[mapguide-commits] r8169 - in trunk/MgDev: . UnitTest/WebTier/DotNet/MgTestRunner
svn_mapguide at osgeo.org
Mon May 26 21:50:06 PDT 2014
Author: jng
Date: 2014-05-26 21:50:06 -0700 (Mon, 26 May 2014)
New Revision: 8169
trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/MgTestRunner.csproj
trunk/MgDev/run_tests.bat
Merge in changes from 2.6:
- run_tests.bat: Display return codes on failures and turn back on server test
- Properly quote a path in MgTestRunner post-build
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/MgTestRunner.csproj
--- trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/MgTestRunner.csproj 2014-05-27 04:48:00 UTC (rev 8168)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/MgTestRunner.csproj 2014-05-27 04:50:06 UTC (rev 8169)
@@ -99,7 +99,7 @@
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<PropertyGroup>
<PostBuildEvent>copy /Y "$(SolutionDir)Libs\*.*" "$(TargetDir)"
-xcopy /S /Y /I $(SolutionDir)..\..\..\Common\MapGuideCommon\Resources "$(TargetDir)\Resources"</PostBuildEvent>
+xcopy /S /Y /I "$(SolutionDir)..\..\..\Common\MapGuideCommon\Resources" "$(TargetDir)\Resources"</PostBuildEvent>
</PropertyGroup>
<PropertyGroup>
<PreBuildEvent>call "$(SolutionDir)prebuild.bat" "$(ConfigurationName)" "$(PlatformName)"</PreBuildEvent>
Modified: trunk/MgDev/run_tests.bat
--- trunk/MgDev/run_tests.bat 2014-05-27 04:48:00 UTC (rev 8168)
+++ trunk/MgDev/run_tests.bat 2014-05-27 04:50:06 UTC (rev 8169)
@@ -22,6 +22,8 @@
SET RUN_PHP_TESTS=1
SET RUN_DOTNET_TESTS=1
+SET RETURN_CODE=0
echo *************** TEST SUMMARY ******************
echo Platform: %PLAT%
echo Configuration: %CONF%
@@ -45,7 +47,10 @@
SET TEST_COMPONENT=Build DotNet test runner
pushd UnitTest\WebTier\DotNet
msbuild /p:Configuration=%CONFIG%;Platform=%PLAT% /fl /flp:logfile=build.log DotNet.sln
- if %ERRORLEVEL% neq 0 goto error
+ if "%ERRORLEVEL%" == "1" (
+ set RETURN_CODE=%ERRORLEVEL%
+ goto error
popd
:start_mgserver
@@ -64,7 +69,10 @@
pushd UnitTest
SET TEST_COMPONENT=Prepare webtier test suites
php -n -d display_errors=Off -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -d extension=php_SQLitePhpApi.dll prepare.php
-if %ERRORLEVEL% neq 0 goto error
+if %ERRORLEVEL% neq 0 (
+ goto error
popd
:start_php_webserver
if "%START_WEBSERVER%" == "1" (
@@ -129,7 +137,7 @@
goto done
:error
-echo [error]: An error occured with %TEST_COMPONENT%
+echo [error]: An error occured with %TEST_COMPONENT% (exit code: %RETURN_CODE%)
goto quit
:done
More information about the mapguide-commits
