[mapguide-commits] r8263 - in sandbox/jng/convenience_apis/UnitTest: Common WebTier/DotNet/MgTestRunner WebTier/DotNet/TestCommon WebTier/DotNet/TestCommon/ExternalTests WebTier/DotNet/TestMapGuideApi WebTier/DotNet/TestMapGuideApi/ExternalTests
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jun 25 08:30:06 PDT 2014
Author: jng
Date: 2014-06-25 08:30:06 -0700 (Wed, 25 Jun 2014)
New Revision: 8263
Added:
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Assert.cs
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ByteReaderTest.cs
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/CollectionTests.cs
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/PropertiesTest.cs
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/CollectionTests.cs
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs
Removed:
   sandbox/jng/convenience_apis/UnitTest/Common/DotNetWrappers/
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj
   sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj
Improve DotNet test runner. Add support for external tests outside of the SQLite-defined test suite and integrate the existing common dotnet wrapper tests into it. This removes the need for the DotNetWrappers test project and it has been deleted as a result.
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs	2014-06-23 14:31:00 UTC (rev 8262)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs	2014-06-25 15:30:06 UTC (rev 8263)
@@ -16,6 +16,32 @@
         static MgUserInformation userInfo;
         static MgSiteConnection siteConn;
+        class PlatformFactory : IPlatformFactory
+            private MgSiteConnection _siteConn;
+            public PlatformFactory(MgSiteConnection siteConn)
+                _siteConn = siteConn;
+            public MgService CreateService(int serviceType)
+                return _siteConn.CreateService(serviceType);
+            public MgMapBase CreateMap()
+                return new MgMap(_siteConn);
+            public MgLayerBase CreateLayer(MgResourceIdentifier resId)
+                MgResourceService resSvc = (MgResourceService)_siteConn.CreateService(MgServiceType.ResourceService);
+                return new MgLayer(resId, resSvc);
         //Usage: MgTestRunner.exe <webconfig.ini path> <MENTOR_DICTIONARY_PATH> [test log path]
         static void Main(string[] args)
@@ -38,6 +64,8 @@
                     siteConn = new MgSiteConnection();
                     siteConn.Open(userInfo);
+                    var factory = new PlatformFactory(siteConn);
                     int testsRun = 0;
                     bool isEnterprise = false;
                     failures += ExecuteTest(ApiTypes.Platform, "../../TestData/ResourceService/ResourceServiceTest.dump", ref testsRun, logger, isEnterprise);
@@ -49,6 +77,9 @@
                     failures += ExecuteTest(ApiTypes.Platform, "../../TestData/MapLayer/MapLayerTest.dump", ref testsRun, logger, isEnterprise);
                     failures += ExecuteTest(ApiTypes.Platform, "../../TestData/WebLayout/WebLayoutTest.dump", ref testsRun, logger, isEnterprise);
                     failures += ExecuteTest(ApiTypes.Platform, "../../TestData/Unicode/UnicodeTest.dump", ref testsRun, logger, isEnterprise);
+                    //Run auxillary tests not part of the SQLite-defined suite
+                    failures += CommonTests.Execute(factory, logger, ref testsRun);
+                    failures += MapGuideTests.Execute(factory, logger, ref testsRun);
                     logger.Write("\n\nTests failed/run: {0}/{1}\n", failures, testsRun);
                     Console.Write("\n\nTests failed/run: {0}/{1}\n", failures, testsRun);
                     logger.Write("Run ended: {0}\n\n", DateTime.Now.ToString());
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Assert.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Assert.cs	                        (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Assert.cs	2014-06-25 15:30:06 UTC (rev 8263)
@@ -0,0 +1,77 @@
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+using System.Threading.Tasks;
+namespace OSGeo.MapGuide.Test.Common
+    [Serializable]
+    public class AssertException : Exception
+        public AssertException() { }
+        public AssertException(string message) : base(message) { }
+        public AssertException(string message, Exception inner) : base(message, inner) { }
+        protected AssertException(
+          System.Runtime.Serialization.SerializationInfo info,
+          System.Runtime.Serialization.StreamingContext context)
+            : base(info, context) { }
+        public static void AreBytesEqual(byte[] expected, byte[] actual)
+            byte[] a = expected;
+            byte[] b = actual;
+            if (a.Length != b.Length)
+                throw new AssertException("Expected byte array size of " + a.Length + ", got size of: " + b.Length);
+            for (int i = 0; i < a.Length; i++)
+                if (a[i] != b[i])
+                    throw new AssertException("Byte number " + (i + 1) + " in expected byte array does not match byte in actual byte array");
+        public static void AreEqual<T>(T expected, T actual)
+            if (typeof(T) == typeof(byte[]))
+                AreBytesEqual(expected as byte[], actual as byte[]);
+            else if (!EqualityComparer<T>.Default.Equals(expected, actual))
+                throw new AssertException("Expected: " + expected + ", got: " + actual);
+        public static void Greater<T>(T value, T against) where T : IComparable
+            if (value.CompareTo(against) <= 0)
+                throw new AssertException(value + " is not greater than " + against);
+        public static void IsNull(object obj)
+            if (obj != null)
+                throw new AssertException("Reference is not null");
+        public static void IsTrue(bool condition)
+            if (!condition)
+                throw new AssertException("Condition evaluated to false. Expected: true");
+        public static void IsFalse(bool condition)
+            if (condition)
+                throw new AssertException("Condition evaluated to true. Expected: false");
+        public static void IsNaN(double value)
+            if (!double.IsNaN(value))
+                throw new AssertException("Double is a number. Expected: NaN");
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs	                        (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs	2014-06-25 15:30:06 UTC (rev 8263)
@@ -0,0 +1,63 @@
+using System;
+using System.IO;
+using System.Linq;
+using System.Reflection;
+using System.Text;
+    //Defines tests outside of the SQLite-based test suite
+    public interface IExternalTest
+        void Execute(IPlatformFactory factory, ITestLogger logger);
+    public interface IPlatformFactory
+        MgService CreateService(int serviceType);
+        MgMapBase CreateMap();
+        MgLayerBase CreateLayer(MgResourceIdentifier resId);
+    public class CommonTests
+        public static int Execute(IPlatformFactory factory, ITestLogger logger, ref int testsRun)
+            int failures = 0;
+            var types = typeof(IPlatformFactory).Assembly.GetTypes();
+            foreach (var type in types)
+                if (typeof(IExternalTest).IsAssignableFrom(type) && type.IsClass)
+                    var test = (IExternalTest)Activator.CreateInstance(type);
+                    try
+                        logger.WriteLine("****** Executing platform test: " + type.Name + " *********");
+                        Console.WriteLine("Executing external platform test: " + type.Name);
+                        test.Execute(factory, logger);
+                    catch (AssertException ex)
+                        logger.WriteLine("Assertion failure: " + ex.Message);
+                        Console.WriteLine("Assertion failure: " + ex.Message);
+                        failures++;
+                    catch (Exception ex)
+                        logger.WriteLine("General failure: " + ex.ToString());
+                        Console.WriteLine("General failure: " + ex.ToString());
+                        failures++;
+                    finally
+                        testsRun++;
+            return failures;
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ByteReaderTest.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ByteReaderTest.cs	                        (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ByteReaderTest.cs	2014-06-25 15:30:06 UTC (rev 8263)
@@ -0,0 +1,118 @@
+using System;
+using System.Linq;
+using System.Text;
+namespace OSGeo.MapGuide.Test.Common.ExternalTests
