[mapguide-commits] r8132 - in branches/2.6/MgDev/Desktop: . MgDesktop MgDesktop/Services MgDesktop/Services/Feature MgDesktop/System UnitTest cmake cmake/modules
svn_mapguide at osgeo.org
Thu May 15 09:51:12 PDT 2014
Author: jng
Date: 2014-05-15 09:51:12 -0700 (Thu, 15 May 2014)
New Revision: 8132
Added:
branches/2.6/MgDev/Desktop/CMakeLists.txt
branches/2.6/MgDev/Desktop/MgDesktop/CMakeLists.txt
branches/2.6/MgDev/Desktop/MgDesktop/postinstall.sh
branches/2.6/MgDev/Desktop/UnitTest/CMakeLists.txt
branches/2.6/MgDev/Desktop/UnitTest/postbuild.sh
branches/2.6/MgDev/Desktop/UnitTest/postinstall.sh
branches/2.6/MgDev/Desktop/cmake/
branches/2.6/MgDev/Desktop/cmake/modules/
branches/2.6/MgDev/Desktop/cmake/modules/FindACE.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindCppUnit.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindDWFCore.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindDWFEMap.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindDWFToolkit.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindFDO.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindFDOInternal.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindFDOThirdparty.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgFoundation.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgGeometry.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgGwsCommon.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgGwsQueryEngine.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgMdfModel.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgMdfParser.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgPlatformBase.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgRenderers.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgSecurity.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMgStylization.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindMySQL.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindPostgreSQL.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindSqlite.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindXalanC.cmake
branches/2.6/MgDev/Desktop/cmake/modules/FindXercesC.cmake
branches/2.6/MgDev/Desktop/cmake/modules/MacroOptionalAddSubdirectory.cmake
branches/2.6/MgDev/Desktop/cmake/modules/MacroPushRequiredVars.cmake
branches/2.6/MgDev/Desktop/cmake/modules/TestCmakeVersion.cxx
branches/2.6/MgDev/Desktop/MgDesktop/Platform.ini
branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.cpp
branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionUtil.cpp
branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FeatureConnection.h
branches/2.6/MgDev/Desktop/MgDesktop/Services/FeatureReader.cpp
branches/2.6/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp
branches/2.6/MgDev/Desktop/MgDesktop/System/Mutex.h
branches/2.6/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp
branches/2.6/MgDev/Desktop/UnitTest/TestFeatureService.cpp
branches/2.6/MgDev/Desktop/UnitTest/TestResourceService.cpp
mg-desktop: Add compilation support for Linux. We use CMake to build mg-desktop. This currently builds the mg-desktop library and the unit test executable
Added: branches/2.6/MgDev/Desktop/CMakeLists.txt
--- branches/2.6/MgDev/Desktop/CMakeLists.txt (rev 0)
+++ branches/2.6/MgDev/Desktop/CMakeLists.txt 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,48 @@
+project(mgdesktop)
+# CMake base requires and policy tweaks
+cmake_minimum_required( VERSION 2.6.2 FATAL_ERROR )
+# CMP0005: keep escaping behaviour for definitions added via add_definitions()
+cmake_policy( SET CMP0005 OLD )
+# Look first in internal modules
+set(CMAKE_MODULE_PATH
+ ${CMAKE_CURRENT_SOURCE_DIR}/cmake/modules
+# Make CPack available to easy generate binary packages
+include(CPack)
+# Set MapGuide version macros
+set( MG_VERSION_MAJOR 2 )
+set( MG_VERSION_MINOR 6 )
+set( MG_VERSION_RELEASE 0 )
+set( MG_VERSION "${MG_VERSION_MAJOR}.${MG_VERSION_MINOR}.${MG_VERSION_RELEASE}" )
+set( MG_DISTRIBUTION_TEXT "Self compiled sources" CACHE STRING "Indicate compilation origin" )
+set( MG_SRC_ROOT ${CMAKE_CURRENT_SOURCE_DIR} )
+set( MG_ROOT_DIR "/usr/local/mapguideopensource-${MG_VERSION}")
+set( MG_LIB_DIR "${MG_ROOT_DIR}/lib" )
+set( MG_COORDSYS_DIR "${MG_ROOT_DIR}/share/gis/coordsys" )
+# Override install directory to match what the automake build does (/usr/local, rather than /usr/local/lib)
+set( INSTALL_PREFIX "${MG_ROOT_DIR}/desktop" )
+if( UNIX )
+ add_definitions( -DFULLPROTO -fPIC -DPIC )
+endif( UNIX )
+if (CMAKE_SYSTEM_NAME MATCHES Linux)
+ add_definitions( -DLINUX -DLINUX_IA32 -pthread )
+endif (CMAKE_SYSTEM_NAME MATCHES Linux)
+if( CMAKE_COMPILER_IS_GNUCXX )
+ add_definitions( -D__USE_GNU -Wno-deprecated -Wno-write-strings -Wno-format )
+ set ( CMAKE_SHARED_LINKER_FLAGS "-Wl,--as-needed -Wl,--no-undefined -lc ${CMAKE_SHARED_LINKER_FLAGS}")
+ set ( CMAKE_CXX_FLAGS "-O2 -march=i686" )
+endif( CMAKE_COMPILER_IS_GNUCXX )
+add_subdirectory( MgDesktop )
+#add_subdirectory( DesktopUnmanagedApi )
+add_subdirectory( UnitTest )
Added: branches/2.6/MgDev/Desktop/MgDesktop/CMakeLists.txt
--- branches/2.6/MgDev/Desktop/MgDesktop/CMakeLists.txt (rev 0)
+++ branches/2.6/MgDev/Desktop/MgDesktop/CMakeLists.txt 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,86 @@
+find_package( Threads REQUIRED )
+find_package( ACE REQUIRED )
+find_package( FDO REQUIRED )
+find_package( DWFCore REQUIRED )
+find_package( DWFToolkit REQUIRED )
+find_package( DWFEMap REQUIRED )
+find_package( MgGwsCommon REQUIRED )
+find_package( MgGwsQueryEngine REQUIRED )
+find_package( MgMdfModel REQUIRED )
+find_package( MgMdfParser REQUIRED )
+find_package( MgFoundation REQUIRED )
+find_package( MgGeometry REQUIRED )
+find_package( MgPlatformBase REQUIRED )
+find_package( MgRenderers REQUIRED )
+find_package( MgStylization REQUIRED )
+find_package( MgSecurity REQUIRED )
+find_package( XercesC REQUIRED )
+include_directories(
+ ${CMAKE_CURRENT_SOURCE_DIR}/Exception
+ ${CMAKE_CURRENT_SOURCE_DIR}/Log
+ ${CMAKE_CURRENT_SOURCE_DIR}/MapLayer
+ ${CMAKE_CURRENT_SOURCE_DIR}/Services
+ ${CMAKE_CURRENT_SOURCE_DIR}/System
+ ${FDO_INCLUDE_DIR}
+ ${FDO_INCLUDE_DIR}/ExpressionEngine
+ ${MgMdfModel_INCLUDE_DIR}
+ ${MgMdfParser_INCLUDE_DIR}
+ ${MgFoundation_INCLUDE_DIR}
+ ${MgGeometry_INCLUDE_DIR}
+ ${MgPlatformBase_INCLUDE_DIR}
+ ${MgRenderers_INCLUDE_DIR}
+ ${MgStylization_INCLUDE_DIR}
+ ${ACE_INCLUDE_DIR}
+ ${XercesC_INCLUDE_DIR}
+ ${DWFCore_INCLUDE_DIR}
+ ${DWFToolkit_INCLUDE_DIR}
+ ${DWFToolkit_INCLUDE_DIR}/dwf
+ ${DWFEMap_INCLUDE_DIR}
+ ${MgGwsCommon_INCLUDE_DIR}
+ ${MgGwsQueryEngine_INCLUDE_DIR}
+ ${MgGwsQueryEngine_INCLUDE_DIR}/../GwsQueryEngine/inc
+ ${MgSecurity_INCLUDE_DIR}
+set( MgDesktop_SRCS
+ MgDesktopBuild.cpp
+add_library(MgDesktop-${MG_VERSION} SHARED ${MgDesktop_SRCS})
+target_link_libraries(
+ MgDesktop-${MG_VERSION}
+ ${CMAKE_DL_LIBS}
+ ${CMAKE_THREAD_LIBS_INIT}
+ ${ACE_LIBRARIES}
+ ${FDO_LIBRARY}
+ ${FDO_EXPRESSIONENGINE_LIBRARY}
+ ${DWFCore_LIBRARIES}
+ ${DWFToolkit_LIBRARIES}
+ ${DWFEMap_LIBRARIES}
+ ${MgGwsCommon_LIBRARIES}
+ ${MgGwsQueryEngine_LIBRARIES}
+ ${MgMdfModel_LIBRARIES}
+ ${MgMdfParser_LIBRARIES}
+ ${MgFoundation_LIBRARIES}
+ ${MgGeometry_LIBRARIES}
+ ${MgPlatformBase_LIBRARIES}
+ ${MgRenderers_LIBRARIES}
+ ${MgStylization_LIBRARIES}
+ ${MgSecurity_LIBRARIES}
+ ${XercesC_LIBRARIES}
+install(DIRECTORY ${MG_SRC_ROOT}/../Common/Schema
+ DESTINATION ${INSTALL_PREFIX}
+ FILES_MATCHING
+ PATTERN "*.xsd"
+ PATTERN ".svn" EXCLUDE
+ PERMISSIONS OWNER_READ OWNER_WRITE GROUP_READ WORLD_READ
+install(FILES ${MG_SRC_ROOT}/../Common/MapGuideCommon/Resources/mapguide_en.res DESTINATION ${INSTALL_PREFIX}/Resources)
+install(FILES Platform.ini DESTINATION ${INSTALL_PREFIX}/conf)
+install(TARGETS MgDesktop-${MG_VERSION} DESTINATION ${INSTALL_PREFIX}/lib)
+install(CODE "execute_process(COMMAND sh ${CMAKE_CURRENT_SOURCE_DIR}/postinstall.sh)")
Modified: branches/2.6/MgDev/Desktop/MgDesktop/Platform.ini
(Binary files differ)
Modified: branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.cpp
--- branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.cpp 2014-05-14 22:46:15 UTC (rev 8131)
+++ branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionPool.cpp 2014-05-15 16:51:12 UTC (rev 8132)
@@ -31,7 +31,7 @@
ConnPool freePool;
//ConnPool busyPool;
- MgdMutex MgdMutex;
+ MgdMutex mutex;
//The One instance of the connection pool
@@ -46,7 +46,7 @@
CHECK_FEATURE_SOURCE_ARGUMENT(featureSourceId, L"MgdFdoConnectionPool::GetConnection");
- ScopedLock scc(g_pool.MgdMutex);
+ ScopedLock scc(g_pool.mutex);
STRING fsIdStr = featureSourceId->ToString();
ConnPool::iterator it = g_pool.freePool.find(fsIdStr);
@@ -112,7 +112,7 @@
MG_FEATURE_SERVICE_TRY()
STRING providerName = conn->GetProviderName();
FdoPtr<FdoIConnection> fdoConn = conn->m_fdoConn; //conn->GetConnection();
@@ -220,7 +220,7 @@
for (ConnPool::iterator it = g_pool.freePool.begin(); it != g_pool.freePool.end(); ++it)
@@ -250,7 +250,7 @@
if (MgResourceType::FeatureSource != resId->GetResourceType())
return;
@@ -288,7 +288,7 @@
STRING fsIdStr = resId->ToString();
INT32 purged = 0;
