[mapguide-commits] r8003 - trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Mar 30 07:04:23 PDT 2014
Author: jng
Date: 2014-03-30 07:04:23 -0700 (Sun, 30 Mar 2014)
New Revision: 8003
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
#2419: Add support for theming composite lines. The whole theming process for composite rules as a whole is extremely fragile (due to the many possible style permutations you can have with composite symbolization), but this should satisfy the common un-styled point/line/area composite symbolizations. Still, some theming support is better than none.
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs	2014-03-30 14:01:52 UTC (rev 8002)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs	2014-03-30 14:04:23 UTC (rev 8003)
@@ -905,8 +905,11 @@
         enum FillColorSource
             PathFillColor,
-            SymbolParameterDefaultValue,
-            SymbolParameterOverride
+            SymbolParameterFillColorDefaultValue,
+            SymbolParameterFillColorOverride,
+            PathLineColor,
+            SymbolParameterLineColorDefaultValue,
+            SymbolParameterLineColorOverride
         private void GenerateCompositeThemeRules(List<RuleItem> rules, ICompositeTypeStyle col)
@@ -928,73 +931,249 @@
                 template = col.GetRuleAt(0);
                 if (template.CompositeSymbolization != null)
-                    foreach (ISymbolInstance symInst in template.CompositeSymbolization.SymbolInstance)
-                        if (source.HasValue)
-                            break;
+                    IdentifyColorSource(template, ref source, ref fillAlpha);
-                        var symRef = GetSymbolFromReference(m_editor.ResourceService, symInst.Reference);
-                        var simpleSym = symRef as ISimpleSymbolDefinition;
-                        if (simpleSym == null)
-                            throw new NotSupportedException(Strings.CannotCreateThemeFromCompoundSymbolInstance);
+            if (OverwriteRules.Checked)
+                col.RemoveAllRules();
-                        var symName = simpleSym.Name;
-                        //Find the first path graphic with a fill color
-                        foreach (var graphic in simpleSym.Graphics)
+            foreach (RuleItem entry in rules)
+                var r = (template != null) ? CreateCompositeRule(template, _factory) : _factory.CreateDefaultCompositeRule();
+                Debug.WriteLine("Made rule {0}", r.GetHashCode());
+                r.Filter = entry.Filter;
+                r.LegendLabel = entry.Label;
+                if (r.CompositeSymbolization != null)
+                    SetColorForCompositeRule(source, fillAlpha, entry, r);
+                col.AddCompositeRule(r);
+        private void SetColorForCompositeRule(FillColorSource? source, string fillAlpha, RuleItem entry, ICompositeRule r)
+            // NOTE: Same naivete as IdentifyColorSource(). Refer to that method for all the gory details
+            bool bSetFill = false;
+            foreach (ISymbolInstance symInst in r.CompositeSymbolization.SymbolInstance)
+                if (bSetFill)
+                    break;
+                var symRef = GetSymbolFromReference(m_editor.ResourceService, symInst.Reference);
+                var simpleSym = symRef as ISimpleSymbolDefinition;
+                if (simpleSym == null)
+                    throw new NotSupportedException(Strings.CannotCreateThemeFromCompoundSymbolInstance);
+                var symName = simpleSym.Name;
+                //Find the first path graphic with a fill color
+                foreach (var graphic in simpleSym.Graphics)
+                    if (bSetFill)
+                        break;
+                    if (graphic.Type == GraphicElementType.Path)
+                        IPathGraphic path = (IPathGraphic)graphic;
+                        if (path.FillColor != null)
+                            string color = path.FillColor;
+                            if (source.Value == FillColorSource.PathFillColor)
+                                path.FillColor = "0x" + fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
+                                Debug.WriteLine(string.Format("Set fill color to {0} for symbol instance {1} of symbolization {2} in rule {3}", path.FillColor, symInst.GetHashCode(), r.CompositeSymbolization.GetHashCode(), r.GetHashCode()));
+                                bSetFill = true;
                                 break;
-                            if (graphic.Type == GraphicElementType.Path)
+                            //Is this a parameter?
+                            if (color.StartsWith("%") && color.EndsWith("%"))
-                                IPathGraphic path = (IPathGraphic)graphic;
-                                if (path.FillColor != null)
+                                string paramName = color.Substring(1, color.Length - 2);
+                                if (simpleSym.ParameterDefinition != null)
-                                    var hexIdx = path.FillColor.IndexOf("0x");
-                                    if (hexIdx >= 0 && hexIdx + 4 < path.FillColor.Length)
+                                    foreach (var paramDef in simpleSym.ParameterDefinition.Parameter)
-                                        fillAlpha = path.FillColor.Substring(hexIdx + 2, 2);
-                                        source = FillColorSource.PathFillColor;
+                                        if (bSetFill)
+                                            break;
+                                        if (paramDef.Name == paramName)
+                                            if (source.Value == FillColorSource.SymbolParameterFillColorDefaultValue)
+                                                paramDef.DefaultValue = "0x" + fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
+                                                Debug.WriteLine(string.Format("Set fill color default parameter value to {0} for symbol instance {1} of symbolization {2} in rule {3}", paramDef.DefaultValue, symInst.GetHashCode(), r.CompositeSymbolization.GetHashCode(), r.GetHashCode()));
+                                                bSetFill = true;
+                                                break;
+                                            //But wait ... Is there an override for this too?