+    internal class ByteReaderTestData
+        internal static byte[] testBytes;
+        internal static int nBytes = 32768;
+        internal static int nBlocks = 256;
+        internal static string testString = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789";
+        internal static string infileName;
+        internal static string outfileName;
+        private static bool bFirstTime = true;
+        public static void Init()
+            if (bFirstTime)
+                infileName = System.IO.Path.GetTempFileName();
+                outfileName = System.IO.Path.GetTempFileName();
+                testBytes = new byte[nBytes];
+                for (int i = 0; i < nBytes; i++)
+                    testBytes[i] = (byte)(i % 255);
+                System.IO.FileStream fp = System.IO.File.OpenWrite(infileName);
+                for (int j = 0; j < nBlocks; j++)
+                    fp.Write(testBytes, 0, nBytes);
+                fp.Close();
+                bFirstTime = false;
+    public class ByteReaderTest : IExternalTest
+        public void Execute(IPlatformFactory factory, ITestLogger logger)
+            ByteReaderTestData.Init();
+            var nBytes = ByteReaderTestData.nBytes;
+            var nBlocks = ByteReaderTestData.nBlocks;
+            var testBytes = ByteReaderTestData.testBytes;
+            var infileName = ByteReaderTestData.infileName;
+            var outfileName = ByteReaderTestData.outfileName;
+            byte[] buf = new byte[nBytes];
+            MgByteReader reader = new MgByteReader(infileName, "png", false);
+            Assert.AreEqual(nBlocks * nBytes, reader.GetLength());
+            reader.Read(buf, nBytes);
+            Assert.AreEqual(buf, testBytes);
+            Assert.AreEqual((nBlocks - 1) * nBytes, reader.GetLength());
+            reader.Rewind();
+            reader.ToFile(outfileName);
+            reader.Rewind();
+            byte[] buf2 = new byte[nBytes];
+            System.IO.FileStream fp = System.IO.File.OpenRead(outfileName);
+                fp.Read(buf2, 0, nBytes);
+                Assert.AreEqual(buf, buf2);
+            fp.Close();
+    public class MemoryConstructor : IExternalTest
+            MgByteReader reader = new MgByteReader(testBytes, nBytes, "png");
+            Assert.AreEqual(nBytes, reader.GetLength());
+            Assert.AreEqual(0, reader.GetLength());
+            reader.Rewind();
+            fp.Read(buf, 0, nBytes);
+            fp.Close();
+    public class StringConstructor : IExternalTest
+            var testString = ByteReaderTestData.testString;
+            MgByteReader reader = new MgByteReader(testString, "text/html");
+            Assert.AreEqual(testString.Length, reader.GetLength());
+            string buf = reader.ToString();
+            Assert.AreEqual(testString, buf);
+            reader.Rewind();
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/CollectionTests.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/CollectionTests.cs	                        (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/CollectionTests.cs	2014-06-25 15:30:06 UTC (rev 8263)
@@ -0,0 +1,995 @@
+using System;
+using System.Collections.Specialized;
+using System.Linq;
+using System.Text;
+    public class GeomBuild
+        private MgGeometryFactory factory = new MgGeometryFactory();
+        public MgPoint CreatePoint()
+            MgCoordinate coord = factory.CreateCoordinateXYZ(5.0, 3.0, 2.0);
+            return factory.CreatePoint(coord);
+        public MgLineString CreateLineString(double offset)
+            MgCoordinateCollection coordCol = new MgCoordinateCollection();
+            MgCoordinate coord1 = factory.CreateCoordinateXY(offset + 0.0, 1.0);
+            MgCoordinate coord2 = factory.CreateCoordinateXY(offset + 2.0, 3.0);
+            MgCoordinate coord3 = factory.CreateCoordinateXY(offset + 4.0, 5.0);
+            coordCol.Add(coord1);
+            coordCol.Add(coord2);
+            coordCol.Add(coord3);
+            return factory.CreateLineString(coordCol);
+        public MgLinearRing CreateLinearRing(double offset)
+            MgCoordinate oCoord1 = factory.CreateCoordinateXY(0.0, offset);
+            MgCoordinate oCoord2 = factory.CreateCoordinateXY(5.0, offset);
+            MgCoordinate oCoord3 = factory.CreateCoordinateXY(5.0, offset + 5.0);
+            MgCoordinate oCoord4 = factory.CreateCoordinateXY(0.0, offset + 5.0);
+            MgCoordinate oCoord5 = factory.CreateCoordinateXY(0.0, offset);
+            MgCoordinateCollection outerRingCoord = new MgCoordinateCollection();
+            outerRingCoord.Add(oCoord1);
+            outerRingCoord.Add(oCoord2);
+            outerRingCoord.Add(oCoord3);
+            outerRingCoord.Add(oCoord4);
+            outerRingCoord.Add(oCoord5);
+            return factory.CreateLinearRing(outerRingCoord);
+        public MgPolygon CreatePolygon(double offset)
+            // OuterRing
+            MgCoordinate oCoord1 = factory.CreateCoordinateXY(offset + 0.0, 0.0);
+            MgCoordinate oCoord2 = factory.CreateCoordinateXY(offset + 5.0, 0.0);
+            MgCoordinate oCoord3 = factory.CreateCoordinateXY(offset + 5.0, 5.0);
+            MgCoordinate oCoord4 = factory.CreateCoordinateXY(offset + 0.0, 5.0);
+            MgCoordinate oCoord5 = factory.CreateCoordinateXY(offset + 0.0, 0.0);
+            // Inner Ring1
+            MgCoordinate i1Coord1 = factory.CreateCoordinateXY(offset + 1.0, 1.0);
+            MgCoordinate i1Coord2 = factory.CreateCoordinateXY(offset + 2.0, 1.0);
+            MgCoordinate i1Coord3 = factory.CreateCoordinateXY(offset + 2.0, 2.0);
+            MgCoordinate i1Coord4 = factory.CreateCoordinateXY(offset + 1.0, 1.0);
+            MgCoordinateCollection inner1RingCoord = new MgCoordinateCollection();
+            inner1RingCoord.Add(i1Coord1);
+            inner1RingCoord.Add(i1Coord2);
+            inner1RingCoord.Add(i1Coord3);
+            inner1RingCoord.Add(i1Coord4);
+            // Inner Ring2
+            MgCoordinate i2Coord1 = factory.CreateCoordinateXY(offset + 3.0, 3.0);
+            MgCoordinate i2Coord2 = factory.CreateCoordinateXY(offset + 4.0, 3.0);
+            MgCoordinate i2Coord3 = factory.CreateCoordinateXY(offset + 4.0, 4.0);
+            MgCoordinate i2Coord4 = factory.CreateCoordinateXY(offset + 3.0, 3.0);
+            MgCoordinateCollection inner2RingCoord = new MgCoordinateCollection();
+            inner2RingCoord.Add(i2Coord1);
+            inner2RingCoord.Add(i2Coord2);
+            inner2RingCoord.Add(i2Coord3);
+            inner2RingCoord.Add(i2Coord4);
+            MgLinearRing extRing = factory.CreateLinearRing(outerRingCoord);
+            MgLinearRing intRing1 = factory.CreateLinearRing(inner1RingCoord);
+            MgLinearRing intRing2 = factory.CreateLinearRing(inner2RingCoord);
+            MgLinearRingCollection intRings = new MgLinearRingCollection();
+            intRings.Add(intRing1);
+            intRings.Add(intRing2);
+            return factory.CreatePolygon(extRing, intRings);
+        public MgCurveString CreateCurveString(double offset)
+            // Create and return a curvestring consisting of
+            // one circulararc segment and one linearstring segment
+            // arcseg  = (0,0), (0,1), (1,2)
+            // lineseg = (1,2), (3,0), (3,2)
+            // ArcSegment
+            MgCoordinate startPos = factory.CreateCoordinateXY(offset + 0.0, offset + 0.0);
+            MgCoordinate midPos = factory.CreateCoordinateXY(offset + 0.0, offset + 1.0);
+            MgCoordinate endPos = factory.CreateCoordinateXY(offset + 1.0, offset + 2.0);
+            MgArcSegment arcSeg = factory.CreateArcSegment(startPos, endPos, midPos);
+            // Linear Segment
+            MgCoordinateCollection points = new MgCoordinateCollection();
+            MgCoordinate pt1 = factory.CreateCoordinateXY(offset + 1.0, offset + 2.0);
+            MgCoordinate pt2 = factory.CreateCoordinateXY(offset + 3.0, offset + 0.0);
+            MgCoordinate pt3 = factory.CreateCoordinateXY(offset + 3.0, offset + 2.0);
+            points.Add(pt1);
+            points.Add(pt2);
+            points.Add(pt3);
+            MgLinearSegment lineSeg = factory.CreateLinearSegment(points);
+            // CurveSegment
+            MgCurveSegmentCollection curveSegs = new MgCurveSegmentCollection();
+            curveSegs.Add(arcSeg);
+            curveSegs.Add(lineSeg);
+            return factory.CreateCurveString(curveSegs);
+        public MgCurveRing CreateCurveRing(double offset)
+            // Ring is a closed entity.