@@ -340,7 +340,7 @@
void MgdFdoConnectionPool::GetCacheInfo(std::vector<PoolCacheEntry*>& entries)
@@ -374,4 +374,4 @@
entries.push_back(ent);
\ No newline at end of file
Modified: branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionUtil.cpp
--- branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionUtil.cpp 2014-05-14 22:46:15 UTC (rev 8131)
+++ branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FdoConnectionUtil.cpp 2014-05-15 16:51:12 UTC (rev 8132)
@@ -200,9 +200,9 @@
FdoPtr<FdoStringElement> company = tokenParts->GetItem(0);
FdoPtr<FdoStringElement> provider = tokenParts->GetItem(1);
- STRING name = company->GetString();
+ STRING name = (FdoString*)company->GetString();
name += L".";
- name += provider->GetString();
+ name += (FdoString*)provider->GetString();
return name;
@@ -309,4 +309,4 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("[WARNING] Create/Close call mismatch - Create calls: %d, Close calls: %d\n"), sm_nConnectionsCreated, sm_nConnectionsClosed));
-#endif
+#endif
Modified: branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FeatureConnection.h
--- branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FeatureConnection.h 2014-05-14 22:46:15 UTC (rev 8131)
+++ branches/2.6/MgDev/Desktop/MgDesktop/Services/Feature/FeatureConnection.h 2014-05-15 16:51:12 UTC (rev 8132)
@@ -5,7 +5,6 @@
class MgResourceIdentifier;
class MgdFdoConnectionPool;
-template class Ptr<MgResourceIdentifier>;
/// \cond INTERNAL
class MgdFeatureConnection : public MgGuardDisposable
@@ -50,4 +49,4 @@
bool m_bCloseConnection;
///\endcond
-#endif
+#endif
Modified: branches/2.6/MgDev/Desktop/MgDesktop/Services/FeatureReader.cpp
--- branches/2.6/MgDev/Desktop/MgDesktop/Services/FeatureReader.cpp 2014-05-14 22:46:15 UTC (rev 8131)
+++ branches/2.6/MgDev/Desktop/MgDesktop/Services/FeatureReader.cpp 2014-05-15 16:51:12 UTC (rev 8132)
@@ -390,7 +390,7 @@
try
FdoInt32 len = 0;
- data = m_reader->GetGeometry(propertyName.c_str(), &length);
+ data = m_reader->GetGeometry(propertyName.c_str(), &len);
length = len;
catch(...)
@@ -887,4 +887,4 @@
FdoIFeatureReader* MgdFeatureReader::GetInternalReader()
return FDO_SAFE_ADDREF(m_reader);
Modified: branches/2.6/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp
--- branches/2.6/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp 2014-05-14 22:46:15 UTC (rev 8131)
+++ branches/2.6/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp 2014-05-15 16:51:12 UTC (rev 8132)
@@ -9,6 +9,14 @@
#include "Services/Feature/FdoConnectionPool.h"
#include "CryptographyUtil.h"
+static void XmlChToWideChar(const XMLCh* ch, REFSTRING wStr)
+ char* mbCh = XMLString::transcode(ch);
+ std::string mbStr = mbCh;
+ MgUtil::MultiByteToWideChar(mbStr, wStr);
+ XMLString::release(&mbCh);
static int MgDirEntrySelector(const ACE_DIRENT *d)
return (0 != ACE_OS::strcmp(d->d_name, ACE_TEXT(".")) &&
@@ -342,7 +350,8 @@
STRING resType = resource->GetResourceType();
DOMElement* docEl = doc->getDocumentElement();
CHECKNULL(docEl, L"MgdResourceService::SetResource");
- STRING docElName = docEl->getNodeName();
+ STRING docElName;
+ XmlChToWideChar(docEl->getNodeName(), docElName);
//Now make sure it's the right type of XML document
@@ -368,7 +377,8 @@
catch (const SAXParseException& e)
- STRING msg = e.getMessage();
+ STRING msg;
+ XmlChToWideChar(e.getMessage(), msg);
XMLFileLoc lineNum = e.getLineNumber();
XMLFileLoc colNum = e.getColumnNumber();
@@ -377,10 +387,10 @@
STRING pubIdStr;
if (NULL != pubId)
- pubIdStr = pubId;
+ XmlChToWideChar(pubId, pubIdStr);
STRING sysIdStr;
if (NULL != sysId)
- sysIdStr = sysId;
+ XmlChToWideChar(sysId, sysIdStr);
STRING lineNumStr;
STRING colNumStr;
@@ -1821,4 +1831,4 @@
MgdUnmanagedDataManager* umgr = MgdUnmanagedDataManager::GetInstance();
umgr->AddAliasMapping(aliasName, path);
Modified: branches/2.6/MgDev/Desktop/MgDesktop/System/Mutex.h
--- branches/2.6/MgDev/Desktop/MgDesktop/System/Mutex.h 2014-05-14 22:46:15 UTC (rev 8131)
+++ branches/2.6/MgDev/Desktop/MgDesktop/System/Mutex.h 2014-05-15 16:51:12 UTC (rev 8132)
@@ -69,7 +69,7 @@
~MgdMutex()
- pthread_MgdMutex_destroy(&m_CritSect);
+ pthread_mutex_destroy(&m_CritSect);
void Initialize()
@@ -77,26 +77,26 @@
if(!m_bInitialized)
m_bInitialized = true;
- pthread_MgdMutexattr_init(&m_attributes);
- pthread_MgdMutexattr_settype(&m_attributes, PTHREAD_MgdMutex_RECURSIVE);
- pthread_MgdMutex_init(&m_CritSect, &m_attributes);
- pthread_MgdMutexattr_destroy(&m_attributes);
+ pthread_mutexattr_init(&m_attributes);
+ pthread_mutexattr_settype(&m_attributes, PTHREAD_MUTEX_RECURSIVE);
+ pthread_mutex_init(&m_CritSect, &m_attributes);
+ pthread_mutexattr_destroy(&m_attributes);
void Enter()
- pthread_MgdMutex_lock(&m_CritSect);
+ pthread_mutex_lock(&m_CritSect);
void Leave()
- pthread_MgdMutex_unlock(&m_CritSect);
+ pthread_mutex_unlock(&m_CritSect);
private:
- pthread_MgdMutex_t m_CritSect;
- pthread_MgdMutexattr_t m_attributes;
+ pthread_mutex_t m_CritSect;
+ pthread_mutexattr_t m_attributes;
#endif //_WIN32
@@ -108,17 +108,17 @@
class ScopedLock
public:
- ScopedLock(MgdMutex& MgdMutex):m_MgdMutex(MgdMutex)
+ ScopedLock(MgdMutex& mutex):m_mutex(mutex)
- m_MgdMutex.Enter();
+ m_mutex.Enter();
~ScopedLock()
- m_MgdMutex.Leave();
+ m_mutex.Leave();
private:
ScopedLock();
- MgdMutex& m_MgdMutex;
+ MgdMutex& m_mutex;
-#endif
+#endif
Modified: branches/2.6/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp
--- branches/2.6/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp 2014-05-14 22:46:15 UTC (rev 8131)
+++ branches/2.6/MgDev/Desktop/MgDesktop/System/PlatformInit.cpp 2014-05-15 16:51:12 UTC (rev 8132)
@@ -61,6 +61,9 @@
mentorDictPath,
MgdConfigProperties::DefaultGeneralPropertyMentorDictionaryPath);
+ Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
+ Ptr<MgCoordinateSystemCatalog> csCatalog = csFactory->GetCatalog();
#ifdef WIN32
HMODULE hlib = NULL;
@@ -88,9 +91,6 @@
MG_LOG_TRACE_ENTRY(L"PATH = " + updatedPath);
- Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
- Ptr<MgCoordinateSystemCatalog> csCatalog = csFactory->GetCatalog();
//If specified in config inject this path into MENTOR_DICTIONARY_PATH
if (!mentorDictPath.empty())
@@ -127,7 +127,9 @@
if (MgFileUtil::IsDirectory(mentorDictPath))
- setenv("MENTOR_DICTIONARY_PATH", mentorDictPath.c_str(), 1);
+ //std::string mbDictPath = MgUtil::WideCharToMultiByte(mentorDictPath);
+ //setenv("MENTOR_DICTIONARY_PATH", mbDictPath.c_str(), 1);
+ csCatalog->SetDictionaryDir(mentorDictPath);
#endif
@@ -250,4 +252,4 @@
EXCEPTION_CLASS_CREATOR(InvalidPrintLayoutSizeUnitsException)
return true;
Added: branches/2.6/MgDev/Desktop/MgDesktop/postinstall.sh
--- branches/2.6/MgDev/Desktop/MgDesktop/postinstall.sh (rev 0)
+++ branches/2.6/MgDev/Desktop/MgDesktop/postinstall.sh 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,14 @@
+#!/bin/bash
+PLATFORMINI=/usr/local/mapguideopensource-2.6.0/desktop/conf/Platform.ini
+echo "Running post-install operations"
+if [ ! -f /usr/local/mapguideopensource-2.6.0/desktop/lib/libMgDesktop.so ]; then
+ ln -s /usr/local/mapguideopensource-2.6.0/desktop/lib/libMgDesktop-2.6.0.so /usr/local/mapguideopensource-2.6.0/desktop/lib/libMgDesktop.so
+fi
+echo "Updating $PLATFORMINI"
+dos2unix $PLATFORMINI
+sed -i 's/= Schema\//= \/usr\/local\/mapguideopensource\-2.6.0\/desktop\/Schema/g' $PLATFORMINI
+sed -i 's/= Resources\//= \/usr\/local\/mapguideopensource\-2.6.0\/desktop\/Resources/g' $PLATFORMINI
+sed -i 's/= FDO\//= \/usr\/local\/fdo\-3.9.0\/lib/g' $PLATFORMINI
+sed -i 's/= Dictionaries\//= \/usr\/local\/mapguideopensource\-2.6.0\/share\/gis\/coordsys/g' $PLATFORMINI
+echo "Updated $PLATFORMINI"
Added: branches/2.6/MgDev/Desktop/UnitTest/CMakeLists.txt
--- branches/2.6/MgDev/Desktop/UnitTest/CMakeLists.txt (rev 0)
+++ branches/2.6/MgDev/Desktop/UnitTest/CMakeLists.txt 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,89 @@
+find_package( CppUnit REQUIRED )
+ ${CMAKE_CURRENT_SOURCE_DIR}/../MgDesktop
+ ${CPPUNIT_INCLUDE_DIR}
+ main.cpp
+ TestFeatureService.cpp
+ TestLogManager.cpp
+ TestLogManagerThread.cpp
+ TestMappingService.cpp
+ TestProfilingService.cpp
+ TestRenderingService.cpp
+ TestResourceService.cpp
+ TestTileService.cpp
+add_executable(UnitTest ${MgDesktop_SRCS})
+ UnitTest
+ ${CMAKE_DL_LIBS}
+ ${CPPUNIT_LIBRARIES}
+ ${ACE_LIBRARIES}
+ ${FDO_LIBRARY}
+add_custom_command(TARGET UnitTest
+ POST_BUILD
+ COMMAND sh ${CMAKE_CURRENT_SOURCE_DIR}/postbuild.sh ${MG_SRC_ROOT}
+#install(TARGETS UnitTest DESTINATION ${INSTALL_PREFIX}/lib)
+#install(CODE "execute_process(COMMAND sh ${CMAKE_CURRENT_SOURCE_DIR}/postinstall.sh)")
Modified: branches/2.6/MgDev/Desktop/UnitTest/TestFeatureService.cpp
--- branches/2.6/MgDev/Desktop/UnitTest/TestFeatureService.cpp 2014-05-14 22:46:15 UTC (rev 8131)
+++ branches/2.6/MgDev/Desktop/UnitTest/TestFeatureService.cpp 2014-05-15 16:51:12 UTC (rev 8132)
@@ -21,6 +21,7 @@
#include "TestFeatureService.h"
#include "CppUnitExtensions.h"
#include "Fdo.h"
+#include <ctime>
//Uncommenting this will make the join benchmarks 10-15x slower (because we're writing each feature out!)
