapdefinition.templ 2014-04-01 13:17:43 UTC (rev 8008)
+++ trunk/MgDev/Web/src/schemareport/templatefiles/mapdefinition.templ 2014-04-02 14:08:41 UTC (rev 8009)
@@ -6,4 +6,5 @@
<BackgroundColor>%s</BackgroundColor>
%s
%s
+ %s
</MapDefinition>
Copied: trunk/MgDev/Web/src/schemareport/templatefiles/textwatermark.templ (from rev 8007, branches/2.5/MgDev/Web/src/schemareport/templatefiles/textwatermark.templ)
--- trunk/MgDev/Web/src/schemareport/templatefiles/textwatermark.templ (rev 0)
+++ trunk/MgDev/Web/src/schemareport/templatefiles/textwatermark.templ 2014-04-02 14:08:41 UTC (rev 8009)
@@ -0,0 +1,38 @@
+<?xml version="1.0"?>
+<WatermarkDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="WatermarkDefinition-2.4.0.xsd">
+ <Content>
+ <SimpleSymbolDefinition>
+ <Name />
+ <Description />
+ <Graphics>
+ <Text>
+ <Content>'%s'</Content>
+ <FontName>'Arial'</FontName>
+ <Height>3</Height>
+ <Justification>'Left'</Justification>
+ <TextColor>FF000000</TextColor>
+ <Frame>
+ <FillColor>CCFFFFFF</FillColor>
+ </Frame>
+ </Text>
+ </Graphics>
+ <PointUsage />
+ <ParameterDefinition />
+ </SimpleSymbolDefinition>
+ </Content>
+ <Appearance />
+ <Position>
+ <XYPosition>
+ <XPosition>
+ <Offset>10</Offset>
+ <Unit>Points</Unit>
+ <Alignment>Left</Alignment>
+ </XPosition>
+ <YPosition>
+ <Alignment>Top</Alignment>
+ </YPosition>
+ </XYPosition>
+ </Position>
+</WatermarkDefinition>
More information about the mapguide-commits
