[mapguide-commits] r8147 - in branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan: . Library/Samples/Sheboygan Library/Samples/Sheboygan/Layers_Advanced Library/Samples/Sheboygan/Layouts Library/Samples/Sheboygan/Maps Library/Samples/Sheboygan/Symbols Library/Samples/Sheboygan/Watermarks
svn_mapguide at osgeo.org
Fri May 23 03:33:50 PDT 2014
Author: jng
Date: 2014-05-23 03:33:50 -0700 (Fri, 23 May 2014)
New Revision: 8147
Added:
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
#2031: Add an Advanced Stylization version of the Sheboygan map, where all the layers are using Advanced Stylization
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,99 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="LayerDefinition-2.4.0.xsd">
+ <VectorLayerDefinition>
+ <ResourceId>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>SHP_Schema:BuildingOutlines</FeatureName>
+ <FeatureNameType>FeatureClass</FeatureNameType>
+ <Geometry>SHPGEOM</Geometry>
+ <VectorScaleRange>
+ <MaxScale>1500</MaxScale>
+ <CompositeTypeStyle>
+ <CompositeRule>
+ <LegendLabel/>
+ <CompositeSymbolization>
+ <SymbolInstance>
+ <SimpleSymbolDefinition>
+ <Name>Solid Fill</Name>
+ <Description>Default Area Symbol</Description>
+ <Graphics>
+ <Path>
+ <Geometry>M 0.0,0.0 h 100.0 v 100.0 h -100.0 z</Geometry>
+ <FillColor>%FILLCOLOR%</FillColor>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ <RepeatX>100.0</RepeatX>
+ <RepeatY>100.0</RepeatY>
+ </AreaUsage>
+ <ParameterDefinition>
+ <Parameter>
+ <Identifier>FILLCOLOR</Identifier>
+ <DefaultValue>0xff808080</DefaultValue>
+ <DisplayName>&Fill Color</DisplayName>
+ <Description>Fill Color</Description>
+ <DataType>FillColor</DataType>
+ </Parameter>
+ </ParameterDefinition>
+ </SimpleSymbolDefinition>
+ <ParameterOverrides>
+ <Override>
+ <SymbolName>Solid Fill</SymbolName>
+ <ParameterIdentifier>FILLCOLOR</ParameterIdentifier>
+ <ParameterValue>0xff808080</ParameterValue>
+ </Override>
+ </ParameterOverrides>
+ <GeometryContext>Polygon</GeometryContext>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Name>Solid Line</Name>
+ <Description>Default Line Symbol</Description>
+ <Graphics>
+ <Path>
+ <Geometry>M 0.0,0.0 L 1.0,0.0</Geometry>
+ <LineColor>%LINECOLOR%</LineColor>
+ <LineWeight>%LINEWEIGHT%</LineWeight>
+ <LineWeightScalable>false</LineWeightScalable>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ <Repeat>1.0</Repeat>
+ </LineUsage>
+ <Parameter>
+ <Identifier>LINECOLOR</Identifier>
+ <DefaultValue>0xffdddddd</DefaultValue>
+ <DisplayName>Line &Color</DisplayName>
+ <Description>Line Color</Description>
+ <DataType>LineColor</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>LINEWEIGHT</Identifier>
+ <DefaultValue>0.0</DefaultValue>
+ <DisplayName>Line & Thickness</DisplayName>
+ <Description>Line Thickness</Description>
+ <DataType>LineWeight</DataType>
+ </Parameter>
+ <Override>
+ <SymbolName>Solid Line</SymbolName>
+ <ParameterIdentifier>LINECOLOR</ParameterIdentifier>
+ <ParameterValue>0xffdddddd</ParameterValue>
+ </Override>
+ <Override>
+ <ParameterIdentifier>LINEWEIGHT</ParameterIdentifier>
+ <ParameterValue>0.0</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ </CompositeSymbolization>
+ </CompositeRule>
+ </CompositeTypeStyle>
+ </VectorScaleRange>
+ </VectorLayerDefinition>
+</LayerDefinition>
\ No newline at end of file
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+<ResourceDocumentHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
+ <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
+ <Inherited>true</Inherited>
+ </Security>
+</ResourceDocumentHeader>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,188 @@
+ <ResourceId>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>SHP_Schema:CityLimits</FeatureName>
+ <MaxScale>10000</MaxScale>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xffc0c0c0</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffc0c0c0</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+ <MinScale>10000</MinScale>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xffd5c8ac</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffd5c8ac</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+</LayerDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,290 @@
+ <ResourceId>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>Default:VotingDistricts</FeatureName>
+ <Geometry>Geometry</Geometry>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0x00ffffff</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0x00ffffff</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ <DefaultValue>0xffa68b53</DefaultValue>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffa68b53</ParameterValue>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Name>MTEXT</Name>
+ <Description>Default MTEXT Symbol</Description>
+ <Graphics>
+ <Text>
+ <Content>%CONTENT%</Content>
+ <FontName>%FONTNAME%</FontName>
+ <Bold>%BOLD%</Bold>
+ <Italic>%ITALIC%</Italic>
+ <Underlined>%UNDERLINED%</Underlined>
+ <Overlined>%OVERLINED%</Overlined>
+ <Height>%FONTHEIGHT%</Height>
+ <PositionX>%StyleEditorGenerated_TextPositionX_0%</PositionX>
+ <PositionY>%StyleEditorGenerated_TextPositionY_0%</PositionY>
+ <HorizontalAlignment>%HORIZONTALALIGNMENT%</HorizontalAlignment>
+ <VerticalAlignment>%VERTICALALIGNMENT%</VerticalAlignment>
+ <Justification>%JUSTIFICATION%</Justification>
+ <LineSpacing>%LINESPACING%</LineSpacing>
+ <TextColor>%TEXTCOLOR%</TextColor>
+ <GhostColor>%GHOSTCOLOR%</GhostColor>
+ <Frame>
+ <LineColor>%FRAMELINECOLOR%</LineColor>
+ <FillColor>%FRAMEFILLCOLOR%</FillColor>
+ <OffsetX>0</OffsetX>
+ <OffsetY>0</OffsetY>
+ </Frame>
+ <Markup>'MTEXT'</Markup>
+ </Text>
+ </Graphics>
+ <AreaUsage>
+ <Angle>%ROTATION%</Angle>
+ </AreaUsage>
+ <Parameter>
+ <Identifier>CONTENT</Identifier>
+ <DefaultValue>Concat('District ', FeatId)</DefaultValue>
+ <DisplayName>T&ext</DisplayName>
+ <Description>Text</Description>
+ <DataType>Content</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>FONTNAME</Identifier>
+ <DefaultValue>'Verdana'</DefaultValue>
+ <DisplayName>&Font Name</DisplayName>
+ <Description>Font Name</Description>
+ <DataType>FontName</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>FONTHEIGHT</Identifier>
+ <DefaultValue>3.5</DefaultValue>
+ <DisplayName>Font &Size</DisplayName>
+ <Description>Font Size</Description>
+ <DataType>FontHeight</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>BOLD</Identifier>
+ <DefaultValue>false</DefaultValue>
+ <DisplayName>Bold</DisplayName>
+ <Description>Bold</Description>