+            // Create and return a ring consisting of
+            // lineseg = (1,2), (0,0)
+            // ArcSegment
+            // Linear Segment
+            MgCoordinate fromPt = factory.CreateCoordinateXY(offset + 1.0, offset + 2.0);
+            MgCoordinate toPt = factory.CreateCoordinateXY(offset + 0.0, offset + 0.0);
+            points.Add(fromPt);
+            points.Add(toPt);
+            // Curve Segment
+            return factory.CreateCurveRing(curveSegs);
+        public MgCurvePolygon CreateCurvePolygon(double offset, int increment)
+            MgCurveRing extRing = CreateCurveRing(offset + increment);
+            MgCurveRingCollection intRings = new MgCurveRingCollection();
+            MgCurveRing ring1 = CreateCurveRing(offset + 2 * increment);
+            MgCurveRing ring2 = CreateCurveRing(offset + 3 * increment);
+            intRings.Add(ring1);
+            intRings.Add(ring2);
+            return factory.CreateCurvePolygon(extRing, intRings);
+        public MgMultiPoint CreateMultiPoint()
+            MgCoordinate coord1 = factory.CreateCoordinateXYZ(1.0, 2.0, 3.0);
+            MgPoint point1 = factory.CreatePoint(coord1);
+            MgCoordinate coord2 = factory.CreateCoordinateXYZ(4.0, 5.0, 6.0);
+            MgPoint point2 = factory.CreatePoint(coord2);
+            MgCoordinate coord3 = factory.CreateCoordinateXYZ(7.0, 8.0, 9.0);
+            MgPoint point3 = factory.CreatePoint(coord3);
+            MgPointCollection pnts = new MgPointCollection();
+            pnts.Add(point1);
+            pnts.Add(point2);
+            pnts.Add(point3);
+            return factory.CreateMultiPoint(pnts);
+        public MgMultiLineString CreateMultiLineString()
+            MgCoordinate coord1 = factory.CreateCoordinateXYZ(0.0, 1.0, 2.0);
+            MgCoordinate coord2 = factory.CreateCoordinateXYZ(3.0, 4.0, 5.0);
+            MgCoordinate coord3 = factory.CreateCoordinateXYZ(6.0, 7.0, 8.0);
+            MgCoordinateCollection coordColA = new MgCoordinateCollection();
+            coordColA.Add(coord1);
+            coordColA.Add(coord2);
+            coordColA.Add(coord3);
+            MgCoordinate coord4 = factory.CreateCoordinateXYZ(9.0, 10.0, 11.0);
+            MgCoordinate coord5 = factory.CreateCoordinateXYZ(12.0, 13.0, 14.0);
+            MgCoordinate coord6 = factory.CreateCoordinateXYZ(15.0, 16.0, 17.0);
+            MgCoordinateCollection coordColB = new MgCoordinateCollection();
+            coordColB.Add(coord4);
+            coordColB.Add(coord5);
+            coordColB.Add(coord6);
+            MgLineString lineString1 = factory.CreateLineString(coordColA);
+            MgLineString lineString2 = factory.CreateLineString(coordColB);
+            MgLineStringCollection lineStrings = new MgLineStringCollection();
+            lineStrings.Add(lineString1);
+            lineStrings.Add(lineString2);
+            return factory.CreateMultiLineString(lineStrings);
+        public MgMultiPolygon CreateMultiPolygon()
+            MgPolygon polygon1 = CreatePolygon(0.0);
+            MgPolygon polygon2 = CreatePolygon(0.0);
+            MgPolygonCollection polygons = new MgPolygonCollection();
+            polygons.Add(polygon1);
+            polygons.Add(polygon2);
+            return factory.CreateMultiPolygon(polygons);
+        MgMultiCurveString CreateMultiCurveString()
+            MgCurveString curveString1 = CreateCurveString(100);
+            MgCurveString curveString2 = CreateCurveString(200);
+            MgCurveString curveString3 = CreateCurveString(300);
+            MgCurveStringCollection curveStrings = new MgCurveStringCollection();
+            curveStrings.Add(curveString1);
+            curveStrings.Add(curveString2);
+            curveStrings.Add(curveString3);
+            return factory.CreateMultiCurveString(curveStrings);
+        public MgMultiCurvePolygon CreateMultiCurvePolygon(int numCurvePolys, double offset)
+            MgCurvePolygonCollection curvePolys = new MgCurvePolygonCollection();
+            for (int i = 0; i < numCurvePolys; i++)
+                MgCurvePolygon curvePoly = CreateCurvePolygon(i + offset, 1);
+                curvePolys.Add(curvePoly);
+            return factory.CreateMultiCurvePolygon(curvePolys);
+        public MgMultiGeometry CreateMultiGeometry()
+            MgGeometryCollection geometries = new MgGeometryCollection();
+            MgGeometry geometry = null;
+            // CurvePolygon
+            geometry = (MgGeometry)CreateCurvePolygon(0, 1);
+            geometries.Add(geometry);
+            // CurveString
+            // Not doing CurveString because of some unfixed defect.
+            // It may be the same one that sometimes affects MultiPolygon.
+            geometry = (MgGeometry)CreateCurveString(100);
+            // LineString
+            geometry = (MgGeometry)CreateLineString(1.0);
+            // Point
+            geometry = (MgGeometry)CreatePoint();
+            // Polygon
+            geometry = CreatePolygon(0.0);
+            // Make MultiGeometry from the many geometries collected above.
+            return factory.CreateMultiGeometry(geometries);
+        public MgArcSegment CreateArcSegment(double offset)
+            return factory.CreateArcSegment(startPos, endPos, midPos);
+    public class CollectionTestsIntCollection : IExternalTest
+            MgIntCollection coll = new MgIntCollection();
+            coll.Add(10);
+            coll.Add(20);
+            coll.Add(30);
+            coll.Add(40);
+            coll.Add(50);
+            Assert.AreEqual(20, coll.GetItem(1));
+            Assert.AreEqual(30, coll[2]);
+            Assert.AreEqual(5, coll.Count);
+            int j = 0;
+            foreach (int i in coll)
+                j += i;
+            Assert.AreEqual(150, j);
+    public class CollectionTestsPropertyCollection : IExternalTest
+            MgPropertyCollection coll = new MgPropertyCollection();
+            MgDoubleProperty dblProp = new MgDoubleProperty("DoubleProp", 1.1111);
+            MgInt32Property intProp = new MgInt32Property("IntProp", 1);
+            MgDateTime dateTime = new MgDateTime(2006, 9, 21);
+            MgDateTimeProperty dateProp = new MgDateTimeProperty("DateProp", dateTime);
+            MgSingleProperty single = new MgSingleProperty("SingleProp", (float)2.2222);
+            coll.Add(dblProp);
+            coll.Add(intProp);
+            coll.Add(dateProp);
+            coll[2] = single;
+            Assert.AreEqual(1.1111, (coll[0] as MgDoubleProperty).GetValue());
+            Assert.AreEqual(MgPropertyType.Double, coll[0].GetPropertyType());
+            Assert.AreEqual(MgPropertyType.Int32, coll[1].GetPropertyType());
+            Assert.AreEqual(MgPropertyType.Single, coll[2].GetPropertyType());
+            Assert.AreEqual((float)2.2222, (coll[2] as MgSingleProperty).GetValue());
+            Assert.AreEqual(3, coll.Count);
+            string str = "";
+            foreach (MgProperty prop in coll)
+                str = str + "[" + prop.GetName() + "]";
+            Assert.AreEqual("[DoubleProp][IntProp][SingleProp]", str);
+    public class CollectionTestsBatchPropertyCollection : IExternalTest
+            MgPropertyCollection coll1 = new MgPropertyCollection();
+            coll1.Add(dblProp);
+            MgPropertyCollection coll2 = new MgPropertyCollection();
+            coll2.Add(intProp);
+            MgPropertyCollection coll3 = new MgPropertyCollection();
+            coll3.Add(single);
+            MgBatchPropertyCollection coll = new MgBatchPropertyCollection();
+            coll.Add(coll1);
+            coll.Add(coll2);
+            Assert.AreEqual(2, coll.Count);
+            Assert.AreEqual(MgPropertyType.Double, coll[0][0].GetPropertyType());
+            Assert.AreEqual(MgPropertyType.Int32, coll[1][0].GetPropertyType());
+            coll[1] = coll3;
+            string str = "";
+            foreach (MgPropertyCollection c in coll)
+                str = str + "[" + c[0].GetName() + "]";
+            Assert.AreEqual("[DoubleProp][SingleProp]", str);
+    public class CollectionTestsClassDefinitionCollection : IExternalTest
+            MgClassDefinition class1 = new MgClassDefinition();
+            class1.SetName("class1");
+            MgClassDefinition class2 = new MgClassDefinition();
+            class2.SetName("class2");
+            MgClassDefinition class3 = new MgClassDefinition();
+            class3.SetName("class3");
+            MgClassDefinitionCollection coll = new MgClassDefinitionCollection();
+            coll.Insert(0, class3);
+            coll.Insert(0, class2);
+            coll.Insert(0, class1);
+            Assert.AreEqual("class2", coll[1].GetName());
+            MgClassDefinition tmp = coll[0];
+            coll[0] = coll[1];
+            coll[1] = coll[2];
+            coll[2] = tmp;
+            string str = "";
+            foreach (MgClassDefinition def in coll)
+                str = str + "[" + def.GetName() + "]";
