[mapguide-commits] r8089 - in branches/2.6/MgDev: . Oem/SWIGEx Oem/SWIGEx/Linux Oem/dbxml/xqilla Oem/dbxml/xqilla/src/items Server/src/Core
svn_mapguide at osgeo.org
Tue Apr 29 08:24:28 PDT 2014
Author: jng
Date: 2014-04-29 08:24:28 -0700 (Tue, 29 Apr 2014)
New Revision: 8089
Added:
branches/2.6/MgDev/Oem/SWIGEx/Linux/
branches/2.6/MgDev/Oem/SWIGEx/Linux/swig
Removed:
branches/2.6/MgDev/Oem/dbxml/xqilla/Makefile.am
branches/2.6/MgDev/Oem/dbxml/xqilla/Makefile.in
branches/2.6/MgDev/Oem/dbxml/xqilla/src/items/DatatypeFactoryTemplate.hpp
branches/2.6/MgDev/Server/src/Core/Makefile.am
branches/2.6/MgDev/build_oem.sh
#2436: Port GCC fixes to 2.6
Deleted: branches/2.6/MgDev/Oem/SWIGEx/Linux/swig
(Binary files differ)
Copied: branches/2.6/MgDev/Oem/SWIGEx/Linux/swig (from rev 8083, trunk/MgDev/Oem/SWIGEx/Linux/swig)
Modified: branches/2.6/MgDev/Oem/dbxml/xqilla/Makefile.am
--- branches/2.6/MgDev/Oem/dbxml/xqilla/Makefile.am 2014-04-29 14:29:59 UTC (rev 8088)
+++ branches/2.6/MgDev/Oem/dbxml/xqilla/Makefile.am 2014-04-29 15:24:28 UTC (rev 8089)
@@ -640,7 +640,7 @@
$(LEX) -BUs -Pxq -S$(LEXSKEL) -o$(LEXERFILE) $(LEXTEMPLATE) # This can take a long time
$(PARSERCPP) $(PARSERHPP): $(PARSERFILE)
- $(YACC) -d -v -o $(PARSERCPP) $(PARSERFILE)
+ if [ ! -f $(PARSERCPP) ]; then $(YACC) -d -v -o $(PARSERCPP) $(PARSERFILE); fi;
.PHONY: test docs
Modified: branches/2.6/MgDev/Oem/dbxml/xqilla/Makefile.in
--- branches/2.6/MgDev/Oem/dbxml/xqilla/Makefile.in 2014-04-29 14:29:59 UTC (rev 8088)
+++ branches/2.6/MgDev/Oem/dbxml/xqilla/Makefile.in 2014-04-29 15:24:28 UTC (rev 8089)
@@ -5375,7 +5375,7 @@
$(LEXERFILE): $(LEXTEMPLATE) $(LEXSKEL)
.PHONY: test docs
Modified: branches/2.6/MgDev/Oem/dbxml/xqilla/src/items/DatatypeFactoryTemplate.hpp
--- branches/2.6/MgDev/Oem/dbxml/xqilla/src/items/DatatypeFactoryTemplate.hpp 2014-04-29 14:29:59 UTC (rev 8088)
+++ branches/2.6/MgDev/Oem/dbxml/xqilla/src/items/DatatypeFactoryTemplate.hpp 2014-04-29 15:24:28 UTC (rev 8089)
@@ -79,8 +79,8 @@
AnyAtomicType::Ptr createInstance(const XMLCh* value,
const DynamicContext* context) const
- return createInstanceNoCheck(DatatypeFactoryTemplate<TYPE>::getPrimitiveTypeURI(),
- DatatypeFactoryTemplate<TYPE>::getPrimitiveTypeName(), value, context);
+ return this->createInstanceNoCheck(DatatypeFactoryTemplate<TYPE>::getPrimitiveTypeURI(),
+ DatatypeFactoryTemplate<TYPE>::getPrimitiveTypeName(), value, context);
bool checkInstance(const XMLCh* value,
Modified: branches/2.6/MgDev/Server/src/Core/Makefile.am
--- branches/2.6/MgDev/Server/src/Core/Makefile.am 2014-04-29 14:29:59 UTC (rev 8088)
+++ branches/2.6/MgDev/Server/src/Core/Makefile.am 2014-04-29 15:24:28 UTC (rev 8089)
@@ -91,6 +91,7 @@
mgserver_LDADD = \
-lACE \
+ -ldl \
-ldb_cxx \
-ldbxml \
-ldwfcore \
Modified: branches/2.6/MgDev/build_oem.sh
--- branches/2.6/MgDev/build_oem.sh 2014-04-29 14:29:59 UTC (rev 8088)
+++ branches/2.6/MgDev/build_oem.sh 2014-04-29 15:24:28 UTC (rev 8089)
@@ -118,7 +118,10 @@
build_dwfcore()
pushd DWFTK7.1/develop/global/src/dwfcore
+ aclocal
libtoolize --copy --force
+ automake --add-missing --copy
+ autoconf
sh ./configure --enable-optimized --prefix="${INSTALLDIR}"
make
check_build
@@ -151,7 +154,10 @@
build_dwftk()
+ aclocal
+ autoconf
make
check_build
@@ -184,7 +190,10 @@
build_dwfemap()
pushd DWFTK7.1/develop/global/src/dwfemap
+ aclocal
+ autoconf
make
check_build
@@ -622,7 +631,7 @@
pushd Oem
-for lib in ace dwfcore dwftk dwfemap geos swigex bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
+for lib in ace dwfcore dwftk dwfemap geos bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
do
echo "$lib: Initialization..........................."
init_"$lib"
More information about the mapguide-commits