+ <DataType>Bold</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>ITALIC</Identifier>
+ <DisplayName>Italic</DisplayName>
+ <Description>Italic</Description>
+ <DataType>Italic</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>UNDERLINED</Identifier>
+ <DisplayName>Underlined</DisplayName>
+ <Description>Underlined</Description>
+ <DataType>Underlined</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>OVERLINED</Identifier>
+ <DisplayName>Overlined</DisplayName>
+ <Description>Overlined</Description>
+ <DataType>Overlined</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>JUSTIFICATION</Identifier>
+ <DefaultValue>'FromAlignment'</DefaultValue>
+ <DisplayName>Justification</DisplayName>
+ <Description>Justification</Description>
+ <DataType>Justification</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>LINESPACING</Identifier>
+ <DefaultValue>1.05</DefaultValue>
+ <DisplayName>Line Spacing</DisplayName>
+ <Description>Line Spacing</Description>
+ <DataType>LineSpacing</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>GHOSTCOLOR</Identifier>
+ <DefaultValue/>
+ <DisplayName>Ghost Color</DisplayName>
+ <Description>Ghost Color</Description>
+ <DataType>GhostColor</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>FRAMELINECOLOR</Identifier>
+ <DefaultValue/>
+ <DisplayName>Frame Line Color</DisplayName>
+ <Description>Frame Line Color</Description>
+ <DataType>FrameLineColor</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>FRAMEFILLCOLOR</Identifier>
+ <DefaultValue/>
+ <DisplayName>Frame Fill Color</DisplayName>
+ <Description>Frame Fill Color</Description>
+ <DataType>FrameFillColor</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>TEXTCOLOR</Identifier>
+ <DefaultValue>0xff625231</DefaultValue>
+ <DisplayName>Text Color</DisplayName>
+ <Description>Text Color</Description>
+ <DataType>TextColor</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>VERTICALALIGNMENT</Identifier>
+ <DefaultValue>'Halfline'</DefaultValue>
+ <DisplayName>&Vertical Alignment</DisplayName>
+ <Description>Vertical Alignment</Description>
+ <DataType>VerticalAlignment</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>ROTATION</Identifier>
+ <DisplayName>&Rotation</DisplayName>
+ <Description>Rotation</Description>
+ <DataType>Angle</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>HORIZONTALALIGNMENT</Identifier>
+ <DefaultValue>'Center'</DefaultValue>
+ <DisplayName>Hori&zontal Alignment</DisplayName>
+ <Description>Horizontal Alignment</Description>
+ <DataType>HorizontalAlignment</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>StyleEditorGenerated_TextPositionX_0</Identifier>
+ <DisplayName>PositionX</DisplayName>
+ <Description>PositionX</Description>
+ <DataType>Real</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>StyleEditorGenerated_TextPositionY_0</Identifier>
+ <DisplayName>PositionY</DisplayName>
+ <Description>PositionY</Description>
+ </Parameter>
+ <Override>
+ <SymbolName>MTEXT</SymbolName>
+ <ParameterIdentifier>CONTENT</ParameterIdentifier>
+ <ParameterValue>Concat('District ', FeatId)</ParameterValue>
+ </Override>
+ <Override>
+ <ParameterIdentifier>FONTNAME</ParameterIdentifier>
+ <ParameterValue>'Verdana'</ParameterValue>
+ </Override>
+ <Override>
+ <ParameterIdentifier>FONTHEIGHT</ParameterIdentifier>
+ <ParameterValue>3.5</ParameterValue>
+ </Override>
+ <Override>
+ <ParameterIdentifier>TEXTCOLOR</ParameterIdentifier>
+ <ParameterValue>0xff625231</ParameterValue>
+ </Override>
+ <CheckExclusionRegion>true</CheckExclusionRegion>
+ <AddToExclusionRegion>true</AddToExclusionRegion>
+ <PositioningAlgorithm>'Default'</PositioningAlgorithm>
+ </SymbolInstance>
+ </CompositeRule>
+</LayerDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,98 @@
+ <ResourceId>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>SHP_Schema:HydrographicPolygons</FeatureName>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xffabc7e9</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffabc7e9</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+</LayerDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,98 @@
+ <ResourceId>Library://Samples/Sheboygan/Data/Islands.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>SHP_Schema:Islands</FeatureName>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+</LayerDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,736 @@
+ <ResourceId>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>SHP_Schema:Parcels</FeatureName>
+ <PropertyMapping>
+ <Name>RLDESCR1</Name>
+ <Value>Description1</Value>
+ </PropertyMapping>
+ <PropertyMapping>
+ <Name>RTYPE</Name>
+ <Value>Zone</Value>
+ <PropertyMapping>
+ <Name>RACRE</Name>
+ <Value>Acreage</Value>
+ <PropertyMapping>
+ <Name>RLOT</Name>
+ <Value>Lot Dimensions</Value>
+ <PropertyMapping>
+ <Name>RNAME</Name>
+ <Value>Owner</Value>
+ <PropertyMapping>
+ <Name>RLDESCR2</Name>
+ <Value>Description2</Value>
+ <PropertyMapping>
+ <Name>RLDESCR3</Name>
+ <Value>Description3</Value>
+ <PropertyMapping>
+ <Name>RBILAD</Name>
+ <Value>Billing Address</Value>
+ <PropertyMapping>
+ <Name>RSQFT</Name>
+ <Value>Lot Size (SqFt)</Value>
+ <PropertyMapping>
+ <Name>RLDESCR4</Name>
+ <Value>Description4</Value>
+ <ToolTip>concat('Parcel\nName: ', concat(RNAME, concat('\nAddress: ', RBILAD)))</ToolTip>
+ <CompositeRule>
+ <LegendLabel>Zone: AGR</LegendLabel>
+ <Filter>"RTYPE" = 'AGR'</Filter>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xffc19e6a</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffc19e6a</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+ <CompositeRule>
+ <LegendLabel>Zone: EXM</LegendLabel>
+ <Filter>"RTYPE" = 'EXM'</Filter>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xffb9a670</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffb9a670</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+ <CompositeRule>
+ <LegendLabel>Zone: MER</LegendLabel>
+ <Filter>"RTYPE" = 'MER'</Filter>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xffb2ae77</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffb2ae77</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+ <CompositeRule>
+ <LegendLabel>Zone: MFG</LegendLabel>
+ <Filter>"RTYPE" = 'MFG'</Filter>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xffabb67e</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffabb67e</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+ <CompositeRule>
+ <LegendLabel>Zone: RES</LegendLabel>
