[mapguide-commits] r8125 - in branches/2.6/vagrant: . centos/x64 centos/x86 scripts sources/patches sources/patches/fdo sources/patches/mapguide ubuntu/x64 ubuntu/x86
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon May 12 05:17:02 PDT 2014
Author: jng
Date: 2014-05-12 05:17:02 -0700 (Mon, 12 May 2014)
New Revision: 8125
Added:
   branches/2.6/vagrant/scripts/mginstallcentos.sh
   branches/2.6/vagrant/scripts/mginstallubuntu.sh
   branches/2.6/vagrant/scripts/mguninstallubuntu.sh
   branches/2.6/vagrant/sources/patches/fdo/Thirdparty/
   branches/2.6/vagrant/sources/patches/mapguide/Oem/
Removed:
   branches/2.6/vagrant/scripts/build_oem_ubuntu.sh
   branches/2.6/vagrant/build.bat
   branches/2.6/vagrant/centos/x64/Vagrantfile
   branches/2.6/vagrant/centos/x86/Vagrantfile
   branches/2.6/vagrant/clean.bat
   branches/2.6/vagrant/scripts/build.sh
   branches/2.6/vagrant/scripts/build_fdo.sh
   branches/2.6/vagrant/sources/patches/patchinfo.txt
   branches/2.6/vagrant/ubuntu/x64/Vagrantfile
   branches/2.6/vagrant/ubuntu/x86/Vagrantfile
This is the vagrant configuration used to produce the 2.6 beta 1 builds of MapGuide for Ubuntu and CentOS
Modified: branches/2.6/vagrant/build.bat
--- branches/2.6/vagrant/build.bat	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/build.bat	2014-05-12 12:17:02 UTC (rev 8125)
@@ -9,6 +9,12 @@
 SET TEARDOWN_CENTOS_64=0
 SET ROOT=%CD%
 SET COMPONENT=
+echo **************** Build Summary *********************
+echo Building Ubuntu (32-bit): %BUILD_UBUNTU_32% (teardown=%TEARDOWN_UBUNTU_32%)
+echo Building Ubuntu (64-bit): %BUILD_UBUNTU_64% (teardown=%TEARDOWN_UBUNTU_64%)
+echo Building CentOS (32-bit): %BUILD_CENTOS_32% (teardown=%TEARDOWN_CENTOS_32%)
+echo Building CentOS (64-bit): %BUILD_CENTOS_64% (teardown=%TEARDOWN_CENTOS_64%)
+echo ****************************************************
 :prepare
 echo [build]: Prepare scripts for provisioning
 if %BUILD_CENTOS_32% == 1 copy /Y scripts\*.* %ROOT%\centos\x86
Modified: branches/2.6/vagrant/centos/x64/Vagrantfile
--- branches/2.6/vagrant/centos/x64/Vagrantfile	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/centos/x64/Vagrantfile	2014-05-12 12:17:02 UTC (rev 8125)
@@ -126,6 +126,14 @@
 		exit $error
 	fi
+check_test()
+	error=$?
+	if [ $error -ne 0 ]; then
+		echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)"
+		echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)" >> ~/unit_test_status.log
+	fi
 if hash scons 2>/dev/null; then
 	echo [provision]: We have scons
 else
@@ -140,12 +148,18 @@
 HAVE_FDO_LIBS=0
 HAVE_MAPGUIDE=0
 MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
 SCRIPT_ROOT=~/scripts
-FDO_SRC_ROOT=~/fdo
-FDO_SRC=$FDO_SRC_ROOT/trunk
+FDO_SRC_ROOT=~/fdo/branches
+FDO_VER_MM=3.9
+MG_VER_MM=2.6
+FDO_SRC_DIR=3.9
+FDO_SRC=$FDO_SRC_ROOT/$FDO_SRC_DIR
 FDO_LIB_SRC=~/fdo_rdbms_thirdparty
-MG_SRC_ROOT=~/mapguide/trunk
+MG_SRC_ROOT=~/mapguide/branches/2.6
 MG_SRC=$MG_SRC_ROOT/MgDev
+FDO_TARBALL=fdo-checkout-3.9.tar.gz
+MG_TARBALL=mapguide-checkout-2.6.tar.gz
 if [ -d $FDO_SRC ];
 then
     HAVE_FDO=1
@@ -158,8 +172,8 @@
 then
     HAVE_MAPGUIDE=1
 fi
-echo [provision]: Checking all tools and libs are in place
-yum install -y gcc-* gd-* automake bison byacc flex doxygen expat expat-devel libtool libjpeg-devel libpng libpng-devel libxml2 libxml2-devel openssl curl curl-devel libxslt libxslt-devel subversion java-1.7.0-openjdk java-1.7.0-openjdk-devel ant dos2unix openssh-server openldap-devel alsa-lib-devel pcre-devel unixODBC-devel libcom_err-devel krb5-devel openssl-devel mysql-devel postgresql-devel unixODBC
+#echo [provision]: Checking all tools and libs are in place
+#yum install -y gcc-* gd-* automake bison byacc flex doxygen expat expat-devel libtool libjpeg-devel libpng libpng-devel libxml2 libxml2-devel openssl curl curl-devel libxslt libxslt-devel subversion java-1.7.0-openjdk java-1.7.0-openjdk-devel ant dos2unix openssh-server openldap-devel alsa-lib-devel pcre-devel unixODBC-devel libcom_err-devel krb5-devel openssl-devel mysql-devel postgresql-devel unixODBC
 echo [provision]: Copying shell scripts
 mkdir -p $SCRIPT_ROOT
 cp -f /vagrant/*.sh $SCRIPT_ROOT
@@ -179,15 +193,15 @@
 fi
 if [ $HAVE_FDO -eq 0 ];
 then
-    echo [provision]: Extracting FDO trunk working copy
-    mkdir -p ~/fdo
-    tar -zxf /mapguide_sources/fdo-checkout.tar.gz -C ~/fdo
+    echo [provision]: Extracting FDO working copy
+    mkdir -p $FDO_SRC_ROOT
+    tar -zxf /mapguide_sources/$FDO_TARBALL -C $FDO_SRC_ROOT
 fi
 if [ $HAVE_MAPGUIDE -eq 0 ];
 then
-    echo [provision]: Extracting MapGuide trunk working copy
+    echo [provision]: Extracting MapGuide working copy
     mkdir -p $MG_SRC_ROOT
-    tar -zxf /mapguide_sources/mapguide-checkout.tar.gz -C $MG_SRC_ROOT
+    tar -zxf /mapguide_sources/$MG_TARBALL -C $MG_SRC_ROOT
 fi
 echo [provision]: svn update FDO
 BUILD_COMPONENT="svn update FDO"
@@ -207,6 +221,8 @@
     echo [provision]: Applying MapGuide source patches
     cp -R /mapguide_sources/patches/mapguide/* $MG_SRC
 fi
+echo [provision]: Making sure swig is executable
+chmod +x $MG_SRC/Oem/SWIGEx/Linux/swig
 cd ~/scripts
 BUILD_COMPONENT="FDO"
 sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
@@ -214,27 +230,64 @@
 BUILD_COMPONENT="MapGuide"
 sudo -E ./build.sh 2>&1 | tee ~/mapguide_build.log
 check_build
+FDO_REV=`svn info $FDO_SRC | perl revnum.pl`
+MG_REV=`svn info $MG_SRC | perl revnum.pl`
+> ~/unit_test_status.log
+if [ $FDO_UNIT_TEST -eq 1 ];
+then
+    echo [provision]: Unit test FDO
+    BUILD_COMPONENT="Unit Test FDO Core"
+    cd $SCRIPT_ROOT/fdo_build_area/Fdo/UnitTest
+    sudo ./UnitTest 2>&1 | tee ~/fdo_core_unit_test.log
+    check_test
+    BUILD_COMPONENT="Unit Test SHP Provider"
+    cd $SCRIPT_ROOT/fdo_build_area/Providers/SHP/Src/UnitTest
+    sudo ./UnitTest 2>&1 | tee ~/fdo_shp_unit_test.log
+    check_test
+    BUILD_COMPONENT="Unit Test SDF Provider"
+    cd $SCRIPT_ROOT/fdo_build_area/Providers/SDF/Src/UnitTest
+    sudo ./UnitTest 2>&1 | tee ~/fdo_sdf_unit_test.log
+    check_test
+    BUILD_COMPONENT="Unit Test SQLite Provider"
+    cd $SCRIPT_ROOT/fdo_build_area/Providers/SQLite/Src/UnitTest
+    sudo ./UnitTest 2>&1 | tee ~/fdo_sqlite_unit_test.log
+    check_test
+    BUILD_COMPONENT="Unit Test GDAL Provider"
+    cd $SCRIPT_ROOT/fdo_build_area/Providers/GDAL/Src/UnitTest
+    sudo ./UnitTest 2>&1 | tee ~/fdo_gdal_unit_test.log
+    check_test
+    BUILD_COMPONENT="Unit Test WMS Provider"
+    cd $SCRIPT_ROOT/fdo_build_area/Providers/WMS/Src/UnitTest
+    sudo ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
+    check_test
+fi
 if [ $MG_UNIT_TEST -eq 1 ];
 then
     echo [provision]: Unit test MapGuide
+    BUILD_COMPONENT="Unit Test MapGuide Server"
     cd $SCRIPT_ROOT/mgdev
     sudo make check 2>&1 | tee ~/mapguide_unit_test.log
