[mapguide-commits] r8297 - branches/2.6/MgDev/Web/src/viewerfiles
svn_mapguide at osgeo.org
Wed Jul 9 07:09:37 PDT 2014
Author: jng
Date: 2014-07-09 07:09:37 -0700 (Wed, 09 Jul 2014)
New Revision: 8297
branches/2.6/MgDev/Web/src/viewerfiles/ajaxmappane.templ
#2462: Fix issue with selecting features in AJAX viewer via shift-click. The issue is that the code that processes the v2.6 QUERYMAPFEATURES response doesn't properly handle the case of appending selections via shift-click. This submission adds appending support.
Modified: branches/2.6/MgDev/Web/src/viewerfiles/ajaxmappane.templ
--- branches/2.6/MgDev/Web/src/viewerfiles/ajaxmappane.templ 2014-07-09 12:51:43 UTC (rev 8296)
+++ branches/2.6/MgDev/Web/src/viewerfiles/ajaxmappane.templ 2014-07-09 14:09:37 UTC (rev 8297)
@@ -3044,7 +3044,10 @@
if(geom.indexOf("NaN") >= 0) return;
var reqData = 1; //attributes
- if (msie8plus || !msie)
+ //Only request inline selection if not appending, because we're not smart enough to know how
+ //to merge selection images together. This will cause a follow-up GETDYNAMICMAPOVERLAYIMAGE
+ //for the selection image
+ if (!append && (msie8plus || !msie))
reqData |= 2; //inline selection
var reqParams = "OPERATION=QUERYMAPFEATURES&VERSION=2.6.0&PERSIST=1&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&SEQ=" + Math.random();
reqParams += "&LAYERNAMES=" + encodeURIComponent(GetVisSelLayers()) + "&GEOMETRY=" + geom + "&SELECTIONVARIANT=" + queryVariant + "&CLIENTAGENT=" + encodeURIComponent(clientAgent);
@@ -3180,7 +3183,7 @@
//Check if we have attributes inline
var props = xmlIn.getElementsByTagName("SelectedLayer");
var resp = ConvertToSelectedFeatureSet(props);
- ProcessSelectedFeatureSet(resp);
+ ProcessSelectedFeatureSet(resp, append);
else
@@ -4224,16 +4227,18 @@
return featuresByLayer;
-function ProcessSelectedFeatureSet(resp)
+function ProcessSelectedFeatureSet(resp, append)
- selFeatures = {};
- selBounds = null;
if (!resp)
return;
var selLayers = document.getElementById("selLayers");
- selLayers.length = 0;
- GetPropertyCtrl().Clear();
+ if (!append) {
+ selFeatures = {};
+ selBounds = null;
+ selLayers.length = 0;
+ GetPropertyCtrl().Clear();
//Construct layer list
for(var layerName in resp)
@@ -4241,15 +4246,33 @@
var opt = new Option();
opt.text = layerName;
opt.value = layerName;
- if(msie)
- selLayers.add(opt);
- else
- selLayers.add(opt, null);
+ var bAddOption = true;
+ if (append) {
+ for (var i = 0; i < selLayers.length; i++) {
+ if (layerName == selLayers[i].value) {
+ bAddOption = false;
+ break;
+ if (bAddOption) {
+ if(msie)
+ selLayers.add(opt);
+ else
+ selLayers.add(opt, null);
//Associates the selected features on layer
- selFeatures[layerName] = resp[layerName];
+ if (append) {
+ if (typeof(selFeatures[layerName]) == 'undefined')
+ selFeatures[layerName] = [];
+ for (var i = 0; i < resp[layerName].length; i++) {
+ var feat = resp[layerName][i];
+ selFeatures[layerName].push(feat);
+ } else {
+ selFeatures[layerName] = resp[layerName];
//Update selection bounding box
More information about the mapguide-commits
