[mapguide-commits] r8167 - in branches/2.6/MgDev: . BuildTools/WebTools/IMake BuildTools/WebTools/IMake/Win32 Common/Foundation/Data Common/Geometry/CoordinateSystem Common/MapGuideCommon/Services Common/PlatformBase/Services UnitTest/WebTier/DotNet UnitTest/WebTier/DotNet/MgTestRunner UnitTest/WebTier/DotNet/TestMapGuideApi UnitTest/WebTier/Php
svn_mapguide at osgeo.org
Mon May 26 21:27:00 PDT 2014
Author: jng
Date: 2014-05-26 21:27:00 -0700 (Mon, 26 May 2014)
New Revision: 8167
Added:
branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.vcxproj
Removed:
branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.vcproj
branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.cpp
branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.sln
branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.xsd
branches/2.6/MgDev/BuildTools/WebTools/IMake/Win32/IMake.exe
branches/2.6/MgDev/Common/Foundation/Data/FeaturePropertyType.h
branches/2.6/MgDev/Common/Foundation/Data/MimeType.h
branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h
branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h
branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h
branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h
branches/2.6/MgDev/Common/MapGuideCommon/Services/ImageFormats.h
branches/2.6/MgDev/Common/MapGuideCommon/Services/MappingDefs.h
branches/2.6/MgDev/Common/MapGuideCommon/Services/UnitType.h
branches/2.6/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h
branches/2.6/MgDev/Common/PlatformBase/Services/FeatureCommandType.h
branches/2.6/MgDev/Common/PlatformBase/Services/FeatureGeometricType.h
branches/2.6/MgDev/Common/PlatformBase/Services/FeatureService.h
branches/2.6/MgDev/Common/PlatformBase/Services/ObjectPropertyType.h
branches/2.6/MgDev/Common/PlatformBase/Services/RasterTypes.h
branches/2.6/MgDev/Common/PlatformBase/Services/ReaderType.h
branches/2.6/MgDev/Common/PlatformBase/Services/ResourceDefs.h
branches/2.6/MgDev/Common/PlatformBase/Services/SpatialContextExtentType.h
branches/2.6/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/MgTestRunner.csproj
branches/2.6/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs
branches/2.6/MgDev/UnitTest/WebTier/DotNet/prebuild.bat
branches/2.6/MgDev/UnitTest/WebTier/Php/Validate.php
branches/2.6/MgDev/run_tests.bat
Merge from trunk r8158, r8159, r8160, r8161, r8162, r8163, r8164, r8165. This covers the following:
- DotNet test runner fixes for x64
- Add more resilience to run_tests.bat
- #2451: Fix improper doxygen formatting for some constant classes
- IMake updates
- #2452: Properly process EXTERNAL_API members
- Update IMake.xsd to include new DocTarget element introduced for 2.5
- Strip known HTML tags and apply proper escaping for documentation when transferred to .net XML documentation
Modified: branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.cpp
--- branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.cpp 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.cpp 2014-05-27 04:27:00 UTC (rev 8167)
@@ -12,7 +12,8 @@
java
-static char version[] = "1.2";
+static char version[] = "1.2.2";
+static char EXTERNAL_API_DOCUMENTATION[] = "(NOTE: This API is not officially supported and may be subject to removal in a future release without warning. Use with caution.)";
static string module;
static string customPath;
@@ -540,6 +541,35 @@
return str.length() > 3; //A "///" does not count
+bool stringReplace(string& str, const string& find, const string& replace)
+ size_t start_pos = str.find(find);
+ if(start_pos == string::npos)
+ return false;
+ str.replace(start_pos, find.length(), replace);
+ return true;
+void stripHtml(string& str)
+ //NOTE: We're only stripping tags known to exist in some bits of API documentation
+ stringReplace(str, "<p>", "");
+ stringReplace(str, "<b>", "");
+ stringReplace(str, "<c>", "");
+ stringReplace(str, "</p>", "");
+ stringReplace(str, "</b>", "");
+ stringReplace(str, "</c>", "");
+void xmlEscapeString(string& str)
+ stringReplace(str, "&", "&");
+ stringReplace(str, "'", "'");
+ stringReplace(str, "\"", """);
+ stringReplace(str, "<", "<");
+ stringReplace(str, ">", ">");
string linkifyCSharpDocFragment(const string& str)
// Explode the fragment into a space delimited list.