@@ -72,7 +73,7 @@
pService->SetResource(ldfres3, ldfrdr3, NULL);
Ptr<MgResourceIdentifier> fsres3 = new MgResourceIdentifier(L"Library://UnitTests/Data/ParcelsWriteable.FeatureSource");
- Ptr<MgByteSource> fssrc3 = new MgByteSource(L"../UnitTestFiles/UT_Parcels_writeable.fs", false);
+ Ptr<MgByteSource> fssrc3 = new MgByteSource(L"../UnitTestFiles/UT_Parcels_Writeable.fs", false);
Ptr<MgByteReader> fsrdr3 = fssrc3->GetReader();
pService->SetResource(fsres3, fsrdr3, NULL);
@@ -3174,7 +3175,8 @@
#else
const int iterations = 1000;
#endif
- long lStart = GetTickCount();
+ clock_t lStart = clock();
for(int i=0;i<iterations;i++)
int nFeatures = 0;
@@ -3188,8 +3190,8 @@
reader->Close();
CPPUNIT_ASSERT(nFeatures == 17565);
- ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (Average of %d runs): = %6.4f (s)\n"), iterations, ((GetTickCount()-lStart)/1000.0)/(double)iterations ));
+ clock_t lEnd = clock();
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (Average of %d runs): = %6.4f (s)\n"), iterations, ((lEnd-lStart)/CLOCKS_PER_SEC)/(double)iterations ));
ACE_DEBUG((LM_INFO, ACE_TEXT("TestCase_BenchmarkSelectFeatures - END\n")));
catch(MgException* e)
@@ -3636,8 +3638,8 @@
// ----- Start the tests ------- //
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSdfJoin() - Inner Join \n")));
reader = featSvc->SelectFeatures(fsId, L"ParcelsInner", NULL);
while(reader->ReadNext())
@@ -3645,9 +3647,11 @@
reader->Close();
- ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (%d results): = %6.4f (s)\n"), total, ((GetTickCount()-lStart)/1000.0) ));
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (%d results): = %6.4f (s)\n"), total, ((lEnd-lStart)/CLOCKS_PER_SEC) ));
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSdfJoin() - Left Outer Join \n")));
- lStart = GetTickCount();
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuter", NULL);
@@ -3657,9 +3661,11 @@
reader->Close();
+ lEnd = clock();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSdfJoin() - Inner Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOne", NULL);
@@ -3669,9 +3675,10 @@
reader->Close();
+ lEnd = clock();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSdfJoin() - Left Outer Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOne", NULL);
@@ -3681,7 +3688,8 @@
reader->Close();
+ lEnd = clock();
@@ -3736,7 +3744,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteJoin() - Inner Join \n")));
long total = 0L;
@@ -3746,9 +3754,9 @@
reader->Close();
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time (%d results): = %6.4f (s)\n"), total, ((clock()-lStart)/CLOCKS_PER_SEC) ));
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteJoin() - Left Outer Join \n")));
+ lStart = clock();
total = 0L;
@@ -3758,9 +3766,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteJoin() - Inner Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
@@ -3770,9 +3778,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteJoin() - Left Outer Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
@@ -3782,7 +3790,7 @@
reader->Close();
@@ -3831,7 +3839,7 @@
aggOpts->AddComputedProperty(L"TotalCount", L"Count(SdfId)");
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Inner Join \n")));
long total = 0L;
int iterations = 0;
@@ -3845,9 +3853,9 @@
reader->Close();
CPPUNIT_ASSERT(iterations == 1);
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Left Outer Join \n")));
+ lStart = clock();
iterations = 0L;
reader = featSvc->SelectAggregate(fsId, L"ParcelsLeftOuter", aggOpts);
@@ -3860,9 +3868,9 @@
reader->Close();
CPPUNIT_ASSERT(iterations == 1L);
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Inner Join (Forced 1:1) \n")));
+ lStart = clock();
iterations = 0L;
reader = featSvc->SelectAggregate(fsId, L"ParcelsInnerOneToOne", aggOpts);
@@ -3875,9 +3883,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkSqliteAggregateJoin() - Left Outer Join (Forced 1:1) \n")));
+ lStart = clock();
iterations = 0L;
reader = featSvc->SelectAggregate(fsId, L"ParcelsLeftOuterOneToOne", aggOpts);
@@ -3890,7 +3898,7 @@
reader->Close();
@@ -3936,7 +3944,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkMergeSortJoin() - Inner Join \n")));
long total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerSortMerge", NULL);
@@ -3958,9 +3966,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkMergeSortJoin() - Left Outer Join \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterSortMerge", NULL);
@@ -3978,9 +3986,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkMergeSortJoin() - Inner Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOneSortMerge", NULL);
@@ -3998,9 +4006,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkMergeSortJoin() - Left Outer Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOneSortMerge", NULL);
@@ -4018,7 +4026,7 @@
reader->Close();
@@ -4064,7 +4072,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkBatchSortedBlockJoin() - Inner Join \n")));
long total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerBatchSortedBlock", NULL);
@@ -4086,9 +4094,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkBatchSortedBlockJoin() - Left Outer Join \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterBatchSortedBlock", NULL);
@@ -4106,9 +4114,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkBatchSortedBlockJoin() - Inner Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOneBatchSortedBlock", NULL);
@@ -4126,9 +4134,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkBatchSortedBlockJoin() - Left Outer Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOneBatchSortedBlock", NULL);
@@ -4146,7 +4154,7 @@
reader->Close();
@@ -4192,7 +4200,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsSortedBlockJoin() - Inner Join \n")));
long total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerNestedLoopSortedBlock", NULL);
@@ -4214,9 +4222,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsSortedBlockJoin() - Left Outer Join \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterNestedLoopSortedBlock", NULL);
@@ -4234,9 +4242,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsSortedBlockJoin() - Inner Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOneNestedLoopSortedBlock", NULL);
@@ -4254,9 +4262,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsSortedBlockJoin() - Left Outer Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOneNestedLoopSortedBlock", NULL);
@@ -4274,7 +4282,7 @@
reader->Close();
@@ -4551,7 +4559,7 @@
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsJoin() - Inner Join \n")));
long total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerNestedLoops", NULL);
@@ -4574,9 +4582,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsJoin() - Left Outer Join \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterNestedLoops", NULL);
@@ -4594,9 +4602,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsJoin() - Inner Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsInnerOneToOneNestedLoops", NULL);
@@ -4614,9 +4622,9 @@
reader->Close();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestFeatureService::TestCase_BenchmarkNestedLoopsJoin() - Left Outer Join (Forced 1:1) \n")));
+ lStart = clock();
total = 0L;
reader = featSvc->SelectFeatures(fsId, L"ParcelsLeftOuterOneToOneNestedLoops", NULL);
@@ -4634,7 +4642,7 @@
reader->Close();
@@ -4719,4 +4727,4 @@
throw;
Modified: branches/2.6/MgDev/Desktop/UnitTest/TestResourceService.cpp
--- branches/2.6/MgDev/Desktop/UnitTest/TestResourceService.cpp 2014-05-14 22:46:15 UTC (rev 8131)
+++ branches/2.6/MgDev/Desktop/UnitTest/TestResourceService.cpp 2014-05-15 16:51:12 UTC (rev 8132)
@@ -16,10 +16,11 @@
#include "MgDesktop.h"
-#include "Services\Resource\ResourceContentCache.h"
+#include "Services/Resource/ResourceContentCache.h"
#include "Fdo.h"
#include "TestResourceService.h"
+#include <ctime>
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION(TestResourceService, "TestResourceService");
@@ -1154,44 +1155,44 @@
MgdResourceContentCache* cache = MgdResourceContentCache::GetInstance();
cache->Clear();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Individual GetResourceContent calls (cold) \n")));
for (INT32 i = 0; i < resources->GetCount(); i++)
Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resources->GetItem(i));
Ptr<MgByteReader> content = pService->GetResourceContent(resId);
- ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time: = %6.4f (s)\n"), ((GetTickCount()-lStart)/1000.0) ));
+ ACE_DEBUG((LM_INFO, ACE_TEXT(" Execution Time: = %6.4f (s)\n"), ((clock()-lStart)/CLOCKS_PER_SEC) ));
ACE_DEBUG((LM_INFO, ACE_TEXT(" %d resource content items in cache\n"), (cache->GetCacheSize()) ));
+ lStart = clock();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Individual GetResourceContent calls (cached contents) \n")));
//Evict all cached copies to avoid distortion of results due to caching
cache->Clear();
+ lStart = clock();
Ptr<MgStringCollection> contents;
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Multi-threaded GetResourceContents call (cold) \n")));
contents = pService->GetResourceContents(resources, NULL);
CPPUNIT_ASSERT(NULL != contents.p);
CPPUNIT_ASSERT(contents->GetCount() == resources->GetCount());
+ lStart = clock();
ACE_DEBUG((LM_INFO, ACE_TEXT("\nTestResourceService::TestCase_BenchmarkGetResourceContents() - Multi-threaded GetResourceContents call (cached contents) \n")));
@@ -1218,7 +1219,7 @@
pService->DeleteResource(&resId);
- Ptr<MgByteSource> byteSource = new MgByteSource(L"..\\UnitTestFiles\\PackageTest.mgp");
+ Ptr<MgByteSource> byteSource = new MgByteSource(L"../UnitTestFiles/PackageTest.mgp");
Ptr<MgByteReader> byteReader = byteSource->GetReader();
//This package contains an UPDATEREPOSITORY directive, which should no-op when loaded by mg-desktop
@@ -1263,4 +1264,4 @@
SAFE_RELEASE(e);
CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
Added: branches/2.6/MgDev/Desktop/UnitTest/postbuild.sh
--- branches/2.6/MgDev/Desktop/UnitTest/postbuild.sh (rev 0)
+++ branches/2.6/MgDev/Desktop/UnitTest/postbuild.sh 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+#!/bin/bash
+OUTDIR=$PWD/../UnitTestFiles
+ROOTDIR=$1
+UNITTEST_DIR=$ROOTDIR/../UnitTest/TestData
+echo "Performing post-build actions for unit test"
+echo "Output directory is: $OUTDIR"
+echo "Source dir is: $UNITTEST_DIR"
+if [ ! -d $PWD/../UnitTestFiles ]; then
+ mkdir -p $PWD/../UnitTestFiles
+fi
+echo "Copy $ROOTDIR/DesktopTestData to $OUTDIR"
+cp $ROOTDIR/DesktopTestData/* $OUTDIR/
+for dirname in CoordinateSystems DrawingService KmlService MapLayer MappingService MdfModel PrintLayout ResourceService ServerAdmin SiteService Symbology TileService Unicode WebLayout Wfs Wms
+do
+ SRC_DIR=$UNITTEST_DIR/$dirname
+ echo "Copy $SRC_DIR to $OUTDIR"
+ cp $SRC_DIR/* $OUTDIR/
+done
+for dirname in SDF SHP SQLite
+do
+ SRC_DIR=$UNITTEST_DIR/FeatureService/$dirname
+done
Added: branches/2.6/MgDev/Desktop/UnitTest/postinstall.sh
--- branches/2.6/MgDev/Desktop/UnitTest/postinstall.sh (rev 0)
+++ branches/2.6/MgDev/Desktop/UnitTest/postinstall.sh 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,3 @@
+#!/bin/bash
+echo "Performing post-install actions for unit test"
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindACE.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindACE.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindACE.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find ACE component
+cmake_policy( SET CMP0011 OLD )
+IF (ACE_INCLUDE_DIR AND ACE_LIBRARIES)
+ # in cache already
+ SET(ACE_FIND_QUIETLY TRUE)
+ENDIF (ACE_INCLUDE_DIR AND ACE_LIBRARIES)
+FIND_PATH(ACE_INCLUDE_DIR ace/INET_Addr.h
+ HINTS
+ ${MG_SRC_ROOT}/../Oem/ACE/ACE_wrappers
+FIND_LIBRARY(ACE_LIBRARIES NAMES ACE
+ HINTS
+ ${MG_LIB_DIR}
+ ${MG_SRC_ROOT}/../Oem/ACE/ACE_wrappers/lib
+include(FindPackageHandleStandardArgs)
+find_package_handle_standard_args(ACE DEFAULT_MSG
+ ACE_INCLUDE_DIR ACE_LIBRARIES )
+MARK_AS_ADVANCED(ACE_INCLUDE_DIR ACE_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindCppUnit.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindCppUnit.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindCppUnit.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,36 @@
+# - Try to find cppunit
+# Once done this will define
+# CPPUNIT_FOUND - System has cppunit
+# CPPUNIT_INCLUDE_DIR - The cppunit include directory
+# CPPUNIT_LIBRARIES - The libraries needed to use cppunit
+# Copyright (c) 2009, Helio Chissini de Castro, <helio at kde.org>
+# Redistribution and use is allowed according to the terms of the BSD license.
+# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
+IF (CPPUNIT_INCLUDE_DIR AND CPPUNIT_LIBRARIES)
+ SET(cppunit_FIND_QUIETLY TRUE)
+ENDIF (CPPUNIT_INCLUDE_DIR AND CPPUNIT_LIBRARIES)
+FIND_PATH(CPPUNIT_INCLUDE_DIR cppunit/CompilerOutputter.h
+ HINTS
+ ${MG_SRC_ROOT}/../Oem/CppUnit-1.9.14/include
+ PATH_SUFFIXES cppunit
+FIND_LIBRARY(CPPUNIT_LIBRARIES NAMES cppunit
+ HINTS
+ ${MG_SRC_ROOT}/../Oem/CppUnit-1.9.14/src/cppunit/.libs
+INCLUDE(FindPackageHandleStandardArgs)
+# handle the QUIETLY and REQUIRED arguments and set CPPUNIT_FOUND to TRUE if
+# all listed variables are TRUE
+FIND_PACKAGE_HANDLE_STANDARD_ARGS(cppunit DEFAULT_MSG CPPUNIT_LIBRARIES CPPUNIT_INCLUDE_DIR)
+MARK_AS_ADVANCED(CPPUNIT_INCLUDE_DIR CPPUNIT_LIBRARIES CPPUNIT_LIBRARY_DIR)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindDWFCore.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindDWFCore.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindDWFCore.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find DWFCore component
+IF (DWFCore_INCLUDE_DIR AND DWFCore_LIBRARIES)
+ SET(DWFCore_FIND_QUIETLY TRUE)
+ENDIF (DWFCore_INCLUDE_DIR AND DWFCore_LIBRARIES)
+FIND_PATH(DWFCore_INCLUDE_DIR dwfcore/Core.h
+ HINTS
+ ${MG_SRC_ROOT}/../Oem/DWFTK7.1/develop/global/src
+FIND_LIBRARY(DWFCore_LIBRARIES NAMES dwfcore-1.1.1
+ HINTS
+ ${MG_LIB_DIR}
+ ${MG_SRC_ROOT}/../Oem/DWFTK7.1/develop/global/src/dwfcore/.libs
+find_package_handle_standard_args(DWFCore DEFAULT_MSG
+ DWFCore_INCLUDE_DIR DWFCore_LIBRARIES )
+MARK_AS_ADVANCED(DWFCore_INCLUDE_DIR DWFCore_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindDWFEMap.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindDWFEMap.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindDWFEMap.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find DWFEMap component
+IF (DWFEMap_INCLUDE_DIR AND DWFEMap_LIBRARIES)
+ SET(DWFEMap_FIND_QUIETLY TRUE)
+ENDIF (DWFEMap_INCLUDE_DIR AND DWFEMap_LIBRARIES)
+FIND_PATH(DWFEMap_INCLUDE_DIR dwfemap/EMapToolkit.h
+ HINTS
+FIND_LIBRARY(DWFEMap_LIBRARIES NAMES dwfemap-1.0.0
+ HINTS
+ ${MG_LIB_DIR}
+ ${MG_SRC_ROOT}/../Oem/DWFTK7.1/develop/global/src/dwfemap/.libs
+find_package_handle_standard_args(DWFEMap DEFAULT_MSG
+ DWFEMap_INCLUDE_DIR DWFEMap_LIBRARIES )
+MARK_AS_ADVANCED(DWFEMap_INCLUDE_DIR DWFEMap_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindDWFToolkit.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindDWFToolkit.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindDWFToolkit.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find DWFToolkit component
+IF (DWFToolkit_INCLUDE_DIR AND DWFToolkit_LIBRARIES)
+ SET(DWFToolkit_FIND_QUIETLY TRUE)
+ENDIF (DWFToolkit_INCLUDE_DIR AND DWFToolkit_LIBRARIES)
+FIND_PATH(DWFToolkit_INCLUDE_DIR dwf/Toolkit.h
+ HINTS
+FIND_LIBRARY(DWFToolkit_LIBRARIES NAMES dwftk-7.1.1
+ HINTS
+ ${MG_LIB_DIR}
+ ${MG_SRC_ROOT}/../Oem/DWFTK7.1/develop/global/src/dwf/.libs
+find_package_handle_standard_args(DWFToolkit DEFAULT_MSG
+ DWFToolkit_INCLUDE_DIR DWFToolkit_LIBRARIES )
+MARK_AS_ADVANCED(DWFToolkit_INCLUDE_DIR DWFToolkit_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindFDO.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindFDO.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindFDO.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,35 @@
+# - Find the FDO dir, include and library dirs
+set( FDO_VERSION 3.9.0 )
+set( FDO_DIR /usr/local/fdo-${FDO_VERSION} )
+if( FDO_INCLUDE_DIR AND FDO_LIBRARY_DIR)
+ set( FDO_FIND_QUIETLY TRUE )
+endif( FDO_INCLUDE_DIR AND FDO_LIBRARY_DIR )
+FIND_PATH( FDO_INCLUDE_DIR Fdo.h ${FDO_DIR}/include )
+FIND_LIBRARY( FDO_LIBRARY NAMES FDO PATHS ${FDO_DIR}/lib ${FDO_DIR}/lib64 )
+FIND_LIBRARY( FDO_EXPRESSIONENGINE_LIBRARY NAMES ExpressionEngine PATHS ${FDO_DIR}/lib ${FDO_DIR}/lib64 )
+FIND_PATH( FDO_LIBRARY_DIR libFDO.so ${FDO_DIR}/lib ${FDO_DIR}/lib64 )
+if( FDO_INCLUDE_DIR AND FDO_LIBRARY AND FDO_LIBRARY_DIR )
+ set(FDO_FOUND TRUE)
+else( FDO_INCLUDE_DIR AND FDO_LIBRARY AND FDO_LIBRARY_DIR )
+ set(FDO_FOUND FALSE)
+endif( FDO_INCLUDE_DIR AND FDO_LIBRARY AND FDO_LIBRARY_DIR )
+if( FDO_FOUND )
+ if( NOT FDO_FIND_QUIETLY )
+ message( STATUS "Found FDO: ${FDO_LIBRARY}" )
