[mapguide-commits] r8113 - in trunk/Tools/Maestro/Maestro.Base: Commands/SiteExplorer UI
svn_mapguide at osgeo.org
Tue May 6 22:49:54 PDT 2014
Author: jng
Date: 2014-05-06 22:49:54 -0700 (Tue, 06 May 2014)
New Revision: 8113
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/CompileFullDependencyListCommand.cs
trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.cs
trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.resx
#2327: Add support for downward dependencies in the "Compile Full Dependency List" command.
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/CompileFullDependencyListCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/CompileFullDependencyListCommand.cs 2014-05-06 20:04:22 UTC (rev 8112)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/CompileFullDependencyListCommand.cs 2014-05-07 05:49:54 UTC (rev 8113)
@@ -44,14 +44,17 @@
var items = siteExp.SelectedItems;
var prg = new ProgressDialog();
- var results = (ICollection<string>)prg.RunOperationAsync(wb, DoBackgroundWorker, items, conn);
+ var results = (DependencySet)prg.RunOperationAsync(wb, DoBackgroundWorker, items, conn);
- var list = new List<string>(results);
- list.Sort();
- new ResourceDependencyListDialog(list).Show(wb);
+ var downlist = new List<string>(results.DownstreamDependencies);
+ downlist.Sort();
+ var uplist = new List<string>(results.UpstreamDependencies);
+ uplist.Sort();
+ var selResources = new List<string>(results.SelectedResources);
+ new ResourceDependencyListDialog(selResources, downlist, uplist).Show(wb);
- private static IEnumerable<string> GetDirectDependents(string resId, IResourceService resSvc)
+ private static IEnumerable<string> GetDirectUpstreamDependents(string resId, IResourceService resSvc)
using (var s = resSvc.GetResourceXmlData(resId))
@@ -64,15 +67,39 @@
- private static void ProcessDependencies(ICollection<string> results, string resourceId, IResourceService resSvc)
+ private static void ProcessUpstreamDependencies(ICollection<string> results, string resourceId, IResourceService resSvc)
- foreach (var resId in GetDirectDependents(resourceId, resSvc))
+ foreach (var resId in GetDirectUpstreamDependents(resourceId, resSvc))
results.Add(resId);
- ProcessDependencies(results, resId, resSvc);
+ ProcessUpstreamDependencies(results, resId, resSvc);
+ private static void ProcessDownstreamDependencies(ICollection<string> results, string resourceId, IResourceService resSvc)
+ var downRefs = resSvc.EnumerateResourceReferences(resourceId);
+ foreach (var resId in downRefs.ResourceId)
+ results.Add(resId);
+ ProcessDownstreamDependencies(results, resId, resSvc);
+ class DependencySet
+ public DependencySet(ICollection<string> selResources, ICollection<string> downRefs, ICollection<string> upRefs)
+ this.SelectedResources = selResources;
+ this.DownstreamDependencies = downRefs;
+ this.UpstreamDependencies = upRefs;
+ public ICollection<string> SelectedResources { get; private set; }
+ public ICollection<string> DownstreamDependencies { get; private set; }
+ public ICollection<string> UpstreamDependencies { get; private set; }
private static object DoBackgroundWorker(BackgroundWorker wrk, DoWorkEventArgs e, params object[] args)
var items = (RepositoryItem[])args[0];
@@ -83,15 +110,18 @@
wrk.ReportProgress(pe.Progress, o);
- var result = new HashSet<string>();
+ var upRefs = new HashSet<string>();
+ var downRefs = new HashSet<string>();
+ var selResources = new HashSet<string>();
foreach (var ri in items)
- result.Add(ri.ResourceId);
- ProcessDependencies(result, ri.ResourceId, conn.ResourceService);
+ selResources.Add(ri.ResourceId);
+ ProcessUpstreamDependencies(upRefs, ri.ResourceId, conn.ResourceService);
+ ProcessDownstreamDependencies(downRefs, ri.ResourceId, conn.ResourceService);
- return result;
+ return new DependencySet(selResources, downRefs, upRefs);
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.Designer.cs 2014-05-06 20:04:22 UTC (rev 8112)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.Designer.cs 2014-05-07 05:49:54 UTC (rev 8113)
@@ -30,9 +30,19 @@
