[mapguide-commits] r8281 - in branches/2.6/MgDev/nuget/MapGuideNuget: .nuget CoordSysEnumTest CoordSysEnumTest64 DesktopConsoleTest DesktopConsoleTest64 DesktopViewerTest DesktopViewerTest64 MapGuideNuget MapGuideNuget64
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jul 4 04:36:55 PDT 2014
Author: jng
Date: 2014-07-04 04:36:55 -0700 (Fri, 04 Jul 2014)
New Revision: 8281
Removed:
   branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config
   branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/packages.config
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest/packages.config
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config
   branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget/packages.config
   branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config
   branches/2.6/MgDev/nuget/MapGuideNuget/.nuget/NuGet.exe
   branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj
   branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/DesktopConsoleTest.csproj
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest/DesktopViewerTest.csproj
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj
   branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj
   branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj
Update nuget test solution. The solution and its projects should be in a clean slate.
Modified: branches/2.6/MgDev/nuget/MapGuideNuget/.nuget/NuGet.exe
(Binary files differ)
Modified: branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj
--- branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj	2014-07-04 11:36:55 UTC (rev 8281)
@@ -13,6 +13,8 @@
     <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
     <TargetFrameworkProfile>Client</TargetFrameworkProfile>
     <FileAlignment>512</FileAlignment>
+    <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\</SolutionDir>
+    <RestorePackages>true</RestorePackages>
   </PropertyGroup>
   <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x86' ">
     <PlatformTarget>x86</PlatformTarget>
@@ -35,15 +37,6 @@
     <WarningLevel>4</WarningLevel>
   </PropertyGroup>
   <ItemGroup>
-    <Reference Include="OSGeo.MapGuide.Foundation">
-      <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.Geometry">
-      <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.PlatformBase">
-      <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
-    </Reference>
     <Reference Include="System" />
     <Reference Include="System.Core" />
     <Reference Include="System.Xml.Linq" />
@@ -76,7 +69,6 @@
       <AutoGen>True</AutoGen>
       <DependentUpon>Resources.resx</DependentUpon>
     </Compile>
-    <None Include="packages.config" />
     <None Include="Properties\Settings.settings">
       <Generator>SettingsSingleFileGenerator</Generator>
       <LastGenOutput>Settings.Designer.cs</LastGenOutput>
@@ -90,10 +82,15 @@
   <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
   <PropertyGroup>
     <PostBuildEvent>
-if not exist "$(TargetDir)Dictionaries" md "$(TargetDir)Dictionaries"
-xcopy /s /y "$(SolutionDir)packages\cs-map-dictionaries.2.4.0.7093\dictionaries\*.*" "$(TargetDir)Dictionaries"
-xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x86.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"</PostBuildEvent>
+    </PostBuildEvent>
   </PropertyGroup>
+  <Import Project="$(SolutionDir)\.nuget\NuGet.targets" Condition="Exists('$(SolutionDir)\.nuget\NuGet.targets')" />
+  <Target Name="EnsureNuGetPackageBuildImports" BeforeTargets="PrepareForBuild">
+    <PropertyGroup>
+      <ErrorText>This project references NuGet package(s) that are missing on this computer. Enable NuGet Package Restore to download them.  For more information, see http://go.microsoft.com/fwlink/?LinkID=322105. The missing file is {0}.</ErrorText>
+    </PropertyGroup>
+    <Error Condition="!Exists('$(SolutionDir)\.nuget\NuGet.targets')" Text="$([System.String]::Format('$(ErrorText)', '$(SolutionDir)\.nuget\NuGet.targets'))" />
+  </Target>
   <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
        Other similar extension points exist, see Microsoft.Common.targets.