+    check_test
 fi
 cd $SCRIPT_ROOT
 sudo mkdir -p /vagrant/build
 sudo mv -f ~/*.log /vagrant/build
 sudo cp bin/*.tar.gz /vagrant/build
 sudo cp fdosdk*.tar.gz /vagrant/build
+sudo cp ~/unit_test_status.log /vagrant/build/unit_test_status.log
+sudo cp /vagrant/mginstallcentos.sh /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_REV=0/FDOVER_REV='"$FDO_REV"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_REV=0/MGVER_REV='"$MG_REV"'/g' /vagrant/build/mginstallcentos.sh
 if [ ! -d /mapguide_sources/updated ]; then
     sudo mkdir -p /mapguide_sources/updated
-    cd ~/mapguide/trunk
+    cd $MG_SRC_ROOT
     echo [provision]: Updating mapguide source tarball
-    tar -zcf mapguide-checkout.tar.gz MgDev
-    sudo mv mapguide-checkout.tar.gz /mapguide_sources/updated
-    cd ~/fdo
+    tar -zcf $MG_TARBALL MgDev
+    sudo mv $MG_TARBALL /mapguide_sources/updated
+    cd $FDO_SRC_ROOT
     echo [provision]: Updating fdo source tarball
-    tar -zcf fdo-checkout.tar.gz trunk
-    sudo mv fdo-checkout.tar.gz /mapguide_sources/updated
+    tar -zcf $FDO_TARBALL $FDO_SRC_DIR
+    sudo mv $FDO_TARBALL /mapguide_sources/updated
 else
     echo [provision]: Updated tarballs already exist. Doing nothing
 fi
Modified: branches/2.6/vagrant/centos/x86/Vagrantfile
--- branches/2.6/vagrant/centos/x86/Vagrantfile	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/centos/x86/Vagrantfile	2014-05-12 12:17:02 UTC (rev 8125)
 		exit $error
 	fi
+check_test()
+	error=$?
+	fi
 else
 HAVE_FDO_LIBS=0
 HAVE_MAPGUIDE=0
 MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
-FDO_SRC_ROOT=~/fdo
+FDO_VER_MM=3.9
+MG_VER_MM=2.6
+FDO_SRC_DIR=3.9
 if [ -d $FDO_SRC ];
 then
     HAVE_FDO=1
@@ -158,8 +172,8 @@
 then
     HAVE_MAPGUIDE=1
 fi
 fi
 then
-    mkdir -p ~/fdo
 fi
 then
 fi
@@ -207,6 +221,8 @@
 fi
 cd ~/scripts
 check_build
+then
+    check_test
+    check_test
+    check_test
+    check_test
+    check_test
+    check_test
+fi
 then
+    check_test
 fi
 cd $SCRIPT_ROOT
+    cd $MG_SRC_ROOT
-    cd ~/fdo
+    cd $FDO_SRC_ROOT
 else
 fi
Modified: branches/2.6/vagrant/clean.bat
--- branches/2.6/vagrant/clean.bat	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/clean.bat	2014-05-12 12:17:02 UTC (rev 8125)
@@ -1,6 +1,9 @@
 @echo off
 SET ROOT=%CD%
 SET COMPONENT=
+pushd sources
+rd /S /Q updated
+popd
 pushd ubuntu\x86
 SET COMPONENT=Ubuntu Build 32-bit
 echo [clean]: MapGuide Ubuntu build 32-bit
Modified: branches/2.6/vagrant/scripts/build.sh
--- branches/2.6/vagrant/scripts/build.sh	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/scripts/build.sh	2014-05-12 12:17:02 UTC (rev 8125)
@@ -5,6 +5,7 @@
 BUILDNUM=${APIVERSION}.0
 BUILDROOT=`pwd`
 MGCPUPLATFORM=i386
+MGDEBUG=0
 INSTALLROOT=/usr/local/mapguideopensource-${BUILDNUM}
 #INSTALLROOT=/usr/local/mapguideopensource-trunk
 LOCKFILEDIR=/var/lock/mgserver
@@ -16,7 +17,7 @@
 SVNROOT=/home/vagrant
 #SVNROOT="svn://svn.bld.mgproto.net"
 #SVNROOT="http://svn.osgeo.org"
-SVNRELPATH=/mapguide/trunk/MgDev
+SVNRELPATH=/mapguide/branches/2.6/MgDev
 MY_MAKE_OPTS="-j 2"
 UBUNTU=0
 PRESERVE_BUILD_ROOT=1
@@ -26,6 +27,7 @@
 echo " SVN Source is: ${SVNROOT}${SVNRELPATH}"
 echo " Make Options: ${MY_MAKE_OPTS}"
 echo " Is Ubuntu?: ${UBUNTU}"
+echo " Debug Build?: ${MGDEBUG}"
 echo " Preserving the build dir?: ${PRESERVE_BUILD_ROOT}"
 echo " JAVA_HOME: ${JAVA_HOME}"
 echo "******************************************************************"
@@ -61,7 +63,7 @@
 then
     if [ ! -d ${MGSOURCE} ];
     then
-    	echo "Build root ${MGSOURCE} does not exist. Doing svn export"
+        echo "Build root ${MGSOURCE} does not exist. Doing svn export"
     fi
     echo "Exporting svn revision ${REVISION}"
     if [ ${LOCALSVN} -eq 1 ]
@@ -69,15 +71,53 @@
         echo "Making local SVN copy of ${SVNROOT}${SVNRELPATH} to ${MGSOURCE}"
         cp -R ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
         echo "Cleaning out .svn directories"
-	pushd ${MGSOURCE}
+    pushd ${MGSOURCE}
         find . -name .svn -exec rm -rf {} \;
-	popd
+    popd
     else
         echo "Performing fresh SVN export of ${SVNROOT}${SVNRELPATH} (r${REVISION}) to ${MGSOURCE}"
         svn export -q -r ${REVISION} ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
     fi
 fi
+if [ ${UBUNTU} -eq 1 ];
+then
+    echo "[info]: Performing Ubuntu-specific modifications"
+    # GCC 4.8 is causing too much instability, so downgrade one version
+    #GCCVER=4.7
+    #export GCCVER
+    #CC=gcc-$GCCVER
+    #export CC
+    #CXX=g++-$GCCVER
+    #export CXX
+    #echo "[info]: Using GCC $GCCVER for Ubuntu"
+    # Patch some build scripts and makefiles to accept our chosen compiler
+    # CS-Map Dictionary Compiler
+    #echo "[info]: Patch CS-Map compiler makefile"
+    #sed -i 's/gcc \$/'"$CC"' \$/g' ${MGSOURCE}/Oem/CsMap/Dictionaries/Compiler.mak
+    #sed -i 's/gcc -v/'"$CC"' -v/g' ${MGSOURCE}/Oem/CsMap/Dictionaries/Compiler.mak
+    # libpng makefile
+    #echo "[info]: Patch libpng makefile"
+    #sed -i 's/CC=cc/CC='"$CC"'/g' ${MGSOURCE}/Oem/gd/lpng/scripts/makefile.std
+    # AGG 2.4 Linux Makefile
+    #echo "[info]: Replace agg-2.4 makefile"
+    #echo "AGGLIBS= -lagg " > ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+    #echo "AGGCXXFLAGS = -O3 -I/usr/X11R6/include -L/usr/X11R6/lib" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+    #echo "CXX = $CXX" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+    #echo "C = $CC" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+    #echo "LIB = ar cr" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+    #echo "" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+    #echo ".PHONY : clean" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+else
+    echo "[info]: Performing CentOS-specific modifications"
+    sed -i 's/sh .\/buildall.sh/sh .\/buildall.sh --with-xerces-conf=--enable-transcoder-iconv/g' ${MGSOURCE}/build_oem.sh
+    sed -i 's/sh .\/buildall.sh --with-xerces-conf=--enable-transcoder-iconv --clean/sh .\/buildall.sh --clean/g' ${MGSOURCE}/build_oem.sh
+fi
 start_time=`date +%s`
 echo "Building Revision ${BUILDNUM}.${REVISION}"
@@ -98,9 +138,15 @@
 echo "Building Oem"
 BUILD_COMPONENT="Oem"
-./build_oem.sh --prefix ${INSTALLROOT}
-check_build
+if [ ${MGDEBUG} -eq 1 ]; then
+    ./build_oem.sh --prefix ${INSTALLROOT} --config debug
+    check_build
+else
+    check_build
+fi
 echo "Building Fusion"
 pushd ${MGSOURCE}/Oem/fusion
 BUILD_COMPONENT="Fusion"
@@ -117,10 +163,18 @@
 autoconf
 if [ $(uname -m) = "x86_64" ]; then
     MGCPUPLATFORM=amd64
-    ./configure --enable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+    if [ ${MGDEBUG} -eq 1 ]; then
+        ./configure --disable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+    else
