[mapguide-commits] r8312 - sandbox/adsk/2.6l/Common/MapGuideCommon/Controller
svn_mapguide at osgeo.org
Wed Jul 30 02:29:09 PDT 2014
Author: christinebao
Date: 2014-07-30 02:29:09 -0700 (Wed, 30 Jul 2014)
New Revision: 8312
sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.cpp
sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.h
Merge r8252 for #2459: Fix QUERYMAPFEATURES producing inconsistent results. We no longer use the QueryFeatureProperties API for attribute collection and write the attributes directly based on the MgSelection obtained from the initial MgFeatureInformation.
Modified: sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.cpp
--- sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.cpp 2014-07-29 21:51:33 UTC (rev 8311)
+++ sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.cpp 2014-07-30 09:29:09 UTC (rev 8312)
@@ -20,6 +20,8 @@
#include "VectorLayerDefinition.h"
#include "NameStringPair.h"
+typedef std::map<STRING, STRING> DisplayNameMap;
#define REQUEST_ATTRIBUTES 1
#define REQUEST_INLINE_SELECTION 2
#define REQUEST_TOOLTIP 4
@@ -247,6 +249,7 @@
// Create a Resource Service instance
Ptr<MgResourceService> resourceService = (MgResourceService*)GetService(MgServiceType::ResourceService);
+ Ptr<MgFeatureService> featureService = (MgFeatureService*)GetService(MgServiceType::FeatureService);
// Create MgMap
Ptr<MgMap> map = new MgMap(m_siteConn);
@@ -289,24 +292,18 @@
inlineSelectionImg = service->RenderDynamicOverlay(map, newSelection, renderOpts);
- // Collect any attributes of selected features
- if ((requestData & REQUEST_ATTRIBUTES) == REQUEST_ATTRIBUTES)
- // This could be chunky for big selections, but client applications can control this via MAXFEATURES, so the onus is on them
- attributes = service->QueryFeatureProperties(map, layerNames, selectionGeometry, selectionVariant, L"", maxFeatures, layerAttributeFilter, true);
+ result = CollectQueryMapFeaturesResult(resourceService, featureService, map, requestData, featureInfo, newSelection, inlineSelectionImg);
- result = CollectQueryMapFeaturesResult(resourceService, requestData, featureInfo, newSelection, attributes, inlineSelectionImg);
// Return XML
return result.Detach();
MgByteReader* MgHtmlController::CollectQueryMapFeaturesResult(MgResourceService* resourceService,
+ MgFeatureService* featureService,
+ MgMapBase* map,
INT32 requestData,
MgFeatureInformation* featInfo,
MgSelection* selectionSet,
- MgBatchPropertyCollection* attributes,
MgByteReader* inlineSelection)
STRING xml;
@@ -372,10 +369,10 @@
else
xml.append(L"<InlineSelectionImage />\n");
- if (((requestData & REQUEST_ATTRIBUTES) == REQUEST_ATTRIBUTES) && NULL != attributes)
+ if ((requestData & REQUEST_ATTRIBUTES) == REQUEST_ATTRIBUTES)
xml.append(L"<SelectedFeatures>\n");
- WriteSelectedFeatureAttributes(resourceService, selectionSet, attributes, xml);
+ WriteSelectedFeatureAttributes(resourceService, featureService, map, selectionSet, xml);
xml.append(L"</SelectedFeatures>\n");
else
@@ -388,25 +385,56 @@
return MgUtil::GetByteReader(xmlDoc, &mimeType);
+MgCoordinateSystemTransform* MgHtmlController::GetLayerToMapTransform(MgLayerBase* layer,
+ MgCoordinateSystem* mapCs,
+ MgCoordinateSystemFactory* csFactory,
+ MgFeatureService* featureService)
+ Ptr<MgCoordinateSystemTransform> trans;
+ MG_TRY()
+ Ptr<MgClassDefinition> clsDef = layer->GetClassDefinition();
+ Ptr<MgPropertyDefinitionCollection> clsProps = clsDef->GetProperties();
+ INT32 gidx = clsProps->IndexOf(layer->GetFeatureGeometryName());
+ if (gidx >= 0)
+ Ptr<MgPropertyDefinition> propDef = clsProps->GetItem(gidx);
+ MgGeometricPropertyDefinition* geomProp = static_cast<MgGeometricPropertyDefinition*>(propDef.p);
+ STRING scName = geomProp->GetSpatialContextAssociation();
+ Ptr<MgResourceIdentifier> fsId = new MgResourceIdentifier(layer->GetFeatureSourceId());
+ Ptr<MgSpatialContextReader> scReader = featureService->GetSpatialContexts(fsId, false);
+ while(scReader->ReadNext())
+ if (scReader->GetName() == scName)
+ Ptr<MgCoordinateSystem> layerCs = csFactory->Create(scReader->GetCoordinateSystemWkt());
+ trans = csFactory->GetTransform(layerCs, mapCs);
+ break;
+ scReader->Close();
+ MG_CATCH_AND_RELEASE()
+ return trans.Detach();
void MgHtmlController::WriteSelectedFeatureAttributes(MgResourceService* resourceService,
+ MgMapBase* map,
REFSTRING xmlOut)
- //Rather than doing a verbatim xml dump of MgBatchPropertyCollection, let's output something
- //that is more intuitive for client applications using this service operation to understand.