   <Target Name="BeforeBuild">
Deleted: branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config
--- branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config	2014-07-04 11:36:55 UTC (rev 8281)
@@ -1,5 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<packages>
-  <package id="cs-map-dictionaries" version="2.4.0.7093" targetFramework="net40-Client" />
-  <package id="mapguide-api-base-x86" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
\ No newline at end of file
Modified: branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj
--- branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj	2014-07-04 11:36:55 UTC (rev 8281)
@@ -36,15 +36,6 @@
     <CodeAnalysisRuleSet>ManagedMinimumRules.ruleset</CodeAnalysisRuleSet>
   </PropertyGroup>
   <ItemGroup>
-      <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
-    </Reference>
-      <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
-    </Reference>
-      <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
-    </Reference>
@@ -77,7 +68,6 @@
     </Compile>
@@ -91,9 +81,7 @@
   <PropertyGroup>
     <PostBuildEvent>
-xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x64.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"</PostBuildEvent>
+    </PostBuildEvent>
   </PropertyGroup>
   <Import Project="$(SolutionDir)\.nuget\nuget.targets" />
Deleted: branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config
--- branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config	2014-07-04 11:36:55 UTC (rev 8281)
@@ -1,5 +0,0 @@
-<packages>
-  <package id="mapguide-api-base-x64" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
Modified: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/DesktopConsoleTest.csproj
--- branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/DesktopConsoleTest.csproj	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/DesktopConsoleTest.csproj	2014-07-04 11:36:55 UTC (rev 8281)
@@ -13,6 +13,8 @@
   </PropertyGroup>
@@ -34,22 +36,6 @@
   </PropertyGroup>
   <ItemGroup>
-    <Reference Include="OSGeo.MapGuide.Desktop, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=AMD64">
-      <SpecificVersion>False</SpecificVersion>
-      <HintPath>..\packages\mg-desktop-net40-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Desktop.dll</HintPath>
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.Foundation, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.Geometry, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.PlatformBase, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
-    </Reference>
     <Reference Include="System.Drawing" />
@@ -64,17 +50,18 @@
     <Compile Include="Program.cs" />
     <Compile Include="Properties\AssemblyInfo.cs" />
   </ItemGroup>
-  <ItemGroup>
-  </ItemGroup>
   <PropertyGroup>
     <PostBuildEvent>
-xcopy /s /y "$(SolutionDir)packages\mg-desktop-net40-x86.2.4.0.7093\mg-desktop\*.*" "$(TargetDir)"</PostBuildEvent>
+    </PostBuildEvent>
   </PropertyGroup>
+    <PropertyGroup>
+    </PropertyGroup>
+  </Target>
Deleted: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/packages.config
--- branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/packages.config	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/packages.config	2014-07-04 11:36:55 UTC (rev 8281)
@@ -1,6 +0,0 @@
-<packages>
-  <package id="mg-desktop-net40-x86" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
Modified: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj
--- branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj	2014-07-04 11:36:55 UTC (rev 8281)
@@ -35,18 +35,6 @@
   </PropertyGroup>
   <ItemGroup>
-    <Reference Include="OSGeo.MapGuide.Desktop">
-      <HintPath>..\packages\mg-desktop-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Desktop.dll</HintPath>
-    </Reference>
-    </Reference>
-    </Reference>
-    </Reference>
@@ -61,16 +49,10 @@
   </ItemGroup>
-  <ItemGroup>
-  </ItemGroup>
   <PropertyGroup>
     <PostBuildEvent>
-xcopy /s /y "$(SolutionDir)packages\mg-desktop-net40-x64.2.4.0.7093\mg-desktop\*.*" "$(TargetDir)"</PostBuildEvent>
+    </PostBuildEvent>
   </PropertyGroup>
Deleted: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config
--- branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config	2014-07-04 11:36:55 UTC (rev 8281)
@@ -1,6 +0,0 @@
-<packages>
-  <package id="mg-desktop-net40-x64" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
Modified: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest/DesktopViewerTest.csproj
--- branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest/DesktopViewerTest.csproj	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest/DesktopViewerTest.csproj	2014-07-04 11:36:55 UTC (rev 8281)
@@ -13,6 +13,8 @@
   </PropertyGroup>
@@ -34,30 +36,6 @@
   </PropertyGroup>
   <ItemGroup>
-    </Reference>
-    </Reference>
-    </Reference>
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.Viewer, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=MSIL">
-      <HintPath>..\packages\mg-desktop-viewer-net40-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.dll</HintPath>
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.Viewer.Desktop, Version=2.4.0.7093, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=MSIL">
