[mapguide-commits] r8151 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Sat May 24 01:44:27 PDT 2014
Author: jng
Date: 2014-05-24 01:44:27 -0700 (Sat, 24 May 2014)
New Revision: 8151
trunk/Tools/Maestro/Maestro/changelog.txt
changelog.txt update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2014-05-24 05:20:10 UTC (rev 8150)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2014-05-24 08:44:27 UTC (rev 8151)
@@ -1,4 +1,16 @@
-6.0a1
+ - MgCooker changes
+ - Removed non-official tile generation method
+ - Removed username/password/native connection options in UI. Replaced with provider/connection string
+ - Added support for adding default point/line/area composite styles in Layer Definition Editor
+ - Added support for including downward dependencies in the "Compile Full Dependency List" command
+ - Added specialized builder support for LOOKUP() and RANGE() expression functions in Expression Editor
+ - Added support for customizing border colors when theming
+ - Improve the usability of the Composite Symbolization dialog
+ - Fix: Negative index exception in grid-based editor when selecting row header
+ - Fix: XML diff false positives
+ - Fix: Wrong previews in Composite Symbolization dialog when multiple composite styles defined
+6.0a1
- New grid-based style editor. All layers will use this editor unless you un-tick "Use grid-based style editor" in the options
More information about the mapguide-commits
