[mapguide-commits] r8294 - trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jul 9 05:46:45 PDT 2014
Author: jng
Date: 2014-07-09 05:46:45 -0700 (Wed, 09 Jul 2014)
New Revision: 8294
   trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
Fix broken sample code in light of the Sheboygan dataset update.
Modified: trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
--- trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php	2014-07-09 12:41:48 UTC (rev 8293)
+++ trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php	2014-07-09 12:46:45 UTC (rev 8294)
@@ -36,6 +36,9 @@
     $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST : $_GET;
     $sessionId = $args['SESSION'];
     $mapName = $args['MAPNAME'];
+    $selectionXml = '';
+    $idName = "";
+    $geomName = "";
     try
@@ -53,17 +56,21 @@
       $map->Open($mapName);
       // Get the geometry for the boundaries of District 1
+      $layer = $map->GetLayers()->GetItem('Districts');
+      // Use the layer's class definition to determine its identity property and geometry property name
+      $clsDef = $layer->GetClassDefinition();
+      $idProps = $clsDef->GetIdentityProperties();
+      $idProp = $idProps->GetItem(0);
+      $idName = $idProp->GetName();
+      $geomName = $clsDef->GetDefaultGeometryPropertyName();
       $districtQuery = new MgFeatureQueryOptions();
-      $layer = $map->GetLayers()->GetItem('Districts');
-      $classDef = $layer->GetClassDefinition();
-      $clsIdProps = $classDef->GetIdentityProperties();
-      $idProp = $clsIdProps->GetItem(0);
-      $districtQuery->SetFilter($idProp->GetName()." = 1");
+      $districtQuery->SetFilter("$idName = 1");
       $featureReader = $layer->SelectFeatures($districtQuery);
       $featureReader->ReadNext();
-      $districtGeometryData = $featureReader->GetGeometry($layer->GetFeatureGeometryName());
+      $districtGeometryData = $featureReader->GetGeometry($geomName);
       // Convert the AGF binary data to MgGeometry.
More information about the mapguide-commits mailing list