-      <HintPath>..\packages\mg-desktop-viewer-net40-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.Desktop.dll</HintPath>
-    </Reference>
@@ -90,7 +68,6 @@
     </Compile>
@@ -104,11 +81,15 @@
   <PropertyGroup>
     <PostBuildEvent>
+    </PostBuildEvent>
   </PropertyGroup>
+    <PropertyGroup>
+    </PropertyGroup>
+  </Target>
Deleted: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest/packages.config
--- branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest/packages.config	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest/packages.config	2014-07-04 11:36:55 UTC (rev 8281)
@@ -1,7 +0,0 @@
-<packages>
-  <package id="mg-desktop-viewer-net40-x86" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
Modified: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj
--- branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj	2014-07-04 11:36:55 UTC (rev 8281)
@@ -35,24 +35,6 @@
   </PropertyGroup>
   <ItemGroup>
-    </Reference>
-    </Reference>
-    </Reference>
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.Viewer">
-      <HintPath>..\packages\mg-desktop-viewer-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.dll</HintPath>
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.Viewer.Desktop">
-      <HintPath>..\packages\mg-desktop-viewer-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.Desktop.dll</HintPath>
-    </Reference>
@@ -82,7 +64,6 @@
     </Compile>
@@ -96,10 +77,7 @@
   <PropertyGroup>
     <PostBuildEvent>
+    </PostBuildEvent>
   </PropertyGroup>
Deleted: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config
--- branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config	2014-07-04 11:36:55 UTC (rev 8281)
@@ -1,7 +0,0 @@
-<packages>
-  <package id="mg-desktop-viewer-net40-x64" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
Modified: branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj
--- branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget/MapGuideNuget.csproj	2014-07-04 11:36:55 UTC (rev 8281)
@@ -19,24 +19,11 @@
     <IISExpressAnonymousAuthentication />
     <IISExpressWindowsAuthentication />
     <IISExpressUseClassicPipelineMode />
   </PropertyGroup>
   <ItemGroup>
     <Reference Include="Microsoft.CSharp" />
-    </Reference>
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.MapGuideCommon">
-      <HintPath>..\packages\mapguide-api-web-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.MapGuideCommon.dll</HintPath>
-    </Reference>
-    </Reference>
-    <Reference Include="OSGeo.MapGuide.Web">
-      <HintPath>..\packages\mapguide-api-web-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Web.dll</HintPath>
-    </Reference>
     <Reference Include="System.Web.DynamicData" />
     <Reference Include="System.Web.Entity" />
     <Reference Include="System.Web.ApplicationServices" />
@@ -73,7 +60,6 @@
   </ItemGroup>
   <ItemGroup>
-    <Content Include="packages.config" />
     <None Include="Web.Debug.config">
       <DependentUpon>Web.config</DependentUpon>
     </None>
@@ -127,9 +113,15 @@
   </ProjectExtensions>
   <PropertyGroup>
     <PostBuildEvent>
-xcopy /s /y "$(SolutionDir)packages\mapguide-api-web-x86.2.4.0.7093\mapguide-api-web\*.*" "$(TargetDir)"</PostBuildEvent>
+    </PostBuildEvent>
   </PropertyGroup>
+    <PropertyGroup>
+    </PropertyGroup>
+  </Target>
Deleted: branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget/packages.config
--- branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget/packages.config	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget/packages.config	2014-07-04 11:36:55 UTC (rev 8281)
@@ -1,5 +0,0 @@
-<packages>
-  <package id="mapguide-api-base-x86" version="2.4.0.7093" targetFramework="net40" />
-  <package id="mapguide-api-web-x86" version="2.4.0.7093" targetFramework="net40" />
-</packages>
Modified: branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj
--- branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj	2014-07-04 11:36:55 UTC (rev 8281)
@@ -24,21 +24,6 @@
   </PropertyGroup>
   <ItemGroup>
-    </Reference>
-    </Reference>
-      <HintPath>..\packages\mapguide-api-web-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.MapGuideCommon.dll</HintPath>
-    </Reference>
-    </Reference>
-      <HintPath>..\packages\mapguide-api-web-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Web.dll</HintPath>
-    </Reference>
@@ -75,7 +60,6 @@
   </ItemGroup>
   <ItemGroup>
     </None>
@@ -129,8 +113,7 @@
   <PropertyGroup>
     <PostBuildEvent>
-xcopy /s /y "$(SolutionDir)packages\mapguide-api-web-x64.2.4.0.7093\mapguide-api-web\*.*" "$(TargetDir)"</PostBuildEvent>
+    </PostBuildEvent>
   </PropertyGroup>
Deleted: branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config
--- branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config	2014-07-04 10:14:44 UTC (rev 8280)
+++ branches/2.6/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config	2014-07-04 11:36:55 UTC (rev 8281)
@@ -1,5 +0,0 @@
-<packages>
-  <package id="mapguide-api-base-x64" version="2.4.0.7093" targetFramework="net40" />
-  <package id="mapguide-api-web-x64" version="2.4.0.7093" targetFramework="net40" />
-</packages>
More information about the mapguide-commits mailing list