@@ -555,6 +585,8 @@
//interfere with doxygen directive translation
if (item == "\\link" || item == "\\endlink")
continue;
+ stripHtml(item);
+ xmlEscapeString(item);
elems.push_back(item);
@@ -665,7 +697,7 @@
return output;
-string doxygenToJavaDoc(const string& commentStr)
+string doxygenToJavaDoc(const string& commentStr, bool isPublished)
// Doxygen documentation translation overview:
@@ -810,6 +842,11 @@
std::string javaDoc = "\n/**\n";
if (descriptionParts.size() > 0) {
+ if (!isPublished) {
+ javaDoc.append(" * ");
+ javaDoc.append(EXTERNAL_API_DOCUMENTATION);
+ javaDoc.append("\n");
for (int i = 0; i < descriptionParts.size(); i++) {
javaDoc.append(" *");
javaDoc.append(linkifyJavaDocFragment(descriptionParts[i]));
@@ -817,7 +854,13 @@
javaDoc.append(" *\n");
} else {
- javaDoc.append(" * TODO: API Documentation is missing or failed to translate doxygen brief directive (message inserted by IMake.exe)\n");
+ } else {
+ javaDoc.append(" * TODO: API Documentation is missing or failed to translate doxygen brief directive (message inserted by IMake.exe)\n");
if (paramParts.size() > 0) {
@@ -858,7 +901,7 @@
return javaDoc;
-string doxygenToCsharpDoc(const string& commentStr)
+string doxygenToCsharpDoc(const string& commentStr, bool isPublished)
//See doxygenToJavaDoc for how we do this sorcery
@@ -961,6 +1004,11 @@
std::string csharpDoc = "\n///<summary>\n";
+ csharpDoc.append("/// ");
+ csharpDoc.append(EXTERNAL_API_DOCUMENTATION);
+ csharpDoc.append("\n");
csharpDoc.append("///");
csharpDoc.append(linkifyCSharpDocFragment(descriptionParts[i]));
@@ -968,13 +1016,23 @@
csharpDoc.append("///</summary>\n");
} else {
- csharpDoc.append("///TODO: API Documentation is missing or failed to translate doxygen brief directive (message inserted by IMake.exe)\n///</summary>\n");
+ } else {
+ csharpDoc.append("///TODO: API Documentation is missing or failed to translate doxygen brief directive (message inserted by IMake.exe)\n///</summary>\n");
for (int i = 0; i < paramParts.size(); i++) {
+ std::string paramPart = paramParts[i];
+ stripHtml(paramPart);
+ xmlEscapeString(paramPart);
std::vector<std::string> pelems;
- std::stringstream pss(linkifyCSharpDocFragment(paramParts[i]));
+ std::stringstream pss(linkifyCSharpDocFragment(paramPart));
std::string pitem;
while(std::getline(pss, pitem, ' ')) {
if (!pitem.empty())
@@ -998,7 +1056,9 @@
if (returnParts.size() > 0) {
csharpDoc.append("///<returns>");
for (int i = 0; i < returnParts.size(); i++) {
- csharpDoc.append(linkifyCSharpDocFragment(returnParts[i]));
+ string retPart = returnParts[i];
+ stripHtml(retPart);
+ csharpDoc.append(linkifyCSharpDocFragment(retPart));
if (i < returnParts.size() - 1)
csharpDoc.append("\n/// ");
@@ -1035,7 +1095,7 @@
// ---------------------- csharpDoc END ------------------------ //
- csharpDoc.append("///\n");
+ //csharpDoc.append("///\n");
if (isDeprecated)
csharpDoc.append("[Obsolete(\"This method is deprecated\")]\n");
return csharpDoc;
@@ -1049,15 +1109,15 @@
string convertedDoc;
if (language == java) {
- convertedDoc = doxygenToJavaDoc(commentStr);
+ convertedDoc = doxygenToJavaDoc(commentStr, true); //EXTERNAL_API only applies to class members, so treat this fragment as PUBLISHED_API
fprintf(docOutFile, "\n%%typemap(javaclassmodifiers) %s %%{%s public%%}\n", className.c_str(), convertedDoc.c_str());
} else if(language == csharp) {
- convertedDoc = doxygenToCsharpDoc(commentStr);
+ convertedDoc = doxygenToCsharpDoc(commentStr, true); //EXTERNAL_API only applies to class members, so treat this fragment as PUBLISHED_API
fprintf(docOutFile, "\n%%typemap(csclassmodifiers) %s %%{%s public%%}\n", className.c_str(), convertedDoc.c_str());
-void outputMethodDoc(const string& className, const string& methodDecl, const string& commentStr)
+void outputMethodDoc(const string& className, const string& methodDecl, const string& commentStr, bool isPublished)
//Nothing for PHP
if (language == php)
@@ -1113,15 +1173,15 @@
swigMethodDecl += methodName;
+ convertedDoc = doxygenToJavaDoc(commentStr, isPublished);
fprintf(docOutFile, "\n%%javamethodmodifiers %s %%{%s public%%}\n", swigMethodDecl.c_str(), convertedDoc.c_str());
+ convertedDoc = doxygenToCsharpDoc(commentStr, isPublished);
fprintf(docOutFile, "\n%%csmethodmodifiers %s %%{%s public%%}\n", swigMethodDecl.c_str(), convertedDoc.c_str());
-void processExternalApiSection(string& className, vector<string>& tokens, int begin, int end)
+void processExternalApiSection(string& className, vector<string>& tokens, int begin, int end, bool isPublished)
//until we find a problem with that, we output whatever we find in this section. In the
//process we perform type substitution if required
@@ -1204,10 +1264,10 @@
