[mapguide-commits] r8303 - in branches/2.6/MgDev/Common: Foundation/System MapGuideCommon/Controller
svn_mapguide at osgeo.org
Wed Jul 16 05:03:49 PDT 2014
Author: jng
Date: 2014-07-16 05:03:49 -0700 (Wed, 16 Jul 2014)
New Revision: 8303
branches/2.6/MgDev/Common/Foundation/System/Util.cpp
branches/2.6/MgDev/Common/Foundation/System/Util.h
branches/2.6/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
#2467: Fix MgOutOfRangeException in v2.6 QUERYMAPFEATURES when working with dates pre-1970. The default ToXmlString() cannot handle dates before unix epoch. The fix is to manually write out the MgDateTime in yyyy-mm-dd hh:mm:ss format. This submission includes a new MgUtil::PadLeft() method to assist in writing out dates in this particular format.
Modified: branches/2.6/MgDev/Common/Foundation/System/Util.cpp
--- branches/2.6/MgDev/Common/Foundation/System/Util.cpp 2014-07-11 02:17:44 UTC (rev 8302)
+++ branches/2.6/MgDev/Common/Foundation/System/Util.cpp 2014-07-16 12:03:49 UTC (rev 8303)
@@ -1253,3 +1253,9 @@
className = qualifiedClassName.substr(index + 1);
+void MgUtil::PadLeft(REFSTRING str, const size_t numChars, wchar_t ch)
+ if (numChars > str.size())
+ str.insert(0, numChars - str.size(), ch);
\ No newline at end of file
Modified: branches/2.6/MgDev/Common/Foundation/System/Util.h
--- branches/2.6/MgDev/Common/Foundation/System/Util.h 2014-07-11 02:17:44 UTC (rev 8302)
+++ branches/2.6/MgDev/Common/Foundation/System/Util.h 2014-07-16 12:03:49 UTC (rev 8303)
@@ -538,6 +538,8 @@
static bool GetLinuxMemoryStatus(MgLinuxMemoryStatus* pMemoryStatus);
+ static void PadLeft(REFSTRING str, const size_t numChars, wchar_t ch);
static void Int32ToLocaleSpecificString(INT32 val, string& str);
static void Int32ToString(INT32 val, string& str);
Modified: branches/2.6/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
--- branches/2.6/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2014-07-11 02:17:44 UTC (rev 8302)
+++ branches/2.6/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2014-07-16 12:03:49 UTC (rev 8303)
@@ -583,7 +583,41 @@
Ptr<MgDateTime> dt = reader->GetDateTime(i);
xmlOut.append(L"<Value>");
- xmlOut.append(dt->ToXmlString());
+ //ToXmlString() won't work with dates before Jan 1, 1970, so use yyyy-mm-dd hh:mm:ss
+ STRING dateStr;
+ STRING str;
+ if (dt->IsDate())
+ MgUtil::Int32ToString(dt->GetYear(), str);
+ dateStr += str;
+ MgUtil::Int32ToString(dt->GetMonth(), str);
+ dateStr += L"-";
+ MgUtil::PadLeft(str, 2, L'0');
+ dateStr += str;
+ MgUtil::Int32ToString(dt->GetDay(), str);
+ dateStr += L"-";
+ dateStr += str;
+ if (dt->IsTime())
+ if (dt->IsDate())
+ dateStr += L" ";
+ MgUtil::Int32ToString(dt->GetHour(), str);
+ dateStr += str;
+ MgUtil::Int32ToString(dt->GetMinute(), str);
+ dateStr += L":";
+ dateStr += str;
+ MgUtil::Int32ToString(dt->GetSecond(), str);
+ dateStr += L":";
+ dateStr += str;
+ xmlOut.append(dateStr);
xmlOut.append(L"</Value>\n");
break;
More information about the mapguide-commits