+        ./configure --enable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+    fi
 else
     MGCPUPLATFORM=i386
-    ./configure --enable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+        ./configure --disable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+    else
+        ./configure --enable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+    fi
 fi
 make $MY_MAKE_OPTS
 check_build
Modified: branches/2.6/vagrant/scripts/build_fdo.sh
--- branches/2.6/vagrant/scripts/build_fdo.sh	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/scripts/build_fdo.sh	2014-05-12 12:17:02 UTC (rev 8125)
@@ -7,6 +7,8 @@
 # Modify setenvironment.sh to point to the correct Oracle, MySQL and PostgreSQL paths
 # before building
+FDO_DEBUG=0
 FDO_BUILD_COMPONENT=
 # FDO version. Make sure this matches your FDO build source
@@ -14,6 +16,14 @@
 FDO_VER_MINOR=9
 FDO_VER_REV=0
+# Extra flags to pass to FDO build scripts
+FDO_BUILD_FLAGS=
+if [ $FDO_DEBUG -eq 1 ]; then
+    FDO_BUILD_FLAGS="--config debug"
+else
+    FDO_BUILD_FLAGS="--config release"
+fi
 UBUNTU=0
 FDO_CPU=x86
 FDO_PLATFORM=32
@@ -26,65 +36,65 @@
 check_build()
-	error=$?
-	if [ $error -ne 0 ]; then
-		echo "[error]: ${FDO_BUILD_COMPONENT} - Error build failed ($error)"
-		exit $error
-	fi
+    error=$?
+        echo "[error]: ${FDO_BUILD_COMPONENT} - Error build failed ($error)"
+        exit $error
+    fi
 check_fdo_lib()
-	libname=$1-${FDO_VER_FULL}.so
-	libpath=${FDO_INST}/lib/${libname}
-	if [ ! -e ${libpath} ]; then
-		echo "[error]: Error building ${libname}"
-		exit 1
-	fi
+    libname=$1-${FDO_VER_FULL}.so
+    libpath=${FDO_INST}/lib/${libname}
+    if [ ! -e ${libpath} ]; then
+        echo "[error]: Error building ${libname}"
+        exit 1
+    fi
 save_current_file_list()
-	echo "[info]: Saving current FDO dir file list"
-	pushd $FDO_INST
-	# For lazy folks who build from svn working copies instead of svn exports, we need to weed out any .svn dirs before compiling the file-list
-	find . -name .svn -exec rm -rf {} \;
-	find . -type f -print > ${FDO_FILELIST}/temp.lst
-	find . -type l -print >> ${FDO_FILELIST}/temp.lst
-	sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/orig.lst
-	find . -type d -print | sort > ${FDO_FILELIST}/origdir.lst
-	popd
+    echo "[info]: Saving current FDO dir file list"
+    pushd $FDO_INST
+    # For lazy folks who build from svn working copies instead of svn exports, we need to weed out any .svn dirs before compiling the file-list
+    find . -name .svn -exec rm -rf {} \;
+    find . -type f -print > ${FDO_FILELIST}/temp.lst
+    find . -type l -print >> ${FDO_FILELIST}/temp.lst
+    sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/orig.lst
+    find . -type d -print | sort > ${FDO_FILELIST}/origdir.lst
+    popd
 update_fdocore_file_list()
-	echo "[info]: Updating FDO core file list for deb packaging"
-	pushd $FDO_INST
-	sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/fdocore.lst
-	find . -type d -print | sort > ${FDO_FILELIST}/fdocoredir.lst
-	popd
+    echo "[info]: Updating FDO core file list for deb packaging"
+    pushd $FDO_INST
+    sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/fdocore.lst
+    find . -type d -print | sort > ${FDO_FILELIST}/fdocoredir.lst
+    popd
 update_provider_file_list()
-	PROVIDER=$1
-	echo "[info]: Updating $PROVIDER file list for deb packaging"
-	pushd $FDO_INST
-	#mkdir -p $BUILDLIST
-	cat ${FDO_FILELIST}/orig.lst >> ${FDO_FILELIST}/temp.lst
-	sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}.lst
-	find . -type d -print | sort > ${FDO_FILELIST}/temp.lst
-	cat ${FDO_FILELIST}/origdir.lst >> ${FDO_FILELIST}/temp.lst
-	sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}dir.lst
-	popd
+    PROVIDER=$1
+    echo "[info]: Updating $PROVIDER file list for deb packaging"
+    pushd $FDO_INST
+    #mkdir -p $BUILDLIST
+    cat ${FDO_FILELIST}/orig.lst >> ${FDO_FILELIST}/temp.lst
+    sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}.lst
+    find . -type d -print | sort > ${FDO_FILELIST}/temp.lst
+    cat ${FDO_FILELIST}/origdir.lst >> ${FDO_FILELIST}/temp.lst
+    sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}dir.lst
+    popd
 BUILDROOT=`pwd`
@@ -93,7 +103,7 @@
 CMAKE=0
-FDO_SRC=/home/vagrant/fdo/trunk
+FDO_SRC=/home/vagrant/fdo/branches/3.9
 #FDO_SRC=http://svn.osgeo.org/fdo/trunk
 FDO_BUILD_AREA=${BUILDROOT}/fdo_build_area
 FDO_FILELIST=${FDO_BUILD_AREA}/install/filelist
@@ -160,21 +170,30 @@
     then
         echo "[info]: Updating setenvironment.sh"
-	    sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/vagrant\/fdo_rdbms_thirdparty_system\/mysql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
-	    sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/vagrant\/fdo_rdbms_thirdparty_system\/pgsql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
+        sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/vagrant\/fdo_rdbms_thirdparty_system\/mysql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
+        sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/vagrant\/fdo_rdbms_thirdparty_system\/pgsql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
+        # Also need to patch some FDO thirdparty build scripts to accept our non-default compiler
+        #echo "[info]: Patching mkcatdefs build script"
+        #sed -i 's/gcc -DLINUX -g/'"$CC"' -DLINUX -g/g' ${FDO_BUILD_AREA}/Thirdparty/linux/mkcatdefs/src/build
+        #echo "[info]: Patching xalan/xerces build script"
+        #sed -i 's/.\/runConfigure -p linux -P/.\/runConfigure -p linux -c '"$CC"' -x '"$CXX"' -P/g' ${FDO_BUILD_AREA}/Thirdparty/apache/build2.sha
+        #echo "[info]: Patching boost build script"
+        #sed -i 's/# using gcc : 3.2 : g++-3.2 ;/using gcc : '"$GCCVER"' : '"$CXX"' ;/g' ${FDO_BUILD_AREA}/Thirdparty/boost/tools/build/v2/user-config.jam
+        #sed -i 's/.\/b2 toolset=gcc/.\/b2 toolset='"$CC"'/g' ${FDO_BUILD_AREA}/Thirdparty/boost/build.sh
     else
-	    # Note: Change your paths here if they're different
-	    sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/mysql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
-	    sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/pgsql/g' ${FDO_BUILD_AREA}/setenvironment.sh
+        # Note: Change your paths here if they're different
+        sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/mysql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
+        sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/pgsql/g' ${FDO_BUILD_AREA}/setenvironment.sh
     fi
-	echo "export FDOORACLE=/home/vagrant/fdo_rdbms_thirdparty/oracle/${FDO_CPU}/instantclient_11_2/sdk" >> ${FDO_BUILD_AREA}/setenvironment.sh
+    echo "export FDOORACLE=/home/vagrant/fdo_rdbms_thirdparty/oracle/${FDO_CPU}/instantclient_11_2/sdk" >> ${FDO_BUILD_AREA}/setenvironment.sh