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ResourceDependencyListDialog));
this.label1 = new System.Windows.Forms.Label();
- this.lstDependencies = new System.Windows.Forms.ListBox();
- this.btnSave = new System.Windows.Forms.Button();
+ this.lstUpstreamDependencies = new System.Windows.Forms.ListBox();
+ this.btnSaveUpList = new System.Windows.Forms.Button();
this.btnClose = new System.Windows.Forms.Button();
+ this.btnSaveDownList = new System.Windows.Forms.Button();
+ this.lstDownstreamDependencies = new System.Windows.Forms.ListBox();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.groupBox2 = new System.Windows.Forms.GroupBox();
+ this.groupBox3 = new System.Windows.Forms.GroupBox();
+ this.lstSelectedResources = new System.Windows.Forms.ListBox();
+ this.chkIncludeSelected = new System.Windows.Forms.CheckBox();
+ this.groupBox1.SuspendLayout();
+ this.groupBox2.SuspendLayout();
+ this.groupBox3.SuspendLayout();
this.SuspendLayout();
// label1
@@ -40,18 +50,18 @@
resources.ApplyResources(this.label1, "label1");
this.label1.Name = "label1";
- // lstDependencies
+ // lstUpstreamDependencies
- resources.ApplyResources(this.lstDependencies, "lstDependencies");
- this.lstDependencies.FormattingEnabled = true;
- this.lstDependencies.Name = "lstDependencies";
+ resources.ApplyResources(this.lstUpstreamDependencies, "lstUpstreamDependencies");
+ this.lstUpstreamDependencies.FormattingEnabled = true;
+ this.lstUpstreamDependencies.Name = "lstUpstreamDependencies";
- // btnSave
+ // btnSaveUpList
- resources.ApplyResources(this.btnSave, "btnSave");
- this.btnSave.Name = "btnSave";
- this.btnSave.UseVisualStyleBackColor = true;
- this.btnSave.Click += new System.EventHandler(this.btnSave_Click);
+ resources.ApplyResources(this.btnSaveUpList, "btnSaveUpList");
+ this.btnSaveUpList.Name = "btnSaveUpList";
+ this.btnSaveUpList.UseVisualStyleBackColor = true;
+ this.btnSaveUpList.Click += new System.EventHandler(this.btnSaveUpList_Click);
// btnClose
@@ -60,17 +70,72 @@
this.btnClose.UseVisualStyleBackColor = true;
this.btnClose.Click += new System.EventHandler(this.btnClose_Click);
+ // btnSaveDownList
+ resources.ApplyResources(this.btnSaveDownList, "btnSaveDownList");
+ this.btnSaveDownList.Name = "btnSaveDownList";
+ this.btnSaveDownList.UseVisualStyleBackColor = true;
+ this.btnSaveDownList.Click += new System.EventHandler(this.btnSaveDownList_Click);
+ // lstDownstreamDependencies
+ resources.ApplyResources(this.lstDownstreamDependencies, "lstDownstreamDependencies");
+ this.lstDownstreamDependencies.FormattingEnabled = true;
+ this.lstDownstreamDependencies.Name = "lstDownstreamDependencies";
+ // groupBox1
+ resources.ApplyResources(this.groupBox1, "groupBox1");
+ this.groupBox1.Controls.Add(this.lstUpstreamDependencies);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.TabStop = false;
+ // groupBox2
+ resources.ApplyResources(this.groupBox2, "groupBox2");
+ this.groupBox2.Controls.Add(this.lstDownstreamDependencies);
+ this.groupBox2.Name = "groupBox2";
+ this.groupBox2.TabStop = false;
+ // groupBox3
+ resources.ApplyResources(this.groupBox3, "groupBox3");
+ this.groupBox3.Controls.Add(this.lstSelectedResources);
+ this.groupBox3.Name = "groupBox3";
+ this.groupBox3.TabStop = false;
+ // lstSelectedResources
+ resources.ApplyResources(this.lstSelectedResources, "lstSelectedResources");
+ this.lstSelectedResources.FormattingEnabled = true;
+ this.lstSelectedResources.Name = "lstSelectedResources";
+ // chkIncludeSelected
+ resources.ApplyResources(this.chkIncludeSelected, "chkIncludeSelected");
+ this.chkIncludeSelected.Checked = true;
+ this.chkIncludeSelected.CheckState = System.Windows.Forms.CheckState.Checked;
+ this.chkIncludeSelected.Name = "chkIncludeSelected";
+ this.chkIncludeSelected.UseVisualStyleBackColor = true;
// ResourceDependencyListDialog
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
resources.ApplyResources(this, "$this");
this.ControlBox = false;
+ this.Controls.Add(this.chkIncludeSelected);
+ this.Controls.Add(this.groupBox3);