+ <Filter>"RTYPE" = 'RES'</Filter>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xffa4be85</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffa4be85</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+ <CompositeRule>
+ <LegendLabel>Zone: S&W</LegendLabel>
+ <Filter>"RTYPE" = 'S&W'</Filter>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xff9dc68c</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xff9dc68c</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+ <CompositeRule>
+ <LegendLabel>Zone: WTC</LegendLabel>
+ <Filter>"RTYPE" = 'WTC'</Filter>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xff96ce93</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xff96ce93</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+ <CompositeRule>
+ <LegendLabel>Zone: Other</LegendLabel>
+ <Filter/>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0xffd4d4d4</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xffd4d4d4</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ <DefaultValue>0xff000000</DefaultValue>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ <ParameterValue>0xff000000</ParameterValue>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+</LayerDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,328 @@
+ <ResourceId>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>Default:RoadCenterLines</FeatureName>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ <LineWeightScalable>true</LineWeightScalable>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ <UsageContext>Line</UsageContext>
+ <GeometryContext>LineString</GeometryContext>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Text>
+ <Frame>
+ </Frame>
+ </Text>
+ </Graphics>
+ <LineUsage>
+ <AngleControl>'FromAngle'</AngleControl>
+ </LineUsage>
+ <Parameter>
+ <DefaultValue>NAME</DefaultValue>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ <DefaultValue>3.0</DefaultValue>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ <DefaultValue/>
+ </Parameter>
+ <Parameter>
+ <DefaultValue/>
+ </Parameter>
+ <Parameter>
+ <DefaultValue/>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ <DefaultValue>'Baseline'</DefaultValue>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ <ParameterValue>NAME</ParameterValue>
+ </Override>
+ <Override>
+ </Override>
+ <Override>
+ <ParameterValue>3.0</ParameterValue>
+ </Override>
+ <Override>
+ </Override>
+ <Override>
+ <ParameterIdentifier>HORIZONTALALIGNMENT</ParameterIdentifier>
+ <ParameterValue>'Center'</ParameterValue>
+ </Override>
+ <Override>
+ <ParameterIdentifier>VERTICALALIGNMENT</ParameterIdentifier>
+ <ParameterValue>'Baseline'</ParameterValue>
+ </Override>
+ <DrawLast>true</DrawLast>
+ <PositioningAlgorithm>'PathLabels'</PositioningAlgorithm>
+ </SymbolInstance>
+ </CompositeRule>
+ <MaxScale>24000</MaxScale>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+</LayerDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,98 @@
+ <ResourceId>Library://Samples/Sheboygan/Data/Soils.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>SHP_Schema:Soils</FeatureName>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <AreaUsage>
+ </AreaUsage>
+ <Parameter>
+ <DefaultValue>0x69804000</DefaultValue>
+ </Parameter>
+ <Override>
+ <ParameterValue>0x69804000</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ <SymbolInstance>
+ <Graphics>
+ <Path>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ </LineUsage>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Override>
+ </Override>
+ <Override>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+</LayerDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,24 @@
+ <ResourceId>Library://Samples/Sheboygan/Data/Rail.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>SHP_Schema:Rail</FeatureName>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <ResourceId>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</ResourceId>
+ <ParameterOverrides/>
+ </SymbolInstance>
+ </CompositeRule>
+</LayerDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,30 @@
+ <ResourceId>Library://Samples/Sheboygan/Data/Trees.FeatureSource</ResourceId>
+ <Watermarks/>
+ <FeatureName>SHP_Schema:Trees</FeatureName>
+ <MaxScale>12000</MaxScale>
+ <CompositeRule>
+ <LegendLabel/>
+ <SymbolInstance>
+ <ResourceId>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</ResourceId>
+ <Override>
+ <SymbolName>Circle</SymbolName>
+ <ParameterValue>0xff008000</ParameterValue>
+ </Override>
+ </SymbolInstance>
+ </CompositeRule>
+</LayerDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+<ResourceFolderHeader xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourceFolderHeader-1.0.0.xsd">
+ </Security>
+</ResourceFolderHeader>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,550 @@
+<WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="WebLayout-2.6.0.xsd">
+ <Title>Sheboygan (Advanced Stylization)</Title>
+ <Map>
+ <ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</ResourceId>
+ <HyperlinkTarget>TaskPane</HyperlinkTarget>
+ </Map>
+ <EnablePingServer>true</EnablePingServer>
+ <SelectionColor>0000FFFF</SelectionColor>
+ <PointSelectionBuffer>2</PointSelectionBuffer>
+ <MapImageFormat>PNG</MapImageFormat>
+ <SelectionImageFormat>PNG</SelectionImageFormat>
+ <StartupScript>alert("This map (Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition) demonstrates use of Advanced Stylization");</StartupScript>
+ <ToolBar>
+ <Visible>true</Visible>
+ <Button xsi:type="CommandItemType">
+ <Function>Command</Function>
+ <Command>Print</Command>
+ </Button>
+ <Command>GetPrintablePage</Command>
+ </Button>
+ <Button xsi:type="SeparatorItemType">
+ <Function>Separator</Function>
+ </Button>
+ <Command>Measure</Command>
+ </Button>
+ <Command>Buffer</Command>
+ </Button>
+ </Button>
+ <Button xsi:type="FlyoutItemType">
+ <Function>Flyout</Function>
+ <Label>Zoom</Label>
+ <SubItem xsi:type="CommandItemType">
+ <Command>PreviousView</Command>
+ </SubItem>
+ <Command>NextView</Command>
+ </SubItem>
+ <Command>RestoreView</Command>
+ </SubItem>
+ </Button>
+ </Button>
+ <Command>ZoomRectangle</Command>
+ </Button>
+ <Command>ZoomIn</Command>
+ </Button>
+ <Command>ZoomOut</Command>
+ </Button>
+ <Command>Zoom</Command>
+ </Button>
+ </Button>
+ <Command>Select</Command>
+ </Button>
+ <Command>Pan</Command>
+ </Button>
+ </Button>
+ <Command>MapTip</Command>
+ </Button>
+ </ToolBar>
+ <InformationPane>
+ <Width>200</Width>
+ <LegendVisible>true</LegendVisible>
+ <PropertiesVisible>true</PropertiesVisible>
+ </InformationPane>
+ <ContextMenu>
+ <MenuItem xsi:type="CommandItemType">