+            Assert.AreEqual("[class2][class3][class1]", str);
+    public class CollectionTestsCoordinateCollection : IExternalTest
+            MgGeometryFactory gf = new MgGeometryFactory();
+            MgCoordinate c1 = gf.CreateCoordinateXY(1.0, 1.0);
+            MgCoordinate c2 = gf.CreateCoordinateXY(2.0, 2.0);
+            MgCoordinate c3 = gf.CreateCoordinateXY(3.0, 3.0);
+            MgCoordinate c4 = gf.CreateCoordinateXY(4.0, 4.0);
+            MgCoordinateCollection coll = new MgCoordinateCollection();
+            coll.Add(c1);
+            coll.Insert(1, c2);
+            coll.Add(c3);
+            coll.Add(c4);
+            Assert.AreEqual(4, coll.Count);
+            Assert.AreEqual(1.0, coll[0].GetX());
+            coll[3] = coll[2];
+            Assert.AreEqual(3.0, coll[3].GetX());
+            double sum = 0.0;
+            foreach (MgCoordinate coord in coll)
+                sum += coord.GetX();
+            Assert.AreEqual(9.0, sum);
+    public class CollectionTestsCurvePolygonCollection : IExternalTest
+            var build = new GeomBuild();
+            MgCurvePolygon geom1 = build.CreateCurvePolygon(2.0, 5);
+            MgCurvePolygon geom2 = build.CreateCurvePolygon(12.0, 5);
+            MgCurvePolygon geom3 = build.CreateCurvePolygon(2.0, 5);
+            MgCurvePolygonCollection coll = new MgCurvePolygonCollection();
+            coll.Add(geom1);
+            coll.Add(geom2);
+            coll.Add(geom3);
+            Assert.IsTrue(geom1.Equals(coll[0]));
+            Assert.IsTrue(coll[0].Equals(coll[2]));
+            Assert.IsFalse(coll[0].Equals(coll[1]));
+            Assert.IsTrue(coll[0].Equals(coll[1]));
+            double width = 0.0;
+            foreach (MgCurvePolygon geom in coll)
+                width += geom.Envelope().GetWidth();
+            Assert.AreEqual(geom1.Envelope().GetWidth() * 3.0, width);
+    public class CollectionTestsCurveRingCollection : IExternalTest
+            MgCurveRing geom1 = build.CreateCurveRing(2.0);
+            MgCurveRing geom2 = build.CreateCurveRing(12.0);
+            MgCurveRing geom3 = build.CreateCurveRing(2.0);
+            MgCurveRingCollection coll = new MgCurveRingCollection();
+            coll.Add(geom1);
+            coll.Add(geom2);
+            coll.Add(geom3);
+            Assert.IsTrue(geom1.Envelope().Contains(coll[0].Envelope()));
+            Assert.IsTrue(coll[0].Envelope().Contains(coll[2].Envelope()));
+            Assert.IsFalse(coll[0].Envelope().Contains(coll[1].Envelope()));
+            Assert.IsTrue(coll[0].Envelope().Contains(coll[1].Envelope()));
+            foreach (MgCurveRing geom in coll)
+    public class CollectionTestsCurveSegmentCollection : IExternalTest
+            MgArcSegment geom1 = build.CreateArcSegment(2.0);
+            MgArcSegment geom2 = build.CreateArcSegment(12.0);
+            MgArcSegment geom3 = build.CreateArcSegment(2.0);
+            MgCurveSegmentCollection coll = new MgCurveSegmentCollection();
+            coll.Add(geom1);
+            coll.Add(geom2);
+            coll.Add(geom3);
+            foreach (MgCurveSegment geom in coll)
+    public class CollectionTestsCurveStringCollection : IExternalTest
+            MgCurveString geom1 = build.CreateCurveString(2.0);
+            MgCurveString geom2 = build.CreateCurveString(12.0);
+            MgCurveString geom3 = build.CreateCurveString(2.0);
+            MgCurveStringCollection coll = new MgCurveStringCollection();
+            coll.Add(geom1);
+            coll.Add(geom2);
+            coll.Add(geom3);
+            foreach (MgCurveString geom in coll)
+    public class CollectionTestsFeatureCommandCollection : IExternalTest
+            MgPropertyCollection propVals = new MgPropertyCollection();
+            MgInt32Property prop = new MgInt32Property("prop", 1);
+            propVals.Add(prop);
+            MgUpdateFeatures update = new MgUpdateFeatures("class2", propVals, "where cat < dog");
+            MgInsertFeatures insert = new MgInsertFeatures("class3", propVals);
+            MgDeleteFeatures del = new MgDeleteFeatures("class1", "where cat > dog");
+            MgFeatureCommandCollection coll = new MgFeatureCommandCollection();
+            coll.Add(update);
+            coll.Add(insert);
+            coll.Add(del);
+            Assert.AreEqual(MgFeatureCommandType.DeleteFeatures, coll[2].GetCommandType());
+            string txt = "";
+            foreach (MgFeatureCommand cmd in coll)
+                txt += "[" + cmd.GetCommandType() + "]";
+            Assert.AreEqual("[0][0][2]", txt);
+    public class CollectionTestsFeatureSchemaCollection : IExternalTest
+            MgFeatureSchema schema1 = new MgFeatureSchema("schema1", "desc1");
+            MgFeatureSchema schema2 = new MgFeatureSchema("schema2", "desc2");
+            MgFeatureSchema schema3 = new MgFeatureSchema("schema3", "desc3");
+            MgFeatureSchemaCollection coll = new MgFeatureSchemaCollection();
+            coll.Add(schema1);
+            coll.Add(schema2);
+            coll.Add(schema3);
+            Assert.AreEqual("schema3", coll[2].GetName());
+            coll[0] = coll[2];
+            string txt = "";
+            foreach (MgFeatureSchema schema in coll)
+                txt += "[" + schema.GetName() + "]";
+            Assert.AreEqual("[schema3][schema2][schema3]", txt);
+    public class CollectionTestsGeometryCollection : IExternalTest
+            var wkt = new MgWktReaderWriter();
+            MgPoint geom1 = wkt.Read("POINT XY (1.0 1.0)") as MgPoint;
+            MgPoint geom2 = wkt.Read("POINT XY (2.0 2.0)") as MgPoint;
+            MgPoint geom3 = wkt.Read("POINT XY (1.0 1.0)") as MgPoint;
+            MgGeometryCollection coll = new MgGeometryCollection();
+            coll.Add(geom1);
+            coll.Add(geom2);
+            coll.Add(geom3);
+            double x = 0.0;
+            foreach (MgGeometry geom in coll)
+                x += (geom as MgPoint).GetCoordinate().GetX();
+            Assert.AreEqual(5.0, x);
+    public class CollectionTestsLayerCollection : IExternalTest
+            logger.WriteLine("Skipping CollectionTestsLayerCollection: Resource Service required to construct MgLayer");
+    public class CollectionTestsLayerGroupCollection : IExternalTest
+            logger.WriteLine("Skipping CollectionTestsLayerCollection: MgLayerGroupCollection constructor not visible");
+            MgLayerGroup group1 = new MgLayerGroup("group1");
+            MgLayerGroup group2 = new MgLayerGroup("group2");
+            MgLayerGroup group3 = new MgLayerGroup("group3");
+            MgLayerGroup group4 = new MgLayerGroup("group4");
+            MgLayerGroupCollection coll = new MgLayerGroupCollection();
+            coll.Add(group1);
+            coll.Insert(1, group2);
+            coll.Add(group3);
+            coll.Insert(3, group4);
+            Assert.AreEqual(coll[2].GetName(), "group3");
+            string txt = "";
+            foreach (MgLayerGroup group in coll)
+                txt += "[" + group.GetName() + "]";
+            Assert.AreEqual("[group1][group3][group3][group4]", txt);
+    public class CollectionTestsLinearRingCollection : IExternalTest
+            MgLinearRing geom1 = build.CreateLinearRing(1.0);
+            MgLinearRing geom2 = build.CreateLinearRing(5.0);
+            MgLinearRing geom3 = build.CreateLinearRing(1.0);
+            MgLinearRingCollection coll = new MgLinearRingCollection();
+            coll.Add(geom1);
+            coll.Add(geom2);
+            coll.Add(geom3);
+            foreach (MgLinearRing geom in coll)
+    public class CollectionTestsLineStringCollection : IExternalTest
+            MgLineString geom1 = build.CreateLineString(5.0);
+            MgLineString geom2 = build.CreateLineString(11.0);
+            MgLineString geom3 = build.CreateLineString(5.0);
+            MgLineStringCollection coll = new MgLineStringCollection();
+            coll.Add(geom1);
+            coll.Add(geom2);
+            coll.Add(geom3);
+            foreach (MgLineString geom in coll)
+    public class CollectionTestsMapCollection : IExternalTest
+            string coordsys = "GEOGCS[\"LL84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9108\"]],AXIS[\"Lat\",NORTH],AXIS[\"Long\",EAST],AUTHORITY[\"EPSG\",\"4326\"]]";
+            MgEnvelope env = new MgEnvelope(10, 10, 20, 20);
+            MgMapBase map1 = factory.CreateMap();
+            map1.Create(coordsys, env, "map1");
+            MgMapBase map2 = factory.CreateMap();
+            map2.Create(coordsys, env, "map2");
+            MgMapBase map3 = factory.CreateMap();
+            map3.Create(coordsys, env, "map3");
+            MgMapBase map4 = factory.CreateMap();
+            map4.Create(coordsys, env, "map4");
+            MgMapCollection coll = new MgMapCollection();
+            coll.Add(map1);
+            coll.Insert(1, map2);
+            coll.Add(map3);
+            Assert.AreEqual(coll[2].GetName(), "map3");
+            coll[1] = map4;
+            string txt = "";
+            foreach (MgMapBase map in coll)