 # Must have root
 if [[ $EUID -ne 0 ]]; then
-	echo "[error]: You must run this script with superuser privileges"
-	exit 1
+    echo "[error]: You must run this script with superuser privileges"
+    exit 1
 fi
 echo "***********************************************************"
@@ -184,6 +203,7 @@
 echo " FDO CPU Target: ${FDO_BUILD_CPU}"
 echo " CMake build: ${CMAKE}"
+echo " Debug build: ${FDO_DEBUG}"
 echo " Export from local SVN checkout: ${LOCALSVN}"
 echo " Re-use previous build area: ${PRESERVE_BUILD_ROOT}"
@@ -192,55 +212,63 @@
 then
+    #GCCVER=4.7
+    #export GCCVER
+    #CC=gcc-$GCCVER
+    #export CC
+    #CXX=g++-$GCCVER
+    #export CXX
     shim_thirdparty_lib_paths
 fi
 if [ -d ${FDO_INST} ];
 then
-	echo "[info]: Deleting directory ${FDO_INST} before build"
-	rm -rf ${FDO_INST}
+    echo "[info]: Deleting directory ${FDO_INST} before build"
+    rm -rf ${FDO_INST}
 else
-	echo "[info]: ${FDO_INST} doesn't exist. Continuing build"
+    echo "[info]: ${FDO_INST} doesn't exist. Continuing build"
 fi
 if [ ${CMAKE} -eq 1 ];
 then
-	echo "[error]: CMake build of FDO not supported yet"
-	exit 1
+    echo "[error]: CMake build of FDO not supported yet"
+    exit 1
 else
-	echo "[info]: Using automake build"
-	if [ -d ${FDO_BUILD_AREA} ];
-	then
-		if [ ${PRESERVE_BUILD_ROOT} -eq 1 ];
-		then
-			echo "[info]: FDO build area ${FDO_BUILD_AREA} exists. Going straight to build"
-			modify_sdk_paths
-		else
-			echo "[info]: Removing old FDO build area at ${FDO_BUILD_AREA}"
-			rm -rf ${FDO_BUILD_AREA}
-			if [ ${LOCALSVN} -eq 1 ]
-			then
-				svn export -q ${FDO_SRC} ${FDO_BUILD_AREA}
-				modify_sdk_paths
-			else
-				echo "[info]: Performing fresh SVN export of ${FDO_SRC} (r${REVISION}) to ${FDO_BUILD_AREA}"
-				svn export -q -r ${REVISION} ${FDO_SRC} ${FDO_BUILD_AREA}
-				modify_sdk_paths
-			fi
-		fi
-	else
-		echo "[info]: FDO build area ${FDO_BUILD_AREA} does not exist. Doing svn export"
-		echo "[info]: Exporting svn revision ${REVISION}"
-		then
-			modify_sdk_paths
-		else
-			modify_sdk_paths
-		fi
-	fi
+    echo "[info]: Using automake build"
+    if [ -d ${FDO_BUILD_AREA} ];
+    then
+        if [ ${PRESERVE_BUILD_ROOT} -eq 1 ];
+        then
+            echo "[info]: FDO build area ${FDO_BUILD_AREA} exists. Going straight to build"
+            modify_sdk_paths
+        else
+            echo "[info]: Removing old FDO build area at ${FDO_BUILD_AREA}"
+            rm -rf ${FDO_BUILD_AREA}
+            if [ ${LOCALSVN} -eq 1 ]
+            then
+                svn export -q ${FDO_SRC} ${FDO_BUILD_AREA}
+                modify_sdk_paths
+            else
+                echo "[info]: Performing fresh SVN export of ${FDO_SRC} (r${REVISION}) to ${FDO_BUILD_AREA}"
+                svn export -q -r ${REVISION} ${FDO_SRC} ${FDO_BUILD_AREA}
+                modify_sdk_paths
+            fi
+        fi
+    else
+        echo "[info]: FDO build area ${FDO_BUILD_AREA} does not exist. Doing svn export"
+        echo "[info]: Exporting svn revision ${REVISION}"
+        then
+            modify_sdk_paths
+        else
+            modify_sdk_paths
+        fi
+    fi
 fi
 echo "[info]: Building FDO (${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}) rev (${REVISION})"
@@ -248,35 +276,36 @@
 source ./setenvironment.sh
 if [ ! -d ${FDO_INST} ];
 then
-	echo "[error]: FDO install directory ${FDO_INST} doesn't exist. setenvironment.sh should've created this directory. Ensure the FDO version number in this script is correct"
-	exit 1;
+    echo "[error]: FDO install directory ${FDO_INST} doesn't exist. setenvironment.sh should've created this directory. Ensure the FDO version number in this script is correct"
+    exit 1;
 fi
 FDO_BUILD_COMPONENT="FDO Thirdparty"
-./build_thirdparty.sh -b ${FDO_PLATFORM}
+./build_thirdparty.sh -b ${FDO_PLATFORM} ${FDO_BUILD_FLAGS}
 check_build
 then
-	FDO_BUILD_COMPONENT="FDO (cmake)"
-	exit 1;
+    FDO_BUILD_COMPONENT="FDO (cmake)"
+    exit 1;
 else
-	#NOTE: We never build ArcSDE provider because we haven't paid the ESRI tax for their ArcSDE SDK
-	for comp in fdocore fdo utilities
-	do
-		FDO_BUILD_COMPONENT="$comp (automake)"
-		./build_linux.sh --w $comp --p ${FDO_INST} --b ${FDO_PLATFORM}
-		update_fdocore_file_list
-		check_build
-	done
-	for comp in shp sqlite gdal ogr wfs wms rdbms kingoracle sdf
-	do
-		save_current_file_list
-		update_provider_file_list $comp
-		check_build
-	done
+    #NOTE: We never build ArcSDE provider because we haven't paid the ESRI tax for their ArcSDE SDK
+    for comp in fdocore fdo utilities
+    do
+        FDO_BUILD_COMPONENT="$comp (automake)"
+        ./build_linux.sh --w $comp --p ${FDO_INST} --b ${FDO_PLATFORM} ${FDO_BUILD_FLAGS}
+        update_fdocore_file_list
+        check_build
+    done
+    for comp in shp sqlite gdal ogr wfs wms rdbms kingoracle sdf
+    do
+        save_current_file_list
+        update_provider_file_list $comp
+        check_build
+    done
 fi
 check_fdo_lib libFDO
 check_fdo_lib libExpressionEngine
@@ -302,32 +331,37 @@
 end_time=`date +%s`
-FDO_BUILD_COMPONENT="Remove .la files from ${FDO_INST}"
-# Remove .la files from lib directory
-rm -f ${FDO_INST}/lib/*.la
-check_build
+if [ $FDO_DEBUG -eq 0 ];
+then
+    FDO_BUILD_COMPONENT="Remove .la files from ${FDO_INST}"
+    # Remove .la files from lib directory
+    rm -f ${FDO_INST}/lib/*.la
+    check_build
-FDO_BUILD_COMPONENT="Strip so symbols and remove execute flag"
-# Remove unneeded symbols from files in the lib directory
-# and make them non-executable
-for file in `find ${FDO_INST}/lib/lib*.so* -type f -print`
-do
-	strip --strip-unneeded ${file}
-	chmod a-x ${file}
-done
-check_build
+    FDO_BUILD_COMPONENT="Strip so symbols and remove execute flag"
+    # Remove unneeded symbols from files in the lib directory
+    # and make them non-executable
+    for file in `find ${FDO_INST}/lib/lib*.so* -type f -print`
+    do
+        strip --strip-unneeded ${file}
+        chmod a-x ${file}
+    done
+    check_build
-cd $BUILDROOT
-FDO_BUILD_COMPONENT="Make tarball"
-# Create a binary tar ball for FDO
-tar -zcf fdosdk-centos6-${FDO_BUILD_CPU}-${FDO_VER_FULL}_${REVISION}.tar.gz ${FDO_INST}
-check_build
+    FDO_BUILD_COMPONENT="Make tarball"
+    # Create a binary tar ball for FDO
+    cd ${FDO_INST}
+    tar -zcf ${BUILDROOT}/fdosdk-centos6-${FDO_BUILD_CPU}-${FDO_VER_FULL}_${REVISION}.tar.gz *
+    check_build
-if [ ${UBUNTU} -eq 1 ];
-then
-cd ${FDO_BUILD_AREA}/install
-dos2unix *
-./dpkgall.sh ${FDO_BUILD_CPU} ${REVISION}
+    if [ ${UBUNTU} -eq 1 ];
+    then
+        cd ${FDO_BUILD_AREA}/install
+        dos2unix *
+        ./dpkgall.sh ${FDO_BUILD_CPU} ${REVISION}
+    fi
+else
+    echo "[info]: Not packaging FDO in debug mode"
 fi
 echo "[info]: FDO build complete!"
