[mapguide-commits] r8115 - trunk/Tools/Maestro/MgCooker
svn_mapguide at osgeo.org
Wed May 7 00:05:43 PDT 2014
Author: jng
Date: 2014-05-07 00:05:43 -0700 (Wed, 07 May 2014)
New Revision: 8115
trunk/Tools/Maestro/MgCooker/SetupRun.cs
More MgCooker constant-ification
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.cs
--- trunk/Tools/Maestro/MgCooker/SetupRun.cs 2014-05-07 06:53:26 UTC (rev 8114)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.cs 2014-05-07 07:05:43 UTC (rev 8115)
@@ -83,32 +83,32 @@
catch { }
- if (m_commandlineargs.ContainsKey("mapdefinitions")) //NOXLATE
- m_commandlineargs.Remove("mapdefinitions"); //NOXLATE
- if (m_commandlineargs.ContainsKey("mapagent")) //NOXLATE
- MapAgent.Text = m_commandlineargs["mapagent"]; //NOXLATE
- if (m_commandlineargs.ContainsKey("username")) //NOXLATE
- Username.Text = m_commandlineargs["username"]; //NOXLATE
- if (m_commandlineargs.ContainsKey("password")) //NOXLATE
- Password.Text = m_commandlineargs["password"]; //NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.MAPDEFINITIONS)) //NOXLATE
+ m_commandlineargs.Remove(TileRunParameters.MAPDEFINITIONS); //NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.MAPAGENT)) //NOXLATE
+ MapAgent.Text = m_commandlineargs[TileRunParameters.MAPAGENT]; //NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.USERNAME)) //NOXLATE
+ Username.Text = m_commandlineargs[TileRunParameters.USERNAME]; //NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.PASSWORD)) //NOXLATE
+ Password.Text = m_commandlineargs[TileRunParameters.PASSWORD]; //NOXLATE
- if (m_commandlineargs.ContainsKey("native-connection")) //NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.NATIVECONNECTION)) //NOXLATE
UseNativeAPI.Checked = true;
- if (m_commandlineargs.ContainsKey("limitrows")) //NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.LIMITROWS)) //NOXLATE
int i;
- if (int.TryParse(m_commandlineargs["limitrows"], out i) && i > 0) //NOXLATE
+ if (int.TryParse(m_commandlineargs[TileRunParameters.LIMITROWS], out i) && i > 0) //NOXLATE
MaxRowLimit.Value = i;
TilesetLimitPanel.Enabled = true;
- if (m_commandlineargs.ContainsKey("limitcols")) //NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.LIMITCOLS)) //NOXLATE
int i;
- if (int.TryParse(m_commandlineargs["limitcols"], out i) && i > 0) //NOXLATE
+ if (int.TryParse(m_commandlineargs[TileRunParameters.LIMITCOLS], out i) && i > 0) //NOXLATE
MaxColLimit.Value = i;
@@ -137,12 +137,12 @@
- if (m_commandlineargs.ContainsKey("metersperunit")) //NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.METERSPERUNIT)) //NOXLATE
double d;
if (
- double.TryParse(m_commandlineargs["metersperunit"], System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.CurrentUICulture, out d) //NOXLATE
- || double.TryParse(m_commandlineargs["metersperunit"], System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, out d) //NOXLATE
+ double.TryParse(m_commandlineargs[TileRunParameters.METERSPERUNIT], System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.CurrentUICulture, out d) //NOXLATE
+ || double.TryParse(m_commandlineargs[TileRunParameters.METERSPERUNIT], System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, out d) //NOXLATE
if (d >= (double)MetersPerUnit.Minimum && d <= (double)MetersPerUnit.Maximum)
@@ -161,20 +161,20 @@
var basegroupsSelected = new List<string>();
- if (m_commandlineargs.ContainsKey("basegroups"))//NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.BASEGROUPS))//NOXLATE
- basegroupsSelected = new List<string>(m_commandlineargs["basegroups"].Split(','));//NOXLATE
- m_commandlineargs.Remove("basegroups"); //NOXLATE
