[mapguide-commits] r8141 - branches/2.6/MgDev/Common/MapGuideCommon/Services
svn_mapguide at osgeo.org
Wed May 21 00:07:10 PDT 2014
Author: jng
Date: 2014-05-21 00:07:10 -0700 (Wed, 21 May 2014)
New Revision: 8141
branches/2.6/MgDev/Common/MapGuideCommon/Services/RenderingService.h
Fix up the API documentation for MgRenderingService::RenderTile. This method is just a tile rendering primitive. No tile caching is done by this method.
Modified: branches/2.6/MgDev/Common/MapGuideCommon/Services/RenderingService.h
--- branches/2.6/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2014-05-21 04:49:32 UTC (rev 8140)
+++ branches/2.6/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2014-05-21 07:07:10 UTC (rev 8141)
@@ -39,10 +39,13 @@
/// \brief
- /// Returns the specified base map tile for the given map. If a cached tile
- /// image exists it will return it, otherwise the tile is rendered and added
- /// to the cache.
+ /// Returns the specified base map tile for the given map.
+ /// \remarks
+ /// This method only renders the given tile. No tile caching is performed
+ /// by this method. To render and cache the tile, use the
+ /// \link MgTileService::GetTile GetTile \endlink method instead
/// \param map
/// Input
/// map object containing current state of map.
More information about the mapguide-commits