Deleted: branches/2.6/vagrant/scripts/build_oem_ubuntu.sh
--- branches/2.6/vagrant/scripts/build_oem_ubuntu.sh	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/scripts/build_oem_ubuntu.sh	2014-05-12 12:17:02 UTC (rev 8125)
@@ -1,653 +0,0 @@
-#! /bin/bash
-# MapGuide Open Source build script (tweaked for Ubuntu)
-# Initialization
-echo "MapGuide Open Source build script for OEM components"
-INSTALLDIR=/usr/local/mapguideopensource
-MY_MAKE_OPTS="-j 2"
-CLEAN_FLAG=0
-while [ $# -gt 0 ]; do    # Until you run out of parameters...
-    case "$1" in
-        -prefix|--prefix)
-            INSTALLDIR="$2"
-            shift
-        -clean|--clean)
-            CLEAN_FLAG=1
-            shift
-        -help|--help)
-            echo "Usage: $0 (options)"
-            echo "Options:"
-            echo "  --prefix [installation directory]"
-            echo "  --clean [clean all objects and binaries in Oem]"
-            echo "  --help [Display usage]"
-            exit
-    esac
-    shift   # Check next set of parameters.
-done
-echo "OEM Build Initialization ............................"
-echo "Oem Libraries will be installed at: ${INSTALLDIR}"
-LIB_NAME=""
-# Generic Functions
-check_build()
-    error=$?
-        echo "$LIB_NAME: Error build failed ($error)................."
-        exit $error
-    fi
-check_clean()
-    error=$?
-        echo "$LIB_NAME: Error clean failed ($error)................."
-        exit $error
-    fi
-# Build ACE 5.7
-# Notes: none
-init_ace()
-    LIB_NAME="ACE 5.7"
-build_ace()
-    pushd ACE/ACE_wrappers
-    ACE_PATH="${PWD}"
-    pushd ace
-    env ACE_ROOT="${ACE_PATH}" make $MY_MAKE_OPTS
-    check_build
-    popd
-    popd
-clean_ace()
-    ACE_PATH="${PWD}"
-    pushd ace
-    env ACE_ROOT="${ACE_PATH}" make clean
-    check_clean
-    popd
-    popd
-# Build DWFCORE 1.0
-# Notes: none
-init_dwfcore()
-    LIB_NAME="DWFCORE 1.0"
-    pushd DWFTK7.1/develop/global/build/gnu/dwfcore
-    sh ./build_setup.sh
-    popd
-build_dwfcore()
-    pushd DWFTK7.1/develop/global/src/dwfcore
-    sh ./configure --enable-optimized --prefix="${INSTALLDIR}"
-    make $MY_MAKE_OPTS
-    check_build
-    popd
-clean_dwfcore()
-    make clean
-    check_clean
-    popd
-# Build DWFTOOLKIT 7.1
-# Notes: none
-init_dwftk()
-    LIB_NAME="DWFTK 7.1"
-    pushd DWFTK7.1/develop/global/build/gnu/dwftoolkit
-    popd
-build_dwftk()
-    check_build
-    popd
-clean_dwftk()
-    make clean
-    check_clean
-    popd
-# Build DWFEMAP 1.0
-# Notes: none
-init_dwfemap()
-    LIB_NAME="DWFEMAP 1.0"
-    pushd DWFTK7.1/develop/global/build/gnu/dwfemap
-    popd
-build_dwfemap()
-    pushd DWFTK7.1/develop/global/src/dwfemap
-    check_build
-    popd
-clean_dwfemap()
-    make clean
-    check_clean
-    popd
-# Build GEOS 2.2.0
-# Notes: none
-init_geos()
-    LIB_NAME="GEOS 2.2.0"
-build_geos()
-    pushd geos-2.2.0
-    # Force regen to take into account our modified configure.in
-    aclocal -I macros
-    libtoolize --copy --force
-    autoconf
-    automake --add-missing --copy --force-missing
-    if [ $(uname -m) = "x86_64" ]; then
-        sh ./configure --with-pic --prefix="${INSTALLDIR}"
-    else
-        sh ./configure --prefix="${INSTALLDIR}"
-    fi
-    # The check build is disabled as the build will fail with automake version < 2.59
-    # check_build
-    popd
-clean_geos()
-    pushd geos-2.2.0
-    make clean
-    check_clean
-    popd
-# Build PHP 5.5.11
-# Notes: Configure PHP source tree for building PHP extension
-init_php()
-    LIB_NAME="PHP 5.5.11"
-build_php()
-    # Nothing to do here. build_apt.sh builds PHP
-    pushd LinuxApt/php-5.5.11
-    popd
-clean_php()
-    make distclean
-    check_clean
-    popd
-# Build SWIGEx 1.0
-# Notes: none
-init_swigex()
-    LIB_NAME="SWIGEx 1.0"
-build_swigex()
-    pushd SWIGEx
-    mkdir -p Linux/obj/release
-    check_build
-    popd
-clean_swigex()
-    pushd SWIGEx
-    # Note: the qmake system is required to regenerate the Makefile.
-    #       This is disabled.
-    # make clean
-    # check_clean
-    popd
-# Build BDBXML
-# Notes: none
-init_bdbxml()
-    LIB_NAME="BDBXML"
-build_bdbxml()
-    # Need to force regen of the correct xerces config header before building dbxml proper
-    pushd dbxml/xerces-c-src
-    sh ./configure
-    popd
-    # Also need to check and set executable flag for s_paths
-    pushd dbxml/dbxml/dist
-    chmod +x s_paths
-    popd
-    pushd dbxml
-    sh ./buildall.sh
-    check_build
-    popd
-clean_bdbxml()
-    pushd dbxml
-    sh ./buildall.sh --clean
-    check_clean
-    popd
-# Build CPPUNIT 1.9.14
-# Notes: none
-init_cppunit()
-    LIB_NAME="CPPUNIT 1.9.14"
-build_cppunit()
-    pushd CppUnit-1.9.14
-    # the configure script as-is is incompatible with ubuntu, so regen it
-    aclocal -I config
-    autoconf
-    # -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
-    sh ./configure --prefix="${INSTALLDIR}" LDFLAGS="-ldl"
-    check_build
-    popd
-clean_cppunit()
-    make clean
-    check_clean
-    popd
-# Build IMake 1.0
-# Notes: none
-init_imake()
-    LIB_NAME="IMake 1.0"
-build_imake()
-    pushd ../BuildTools/WebTools/IMake
-    mkdir -p Linux/obj/debug
-    check_build
-    popd
-clean_imake()
-    # Note: does not support clean as qmake is needed to regenerate the Makefile.