+ this.Controls.Add(this.groupBox2);
+ this.Controls.Add(this.groupBox1);
+ this.Controls.Add(this.btnSaveDownList);
this.Controls.Add(this.btnClose);
- this.Controls.Add(this.btnSave);
- this.Controls.Add(this.lstDependencies);
+ this.Controls.Add(this.btnSaveUpList);
this.Controls.Add(this.label1);
this.Name = "ResourceDependencyListDialog";
this.ShowIcon = false;
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox2.ResumeLayout(false);
+ this.groupBox3.ResumeLayout(false);
this.ResumeLayout(false);
this.PerformLayout();
@@ -79,8 +144,15 @@
#endregion
private System.Windows.Forms.Label label1;
- private System.Windows.Forms.ListBox lstDependencies;
- private System.Windows.Forms.Button btnSave;
+ private System.Windows.Forms.ListBox lstUpstreamDependencies;
+ private System.Windows.Forms.Button btnSaveUpList;
private System.Windows.Forms.Button btnClose;
+ private System.Windows.Forms.Button btnSaveDownList;
+ private System.Windows.Forms.ListBox lstDownstreamDependencies;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.GroupBox groupBox2;
+ private System.Windows.Forms.GroupBox groupBox3;
+ private System.Windows.Forms.ListBox lstSelectedResources;
+ private System.Windows.Forms.CheckBox chkIncludeSelected;
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.cs 2014-05-06 20:04:22 UTC (rev 8112)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.cs 2014-05-07 05:49:54 UTC (rev 8113)
@@ -37,13 +37,19 @@
InitializeComponent();
- private IList<string> _items;
+ private IList<string> _uplist;
+ private IList<string> _downlist;
+ private IList<string> _selResources;
- public ResourceDependencyListDialog(IList<string> items)
+ public ResourceDependencyListDialog(IList<string> selResources, IList<string> downlist, IList<string> uplist)
: this()
- _items = items;
- lstDependencies.DataSource = _items;
+ _uplist = uplist;
+ _downlist = downlist;
+ _selResources = selResources;
+ lstSelectedResources.DataSource = _selResources;
+ lstUpstreamDependencies.DataSource = _uplist;
+ lstDownstreamDependencies.DataSource = _downlist;
private void btnClose_Click(object sender, EventArgs e)
@@ -51,16 +57,34 @@
this.Close();
- private void btnSave_Click(object sender, EventArgs e)
+ private void btnSaveUpList_Click(object sender, EventArgs e)
using (var save = DialogFactory.SaveFile())
save.Filter = string.Format(OSGeo.MapGuide.MaestroAPI.Strings.GenericFilter, OSGeo.MapGuide.MaestroAPI.Strings.PickTxt, "txt"); //NOXLATE
if (save.ShowDialog() == System.Windows.Forms.DialogResult.OK)
- System.IO.File.WriteAllLines(save.FileName, _items);
+ if (chkIncludeSelected.Checked)
+ System.IO.File.WriteAllLines(save.FileName, _selResources.Concat(_uplist));
+ else
+ System.IO.File.WriteAllLines(save.FileName, _uplist);
+ private void btnSaveDownList_Click(object sender, EventArgs e)
+ using (var save = DialogFactory.SaveFile())
+ save.Filter = string.Format(OSGeo.MapGuide.MaestroAPI.Strings.GenericFilter, OSGeo.MapGuide.MaestroAPI.Strings.PickTxt, "txt"); //NOXLATE
+ if (save.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ System.IO.File.WriteAllLines(save.FileName, _selResources.Concat(_downlist));
+ else
+ System.IO.File.WriteAllLines(save.FileName, _downlist);
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.resx 2014-05-06 20:04:22 UTC (rev 8112)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ResourceDependencyListDialog.resx 2014-05-07 05:49:54 UTC (rev 8113)
@@ -144,65 +144,68 @@
<value>$this</value>
</data>
<data name=">>label1.ZOrder" xml:space="preserve">
- <value>3</value>
+ <value>7</value>
</data>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
- <data name="lstDependencies.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Top, Bottom, Left, Right</value>
+ <data name="lstUpstreamDependencies.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Fill</value>
</data>
- <data name="lstDependencies.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 45</value>
+ <data name="lstUpstreamDependencies.HorizontalScrollbar" type="System.Boolean, mscorlib">
+ <value>True</value>
</data>