+                txt += "[" + map.GetName() + "]";
+            Assert.AreEqual("[map1][map4][map3]", txt);
+    public class CollectionTestsPointCollection : IExternalTest
+            MgPointCollection coll = new MgPointCollection();
+            coll.Add(geom1);
+            coll.Add(geom2);
+            coll.Add(geom3);
+            double x = 0.0;
+            foreach (MgPoint geom in coll)
+                x += geom.GetCoordinate().GetX();
+    public class CollectionTestsPolygonCollection : IExternalTest
+            MgPolygon geom1 = build.CreatePolygon(2.0);
+            MgPolygon geom2 = build.CreatePolygon(12.0);
+            MgPolygon geom3 = build.CreatePolygon(2.0);
+            MgPolygonCollection coll = new MgPolygonCollection();
+            coll.Add(geom1);
+            coll.Add(geom2);
+            coll.Add(geom3);
+            foreach (MgPolygon geom in coll)
+    public class CollectionTestsPropertyDefinitionCollection : IExternalTest
+            MgDataPropertyDefinition def1 = new MgDataPropertyDefinition("def1");
+            MgDataPropertyDefinition def2 = new MgDataPropertyDefinition("def2");
+            MgDataPropertyDefinition def3 = new MgDataPropertyDefinition("def3");
+            MgDataPropertyDefinition def4 = new MgDataPropertyDefinition("def4");
+            MgPropertyDefinitionCollection coll = new MgPropertyDefinitionCollection();
+            coll.Add(def1);
+            coll.Add(def2);
+            coll.Insert(2, def4);
+            coll.Insert(2, def3);
+            Assert.AreEqual("def1", coll[0].GetName());
+            MgPropertyDefinition tmp = coll[0];
+            coll.Remove(def1);
+            coll.Insert(0, tmp);
+            string txt = "";
+            foreach (MgPropertyDefinition def in coll)
+                txt += "[" + def.GetName() + "]";
+            Assert.AreEqual("[def1][def2][def3][def4]", txt);
+    public class CollectionTestsReadOnlyLayerCollection : IExternalTest
+            logger.WriteLine("Skipping CollectionTestsReadOnlyLayerCollection: Resource Service required to construct MgLayer");
+    public class CollectionTestsStringCollection : IExternalTest
+            StringCollection strColl = new StringCollection();
+            strColl.Add("string1");
+            strColl.Add("string2");
+            strColl.Add("string3");
+            MgStringCollection coll1 = new MgStringCollection();
+            coll1.Add("Hello");
+            MgStringCollection coll2 = new MgStringCollection(strColl);
+            Assert.AreEqual(4, coll2.GetCount());
+            StringCollection coll3 = coll2;
+            Assert.AreEqual(4, coll3.Count);
+            for (int i = 0; i < 4; i++)
+                Assert.AreEqual(strColl[i], coll2.GetItem(i));
+                Assert.AreEqual(strColl[i], coll3[i]);
+    public class CollectionTestsStringPropertyCollection : IExternalTest
+            MgStringProperty prop1 = new MgStringProperty("prop1", "val1");
+            MgStringProperty prop2 = new MgStringProperty("prop2", "val2");
+            MgStringProperty prop3 = new MgStringProperty("prop3", "val3");
+            MgStringProperty prop4 = new MgStringProperty("prop4", "val4");
+            MgStringPropertyCollection coll = new MgStringPropertyCollection();
+            coll.Add(prop1);
+            coll.Add(prop2);
+            coll.Remove(prop3);
+            coll.Remove(coll[1]);
+            Assert.AreEqual(1, coll.Count);
+            coll.Add(prop3);
+            coll[1] = prop2;
+            coll.Insert(2, prop3);
+            Assert.AreEqual(2, coll.IndexOf(prop3));
+            coll.Add(prop4);
+            string txt = "";
+            foreach (MgStringProperty prop in coll)
+                txt += "[" + prop.GetName() + "]";
+            Assert.AreEqual("[prop1][prop2][prop3][prop4]", txt);
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/PropertiesTest.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/PropertiesTest.cs	                        (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/PropertiesTest.cs	2014-06-25 15:30:06 UTC (rev 8263)
@@ -0,0 +1,1080 @@
+using System;
+using System.IO;
+using System.Linq;
+using System.Text;
+    public class PropertiesTestColor : IExternalTest
+            short nRed = 22;
+            short nGreen = 33;
+            short nBlue = 44;
+            short nAlpha = 55;
+            MgColor color = new MgColor(nRed, nGreen, nBlue, nAlpha);
+            Assert.AreEqual(nRed, color.Red);
+            Assert.AreEqual(nGreen, color.Green);
+            Assert.AreEqual(nBlue, color.Blue);
+            Assert.AreEqual(nAlpha, color.Alpha);
+            String scolor = nRed.ToString("x") + nGreen.ToString("x") + nBlue.ToString("x") + nAlpha.ToString("x");
+            Assert.AreEqual(scolor, color.Color);
+    public class PropertiesTestDateTime : IExternalTest
+            MgDateTime dt = new MgDateTime();
+            dt.Year = 2006;
+            dt.Month = 9;
+            dt.Day = 21;
+            dt.Hour = 16;
+            dt.Minute = 4;
+            dt.Second = 25;
+            dt.Microsecond = 99;
+            Assert.AreEqual(2006, dt.Year);
+            Assert.AreEqual(9, dt.Month);
+            Assert.AreEqual(21, dt.Day);
+            Assert.AreEqual(16, dt.Hour);
+            Assert.AreEqual(4, dt.Minute);
+            Assert.AreEqual(25, dt.Second);
+            Assert.AreEqual(99, dt.Microsecond);
+    public class PropertiesTestByteReader : IExternalTest
+            MgByteSource source = new MgByteSource("../../TestData/DrawingService/SpaceShip.dwf");
+            source.MimeType = MgMimeType.Dwf;
+            MgByteReader reader = source.GetReader();
+            Assert.AreEqual(MgMimeType.Dwf, reader.MimeType);
+    public class PropertiesTestByteSource : IExternalTest
+            string tmp = Path.GetTempFileName();
+            try
+                File.WriteAllText(tmp, "Hello World");
+                MgByteSource source = new MgByteSource(tmp);
+                source.MimeType = "text/plain";
+                Assert.AreEqual(MgMimeType.Text, source.MimeType);
+            finally
+                try
+                    File.Delete(tmp);
+                catch { }
+    public class PropertiesTestPropertyDefinition : IExternalTest
+            MgPropertyDefinition propDef = new MgPropertyDefinition("TestProp", MgPropertyType.Int32);
+            propDef.Description = "description";
+            propDef.QualifiedName = "qualifiedName";
+            Assert.AreEqual("TestProp", propDef.Name);
+            Assert.AreEqual(MgPropertyType.Int32, propDef.PropertyType);
+            Assert.AreEqual("description", propDef.Description);
+            Assert.AreEqual("qualifiedName", propDef.QualifiedName);
+    public class PropertiesTestStringProperty : IExternalTest
+            MgStringProperty sp = new MgStringProperty("TestStringName", "TestStringValue");
+            Assert.AreEqual("TestStringValue", sp.Value);
+            Assert.AreEqual("TestStringName", sp.Name);
+    public class PropertiesTestBlobProperty : IExternalTest
+            try
+                MgByteSource bs = new MgByteSource(tmp);
+                MgByteReader reader = bs.GetReader();
+                MgBlobProperty bp = new MgBlobProperty("BlobPropName", reader);
+                Assert.AreEqual("BlobPropName", bp.Name);
+                Assert.Greater((int)bp.Value.GetLength(), 0);
+                Assert.AreEqual(reader.GetLength(), bp.Value.GetLength());
+                Assert.AreEqual(MgPropertyType.Blob, bp.PropertyType);
+                MgByteSource bs2 = new MgByteSource("../../TestData/DrawingService/SpaceShip.dwf");
+                MgByteReader reader2 = bs2.GetReader();
+                bp.Value = reader2;
+                Assert.AreEqual(reader2.GetLength(), bp.Value.GetLength());
+            finally
+                try
+                    File.Delete(tmp);
+                catch { }
+    public class PropertiesTestBooleanProperty : IExternalTest
+            MgBooleanProperty bp = new MgBooleanProperty("BoolPropName", true);
+            Assert.IsTrue(bp.Value);
+            Assert.AreEqual("BoolPropName", bp.Name);
+            Assert.AreEqual(MgPropertyType.Boolean, bp.PropertyType);
+            bp.Value = false;
+            Assert.IsFalse(bp.Value);
+    public class PropertiesTestByteProperty : IExternalTest
+            byte bpv = 123;
+            MgByteProperty bp = new MgByteProperty("BytePropName", bpv);
+            Assert.AreEqual("BytePropName", bp.Name);
+            Assert.AreEqual(bpv, bp.Value);
+            Assert.AreEqual(MgPropertyType.Byte, bp.PropertyType);
+    public class PropertiesTestClobProperty : IExternalTest
+            try
+                MgClobProperty cp = new MgClobProperty("ClobPropName", reader);
+                Assert.AreEqual("ClobPropName", cp.Name);
+                Assert.Greater((int)cp.Value.GetLength(), 0);
+                Assert.AreEqual(reader.GetLength(), cp.Value.GetLength());