+ </MenuItem>
+ <Command>ClearSelection</Command>
+ </MenuItem>
+ <MenuItem xsi:type="FlyoutItemType">
+ <Label>Select More</Label>
+ <Command>SelectRadius</Command>
+ </SubItem>
+ <Command>SelectPolygon</Command>
+ </SubItem>
+ <Command>SelectWithin</Command>
+ </SubItem>
+ </MenuItem>
+ </MenuItem>
+ <MenuItem xsi:type="SeparatorItemType">
+ </MenuItem>
+ </MenuItem>
+ </MenuItem>
+ </MenuItem>
+ </MenuItem>
+ </SubItem>
+ </SubItem>
+ <Command>FitToWindow</Command>
+ </SubItem>
+ </SubItem>
+ <Command>ZoomToSelection</Command>
+ </SubItem>
+ </MenuItem>
+ </MenuItem>
+ </MenuItem>
+ </MenuItem>
+ </MenuItem>
+ <Command>Refresh</Command>
+ </MenuItem>
+ <Command>CopyMap</Command>
+ </MenuItem>
+ </MenuItem>
+ </MenuItem>
+ </MenuItem>
+ <Command>ViewOptions</Command>
+ </MenuItem>
+ </MenuItem>
+ <Command>Help</Command>
+ </MenuItem>
+ <Command>About</Command>
+ </MenuItem>
+ </ContextMenu>
+ <TaskPane>
+ <Width>250</Width>
+ <TaskBar>
+ <Home>
+ <Name>Home</Name>
+ <Tooltip>Return to home task page</Tooltip>
+ <Description>Return to home task page</Description>
+ <ImageURL>../stdicons/icon_home.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_home_disabled.gif</DisabledImageURL>
+ </Home>
+ <Forward>
+ <Name>Forward</Name>
+ <Tooltip>Forward to next task page</Tooltip>
+ <Description>Forward to next task page</Description>
+ <ImageURL>../stdicons/icon_forward.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_forward_disabled.gif</DisabledImageURL>
+ </Forward>
+ <Back>
+ <Name>Back</Name>
+ <Tooltip>Return to previous task page</Tooltip>
+ <Description>Return to previous task page</Description>
+ <ImageURL>../stdicons/icon_back.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_back_disabled.gif</DisabledImageURL>
+ </Back>
+ <Tasks>
+ <Name>Tasks</Name>
+ <Tooltip>Task List</Tooltip>
+ <Description>View a list of available tasks</Description>
+ <ImageURL>../stdicons/icon_tasks.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_tasks_disabled.gif</DisabledImageURL>
+ </Tasks>
+ </TaskBar>
+ </TaskPane>
+ <StatusBar>
+ </StatusBar>
+ <ZoomControl>
+ </ZoomControl>
+ <CommandSet>
+ <Command xsi:type="BasicCommandType">
+ <Name>Pan</Name>
+ <Label>Pan Mode</Label>
+ <Tooltip>Pan Mode</Tooltip>
+ <Description>Drag the map to view areas out of range</Description>
+ <ImageURL>../stdicons/icon_pan.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_pan_disabled.gif</DisabledImageURL>
+ <TargetViewer>All</TargetViewer>
+ <Action>Pan</Action>
+ </Command>
+ <Name>PanUp</Name>
+ <Label>Pan Up</Label>
+ <Tooltip>Pan Up</Tooltip>
+ <Description>Pan up by a preset increment</Description>
+ <ImageURL>../stdicons/icon_panup.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_panup_disabled.gif</DisabledImageURL>
+ <Action>PanUp</Action>
+ </Command>
+ <Name>PanDown</Name>
+ <Label>Pan Down</Label>
+ <Tooltip>Pan Down</Tooltip>
+ <Description>Pan down by a preset increment</Description>
+ <ImageURL>../stdicons/icon_pandown.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_pandown_disabled.gif</DisabledImageURL>
+ <Action>PanDown</Action>
+ </Command>
+ <Name>PanRight</Name>
+ <Label>Pan Right</Label>
+ <Tooltip>Pan Right</Tooltip>
+ <Description>Pan right by a preset increment</Description>
+ <ImageURL>../stdicons/icon_panright.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_panright_disabled.gif</DisabledImageURL>
+ <Action>PanRight</Action>
+ </Command>
+ <Name>PanLeft</Name>
+ <Label>Pan Left</Label>
+ <Tooltip>Pan Left</Tooltip>
+ <Description>Pan left by a preset increment</Description>
+ <ImageURL>../stdicons/icon_panleft.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_panleft_disabled.gif</DisabledImageURL>
+ <Action>PanLeft</Action>
+ </Command>
+ <Name>Zoom</Name>
+ <Tooltip>Zoom Dynamic</Tooltip>
+ <Description>Zoom dynamically by clicking and dragging</Description>
+ <ImageURL>../stdicons/icon_zoom.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_zoom_disabled.gif</DisabledImageURL>
+ <TargetViewer>Dwf</TargetViewer>
+ <Action>Zoom</Action>
+ </Command>
+ <Name>ZoomIn</Name>
+ <Label>Zoom In</Label>
+ <Tooltip>Zoom In</Tooltip>
+ <Description>Zoom in by a preset increment</Description>
+ <ImageURL>../stdicons/icon_zoomin.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_zoomin_disabled.gif</DisabledImageURL>
+ <Action>ZoomIn</Action>
+ </Command>
+ <Name>ZoomOut</Name>
+ <Label>Zoom Out</Label>
+ <Tooltip>Zoom Out</Tooltip>
+ <Description>Zoom out by a preset increment</Description>
+ <ImageURL>../stdicons/icon_zoomout.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_zoomout_disabled.gif</DisabledImageURL>
+ <Action>ZoomOut</Action>
+ </Command>
+ <Name>ZoomRectangle</Name>
+ <Label>Zoom Rectangle</Label>
+ <Tooltip>Zoom Rectangle</Tooltip>
+ <Description>Zoom in on an area</Description>
+ <ImageURL>../stdicons/icon_zoomrect.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_zoomrect_disabled.gif</DisabledImageURL>
+ <Action>ZoomRectangle</Action>
+ </Command>
+ <Name>ZoomToSelection</Name>
+ <Label>Zoom Selection</Label>
+ <Tooltip>Zoom Selection</Tooltip>
+ <Description>Zoom to the extents of selected features</Description>
+ <ImageURL>../stdicons/icon_zoomselect.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_zoomselect_disabled.gif</DisabledImageURL>
+ <Action>ZoomToSelection</Action>
+ </Command>
+ <Name>FitToWindow</Name>
+ <Label>Initial Map View</Label>
+ <Tooltip>Initial Map View</Tooltip>
+ <Description>Fit the extents of the map to the window</Description>
+ <ImageURL>../stdicons/icon_fitwindow.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_fitwindow_disabled.gif</DisabledImageURL>
+ <Action>FitToWindow</Action>
+ </Command>
+ <Name>PreviousView</Name>
+ <Label>Previous View</Label>
+ <Tooltip>Previous View</Tooltip>
+ <Description>Go to previous view</Description>
+ <ImageURL>../stdicons/icon_zoomprev.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_zoomprev_disabled.gif</DisabledImageURL>
+ <Action>PreviousView</Action>
+ </Command>
+ <Name>NextView</Name>
+ <Label>Next View</Label>
+ <Tooltip>Next View</Tooltip>
+ <Description>Go to next view</Description>
+ <ImageURL>../stdicons/icon_zoomnext.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_zoomnext_disabled.gif</DisabledImageURL>
+ <Action>NextView</Action>
+ </Command>
+ <Name>RestoreView</Name>
+ <Label>Initial Center and Scale</Label>
+ <Tooltip>Initial Center and Scale</Tooltip>
+ <Description>Zoom to initial map center and scale</Description>