-    # make clean
-    # check_clean
-    popd
-# Build ZLIB 1.2.3
-# Notes: none
-init_zlib()
-    LIB_NAME="ZLIB 1.2.3"
-build_zlib()
-    pushd gd/zlib
-    sh ./configure
-    check_build
-    popd
-clean_zlib()
-    pushd gd/zlib
-    make clean
-    check_clean
-    popd
-# Build LIBPNG 1.2.8
-# Notes: none
-init_libpng()
-    LIB_NAME="LIBPNG 1.2.8"
-build_libpng()
-    pushd gd/lpng
-    cp scripts/makefile.std makefile
-        #Inject -fPIC to CFLAGS for 64-bit
-        sed 's/^CFLAGS=/CFLAGS= -fPIC /g' makefile > makefile64
-        make -fmakefile64 $MY_MAKE_OPTS
-    else
-    fi
-    check_build
-    popd
-clean_libpng()
-    pushd gd/lpng
-    make clean
-    check_clean
-    popd
-# Build JPEG 6b
-# Notes: none
-init_jpeg()
-    LIB_NAME="JPEG 6b"
-build_jpeg()
-    pushd gd/jpeg
-        sh ./configure --enable-static --disable-shared
-        #--with-pic does nothing (probably ancient configure script), so do some sed trickery
-        #to inject this flag. Know a better way? Enlighten us :)
-        sed 's/^CFLAGS=/CFLAGS= -fPIC/g' Makefile > Makefile64
-        make -fMakefile64 $MY_MAKE_OPTS
-    else
-    fi
-    check_build
-    popd
-clean_jpeg()
-    pushd gd/jpeg
-    make clean
-    check_clean
-    popd
-# Build FREETYPE 2.1.10
-# Notes: none
-init_freetype()
-    LIB_NAME="FREETYPE 2.1.10"
-build_freetype()
-    pushd gd/freetype
-        sh ./configure --enable-static --disable-shared --with-pic
-    else
-    fi
-    check_build
-    popd
-clean_freetype()
-    pushd gd/freetype
-    make clean
-    check_clean
-    popd
-# Build GD 2.0.33
-# Notes: none
-init_gd()
-    LIB_NAME="GD 2.0.33"
-build_gd()
-    pushd gd/gd
-        sh ./configure --enable-static --disable-shared --without-fontconfig --with-pic
-    else
-    fi
-    check_build
-    popd
-clean_gd()
-    pushd gd/gd
-    make clean
-    check_clean
-    popd
-# Build AGG 2.4
-# Notes: none
-init_agg()
-    LIB_NAME="AGG 2.4"
-build_agg()
-    pushd agg-2.4
-        make $MY_MAKE_OPTS EXTRACXXFLAGS=-fPIC
-    else
-    fi
-    check_build
-    popd
-clean_agg()
-    pushd agg-2.4
-    make clean
-    check_clean
-    popd
-# Build JSON
-# Notes: none
-init_json()
-    LIB_NAME="JSON"
-build_json()
-    pushd jsoncpp
-    #Use the scons installed by apt-get
-    scons platform=linux-gcc
-    popd
-clean_json()
-    pushd jsoncpp
-    rm -rf lib buildscons dist
-    popd
-# Build CSMAP
-# Notes: none
-init_csmap()
-    LIB_NAME="CSMAP"
-build_csmap()
-    pushd CsMap
-    mkdir -p .libs
-    pushd Source
-        #Need to build CS-Map with -fPIC because linking libraries will be built with -fPIC
-	sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Library64.mak
-	make -fLibrary64.mak $MY_MAKE_OPTS
-    else
-    	make -fLibrary.mak $MY_MAKE_OPTS
-    fi
-    cp CsMap.a ../.libs/libCsmap.a
-    popd
-    pushd Dictionaries
-    if [ $(uname -m) = "x86_x64" ]; then
-        sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Compiler64.mak
-	make -fCompiler64.mak $MY_MAKE_OPTS
-    else
-        make -fCompiler.mak $MY_MAKE_OPTS
-    fi
-    ./CS_Comp -b . .
-    popd
-    check_build
-    popd
-clean_csmap()
-    pushd CsMap
-    make clean
-    check_clean
-    popd
-# Script loop
-pushd Oem
-for lib in ace dwfcore dwftk dwfemap geos php swigex bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
-do
-    echo "$lib: Initialization..........................."
-    init_"$lib"
-    if test "$CLEAN_FLAG" = "1"; then
-        echo "$lib: Clean ....................................."
-        clean_"$lib"
-        echo "$lib: Clean Successful .........................."
-    else
-        echo "$lib: Configure/Build ..........................."
-        build_"$lib"
-        echo "$lib: Build Successful .........................."
-    fi
-done
-popd
Added: branches/2.6/vagrant/scripts/mginstallcentos.sh
--- branches/2.6/vagrant/scripts/mginstallcentos.sh	                        (rev 0)
+++ branches/2.6/vagrant/scripts/mginstallcentos.sh	2014-05-12 12:17:02 UTC (rev 8125)
@@ -0,0 +1,79 @@
+#!/bin/bash
+URL="http://download.osgeo.org/mapguide/releases/2.6/Beta1"
+#URL="http://192.168.0.4/downloads"
+FDOVER_MAJOR_MINOR=3.9
+FDOVER_POINT=0
+FDOVER_REV=0
+FDO_ARCH=i386
+FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.${FDOVER_POINT}
+FDOVER=${FDOVER_MAJOR_MINOR_REV}_${FDOVER_REV}
+MGVER_MAJOR_MINOR=2.6
+MGVER_POINT=0
+MGVER_REV=0
+MG_ARCH=i386
+MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.${MGVER_POINT}
+MGVER=${MGVER_MAJOR_MINOR_REV}.${MGVER_REV}
+FDO_TARBALL=fdosdk-centos6-${FDO_ARCH}-${FDOVER}.tar.gz
+MG_TARBALL=mapguideopensource-${MGVER}.${MG_ARCH}.tar.gz
+MG_URL=${URL}/${MG_TARBALL}
+FDO_URL=${URL}/${FDO_TARBALL}
+# Must have root
+if [[ $EUID -ne 0 ]]; then
+	echo "You must run this script with superuser privileges"
+	exit 1
+fi
+if [ ! -f ${FDO_TARBALL} ]; then
+wget -N ${FDO_URL}
+fi
+#tar -C / -zxvf ${FDO_TARBALL}
+mkdir -p /usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}
+tar -C /usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}/ -zxf ${FDO_TARBALL}
+if [ ! -f ${MG_TARBALL} ]; then
+wget -N ${MG_URL}
+fi
+tar -C / -zxf ${MG_TARBALL}
+# All of this is to make SELinux happy
+pushd /usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}/lib
+chcon -t textrel_shlib_t *.so
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin
+chcon -t textrel_shlib_t mgserver
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/lib
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/lib
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/lib
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/lib
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/modules
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/bin
+./apachectl start
+popd
+./mgserverd.sh
+popd
+echo DONE
Added: branches/2.6/vagrant/scripts/mginstallubuntu.sh
--- branches/2.6/vagrant/scripts/mginstallubuntu.sh	                        (rev 0)
+++ branches/2.6/vagrant/scripts/mginstallubuntu.sh	2014-05-12 12:17:02 UTC (rev 8125)
@@ -0,0 +1,344 @@
+#!/bin/bash
+TEMPDIR=/tmp/build_mapguide
+URL="http://download.osgeo.org/mapguide/releases/2.6/Beta1/ubuntu14"
+#URL="http://192.168.0.5/downloads/ubuntu14"
+FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.0
+FDOBUILD=0
+FDOARCH=i386
+FDOVER=${FDOVER_MAJOR_MINOR_REV}-${FDOBUILD}_${FDOARCH}
+MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.0
+MGBUILD=0
+MGARCH=i386
+MGVER=${MGVER_MAJOR_MINOR_REV}-${MGBUILD}_${MGARCH}
+# Must have root
+	exit 1
+fi
+# Install required packages
+apt-get -y install dialog libexpat1 libssl1.0.0 odbcinst unixodbc libcurl3 libxslt1.1
+DIALOG=${DIALOG=dialog}
+main()
+	dialog_welcome
+	dialog_fdo_provider
+	start_install
+	install_mapguide_packages
+	post_install
+dialog_welcome()
+	$DIALOG --backtitle "MapGuide Open Source Ubuntu installer" \
+	        --title "Welcome" --clear \
+        	--yesno "Welcome to the MapGuide Open Source Ubuntu installer. Would you like to proceed?" 10 30
+	case $? in
+	  1)
+		echo "Cancelled"
+		exit 1;;
+	  255)
+		echo "Cancelled"
+		exit 255;;
+	esac
+dialog_fdo_provider()
+	tempfile=`tempfile 2>/dev/null` || tempfile=/tmp/test$$
+	trap "rm -f $tempfile" 0 1 2 5 15
+	#arcsde    	"OSGeo FDO Provider for ArcSDE" off \
+	# Disable RDBMS provider selection by default
+			--title "FDO Providers" --clear \
+		    --checklist "Check the FDO Providers you want to install" 20 61 5 \
+		    sdf  		"OSGeo FDO Provider for SDF" ON \
+		    shp    		"OSGeo FDO Provider for SHP" ON \
+		    sqlite 		"OSGeo FDO Provider for SQLite" ON \
+		    gdal    	"OSGeo FDO Provider for GDAL" ON \
+   		    ogr    		"OSGeo FDO Provider for OGR" ON \
+   		    kingoracle  "OSGeo FDO Provider for Oracle" off \
+		    rdbms	"RDBMS FDO Providers (ODBC, MySQL, PostgreSQL)" off \
