[mapguide-commits] r8203 - in sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan: . MapsTiled TileSets
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jun 13 18:05:50 PDT 2014
Author: jng
Date: 2014-06-13 18:05:50 -0700 (Fri, 13 Jun 2014)
New Revision: 8203
Added:
   sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/
   sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml
   sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml
   sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml
   sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml
   sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/_HEADER.xml
   sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml
Add example tilesets to Sheboygan sample data set
Modified: sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml
--- sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml	2014-06-14 00:58:00 UTC (rev 8202)
+++ sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml	2014-06-14 01:05:50 UTC (rev 8203)
@@ -1,5 +1,5 @@
-<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="MapDefinition-2.4.0.xsd">
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="MapDefinition-3.0.0.xsd" version="3.0.0">
   <Name>Sheboygan Tiled Map</Name>
   <CoordinateSystem>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</CoordinateSystem>
   <Extents>
@@ -9,79 +9,9 @@
     <MaxY>43.797520000480347</MaxY>
   </Extents>
   <BackgroundColor>ffcdbd9c</BackgroundColor>
-  <BaseMapDefinition>
-    <FiniteDisplayScale>1000</FiniteDisplayScale>
-    <FiniteDisplayScale>1930.69773</FiniteDisplayScale>
-    <FiniteDisplayScale>3727.59372</FiniteDisplayScale>
-    <FiniteDisplayScale>7196.85673</FiniteDisplayScale>
-    <FiniteDisplayScale>13894.95494</FiniteDisplayScale>
-    <FiniteDisplayScale>26826.95795</FiniteDisplayScale>
-    <FiniteDisplayScale>51794.74679</FiniteDisplayScale>
-    <FiniteDisplayScale>100000</FiniteDisplayScale>
-    <BaseMapLayerGroup>
-      <Name>Base Layer Group</Name>
-      <Visible>true</Visible>
-      <ShowInLegend>true</ShowInLegend>
-      <ExpandInLegend>true</ExpandInLegend>
-      <LegendLabel>Tiled Layers</LegendLabel>
-      <BaseMapLayer>
-        <Name>Roads</Name>
-        <ResourceId>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</ResourceId>
-        <Selectable>false</Selectable>
-        <LegendLabel>Roads</LegendLabel>
-      </BaseMapLayer>
-      <BaseMapLayer>
-        <Name>Districts</Name>
-        <ResourceId>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</ResourceId>
-        <LegendLabel>Districts</LegendLabel>
-      </BaseMapLayer>
-      <BaseMapLayer>
-        <Name>Buildings</Name>
-        <ResourceId>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</ResourceId>
-        <LegendLabel>Buildings</LegendLabel>
-      </BaseMapLayer>
-      <BaseMapLayer>
-        <Name>Parcels</Name>
-        <ResourceId>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</ResourceId>
-        <Selectable>true</Selectable>
-        <LegendLabel>Parcels</LegendLabel>
-      </BaseMapLayer>
-      <BaseMapLayer>
-        <Name>Islands</Name>
-        <ResourceId>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</ResourceId>
-        <LegendLabel>Islands</LegendLabel>
-      </BaseMapLayer>
-      <BaseMapLayer>
-        <Name>Hydrography</Name>
-        <ResourceId>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</ResourceId>
-        <LegendLabel>Hydrography</LegendLabel>
-      </BaseMapLayer>
-      <BaseMapLayer>
-        <Name>CityLimits</Name>
-        <ResourceId>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</ResourceId>
-        <LegendLabel>CityLimits</LegendLabel>
-      </BaseMapLayer>
-    </BaseMapLayerGroup>
-  </BaseMapDefinition>
+  <TileSetSource>
+    <ResourceId>Library://Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition</ResourceId>
+  </TileSetSource>
   <Watermarks>
     <Watermark>
       <Name>MapTiledText</Name>
Added: sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml
--- sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml	                        (rev 0)
+++ sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_CONTENT.xml	2014-06-14 01:05:50 UTC (rev 8203)
@@ -0,0 +1,99 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<TileSetDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="TileSetDefinition-3.0.0.xsd">
+  <TileStoreParameters>
+    <TileProvider>Default</TileProvider>
+    <Parameter>
+      <Name>TilePath</Name>
+      <Value>%MG_TILE_CACHE_PATH%</Value>
+    </Parameter>
+    <Parameter>
+      <Name>TileWidth</Name>
+      <Value>256</Value>