+                                            var ov = symInst.ParameterOverrides;
+                                            if (ov != null)
+                                                foreach (var pov in ov.Override)
+                                                    if (bSetFill)
+                                                        break;
+                                                    if (pov.SymbolName == symName && pov.ParameterIdentifier == paramName)
+                                                        if (source.Value == FillColorSource.SymbolParameterFillColorOverride)
+                                                            pov.ParameterValue = "0x" + fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
+                                                            Debug.WriteLine(string.Format("Set fill color parameter override value to {0} for symbol instance {1} of symbolization {2} in rule {3}", pov.ParameterValue, symInst.GetHashCode(), r.CompositeSymbolization.GetHashCode(), r.GetHashCode()));
+                                                            bSetFill = true;
+                                                            break;
-                                    else
+                        else if (path.LineColor != null && simpleSym.LineUsage != null)
+                            string color = path.LineColor;
+                            if (source.Value == FillColorSource.PathLineColor)
+                                path.LineColor = "0x" + fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
+                                Debug.WriteLine(string.Format("Set line color to {0} for symbol instance {1} of symbolization {2} in rule {3}", path.FillColor, symInst.GetHashCode(), r.CompositeSymbolization.GetHashCode(), r.GetHashCode()));
+                                bSetFill = true;
+                                break;
-                                        string color = path.FillColor;
-                                        //Is this a parameter?
-                                        if (color.StartsWith("%") && color.EndsWith("%"))
+                                        if (bSetFill)
+                                            break;
-                                            string paramName = color.Substring(1, color.Length - 2);
-                                            if (simpleSym.ParameterDefinition != null)
+                                            if (source.Value == FillColorSource.SymbolParameterLineColorDefaultValue)
-                                                foreach (var paramDef in simpleSym.ParameterDefinition.Parameter)
+                                                Debug.WriteLine(string.Format("Set line color default parameter value to {0} for symbol instance {1} of symbolization {2} in rule {3}", paramDef.DefaultValue, symInst.GetHashCode(), r.CompositeSymbolization.GetHashCode(), r.GetHashCode()));
+                                                bSetFill = true;
+                                                break;
+                                            if (ov != null)
+                                                    if (bSetFill)
                                                         break;
-                                                    if (paramDef.Name == paramName)
-                                                        hexIdx = paramDef.DefaultValue.IndexOf("0x");
-                                                        if (hexIdx >= 0 && hexIdx + 4 < paramDef.DefaultValue.Length)
+                                                        if (source.Value == FillColorSource.SymbolParameterLineColorOverride)
-                                                            fillAlpha = paramDef.DefaultValue.Substring(hexIdx + 2, 2);
-                                                            source = FillColorSource.SymbolParameterDefaultValue;
+                                                            Debug.WriteLine(string.Format("Set line color parameter override value to {0} for symbol instance {1} of symbolization {2} in rule {3}", pov.ParameterValue, symInst.GetHashCode(), r.CompositeSymbolization.GetHashCode(), r.GetHashCode()));
+                                                            bSetFill = true;
+                                                            break;
-                                                        //But wait ... Is there an override for this too?
-                                                        var ov = symInst.ParameterOverrides;
-                                                        if (ov != null)
+        private void IdentifyColorSource(ICompositeRule template, ref FillColorSource? source, ref string fillAlpha)
+            // FIXME: This is very naive. It will identify the first color it finds and runs with it.
+            // It doesn't take into consideration things such as usage contexts, which we currently only care about on
+            // the 2nd pass when we still can't identify a color and presumably we're dealing with a composite symbolization
+            // with line usage (where fill colors won't exist most of the time). Thematics should be fine on the most basic
+            // of composite symbolization cases, but I expect this process to break down hardcore on the most elaborate of
+            // composite symbolization cases. Still, some thematic support is better than none.