+   		    wfs    		"OSGeo FDO Provider for WFS" ON \
+		    wms   		"OSGeo FDO Provider for WMS" ON  2> $tempfile
+	choice=`cat $tempfile | sed s/\"//g`
+	case $? in
+	  1)
+		echo "Cancelled"
+		exit 1;;
+	  255)
+		echo "Cancelled"
+		exit 255;;
+	esac
+start_install()
+	# set initial registration state
+	arcsde_registered=0
+	gdal_registered=0
+	kingoracle_registered=0
+	rdbms_registered=0
+	ogr_registered=0
+	sdf_registered=0
+	shp_registered=0
+	sqlite_registered=0
+	wfs_registered=0
+	wms_registered=0
+	# Include core and rdbms packages regardless of choice.
+	choice="core rdbms $choice"
+	# Download and install Ubuntu packages for FDO
+	for file in $choice
+	do
+	  #echo "Downloading ${URL}/fdo-${file}_${FDOVER}.deb"
+	  wget -N ${URL}/fdo-${file}_${FDOVER}.deb
+	  #echo "Installing fdo-${file}_${FDOVER}.deb"
+  	  dpkg -E -G --install fdo-${file}_${FDOVER}.deb
+	done
+	# Nuke the old providers.xml, we're rebuiding it
+	providersxml=/usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}/lib/providers.xml
+	echo -ne "<?xml version=\"1.0\" encoding=\"utf-8\" standalone=\"no\" ?>" > ${providersxml}
+	echo -ne "\n<FeatureProviderRegistry>" >> ${providersxml}
+	do
+		case $file in
+		  arcsde)
+			if [ $arcsde_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering ArcSDE Provider"
+			echo -ne "\n  <FeatureProvider>" >> ${providersxml}
+			echo -ne "\n    <Name>OSGeo.ArcSDE.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for ArcSDE</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>Read/write access to an ESRI ArcSDE-based data store, using Oracle and SQL Server</Description>" >> ${providersxml}
+			echo -ne "\n    <IsManaged>False</IsManaged>" >> ${providersxml}
+			echo -ne "\n    <Version>${FDOVER_MAJOR_MINOR_REV}.0</Version>" >> ${providersxml}
+			echo -ne "\n    <FeatureDataObjectsVersion>${FDOVER_MAJOR_MINOR_REV}.0</FeatureDataObjectsVersion>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libArcSDEProvider.so</LibraryPath>" >> ${providersxml}
+			echo -ne "\n  </FeatureProvider>" >> ${providersxml}
+			arcsde_registered=1
+		  gdal)
+			if [ $gdal_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering GDAL Provider"
+			echo -ne "\n    <Name>OSGeo.Gdal.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for GDAL</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>FDO Provider for GDAL</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libGRFPProvider.so</LibraryPath>" >> ${providersxml}
+			gdal_registered=1
+		  kingoracle)
+			if [ $kingoracle_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering King Oracle Provider"
+			echo -ne "\n    <Name>OSGeo.KingOracle.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for Oracle</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>Read/write access to spatial and attribute data in Oracle Spatial</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libKingOracleProvider.so</LibraryPath>" >> ${providersxml}
+			kingoracle_registered=1
+		  rdbms)
+			if [ $rdbms_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering ODBC Provider"
+			echo -ne "\n    <Name>OSGeo.ODBC.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for ODBC</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>FDO Provider for ODBC</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libFdoODBC.so</LibraryPath>" >> ${providersxml}
+			echo "Registering PostgreSQL Provider"
+			echo -ne "\n    <Name>OSGeo.PostgreSQL.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for PostgreSQL</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>Read/write access to PostgreSQL/PostGIS-based data store. Supports spatial data types and spatial query operations</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libFdoPostgreSQL.so</LibraryPath>" >> ${providersxml}
+			echo "Registering MySQL Provider"
+			echo -ne "\n    <Name>OSGeo.MySQL.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for MySQL</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>FDO Provider for MySQL</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libFdoMySQL.so</LibraryPath>" >> ${providersxml}
+			rdbms_registered=1
+		  ogr)
+			if [ $ogr_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering OGR Provider"
+			echo -ne "\n    <Name>OSGeo.OGR.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for OGR</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>FDO Access to OGR Data Sources</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libOGRProvider.so</LibraryPath>" >> ${providersxml}
+			ogr_registered=1
+		  sdf)
+			if [ $sdf_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering SDF Provider"
+			echo -ne "\n    <Name>OSGeo.SDF.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for SDF</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>Read/write access to Autodesk's spatial database format, a file-based geodatabase that supports multiple features/attributes, spatial indexing and file-locking</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libSDFProvider.so</LibraryPath>" >> ${providersxml}
+			sdf_registered=1
+		  shp)
+			if [ $shp_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering SHP Provider"
+			echo -ne "\n    <Name>OSGeo.SHP.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for SHP</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>Read/write access to spatial and attribute data in an ESRI SHP file</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libSHPProvider.so</LibraryPath>" >> ${providersxml}
+			shp_registered=1
+		  sqlite)
+			if [ $sqlite_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering SQLite Provider"
+			echo -ne "\n    <Name>OSGeo.SQLite.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for SQLite</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>Read/write access to feature data in a SQLite file</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libSQLiteProvider.so</LibraryPath>" >> ${providersxml}
+			sqlite_registered=1
+		  wfs)
+			if [ $wfs_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering WFS Provider"
+			echo -ne "\n    <Name>OSGeo.WFS.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for WFS</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>Read access to OGC WFS-based data store</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libWFSProvider.so</LibraryPath>" >> ${providersxml}
+			wfs_registered=1
+		  wms)
+			if [ $wms_registered -eq 1 ];
+			then
+				continue
+			fi
+			echo "Registering WMS Provider"
+			echo -ne "\n    <Name>OSGeo.WMS.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+			echo -ne "\n    <DisplayName>OSGeo FDO Provider for WMS</DisplayName>" >> ${providersxml}
+			echo -ne "\n    <Description>Read access to OGC WMS-based data store</Description>" >> ${providersxml}
+			echo -ne "\n    <LibraryPath>libWMSProvider.so</LibraryPath>" >> ${providersxml}
+			wms_registered=1
+		esac
+	done
+	echo -ne "\n</FeatureProviderRegistry>" >> ${providersxml}
+install_mapguide_packages()
+	# Download Ubuntu packages for MapGuide
+	for file in common server webextensions httpd
+	do
+	  echo "Downloading: ${URL}/mapguideopensource-${file}_${MGVER}.deb"
+	  wget -N ${URL}/mapguideopensource-${file}_${MGVER}.deb
+ 	  echo "Installing: mapguideopensource-${file}_${MGVER}.deb"
+   	  dpkg -E -G --install mapguideopensource-${file}_${MGVER}.deb
+	done
+post_install()
+	echo "Creating lock file directory for MapGuide Server"
+	# Create lock file directory for Server
+	if [ ! -d /var/lock/mgserver ]; then
+	  mkdir /var/lock/mgserver
+	fi
+	echo "Starting httpd"
+	pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/bin
+	./apachectl start
+	popd
+	echo "Starting mgserver"
+	pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin
+	./mgserverd.sh
+	popd
+	echo "DONE!"