- //We could assume sorted layers in the MgBatchPropertyCollection, but play safe
- //and store our per-layer XML fragments in a bucket (keyed on layer name) and return
- //the merged bucket result at the end
- std::map<STRING, STRING> bucket;
MgAgfReaderWriter agfRw;
MgWktReaderWriter wktRw;
+ MgCoordinateSystemFactory csFactory;
Ptr<MgReadOnlyLayerCollection> selLayers = selectionSet->GetLayers();
if (NULL != selLayers.p)
+ Ptr<MgCoordinateSystem> mapCs = csFactory.Create(map->GetMapSRS());
// Our structure is as follows
// [0...n] <SelectedLayer> - A layer containing selected features
@@ -421,219 +449,223 @@
Ptr<MgLayerBase> selLayer = selLayers->GetItem(i);
STRING layerName = selLayer->GetName();
- if (bucket.find(layerName) == bucket.end())
+ Ptr<MgCoordinateSystemTransform> transform = GetLayerToMapTransform(selLayer, mapCs, &csFactory, featureService);
+ xmlOut.append(L"<SelectedLayer id=\"");
+ xmlOut.append(selLayer->GetObjectId());
+ xmlOut.append(L"\" name=\"");
+ xmlOut.append(selLayer->GetName());
+ xmlOut.append(L"\">\n");
+ xmlOut.append(L"<LayerMetadata>\n");
+ Ptr<MgClassDefinition> clsDef = selLayer->GetClassDefinition();
+ Ptr<MgResourceIdentifier> layerId = selLayer->GetLayerDefinition();
+ Ptr<MgStringCollection> propNames = new MgStringCollection();
+ DisplayNameMap displayNameMap;
+ //We need the property mappings of the source layer definition to compile our layer metadata
+ std::auto_ptr<MdfModel::LayerDefinition> ldf(MgLayerBase::GetLayerDefinition(resourceService, layerId));
+ if (ldf.get() != NULL)
- STRING xml = L"<SelectedLayer id=\"";
- xml.append(selLayer->GetObjectId());
- xml.append(L"\" name=\"");
- xml.append(selLayer->GetName());
- xml.append(L"\">\n");
- xml.append(L"<LayerMetadata>\n");
- Ptr<MgClassDefinition> clsDef = selLayer->GetClassDefinition();
- Ptr<MgPropertyDefinitionCollection> clsProps = clsDef->GetProperties();
- Ptr<MgResourceIdentifier> layerId = selLayer->GetLayerDefinition();
- //We need the property mappings of the source layer definition to compile our layer metadata
- std::auto_ptr<MdfModel::LayerDefinition> ldf(MgLayerBase::GetLayerDefinition(resourceService, layerId));
- if (ldf.get() != NULL)
+ MdfModel::VectorLayerDefinition* vl = dynamic_cast<MdfModel::VectorLayerDefinition*>(ldf.get());
+ if(vl != NULL)
- MdfModel::VectorLayerDefinition* vl = dynamic_cast<MdfModel::VectorLayerDefinition*>(ldf.get());
- if(vl != NULL)
+ MdfModel::NameStringPairCollection* pmappings = vl->GetPropertyMappings();
+ for (int j=0; j<pmappings->GetCount(); j++)
- MdfModel::NameStringPairCollection* pmappings = vl->GetPropertyMappings();
- for (int j=0; j<pmappings->GetCount(); j++)
+ STRING pTypeStr;
+ MdfModel::NameStringPair* m = pmappings->GetAt(j);
+ propNames->Add(m->GetName());
+ displayNameMap.insert(std::make_pair(m->GetName(), m->GetValue()));
+ INT32 pidx = clsProps->IndexOf(m->GetName());
+ if (pidx >= 0)
- STRING pTypeStr;