fprintf(outfile, "%s\n ", convertedDoc.c_str());
} else if (language == csharp) {
commentStr.clear();
@@ -1366,7 +1426,7 @@
if(token[0] == ';' || assignmentAdded)
if (!translateMode) {
- outputMethodDoc(className, methodDecl, commentStr);
+ outputMethodDoc(className, methodDecl, commentStr, isPublished);
commentStr.clear();
methodDecl.clear();
@@ -1485,10 +1545,10 @@
fprintf(outfile, "%s", convertedDoc.c_str());
@@ -1545,7 +1605,7 @@
string sectionName = tokens[sections[k] - 1];
if(sectionName == "EXTERNAL_API" || sectionName == "PUBLISHED_API")
- processExternalApiSection(className, tokens, sections[k] + 1, sections[k + 1] - (k < (int)sections.size() - 2? 2: 1));
+ processExternalApiSection(className, tokens, sections[k] + 1, sections[k + 1] - (k < (int)sections.size() - 2? 2: 1), (sectionName == "PUBLISHED_API"));
else if(sectionName == "CLASS_ID" && !translateMode)
processClassIdSection(tokens, sections[k] + 1, sections[k + 1] - (k < (int)sections.size() - 2? 2: 1));
Modified: branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.sln
--- branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.sln 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.sln 2014-05-27 04:27:00 UTC (rev 8167)
@@ -1,6 +1,6 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IMake", "IMake.vcproj", "{B601F04C-0D42-4AFC-A092-B31185E2EA8C}"
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio Express 2012 for Windows Desktop
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IMake", "IMake.vcxproj", "{B601F04C-0D42-4AFC-A092-B31185E2EA8C}"
EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Deleted: branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.vcproj
--- branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.vcproj 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.vcproj 2014-05-27 04:27:00 UTC (rev 8167)
@@ -1,211 +0,0 @@
-<?xml version="1.0" encoding="Windows-1252"?>
-<VisualStudioProject
- ProjectType="Visual C++"
- Version="9.00"
- Name="IMake"
- ProjectGUID="{B601F04C-0D42-4AFC-A092-B31185E2EA8C}"
- Keyword="Win32Proj"
- TargetFrameworkVersion="131072"
- <Platforms>
- <Platform
- Name="Win32"
- </Platforms>
- <ToolFiles>
- </ToolFiles>
- <Configurations>
- <Configuration
- Name="Debug|Win32"
- OutputDirectory="Win32"
- IntermediateDirectory="Debug"
- ConfigurationType="1"
- CharacterSet="2"
- <Tool
- Name="VCPreBuildEventTool"
- <Tool
- Name="VCCustomBuildTool"
- <Tool
- Name="VCXMLDataGeneratorTool"
- <Tool
- Name="VCWebServiceProxyGeneratorTool"
- <Tool
- Name="VCMIDLTool"
- <Tool
- Name="VCCLCompilerTool"
- Optimization="0"
- PreprocessorDefinitions="WIN32;_DEBUG;_CONSOLE"
- MinimalRebuild="true"
- BasicRuntimeChecks="3"
- RuntimeLibrary="1"
- UsePrecompiledHeader="2"
- WarningLevel="3"
- Detect64BitPortabilityProblems="false"
- DebugInformationFormat="3"
- <Tool
- Name="VCManagedResourceCompilerTool"
- <Tool
- Name="VCResourceCompilerTool"
- <Tool
- Name="VCPreLinkEventTool"
- <Tool
- Name="VCLinkerTool"
- OutputFile="$(OutDir)\IMake.exe"
- LinkIncremental="2"
- GenerateDebugInformation="true"
- ProgramDatabaseFile="$(OutDir)\IMake.pdb"
- SubSystem="1"
- RandomizedBaseAddress="1"
- DataExecutionPrevention="0"
- TargetMachine="1"
- <Tool
- Name="VCALinkTool"
- <Tool
- Name="VCManifestTool"
- <Tool
- Name="VCXDCMakeTool"
- <Tool
- Name="VCBscMakeTool"
- <Tool
- Name="VCFxCopTool"
- <Tool
- Name="VCAppVerifierTool"
- <Tool
- Name="VCPostBuildEventTool"
- </Configuration>
- <Configuration
- Name="Release|Win32"
- IntermediateDirectory="Release"
- CharacterSet="2"
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- Name="VCMIDLTool"
- <Tool
- PreprocessorDefinitions="WIN32;NDEBUG;_CONSOLE"
- RuntimeLibrary="0"
- WarningLevel="3"
- <Tool
- <Tool
- <Tool
- <Tool
- LinkIncremental="1"
- SubSystem="1"
- OptimizeReferences="2"
- EnableCOMDATFolding="2"
- TargetMachine="1"
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- </Configuration>
- </Configurations>
- <References>
- </References>
- <Files>
- <File
- RelativePath=".\IMake.cpp"
- </File>
- <File
- RelativePath=".\SimpleXmlParser.cpp"
- </File>
- <File
- RelativePath=".\SimpleXmlParser.h"
- </File>
- <File
- RelativePath=".\stdafx.cpp"
- <FileConfiguration
- <Tool
- UsePrecompiledHeader="1"
- </FileConfiguration>
- <Tool
- </File>
- <File
- RelativePath=".\stdafx.h"
- </File>
- </Files>
- <Globals>
- </Globals>
-</VisualStudioProject>
Copied: branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.vcxproj (from rev 8164, trunk/MgDev/BuildTools/WebTools/IMake/IMake.vcxproj)
--- branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.vcxproj (rev 0)
+++ branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.vcxproj 2014-05-27 04:27:00 UTC (rev 8167)