+    </Parameter>
+    <Parameter>
+      <Name>TileHeight</Name>
+    </Parameter>
+    <Parameter>
+      <Name>TileFormat</Name>
+      <Value>PNG</Value>
+    </Parameter>
+    <Parameter>
+      <Name>FiniteScaleList</Name>
+      <Value>200000,100000,50000,25000,12500,6250,3125,1562.5,781.25,390.625</Value>
+    </Parameter>
+    <Parameter>
+      <Name>CoordinateSystem</Name>
+      <Value>GEOGCS["LL84",DATUM["WGS 84",SPHEROID["WGS 84",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",0.01745329252]]</Value>
+    </Parameter>
+  </TileStoreParameters>
+  <Extents>
+    <MinX>-87.79786601383196</MinX>
+    <MaxX>-87.66452777186925</MaxX>
+    <MinY>43.6868578621819</MinY>
+    <MaxY>43.8037962206133</MaxY>
+  </Extents>
+  <BaseMapLayerGroup>
+      <Name>Base Layer Group</Name>
+      <Visible>true</Visible>
+      <ShowInLegend>true</ShowInLegend>
+      <ExpandInLegend>true</ExpandInLegend>
+      <LegendLabel>Tiled Layers</LegendLabel>
+      <BaseMapLayer>
+        <Name>Roads</Name>
+        <ResourceId>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</ResourceId>
+        <Selectable>false</Selectable>
+        <LegendLabel>Roads</LegendLabel>
+      </BaseMapLayer>
+      <BaseMapLayer>
+        <Name>Districts</Name>
+        <ResourceId>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</ResourceId>
+        <LegendLabel>Districts</LegendLabel>
+      </BaseMapLayer>
+      <BaseMapLayer>
+        <Name>Buildings</Name>
+        <ResourceId>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</ResourceId>
+        <LegendLabel>Buildings</LegendLabel>
+      </BaseMapLayer>
+      <BaseMapLayer>
+        <Name>Parcels</Name>
+        <ResourceId>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</ResourceId>
+        <Selectable>true</Selectable>
+        <LegendLabel>Parcels</LegendLabel>
+      </BaseMapLayer>
+      <BaseMapLayer>
+        <Name>Islands</Name>
+        <ResourceId>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</ResourceId>
+        <LegendLabel>Islands</LegendLabel>
+      </BaseMapLayer>
+      <BaseMapLayer>
+        <Name>Hydrography</Name>
+        <ResourceId>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</ResourceId>
+        <LegendLabel>Hydrography</LegendLabel>
+      </BaseMapLayer>
+      <BaseMapLayer>
+        <Name>CityLimits</Name>
+        <ResourceId>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</ResourceId>
+        <LegendLabel>CityLimits</LegendLabel>
+      </BaseMapLayer>
+    </BaseMapLayerGroup>
+</TileSetDefinition>
\ No newline at end of file
Added: sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml
--- sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml	                        (rev 0)
+++ sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/Sheboygan.TileSetDefinition_HEADER.xml	2014-06-14 01:05:50 UTC (rev 8203)
@@ -0,0 +1,6 @@
+<ResourceDocumentHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
+	<Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
+		<Inherited>true</Inherited>
+	</Security>
+</ResourceDocumentHeader>
Added: sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml
--- sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml	                        (rev 0)
+++ sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_CONTENT.xml	2014-06-14 01:05:50 UTC (rev 8203)
@@ -0,0 +1,83 @@
+    <TileProvider>XYZ</TileProvider>
+    <Parameter>
+    </Parameter>
+    <Parameter>
+    </Parameter>
+  <Extents>
+  </Extents>
+    <BaseMapLayer>
+    </BaseMapLayer>
+    <BaseMapLayer>
+    </BaseMapLayer>
+    <BaseMapLayer>
+    </BaseMapLayer>
+    <BaseMapLayer>
+    </BaseMapLayer>
+    <BaseMapLayer>
+    </BaseMapLayer>
+    <BaseMapLayer>
+    </BaseMapLayer>
+    <BaseMapLayer>
+    </BaseMapLayer>
Added: sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml
--- sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml	                        (rev 0)
+++ sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/SheboyganXYZ.TileSetDefinition_HEADER.xml	2014-06-14 01:05:50 UTC (rev 8203)
@@ -0,0 +1,6 @@
+	</Security>
Added: sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/_HEADER.xml
--- sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/_HEADER.xml	                        (rev 0)
+++ sandbox/jng/tiling/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/TileSets/_HEADER.xml	2014-06-14 01:05:50 UTC (rev 8203)
@@ -0,0 +1,6 @@
+<ResourceFolderHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourceFolderHeader-1.0.0.xsd">
+	</Security>
+</ResourceFolderHeader>
More information about the mapguide-commits mailing list