- MdfModel::NameStringPair* m = pmappings->GetAt(j);
- INT32 pidx = clsProps->IndexOf(m->GetName());
- if (pidx >= 0)
+ Ptr<MgPropertyDefinition> propDef = clsProps->GetItem(pidx);
+ INT32 pdType = propDef->GetPropertyType();
+ INT32 pType = MgPropertyType::Null;
+ if (pdType == MgFeaturePropertyType::DataProperty)
- Ptr<MgPropertyDefinition> propDef = clsProps->GetItem(pidx);
- INT32 pdType = propDef->GetPropertyType();
- INT32 pType = MgPropertyType::Null;
- if (pdType == MgFeaturePropertyType::DataProperty)
- pType = ((MgDataPropertyDefinition*)propDef.p)->GetDataType();
- else if (pdType == MgFeaturePropertyType::GeometricProperty)
- pType = MgPropertyType::Geometry;
- MgUtil::Int32ToString(pType, pTypeStr);
- xml.append(L"<Property>\n");
- xml.append(L"<Name>");
- xml.append(m->GetName());
- xml.append(L"</Name>\n");
- xml.append(L"<Type>");
- xml.append(pTypeStr);
- xml.append(L"</Type>\n");
- xml.append(L"<DisplayName>");
- xml.append(m->GetValue());
- xml.append(L"</DisplayName>\n");
- xml.append(L"</Property>\n");
+ pType = ((MgDataPropertyDefinition*)propDef.p)->GetDataType();
+ else if (pdType == MgFeaturePropertyType::GeometricProperty)
+ pType = MgPropertyType::Geometry;
+ MgUtil::Int32ToString(pType, pTypeStr);
+ xmlOut.append(L"<Property>\n");
+ xmlOut.append(L"<Name>");
+ xmlOut.append(m->GetName());
+ xmlOut.append(L"</Name>\n");
+ xmlOut.append(L"<Type>");
+ xmlOut.append(pTypeStr);
+ xmlOut.append(L"</Type>\n");
+ xmlOut.append(L"<DisplayName>");
+ xmlOut.append(m->GetValue());
+ xmlOut.append(L"</DisplayName>\n");
+ xmlOut.append(L"</Property>\n");
- xml += L"</LayerMetadata>\n";
- bucket[layerName] = xml;
- for (INT32 i = 0; i < attributes->GetCount(); i++)
- Ptr<MgPropertyCollection> featProps = attributes->GetItem(i);
- INT32 lidx = featProps->IndexOf(L"_MgLayerName");
- INT32 fidx = featProps->IndexOf(L"_MgFeatureBoundingBox");
- //Must have both the _MgLayerName and _MgFeatureBoundingBox
- if (lidx < 0 || fidx < 0)
- continue;
- Ptr<MgStringProperty> layerNameProp = (MgStringProperty*)featProps->GetItem(lidx);
- Ptr<MgStringProperty> boundsProp = (MgStringProperty*)featProps->GetItem(fidx);
- //Locate the matching bucketed fragment to append to
- STRING layerName = layerNameProp->GetValue();
- if (bucket.find(layerName) != bucket.end())
+ propNames->Add(selLayer->GetFeatureGeometryName()); //Don't forget geometry
+ xmlOut.append(L"</LayerMetadata>\n");
+ Ptr<MgReader> reader = selectionSet->GetSelectedFeatures(selLayer, selLayer->GetFeatureClassName(), propNames);
+ while(reader->ReadNext())
- //Good to go, write our feature to this bucketed fragment
- REFSTRING xml = bucket[layerName];
- xml.append(L"<Feature>\n");
- xml.append(L"<Bounds>");
- xml.append(boundsProp->GetValue());
- xml.append(L"</Bounds>\n");
- for (INT32 p = 0; p < featProps->GetCount(); p++)
+ xmlOut.append(L"<Feature>\n");
+ STRING geomPropName = selLayer->GetFeatureGeometryName();