@@ -0,0 +1,106 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project DefaultTargets="Build" ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup Label="ProjectConfigurations">
+ <ProjectConfiguration Include="Debug|Win32">
+ <Configuration>Debug</Configuration>
+ <Platform>Win32</Platform>
+ </ProjectConfiguration>
+ <ProjectConfiguration Include="Release|Win32">
+ <Configuration>Release</Configuration>
+ </ItemGroup>
+ <PropertyGroup Label="Globals">
+ <ProjectGuid>{B601F04C-0D42-4AFC-A092-B31185E2EA8C}</ProjectGuid>
+ <Keyword>Win32Proj</Keyword>
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
+ <ConfigurationType>Application</ConfigurationType>
+ <PlatformToolset>v110</PlatformToolset>
+ <CharacterSet>MultiByte</CharacterSet>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
+ <ImportGroup Label="ExtensionSettings">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
+ <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
+ </ImportGroup>
+ <PropertyGroup Label="UserMacros" />
+ <PropertyGroup>
+ <_ProjectFileVersion>11.0.61030.0</_ProjectFileVersion>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <OutDir>Win32\</OutDir>
+ <IntDir>Debug\</IntDir>
+ <LinkIncremental>true</LinkIncremental>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <IntDir>Release\</IntDir>
+ <LinkIncremental>false</LinkIncremental>
+ </PropertyGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <ClCompile>
+ <Optimization>Disabled</Optimization>
+ <PreprocessorDefinitions>WIN32;_DEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <MinimalRebuild>true</MinimalRebuild>
+ <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
+ <RuntimeLibrary>MultiThreadedDebug</RuntimeLibrary>
+ <PrecompiledHeader>Use</PrecompiledHeader>
+ <WarningLevel>Level3</WarningLevel>
+ <DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
+ </ClCompile>
+ <Link>
+ <OutputFile>$(OutDir)IMake.exe</OutputFile>
+ <GenerateDebugInformation>true</GenerateDebugInformation>
+ <ProgramDatabaseFile>$(OutDir)IMake.pdb</ProgramDatabaseFile>
+ <SubSystem>Console</SubSystem>
+ <RandomizedBaseAddress>false</RandomizedBaseAddress>
+ <DataExecutionPrevention />
+ <TargetMachine>MachineX86</TargetMachine>
+ </Link>
+ </ItemDefinitionGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <ClCompile>
+ <PreprocessorDefinitions>WIN32;NDEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <RuntimeLibrary>MultiThreaded</RuntimeLibrary>
+ </ClCompile>
+ <Link>
+ <OptimizeReferences>true</OptimizeReferences>
+ <EnableCOMDATFolding>true</EnableCOMDATFolding>
+ </Link>
+ <ItemGroup>
+ <ClCompile Include="IMake.cpp" />
+ <ClCompile Include="SimpleXmlParser.cpp" />
+ <ClCompile Include="stdafx.cpp">
+ <PrecompiledHeader Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Create</PrecompiledHeader>
+ <PrecompiledHeader Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Create</PrecompiledHeader>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="SimpleXmlParser.h" />
+ <ClInclude Include="stdafx.h" />
+ </ItemGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
+ <ImportGroup Label="ExtensionTargets">
+ </ImportGroup>
+</Project>
\ No newline at end of file
Modified: branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.xsd
--- branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.xsd 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.xsd 2014-05-27 04:27:00 UTC (rev 8167)
@@ -21,6 +21,11 @@
<xs:attribute name="path" type="xs:string" use="required" />
</xs:complexType>
</xs:element>
+ <xs:element name="DocTarget">
+ <xs:complexType>
+ <xs:attribute name="path" type="xs:string" use="required" />
+ </xs:complexType>
+ </xs:element>
<xs:element name="CppInline" minOccurs="0" />
<xs:element name="TypeReplacements" minOccurs="0">
<xs:complexType>
Modified: branches/2.6/MgDev/BuildTools/WebTools/IMake/Win32/IMake.exe
(Binary files differ)
Modified: branches/2.6/MgDev/Common/Foundation/Data/FeaturePropertyType.h
--- branches/2.6/MgDev/Common/Foundation/Data/FeaturePropertyType.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/Foundation/Data/FeaturePropertyType.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -59,6 +59,7 @@
static const int AssociationProperty = 103;
+ /// \brief
/// Type name for a raster property definition. See
/// MgRasterPropertyDefinition.
static const int RasterProperty = 104;
Modified: branches/2.6/MgDev/Common/Foundation/Data/MimeType.h
--- branches/2.6/MgDev/Common/Foundation/Data/MimeType.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/Foundation/Data/MimeType.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -32,42 +32,55 @@
/// The "value(xxx)" comments are used by SWIG to build constants.php. Do not alter them.
