[mapguide-commits] r8291 - branches/2.6/MgDev/Web/src/mapviewerphp
svn_mapguide at osgeo.org
Wed Jul 9 05:34:58 PDT 2014
Author: jng
Date: 2014-07-09 05:34:58 -0700 (Wed, 09 Jul 2014)
New Revision: 8291
Removed:
branches/2.6/MgDev/Web/src/mapviewerphp/setselection.php
branches/2.6/MgDev/Web/src/mapviewerphp/mapframe.php
#2465: Remove setselection.php and don't plug in this script reference in mapframe.php
Modified: branches/2.6/MgDev/Web/src/mapviewerphp/mapframe.php
--- branches/2.6/MgDev/Web/src/mapviewerphp/mapframe.php 2014-07-09 12:34:36 UTC (rev 8290)
+++ branches/2.6/MgDev/Web/src/mapviewerphp/mapframe.php 2014-07-09 12:34:58 UTC (rev 8291)
@@ -143,7 +143,6 @@
$unitsType,
$bgColor,
$hlTgt, $hlTgtName,
- $vpath . "setselection.php",
$showSlider? "true": "false",
$locale,
$scaleCreationCode,
Deleted: branches/2.6/MgDev/Web/src/mapviewerphp/setselection.php
--- branches/2.6/MgDev/Web/src/mapviewerphp/setselection.php 2014-07-09 12:34:36 UTC (rev 8290)
+++ branches/2.6/MgDev/Web/src/mapviewerphp/setselection.php 2014-07-09 12:34:58 UTC (rev 8291)
@@ -1,130 +0,0 @@
-<?php
-// Copyright (C) 2004-2011 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
- include 'common.php';
- include 'constants.php';
- $mapName = "";
- $sessionId = "";
- $selText = "";
- $queryInfo = false;
- GetRequestParameters();
- try
- InitializeWebTier();
- $cred = new MgUserInformation($sessionId);
- $cred->SetClientIp(GetClientIp());
- $cred->SetClientAgent(GetClientAgent());
- //connect to the site and get an instance of the resoucre service
- $site = new MgSiteConnection();
- $site->Open($cred);
- $resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
- //load the map runtime state
- $map = new MgMap();
- $map->Open($resourceSrvc, $mapName);
- // Create the selection set and save it
- $sel = new MgSelection($map);
- if($selText != "")
- $sel->FromXml($selText);
- $sel->Save($resourceSrvc, $mapName);
- if($queryInfo) {
- //Query feature info for the feature in the selection set. This will return the current set
- //along with property info
- //There must be only one feature in the feature set
- $layers = $sel->GetLayers();
- if($layers == null || $layers->GetCount() != 1) {
- echo "Error: There must be exactly one feature in the set."; ///NOXLATE dbg report only
- return;
- $layer = $layers->GetItem(0);
- $featureClassName = $layer->GetFeatureClassName();
- $filter = $sel->GenerateFilter($layer, $featureClassName);
- $featureSrvc = $site->CreateService(MgServiceType::FeatureService);
- $query = new MgFeatureQueryOptions();
- $query->SetFilter($filter);
- $featureSource = new MgResourceIdentifier($layer->GetFeatureSourceId());
- $features = $featureSrvc->SelectFeatures($featureSource, $featureClassName, $query);
- $featCount = 0;
- while($features->ReadNext())
- if($featCount++ == 1)
- break;
- $features->Close();
- if($featCount != 1) {
- return;
- $renderingSrvc = $site->CreateService(MgServiceType::RenderingService);
- $layerNames = new MgStringCollection();
- $layerNames->Add($layer->GetName());
- $featInfo = $renderingSrvc->QueryFeatures($map, $layerNames, NULL, MgFeatureSpatialOperations::Intersects, $selText, 1, 2);
- header('Content-Type: text/xml; charset: UTF-8');
- echo $featInfo->ToXml()->ToString();
- catch(MgException $e)
- echo "ClearSelection Exception: " . $e->GetDetails();
-function GetParameters($params)
- global $mapName, $sessionId, $selText, $queryInfo;
- $sessionId = ValidateSessionId(GetParameter($params, 'SESSION'));
- $mapName = ValidateMapName(GetParameter($params, 'MAPNAME'));
- if(isset($params['QUERYINFO']))
- $queryInfo = (GetIntParameter($params, 'QUERYINFO') == 1);
- $selText = UnescapeMagicQuotes(GetParameter($params, 'SELECTION'));
-function UnescapeMagicQuotes($str)
- if(ini_get("magic_quotes_sybase") == "1")
- return str_replace("''", "'", $str);
- else if(get_magic_quotes_gpc() == "1")
- //Unescape double quotes
- $str = str_replace('\\"', '"', $str);
- //remove additional backslash
- return str_replace("\\", "", $str);
- return $str;
-function GetRequestParameters()
- if($_SERVER['REQUEST_METHOD'] == "POST")
- GetParameters($_POST);
- else
- GetParameters($_GET);
More information about the mapguide-commits