+ <ImageURL>../stdicons/icon_restorecenter.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_restorecenter_disabled.gif</DisabledImageURL>
+ <Action>RestoreView</Action>
+ </Command>
+ <Name>Select</Name>
+ <Label>Select</Label>
+ <Tooltip>Select</Tooltip>
+ <Description>Select features by clicking and dragging</Description>
+ <ImageURL>../stdicons/icon_select.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_select_disabled.gif</DisabledImageURL>
+ <Action>Select</Action>
+ </Command>
+ <Name>SelectRadius</Name>
+ <Label>Select Radius</Label>
+ <Tooltip>Select Radius</Tooltip>
+ <Description>Click and drag to select all features inside the circle</Description>
+ <ImageURL>../stdicons/icon_selectradius.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_selectradius_disabled.gif</DisabledImageURL>
+ <Action>SelectRadius</Action>
+ </Command>
+ <Name>SelectPolygon</Name>
+ <Label>Select Polygon</Label>
+ <Tooltip>Select Polygon</Tooltip>
+ <Description>Click and drag to select all features that fall within</Description>
+ <ImageURL>../stdicons/icon_selectpolygon.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_selectpolygon_disabled.gif</DisabledImageURL>
+ <Action>SelectPolygon</Action>
+ </Command>
+ <Name>ClearSelection</Name>
+ <Label>Clear the current selection</Label>
+ <Tooltip>Clear Selection</Tooltip>
+ <Description>Clear the current selection</Description>
+ <ImageURL>../stdicons/icon_clearselect.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_clearselect_disabled.gif</DisabledImageURL>
+ <Action>ClearSelection</Action>
+ </Command>
+ <Name>Refresh</Name>
+ <Label>Refresh Map</Label>
+ <Tooltip>Refresh Map</Tooltip>
+ <Description>Refresh map to reload all layers keeping current center and scale</Description>
+ <ImageURL>../stdicons/icon_refreshmap.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_refreshmap_disabled.gif</DisabledImageURL>
+ <Action>Refresh</Action>
+ </Command>
+ <Name>CopyMap</Name>
+ <Label>Copy</Label>
+ <Tooltip>Copy</Tooltip>
+ <Description>Copy current view of map to clipboard</Description>
+ <ImageURL>../stdicons/icon_copy.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_copy_disabled.gif</DisabledImageURL>
+ <Action>CopyMap</Action>
+ </Command>
+ <Name>About</Name>
+ <Label>About</Label>
+ <Tooltip>About</Tooltip>
+ <Description>Display information about this application</Description>
+ <Action>About</Action>
+ </Command>
+ <Command xsi:type="BufferCommandType">
+ <Name>Buffer</Name>
+ <Label>Buffer</Label>
+ <Tooltip>Buffer</Tooltip>
+ <Description>Create buffers around the selected features</Description>
+ <ImageURL>../stdicons/icon_buffer.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_buffer_disabled.gif</DisabledImageURL>
+ <Target>TaskPane</Target>
+ </Command>
+ <Command xsi:type="SelectWithinCommandType">
+ <Name>SelectWithin</Name>
+ <Label>Select Within</Label>
+ <Tooltip>Select Within</Tooltip>
+ <Description>Select features that fall within currently selected areas</Description>
+ <ImageURL>../stdicons/icon_selectwithin.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_selectwithin_disabled.gif</DisabledImageURL>
+ </Command>
+ <Command xsi:type="MeasureCommandType">
+ <Name>Measure</Name>
+ <Label>Measure</Label>
+ <Tooltip>Measure</Tooltip>
+ <Description>Measure distances on the map</Description>
+ <ImageURL>../stdicons/icon_measure.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_measure_disabled.gif</DisabledImageURL>
+ </Command>
+ <Command xsi:type="PrintCommandType">
+ <Name>Print</Name>
+ <Label>Print</Label>
+ <Tooltip>Print</Tooltip>
+ <Description>Print with optional layout</Description>
+ <ImageURL>../stdicons/icon_print.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_print_disabled.gif</DisabledImageURL>
+ </Command>
+ <Command xsi:type="ViewOptionsCommandType">
+ <Name>ViewOptions</Name>
+ <Label>View Options</Label>
+ <Tooltip>View Options</Tooltip>
+ <Description>View Options</Description>
+ <ImageURL>../stdicons/icon_viewoptions.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_viewoptions_disabled.gif</DisabledImageURL>
+ </Command>
+ <Command xsi:type="GetPrintablePageCommandType">
+ <Name>GetPrintablePage</Name>
+ <Label>Get Printable Page</Label>
+ <Tooltip>Get Printable Page</Tooltip>
+ <Description>Get Printer-friendly page</Description>
+ <ImageURL>../stdicons/icon_printablepage.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_printablepage_disabled.gif</DisabledImageURL>
+ <TargetViewer>Ajax</TargetViewer>
+ <Target>NewWindow</Target>
+ </Command>
+ <Command xsi:type="HelpCommandType">
+ <Name>Help</Name>
+ <Label>Help</Label>
+ <Tooltip>Help</Tooltip>
+ <Description>Launch help for this application</Description>
+ <ImageURL>../stdicons/icon_help.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_help_disabled.gif</DisabledImageURL>
+ </Command>
+ <Name>MapTip</Name>
+ <Label>Maptip</Label>
+ <Tooltip>Click to enable/disable display of map tooltips</Tooltip>
+ <Description>Click to enable/disable display of map tooltips</Description>
+ <ImageURL>../stdicons/icon_maptip.gif</ImageURL>
+ <DisabledImageURL>../stdicons/icon_maptip_disabled.gif</DisabledImageURL>
+ <Action>MapTip</Action>
+ </Command>
+ </CommandSet>
+</WebLayout>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,142 @@
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="MapDefinition-2.4.0.xsd">
+ <Name>Sheboygan Map</Name>
+ <CoordinateSystem>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</CoordinateSystem>
+ <Extents>
+ <MinX>-87.764986990962839</MinX>
+ <MaxX>-87.695521510899724</MaxX>
+ <MinY>43.691398128787782</MinY>
+ <MaxY>43.797520000480347</MaxY>
+ </Extents>
+ <BackgroundColor>ffcdbd9c</BackgroundColor>
+ <MapLayer>
+ <Name>Trees</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</ResourceId>
+ <Selectable>false</Selectable>
+ <ShowInLegend>true</ShowInLegend>
+ <LegendLabel>Trees</LegendLabel>
+ <ExpandInLegend>true</ExpandInLegend>
+ <Group>Municipal</Group>
+ </MapLayer>
+ <MapLayer>
+ <Name>Roads</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</ResourceId>
+ <LegendLabel>Roads</LegendLabel>
+ <Group>Transportation</Group>
+ </MapLayer>
+ <MapLayer>
+ <Name>Rail Lines</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</ResourceId>
+ <LegendLabel>Rail Lines</LegendLabel>
+ <Visible>false</Visible>
+ </MapLayer>
+ <MapLayer>
+ <Name>Districts</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</ResourceId>
+ <LegendLabel>Districts</LegendLabel>
+ </MapLayer>
+ <MapLayer>