+                Assert.AreEqual(MgPropertyType.Clob, cp.PropertyType);
+                cp.Value = reader2;
+                Assert.AreEqual(reader2.GetLength(), cp.Value.GetLength());
+            finally
+                try
+                    File.Delete(tmp);
+                catch { }
+    public class PropertiesTestDateTimeProperty : IExternalTest
+            MgDateTime dt = new MgDateTime(2006, 9, 22, 8, 33, 44, 55);
+            MgDateTimeProperty dtp = new MgDateTimeProperty("DateTimePropName", dt);
+            Assert.AreEqual("DateTimePropName", dtp.Name);
+            Assert.AreEqual(MgPropertyType.DateTime, dtp.PropertyType);
+            Assert.AreEqual(dt.Year, dtp.Value.Year);
+            Assert.AreEqual(dt.Month, dtp.Value.Month);
+            Assert.AreEqual(dt.Day, dtp.Value.Day);
+            Assert.AreEqual(dt.Hour, dtp.Value.Hour);
+            Assert.AreEqual(dt.Minute, dtp.Value.Minute);
+            Assert.AreEqual(dt.Second, dtp.Value.Second);
+            Assert.AreEqual(dt.Microsecond, dtp.Value.Microsecond);
+    public class PropertiesTestDoubleProperty : IExternalTest
+            MgDoubleProperty dp = new MgDoubleProperty("DoublePropName", 4.251973);
+            Assert.AreEqual("DoublePropName", dp.Name);
+            Assert.AreEqual(MgPropertyType.Double, dp.PropertyType);
+            Assert.AreEqual(4.251973, dp.Value);
+    public class PropertiesTestInt16Property : IExternalTest
+            MgInt16Property ip = new MgInt16Property("Int16PropName", -32768);
+            Assert.AreEqual("Int16PropName", ip.Name);
+            Assert.AreEqual(MgPropertyType.Int16, ip.PropertyType);
+            Assert.AreEqual(Int16.MinValue, ip.Value);
+    public class PropertiesTestInt32Property : IExternalTest
+            MgInt32Property ip = new MgInt32Property("Int32PropName", -2147483648);
+            Assert.AreEqual("Int32PropName", ip.Name);
+            Assert.AreEqual(MgPropertyType.Int32, ip.PropertyType);
+            Assert.AreEqual(Int32.MinValue, ip.Value);
+    public class PropertiesTestInt64Property : IExternalTest
+            MgInt64Property ip = new MgInt64Property("Int64PropName", -9223372036854775808);
+            Assert.AreEqual("Int64PropName", ip.Name);
+            Assert.AreEqual(MgPropertyType.Int64, ip.PropertyType);
+            Assert.AreEqual(Int64.MinValue, ip.Value);
+    public class PropertiesTestSingleProperty : IExternalTest
+            MgSingleProperty sp = new MgSingleProperty("SinglePropName", 4.251973f);
+            Assert.AreEqual("SinglePropName", sp.Name);
+            Assert.AreEqual(MgPropertyType.Single, sp.PropertyType);
+            Assert.AreEqual(4.251973f, sp.Value);
+    public class PropertiesTestLayerBase : IExternalTest
+            logger.WriteLine("Skipping PropertiesTestLayerBase: Resource Service required to construct MgLayer");
+            //MgUserInformation user = new MgUserInformation("Administrator", "admin");
+            //MgSiteConnection siteConnection = new MgSiteConnection();
+            //siteConnection.Open(user);
+            //MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
+            //MgResourceIdentifier id = new MgResourceIdentifier("Library://UnitTests/Data/Shuttle.DrawingSource");
+            //MgLayerBase lb = new MgLayerBase(id, resourceService);
+            //lb.Name = "TestLayerName";
+            //Assert.AreEqual("TestLayerName", lb.Name);
+            //Assert.AreEqual(MgLayerType.Dynamic, lb.LayerType);
+            //MgLayerGroup lg = new MgLayerGroup("TestLayerGroup");
+            //lb.Group = lg;
+            //Assert.AreEqual(lg.Name, lb.Group.Name);
+            //lb.Visible = true;
+            //Assert.AreEqual(true, lb.Visible);
+            //lb.Visible = false;
+            //Assert.AreEqual(false, lb.Visible);
+            //lb.Selectable = true;
+            //Assert.AreEqual(true, lb.Selectable);
+            //lb.Selectable = false;
+            //Assert.AreEqual(false, lb.Selectable);
+            //Assert.AreEqual(id.ToString(), lb.LayerDefinition.ToString());
+            //lb.DisplayInLegend = true;
+            //Assert.AreEqual(true, lb.DisplayInLegend);
+            //lb.DisplayInLegend = false;
+            //Assert.AreEqual(false, lb.DisplayInLegend);
+            //Assert.AreEqual(false, lb.ExpandInLegend);
+            //lb.LegendLabel = "TestLegendLabel";
+            //Assert.AreEqual("TestLegendLabel", lb.LegendLabel);
+            //Assert.AreEqual("", lb.FeatureSourceId);
+            //Assert.AreEqual("", lb.FeatureClassName);
+    public class PropertiesTestLayerGroup : IExternalTest
+            MgLayerGroup lg = new MgLayerGroup("TestLayerGroupName");
+            Assert.AreEqual("TestLayerGroupName", lg.Name);
+            Assert.AreEqual(MgLayerGroupType.Normal, lg.LayerGroupType);
+            lg.Group = new MgLayerGroup("AnotherTestLayerGroupName");
+            Assert.AreEqual("AnotherTestLayerGroupName", lg.Group.Name);
+            lg.Visible = true;
+            Assert.IsTrue(lg.Visible);
+            lg.Visible = false;
+            Assert.IsFalse(lg.Visible);
+            lg.DisplayInLegend = true;
+            Assert.IsTrue(lg.DisplayInLegend);
+            lg.DisplayInLegend = false;
+            Assert.IsFalse(lg.DisplayInLegend);
+            Assert.IsFalse(lg.ExpandInLegend);
+            lg.LegendLabel = "TestLegendLabel";
+            Assert.AreEqual("TestLegendLabel", lg.LegendLabel);
+    public class PropertiesTestMapBase : IExternalTest
+            MgMapBase mb = factory.CreateMap();
+            Assert.AreEqual("", mb.Name);
+            Assert.AreEqual("", mb.SessionId);
+            Assert.IsNull(mb.MapDefinition);
+            Assert.AreEqual("", mb.MapSRS);
+            Assert.IsNull(mb.MapExtent);
+            Assert.IsNull(mb.ViewCenter);
+            Assert.AreEqual(1.0, mb.ViewScale);
+            Assert.IsNull(mb.DataExtent);
+            Assert.AreEqual(96, mb.DisplayDpi);
+            Assert.AreEqual(0, mb.DisplayWidth);
+            Assert.AreEqual(0, mb.DisplayHeight);
+            Assert.AreEqual(0, mb.FiniteDisplayScaleCount);
+    public class PropertiesTestClassDefinition : IExternalTest
+            MgClassDefinition classDef = new MgClassDefinition();
+            classDef.DefaultGeometryPropertyName = "TestDefaultGeometryPropName";
+            Assert.AreEqual("TestDefaultGeometryPropName", classDef.DefaultGeometryPropertyName);
+            classDef.Name = "TestName";
+            Assert.AreEqual("TestName", classDef.Name);
+            classDef.Description = "TestDescription";
+            Assert.AreEqual("TestDescription", classDef.Description);
+            Assert.IsNull(classDef.BaseClassDefinition);
+    public class PropertiesTestFileFeatureSourceParams : IExternalTest
+            MgFileFeatureSourceParams csp = new MgFileFeatureSourceParams();
+            csp.ProviderName = "OSGeo.SDF";
+            Assert.AreEqual("OSGeo.SDF", csp.ProviderName);
+            csp.SpatialContextName = "TestSpatialContextName";
+            Assert.AreEqual("TestSpatialContextName", csp.SpatialContextName);
+            csp.SpatialContextDescription = "TestSpatialContextDescription";
+            Assert.AreEqual("TestSpatialContextDescription", csp.SpatialContextDescription);
+            csp.CoordinateSystemWkt = "TestCoordSysWkt";
+            Assert.AreEqual("TestCoordSysWkt", csp.CoordinateSystemWkt);
+            csp.XYTolerance = 0.0001;
+            Assert.AreEqual(0.0001, csp.XYTolerance);
+            csp.ZTolerance = 0.01;
+            Assert.AreEqual(0.01, csp.ZTolerance);
+            MgFeatureSchema schema = new MgFeatureSchema("SchemaName", "SchemaDescription");
+            csp.FeatureSchema = schema;
+            Assert.AreEqual(schema.Name, csp.FeatureSchema.Name);
+            Assert.AreEqual(schema.Description, csp.FeatureSchema.Description);
+    public class PropertiesTestDataPropertyDefinition : IExternalTest
+            MgDataPropertyDefinition dpd = new MgDataPropertyDefinition("DataPropDefName");
+            dpd.DataType = MgPropertyType.Int32;
+            Assert.AreEqual(MgPropertyType.Int32, dpd.DataType);
+            dpd.Length = 0;
+            Assert.AreEqual(0, dpd.Length);
+            dpd.Precision = 0;
+            Assert.AreEqual(0, dpd.Precision);
+            dpd.Scale = 0;
+            Assert.AreEqual(0, dpd.Scale);
+            dpd.DefaultValue = "123";
+            Assert.AreEqual("123", dpd.DefaultValue);
+            dpd.Nullable = true;
+            Assert.IsTrue(dpd.Nullable);
+            dpd.ReadOnly = false;
+            Assert.IsFalse(dpd.ReadOnly);
+    public class PropertiesTestDeleteFeatures : IExternalTest
+            MgDeleteFeatures df = new MgDeleteFeatures("dfClassName", "dfFilterText");
+            Assert.AreEqual("dfClassName", df.FeatureClassName);
+            Assert.AreEqual("dfFilterText", df.FilterText);
+    public class PropertiesTestFeatureProperty : IExternalTest
+            MgFeatureProperty fp = new MgFeatureProperty("FeatureProp", null);