+ if (!reader->IsNull(geomPropName))
- //Skip special properties
- if (p == lidx || p == fidx)
+ try
+ Ptr<MgByteReader> agf = reader->GetGeometry(geomPropName);
+ Ptr<MgGeometry> geom = agfRw.Read(agf, transform);
+ Ptr<MgEnvelope> env = geom->Envelope();
+ Ptr<MgCoordinate> ll = env->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> ur = env->GetUpperRightCoordinate();
+ xmlOut.append(L"<Bounds>");
+ STRING str;
+ MgUtil::DoubleToString(ll->GetX(), str);
+ xmlOut.append(str);
+ xmlOut.append(L" ");
+ MgUtil::DoubleToString(ll->GetY(), str);
+ MgUtil::DoubleToString(ur->GetX(), str);
+ MgUtil::DoubleToString(ur->GetY(), str);
+ xmlOut.append(L"</Bounds>\n");
+ catch (MgException* ex) //Bad geom maybe
+ SAFE_RELEASE(ex);
+ for (INT32 i = 0; i < reader->GetPropertyCount(); i++)
+ STRING propName = reader->GetPropertyName(i);
+ DisplayNameMap::iterator it = displayNameMap.find(propName);
+ //Skip properties without display mappings
+ if (it == displayNameMap.end())
continue;
- Ptr<MgNullableProperty> prop = dynamic_cast<MgNullableProperty*>(featProps->GetItem(p));
- if (NULL != prop.p)
+ xmlOut.append(it->second);
+ if (!reader->IsNull(i))
- xml.append(prop->GetName());
- //We'll follow MgProperty spec. Null is represented by omission of <Value>
- if (!prop->IsNull())
+ INT32 ptype = reader->GetPropertyType(i);
+ switch(ptype)
- INT32 ptype = prop->GetPropertyType();
- switch(ptype)
+ //case MgPropertyType::Blob:
+ case MgPropertyType::Boolean:
- //case MgPropertyType::Blob:
- case MgPropertyType::Boolean:
+ xmlOut.append(L"<Value>");
+ xmlOut.append(reader->GetBoolean(i) ? L"true" : L"false");
+ xmlOut.append(L"</Value>\n");
+ break;
+ case MgPropertyType::Byte:
+ STRING sVal;
+ MgUtil::Int32ToString((INT32)reader->GetByte(i), sVal);
+ xmlOut.append(sVal);
+ break;
+ //case MgPropertyType::Clob:
+ case MgPropertyType::DateTime:
+ Ptr<MgDateTime> dt = reader->GetDateTime(i);
+ xmlOut.append(dt->ToXmlString());
+ break;
+ case MgPropertyType::Decimal:
+ case MgPropertyType::Double:
+ STRING sVal;
+ MgUtil::DoubleToString(reader->GetDouble(i), sVal);
+ break;
+ case MgPropertyType::Geometry:
+ try
- xml.append(L"<Value>");
- xml.append(((MgBooleanProperty*)prop.p)->GetValue() ? L"true" : L"false");
- xml.append(L"</Value>\n");
+ Ptr<MgByteReader> agf = reader->GetGeometry(i);
+ Ptr<MgGeometry> geom = agfRw.Read(agf);
+ STRING wkt = wktRw.Write(geom);
+ xmlOut.append(wkt);
- break;
- case MgPropertyType::Byte:
- STRING sVal;
- MgUtil::Int32ToString((INT32)((MgByteProperty*)prop.p)->GetValue(), sVal);
- xml.append(sVal);
+ SAFE_RELEASE(ex);
- break;
- //case MgPropertyType::Clob:
- case MgPropertyType::DateTime:
- Ptr<MgDateTime> dt = ((MgDateTimeProperty*)prop.p)->GetValue();
- xml.append(dt->ToXmlString());
- break;
- case MgPropertyType::Decimal:
- case MgPropertyType::Double:
- STRING sVal;
- MgUtil::DoubleToString(((MgDoubleProperty*)prop.p)->GetValue(), sVal);
- xml.append(sVal);
- break;