- <data name="lstDependencies.Size" type="System.Drawing.Size, System.Drawing">
- <value>401, 316</value>
+ <data name="lstUpstreamDependencies.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 16</value>
</data>
- <data name="lstDependencies.TabIndex" type="System.Int32, mscorlib">
+ <data name="lstUpstreamDependencies.Size" type="System.Drawing.Size, System.Drawing">
+ <value>272, 235</value>
+ </data>
+ <data name="lstUpstreamDependencies.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
</data>
- <data name=">>lstDependencies.Name" xml:space="preserve">
- <value>lstDependencies</value>
+ <data name=">>lstUpstreamDependencies.Name" xml:space="preserve">
+ <value>lstUpstreamDependencies</value>
</data>
- <data name=">>lstDependencies.Type" xml:space="preserve">
+ <data name=">>lstUpstreamDependencies.Type" xml:space="preserve">
<value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>lstDependencies.Parent" xml:space="preserve">
- <value>$this</value>
+ <data name=">>lstUpstreamDependencies.Parent" xml:space="preserve">
+ <value>groupBox1</value>
</data>
- <data name=">>lstDependencies.ZOrder" xml:space="preserve">
- <value>2</value>
+ <data name=">>lstUpstreamDependencies.ZOrder" xml:space="preserve">
+ <value>0</value>
</data>
- <data name="btnSave.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <data name="btnSaveUpList.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Left</value>
</data>
- <data name="btnSave.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 378</value>
+ <data name="btnSaveUpList.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 449</value>
</data>
- <data name="btnSave.Size" type="System.Drawing.Size, System.Drawing">
- <value>75, 23</value>
+ <data name="btnSaveUpList.Size" type="System.Drawing.Size, System.Drawing">
+ <value>118, 23</value>
</data>
- <data name="btnSave.TabIndex" type="System.Int32, mscorlib">
+ <data name="btnSaveUpList.TabIndex" type="System.Int32, mscorlib">
<value>2</value>
</data>
- <data name="btnSave.Text" xml:space="preserve">
- <value>Save</value>
+ <data name="btnSaveUpList.Text" xml:space="preserve">
+ <value>Save Upstream List</value>
</data>
- <data name=">>btnSave.Name" xml:space="preserve">
- <value>btnSave</value>
+ <data name=">>btnSaveUpList.Name" xml:space="preserve">
+ <value>btnSaveUpList</value>
</data>
- <data name=">>btnSave.Type" xml:space="preserve">
+ <data name=">>btnSaveUpList.Type" xml:space="preserve">
<value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>btnSave.Parent" xml:space="preserve">
+ <data name=">>btnSaveUpList.Parent" xml:space="preserve">
</data>
- <data name=">>btnSave.ZOrder" xml:space="preserve">
- <value>1</value>
+ <data name=">>btnSaveUpList.ZOrder" xml:space="preserve">
+ <value>6</value>
</data>
<data name="btnClose.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Right</value>
</data>
<data name="btnClose.Location" type="System.Drawing.Point, System.Drawing">
- <value>338, 378</value>
+ <value>540, 449</value>
</data>
<data name="btnClose.Size" type="System.Drawing.Size, System.Drawing">
@@ -223,13 +226,205 @@
</data>
<data name=">>btnClose.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="btnSaveDownList.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Left</value>
+ </data>
+ <data name="btnSaveDownList.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
+ <data name="btnSaveDownList.Location" type="System.Drawing.Point, System.Drawing">
+ <value>136, 449</value>
+ </data>
+ <data name="btnSaveDownList.Size" type="System.Drawing.Size, System.Drawing">
+ <value>131, 23</value>
+ </data>
+ <data name="btnSaveDownList.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="btnSaveDownList.Text" xml:space="preserve">
+ <value>Save Downstream List</value>
+ </data>
+ <data name=">>btnSaveDownList.Name" xml:space="preserve">
+ <value>btnSaveDownList</value>
+ </data>