/// \endif
+ /// \brief
/// application/agf
static const STRING Agf; ///\if INTERNAL value("application/agf") \endif
+ /// \brief
/// application/octet-stream
static const STRING Binary; ///\if INTERNAL value("application/octet-stream") \endif
+ /// \brief
/// model/vnd.dwf
static const STRING Dwf; ///\if INTERNAL value("model/vnd.dwf") \endif
+ /// \brief
/// image/gif
static const STRING Gif; ///\if INTERNAL value("image/gif") \endif
+ /// \brief
/// image/jpeg
static const STRING Jpeg; ///\if INTERNAL value("image/jpeg") \endif
+ /// \brief
/// image/png
static const STRING Png; ///\if INTERNAL value("image/png") \endif
+ /// \brief
/// text/plain
static const STRING Text; ///\if INTERNAL value("text/plain") \endif
+ /// \brief
/// image/tiff
static const STRING Tiff; ///\if INTERNAL value("image/tiff") \endif
+ /// \brief
/// text/xml
static const STRING Xml; ///\if INTERNAL value("text/xml") \endif
+ /// \brief
/// application/json
static const STRING Json; ///\if INTERNAL value("application/json") \endif
+ /// \brief
/// text/html
static const STRING Html; ///\if INTERNAL value("text/html") \endif
+ /// \brief
/// application/vnd.google-earth.kml+xml
static const STRING Kml; ///\if INTERNAL value("application/vnd.google-earth.kml+xml") \endif
+ /// \brief
/// application/vnd.google-earth.kmz
static const STRING Kmz; ///\if INTERNAL value("application/vnd.google-earth.kmz") \endif
Modified: branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h
--- branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -317,32 +317,32 @@
/// \brief
+ /// The operation succeeded
static const INT32 Ok = 1000;
/// \brief
+ /// The operation ran out of memory
static const INT32 OutOfMemory = 1001;
/// \brief
+ /// An initialization operation failed
static const INT32 InitializationFailed = 1002;
/// \brief
+ /// A conversion operation failed
static const INT32 ConversionFailed = 1003;
/// \brief
+ /// An argument supplied to an operation was null
static const INT32 NullArgument = 1004;
/// \brief
+ /// An argument supplied to an operation was invalid
static const INT32 InvalidArgument = 1005;
Modified: branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h
--- branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -24,6 +24,7 @@
/// \brief
+/// Defines the type of a geodetic transformation method
class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformationMethod
Modified: branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h
--- branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -23,7 +23,7 @@
-/// <summary>
+/// \brief
/// An enumeration of the supported values for the <c>m_Orientation</c> member
/// of several objects related to grids and graticules. <p>
/// This value is used to qualify objects which are of the "iso" type. I.e. a
@@ -34,25 +34,24 @@
/// points which share a common <b>easting</b> value, and the "m_Value" element
/// of that object will be an <b>easting</b> value. Note that in this example,
/// the line is typically a vertical line.
-/// </summary>
class MG_GEOMETRY_API MgCoordinateSystemGridOrientation
PUBLISHED_API:
- /// \brief Not specified yet, initialize to this value.
+ /// \brief
+ /// Not specified yet, initialize to this value.
static const INT8 None = 0;
- /// \brief The object represents a constant easting value.
+ /// \brief
+ /// The object represents a constant easting value.
static const INT8 EastWest = 1; // generally indicates a vertical grid line
- /// \brief The object represents a constant northing value.
+ /// \brief
+ /// The object represents a constant northing value.
static const INT8 NorthSouth = 2; // generally indicates a horizontal grid line
- /// \brief Indicates the failure of an algorithm or other problem.
+ /// \brief
+ /// Indicates the failure of an algorithm or other problem.
static const INT8 Unknown = 3; // indicates a failure of an algorithm
Modified: branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h
--- branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -23,7 +23,7 @@
-/// <summary>
+/// \brief
/// An enumeration of the various types of specialized grids/graticules
/// currently supported. A specialized grid is one for which specific
/// standards exist to which the results of this feature are compliant with.
@@ -33,7 +33,6 @@
/// with similar features and is currently entirely arbitrary. Using a
/// numeric literal instead of thes names of the defined constants is a sure
/// way to write code that will get broken in the future.
-/// </summary>
class MG_GEOMETRY_API MgCoordinateSystemGridSpecializationType
PUBLISHED_API:
Modified: branches/2.6/MgDev/Common/MapGuideCommon/Services/ImageFormats.h
--- branches/2.6/MgDev/Common/MapGuideCommon/Services/ImageFormats.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/MapGuideCommon/Services/ImageFormats.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -30,21 +30,27 @@
/// \internal
+ /// \brief
/// Gif format
static const STRING Gif; /// \if INTERNAL value("GIF") \endif
+ /// \brief
/// Jpeg format
static const STRING Jpeg; /// \if INTERNAL value("JPG") \endif
+ /// \brief
/// Png format
static const STRING Png; /// \if INTERNAL value("PNG") \endif
+ /// \brief
/// Png format
static const STRING Png8; /// \if INTERNAL value("PNG8") \endif
+ /// \brief
/// Tiff format
static const STRING Tiff; /// \if INTERNAL value("TIF") \endif
+ /// \brief
/// Raw format
static const STRING Raw; /// \if INTERNAL value("RAW") \endif
Modified: branches/2.6/MgDev/Common/MapGuideCommon/Services/MappingDefs.h
--- branches/2.6/MgDev/Common/MapGuideCommon/Services/MappingDefs.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/MapGuideCommon/Services/MappingDefs.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -37,9 +37,11 @@
/// \endif
+ /// \brief
/// Page units are in inches.
static const STRING Inches; ///\if INTERNAL value("in") \endif
+ /// \brief
/// Page units are in millimeters.
static const STRING Millimeters; ///\if INTERNAL value("mm") \endif
Modified: branches/2.6/MgDev/Common/MapGuideCommon/Services/UnitType.h
--- branches/2.6/MgDev/Common/MapGuideCommon/Services/UnitType.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/MapGuideCommon/Services/UnitType.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -29,9 +29,11 @@
/// \endif
+ /// \brief
/// US English.
static const STRING USEnglish; ///\if INTERNAL value("US-English") \endif
+ /// \brief
/// Metric.
