[mapguide-commits] r7987 - trunk/MgDev
svn_mapguide at osgeo.org
Sun Mar 9 04:21:04 PDT 2014
Author: jng
Date: 2014-03-09 04:21:04 -0700 (Sun, 09 Mar 2014)
New Revision: 7987
trunk/MgDev/build_oem.sh
64-bit changes for build_oem.sh
- Add support for a --build switch that allows the user to specify whether they're building for 32-bit or 64-bit
- Ensure that Oem components being built as static libraries in 64-bit have the necessary -fPIC compiler flag passed in
- Remove PHP as Oem/LinuxApt/built_apt.sh builds that
Modified: trunk/MgDev/build_oem.sh
--- trunk/MgDev/build_oem.sh 2014-03-03 23:29:44 UTC (rev 7986)
+++ trunk/MgDev/build_oem.sh 2014-03-09 11:21:04 UTC (rev 7987)
@@ -13,6 +13,7 @@
echo "MapGuide Open Source build script for OEM components"
INSTALLDIR=/usr/local/mapguideopensource
CLEAN_FLAG=0
+BUILD_CPU=32
while [ $# -gt 0 ]; do # Until you run out of parameters...
case "$1" in
-prefix|--prefix)
@@ -23,11 +24,16 @@
CLEAN_FLAG=1
shift
+ -build|--build)
+ BUILD_CPU=$2
+ shift
-help|--help)
echo "Usage: $0 (options)"
echo "Options:"
echo " --prefix [installation directory]"
echo " --clean [clean all objects and binaries in Oem]"
+ echo " --build [32(default)|64]"
echo " --help [Display usage]"
exit
@@ -103,7 +109,9 @@
LIB_NAME="DWFCORE 1.0"
pushd DWFTK7.1/develop/global/build/gnu/dwfcore
- sh ./build_setup.sh
+ if [ $CLEAN_FLAG -eq 0 ]; then
+ sh ./build_setup.sh
+ fi
popd
@@ -134,7 +142,9 @@
LIB_NAME="DWFTK 7.1"
pushd DWFTK7.1/develop/global/build/gnu/dwftoolkit
+ fi
popd
@@ -165,7 +175,9 @@
LIB_NAME="DWFEMAP 1.0"
pushd DWFTK7.1/develop/global/build/gnu/dwfemap
+ fi
popd
@@ -200,7 +212,11 @@
build_geos()
pushd geos-2.2.0
- sh ./configure --prefix="${INSTALLDIR}"
+ if [ $BUILD_CPU -eq 64 ]; then
+ sh ./configure --with-pic --prefix="${INSTALLDIR}"
+ else
+ sh ./configure --prefix="${INSTALLDIR}"
+ fi
make
# The check build is disabled as the build will fail with automake version < 2.59
# check_build
@@ -216,31 +232,6 @@
-# Build PHP 5.3.1
-# Notes: Configure PHP source tree for building PHP extension
-init_php()
- LIB_NAME="PHP 5.5.3"
-build_php()
- # Nothing to do here. build_apt.sh builds PHP
- pushd LinuxApt/php-5.5.3
- popd
-clean_php()
- make distclean
- check_clean
- popd
# Build SWIGEx 1.0
# Notes: none
@@ -331,7 +322,6 @@
clean_cppunit()
pushd CppUnit-1.9.14
make clean
check_clean
popd
@@ -406,7 +396,13 @@
pushd gd/lpng
cp scripts/makefile.std makefile
- make
+ #Inject -fPIC to CFLAGS for 64-bit
+ sed 's/^CFLAGS=/CFLAGS= -fPIC /g' makefile > makefile64
+ make -fmakefile64
+ else
+ make
+ fi
check_build
popd
@@ -432,8 +428,16 @@
build_jpeg()
pushd gd/jpeg
- sh ./configure --enable-static --disable-shared
- make
+ sh ./configure --enable-static --disable-shared
+ #--with-pic does nothing (probably ancient configure script), so do some sed trickery
+ #to inject this flag. Know a better way? Enlighten us :)
+ sed 's/^CFLAGS=/CFLAGS= -fPIC/g' Makefile > Makefile64
+ make -fMakefile64
+ else
+ make
+ fi
check_build
popd
@@ -459,7 +463,11 @@
build_freetype()
pushd gd/freetype
+ sh ./configure --enable-static --disable-shared --with-pic
+ else
+ fi
make
check_build
popd
@@ -486,7 +494,11 @@
build_gd()
pushd gd/gd
- sh ./configure --enable-static --disable-shared --without-fontconfig
+ sh ./configure --enable-static --disable-shared --without-fontconfig --with-pic
+ else
+ fi
make
check_build
popd
@@ -513,7 +525,11 @@
build_agg()
pushd agg-2.4
- make
+ make EXTRACXXFLAGS=-fPIC
+ else
+ make
+ fi
check_build
popd
@@ -566,11 +582,23 @@
pushd CsMap
mkdir -p .libs
pushd Source
- make -fLibrary.mak
+ #Need to build CS-Map with -fPIC because linking libraries will be built with -fPIC
+ sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Library64.mak
+ make -fLibrary64.mak
+ else
+ make -fLibrary.mak
+ fi
cp CsMap.a ../.libs/libCsmap.a
popd
pushd Dictionaries
- make -fCompiler.mak
+ sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Compiler64.mak
+ make -fCompiler64.mak
+ else
+ make -fCompiler.mak
+ fi
./CS_Comp -b . .
popd
check_build
@@ -579,8 +607,12 @@
clean_csmap()
- pushd CsMap
- make clean
+ pushd CsMap/Source
+ make clean -fLibrary64.mak
+ else
+ make clean -fLibrary.mak
+ fi
check_clean
popd
@@ -590,7 +622,7 @@
pushd Oem
-for lib in ace dwfcore dwftk dwfemap geos php swigex bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
+for lib in ace dwfcore dwftk dwfemap geos swigex bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
do
echo "$lib: Initialization..........................."
init_"$lib"
More information about the mapguide-commits