+# Create temporary download directory
+mkdir -p ${TEMPDIR}
+pushd ${TEMPDIR}
+main
+popd
\ No newline at end of file
Added: branches/2.6/vagrant/scripts/mguninstallubuntu.sh
--- branches/2.6/vagrant/scripts/mguninstallubuntu.sh	                        (rev 0)
+++ branches/2.6/vagrant/scripts/mguninstallubuntu.sh	2014-05-12 12:17:02 UTC (rev 8125)
@@ -0,0 +1,21 @@
+#!/bin/bash
+# Must have root
+	exit 1
+fi
+# Remove Ubuntu packages for MapGuide
+for file in server webextensions httpd common
+do
+  dpkg --remove mapguideopensource-${file}
+done
+# Remove Ubuntu packages for FDO
+for file in gdal kingoracle ogr rdbms sdf shp sqlite wfs wms arcsde core
+do
+  dpkg --remove fdo-${file}
+done
Modified: branches/2.6/vagrant/sources/patches/patchinfo.txt
--- branches/2.6/vagrant/sources/patches/patchinfo.txt	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/sources/patches/patchinfo.txt	2014-05-12 12:17:02 UTC (rev 8125)
@@ -1,2 +1 @@
-http://trac.osgeo.org/csmap/ticket/172
-http://trac.osgeo.org/fdo/ticket/888
+No custom patches required
Modified: branches/2.6/vagrant/ubuntu/x64/Vagrantfile
--- branches/2.6/vagrant/ubuntu/x64/Vagrantfile	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/ubuntu/x64/Vagrantfile	2014-05-12 12:17:02 UTC (rev 8125)
@@ -10,7 +10,7 @@
   # please see the online documentation at vagrantup.com.
   # Every Vagrant virtual environment requires a box to build off of.
-  config.vm.box = "vagrant-trusty64"
+  config.vm.box = "vagrant-precise64"
   # The url from where the 'config.vm.box' box will be fetched if it
   # doesn't already exist on the user's system.
 		exit $error
 	fi
+check_test()
+	error=$?
+	fi
 cd ~
 echo [provision]: Home directory is `pwd`
 echo [provision]: Checking directories
@@ -133,12 +141,18 @@
 HAVE_FDO_LIBS=0
 HAVE_MAPGUIDE=0
 MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
-FDO_SRC_ROOT=~/fdo
+FDO_VER_MM=3.9
+MG_VER_MM=2.6
+FDO_SRC_DIR=3.9
 if [ -d $FDO_SRC ];
 then
     HAVE_FDO=1
@@ -159,8 +173,8 @@
     sudo mkdir -p /usr/include/asm
     sudo cp /mapguide_sources/atomic.h /usr/include/asm
 fi
-echo [provision]: Checking libraries
-sudo apt-get install -y libpq-dev libmysqlclient-dev
+#echo [provision]: Checking libraries
+#sudo apt-get install -y libpq-dev libmysqlclient-dev
@@ -180,26 +194,26 @@
 fi
 then
-    mkdir -p ~/fdo
 fi
 then
 fi
 # Only for this VM, svn is 1.8 so we have to upgrade the WC first before it can be updated
-svn upgrade $FDO_SRC
+#svn upgrade $FDO_SRC
 svn update $FDO_SRC
 check_build
 echo [provision]: svn update MapGuide
 BUILD_COMPONENT="svn update MapGuide"
-svn upgrade $MG_SRC
+#svn upgrade $MG_SRC
 svn update $MG_SRC
 check_build
 if [ -d /mapguide_sources/patches/fdo ];
@@ -221,21 +235,57 @@
 check_build
 BUILD_COMPONENT="MapGuide deb packages"
 sudo ./dpkgmapguide.sh amd64 $MG_REV
 check_build
+then
+    check_test
+    check_test
+    check_test
+    check_test
+    check_test
+    check_test
+fi
 then
+    check_test
 fi
 cd $SCRIPT_ROOT
 sudo cp fdo_build_area/install/bin/*.deb /vagrant/build
 sudo cp bin/*.deb /vagrant/build
+sudo cp /vagrant/mginstallubuntu.sh /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOBUILD=0/FDOBUILD='"$FDO_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGBUILD=0/MGBUILD='"$MG_REV"'/g' /vagrant/build/mginstallubuntu.sh
 # Do not update the working copy tarballs. Ubuntu 14.04 uses svn 1.8 which will break
 # the working copy if copied over to a CentOS VM (which is still on 1.6)
@@ -243,14 +293,14 @@
 #if [ ! -d /mapguide_sources/updated ]; then
 #    sudo mkdir -p /mapguide_sources/updated
-#    cd ~/mapguide/trunk
+#    cd $MG_SRC_ROOT
 #    echo [provision]: Updating mapguide source tarball
-#    tar -zcf mapguide-checkout.tar.gz MgDev
-#    sudo mv mapguide-checkout.tar.gz /mapguide_sources/updated
-#    cd ~/fdo
+#    tar -zcf $MG_TARBALL MgDev
+#    sudo mv $MG_TARBALL /mapguide_sources/updated
+#    cd $FDO_SRC_ROOT
 #    echo [provision]: Updating fdo source tarball
-#    tar -zcf fdo-checkout.tar.gz trunk
-#    sudo mv fdo-checkout.tar.gz /mapguide_sources/updated
+#    tar -zcf $FDO_TARBALL $FDO_SRC_DIR
+#    sudo mv $FDO_TARBALL /mapguide_sources/updated
 #else
 #    echo [provision]: Updated tarballs already exist. Doing nothing
 #fi
Modified: branches/2.6/vagrant/ubuntu/x86/Vagrantfile
--- branches/2.6/vagrant/ubuntu/x86/Vagrantfile	2014-05-12 12:15:21 UTC (rev 8124)
+++ branches/2.6/vagrant/ubuntu/x86/Vagrantfile	2014-05-12 12:17:02 UTC (rev 8125)
@@ -10,7 +10,7 @@
-  config.vm.box = "vagrant-trusty32"
+  config.vm.box = "vagrant-precise32"
 		exit $error
 	fi
+check_test()
+	error=$?
+	fi
 cd ~
 HAVE_FDO_LIBS=0
 HAVE_MAPGUIDE=0
 MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
-FDO_SRC_ROOT=~/fdo
+FDO_VER_MM=3.9
+MG_VER_MM=2.6
+FDO_SRC_DIR=3.9
 if [ -d $FDO_SRC ];
 then
     HAVE_FDO=1
@@ -159,8 +173,8 @@
 fi
 fi
 then
-    mkdir -p ~/fdo
 fi
 then
 fi
-# Only for this VM, svn is 1.8 so we have to upgrade the WC first before it can be updated
+# Only for Ubuntu 14.04 VM, svn is 1.8 so we have to upgrade the WC first before it can be updated
 svn update $FDO_SRC
 check_build
 svn update $MG_SRC
 check_build
 check_build
 sudo ./dpkgmapguide.sh i386 $MG_REV
 check_build
+then
+    check_test
+    check_test
+    check_test
+    check_test
+    check_test
+    check_test
+fi
 then
+    check_test
 fi
 cd $SCRIPT_ROOT
+#    cd $MG_SRC_ROOT
-#    cd ~/fdo
+#    cd $FDO_SRC_ROOT
 #else
 #fi
More information about the mapguide-commits mailing list