static const STRING Metric; ///\if INTERNAL value("Metric") \endif
Modified: branches/2.6/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h
--- branches/2.6/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -29,39 +29,47 @@
PUBLISHED_API:
+ /// \brief
/// Resource Service
static const INT16 ResourceService = 0;
+ /// \brief
/// DWF Drawing Service
static const INT16 DrawingService = 1;
+ /// \brief
/// FDO Feature Service
static const INT16 FeatureService = 2;
+ /// \brief
/// Mapping Service
static const INT16 MappingService = 3;
+ /// \brief
/// Rendering Service
static const INT16 RenderingService = 4;
+ /// \brief
/// Tile Service
static const INT16 TileService = 5;
+ /// \brief
/// Kml Service
static const INT16 KmlService = 6;
+ /// \brief
/// Profiling Service
static const INT16 ProfilingService = 10;
Modified: branches/2.6/MgDev/Common/PlatformBase/Services/FeatureCommandType.h
--- branches/2.6/MgDev/Common/PlatformBase/Services/FeatureCommandType.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/PlatformBase/Services/FeatureCommandType.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -31,18 +31,23 @@
PUBLISHED_API:
+ /// \brief
/// Specifies the type of an MgInsertFeatures object.
static const int InsertFeatures = 0;
+ /// \brief
/// Specifies the type of an MgUpdateFeatures object.
static const int UpdateFeatures = 1;
+ /// \brief
/// Specifies the type of an MgDeleteFeatures object.
static const int DeleteFeatures = 2;
+ /// \brief
/// Specifies the type of an MgLockFeatures object.
static const int LockFeatures = 3;
+ /// \brief
/// Specifies the type of an MgUnlockFeatures object.
static const int UnlockFeatures = 4;
INTERNAL_API:
Modified: branches/2.6/MgDev/Common/PlatformBase/Services/FeatureGeometricType.h
--- branches/2.6/MgDev/Common/PlatformBase/Services/FeatureGeometricType.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/PlatformBase/Services/FeatureGeometricType.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -35,21 +35,25 @@
PUBLISHED_API:
+ /// \brief
/// Represents zero-dimensional geometric primitives, such as
/// MgPoint.
static const int Point = 1;
+ /// \brief
/// Represents one-dimensional geometric primitives, such as
/// MgLineString and MgCurveString.
static const int Curve = 2;
+ /// \brief
/// Represents two-dimensional geometric primitives, such as
/// MgPolygon and MgCurvePolygon.
static const int Surface = 4;
+ /// \brief
/// Represents three-dimensional geometric primitives, such as
/// Cubes.
static const int Solid = 8;
Modified: branches/2.6/MgDev/Common/PlatformBase/Services/FeatureService.h
--- branches/2.6/MgDev/Common/PlatformBase/Services/FeatureService.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/PlatformBase/Services/FeatureService.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -1891,6 +1891,7 @@
static const INT32 m_cls_id = PlatformBase_FeatureService_FeatureService;
+///\cond INTERNAL
#define MG_CHECK_FEATURE_SET_COUNT(pointer, methodname) \
if (0 == pointer->GetCount()) \
@@ -1904,6 +1905,7 @@
throw new MgInvalidPropertyTypeException(methodname, \
__LINE__, __WFILE__, NULL, L"", NULL); \
+///\endcond
Modified: branches/2.6/MgDev/Common/PlatformBase/Services/ObjectPropertyType.h
--- branches/2.6/MgDev/Common/PlatformBase/Services/ObjectPropertyType.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/PlatformBase/Services/ObjectPropertyType.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -24,8 +24,8 @@
/// \brief
-/// Defines the type of an MgObjectPropertionDefinition object
-/// property, that is, whether the property ccontains a single
+/// Defines the type of an \link MgObjectPropertionDefinition \endlink object
+/// property, that is, whether the property contains a single
/// feature class object, or an unordered or ordered collection
/// of them.
@@ -33,21 +33,23 @@
PUBLISHED_API:
+ /// \brief
/// Signifies that the object property contains a single feature
/// class object.
static const int Value = 0;
+ /// \brief
/// Signifies that the object property contains more than one
/// feature class object. The collection of objects is in no
/// particular order relative to the identity property defined
- /// for the collection. See
- /// MgObjectPropertyDefinition::GetIdentityProperty.
+ /// for the collection. See \link MgObjectPropertyDefinition::GetIdentityProperty \endlink
static const int Collection = 1;
+ /// \brief
/// feature class object in ascending or descending order
/// relative to the identity property defined for the collection.
- /// See MgObjectPropertyDefinition::GetIdentityProperty.
+ /// See \link MgObjectPropertyDefinition::GetIdentityProperty \endlink
static const int OrderedCollection = 2;
INTERNAL_API:
Modified: branches/2.6/MgDev/Common/PlatformBase/Services/RasterTypes.h
--- branches/2.6/MgDev/Common/PlatformBase/Services/RasterTypes.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/PlatformBase/Services/RasterTypes.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -32,27 +32,34 @@
// These correspond to FDO RasterDataModelType definitions
+ /// \brief
/// Data is organized in an unknown or provider specific manner.
static const INT32 Unknown; /// value(0)
+ /// \brief
/// Data is rectangular grid, floating point data model.
static const INT32 Data; /// value(1)
+ /// \brief
/// Data is one bit (black/white - bitonal) pixels.
static const INT32 Bitonal; /// value(2)
+ /// \brief
/// Data is monochrome (black->gray->white) pixels.