+            // So anyways, 1st pass: Assume point/area and identify the first fill color we find
+            foreach (ISymbolInstance symInst in template.CompositeSymbolization.SymbolInstance)
+                if (source.HasValue)
+                    break;
+                        break;
+                            var hexIdx = path.FillColor.IndexOf("0x");
+                            if (hexIdx >= 0 && hexIdx + 4 < path.FillColor.Length)
+                                fillAlpha = path.FillColor.Substring(hexIdx + 2, 2);
+                                source = FillColorSource.PathFillColor;
+                            else
+                                                break;
+                                                hexIdx = paramDef.DefaultValue.IndexOf("0x");
+                                                if (hexIdx >= 0 && hexIdx + 4 < paramDef.DefaultValue.Length)
+                                                    fillAlpha = paramDef.DefaultValue.Substring(hexIdx + 2, 2);
+                                                    source = FillColorSource.SymbolParameterFillColorDefaultValue;
+                                                if (ov != null)
-                                                            foreach (var pov in ov.Override)
+                                                            hexIdx = pov.ParameterValue.IndexOf("0x");
+                                                            if (hexIdx >= 0 && hexIdx + 4 < pov.ParameterValue.Length)
-        if (pov.SymbolName == symName && pov.ParameterIdentifier == paramName)
-        hexIdx = pov.ParameterValue.IndexOf("0x");
-        if (hexIdx >= 0 && hexIdx + 4 < pov.ParameterValue.Length)
-        fillAlpha = pov.ParameterValue.Substring(hexIdx + 2, 2);
-        source = FillColorSource.SymbolParameterOverride;
-        break;
+        fillAlpha = pov.ParameterValue.Substring(hexIdx + 2, 2);
+        source = FillColorSource.SymbolParameterFillColorOverride;
+        break;
@@ -1009,50 +1188,45 @@
-            if (OverwriteRules.Checked)
+            if (!source.HasValue)
-                col.RemoveAllRules();
+                //Still no source? Time for a 2nd pass, this time find the first line color where the symbol instance has a line usage
+                //context
+                        break;
-            foreach (RuleItem entry in rules)
-                var r = (template != null) ? CreateCompositeRule(template, _factory) : _factory.CreateDefaultCompositeRule();
-                Debug.WriteLine("Made rule {0}", r.GetHashCode());
-                r.Filter = entry.Filter;
-                r.LegendLabel = entry.Label;
-                if (r.CompositeSymbolization != null)
-                    bool bSetFill = false;
-                    foreach (ISymbolInstance symInst in r.CompositeSymbolization.SymbolInstance)
-                        if (bSetFill)
                             break;
-                            if (bSetFill)
-                                break;
+                            if (path.LineColor != null)
+                                //Bail on this symbol if it has no line usage context
+                                if (simpleSym.LineUsage == null)
+                                    continue;
+                                var hexIdx = path.LineColor.IndexOf("0x");
+                                if (hexIdx >= 0 && hexIdx + 4 < path.LineColor.Length)
-                                    if (source.Value == FillColorSource.PathFillColor)
-                                        path.FillColor = "0x" + fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
-                                        Debug.WriteLine(string.Format("Set fill color to {0} for symbol instance {1} of symbolization {2} in rule {3}", path.FillColor, symInst.GetHashCode(), r.CompositeSymbolization.GetHashCode(), r.GetHashCode()));
-                                        bSetFill = true;
-                                        break;
+                                    fillAlpha = path.LineColor.Substring(hexIdx + 2, 2);
+                                    source = FillColorSource.PathLineColor;
+                                else
@@ -1061,36 +1235,31 @@
-                                                if (bSetFill)
                                                     break;
-                                                    if (source.Value == FillColorSource.SymbolParameterDefaultValue)
-                                                        paramDef.DefaultValue = "0x" + fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
-                                                        Debug.WriteLine(string.Format("Set fill color default parameter value to {0} for symbol instance {1} of symbolization {2} in rule {3}", paramDef.DefaultValue, symInst.GetHashCode(), r.CompositeSymbolization.GetHashCode(), r.GetHashCode()));
-                                                        bSetFill = true;
-                                                        break;
+                                                        source = FillColorSource.SymbolParameterLineColorDefaultValue;
                                                     if (ov != null)
-                                                            if (bSetFill)
-        break;
-        //fillAlpha = pov.ParameterValue;
-        if (source == FillColorSource.SymbolParameterOverride)
-        pov.ParameterValue = "0x" + fillAlpha + Utility.SerializeHTMLColor(entry.Color, string.IsNullOrEmpty(fillAlpha));
-        Debug.WriteLine(string.Format("Set fill color parameter override value to {0} for symbol instance {1} of symbolization {2} in rule {3}", pov.ParameterValue, symInst.GetHashCode(), r.CompositeSymbolization.GetHashCode(), r.GetHashCode()));
-        bSetFill = true;
+        source = FillColorSource.SymbolParameterLineColorOverride;
        break;
@@ -1105,8 +1274,6 @@
-                col.AddCompositeRule(r);
More information about the mapguide-commits mailing list