+ <Name>Buildings</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</ResourceId>
+ <LegendLabel>Buildings</LegendLabel>
+ </MapLayer>
+ <MapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <LegendLabel>Parcels</LegendLabel>
+ </MapLayer>
+ <MapLayer>
+ <Name>Islands</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</ResourceId>
+ <LegendLabel>Islands</LegendLabel>
+ <Group>Base Map</Group>
+ </MapLayer>
+ <MapLayer>
+ <Name>Hydrography</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</ResourceId>
+ <LegendLabel>Hydrography</LegendLabel>
+ </MapLayer>
+ <MapLayer>
+ <Name>Soils</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</ResourceId>
+ <LegendLabel>Soils</LegendLabel>
+ </MapLayer>
+ <MapLayer>
+ <Name>CityLimits</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</ResourceId>
+ <LegendLabel>CityLimits</LegendLabel>
+ </MapLayer>
+ <MapLayerGroup>
+ <Name>Base Map</Name>
+ <LegendLabel>Base Map</LegendLabel>
+ <Group/>
+ </MapLayerGroup>
+ <MapLayerGroup>
+ <Name>Municipal</Name>
+ <LegendLabel>Municipal</LegendLabel>
+ <Group/>
+ </MapLayerGroup>
+ <MapLayerGroup>
+ <Name>Transportation</Name>
+ <LegendLabel>Transportation</LegendLabel>
+ <Group/>
+ </MapLayerGroup>
+ <Watermarks>
+ <Watermark>
+ <Name>MapText</Name>
+ <ResourceId>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</ResourceId>
+ </Watermark>
+ </Watermarks>
+</MapDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,102 @@
+<SimpleSymbolDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="SymbolDefinition-2.4.0.xsd" version="2.4.0">
+ <Name>Rail</Name>
+ <Description>Rail Trackss Symbol</Description>
+ <Graphics>
+ <Path>
+ <Geometry>M 2.0,0 l 0,2.5 M 2.0,0 l 0,-2.5 </Geometry>
+ <ScaleX>%SCALEX0%</ScaleX>
+ <ScaleY>%SCALEY0%</ScaleY>
+ <LineCap>%LINECAP0%</LineCap>
+ <LineJoin>%LINEJOIN0%</LineJoin>
+ </Path>
+ <Path>
+ <Geometry>M 0,0 L 9,0</Geometry>
+ <ScaleX>%SCALEX1%</ScaleX>
+ <ScaleY>%SCALEY1%</ScaleY>
+ <LineCap>%LINECAP1%</LineCap>
+ <LineJoin>%LINEJOIN1%</LineJoin>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ <Repeat>4.5</Repeat>
+ </LineUsage>
+ <Parameter>
+ <DefaultValue>ff000000</DefaultValue>
+ </Parameter>
+ <Parameter>
+ <DisplayName>Line &Thickness</DisplayName>
+ </Parameter>
+ <Parameter>
+ <Identifier>SCALEX0</Identifier>
+ <DefaultValue>0.705556966669489</DefaultValue>
+ <DisplayName>Path ScaleX</DisplayName>
+ <Description>Path ScaleX</Description>
+ </Parameter>
+ <Parameter>
+ <Identifier>SCALEY0</Identifier>
+ <DefaultValue>0.70555696666949</DefaultValue>
+ <DisplayName>Path ScaleY</DisplayName>
+ <Description>Path ScaleY</Description>
+ </Parameter>
+ <Parameter>
+ <Identifier>LINECAP0</Identifier>
+ <DefaultValue>'Round'</DefaultValue>
+ <DisplayName>Line Cap</DisplayName>
+ <Description>The cap type to use at the ends of each segment in the path outline. This must evaluate to one of: None, Round (default), Triangle, or Square.</Description>
+ <DataType>String</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>LINEJOIN0</Identifier>
+ <DisplayName>Line Join</DisplayName>
+ <Description>The join type to use at each vertex in the path outline. This must evaluate to one of: None, Bevel, Round (default), or Miter.</Description>
+ </Parameter>
+ <Parameter>
+ <Identifier>SCALEX1</Identifier>
+ </Parameter>
+ <Parameter>
+ <Identifier>SCALEY1</Identifier>
+ </Parameter>
+ <Parameter>
+ <Identifier>LINECAP1</Identifier>
+ </Parameter>
+ <Parameter>
+ <Identifier>LINEJOIN1</Identifier>
+ </Parameter>
+</SimpleSymbolDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,78 @@
+ <Name>Circle</Name>
+ <Description>Default Point Symbol</Description>
+ <Graphics>
+ <Path>
+ <Geometry>M -1,0 A 1,1 0 1 1 1,0 A 1,1 0 1 1 -1,0</Geometry>
+ <ScaleX>%StyleEditorGenerated_ScaleX_0%</ScaleX>
+ <ScaleY>%StyleEditorGenerated_ScaleY_0%</ScaleY>
+ <LineCap>%StyleEditorGenerated_LineCap_0%</LineCap>
+ <LineJoin>%StyleEditorGenerated_LineJoin_0%</LineJoin>
+ </Path>
+ </Graphics>
+ <PointUsage>
+ </PointUsage>
+ <Parameter>
+ <DefaultValue>0xffffffff</DefaultValue>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ </Parameter>
+ <Parameter>
+ <Identifier>StyleEditorGenerated_ScaleX_0</Identifier>
+ <DefaultValue>1.0</DefaultValue>
+ </Parameter>
+ <Parameter>
+ <Identifier>StyleEditorGenerated_ScaleY_0</Identifier>
+ </Parameter>
+ <Parameter>
+ <Identifier>StyleEditorGenerated_LineCap_0</Identifier>
+ </Parameter>
+ <Parameter>
+ <Identifier>StyleEditorGenerated_LineJoin_0</Identifier>
+ </Parameter>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,38 @@
+<WatermarkDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="WatermarkDefinition-2.4.0.xsd">
+ <Content>
+ <Name/>
+ <Description/>
+ <Graphics>
+ <Text>
+ <Content>'MapGuide Sheboygan Map (Advanced Stylization)'</Content>
+ <FontName>'Arial'</FontName>
+ <Height>3</Height>
+ <Frame>
+ <FillColor>0xFFFFFFFF</FillColor>
+ <OffsetX>0.0</OffsetX>
+ <OffsetY>0.0</OffsetY>
+ </Frame>
+ </Text>
+ </Graphics>
+ <PointUsage/>
+ <ParameterDefinition/>
+ </Content>
+ <Appearance/>
+ <Position>
+ <XYPosition>
+ <XPosition>
+ <Offset>5</Offset>
+ <Unit>Pixels</Unit>
+ <Alignment>Right</Alignment>
+ </XPosition>
+ <YPosition>
+ <Unit>Points</Unit>
+ <Alignment>Bottom</Alignment>
+ </YPosition>
+ </XYPosition>
+ </Position>
+</WatermarkDefinition>
Added: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml (rev 0)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -0,0 +1,6 @@
+ </Security>
Modified: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2014-05-23 06:50:13 UTC (rev 8146)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/MgResourcePackageManifest.xml 2014-05-23 10:33:50 UTC (rev 8147)
@@ -1 +1 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no" ?><ResourcePackageManifest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd"><Operations><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/S
amples/Sheboygan/Layers/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samp
les/Sheboygan/Layouts/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/S
heboygan/Watermarks/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><N
ame>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SE
TRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter>
<Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.Laye
rDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Valu
e></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTEN
T.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Pa
rameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Para