/// It is necessary to know the BitsPerPixel value to interpret the data.
static const INT32 Gray; /// value(3)
+ /// \brief
/// Data is red/green/blue (in that order) pixels.
static const INT32 RGB; /// value(4)
+ /// \brief
/// Data is red/green/blue/alpha (in that order) pixels; RGB with transparency.
static const INT32 RGBA; /// value(5)
+ /// \brief
/// Data is monochrome but backed by a pallette (value->pallette->colour) pixels.
static const INT32 Palette; /// value(6)
Modified: branches/2.6/MgDev/Common/PlatformBase/Services/ReaderType.h
--- branches/2.6/MgDev/Common/PlatformBase/Services/ReaderType.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/PlatformBase/Services/ReaderType.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -36,12 +36,15 @@
PUBLISHED_API:
+ /// \brief
/// Signifies that the object is of type MgFeatureReader.
static const int FeatureReader = 0;
+ /// \brief
/// Signifies that the object is of type MgDataReader.
static const int DataReader = 1;
+ /// \brief
/// Signifies that the object is of type MgSqlDataReader.
static const int SqlDataReader = 2;
INTERNAL_API:
Modified: branches/2.6/MgDev/Common/PlatformBase/Services/ResourceDefs.h
--- branches/2.6/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -52,10 +52,12 @@
/// \endif
+ /// \brief
/// The repository is the \link library library \endlink.
static const STRING Library; ///\if INTERNAL value("Library") \endif
+ /// \brief
/// The repository is a \link session_repository session repository \endlink,
/// used to store temporary data.
/// \note1
@@ -492,12 +494,15 @@
/// \endif
+ /// \brief
/// No Access permission.
static const STRING NoAccess; ///\if INTERNAL value("n") \endif
+ /// \brief
/// Read-Only permission.
static const STRING ReadOnly; ///\if INTERNAL value("r") \endif
+ /// \brief
/// Read/Write permission.
static const STRING ReadWrite; ///\if INTERNAL value("r,w") \endif
@@ -549,12 +554,15 @@
/// \endif
+ /// \brief
/// Return folders only
static const STRING Folders; ///\if INTERNAL value("Folders") \endif
+ /// \brief
/// Return files only
static const STRING Files; ///\if INTERNAL value("Files") \endif
+ /// \brief
/// Return both files and folders
static const STRING Both; ///\if INTERNAL value("Both") \endif
Modified: branches/2.6/MgDev/Common/PlatformBase/Services/SpatialContextExtentType.h
--- branches/2.6/MgDev/Common/PlatformBase/Services/SpatialContextExtentType.h 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/Common/PlatformBase/Services/SpatialContextExtentType.h 2014-05-27 04:27:00 UTC (rev 8167)
@@ -29,9 +29,11 @@
class MgSpatialContextExtentType
PUBLISHED_API:
+ /// \brief
/// The spatial extent of the context is static and must be specified
/// when the context is created.
static const int scStatic = 0;
+ /// \brief
/// The spatial extent of the context is dynamic and changes as data is
/// added and removed from the context.
static const int scDynamic = 1;
Modified: branches/2.6/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/MgTestRunner.csproj
--- branches/2.6/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/MgTestRunner.csproj 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/MgTestRunner.csproj 2014-05-27 04:27:00 UTC (rev 8167)
@@ -99,7 +99,7 @@
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<PropertyGroup>
<PostBuildEvent>copy /Y "$(SolutionDir)Libs\*.*" "$(TargetDir)"
-xcopy /S /Y /I $(SolutionDir)..\..\..\Web\src\mapagent\Resources "$(TargetDir)\Resources"</PostBuildEvent>
+xcopy /S /Y /I "$(SolutionDir)..\..\..\Common\MapGuideCommon\Resources" "$(TargetDir)\Resources"</PostBuildEvent>
</PropertyGroup>
<PropertyGroup>
<PreBuildEvent>call "$(SolutionDir)prebuild.bat" "$(ConfigurationName)" "$(PlatformName)"</PreBuildEvent>
Modified: branches/2.6/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs
--- branches/2.6/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2014-05-27 04:27:00 UTC (rev 8167)
@@ -412,7 +412,11 @@
if (strExpectedResult != null && strResultData != null)
- bEqual = strResultData.Equals(strExpectedResult, StringComparison.InvariantCultureIgnoreCase);
+ //Normalize line endings on LF before comparsion (in case the SQLite GUI recorded CRLFs)
+ string normStrResultData = strResultData.Replace("\r\n", "\n");
+ string normStrExpectedResult = strExpectedResult.Replace("\r\n", "\n");
+ bEqual = normStrResultData.Equals(normStrExpectedResult, StringComparison.InvariantCultureIgnoreCase);
else if (bExpected != null && bActual != null)