+ endif( NOT FDO_FIND_QUIETLY )
+ mark_as_advanced( FDO_INCLUDE_DIR FDO_LIBRARY FDO_LIBRARY_DIR )
+else( FDO_FOUND )
+ if( FDO_FIND_REQUIRED )
+ message(FATAL_ERROR "Could NOT find FDO")
+ endif (FDO_FIND_REQUIRED)
+endif (FDO_FOUND)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindFDOInternal.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindFDOInternal.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindFDOInternal.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,58 @@
+# extra macros
+include(MacroOptionalAddSubdirectory)
+# Set a core build flag to enable Providers know that building are
+# done inside main core source, and not standalone
+set( FDO_CORE_BUILD TRUE )
+# Global definitions ( used by all sources )
+# Check if is a 64 bits install and use user defined LIB_SUFFIX
+if( UNIX )
+ set( LIB_SUFFIX "" CACHE STRING "Define suffix of directory name (32/64)" )
+ include( CheckTypeSize )
+ check_type_size( "void*" VOID_SIZE )
+ if( VOID_SIZE EQUAL 8 )
+ message( STATUS "Compiling in 64 bits machine" )
+ set( LIB_SUFFIX "64" )
+ endif( VOID_SIZE EQUAL 8 )
+ set( LIB_INSTALL_DIR "lib${LIB_SUFFIX}" )
+endif( UNIX )
+# Define the instalation prefix
+if( UNIX )
+ if( INSTALL_PREFIX )
+ set( CMAKE_INSTALL_PREFIX ${INSTALL_PREFIX} )
+ else( INSTALL_PREFIX )
+ set( CMAKE_INSTALL_PREFIX ${CMAKE_INSTALL_PREFIX}/${LIB_INSTALL_DIR}/fdo-${FDO_VERSION} )
+ endif( INSTALL_PREFIX )
+endif( UNIX )
+# Make global include directories, even binary build dir
+# to match build generated files
+set( UNMANAGED_DIR ${FDO}/Unmanaged )
+set( UNMANAGED_INCLUDE_DIR ${FDO}/Unmanaged/Inc )
+set( UNMANAGED_COMMON_INCLUDE_DIR ${FDO}/Unmanaged/Src/Common )
+set( UNMANAGED_NLS_INCLUDE_DIR ${FDO}/Unmanaged/Src/Nls )
+set( UTILITIES_COMMON_INCLUDE_DIR ${FDOUTILITIES}/Common/Inc )
+set( UTILITIES_TESTCOMMON_INCLUDE_DIR ${FDOUTILITIES}/TestCommon/Inc )
+set( UTILITIES_OWS_INCLUDE_DIR ${FDOUTILITIES}/OWS/Inc )
+set( UTILITIES_EXPRESSION_INCLUDE_DIR ${FDOUTILITIES}/ExpressionEngine/Inc )
+set( UTILITIES_SQLITEINTERFACE_INCLUDE_DIR ${FDOUTILITIES}/SQLiteInterface )
+set( UTILITIES_SCHEMAMGR_INCLUDE_DIR ${FDOUTILITIES}/SchemaMgr/Inc )
+# Messages are generated on binary dir, so make it include global
+include_directories( ${CMAKE_CURRENT_BINARY_DIR}/Fdo/Unmanaged/Inc )
+mark_as_advanced(
+ UNMANAGED_DIR
+ UNMANAGED_INCLUDE_DIR
+ UNMANAGED_COMMON_INCLUDE_DIR
+ UNMANAGED_NLS_INCLUDE_DIR
+ UTILITIES_COMMON_INCLUDE_DIR
+ UTILITIES_TESTCOMMON_INCLUDE_DIR
+ UTILITIES_OWS_INCLUDE_DIR
+ UTILITIES_EXPRESSION_INCLUDE_DIR
+ UTILITIES_SQLITEINTERFACE_INCLUDE_DIR
+ UTILITIES_SCHEMAMGR_INCLUDE_DIR
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindFDOThirdparty.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindFDOThirdparty.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindFDOThirdparty.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,154 @@
+# This file is strictly to check and enable system or internal Thirdparty
+# libraries
+if( ALL_THIRDPARTY )
+ set( INTERNAL_CPPUNIT true )
+ set( INTERNAL_GDAL true )
+ set( INTERNAL_OPENSSL true )
+ set( INTERNAL_MYSQL true )
+ set( INTERNAL_POSTGRESQL true )
+ set( INTERNAL_BOOST true )
+ set( INTERNAL_CURL true )
+ set( INTERNAL_XERCESC true )
+ set( INTERNAL_XALANC true )
+endif( ALL_THIRDPARTY )
+# Check GDAL or add ThirdParty
+if( NOT INTERNAL_GDAL )
+ find_package(GDAL REQUIRED)
+else( NOT INTERNAL_GDAL )
+ set( LOCAL_GDAL TRUE )
+ set( GDAL_LIBRARIES ${FDOTHIRDPARTY}/gdal/lib )
+ set( GDAL_INCLUDE_DIR ${FDOTHIRDPARTY}/gdal
+ ${FDOTHIRDPARTY}/gdal/include
+ ${FDOTHIRDPARTY}/gdal/ogr/ogrsf_frmts
+ message (STATUS "GDAL Include Dir: ${GDAL_INCLUDE_DIR}")
+ find_library( GDAL_LIBRARY NAMES gdal
+ PATHS ${GDAL_LIBRARIES}
+endif( NOT INTERNAL_GDAL )
+# Check MySQL or add ThirdParty
+if( NOT INTERNAL_MYSQL )
+ find_package(MySQL REQUIRED)
+else( NOT INTERNAL_MYSQL )
+ set( LOCAL_MYSQL TRUE )
+endif( NOT INTERNAL_MYSQL )
+# Check PostgreSQL or add Thirdparty
+if (NOT INTERNAL_POSTGRESQL)
+ find_package(PostgreSQL REQUIRED)
+else (NOT INTERNAL_POSTGRESQL)
+ set ( LOCAL_POSTGRESQL TRUE )
+ set ( POSTGRESQL_INCLUDE_DIR ${FDOTHIRDPARTY}/pgsql/include/ )
+ set ( POSTGRESQL_LIBRARIES ${FDOTHIRDPARTY}/pgsql/lib/libpq.a )
+ set ( POSTGRESQL_FOUND TRUE )
+ mark_as_advanced ( POSTGRESQL_INCLUDE_DIR POSTGRESQL_LIBRARIES )
+endif (NOT INTERNAL_POSTGRESQL)
+# Check for Apache or ThirdParty
+if( NOT INTERNAL_APACHE )
+else( NOT INTERNAL_APACHE )
+ set( LOCAL_APACHE TRUE )
+endif( NOT INTERNAL_APACHE )
+# Check for cppunit or ThirdParty
+if( NOT INTERNAL_CPPUNIT )
+ find_package( CppUnit )
+else( NOT INTERNAL_CPPUNIT )
+ set( LOCAL_CPPUNIT TRUE )
+ set( CPPUNIT_LIBRARY_DIR ${FDOTHIRDPARTY}/linux/cppunit/lib )
+ set( CPPUNIT_INCLUDE_DIR ${FDOTHIRDPARTY}/linux/cppunit/include )
+ find_library ( CPPUNIT_LIBRARIES NAMES cppunit
+ PATHS ${CPPUNIT_LIBRARY_DIR}
+ set( CPPUNIT_FOUND TRUE )
+ mark_as_advanced( CPPUNIT_LIBRARY_DIR CPPUNIT_INCLUDE_DIR )
+endif( NOT INTERNAL_CPPUNIT )
+# Check for xerces-c or ThirdParty
+if( NOT INTERNAL_XERCESC )
+ find_package( XercesC REQUIRED )
+else( NOT INTERNAL_XERCESC )
+ set( LOCAL_XERCESC TRUE )
+ set( XERCESC_LIBRARY_DIR ${FDOTHIRDPARTY}/apache/xerces/lib/ )
+ set( XERCESC_INCLUDE_DIR ${FDOTHIRDPARTY}/apache/xerces/src/ )
+ find_library( XERCESC_LIBRARIES NAMES xerces-c
+ PATHS ${XERCESC_LIBRARY_DIR}
+ set( XERCESC_FOUND TRUE )
+ mark_as_advanced( XERCESC_LIBRARY_DIR XERCESC_INCLUDE_DIR )
+endif( NOT INTERNAL_XERCESC )
+# Check for xalan-c or ThirdParty
+if( NOT INTERNAL_XALANC )
+ find_package( XalanC REQUIRED )
+else( NOT INTERNAL_XALANC )
+ set( LOCAL_XALANC TRUE )
+ set( XALANC_LIBRARY_DIR ${FDOTHIRDPARTY}/apache/xalan/lib/ )
+ set( XALANC_INCLUDE_DIR ${FDOTHIRDPARTY}/apache/xalan/src/
+ ${FDOTHIRDPARTY}/apache/xalan/nls/include/
+ find_library( XALANC_LIBRARIES NAMES xalan-c xalanMsg
+ PATHS ${XALANC_LIBRARY_DIR}
+ set( XALANC_FOUND TRUE )
+ mark_as_advanced( XALANC_LIBRARY_DIR XALANC_INCLUDE_DIR )
+endif( NOT INTERNAL_XALANC )
+# SqLite ThirdParty
+set( SQLITE_INCLUDE_DIR ${FDOTHIRDPARTY}/Sqlite3.3.13/Src )
+set( SQLITE_DIR ${FDOTHIRDPARTY}/Sqlite3.3.13/Src )
+mark_as_advanced( SQLITE_INCLUDE_DIR SQLITE_DIR )
+# Check for Boost or ThirdParty
+if( NOT INTERNAL_BOOST )
+ set (Boost_USE_MULTITHREADED ON) # be specific, we're after -mt versions of boost libs
+ find_package( Boost COMPONENTS thread date_time REQUIRED )
+else( NOT INTERNAL_BOOST )
+ set( LOCAL_BOOST TRUE )
+ set( Boost_INCLUDE_DIRS ${FDOTHIRDPARTY}/boost/ )
+ exec_program(
+ ${CMAKE_CXX_COMPILER}
+ ARGS -dumpversion
+ OUTPUT_VARIABLE _compiler_output)
+ string(REGEX REPLACE ".* ([0-9]\\.[0-9]\\.[0-9]) .*" "\\1"
+ gcc_compiler_version ${_compiler_output})
+ message (STATUS "GCC Version is: ${gcc_compiler_version}")
+ # HACK: I give up trying to grok find_library(), we want it to search the super-complex path under ${FDOTHIRDPARTY}
+ # but it still gives us /usr/lib. So set these directly
+ set (Boost_THREAD_LIBRARY ${FDOTHIRDPARTY}/boost/bin.v2/libs/thread/build/gcc-${gcc_compiler_version}/release/link-static/threading-multi/libboost_thread.a )
+ set (Boost_DATE_TIME_LIBRARY ${FDOTHIRDPARTY}/boost/bin.v2/libs/thread/build/gcc-${gcc_compiler_version}/release/link-static/threading-multi/libboost_date_time.a )
+ set (Boost_THREAD_FOUND TRUE)
+ set (Boost_DATE_TIME_FOUND TRUE)
+ mark_as_advanced ( Boost_INCLUDE_DIRS Boost_THREAD_LIBRARY Boost_DATE_TIME_LIBRARY )
+endif( NOT INTERNAL_BOOST )
+# Check for Curl or ThirdParty
+if( NOT INTERNAL_CURL )
+ find_package( CURL REQUIRED )
+else( NOT INTERNAL_CURL )
+ set( LOCAL_CURL TRUE )
+ set( CURL_INCLUDE_DIRS ${FDOTHIRDPARTY}/libcurl/include/ )
+ find_library( CURL_LIBRARIES NAMES curl
+ PATHS ${FDOTHIRDPARTY}/libcurl/lib/ )
+ mark_as_advanced( CURL_INCLUDE_DIRS CURL_LIBRARIES )
+endif( NOT INTERNAL_CURL )
+# Check for OpenSSL or ThirdParty
+if( NOT INTERNAL_OPENSSL )
+ find_package( OpenSSL REQUIRED )
+else( NOT INTERNAL_OPENSSL )
+ set( LOCAL_OPENSSL TRUE )
+ set( OPENSSL_INCLUDE_DIR ${FDOTHIRDPARTY}/openssl/ )
+ set( OPENSSL_LIBRARY ${FDOTHIRDPARTY}/openssl/lib/linux/libssl.a )
+ set( OPENSSL_CRYPTO_LIBRARY ${FDOTHIRDPARTY}/openssl/lib/linux/libcrypto.a )
+ set( OPENSSL_LIBRARIES ${OPENSSL_LIBRARY}
+ ${OPENSSL_CRYPTO_LIBRARY} )
+ message (STATUS "Using OpenSSL: ${OPENSSL_LIBRARIES}")
+ mark_as_advanced( OPENSSL_INCLUDE_DIR OPENSSL_LIBRARIES )
+endif( NOT INTERNAL_OPENSSL )
