[mapguide-commits] r8078 - in trunk/Tools/Maestro: Maestro.Base Maestro.Base/Commands Maestro.Base/UI Maestro.Editors Maestro.Editors/Diff OSGeo.MapGuide.MaestroAPI/Resource/Comparison
svn_mapguide at osgeo.org
Sun Apr 27 07:56:36 PDT 2014
Author: jng
Date: 2014-04-27 07:56:35 -0700 (Sun, 27 Apr 2014)
New Revision: 8078
Added:
trunk/Tools/Maestro/Maestro.Editors/Diff/XmlCompareUtil.cs
Removed:
trunk/Tools/Maestro/Maestro.Base/Util/
trunk/Tools/Maestro/Maestro.Base/Commands/ViewXmlChangesCommand.cs
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/UI/DirtyStateConfirmationDialog.cs
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Comparison/TextFile.cs
Refactor the XML content comparison preparation code
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/ViewXmlChangesCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/ViewXmlChangesCommand.cs 2014-04-27 14:23:32 UTC (rev 8077)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/ViewXmlChangesCommand.cs 2014-04-27 14:56:35 UTC (rev 8078)
@@ -28,7 +28,6 @@
using Maestro.Shared.UI;
using OSGeo.MapGuide.MaestroAPI.Resource.Comparison;
using System.Xml;
-using Maestro.Base.Util;
namespace Maestro.Base.Commands
@@ -49,13 +48,11 @@
try
edSvc.SyncSessionCopy();
- XmlCompareUtil.PrepareForComparison(edSvc.ResourceService,
- edSvc.ResourceID,
- edSvc.EditedResourceID,
- out sourceFile,
- out targetFile);
- sLF = new TextFileDiffList(sourceFile);
- dLF = new TextFileDiffList(targetFile);
+ var set = XmlCompareUtil.PrepareForComparison(edSvc.ResourceService,
+ edSvc.ResourceID,
+ edSvc.EditedResourceID);
+ sLF = set.Source;
+ dLF = set.Target;
catch (Exception ex)
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2014-04-27 14:23:32 UTC (rev 8077)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2014-04-27 14:56:35 UTC (rev 8078)
@@ -441,7 +441,6 @@
<DependentUpon>ValidationResultsDialog.cs</DependentUpon>
</Compile>
<Compile Include="MaestroPaths.cs" />
- <Compile Include="Util\XmlCompareUtil.cs" />
<Compile Include="Workbench.cs">
<SubType>Form</SubType>
</Compile>
Modified: trunk/Tools/Maestro/Maestro.Base/UI/DirtyStateConfirmationDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/DirtyStateConfirmationDialog.cs 2014-04-27 14:23:32 UTC (rev 8077)
+++ trunk/Tools/Maestro/Maestro.Base/UI/DirtyStateConfirmationDialog.cs 2014-04-27 14:56:35 UTC (rev 8078)
@@ -31,7 +31,6 @@
using Maestro.Editors.Diff;
using System.IO;
namespace Maestro.Base.UI
@@ -70,13 +69,11 @@
try
_edSvc.SyncSessionCopy();
- XmlCompareUtil.PrepareForComparison(_edSvc.ResourceService,
- _edSvc.ResourceID,
- _edSvc.EditedResourceID,
- out sourceFile,
- out targetFile);
+ var set = XmlCompareUtil.PrepareForComparison(_edSvc.ResourceService,
+ _edSvc.ResourceID,
+ _edSvc.EditedResourceID);
+ sLF = set.Source;
+ dLF = set.Target;
Added: trunk/Tools/Maestro/Maestro.Editors/Diff/XmlCompareUtil.cs
--- trunk/Tools/Maestro/Maestro.Editors/Diff/XmlCompareUtil.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Diff/XmlCompareUtil.cs 2014-04-27 14:56:35 UTC (rev 8078)
@@ -0,0 +1,81 @@
+#region Disclaimer / License
+// Copyright (C) 2014, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using OSGeo.MapGuide.MaestroAPI.Resource.Comparison;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using System;
+using System.Collections.Generic;
+using System.IO;
+using System.Linq;
+using System.Text;
+using System.Xml;
+namespace Maestro.Editors.Diff
+ public class XmlComparisonSet
+ internal XmlComparisonSet(TextFileDiffList source, TextFileDiffList target)
+ this.Source = source;
+ this.Target = target;
+ public TextFileDiffList Source { get; private set; }
+ public TextFileDiffList Target { get; private set; }
+ public class XmlCompareUtil
+ /// <summary>
+ /// Prepares the source and target resource content for XML comparison
+ /// </summary>
+ /// <param name="resSvc"></param>
+ /// <param name="sourceId"></param>
+ /// <param name="targetId"></param>
+ public static XmlComparisonSet PrepareForComparison(IResourceService resSvc, string sourceId, string targetId)
+ //Route both source and target XML content through
+ //XmlDocument objects to ensure issues like whitespacing do
+ //not throw us off
+ var sourceFile = Path.GetTempFileName();
+ var targetFile = Path.GetTempFileName();
+ using (var sourceStream = resSvc.GetResourceXmlData(sourceId))
+ using (var targetStream = resSvc.GetResourceXmlData(targetId))
+ var sourceDoc = new XmlDocument();
+ var targetDoc = new XmlDocument();
+ sourceDoc.Load(sourceStream);
+ targetDoc.Load(targetStream);
+ using (var fs = File.OpenWrite(sourceFile))
+ using (var ft = File.OpenWrite(targetFile))
+ sourceDoc.Save(fs);
+ targetDoc.Save(ft);
+ return new XmlComparisonSet(
+ new TextFileDiffList(sourceFile, true),
+ new TextFileDiffList(targetFile, true));
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2014-04-27 14:23:32 UTC (rev 8077)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2014-04-27 14:56:35 UTC (rev 8078)
@@ -214,6 +214,7 @@
<Compile Include="Diff\TextDiffView.Designer.cs">
<DependentUpon>TextDiffView.cs</DependentUpon>
</Compile>
+ <Compile Include="Diff\XmlCompareUtil.cs" />
<Compile Include="DrawingSource\DrawingSourceEditorCtrl.cs">
<SubType>UserControl</SubType>
</Compile>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Comparison/TextFile.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Comparison/TextFile.cs 2014-04-27 14:23:32 UTC (rev 8077)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Comparison/TextFile.cs 2014-04-27 14:56:35 UTC (rev 8078)
@@ -74,7 +74,17 @@
/// </summary>
/// <param name="fileName"></param>
public TextFileDiffList(string fileName)
+ : this(fileName, false)
+ /// <summary>
+ /// Creates a new instance
+ /// </summary>
+ /// <param name="fileName"></param>
+ /// <param name="deleteFile"></param>
+ public TextFileDiffList(string fileName, bool deleteFile)
_lines = new List<TextLine>();
using (StreamReader sr = new StreamReader(fileName))
@@ -86,6 +96,14 @@
_lines.Add(new TextLine(line));
+ if (deleteFile)
+ try
+ File.Delete(fileName);
+ catch { }
#region IDiffList Members
/// <summary>
More information about the mapguide-commits
