[mapguide-commits] r8341 - in trunk/MgDev: . Common/Renderers Common/Stylization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Aug 20 07:21:18 PDT 2014
Author: jng
Date: 2014-08-20 07:21:17 -0700 (Wed, 20 Aug 2014)
New Revision: 8341
   trunk/MgDev/
   trunk/MgDev/Common/Renderers/AGGRenderer.cpp
   trunk/MgDev/Common/Renderers/GDRenderer.cpp
   trunk/MgDev/Common/Stylization/SE_Renderer.cpp
Merged revision(s) 8340 from branches/2.6/MgDev:
#2481: The previous fix for #852 is incomplete. When SE_Renderer::SetRenderMode() is called without an RGBA value, it is supposed do default to blue with a pre-determined transparency but because that default color has an alpha component of 0, the fill is now fully transparent. The fix is to default to blue with an alpha of 255, that will result in the old behaviour.
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335
/sandbox/jng/convenience_apis:8263
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
   + /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340
Modified: trunk/MgDev/Common/Renderers/AGGRenderer.cpp
--- trunk/MgDev/Common/Renderers/AGGRenderer.cpp	2014-08-20 14:03:31 UTC (rev 8340)
+++ trunk/MgDev/Common/Renderers/AGGRenderer.cpp	2014-08-20 14:21:17 UTC (rev 8341)
@@ -1408,7 +1408,7 @@
 void AGGRenderer::SetRenderSelectionMode(bool mode)
-    SetRenderSelectionMode(mode, 0x0000FF00);
+    SetRenderSelectionMode(mode, 0x0000FFFF);
Modified: trunk/MgDev/Common/Renderers/GDRenderer.cpp
--- trunk/MgDev/Common/Renderers/GDRenderer.cpp	2014-08-20 14:03:31 UTC (rev 8340)
+++ trunk/MgDev/Common/Renderers/GDRenderer.cpp	2014-08-20 14:21:17 UTC (rev 8341)
@@ -1529,7 +1529,7 @@
 void GDRenderer::SetRenderSelectionMode(bool mode)
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2014-08-20 14:03:31 UTC (rev 8340)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2014-08-20 14:21:17 UTC (rev 8341)
@@ -150,7 +150,7 @@
 void SE_Renderer::SetRenderSelectionMode(bool mode)
Property changes on: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
   - /branches/2.4/MgDev/Common/Stylization/SE_Renderer.cpp:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/adsk/2.4j/Common/Stylization/SE_Renderer.cpp:6327-6445
/sandbox/jng/createruntimemap/Common/Stylization/SE_Renderer.cpp:7486-7555
/sandbox/rfc94/Common/Stylization/SE_Renderer.cpp:5099-5163
/trunk/MgDev/Common/Stylization/SE_Renderer.cpp:6250-6326
   + /branches/2.4/MgDev/Common/Stylization/SE_Renderer.cpp:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev/Common/Stylization/SE_Renderer.cpp:8340
More information about the mapguide-commits mailing list
