[mapguide-commits] r8201 - in sandbox/jng/tiling/Common: MapGuideCommon/MapLayer MapGuideCommon/Services PlatformBase/MapLayer
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jun 13 17:09:48 PDT 2014
Author: jng
Date: 2014-06-13 17:09:48 -0700 (Fri, 13 Jun 2014)
New Revision: 8201
   sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.h
   sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingService.h
   sandbox/jng/tiling/Common/MapGuideCommon/Services/TileService.h
   sandbox/jng/tiling/Common/PlatformBase/MapLayer/LayerGroup.h
   sandbox/jng/tiling/Common/PlatformBase/MapLayer/LayerGroupType.h
   sandbox/jng/tiling/Common/PlatformBase/MapLayer/MapBase.h
Clean up documentation of the new APIs.
Modified: sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.h
--- sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.h	2014-06-11 13:19:17 UTC (rev 8200)
+++ sandbox/jng/tiling/Common/MapGuideCommon/MapLayer/Map.h	2014-06-14 00:09:48 UTC (rev 8201)
@@ -316,9 +316,14 @@
     /// \brief
     /// Initializes a new MgMap object given a resource service, map
-    /// definition, and a name for the map. This method is used for
-    /// MapGuide Viewers or for offline map production.
+    /// definition or tile set definiton, and a name for the map. This
+    /// method is used for MapGuide Viewers or for offline map production.
+    /// \remarks
+    /// If creating a MgMap object from a tile set definition, only "Default" is the
+    /// acceptable tile provider. Any other provider will cause this method to
+    /// throw a MgUnsupportedTileProviderException
     /// \deprecated
     /// This method has been deprecated. Use the following method:
     /// \link MgMap::Create(MgResourceIdentifier*,CREFSTRING) Create(MgResourceIdentifier mapDefinition, string mapName) \endlink.
@@ -337,9 +342,9 @@
     /// \param resourceService
     /// An MgResourceService that can be used to
     /// retrieve the map definition.
-    /// \param mapDefinition
+    /// \param resource
     /// An MgResourceIdentifier that specifies the
-    /// location of the map definition in a resource
+    /// location of the map definition or tile set definition in a resource
     /// repository.
     /// \param mapName
     /// A string that specifies the name of the map.
@@ -354,14 +359,19 @@
     /// \endcode
     /// \htmlinclude ExampleBottom.html
-    virtual void Create(MgResourceService* resourceService, MgResourceIdentifier* mapDefinition, CREFSTRING mapName);
+    virtual void Create(MgResourceService* resourceService, MgResourceIdentifier* resource, CREFSTRING mapName);
     /// \brief
-    /// Initializes a new MgMap object given a map definition
-    /// and a name for the map. This method is used for
+    /// Initializes a new MgMap object given a map definition or tile set
+    /// definition and a name for the map. This method is used for
+    /// \remarks
     /// <!-- Syntax in .Net, Java, and PHP -->
     /// \htmlinclude DotNetSyntaxTop.html
     /// void Create(MgResourceIdentifier mapDefinition, string mapName);
@@ -373,7 +383,7 @@
     /// \htmlinclude SyntaxBottom.html
     /// repository.
@@ -393,7 +403,7 @@
     /// \endcode
-    virtual void Create(MgResourceIdentifier* mapDefinition, CREFSTRING mapName);
+    virtual void Create(MgResourceIdentifier* resource, CREFSTRING mapName);
     /// \brief
Modified: sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingService.h
--- sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingService.h	2014-06-11 13:19:17 UTC (rev 8200)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingService.h	2014-06-14 00:09:48 UTC (rev 8201)
@@ -144,6 +144,7 @@
     /// \return
     /// A byte reader containing the rendered tile image.