+# TODO
+# Check UnixODBC
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgFoundation.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgFoundation.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgFoundation.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find MgFoundation component
+IF (MgFoundation_INCLUDE_DIR AND MgFoundation_LIBRARIES)
+ SET(MgFoundation_FIND_QUIETLY TRUE)
+ENDIF (MgFoundation_INCLUDE_DIR AND MgFoundation_LIBRARIES)
+FIND_PATH(MgFoundation_INCLUDE_DIR Foundation.h
+ HINTS
+ ${MG_SRC_ROOT}/../Common/Foundation
+FIND_LIBRARY(MgFoundation_LIBRARIES NAMES MgFoundation
+ HINTS
+ ${MG_LIB_DIR}
+ ${MG_SRC_ROOT}/../Common/.libs
+find_package_handle_standard_args(MgFoundation DEFAULT_MSG
+ MgFoundation_INCLUDE_DIR MgFoundation_LIBRARIES)
+MARK_AS_ADVANCED(MgFoundation_INCLUDE_DIR MgFoundation_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgGeometry.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgGeometry.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgGeometry.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find MgGeometry component
+IF (MgGeometry_INCLUDE_DIR AND MgGeometry_LIBRARIES)
+ SET(MgGeometry_FIND_QUIETLY TRUE)
+ENDIF (MgGeometry_INCLUDE_DIR AND MgGeometry_LIBRARIES)
+FIND_PATH(MgGeometry_INCLUDE_DIR Geometry.h
+ HINTS
+ ${MG_SRC_ROOT}/../Common/Geometry
+FIND_LIBRARY(MgGeometry_LIBRARIES NAMES MgGeometry
+ HINTS
+ ${MG_LIB_DIR}
+find_package_handle_standard_args(MgGeometry DEFAULT_MSG
+ MgGeometry_INCLUDE_DIR MgGeometry_LIBRARIES)
+MARK_AS_ADVANCED(MgGeometry_INCLUDE_DIR MgGeometry_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgGwsCommon.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgGwsCommon.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgGwsCommon.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find MgGwsCommon component
+IF (MgGwsCommon_INCLUDE_DIR AND MgGwsCommon_LIBRARIES)
+ SET(MgGwsCommon_FIND_QUIETLY TRUE)
+ENDIF (MgGwsCommon_INCLUDE_DIR AND MgGwsCommon_LIBRARIES)
+FIND_PATH(MgGwsCommon_INCLUDE_DIR GwsCommonImp.h
+ HINTS
+ ${MG_SRC_ROOT}/../Server/src/Gws/GwsCommon/inc
+FIND_LIBRARY(MgGwsCommon_LIBRARIES NAMES MgGwsCommon
+ HINTS
+ ${MG_LIB_DIR}
+ ${MG_SRC_ROOT}/../Server/src/Gws/GwsCommon/.libs
+find_package_handle_standard_args(MgGwsCommon DEFAULT_MSG
+ MgGwsCommon_INCLUDE_DIR MgGwsCommon_LIBRARIES)
+MARK_AS_ADVANCED(MgGwsCommon_INCLUDE_DIR MgGwsCommon_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgGwsQueryEngine.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgGwsQueryEngine.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgGwsQueryEngine.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find MgGwsQueryEngine component
+IF (MgGwsQueryEngine_INCLUDE_DIR AND MgGwsQueryEngine_LIBRARIES)
+ SET(MgGwsQueryEngine_FIND_QUIETLY TRUE)
+ENDIF (MgGwsQueryEngine_INCLUDE_DIR AND MgGwsQueryEngine_LIBRARIES)
+FIND_PATH(MgGwsQueryEngine_INCLUDE_DIR GwsQueryEngine.h
+ HINTS
+ ${MG_SRC_ROOT}/../Server/src/Gws/Include
+FIND_LIBRARY(MgGwsQueryEngine_LIBRARIES NAMES MgGwsQueryEngine
+ HINTS
+ ${MG_LIB_DIR}
+ ${MG_SRC_ROOT}/../Server/src/Gws/GwsQueryEngine/.libs
+find_package_handle_standard_args(MgGwsQueryEngine DEFAULT_MSG
+ MgGwsQueryEngine_INCLUDE_DIR MgGwsQueryEngine_LIBRARIES)
+MARK_AS_ADVANCED(MgGwsQueryEngine_INCLUDE_DIR MgGwsQueryEngine_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgMdfModel.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgMdfModel.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgMdfModel.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find MgMdfModel component
+IF (MgMdfModel_INCLUDE_DIR AND MgMdfModel_LIBRARIES)
+ SET(MgMdfModel_FIND_QUIETLY TRUE)
+ENDIF (MgMdfModel_INCLUDE_DIR AND MgMdfModel_LIBRARIES)
+FIND_PATH(MgMdfModel_INCLUDE_DIR MdfModel.h
+ HINTS
+ ${MG_SRC_ROOT}/../Common/MdfModel
+FIND_LIBRARY(MgMdfModel_LIBRARIES NAMES MgMdfModel
+ HINTS
+ ${MG_LIB_DIR}
+find_package_handle_standard_args(MgMdfModel DEFAULT_MSG
+ MgMdfModel_INCLUDE_DIR MgMdfModel_LIBRARIES)
+MARK_AS_ADVANCED(MgMdfModel_INCLUDE_DIR MgMdfModel_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgMdfParser.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgMdfParser.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgMdfParser.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find MgMdfParser component
+IF (MgMdfParser_INCLUDE_DIR AND MgMdfParser_LIBRARIES)
+ SET(MgMdfParser_FIND_QUIETLY TRUE)
+ENDIF (MgMdfParser_INCLUDE_DIR AND MgMdfParser_LIBRARIES)
+FIND_PATH(MgMdfParser_INCLUDE_DIR MdfParser.h
+ HINTS
+ ${MG_SRC_ROOT}/../Common/MdfParser
+FIND_LIBRARY(MgMdfParser_LIBRARIES NAMES MgMdfParser
+ HINTS
+ ${MG_LIB_DIR}
+find_package_handle_standard_args(MgMdfParser DEFAULT_MSG
+ MgMdfParser_INCLUDE_DIR MgMdfParser_LIBRARIES)
+MARK_AS_ADVANCED(MgMdfParser_INCLUDE_DIR MgMdfParser_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgPlatformBase.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgPlatformBase.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgPlatformBase.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find MgPlatformBase component
+IF (MgPlatformBase_INCLUDE_DIR AND MgPlatformBase_LIBRARIES)
+ SET(MgPlatformBase_FIND_QUIETLY TRUE)
+ENDIF (MgPlatformBase_INCLUDE_DIR AND MgPlatformBase_LIBRARIES)
+FIND_PATH(MgPlatformBase_INCLUDE_DIR PlatformBase.h
+ HINTS
+ ${MG_SRC_ROOT}/../Common/PlatformBase
+FIND_LIBRARY(MgPlatformBase_LIBRARIES NAMES MgPlatformBase
+ HINTS
+ ${MG_LIB_DIR}
+find_package_handle_standard_args(MgPlatformBase DEFAULT_MSG
+ MgPlatformBase_INCLUDE_DIR MgPlatformBase_LIBRARIES)
+MARK_AS_ADVANCED(MgPlatformBase_INCLUDE_DIR MgPlatformBase_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgRenderers.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgRenderers.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgRenderers.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find MgRenderers component
+IF (MgRenderers_INCLUDE_DIR AND MgRenderers_LIBRARIES)
+ SET(MgRenderers_FIND_QUIETLY TRUE)
+ENDIF (MgRenderers_INCLUDE_DIR AND MgRenderers_LIBRARIES)
+FIND_PATH(MgRenderers_INCLUDE_DIR Renderers.h
+ HINTS
+ ${MG_SRC_ROOT}/../Common/Renderers
+FIND_LIBRARY(MgRenderers_LIBRARIES NAMES MgRenderers
+ HINTS
+ ${MG_LIB_DIR}
+find_package_handle_standard_args(MgRenderers DEFAULT_MSG
+ MgRenderers_INCLUDE_DIR MgRenderers_LIBRARIES)
+MARK_AS_ADVANCED(MgRenderers_INCLUDE_DIR MgRenderers_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgSecurity.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgSecurity.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgSecurity.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,27 @@
+# - Find MgSecurity component
+IF (MgSecurity_INCLUDE_DIR AND MgSecurity_LIBRARIES)
+ SET(MgSecurity_FIND_QUIETLY TRUE)
+ENDIF (MgSecurity_INCLUDE_DIR AND MgSecurity_LIBRARIES)
+FIND_PATH(MgSecurity_INCLUDE_DIR CryptographyUtil.h
+ HINTS
+ ${MG_SRC_ROOT}/../Common/Security
+FIND_LIBRARY(MgSecurity_LIBRARIES NAMES MgSecurity
+ HINTS
+find_package_handle_standard_args(MgSecurity DEFAULT_MSG
+ MgSecurity_INCLUDE_DIR MgSecurity_LIBRARIES)
+MARK_AS_ADVANCED(MgSecurity_INCLUDE_DIR MgSecurity_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMgStylization.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMgStylization.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMgStylization.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,28 @@
+# - Find MgStylization component
+IF (MgStylization_INCLUDE_DIR AND MgStylization_LIBRARIES)
+ SET(MgStylization_FIND_QUIETLY TRUE)
+ENDIF (MgStylization_INCLUDE_DIR AND MgStylization_LIBRARIES)
+FIND_PATH(MgStylization_INCLUDE_DIR Stylization.h
+ HINTS
+ ${MG_SRC_ROOT}/../Common/Stylization
+FIND_LIBRARY(MgStylization_LIBRARIES NAMES MgStylization
+ HINTS
+ ${MG_LIB_DIR}
+find_package_handle_standard_args(MgStylization DEFAULT_MSG
+ MgStylization_INCLUDE_DIR MgStylization_LIBRARIES)
+MARK_AS_ADVANCED(MgStylization_INCLUDE_DIR MgStylization_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindMySQL.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindMySQL.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindMySQL.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,138 @@
+# - Try to find MySQL / MySQL Embedded library
+# Find the MySQL includes and client library
+# This module defines
+# MYSQL_INCLUDE_DIR, where to find mysql.h
+# MYSQL_LIBRARIES, the libraries needed to use MySQL.