+ <data name=">>btnSaveDownList.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnSaveDownList.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>btnSaveDownList.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="lstDownstreamDependencies.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="lstDownstreamDependencies.HorizontalScrollbar" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lstDownstreamDependencies.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="lstDownstreamDependencies.Size" type="System.Drawing.Size, System.Drawing">
+ <value>313, 235</value>
+ </data>
+ <data name="lstDownstreamDependencies.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name=">>lstDownstreamDependencies.Name" xml:space="preserve">
+ <value>lstDownstreamDependencies</value>
+ </data>
+ <data name=">>lstDownstreamDependencies.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lstDownstreamDependencies.Parent" xml:space="preserve">
+ <value>groupBox2</value>
+ </data>
+ <data name=">>lstDownstreamDependencies.ZOrder" xml:space="preserve">
<value>0</value>
</data>
+ <data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left</value>
+ </data>
+ <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 189</value>
+ </data>
+ <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>278, 254</value>
+ </data>
+ <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="groupBox1.Text" xml:space="preserve">
+ <value>Upstream Dependencies</value>
+ </data>
+ <data name=">>groupBox1.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>groupBox1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>296, 189</value>
+ </data>
+ <data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>319, 254</value>
+ </data>
+ <data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name="groupBox2.Text" xml:space="preserve">
+ <value>Downstream Dependencies</value>
+ </data>
+ <data name=">>groupBox2.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="groupBox3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="lstSelectedResources.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="lstSelectedResources.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="lstSelectedResources.Size" type="System.Drawing.Size, System.Drawing">
+ <value>597, 125</value>
+ </data>
+ <data name="lstSelectedResources.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>lstSelectedResources.Name" xml:space="preserve">
+ <value>lstSelectedResources</value>
+ </data>
+ <data name=">>lstSelectedResources.Type" xml:space="preserve">
+ </data>
+ <data name=">>lstSelectedResources.Parent" xml:space="preserve">
+ <value>groupBox3</value>
+ </data>
+ <data name=">>lstSelectedResources.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 39</value>
+ </data>
+ <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>603, 144</value>
+ </data>
+ <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name="groupBox3.Text" xml:space="preserve">
+ <value>Selected Resources</value>
+ </data>
+ <data name=">>groupBox3.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="chkIncludeSelected.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="chkIncludeSelected.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkIncludeSelected.Location" type="System.Drawing.Point, System.Drawing">
+ <value>273, 453</value>
+ </data>
+ <data name="chkIncludeSelected.Size" type="System.Drawing.Size, System.Drawing">
+ <value>223, 17</value>
+ </data>
+ <data name="chkIncludeSelected.TabIndex" type="System.Int32, mscorlib">
+ <value>8</value>
+ </data>
+ <data name="chkIncludeSelected.Text" xml:space="preserve">
+ <value>Include Selected Resources when saving</value>
+ </data>
+ <data name=">>chkIncludeSelected.Name" xml:space="preserve">
+ <value>chkIncludeSelected</value>
+ </data>
+ <data name=">>chkIncludeSelected.Type" xml:space="preserve">
+ <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>chkIncludeSelected.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkIncludeSelected.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
- <value>425, 413</value>
+ <value>627, 484</value>
</data>
<data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
<value>CenterParent</value>
More information about the mapguide-commits