+    /// \since 3.0
     virtual MgByteReader* RenderTileXYZ(
         MgMap* map,
         CREFSTRING baseMapLayerGroupName,
Modified: sandbox/jng/tiling/Common/MapGuideCommon/Services/TileService.h
--- sandbox/jng/tiling/Common/MapGuideCommon/Services/TileService.h	2014-06-11 13:19:17 UTC (rev 8200)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Services/TileService.h	2014-06-14 00:09:48 UTC (rev 8201)
@@ -61,10 +61,15 @@
     /// \brief
-    /// Returns the specified base map tile for the given map.  If a cached tile
-    /// image exists it will return it, otherwise the tile is rendered and added
-    /// to the cache.
+    /// Returns the specified base map tile for the given map or tile set.
+    /// If a cached tile image exists it will return it, otherwise the tile
+    /// is rendered and added to the cache.
+    /// \remarks
+    /// If retrieving a tile from a tile set, the row, column and scale index
+    /// may take on different meaning depending on the tile provider specified
+    /// in the tile set
     /// \param resource
     /// Input
     /// Resource identifier for the map definition or Tile Set Definition
@@ -164,8 +169,12 @@
     /// \brief
-    /// Returns the list of available tile providers, along with supported connection parameters
+    /// Returns the XML description of available tile providers, along with supported connection parameters. This provides
+    /// sufficient information for client applications to build rich editor user interfaces for editing Tile Set Definitions
+    /// \return
+    /// The XML description of available tile providers
     /// \since 3.0
     virtual MgByteReader* GetTileProviders() = 0;
Modified: sandbox/jng/tiling/Common/PlatformBase/MapLayer/LayerGroup.h
--- sandbox/jng/tiling/Common/PlatformBase/MapLayer/LayerGroup.h	2014-06-11 13:19:17 UTC (rev 8200)
+++ sandbox/jng/tiling/Common/PlatformBase/MapLayer/LayerGroup.h	2014-06-14 00:09:48 UTC (rev 8201)
@@ -442,13 +442,13 @@
-    /// bool SetExpandInLegend(bool expandInLegend);
+    /// MgResourceIdentifier GetTileSetDefinition();
     /// \htmlinclude JavaSyntaxTop.html
-    /// boolean SetExpandInLegend(boolean expandInLegend);
     /// \htmlinclude PHPSyntaxTop.html
     /// \since 3.0
Modified: sandbox/jng/tiling/Common/PlatformBase/MapLayer/LayerGroupType.h
--- sandbox/jng/tiling/Common/PlatformBase/MapLayer/LayerGroupType.h	2014-06-11 13:19:17 UTC (rev 8200)
+++ sandbox/jng/tiling/Common/PlatformBase/MapLayer/LayerGroupType.h	2014-06-14 00:09:48 UTC (rev 8201)
@@ -42,8 +42,12 @@
     static const INT32 BaseMap = 2;
     /// \brief
-    /// Specifies that the layer is a base map layer from a TileSetDefinition resource
+    /// Specifies that the layer is a base map layer from a TileSetDefinition resource.
+    /// \remarks
+    /// From a client application perspective, a layer group with of this type should be treated
+    /// the same as layer group of type \link MgLayerGroupType::BaseMap BaseMap \endlink
     /// \since 3.0
     static const INT32 BaseMapFromTileSet = 3;
Modified: sandbox/jng/tiling/Common/PlatformBase/MapLayer/MapBase.h
--- sandbox/jng/tiling/Common/PlatformBase/MapLayer/MapBase.h	2014-06-11 13:19:17 UTC (rev 8200)
+++ sandbox/jng/tiling/Common/PlatformBase/MapLayer/MapBase.h	2014-06-14 00:09:48 UTC (rev 8201)
@@ -158,7 +158,9 @@
     /// Returns the resource identifier that specifies the location
     /// of the map definition that was used to create this map.
-    /// \note1
+    /// \remarks
+    /// If this map was created from a Tile Set Definition, this method
+    /// will return NULL
@@ -173,7 +175,8 @@
     /// \return
     /// Returns an MgResourceIdentifier that specifies the location
-    /// of the map definition.
+    /// of the map definition. NULL is returned if this map was created
+    /// from a Tile Set Definition
     virtual MgResourceIdentifier* GetMapDefinition();  /// __get
More information about the mapguide-commits mailing list