+# MYSQL_LIB_DIR, path to the MYSQL_LIBRARIES
+# MYSQL_EMBEDDED_LIBRARIES, the libraries needed to use MySQL Embedded.
+# MYSQL_EMBEDDED_LIB_DIR, path to the MYSQL_EMBEDDED_LIBRARIES
+# MYSQL_FOUND, If false, do not try to use MySQL.
+# MYSQL_EMBEDDED_FOUND, If false, do not try to use MySQL Embedded.
+# Copyright (c) 2006-2008, Jarosław Staniek <staniek at kde.org>
+include(CheckCXXSourceCompiles)
+include(MacroPushRequiredVars)
+if(WIN32)
+ find_path(MYSQL_INCLUDE_DIR mysql.h
+ PATHS
+ $ENV{MYSQL_INCLUDE_DIR}
+ $ENV{MYSQL_DIR}/include
+ $ENV{ProgramFiles}/MySQL/*/include
+ $ENV{SystemDrive}/MySQL/*/include
+else(WIN32)
+ PATHS
+ /usr/local/mysql/include
+ /opt/mysql/mysql/include
+ PATH_SUFFIXES
+ mysql
+endif(WIN32)
+if(WIN32)
+ # path suffix for debug/release mode
+ # binary_dist: mysql binary distribution
+ # build_dist: custom build
+ if(CMAKE_BUILD_TYPE STREQUAL "Debug")
+ set(binary_dist debug)
+ set(build_dist Debug)
+ else(CMAKE_BUILD_TYPE STREQUAL "Debug")
+ ADD_DEFINITIONS(-DDBUG_OFF)
+ set(binary_dist opt)
+ set(build_dist Release)
+ endif(CMAKE_BUILD_TYPE STREQUAL "Debug")
+# find_library(MYSQL_LIBRARIES NAMES mysqlclient
+ find_library(MYSQL_LIBRARIES NAMES libmysql
+ PATHS
+ $ENV{MYSQL_DIR}/lib/${binary_dist}
+ $ENV{MYSQL_DIR}/libmysql/${build_dist}
+ $ENV{MYSQL_DIR}/client/${build_dist}
+ $ENV{ProgramFiles}/MySQL/*/lib/${binary_dist}
+ $ENV{SystemDrive}/MySQL/*/lib/${binary_dist}
+else(WIN32)
+ PATHS
+ $ENV{MYSQL_DIR}/libmysql_r/.libs
+ $ENV{MYSQL_DIR}/lib/mysql
+ /usr/local/mysql/lib
+ /opt/mysql/mysql/lib
+ PATH_SUFFIXES
+ mysql
+endif(WIN32)
+if(WIN32)
+ set(MYSQL_LIB_PATHS
+ $ENV{MYSQL_DIR}/lib/opt
+ $ENV{MYSQL_DIR}/client/release
+ $ENV{ProgramFiles}/MySQL/*/lib/opt
+ $ENV{SystemDrive}/MySQL/*/lib/opt
+ find_library(MYSQL_LIBRARIES NAMES mysqlclient
+ PATHS
+ ${MYSQL_LIB_PATHS}
+else(WIN32)
+ PATH_SUFFIXES
+ mysql
+ PATHS
+endif(WIN32)
+find_library(MYSQL_EMBEDDED_LIBRARIES NAMES mysqld
+ PATHS
+if(MYSQL_LIBRARIES)
+ get_filename_component(MYSQL_LIB_DIR ${MYSQL_LIBRARIES} PATH)
+endif(MYSQL_LIBRARIES)
+if(MYSQL_EMBEDDED_LIBRARIES)
+ get_filename_component(MYSQL_EMBEDDED_LIB_DIR ${MYSQL_EMBEDDED_LIBRARIES} PATH)
+endif(MYSQL_EMBEDDED_LIBRARIES)
+macro_push_required_vars()
+set( CMAKE_REQUIRED_INCLUDES ${MYSQL_INCLUDE_DIR} )
+set( CMAKE_REQUIRED_LIBRARIES ${MYSQL_EMBEDDED_LIBRARIES} )
+check_cxx_source_compiles( "#include <mysql.h>\nint main() { int i = MYSQL_OPT_USE_EMBEDDED_CONNECTION; }" HAVE_MYSQL_OPT_EMBEDDED_CONNECTION )
+macro_pop_required_vars()
+if(MYSQL_INCLUDE_DIR AND MYSQL_LIBRARIES)
+ set(MYSQL_FOUND TRUE)
+ message(STATUS "Found MySQL: ${MYSQL_INCLUDE_DIR}, ${MYSQL_LIBRARIES}")
+else(MYSQL_INCLUDE_DIR AND MYSQL_LIBRARIES)
+ set(MYSQL_FOUND FALSE)
+ message(STATUS "MySQL not found.")
+endif(MYSQL_INCLUDE_DIR AND MYSQL_LIBRARIES)
+if(MYSQL_INCLUDE_DIR AND MYSQL_EMBEDDED_LIBRARIES AND HAVE_MYSQL_OPT_EMBEDDED_CONNECTION)
+ set(MYSQL_EMBEDDED_FOUND TRUE)
+ message(STATUS "Found MySQL Embedded: ${MYSQL_INCLUDE_DIR}, ${MYSQL_EMBEDDED_LIBRARIES}")
+else(MYSQL_INCLUDE_DIR AND MYSQL_EMBEDDED_LIBRARIES AND HAVE_MYSQL_OPT_EMBEDDED_CONNECTION)
+ set(MYSQL_EMBEDDED_FOUND FALSE)
+ message(STATUS "MySQL Embedded not found.")
+endif(MYSQL_INCLUDE_DIR AND MYSQL_EMBEDDED_LIBRARIES AND HAVE_MYSQL_OPT_EMBEDDED_CONNECTION)
+mark_as_advanced(MYSQL_INCLUDE_DIR MYSQL_LIBRARIES MYSQL_EMBEDDED_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindPostgreSQL.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindPostgreSQL.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindPostgreSQL.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,37 @@
+# - Find PostgreSQL
+# Find the PostgreSQL includes and client library
+# POSTGRESQL_INCLUDE_DIR, where to find POSTGRESQL.h
+# POSTGRESQL_LIBRARIES, the libraries needed to use POSTGRESQL.
+# POSTGRESQL_FOUND, If false, do not try to use PostgreSQL.
