[mapguide-commits] r8186 - in trunk/Tools/Maestro/SDK/Samples: DrawMap DwfInspector MapViewer QueryFeatureSource SchemaViewer StandaloneWebLayoutEditor
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Jun 9 04:02:12 PDT 2014
Author: jng
Date: 2014-06-09 04:02:12 -0700 (Mon, 09 Jun 2014)
New Revision: 8186
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs
Fix SDK samples in light of r8183
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs	2014-06-06 08:25:36 UTC (rev 8185)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs	2014-06-09 11:02:12 UTC (rev 8186)
@@ -113,7 +113,7 @@
             //to easily select a given resource. In our case, we want the user to select
             //a Map Definition
             using (var picker = new ResourcePicker(_conn.ResourceService,
-                                                   ResourceTypes.MapDefinition,
+                                                   ResourceTypes.MapDefinition.ToString(),
                                                    ResourcePickerMode.OpenResource))
                 if (picker.ShowDialog() == DialogResult.OK)
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs	2014-06-06 08:25:36 UTC (rev 8185)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs	2014-06-09 11:02:12 UTC (rev 8186)
@@ -97,7 +97,7 @@
             //a Drawing Source
-                                                   ResourceTypes.DrawingSource,
+                                                   ResourceTypes.DrawingSource.ToString(),
Modified: trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs	2014-06-06 08:25:36 UTC (rev 8185)
+++ trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs	2014-06-09 11:02:12 UTC (rev 8186)
@@ -72,7 +72,7 @@
             //a Map Definition
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs	2014-06-06 08:25:36 UTC (rev 8185)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs	2014-06-09 11:02:12 UTC (rev 8186)
@@ -135,7 +135,7 @@
             //a Map Definition
-                                                   ResourceTypes.FeatureSource,
+                                                   ResourceTypes.FeatureSource.ToString(),
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs	2014-06-06 08:25:36 UTC (rev 8185)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs	2014-06-09 11:02:12 UTC (rev 8186)
@@ -70,7 +70,7 @@
             //a Feature Source
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs	2014-06-06 08:25:36 UTC (rev 8185)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs	2014-06-09 11:02:12 UTC (rev 8186)
@@ -81,7 +81,7 @@
             //a Feature Source
-                                                   ResourceTypes.WebLayout,
+                                                   ResourceTypes.WebLayout.ToString(),
More information about the mapguide-commits mailing list