+ basegroupsSelected = new List<string>(m_commandlineargs[TileRunParameters.BASEGROUPS].Split(','));//NOXLATE
+ m_commandlineargs.Remove(TileRunParameters.BASEGROUPS); //NOXLATE
var scalesSelected = new List<int>();
- if (m_commandlineargs.ContainsKey("scaleindex")) //NOXLATE
+ if (m_commandlineargs.ContainsKey(TileRunParameters.SCALEINDEX)) //NOXLATE
- foreach (string scaleIndex in m_commandlineargs["scaleindex"].Split(','))//NOXLATE
+ foreach (string scaleIndex in m_commandlineargs[TileRunParameters.SCALEINDEX].Split(','))//NOXLATE
scalesSelected.Add(int.Parse(scaleIndex));
- m_commandlineargs.Remove("scaleindex"); //NOXLATE
+ m_commandlineargs.Remove(TileRunParameters.SCALEINDEX); //NOXLATE
MapTree.Nodes.Clear();
@@ -386,26 +386,26 @@
//Common args for all map defintions to be tiled
List<string> args = new List<string>();
- args.Add("--mapagent=\"" + MapAgent.Text + "\""); //NOXLATE
- args.Add("--username=\"" + Username.Text + "\""); //NOXLATE
- args.Add("--password=\"" + Password.Text + "\""); //NOXLATE
+ args.Add("--" + TileRunParameters.MAPAGENT + "=\"" + MapAgent.Text + "\""); //NOXLATE
+ args.Add("--" + TileRunParameters.USERNAME + "=\"" + Username.Text + "\""); //NOXLATE
+ args.Add("--" + TileRunParameters.PASSWORD + "=\"" + Password.Text + "\""); //NOXLATE
if (LimitTileset.Checked)
if (MaxRowLimit.Value > 0)
- args.Add("--limitrows=\"" + ((int)MaxRowLimit.Value).ToString() + "\""); //NOXLATE
+ args.Add("--" + TileRunParameters.LIMITROWS + "=\"" + ((int)MaxRowLimit.Value).ToString() + "\""); //NOXLATE
if (MaxColLimit.Value > 0)
- args.Add("--limitcols=\"" + ((int)MaxColLimit.Value).ToString() + "\""); //NOXLATE
+ args.Add("--" + TileRunParameters.LIMITCOLS + "=\"" + ((int)MaxColLimit.Value).ToString() + "\""); //NOXLATE
if (UseNativeAPI.Checked)
- args.Add("--native-connection"); //NOXLATE
+ args.Add("--" + TileRunParameters.NATIVECONNECTION + ""); //NOXLATE
if (UseOfficialMethod.Checked)
- args.Add("--metersperunit=" + ((double)MetersPerUnit.Value).ToString(System.Globalization.CultureInfo.InvariantCulture)); //NOXLATE
+ args.Add("--" + TileRunParameters.METERSPERUNIT + "=" + ((double)MetersPerUnit.Value).ToString(System.Globalization.CultureInfo.InvariantCulture)); //NOXLATE
- args.Add("--threadcount=" + ((int)ThreadCount.Value).ToString()); //NOXLATE
+ args.Add("--" + TileRunParameters.THREADCOUNT + "=" + ((int)ThreadCount.Value).ToString()); //NOXLATE
if (RandomTileOrder.Checked)
- args.Add("--random-tile-order"); //NOXLATE
+ args.Add("--" + TileRunParameters.RANDOMTILEORDER + ""); //NOXLATE
string executable = System.IO.Path.GetFileName(System.Reflection.Assembly.GetExecutingAssembly().Location);
@@ -458,9 +458,9 @@
argsMap.Add("batch"); //NOXLATE
- argsMap.Add("--mapdefinitions=\"" + c.MapDefinition + "\"");
- argsMap.Add("--basegroups=\"" + c.Group + "\"");
- StringBuilder si = new StringBuilder("--scaleindex="); //NOXLATE
+ argsMap.Add("--" + TileRunParameters.MAPDEFINITIONS + "=\"" + c.MapDefinition + "\"");
+ argsMap.Add("--" + TileRunParameters.BASEGROUPS + "=\"" + c.Group + "\"");
+ StringBuilder si = new StringBuilder("--" + TileRunParameters.SCALEINDEX + "="); //NOXLATE
for (int i = 0; i < c.ScaleIndexes.Length; i++)
if (i != 0)
@@ -471,7 +471,7 @@
if (c.ExtentOverride != null)
- StringBuilder ov = new StringBuilder("--extentoverride="); //NOXLATE
+ StringBuilder ov = new StringBuilder("--" + TileRunParameters.EXTENTOVERRIDE + "="); //NOXLATE
ov.Append(c.ExtentOverride.MinX.ToString(System.Globalization.CultureInfo.InvariantCulture));
ov.Append(","); //NOXLATE
ov.Append(c.ExtentOverride.MinY.ToString(System.Globalization.CultureInfo.InvariantCulture));
More information about the mapguide-commits