+# Copyright (c) 2006, Jaroslaw Staniek, <js at iidea.pl>
+if (POSTGRESQL_INCLUDE_DIR AND POSTGRESQL_LIBRARIES)
+ # Already in cache, be silent
+ set(PostgreSQL_FIND_QUIETLY TRUE)
+endif (POSTGRESQL_INCLUDE_DIR AND POSTGRESQL_LIBRARIES)
+find_path(POSTGRESQL_INCLUDE_DIR libpq-fe.h
+ /usr/include/pgsql/
+ /usr/local/include/pgsql/
+ /usr/include/postgresql/
+find_library(POSTGRESQL_LIBRARIES NAMES pq)
+find_package_handle_standard_args(PostgreSQL DEFAULT_MSG
+ POSTGRESQL_INCLUDE_DIR POSTGRESQL_LIBRARIES )
+if (POSTGRESQL_FOUND)
+ message(STATUS "Found PostgreSQL: ${POSTGRESQL_INCLUDE_DIR}, ${POSTGRESQL_LIBRARIES}")
+endif (POSTGRESQL_FOUND)
+mark_as_advanced(POSTGRESQL_INCLUDE_DIR POSTGRESQL_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindSqlite.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindSqlite.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindSqlite.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,50 @@
+# - Try to find Sqlite
+# SQLITE_FOUND - system has Sqlite
+# SQLITE_INCLUDE_DIR - the Sqlite include directory
+# SQLITE_LIBRARIES - Link these to use Sqlite
+# SQLITE_DEFINITIONS - Compiler switches required for using Sqlite
+# Copyright (c) 2008, Gilles Caulier, <caulier.gilles at gmail.com>
+if ( SQLITE_INCLUDE_DIR AND SQLITE_LIBRARIES )
+ SET(Sqlite_FIND_QUIETLY TRUE)
+endif ( SQLITE_INCLUDE_DIR AND SQLITE_LIBRARIES )
+# use pkg-config to get the directories and then use these values
+# in the FIND_PATH() and FIND_LIBRARY() calls
+if( NOT WIN32 )
+ find_package(PkgConfig)
+ pkg_check_modules(PC_SQLITE sqlite3)
+ set(SQLITE_DEFINITIONS ${PC_SQLITE_CFLAGS_OTHER})
+endif( NOT WIN32 )
+FIND_PATH(SQLITE_INCLUDE_DIR NAMES sqlite3.h
+ PATHS
+ ${PC_SQLITE_INCLUDEDIR}
+ ${PC_SQLITE_INCLUDE_DIRS}
+FIND_LIBRARY(SQLITE_LIBRARIES NAMES sqlite3
+ PATHS
+ ${PC_SQLITE_LIBDIR}
+ ${PC_SQLITE_LIBRARY_DIRS}
+FIND_PACKAGE_HANDLE_STANDARD_ARGS(Sqlite DEFAULT_MSG SQLITE_INCLUDE_DIR SQLITE_LIBRARIES )
+# show the SQLITE_INCLUDE_DIR and SQLITE_LIBRARIES variables only in the advanced view
+MARK_AS_ADVANCED(SQLITE_INCLUDE_DIR SQLITE_LIBRARIES )
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindXalanC.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindXalanC.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindXalanC.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,35 @@
+# - Try to find XalanC
+# XALANC_FOUND - System has XalanC
+# XALANC_INCLUDE_DIR - The XalanC include directory
+# XALANC_LIBRARY_DIR - The XalanC library dir
+# XALANC_LIBRARIES - The libraries needed to use XalanC
+# XALANC_DEFINITIONS - Compiler switches required for using XalanC
+IF (XALANC_INCLUDE_DIR AND XALANC_LIBRARIES)
+ SET(XalanC_FIND_QUIETLY TRUE)
+ENDIF (XALANC_INCLUDE_DIR AND XALANC_LIBRARIES)
+FIND_PATH(XALANC_INCLUDE_DIR DOMSupport/DOMServices.hpp
+ PATHS
+ /usr/local/include/xalanc
+ /usr/include/xalanc
+ PATH_SUFFIXES
+ xalanc
+FIND_LIBRARY(XALANC_LIBRARIES NAMES xalan-c xalanMsg)
+FIND_PACKAGE_HANDLE_STANDARD_ARGS(XalanC DEFAULT_MSG XALANC_LIBRARIES XALANC_INCLUDE_DIR)
+MARK_AS_ADVANCED(XALANC_INCLUDE_DIR XALANC_LIBRARIES XALANC_LIBRARY_DIR)
Added: branches/2.6/MgDev/Desktop/cmake/modules/FindXercesC.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/FindXercesC.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/FindXercesC.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,34 @@
+# - Try to find XercesC
+# XercesC_FOUND - System has XercesC
+# XercesC_INCLUDE_DIR - The XercesC include directory
+# XercesC_LIBRARIES - The libraries needed to use XercesC
+# Copyright (c) 2009, Helio Chissini de Castro, <helio at kde.org>. Modified for use by mg-desktop by Jackie Ng <jumpinjackie at gmail.com>
+IF (XercesC_INCLUDE_DIR AND XercesC_LIBRARIES)
+ SET(XercesC_FIND_QUIETLY TRUE)
+ENDIF (XercesC_INCLUDE_DIR AND XercesC_LIBRARIES)
+FIND_PATH(XercesC_INCLUDE_DIR xercesc/util/PlatformUtils.hpp
+ HINTS
+ ${MG_SRC_ROOT}/../Oem/dbxml/xerces-c-src/src
+ PATH_SUFFIXES xerces-c
+FIND_LIBRARY(XercesC_LIBRARIES NAMES xerces-c
+ HINTS
+ ${MG_LIB_DIR}
+ ${MG_SRC_ROOT}/../Oem/dbxml/xerces-c-src/src/.libs
+find_package_handle_standard_args(XercesC DEFAULT_MSG
+ XercesC_INCLUDE_DIR XercesC_LIBRARIES)
+MARK_AS_ADVANCED(XercesC_INCLUDE_DIR XercesC_LIBRARIES)
Added: branches/2.6/MgDev/Desktop/cmake/modules/MacroOptionalAddSubdirectory.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/MacroOptionalAddSubdirectory.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/MacroOptionalAddSubdirectory.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,41 @@
+# - MACRO_OPTIONAL_ADD_SUBDIRECTORY() combines ADD_SUBDIRECTORY() with an OPTION()
+# MACRO_OPTIONAL_ADD_SUBDIRECTORY( <dir> )
+# If you use MACRO_OPTIONAL_ADD_SUBDIRECTORY() instead of ADD_SUBDIRECTORY(),
+# this will have two effects
+# 1 - CMake will not complain if the directory doesn't exist
+# This makes sense if you want to distribute just one of the subdirs
+# in a source package, e.g. just one of the subdirs in kdeextragear.
+# 2 - If the directory exists, it will offer an option to skip the
+# subdirectory.
+# This is useful if you want to compile only a subset of all
+# directories.
+# If the CMake variable DISABLE_ALL_OPTIONAL_SUBDIRECTORIES is set to TRUE
+# for the first CMake run on the project, all optional subdirectories will be disabled
+# by default (but can of course be enabled via the respective options).
+# E.g. the following will disable all optional subdirectories except the one named "kcalc":
+# $ cmake -DDISABLE_ALL_OPTIONAL_SUBDIRECTORIES=TRUE -DBUILD_kcalc=TRUE <srcdir>
+# Copyright (c) 2007, Alexander Neundorf, <neundorf at kde.org>
+MACRO (MACRO_OPTIONAL_ADD_SUBDIRECTORY _dir )
+ GET_FILENAME_COMPONENT(_fullPath ${_dir} ABSOLUTE)
+ IF(EXISTS ${_fullPath})
+ IF(DISABLE_ALL_OPTIONAL_SUBDIRECTORIES)
+ SET(_DEFAULT_OPTION_VALUE FALSE)
+ ELSE(DISABLE_ALL_OPTIONAL_SUBDIRECTORIES)
+ SET(_DEFAULT_OPTION_VALUE TRUE)
+ ENDIF(DISABLE_ALL_OPTIONAL_SUBDIRECTORIES)
+ IF(DISABLE_ALL_OPTIONAL_SUBDIRS AND NOT DEFINED BUILD_${_dir})
+ ENDIF(DISABLE_ALL_OPTIONAL_SUBDIRS AND NOT DEFINED BUILD_${_dir})
+ OPTION(BUILD_${_dir} "Build directory ${_dir}" ${_DEFAULT_OPTION_VALUE})
+ IF(BUILD_${_dir})
+ ADD_SUBDIRECTORY(${_dir})
+ ENDIF(BUILD_${_dir})
+ ENDIF(EXISTS ${_fullPath})
+ENDMACRO (MACRO_OPTIONAL_ADD_SUBDIRECTORY)
Added: branches/2.6/MgDev/Desktop/cmake/modules/MacroPushRequiredVars.cmake
--- branches/2.6/MgDev/Desktop/cmake/modules/MacroPushRequiredVars.cmake (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/MacroPushRequiredVars.cmake 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,47 @@
+# this module defines two macros:
+# MACRO_PUSH_REQUIRED_VARS()
+# and
+# MACRO_POP_REQUIRED_VARS()
+# use these if you call cmake macros which use
+# any of the CMAKE_REQUIRED_XXX variables
+# Usage:
+# SET(CMAKE_REQUIRED_DEFINITIONS ${CMAKE_REQUIRED_DEFINITIONS} -DSOME_MORE_DEF)
+# CHECK_FUNCTION_EXISTS(...)
+# Copyright (c) 2006, Alexander Neundorf, <neundorf at kde.org>
+MACRO(MACRO_PUSH_REQUIRED_VARS)
+ IF(NOT DEFINED _PUSH_REQUIRED_VARS_COUNTER)
+ SET(_PUSH_REQUIRED_VARS_COUNTER 0)
+ ENDIF(NOT DEFINED _PUSH_REQUIRED_VARS_COUNTER)
+ MATH(EXPR _PUSH_REQUIRED_VARS_COUNTER "${_PUSH_REQUIRED_VARS_COUNTER}+1")
+ SET(_CMAKE_REQUIRED_INCLUDES_SAVE_${_PUSH_REQUIRED_VARS_COUNTER} ${CMAKE_REQUIRED_INCLUDES})
+ SET(_CMAKE_REQUIRED_DEFINITIONS_SAVE_${_PUSH_REQUIRED_VARS_COUNTER} ${CMAKE_REQUIRED_DEFINITIONS})
+ SET(_CMAKE_REQUIRED_LIBRARIES_SAVE_${_PUSH_REQUIRED_VARS_COUNTER} ${CMAKE_REQUIRED_LIBRARIES})
+ SET(_CMAKE_REQUIRED_FLAGS_SAVE_${_PUSH_REQUIRED_VARS_COUNTER} ${CMAKE_REQUIRED_FLAGS})
+ENDMACRO(MACRO_PUSH_REQUIRED_VARS)
+MACRO(MACRO_POP_REQUIRED_VARS)
+# don't pop more than we pushed
+ IF("${_PUSH_REQUIRED_VARS_COUNTER}" GREATER "0")
+ SET(CMAKE_REQUIRED_INCLUDES ${_CMAKE_REQUIRED_INCLUDES_SAVE_${_PUSH_REQUIRED_VARS_COUNTER}})
+ SET(CMAKE_REQUIRED_DEFINITIONS ${_CMAKE_REQUIRED_DEFINITIONS_SAVE_${_PUSH_REQUIRED_VARS_COUNTER}})
+ SET(CMAKE_REQUIRED_LIBRARIES ${_CMAKE_REQUIRED_LIBRARIES_SAVE_${_PUSH_REQUIRED_VARS_COUNTER}})
+ SET(CMAKE_REQUIRED_FLAGS ${_CMAKE_REQUIRED_FLAGS_SAVE_${_PUSH_REQUIRED_VARS_COUNTER}})
+ MATH(EXPR _PUSH_REQUIRED_VARS_COUNTER "${_PUSH_REQUIRED_VARS_COUNTER}-1")
+ ENDIF("${_PUSH_REQUIRED_VARS_COUNTER}" GREATER "0")
+ENDMACRO(MACRO_POP_REQUIRED_VARS)
Added: branches/2.6/MgDev/Desktop/cmake/modules/TestCmakeVersion.cxx
--- branches/2.6/MgDev/Desktop/cmake/modules/TestCmakeVersion.cxx (rev 0)
+++ branches/2.6/MgDev/Desktop/cmake/modules/TestCmakeVersion.cxx 2014-05-15 16:51:12 UTC (rev 8132)
@@ -0,0 +1,18 @@
+#include <cppunit/config-auto.h>
+#include <cstdlib>
+#include <cstdio>
+// Simple test against arbitrary versions > 1.10
+#define MIN_MAJOR 1
+#define MIN_MINOR 10
+int main(int, char*[])
+ char *base;
+ if( strtol( CPPUNIT_VERSION, &base, 10 ) == MIN_MAJOR )
+ if( strtol( ++base, NULL, 10 ) >= MIN_MINOR )
+ return 1;
+ return 0;
+ return 0;
More information about the mapguide-commits