- case MgPropertyType::Geometry:
- try
- Ptr<MgByteReader> agf = ((MgGeometryProperty*)prop.p)->GetValue();
- Ptr<MgGeometry> geom = agfRw.Read(agf);
- STRING wkt = wktRw.Write(geom);
- xml.append(wkt);
- catch (MgException* ex) //Bad geom maybe
- SAFE_RELEASE(ex);
- break;
- case MgPropertyType::Int16:
- STRING sVal;
- MgUtil::Int32ToString((INT32)((MgInt16Property*)prop.p)->GetValue(), sVal);
- xml.append(sVal);
- break;
- case MgPropertyType::Int32:
- STRING sVal;
- MgUtil::Int32ToString(((MgInt32Property*)prop.p)->GetValue(), sVal);
- xml.append(sVal);
- break;
- case MgPropertyType::Int64:
- STRING sVal;
- MgUtil::Int64ToString(((MgInt64Property*)prop.p)->GetValue(), sVal);
- xml.append(sVal);
- break;
- case MgPropertyType::Single:
- STRING sVal;
- MgUtil::SingleToString(((MgSingleProperty*)prop.p)->GetValue(), sVal);
- xml.append(sVal);
- break;
- case MgPropertyType::String:
- xml.append(MgUtil::ReplaceEscapeCharInXml(((MgStringProperty*)prop.p)->GetValue()));
- break;
+ break;
+ case MgPropertyType::Int16:
+ STRING sVal;
+ MgUtil::Int32ToString((INT32)reader->GetInt16(i), sVal);
+ break;
+ case MgPropertyType::Int32:
+ STRING sVal;
+ MgUtil::Int32ToString(reader->GetInt32(i), sVal);
+ break;
+ case MgPropertyType::Int64:
+ STRING sVal;
+ MgUtil::Int64ToString(reader->GetInt64(i), sVal);
+ break;
+ case MgPropertyType::Single:
+ STRING sVal;
+ MgUtil::SingleToString(reader->GetSingle(i), sVal);
+ break;
+ case MgPropertyType::String:
+ xmlOut.append(MgUtil::ReplaceEscapeCharInXml(reader->GetString(i)));
+ break;
- xml.append(L"</Feature>\n");
+ xmlOut.append(L"</Feature>\n");
+ reader->Close();
+ xmlOut.append(L"</SelectedLayer>");
- //Now merge the bucketed fragments
- for (std::map<STRING, STRING>::iterator it = bucket.begin(); it != bucket.end(); it++)
- //Close off the <SelectedLayer> elements
- STRING xml = it->second;
- xml.append(L"</SelectedLayer>");
- //Good to append to the final result
- xmlOut.append(xml);
Modified: sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.h
--- sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.h 2014-07-29 21:51:33 UTC (rev 8311)
+++ sandbox/adsk/2.6l/Common/MapGuideCommon/Controller/HtmlController.h 2014-07-30 09:29:09 UTC (rev 8312)
@@ -272,10 +272,11 @@
/// Assembles the composite QueryMapFeatures result
virtual MgByteReader* CollectQueryMapFeaturesResult(MgResourceService* resourceService,
+ MgMapBase* map,
INT32 requestData,
- MgSelection* selectionSet,
+ MgSelection* selectionSet,
MgByteReader* inlineSelection);
@@ -292,10 +293,16 @@
private:
static void WriteSelectedFeatureAttributes(MgResourceService* resourceService,
+ MgMapBase* map,
- MgBatchPropertyCollection* attriubtes,
REFSTRING xmlOut);
+ static MgCoordinateSystemTransform* GetLayerToMapTransform(MgLayerBase* layer,
+ MgFeatureService* featureService);
CLASS_ID:
static const INT32 m_cls_id = MapGuide_MapLayer_ZcvController;
More information about the mapguide-commits