+            Assert.AreEqual("FeatureProp", fp.Name);
+            Assert.AreEqual(MgPropertyType.Feature, fp.PropertyType);
+            Assert.IsNull(fp.Value);
+    public class PropertiesTestFeatureSchema : IExternalTest
+            MgFeatureSchema fs = new MgFeatureSchema();
+            fs.Name = "fsName";
+            Assert.AreEqual("fsName", fs.Name);
+            fs.Description = "fsDescription";
+            Assert.AreEqual("fsDescription", fs.Description);
+    public class PropertiesTestGeometryPropertyDefinition : IExternalTest
+            MgGeometricPropertyDefinition gpd = new MgGeometricPropertyDefinition("gdpName");
+            gpd.GeometryTypes = MgGeometryType.LineString;
+            Assert.AreEqual(MgGeometryType.LineString, gpd.GeometryTypes);
+            gpd.ReadOnly = false;
+            Assert.IsFalse(gpd.ReadOnly);
+            gpd.ReadOnly = true;
+            Assert.IsTrue(gpd.ReadOnly);
+            gpd.HasElevation = true;
+            Assert.IsTrue(gpd.HasElevation);
+            gpd.HasMeasure = true;
+            Assert.IsTrue(gpd.HasMeasure);
+            gpd.SpatialContextAssociation = "spatialContextAssociation";
+            Assert.AreEqual("spatialContextAssociation", gpd.SpatialContextAssociation);
+    public class PropertiesTestGeometryProperty : IExternalTest
+            try
+                MgGeometryProperty gp = new MgGeometryProperty("GeomPropName", reader);
+                gp.Value = reader2;
+                Assert.AreEqual(reader2.GetLength(), gp.Value.GetLength());
+                Assert.AreEqual(MgPropertyType.Geometry, gp.PropertyType);
+            finally
+                try
+                    File.Delete(tmp);
+                catch { }
+    public class PropertiesTestInsertFeatures : IExternalTest
+            MgPropertyCollection propColl = new MgPropertyCollection();
+            propColl.Add(new MgInt32Property("intProp", 10));
+            MgInsertFeatures inf = new MgInsertFeatures("ClassName", propColl);
+            Assert.AreEqual("ClassName", inf.FeatureClassName);
+    public class PropertiesTestObjectPropertyDefinition : IExternalTest
+            MgObjectPropertyDefinition opd = new MgObjectPropertyDefinition("odpName");
+            classDef.Name = "testClassDef";
+            opd.ClassDefinition = classDef;
+            Assert.AreEqual(classDef.Name, opd.ClassDefinition.Name);
+            opd.ObjectType = MgObjectPropertyType.OrderedCollection;
+            Assert.AreEqual(MgObjectPropertyType.OrderedCollection, opd.ObjectType);
+            opd.OrderType = MgOrderingOption.Ascending;
+            Assert.AreEqual(MgOrderingOption.Ascending, opd.OrderType);
+            MgDataPropertyDefinition dpd = new MgDataPropertyDefinition("dpdName");
+            opd.IdentityProperty = dpd;
+            Assert.AreEqual(dpd.Name, opd.IdentityProperty.Name);
+    public class PropertiesTestRasterProperty : IExternalTest
+            MgRasterProperty rp = new MgRasterProperty("RasterPropName", null);
+            Assert.AreEqual("RasterPropName", rp.Name);
+            Assert.AreEqual(MgPropertyType.Raster, rp.PropertyType);
+            Assert.IsNull(rp.Value);
+    public class PropertiesTestRasterPropertyDefinition : IExternalTest
+            MgRasterPropertyDefinition rpd = new MgRasterPropertyDefinition("rasterPropDef");
+            rpd.ReadOnly = true;
+            Assert.IsTrue(rpd.ReadOnly);
+            rpd.Nullable = true;
+            Assert.IsTrue(rpd.Nullable);
+            rpd.DefaultImageXSize = 600;
+            Assert.AreEqual(600, rpd.DefaultImageXSize);
+            rpd.DefaultImageYSize = 600;
+            Assert.AreEqual(600, rpd.DefaultImageYSize);
+            Assert.AreEqual("rasterPropDef", rpd.Name);
+    public class PropertiesTestResourceIdentifier : IExternalTest
+            MgResourceIdentifier resId = new MgResourceIdentifier("Library://UnitTests/Data/Shuttle.DrawingSource");
+            resId.RepositoryType = MgRepositoryType.Library;
+            Assert.AreEqual(MgRepositoryType.Library, resId.RepositoryType);
+            resId.RepositoryName = "resName";
+            Assert.AreEqual("resName", resId.RepositoryName);
+            resId.Path = "Data";
+            Assert.AreEqual("Data", resId.Path);
+            resId.Name = "Shuttle";
+            Assert.AreEqual("Shuttle", resId.Name);
+            resId.ResourceType = MgResourceType.DrawingSource;
+            Assert.AreEqual(MgResourceType.DrawingSource, resId.ResourceType);
+    public class PropertiesTestUpdateFeatures : IExternalTest
+            MgUpdateFeatures uf = new MgUpdateFeatures("ClassName", propColl, "filter");
+            Assert.AreEqual("ClassName", uf.FeatureClassName);
+    public class PropertiesTestCoordinateSystem : IExternalTest
+            MgCoordinateSystemFactory csFactory = new MgCoordinateSystemFactory();
+            MgCoordinateSystem coordSys = csFactory.CreateFromCode("LL84");
+            Assert.AreEqual(MgCoordinateSystemType.Geographic, coordSys.Type);
+            Assert.AreEqual("DEGREE", coordSys.Units);
+            Assert.AreEqual(-180, coordSys.MinX);
+            Assert.AreEqual(-90, coordSys.MinY);
+            Assert.AreEqual(180, coordSys.MaxX);
+            Assert.AreEqual(90, coordSys.MaxY);
+            Assert.AreEqual("LL84", coordSys.CsCode);
+            Assert.AreEqual("WGS84 datum, Latitude-Longitude; Degrees", coordSys.Description);
+            Assert.AreEqual("LL", coordSys.Projection);
+            Assert.AreEqual("Null Projection, produces/processes Latitude & Longitude", coordSys.ProjectionDescription);
+            Assert.AreEqual("WGS84", coordSys.Datum);
+            Assert.AreEqual("World Geodetic System of 1984", coordSys.DatumDescription);
+            Assert.AreEqual("WGS84", coordSys.Ellipsoid);
+            Assert.AreEqual("World Geodetic System of 1984, GEM 10C", coordSys.EllipsoidDescription);
+    public class PropertiesTestArcSegment : IExternalTest
+            MgCoordinateXY start = gf.CreateCoordinateXY(0, 0) as MgCoordinateXY;
+            MgCoordinateXY end = gf.CreateCoordinateXY(10, 10) as MgCoordinateXY;
+            MgCoordinateXY control = gf.CreateCoordinateXY(5, 5) as MgCoordinateXY;
+            MgArcSegment arcSegment = gf.CreateArcSegment(start, end, control);
+            Assert.AreEqual(MgGeometryComponentType.ArcSegment, arcSegment.ComponentType);
+            Assert.AreEqual(control.ToString(), arcSegment.ControlCoordinate.ToString());
+            Assert.AreEqual(start.ToString(), arcSegment.StartCoordinate.ToString());
+            Assert.AreEqual(end.ToString(), arcSegment.EndCoordinate.ToString());
+    public class PropertiesTestCoordinateXY : IExternalTest
+            MgCoordinateXY coord = gf.CreateCoordinateXY(100, 100) as MgCoordinateXY;
+            Assert.AreEqual(100, coord.X);
+            Assert.AreEqual(100, coord.Y);
+            MgCoordinate coord2 = coord;
+            Assert.AreEqual(100, coord2.X);
+            Assert.AreEqual(100, coord2.Y);
+    public class PropertiesTestCoordinateXYM : IExternalTest
+            MgCoordinateXYM coord = gf.CreateCoordinateXYM(100, 100, 10) as MgCoordinateXYM;
+            Assert.AreEqual(10, coord.M);
+            Assert.AreEqual(10, coord2.M);
+    public class PropertiesTestCoordinateXYZ : IExternalTest
+            MgCoordinateXYZ coord = gf.CreateCoordinateXYZ(100, 100, 10) as MgCoordinateXYZ;
+            Assert.AreEqual(10, coord.Z);
+            Assert.AreEqual(10, coord2.Z);
+    public class PropertiesTestCoordinateXYZM : IExternalTest
+            MgCoordinateXYZM coord = gf.CreateCoordinateXYZM(100, 100, 10, 5) as MgCoordinateXYZM;
+            Assert.AreEqual(5, coord.M);
+            Assert.AreEqual(5, coord2.M);
+    public class PropertiesTestCurvePolygon : IExternalTest
+            MgCoordinate pt1 = gf.CreateCoordinateXY(0, 0);
+            MgCoordinate pt2 = gf.CreateCoordinateXY(0, 10);
+            MgCoordinate pt3 = gf.CreateCoordinateXY(10, 10);
+            MgCoordinate pt4 = gf.CreateCoordinateXY(10, 0);
+            MgCoordinateCollection coordinates = new MgCoordinateCollection();
+            coordinates.Add(pt1);
+            coordinates.Add(pt2);
+            coordinates.Add(pt3);
+            coordinates.Add(pt4);
+            MgLinearSegment linearSegment = gf.CreateLinearSegment(coordinates);
+            MgCurveSegmentCollection curveSegments = new MgCurveSegmentCollection();
+            curveSegments.Add(linearSegment);
+            MgCurveRing outerRing = gf.CreateCurveRing(curveSegments);
+            MgCurvePolygon cp = gf.CreateCurvePolygon(outerRing, null);
+            Assert.AreEqual(outerRing.ToString(), cp.ExteriorRing.ToString());
+            Assert.AreEqual(0, cp.InteriorRingCount);
+            Assert.AreEqual(MgGeometryType.CurvePolygon, cp.GeometryType);
+            Assert.AreEqual(2, cp.Dimension);
+    public class PropertiesTestCurveRing : IExternalTest
+            Assert.AreEqual(MgGeometryComponentType.CurveRing, outerRing.ComponentType);
