[mapguide-commits] r8024 - in trunk/Tools/MgInstantSetup: . InstantSetup InstantSetup/Properties InstantSetup.Core InstantSetup.Core/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Apr 9 08:40:32 PDT 2014
Author: jng
Date: 2014-04-09 08:40:32 -0700 (Wed, 09 Apr 2014)
New Revision: 8024
   trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs
   trunk/Tools/MgInstantSetup/InstantSetup.Core/InstantSetup.Core.csproj
   trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.Designer.cs
   trunk/Tools/MgInstantSetup/InstantSetup.Core/app.config
   trunk/Tools/MgInstantSetup/InstantSetup/InstantSetup.csproj
   trunk/Tools/MgInstantSetup/InstantSetup/Properties/Resources.Designer.cs
   trunk/Tools/MgInstantSetup/InstantSetup/Properties/Settings.Designer.cs
   trunk/Tools/MgInstantSetup/InstantSetup/app.config
   trunk/Tools/MgInstantSetup/MgInstantSetup.sln
MgInstantSetup update:
 - Move to VS2012 / .net 4.0
 - Default Apache dir name to "Apache24"
Modified: trunk/Tools/MgInstantSetup/InstantSetup/InstantSetup.csproj
--- trunk/Tools/MgInstantSetup/InstantSetup/InstantSetup.csproj	2014-04-09 15:39:35 UTC (rev 8023)
+++ trunk/Tools/MgInstantSetup/InstantSetup/InstantSetup.csproj	2014-04-09 15:40:32 UTC (rev 8024)
@@ -1,5 +1,5 @@
 <?xml version="1.0" encoding="utf-8"?>
-<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
   <PropertyGroup>
     <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
     <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
@@ -10,11 +10,14 @@
     <AppDesignerFolder>Properties</AppDesignerFolder>
     <RootNamespace>InstantSetup</RootNamespace>
     <AssemblyName>InstantSetup</AssemblyName>
-    <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+    <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
     <FileAlignment>512</FileAlignment>
-    <TargetFrameworkSubset>
-    </TargetFrameworkSubset>
     <ApplicationManifest>app.manifest</ApplicationManifest>
+    <FileUpgradeFlags>
+    </FileUpgradeFlags>
+    <UpgradeBackupLocation>
+    </UpgradeBackupLocation>
+    <OldToolsVersion>3.5</OldToolsVersion>
   </PropertyGroup>
   <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
     <DebugSymbols>true</DebugSymbols>
Modified: trunk/Tools/MgInstantSetup/InstantSetup/Properties/Resources.Designer.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/Properties/Resources.Designer.cs	2014-04-09 15:39:35 UTC (rev 8023)
+++ trunk/Tools/MgInstantSetup/InstantSetup/Properties/Resources.Designer.cs	2014-04-09 15:40:32 UTC (rev 8024)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:2.0.50727.4952
+//     Runtime Version:4.0.30319.18444
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -19,7 +19,7 @@
     // class via a tool like ResGen or Visual Studio.
     // To add or remove a member, edit your .ResX file then rerun ResGen
     // with the /str option, or rebuild your VS project.
-    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
+    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")]
     [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
     [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
     internal class Resources {
Modified: trunk/Tools/MgInstantSetup/InstantSetup/Properties/Settings.Designer.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/Properties/Settings.Designer.cs	2014-04-09 15:39:35 UTC (rev 8023)
+++ trunk/Tools/MgInstantSetup/InstantSetup/Properties/Settings.Designer.cs	2014-04-09 15:40:32 UTC (rev 8024)
@@ -1,28 +1,24 @@
 // <auto-generated>
 // </auto-generated>
-namespace InstantSetup.Properties
+namespace InstantSetup.Properties {
-    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "9.0.0.0")]
-    internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase
+    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "11.0.0.0")]
+    internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase {
         private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
-        public static Settings Default
-            get
+        public static Settings Default {
+            get {
                 return defaultInstance;
Modified: trunk/Tools/MgInstantSetup/InstantSetup/app.config
--- trunk/Tools/MgInstantSetup/InstantSetup/app.config	2014-04-09 15:39:35 UTC (rev 8023)
+++ trunk/Tools/MgInstantSetup/InstantSetup/app.config	2014-04-09 15:40:32 UTC (rev 8024)
@@ -1,3 +1,3 @@
-<?xml version="1.0"?>
+<?xml version="1.0"?>
 <configuration>
-<startup><supportedRuntime version="v2.0.50727"/></startup></configuration>
+	<startup/></configuration>
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs	2014-04-09 15:39:35 UTC (rev 8023)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs	2014-04-09 15:40:32 UTC (rev 8024)
@@ -35,7 +35,7 @@
             this.VirtualDirectoryName = "mapguide";
             this.HttpdServiceName = "ApacheMapGuide";
-            this.ApacheDirName = "Apache2";
+            this.ApacheDirName = "Apache24";
         public bool EnableJava { get; set; }
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/InstantSetup.Core.csproj
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/InstantSetup.Core.csproj	2014-04-09 15:39:35 UTC (rev 8023)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/InstantSetup.Core.csproj	2014-04-09 15:40:32 UTC (rev 8024)
@@ -1,5 +1,5 @@
   <PropertyGroup>
@@ -10,10 +10,13 @@
     <RootNamespace>InstantSetup.Core</RootNamespace>
     <AssemblyName>InstantSetup.Core</AssemblyName>
   </PropertyGroup>
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.Designer.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.Designer.cs	2014-04-09 15:39:35 UTC (rev 8023)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.Designer.cs	2014-04-09 15:40:32 UTC (rev 8024)
@@ -1,7 +1,7 @@
 // <auto-generated>
-//     Runtime Version:2.0.50727.5420
@@ -19,7 +19,7 @@
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/app.config
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/app.config	2014-04-09 15:39:35 UTC (rev 8023)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/app.config	2014-04-09 15:40:32 UTC (rev 8024)
@@ -1,3 +1,3 @@
 <configuration>
Modified: trunk/Tools/MgInstantSetup/MgInstantSetup.sln
--- trunk/Tools/MgInstantSetup/MgInstantSetup.sln	2014-04-09 15:39:35 UTC (rev 8023)
+++ trunk/Tools/MgInstantSetup/MgInstantSetup.sln	2014-04-09 15:40:32 UTC (rev 8024)
@@ -1,6 +1,6 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio Express 2012 for Windows Desktop
 Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "InstantSetup.Core", "InstantSetup.Core\InstantSetup.Core.csproj", "{70F74850-DC74-431E-993D-8200E13B026A}"
 EndProject
 Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "InstantSetup", "InstantSetup\InstantSetup.csproj", "{72CDEB87-1ED2-4177-8C00-962E79F36CA6}"
More information about the mapguide-commits mailing list