meter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</
Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_H
EADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation
><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>5594</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value><ContentT
ype>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>22760</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters>
<Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATAL
ENGTH</Name><Value>8038400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>BuildingOutlines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Libra
ry://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>CityLimits.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parame
ters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_DATA_HydrographicLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>768000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOU
RCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Paramete
rs><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>512000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicPolygons.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</C
ontentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Islands.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parame
ter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>1996800</Value></Parameter><Parameter><Nam
e>DATANAME</Name><Value>LandUse.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Oper
ation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>11929600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Parcels.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value><C
ontentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>870400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Rail.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Pa
rameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Na
me><Value>665600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>RoadCenterLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data
/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>4556800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Soils.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheb
oygan/Data/Trees.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>6656000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Trees.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>D
ELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value><ContentType>application/octet-stre
am</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>VotingDistricts.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></
Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Na
me>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Versi
on><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</Cont
entType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOU
RCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Va
lue>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESO
URCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.x
ml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEA
DER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinitio
n</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/S
heboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinitio
n_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RE
SOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation></Operations></ResourcePackageManifest>
\ No newline at end of file
+<?xml version="1.0" encoding="UTF-8" standalone="no" ?><ResourcePackageManifest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourcePackageManifest-1.0.0.xsd"><Operations><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/S
heboygan/Watermarks/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</
ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>
Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>
Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Islands.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboyga
n/Layers/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</Conte
ntType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhpTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</
Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0
.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJspTiled.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value
>Library/Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout</Value></Para
meter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Paramete
rs></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml<
/ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>5594</Value></Parameter><Parameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Versio
n><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Symbols/Logos.SymbolLibrary_DATA_symbols.dwf</Value><ContentType>model/vnd.dwf</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>22760</Value></Parameter><P
arameter><Name>DATANAME</Name><Value>symbols.dwf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Logos.SymbolLibrary</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.Fe
atureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>8038400</Value></Parameter><Parameter><Name>DATANAME</Name><Value>BuildingOutlines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>C
ONTENT</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/CityLimits.FeatureSource_DATA_CityLimits.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>CityLimits.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/CityLimits.Fe
atureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicLin
es.FeatureSource_DATA_HydrographicLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>768000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Sa
mples/Sheboygan/Data/HydrographicPolygons.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>512000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>HydrographicPolygons.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters
><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Islands.FeatureSource_DATA_Islands.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Paramet
er><Name>DATANAME</Name><Value>Islands.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Islands.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters
></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/LandUse.FeatureSource_DATA_LandUse.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>1996800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>LandUse.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/LandUse.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_CONTENT.x
ml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Parcels.FeatureSource_DATA_Parcels.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>11929600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Parcels.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Versio
n>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Rail.FeatureSource_DATA_Rail.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>870400</Value></Paramete
r><Parameter><Name>DATANAME</Name><Value>Rail.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Rail.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSo
urce</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>665600</Value></Parameter><Parameter><Name>DATANAME</Name><Value>RoadCenterLines.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Val
ue>Library/Samples/Sheboygan/Data/Soils.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Soils.FeatureSource_DATA_Soils.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>4556800</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Soils.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Soils.FeatureSource</Value></Parameter></Parameters></Opera
tion><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/Trees.FeatureSource_DATA_Trees.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Paramete
r><Name>DATALENGTH</Name><Value>6656000</Value></Parameter><Parameter><Name>DATANAME</Name><Value>Trees.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/Trees.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value
>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCEDATA</Name><Version>1.0.0</Version><Parameters><Parameter><Name>DATA</Name><Value>Library/Samples/Sheboygan/Data/VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf</Value><ContentType>application/octet-stream</ContentType></Parameter><Parameter><Name>DATALENGTH</Name><Value>307200</Value></Parameter><Parameter><Name>DATANAME</Name><Value>VotingDistricts.sdf</Value></Parameter><Parameter><Name>DATATYPE</Name><Value>File</Value></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Ver
sion>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Libr
ary/Samples/Sheboygan/Layers/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapText.WatermarkD
efinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapCommercialText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><V
alue>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapTiledText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><P
arameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/SheboyganV26.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layou
ts/SheboyganV26.WebLayout_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/SheboyganV26.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/SlateCommercial.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Flexibl
eLayouts/SlateCommercial.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RE
SOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/TurquoiseYellow.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operat
ion><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_CONTENT.x
ml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/LimeGold.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition_HEADER.xml<
/Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/FlexibleLayouts/Maroon.ApplicationDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Trees.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE<
/Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers/Soils.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><
Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/S
heboygan/Maps/SheboyganCommercial.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/CityLimits.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Adv
anced/CityLimits.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Hydrography.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name
><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Islands.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter>
<Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Roads.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Sample
s/Sheboygan/Layers_Advanced/Soils.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Soils.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Tracks.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Track
s.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Rail.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Rail.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Val
ue></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Symbols/Trees.SymbolDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Symbols/Trees.SymbolDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_CONTENT.xml</Val
ue><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Maps/Sheboygan_Advanced.MapDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition_HEADER.xml</Value><ContentType
>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Watermarks/MapAdvancedText.WatermarkDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Parcels.LayerDefinition</Value></Parameter></Parameters></Operation><Oper
ation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Trees.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Paramet
ers></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Buildings.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition
_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_HEADER.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition</Value></Parameter></Parameters></Operation><Operation><Name>DELETERESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></Parameters></Operation><Operation><Name>SETRESOURCE</Name><Version>1.0.0</Version><Parameters><Parameter><Name>CONTENT</Name><Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_CONTENT.xml</Value><ContentType>text/xml</ContentType></Parameter><Parameter><Name>HEADER</Name><Value>Library/Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout_HEADER.xml</Value><ContentType>t
ext/xml</ContentType></Parameter><Parameter><Name>RESOURCEID</Name><Value>Library://Samples/Sheboygan/Layouts/AdvancedStylization.WebLayout</Value></Parameter></Parameters></Operation></Operations></ResourcePackageManifest>
More information about the mapguide-commits