+            Assert.AreEqual(1, outerRing.Count);
+            Assert.AreEqual(2, outerRing.Dimension);
+    public class PropertiesTestCurveString : IExternalTest
+            MgCurveString curveString = gf.CreateCurveString(curveSegments);
+            Assert.AreEqual(1, curveString.Count);
+            Assert.AreEqual(pt1.ToString(), curveString.StartCoordinate.ToString());
+            Assert.AreEqual(pt4.ToString(), curveString.EndCoordinate.ToString());
+            Assert.AreEqual(MgGeometryType.CurveString, curveString.GeometryType);
+            Assert.AreEqual(1, curveString.Dimension);
+    public class PropertiesTestEnvelope : IExternalTest
+            MgEnvelope env = new MgEnvelope(-180, -90, 180, 90);
+            Assert.AreEqual(-180, env.LowerLeftCoordinate.GetX());
+            Assert.AreEqual(-90, env.LowerLeftCoordinate.GetY());
+            Assert.AreEqual(180, env.UpperRightCoordinate.GetX());
+            Assert.AreEqual(90, env.UpperRightCoordinate.GetY());
+            Assert.AreEqual(360, env.Width);
+            Assert.AreEqual(180, env.Height);
+            Assert.IsNaN(env.Depth);
+    public class PropertiesTestLinearRing : IExternalTest
+            MgLinearRing linearRing = gf.CreateLinearRing(coordinates);
+            Assert.AreEqual(MgGeometryComponentType.LinearRing, linearRing.ComponentType);
+            Assert.AreEqual(2, linearRing.Dimension);
+    public class PropertiesTestLinearSegment : IExternalTest
+            Assert.AreEqual(MgGeometryComponentType.LinearSegment, linearSegment.ComponentType);
+            Assert.AreEqual(pt1.ToString(), linearSegment.StartCoordinate.ToString());
+            Assert.AreEqual(pt4.ToString(), linearSegment.EndCoordinate.ToString());
+            Assert.AreEqual(1, linearSegment.Dimension);
+    public class PropertiesTestLineString : IExternalTest
+            MgLineString linestring = gf.CreateLineString(coordinates);
+            Assert.AreEqual(pt1.ToString(), linestring.StartCoordinate.ToString());
+            Assert.AreEqual(pt4.ToString(), linestring.EndCoordinate.ToString());
+            Assert.AreEqual(MgGeometryType.LineString, linestring.GeometryType);
+            Assert.AreEqual(1, linestring.Dimension);
+    public class PropertiesTestMultiCurvePolygon : IExternalTest
+            MgCurveRing curveRing = gf.CreateCurveRing(curveSegments);
+            MgCurvePolygon cp = gf.CreateCurvePolygon(curveRing, null);
+            MgCurvePolygonCollection cpc = new MgCurvePolygonCollection();
+            cpc.Add(cp);
+            MgMultiCurvePolygon mcp = gf.CreateMultiCurvePolygon(cpc);
+            Assert.AreEqual(1, mcp.Count);
+            Assert.AreEqual(MgGeometryType.MultiCurvePolygon, mcp.GeometryType);
+            Assert.AreEqual(2, mcp.Dimension);
+    public class PropertiesTestMultiCurveString : IExternalTest
+            MgCurveStringCollection csc = new MgCurveStringCollection();
+            csc.Add(curveString);
+            MgMultiCurveString mcs = gf.CreateMultiCurveString(csc);
+            Assert.AreEqual(1, mcs.Count);
+            Assert.AreEqual(MgGeometryType.MultiCurveString, mcs.GeometryType);
+            Assert.AreEqual(1, mcs.Dimension);
+    public class PropertiesTestMultiGeometry : IExternalTest
+            MgLineString ls = gf.CreateLineString(coordinates);
+            geometries.Add(ls);
+            MgMultiGeometry mg = gf.CreateMultiGeometry(geometries);
+            Assert.AreEqual(1, mg.Count);
+            Assert.AreEqual(MgGeometryType.MultiGeometry, mg.GeometryType);
+            Assert.AreEqual(4, mg.Dimension);
+    public class PropertiesTestMultiLineString : IExternalTest
+            MgLineStringCollection lineStringCollection = new MgLineStringCollection();
+            lineStringCollection.Add(ls);
+            MgMultiLineString mls = gf.CreateMultiLineString(lineStringCollection);
+            Assert.AreEqual(1, mls.Count);
+            Assert.AreEqual(MgGeometryType.MultiLineString, mls.GeometryType);
+            Assert.AreEqual(1, mls.Dimension);
+    public class PropertiesTestMultiPoint : IExternalTest
+            MgPoint mgpt1 = gf.CreatePoint(pt1);
+            MgPoint mgpt2 = gf.CreatePoint(pt2);
+            MgPoint mgpt3 = gf.CreatePoint(pt3);
+            MgPoint mgpt4 = gf.CreatePoint(pt4);
+            MgPointCollection points = new MgPointCollection();
+            points.Add(mgpt1);
+            points.Add(mgpt2);
+            points.Add(mgpt3);
+            points.Add(mgpt4);
+            MgMultiPoint mp = gf.CreateMultiPoint(points);
+            Assert.AreEqual(4, mp.Count);
+            Assert.AreEqual(MgGeometryType.MultiPoint, mp.GeometryType);
+            Assert.AreEqual(0, mp.Dimension);
+    public class PropertiesTestPolygon : IExternalTest
+            MgPolygon polygon = gf.CreatePolygon(linearRing, null);
+            Assert.AreEqual(linearRing.ToString(), polygon.ExteriorRing.ToString());
+            Assert.AreEqual(0, polygon.InteriorRingCount);
+            Assert.AreEqual(MgGeometryType.Polygon, polygon.GeometryType);
+            Assert.AreEqual(2, polygon.Dimension);
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj	2014-06-23 14:31:00 UTC (rev 8262)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj	2014-06-25 15:30:06 UTC (rev 8263)
@@ -72,6 +72,11 @@
   </ItemGroup>
   <ItemGroup>
     <Compile Include="ApiTypes.cs" />
+    <Compile Include="Assert.cs" />
+    <Compile Include="CommonTests.cs" />
+    <Compile Include="ExternalTests\ByteReaderTest.cs" />
+    <Compile Include="ExternalTests\CollectionTests.cs" />
+    <Compile Include="ExternalTests\PropertiesTest.cs" />
     <Compile Include="FeatureService\Operations.cs" />
     <Compile Include="ITestExecutor.cs" />
     <Compile Include="ITestExecutorCollection.cs" />
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/CollectionTests.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/CollectionTests.cs	                        (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/CollectionTests.cs	2014-06-25 15:30:06 UTC (rev 8263)
@@ -0,0 +1,59 @@
+using OSGeo.MapGuide.Test.Common;
+using System;
+using System.Linq;
+using System.Text;
+namespace OSGeo.MapGuide.Test.Web.ExternalTests
+    public class CollectionTestsMapPlotCollection : IExternalTest
+            MgMap map1 = (MgMap)factory.CreateMap();
+            MgMap map2 = (MgMap)factory.CreateMap();
+            MgMap map3 = (MgMap)factory.CreateMap();
+            MgPlotSpecification spec = new MgPlotSpecification((float)8.0, (float)11.0, "in", (float)0.0, (float)0.0, (float)5.0, (float)5.0);
+            MgResourceIdentifier resId = new MgResourceIdentifier("Library://test.WebLayout");
+            MgLayout layout1 = new MgLayout(resId, "Title1", "in");
+            MgMapPlot plot1 = new MgMapPlot(map1, spec, layout1);
+            MgLayout layout2 = new MgLayout(resId, "Title2", "in");
+            MgMapPlot plot2 = new MgMapPlot(map2, spec, layout2);
+            MgLayout layout3 = new MgLayout(resId, "Title3", "in");
+            MgMapPlot plot3 = new MgMapPlot(map3, spec, layout3);
+            MgMapPlotCollection coll = new MgMapPlotCollection();
+            coll.Add(plot1);
+            coll.Add(plot2);
+            coll.Remove(plot1);
+            coll.Insert(0, plot1);
+            coll.Insert(2, plot3);
+            MgMapPlot tmp = coll[2];
+            coll[2] = tmp;
+            string txt = "";
+            foreach (MgMapPlot plot in coll)
+                txt += "[" + plot.GetLayout().GetTitle() + "]";
+            Assert.AreEqual("[Title1][Title2][Title3]", txt);
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs	                        (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs	2014-06-25 15:30:06 UTC (rev 8263)
@@ -0,0 +1,49 @@
+using System;
+using System.Linq;
+using System.Text;
+    public class MapGuideTests
+            int failures = 0;
+            var types = typeof(MapGuideTests).Assembly.GetTypes();
+                    try
+                        logger.WriteLine("****** Executing MapGuide test: " + type.Name + " *********");
+                        Console.WriteLine("Executing external MapGuide test: " + type.Name);
+                        failures++;
+                        failures++;
+                    finally
+                        testsRun++;
+            return failures;
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj	2014-06-23 14:31:00 UTC (rev 8262)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj	2014-06-25 15:30:06 UTC (rev 8263)
@@ -79,6 +79,8 @@
   <ItemGroup>
     <Compile Include="DrawingService\DrawingServiceOperationExecutor.cs" />
     <Compile Include="DrawingService\Operations.cs" />
+    <Compile Include="MapGuideTests.cs" />
     <Compile Include="MappingService\MappingServiceOperationExecutor.cs" />
     <Compile Include="Properties\AssemblyInfo.cs" />
     <Compile Include="MapGuideTestExecutorCollection.cs" />
More information about the mapguide-commits mailing list