Modified: branches/2.6/MgDev/UnitTest/WebTier/DotNet/prebuild.bat
--- branches/2.6/MgDev/UnitTest/WebTier/DotNet/prebuild.bat 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/UnitTest/WebTier/DotNet/prebuild.bat 2014-05-27 04:27:00 UTC (rev 8167)
@@ -22,7 +22,7 @@
goto done
:copy
-if "%PLAT%"=="x64" (
+if %PLAT%=="x64" (
echo Copying x64 binaries from %SLN_DIR%..\..\..\Web\bin\%CFG%64
copy /Y %SLN_DIR%..\..\..\Web\bin\%CFG%64\*.* "%SLN_DIR%Libs\"
echo Copying x64 SqliteDotNet.dll
Modified: branches/2.6/MgDev/UnitTest/WebTier/Php/Validate.php
--- branches/2.6/MgDev/UnitTest/WebTier/Php/Validate.php 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/UnitTest/WebTier/Php/Validate.php 2014-05-27 04:27:00 UTC (rev 8167)
@@ -138,8 +138,12 @@
if ($_POST['testExecutionMode'] == "validate")
+ //Normalize line endings so comparisons don't fall over due to incorrect line endings when expected results were entered in SQLite GUI
+ $normResultData = str_replace("\r\n", "\n", $resultData);
+ $normExpectedResult = str_replace("\r\n", "\n", $expectedResult);
//If the results are different and special validation fails then the operation failed ->mark it red
- if (strncasecmp($resultData, $expectedResult, strlen($resultData . $expectedResult)) && !(ValidateUtils::SpecialValidation($operation, $resultData, $expectedResult)))
+ if (strncasecmp($normResultData, $normExpectedResult, strlen($normResultData . $normExpectedResult)) && !(ValidateUtils::SpecialValidation($operation, $resultData, $expectedResult)))
$outcome="fail";
$exitStatus=1;
Modified: branches/2.6/MgDev/run_tests.bat
--- branches/2.6/MgDev/run_tests.bat 2014-05-27 04:17:07 UTC (rev 8166)
+++ branches/2.6/MgDev/run_tests.bat 2014-05-27 04:27:00 UTC (rev 8167)
@@ -18,10 +18,12 @@
SET START_MGSERVER=1
SET START_WEBSERVER=1
-SET RUN_SERVER_TESTS=1
+SET RUN_SERVER_TESTS=0
SET RUN_PHP_TESTS=1
SET RUN_DOTNET_TESTS=1
+SET RETURN_CODE=0
echo *************** TEST SUMMARY ******************
echo Platform: %PLAT%
echo Configuration: %CONF%
@@ -44,8 +46,11 @@
echo [build]: DotNet test runner
SET TEST_COMPONENT=Build DotNet test runner
pushd UnitTest\WebTier\DotNet
- msbuild /p:Configuration=%CONFIG%;Platform=%PLAT% DotNet.sln
- if %ERRORLEVEL% neq 0 goto error
+ msbuild /p:Configuration=%CONFIG%;Platform=%PLAT% /fl /flp:logfile=build.log DotNet.sln
+ if "%ERRORLEVEL%" == "1" (
+ set RETURN_CODE=%ERRORLEVEL%
+ goto error
popd
:start_mgserver
@@ -64,7 +69,10 @@
pushd UnitTest
SET TEST_COMPONENT=Prepare webtier test suites
php -n -d display_errors=Off -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -d extension=php_SQLitePhpApi.dll prepare.php
-if %ERRORLEVEL% neq 0 goto error
+if %ERRORLEVEL% neq 0 (
+ goto error
popd
:start_php_webserver
if "%START_WEBSERVER%" == "1" (
@@ -75,6 +83,20 @@
:test_php
if "%RUN_PHP_TESTS%" == "1" (
echo [test]: PHP tests
+ REM Clear out old dbs before running
+ pushd UnitTest\TestData
+ if exist Unicode\UnicodeTest.db del /F Unicode\UnicodeTest.db
+ if exist WmsTest\WmsTest.db del /F WmsTest\WmsTest.db
+ if exist WebLayout\WebLayoutTest.db del /F WebLayout\WebLayoutTest.db
+ if exist WfsTest\WfsTest.db del /F WfsTest\WfsTest.db
+ if exist MapLayer\MapLayerTest.db del /F MapLayer\MapLayerTest.db
+ if exist ServerAdmin\ServerAdminTest.db del /F ServerAdmin\ServerAdminTest.db
+ if exist MappingService\MappingServiceTest.db del /F MappingService\MappingServiceTest.db
+ if exist SiteService\SiteServiceTest.db del /F SiteService\SiteServiceTest.db
+ if exist FeatureService\FeatureServiceTest.db del /F FeatureService\FeatureServiceTest.db
+ if exist DrawingService\DrawingServiceTest.db del /F DrawingService\DrawingServiceTest.db
+ if exist ResourceService\ResourceServiceTest.db del /F ResourceService\ResourceServiceTest.db
+ popd
pushd UnitTest\WebTier\Php
php.exe -n -d display_errors=Off -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -d extension=php_SQLitePhpApi.dll RunTests.php
popd
@@ -82,6 +104,20 @@
:test_dotnet
if "%RUN_DOTNET_TESTS%" == "1" (
echo [test]: .net tests
+ popd
pushd UnitTest\WebTier\DotNet_%PLAT%
MgTestRunner.exe "%WEBCONFIGINI%" "../../../Oem/CsMap/Dictionaries"
if %ERRORLEVEL% neq 0 echo [test]: .net test runner had one or more test failures. Check log files for more information
@@ -101,7 +137,7 @@
goto done
:error
-echo [error]: An error occured with %TEST_COMPONENT%
+echo [error]: An error occured with %TEST_COMPONENT% (exit code: %RETURN_CODE%)
goto quit
:done
More information about the mapguide-commits
